如果RK3288接的是nandflash,kernel应该怎么改?
我们的板子用的是nandflash,型号是瑞芯微支持的,uboot已经可以正常起来,但kernel部分还有问题。
不知道kernel应该都需要改什么,编译出来的源码才能支持nandflash。
在你使用的dts 找到如下内容,用nand的话,将相应的nand接口改为okay
&nandc0 {
status = “okay”; // used nand set “okay” ,used emmc set “disabled”
&nandc1 {
status = “disabled”; // used nand set “okay” ,used emmc set “disabled”
&nandc0reg {
&nandc0 {
status = “okay”; // u …
我公司的板子也是用NAND Flash開機, 該NAND元件有列入support list中, 我嘗試過修改DTS, 還是不成功, 請教還有哪些地方需修改?
謝謝!
我公司的板子也是使用NAND FLASH, 有列入supporting list, 我依此方式修改, 仍無法開機, 請問還有哪需修改?這問題折騰許久了! 謝謝!
Log 如下:
DDR Version 1.00 20160614
Channel a: DDR3 200MHz
Bus Width=32 Col=10 Bank=8 Row=14 CS=1 Die Bus-Width=16 Size=512MB
Channel b: DDR3 200MHz
Memory OK
Memory OK
Boot1 Release Time: 2016-10-19, version: 2.35
ChipType = 8 211
No.1 FLASH ID:2c 44 44 4b a9 0
No.2 FLASH ID:33 33 33 33 33 33
No.4 FLASH ID:33 33 33 33 33 33
No.6 FLASH ID:33 33 33 33 33 33
No.8 FLASH ID:33 33 33 33 33 33
ECC:60
SdmmcInit=0 400
StorageInit ok = 166346
theLoader 0 258805
U-Boot 2014.10-RK3288-10 (Dec 15 2017 - 09:01:23)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
Adding bank:0000000000000000(0000000040000000)
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 400
SdmmcInit = 2 400
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
pmic:act8846
can’t find dts node for pwm1
#Boot ver: 2016-11-01#2.35
empty serial no.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
no fuel gauge found
got recovery cmd from misc.
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x02000000 (0x006a48f0)
ramdisk @ 0x05bf0000 (0x002ad1b0)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0561c058 … OK
Add bank:0000000000000000, 0000000040000000
[ 0.000000] Linux version 3.10.0 (jl@jl-VirtualBox) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #6 SMP PREEMPT Wed Dec 13 11:23:24 KST 2017
[ 0.000000] ion heap(cma): base(0) size(1000000) align(0)
[ 0.000000] cma: CMA: reserved 16 MiB at 3f000000
[ 0.000000] ion_reserve: cma reserved base 3f000000 size 16777216
[ 0.000000] cma: CMA: reserved 16 MiB at 1f000000
[ 0.000000] Boot mode: RECOVERY (2) flag: RECOVER (0xc3524203)
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1714000 s13376 r8192 d15296 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 261120
[ 0.000000] Kernel command line: vmalloc=496M console=ttyS2 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00002000@0x0039A000(baseparamer),0x00200000@0x0039C000(userdata),0x00020000@0x0059C000(radical_update),-@0x005BC000(user) storagemedia=nand loader.timestamp=2017-12-15_09:01:23
[ 0.000000] allocated 2097152 bytes of page_cgroup
[ 0.000000] Memory: 1024MB = 1024MB total
[ 0.000000] Memory: 986692k/986692k available, 61884k reserved, 507904K highmem
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0bae84c (11931 kB)
[ 0.000000] .init : 0xc0baf000 - 0xc0c08440 ( 358 kB)
[ 0.000000] .data : 0xc0c0a000 - 0xc0d9c980 (1611 kB)
[ 0.000000] .bss : 0xc0d9c980 - 0xc0ebdb3c (1157 kB)
[ 0.000000] rk_clk_tree_init start!
[ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div
[ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error
[ 0.000000] rkclk_init_clks: cnt_rate = 29
[ 0.000000] rk3288 set GPLL BW 20 for HDMI!
[ 0.000000] process version: 3
[ 0.000000] channel:0, lkg:11
[ 0.000000] target-temp:80
[ 0.000000] channel:2, lkg:0
[ 0.000000] channel:1, lkg:10
[ 0.239578] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.239594] pid_max: default: 32768 minimum: 301
[ 0.239714] Security Framework initialized
[ 0.239731] SELinux: Initializing.
[ 0.239803] Mount-cache hash table entries: 512
[ 0.240447] Initializing cgroup subsys debug
[ 0.240462] Initializing cgroup subsys memory
[ 0.240487] Initializing cgroup subsys freezer
[ 0.240515] CPU: Testing write buffer coherency: ok
[ 0.240829] /cpus/cpu@0 missing clock-frequency property
[ 0.240844] /cpus/cpu@1 missing clock-frequency property
[ 0.240854] /cpus/cpu@2 missing clock-frequency property
[ 0.240863] /cpus/cpu@3 missing clock-frequency property
[ 0.240915] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.240966] Setting up static identity map for 0xc0859e00 - 0xc0859e58
[ 0.243303] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x176d (version 3.1)
[ 0.317726] CPU1: Booted secondary processor
[ 0.317760] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.337400] CPU2: Booted secondary processor
[ 0.337425] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.357109] CPU3: Booted secondary processor
[ 0.357132] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.357232] Brought up 4 CPUs
[ 0.357260] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.357269] CPU: All CPU(s) started in SVC mode.
[ 0.358001] devtmpfs: initialized
[ 0.362151] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.363238] pinctrl core: initialized pinctrl subsystem
[ 0.363487] regulator-dummy: no parameters
[ 0.377181] NET: Registered protocol family 16
[ 0.378920] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.379297] ion_snapshot: 0x1ea98000 map to 0xe0907000 and copy to 0xc0e98e0c (version 0.1)
[ 0.379525] Registered FIQ tty driver
[ 0.379909] fiq-debugger is disabled in device tree
[ 0.380511] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[ 0.380532] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[ 0.380550] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 0.380566] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[ 0.380656] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 0.380721] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 0.380783] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 0.380845] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 0.380906] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 0.380970] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[ 0.381032] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 0.381095] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[ 0.381163] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 0.381228] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 0.381242] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 0.381253] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 0.381265] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 0.381885] rockchip_interrupts_register:bank_num=7
[ 0.383833] of_get_gpio_init_config:gpio[0] = 136, value = 0
[ 0.383877] rockchip_pinctrl_probe:init ok
[ 0.390725] rk_iommu ff900800.iep_mmu: (iep) Enter
[ 0.390821] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.390834] rk_iommu ff900800.iep_mmu: (iep) Initialized
[ 0.391005] rk_iommu ff950800.vip_mmu: (vip) Enter
[ 0.391083] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.391096] rk_iommu ff950800.vip_mmu: (vip) Initialized
[ 0.391264] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[ 0.391341] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.391354] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[ 0.391513] rk_iommu ff940300.vopl_mmu: (vopl) Enter
[ 0.391591] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.391602] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[ 0.391778] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[ 0.391859] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.391871] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[ 0.392035] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[ 0.392113] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.392126] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[ 0.392301] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[ 0.392390] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.392403] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
[ 0.394004] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.394017] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.394594] rk3368_init_rockchip_pmu_ops: could not find pmu dt node
[ 0.394618] DDR DEBUG: version 1.00 20150126
[ 0.394647] DDR DEBUG: Channel a:
[ 0.394656] DDR DEBUG: DDR3 Device
[ 0.394669] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=14 CS=1 Total Capability=512MB
[ 0.394678] DDR DEBUG: Channel b:
[ 0.394685] DDR DEBUG: DDR3 Device
[ 0.394698] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=14 CS=1 Total Capability=512MB
[ 0.394707] DDR DEBUG: addr=0xda6000
[ 0.394717] DDR DEBUG: stride=6, size=512, halfcap=20000000
[ 0.394726] DDR DEBUG: socAddr[0]=0xda6000, socAddr[1]=0xda6200
[ 0.394735] DDR DEBUG: chAddr[0]=0xda6000, chAddr[1]=0xda6000
[ 0.394747] DDR DEBUG: dtar[0]=0x601b4000, dtar[1]=0x601b4000
[ 0.394802] DDR DEBUG: init success!!! freq=200MHz
[ 0.394810] DDR DEBUG: Channel a:
[ 0.394823] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,180
[ 0.394836] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,180
[ 0.394849] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,180
[ 0.394861] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,180
[ 0.394872] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.394882] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.394891] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.394899] DDR DEBUG: Channel b:
[ 0.394910] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=3,0, DGSL=1,1 extra clock, DGPS=270,180
[ 0.394923] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,180
[ 0.394935] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,180
[ 0.394948] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=3,0, DGSL=1,1 extra clock, DGPS=270,180
[ 0.394958] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.394968] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.394977] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.419394] bio: create slab at 0
[ 0.419937] Rockchip hdmi driver version 2.0
[ 0.419937] .
[ 0.421087] SCSI subsystem initialized
[ 0.421245] usbcore: registered new interface driver usbfs
[ 0.421290] usbcore: registered new interface driver hub
[ 0.421372] usbcore: registered new device driver usb
[ 0.424013] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 0.424662] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
[ 0.425106] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
[ 0.425359] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 0.425843] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 0.425959] media: Linux media interface: v0.10
[ 0.425998] Linux video capture interface: v2.00
[ 0.426068] pps_core: LinuxPPS API ver. 1 registered
[ 0.426079] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.426100] PTP clock support registered
[ 0.426159] i2c-core: driver [bq24296] using legacy suspend method
[ 0.426169] i2c-core: driver [bq24296] using legacy resume method
[ 0.426858] ion_drm_heap_create: 0@0
[ 0.426995] Rockchip ion module is successfully loaded (v1.1)
[ 0.427152] Advanced Linux Sound Architecture Driver Initialized.
[ 0.427573] Bluetooth: Core ver 2.16
[ 0.427611] NET: Registered protocol family 31
[ 0.427621] Bluetooth: HCI device and connection manager initialized
[ 0.427636] Bluetooth: HCI socket layer initialized
[ 0.427650] Bluetooth: L2CAP socket layer initialized
[ 0.427675] Bluetooth: SCO socket layer initialized
[ 0.427899] cfg80211: Calling CRDA to update world regulatory domain
[ 0.428599] act8846_i2c_probe,line=898
[ 0.429602] act8846_parse_dt,line=746
[ 0.430066] act8846_i2c_probe: act8846_pmic_hold=1
[ 0.430088] act8846_i2c_probe: act8846_pmic_sleep=1
[ 0.430103] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
[ 0.430118] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
[ 0.432202] act_dcdc1: 1200 mV
[ 0.435170] vccio: 3300 mV
[ 0.437056] vdd_logic: 700 ↔ 1500 mV at 1125 mV
[ 0.440022] act_dcdc4: 2000 mV
[ 0.441275] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
[ 0.443572] act_ldo2: 1050 mV
[ 0.445925] act_ldo3: 3300 mV
[ 0.448237] act_ldo4: 3300 mV
[ 0.450533] act_ldo5: 3300 mV
[ 0.452847] act_ldo6: 1100 mV
[ 0.455149] vcc_18: 1800 mV
[ 0.457451] act_ldo8: 1850 mV
[ 0.462210] vdd_arm: 712 ↔ 1500 mV at 900 mV
[ 0.466895] vdd_gpu: 712 ↔ 1500 mV at 900 mV
[ 0.467646] rk808_i2c_probe,line=1355
[ 0.468980] The device is not rk808 -11
[ 0.469065] rk808: probe of 0-001b failed with error -11
[ 0.469141] i2c-core: driver [rk818] using legacy suspend method
[ 0.469151] i2c-core: driver [rk818] using legacy resume method
[ 0.470810] Switching to clocksource arch_sys_counter
[ 0.495015] rga: Module initialized.
[ 0.495739] rga2 ff920000.rga: rga ion client create success!
[ 0.495904] rga: Driver loaded succesfully
[ 0.496112] fb disp policy is box
[ 0.496153] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.496165] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.496497] rk-screen rk_screen.8: rockchip screen probe success
[ 0.496721] rk32-lvds rk32-lvds: rk32 lvds driver probe success
[ 0.497075] rk32-edp ff970000.edp: screen is not edp!
[ 0.497094] rk32-edp: probe of ff970000.edp failed with error -22
[ 0.497587] rk3288-lcdc lcdc0: can’t find power_ctr node for lcdc0
[ 0.497814] graphics fb0: rockchip framebuffer registerd:fb0
[ 0.498123] graphics fb1: rockchip framebuffer registerd:fb1
[ 0.498296] graphics fb2: rockchip framebuffer registerd:fb2
[ 0.498463] graphics fb3: rockchip framebuffer registerd:fb3
[ 0.499264] vop ver:3007236,unsupport output color:1
[ 0.499401] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60
[ 0.499425] rk3288-lcdc lcdc0: wakeup from standby!
[ 0.532971] alloc_buffer:ion_phy_addr=0x10000000
[ 0.546545] fb0:phy:10000000>>vir:e0991000>>len:0x1800000
[ 0.546574] rk_iommu ff930300.vopb_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eab4000
[ 0.546589] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
[ 0.546822] rk3288-lcdc lcdc1: can’t find power_ctr node for lcdc1
[ 0.546835] rk_fb_trsm_ops_get:un supported transmitter:0!
[ 0.547104] graphics fb4: rockchip framebuffer registerd:fb4
[ 0.547440] graphics fb5: rockchip framebuffer registerd:fb5
[ 0.547610] graphics fb6: rockchip framebuffer registerd:fb6
[ 0.547779] graphics fb7: rockchip framebuffer registerd:fb7
[ 0.548591] unknow screen type: 0
[ 0.548608] vop ver:3007236,unsupport output color:1
[ 0.548669] rk3288-lcdc lcdc1: lcdc1: dclk:148500000>>fps:60
[ 0.548683] rk3288-lcdc lcdc1: wakeup from standby!
[ 0.552419] fb4:phy:10000000>>vir:e0991000>>len:0x1800000
[ 0.552435] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu enabled
[ 0.553278] rockchip_set_mux:warning ignore bank num 15
[ 0.553419] rockchip_set_mux:warning ignore bank num 15
[ 0.553535] rockchip_set_mux:warning ignore bank num 15
[ 0.553661] rockchip_set_mux:warning ignore bank num 15
[ 0.553775] rockchip_set_mux:warning ignore bank num 15
[ 0.553888] rockchip_set_mux:warning ignore bank num 15
[ 0.554474] rockchip_set_mux:warning ignore bank num 15
[ 0.554634] rockchip_set_mux:warning ignore bank num 15
[ 0.555176] rockchip_set_mux:warning ignore bank num 15
[ 0.555319] rockchip_set_mux:warning ignore bank num 15
[ 0.555856] rockchip_set_mux:warning ignore bank num 15
[ 0.556009] rockchip_set_mux:warning ignore bank num 15
[ 0.556548] rockchip_set_mux:warning ignore bank num 15
[ 0.556700] rockchip_set_mux:warning ignore bank num 15
[ 0.557801] tc358749_hdmiin_probe!
[ 0.617067] tc358749_hdmiin_probe OK!
[ 0.617533] NET: Registered protocol family 2
[ 0.618193] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.618269] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.618342] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.618405] TCP: reno registered
[ 0.618420] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.618444] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.618655] NET: Registered protocol family 1
[ 0.619256] Unpacking initramfs…
[ 0.751632] Freeing initrd memory: 2740K (c5bf0000 - c5e9d000)
[ 0.752323] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 0.752869] vcodec_service: probe device ff9a0000.vpu_service
[ 0.753072] vcodec_service: No reset resource define
[ 0.753250] vcodec_service: ff9a0000.vpu_service: power on
[ 0.753361] vcodec_service: probe device ff9a0000.vpu_service
[ 0.753376] vcodec_service: checking hw id 4831
[ 0.754377] vcodec_service: ff9a0000.vpu_service: power off…
[ 0.754423] vcodec_service: done
[ 0.754433] vcodec_service: init success
[ 0.754501] vcodec_service: probe device ff9c0000.hevc_service
[ 0.754833] vcodec_service: ff9c0000.hevc_service: power on
[ 0.754894] vcodec_service: probe device ff9c0000.hevc_service
[ 0.754908] vcodec_service: checking hw id 6867
[ 0.755466] vcodec_service: ff9c0000.hevc_service: power off…
[ 0.755508] vcodec_service: done
[ 0.755518] vcodec_service: init success
[ 0.755645] rknandbase v1.0 2014-03-31
[ 0.755879] rknand_probe clk rate = 148500000
[ 0.756027] rknand_probe clk rate = 148500000
[ 0.756095] rknand ff400000.nandc0: can’t request region for resource [mem 0xff400000-0xff403fff]
[ 0.756109] rknand ff400000.nandc0: no reg resource?
[ 0.756129] rknand: probe of ff400000.nandc0 failed with error -1
[ 0.756283] rknand_driver:ret = 0
[ 0.758195] audit: initializing netlink socket (disabled)
[ 0.758240] type=2000 audit(0.520:1): initialized
[ 0.758997] bounce pool size: 64 pages
[ 0.763545] fuse init (API version 7.22)
[ 0.763917] msgmni has been set to 972
[ 0.765745] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.765762] io scheduler noop registered
[ 0.765773] io scheduler deadline registered
[ 0.765861] io scheduler cfq registered (default)
[ 0.767103] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess.
[ 0.767821] IEP Power ON
[ 0.767861] iep ion client create success!
[ 0.768322] rk_iommu ff900800.iep_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eaae000
[ 0.768332] IEP Power OFF
[ 0.768350] IEP Driver loaded succesfully
[ 0.768447] Module initialized.
[ 0.769265] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 0.769284] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 0.770651] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 0.770668] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.770948] pwm-voltage-regulator pwm_regulator.21: unable to request PWM, trying legacy API
[ 0.770964] pwm-voltage-regulator pwm_regulator.21: unable to request legacy PWM
[ 0.770973] pwm_regulator_probe:error
[ 0.770992] platform pwm_regulator.21: Driver pwm-voltage-regulator requests probe deferral
[ 0.771191] rk_serial.c v1.8 2014-03-04
[ 0.771422] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[ 0.771611] serial ff180000.serial: membase e097e000
[ 0.771771] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1
[ 0.771950] serial ff190000.serial: membase e2192000
[ 0.772091] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
[ 0.773794] console [ttyS2] enabled
[ 0.773981] serial ff690000.serial: membase fed60000
[ 0.774179] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90) is a rk29_serial.3
[ 0.774363] serial ff1b0000.serial: membase e219e000
[ 0.777228] loop: module loaded
[ 0.777601] zram: Created 1 device(s) …
[ 0.777680] i2c-core: driver [mpu6050B1] using legacy suspend method
[ 0.777693] i2c-core: driver [mpu6050B1] using legacy resume method
[ 0.777711] mpu_init: Probe name mpu6050B1
[ 0.777858] ak8963_mod_init: Probe name ak8963_mod
[ 0.778568] SCSI Media Changer driver v0.25
[ 0.778890] tun: Universal TUN/TAP device driver, 1.6
[ 0.778902] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.779028] vmac_init.
[ 0.779586] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 0.779602] stmmac_probe_config_dt: clock input/output? (input).
[ 0.779616] stmmac_probe_config_dt: TX delay(0x30).
[ 0.779628] stmmac_probe_config_dt: RX delay(0x20).
[ 0.779678] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[ 0.779690] stmmc_pltfr_init:
[ 0.779699] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[ 0.779721] gmac_phy_reset: ERROR: Request pin stmmc_pltfr_init failed.
[ 0.779732] stmmc_pltfr_init: init for RGMII
[ 0.779743] tx delay=0x30
[ 0.779743] rx delay=0x20
[ 0.779760] tx delay=0x30
[ 0.779760] rx delay=0x20
[ 0.780229] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.780241] Normal descriptors
[ 0.780250] Ring mode enabled
[ 0.780261] DMA HW capability register supported
[ 0.780273] RX Checksum Offload Engine supported (type 2)
[ 0.780284] TX Checksum insertion supported
[ 0.780293] Wake-Up On Lan supported
[ 0.780341] Enable RX Mitigation via HW Watchdog Timer
[ 0.780772] PPP generic driver version 2.4.2
[ 0.780922] PPP BSD Compression module registered
[ 0.780936] PPP Deflate Compression module registered
[ 0.780958] PPP MPPE Compression module registered
[ 0.780971] NET: Registered protocol family 24
[ 0.781006] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 0.781021] CSLIP: code copyright 1989 Regents of the University of California.
[ 0.781035] Rockchip WiFi SYS interface (V1.00) …
[ 0.781070] esp_mem_init enter date Sep 12 2017 08:27:52
[ 0.781082] esp_mem_init VERSION [V2.5]
[ 0.781125] esp_mem_init complete
[ 0.781210] usbcore: registered new interface driver catc
[ 0.781257] usbcore: registered new interface driver kaweth
[ 0.781270] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 0.781312] usbcore: registered new interface driver pegasus
[ 0.781351] usbcore: registered new interface driver rtl8150
[ 0.781390] usbcore: registered new interface driver r8152
[ 0.781403] hso: drivers/net/usb/hso.c: Option Wireless
[ 0.781473] usbcore: registered new interface driver hso
[ 0.781518] usbcore: registered new interface driver asix
[ 0.781563] usbcore: registered new interface driver ax88179_178a
[ 0.781604] usbcore: registered new interface driver cdc_ether
[ 0.781643] usbcore: registered new interface driver cdc_eem
[ 0.781681] usbcore: registered new interface driver dm9601
[ 0.781719] usbcore: registered new interface driver dm9620
[ 0.781766] usbcore: registered new interface driver smsc75xx
[ 0.781818] usbcore: registered new interface driver smsc95xx
[ 0.781858] usbcore: registered new interface driver gl620a
[ 0.781897] usbcore: registered new interface driver net1080
[ 0.781936] usbcore: registered new interface driver plusb
[ 0.781977] usbcore: registered new interface driver rndis_host
[ 0.782015] usbcore: registered new interface driver cdc_subset
[ 0.782053] usbcore: registered new interface driver zaurus
[ 0.782094] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 0.782163] usbcore: registered new interface driver int51x1
[ 0.782206] usbcore: registered new interface driver kalmia
[ 0.782247] usbcore: registered new interface driver ipheth
[ 0.782290] usbcore: registered new interface driver sierra_net
[ 0.782332] usbcore: registered new interface driver cx82310_eth
[ 0.782379] usbcore: registered new interface driver cdc_ncm
[ 0.782427] usbcore: registered new interface driver qmi_wwan
[ 0.782468] usbcore: registered new interface driver cdc_mbim
[ 0.782482] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.784927] EHCI: ehci_rk_probe e2240000 e2240010
[ 0.784946] rockchip_ehci_host ff500000.usb: EHCI Host Controller
[ 0.784977] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[ 0.785350] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
[ 0.795614] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00
[ 0.795695] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.795712] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.795728] usb usb1: Product: EHCI Host Controller
[ 0.795741] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 0.795754] usb usb1: SerialNumber: ff500000.usb
[ 0.796229] hub 1-0:1.0: USB hub found
[ 0.796257] hub 1-0:1.0: 1 port detected
[ 0.796426] EHCI: ehci_rk_probe ok
[ 0.796530] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.796829] usbcore: registered new interface driver cdc_acm
[ 0.796843] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.796896] usbcore: registered new interface driver usblp
[ 0.796940] usbcore: registered new interface driver cdc_wdm
[ 0.797001] usbcore: registered new interface driver usb-storage
[ 0.797048] usbcore: registered new interface driver ums-alauda
[ 0.797088] usbcore: registered new interface driver ums-cypress
[ 0.797128] usbcore: registered new interface driver ums-datafab
[ 0.797166] usbcore: registered new interface driver ums_eneub6250
[ 0.797204] usbcore: registered new interface driver ums-freecom
[ 0.797243] usbcore: registered new interface driver ums-isd200
[ 0.797282] usbcore: registered new interface driver ums-jumpshot
[ 0.797321] usbcore: registered new interface driver ums-karma
[ 0.797360] usbcore: registered new interface driver ums-onetouch
[ 0.797400] usbcore: registered new interface driver ums-sddr09
[ 0.797446] usbcore: registered new interface driver ums-sddr55
[ 0.797486] usbcore: registered new interface driver ums-usbat
[ 0.797578] usbcore: registered new interface driver usbserial
[ 0.797622] usbcore: registered new interface driver usbserial_generic
[ 0.797656] usbserial: USB Serial support registered for generic
[ 0.797696] usbcore: registered new interface driver option
[ 0.797727] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.797802] usbcore: registered new interface driver trancevibrator
[ 0.797814] usb20_otg: version 3.10a 21-DEC-2012
[ 0.798255] e2280040
[ 0.798268] Core Release: 3.10a
[ 0.798281] Setting default values for core params
[ 0.798409] Using Buffer DMA mode
[ 0.798421] Periodic Transfer Interrupt Enhancement - disabled
[ 0.798432] Multiprocessor Interrupt Enhancement - disabled
[ 0.798445] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.798456] ^^^^^^^^^^^^^^^^^Device Mode
[ 0.798469] Dedicated Tx FIFOs mode
[ 0.798488] pcd_init otg_dev = ddecc180
[ 0.798807] usb20_otg ff580000.usb: DWC OTG Controller
[ 0.798838] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
[ 0.798871] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 0.798937] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.798954] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.798970] usb usb2: Product: DWC OTG Controller
[ 0.798983] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 0.798996] usb usb2: SerialNumber: ff580000.usb
[ 0.799417] hub 2-0:1.0: USB hub found
[ 0.799441] hub 2-0:1.0: 1 port detected
[ 0.799748] usb20_host: version 3.10a 21-DEC-2012
[ 0.802244] e2300040
[ 0.802257] Core Release: 3.10a
[ 0.802269] Setting default values for core params
[ 0.802378] Using Buffer DMA mode
[ 0.802389] Periodic Transfer Interrupt Enhancement - disabled
[ 0.802401] Multiprocessor Interrupt Enhancement - disabled
[ 0.802413] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.802423] ^^^^^^^^^^^^^^^^^^Host Mode
[ 0.802449] usb20_host ff540000.usb: DWC OTG Controller
[ 0.802475] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
[ 0.802504] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[ 0.802595] Init: Power Port (0)
[ 0.802651] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.802667] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.802681] usb usb3: Product: DWC OTG Controller
[ 0.802694] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 0.802707] usb usb3: SerialNumber: ff540000.usb
[ 0.803098] hub 3-0:1.0: USB hub found
[ 0.803126] hub 3-0:1.0: 1 port detected
[ 0.803817] usbcore: registered new interface driver xpad
[ 0.803880] usbcore: registered new interface driver usb_acecad
[ 0.803929] usbcore: registered new interface driver aiptek
[ 0.803976] usbcore: registered new interface driver gtco
[ 0.804022] usbcore: registered new interface driver hanwang
[ 0.804075] usbcore: registered new interface driver kbtab
[ 0.804130] usbcore: registered new interface driver wacom
[ 0.804253] ==gsl_ts_init==
[ 0.804300] ret=0
[ 0.804564] sensor_register_slave:mma8452,id=17
[ 0.804578] sensor_register_slave:gs_mc3230,id=23
[ 0.804589] gsensor_init
[ 0.804599] sensor_register_slave:mpu6880_acc,id=24
[ 0.804611] sensor_register_slave:mpu6500_acc,id=25
[ 0.804622] sensor_register_slave:cm3217,id=48
[ 0.804634] sensor_register_slave:cm3218,id=49
[ 0.804852] .. rk pwm remotectl v1.1 init
[ 0.805120] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
[ 0.810187] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 0.810237] i2c /dev entries driver
[ 0.810923] IR NEC protocol handler initialized
[ 0.810937] IR RC5(x) protocol handler initialized
[ 0.810948] IR RC6 protocol handler initialized
[ 0.810958] IR JVC protocol handler initialized
[ 0.810968] IR Sony protocol handler initialized
[ 0.810979] IR RC5 (streamzap) protocol handler initialized
[ 0.810989] IR SANYO protocol handler initialized
[ 0.811000] IR MCE Keyboard/mouse protocol handler initialized
[ 0.811170] usbcore: registered new interface driver uvcvideo
[ 0.811183] USB Video Class driver (1.1.1)
[ 0.811197] CamSys driver version: v0.32.0, CamSys head file version: v0.11.0
[ 0.812680] D1:camsys_platform_probe(1300): 1-gpios-cifpower: gpio=236
[ 0.812705] D1:camsys_platform_probe(1303): gpios-cifpower: gpio_request
[ 0.812727] D1:camsys_platform_probe(1305): 1-gpios-cifpower: gpio_request=0
[ 0.812749] D1:camsys_platform_probe(1314): gpios-cifpower: 236 high
[ 0.812790] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288
[ 0.812790]
[ 0.812865] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 0.813026] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe21d8000 size: 0x4000)
[ 0.813671] D1:camsys_platform_probe(1447): ff910000.isp memory:
[ 0.813691] D1:camsys_platform_probe(1457): Register memory (phy: 0xff910000 vir: 0xe22e0000 size: 0x10000)
[ 0.813708] D1:camsys_platform_probe(1452): I2c memory (phy: 0x1dfd3000 vir: 0xddfd3000 size: 0x1000)
[ 0.813723] D1:camsys_init_ext_fsh_module(20): init external flash module
[ 0.813736] D1:camsys_platform_probe(1472): Probe ff910000.isp device success
[ 0.814135] test power disabled
[ 0.814192] i2c-core: driver [bq27320] using legacy suspend method
[ 0.814204] i2c-core: driver [bq27320] using legacy resume method
[ 0.814537] rockchip_temp_probe,line=364
[ 0.864488] tsadc ff280000.tsadc: initialized
[ 0.864860] device-mapper: uevent: version 1.0.3
[ 0.865105] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 0.865401] Bluetooth: HCI UART driver ver 2.2
[ 0.865417] Bluetooth: HCI H4 protocol initialized
[ 0.865429] Bluetooth: HCILL protocol initialized
[ 0.865440] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21
[ 0.865453] rtk_btusb: Register usb char device interface for BT driver
[ 0.865629] usbcore: registered new interface driver rtk_btusb
[ 0.866260] DVFS WARNING: clk_enable_dvfs: clk(aclk_vio1) freq table all value are smaller than default(594000), use default, just enable dvfs
[ 0.870399] cpufreq version 1.0, suspend freq 1200 MHz
[ 0.870599] cpuidle: using governor ladder
[ 0.870612] cpuidle: using governor menu
[ 0.870649] Synopsys Designware Multimedia Card Interface Driver
[ 0.870661] MHSC version = Ver 2.00 2015-06-10
[ 0.871147] dw cru_regsbase addr 0x1d8.
[ 0.871161] dw cru_reset_offset val 0.
[ 0.871176] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[ 0.871222] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc
[ 0.871531] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
[ 0.871699] dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc0]
[ 0.872210] dwmmc_rockchip ff0c0000.rksdmmc: mmc0: No udbg pinctrl found!
[ 0.872324] 1358..dw_mci_set_ios: no card. [mmc0]
[ 0.884169] 1358..dw_mci_set_ios: no card. [mmc0]
[ 0.903874] 1358..dw_mci_set_ios: no card. [mmc0]
[ 0.903923] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
[ 0.903942] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
[ 0.904368] dw cru_regsbase addr 0x1d8.
[ 0.904381] dw cru_reset_offset val 1.
[ 0.904396] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[ 0.904437] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc
[ 0.904980] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
[ 0.905150] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc1]
[ 0.905494] 1358..dw_mci_set_ios: no card. [mmc1]
[ 0.923522] 1358..dw_mci_set_ios: no card. [mmc1]
[ 0.943203] 1358..dw_mci_set_ios: no card. [mmc1]
[ 0.943227] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
[ 0.943239] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[ 0.943473] leds-gpio leds.26: pins are not configured from the driver
[ 0.943757] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.945249] usbcore: registered new interface driver usbhid
[ 0.945261] usbhid: USB HID core driver
[ 0.945376] ashmem: initialized
[ 0.945495] logger: created 256K log ‘log_main’
[ 0.945588] logger: created 256K log ‘log_events’
[ 0.945691] logger: created 256K log ‘log_radio’
[ 0.945783] logger: created 256K log ‘log_system’
[ 0.946868] input: rk29-keypad as /devices/ff100000.adc/key.29/input/input1
[ 0.947710] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ff890000.rockchip-i2s; cannot claim for 2-0010
[ 0.947726] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
[ 0.947738] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl
[ 0.947749] ES8323 2-0010: Error applying setting, reverse things back
[ 0.948040] es8323 probe i2c recv ok
[ 0.948970] rockchip-spdif ff880000.rockchip-spdif: spdif ready.
[ 0.949525] es8323_probe
[ 1.583165] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → NULL → Left Line Mux
[ 1.583179] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → NULL → Left Line Mux
[ 1.583190] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → NULL → Left Line Mux
[ 1.583198] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → NULL → Left Line Mux
[ 1.583208] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → NULL → Left Line Mux
[ 1.583216] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → NULL → Left Line Mux
[ 1.583226] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → NULL → Right Line Mux
[ 1.583234] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → NULL → Right Line Mux
[ 1.583243] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → NULL → Right Line Mux
[ 1.583250] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → NULL → Right Line Mux
[ 1.583259] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → NULL → Right Line Mux
[ 1.583267] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → NULL → Right Line Mux
[ 1.583276] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left PGA Mux
[ 1.583283] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left PGA Mux
[ 1.583292] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left PGA Mux
[ 1.583299] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left PGA Mux
[ 1.583308] ES8323 2-0010: ASoC: no dapm match for Differential Mux → LAMP → Left PGA Mux
[ 1.583316] ES8323 2-0010: ASoC: Failed to add route Differential Mux → LAMP → Left PGA Mux
[ 1.583325] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right PGA Mux
[ 1.583333] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right PGA Mux
[ 1.583342] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right PGA Mux
[ 1.583350] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right PGA Mux
[ 1.583359] ES8323 2-0010: ASoC: no dapm match for Differential Mux → RAMP → Right PGA Mux
[ 1.583366] ES8323 2-0010: ASoC: Failed to add route Differential Mux → RAMP → Right PGA Mux
[ 1.583376] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Differential Mux
[ 1.583383] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Differential Mux
[ 1.583392] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Differential Mux
[ 1.583400] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Differential Mux
[ 1.583409] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Differential Mux
[ 1.583417] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Differential Mux
[ 1.583425] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Differential Mux
[ 1.583433] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Differential Mux
[ 1.583453] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left Line Mux
[ 1.583461] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left Line Mux
[ 1.583469] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left Line Mux
[ 1.583477] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left Line Mux
[ 1.583486] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → LAMP → Left Line Mux
[ 1.583494] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → LAMP → Left Line Mux
[ 1.583503] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right Line Mux
[ 1.583510] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right Line Mux
[ 1.583519] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right Line Mux
[ 1.583527] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right Line Mux
[ 1.583536] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → RAMP → Right Line Mux
[ 1.583543] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → RAMP → Right Line Mux
[ 1.583688] ES8323 2-0010: ASoC: mux Right Line Mux has no paths
[ 1.583700] ES8323 2-0010: ASoC: mux Left Line Mux has no paths
[ 1.583710] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths
[ 1.583720] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths
[ 1.583739] ES8323 2-0010: ASoC: mux Differential Mux has no paths
[ 1.590642] rockchip-es8323 rockchip-es8323.25: ES8323 HiFi ↔ ff890000.rockchip-i2s mapping ok
[ 1.591080] input: RK_ES8323 Headphone Jack as /devices/rockchip-es8323.25/sound/card0/input2
[ 1.591472] u32 classifier
[ 1.591479] Actions configured
[ 1.591489] Netfilter messages via NETLINK v0.30.
[ 1.591544] nf_conntrack version 0.5.0 (15971 buckets, 63884 max)
[ 1.591833] ctnetlink v0.93: registering with nfnetlink.
[ 1.591900] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 1.591907] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 1.592125] xt_time: kernel timezone is -0000
[ 1.592296] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.592403] arp_tables: (C) 2002 David S. Miller
[ 1.592440] TCP: cubic registered
[ 1.592446] Initializing XFRM netlink socket
[ 1.592643] NET: Registered protocol family 10
[ 1.593085] mip6: Mobile IPv6
[ 1.593106] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.593212] sit: IPv6 over IPv4 tunneling driver
[ 1.593493] NET: Registered protocol family 17
[ 1.593515] NET: Registered protocol family 15
[ 1.593558] Bridge firewalling registered
[ 1.593570] Ebtables v2.0 registered
[ 1.593764] Bluetooth: RFCOMM TTY layer initialized
[ 1.593785] Bluetooth: RFCOMM socket layer initialized
[ 1.593792] Bluetooth: RFCOMM ver 1.11
[ 1.593799] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.593805] Bluetooth: BNEP filters: protocol multicast
[ 1.593814] Bluetooth: BNEP socket layer initialized
[ 1.593821] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.593831] Bluetooth: HIDP socket layer initialized
[ 1.593854] l2tp_core: L2TP core driver, V2.0
[ 1.593866] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.593873] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.594067] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.594077] [WLAN_RFKILL]: can’t find rockchip,grf property
[ 1.594085] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[ 1.594092] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.594100] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 1.594108] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.594128] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
[ 1.594147] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
[ 1.594154] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.594181] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
[ 1.594189] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.594219] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.594844] rk3288_init_suspend
[ 1.594854] rk3288_suspend_init enter
[ 1.595045] rk3288_suspend_init: pm_ctrbits =200007
[ 1.595077] gpio_get_dts_info suspend:4
[ 1.595084] gpio_get_dts_info resume:4
[ 1.595090] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 1.595116] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 1.595242] clks_gating_suspend_init:clkgt info ok
[ 1.595331] Registering SWP/SWPB emulation handler
[ 1.595636] ddrfreq: verion 1.2 20140526
[ 1.595647] ddrfreq: normal 456MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 456MHz
[ 1.595655] ddrfreq: auto-freq=0
[ 1.595660] ddrfreq: auto-freq-table[0] 240MHz
[ 1.595666] ddrfreq: auto-freq-table[1] 324MHz
[ 1.595671] ddrfreq: auto-freq-table[2] 456MHz
[ 1.595676] ddrfreq: auto-freq-table[3] 528MHz
[ 1.611832] act_ldo3: operation not allowed
[ 1.611841] vga_edid_probe: turn on ldo3 done.
[ 1.612094] act_ldo4: operation not allowed
[ 1.612101] vga_edid_probe: turn on ldo done.
[ 1.612360] act_ldo2: operation not allowed
[ 1.612367] vga_edid_probe: turn on ldo2 done.
[ 1.612612] act_ldo8: operation not allowed
[ 1.612619] vga_edid_probe: turn on ldo done.
[ 1.612630] invalid gpio-pwn: -2
[ 1.612642] vga_edid: probe of 4-0050 failed with error -1
[ 1.612664] regulator-dummy: disabling
[ 1.612884] =======================================================
[ 1.612892] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 1.612898] =======================================================
[ 1.612904] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init.
[ 1.612952] dhd_module_init: in
[ 1.612960] ======== bcm_wlan_set_plat_data ========
[ 1.612966] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 1.612986] host_oob_irq: 195
[ 1.612991] host_oob_irq_flags=4
[ 1.612996] dhd_wifi_platform_load: Enter
[ 1.613008] pcd_pullup, is_on 0
[ 1.613012] Power-up adapter ‘DHD generic adapter’
[ 1.613029] wifi_platform_set_power = 1
[ 1.613034] ======== PULL WL_REG_ON HIGH! ========
[ 1.613040] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.613047] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[ 1.613049] file system registered
[ 1.613058] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
[ 1.613064] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 1.613586] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 1.613595] android_usb gadget: Number of LUNs=2
[ 1.613602] lun0: LUN: removable file: (no medium)
[ 1.613608] lun1: LUN: removable file: (no medium)
[ 1.613751] android_usb gadget: android_usb ready
[ 1.613819] sensor_init: Probe name sensors
[ 1.613833] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 1.614359] rtc_hym8563 0-0051: setting system clock to 2011-01-01 12:03:15 UTC (1293883395)
[ 1.620469] rockchip-spdif-card rockchip-spdif-card.24: rk-hdmi-spdif-hifi ↔ ff880000.rockchip-spdif mapping ok
[ 1.720556] [WLAN_RFKILL]: wifi turn on power. 156
[ 1.927193] wifi_platform_bus_enumerate device present 1
[ 1.927200] ======== Card detection to detect SDIO card! ========
[ 1.927207] mmc1:mmc host rescan start!
[ 2.143678] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc1]
[ 2.178364] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.179873] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.181381] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.184086] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.236576] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 2.236596] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc1]
[ 2.236643] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=4bits.[mmc1]
[ 2.238554] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 2.238574] mmc1: new high speed SDIO card at address 0001
[ 2.254581] bcmsdh_register: register client driver
[ 2.254642] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2.254701] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2.254707] bus num (host idx)=1, slot num (rca)=1
[ 2.254713] found adapter info ‘DHD generic adapter’
[ 2.254961] F1 signature read @0x18000000=0x16224335
[ 2.256655] F1 signature OK, socitype:0x1 chip:0x4339 rev:0x1 pkg:0x2
[ 2.256919] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 2.256961] wifi_platform_get_mac_addr
[ 2.256968] ======== bcm_wlan_get_mac_address ========
[ 2.256974] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
[ 2.256984] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
[ 2.256990] [WLAN_RFKILL]: This mac address is not valid, ignored…
[ 2.256999] dhd_conf_set_chiprev: chip=0x4339, chiprev=1
[ 2.257036] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmware/config.txt
[ 2.257278] wl_create_event_handler(): thread:wl_event_handler:77 started
[ 2.257282] tsk Enter, tsk = 0xc592149c
[ 2.257386] dhd_attach(): thread:dhd_watchdog_thread:78 started
[ 2.257427] dhd_attach(): thread:dhd_dpc:79 started
[ 2.257436] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
[ 2.257470] dhd_attach(): thread:dhd_rxf:7a started
[ 2.257480] dhd_deferred_work_init: work queue initialized
[ 2.257588] dhdsdio_probe_init: set use_rxchain 1 from config.txt
[ 2.263236] Dongle Host Driver, version 1.201.59.5 (r506368)
[ 2.263236] Compiled in drivers/net/wireless/bcmdhd on Sep 12 2017 at 08:28:39
[ 2.263495] Register interface [wlan0] MAC: 04:e6:76:c1:b9:aa
[ 2.263495]
[ 2.263506] dhd_prot_ioctl : bus is down. we have nothing to do
[ 2.263540] bcmsdh_oob_intr_unregister: Enter
[ 2.263547] bcmsdh_oob_intr_unregister: irq is not registered
[ 2.263555] dhd_txglom_enable: enable 0
[ 2.263560] dhd_bus_devreset: WLAN OFF DONE
[ 2.263589] wifi_platform_set_power = 0
[ 2.263594] ======== PULL WL_REG_ON LOW! ========
[ 2.263600] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 2.263606] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[ 2.369982] [WLAN_RFKILL]: wifi shut off power.
[ 2.369990] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
[ 2.369996] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 2.370024] dhd_module_init: Exit err=0
[ 2.773424] EHCI: rk_ehci_hcd_enable, disable host controller
[ 8.687482] [otg id chg] last id -1 current id 1
[ 8.687644] PortPower off
[ 8.687716] rk_battery_charger_detect_cb , battery_charger_detect 6
[ 8.787225] Using Buffer DMA mode
[ 8.787240] Periodic Transfer Interrupt Enhancement - disabled
[ 8.787247] Multiprocessor Interrupt Enhancement - disabled
[ 8.787256] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 8.787263] ^^^^^^^^^^^^^^^^^Device Mode
[ 8.825102] es8323_mic_state_ctrl read:
[ 8.825129] mic_state_switch 0
[ 8.825137] hp_det = 0,insert hp
[ 8.825143] hp mic use intern
[ 9.278523] rk_battery_charger_detect_cb , battery_charger_detect 0
jsl1204 发表于 2017-12-17 08:50
我公司的板子也是使用NAND FLASH, 有列入supporting list, 我依此方式修改, 仍無法開機, 請問還有哪需修改? …
你好,你的问题解决了吗,我现在的问题和你的一样,也是从nand flash启动,但是最后mmc0都找不到
