请教3288调试gt911驱动正常后,无法进入android
大家好!
自己做的3288的板子,用firefly的android5.1固件,用rk3288-tb_8846.dts,开始编译调试正常,调试屏系统正常,调试gt911驱动,驱动没有成功时系统正常,驱动加载成功了,就进不去android了 。内核一直重启。。找不到原因啊。。
下面是启动log
可以看到 goodix加载input0正常 后来就重启了
DDR Version 1.06 20171020
Channel a: DDR3 400MHz
Channel b: DDR3 400MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-10-g6ebd1b8 (Dec 05 2018 - 18:38:07)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 396000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 400
SdmmcInit = 2 0
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
Memory OK
Memory OK
CPU: rk3288
cpu version = 0
128 MiB
SdmmcInit = 0 400
SdmmcInit = 2 0
storage init OK!
GetParam
pmic:act8846
can’t find dts node for pwm1
#Boot ver: 2018-12-05#2.30
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
pll_src = 0, dclk_hz = 54000000, dclk_div = 7
no fuel gauge found
got recovery cmd from misc.
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x02000000 (0x0069a638)
ramdisk @ 0x05bf0000 (0x002ad1c0)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0563c838 … OK
[ 0.000000] Booting Linux on physical CPU 0x500 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.0 (tang@tang-ThinkPad-T480) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #7 SMP PREEMPT Thu Jun 13 12:19:36 CST 2019 [ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288 [ 0.000000] rockchip_uboot_logo_setup: mem: 0x02000000@0x7dc00000, offset:0x00000000 [ 0.000000] rockchip_uboot_mem_reserve: reserve 0x02000000@0x7dc00000 for uboot logo [ 0.000000] rockchip_ion_reserve [ 0.000000] ion heap(drm): base(0) size(0) align(0) [ 0.000000] ion heap(cma): base(0) size(28000000) align(0) [ 0.000000] ion heap(vmalloc): base(0) size(0) align(0) [ 0.000000] cma: CMA: reserved 640 MiB at 55c00000 [ 0.000000] ion_reserve: cma reserved base 55c00000 size 671088640 [ 0.000000] cma: CMA: reserved 16 MiB at 1e000000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] Boot mode: RECOVERY (2) flag: RECOVER (0xc3524203) [ 0.000000] PERCPU: Embedded 9 pages/cpu @c1f04000 s13376 r8192 d15296 u36864 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523296 [ 0.000000] Kernel command line: vmalloc=512M console=ttyFIQ0 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00200000@0x0039A000(userdata),0x00020000@0x0059A000(radical_update),-@0x005BA000(user) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2018-12-05_18:38:07 [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] allocated 4194304 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Memory: 2048MB = 2048MB total [ 0.000000] Memory: 1353220k/1353220k available, 743932k reserved, 901120K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xdf800000 - 0xff000000 ( 504 MB) [ 0.000000] lowmem : 0xc0000000 - 0xdf000000 ( 496 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0b9a95c (11851 kB) [ 0.000000] .init : 0xc0b9b000 - 0xc0bf4440 ( 358 kB) [ 0.000000] .data : 0xc0bf6000 - 0xc0d87d80 (1608 kB) [ 0.000000] .bss : 0xc0d87d80 - 0xc0ea88bc (1155 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] rk_clk_tree_init start! [ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div [ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error [ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1 [ 0.000000] rkclk_init_clks: cnt_parent = 7 [ 0.000000] rkclk_init_clks: cnt_rate = 29 [ 0.000000] rk3288 set GPLL BW 20 for HDMI! [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] Switching to timer-based delay loop [ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns [ 0.000000] process version: 3 [ 0.000000] channel:0, lkg:12 [ 0.000000] target-temp:80 [ 0.000000] channel:2, lkg:0 [ 0.000000] channel:0, lkg:12 [ 0.000000] channel:1, lkg:10 [ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms [ 0.340565] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.340580] pid_max: default: 32768 minimum: 301 [ 0.340689] Security Framework initialized [ 0.340702] SELinux: Initializing. [ 0.340771] Mount-cache hash table entries: 512 [ 0.341360] Initializing cgroup subsys debug [ 0.341373] Initializing cgroup subsys memory [ 0.341398] Initializing cgroup subsys freezer [ 0.341424] CPU: Testing write buffer coherency: ok [ 0.341672] /cpus/cpu@0 missing clock-frequency property [ 0.341684] /cpus/cpu@1 missing clock-frequency property [ 0.341694] /cpus/cpu@2 missing clock-frequency property [ 0.341702] /cpus/cpu@3 missing clock-frequency property [ 0.341745] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500 [ 0.341789] Setting up static identity map for 0xc0858378 - 0xc08583d0 [ 0.343652] last_log: 0x1d900000 map to 0xdf804000 and copy to 0xdf886000, size 0x80000 early 0x1831 (version 3.1) [ 0.418632] CPU1: Booted secondary processor [ 0.418660] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501 [ 0.438312] CPU2: Booted secondary processor [ 0.438334] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502 [ 0.458022] CPU3: Booted secondary processor [ 0.458044] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503 [ 0.458143] Brought up 4 CPUs [ 0.458170] SMP: Total of 4 processors activated (192.00 BogoMIPS). [ 0.458178] CPU: All CPU(s) started in SVC mode. [ 0.458836] devtmpfs: initialized [ 0.462924] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0 [ 0.463869] pinctrl core: initialized pinctrl subsystem [ 0.464085] regulator-dummy: no parameters [ 0.487065] NET: Registered protocol family 16 [ 0.488692] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.488985] ion_snapshot: 0x1da98000 map to 0xdf907000 and copy to 0xc0e83b4c (version 0.1) [ 0.489145] Registered FIQ tty driver [ 0.490277] console [ttyFIQ0] enabled [ 0.490474] Registered fiq debugger ttyFIQ0 [ 0.491063] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff [ 0.491087] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f [ 0.491112] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f [ 0.491131] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b [ 0.491214] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff [ 0.491281] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff [ 0.491345] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff [ 0.491411] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff [ 0.491476] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff [ 0.491541] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff [ 0.491606] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff [ 0.491671] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff [ 0.491741] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff [ 0.491808] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3 [ 0.491824] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f [ 0.491838] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf [ 0.491852] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f [ 0.492449] rockchip_interrupts_register:bank_num=7 [ 0.494315] of_get_gpio_init_config:gpio[0] = 6, value = 0 [ 0.494367] rockchip_pinctrl_probe:init ok [ 0.500648] rk_iommu ff900800.iep_mmu: (iep) Enter [ 0.500716] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.500732] rk_iommu ff900800.iep_mmu: (iep) Initialized [ 0.500894] rk_iommu ff950800.vip_mmu: (vip) Enter [ 0.500952] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.500968] rk_iommu ff950800.vip_mmu: (vip) Initialized [ 0.501131] rk_iommu ff930300.vopb_mmu: (vopb) Enter [ 0.501190] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.501206] rk_iommu ff930300.vopb_mmu: (vopb) Initialized [ 0.501365] rk_iommu ff940300.vopl_mmu: (vopl) Enter [ 0.501424] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.501440] rk_iommu ff940300.vopl_mmu: (vopl) Initialized [ 0.501611] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter [ 0.501672] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.501688] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized [ 0.501853] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter [ 0.501912] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.501928] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized [ 0.502101] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter [ 0.502161] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.502176] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized [ 0.503998] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.504014] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.504534] rk3368_init_rockchip_pmu_ops: could not find pmu dt node [ 0.504558] DDR DEBUG: version 1.00 20150126 [ 0.504582] DDR DEBUG: Channel a: [ 0.504591] DDR DEBUG: DDR3 Device [ 0.504606] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB [ 0.504617] DDR DEBUG: Channel b: [ 0.504626] DDR DEBUG: DDR3 Device [ 0.504639] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB [ 0.504651] DDR DEBUG: addr=0xd91000 [ 0.504662] DDR DEBUG: stride=9, size=256, halfcap=40000000 [ 0.504672] DDR DEBUG: socAddr[0]=0xd91000, socAddr[1]=0xd91100 [ 0.504684] DDR DEBUG: chAddr[0]=0xd91000, chAddr[1]=0xd91000 [ 0.504696] DDR DEBUG: dtar[0]=0x101b2000, dtar[1]=0x101b2000 [ 0.504750] DDR DEBUG: init success!!! freq=396MHz [ 0.504760] DDR DEBUG: Channel a: [ 0.504773] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=90,360 [ 0.504789] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=90,360 [ 0.504804] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=90,360 [ 0.504820] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=90,360 [ 0.504834] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0 [ 0.504846] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19 [ 0.504856] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2 [ 0.504865] DDR DEBUG: Channel b: [ 0.504878] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=90,360 [ 0.504893] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=90,360 [ 0.504908] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=90,360 [ 0.504923] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=90,360 [ 0.504937] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0 [ 0.504949] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19 [ 0.504959] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2 [ 0.529431] bio: create slab at 0 [ 0.529909] Rockchip hdmi driver version 2.0 . [ 0.531017] SCSI subsystem initialized [ 0.531168] usbcore: registered new interface driver usbfs [ 0.531214] usbcore: registered new interface driver hub [ 0.531302] usbcore: registered new device driver usb [ 0.535005] i2c i2c-0: of_i2c: modalias failure on /i2c@ff650000/rk818@1c [ 0.535566] i2c i2c-0: of_i2c: modalias failure on /i2c@ff650000/ricoh619@32 [ 0.536336] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter [ 0.537017] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter [ 0.537990] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter [ 0.538242] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter [ 0.538676] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter [ 0.538791] media: Linux media interface: v0.10 [ 0.538832] Linux video capture interface: v2.00 [ 0.538887] pps_core: LinuxPPS API ver. 1 registered [ 0.538899] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email]giometti@linux.it[/email]> [ 0.538927] PTP clock support registered [ 0.539506] bq24296 0-006b: bq24296_battery_probe(): Failed in reading register0x0a [ 0.539530] bq24296: probe of 0-006b failed with error -11 [ 0.539575] i2c-core: driver [bq24296] using legacy suspend method [ 0.539588] i2c-core: driver [bq24296] using legacy resume method [ 0.539905] RK29 Watchdog Timer, (c) 2011 Rockchip Electronics [ 0.540349] ion_drm_heap_create: 0@0 [ 0.540466] Rockchip ion module is successfully loaded (v1.1) [ 0.540620] Advanced Linux Sound Architecture Driver Initialized. [ 0.540981] Bluetooth: Core ver 2.16 [ 0.541016] NET: Registered protocol family 31 [ 0.541028] Bluetooth: HCI device and connection manager initialized [ 0.541044] Bluetooth: HCI socket layer initialized [ 0.541059] Bluetooth: L2CAP socket layer initialized [ 0.541084] Bluetooth: SCO socket layer initialized [ 0.541315] cfg80211: Calling CRDA to update world regulatory domain [ 0.541935] act8846_i2c_probe,line=898 [ 0.542886] act8846_parse_dt,line=746 [ 0.543320] invalid gpio: -2 [ 0.543338] lhm invalid gpio: -2 [ 0.543359] act8846_i2c_probe: act8846_pmic_hold=1 [ 0.543381] act8846_i2c_probe: act8846_pmic_sleep=1 [ 0.543391] ------------[ cut here ]------------ [ 0.543410] WARNING: at drivers/gpio/gpiolib.c:126 gpio_to_desc+0x20/0x44() [ 0.543421] invalid GPIO -2 [ 0.543430] Modules linked in: [ 0.543446] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.0 #7 [ 0.543478] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14) [ 0.543501] [] (show_stack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68) [ 0.543522] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_fmt+0x2c/0x3c) [ 0.543541] [] (warn_slowpath_fmt+0x2c/0x3c) from [] (gpio_to_desc+0x20/0x44) [ 0.543562] [] (gpio_to_desc+0x20/0x44) from [] (gpio_request+0xc/0x18) [ 0.543586] [] (gpio_request+0xc/0x18) from [] (act8846_i2c_probe+0x1fc/0x3ec) [ 0.543611] [] (act8846_i2c_probe+0x1fc/0x3ec) from [] (i2c_device_probe+0xa8/0xd4) [ 0.543635] [] (i2c_device_probe+0xa8/0xd4) from [] (really_probe+0xa8/0x20c) [ 0.543657] [] (really_probe+0xa8/0x20c) from [] (driver_probe_device+0x30/0x48) [ 0.543678] [] (driver_probe_device+0x30/0x48) from [] (__driver_attach+0x60/0x84) [ 0.543699] [] (__driver_attach+0x60/0x84) from [] (bus_for_each_dev+0x50/0x90) [ 0.543720] [] (bus_for_each_dev+0x50/0x90) from [] (bus_add_driver+0xac/0x20c) [ 0.543741] [] (bus_add_driver+0xac/0x20c) from [] (driver_register+0x9c/0x138) [ 0.543761] [] (driver_register+0x9c/0x138) from [] (i2c_register_driver+0x40/0xac) [ 0.543784] [] (i2c_register_driver+0x40/0xac) from [] (act8846_module_init+0x10/0x34) [ 0.543805] [] (act8846_module_init+0x10/0x34) from [] (do_one_initcall+0x34/0xc8) [ 0.543827] [] (do_one_initcall+0x34/0xc8) from [] (do_initcalls+0x70/0xa0) [ 0.543847] [] (do_initcalls+0x70/0xa0) from [] (kernel_init_freeable+0x90/0x130) [ 0.543868] [] (kernel_init_freeable+0x90/0x130) from [] (kernel_init+0x8/0xe4) [ 0.543890] [] (kernel_init+0x8/0xe4) from [] (ret_from_fork+0x14/0x3c) [ 0.543913] ---[ end trace 49c457d4d8f143a5 ]--- [ 0.543924] gpiod_request: invalid GPIO [ 0.543939] act8846 0-005a: Failed to request gpio -2 with ret:-22 [ 0.548414] vdd_arm: 712 <--> 1500 mV at 1000 mV [ 0.553110] vdd_gpu: 712 <--> 1500 mV at 1000 mV [ 0.553857] rk808_i2c_probe,line=1355 [ 0.555166] The device is not rk808 -11 [ 0.555244] rk808: probe of 0-001b failed with error -11 [ 0.555324] i2c-core: driver [rk818] using legacy suspend method [ 0.555337] i2c-core: driver [rk818] using legacy resume method [ 0.556995] Switching to clocksource arch_sys_counter [ 0.577586] rga: Module initialized. [ 0.578140] rga2 ff920000.rga: rga ion client create success! [ 0.578296] rga: Driver loaded succesfully [ 0.578502] rk-fb rockchip-fb: rk fb ion client create success! [ 0.578517] rk-fb rockchip-fb: rockchip framebuffer driver probe [ 0.578772] rk-screen rk_screen.9: rockchip screen probe success [ 0.579003] rk32-lvds rk32-lvds: rk32 lvds driver probe success [ 0.579363] rk32-edp ff970000.edp: screen is not edp! [ 0.579384] rk32-edp: probe of ff970000.edp failed with error -22 [ 0.580032] graphics fb0: rockchip framebuffer registerd:fb0 [ 0.580322] graphics fb1: rockchip framebuffer registerd:fb1 [ 0.580487] graphics fb2: rockchip framebuffer registerd:fb2 [ 0.580651] graphics fb3: rockchip framebuffer registerd:fb3 [ 0.580858] rk3288-lcdc lcdc0: lcdc0: dclk:54000000>>fps:63 [ 0.580874] rk3288-lcdc lcdc0: wakeup from standby! [ 0.591513] alloc_buffer:ion_phy_addr=0x55c00000 [ 0.595521] fb0:phy:55c00000>>vir:df991000>>len:0x800000 [ 0.598950] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu disabled [ 0.599092] rk3288-lcdc lcdc1: can't find power_ctr node for lcdc1 [ 0.599106] rk_fb_trsm_ops_get:un supported transmitter:0! [ 0.599306] graphics fb4: rockchip framebuffer registerd:fb4 [ 0.599598] graphics fb5: rockchip framebuffer registerd:fb5 [ 0.599770] graphics fb6: rockchip framebuffer registerd:fb6 [ 0.599937] graphics fb7: rockchip framebuffer registerd:fb7 [ 0.599953] fb4:phy:55c00000>>vir:df991000>>len:0x800000 [ 0.599968] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu disabled [ 0.600738] rockchip_set_mux:warning ignore bank num 15 [ 0.600860] rockchip_set_mux:warning ignore bank num 15 [ 0.600971] rockchip_set_mux:warning ignore bank num 15 [ 0.601094] rockchip_set_mux:warning ignore bank num 15 [ 0.601207] rockchip_set_mux:warning ignore bank num 15 [ 0.601318] rockchip_set_mux:warning ignore bank num 15 [ 0.601436] rockchip_set_mux:warning ignore bank num 15 [ 0.601558] rockchip_set_mux:warning ignore bank num 15 [ 0.601689] rockchip_set_mux:warning ignore bank num 15 [ 0.601815] rockchip_set_mux:warning ignore bank num 15 [ 0.602938] cw201x:support DC charger [ 0.603926] cw_bat_probe cw_init error [ 0.603948] cw201x: probe of 0-0062 failed with error -11 [ 0.604345] NET: Registered protocol family 2 [ 0.604953] TCP established hash table entries: 4096 (order: 3, 32768 bytes) [ 0.605033] TCP bind hash table entries: 4096 (order: 3, 32768 bytes) [ 0.605108] TCP: Hash tables configured (established 4096 bind 4096) [ 0.605155] TCP: reno registered [ 0.605170] UDP hash table entries: 256 (order: 1, 8192 bytes) [ 0.605195] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [ 0.605369] NET: Registered protocol family 1 [ 0.605913] Unpacking initramfs... [ 0.736896] Freeing initrd memory: 2740K (c5bf0000 - c5e9d000) [ 0.737514] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available [ 0.737986] vcodec_service: probe device ff9a0000.vpu_service [ 0.738128] vcodec_service: No reset resource define [ 0.738259] vcodec_service: ff9a0000.vpu_service: power on [ 0.738327] vcodec_service: probe device ff9a0000.vpu_service [ 0.738344] vcodec_service: checking hw id 4831 [ 0.738715] vcodec_service: ff9a0000.vpu_service: power off... [ 0.738757] vcodec_service: done [ 0.738767] vcodec_service: init success [ 0.738821] vcodec_service: probe device ff9c0000.hevc_service [ 0.739136] vcodec_service: ff9c0000.hevc_service: power on [ 0.739188] vcodec_service: probe device ff9c0000.hevc_service [ 0.739204] vcodec_service: checking hw id 6867 [ 0.739448] vcodec_service: ff9c0000.hevc_service: power off... [ 0.739490] vcodec_service: done [ 0.739500] vcodec_service: init success [ 0.739626] rknandbase v1.0 2014-03-31 [ 0.739742] rknand: probe of ff400000.nandc0 failed with error -1 [ 0.739855] rknand_driver:ret = 0 [ 0.741778] audit: initializing netlink socket (disabled) [ 0.741816] type=2000 audit(0.400:1): initialized [ 0.742565] bounce pool size: 64 pages [ 0.747040] fuse init (API version 7.22) [ 0.747399] msgmni has been set to 920 [ 0.754025] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 0.754043] io scheduler noop registered [ 0.754054] io scheduler deadline registered [ 0.754142] io scheduler cfq registered (default) [ 0.755558] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess. [ 0.756191] IEP Driver loaded succesfully [ 0.756280] Module initialized. [ 1.019942] rk_battery_charger_detect_cb , battery_charger_detect 2 [ 1.020441] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208 [ 1.020461] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10 [ 1.021817] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208 [ 1.021837] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [ 1.022155] vdd_logic: 925 <--> 1400 mV at 1000 mV [ 1.022443] rk_serial.c v1.8 2014-03-04 [ 1.022651] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0 [ 1.022827] serial ff180000.serial: membase e219a000 [ 1.025500] loop: module loaded [ 1.025851] zram: Created 1 device(s) ... [ 1.025998] i2c i2c-1: mpu_probe: 0 [ 1.026107] 6mldl_cfg:Reset MPU6050 B1 [ 1.027075] drivers/misc/inv_mpu/mlsl-kernel.c|inv_i2c_write|48 returning -11 [ 1.027090] drivers/misc/inv_mpu/mldl_cfg.c|mpu60xx_pwr_mgmt|574 returning -11 [ 1.027104] drivers/misc/inv_mpu/mldl_cfg.c|inv_mpu_open|1472 returning -11 [ 1.027118] i2c i2c-1: Unable to open mpu6050B1 -11 [ 1.027133] i2c i2c-1: mpu_probe failed -19 [ 1.027182] i2c-core: driver [mpu6050B1] using legacy suspend method [ 1.027195] i2c-core: driver [mpu6050B1] using legacy resume method [ 1.027212] mpu_init: Probe name mpu6050B1 [ 1.027409] bus=0,adapt_num=0,addr=d [ 1.027421] 1 0 0 0 1 0 0 0 -1 [ 1.027450] i2c i2c-1: ak8963_mod_probe: (null) [ 1.027459] yemk:ak8963_mod_probe [ 1.027472] i2c i2c-1: inv_mpu_register_slave: Null mpu_private_data [ 1.027484] invensense: in ak8963_mod_probe, result is -22 [ 1.027497] i2c i2c-1: Slave registration failed: (null), -22 [ 1.027509] i2c i2c-1: ak8963_mod_probe failed -22 [ 1.027525] ak8963_mod: probe of 1-000d failed with error -22 [ 1.027564] ak8963_mod_init: Probe name ak8963_mod [ 1.028203] SCSI Media Changer driver v0.25 [ 1.028509] tun: Universal TUN/TAP device driver, 1.6 [ 1.028522] tun: (C) 1999-2004 Max Krasnyansky <[email]maxk@qualcomm.com[/email]> [ 1.028640] vmac_init. [ 1.028965] PPP generic driver version 2.4.2 [ 1.029091] PPP BSD Compression module registered [ 1.029107] PPP Deflate Compression module registered [ 1.029127] PPP MPPE Compression module registered [ 1.029139] NET: Registered protocol family 24 [ 1.029170] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled). [ 1.029183] CSLIP: code copyright 1989 Regents of the University of California. [ 1.029195] Rockchip WiFi SYS interface (V1.00) ... [ 1.029229] esp_mem_init enter date Jun 7 2019 22:10:25 [ 1.029239] esp_mem_init VERSION [V2.5] [ 1.029278] esp_mem_init complete [ 1.029346] usbcore: registered new interface driver catc [ 1.029411] usbcore: registered new interface driver kaweth [ 1.029424] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver [ 1.029466] usbcore: registered new interface driver pegasus [ 1.029506] usbcore: registered new interface driver rtl8150 [ 1.029546] usbcore: registered new interface driver r8152 [ 1.029557] hso: drivers/net/usb/hso.c: Option Wireless [ 1.029630] usbcore: registered new interface driver hso [ 1.029676] usbcore: registered new interface driver asix [ 1.029721] usbcore: registered new interface driver ax88179_178a [ 1.029761] usbcore: registered new interface driver cdc_ether [ 1.029800] usbcore: registered new interface driver cdc_eem [ 1.029839] usbcore: registered new interface driver dm9601 [ 1.029878] usbcore: registered new interface driver dm9620 [ 1.029930] usbcore: registered new interface driver smsc75xx [ 1.029979] usbcore: registered new interface driver smsc95xx [ 1.030020] usbcore: registered new interface driver gl620a [ 1.030060] usbcore: registered new interface driver net1080 [ 1.030100] usbcore: registered new interface driver plusb [ 1.030141] usbcore: registered new interface driver rndis_host [ 1.030184] usbcore: registered new interface driver cdc_subset [ 1.030224] usbcore: registered new interface driver zaurus [ 1.030266] usbcore: registered new interface driver MOSCHIP usb-ethernet driver [ 1.030323] usbcore: registered new interface driver int51x1 [ 1.030372] usbcore: registered new interface driver kalmia [ 1.030412] usbcore: registered new interface driver ipheth [ 1.030453] usbcore: registered new interface driver sierra_net [ 1.030496] usbcore: registered new interface driver cx82310_eth [ 1.030542] usbcore: registered new interface driver cdc_ncm [ 1.030581] usbcore: registered new interface driver qmi_wwan [ 1.030618] usbcore: registered new interface driver cdc_mbim [ 1.030631] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.033038] EHCI: ehci_rk_probe e2200000 e2200010 [ 1.033055] rockchip_ehci_host ff500000.usb: EHCI Host Controller [ 1.033084] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1 [ 1.033404] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000 [ 1.049068] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00 [ 1.049139] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.049156] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.049170] usb usb1: Product: EHCI Host Controller [ 1.049183] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd [ 1.049195] usb usb1: SerialNumber: ff500000.usb [ 1.049612] hub 1-0:1.0: USB hub found [ 1.049635] hub 1-0:1.0: 1 port detected [ 1.049788] EHCI: ehci_rk_probe ok [ 1.049885] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 1.050146] usbcore: registered new interface driver cdc_acm [ 1.050159] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 1.050210] usbcore: registered new interface driver usblp [ 1.050251] usbcore: registered new interface driver cdc_wdm [ 1.050318] usbcore: registered new interface driver usb-storage [ 1.050359] usbcore: registered new interface driver ums-alauda [ 1.050396] usbcore: registered new interface driver ums-cypress [ 1.050433] usbcore: registered new interface driver ums-datafab [ 1.050471] usbcore: registered new interface driver ums_eneub6250 [ 1.050507] usbcore: registered new interface driver ums-freecom [ 1.050545] usbcore: registered new interface driver ums-isd200 [ 1.050582] usbcore: registered new interface driver ums-jumpshot [ 1.050620] usbcore: registered new interface driver ums-karma [ 1.050662] usbcore: registered new interface driver ums-onetouch [ 1.050701] usbcore: registered new interface driver ums-sddr09 [ 1.050739] usbcore: registered new interface driver ums-sddr55 [ 1.050777] usbcore: registered new interface driver ums-usbat [ 1.050861] usbcore: registered new interface driver usbserial [ 1.050902] usbcore: registered new interface driver usbserial_generic [ 1.050934] usbserial: USB Serial support registered for generic [ 1.050973] usbcore: registered new interface driver option [ 1.051007] usbserial: USB Serial support registered for GSM modem (1-port) [ 1.051078] usbcore: registered new interface driver trancevibrator [ 1.051091] usb20_otg: version 3.10a 21-DEC-2012 [ 1.051457] e2280040 [ 1.051470] Core Release: 3.10a [ 1.051481] Setting default values for core params [ 1.051606] Using Buffer DMA mode [ 1.051618] Periodic Transfer Interrupt Enhancement - disabled [ 1.051628] Multiprocessor Interrupt Enhancement - disabled [ 1.051640] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 1.051650] ^^^^^^^^^^^^^^^^^Device Mode [ 1.051663] Dedicated Tx FIFOs mode [ 1.051680] pcd_init otg_dev = dcf694c0 [ 1.051815] usb20_otg ff580000.usb: DWC OTG Controller [ 1.051843] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2 [ 1.051872] usb20_otg ff580000.usb: irq 55, io mem 0x00000000 [ 1.051926] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.051942] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.051956] usb usb2: Product: DWC OTG Controller [ 1.051969] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd [ 1.051981] usb usb2: SerialNumber: ff580000.usb [ 1.052368] hub 2-0:1.0: USB hub found [ 1.052390] hub 2-0:1.0: 1 port detected [ 1.052683] usb20_host: version 3.10a 21-DEC-2012 [ 1.055151] e2300040 [ 1.055165] Core Release: 3.10a [ 1.055175] Setting default values for core params [ 1.055274] Using Buffer DMA mode [ 1.055285] Periodic Transfer Interrupt Enhancement - disabled [ 1.055296] Multiprocessor Interrupt Enhancement - disabled [ 1.055307] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 1.055316] ^^^^^^^^^^^^^^^^^^Host Mode [ 1.055339] usb20_host ff540000.usb: DWC OTG Controller [ 1.055365] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3 [ 1.055392] usb20_host ff540000.usb: irq 57, io mem 0x00000000 [ 1.055483] Init: Power Port (0) [ 1.055536] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.055552] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.055566] usb usb3: Product: DWC OTG Controller [ 1.055579] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd [ 1.055591] usb usb3: SerialNumber: ff540000.usb [ 1.055970] hub 3-0:1.0: USB hub found [ 1.055996] hub 3-0:1.0: 1 port detected [ 1.056643] usbcore: registered new interface driver xpad [ 1.056696] usbcore: registered new interface driver usb_acecad [ 1.056748] usbcore: registered new interface driver aiptek [ 1.056793] usbcore: registered new interface driver gtco [ 1.056839] usbcore: registered new interface driver hanwang [ 1.056883] usbcore: registered new interface driver kbtab [ 1.056934] usbcore: registered new interface driver wacom [ 1.057196] ___goodix_ts_probe() start____ [ 1.206655] input: goodix-ts as /devices/virtual/input/input0 [ 1.207246] sensor_register_slave:mma8452,id=17 [ 1.207261] sensor_register_slave:gs_mc3230,id=23 [ 1.207270] gsensor_init [ 1.207280] sensor_register_slave:mpu6880_acc,id=24 [ 1.207292] sensor_register_slave:mpu6500_acc,id=25 [ 1.207303] sensor_register_slave:cm3217,id=48 [ 1.207313] sensor_register_slave:cm3218,id=49 [ 1.212073] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0 [ 1.212680] i2c /dev entries driver [ 1.213337] IR NEC protocol handler initialized [ 1.213351] IR RC5(x) protocol handler initialized [ 1.213361] IR RC6 protocol handler initialized [ 1.213371] IR JVC protocol handler initialized [ 1.213380] IR Sony protocol handler initialized [ 1.213390] IR RC5 (streamzap) protocol handler initialized [ 1.213400] IR SANYO protocol handler initialized [ 1.213410] IR MCE Keyboard/mouse protocol handler initialized [ 1.213584] usbcore: registered new interface driver uvcvideo [ 1.213596] USB Video Class driver (1.1.1) [ 1.213609] CamSys driver version: v0.32.0, CamSys head file version: v0.11.0 [ 1.214984] D1:camsys_platform_probe(1300): 1-gpios-cifpower: gpio=236 [ 1.215007] D1:camsys_platform_probe(1303): gpios-cifpower: gpio_request [ 1.215024] D1:camsys_platform_probe(1305): 1-gpios-cifpower: gpio_request=0 [ 1.215042] D1:camsys_platform_probe(1314): gpios-cifpower: 236 high [ 1.215082] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288 [ 1.215082] [ 1.215143] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0) [ 1.215281] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe21f8000 size: 0x4000) [ 1.215922] D1:camsys_platform_probe(1446): ff910000.isp memory: [ 1.215940] D1:camsys_platform_probe(1456): Register memory (phy: 0xff910000 vir: 0xe2240000 size: 0x10000) [ 1.215956] D1:camsys_platform_probe(1451): I2c memory (phy: 0x1cf54000 vir: 0xdcf54000 size: 0x1000) [ 1.215970] D1:camsys_init_ext_fsh_module(20): init external flash module [ 1.215983] D1:camsys_platform_probe(1471): Probe ff910000.isp device success [ 1.216400] not find test_power_init dev node [ 1.218003] The device is not bq27320 -11 [ 1.218023] bq27320: probe of 0-0055 failed with error -11 [ 1.218067] i2c-core: driver [bq27320] using legacy suspend method [ 1.218079] i2c-core: driver [bq27320] using legacy resume method [ 1.218381] rockchip_temp_probe,line=364 [ 1.275380] tsadc ff280000.tsadc: initialized [ 1.275757] device-mapper: uevent: version 1.0.3 [ 1.275993] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: [email]dm-devel@redhat.com[/email] [ 1.276297] Bluetooth: HCI UART driver ver 2.2 [ 1.276311] Bluetooth: HCI H4 protocol initialized [ 1.276323] Bluetooth: HCILL protocol initialized [ 1.276334] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21 [ 1.276345] rtk_btusb: Register usb char device interface for BT driver [ 1.276507] usbcore: registered new interface driver rtk_btusb [ 1.279298] cpufreq version 1.0, suspend freq 1200 MHz [ 1.279467] cpuidle: using governor ladder [ 1.279480] cpuidle: using governor menu [ 1.279512] Synopsys Designware Multimedia Card Interface Driver [ 1.279524] MHSC version = Ver 2.00 2015-06-10 [ 1.279812] dw cru_regsbase addr 0x1d8. [ 1.279825] dw cru_reset_offset val 3. [ 1.279840] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a [ 1.279876] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc [ 1.280129] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller. [ 1.280274] dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0] [ 1.280429] 1358..dw_mci_set_ios: no card. [mmc0] [ 1.295068] 1358..dw_mci_set_ios: no card. [mmc0] [ 1.314815] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0] [ 1.314843] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo [ 1.314861] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized [ 1.315186] dw cru_regsbase addr 0x1d8. [ 1.315199] dw cru_reset_offset val 0. [ 1.315218] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a [ 1.315292] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc [ 1.316010] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller. [ 1.316398] dw_mci_init_slot: fmin=400000, fmax=50000000 [mmc1] [ 1.316455] mmc1: no vmmc regulator found [ 1.316547] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found! [ 1.316605] 1358..dw_mci_set_ios: no card. [mmc1] [ 1.334427] 1358..dw_mci_set_ios: no card. [mmc1] [ 1.346886] mmc0: BKOPS_EN bit is not set [ 1.348769] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1) [ 1.348791] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0] [ 1.348840] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=8bits.[mmc0] [ 1.348937] mmc0: new high speed MMC card at address 0001 [ 1.349171] mmcblk0: mmc0:0001 8WPD3R 7.28 GiB [ 1.349273] mmcblk0rpmb: mmc0:0001 8WPD3R partition 3 512 KiB [ 1.349523] parameter: 0x000000000 -- 0x000400000 (4 MB) [ 1.349534] uboot: 0x000400000 -- 0x000800000 (4 MB) [ 1.349543] misc: 0x000800000 -- 0x000c00000 (4 MB) [ 1.349552] resource: 0x000c00000 -- 0x001c00000 (16 MB) [ 1.349560] kernel: 0x001c00000 -- 0x002c00000 (16 MB) [ 1.349568] boot: 0x002c00000 -- 0x004c00000 (32 MB) [ 1.349576] recovery: 0x004c00000 -- 0x006c00000 (32 MB) [ 1.349584] backup: 0x006c00000 -- 0x00a000000 (52 MB) [ 1.349592] cache: 0x00a000000 -- 0x012000000 (128 MB) [ 1.349601] kpanic: 0x012000000 -- 0x012400000 (4 MB) [ 1.349609] system: 0x012400000 -- 0x072400000 (1536 MB) [ 1.349617] metadata: 0x072400000 -- 0x073400000 (16 MB) [ 1.349625] userdata: 0x073400000 -- 0x0b3400000 (1024 MB) [ 1.349633] radical_update: 0x0b3400000 -- 0x0b7400000 (64 MB) [ 1.349642] user: 0x0b7400000 -- 0x1d1c00000 (4520 MB) [ 1.349670] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p151358..dw_mci_set_ios: no card. [mmc1] [ 1.354128] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo [ 1.354140] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized [ 1.354403] dw cru_regsbase addr 0x1d8. [ 1.354411] dw cru_reset_offset val 1. [ 1.354421] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a [ 1.354449] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc [ 1.354650] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller. [ 1.354749] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2] [ 1.354980] 1358..dw_mci_set_ios: no card. [mmc2] [ 1.373773] 1358..dw_mci_set_ios: no card. [mmc2] [ 1.393469] 1358..dw_mci_set_ios: no card. [mmc2] [ 1.393487] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo [ 1.393498] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized [ 1.393723] hidraw: raw HID events driver (C) Jiri Kosina [ 1.395130] usbcore: registered new interface driver usbhid [ 1.395139] usbhid: USB HID core driver [ 1.395239] ashmem: initialized [ 1.395343] logger: created 256K log 'log_main' [ 1.395432] logger: created 256K log 'log_events' [ 1.395524] logger: created 256K log 'log_radio' [ 1.395610] logger: created 256K log 'log_system' [ 1.396645] input: rk29-keypad as /devices/ff100000.adc/key.35/input/input1 [ 1.397355] jp es8323_line_det_gpio:-1 [ 1.398021] es8323 probe error [ 1.398037] ES8323: probe of 2-0010 failed with error -11 [ 1.398321] RT5631 Audio Codec 0.01 alsa 1.0.26 [ 1.398976] RT5631 probe error [ 1.398988] rt5631: probe of 2-001a failed with error -11 [ 1.399689] rt3261 && rt3224 probe error [ 1.399701] rt3261: probe of 2-001c failed with error -11 [ 1.400098] rockchip-spdif ff880000.rockchip-spdif: spdif ready. [ 1.400310] rockchip-rt5631 rockchip-rt5631.31: ASoC: CODEC (null) not registered [ 1.400336] rockchip_rt5631_audio_probe() register card failed:-517 [ 1.400351] platform rockchip-rt5631.31: Driver rockchip-rt5631 requests probe deferral [ 1.400545] rockchip-rt3261 rockchip-rt3224.32: ASoC: CODEC (null) not registered [ 1.400564] rockchip_rt3261_audio_probe() register card failed:-517 [ 1.400577] platform rockchip-rt3224.32: Driver rockchip-rt3261 requests probe deferral [ 1.402623] rockchip-hdmi-i2s rockchip-hdmi-i2s.29: rk-hdmi-i2s-hifi <-> ff890000.rockchip-i2s mapping ok [ 1.403061] u32 classifier [ 1.403070] Actions configured [ 1.403081] Netfilter messages via NETLINK v0.30. [ 1.403124] nf_conntrack version 0.5.0 (16384 buckets, 65536 max) [ 1.403427] ctnetlink v0.93: registering with nfnetlink. [ 1.403479] NF_TPROXY: Transparent proxy support initialized, version 4.1.0 [ 1.403487] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd. [ 1.403734] xt_time: kernel timezone is -0000 [ 1.403920] ip_tables: (C) 2000-2006 Netfilter Core Team [ 1.404042] arp_tables: (C) 2002 David S. Miller [ 1.404077] TCP: cubic registered [ 1.404084] Initializing XFRM netlink socket [ 1.404298] NET: Registered protocol family 10 [ 1.404712] mip6: Mobile IPv6 [ 1.404739] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 1.404844] sit: IPv6 over IPv4 tunneling driver [ 1.405144] NET: Registered protocol family 17 [ 1.405166] NET: Registered protocol family 15 [ 1.405212] Bridge firewalling registered [ 1.405223] Ebtables v2.0 registered [ 1.405347] Bluetooth: RFCOMM TTY layer initialized [ 1.405370] Bluetooth: RFCOMM socket layer initialized [ 1.405378] Bluetooth: RFCOMM ver 1.11 [ 1.405386] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 1.405393] Bluetooth: BNEP filters: protocol multicast [ 1.405404] Bluetooth: BNEP socket layer initialized [ 1.405412] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 1.405422] Bluetooth: HIDP socket layer initialized [ 1.405445] l2tp_core: L2TP core driver, V2.0 [ 1.405458] l2tp_ppp: PPPoL2TP kernel driver, V2.0 [ 1.405466] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 1.405624] [WLAN_RFKILL]: Enter rfkill_wlan_probe [ 1.405634] [WLAN_RFKILL]: can't find rockchip,grf property [ 1.405643] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6335 [ 1.405651] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control. [ 1.405660] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control. [ 1.405669] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio. [ 1.405689] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0. [ 1.405711] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0. [ 1.405720] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio [ 1.405743] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V [ 1.405752] [WLAN_RFKILL]: Exit rfkill_wlan_probe [ 1.405793] [BT_RFKILL]: Enter rfkill_rk_init [ 1.405916] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147. [ 1.405934] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155. [ 1.405949] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157. [ 1.405965] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154. [ 1.405979] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159. [ 1.406021] [BT_RFKILL]: Request irq for bt wakeup host [ 1.406095] [BT_RFKILL]: ** disable irq [ 1.406171] [BT_RFKILL]: ap6335 device registered. [ 1.406321] rk_cam_cif(3053):rk312x-camera version: v0.2.0 Zoom by ipp [ 1.406630] rockchip-pinctrl ff770000.pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff950000.cif [ 1.406644] rockchip-pinctrl ff770000.pinctrl: pin-75 (ff950000.cif) status -22 [ 1.406654] rockchip-pinctrl ff770000.pinctrl: could not request pin 75 on device rockchip-pinctrl [ 1.406665] rk_cif ff950000.cif: Error applying setting, reverse things back [ 1.406675] rk_cif ff950000.cif: rk_camera_cif_iomux:could not set cif_pin_all pins [ 1.406822] soc-camera-pdrv gc0329_back_3: Probing gc0329_back_3 [ 1.406960] rk3288_init_suspend [ 1.406971] rk3288_suspend_init enter [ 1.407069] rk3288_suspend_init: pm_ctrbits =200007 [ 1.407100] gpio_get_dts_info suspend:4 [ 1.407108] gpio_get_dts_info resume:4 [ 1.407114] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 [ 1.407146] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 [ 1.407295] clks_gating_suspend_init:clkgt info ok [ 1.407381] Registering SWP/SWPB emulation handler [ 1.407393] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 0x02000000@0x7dc00000 [ 1.410547] ddrfreq: verion 1.2 20140526 [ 1.410562] ddrfreq: normal 396MHz video_1080p 240MHz video_4k 396MHz dualview 396MHz idle 0MHz suspend 200MHz reboot 396MHz [ 1.410570] ddrfreq: auto-freq=1 [ 1.410576] ddrfreq: auto-freq-table[0] 240MHz [ 1.410583] ddrfreq: auto-freq-table[1] 324MHz [ 1.410590] ddrfreq: auto-freq-table[2] 396MHz [ 1.410596] ddrfreq: auto-freq-table[3] 528MHz [ 1.411052] regulator-dummy: disabling [ 1.411436] rockchip-rt5631 rockchip-rt5631.31: ASoC: CODEC (null) not registered [ 1.411466] rockchip_rt5631_audio_probe() register card failed:-517 [ 1.411482] platform rockchip-rt5631.31: Driver rockchip-rt5631 requests probe deferral [ 1.411717] rockchip-rt3261 rockchip-rt3224.32: ASoC: CODEC (null) not registered [ 1.411737] rockchip_rt3261_audio_probe() register card failed:-517 [ 1.411752] platform rockchip-rt3224.32: Driver rockchip-rt3261 requests probe deferral [ 1.411786] ======================================================= [ 1.411795] ==== Launching Wi-Fi driver! (Powered by Rockchip) ==== [ 1.411802] ======================================================= [ 1.411810] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init. [ 1.411875] dhd_module_init: in [ 1.411885] ======== bcm_wlan_set_plat_data ======== [ 1.411894] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter [ 1.411919] host_oob_irq: 197
[ 1.411925] host_oob_irq_flags=4
[ 1.411931] dhd_wifi_platform_load: Enter
[ 1.411949] Power-up adapter ‘DHD generic adapter’
[ 1.411953] pcd_pullup, is_on 0
[ 1.411988] wifi_platform_set_power = 1
[ 1.411995] ======== PULL WL_REG_ON HIGH! ========
[ 1.411999] file system registered
[ 1.412009] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.412017] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
[ 1.412024] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 1.412650] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 1.412661] android_usb gadget: Number of LUNs=2
[ 1.412671] lun0: LUN: removable file: (no medium)
[ 1.412679] lun1: LUN: removable file: (no medium)
[ 1.412846] android_usb gadget: android_usb ready
[ 1.412960] sensor_init: Probe name sensors
[ 1.412981] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 1.413543] rtc_hym8563 0-0051: setting system clock to 2019-06-13 06:05:42 UTC (1560405942)
[ 1.419728] rockchip_headset_probe() headset have hook adc mode
[ 1.419840] input: rockchip_headset.34 as /devices/ff100000.adc/rockchip_headset.34/input/input2
[ 1.420356] rockchip-rt5631 rockchip-rt5631.31: ASoC: CODEC (null) not registered
[ 1.420382] rockchip_rt5631_audio_probe() register card failed:-517
[ 1.420396] platform rockchip-rt5631.31: Driver rockchip-rt5631 requests probe deferral
[ 1.420595] rockchip-rt3261 rockchip-rt3224.32: ASoC: CODEC (null) not registered
[ 1.420612] rockchip_rt3261_audio_probe() register card failed:-517
[ 1.420624] platform rockchip-rt3224.32: Driver rockchip-rt3261 requests probe deferral
[ 1.421099] ret 1024
[ 1.421495] usbcore: registered new interface driver snd-usb-audio
[ 1.421504] ALSA device list:
[ 1.421509] #0: RK-HDMI-I2S
[ 1.421745] Freeing unused kernel memory: 356K (c0b9b000 - c0bf4000)
[ 1.422996] ret: 0
[ 1.462754] min_w = 640,min_h = 480 ,max_real_w = 640,max_real_h = 480,max_w = 640,max_h =480
[ 1.482957] gc0329_back_3(rk_cam_sensor:167): write reg(0xfc, val:0x16) failed, try to write again!
[ 1.483876] gc0329_back_3(rk_cam_sensor:167): write reg(0xfc, val:0x16) failed, try to write again!
[ 1.484787] gc0329_back_3(rk_cam_sensor:167): write reg(0xfc, val:0x16) failed, try to write again!
[ 1.511534] [WLAN_RFKILL]: wifi turn on power. 156
[ 1.512752] gc0329_back_3(rk_cam_sensor:333): read reg(0x0 val:0x0) failed, try to read again!
[ 1.512773] gc0329(917): gc0329 read chip id high byte failed
[ 1.512773]
[ 1.512783] gc0329(924): error: gc0329 mismatched pid = 0x0
[ 1.512783]
[ 1.512792] gc0329_back_3(rk_cam_sensor:716): error: mismatched pid = 0x0
[ 1.512792]
[ 1.512887] ret: 0
[ 1.514786] type=1403 audit(1560405942.590:2): policy loaded auid=4294967295 ses=4294967295
[ 1.538093] init: could not import file ‘/init.recovery.rk30board.rc’ from ‘/init.rc’
[ 1.539547] init: invalid gid ‘trace’
[ 1.539623] bat_cap: oldcap path is /sys/devices/ff100000.adc
[ 1.539658] bat_cap: oldcap_path no exist
[ 1.539788] healthd: No charger supplies found
[ 1.539798] healthd: No battery devices found
[ 1.541443] rockchip-rt5631 rockchip-rt5631.31: ASoC: CODEC (null) not registered
[ 1.541468] rockchip_rt5631_audio_probe() register card failed:-517
[ 1.541481] platform rockchip-rt5631.31: Driver rockchip-rt5631 requests probe deferral
[ 1.541689] rockchip-rt3261 rockchip-rt3224.32: ASoC: CODEC (null) not registered
[ 1.541706] rockchip_rt3261_audio_probe() register card failed:-517
[ 1.541717] platform rockchip-rt3224.32: Driver rockchip-rt3261 requests probe deferral
[ 1.628012] init: /dev/hw_random not found
[ 1.628947] init: /dev/hw_random not found
[ 1.629784] android_usb: already disabled
[ 1.629935] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 1.629947] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
[ 1.718185] wifi_platform_bus_enumerate device present 1
[ 1.718195] ======== Card detection to detect SDIO card! ========
[ 1.718202] mmc2:mmc host rescan start!
[ 1.934656] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2]
[ 1.969285] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.970782] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.972278] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.974976] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.027445] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 2.027465] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
[ 2.027511] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=4bits.[mmc2]
[ 2.029121] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 2.029140] mmc2: new high speed SDIO card at address 0001
[ 2.029697] rockchip-rt5631 rockchip-rt5631.31: ASoC: CODEC (null) not registered
[ 2.029720] rockchip_rt5631_audio_probe() register card failed:-517
[ 2.029733] platform rockchip-rt5631.31: Driver rockchip-rt5631 requests probe deferral
[ 2.029938] rockchip-rt3261 rockchip-rt3224.32: ASoC: CODEC (null) not registered
[ 2.029954] rockchip_rt3261_audio_probe() register card failed:-517
[ 2.029965] platform rockchip-rt3224.32: Driver rockchip-rt3261 requests probe deferral
[ 2.045299] bcmsdh_register: register client driver
[ 2.045381] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2.045454] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2.045462] bus num (host idx)=2, slot num (rca)=1
[ 2.045468] found adapter info ‘DHD generic adapter’
[ 2.045587] rockchip-rt5631 rockchip-rt5631.31: ASoC: CODEC (null) not registered
[ 2.045605] rockchip_rt5631_audio_probe() register card failed:-517
[ 2.045616] platform rockchip-rt5631.31: Driver rockchip-rt5631 requests probe deferral
[ 2.045704] F1 signature read @0x18000000=0x16224335
[ 2.045806] rockchip-rt3261 rockchip-rt3224.32: ASoC: CODEC (null) not registered
[ 2.045821] rockchip_rt3261_audio_probe() register card failed:-517
[ 2.045832] platform rockchip-rt3224.32: Driver rockchip-rt3261 requests probe deferral
[ 2.047425] F1 signature OK, socitype:0x1 chip:0x4339 rev:0x1 pkg:0x2
[ 2.047683] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 2.047728] wifi_platform_get_mac_addr
[ 2.047735] ======== bcm_wlan_get_mac_address ========
[ 2.047742] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
[ 2.047751] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
[ 2.047758] [WLAN_RFKILL]: This mac address is not valid, ignored…
[ 2.047767] dhd_conf_set_chiprev: chip=0x4339, chiprev=1
[ 2.047807] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmware/config.txt
[ 2.048159] wl_create_event_handler(): thread:wl_event_handler:8c started
[ 2.048164] tsk Enter, tsk = 0xc5ae149c
[ 2.048296] dhd_attach(): thread:dhd_watchdog_thread:8d started
[ 2.048337] dhd_attach(): thread:dhd_dpc:8e started
[ 2.048362] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
[ 2.048387] dhd_attach(): thread:dhd_rxf:8f started
[ 2.048401] dhd_deferred_work_init: work queue initialized
[ 2.048515] dhdsdio_probe_init: set use_rxchain 1 from config.txt
[ 2.053628] Dongle Host Driver, version 1.201.59.5 (r506368)
[ 2.053628] Compiled in drivers/net/wireless/bcmdhd on Jun 7 2019 at 22:10:29
[ 2.054003] Register interface [wlan0] MAC: 28:ed:e0:0f:1f:24
[ 2.054003]
[ 2.054016] dhd_prot_ioctl : bus is down. we have nothing to do
[ 2.054049] bcmsdh_oob_intr_unregister: Enter
[ 2.054055] bcmsdh_oob_intr_unregister: irq is not registered
[ 2.054065] dhd_txglom_enable: enable 0
[ 2.054071] dhd_bus_devreset: WLAN OFF DONE
[ 2.054103] wifi_platform_set_power = 0
[ 2.054110] ======== PULL WL_REG_ON LOW! ========
[ 2.054116] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 2.160965] [WLAN_RFKILL]: wifi shut off power.
[ 2.160974] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
[ 2.160980] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 2.161033] dhd_module_init: Exit err=0
[ 2.161325] rockchip-rt5631 rockchip-rt5631.31: ASoC: CODEC (null) not registered
[ 2.161349] rockchip_rt5631_audio_probe() register card failed:-517
[ 2.161363] platform rockchip-rt5631.31: Driver rockchip-rt5631 requests probe deferral
[ 2.161575] rockchip-rt3261 rockchip-rt3224.32: ASoC: CODEC (null) not registered
[ 2.161591] rockchip_rt3261_audio_probe() register card failed:-517
[ 2.161602] platform rockchip-rt3224.32: Driver rockchip-rt3261 requests probe deferral
[ 3.026900] EHCI: rk_ehci_hcd_enable, disable host controller
[ 3.981395] yemk:mpu6050_load_cablic
[ 3.981403] mpu6050_load_cablic: open file /dev/mtd/mtd6
[ 6.247523] drmboot: module license ‘unspecified’ taints kernel.
[ 6.247553] Disabling lock debug__bgonie to n_tzdattaint
ldn t f.n47an9] zda inwhen2loo091g f[ loc.24ime7] /rm n/st oNo [ t 6lli893ttyinipenUnael/tto oNo peh dstece proaddtyssir__boryic_ota/_tzparty cornon’t fi an.24zda4] whenoiooksb: foreaMT!d
/sbln/s
[ war6.24: 42]‘tnhav usull dob ecatro
yntbx nir spenifying : cperdn’‘roinrodny tzdnuf whur lo, ung ${n po} xrutea!
# St 6.ing994covniy usd 1 de oncatu sy 13x 6:0 sp7c201i
prd crtyineo.prodlin.momal’, =5e M cameolenstyFI
[and 6.dbo037selnitx=psinissepr aateoidyntt.hforwspe=rfyiboaproanrroi’root.riasol’, tyF ${ ine} /inte m
[ ar s=r500xx] id:0: p002er0@ ‘r000eri0(po’ metsn’,0xxis0200hilx0exp2n00(g ‘ot),ser000no’0@0 00.250(m5] ),0t: 008not@0xpan060$roreerirceo’ x00le 00itix00to 000ys/rness/0x0ro1d_u0@0x0dro600/iSootal’x00 000251000] i00(: Woveing,0xSer1a0e c0x0ole600edsackSEL,0xx d40ain@0xfin500 plcace f,0x00[ 000.2x0036000eadpanscr,0xors000 0x0259201] sysd s),0ng000[ 0@0.253924] (me_puatap, x00on000
@0x0039A000(userdata),0x00020000@0x0059A000(radical_update),-@0x005BA000(user) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2018-12-05_18:38:07 androidboot.mode=emmc
bootmode = emmc
recovery filesystem table
0 /mnt/internal_sd vfat /dev/block/platform/ff0f0000.rksdmmc/by-name/user 0
1 /mnt/external_sd vfat /dev/block/mmcblk1p1 0
2 /system ext4 /dev/block/platform/ff0f0000.rksdmmc/by-name/system 0
3 /cache ext4 /dev/block/platform/ff0f0000.rksdmmc/by-name/cache 0
4 /metadata ext4 /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata 0
5 /data ext4 /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata 0
6 /cust ext4 /dev/block/platform/ff0f0000.rksdmmc/by-name/cust 0
7 /custom ext4 /dev/block/platform/ff0f0000.rksdmmc/by-name/custom 0
8 /radical_update ext4 /dev/block/platform/ff0f0000.rksdmmc/by-name/radical_update 0
9 /misc emmc /dev/block/platform/ff0f0000.rksdmmc/by-name/misc 0
10 /uboot emmc /dev/block/platform/ff0f0000.rksdmmc/by-name/uboot 0
11 /charge emmc /dev/block/platform/ff0f0000.rksdmmc/by-name/charge 0
12 /resource emmc /dev/block/platform/ff0f0000.rksdmmc/by-name/resource 0
13 /parameter emmc /dev/block/platform/ff0f0000.rksdmmc/by-name/parameter 0
14 /boot emmc /dev/block/platform/ff0f0000.rksdmmc/by-name/boot 0
15 /recovery emmc /dev/block/platform/ff0f0000.rksdmmc/by-name/recovery 0
16 /backup emmc /dev/block/platform/ff0f0000.rksdmmc/by-name/backup 0
17 /tmp ramdisk ramdisk 0
I/ [File] : bootable/recovery/recovery.cpp; [Line] : 1416; [Func] : SetSdcardRootPath; InternalSD_ROOT: /mnt/internal_sd
I/ [File] : bootable/recovery/recovery.cpp; [Line] : 1418; [Func] : SetSdcardRootPath; ExternalSD_ROOT: /mnt/external_sd
failed to create /cache dir,err=File exists!
[ 6.494562] EXT4-fs (mmcblk0p9): recovery complete
[ 6.494586] EXT4-f [(mlebl: p9otamoe/tecofirysyecevewi.c o; erin d ta23od; [Ouns: :
main; to dump args befor get_args() :
1 argument(s) :
/sbin/recovery
D/ [File] : bootable/recovery/recovery.cpp; [Line] : 612; [Func] : get_args; to dump ‘boot’ :
command : boot-recovery
status :
recovery : recovery
–wipe_all
 stage :
I/ [File] : bootable/recovery/recovery.cpp; [Line] : 618; [Func] : get_args; Boot command: boot-recovery
I/ [File] : bootable/recovery/recovery.cpp; [Line] : 636; [Func] : get_args; Got arguments from boot message
D/ [File] : bootable/recovery/recovery.cpp; [Line] : 2378; [Func] : main; to dump args after get_args() :
2 argument(s) :
recovery
–wipe_all
locale is [zh_CN]
stage is
reason is [(null)]
can’t open /dev/tty0: No such file or directory
fb0 reports (possibly inaccurate):
vi.bits_per_pixel = 16
vi.red.offset = 11 .length = 5
vi.green.offset = 5 .length = 6
vi.blue.offset = 0 .length = 5
fi.line_length = 2048
framebuffer: 0 (1024 x 600) double_buffer 1
SRX
CPU: rk3288
cpu version = 0
128 MiB
SdmmcInit = 0 20
SdmmcInit = 2 0
storage init OK!
GetParam
pmic:act8846
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
[ 0.000000] Booting Linux on physical CPU 0x500 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.0 (tang@tang-ThinkPad-T480) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #7 SMP PREEMPT Thu Jun 13 12:19:36 CST 2019 [ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288 [ 0.000000] rockchip_uboot_logo_setup: mem: 0x02000000@0x7dc00000, offset:0x00000000 [ 0.000000] rockchip_uboot_mem_reserve: reserve 0x02000000@0x7dc00000 for uboot logo [ 0.000000] rockchip_ion_reserve [ 0.000000] ion heap(drm): base(0) size(0) align(0) [ 0.000000] ion heap(cma): base(0) size(28000000) align(0) [ 0.000000] ion heap(vmalloc): base(0) size(0) align(0) [ 0.000000] cma: CMA: reserved 640 MiB at 55c00000 [ 0.000000] ion_reserve: cma reserved base 55c00000 size 671088640 [ 0.000000] cma: CMA: reserved 16 MiB at 1e000000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] Boot mode: RECOVERY (2) flag: RECOVER (0xc3524203) [ 0.000000] PERCPU: Embedded 9 pages/cpu @c1f04000 s13376 r8192 d15296 u36864 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523296 [ 0.000000] Kernel command line: vmalloc=512M console=ttyFIQ0 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00200000@0x0039A000(userdata),0x00020000@0x0059A000(radical_update),-@0x005BA000(user) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2018-12-05_18:38:07 [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] allocated 4194304 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Memory: 2048MB = 2048MB total [ 0.000000] Memory: 1353220k/1353220k available, 743932k reserved, 901120K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xdf800000 - 0xff000000 ( 504 MB) [ 0.000000] lowmem : 0xc0000000 - 0xdf000000 ( 496 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0b9a95c (11851 kB) [ 0.000000] .init : 0xc0b9b000 - 0xc0bf4440 ( 358 kB) [ 0.000000] .data : 0xc0bf6000 - 0xc0d87d80 (1608 kB) [ 0.000000] .bss : 0xc0d87d80 - 0xc0ea88bc (1155 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] rk_clk_tree_init start! [ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div [ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error [ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1 [ 0.000000] rkclk_init_clks: cnt_parent = 7 [ 0.000000] rkclk_init_clks: cnt_rate = 29 [ 0.000000] rk3288 set GPLL BW 20 for HDMI! [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] Switching to timer-based delay loop [ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns [ 0.000000] process version: 3 [ 0.000000] channel:0, lkg:12 [ 0.000000] target-temp:80 [ 0.000000] channel:2, lkg:0 [ 0.000000] channel:0, lkg:12 [ 0.000000] channel:1, lkg:10 [ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms [ 0.343263] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.343278] pid_max: default: 32768 minimum: 301 [ 0.343387] Security Framework initialized [ 0.343400] SELinux: Initializing. [ 0.343469] Mount-cache hash table entries: 512 [ 0.344058] Initializing cgroup subsys debug [ 0.344071] Initializing cgroup subsys memory [ 0.344096] Initializing cgroup subsys freezer [ 0.344122] CPU: Testing write buffer coherency: ok [ 0.344369] /cpus/cpu@0 missing clock-frequency property [ 0.344381] /cpus/cpu@1 missing clock-frequency property [ 0.344391] /cpus/cpu@2 missing clock-frequency property [ 0.344400] /cpus/cpu@3 missing clock-frequency property [ 0.344443] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500 [ 0.344487] Setting up static identity map for 0xc0858378 - 0xc08583d0 [ 0.346262] last_log: 0x1d900000 map to 0xdf804000 and copy to 0xdf886000, size 0x80000 early 0x1831 (version 3.1) [ 0.421332] CPU1: Booted secondary processor [ 0.421359] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501 [ 0.441008] CPU2: Booted secondary processor [ 0.441032] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502 [ 0.460717] CPU3: Booted secondary processor [ 0.460740] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503 [ 0.460838] Brought up 4 CPUs [ 0.460865] SMP: Total of 4 processors activated (192.00 BogoMIPS). [ 0.460874] CPU: All CPU(s) started in SVC mode. [ 0.461525] devtmpfs: initialized [ 0.465636] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0 [ 0.466578] pinctrl core: initialized pinctrl subsystem [ 0.466794] regulator-dummy: no parameters [ 0.489802] NET: Registered protocol family 16 [ 0.491412] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.491708] ion_snapshot: 0x1da98000 map to 0xdf907000 and copy to 0xc0e83b4c (version 0.1) [ 0.491863] Registered FIQ tty driver [ 0.492987] console [ttyFIQ0] enabled [ 0.493184] Registered fiq debugger ttyFIQ0 [ 0.493771] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff [ 0.493795] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f [ 0.493820] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f [ 0.493840] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b [ 0.493922] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff [ 0.493990] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff [ 0.494056] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff [ 0.494121] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff [ 0.494185] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff [ 0.494249] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff [ 0.494313] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff [ 0.494377] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff [ 0.494447] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff [ 0.494514] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3 [ 0.494530] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f [ 0.494544] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf [ 0.494557] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f [ 0.495157] rockchip_interrupts_register:bank_num=7 [ 0.497016] of_get_gpio_init_config:gpio[0] = 6, value = 0 [ 0.497066] rockchip_pinctrl_probe:init ok [ 0.503354] rk_iommu ff900800.iep_mmu: (iep) Enter [ 0.503421] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.503437] rk_iommu ff900800.iep_mmu: (iep) Initialized [ 0.503599] rk_iommu ff950800.vip_mmu: (vip) Enter [ 0.503658] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.503674] rk_iommu ff950800.vip_mmu: (vip) Initialized [ 0.503836] rk_iommu ff930300.vopb_mmu: (vopb) Enter [ 0.503897] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.503912] rk_iommu ff930300.vopb_mmu: (vopb) Initialized [ 0.504073] rk_iommu ff940300.vopl_mmu: (vopl) Enter [ 0.504131] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.504147] rk_iommu ff940300.vopl_mmu: (vopl) Initialized [ 0.504319] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter [ 0.504380] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.504395] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized [ 0.504562] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter [ 0.504621] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.504636] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized [ 0.504809] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter [ 0.504869] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.504884] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized [ 0.506698] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.506713] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.507231] rk3368_init_rockchip_pmu_ops: could not find pmu dt node [ 0.507254] DDR DEBUG: version 1.00 20150126 [ 0.507278] DDR DEBUG: Channel a: [ 0.507288] DDR DEBUG: DDR3 Device [ 0.507302] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB [ 0.507314] DDR DEBUG: Channel b: [ 0.507322] DDR DEBUG: DDR3 Device [ 0.507335] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB [ 0.507347] DDR DEBUG: addr=0xd91000 [ 0.507358] DDR DEBUG: stride=9, size=256, halfcap=40000000 [ 0.507368] DDR DEBUG: socAddr[0]=0xd91000, socAddr[1]=0xd91100 [ 0.507379] DDR DEBUG: chAddr[0]=0xd91000, chAddr[1]=0xd91000 [ 0.507392] DDR DEBUG: dtar[0]=0x101b2000, dtar[1]=0x101b2000 [ 0.507447] DDR DEBUG: init success!!! freq=396MHz [ 0.507457] DDR DEBUG: Channel a: [ 0.507470] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=90,270 [ 0.507486] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=90,270 [ 0.507502] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=90,270 [ 0.507517] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=90,270 [ 0.507532] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0 [ 0.507544] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19 [ 0.507554] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2 [ 0.507563] DDR DEBUG: Channel b: [ 0.507576] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=90,270 [ 0.507592] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=90,270 [ 0.507606] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=90,270 [ 0.507622] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=90,270 [ 0.507636] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0 [ 0.507647] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19 [ 0.507657] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2 [ 0.532100] bio: create slab at 0 [ 0.532571] Rockchip hdmi driver version 2.0 . [ 0.533666] SCSI subsystem initialized [ 0.533815] usbcore: registered new interface driver usbfs [ 0.533861] usbcore: registered new interface driver hub [ 0.533944] usbcore: registered new device driver usb [ 0.537639] i2c i2c-0: of_i2c: modalias failure on /i2c@ff650000/rk818@1c [ 0.538202] i2c i2c-0: of_i2c: modalias failure on /i2c@ff650000/ricoh619@32 [ 0.538972] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter [ 0.539634] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter [ 0.540618] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter [ 0.540869] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter [ 0.541309] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter [ 0.541426] media: Linux media interface: v0.10 [ 0.541467] Linux video capture interface: v2.00 [ 0.541524] pps_core: LinuxPPS API ver. 1 registered [ 0.541536] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email]giometti@linux.it[/email]> [ 0.541563] PTP clock support registered [ 0.542146] bq24296 0-006b: bq24296_battery_probe(): Failed in reading register0x0a [ 0.542170] bq24296: probe of 0-006b failed with error -11 [ 0.542215] i2c-core: driver [bq24296] using legacy suspend method [ 0.542228] i2c-core: driver [bq24296] using legacy resume method [ 0.542543] RK29 Watchdog Timer, (c) 2011 Rockchip Electronics [ 0.542990] ion_drm_heap_create: 0@0 [ 0.543109] Rockchip ion module is successfully loaded (v1.1) [ 0.543266] Advanced Linux Sound Architecture Driver Initialized. [ 0.543627] Bluetooth: Core ver 2.16 [ 0.543662] NET: Registered protocol family 31 [ 0.543673] Bluetooth: HCI device and connection manager initialized [ 0.543690] Bluetooth: HCI socket layer initialized [ 0.543704] Bluetooth: L2CAP socket layer initialized [ 0.543731] Bluetooth: SCO socket layer initialized [ 0.543967] cfg80211: Calling CRDA to update world regulatory domain [ 0.544587] act8846_i2c_probe,line=898 [ 0.545540] act8846_parse_dt,line=746 [ 0.545974] invalid gpio: -2 [ 0.545991] lhm invalid gpio: -2 [ 0.546012] act8846_i2c_probe: act8846_pmic_hold=1 [ 0.546034] act8846_i2c_probe: act8846_pmic_sleep=1 [ 0.546044] ------------[ cut here ]------------ [ 0.546064] WARNING: at drivers/gpio/gpiolib.c:126 gpio_to_desc+0x20/0x44() [ 0.546075] invalid GPIO -2 [ 0.546084] Modules linked in: [ 0.546101] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.0 #7 [ 0.546132] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14) [ 0.546154] [] (show_stack+0x10/0x14) from [] (warn_slowpath_common+0x4c/0x68) [ 0.546175] [] (warn_slowpath_common+0x4c/0x68) from [] (warn_slowpath_fmt+0x2c/0x3c) [ 0.546195] [] (warn_slowpath_fmt+0x2c/0x3c) from [] (gpio_to_desc+0x20/0x44) [ 0.546216] [] (gpio_to_desc+0x20/0x44) from [] (gpio_request+0xc/0x18) [ 0.546240] [] (gpio_request+0xc/0x18) from [] (act8846_i2c_probe+0x1fc/0x3ec) [ 0.546265] [] (act8846_i2c_probe+0x1fc/0x3ec) from [] (i2c_device_probe+0xa8/0xd4) [ 0.546290] [] (i2c_device_probe+0xa8/0xd4) from [] (really_probe+0xa8/0x20c) [ 0.546313] [] (really_probe+0xa8/0x20c) from [] (driver_probe_device+0x30/0x48) [ 0.546334] [] (driver_probe_device+0x30/0x48) from [] (__driver_attach+0x60/0x84) [ 0.546355] [] (__driver_attach+0x60/0x84) from [] (bus_for_each_dev+0x50/0x90) [ 0.546376] [] (bus_for_each_dev+0x50/0x90) from [] (bus_add_driver+0xac/0x20c) [ 0.546397] [] (bus_add_driver+0xac/0x20c) from [] (driver_register+0x9c/0x138) [ 0.546418] [] (driver_register+0x9c/0x138) from [] (i2c_register_driver+0x40/0xac) [ 0.546440] [] (i2c_register_driver+0x40/0xac) from [] (act8846_module_init+0x10/0x34) [ 0.546461] [] (act8846_module_init+0x10/0x34) from [] (do_one_initcall+0x34/0xc8) [ 0.546483] [] (do_one_initcall+0x34/0xc8) from [] (do_initcalls+0x70/0xa0) [ 0.546503] [] (do_initcalls+0x70/0xa0) from [] (kernel_init_freeable+0x90/0x130) [ 0.546524] [] (kernel_init_freeable+0x90/0x130) from [] (kernel_init+0x8/0xe4) [ 0.546547] [] (kernel_init+0x8/0xe4) from [] (ret_from_fork+0x14/0x3c) [ 0.546571] ---[ end trace 6a14de6245755d37 ]--- [ 0.546582] gpiod_request: invalid GPIO [ 0.546596] act8846 0-005a: Failed to request gpio -2 with ret:-22 [ 0.551074] vdd_arm: 712 <--> 1500 mV at 1350 mV [ 0.555769] vdd_gpu: 712 <--> 1500 mV at 900 mV [ 0.556524] rk808_i2c_probe,line=1355 [ 0.557835] The device is not rk808 -11 [ 0.557911] rk808: probe of 0-001b failed with error -11 [ 0.557993] i2c-core: driver [rk818] using legacy suspend method [ 0.558006] i2c-core: driver [rk818] using legacy resume method [ 0.559679] Switching to clocksource arch_sys_counter [ 0.580271] rga: Module initialized. [ 0.580841] rga2 ff920000.rga: rga ion client create success! [ 0.580999] rga: Driver loaded succesfully [ 0.581208] rk-fb rockchip-fb: rk fb ion client create success! [ 0.581223] rk-fb rockchip-fb: rockchip framebuffer driver probe [ 0.581478] rk-screen rk_screen.9: rockchip screen probe success [ 0.581710] rk32-lvds rk32-lvds: rk32 lvds driver probe success [ 0.582065] rk32-edp ff970000.edp: screen is not edp! [ 0.582087] rk32-edp: probe of ff970000.edp failed with error -22 [ 0.582745] graphics fb0: rockchip framebuffer registerd:fb0 [ 0.583039] graphics fb1: rockchip framebuffer registerd:fb1 [ 0.583204] graphics fb2: rockchip framebuffer registerd:fb2 [ 0.583366] graphics fb3: rockchip framebuffer registerd:fb3 [ 0.583574] rk3288-lcdc lcdc0: lcdc0: dclk:54000000>>fps:63 [ 0.583589] rk3288-lcdc lcdc0: wakeup from standby! [ 0.594263] alloc_buffer:ion_phy_addr=0x55c00000 [ 0.598264] fb0:phy:55c00000>>vir:df991000>>len:0x800000 [ 0.601736] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu disabled [ 0.601876] rk3288-lcdc lcdc1: can't find power_ctr node for lcdc1 [ 0.601891] rk_fb_trsm_ops_get:un supported transmitter:0! [ 0.602097] graphics fb4: rockchip framebuffer registerd:fb4 [ 0.602398] graphics fb5: rockchip framebuffer registerd:fb5 [ 0.602560] graphics fb6: rockchip framebuffer registerd:fb6 [ 0.602729] graphics fb7: rockchip framebuffer registerd:fb7 [ 0.602745] fb4:phy:55c00000>>vir:df991000>>len:0x800000 [ 0.602760] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu disabled [ 0.603530] rockchip_set_mux:warning ignore bank num 15 [ 0.603651] rockchip_set_mux:warning ignore bank num 15 [ 0.603763] rockchip_set_mux:warning ignore bank num 15 [ 0.603885] rockchip_set_mux:warning ignore bank num 15 [ 0.603997] rockchip_set_mux:warning ignore bank num 15 [ 0.604115] rockchip_set_mux:warning ignore bank num 15 [ 0.604229] rockchip_set_mux:warning ignore bank num 15 [ 0.604352] rockchip_set_mux:warning ignore bank num 15 [ 0.604482] rockchip_set_mux:warning ignore bank num 15 [ 0.604606] rockchip_set_mux:warning ignore bank num 15 [ 0.605709] cw201x:support DC charger [ 0.606697] cw_bat_probe cw_init error [ 0.606719] cw201x: probe of 0-0062 failed with error -11 [ 0.607117] NET: Registered protocol family 2 [ 0.607723] TCP established hash table entries: 4096 (order: 3, 32768 bytes) [ 0.607803] TCP bind hash table entries: 4096 (order: 3, 32768 bytes) [ 0.607878] TCP: Hash tables configured (established 4096 bind 4096) [ 0.607924] TCP: reno registered [ 0.607939] UDP hash table entries: 256 (order: 1, 8192 bytes) [ 0.607965] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [ 0.608144] NET: Registered protocol family 1 [ 0.608692] Unpacking initramfs... [ 0.740178] Freeing initrd memory: 2740K (c5bf0000 - c5e9d000) [ 0.740804] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available [ 0.741283] vcodec_service: probe device ff9a0000.vpu_service [ 0.741422] vcodec_service: No reset resource define [ 0.741555] vcodec_service: ff9a0000.vpu_service: power on [ 0.741625] vcodec_service: probe device ff9a0000.vpu_service [ 0.741643] vcodec_service: checking hw id 4831 [ 0.742041] vcodec_service: ff9a0000.vpu_service: power off... [ 0.742084] vcodec_service: done [ 0.742094] vcodec_service: init success [ 0.742149] vcodec_service: probe device ff9c0000.hevc_service [ 0.742454] vcodec_service: ff9c0000.hevc_service: power on [ 0.742508] vcodec_service: probe device ff9c0000.hevc_service [ 0.742525] vcodec_service: checking hw id 6867 [ 0.742780] vcodec_service: ff9c0000.hevc_service: power off... [ 0.742822] vcodec_service: done [ 0.742832] vcodec_service: init success [ 0.742956] rknandbase v1.0 2014-03-31 [ 0.743074] rknand: probe of ff400000.nandc0 failed with error -1 [ 0.743185] rknand_driver:ret = 0 [ 0.745114] audit: initializing netlink socket (disabled) [ 0.745151] type=2000 audit(0.400:1): initialized [ 0.745936] bounce pool size: 64 pages [ 0.750408] fuse init (API version 7.22) [ 0.750776] msgmni has been set to 920 [ 0.752538] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 0.752557] io scheduler noop registered [ 0.752568] io scheduler deadline registered [ 0.752656] io scheduler cfq registered (default) [ 0.754056] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess. [ 0.754679] IEP Driver loaded succesfully [ 0.754766] Module initialized. [ 1.022608] rk_battery_charger_detect_cb , battery_charger_detect 2 [ 1.023109] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208 [ 1.023128] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10 [ 1.024491] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208 [ 1.024512] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [ 1.024833] vdd_logic: 925 <--> 1400 mV at 1000 mV [ 1.025115] rk_serial.c v1.8 2014-03-04 [ 1.025325] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0 [ 1.025501] serial ff180000.serial: membase e219a000 [ 1.028162] loop: module loaded [ 1.028511] zram: Created 1 device(s) ... [ 1.028658] i2c i2c-1: mpu_probe: 0 [ 1.028765] 6mldl_cfg:Reset MPU6050 B1 [ 1.029731] drivers/misc/inv_mpu/mlsl-kernel.c|inv_i2c_write|48 returning -11 [ 1.029747] drivers/misc/inv_mpu/mldl_cfg.c|mpu60xx_pwr_mgmt|574 returning -11 [ 1.029760] drivers/misc/inv_mpu/mldl_cfg.c|inv_mpu_open|1472 returning -11 [ 1.029775] i2c i2c-1: Unable to open mpu6050B1 -11 [ 1.029790] i2c i2c-1: mpu_probe failed -19 [ 1.029842] i2c-core: driver [mpu6050B1] using legacy suspend method [ 1.029854] i2c-core: driver [mpu6050B1] using legacy resume method [ 1.029872] mpu_init: Probe name mpu6050B1 [ 1.030073] bus=0,adapt_num=0,addr=d [ 1.030085] 1 0 0 0 1 0 0 0 -1 [ 1.030114] i2c i2c-1: ak8963_mod_probe: (null) [ 1.030124] yemk:ak8963_mod_probe [ 1.030137] i2c i2c-1: inv_mpu_register_slave: Null mpu_private_data [ 1.030148] invensense: in ak8963_mod_probe, result is -22 [ 1.030161] i2c i2c-1: Slave registration failed: (null), -22 [ 1.030174] i2c i2c-1: ak8963_mod_probe failed -22 [ 1.030189] ak8963_mod: probe of 1-000d failed with error -22 [ 1.030228] ak8963_mod_init: Probe name ak8963_mod [ 1.030863] SCSI Media Changer driver v0.25 [ 1.031174] tun: Universal TUN/TAP device driver, 1.6 [ 1.031187] tun: (C) 1999-2004 Max Krasnyansky <[email]maxk@qualcomm.com[/email]> [ 1.031310] vmac_init. [ 1.031606] PPP generic driver version 2.4.2 [ 1.031730] PPP BSD Compression module registered [ 1.031742] PPP Deflate Compression module registered [ 1.031762] PPP MPPE Compression module registered [ 1.031774] NET: Registered protocol family 24 [ 1.031804] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled). [ 1.031817] CSLIP: code copyright 1989 Regents of the University of California. [ 1.031829] Rockchip WiFi SYS interface (V1.00) ... [ 1.031869] esp_mem_init enter date Jun 7 2019 22:10:25 [ 1.031880] esp_mem_init VERSION [V2.5] [ 1.031920] esp_mem_init complete [ 1.031987] usbcore: registered new interface driver catc [ 1.032029] usbcore: registered new interface driver kaweth [ 1.032062] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver [ 1.032117] usbcore: registered new interface driver pegasus [ 1.032159] usbcore: registered new interface driver rtl8150 [ 1.032200] usbcore: registered new interface driver r8152 [ 1.032211] hso: drivers/net/usb/hso.c: Option Wireless [ 1.032273] usbcore: registered new interface driver hso [ 1.032323] usbcore: registered new interface driver asix [ 1.032363] usbcore: registered new interface driver ax88179_178a [ 1.032403] usbcore: registered new interface driver cdc_ether [ 1.032442] usbcore: registered new interface driver cdc_eem [ 1.032481] usbcore: registered new interface driver dm9601 [ 1.032520] usbcore: registered new interface driver dm9620 [ 1.032574] usbcore: registered new interface driver smsc75xx [ 1.032623] usbcore: registered new interface driver smsc95xx [ 1.032664] usbcore: registered new interface driver gl620a [ 1.032704] usbcore: registered new interface driver net1080 [ 1.032744] usbcore: registered new interface driver plusb [ 1.032785] usbcore: registered new interface driver rndis_host [ 1.032825] usbcore: registered new interface driver cdc_subset [ 1.032868] usbcore: registered new interface driver zaurus [ 1.032911] usbcore: registered new interface driver MOSCHIP usb-ethernet driver [ 1.032967] usbcore: registered new interface driver int51x1 [ 1.033015] usbcore: registered new interface driver kalmia [ 1.033054] usbcore: registered new interface driver ipheth [ 1.033094] usbcore: registered new interface driver sierra_net [ 1.033131] usbcore: registered new interface driver cx82310_eth [ 1.033180] usbcore: registered new interface driver cdc_ncm [ 1.033219] usbcore: registered new interface driver qmi_wwan [ 1.033257] usbcore: registered new interface driver cdc_mbim [ 1.033269] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.035678] EHCI: ehci_rk_probe e2200000 e2200010 [ 1.035695] rockchip_ehci_host ff500000.usb: EHCI Host Controller [ 1.035725] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1 [ 1.036029] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000 [ 1.051751] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00 [ 1.051837] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.051854] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.051868] usb usb1: Product: EHCI Host Controller [ 1.051880] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd [ 1.051893] usb usb1: SerialNumber: ff500000.usb [ 1.052295] hub 1-0:1.0: USB hub found [ 1.052318] hub 1-0:1.0: 1 port detected [ 1.052472] EHCI: ehci_rk_probe ok [ 1.052567] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 1.052830] usbcore: registered new interface driver cdc_acm [ 1.052843] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 1.052895] usbcore: registered new interface driver usblp [ 1.052940] usbcore: registered new interface driver cdc_wdm [ 1.052999] usbcore: registered new interface driver usb-storage [ 1.053038] usbcore: registered new interface driver ums-alauda [ 1.053077] usbcore: registered new interface driver ums-cypress [ 1.053115] usbcore: registered new interface driver ums-datafab [ 1.053152] usbcore: registered new interface driver ums_eneub6250 [ 1.053189] usbcore: registered new interface driver ums-freecom [ 1.053226] usbcore: registered new interface driver ums-isd200 [ 1.053264] usbcore: registered new interface driver ums-jumpshot [ 1.053305] usbcore: registered new interface driver ums-karma [ 1.053344] usbcore: registered new interface driver ums-onetouch [ 1.053383] usbcore: registered new interface driver ums-sddr09 [ 1.053420] usbcore: registered new interface driver ums-sddr55 [ 1.053458] usbcore: registered new interface driver ums-usbat [ 1.053541] usbcore: registered new interface driver usbserial [ 1.053581] usbcore: registered new interface driver usbserial_generic [ 1.053613] usbserial: USB Serial support registered for generic [ 1.053658] usbcore: registered new interface driver option [ 1.053689] usbserial: USB Serial support registered for GSM modem (1-port) [ 1.053759] usbcore: registered new interface driver trancevibrator [ 1.053771] usb20_otg: version 3.10a 21-DEC-2012 [ 1.054140] e2280040 [ 1.054155] Core Release: 3.10a [ 1.054166] Setting default values for core params [ 1.054290] Using Buffer DMA mode [ 1.054302] Periodic Transfer Interrupt Enhancement - disabled [ 1.054313] Multiprocessor Interrupt Enhancement - disabled [ 1.054324] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 1.054334] ^^^^^^^^^^^^^^^^^Device Mode [ 1.054346] Dedicated Tx FIFOs mode [ 1.054364] pcd_init otg_dev = dcf53640 [ 1.054500] usb20_otg ff580000.usb: DWC OTG Controller [ 1.054528] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2 [ 1.054558] usb20_otg ff580000.usb: irq 55, io mem 0x00000000 [ 1.054612] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.054628] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.054642] usb usb2: Product: DWC OTG Controller [ 1.054655] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd [ 1.054667] usb usb2: SerialNumber: ff580000.usb [ 1.055053] hub 2-0:1.0: USB hub found [ 1.055074] hub 2-0:1.0: 1 port detected [ 1.055367] usb20_host: version 3.10a 21-DEC-2012 [ 1.057840] e2300040 [ 1.057854] Core Release: 3.10a [ 1.057865] Setting default values for core params [ 1.057973] Using Buffer DMA mode [ 1.057984] Periodic Transfer Interrupt Enhancement - disabled [ 1.057995] Multiprocessor Interrupt Enhancement - disabled [ 1.058006] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 1.058015] ^^^^^^^^^^^^^^^^^^Host Mode [ 1.058039] usb20_host ff540000.usb: DWC OTG Controller [ 1.058065] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3 [ 1.058093] usb20_host ff540000.usb: irq 57, io mem 0x00000000 [ 1.058184] Init: Power Port (0) [ 1.058238] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.058255] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.058268] usb usb3: Product: DWC OTG Controller [ 1.058281] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd [ 1.058293] usb usb3: SerialNumber: ff540000.usb [ 1.058678] hub 3-0:1.0: USB hub found [ 1.058700] hub 3-0:1.0: 1 port detected [ 1.059348] usbcore: registered new interface driver xpad [ 1.059407] usbcore: registered new interface driver usb_acecad [ 1.059455] usbcore: registered new interface driver aiptek [ 1.059500] usbcore: registered new interface driver gtco [ 1.059546] usbcore: registered new interface driver hanwang [ 1.059590] usbcore: registered new interface driver kbtab [ 1.059640] usbcore: registered new interface driver wacom [ 1.059902] ___goodix_ts_probe() start____ [ 1.209333] input: goodix-ts as /devices/virtual/input/input0 [ 1.209922] sensor_register_slave:mma8452,id=17 [ 1.209938] sensor_register_slave:gs_mc3230,id=23 [ 1.209947] gsensor_init [ 1.209957] sensor_register_slave:mpu6880_acc,id=24 [ 1.209967] sensor_register_slave:mpu6500_acc,id=25 [ 1.209978] sensor_register_slave:cm3217,id=48 [ 1.209989] sensor_register_slave:cm3218,id=49 [ 1.214737] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0 [ 1.215342] i2c /dev entries driver [ 1.215998] IR NEC protocol handler initialized [ 1.216011] IR RC5(x) protocol handler initialized [ 1.216022] IR RC6 protocol handler initialized [ 1.216031] IR JVC protocol handler initialized [ 1.216041] IR Sony protocol handler initialized [ 1.216051] IR RC5 (streamzap) protocol handler initialized [ 1.216061] IR SANYO protocol handler initialized [ 1.216071] IR MCE Keyboard/mouse protocol handler initialized [ 1.216249] usbcore: registered new interface driver uvcvideo [ 1.216262] USB Video Class driver (1.1.1) [ 1.216274] CamSys driver version: v0.32.0, CamSys head file version: v0.11.0 [ 1.217673] D1:camsys_platform_probe(1300): 1-gpios-cifpower: gpio=236 [ 1.217697] D1:camsys_platform_probe(1303): gpios-cifpower: gpio_request [ 1.217713] D1:camsys_platform_probe(1305): 1-gpios-cifpower: gpio_request=0 [ 1.217731] D1:camsys_platform_probe(1314): gpios-cifpower: 236 high [ 1.217772] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288 [ 1.217772] [ 1.217833] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0) [ 1.217970] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe21f8000 size: 0x4000) [ 1.218583] D1:camsys_platform_probe(1446): ff910000.isp memory: [ 1.218601] D1:camsys_platform_probe(1456): Register memory (phy: 0xff910000 vir: 0xe2240000 size: 0x10000) [ 1.218617] D1:camsys_platform_probe(1451): I2c memory (phy: 0x1cf9f000 vir: 0xdcf9f000 size: 0x1000) [ 1.218631] D1:camsys_init_ext_fsh_module(20): init external flash module [ 1.218643] D1:camsys_platform_probe(1471): Probe ff910000.isp device success [ 1.219054] not find test_power_init dev node [ 1.220653] The device is not bq27320 -11 [ 1.220674] bq27320: probe of 0-0055 failed with error -11 [ 1.220718] i2c-core: driver [bq27320] using legacy suspend method [ 1.220731] i2c-core: driver [bq27320] using legacy resume method [ 1.221042] rockchip_temp_probe,line=364 [ 1.278063] tsadc ff280000.tsadc: initialized [ 1.278428] device-mapper: uevent: version 1.0.3 [ 1.278663] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: [email]dm-devel@redhat.com[/email] [ 1.278951] Bluetooth: HCI UART driver ver 2.2 [ 1.278967] Bluetooth: HCI H4 protocol initialized [ 1.278977] Bluetooth: HCILL protocol initialized [ 1.278988] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21 [ 1.278999] rtk_btusb: Register usb char device interface for BT driver [ 1.279177] usbcore: registered new interface driver rtk_btusb [ 1.281930] cpufreq version 1.0, suspend freq 1200 MHz [ 1.282106] cpuidle: using governor ladder [ 1.282119] cpuidle: using governor menu [ 1.282154] Synopsys Designware Multimedia Card Interface Driver [ 1.282166] MHSC version = Ver 2.00 2015-06-10 [ 1.282454] dw cru_regsbase addr 0x1d8. [ 1.282467] dw cru_reset_offset val 3. [ 1.282481] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a [ 1.282520] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc [ 1.282786] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller. [ 1.282931] dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0] [ 1.283088] 1358..dw_mci_set_ios: no card. [mmc0] [ 1.297752] 1358..dw_mci_set_ios: no card. [mmc0] [ 1.317494] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0] [ 1.317514] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo [ 1.317532] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized [ 1.317842] dw cru_regsbase addr 0x1d8. [ 1.317855] dw cru_reset_offset val 0. [ 1.317869] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a [ 1.317947] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc [ 1.318671] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller. [ 1.319181] dw_mci_init_slot: fmin=400000, fmax=50000000 [mmc1] [ 1.319240] mmc1: no vmmc regulator found [ 1.319333] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found! [ 1.319410] 1358..dw_mci_set_ios: no card. [mmc1] [ 1.337114] 1358..dw_mci_set_ios: no card. [mmc1] [ 1.349569] mmc0: BKOPS_EN bit is not set [ 1.351448] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1) [ 1.351471] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0] [ 1.351520] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=8bits.[mmc0] [ 1.351619] mmc0: new high speed MMC card at address 0001 [ 1.351839] mmcblk0: mmc0:0001 8WPD3R 7.28 GiB [ 1.351938] mmcblk0rpmb: mmc0:0001 8WPD3R partition 3 512 KiB [ 1.352192] parameter: 0x000000000 -- 0x000400000 (4 MB) [ 1.352204] uboot: 0x000400000 -- 0x000800000 (4 MB) [ 1.352212] misc: 0x000800000 -- 0x000c00000 (4 MB) [ 1.352220] resource: 0x000c00000 -- 0x001c00000 (16 MB) [ 1.352229] kernel: 0x001c00000 -- 0x002c00000 (16 MB) [ 1.352237] boot: 0x002c00000 -- 0x004c00000 (32 MB) [ 1.352245] recovery: 0x004c00000 -- 0x006c00000 (32 MB) [ 1.352253] backup: 0x006c00000 -- 0x00a000000 (52 MB) [ 1.352261] cache: 0x00a000000 -- 0x012000000 (128 MB) [ 1.352269] kpanic: 0x012000000 -- 0x012400000 (4 MB) [ 1.352278] system: 0x012400000 -- 0x072400000 (1536 MB) [ 1.352286] metadata: 0x072400000 -- 0x073400000 (16 MB) [ 1.352294] userdata: 0x073400000 -- 0x0b3400000 (1024 MB) [ 1.352302] radical_update: 0x0b3400000 -- 0x0b7400000 (64 MB) [ 1.352311] user: 0x0b7400000 -- 0x1d1c00000 (4520 MB) [ 1.352334] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p151358..dw_mci_set_ios: no card. [mmc1] [ 1.356814] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo [ 1.356821] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized [ 1.357087] dw cru_regsbase addr 0x1d8. [ 1.357095] dw cru_reset_offset val 1. [ 1.357104] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a [ 1.357134] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc [ 1.357334] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller. [ 1.357430] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2] [ 1.357667] 1358..dw_mci_set_ios: no card. [mmc2] [ 1.376458] 1358..dw_mci_set_ios: no card. [mmc2] [ 1.396155] 1358..dw_mci_set_ios: no card. [mmc2] [ 1.396173] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo [ 1.396184] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized [ 1.396402] hidraw: raw HID events driver (C) Jiri Kosina [ 1.397830] usbcore: registered new interface driver usbhid [ 1.397839] usbhid: USB HID core driver [ 1.397936] ashmem: initialized [ 1.398039] logger: created 256K log 'log_main' [ 1.398126] logger: created 256K log 'log_events' [ 1.398219] logger: created 256K log 'log_radio' [ 1.398306] logger: created 256K log 'log_system' [ 1.399336] input: rk29-keypad as /devices/ff100000.adc/key.35/input/input1 [ 1.400044] jp es8323_line_det_gpio:-1 [ 1.400710] es8323 probe error [ 1.400727] ES8323: probe of 2-0010 failed with error -11 [ 1.401008] RT5631 Audio Codec 0.01 alsa 1.0.26 [ 1.401659] RT5631 probe error [ 1.401671] rt5631: probe of 2-001a failed with error -11 [ 1.402373] rt3261 && rt3224 probe error [ 1.402385] rt3261: probe of 2-001c failed with error -11 [ 1.402791] rockchip-spdif ff880000.rockchip-spdif: spdif ready. [ 1.403003] rockchip-rt5631 rockchip-rt5631.31: ASoC: CODEC (null) not registered [ 1.403030] rockchip_rt5631_audio_probe() register card failed:-517 [ 1.403044] platform rockchip-rt5631.31: Driver rockchip-rt5631 requests probe deferral [ 1.403237] rockchip-rt3261 rockchip-rt3224.32: ASoC: CODEC (null) not registered [ 1.403255] rockchip_rt3261_audio_probe() register card failed:-517 [ 1.403269] platform rockchip-rt3224.32: Driver rockchip-rt3261 requests probe deferral [ 1.405278] rockchip-hdmi-i2s rockchip-hdmi-i2s.29: rk-hdmi-i2s-hifi <-> ff890000.rockchip-i2s mapping ok [ 1.405729] u32 classifier [ 1.405738] Actions configured [ 1.405749] Netfilter messages via NETLINK v0.30. [ 1.405793] nf_conntrack version 0.5.0 (16384 buckets, 65536 max) [ 1.406100] ctnetlink v0.93: registering with nfnetlink. [ 1.406149] NF_TPROXY: Transparent proxy support initialized, version 4.1.0 [ 1.406158] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd. [ 1.406406] xt_time: kernel timezone is -0000 [ 1.406593] ip_tables: (C) 2000-2006 Netfilter Core Team [ 1.406717] arp_tables: (C) 2002 David S. Miller [ 1.406751] TCP: cubic registered [ 1.406758] Initializing XFRM netlink socket [ 1.406975] NET: Registered protocol family 10 [ 1.407385] mip6: Mobile IPv6 [ 1.407410] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 1.407515] sit: IPv6 over IPv4 tunneling driver [ 1.407819] NET: Registered protocol family 17 [ 1.407842] NET: Registered protocol family 15 [ 1.407890] Bridge firewalling registered [ 1.407901] Ebtables v2.0 registered [ 1.408040] Bluetooth: RFCOMM TTY layer initialized [ 1.408063] Bluetooth: RFCOMM socket layer initialized [ 1.408072] Bluetooth: RFCOMM ver 1.11 [ 1.408080] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 1.408087] Bluetooth: BNEP filters: protocol multicast [ 1.408098] Bluetooth: BNEP socket layer initialized [ 1.408105] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 1.408116] Bluetooth: HIDP socket layer initialized [ 1.408140] l2tp_core: L2TP core driver, V2.0 [ 1.408154] l2tp_ppp: PPPoL2TP kernel driver, V2.0 [ 1.408161] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 1.408316] [WLAN_RFKILL]: Enter rfkill_wlan_probe [ 1.408326] [WLAN_RFKILL]: can't find rockchip,grf property [ 1.408334] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6335 [ 1.408343] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control. [ 1.408351] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control. [ 1.408360] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio. [ 1.408379] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0. [ 1.408402] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0. [ 1.408411] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio [ 1.408434] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V [ 1.408443] [WLAN_RFKILL]: Exit rfkill_wlan_probe [ 1.408482] [BT_RFKILL]: Enter rfkill_rk_init [ 1.408604] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147. [ 1.408621] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155. [ 1.408637] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157. [ 1.408652] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154. [ 1.408667] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159. [ 1.408710] [BT_RFKILL]: Request irq for bt wakeup host [ 1.408787] [BT_RFKILL]: ** disable irq [ 1.408858] [BT_RFKILL]: ap6335 device registered. [ 1.409003] rk_cam_cif(3053):rk312x-camera version: v0.2.0 Zoom by ipp [ 1.409313] rockchip-pinctrl ff770000.pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff950000.cif [ 1.409327] rockchip-pinctrl ff770000.pinctrl: pin-75 (ff950000.cif) status -22 [ 1.409338] rockchip-pinctrl ff770000.pinctrl: could not request pin 75 on device rockchip-pinctrl [ 1.409349] rk_cif ff950000.cif: Error applying setting, reverse things back [ 1.409359] rk_cif ff950000.cif: rk_camera_cif_iomux:could not set cif_pin_all pins [ 1.409509] soc-camera-pdrv gc0329_back_3: Probing gc0329_back_3 [ 1.409655] rk3288_init_suspend [ 1.409666] rk3288_suspend_init enter [ 1.409765] rk3288_suspend_init: pm_ctrbits =200007 [ 1.409792] gpio_get_dts_info suspend:4 [ 1.409800] gpio_get_dts_info resume:4 [ 1.409806] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 [ 1.409838] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 [ 1.409983] clks_gating_suspend_init:clkgt info ok [ 1.410074] Registering SWP/SWPB emulation handler [ 1.410085] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 0x02000000@0x7dc00000 [ 1.413218] ddrfreq: verion 1.2 20140526 [ 1.413232] ddrfreq: normal 396MHz video_1080p 240MHz video_4k 396MHz dualview 396MHz idle 0MHz suspend 200MHz reboot 396MHz [ 1.413241] ddrfreq: auto-freq=1 [ 1.413247] ddrfreq: auto-freq-table[0] 240MHz [ 1.413254] ddrfreq: auto-freq-table[1] 324MHz [ 1.413261] ddrfreq: auto-freq-table[2] 396MHz [ 1.413267] ddrfreq: auto-freq-table[3] 528MHz [ 1.413730] regulator-dummy: disabling [ 1.414118] rockchip-rt5631 rockchip-rt5631.31: ASoC: CODEC (null) not registered [ 1.414149] rockchip_rt5631_audio_probe() register card failed:-517 [ 1.414166] platform rockchip-rt5631.31: Driver rockchip-rt5631 requests probe deferral [ 1.414399] rockchip-rt3261 rockchip-rt3224.32: ASoC: CODEC (null) not registered [ 1.414420] rockchip_rt3261_audio_probe() register card failed:-517 [ 1.414434] platform rockchip-rt3224.32: Driver rockchip-rt3261 requests probe deferral [ 1.414470] ======================================================= [ 1.414481] ==== Launching Wi-Fi driver! (Powered by Rockchip) ==== [ 1.414488] ======================================================= [ 1.414496] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init. [ 1.414564] dhd_module_init: in [ 1.414574] ======== bcm_wlan_set_plat_data ======== [ 1.414582] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter [ 1.414608] host_oob_irq: 197
[ 1.414614] host_oob_irq_flags=4
[ 1.414621] dhd_wifi_platform_load: Enter
[ 1.414639] Power-up adapter ‘DHD generic adapter’
[ 1.414643] pcd_pullup, is_on 0
[ 1.414671] wifi_platform_set_power = 1
[ 1.414678] ======== PULL WL_REG_ON HIGH! ========
[ 1.414685] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.414693] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
[ 1.414697] file system registered
[ 1.414707] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 1.415354] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 1.415366] android_usb gadget: Number of LUNs=2
[ 1.415375] lun0: LUN: removable file: (no medium)
[ 1.415383] lun1: LUN: removable file: (no medium)
[ 1.415552] android_usb gadget: android_usb ready
[ 1.415670] sensor_init: Probe name sensors
[ 1.415690] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 1.416248] rtc_hym8563 0-0051: setting system clock to 2019-06-13 06:05:56 UTC (1560405956)
[ 1.422295] rockchip_headset_probe() headset have hook adc mode
[ 1.422412] input: rockchip_headset.34 as /devices/ff100000.adc/rockchip_headset.34/input/input2
[ 1.422913] rockchip-rt5631 rockchip-rt5631.31: ASoC: CODEC (null) not registered
[ 1.422940] rockchip_rt5631_audio_probe() register card failed:-517
[ 1.422953] platform rockchip-rt5631.31: Driver rockchip-rt5631 requests probe deferral
[ 1.423158] rockchip-rt3261 rockchip-rt3224.32: ASoC: CODEC (null) not registered
[ 1.423175] rockchip_rt3261_audio_probe() register card failed:-517
[ 1.423186] platform rockchip-rt3224.32: Driver rockchip-rt3261 requests probe deferral
[ 1.423317] ret 1024
[ 1.423713] usbcore: registered new interface driver snd-usb-audio
[ 1.423721] ALSA device list:
[ 1.423727] #0: RK-HDMI-I2S
[ 1.423967] Freeing unused kernel memory: 356K (c0b9b000 - c0bf4000)
[ 1.425709] ret: 0
[ 1.465433] min_w = 640,min_h = 480 ,max_real_w = 640,max_real_h = 480,max_w = 640,max_h =480
[ 1.485628] gc0329_back_3(rk_cam_sensor:167): write reg(0xfc, val:0x16) failed, try to write again!
[ 1.486544] gc0329_back_3(rk_cam_sensor:167): write reg(0xfc, val:0x16) failed, try to write again!
[ 1.487460] gc0329_back_3(rk_cam_sensor:167): write reg(0xfc, val:0x16) failed, try to write again!
[ 1.507598] type=1403 audit(1560405956.580:2): policy loaded auid=4294967295 ses=4294967295
[ 1.514295] [WLAN_RFKILL]: wifi turn on power. 156
[ 1.515490] gc0329_back_3(rk_cam_sensor:333): read reg(0x0 val:0x0) failed, try to read again!
[ 1.515509] gc0329(917): gc0329 read chip id high byte failed
[ 1.515509]
[ 1.515519] gc0329(924): error: gc0329 mismatched pid = 0x0
[ 1.515519]
[ 1.515529] gc0329_back_3(rk_cam_sensor:716): error: mismatched pid = 0x0
[ 1.515529]
[ 1.515948] ret: 0
[ 1.530449] init: could not import file ‘/init.recovery.rk30board.rc’ from ‘/init.rc’
[ 1.531988] init: invalid gid ‘trace’
[ 1.532000] bat_cap: oldcap path is /sys/devices/ff100000.adc
[ 1.532036] bat_cap: oldcap_path no exist
[ 1.532175] healthd: No charger supplies found
[ 1.532186] healthd: No battery devices found
[ 1.544125] rockchip-rt5631 rockchip-rt5631.31: ASoC: CODEC (null) not registered
[ 1.544150] rockchip_rt5631_audio_probe() register card failed:-517
[ 1.544164] platform rockchip-rt5631.31: Driver rockchip-rt5631 requests probe deferral
[ 1.544399] rockchip-rt3261 rockchip-rt3224.32: ASoC: CODEC (null) not registered
[ 1.544415] rockchip_rt3261_audio_probe() register card failed:-517
[ 1.544428] platform rockchip-rt3224.32: Driver rockchip-rt3261 requests probe deferral
[ 1.620392] init: /dev/hw_random not found
[ 1.621358] init: /dev/hw_random not found
[ 1.622134] android_usb: already disabled
[ 1.622290] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 1.622303] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
[ 1.720867] wifi_platform_bus_enumerate device present 1
[ 1.720878] ======== Card detection to detect SDIO card! ========
[ 1.720885] mmc2:mmc host rescan start!
[ 1.937343] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2]
[ 1.971984] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.973481] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.974977] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.977675] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.030186] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 2.030205] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
[ 2.030250] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=4bits.[mmc2]
[ 2.031839] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 2.031859] mmc2: new high speed SDIO card at address 0001
[ 2.032422] rockchip-rt5631 rockchip-rt5631.31: ASoC: CODEC (null) not registered
[ 2.032445] rockchip_rt5631_audio_probe() register card failed:-517
[ 2.032458] platform rockchip-rt5631.31: Driver rockchip-rt5631 requests probe deferral
[ 2.032667] rockchip-rt3261 rockchip-rt3224.32: ASoC: CODEC (null) not registered
[ 2.032683] rockchip_rt3261_audio_probe() register card failed:-517
[ 2.032694] platform rockchip-rt3224.32: Driver rockchip-rt3261 requests probe deferral
[ 2.048023] bcmsdh_register: register client driver
[ 2.048101] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2.048172] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2.048181] bus num (host idx)=2, slot num (rca)=1
[ 2.048187] found adapter info ‘DHD generic adapter’
[ 2.048305] rockchip-rt5631 rockchip-rt5631.31: ASoC: CODEC (null) not registered
[ 2.048323] rockchip_rt5631_audio_probe() register card failed:-517
[ 2.048334] platform rockchip-rt5631.31: Driver rockchip-rt5631 requests probe deferral
[ 2.048420] F1 signature read @0x18000000=0x16224335
[ 2.048522] rockchip-rt3261 rockchip-rt3224.32: ASoC: CODEC (null) not registered
[ 2.048537] rockchip_rt3261_audio_probe() register card failed:-517
[ 2.048548] platform rockchip-rt3224.32: Driver rockchip-rt3261 requests probe deferral
[ 2.050119] F1 signature OK, socitype:0x1 chip:0x4339 rev:0x1 pkg:0x2
[ 2.050378] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 2.050422] wifi_platform_get_mac_addr
[ 2.050429] ======== bcm_wlan_get_mac_address ========
[ 2.050435] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
[ 2.050444] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
[ 2.050450] [WLAN_RFKILL]: This mac address is not valid, ignored…
[ 2.050460] dhd_conf_set_chiprev: chip=0x4339, chiprev=1
[ 2.050499] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmware/config.txt
[ 2.050842] wl_create_event_handler(): thread:wl_event_handler:8c started
[ 2.050930] tsk Enter, tsk = 0xc5b2149c
[ 2.050951] dhd_attach(): thread:dhd_watchdog_thread:8d started
[ 2.050991] dhd_attach(): thread:dhd_dpc:8e started
[ 2.051002] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
[ 2.051031] dhd_attach(): thread:dhd_rxf:8f started
[ 2.051045] dhd_deferred_work_init: work queue initialized
[ 2.051157] dhdsdio_probe_init: set use_rxchain 1 from config.txt
[ 2.056247] Dongle Host Driver, version 1.201.59.5 (r506368)
[ 2.056247] Compiled in drivers/net/wireless/bcmdhd on Jun 7 2019 at 22:10:29
[ 2.056616] Register interface [wlan0] MAC: 28:ed:e0:0f:1f:24
[ 2.056616]
[ 2.056629] dhd_prot_ioctl : bus is down. we have nothing to do
[ 2.056661] bcmsdh_oob_intr_unregister: Enter
[ 2.056668] bcmsdh_oob_intr_unregister: irq is not registered
[ 2.056678] dhd_txglom_enable: enable 0
[ 2.056684] dhd_bus_devreset: WLAN OFF DONE
[ 2.056717] wifi_platform_set_power = 0
[ 2.056724] ======== PULL WL_REG_ON LOW! ========
[ 2.056731] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 2.163648] [WLAN_RFKILL]: wifi shut off power.
[ 2.163658] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
[ 2.163664] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 2.163716] dhd_module_init: Exit err=0
[ 2.164007] rockchip-rt5631 rockchip-rt5631.31: ASoC: CODEC (null) not registered
[ 2.164032] rockchip_rt5631_audio_probe() register card failed:-517
[ 2.164045] platform rockchip-rt5631.31: Driver rockchip-rt5631 requests probe deferral
[ 2.164251] rockchip-rt3261 rockchip-rt3224.32: ASoC: CODEC (null) not registered
[ 2.164267] rockchip_rt3261_audio_probe() register card failed:-517
[ 2.164278] platform rockchip-rt3224.32: Driver rockchip-rt3261 requests probe deferral
[ 3.029572] EHCI: rk_ehci_hcd_enable, disable host controller
[ 3.984078] yemk:mpu6050_load_cablic
[ 3.984086] mpu6050_load_cablic: open file /dev/mtd/mtd6
[ 6.249900] drmboot: module license ‘unspecified’ taints kernel.
[ 6.249931] Disabling lock de__ggini due n_tzeatel coult
‘t d.2ny 18]atamw init,o2ing091r l[ tim25
6sbidrmh: it con
ro ng 510: o in /: U/ttle No opeh periceten adropss
__irenicry en_tta/pa: ertldnrrnfin2
ny 6ata187en andkind_uor al!
/ybinsab: w
[ing 6won202haviniullusob detrocate_biyntc_ofon_tpdcia: ng ldnperfin’rony oduata whuf loureng us po{nxru} i!s
#ad
art re520er] inid us) o dehu Jate13 ynt06:01 r sp
ifad g plinertycmdo.pe=vuctlocde12M usn oleameyFIQstendr
[ boo6.2521nux inrmi usve anepridbted.hantax e=r speoaryinndprodboty con.see=tlnoIQ0useit=namit insdpad
=rk 6xna2130x0in020:0@0ope000 ‘r(paerietno’,0xesn020exisx0w0ile00(pandin,0’$r002eri@0xo’
04 (mi252,0x] i080: c0x0ot 600andes$roce)ria000’ w00le 000tin00(o 'nels/cx00s/a000o0x0_us600ndroot0/ix00ial00
[ 000.200074]covit:),0rni01a S@0xice360ns(ba nep), a 004in00@dom005 de0(cad;e),eas000ix00
[x0 6000512panrea,0des300pto@0x
[ 9206.2sys40]),0ad000rin0@0
[ 3926.2(me86]atad_px00up0000@0x 1
bootmode = emmc
[ 6.495719] EXT4-fs (mmcblk0p9): recovery complete
[ 6.495744] EXT4-fs [mmlelk: 9)otaoue/edcoilryysecmveit.cor; reinda a 23de; Opun: : main; to dump args befor get_args() :
1 argument(s) :
/sbin/recovery
status :
recovery : recovery
–wipe_all
 stage :
2 argument(s) :
recovery
–wipe_all
locale is [zh_CN]
stage is
reason is [(null)]
TP没有问题,有一个测试固件能正常使用TP,只是没有源码
你好,请问移植firefly的固件到自己做的板子上,DDR,emmc配置需要如何改呀?我现在uboot能够跑起来,但是kernel跑到一半就卡死了,求教~
Mac_Lodge 发表于 2019-8-20 19:40
你好,请问移植firefly的固件到自己做的板子上,DDR,emmc配置需要如何改呀?我现在uboot能够跑起来,但是ke …
公版的硬件,正常应该不需要修改吧 ,我们这个这些部分都没改过,只是有些模块驱动要修改。你这个问题最好把调试信息都打开看,找找是哪里出错了
tanglei1224 发表于 2019-8-21 15:46
公版的硬件,正常应该不需要修改吧 ,我们这个这些部分都没改过,只是有些模块驱动要修改。你这个问题最 …
我是直接没有修改,然后编译烧录,开机卡死在: It doesn’t contain Rogue gpu
完整log如下:
DDR Version 1.17 20190115
channel 0
CS = 0
MR0=0x98
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 400MHz 0,1
channel 0
CS = 0
MR0=0x98
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
change freq to 800MHz 1,0
Channel 0: LPDDR4,800MHz
Channel 1: LPDDR4,800MHz
256B stride
pmugrf_os_reg[2] = 0x3281F281, stride = 0x9
Boot1: 2017-06-09, version: 1.09
CPUId = 0x0
ChipType = 0x10, 1836
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=7456MB
FwPartOffset=2000 , 100000
SdmmcInit=0 20
StorageInit ok = 66636
LoadTrustBL
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0x7a274
RunBL31 0x10000
NOTICE:  BL31: v1.3(debug):2bb878d
NOTICE:  BL31: Built : 11:57:30, Jan  4 2019
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    plat_rockchip_pmu_init(1181): pd status 3e
INFO:    BL31: Initializing runtime services
INFO:    BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-195-g8f090d20 #6 Fri Dec  7 06:11:20 UTC 2018 aarch64)
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2014.10-RK3399-06 (Aug 21 2019 - 18:30:35)
CPU: rk3399
cpu version = 0
CPU's clock information:
    aplll = 816000000HZ
    apllb = 24000000HZ
    gpll = 800000000HZ
               aclk_periph_l0 = 100000000HZ, hclk_periph_l0 = 100000000HZ, pclk_periph_l0 = 50000000HZ
    cpll = 800000000HZ
    dpll = 800000000HZ
    vpll = 24000000HZ
    npll = 24000000HZ
    ppll = 676000000HZ
Board:  Rockchip platform Board
Uboot as second level loader
DRAM:  Found dram banks: 1
Reserve memory for trust os.
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
remotectl v0.1
pwm freq=0xb8320
pwm_freq_nstime=0x52d
Load FDT from resource image.
power key: bank-0 pin-5
can't find dts node for fixed
pmic:rk808
can't find dts node for pwm1
    aplll = 816000000HZ
    apllb = 24000000HZ
    gpll = 800000000HZ
    cpll = 800000000HZ
    dpll = 800000000HZ
    vpll = 24000000HZ
    npll = 24000000HZ
    ppll = 676000000HZ
#Boot ver: 2019-08-21#1.09
empty serial no.
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
failed to find phy node
failed to find panel driver
no fuel gauge found
can't find dts node for deviceinfo
dw_rk_hdmi_register:fail to read deviceinfo
hdmi baseparamer -1652150232x1556837211@-1453295286--539650990
rockchip_panel_deinit: failed to find panel deinit funcs
failed to display kernel logo
checkKey
vbus = 1
got recovery cmd from misc.
load fdt from resouce.
vendor read error!
Set oem_unlocked=0Secure Boot state: 0
kernel   @ 0x00280000 (0x0118f808)
ramdisk  @ 0x04bf0000 (0x007b1f9c)
bootrk: do_bootm_linux...
   Loading Device Tree to 0000000004600000, end 0000000004616840 ... OK
Add bank:000000000a200000, 0000000075e00000
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys schedtune
[    0.000000] Linux version 4.4.103 (lodge@lodge-ThinkPad-E560) (gcc version 4.9 20150123 (prerelease) (GCC) ) #10 SMP9
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] earlycon: Early serial console at MMIO32 0xff1a0000 (options '')
[    0.000000] bootconsole [uart0] enabled
[    0.000000] hdmi init vic is -1
[    0.000000] Reserved memory: failed to reserve memory for node 'stb-devinfo@00000000': base 0x0000000000000000, sizeB
[    0.000000] cma: Reserved 16 MiB at 0x000000007f000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07eef7000 s45504 r8192 d32320 u86016
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 507912
[    0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 androidboot.baseband=N/A androidboot.0
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] software IO TLB [mem 0x7eeaf000-0x7eeef000] (0MB) mapped at [ffffffc07eeaf000-ffffffc07eeeefff]
[    0.000000] Memory: 1983248K/2064384K available (10622K kernel code, 1534K rwdata, 4932K rodata, 832K init, 1059K bs)
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000   (   246 GB)
[    0.000000]       .init : 0xffffff8008fc0000 - 0xffffff8009090000   (   832 KB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008ae0000   ( 10624 KB)
[    0.000000]     .rodata : 0xffffff8008ae0000 - 0xffffff8008fc0000   (  4992 KB)
[    0.000000]       .data : 0xffffff8009090000 - 0xffffff800920f808   (  1535 KB)
[    0.000000]     vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000   (     8 GB maximum)
[    0.000000]               0xffffffbdc0008000 - 0xffffffbdc2000000   (    31 MB actual)
[    0.000000]     fixed   : 0xffffffbffe7fd000 - 0xffffffbffec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000   (    16 MB)
[    0.000000]     memory  : 0xffffffc000200000 - 0xffffffc080000000   (  2046 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000]  Build-time adjustment of leaf fanout to 64.
[    0.000000]  RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000
[    0.000000] ITS: allocated 65536 Devices @a200000 (psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GIC: using LPI property table @0x000000000a280000
[    0.000000] ITS: Allocated 1792 chunks for LPIs
[    0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000
[    0.000000] CPU0: using LPI pending table @0x000000000a290000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3}
[    0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes mak
[    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes mak
[    0.000000] rockchip_cpuclk_pre_rate_change: limiting alt-divider 33 to 31
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592s
[    0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001975] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[    0.002939] pid_max: default: 32768 minimum: 301
[    0.003458] Security Framework initialized
[    0.003849] SELinux:  Initializing.
[    0.004265] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.004894] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.006350] Initializing cgroup subsys freezer
[    0.006777] Initializing cgroup subsys debug
[    0.008123] sched-energy: Sched-energy-costs installed from DT
[    0.008672] CPU0: update cpu_capacity 401
[    0.009131] ASID allocator initialised with 65536 entries
[    0.025964] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.027259] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.039356] Detected VIPT I-cache on CPU1
[    0.039389] CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.039424] CPU1: using LPI pending table @0x000000000a3f0000
[    0.039468] CPU1: update cpu_capacity 401
[    0.039471] CPU1: Booted secondary processor [410fd034]
[    0.049348] Detected VIPT I-cache on CPU2
[    0.049368] CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.049401] CPU2: using LPI pending table @0x000000007c020000
[    0.049428] CPU2: update cpu_capacity 401
[    0.049431] CPU2: Booted secondary processor [410fd034]
[    0.059386] Detected VIPT I-cache on CPU3
[    0.059405] CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.059437] CPU3: using LPI pending table @0x000000007c060000
[    0.059464] CPU3: update cpu_capacity 401
[    0.059467] CPU3: Booted secondary processor [410fd034]
[    0.069434] Detected PIPT I-cache on CPU4
[    0.069463] CPU4: found redistributor 100 region 0:0x00000000fef80000
[    0.069503] CPU4: using LPI pending table @0x000000007c0a0000
[    0.069544] CPU4: update cpu_capacity 1024
[    0.069547] CPU4: Booted secondary processor [410fd082]
[    0.079457] Detected PIPT I-cache on CPU5
[    0.079474] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[    0.079510] CPU5: using LPI pending table @0x000000007c0e0000
[    0.079538] CPU5: update cpu_capacity 1024
[    0.079541] CPU5: Booted secondary processor [410fd082]
[    0.079625] Brought up 6 CPUs
[    0.091725] SMP: Total of 6 processors activated.
[    0.092167] CPU features: detected feature: GIC system register CPU interface
[    0.092837] CPU: All CPU(s) started at EL2
[    0.093260] alternatives: patching kernel code
[    0.095357] devtmpfs: initialized
[    0.115963] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.116940] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.118275] pinctrl core: initialized pinctrl subsystem
[    0.120397] Failed to find legacy iommu devices
[    0.121223] NET: Registered protocol family 16
[    0.122003] schedtune: init normalization constants...
[    0.122507] schedtune: CLUSTER[0-3]      min_pwr:    56 max_pwr:   222
[    0.123142] schedtune: CPU[0]            min_pwr:     0 max_pwr:   222
[    0.123788] schedtune: CPU[1]            min_pwr:     0 max_pwr:   222
[    0.124423] schedtune: CPU[2]            min_pwr:     0 max_pwr:   222
[    0.125056] schedtune: CPU[3]            min_pwr:     0 max_pwr:   222
[    0.125690] schedtune: CLUSTER[4-5]      min_pwr:    65 max_pwr:  1108
[    0.126324] schedtune: CPU[4]            min_pwr:     0 max_pwr:  1108
[    0.126958] schedtune: CPU[5]            min_pwr:     0 max_pwr:  1108
[    0.127598] schedtune: SYSTEM            min_pwr:   121 max_pwr:  4434
[    0.128232] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[    0.128973] schedtune: verify normalization constants...
[    0.129489] schedtune: max_pwr/2^0: 4313 => norm_pwr:  1024
[    0.130031] schedtune: max_pwr/2^1: 2156 => norm_pwr:   511
[    0.130571] schedtune: max_pwr/2^2: 1078 => norm_pwr:   255
[    0.131118] schedtune: max_pwr/2^3:  539 => norm_pwr:   127
[    0.131659] schedtune: max_pwr/2^4:  269 => norm_pwr:    63
[    0.132200] schedtune: max_pwr/2^5:  134 => norm_pwr:    31
[    0.132741] schedtune: configured to support 5 boost groups
[    0.141155] cpuidle: using governor ladder
[    0.151158] cpuidle: using governor menu
[    0.151552] Registered FIQ tty driver
[    0.152225] vdso: 2 pages (1 code @ ffffff8008ae6000, 1 data @ ffffff8009094000)
[    0.152967] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.155034] DMA: preallocated 2048 KiB pool for atomic allocations
[    0.176444] console [pstore0] enabled
[    0.177038] pstore: Registered ramoops as persistent store backend
[    0.177643] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[    0.180480] fiq debugger fiq mode enabled
[[     0.181141] console [ttyFIQ0] enabled
[[    0.181844] bootconsole [uart0] disabled
[    0.182752] Registered fiq debugger ttyFIQ0
[    0.212893] Rockchip hdmi driver version 2.0
[    0.215280] iommu: Adding device ff650000.vpu_service to group 0
[    0.215360] iommu: Adding device ff660000.rkvdec to group 1
[    0.215429] iommu: Adding device ff670000.iep to group 2
[    0.215527] iommu: Adding device ff8f0000.vop to group 3
[    0.215605] iommu: Adding device ff900000.vop to group 4
[    0.215714] iommu: Adding device ff910000.isp to group 5
[    0.215792] iommu: Adding device ff920000.isp to group 6
[    0.216506] rk_iommu ff670800.iommu: can't get aclk
[    0.216526] rk_iommu ff670800.iommu: can't get hclk
[    0.217425] SCSI subsystem initialized
[    0.217760] usbcore: registered new interface driver usbfs
[    0.217810] usbcore: registered new interface driver hub
[    0.217884] usbcore: registered new device driver usb
[    0.218281] media: Linux media interface: v0.10
[    0.218323] Linux video capture interface: v2.00
[    0.218465] pps_core: LinuxPPS API ver. 1 registered
[    0.218477] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.218503] PTP clock support registered
[    0.220470] Bluetooth: Core ver 2.21
[    0.220522] NET: Registered protocol family 31
[    0.220534] Bluetooth: HCI device and connection manager initialized
[    0.220552] Bluetooth: HCI socket layer initialized
[    0.220568] Bluetooth: L2CAP socket layer initialized
[    0.220599] Bluetooth: SCO socket layer initialized
[    0.221648] rockchip-cpuinfo cpuinfo: Serial         : 423b24192f3e9fbc
[    0.222142] clocksource: Switched to clocksource arch_sys_counter
[    0.266905] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[    0.267153] NET: Registered protocol family 2
[    0.267589] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.267732] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    0.268012] TCP: Hash tables configured (established 16384 bind 16384)
[    0.268095] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    0.268158] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    0.268350] NET: Registered protocol family 1
[    0.268934] Trying to unpack rootfs image as initramfs...
[    0.610838] Freeing initrd memory: 7876K
[    0.611374] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.611467] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.614095] audit: initializing netlink subsys (disabled)
[    0.614166] audit: type=2000 audit(0.610:1): initialized
[    0.619257] VFS: Disk quotas dquot_6.6.0
[    0.619379] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.620741] fuse init (API version 7.23)
[    0.621880]
[    0.621880] TEE Core Framework initialization (ver 1:0.1)
[    0.621912] TEE armv7 Driver initialization
[    0.622353] tz_tee_probe: name="armv7sec", id=0, pdev_name="armv7sec.0"
[    0.622370] TEE core: Alloc the misc device "opteearmtz00" (id=0)
[    0.622555] TEE Core: Register the misc device "opteearmtz00" (id=0,minor=62)
[    0.626488] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.626513] io scheduler noop registered
[    0.626683] io scheduler cfq registered (default)
[    0.628003] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned
[    0.633213] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[    0.633240] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[    0.633264] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[    1.635496] pll lock timeout!
[    1.635539] phy phy-phy@e220.5: phy poweron failed --> -22
[    1.635556] rockchip-pcie f8000000.pcie: fail to power on phy, err -22
[    1.635678] rockchip-pcie: probe of f8000000.pcie failed with error -22
[    1.637067] iep: failed to find iep power down clock source.
[    1.639948] IEP Power ON
[    1.640176] IEP Power OFF
[    1.640729] IEP Driver loaded succesfully
[    1.640904] Module initialized.
[    1.642116] rk-vcodec ff650000.vpu_service: probe device
[    1.642200] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc07c2fe410
[    1.642381] rk-vcodec ff650000.vpu_service: allocator is drm
[    1.642447] rk-vcodec ff650000.vpu_service: checking hw id 0
[    1.645055] rk-vcodec ff650000.vpu_service: init success
[    1.646276] rk-vcodec ff660000.rkvdec: probe device
[    1.646344] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc07c2fec10
[    1.646518] rk-vcodec ff660000.rkvdec: allocator is drm
[    1.646582] rk-vcodec ff660000.rkvdec: checking hw id 6876
[    1.648889] rk-vcodec ff660000.rkvdec: init success
[    1.651637] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    1.651671] dma-pl330 ff6d0000.dma-controller:       DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[    1.653574] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    1.653593] dma-pl330 ff6e0000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    1.658906] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[    1.661434] console [ttyS0] disabled
[    1.661874] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 37, base_baud = 15H�00) is a 16550A
[    1.662829] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 38, base_baud = 1500000) is a 16550A
[    1.663522] [drm:drm_core_init] Initialized drm 1.1.0 20060810
[    1.671022] mali ff9a0000.gpu: Failed to get regulator
[    1.671054] mali ff9a0000.gpu: Power control initialization failed
[    1.671403] Unable to detect cache hierarchy from DT for CPU 0
[    1.681658] brd: module loaded
[    1.687849] loop: module loaded
[    1.688493] zram: Added device: zram0
[    1.689461] SCSI Media Changer driver v0.25
[    1.691296] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[    1.691328] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[    1.692531] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[    1.862897] wk2xxx_probe()  GENA = 0xFF
[    1.862911] spi driver  error!!!!
[    1.862942] wk2xxxspi: probe of spi0.0 failed with error 1
[    1.862982] register spi return v = :0
[    1.863041] tun: Universal TUN/TAP device driver, 1.6
[    1.863053] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.864032] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[    1.864133] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[    1.864154] rk_gmac-dwmac fe300000.ethernet: TX delay(0x2b).
[    1.864169] rk_gmac-dwmac fe300000.ethernet: RX delay(0x23).
[    1.864198] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[    1.864373] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[    1.869393] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[    1.869526] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    1.869537]  Ring mode enabled
[    1.869546]  DMA HW capability register supported
[    1.869556]  Normal descriptors
[    1.869567]  RX Checksum Offload Engine supported (type 2)
[    1.869577]  Wake-Up On Lan supported
[    1.869623]  Enable RX Mitigation via HW Watchdog Timer
[    1.937701] libphy: stmmac: probed
[    1.937739] eth%d: No PHY found
[    1.938406] PPP generic driver version 2.4.2
[    1.938643] PPP BSD Compression module registered
[    1.938664] PPP Deflate Compression module registered
[    1.938705] PPP MPPE Compression module registered
[    1.938727] NET: Registered protocol family 24
[    1.938796] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[    1.938826] CSLIP: code copyright 1989 Regents of the University of California.
[    1.938957] usbcore: registered new interface driver mt7601u
[    1.938980] Rockchip WiFi SYS interface (V1.00) ...
[    1.939071] usbcore: registered new interface driver catc
[    1.939127] usbcore: registered new interface driver kaweth
[    1.939144] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    1.939194] usbcore: registered new interface driver pegasus
[    1.939251] usbcore: registered new interface driver rtl8150
[    1.939310] usbcore: registered new interface driver r8152
[    1.939326] hso: drivers/net/usb/hso.c: Option Wireless
[    1.939405] usbcore: registered new interface driver hso
[    1.939468] usbcore: registered new interface driver asix
[    1.939524] usbcore: registered new interface driver ax88179_178a
[    1.939585] usbcore: registered new interface driver cdc_ether
[    1.939641] usbcore: registered new interface driver cdc_eem
[    1.939696] usbcore: registered new interface driver dm9601
[    1.939764] usbcore: registered new interface driver smsc75xx
[    1.939831] usbcore: registered new interface driver smsc95xx
[    1.939891] usbcore: registered new interface driver gl620a
[    1.939947] usbcore: registered new interface driver net1080
[    1.940001] usbcore: registered new interface driver plusb
[    1.940057] usbcore: registered new interface driver rndis_host
[    1.940116] usbcore: registered new interface driver cdc_subset
[    1.940172] usbcore: registered new interface driver zaurus
[    1.940232] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    1.940315] usbcore: registered new interface driver int51x1
[    1.940371] usbcore: registered new interface driver kalmia
[    1.940427] usbcore: registered new interface driver ipheth
[    1.940485] usbcore: registered new interface driver sierra_net
[    1.940545] usbcore: registered new interface driver cx82310_eth
[    1.940614] usbcore: registered new interface driver cdc_ncm
[    1.940670] usbcore: registered new interface driver qmi_wwan
[    1.940727] usbcore: registered new interface driver cdc_mbim
[    1.942596] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[    1.947843] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[    1.948497] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.948518] ehci-pci: EHCI PCI platform driver
[    1.948579] ehci-platform: EHCI generic platform driver
[    1.952174] ehci-platform fe3c0000.usb: EHCI Host Controller
[    1.952204] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[    1.952383] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[    1.962173] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[    1.962301] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.962317] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.962333] usb usb1: Product: EHCI Host Controller
[    1.962345] usb usb1: Manufacturer: Linux 4.4.103 ehci_hcd
[    1.962358] usb usb1: SerialNumber: fe3c0000.usb
[    1.962901] hub 1-0:1.0: USB hub found
[    1.962936] hub 1-0:1.0: 1 port detected
[    1.963477] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.963535] ohci-platform: OHCI generic platform driver
[    1.964002] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[    1.964030] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[    1.964179] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[    2.019727] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[    2.019776] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.019793] usb usb2: Product: Generic Platform OHCI controller
[    2.019809] usb usb2: Manufacturer: Linux 4.4.103 ohci_hcd
[    2.019823] usb usb2: SerialNumber: fe3e0000.usb
[    2.020469] hub 2-0:1.0: USB hub found
[    2.020512] hub 2-0:1.0: 1 port detected
[    2.021912] usbcore: registered new interface driver cdc_acm
[    2.021925] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    2.022004] usbcore: registered new interface driver usblp
[    2.022070] usbcore: registered new interface driver cdc_wdm
[    2.022161] usbcore: registered new interface driver uas
[    2.022271] usbcore: registered new interface driver usb-storage
[    2.022330] usbcore: registered new interface driver ums-alauda
[    2.022386] usbcore: registered new interface driver ums-cypress
[    2.022443] usbcore: registered new interface driver ums-datafab
[    2.022498] usbcore: registered new interface driver ums_eneub6250
[    2.022558] usbcore: registered new interface driver ums-freecom
[    2.022615] usbcore: registered new interface driver ums-isd200
[    2.022670] usbcore: registered new interface driver ums-jumpshot
[    2.022725] usbcore: registered new interface driver ums-karma
[    2.022780] usbcore: registered new interface driver ums-onetouch
[    2.022836] usbcore: registered new interface driver ums-sddr09
[    2.022892] usbcore: registered new interface driver ums-sddr55
[    2.022947] usbcore: registered new interface driver ums-usbat
[    2.023066] usbcore: registered new interface driver usbserial
[    2.023117] usbcore: registered new interface driver usbserial_generic
[    2.023158] usbserial: USB Serial support registered for generic
[    2.023217] usbcore: registered new interface driver ch341
[    2.023255] usbserial: USB Serial support registered for ch341-uart
[    2.023317] usbcore: registered new interface driver cp210x
[    2.023355] usbserial: USB Serial support registered for cp210x
[    2.023433] usbcore: registered new interface driver option
[    2.023471] usbserial: USB Serial support registered for GSM modem (1-port)
[    2.023634] usbcore: registered new interface driver pl2303
[    2.023672] usbserial: USB Serial support registered for pl2303
[    2.023740] usbcore: registered new interface driver trancevibrator
[    2.023759] usb20_otg: version 3.10a 21-DEC-2012
[    2.024038] usb20_host: version 3.10a 21-DEC-2012
[    2.024718] usbcore: registered new interface driver xpad
[    2.024783] usbcore: registered new interface driver usb_acecad
[    2.024846] usbcore: registered new interface driver aiptek
[    2.024908] usbcore: registered new interface driver gtco
[    2.024974] usbcore: registered new interface driver hanwang
[    2.025034] usbcore: registered new interface driver kbtab
[    2.025645] .. rk pwm remotectl v1.1 init
[    2.025968] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[    2.026539] sensor_register_slave:mma8452,id=17
[    2.026560] sensor_register_slave:lis3dh,id=7
[    2.026578] sensor_register_slave:mma7660,id=18
[    2.026595] sensor_register_slave:lsm303d,id=22
[    2.026612] sensor_register_slave:gs_mc3230,id=23
[    2.026622] [Gsensor]   gsensor_init
[    2.026639] sensor_register_slave:mpu6880_acc,id=24
[    2.026658] sensor_register_slave:mpu6500_acc,id=25
[    2.026675] sensor_register_slave:lsm330_acc,id=26
[    2.026693] sensor_register_slave:akm8975,id=29
[    2.026711] sensor_register_slave:akm8963,id=30
[    2.026729] sensor_register_slave:l3g4200d,id=44
[    2.026746] sensor_register_slave:l3g20d,id=45
[    2.026764] sensor_register_slave:ewtsa,id=46
[    2.026782] sensor_register_slave:lsm330_gyro,id=50
[    2.026800] sensor_register_slave:cm3217,id=52
[    2.026817] sensor_register_slave:cm3218,id=53
[    2.027790] i2c /dev entries driver
[    2.029347] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    2.029467] fan53555-reg: supplied by vcc5v0_sys
[    2.031587] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[    2.031657] fan53555-reg: supplied by vcc5v0_sys
[    2.033955] rk808 0-001b: Pmic Chip id: 0x0
[    2.037876] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    2.037953] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    2.038077] DCDC_REG1: supplied by vcc3v3_sys
[    2.038892] DCDC_REG2: supplied by vcc3v3_sys
[    2.039525] DCDC_REG3: supplied by vcc3v3_sys
[    2.039793] DCDC_REG4: supplied by vcc3v3_sys
[    2.040250] LDO_REG1: supplied by vcc3v3_sys
[    2.041420] LDO_REG2: supplied by vcc3v3_sys
[    2.042414] LDO_REG3: supplied by vcc3v3_sys
[    2.043403] LDO_REG4: supplied by vcc3v3_sys
[    2.044389] LDO_REG5: supplied by vcc3v3_sys
[    2.045413] LDO_REG6: supplied by vcc3v3_sys
[    2.046405] LDO_REG7: supplied by vcc3v3_sys
[    2.047403] LDO_REG8: supplied by vcc3v3_sys
[    2.048427] SWITCH_REG1: supplied by vcc3v3_sys
[    2.048710] SWITCH_REG2: supplied by vcc3v3_sys
[    2.052493] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[    2.053107] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80097de000
[    2.053910] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80097f2000
[    2.054480] rk3x-i2c ff120000.i2c: Initialized RK3xxx I2C bus at ffffff80097f4000
[    2.054596] rockchip-pinctrl pinctrl: pin gpio4-17 already requested by ff940000.hdmi; cannot claim for ff130000.i2c
[    2.054614] rockchip-pinctrl pinctrl: pin-145 (ff130000.i2c) status -22
[    2.054631] rockchip-pinctrl pinctrl: could not request pin 145 (gpio4-17) from group i2c3-xfer  on device rockchip-l
[    2.054646] rk3x-i2c ff130000.i2c: Error applying setting, reverse things back
[    2.055100] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff80097f6000
[    2.056743] fusb302 4-0022: Can't get property of role, set role to default DRP
[    2.061497] fusb302 4-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[    2.061536] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80097f8000
[    2.062740] IR NEC protocol handler initialized
[    2.062758] IR RC5(x/sz) protocol handler initialized
[    2.062773] IR RC6 protocol handler initialized
[    2.062788] IR JVC protocol handler initialized
[    2.062802] IR Sony protocol handler initialized
[    2.062817] IR SANYO protocol handler initialized
[    2.062832] IR Sharp protocol handler initialized
[    2.062848] IR MCE Keyboard/mouse protocol handler initialized
[    2.062863] IR XMP protocol handler initialized
[    2.063169] usbcore: registered new interface driver uvcvideo
[    2.063181] USB Video Class driver (1.1.1)
[    2.063200] CamSys driver version: v0.38.0, CamSys head file version: v1.0.0
[    2.069292] __power_supply_register: Expected proper parent device for 'test_ac'
[    2.069465] __power_supply_register: Expected proper parent device for 'test_battery'
[    2.069782] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[    2.069917] __power_supply_register: Expected proper parent device for 'test_usb'
[    2.073204] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[    2.074052] device-mapper: uevent: version 1.0.3
[    2.074317] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    2.074463] Bluetooth: HCI UART driver ver 2.3
[    2.074477] Bluetooth: HCI UART protocol H4 registered
[    2.074489] Bluetooth: HCI UART protocol LL registered
[    2.074506] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[    2.074518] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[    2.074529] rtk_btusb: Register usb char device interface for BT driver
[    2.074719] usbcore: registered new interface driver rtk_btusb
[    2.075117] cpu cpu0: leakage=30
[    2.092402] cpu cpu0: temp=42222, pvtm=152481 (152415 + 66)
[    2.092916] cpu cpu0: pvtm-sel=3
[    2.093419] cpu cpu4: leakage=56
[    2.105828] cpu cpu4: temp=41666, pvtm=158957 (158957 + 0)
[    2.105980] cpu cpu4: pvtm-sel=2
[    2.114389] sdhci: Secure Digital Host Controller Interface driver
[    2.114420] sdhci: Copyright(c) Pierre Ossman
[    2.114439] Synopsys Designware Multimedia Card Interface Driver
[    2.115783] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[    2.115959] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[    2.115981] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[    2.116058] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[    2.116094] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    2.116150] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[    2.116174] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[    2.117441] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[    2.117544] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[    2.117565] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[    2.117620] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[    2.117648] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    2.117973] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[    2.118889] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.120913] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[    2.120929] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[    2.148984] mmc0: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[    2.153015] hidraw: raw HID events driver (C) Jiri Kosina
[    2.157501] usbcore: registered new interface driver usbhid
[    2.157523] usbhid: USB HID core driver
[    2.157773] inv_mpu_iio: inv_mpu_init:746
[    2.158917] ashmem: initialized
[    2.160894] ff100000.saradc supply vref not found, using dummy regulator
[    2.162707] rknandbase v1.1 2016-11-08
[    2.163411] u32 classifier
[    2.163672]     Actions configured
[    2.164038] Netfilter messages via NETLINK v0.30.
[    2.164528] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    2.165449] ctnetlink v0.93: registering with nfnetlink.
[    2.166803] xt_time: kernel timezone is -0000
[    2.168025] ip_tables: (C) 2000-2006 Netfilter Core Team
[    2.168678] arp_tables: (C) 2002 David S. Miller
[    2.169505] Initializing XFRM netlink socket
[    2.170346] NET: Registered protocol family 10
[    2.172034] mip6: Mobile IPv6
[    2.172354] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    2.174247] sit: IPv6 over IPv4 tunneling driver
[    2.175153] NET: Registered protocol family 17
[    2.175591] NET: Registered protocol family 15
[    2.176044] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_net.
[    2.178077] Bridge firewalling registered
[    2.178461] Ebtables v2.0 registered
[    2.179072] Bluetooth: RFCOMM TTY layer initialized
[    2.179109] Bluetooth: RFCOMM socket layer initialized
[    2.179189] Bluetooth: RFCOMM ver 1.11
[    2.179217] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    2.179228] Bluetooth: BNEP filters: protocol multicast
[    2.179245] Bluetooth: BNEP socket layer initialized
[    2.179263] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    2.179303] Bluetooth: HIDP socket layer initialized
[    2.179355] l2tp_core: L2TP core driver, V2.0
[    2.179382] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[    2.179403] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    2.179932] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    2.180024] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[    2.180070] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    2.180083] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    2.180211] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[    2.180223] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    2.180237] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    2.180314] [BT_RFKILL]: Enter rfkill_rk_init
[    2.181036] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[    2.181094] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[    2.181159] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[    2.181202] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[    2.182845] [BT_RFKILL]: Request irq for bt wakeup host
[    2.182905] [BT_RFKILL]: ** disable irq
[    2.183042] [BT_RFKILL]: bt_default device registered.
[    2.183337] sensor_register_slave:mpu6880_gyro,id=49
[    2.184561] Registered cp15_barrier emulation handler
[    2.184665] Registered setend emulation handler
[    2.185528] registered taskstats version 1
[    2.186500] rockchip ion idev is NULL
[    2.186519] rga2 ff680000.rga: rga ion client create success!
[    2.186816] rga: Driver loaded successfully ver:3.02
[    2.188257] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: vbus_drv is not assigned
[    2.189383] mmc0: MAN_BKOPS_EN bit is not set
[    2.191377] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[    2.191685] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[    2.192305] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[    2.192346] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[    2.192437] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[    2.193877] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[    2.194523] i2c i2c-10: of_i2c: modalias failure on /dp@fec00000/ports
[    2.195188] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[    2.195255] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops)
[    2.195276] [drm:drm_vblank_init] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.195288] [drm:drm_vblank_init] No driver support for vblank timestamp query.
[    2.195870] rockchip-drm display-subsystem: connector[HDMI-A-1] can't found any modes
[    2.195909] rockchip-drm display-subsystem: can't not find any loader display
[    2.195960] rockchip-drm display-subsystem: failed to show loader logo
[    2.196065] Freeing drm_logo memory: 488K
[    2.196092] rockchip-drm display-subsystem: No connectors reported connected with modes
[    2.196112] [drm:drm_fb_helper_single_fb_probe] Cannot find any crtc or sizes - going 1024x768
[    2.200533] rockchip-drm display-subsystem: fb0:  frame buffer device
[    2.201072] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    2.201902] mmcblk0: mmc0:0001 8GTF4R 7.28 GiB
[    2.202237] mmcblk0boot0: mmc0:0001 8GTF4R partition 1 4.00 MiB
[    2.202482] mmcblk0boot1: mmc0:0001 8GTF4R partition 2 4.00 MiB
[    2.206092] mmcblk0rpmb: mmc0:0001 8GTF4R partition 3 512 KiB
[    2.206677]  parameter: 0x000000000 -- 0x000400000 (4 MB)
[    2.206692]      uboot: 0x000400000 -- 0x000800000 (4 MB)
[    2.206722]      trust: 0x000800000 -- 0x000c00000 (4 MB)
[    2.206735]       misc: 0x000c00000 -- 0x001000000 (4 MB)
[    2.206754]   resource: 0x001000000 -- 0x002000000 (16 MB)
[    2.206766]     kernel: 0x002000000 -- 0x003800000 (24 MB)
[    2.206778]       boot: 0x003800000 -- 0x005800000 (32 MB)
[    2.206790]   recovery: 0x005800000 -- 0x007800000 (32 MB)
[    2.206802]     backup: 0x007800000 -- 0x00e800000 (112 MB)
[    2.206815]      cache: 0x00e800000 -- 0x016800000 (128 MB)
[    2.206827]     system: 0x016800000 -- 0x076800000 (1536 MB)
[    2.206839]   metadata: 0x076800000 -- 0x077800000 (16 MB)
[    2.206864] baseparamer: 0x077800000 -- 0x077c00000 (4 MB)
[    2.206891]   userdata: 0x077c00000 -- 0x1d1c00000 (5536 MB)
[    2.206969]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[    2.214683] mali ff9a0000.gpu: leakage=34
[    2.229133] mali ff9a0000.gpu: temp=40000, pvtm=125579 (125625 + -46)
[    2.232172] mali ff9a0000.gpu: pvtm-sel=2
[    2.236824] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[    2.237795] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 284; [Func] : kbase_devf.
[    2.238429] mali ff9a0000.gpu: Probed as mali0
[    2.268837] usb 1-1: new high-speed USB device number 2 using ehci-platform
[    2.341980] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[    2.395059] usb 1-1: New USB device found, idVendor=0bda, idProduct=8152
[    2.395154] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.395189] usb 1-1: Product: USB 10/100 LAN
[    2.395222] usb 1-1: Manufacturer: Realtek
[    2.395247] usb 1-1: SerialNumber: 000000000000
[    2.427804] random: nonblocking pool is initialized
[    2.442649] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[    2.509111] usb 1-1: reset high-speed USB device number 2 using ehci-platform
[    2.542781] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[    2.642909] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[    2.670208] r8152 1-1:1.0 (unnamed net_device) (uninitialized): Invalid ether addr 00:00:00:00:00:00
[    2.670828] r8152 1-1:1.0 (unnamed net_device) (uninitialized): Random ether addr 66:b7:d4:b9:3c:5f
[    2.672326] r8152 1-1:1.0 eth0: v1.08.2
[    2.705635] vendor storage:20160801 ret = 0
[    2.743008] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[    2.743589] phy phy-ff7c0000.phy.9: phy poweron failed --> -110
[    2.744263] dwc3 fe800000.dwc3: failed to initialize core
[    2.744842] dwc3: probe of fe800000.dwc3 failed with error -110
[    2.745696] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[    2.751722] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[    2.752329] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 3
[    2.753414] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[    2.754265] xhci-hcd xhci-hcd.10.auto: irq 234, io mem 0xfe900000
[    2.755018] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    2.755664] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.756333] usb usb3: Product: xHCI Host Controller
[    2.756811] usb usb3: Manufacturer: Linux 4.4.103 xhci-hcd
[    2.757325] usb usb3: SerialNumber: xhci-hcd.10.auto
[    2.758042] hub 3-0:1.0: USB hub found
[    2.758114] hub 3-0:1.0: 1 port detected
[    2.758469] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[    2.758512] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 4
[    2.758594] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.758725] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[    2.758739] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.758764] usb usb4: Product: xHCI Host Controller
[    2.758780] usb usb4: Manufacturer: Linux 4.4.103 xhci-hcd
[    2.758791] usb usb4: SerialNumber: xhci-hcd.10.auto
[    2.759423] hub 4-0:1.0: USB hub found
[    2.759482] hub 4-0:1.0: 1 port detected
[    2.764155] ehci-platform fe380000.usb: EHCI Host Controller
[    2.764203] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5
[    2.764514] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[    2.772189] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[    2.772404] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[    2.772417] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.772442] usb usb5: Product: EHCI Host Controller
[    2.772459] usb usb5: Manufacturer: Linux 4.4.103 ehci_hcd
[    2.772470] usb usb5: SerialNumber: fe380000.usb
[    2.773114] hub 5-0:1.0: USB hub found
[    2.773200] hub 5-0:1.0: 1 port detected
[    2.774264] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[    2.774318] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6
[    2.774536] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[    2.829694] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    2.829726] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.829740] usb usb6: Product: Generic Platform OHCI controller
[    2.829754] usb usb6: Manufacturer: Linux 4.4.103 ohci_hcd
[    2.829766] usb usb6: SerialNumber: fe3a0000.usb
[    2.830423] hub 6-0:1.0: USB hub found
[    2.830463] hub 6-0:1.0: 1 port detected
[    2.832108] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[    2.832360] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[    2.832380] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[    2.832419] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[    2.832443] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    2.832521] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[    2.832533] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[    2.832981] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[    2.845575] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    2.859106] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[    2.864432] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[    2.864665] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[    2.864692] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[    2.864770] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[    2.864814] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    2.865067] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[    2.865992] dwmmc_rockchip fe320000.dwmmc: allocated mmc-pwrseq
[    2.866336] vcc_sd: unsupportable voltage range: 3300000-3000000uV
[    2.869456] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[    2.869807] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[    2.882264] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    2.888407] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    2.890116] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    2.891735] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    2.894642] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    2.896681] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[    2.899218] mmc1: queuing unknown CIS tuple 0x81 (9 bytes)
[    2.985995] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    2.988610] mmc1: new high speed SDIO card at address 0001
[    3.001930] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[    3.079068] usb 5-1: new high-speed USB device number 2 using ehci-platform
[    3.102588] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[    3.203247] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[    3.205383] usb 5-1: New USB device found, idVendor=05e3, idProduct=0608
[    3.205518] usb 5-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    3.205561] usb 5-1: Product: USB2.0 Hub
[    3.207126] hub 5-1:1.0: USB hub found
[    3.207801] hub 5-1:1.0: 4 ports detected
[    3.303867] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[    3.404546] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[    3.405122] phy phy-ff7c0000.phy.9: phy poweron failed --> -110
[    3.405755] dwc3 fe800000.dwc3: failed to initialize core
[    3.406343] dwc3: probe of fe800000.dwc3 failed with error -110
[    3.407163] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[    3.475738] usb 5-1.1: new high-speed USB device number 3 using ehci-platform
[    3.512151] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[    3.562016] usb 5-1.1: New USB device found, idVendor=05e3, idProduct=0608
[    3.562076] usb 5-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    3.562110] usb 5-1.1: Product: USB2.0 Hub
[    3.563772] hub 5-1.1:1.0: USB hub found
[    3.564451] hub 5-1.1:1.0: 4 ports detected
[    3.612277] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[    3.712919] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[    3.813538] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[    3.832403] usb 5-1.1.2: new full-speed USB device number 4 using ehci-platform
[    3.914175] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[    3.914766] phy phy-ff7c0000.phy.9: phy poweron failed --> -110
[    3.915388] dwc3 fe800000.dwc3: failed to initialize core
[    3.915937] dwc3: probe of fe800000.dwc3 failed with error -110
[    3.916741] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[    3.917466] usb 5-1.1.2: New USB device found, idVendor=1a86, idProduct=7523
[    3.917524] usb 5-1.1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[    3.917569] usb 5-1.1.2: Product: USB2.0-Serial
[    3.918634] ch341 5-1.1.2:1.0: ch341-uart converter detected
[    3.921491] usb 5-1.1.2: ch341-uart converter now attached to ttyUSB0
[    4.023534] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[    4.123654] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[    4.223766] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[    4.323870] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[    4.423976] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[    4.424009] phy phy-ff7c0000.phy.9: phy poweron failed --> -110
[    4.424138] dwc3 fe800000.dwc3: failed to initialize core
[    4.424223] dwc3: probe of fe800000.dwc3 failed with error -110
[    4.424502] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[    4.528724] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[    4.628859] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[    4.728955] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[    4.829071] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[    4.929185] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[    4.929232] phy phy-ff7c0000.phy.9: phy poweron failed --> -110
[    4.929342] dwc3 fe800000.dwc3: failed to initialize core
[    4.929420] dwc3: probe of fe800000.dwc3 failed with error -110
[    4.929678] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[    4.930323] otg_wakelock_init: No USB transceiver found
[    4.934513] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:06 UTC (1358499006)
[    4.935976] It doesn't contain Rogue gpu
技术小白,无从下手
技术小白,无从下手
