求助-内核启动报vendor storage:20160801 ret = -1
重新编译内核了,内核启动日志如下,请大神帮忙分析一下
Welcome to minicom 2.7
OPTIONS: I18n
Compiled on Nov 15 2018, 20:18:47.
Port /dev/ttyUSB0, 00:17:24
Press CTRL-A Z for help on special keys
pwm-regulator(vdd-core): init 1044000 uV
regulator(vdd-core) init 1044000 uV
MMC: dwmmc@ff490000: 0
In: serial@ff0c0000
Out: serial@ff0c0000
Err: serial@ff0c0000
Model: Rockchip RK3308 EVB
MMC Device 1 not found
no mmc device at slot 1
switch to partitions #0, OK
boot mode: None
CLK:
apll 816000 KHz
dpll 1300000 KHz
vpll0 1179647 KHz
vpll1 903167 KHz
aclk_bus 185714 KHz
hclk_bus 100000 KHz
pclk_bus 100000 KHz
aclk_peri 185714 KHz
hclk_peri 100000 KHz
pclk_peri 100000 KHz
hclk_audio 98303 KHz
pclk_audio 98303 KHz
Net: Net Initialization Skipped
No ethernet found.
Error: Bad gzipped data
FDT load addr 0x10f00000 size 260 KiB
Booting kernel at 0x207f800 with fdt at 27fe800…
## Booting Android Image at 0x0207f800 …
Kernel load addr 0x02080000 size 7671 KiB
## Flattened Device Tree blob at 027fe800
Booting using the fdt blob at 0x27fe800
XIP Kernel Image … OK
Loading Device Tree to 000000000f4ff000, end 000000000f5140b4 … OK
Adding bank: start=0x00200000, size=0x0fe00000
[ 0.000000] Linux version 4.4.143 (chenlei2830@chenlei2830-ThinkPad-T470-W10DG) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #1 S9
[ 0.000000] Boot CPU: AArch64 Processor [410fd042]
[ 0.000000] earlycon: Early serial console at MMIO32 0xff0c0000 (options ‘’)
[ 0.000000] PERCPU: Embedded 18 pages/cpu @ffffffc00ff4e000 s35992 r8192 d29544 u73728
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 64008
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.mode=emmc androidboot.slot_suffix= androidboot.serialno=c3d9b8674f4b94f6 ro7
[ 0.000000] PID hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.000000] software IO TLB [mem 0x0fead000-0x0feed000] (0MB) mapped at [ffffffc00fead000-ffffffc00feecfff]
[ 0.000000] Memory: 246344K/260096K available (5182K kernel code, 374K rwdata, 1768K rodata, 320K init, 490K bss, 13752K reserved, 0K cma-r)
[ 0.000000] .init : 0xffffff8008750000 - 0xffffff80087a0000 ( 320 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008590000 ( 5184 KB)
[ 0.000000] .rodata : 0xffffff8008590000 - 0xffffff8008750000 ( 1792 KB)
[ 0.000000] .data : 0xffffff80087a0000 - 0xffffff80087fd808 ( 375 KB)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc010000000 ( 254 MB)
[ 0.001843] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.002793] pid_max: default: 32768 minimum: 301
[ 0.003348] Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
[ 0.003949] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes)
[ 0.005373] sched-energy: CPU device node has no sched-energy-costs
[ 0.005990] Invalid sched_group_energy for CPU0
[ 0.006409] CPU0: update cpu_capacity 1024
[ 0.006829] ASID allocator initialised with 65536 entries
[ 0.016561] Detected VIPT I-cache on CPU1
[ 0.016616] Invalid sched_group_energy for CPU1
[ 0.016621] CPU1: update cpu_capacity 1024
[ 0.016625] CPU1: Booted secondary processor [410fd042]
[ 0.019579] Detected VIPT I-cache on CPU2
[ 0.019615] Invalid sched_group_energy for CPU2
[ 0.019619] CPU2: update cpu_capacity 1024
[ 0.019623] CPU2: Booted secondary processor [410fd042]
[ 0.022621] Detected VIPT I-cache on CPU3
[ 0.022655] Invalid sched_group_energy for CPU3
[ 0.022659] CPU3: update cpu_capacity 1024
[ 0.022663] CPU3: Booted secondary processor [410fd042]
[ 0.022729] Brought up 4 CPUs
[ 0.027941] SMP: Total of 4 processors activated.
[ 0.028380] CPU: All CPU(s) started at EL2
[ 0.028879] Invalid sched_group_energy for CPU3
[ 0.029300] Invalid sched_group_energy for Cluster3
[ 0.029749] Invalid sched_group_energy for CPU2
[ 0.030179] Invalid sched_group_energy for Cluster2
[ 0.030627] Invalid sched_group_energy for CPU1
[ 0.031044] Invalid sched_group_energy for Cluster1
[ 0.031502] Invalid sched_group_energy for CPU0
[ 0.031919] Invalid sched_group_energy for Cluster0
[ 0.032907] devtmpfs: initialized
[ 0.053136] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.054075] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.055015] pinctrl core: initialized pinctrl subsystem
[ 0.056510] NET: Registered protocol family 16
[ 0.061743] cpuidle: using governor menu
[ 0.062154] Registered FIQ tty driver
[ 0.062774] vdso: 2 pages (1 code @ ffffff8008596000, 1 data @ ffffff80087a4000)
[ 0.063481] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.064309] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.067077] console [pstore-1] enabled
[ 0.067449] pstore: Registered ramoops as persistent store backend
[ 0.068021] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.087548] fiq debugger fiq mode enabled
[[ 0.088299] console [ttyFIQ0] enabled
[ 0.088993] bootconsole [uart0] disabled
[ 0.089607] Registered fiq debugger ttyFIQ0
WARNING: suspend_mode_handler: Not support call: 0x4
[ 0.102423] vcc_1v8: regulator get failed, ret=-517
[ 0.103331] vcc_1v8_codec: regulator get failed, ret=-517
[ 0.104224] vcc_1v8: supplied by vcc_io
[ 0.104336] vcc_1v8_codec: supplied by vcc_io
[ 0.107703] Advanced Linux Sound Architecture Driver Initialized.
[ 0.108398] Bluetooth: Core ver 2.21
[ 0.108469] NET: Registered protocol family 31
[ 0.108486] Bluetooth: HCI device and connection manager initialized
[ 0.108506] Bluetooth: HCI socket layer initialized
[ 0.108522] Bluetooth: L2CAP socket layer initialized
[ 0.108561] Bluetooth: SCO socket layer initialized
[ 0.109662] rockchip-cpuinfo cpuinfo: Serial : 4c4e597125694188
[ 0.110270] clocksource: Switched to clocksource arch_sys_counter
[ 0.112727] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.113064] NET: Registered protocol family 2
[ 0.113767] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.113828] TCP bind hash table entries: 2048 (order: 3, 32768 bytes)
[ 0.113882] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.113964] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.114001] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.114202] NET: Registered protocol family 1
[ 0.115075] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.126386] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.129568] io scheduler noop registered (default)
[ 0.130746] phy phy-ff008000.syscon:usb2-phy@100.0: Failed to get VBUS supply regulator
[ 0.134950] dma-pl330 ff2c0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.135001] dma-pl330 ff2c0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.137421] dma-pl330 ff2d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.137465] dma-pl330 ff2d0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.137800] rockchip-pvtm ff000000.grf:pmu-pvtm: failed to get rst 0 pmu
[ 0.137955] rockchip-pvtm ff00c000.syscon:pvtm: failed to get rst 0 core
[ 0.139424] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 0.141762] ff0e0000.serial: ttyS4 at MMIO 0xff0e0000 (irq = 12, base_baud = 6770833) is a 16550A
[ 0.143701] [drm] Initialized drm 1.1.0 20060810
[ 0.143826] random: nonblocking pool is initialized
[ 0.146442] Unable to detect cache hierarchy for CPU 0
[ 0.147001] Rockchip WiFi SYS interface (V1.00) …
[ 0.147438] ff400000.usb supply vusb_d not found, using dummy regulator
[ 0.147536] ff400000.usb supply vusb_a not found, using dummy regulator
[ 0.149756] dwc2 ff400000.usb: Configuration mismatch. dr_mode forced to device
[ 0.149796] dwc2 ff400000.usb: 128 invalid for host_nperio_tx_fifo_size. Check HW configuration.
[ 0.149819] dwc2 ff400000.usb: 256 invalid for host_perio_tx_fifo_size. Check HW configuration.
[ 0.149871] dwc2 ff400000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[ 0.333748] phy phy-ff008000.syscon:usb2-phy@100.0: charger = USB_CDP_CHARGER
[ 0.334599] i2c /dev entries driver
[ 0.335745] rk3x-i2c ff050000.i2c: Initialized RK3xxx I2C bus at ffffff80088b6000
[ 0.338533] rk_tsadcv2_temp_to_code: Invalid conversion table: code=4095, temperature=2147483647
[ 0.338771] rockchip-thermal ff1f0000.tsadc: tsadc is probed successfully!
[ 0.339379] Bluetooth: HCI UART driver ver 2.3
[ 0.339404] Bluetooth: HCI UART protocol H4 registered
[ 0.339416] Bluetooth: HCI UART protocol LL registered
[ 0.339686] cpu cpu0: leakage=7
[ 0.339943] cpu cpu0: Failed to get pvtm
[ 0.341224] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=1200000000 h_limit=0
[ 0.342714] Synopsys Designware Multimedia Card Interface Driver
[ 0.343779] dwmmc_rockchip ff4a0000.dwmmc: num-slots property not found, assuming 1 slot is available
[ 0.343920] dwmmc_rockchip ff4a0000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.343974] dwmmc_rockchip ff4a0000.dwmmc: Using internal DMA controller.
[ 0.343998] dwmmc_rockchip ff4a0000.dwmmc: Version ID is 270a
[ 0.344067] dwmmc_rockchip ff4a0000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 0.344153] dwmmc_rockchip ff4a0000.dwmmc: No vmmc regulator found
[ 0.344170] dwmmc_rockchip ff4a0000.dwmmc: No vqmmc regulator found
[ 0.344593] dwmmc_rockchip ff4a0000.dwmmc: allocated mmc-pwrseq
[ 0.355427] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.366449] dwmmc_rockchip ff4a0000.dwmmc: 1 slots initialized
[ 0.367234] is31fl32xx 1-003c: register write to 0x00 failed (error -6),val=0
[ 0.395918] mmc0: queuing unknown CIS tuple 0x80 (2 bytes)
[ 0.397535] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.399121] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.401972] mmc0: queuing unknown CIS tuple 0x80 (7 bytes)
[ 0.405445] mmc0: queuing unknown CIS tuple 0x81 (9 bytes)
[ 0.468368] is31fl32xx 1-003c: register write to 0x00 failed (error -6),val=0
[ 0.491096] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 0.493364] mmc0: new high speed SDIO card at address 0001
[ 0.569478] is31fl32xx 1-003c: register write to 0x00 failed (error -6),val=0
[ 0.670516] is31fl32xx_init_regs, write to shutdown register failed
[ 0.670704] is31fl32xx 1-003c: register write to 0x26 failed (error -6),val=1
[ 0.771537] is31fl32xx 1-003c: register write to 0x26 failed (error -6),val=1
[ 0.872528] is31fl32xx 1-003c: register write to 0x26 failed (error -6),val=1
[ 0.974066] rockchip-dmc dmc: failed to get the count of devfreq-event in /dmc node
[ 0.974578] rockchip-dmc dmc: Failed to get leakage
[ 0.974779] rockchip-dmc dmc: Failed to get pvtm
[ 0.975398] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[ 0.975448] rockchip-dmc dmc: don’t add devfreq feature
[ 0.979195] rknandc_base v1.1 2017-01-11
[ 0.979898] rknandc ff4b0000.nandc: rknandc_probe clk rate = 147456000
[ 0.980016] rkflash_dev_init
[ 0.980047] init rkflash[0]
[ 0.980098] rkflash[0] init fail ret = -2
[ 0.980161] rknandc: probe of ff4b0000.nandc failed with error -1
[ 0.980439] rksfc_base v1.1 2016-01-08
[ 0.989835] rk3308-acodec ff560000.acodec: Don’t need pa-drv gpio
[ 0.989894] rk3308-acodec ff560000.acodec: De-pop as much as possible
[ 0.990122] The acodec version is: a
[ 0.991048] 1-001a supply AVDD not found, using dummy regulator
[ 0.991191] 1-001a supply DVDD not found, using dummy regulator
[ 0.991352] 1-001a supply PVDD_A not found, using dummy regulator
[ 0.991456] 1-001a supply PVDD_B not found, using dummy regulator
[ 0.991637] 1-001a supply PVDD_C not found, using dummy regulator
[ 0.991756] 1-001a supply PVDD_D not found, using dummy regulator
[ 0.992144] tas571x 1-001a: error requesting pdn_gpio: -16
[ 0.992801] tas571x: probe of 1-001a failed with error -16
[ 1.001385] rk-multicodecs bluetooth-sound: card: 0 has not been locked, re-probe again
[ 1.001462] rk-multicodecs bluetooth-sound: check_lock_card failed: -517
[ 1.001904] rk-multicodecs vad-sound: ASoC: CPU DAI (null) not registered
[ 1.003328] NET: Registered protocol family 10
[ 1.004904] NET: Registered protocol family 17
[ 1.004990] NET: Registered protocol family 15
[ 1.005353] Bluetooth: RFCOMM TTY layer initialized
[ 1.005396] Bluetooth: RFCOMM socket layer initialized
[ 1.005438] Bluetooth: RFCOMM ver 1.11
[ 1.005479] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.005519] Bluetooth: HIDP socket layer initialized
[ 1.005550] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.006203] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.006251] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6255
[ 1.006316] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.006332] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.006461] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 0, flags = 1.
[ 1.006493] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 1.006510] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.006528] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.006637] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.007241] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 135.
[ 1.007347] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 139.
[ 1.007445] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 140.
[ 1.007467] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[ 1.007567] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.007658] [BT_RFKILL]: ** disable irq
[ 1.007918] [BT_RFKILL]: bt_default device registered.
[ 1.008593] flash vendor_init_thread!
[ 1.008625] flash vendor storage:20170308 ret = -1
[ 1.011126] input: adc-keys as /devices/platform/adc-keys/input/input0
[ 1.012848] rk-multicodecs bluetooth-sound: card: 0 has not been locked, re-probe again
[ 1.012894] rk-multicodecs bluetooth-sound: check_lock_card failed: -517
[ 1.086926] rk-multicodecs vad-sound: multicodec ↔ pdm-i2s-dais mapping ok
[ 1.092842] rk-multicodecs bluetooth-sound: dummy_codec ↔ ff350000.i2s mapping ok
[ 1.096142] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.10 (r)
[ 1.096204] ======== dhd_wlan_init_plat_data ========
[ 1.096227] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 1.096259] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=35, oob_irq_flags=0x418
[ 1.096321] dhd_wlan_init_gpio: WL_REG_ON=-1
[ 1.096341] dhd_wifi_platform_load: Enter
[ 1.096407] Power-up adapter ‘DHD generic adapter’
[ 1.096835] wifi_platform_set_power = 1
[ 1.096874] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 1.096898] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.096920] [WLAN_RFKILL]: wifi turn on power. -1
[ 1.097744] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[ 1.098586] hctosys: unable to open rtc device (rtc0)
[ 1.120203] vcc_sd: disabling
[ 1.120277] vbus_host: disabling
[ 1.120290] vccio_sd: disabling
[ 1.120636] ALSA device list:
[ 1.120654] #0: rockchip,rk3308-vad
[ 1.120663] #1: rockchip,rk3308-pcm
[ 1.120671] #7: Loopback 1
[ 1.120952] Waiting for root device PARTUUID=614e0000-0000…
[ 1.397432] wifi_platform_bus_enumerate device present 1
[ 1.397479] ======== Card detection to detect SDIO card! ========
[ 1.397502] mmc0:mmc host rescan start!
[ 1.413711] bcmsdh_register: register client driver
[ 1.413953] bcmsdh_sdmmc_probe: Enter num=1
[ 1.414114] bcmsdh_sdmmc_probe: Enter num=2
[ 1.414151] bus num (host idx)=0, slot num (rca)=1
[ 1.414174] found adapter info ‘DHD generic adapter’
[ 1.414252] sdioh_attach: set sd_f2_blocksize 256
[ 1.414381] sdioh_attach: sd clock rate = 0
[ 1.414687] dhdsdio_probe : no mutex held. set lock
[ 1.414837] F1 signature read @0x18000000=0x1532a9a6
[ 1.418411] F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x2 pkg:0x3
[ 1.419644] DHD: dongle ram size is set to 524288(orig 524288) at 0x0
[ 1.419861] dhd_conf_set_chiprev: chip=0xa9a6, chiprev=2
[ 1.420402] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 1.421573] CFG80211-ERROR) wl_init_prof : wl_init_prof: No profile
[ 1.421960] wl_escan_attach: Enter
[ 1.422041] wl_escan_init: Enter
[ 1.422336] wl_create_event_handler(): thread:wl_escan_handler:6a started
[ 1.422346] tsk Enter, tsk = 0xffffffc00eed0180
[ 1.422843] dhd_attach(): thread:dhd_watchdog_thread:6b started
[ 1.423067] dhd_attach(): thread:dhd_dpc:6c started
[ 1.423322] dhd_attach(): thread:dhd_rxf:6d started
[ 1.423384] dhd_deferred_work_init: work queue initialized
[ 1.423422] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 → mode 2
[ 1.423496] dhd_bus_set_default_min_res_mask: Unhandled chip id
[ 1.424019] sdioh_cis_read: func_cis_ptr[0]=0x1070
[ 1.447291] Dongle Host Driver, version 1.579.77.41.10 (r)
[ 1.448771] wl_ext_iapsta_attach_netdev: ifidx=0, bssidx=0
[ 1.448829] Register interface [wlan0] MAC: 6c:21:a2:16:c5:1e
[ 1.448829]
[ 1.449037] dhd_tcpack_suppress_set: TCP ACK Suppress mode 2 → mode 0
[ 1.449088] dhd_wl_ioctl: returning as busstate=0
[ 1.449113] dhd_dbg_detach_pkt_monitor, 2204
[ 1.449136] dhd_bus_devreset: == Power OFF ==
[ 1.449583] bcmsdh_oob_intr_unregister: Enter
[ 1.449620] bcmsdh_oob_intr_unregister: irq is not registered
[ 1.449653] dhd_txglom_enable: enable 0
[ 1.449675] dhd_conf_set_txglom_params: txglom_mode=copy
[ 1.449700] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0
[ 1.449721] dhd_conf_set_txglom_params: txinrx_thres=-1, dhd_txminmax=1
[ 1.449744] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=-1
[ 1.449773] dhd_bus_devreset: WLAN OFF DONE
[ 1.449845] wifi_platform_set_power = 0
[ 1.449869] ======== PULL WL_REG_ON(-1) LOW! ========
[ 1.449892] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 1.449924] [WLAN_RFKILL]: wifi shut off power.
[ 1.449947] dhdsdio_probe : the lock is released.
[ 1.450117] dhd_module_init: Exit err=0
In: serial@ff0c0000
boot mode: None
CLK:
apll 816000 KHz
dpll 1300000 KHz
vpll0 1179647 KHz
vpll1 903167 KHz
aclk_bus 185714 KHz
hclk_bus 100000 KHz
pclk_bus 100000 KHz
No ethernet found.
[ 0.001840] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.002789] pid_max: default: 32768 minimum: 301
[ 0.003343] Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
[ 0.003944] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes)
[ 0.005379] sched-energy: CPU device node has no sched-energy-costs
[ 0.005995] Invalid sched_group_energy for CPU0
[ 0.006415] CPU0: update cpu_capacity 1024
[ 0.006836] ASID allocator initialised with 65536 entries
[ 0.016568] Detected VIPT I-cache on CPU1
[ 0.016622] Invalid sched_group_energy for CPU1
[ 0.016626] CPU1: update cpu_capacity 1024
[ 0.016630] CPU1: Booted secondary processor [410fd042]
[ 0.019590] Detected VIPT I-cache on CPU2
[ 0.019626] Invalid sched_group_energy for CPU2
[ 0.019630] CPU2: update cpu_capacity 1024
[ 0.019634] CPU2: Booted secondary processor [410fd042]
[ 0.022634] Detected VIPT I-cache on CPU3
[ 0.022668] Invalid sched_group_energy for CPU3
[ 0.022673] CPU3: update cpu_capacity 1024
[ 0.022677] CPU3: Booted secondary processor [410fd042]
[ 0.022743] Brought up 4 CPUs
[ 0.027949] SMP: Total of 4 processors activated.
[ 0.028388] CPU: All CPU(s) started at EL2
[ 0.028886] Invalid sched_group_energy for CPU3
[ 0.029309] Invalid sched_group_energy for Cluster3
[ 0.029758] Invalid sched_group_energy for CPU2
[ 0.030187] Invalid sched_group_energy for Cluster2
[ 0.030635] Invalid sched_group_energy for CPU1
[ 0.031051] Invalid sched_group_energy for Cluster1
[ 0.031510] Invalid sched_group_energy for CPU0
[ 0.031928] Invalid sched_group_energy for Cluster0
[ 0.032913] devtmpfs: initialized
[ 0.053145] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.054084] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.055030] pinctrl core: initialized pinctrl subsystem
[ 0.056520] NET: Registered protocol family 16
[ 0.062022] cpuidle: using governor menu
[ 0.062432] Registered FIQ tty driver
[ 0.063051] vdso: 2 pages (1 code @ ffffff8008596000, 1 data @ ffffff80087a4000)
[ 0.063755] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.064586] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.067359] console [pstore-1] enabled
[ 0.067732] pstore: Registered ramoops as persistent store backend
[ 0.068304] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.087840] fiq debugger fiq mode enabled
[[ 0.088591] console [ttyFIQ0] enabled
[ 0.089283] bootconsole [uart0] disabled
[ 0.089898] Registered fiq debugger ttyFIQ0
[ 0.102732] vcc_1v8: regulator get failed, ret=-517
[ 0.103644] vcc_1v8_codec: regulator get failed, ret=-517
[ 0.104546] vcc_1v8: supplied by vcc_io
[ 0.104656] vcc_1v8_codec: supplied by vcc_io
[ 0.108038] Advanced Linux Sound Architecture Driver Initialized.
[ 0.108740] Bluetooth: Core ver 2.21
[ 0.108809] NET: Registered protocol family 31
[ 0.108827] Bluetooth: HCI device and connection manager initialized
[ 0.108846] Bluetooth: HCI socket layer initialized
[ 0.108862] Bluetooth: L2CAP socket layer initialized
[ 0.108901] Bluetooth: SCO socket layer initialized
[ 0.109994] rockchip-cpuinfo cpuinfo: Serial : 4c4e597125694188
[ 0.110602] clocksource: Switched to clocksource arch_sys_counter
[ 0.113067] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.113378] NET: Registered protocol family 2
[ 0.114042] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.114101] TCP bind hash table entries: 2048 (order: 3, 32768 bytes)
[ 0.114156] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.114245] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.114276] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.114486] NET: Registered protocol family 1
[ 0.115329] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.126584] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.129801] io scheduler noop registered (default)
[ 0.130960] phy phy-ff008000.syscon:usb2-phy@100.0: Failed to get VBUS supply regulator
[ 0.135228] dma-pl330 ff2c0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.135279] dma-pl330 ff2c0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.137717] dma-pl330 ff2d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.137757] dma-pl330 ff2d0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.138098] rockchip-pvtm ff000000.grf:pmu-pvtm: failed to get rst 0 pmu
[ 0.138247] rockchip-pvtm ff00c000.syscon:pvtm: failed to get rst 0 core
[ 0.139708] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 0.142073] ff0e0000.serial: ttyS4 at MMIO 0xff0e0000 (irq = 12, base_baud = 6770833) is a 16550A
[ 0.143973] [drm] Initialized drm 1.1.0 20060810
[ 0.144134] random: nonblocking pool is initialized
[ 0.146694] Unable to detect cache hierarchy for CPU 0
[ 0.147243] Rockchip WiFi SYS interface (V1.00) …
[ 0.147681] ff400000.usb supply vusb_d not found, using dummy regulator
[ 0.147774] ff400000.usb supply vusb_a not found, using dummy regulator
[ 0.149994] dwc2 ff400000.usb: Configuration mismatch. dr_mode forced to device
[ 0.150033] dwc2 ff400000.usb: 128 invalid for host_nperio_tx_fifo_size. Check HW configuration.
[ 0.150051] dwc2 ff400000.usb: 256 invalid for host_perio_tx_fifo_size. Check HW configuration.
[ 0.150100] dwc2 ff400000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[ 0.373086] phy phy-ff008000.syscon:usb2-phy@100.0: charger = USB_SDP_CHARGER
[ 0.373986] i2c /dev entries driver
[ 0.375131] rk3x-i2c ff050000.i2c: Initialized RK3xxx I2C bus at ffffff80088b6000
[ 0.377926] rk_tsadcv2_temp_to_code: Invalid conversion table: code=4095, temperature=2147483647
[ 0.378162] rockchip-thermal ff1f0000.tsadc: tsadc is probed successfully!
[ 0.378750] Bluetooth: HCI UART driver ver 2.3
[ 0.378776] Bluetooth: HCI UART protocol H4 registered
[ 0.378788] Bluetooth: HCI UART protocol LL registered
[ 0.379058] cpu cpu0: leakage=7
[ 0.379306] cpu cpu0: Failed to get pvtm
[ 0.380578] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=1200000000 h_limit=0
[ 0.382083] Synopsys Designware Multimedia Card Interface Driver
[ 0.383137] dwmmc_rockchip ff4a0000.dwmmc: num-slots property not found, assuming 1 slot is available
[ 0.383277] dwmmc_rockchip ff4a0000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.383328] dwmmc_rockchip ff4a0000.dwmmc: Using internal DMA controller.
[ 0.383351] dwmmc_rockchip ff4a0000.dwmmc: Version ID is 270a
[ 0.383426] dwmmc_rockchip ff4a0000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 0.383512] dwmmc_rockchip ff4a0000.dwmmc: No vmmc regulator found
[ 0.383528] dwmmc_rockchip ff4a0000.dwmmc: No vqmmc regulator found
[ 0.383934] dwmmc_rockchip ff4a0000.dwmmc: allocated mmc-pwrseq
[ 0.394764] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.405799] dwmmc_rockchip ff4a0000.dwmmc: 1 slots initialized
[ 0.406639] is31fl32xx 1-003c: register write to 0x00 failed (error -6),val=0
[ 0.436814] mmc0: queuing unknown CIS tuple 0x80 (2 bytes)
[ 0.438395] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.439972] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.442792] mmc0: queuing unknown CIS tuple 0x80 (7 bytes)
[ 0.446242] mmc0: queuing unknown CIS tuple 0x81 (9 bytes)
[ 0.507812] is31fl32xx 1-003c: register write to 0x00 failed (error -6),val=0
[ 0.534421] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 0.539425] mmc0: new high speed SDIO card at address 0001
[ 0.608776] is31fl32xx 1-003c: register write to 0x00 failed (error -6),val=0
[ 0.709762] is31fl32xx_init_regs, write to shutdown register failed
[ 0.709951] is31fl32xx 1-003c: register write to 0x26 failed (error -6),val=1
[ 0.810862] is31fl32xx 1-003c: register write to 0x26 failed (error -6),val=1
[ 0.911858] is31fl32xx 1-003c: register write to 0x26 failed (error -6),val=1
[ 1.013328] rockchip-dmc dmc: failed to get the count of devfreq-event in /dmc node
[ 1.013838] rockchip-dmc dmc: Failed to get leakage
[ 1.014041] rockchip-dmc dmc: Failed to get pvtm
[ 1.014591] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[ 1.014678] rockchip-dmc dmc: don’t add devfreq feature
[ 1.018461] rknandc_base v1.1 2017-01-11
[ 1.019207] rknandc ff4b0000.nandc: rknandc_probe clk rate = 147456000
[ 1.019324] rkflash_dev_init
[ 1.019358] init rkflash[0]
[ 1.019408] rkflash[0] init fail ret = -2
[ 1.019475] rknandc: probe of ff4b0000.nandc failed with error -1
[ 1.019756] rksfc_base v1.1 2016-01-08
[ 1.028955] rk3308-acodec ff560000.acodec: Don’t need pa-drv gpio
[ 1.029012] rk3308-acodec ff560000.acodec: De-pop as much as possible
[ 1.029240] The acodec version is: a
[ 1.030180] 1-001a supply AVDD not found, using dummy regulator
[ 1.030325] 1-001a supply DVDD not found, using dummy regulator
[ 1.030483] 1-001a supply PVDD_A not found, using dummy regulator
[ 1.030588] 1-001a supply PVDD_B not found, using dummy regulator
[ 1.030755] 1-001a supply PVDD_C not found, using dummy regulator
[ 1.030870] 1-001a supply PVDD_D not found, using dummy regulator
[ 1.031240] tas571x 1-001a: error requesting pdn_gpio: -16
[ 1.031891] tas571x: probe of 1-001a failed with error -16
[ 1.040152] rk-multicodecs bluetooth-sound: card: 0 has not been locked, re-probe again
[ 1.040208] rk-multicodecs bluetooth-sound: check_lock_card failed: -517
[ 1.040641] rk-multicodecs vad-sound: ASoC: CPU DAI (null) not registered
[ 1.042115] NET: Registered protocol family 10
[ 1.043849] NET: Registered protocol family 17
[ 1.043941] NET: Registered protocol family 15
[ 1.044222] Bluetooth: RFCOMM TTY layer initialized
[ 1.044259] Bluetooth: RFCOMM socket layer initialized
[ 1.044301] Bluetooth: RFCOMM ver 1.11
[ 1.044341] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.044371] Bluetooth: HIDP socket layer initialized
[ 1.044402] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.045104] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.045160] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6255
[ 1.045183] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.045199] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.045331] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 0, flags = 1.
[ 1.045355] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 1.045371] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.045396] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.045517] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.046163] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 135.
[ 1.046232] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 139.
[ 1.046322] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 140.
[ 1.046352] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[ 1.046452] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.046534] [BT_RFKILL]: ** disable irq
[ 1.046838] [BT_RFKILL]: bt_default device registered.
[ 1.047470] flash vendor_init_thread!
[ 1.047500] flash vendor storage:20170308 ret = -1
[ 1.050262] input: adc-keys as /devices/platform/adc-keys/input/input0
[ 1.052034] rk-multicodecs bluetooth-sound: card: 0 has not been locked, re-probe again
[ 1.052081] rk-multicodecs bluetooth-sound: check_lock_card failed: -517
[ 1.125756] rk-multicodecs vad-sound: multicodec ↔ pdm-i2s-dais mapping ok
[ 1.130267] rk-multicodecs bluetooth-sound: dummy_codec ↔ ff350000.i2s mapping ok
[ 1.132920] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.10 (r)
[ 1.132968] ======== dhd_wlan_init_plat_data ========
[ 1.132984] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 1.133007] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=35, oob_irq_flags=0x418
[ 1.133021] dhd_wlan_init_gpio: WL_REG_ON=-1
[ 1.133034] dhd_wifi_platform_load: Enter
[ 1.133075] Power-up adapter ‘DHD generic adapter’
[ 1.133520] wifi_platform_set_power = 1
[ 1.133546] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 1.133630] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.133648] [WLAN_RFKILL]: wifi turn on power. -1
[ 1.134127] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[ 1.134827] hctosys: unable to open rtc device (rtc0)
[ 1.152589] vcc_sd: disabling
[ 1.152666] vbus_host: disabling
[ 1.152686] vccio_sd: disabling
[ 1.153133] ALSA device list:
[ 1.153167] #0: rockchip,rk3308-vad
[ 1.153182] #1: rockchip,rk3308-pcm
[ 1.153195] #7: Loopback 1
[ 1.153515] Waiting for root device PARTUUID=614e0000-0000…
[ 1.434772] wifi_platform_bus_enumerate device present 1
[ 1.434820] ======== Card detection to detect SDIO card! ========
[ 1.434843] mmc0:mmc host rescan start!
[ 1.450932] bcmsdh_register: register client driver
[ 1.451160] bcmsdh_sdmmc_probe: Enter num=1
[ 1.451314] bcmsdh_sdmmc_probe: Enter num=2
[ 1.451351] bus num (host idx)=0, slot num (rca)=1
[ 1.451374] found adapter info ‘DHD generic adapter’
[ 1.451451] sdioh_attach: set sd_f2_blocksize 256
[ 1.451536] sdioh_attach: sd clock rate = 0
[ 1.451881] dhdsdio_probe : no mutex held. set lock
[ 1.452033] F1 signature read @0x18000000=0x1532a9a6
[ 1.455547] F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x2 pkg:0x3
[ 1.456805] DHD: dongle ram size is set to 524288(orig 524288) at 0x0
[ 1.457032] dhd_conf_set_chiprev: chip=0xa9a6, chiprev=2
[ 1.457511] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 1.458694] CFG80211-ERROR) wl_init_prof : wl_init_prof: No profile
[ 1.459091] wl_escan_attach: Enter
[ 1.459165] wl_escan_init: Enter
[ 1.459492] wl_create_event_handler(): thread:wl_escan_handler:6b started
[ 1.459524] tsk Enter, tsk = 0xffffffc00eef0180
[ 1.460017] dhd_attach(): thread:dhd_watchdog_thread:6c started
[ 1.460317] dhd_attach(): thread:dhd_dpc:6d started
[ 1.460635] dhd_attach(): thread:dhd_rxf:6e started
[ 1.460682] dhd_deferred_work_init: work queue initialized
[ 1.460709] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 → mode 2
[ 1.460780] dhd_bus_set_default_min_res_mask: Unhandled chip id
[ 1.461089] sdioh_cis_read: func_cis_ptr[0]=0x1070
[ 1.472350] Dongle Host Driver, version 1.579.77.41.10 (r)
[ 1.473861] wl_ext_iapsta_attach_netdev: ifidx=0, bssidx=0
[ 1.473919] Register interface [wlan0] MAC: 6c:21:a2:16:c5:1e
[ 1.473919]
[ 1.474209] dhd_tcpack_suppress_set: TCP ACK Suppress mode 2 → mode 0
[ 1.474259] dhd_wl_ioctl: returning as busstate=0
[ 1.474284] dhd_dbg_detach_pkt_monitor, 2204
[ 1.474307] dhd_bus_devreset: == Power OFF ==
[ 1.474745] bcmsdh_oob_intr_unregister: Enter
[ 1.474772] bcmsdh_oob_intr_unregister: irq is not registered
[ 1.474799] dhd_txglom_enable: enable 0
[ 1.474814] dhd_conf_set_txglom_params: txglom_mode=copy
[ 1.474829] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0
[ 1.474844] dhd_conf_set_txglom_params: txinrx_thres=-1, dhd_txminmax=1
[ 1.474861] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=-1
[ 1.474875] dhd_bus_devreset: WLAN OFF DONE
[ 1.474941] wifi_platform_set_power = 0
[ 1.474958] ======== PULL WL_REG_ON(-1) LOW! ========
[ 1.474975] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 1.475000] [WLAN_RFKILL]: wifi shut off power.
[ 1.475015] dhdsdio_probe : the lock is released.
[ 1.475145] dhd_module_init: Exit err=0
[ 4.052785] vendor storage:20160801 ret = -1
你改了内核什么地方?
我也碰到同样问题,最后怎么解决的?
请问怎么解决的?
问题出现在设备树识别的地方,需要在dts处根据自己的版子进行修改
666
请问这个设备在dts中叫什么名字?
我用rk社区的uboot,kernel也遇到了这个问题,请问楼主解决了吗?解决了的话,是问题出在哪里了?谢谢
