rk3288 android7.1使用ap6335 wifi可以正常打开,蓝牙一打开就提示“蓝牙共享已停止运行”,有遇到同样问题小伙伴吗,求支援!
{:4_89:}{:4_89:}{:4_89:}{:4_89:}{:4_89:}{:4_89:}{:4_89:}
先确认软件log是否有什么特殊的异常
jpchen 发表于 2019-7-11 14:25
先确认软件log是否有什么特殊的异常
--------- beginning of system
07-12 01:27:05.222 I/vold ( 205): Vold 3.0 (the awakening) firing up
07-12 01:27:05.222 V/vold ( 205): Detected support for: ext4 f2fs vfat
07-12 01:27:05.227 D/Vold ( 205): Vendor path: /sys/bus/usb/devices/1-1/idVendor
07-12 01:27:05.227 D/Vold ( 205): === config_file is: 0001_0000
07-12 01:27:05.247 D/vold ( 205): e4crypt_init_user0
07-12 01:27:05.247 D/vold ( 205): e4crypt_prepare_user_storage for volume null, user 0, serial 0, flags 1
07-12 01:27:05.247 D/vold ( 205): Preparing: /data/system/users/0
07-12 01:27:05.247 D/vold ( 205): Preparing: /data/misc/profiles/cur/0
07-12 01:27:05.248 D/vold ( 205): Preparing: /data/misc/profiles/cur/0/foreign-dex
07-12 01:27:05.248 D/vold ( 205): Preparing: /data/system_de/0
07-12 01:27:05.249 D/vold ( 205): Preparing: /data/misc_de/0
07-12 01:27:05.249 D/vold ( 205): Preparing: /data/user_de/0
07-12 01:27:05.249 D/vold ( 205): e4crypt_unlock_user_key 0 serial=0 token_present=0
07-12 01:27:05.345 E/DrmService( 229): ----------------running drmservice---------------
07-12 01:27:05.345 E/DrmService( 229): get prop_board_platform,prop_board_platform = rk3288 , diff=-1
07-12 01:27:05.345 E/DrmService( 229): rknand_sys_storage open fail
07-12 01:27:05.345 E/DrmService( 229): Get HID data:
07-12 01:27:05.411 E/DrmService( 229): ----------serianno =3GKL24GMUB
07-12 01:27:05.412 E/DrmService( 229): Unable to open path (/sys/class/android_usb/android0/iSerial),error is(No such file or directory)
07-12 01:27:05.412 E/DrmService( 229): try /config/usb_gadget/g1/strings/0x409/serialnumber
07-12 01:27:05.412 E/DrmService( 229): auto generate serialno,serialno = 3GKL24GMUB
--------- beginning of main
07-12 01:27:05.522 I/Netd ( 241): Netd 1.0 starting
07-12 01:27:05.529 D/TetherController( 241): Setting IP forward enable = 0
07-12 01:27:05.558 I/gatekeeperd( 242): Starting gatekeeperd…
07-12 01:27:05.565 I/cameraserver( 233): ServiceManager: 0xad919420
07-12 01:27:05.565 I/CameraService( 233): CameraService started (pid=233)
07-12 01:27:05.565 I/CameraService( 233): CameraService process starting
07-12 01:27:05.565 W/BatteryNotifier( 233): batterystats service unavailable!
07-12 01:27:05.582 I/mediacodec( 237): @@@ mediacodecservice starting
07-12 01:27:05.583 W//system/bin/mediacodec( 237): libminijail: allowing syscall: clock_gettime
07-12 01:27:05.584 W//system/bin/mediacodec( 237): libminijail: allowing syscall: connect
07-12 01:27:05.584 W//system/bin/mediacodec( 237): libminijail: allowing syscall: fcntl64
07-12 01:27:05.584 W//system/bin/mediacodec( 237): libminijail: allowing syscall: socket
07-12 01:27:05.584 W//system/bin/mediacodec( 237): libminijail: allowing syscall: writev
07-12 01:27:05.586 W//system/bin/mediacodec( 237): libminijail: logging seccomp filter failures
07-12 01:27:05.711 I/ ( 232): sMaxFastTracks = 8
07-12 01:27:05.711 I/audioserver( 232): ServiceManager: 0xaa899420
07-12 01:27:05.712 W/BatteryNotifier( 232): batterystats service unavailable!
07-12 01:27:05.712 I/AudioFlinger( 232): Using default 3000 mSec as standby time.
07-12 01:27:05.712 I/AudioPolicyService( 232): AudioPolicyService CSTOR in new mode
07-12 01:27:05.720 I/APM::ConfigParsingUtils( 232): loadAudioPolicyConfig() loaded /system/etc/audio_policy.conf
07-12 01:27:05.723 V/MediaUtils( 239): physMem: 2093613056
07-12 01:27:05.723 V/MediaUtils( 239): requested limit: 418722600
07-12 01:27:05.723 V/MediaUtils( 239): actual limit: 418722600
07-12 01:27:05.723 V/MediaUtils( 239): original limits: 4294967295/4294967295
07-12 01:27:05.723 V/MediaUtils( 239): new limits: 418722600/4294967295
07-12 01:27:05.723 W//system/bin/mediaextractor( 239): libminijail: allowing syscall: clock_gettime
07-12 01:27:05.723 W//system/bin/mediaextractor( 239): libminijail: allowing syscall: connect
07-12 01:27:05.723 W//system/bin/mediaextractor( 239): libminijail: allowing syscall: fcntl64
07-12 01:27:05.724 W//system/bin/mediaextractor( 239): libminijail: allowing syscall: socket
07-12 01:27:05.724 W//system/bin/mediaextractor( 239): libminijail: allowing syscall: writev
07-12 01:27:05.725 W//system/bin/mediaextractor( 239): libminijail: logging seccomp filter failures
07-12 01:27:05.737 D/AudioHardwareTiny( 232): ALSA Audio Version: V1.1.0
07-12 01:27:05.737 D/alsa_route( 232): Get route table for sound card0 rockchiprt5640c
07-12 01:27:05.737 D/AudioHardwareTiny( 232): read_snd_card_info buf0 = rockchiprt5640c
07-12 01:27:05.737 D/AudioHardwareTiny( 232): read_snd_card_info buf1 =
07-12 01:27:05.737 D/AudioHardwareTiny( 232): read_snd_card_info buf2 =
07-12 01:27:05.737 I/AudioFlinger( 232): loadHwModule() Loaded primary audio interface from Manta audio HW HAL (audio) handle 10
07-12 01:27:05.737 I/AudioFlinger( 232): openOutput(), module 10 Device 2, SamplingRate 48000, Format 0x000001, Channels 3, flags 2
07-12 01:27:05.737 D/AudioHardwareTiny( 232): audio hal adev_open_output_stream devices = 0x2, flags = 2, samplerate = 48000
07-12 01:27:05.737 D/AudioHardwareTiny( 232): out->config.rate = 44100, out->config.channels = 2 out->config.format = 0,out->config.flag = 0
07-12 01:27:05.738 I/AudioFlinger( 232): HAL output buffer size 512 frames, normal sink buffer size 1024 frames
07-12 01:27:05.750 D/libEGL ( 220): loaded /vendor/lib/egl/libGLES_mali.so
07-12 01:27:05.760 I/BufferProvider( 232): found effect “Multichannel Downmix To Stereo” from The Android Open Source Project
07-12 01:27:05.760 I/AudioFlinger( 232): Using module 10 has the primary audio interface
07-12 01:27:05.760 D/AudioHardwareTiny( 232): adev_set_mode: set_mode = 0
07-12 01:27:05.766 I/AudioFlinger( 232): AudioFlinger’s thread 0xaa403580 ready to run
07-12 01:27:05.766 W/BatteryNotifier( 232): batterystats service unavailable!
07-12 01:27:05.766 D/AudioHardwareTiny( 232): out_set_parameters: kvpairs = routing=2
07-12 01:27:05.767 D/AudioHardwareTiny( 232): pcm_config->rate:44100,in->requested_rate:48000,in->channel_mask:2
07-12 01:27:05.769 D/AudioHardwareTiny( 232): in->mSpeexFrameSize:560
07-12 01:27:05.770 W/BatteryNotifier( 232): batterystats service unavailable!
07-12 01:27:05.770 W/AudioFlinger( 232): no wake lock to update, system not ready yet
07-12 01:27:05.791 I/mali_so ( 220): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 876; [Func] : base_context_deal_with_version_affairs_rk_ext;
07-12 01:27:05.791 I/mali_so ( 220): arm_release_ver of this mali_so is ‘r18p0-01rel0’, rk_so_ver is ‘3@0’.
07-12 01:27:05.792 I/mali_so ( 220): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 901; [Func] : base_context_deal_with_version_affairs_rk_ext;
07-12 01:27:05.792 I/mali_so ( 220): arm_release_vers are match. to set the full mali_ver ‘r18p0-01rel0-x-3@0’ as value of ‘sys.gmali.version’.
07-12 01:27:05.799 I/AudioFlinger( 232): AudioFlinger’s thread 0xaa0031c0 ready to run
07-12 01:27:05.801 I/bt_a2dp_hw( 232): adev_open: adev_open in A2dp_hw module
07-12 01:27:05.801 I/AudioFlinger( 232): loadHwModule() Loaded a2dp audio interface from A2DP Audio HW HAL (audio) handle 18
07-12 01:27:05.804 I/AudioFlinger( 232): loadHwModule() Loaded usb audio interface from USB audio HW HAL (audio) handle 26
07-12 01:27:05.807 I/r_submix( 232): adev_open(name=audio_hw_if)
07-12 01:27:05.807 I/r_submix( 232): adev_init_check()
07-12 01:27:05.807 I/AudioFlinger( 232): loadHwModule() Loaded r_submix audio interface from Wifi Display audio HAL (audio) handle 34
07-12 01:27:05.807 D/r_submix( 232): adev_open_input_stream(addr=0)
07-12 01:27:05.807 D/r_submix( 232): submix_audio_device_create_pipe_l(addr=0, idx=9)
07-12 01:27:05.807 D/r_submix( 232): now using address 0 for route 9
07-12 01:27:05.811 I/AudioFlinger( 232): AudioFlinger’s thread 0xa9f831c0 ready to run
07-12 01:27:05.811 D/r_submix( 232): adev_close_input_stream()
07-12 01:27:05.811 D/r_submix( 232): submix_audio_device_release_pipe_l(idx=9) addr=0
07-12 01:27:05.811 D/r_submix( 232): submix_audio_device_destroy_pipe_l(): pipe destroyed
07-12 01:27:05.812 I/RadioService( 232): RadioService
07-12 01:27:05.812 I/RadioService( 232): onFirstRef
07-12 01:27:05.812 E/RadioService( 232): couldn’t load radio module radio.primary (No such file or directory)
07-12 01:27:05.813 E/SoundTriggerHwService( 232): couldn’t load sound trigger module sound_trigger.primary (No such file or directory)
07-12 01:27:05.813 E/hwc_rk ( 220): BP: baseparamter file can not be find
07-12 01:27:05.815 W/hwc-drm-connector( 220): DrmConnector init id=80,type=HDMI-A
07-12 01:27:05.816 W/hwc-drm-connector( 220): Could not get hdr source metadata property
07-12 01:27:05.816 E/hwc-drm-resources( 220): is_hdr_panel_support_st2084:line=1331, blob is null
07-12 01:27:05.817 W/hwc-drm-connector( 220): DrmConnector init id=87,type=LVDS
07-12 01:27:05.817 W/hwc-drm-connector( 220): Could not get hdr source metadata property
07-12 01:27:05.817 W/hwc-drm-connector( 220): Could not get hdr panel metadata property
07-12 01:27:05.817 W/hwc-drm-connector( 220): Could not get hdmi_output_colorimetry property
07-12 01:27:05.817 W/hwc-drm-connector( 220): Could not get hdmi_output_format property
07-12 01:27:05.818 W/hwc-drm-connector( 220): Could not get hdmi_output_depth property
07-12 01:27:05.818 W/hwc_rk ( 220): BP: DEVICE baseparameter is not ready,can’t use it !
07-12 01:27:05.818 E/hwc-drm-resources( 220): BP: hwc get baseparameter err
07-12 01:27:05.819 E/hwc-drm-plane( 220): Could not get rotation property
07-12 01:27:05.820 E/hwc-drm-plane( 220): Could not get AREA_ID property
07-12 01:27:05.822 E/hwc-drm-plane( 220): Could not get rotation property
07-12 01:27:05.823 E/hwc-drm-plane( 220): Could not get AREA_ID property
07-12 01:27:05.825 E/hwc-drm-plane( 220): Could not get rotation property
07-12 01:27:05.826 E/hwc-drm-plane( 220): Could not get AREA_ID property
07-12 01:27:05.827 E/hwc-drm-plane( 220): Could not get rotation property
07-12 01:27:05.828 E/hwc-drm-plane( 220): Could not get AREA_ID property
07-12 01:27:05.830 E/hwc-drm-plane( 220): Could not get rotation property
07-12 01:27:05.830 I/hwc-drm-plane( 220): Could not get alpha property
07-12 01:27:05.831 E/hwc-drm-plane( 220): Could not get AREA_ID property
07-12 01:27:05.832 E/hwc-drm-plane( 220): Could not get rotation property
07-12 01:27:05.832 I/hwc-drm-plane( 220): Could not get alpha property
07-12 01:27:05.833 E/hwc-drm-plane( 220): Could not get AREA_ID property
07-12 01:27:05.834 E/hwc-drm-plane( 220): Could not get rotation property
07-12 01:27:05.835 I/hwc-drm-plane( 220): Could not get alpha property
07-12 01:27:05.835 E/hwc-drm-plane( 220): Could not get AREA_ID property
07-12 01:27:05.837 E/hwc-drm-plane( 220): Could not get rotation property
07-12 01:27:05.837 I/hwc-drm-plane( 220): Could not get alpha property
07-12 01:27:05.838 E/hwc-drm-plane( 220): Could not get AREA_ID property
07-12 01:27:05.839 E/hwc-drm-plane( 220): Could not get rotation property
07-12 01:27:05.840 I/hwc-drm-plane( 220): Could not get alpha property
07-12 01:27:05.840 E/hwc-drm-plane( 220): Could not get AREA_ID property
07-12 01:27:05.842 E/hwc-drm-plane( 220): Could not get rotation property
07-12 01:27:05.842 I/hwc-drm-plane( 220): Could not get alpha property
07-12 01:27:05.843 E/hwc-drm-plane( 220): Could not get AREA_ID property
07-12 01:27:05.844 E/hwc-drm-plane( 220): Could not get rotation property
07-12 01:27:05.845 E/hwc-drm-plane( 220): Could not get AREA_ID property
07-12 01:27:05.846 E/hwc-drm-plane( 220): Could not get rotation property
07-12 01:27:05.847 E/hwc-drm-plane( 220): Could not get AREA_ID property
07-12 01:27:05.849 E/hwc-drm-plane( 220): Could not get rotation property
07-12 01:27:05.850 E/hwc-drm-plane( 220): Could not get AREA_ID property
07-12 01:27:05.851 E/hwc-drm-plane( 220): Could not get rotation property
07-12 01:27:05.852 E/hwc-drm-plane( 220): Could not get AREA_ID property
07-12 01:27:05.854 E/hwc-drm-plane( 220): Could not get rotation property
07-12 01:27:05.854 I/hwc-drm-plane( 220): Could not get alpha property
07-12 01:27:05.855 E/hwc-drm-plane( 220): Could not get AREA_ID property
07-12 01:27:05.856 E/hwc-drm-plane( 220): Could not get rotation property
07-12 01:27:05.857 I/hwc-drm-plane( 220): Could not get alpha property
07-12 01:27:05.857 E/hwc-drm-plane( 220): Could not get AREA_ID property
07-12 01:27:05.859 E/hwc-drm-plane( 220): Could not get rotation property
07-12 01:27:05.859 I/hwc-drm-plane( 220): Could not get alpha property
07-12 01:27:05.860 E/hwc-drm-plane( 220): Could not get AREA_ID property
07-12 01:27:05.861 E/hwc-drm-plane( 220): Could not get rotation property
07-12 01:27:05.861 I/hwc-drm-plane( 220): Could not get alpha property
07-12 01:27:05.862 E/hwc-drm-plane( 220): Could not get AREA_ID property
07-12 01:27:05.863 E/hwc-drm-plane( 220): Could not get rotation property
07-12 01:27:05.864 I/hwc-drm-plane( 220): Could not get alpha property
07-12 01:27:05.864 E/hwc-drm-plane( 220): Could not get AREA_ID property
07-12 01:27:05.866 E/hwc-drm-plane( 220): Could not get rotation property
07-12 01:27:05.866 I/hwc-drm-plane( 220): Could not get alpha property
07-12 01:27:05.867 E/hwc-drm-plane( 220): Could not get AREA_ID property
07-12 01:27:05.868 E/hwc-drm-display-compositor( 220): vop_bw: Error opening /sys/class/devfreq/dmc/vop_bandwidth: No such file or directory
07-12 01:27:05.869 D/hwc_rk ( 220): RK_GRAPHICS_VER=commit-id:771ae06
07-12 01:27:05.870 I/SurfaceFlinger( 220): Using composer version 1.4
07-12 01:27:05.870 W/hwc_rk ( 220): BP: RESOLUTION baseparameter is not ready,can’t use it !
07-12 01:27:05.870 E/hwcomposer-drm( 220): get native config fail, res = -1
07-12 01:27:05.870 W/hwc_rk ( 220): BP: FB_SIZE baseparameter is not ready,can’t use it !
07-12 01:27:05.870 W/hwcomposer-drm( 220): BP: hwc get baseparameter config err ,res = -1
07-12 01:27:05.870 E/hwcomposer-drm( 220): hwc_get_display_configs:Failed to get connector for display 1 line=3476
07-12 01:27:05.870 I/SurfaceFlinger( 220): EGL information:
07-12 01:27:05.870 I/SurfaceFlinger( 220): vendor : Android
07-12 01:27:05.870 I/SurfaceFlinger( 220): version : 1.4 Android META-EGL
07-12 01:27:05.870 I/SurfaceFlinger( 220): extensions: EGL_KHR_get_all_proc_addresses EGL_ANDROID_presentation_time EGL_KHR_swap_buffers_with_damage EGL_ANDROID_create_native_client_buffer EGL_ANDROID_front_buffer_auto_refresh EGL_KHR_image EGL_KHR_image_base EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_KHR_fence_sync EGL_KHR_create_context EGL_KHR_config_attribs EGL_KHR_surfaceless_context EGL_EXT_create_context_robustness EGL_ANDROID_image_native_buffer EGL_KHR_wait_sync EGL_ANDROID_recordable EGL_KHR_partial_update EGL_KHR_mutable_render_buffer
07-12 01:27:05.870 I/SurfaceFlinger( 220): Client API: OpenGL_ES
07-12 01:27:05.870 I/SurfaceFlinger( 220): EGLSurface: 8-8-8-8, config=0xaa38e318
07-12 01:27:05.896 I/SurfaceFlinger( 220): OpenGL ES informations:
07-12 01:27:05.896 I/SurfaceFlinger( 220): vendor : ARM
07-12 01:27:05.896 I/SurfaceFlinger( 220): renderer : Mali-T760
07-12 01:27:05.896 I/SurfaceFlinger( 220): version : OpenGL ES 3.2 v1.r18p0-01rel0.a8c44f1458350036c79c8cd7019f2c8f
07-12 01:27:05.897 I/SurfaceFlinger( 220): extensions: GL_EXT_debug_marker GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth24 GL_OES_depth_texture GL_OES_depth_texture_cube_map GL_OES_packed_depth_stencil GL_OES_rgb8_rgba8 GL_EXT_read_format_bgra GL_OES_compressed_paletted_texture GL_OES_compressed_ETC1_RGB8_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_EGL_image_external_essl3 GL_OES_EGL_sync GL_OES_texture_npot GL_OES_vertex_half_float GL_OES_required_internalformat GL_OES_vertex_array_object GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_EXT_texture_rg GL_EXT_texture_type_2_10_10_10_REV GL_OES_fbo_render_mipmap GL_OES_element_index_uint GL_EXT_shadow_samplers GL_OES_texture_compression_astc GL_KHR_texture_compression_astc_ldr GL_KHR_texture_compression_astc_hdr GL_KHR_texture_compression_astc_sliced_3d GL_KHR_debug GL_EXT_occlusion_query_boolean GL_EXT_disjoint_timer_query GL_EXT_blend_minmax GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_OES_texture_3D GL_EXT_texture_storage GL_EXT_multisamp
07-12 01:27:05.897 I/SurfaceFlinger( 220): GL_MAX_TEXTURE_SIZE = 8192
07-12 01:27:05.897 I/SurfaceFlinger( 220): GL_MAX_VIEWPORT_DIMS = 8192
07-12 01:27:05.898 D/mali_winsys( 220): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:27:06.085 I/SoftKeymaster( 236): system/keymaster/soft_keymaster_device.cpp, Line 131: Creating device
07-12 01:27:06.085 D/SoftKeymaster( 236): system/keymaster/soft_keymaster_device.cpp, Line 132: Device address: 0xb2332000
07-12 01:27:06.095 D/SurfaceFlinger( 220): shader cache generated - 24 shaders in 196.706436 ms
07-12 01:27:06.100 D/SurfaceFlinger( 220): Set power mode=2, type=0 flinger=0xaa3b2000
07-12 01:27:06.178 W/hwc_rk ( 220): BP: RESOLUTION baseparameter is not ready,can’t use it !
07-12 01:27:06.178 E/hwcomposer-drm( 220): get native config fail, res = -1
07-12 01:27:06.178 I/rockchiprga( 220): Rga built version:version:8f47339+2019-07-11 19:51:01
07-12 01:27:06.180 D/GRALLOC-ROCKCHIP( 220): RK_GRAPHICS_VER=commit-id:3bb0f11
07-12 01:27:06.180 D/GRALLOC-ROCKCHIP( 220): gralloc ver ‘1.0.6’ on arm_release_ver ‘r13p0-00rel0’.
07-12 01:27:06.202 D/hwc_rk ( 220): BP: main brightness 50
07-12 01:27:06.202 D/hwc_rk ( 220): BP: main contrast 50
07-12 01:27:06.202 D/hwc_rk ( 220): BP: main saturation 50
07-12 01:27:06.202 D/hwc_rk ( 220): BP: main hue 50
07-12 01:27:06.281 I/vpu_api ( 240): dlopen vpu lib success
07-12 01:27:06.290 I/mediaserver( 240): ServiceManager: 0xb2319480
07-12 01:27:06.291 W/BatteryNotifier( 240): batterystats service unavailable!
07-12 01:27:06.369 I/vpu_api ( 238): dlopen vpu lib success
07-12 01:27:06.370 I/mediaserver( 238): ServiceManager: 0xa9d19480
07-12 01:27:06.625 I/vpu_api ( 233): dlopen vpu lib success
07-12 01:27:06.700 I/vpu_api ( 231): dlopen vpu lib success
07-12 01:27:06.735 D/AndroidRuntime( 231): >>>>>> START com.android.internal.os.ZygoteInit uid 0 <<<<<<
07-12 01:27:06.779 D/AndroidRuntime( 231): CheckJNI is OFF
07-12 01:27:06.782 D/CameraHal( 233): createInstance(1035): open xml file(/etc/cam_board.xml) success
07-12 01:27:06.783 E/CameraHal( 233): cam_board.xml version(v0x0.0x0.0x0) != xml parser version(v0x0.0xf.0x0)
07-12 01:27:06.784 D/CameraHal( 233):
07-12 01:27:06.784 D/CameraHal( 233): Cam_board.xml Version Check:
07-12 01:27:06.784 D/CameraHal( 233): /etc/cam_board.xml : v0.0xf.0
07-12 01:27:06.784 D/CameraHal( 233): CameraHal_board_xml_parser: v0x0.0xf.0x0
07-12 01:27:06.784 D/CameraHal( 233): ParserSensorInfo(190): SensorName(OV8858)
07-12 01:27:06.784 D/CameraHal( 233): ParserSensorInfo(196): lensName(LG-9569A2)
07-12 01:27:06.784 D/CameraHal( 233): ParserSensorInfo(198): SensorDevID(CAMSYS_DEVID_SENSOR_1B)
07-12 01:27:06.784 D/CameraHal( 233): ParserSensorInfo(209): SensorDevID(33554432)
07-12 01:27:06.784 D/CameraHal( 233): ParserSensorInfo(211): SensorHostDevID(CAMSYS_DEVID_MARVIN)
07-12 01:27:06.784 D/CameraHal( 233): ParserSensorInfo(226): Sensori2cBusNum(3)
07-12 01:27:06.784 D/CameraHal( 233): ParserSensorInfo(229): SensorI2cAddrByte(2)
07-12 01:27:06.784 D/CameraHal( 233): ParserSensorInfo(232): SensorI2cRate(100000)
07-12 01:27:06.784 D/CameraHal( 233): ParserSensorInfo(240): SensorAvdd(NC) min(0) max(0)
07-12 01:27:06.784 D/CameraHal( 233): ParserSensorInfo(254): SensorDvdd(NC) min(0) max(0)
07-12 01:27:06.784 D/CameraHal( 233): ParserSensorInfo(247): SensorDovdd(NC) min(18000000) max(18000000)
07-12 01:27:06.784 D/CameraHal( 233): ParserSensorInfo(235): SensorMclk(24000000)
07-12 01:27:06.784 D/CameraHal( 233): ParserSensorInfo(285): SensorGpioPwen(RK30_PIN0_PC1) active(1)
07-12 01:27:06.784 D/CameraHal( 233): ParserSensorInfo(279): SensorGpioRst(NC) active(0)
07-12 01:27:06.784 D/CameraHal( 233): ParserSensorInfo(261): SensorGpioPwdn(RK30_PIN2_PB7) active(0)
07-12 01:27:06.784 D/CameraHal( 233): ParserSensorInfo(291): SensorFacing(back)
07-12 01:27:06.784 D/CameraHal( 233): ParserSensorInfo(300): SensorInterface(MIPI)
07-12 01:27:06.784 D/CameraHal( 233): ParserSensorInfo(313): SensorMirrorFlip(0)
07-12 01:27:06.784 D/CameraHal( 233): ParserSensorInfo(316): SensorOrientation(0)
07-12 01:27:06.784 D/CameraHal( 233): ParserSensorInfo(435): SensorFovParemeter fov_h(60.0)(60.000000) fov_v(60.0)(60.000000)
07-12 01:27:06.784 D/CameraHal( 233): ParserSensorInfo(438): SensorAWB_Frame_Skip fps(0)
07-12 01:27:06.784 D/CameraHal( 233): ParserSensorInfo(397): SensorGpioPwdn(RK30_PIN2_PB7) active(0)
07-12 01:27:06.784 D/CameraHal( 233): ParserSensorInfo(405): SensorPhy: MIPI lane: 2 phyindex: 0 fmt: 0x2b
07-12 01:27:06.784 D/CameraHal( 233): ParserVCMInfo(450): VCMDrvName(BuiltInSensor)
07-12 01:27:06.785 D/CameraHal( 233): ParserVCMInfo(453): VCMName(NC)
07-12 01:27:06.785 D/CameraHal( 233): ParserVCMInfo(456): VCMI2cBusNum(3)
07-12 01:27:06.785 D/CameraHal( 233): ParserVCMInfo(459): VCMI2cAddrByte(0)
07-12 01:27:06.785 D/CameraHal( 233): ParserVCMInfo(462): VCMI2cRate(0)
07-12 01:27:06.785 D/CameraHal( 233): ParserVCMInfo(477): VCMVdd(NC) min(0) max(0)
07-12 01:27:06.785 D/CameraHal( 233): ParserVCMInfo(471): VCMGpioPower(NC) active(0)
07-12 01:27:06.785 D/CameraHal( 233): ParserVCMInfo(465): VCMGpioPwdn(NC) active(0)
07-12 01:27:06.785 D/CameraHal( 233): ParserVCMInfo(490): start current(0) rated current(100) vcm max(100) step mode(4) drv max(100)
07-12 01:27:06.785 D/CameraHal( 233): ParserFlashInfo(509): FlashName(Internal)
07-12 01:27:06.785 D/CameraHal( 233): ParserFlashInfo(512): FlashI2cBusNum(0)
07-12 01:27:06.785 D/CameraHal( 233): ParserFlashInfo(515): FlashI2cAddrByte(0)
07-12 01:27:06.785 D/CameraHal( 233): ParserFlashInfo(518): FlashI2cRate(0)
07-12 01:27:06.785 D/CameraHal( 233): ParserFlashInfo(521): FlashTrigger(NC) active(0)
07-12 01:27:06.785 D/CameraHal( 233): ParserFlashInfo(525): FlashEn(NC) active(0)
07-12 01:27:06.785 D/CameraHal( 233): ParserFlashInfo(532): FlashLuminance(0)
07-12 01:27:06.785 D/CameraHal( 233): ParserFlashInfo(535): FlashColorTemp(0)
07-12 01:27:06.785 D/CameraHal( 233): StartElementHandler(964): HDR(1)!
07-12 01:27:06.785 D/CameraHal( 233): StartElementHandler(968): ZSL(1)!
07-12 01:27:06.785 D/CameraHal( 233): StartElementHandler(972): zoom(1)!
07-12 01:27:06.785 D/CameraHal( 233): StartElementHandler(1014): Continue_SnapShot(1)!
07-12 01:27:06.785 D/CameraHal( 233): StartElementHandler(1017): InterpolationRes(0)!
07-12 01:27:06.785 D/CameraHal( 233): StartElementHandler(1002): PreviewSize(0x0)!
07-12 01:27:06.786 D/CameraHal( 233): StartElementHandler(998): face detect config(0),max face num is (1)!
07-12 01:27:06.786 D/CameraHal( 233): StartElementHandler(993): Gammaout support 0(mGamma:1.000000,mOffSet:0)!
07-12 01:27:06.786 D/CameraHal( 233): ParserDVConfig(802): DV_QCIF(qcif) resolution(176x144) fps(10) support(1)
07-12 01:27:06.786 D/CameraHal( 233): ParserDVConfig(814): DV_QVGA(qvga) resolution(320x240) fps(10) support(1)
07-12 01:27:06.786 D/CameraHal( 233): ParserDVConfig(826): DV_CIF(cif) resolution(352x288) fps(10) support(1)
07-12 01:27:06.786 D/CameraHal( 233): ParserDVConfig(838): DV_VGA(480p) resolution(640x480) fps(10) support(0)
07-12 01:27:06.786 D/CameraHal( 233): ParserDVConfig(850): DV_480P(480p) resolution(720x480) fps(10) support(0)
07-12 01:27:06.786 D/CameraHal( 233): ParserDVConfig(874): DV_720P(720p) resolution(1280x720) fps(10) support(1)
07-12 01:27:06.786 D/CameraHal( 233): ParserDVConfig(886): DV_1080P(1080p) resolution(1920x1080) fps(10) support(1)
07-12 01:27:06.786 D/CameraHal( 233): ParserSensorInfo(190): SensorName(GC2035)
07-12 01:27:06.786 D/CameraHal( 233): ParserSensorInfo(198): SensorDevID(CAMSYS_DEVID_SENSOR_1A)
07-12 01:27:06.786 D/CameraHal( 233): ParserSensorInfo(209): SensorDevID(16777216)
07-12 01:27:06.786 D/CameraHal( 233): ParserSensorInfo(211): SensorHostDevID(CAMSYS_DEVID_MARVIN)
07-12 01:27:06.786 D/CameraHal( 233): ParserSensorInfo(226): Sensori2cBusNum(3)
07-12 01:27:06.786 D/CameraHal( 233): ParserSensorInfo(229): SensorI2cAddrByte(2)
07-12 01:27:06.786 D/CameraHal( 233): ParserSensorInfo(232): SensorI2cRate(100000)
07-12 01:27:06.786 D/CameraHal( 233): ParserSensorInfo(240): SensorAvdd(NC) min(0) max(0)
07-12 01:27:06.786 D/CameraHal( 233): ParserSensorInfo(254): SensorDvdd(NC) min(0) max(0)
07-12 01:27:06.786 D/CameraHal( 233): ParserSensorInfo(247): SensorDovdd(NC) min(18000000) max(18000000)
07-12 01:27:06.786 D/CameraHal( 233): ParserSensorInfo(235): SensorMclk(24000000)
07-12 01:27:06.786 D/CameraHal( 233): ParserSensorInfo(285): SensorGpioPwen(RK30_PIN0_PC1) active(1)
07-12 01:27:06.786 D/CameraHal( 233): ParserSensorInfo(279): SensorGpioRst(NC) active(0)
07-12 01:27:06.786 D/CameraHal( 233): ParserSensorInfo(261): SensorGpioPwdn(RK30_PIN2_PB6) active(1)
07-12 01:27:06.786 D/CameraHal( 233): ParserSensorInfo(291): SensorFacing(front)
07-12 01:27:06.786 D/CameraHal( 233): ParserSensorInfo(300): SensorInterface(CCIR601)
07-12 01:27:06.786 D/CameraHal( 233): ParserSensorInfo(313): SensorMirrorFlip(0)
07-12 01:27:06.786 D/CameraHal( 233): ParserSensorInfo(316): SensorOrientation(0)
07-12 01:27:06.786 D/CameraHal( 233): ParserSensorInfo(435): SensorFovParemeter fov_h(60.0)(60.000000) fov_v(60.0)(60.000000)
07-12 01:27:06.786 D/CameraHal( 233): ParserSensorInfo(438): SensorAWB_Frame_Skip fps(15)
07-12 01:27:06.787 D/CameraHal( 233): ParserSensorInfo(421): SensorPhy: CIF sensor_d0_to_cif_d: 2 cifnum: 0 fmt: 0x2b
07-12 01:27:06.787 E/CameraHal( 233): ParserSensorInfo(425): SensorPhy: phyindex: 1,open /dev/camsys_marvin1
07-12 01:27:06.787 D/CameraHal( 233): ParserVCMInfo(450): VCMDrvName(NC)
07-12 01:27:06.787 D/CameraHal( 233): ParserVCMInfo(453): VCMName(NC)
07-12 01:27:06.787 D/CameraHal( 233): ParserVCMInfo(456): VCMI2cBusNum(0)
07-12 01:27:06.787 D/CameraHal( 233): ParserVCMInfo(459): VCMI2cAddrByte(0)
07-12 01:27:06.787 D/CameraHal( 233): ParserVCMInfo(462): VCMI2cRate(0)
07-12 01:27:06.787 D/CameraHal( 233): ParserVCMInfo(477): VCMVdd(NC) min(0) max(0)
07-12 01:27:06.787 D/CameraHal( 233): ParserVCMInfo(471): VCMGpioPower(NC) active(0)
07-12 01:27:06.787 D/CameraHal( 233): ParserVCMInfo(465): VCMGpioPwdn(NC) active(0)
07-12 01:27:06.787 D/CameraHal( 233): ParserVCMInfo(490): start current(0) rated current(80) vcm max(100) step mode(13) drv max(100)
07-12 01:27:06.787 D/CameraHal( 233): ParserFlashInfo(509): FlashName(NC)
07-12 01:27:06.787 D/CameraHal( 233): ParserFlashInfo(512): FlashI2cBusNum(0)
07-12 01:27:06.787 D/CameraHal( 233): ParserFlashInfo(515): FlashI2cAddrByte(0)
07-12 01:27:06.787 D/CameraHal( 233): ParserFlashInfo(518): FlashI2cRate(0)
07-12 01:27:06.787 D/CameraHal( 233): ParserFlashInfo(521): FlashTrigger(NC) active(1)
07-12 01:27:06.787 D/CameraHal( 233): ParserFlashInfo(525): FlashEn(NC) active(1)
07-12 01:27:06.787 D/CameraHal( 233): ParserFlashInfo(532): FlashLuminance(0)
07-12 01:27:06.787 D/CameraHal( 233): ParserFlashInfo(535): FlashColorTemp(0)
07-12 01:27:06.787 D/CameraHal( 233): StartElementHandler(964): HDR(1)!
07-12 01:27:06.787 D/CameraHal( 233): StartElementHandler(968): ZSL(1)!
07-12 01:27:06.787 D/CameraHal( 233): StartElementHandler(972): zoom(1)!
07-12 01:27:06.787 D/CameraHal( 233): StartElementHandler(1014): Continue_SnapShot(1)!
07-12 01:27:06.787 D/CameraHal( 233): StartElementHandler(1017): InterpolationRes(0)!
07-12 01:27:06.787 D/CameraHal( 233): StartElementHandler(1002): PreviewSize(800x600)!
07-12 01:27:06.787 D/CameraHal( 233): StartElementHandler(998): face detect config(0),max face num is (0)!
07-12 01:27:06.788 D/CameraHal( 233): ParserDVConfig(802): DV_QCIF(qcif) resolution(176x144) fps(10) support(1)
07-12 01:27:06.788 D/CameraHal( 233): ParserDVConfig(814): DV_QVGA(qvga) resolution(320x240) fps(10) support(1)
07-12 01:27:06.788 D/CameraHal( 233): ParserDVConfig(826): DV_CIF(cif) resolution(352x288) fps(10) support(1)
07-12 01:27:06.788 D/CameraHal( 233): ParserDVConfig(838): DV_VGA(480p) resolution(640x480) fps(10) support(1)
07-12 01:27:06.788 D/CameraHal( 233): ParserDVConfig(850): DV_480P(480p) resolution(720x480) fps(10) support(0)
07-12 01:27:06.788 D/CameraHal( 233): ParserDVConfig(874): DV_720P(720p) resolution(1280x720) fps(10) support(0)
07-12 01:27:06.788 D/CameraHal( 233): ParserDVConfig(886): DV_1080P(1080p) resolution(1920x1080) fps(10) support(0)
07-12 01:27:06.788 D/CameraHal( 233): number of camdevice (2)
07-12 01:27:06.788 D/CameraHal( 233): now DV size(7)
07-12 01:27:06.788 E/CameraHal( 233): camera_get_number_of_cameras(789): board profiles cam num 2
07-12 01:27:06.788 D/CameraHal( 233): read cam name from xml(/data/camera/media_profiles.xml)
07-12 01:27:06.788 E/CameraHal( 233): is not exist, register all
07-12 01:27:06.790 I/art ( 231): option[0]=-Xzygote
07-12 01:27:06.790 I/art ( 231): option[1]=-Xstacktracefile:/data/anr/traces.txt
07-12 01:27:06.790 I/art ( 231): option[2]=exit
07-12 01:27:06.790 I/art ( 231): option[3]=vfprintf
07-12 01:27:06.790 I/art ( 231): option[4]=sensitiveThread
07-12 01:27:06.790 I/art ( 231): option[5]=-verbose:gc
07-12 01:27:06.790 I/art ( 231): option[6]=-Xms16m
07-12 01:27:06.790 I/art ( 231): option[7]=-Xmx512m
07-12 01:27:06.790 I/art ( 231): option[8]=-XX:HeapGrowthLimit=192m
07-12 01:27:06.790 I/art ( 231): option[9]=-XX:HeapMinFree=512k
07-12 01:27:06.790 I/art ( 231): option[10]=-XX:HeapMaxFree=8m
07-12 01:27:06.790 I/art ( 231): option[11]=-XX:HeapTargetUtilization=0.75
07-12 01:27:06.790 I/art ( 231): option[12]=-Xusejit:true
07-12 01:27:06.790 I/art ( 231): option[13]=-Xjitsaveprofilinginfo
07-12 01:27:06.790 I/art ( 231): option[14]=-agentlib:jdwp=transport=dt_android_adb,suspend=n,server=y
07-12 01:27:06.790 I/art ( 231): option[15]=-Xlockprofthreshold:500
07-12 01:27:06.790 I/art ( 231): option[16]=-Ximage-compiler-option
07-12 01:27:06.790 I/art ( 231): option[17]=–runtime-arg
07-12 01:27:06.790 I/art ( 231): option[18]=-Ximage-compiler-option
07-12 01:27:06.790 I/art ( 231): option[19]=-Xms64m
07-12 01:27:06.790 I/art ( 231): option[20]=-Ximage-compiler-option
07-12 01:27:06.790 I/art ( 231): option[21]=–runtime-arg
07-12 01:27:06.790 I/art ( 231): option[22]=-Ximage-compiler-option
07-12 01:27:06.790 I/art ( 231): option[23]=-Xmx64m
07-12 01:27:06.790 I/art ( 231): option[24]=-Ximage-compiler-option
07-12 01:27:06.790 I/art ( 231): option[25]=–image-classes=/system/etc/preloaded-classes
07-12 01:27:06.790 I/art ( 231): option[26]=-Ximage-compiler-option
07-12 01:27:06.790 I/art ( 231): option[27]=–compiled-classes=/system/etc/compiled-classes
07-12 01:27:06.790 I/art ( 231): option[28]=-Xcompiler-option
07-12 01:27:06.790 I/art ( 231): option[29]=–runtime-arg
07-12 01:27:06.790 I/art ( 231): option[30]=-Xcompiler-option
07-12 01:27:06.790 I/art ( 231): option[31]=-Xms64m
07-12 01:27:06.790 I/art ( 231): option[32]=-Xcompiler-option
07-12 01:27:06.790 I/art ( 231): option[33]=–runtime-arg
07-12 01:27:06.790 I/art ( 231): option[34]=-Xcompiler-option
07-12 01:27:06.790 I/art ( 231): option[35]=-Xmx512m
07-12 01:27:06.790 I/art ( 231): option[36]=-Ximage-compiler-option
07-12 01:27:06.790 I/art ( 231): option[37]=–instruction-set-variant=cortex-a15
07-12 01:27:06.790 I/art ( 231): option[38]=-Xcompiler-option
07-12 01:27:06.790 I/art ( 231): option[39]=–instruction-set-variant=cortex-a15
07-12 01:27:06.790 I/art ( 231): option[40]=-Ximage-compiler-option
07-12 01:27:06.790 I/art ( 231): option[41]=–instruction-set-features=default
07-12 01:27:06.791 I/art ( 231): option[42]=-Xcompiler-option
07-12 01:27:06.791 I/art ( 231): option[43]=–instruction-set-features=default
07-12 01:27:06.791 I/art ( 231): option[44]=-Duser.locale=en-US
07-12 01:27:06.791 I/art ( 231): option[45]=–cpu-abilist=armeabi-v7a,armeabi
07-12 01:27:06.791 I/art ( 231): option[46]=-Xfingerprint:Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys
07-12 01:27:06.794 D/CameraHal( 233):
07-12 01:27:06.794 D/CameraHal( 233): CamSys_Head.h Version Check:
07-12 01:27:06.794 D/CameraHal( 233): Kernel camsys_head.h: v0x1.0x0.0x0
07-12 01:27:06.794 D/CameraHal( 233): Kernel camsys_drv : v0x0.0x30.0x0
07-12 01:27:06.794 D/CameraHal( 233): CameraHal camsys_head.h : v0x1.0x0.0x0
07-12 01:27:06.810 E/CameraHal( 233): WARNING: OV8858 soft reset by i2c failed!, please check follow information:
07-12 01:27:06.810 E/CameraHal( 233): Slave_addr: 0x6c 0x20
07-12 01:27:06.810 E/CameraHal( 233): Soft reset reg: 0x103 val: 0x1
07-12 01:27:06.810 E/CameraHal( 233): Power/PowerDown/Reset/Mclk/I2cBus
07-12 01:27:06.821 E/CameraHal( 233): OV8858 device register failed!
07-12 01:27:06.823 E/CameraHal( 233): Open (/dev/camsys_marvin1) failed, error=(No such file or directory),try to open /dev/camsys_marvin
07-12 01:27:06.824 D/CameraHal( 233):
07-12 01:27:06.824 D/CameraHal( 233): CamSys_Head.h Version Check:
07-12 01:27:06.824 D/CameraHal( 233): Kernel camsys_head.h: v0x1.0x0.0x0
07-12 01:27:06.824 D/CameraHal( 233): Kernel camsys_drv : v0x0.0x30.0x0
07-12 01:27:06.824 D/CameraHal( 233): CameraHal camsys_head.h : v0x1.0x0.0x0
07-12 01:27:06.837 E/CameraHal( 233): WARNING: GC2035 soft reset by i2c failed!, please check follow information:
07-12 01:27:06.837 E/CameraHal( 233): Slave_addr: 0x78 0x0
07-12 01:27:06.837 E/CameraHal( 233): Soft reset reg: 0xfe val: 0x80
07-12 01:27:06.837 E/CameraHal( 233): Power/PowerDown/Reset/Mclk/I2cBus
07-12 01:27:06.843 I/vpu_api ( 318): dlopen vpu lib success
07-12 01:27:06.848 E/CameraHal( 233): GC2035 device register failed!
07-12 01:27:06.848 E/CameraHal( 233): camera_get_number_of_cameras(796): load sensor name(OV8858) connect 0
07-12 01:27:06.848 E/CameraHal( 233): camera_get_number_of_cameras(796): load sensor name(GC2035) connect 0
07-12 01:27:06.848 E/CameraHal( 233): camera_get_number_of_cameras(854): Open /dev/video0 failed! strr: No such file or directory
07-12 01:27:06.848 E/CameraHal( 233): camera_get_number_of_cameras(854): Open /dev/video1 failed! strr: No such file or directory
07-12 01:27:06.848 E/CameraHal( 233): camera_get_number_of_cameras(854): Open /dev/video2 failed! strr: No such file or directory
07-12 01:27:06.848 E/CameraHal( 233): camera_get_number_of_cameras(854): Open /dev/video3 failed! strr: No such file or directory
07-12 01:27:06.848 E/CameraHal( 233): camera_get_number_of_cameras(854): Open /dev/video4 failed! strr: No such file or directory
07-12 01:27:06.848 E/CameraHal( 233): camera_get_number_of_cameras(854): Open /dev/video5 failed! strr: No such file or directory
07-12 01:27:06.848 E/CameraHal( 233): camera_get_number_of_cameras(854): Open /dev/video6 failed! strr: No such file or directory
07-12 01:27:06.848 E/CameraHal( 233): camera_get_number_of_cameras(854): Open /dev/video7 failed! strr: No such file or directory
07-12 01:27:06.848 E/CameraHal( 233): camera_get_number_of_cameras(854): Open /dev/video8 failed! strr: No such file or directory
07-12 01:27:06.848 E/CameraHal( 233): camera_get_number_of_cameras(854): Open /dev/video9 failed! strr: No such file or directory
07-12 01:27:06.848 D/CameraHal( 233): camera_get_number_of_cameras(1246): camera_get_number_of_cameras(1246): Current board have 0 cameras attached.
07-12 01:27:06.848 D/CameraHal( 233): camera_get_number_of_cameras(1249): meida_profiles_xml_control time (68882)us
07-12 01:27:06.848 I/CameraService( 233): Loaded “RK29_ICS_CameraHal_Module” camera module
07-12 01:27:06.850 I/BootAnimation( 318): Boot_animation_process entered now!
07-12 01:27:06.850 D/CameraHal( 233): createInstance(1035): open xml file(/etc/cam_board.xml) success
07-12 01:27:06.850 E/CameraHal( 233): cam_board.xml version(v0x0.0x0.0x0) != xml parser version(v0x0.0xf.0x0)
07-12 01:27:06.850 D/CameraHal( 233): Cam_board.xml Version Check:
07-12 01:27:06.850 D/CameraHal( 233): /etc/cam_board.xml : v0.0xf.0
07-12 01:27:06.850 D/CameraHal( 233): CameraHal_board_xml_parser: v0x0.0xf.0x0
07-12 01:27:06.851 D/CameraHal( 233): ParserSensorInfo(190): SensorName(OV8858)
07-12 01:27:06.851 D/CameraHal( 233): ParserSensorInfo(196): lensName(LG-9569A2)
07-12 01:27:06.851 D/CameraHal( 233): ParserSensorInfo(198): SensorDevID(CAMSYS_DEVID_SENSOR_1B)
07-12 01:27:06.851 D/CameraHal( 233): ParserSensorInfo(209): SensorDevID(33554432)
07-12 01:27:06.851 D/CameraHal( 233): ParserSensorInfo(211): SensorHostDevID(CAMSYS_DEVID_MARVIN)
07-12 01:27:06.851 D/CameraHal( 233): ParserSensorInfo(226): Sensori2cBusNum(3)
07-12 01:27:06.851 D/CameraHal( 233): ParserSensorInfo(229): SensorI2cAddrByte(2)
07-12 01:27:06.851 D/CameraHal( 233): ParserSensorInfo(232): SensorI2cRate(100000)
07-12 01:27:06.851 D/CameraHal( 233): ParserSensorInfo(240): SensorAvdd(NC) min(0) max(0)
07-12 01:27:06.851 D/CameraHal( 233): ParserSensorInfo(254): SensorDvdd(NC) min(0) max(0)
07-12 01:27:06.851 D/CameraHal( 233): ParserSensorInfo(247): SensorDovdd(NC) min(18000000) max(18000000)
07-12 01:27:06.851 D/CameraHal( 233): ParserSensorInfo(235): SensorMclk(24000000)
07-12 01:27:06.851 D/CameraHal( 233): ParserSensorInfo(285): SensorGpioPwen(RK30_PIN0_PC1) active(1)
07-12 01:27:06.851 D/CameraHal( 233): ParserSensorInfo(279): SensorGpioRst(NC) active(0)
07-12 01:27:06.851 D/CameraHal( 233): ParserSensorInfo(261): SensorGpioPwdn(RK30_PIN2_PB7) active(0)
07-12 01:27:06.851 D/CameraHal( 233): ParserSensorInfo(291): SensorFacing(back)
07-12 01:27:06.851 D/CameraHal( 233): ParserSensorInfo(300): SensorInterface(MIPI)
07-12 01:27:06.851 D/CameraHal( 233): ParserSensorInfo(313): SensorMirrorFlip(0)
07-12 01:27:06.851 D/CameraHal( 233): ParserSensorInfo(316): SensorOrientation(0)
07-12 01:27:06.851 D/CameraHal( 233): ParserSensorInfo(435): SensorFovParemeter fov_h(60.0)(60.000000) fov_v(60.0)(60.000000)
07-12 01:27:06.851 D/CameraHal( 233): ParserSensorInfo(438): SensorAWB_Frame_Skip fps(0)
07-12 01:27:06.851 D/CameraHal( 233): ParserSensorInfo(397): SensorGpioPwdn(RK30_PIN2_PB7) active(0)
07-12 01:27:06.851 D/CameraHal( 233): ParserSensorInfo(405): SensorPhy: MIPI lane: 2 phyindex: 0 fmt: 0x2b
07-12 01:27:06.851 D/CameraHal( 233): ParserVCMInfo(450): VCMDrvName(BuiltInSensor)
07-12 01:27:06.851 D/CameraHal( 233): ParserVCMInfo(453): VCMName(NC)
07-12 01:27:06.851 D/CameraHal( 233): ParserVCMInfo(456): VCMI2cBusNum(3)
07-12 01:27:06.851 D/CameraHal( 233): ParserVCMInfo(459): VCMI2cAddrByte(0)
07-12 01:27:06.851 D/CameraHal( 233): ParserVCMInfo(462): VCMI2cRate(0)
07-12 01:27:06.851 D/CameraHal( 233): ParserVCMInfo(477): VCMVdd(NC) min(0) max(0)
07-12 01:27:06.851 D/CameraHal( 233): ParserVCMInfo(471): VCMGpioPower(NC) active(0)
07-12 01:27:06.851 D/CameraHal( 233): ParserVCMInfo(465): VCMGpioPwdn(NC) active(0)
07-12 01:27:06.852 D/CameraHal( 233): ParserVCMInfo(490): start current(0) rated current(100) vcm max(100) step mode(4) drv max(100)
07-12 01:27:06.852 D/CameraHal( 233): ParserFlashInfo(509): FlashName(Internal)
07-12 01:27:06.852 D/CameraHal( 233): ParserFlashInfo(512): FlashI2cBusNum(0)
07-12 01:27:06.852 D/CameraHal( 233): ParserFlashInfo(515): FlashI2cAddrByte(0)
07-12 01:27:06.852 D/CameraHal( 233): ParserFlashInfo(518): FlashI2cRate(0)
07-12 01:27:06.852 D/CameraHal( 233): ParserFlashInfo(521): FlashTrigger(NC) active(0)
07-12 01:27:06.852 D/CameraHal( 233): ParserFlashInfo(525): FlashEn(NC) active(0)
07-12 01:27:06.852 D/CameraHal( 233): ParserFlashInfo(532): FlashLuminance(0)
07-12 01:27:06.852 D/CameraHal( 233): ParserFlashInfo(535): FlashColorTemp(0)
07-12 01:27:06.852 D/CameraHal( 233): StartElementHandler(964): HDR(1)!
07-12 01:27:06.852 D/CameraHal( 233): StartElementHandler(968): ZSL(1)!
07-12 01:27:06.852 D/CameraHal( 233): StartElementHandler(972): zoom(1)!
07-12 01:27:06.852 D/CameraHal( 233): StartElementHandler(1014): Continue_SnapShot(1)!
07-12 01:27:06.852 D/CameraHal( 233): StartElementHandler(1017): InterpolationRes(0)!
07-12 01:27:06.852 D/CameraHal( 233): StartElementHandler(1002): PreviewSize(0x0)!
07-12 01:27:06.852 D/CameraHal( 233): StartElementHandler(998): face detect config(0),max face num is (1)!
07-12 01:27:06.852 D/CameraHal( 233): StartElementHandler(993): Gammaout support 0(mGamma:1.000000,mOffSet:0)!
07-12 01:27:06.852 D/CameraHal( 233): ParserDVConfig(802): DV_QCIF(qcif) resolution(176x144) fps(10) support(1)
07-12 01:27:06.852 D/CameraHal( 233): ParserDVConfig(814): DV_QVGA(qvga) resolution(320x240) fps(10) support(1)
07-12 01:27:06.852 D/CameraHal( 233): ParserDVConfig(826): DV_CIF(cif) resolution(352x288) fps(10) support(1)
07-12 01:27:06.852 D/CameraHal( 233): ParserDVConfig(838): DV_VGA(480p) resolution(640x480) fps(10) support(0)
07-12 01:27:06.853 D/CameraHal( 233): ParserDVConfig(850): DV_480P(480p) resolution(720x480) fps(10) support(0)
07-12 01:27:06.853 D/CameraHal( 233): ParserDVConfig(874): DV_720P(720p) resolution(1280x720) fps(10) support(1)
07-12 01:27:06.853 D/CameraHal( 233): ParserDVConfig(886): DV_1080P(1080p) resolution(1920x1080) fps(10) support(1)
07-12 01:27:06.853 D/CameraHal( 233): ParserSensorInfo(190): SensorName(GC2035)
07-12 01:27:06.853 D/CameraHal( 233): ParserSensorInfo(198): SensorDevID(CAMSYS_DEVID_SENSOR_1A)
07-12 01:27:06.853 D/CameraHal( 233): ParserSensorInfo(209): SensorDevID(16777216)
07-12 01:27:06.853 D/CameraHal( 233): ParserSensorInfo(211): SensorHostDevID(CAMSYS_DEVID_MARVIN)
07-12 01:27:06.853 D/CameraHal( 233): ParserSensorInfo(226): Sensori2cBusNum(3)
07-12 01:27:06.853 D/CameraHal( 233): ParserSensorInfo(229): SensorI2cAddrByte(2)
07-12 01:27:06.853 D/CameraHal( 233): ParserSensorInfo(232): SensorI2cRate(100000)
07-12 01:27:06.853 D/CameraHal( 233): ParserSensorInfo(240): SensorAvdd(NC) min(0) max(0)
07-12 01:27:06.853 D/CameraHal( 233): ParserSensorInfo(254): SensorDvdd(NC) min(0) max(0)
07-12 01:27:06.853 D/CameraHal( 233): ParserSensorInfo(247): SensorDovdd(NC) min(18000000) max(18000000)
07-12 01:27:06.853 D/CameraHal( 233): ParserSensorInfo(235): SensorMclk(24000000)
07-12 01:27:06.853 D/CameraHal( 233): ParserSensorInfo(285): SensorGpioPwen(RK30_PIN0_PC1) active(1)
07-12 01:27:06.853 D/CameraHal( 233): ParserSensorInfo(279): SensorGpioRst(NC) active(0)
07-12 01:27:06.853 D/CameraHal( 233): ParserSensorInfo(261): SensorGpioPwdn(RK30_PIN2_PB6) active(1)
07-12 01:27:06.853 D/CameraHal( 233): ParserSensorInfo(291): SensorFacing(front)
07-12 01:27:06.853 D/CameraHal( 233): ParserSensorInfo(300): SensorInterface(CCIR601)
07-12 01:27:06.853 D/CameraHal( 233): ParserSensorInfo(313): SensorMirrorFlip(0)
07-12 01:27:06.853 D/CameraHal( 233): ParserSensorInfo(316): SensorOrientation(0)
07-12 01:27:06.853 D/CameraHal( 233): ParserSensorInfo(435): SensorFovParemeter fov_h(60.0)(60.000000) fov_v(60.0)(60.000000)
07-12 01:27:06.853 D/CameraHal( 233): ParserSensorInfo(438): SensorAWB_Frame_Skip fps(15)
07-12 01:27:06.853 D/CameraHal( 233): ParserSensorInfo(421): SensorPhy: CIF sensor_d0_to_cif_d: 2 cifnum: 0 fmt: 0x2b
07-12 01:27:06.853 E/CameraHal( 233): ParserSensorInfo(425): SensorPhy: phyindex: 1,open /dev/camsys_marvin1
07-12 01:27:06.853 D/CameraHal( 233): ParserVCMInfo(450): VCMDrvName(NC)
07-12 01:27:06.853 D/CameraHal( 233): ParserVCMInfo(453): VCMName(NC)
07-12 01:27:06.853 D/CameraHal( 233): ParserVCMInfo(456): VCMI2cBusNum(0)
07-12 01:27:06.853 D/CameraHal( 233): ParserVCMInfo(459): VCMI2cAddrByte(0)
07-12 01:27:06.853 D/CameraHal( 233): ParserVCMInfo(462): VCMI2cRate(0)
07-12 01:27:06.853 D/CameraHal( 233): ParserVCMInfo(477): VCMVdd(NC) min(0) max(0)
07-12 01:27:06.854 D/CameraHal( 233): ParserVCMInfo(471): VCMGpioPower(NC) active(0)
07-12 01:27:06.854 D/CameraHal( 233): ParserVCMInfo(465): VCMGpioPwdn(NC) active(0)
07-12 01:27:06.854 D/CameraHal( 233): ParserVCMInfo(490): start current(0) rated current(80) vcm max(100) step mode(13) drv max(100)
07-12 01:27:06.854 D/CameraHal( 233): ParserFlashInfo(509): FlashName(NC)
07-12 01:27:06.854 D/CameraHal( 233): ParserFlashInfo(512): FlashI2cBusNum(0)
07-12 01:27:06.854 D/CameraHal( 233): ParserFlashInfo(515): FlashI2cAddrByte(0)
07-12 01:27:06.854 D/CameraHal( 233): ParserFlashInfo(518): FlashI2cRate(0)
07-12 01:27:06.854 D/CameraHal( 233): ParserFlashInfo(521): FlashTrigger(NC) active(1)
07-12 01:27:06.854 D/CameraHal( 233): ParserFlashInfo(525): FlashEn(NC) active(1)
07-12 01:27:06.854 D/CameraHal( 233): ParserFlashInfo(532): FlashLuminance(0)
07-12 01:27:06.854 D/CameraHal( 233): ParserFlashInfo(535): FlashColorTemp(0)
07-12 01:27:06.854 D/CameraHal( 233): StartElementHandler(964): HDR(1)!
07-12 01:27:06.854 D/CameraHal( 233): StartElementHandler(968): ZSL(1)!
07-12 01:27:06.854 D/CameraHal( 233): StartElementHandler(972): zoom(1)!
07-12 01:27:06.854 D/CameraHal( 233): StartElementHandler(1014): Continue_SnapShot(1)!
07-12 01:27:06.854 D/CameraHal( 233): StartElementHandler(1017): InterpolationRes(0)!
07-12 01:27:06.854 D/CameraHal( 233): StartElementHandler(1002): PreviewSize(800x600)!
07-12 01:27:06.854 D/CameraHal( 233): StartElementHandler(998): face detect config(0),max face num is (0)!
07-12 01:27:06.854 D/CameraHal( 233): ParserDVConfig(802): DV_QCIF(qcif) resolution(176x144) fps(10) support(1)
07-12 01:27:06.854 D/CameraHal( 233): ParserDVConfig(814): DV_QVGA(qvga) resolution(320x240) fps(10) support(1)
07-12 01:27:06.854 D/CameraHal( 233): ParserDVConfig(826): DV_CIF(cif) resolution(352x288) fps(10) support(1)
07-12 01:27:06.854 D/CameraHal( 233): ParserDVConfig(838): DV_VGA(480p) resolution(640x480) fps(10) support(1)
07-12 01:27:06.854 D/CameraHal( 233): ParserDVConfig(850): DV_480P(480p) resolution(720x480) fps(10) support(0)
07-12 01:27:06.854 D/CameraHal( 233): ParserDVConfig(874): DV_720P(720p) resolution(1280x720) fps(10) support(0)
07-12 01:27:06.854 D/CameraHal( 233): ParserDVConfig(886): DV_1080P(1080p) resolution(1920x1080) fps(10) support(0)
07-12 01:27:06.855 D/CameraHal( 233): number of camdevice (2)
07-12 01:27:06.855 D/CameraHal( 233): now DV size(7)
07-12 01:27:06.855 E/CameraHal( 233): camera_get_number_of_cameras(789): board profiles cam num 2
07-12 01:27:06.855 D/CameraHal( 233): read cam name from xml(/data/camera/media_profiles.xml)
07-12 01:27:06.855 E/CameraHal( 233): is not exist, register all
07-12 01:27:06.856 D/CameraHal( 233):
07-12 01:27:06.856 D/CameraHal( 233): CamSys_Head.h Version Check:
07-12 01:27:06.856 D/CameraHal( 233): Kernel camsys_head.h: v0x1.0x0.0x0
07-12 01:27:06.856 D/CameraHal( 233): Kernel camsys_drv : v0x0.0x30.0x0
07-12 01:27:06.856 D/CameraHal( 233): CameraHal camsys_head.h : v0x1.0x0.0x0
07-12 01:27:06.868 D/libEGL ( 318): loaded /vendor/lib/egl/libGLES_mali.so
07-12 01:27:06.869 E/CameraHal( 233): WARNING: OV8858 soft reset by i2c failed!, please check follow information:
07-12 01:27:06.870 E/CameraHal( 233): Slave_addr: 0x6c 0x20
07-12 01:27:06.870 E/CameraHal( 233): Soft reset reg: 0x103 val: 0x1
07-12 01:27:06.870 E/CameraHal( 233): Power/PowerDown/Reset/Mclk/I2cBus
07-12 01:27:06.880 E/CameraHal( 233): OV8858 device register failed!
07-12 01:27:06.881 E/CameraHal( 233): Open (/dev/camsys_marvin1) failed, error=(No such file or directory),try to open /dev/camsys_marvin
07-12 01:27:06.881 D/CameraHal( 233):
07-12 01:27:06.881 D/CameraHal( 233): CamSys_Head.h Version Check:
07-12 01:27:06.881 D/CameraHal( 233): Kernel camsys_head.h: v0x1.0x0.0x0
07-12 01:27:06.881 D/CameraHal( 233): Kernel camsys_drv : v0x0.0x30.0x0
07-12 01:27:06.881 D/CameraHal( 233): CameraHal camsys_head.h : v0x1.0x0.0x0
07-12 01:27:06.890 I/mali_so ( 318): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 876; [Func] : base_context_deal_with_version_affairs_rk_ext;
07-12 01:27:06.890 I/mali_so ( 318): arm_release_ver of this mali_so is ‘r18p0-01rel0’, rk_so_ver is ‘3@0’.
07-12 01:27:06.890 D/mali_so ( 318): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 881; [Func] : base_context_deal_with_version_affairs_rk_ext;
07-12 01:27:06.890 D/mali_so ( 318): current process is NOT sf, to bail out.
07-12 01:27:06.894 E/CameraHal( 233): WARNING: GC2035 soft reset by i2c failed!, please check follow information:
07-12 01:27:06.894 E/CameraHal( 233): Slave_addr: 0x78 0x0
07-12 01:27:06.894 E/CameraHal( 233): Soft reset reg: 0xfe val: 0x80
07-12 01:27:06.894 E/CameraHal( 233): Power/PowerDown/Reset/Mclk/I2cBus
07-12 01:27:06.895 D/mali_winsys( 318): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface , egl_color_buffer_format , EGLBoolean) returns 0x3000
07-12 01:27:06.898 D/BootAnimation( 318): bootvideo:No boot video animation,EXIT_VIDEO_NAME:false,bootvideo.showtime:-1
07-12 01:27:06.905 E/CameraHal( 233): GC2035 device register failed!
07-12 01:27:06.905 E/CameraHal( 233): camera_get_number_of_cameras(796): load sensor name(OV8858) connect 0
07-12 01:27:06.905 E/CameraHal( 233): camera_get_number_of_cameras(796): load sensor name(GC2035) connect 0
07-12 01:27:06.905 E/CameraHal( 233): camera_get_number_of_cameras(854): Open /dev/video0 failed! strr: No such file or directory
07-12 01:27:06.905 E/CameraHal( 233): camera_get_number_of_cameras(854): Open /dev/video1 failed! strr: No such file or directory
07-12 01:27:06.905 E/CameraHal( 233): camera_get_number_of_cameras(854): Open /dev/video2 failed! strr: No such file or directory
07-12 01:27:06.905 E/CameraHal( 233): camera_get_number_of_cameras(854): Open /dev/video3 failed! strr: No such file or directory
07-12 01:27:06.905 E/CameraHal( 233): camera_get_number_of_cameras(854): Open /dev/video4 failed! strr: No such file or directory
07-12 01:27:06.905 E/CameraHal( 233): camera_get_number_of_cameras(854): Open /dev/video5 failed! strr: No such file or directory
07-12 01:27:06.905 E/CameraHal( 233): camera_get_number_of_cameras(854): Open /dev/video6 failed! strr: No such file or directory
07-12 01:27:06.905 E/CameraHal( 233): camera_get_number_of_cameras(854): Open /dev/video7 failed! strr: No such file or directory
07-12 01:27:06.905 E/CameraHal( 233): camera_get_number_of_cameras(854): Open /dev/video8 failed! strr: No such file or directory
07-12 01:27:06.905 E/CameraHal( 233): camera_get_number_of_cameras(854): Open /dev/video9 failed! strr: No such file or directory
07-12 01:27:06.905 D/CameraHal( 233): camera_get_number_of_cameras(1246): camera_get_number_of_cameras(1246): Current board have 0 cameras attached.
07-12 01:27:06.905 D/CameraHal( 233): camera_get_number_of_cameras(1249): meida_profiles_xml_control time (57040)us
07-12 01:27:06.907 D/CameraHal( 233): createInstance(1035): open xml file(/etc/cam_board.xml) success
07-12 01:27:06.907 E/CameraHal( 233): cam_board.xml version(v0x0.0x0.0x0) != xml parser version(v0x0.0xf.0x0)
07-12 01:27:06.908 D/CameraHal( 233):
07-12 01:27:06.908 D/CameraHal( 233): Cam_board.xml Version Check:
07-12 01:27:06.908 D/CameraHal( 233): /etc/cam_board.xml : v0.0xf.0
07-12 01:27:06.908 D/CameraHal( 233): CameraHal_board_xml_parser: v0x0.0xf.0x0
07-12 01:27:06.908 D/CameraHal( 233): ParserSensorInfo(190): SensorName(OV8858)
07-12 01:27:06.908 D/CameraHal( 233): ParserSensorInfo(196): lensName(LG-9569A2)
07-12 01:27:06.908 D/CameraHal( 233): ParserSensorInfo(198): SensorDevID(CAMSYS_DEVID_SENSOR_1B)
07-12 01:27:06.908 D/CameraHal( 233): ParserSensorInfo(209): SensorDevID(33554432)
07-12 01:27:06.908 D/CameraHal( 233): ParserSensorInfo(211): SensorHostDevID(CAMSYS_DEVID_MARVIN)
07-12 01:27:06.908 D/CameraHal( 233): ParserSensorInfo(226): Sensori2cBusNum(3)
07-12 01:27:06.908 D/CameraHal( 233): ParserSensorInfo(229): SensorI2cAddrByte(2)
07-12 01:27:06.908 D/CameraHal( 233): ParserSensorInfo(232): SensorI2cRate(100000)
07-12 01:27:06.908 D/CameraHal( 233): ParserSensorInfo(240): SensorAvdd(NC) min(0) max(0)
07-12 01:27:06.908 D/CameraHal( 233): ParserSensorInfo(254): SensorDvdd(NC) min(0) max(0)
07-12 01:27:06.908 D/CameraHal( 233): ParserSensorInfo(247): SensorDovdd(NC) min(18000000) max(18000000)
07-12 01:27:06.908 D/CameraHal( 233): ParserSensorInfo(235): SensorMclk(24000000)
07-12 01:27:06.908 D/CameraHal( 233): ParserSensorInfo(285): SensorGpioPwen(RK30_PIN0_PC1) active(1)
07-12 01:27:06.908 D/CameraHal( 233): ParserSensorInfo(279): SensorGpioRst(NC) active(0)
07-12 01:27:06.908 D/CameraHal( 233): ParserSensorInfo(261): SensorGpioPwdn(RK30_PIN2_PB7) active(0)
07-12 01:27:06.908 D/CameraHal( 233): ParserSensorInfo(291): SensorFacing(back)
07-12 01:27:06.908 D/CameraHal( 233): ParserSensorInfo(300): SensorInterface(MIPI)
07-12 01:27:06.908 D/CameraHal( 233): ParserSensorInfo(313): SensorMirrorFlip(0)
07-12 01:27:06.908 D/CameraHal( 233): ParserSensorInfo(316): SensorOrientation(0)
07-12 01:27:06.908 D/CameraHal( 233): ParserSensorInfo(435): SensorFovParemeter fov_h(60.0)(60.000000) fov_v(60.0)(60.000000)
07-12 01:27:06.908 D/CameraHal( 233): ParserSensorInfo(438): SensorAWB_Frame_Skip fps(0)
07-12 01:27:06.908 D/CameraHal( 233): ParserSensorInfo(397): SensorGpioPwdn(RK30_PIN2_PB7) active(0)
07-12 01:27:06.908 D/CameraHal( 233): ParserSensorInfo(405): SensorPhy: MIPI lane: 2 phyindex: 0 fmt: 0x2b
07-12 01:27:06.908 D/CameraHal( 233): ParserVCMInfo(450): VCMDrvName(BuiltInSensor)
07-12 01:27:06.908 D/CameraHal( 233): ParserVCMInfo(453): VCMName(NC)
07-12 01:27:06.908 D/CameraHal( 233): ParserVCMInfo(456): VCMI2cBusNum(3)
07-12 01:27:06.908 D/CameraHal( 233): ParserVCMInfo(459): VCMI2cAddrByte(0)
07-12 01:27:06.908 D/CameraHal( 233): ParserVCMInfo(462): VCMI2cRate(0)
07-12 01:27:06.908 D/CameraHal( 233): ParserVCMInfo(477): VCMVdd(NC) min(0) max(0)
07-12 01:27:06.908 D/CameraHal( 233): ParserVCMInfo(471): VCMGpioPower(NC) active(0)
07-12 01:27:06.908 D/CameraHal( 233): ParserVCMInfo(465): VCMGpioPwdn(NC) active(0)
07-12 01:27:06.908 D/CameraHal( 233): ParserVCMInfo(490): start current(0) rated current(100) vcm max(100) step mode(4) drv max(100)
07-12 01:27:06.908 D/CameraHal( 233): ParserFlashInfo(509): FlashName(Internal)
07-12 01:27:06.908 D/CameraHal( 233): ParserFlashInfo(512): FlashI2cBusNum(0)
07-12 01:27:06.909 D/CameraHal( 233): ParserFlashInfo(515): FlashI2cAddrByte(0)
07-12 01:27:06.909 D/CameraHal( 233): ParserFlashInfo(518): FlashI2cRate(0)
07-12 01:27:06.909 D/CameraHal( 233): ParserFlashInfo(521): FlashTrigger(NC) active(0)
07-12 01:27:06.909 D/CameraHal( 233): ParserFlashInfo(525): FlashEn(NC) active(0)
07-12 01:27:06.909 D/CameraHal( 233): ParserFlashInfo(532): FlashLuminance(0)
07-12 01:27:06.909 D/CameraHal( 233): ParserFlashInfo(535): FlashColorTemp(0)
07-12 01:27:06.909 D/CameraHal( 233): StartElementHandler(964): HDR(1)!
07-12 01:27:06.909 D/CameraHal( 233): StartElementHandler(968): ZSL(1)!
07-12 01:27:06.909 D/CameraHal( 233): StartElementHandler(972): zoom(1)!
07-12 01:27:06.909 D/CameraHal( 233): StartElementHandler(1014): Continue_SnapShot(1)!
07-12 01:27:06.909 D/CameraHal( 233): StartElementHandler(1017): InterpolationRes(0)!
07-12 01:27:06.909 D/CameraHal( 233): StartElementHandler(1002): PreviewSize(0x0)!
07-12 01:27:06.909 D/CameraHal( 233): StartElementHandler(998): face detect config(0),max face num is (1)!
07-12 01:27:06.909 D/CameraHal( 233): StartElementHandler(993): Gammaout support 0(mGamma:1.000000,mOffSet:0)!
07-12 01:27:06.909 D/CameraHal( 233): ParserDVConfig(802): DV_QCIF(qcif) resolution(176x144) fps(10) support(1)
07-12 01:27:06.909 D/CameraHal( 233): ParserDVConfig(814): DV_QVGA(qvga) resolution(320x240) fps(10) support(1)
07-12 01:27:06.909 D/CameraHal( 233): ParserDVConfig(826): DV_CIF(cif) resolution(352x288) fps(10) support(1)
07-12 01:27:06.909 D/CameraHal( 233): ParserDVConfig(838): DV_VGA(480p) resolution(640x480) fps(10) support(0)
07-12 01:27:06.909 D/CameraHal( 233): ParserDVConfig(850): DV_480P(480p) resolution(720x480) fps(10) support(0)
07-12 01:27:06.909 D/CameraHal( 233): ParserDVConfig(874): DV_720P(720p) resolution(1280x720) fps(10) support(1)
07-12 01:27:06.909 D/CameraHal( 233): ParserDVConfig(886): DV_1080P(1080p) resolution(1920x1080) fps(10) support(1)
07-12 01:27:06.909 D/CameraHal( 233): ParserSensorInfo(190): SensorName(GC2035)
07-12 01:27:06.909 D/CameraHal( 233): ParserSensorInfo(198): SensorDevID(CAMSYS_DEVID_SENSOR_1A)
07-12 01:27:06.909 D/CameraHal( 233): ParserSensorInfo(209): SensorDevID(16777216)
07-12 01:27:06.910 D/CameraHal( 233): ParserSensorInfo(211): SensorHostDevID(CAMSYS_DEVID_MARVIN)
07-12 01:27:06.910 D/CameraHal( 233): ParserSensorInfo(226): Sensori2cBusNum(3)
07-12 01:27:06.910 D/CameraHal( 233): ParserSensorInfo(229): SensorI2cAddrByte(2)
07-12 01:27:06.910 D/CameraHal( 233): ParserSensorInfo(232): SensorI2cRate(100000)
07-12 01:27:06.910 D/CameraHal( 233): ParserSensorInfo(240): SensorAvdd(NC) min(0) max(0)
07-12 01:27:06.910 D/CameraHal( 233): ParserSensorInfo(254): SensorDvdd(NC) min(0) max(0)
07-12 01:27:06.910 D/CameraHal( 233): ParserSensorInfo(247): SensorDovdd(NC) min(18000000) max(18000000)
07-12 01:27:06.910 D/CameraHal( 233): ParserSensorInfo(235): SensorMclk(24000000)
07-12 01:27:06.910 D/CameraHal( 233): ParserSensorInfo(285): SensorGpioPwen(RK30_PIN0_PC1) active(1)
07-12 01:27:06.910 D/CameraHal( 233): ParserSensorInfo(279): SensorGpioRst(NC) active(0)
07-12 01:27:06.910 D/CameraHal( 233): ParserSensorInfo(261): SensorGpioPwdn(RK30_PIN2_PB6) active(1)
07-12 01:27:06.910 D/CameraHal( 233): ParserSensorInfo(291): SensorFacing(front)
07-12 01:27:06.910 D/CameraHal( 233): ParserSensorInfo(300): SensorInterface(CCIR601)
07-12 01:27:06.910 D/CameraHal( 233): ParserSensorInfo(313): SensorMirrorFlip(0)
07-12 01:27:06.910 D/CameraHal( 233): ParserSensorInfo(316): SensorOrientation(0)
07-12 01:27:06.910 D/CameraHal( 233): ParserSensorInfo(435): SensorFovParemeter fov_h(60.0)(60.000000) fov_v(60.0)(60.000000)
07-12 01:27:06.910 D/CameraHal( 233): ParserSensorInfo(438): SensorAWB_Frame_Skip fps(15)
07-12 01:27:06.910 D/CameraHal( 233): ParserSensorInfo(421): SensorPhy: CIF sensor_d0_to_cif_d: 2 cifnum: 0 fmt: 0x2b
07-12 01:27:06.910 E/CameraHal( 233): ParserSensorInfo(425): SensorPhy: phyindex: 1,open /dev/camsys_marvin1
07-12 01:27:06.910 D/CameraHal( 233): ParserVCMInfo(450): VCMDrvName(NC)
07-12 01:27:06.910 D/CameraHal( 233): ParserVCMInfo(453): VCMName(NC)
07-12 01:27:06.910 D/CameraHal( 233): ParserVCMInfo(456): VCMI2cBusNum(0)
07-12 01:27:06.910 D/CameraHal( 233): ParserVCMInfo(459): VCMI2cAddrByte(0)
07-12 01:27:06.910 D/CameraHal( 233): ParserVCMInfo(462): VCMI2cRate(0)
07-12 01:27:06.910 D/CameraHal( 233): ParserVCMInfo(477): VCMVdd(NC) min(0) max(0)
07-12 01:27:06.910 D/CameraHal( 233): ParserVCMInfo(471): VCMGpioPower(NC) active(0)
07-12 01:27:06.910 D/CameraHal( 233): ParserVCMInfo(465): VCMGpioPwdn(NC) active(0)
07-12 01:27:06.910 D/CameraHal( 233): ParserVCMInfo(490): start current(0) rated current(80) vcm max(100) step mode(13) drv max(100)
07-12 01:27:06.910 D/CameraHal( 233): ParserFlashInfo(509): FlashName(NC)
07-12 01:27:06.910 D/CameraHal( 233): ParserFlashInfo(512): FlashI2cBusNum(0)
07-12 01:27:06.910 D/CameraHal( 233): ParserFlashInfo(515): FlashI2cAddrByte(0)
07-12 01:27:06.910 D/CameraHal( 233): ParserFlashInfo(518): FlashI2cRate(0)
07-12 01:27:06.910 D/CameraHal( 233): ParserFlashInfo(521): FlashTrigger(NC) active(1)
07-12 01:27:06.910 D/CameraHal( 233): ParserFlashInfo(525): FlashEn(NC) active(1)
07-12 01:27:06.910 D/CameraHal( 233): ParserFlashInfo(532): FlashLuminance(0)
07-12 01:27:06.910 D/CameraHal( 233): ParserFlashInfo(535): FlashColorTemp(0)
07-12 01:27:06.911 D/CameraHal( 233): StartElementHandler(964): HDR(1)!
07-12 01:27:06.911 D/CameraHal( 233): StartElementHandler(968): ZSL(1)!
07-12 01:27:06.911 D/CameraHal( 233): StartElementHandler(972): zoom(1)!
07-12 01:27:06.911 D/CameraHal( 233): StartElementHandler(1014): Continue_SnapShot(1)!
07-12 01:27:06.911 D/CameraHal( 233): StartElementHandler(1017): InterpolationRes(0)!
07-12 01:27:06.911 D/CameraHal( 233): StartElementHandler(1002): PreviewSize(800x600)!
07-12 01:27:06.911 D/CameraHal( 233): StartElementHandler(998): face detect config(0),max face num is (0)!
07-12 01:27:06.911 D/CameraHal( 233): ParserDVConfig(802): DV_QCIF(qcif) resolution(176x144) fps(10) support(1)
07-12 01:27:06.911 D/CameraHal( 233): ParserDVConfig(814): DV_QVGA(qvga) resolution(320x240) fps(10) support(1)
07-12 01:27:06.911 D/CameraHal( 233): ParserDVConfig(826): DV_CIF(cif) resolution(352x288) fps(10) support(1)
07-12 01:27:06.911 D/CameraHal( 233): ParserDVConfig(838): DV_VGA(480p) resolution(640x480) fps(10) support(1)
07-12 01:27:06.911 D/CameraHal( 233): ParserDVConfig(850): DV_480P(480p) resolution(720x480) fps(10) support(0)
07-12 01:27:06.911 D/CameraHal( 233): ParserDVConfig(874): DV_720P(720p) resolution(1280x720) fps(10) support(0)
07-12 01:27:06.911 D/CameraHal( 233): ParserDVConfig(886): DV_1080P(1080p) resolution(1920x1080) fps(10) support(0)
07-12 01:27:06.911 D/CameraHal( 233): number of camdevice (2)
07-12 01:27:06.911 D/CameraHal( 233): now DV size(7)
07-12 01:27:06.911 E/CameraHal( 233): camera_get_number_of_cameras(789): board profiles cam num 2
07-12 01:27:06.911 D/CameraHal( 233): read cam name from xml(/data/camera/media_profiles.xml)
07-12 01:27:06.911 E/CameraHal( 233): is not exist, register all
07-12 01:27:06.912 D/CameraHal( 233):
07-12 01:27:06.912 D/CameraHal( 233): CamSys_Head.h Version Check:
07-12 01:27:06.912 D/CameraHal( 233): Kernel camsys_head.h: v0x1.0x0.0x0
07-12 01:27:06.912 D/CameraHal( 233): Kernel camsys_drv : v0x0.0x30.0x0
07-12 01:27:06.912 D/CameraHal( 233): CameraHal camsys_head.h : v0x1.0x0.0x0
07-12 01:27:06.925 E/CameraHal( 233): WARNING: OV8858 soft reset by i2c failed!, please check follow information:
07-12 01:27:06.925 E/CameraHal( 233): Slave_addr: 0x6c 0x20
07-12 01:27:06.925 E/CameraHal( 233): Soft reset reg: 0x103 val: 0x1
07-12 01:27:06.925 E/CameraHal( 233): Power/PowerDown/Reset/Mclk/I2cBus
07-12 01:27:06.936 E/CameraHal( 233): OV8858 device register failed!
07-12 01:27:06.937 E/CameraHal( 233): Open (/dev/camsys_marvin1) failed, error=(No such file or directory),try to open /dev/camsys_marvin
07-12 01:27:06.937 D/CameraHal( 233):
07-12 01:27:06.937 D/CameraHal( 233): CamSys_Head.h Version Check:
07-12 01:27:06.937 D/CameraHal( 233): Kernel camsys_head.h: v0x1.0x0.0x0
07-12 01:27:06.937 D/CameraHal( 233): Kernel camsys_drv : v0x0.0x30.0x0
07-12 01:27:06.937 D/CameraHal( 233): CameraHal camsys_head.h : v0x1.0x0.0x0
07-12 01:27:06.950 E/CameraHal( 233): WARNING: GC2035 soft reset by i2c failed!, please check follow information:
07-12 01:27:06.950 E/CameraHal( 233): Slave_addr: 0x78 0x0
07-12 01:27:06.950 E/CameraHal( 233): Soft reset reg: 0xfe val: 0x80
07-12 01:27:06.950 E/CameraHal( 233): Power/PowerDown/Reset/Mclk/I2cBus
07-12 01:27:06.961 E/CameraHal( 233): GC2035 device register failed!
07-12 01:27:06.961 E/CameraHal( 233): camera_get_number_of_cameras(796): load sensor name(OV8858) connect 0
07-12 01:27:06.961 E/CameraHal( 233): camera_get_number_of_cameras(796): load sensor name(GC2035) connect 0
07-12 01:27:06.961 E/CameraHal( 233): camera_get_number_of_cameras(854): Open /dev/video0 failed! strr: No such file or directory
07-12 01:27:06.962 E/CameraHal( 233): camera_get_number_of_cameras(854): Open /dev/video1 failed! strr: No such file or directory
07-12 01:27:06.962 E/CameraHal( 233): camera_get_number_of_cameras(854): Open /dev/video2 failed! strr: No such file or directory
07-12 01:27:06.962 E/CameraHal( 233): camera_get_number_of_cameras(854): Open /dev/video3 failed! strr: No such file or directory
07-12 01:27:06.962 E/CameraHal( 233): camera_get_number_of_cameras(854): Open /dev/video4 failed! strr: No such file or directory
07-12 01:27:06.962 E/CameraHal( 233): camera_get_number_of_cameras(854): Open /dev/video5 failed! strr: No such file or directory
07-12 01:27:06.962 E/CameraHal( 233): camera_get_number_of_cameras(854): Open /dev/video6 failed! strr: No such file or directory
07-12 01:27:06.962 E/CameraHal( 233): camera_get_number_of_cameras(854): Open /dev/video7 failed! strr: No such file or directory
07-12 01:27:06.962 E/CameraHal( 233): camera_get_number_of_cameras(854): Open /dev/video8 failed! strr: No such file or directory
07-12 01:27:06.962 E/CameraHal( 233): camera_get_number_of_cameras(854): Open /dev/video9 failed! strr: No such file or directory
07-12 01:27:06.962 D/CameraHal( 233): camera_get_number_of_cameras(1246): camera_get_number_of_cameras(1246): Current board have 0 cameras attached.
07-12 01:27:06.962 D/CameraHal( 233): camera_get_number_of_cameras(1249): meida_profiles_xml_control time (56546)us
07-12 01:27:06.962 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:07.013 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:07.063 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:07.113 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:07.118 D/ICU ( 231): No timezone override file found: /data/misc/zoneinfo/current/icu/icu_tzdata.dat
07-12 01:27:07.163 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:07.214 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:07.264 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:07.314 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:07.364 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:07.407 E/memtrack( 231): Couldn’t load memtrack module (No such file or directory)
07-12 01:27:07.407 E/android.os.Debug( 231): failed to load memtrack module: -2
07-12 01:27:07.410 I/Radio-JNI( 231): register_android_hardware_Radio DONE
07-12 01:27:07.415 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:07.437 I/SamplingProfilerIntegration( 231): Profiling disabled.
07-12 01:27:07.442 I/art ( 231): Starting a blocking GC Background
07-12 01:27:07.462 I/Zygote ( 231): System server process 466 has been created
07-12 01:27:07.464 D/Zygote ( 231): begin preload
07-12 01:27:07.464 I/Zygote ( 231): Installing ICU cache reference pinning…
07-12 01:27:07.464 I/Zygote ( 231): Preloading ICU data…
07-12 01:27:07.465 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:07.474 I/InstallerConnection( 466): connecting…
07-12 01:27:07.479 I/ ( 235): new connection
07-12 01:27:07.515 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:07.519 I/InstallerConnection( 466): disconnecting…
07-12 01:27:07.519 E/ ( 235): eof
07-12 01:27:07.519 E/ ( 235): failed to read size
07-12 01:27:07.519 I/ ( 235): closing connection
07-12 01:27:07.563 I/Zygote ( 231): Preloading classes…
07-12 01:27:07.566 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:07.566 W/Zygote ( 231): Class not found for preloading: [Landroid.view.Display$ColorTransform;
07-12 01:27:07.616 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:07.639 I/SystemServer( 466): Entered the Android system server!
07-12 01:27:07.666 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:07.693 V/NatController( 241): runCmd(/system/bin/iptables -w -F natctrl_FORWARD) res=0
07-12 01:27:07.702 V/NatController( 241): runCmd(/system/bin/ip6tables -w -F natctrl_FORWARD) res=0
07-12 01:27:07.711 V/NatController( 241): runCmd(/system/bin/iptables -w -A natctrl_FORWARD -j DROP) res=0
07-12 01:27:07.716 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:07.720 V/NatController( 241): runCmd(/system/bin/iptables -w -t nat -F natctrl_nat_POSTROUTING) res=0
07-12 01:27:07.729 V/NatController( 241): runCmd(/system/bin/ip6tables -w -t raw -F natctrl_raw_PREROUTING) res=0
07-12 01:27:07.738 V/NatController( 241): runCmd(/system/bin/iptables -w -F natctrl_tether_counters) res=1
07-12 01:27:07.746 V/NatController( 241): runCmd(/system/bin/ip6tables -w -F natctrl_tether_counters) res=1
07-12 01:27:07.755 V/NatController( 241): runCmd(/system/bin/iptables -w -X natctrl_tether_counters) res=1
07-12 01:27:07.764 V/NatController( 241): runCmd(/system/bin/ip6tables -w -X natctrl_tether_counters) res=1
07-12 01:27:07.767 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:07.774 V/NatController( 241): runCmd(/system/bin/iptables -w -N natctrl_tether_counters) res=0
07-12 01:27:07.783 V/NatController( 241): runCmd(/system/bin/ip6tables -w -N natctrl_tether_counters) res=0
07-12 01:27:07.792 V/NatController( 241): runCmd(/system/bin/iptables -w -t mangle -A natctrl_mangle_FORWARD -p tcp --tcp-flags SYN SYN -j TCPMSS --clamp-mss-to-pmtu) res=0
07-12 01:27:07.817 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:07.867 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:07.875 I/vpu_api ( 521): dlclose vpu lib
07-12 01:27:07.917 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:07.928 E/Netd ( 241): cannot find interface dummy0
07-12 01:27:07.930 E/Netd ( 241): Unable to create netlink socket: Protocol not supported
07-12 01:27:07.930 W/Netd ( 241): Unable to open qlog quota socket, check if xt_quota2 can send via UeventHandler
07-12 01:27:07.931 D/MDnsDS ( 241): MDnsSdListener::Hander starting up
07-12 01:27:07.931 D/MDnsDS ( 241): MDnsSdListener starting to monitor
07-12 01:27:07.931 D/MDnsDS ( 241): Going to poll with pollCount 1
07-12 01:27:07.968 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:08.018 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:08.068 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:08.118 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:08.120 E/Typeface( 231): Error mapping font file /system/fonts/DroidSansFallback.ttf
07-12 01:27:08.169 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:08.183 I/SystemServiceManager( 466): Starting com.android.server.pm.Installer
07-12 01:27:08.189 I/Installer( 466): Waiting for installd to be ready.
07-12 01:27:08.189 I/InstallerConnection( 466): connecting…
07-12 01:27:08.189 I/ ( 235): new connection
07-12 01:27:08.189 I/SystemServiceManager( 466): Starting com.android.server.am.ActivityManagerService$Lifecycle
07-12 01:27:08.219 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:08.233 I/ActivityManager( 466): Memory class: 192
07-12 01:27:08.238 I/ServiceThread( 466): Enabled StrictMode logging for ActivityManager looper.
07-12 01:27:08.241 I/ServiceThread( 466): Enabled StrictMode logging for android.ui looper.
07-12 01:27:08.269 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:08.319 D/BatteryStatsImpl( 466): Reading daily items from /data/system/batterystats-daily.xml
07-12 01:27:08.319 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:08.370 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:08.378 I/art ( 231): Thread[1,tid=231,Native,Thread=0xada85400,peer=0x74f3c000,“main”] recursive attempt to load library “/system/lib/libmedia_jni.so”
07-12 01:27:08.378 D/MtpDeviceJNI( 231): register_android_mtp_MtpDevice
07-12 01:27:08.379 I/art ( 231): Thread[1,tid=231,Native,Thread=0xada85400,peer=0x74f3c000,“main”] recursive attempt to load library “/system/lib/libmedia_jni.so”
07-12 01:27:08.381 D/MediaProfiles( 231): CameraGroupFound(622): media_profiles_id: 0x0
07-12 01:27:08.382 D/MediaProfiles( 231): THIS IS RIGHT: getInstance(697): cameraHal version(0x1.0x51.0x1) before(0.3.33),so don’t have file(/data/camera/media_profiles.xml)
07-12 01:27:08.382 W/MediaProfiles( 231): could not find media config xml file
07-12 01:27:08.420 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:08.446 I/vpu_api ( 543): dlclose vpu lib
07-12 01:27:08.461 I/IntentFirewall( 466): Read new rules (A:0 B:0 S:0)
07-12 01:27:08.463 W/Zygote ( 231): Class not found for preloading: android.view.Display$ColorTransform
07-12 01:27:08.463 W/Zygote ( 231): Class not found for preloading: android.view.Display$ColorTransform$1
07-12 01:27:08.468 I/ServiceThread( 466): Enabled StrictMode logging for android.display looper.
07-12 01:27:08.470 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:08.477 D/AppOps ( 466): AppOpsService published
07-12 01:27:08.478 I/SystemServiceManager( 466): Starting com.android.server.power.PowerManagerService
07-12 01:27:08.481 I/ServiceThread( 466): Enabled StrictMode logging for PowerManagerService looper.
07-12 01:27:08.484 I/chatty ( 466): uid=1000 system_server expire 186 lines
07-12 01:27:08.498 I/SystemServiceManager( 466): Starting com.android.server.lights.LightsService
07-12 01:27:08.505 I/SystemServiceManager( 466): Starting com.android.server.display.DisplayManagerService
07-12 01:27:08.513 I/SystemServiceManager( 466): Starting phase 100
07-12 01:27:08.519 I/DisplayManagerService( 466): Display device added: DisplayDeviceInfo{“Built-in Screen”: uniqueId=“local:0”, 1024 x 600, modeId 1, defaultModeId 1, supportedModes [{id=1, width=1024, height=600, fps=50.0}], colorMode 0, supportedColorModes [0], HdrCapabilities android.view.Display$HdrCapabilities@a69d6308, density 160, 213.0 x 213.0 dpi, appVsyncOff 1000000, presDeadline 20000000, touch INTERNAL, rotation 0, type BUILT_IN, state UNKNOWN, FLAG_DEFAULT_DISPLAY, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
07-12 01:27:08.520 D/SurfaceFlinger( 220): Set power mode=2, type=0 flinger=0xaa3b2000
07-12 01:27:08.520 D/SurfaceFlinger( 220): Screen type=0 is already mode=2
07-12 01:27:08.520 I/chatty ( 466): uid=1000(system) android.display expire 3 lines
07-12 01:27:08.520 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:08.521 I/DisplayManagerService( 466): Display device changed state: “Built-in Screen”, ON
07-12 01:27:08.521 I/SystemServer( 466): StartPackageManagerService
07-12 01:27:08.571 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:08.571 W/SystemConfig( 466): No directory /system/etc/sysconfig, skipping
07-12 01:27:08.606 D/SELinuxMMAC( 466): Using policy file /system/etc/security/mac_permissions.xml
07-12 01:27:08.621 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:08.625 I/System ( 231): Loaded time zone names for “” in 51ms (49ms in ICU)
07-12 01:27:08.646 I/System ( 231): Loaded time zone names for “en_US” in 20ms (18ms in ICU)
07-12 01:27:08.671 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:08.682 I/Zygote ( 231): …preloaded 4158 classes in 1120ms.
07-12 01:27:08.682 I/art ( 231): VMRuntime.preloadDexCaches starting
07-12 01:27:08.721 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:08.760 I/art ( 231): VMRuntime.preloadDexCaches strings total=285273 before=36751 after=36751
07-12 01:27:08.760 I/art ( 231): VMRuntime.preloadDexCaches types total=23662 before=7882 after=7910
07-12 01:27:08.760 I/art ( 231): VMRuntime.preloadDexCaches fields total=112770 before=41093 after=41310
07-12 01:27:08.760 I/art ( 231): VMRuntime.preloadDexCaches methods total=198492 before=82661 after=83227
07-12 01:27:08.760 I/art ( 231): VMRuntime.preloadDexCaches finished
07-12 01:27:08.761 I/Zygote ( 231): Preloading resources…
07-12 01:27:08.772 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:08.791 W/Resources( 231): Preloaded drawable resource #0x108025c (android:drawable/dialog_background_material) that varies with configuration!!
07-12 01:27:08.791 W/Resources( 231): Preloaded drawable resource #0x1080298 (android:drawable/editbox_dropdown_background_dark) that varies with configuration!!
07-12 01:27:08.796 W/Resources( 231): Preloaded color resource #0x10600ea (android:color/material_grey_800) that varies with configuration!!
07-12 01:27:08.796 W/Resources( 231): Preloaded drawable resource #0x10802c9 (android:drawable/floating_popup_background_dark) that varies with configuration!!
07-12 01:27:08.808 W/Resources( 231): Preloaded drawable resource #0x108030b (android:drawable/ic_clear_disabled) that varies with configuration!!
07-12 01:27:08.809 W/Resources( 231): Preloaded drawable resource #0x1080310 (android:drawable/ic_clear_normal) that varies with configuration!!
07-12 01:27:08.811 W/Resources( 231): Preloaded drawable resource #0x1080359 (android:drawable/ic_go) that varies with configuration!!
07-12 01:27:08.813 W/PackageManager( 466): Library not found: /system/framework/org.apache.http.legacy.jar
07-12 01:27:08.817 W/Resources( 231): Preloaded drawable resource #0x1080038 (android:drawable/ic_menu_close_clear_cancel) that varies with configuration!!
07-12 01:27:08.822 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:08.823 W/Resources( 231): Preloaded drawable resource #0x1080045 (android:drawable/ic_menu_more) that varies with configuration!!
07-12 01:27:08.831 W/Resources( 231): Preloaded drawable resource #0x10804eb (android:drawable/menu_background_fill_parent_width) that varies with configuration!!
07-12 01:27:08.869 W/Resources( 231): Preloaded drawable resource #0x1080783 (android:drawable/text_edit_paste_window) that varies with configuration!!
07-12 01:27:08.872 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:08.874 W/Resources( 231): Preloaded drawable resource #0x1080096 (android:drawable/toast_frame) that varies with configuration!!
07-12 01:27:08.874 I/Zygote ( 231): …preloaded 114 resources in 113ms.
07-12 01:27:08.878 W/Resources( 231): Preloaded color resource #0x1060114 (android:color/background_cache_hint_selector_material_dark) that varies with configuration!!
07-12 01:27:08.878 W/Resources( 231): Preloaded color resource #0x1060119 (android:color/btn_default_material_dark) that varies with configuration!!
07-12 01:27:08.879 I/Zygote ( 231): …preloaded 41 resources in 6ms.
07-12 01:27:08.880 D/libEGL ( 231): loaded /vendor/lib/egl/libGLES_mali.so
07-12 01:27:08.902 I/Zygote ( 231): Preloading shared libraries…
07-12 01:27:08.922 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:08.922 W/PackageParser( 466): No actions in intent filter at /system/priv-app/Contacts/Contacts.apk Binary XML file line #409
07-12 01:27:08.924 I/Zygote ( 231): Uninstalled ICU cache reference pinning…
07-12 01:27:08.932 I/Zygote ( 231): Installed AndroidKeyStoreProvider in 8ms.
07-12 01:27:08.941 I/Zygote ( 231): Warmed up JCA providers in 10ms.
07-12 01:27:08.941 D/Zygote ( 231): end preload
07-12 01:27:08.941 I/art ( 231): Starting a blocking GC Explicit
07-12 01:27:08.953 I/art ( 231): Explicit concurrent mark sweep GC freed 8316(467KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 2MB/4MB, paused 141us total 11.578ms
07-12 01:27:08.955 I/art ( 231): Starting a blocking GC Explicit
07-12 01:27:08.961 W/PackageParser( 466): Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.ACCESS_FINE_LOCATION in package: com.DeviceTest at: Binary XML file line #22
07-12 01:27:08.961 W/PackageParser( 466): Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.WRITE_SETTINGS in package: com.DeviceTest at: Binary XML file line #31
07-12 01:27:08.961 W/PackageParser( 466): Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.INTERNET in package: com.DeviceTest at: Binary XML file line #39
07-12 01:27:08.961 W/PackageParser( 466): Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.DEVICE_POWER in package: com.DeviceTest at: Binary XML file line #43
07-12 01:27:08.965 I/art ( 231): Explicit concurrent mark sweep GC freed 1920(87KB) AllocSpace objects, 0(0B) LOS objects, 40% free, 2MB/4MB, paused 129us total 9.551ms
07-12 01:27:08.973 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:08.982 I/Zygote ( 231): Accepting command socket connections
07-12 01:27:08.995 W/PackageManager( 466): Permission android.permission.DOWNLOAD_WITHOUT_NOTIFICATION from package com.android.providers.downloads in an unknown group android.permission-group.NETWORK
07-12 01:27:09.023 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:09.073 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:09.123 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:09.173 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:09.224 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:09.232 W/PackageParser( 466): Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.USE_CREDENTIALS in package: com.android.settings at: Binary XML file line #56
07-12 01:27:09.232 W/PackageParser( 466): Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.READ_SYNC_SETTINGS in package: com.android.settings at: Binary XML file line #61
07-12 01:27:09.232 W/PackageParser( 466): Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.WRITE_SYNC_SETTINGS in package: com.android.settings at: Binary XML file line #62
07-12 01:27:09.274 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:09.281 W/PackageParser( 466): Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.INSTALL_GRANT_RUNTIME_PERMISSIONS in package: com.android.shell at: Binary XML file line #102
07-12 01:27:09.324 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:09.374 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:09.381 W/PackageParser( 466): Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.CONFIGURE_WIFI_DISPLAY in package: com.android.systemui at: Binary XML file line #123
07-12 01:27:09.425 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:09.475 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:09.505 W/PackageParser( 466): Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.READ_CONTACTS in package: com.android.bluetooth at: Binary XML file line #61
07-12 01:27:09.506 W/PackageParser( 466): No actions in intent filter at /system/app/Bluetooth/Bluetooth.apk Binary XML file line #223
07-12 01:27:09.525 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:09.543 W/PackageManager( 466): Non-privileged app; cap priority to 0; package: com.android.calendar activity: com.android.calendar.GoogleCalendarUriIntentFilter origPrio: 50
07-12 01:27:09.575 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:09.593 W/PackageManager( 466): Non-privileged app; cap priority to 0; package: com.android.cts.ctsshim activity: com.android.cts.ctsshim.InstallPriority origPrio: 100
07-12 01:27:09.626 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:09.670 W/PackageParser( 466): Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.WRITE_CONTACTS in package: com.android.email at: Binary XML file line #40
07-12 01:27:09.676 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:09.722 W/PackageParser( 466): Unknown element under : permission at /system/app/Gallery2/Gallery2.apk Binary XML file line #247
07-12 01:27:09.722 W/PackageParser( 466): Unknown element under : permission at /system/app/Gallery2/Gallery2.apk Binary XML file line #250
07-12 01:27:09.726 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:09.776 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:09.817 W/PackageManager( 466): Permission com.android.launcher3.permission.READ_SETTINGS from package com.android.launcher3 in an unknown group android.permission-group.SYSTEM_TOOLS
07-12 01:27:09.817 W/PackageManager( 466): Permission com.android.launcher3.permission.WRITE_SETTINGS from package com.android.launcher3 in an unknown group android.permission-group.SYSTEM_TOOLS
07-12 01:27:09.817 W/PackageManager( 466): Permission com.android.launcher.permission.INSTALL_SHORTCUT from package com.android.launcher3 in an unknown group android.permission-group.SYSTEM_TOOLS
07-12 01:27:09.827 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:09.830 W/PackageParser( 466): Unknown element under : meta-data at /system/app/Lightning/Lightning.apk Binary XML file line #32
07-12 01:27:09.877 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:09.877 W/PackageParser( 466): Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.CHANGE_WIFI_STATE in package: com.android.nfc at: Binary XML file line #47
07-12 01:27:09.877 W/PackageParser( 466): Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.ACCESS_WIFI_STATE in package: com.android.nfc at: Binary XML file line #48
07-12 01:27:09.927 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:09.957 W/PackageParser( 466): Ignoring duplicate uses-permissions/uses-permissions-sdk-m: android.permission.DEVICE_POWER in package: android.rk.RockVideoPlayer at: Binary XML file line #26
07-12 01:27:09.976 I/PackageParser( 466): android_serialport_api.sample: compat added android.permission.WRITE_EXTERNAL_STORAGE android.permission.READ_PHONE_STATE
07-12 01:27:09.977 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:10.025 W/PackageManager( 466): Protected action; cap priority to 0; package: com.android.cts.priv.ctsshim activity: com.android.cts.priv.ctsshim.InstallPriority origPrio: 100
07-12 01:27:10.025 W/PackageManager( 466): Protected action; cap priority to 0; package: com.android.packageinstaller activity: com.android.packageinstaller.PackageInstallerActivity origPrio: 1
07-12 01:27:10.025 W/PackageManager( 466): Package com.android.gallery3d desires unavailable shared library com.google.android.media.effects; ignoring!
07-12 01:27:10.026 I/PackageManager( 466): Adjusting ABI for com.android.providers.media to armeabi-v7a (requirer=com.android.mtp, scannedPackage=null)
07-12 01:27:10.026 I/PackageManager( 466): Adjusting ABI for com.android.providers.downloads to armeabi-v7a (requirer=com.android.mtp, scannedPackage=null)
07-12 01:27:10.026 I/PackageManager( 466): Adjusting ABI for com.android.providers.downloads.ui to armeabi-v7a (requirer=com.android.mtp, scannedPackage=null)
07-12 01:27:10.027 I/PackageManager( 466): Adjusting ABI for com.android.wallpaperbackup to armeabi-v7a (requirer=android, scannedPackage=null)
07-12 01:27:10.027 I/PackageManager( 466): Adjusting ABI for com.android.settings to armeabi-v7a (requirer=android, scannedPackage=null)
07-12 01:27:10.027 I/PackageManager( 466): Adjusting ABI for com.android.location.fused to armeabi-v7a (requirer=android, scannedPackage=null)
07-12 01:27:10.027 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:10.028 I/PackageManager( 466): Adjusting ABI for com.android.inputdevices to armeabi-v7a (requirer=android, scannedPackage=null)
07-12 01:27:10.028 I/PackageManager( 466): Adjusting ABI for com.cghs.stresstest to armeabi-v7a (requirer=android, scannedPackage=null)
07-12 01:27:10.028 I/PackageManager( 466): Adjusting ABI for com.DeviceTest to armeabi-v7a (requirer=android, scannedPackage=null)
07-12 01:27:10.029 I/PackageManager( 466): Adjusting ABI for com.android.providers.settings to armeabi-v7a (requirer=android, scannedPackage=null)
07-12 01:27:10.029 I/PackageManager( 466): Adjusting ABI for com.android.rk.mediafloat to armeabi-v7a (requirer=android, scannedPackage=null)
07-12 01:27:10.029 I/PackageManager( 466): Adjusting ABI for com.android.rk to armeabi-v7a (requirer=android, scannedPackage=null)
07-12 01:27:10.030 I/PackageManager( 466): Adjusting ABI for com.android.keychain to armeabi-v7a (requirer=android, scannedPackage=null)
07-12 01:27:10.030 I/PackageManager( 466): Adjusting ABI for com.android.server.telecom to armeabi-v7a (requirer=android, scannedPackage=null)
07-12 01:27:10.030 I/PackageManager( 466): Adjusting ABI for android.rk.RockVideoPlayer to armeabi-v7a (requirer=android, scannedPackage=null)
07-12 01:27:10.033 I/PackageManager( 466): Time to scan packages: 1.255 seconds
07-12 01:27:10.033 W/PackageManager( 466): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.calendar
07-12 01:27:10.033 W/PackageManager( 466): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cl in package com.android.providers.calendar
07-12 01:27:10.033 W/PackageManager( 466): Not granting permission android.permission.GLOBAL_SEARCH to package com.android.quicksearchbox (protectionLevel=18 flags=0x3808be45)
07-12 01:27:10.034 W/PackageManager( 466): Unknown permission android.permission.NFC_UNLOCK in package com.android.nfc
07-12 01:27:10.034 W/PackageManager( 466): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.android.launcher3
07-12 01:27:10.034 W/PackageManager( 466): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.android.launcher3
07-12 01:27:10.034 W/PackageManager( 466): Not granting permission android.permission.BIND_APPWIDGET to package com.android.launcher3 (protectionLevel=18 flags=0x3c4bbe45)
07-12 01:27:10.034 W/PackageManager( 466): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.calendar
07-12 01:27:10.034 W/PackageManager( 466): Unknown permission android.permission.READ_SETTINGS in package com.android.apkinstaller
07-12 01:27:10.034 W/PackageManager( 466): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.android.onetimeinitializer
07-12 01:27:10.034 W/PackageManager( 466): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.android.onetimeinitializer
07-12 01:27:10.034 W/PackageManager( 466): Unknown permission com.google.android.permission.INSTALL_WEARABLE_PACKAGES in package com.android.packageinstaller
07-12 01:27:10.034 W/PackageManager( 466): Not granting permission android.permission.DELETE_PACKAGES to package com.svox.pico (protectionLevel=18 flags=0x3808be45)
07-12 01:27:10.035 W/PackageManager( 466): Unknown permission com.google.android.gallery3d.permission.PICASA_STORE in package com.android.dreams.phototable
07-12 01:27:10.035 W/PackageManager( 466): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.settings
07-12 01:27:10.035 W/PackageManager( 466): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.android.settings
07-12 01:27:10.035 W/PackageManager( 466): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.android.settings
07-12 01:27:10.036 W/PackageManager( 466): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.DeviceTest
07-12 01:27:10.036 W/PackageManager( 466): Unknown permission com.google.android.gallery3d.permission.GALLERY_PROVIDER in package com.android.bluetooth
07-12 01:27:10.036 W/PackageManager( 466): Unknown permission rockchip.permission.FULL_SCREEN in package android.rk.RockVideoPlayer
07-12 01:27:10.036 W/PackageManager( 466): Unknown permission android.permission.RAISED_THREAD_PRIORITY in package android.rk.RockVideoPlayer
07-12 01:27:10.036 W/PackageManager( 466): Unknown permission android.permission.FULL_SCREEN in package android.rk.RockVideoPlayer
07-12 01:27:10.036 W/PackageManager( 466): Unknown permission archos.permission.FULL_SCREEN in package android.rk.RockVideoPlayer
07-12 01:27:10.036 V/PackageManager( 466): reconcileAppsData for null u0 0x3
07-12 01:27:10.064 I/SELinux ( 235): SELinux: Loaded file_contexts contexts from /file_contexts.bin.
07-12 01:27:10.078 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:10.128 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:10.178 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:10.228 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:10.279 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:10.329 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:10.379 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:10.386 V/PackageManager( 466): reconcileAppsData finished 85 packages
07-12 01:27:10.421 D/PackageManager( 466): Ephemeral resolver NOT found; no matching intent filters
07-12 01:27:10.421 I/PackageManager( 466): Ephemeral deactivated; missing resolver and installer
07-12 01:27:10.429 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:10.439 I/SystemServer( 466): StartOtaDexOptService
07-12 01:27:10.440 I/SystemServer( 466): StartUserManagerService
07-12 01:27:10.440 I/SystemServiceManager( 466): Starting com.android.server.pm.UserManagerService$LifeCycle
07-12 01:27:10.446 I/lowmemorykiller( 218): ActivityManager connected
07-12 01:27:10.447 I/SystemServiceManager( 466): Starting com.android.server.BatteryService
07-12 01:27:10.447 I/chatty ( 466): uid=1000 system_server expire 53 lines
07-12 01:27:10.459 I/chatty ( 466): uid=1000(system) batterystats-sy expire 1 line
07-12 01:27:10.459 I/chatty ( 466): uid=1000(system) Binder:466_1 expire 1 line
07-12 01:27:10.463 I/SystemServiceManager( 466): Starting com.android.server.usage.UsageStatsService
07-12 01:27:10.470 I/chatty ( 466): uid=1000(system) SensorEventAckR expire 1 line
07-12 01:27:10.470 I/chatty ( 466): uid=1000(system) SensorService expire 1 line
07-12 01:27:10.480 I/ServiceManager( 233): Waiting for service media.camera.proxy…
07-12 01:27:10.481 I/SystemServiceManager( 466): Starting com.android.server.webkit.WebViewUpdateService
07-12 01:27:10.487 I/SystemServer( 466): Reading configuration…
07-12 01:27:10.488 I/SystemServer( 466): StartSchedulingPolicyService
07-12 01:27:10.488 I/SystemServiceManager( 466): Starting com.android.server.telecom.TelecomLoaderService
07-12 01:27:10.491 I/SystemServer( 466): StartTelephonyRegistry
07-12 01:27:10.497 I/SystemServer( 466): StartEntropyMixer
07-12 01:27:10.498 I/EntropyMixer( 466): Writing entropy…
07-12 01:27:10.500 I/SystemServer( 466): Camera Service
07-12 01:27:10.502 I/SystemServiceManager( 466): Starting com.android.server.camera.CameraService
07-12 01:27:10.505 I/ServiceThread( 466): Enabled StrictMode logging for CameraService_proxy looper.
07-12 01:27:10.506 I/SystemServer( 466): StartAccountManagerService
07-12 01:27:10.507 I/SystemServiceManager( 466): Starting com.android.server.accounts.AccountManagerService$Lifecycle
07-12 01:27:10.518 I/SystemServer( 466): StartContentService
07-12 01:27:10.520 I/SystemServiceManager( 466): Starting com.android.server.content.ContentService$Lifecycle
07-12 01:27:10.523 I/SystemServer( 466): InstallSystemProviders
07-12 01:27:10.549 I/SystemServer( 466): StartVibratorService
07-12 01:27:10.552 I/SystemServer( 466): StartConsumerIrService
07-12 01:27:10.553 I/SystemServer( 466): StartAlarmManagerService
07-12 01:27:10.553 I/SystemServiceManager( 466): Starting com.android.server.AlarmManagerService
07-12 01:27:10.555 W/AlarmAlignmentManager( 466): updating App alarm config:
07-12 01:27:10.555 W/AlarmAlignmentManager( 466): old config:strategy:SCREEN_OFF_ALARM_STRATEGY_NONE, repeat alignment:0, fixed alignment:0, skip short interval:0, strict:true, ignore top:false, skip nonwakeup:true, align system alarm:false, whitelist size:0, blacklist size:0
07-12 01:27:10.555 W/AlarmAlignmentManager( 466): new config:strategy:SCREEN_OFF_ALARM_STRATEGY_NONE, repeat alignment:0, fixed alignment:0, skip short interval:0, strict:true, ignore top:false, skip nonwakeup:true, align system alarm:false, whitelist size:0, blacklist size:0
07-12 01:27:10.562 I/SystemServer( 466): InitWatchdog
07-12 01:27:10.562 I/SystemServer( 466): StartInputManagerService
07-12 01:27:10.564 I/InputManager( 466): Initializing input manager, mUseDevInputEventForAudioJack=false
07-12 01:27:10.565 I/SystemServer( 466): StartWindowManagerService
07-12 01:27:10.595 I/WindowManager( 466): No existing display settings /data/system/display_settings.xml; starting empty
07-12 01:27:10.622 I/SystemServer( 466): StartVrManagerService
07-12 01:27:10.622 I/SystemServiceManager( 466): Starting com.android.server.vr.VrManagerService
07-12 01:27:10.626 I/InputManager( 466): Starting input manager
07-12 01:27:10.627 I/chatty ( 466): uid=1000(system) InputReader expire 18 lines
07-12 01:27:10.628 I/SystemServiceManager( 466): Starting com.android.server.BluetoothService
07-12 01:27:10.634 D/BluetoothManagerService( 466): Loading stored name and address
07-12 01:27:10.634 D/BluetoothManagerService( 466): Stored bluetooth Name=rk3288,Address=22:22:D2:B5:04:C4
07-12 01:27:10.634 D/BluetoothManagerService( 466): Bluetooth persisted state: 0
07-12 01:27:10.634 I/SystemServer( 466): ConnectivityMetricsLoggerService
07-12 01:27:10.634 I/SystemServiceManager( 466): Starting com.android.server.connectivity.MetricsLoggerService
07-12 01:27:10.636 I/SystemServer( 466): IpConnectivityMetrics
07-12 01:27:10.636 I/SystemServiceManager( 466): Starting com.android.server.connectivity.IpConnectivityMetrics
07-12 01:27:10.637 I/SystemServer( 466): PinnerService
07-12 01:27:10.637 I/SystemServiceManager( 466): Starting com.android.server.PinnerService
07-12 01:27:10.638 I/SystemServiceManager( 466): Starting com.android.server.InputMethodManagerService$Lifecycle
07-12 01:27:10.693 I/SystemServer( 466): StartAccessibilityManagerService
07-12 01:27:10.701 I/ActivityManager( 466): Config changes=1df8 {1.0 dualscreenflag=DISABLE ?mcc?mnc [en_US] ldltr sw600dp w1024dp h600dp 160dpi lrg long land ?uimode ?night -touch -keyb/v/h -nav/h s.2}
07-12 01:27:10.706 I/ActivityManager( 466): Config changes=408 {1.0 dualscreenflag=DISABLE ?mcc?mnc [en_US] ldltr sw600dp w1024dp h528dp 160dpi lrg long land ?uimode ?night finger -keyb/v/h -nav/h s.3}
07-12 01:27:10.711 I/ActivityManager( 466): Config changes=100 {1.0 dualscreenflag=DISABLE ?mcc?mnc [en_US] ldltr sw600dp w1024dp h528dp 160dpi lrg land ?uimode ?night finger -keyb/v/h -nav/h s.4}
07-12 01:27:10.724 I/SystemServiceManager( 466): Starting com.android.server.MountService$Lifecycle
07-12 01:27:10.734 I/SystemServer( 466): start UiModeManagerService.
07-12 01:27:10.735 D/MountService( 466): Thinking about init, mSystemReady=false, mDaemonConnected=true
07-12 01:27:10.735 D/MountService( 466): Thinking about reset, mSystemReady=false, mDaemonConnected=true
07-12 01:27:10.735 I/UsageStatsService( 466): User[0] Rollover scheduled @ 2019-07-12 12:49:00(1562935740709)
07-12 01:27:10.736 D/MountService( 466): Thinking about reset, mSystemReady=false, mDaemonConnected=true
07-12 01:27:10.736 D/CryptdConnector( 466): SND → {1 cryptfs getfield SystemLocale}
07-12 01:27:10.737 D/CryptdConnector( 466): RCV ← {200 1 -1}
07-12 01:27:10.738 W/MountService( 466): No primary storage mounted!
07-12 01:27:10.739 D/VoldConnector( 466): SND → {1 asec list}
07-12 01:27:10.739 I/SystemServiceManager( 466): Starting com.android.server.UiModeManagerService
07-12 01:27:10.739 D/VoldConnector( 466): RCV ← {200 1 asec operation succeeded}
07-12 01:27:10.740 I/chatty ( 466): uid=1000(system) MountService expire 3 lines
07-12 01:27:10.740 W/PackageManager( 466): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.calendar
07-12 01:27:10.740 W/PackageManager( 466): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cl in package com.android.providers.calendar
07-12 01:27:10.740 W/PackageManager( 466): Not granting permission android.permission.GLOBAL_SEARCH to package com.android.quicksearchbox (protectionLevel=18 flags=0x3808be45)
07-12 01:27:10.740 W/PackageManager( 466): Unknown permission android.permission.NFC_UNLOCK in package com.android.nfc
07-12 01:27:10.740 W/PackageManager( 466): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.android.launcher3
07-12 01:27:10.741 W/PackageManager( 466): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.android.launcher3
07-12 01:27:10.741 W/PackageManager( 466): Not granting permission android.permission.BIND_APPWIDGET to package com.android.launcher3 (protectionLevel=18 flags=0x3c4bbe45)
07-12 01:27:10.741 W/PackageManager( 466): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.calendar
07-12 01:27:10.741 W/PackageManager( 466): Unknown permission android.permission.READ_SETTINGS in package com.android.apkinstaller
07-12 01:27:10.741 W/PackageManager( 466): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.android.onetimeinitializer
07-12 01:27:10.741 W/PackageManager( 466): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.android.onetimeinitializer
07-12 01:27:10.741 W/PackageManager( 466): Unknown permission com.google.android.permission.INSTALL_WEARABLE_PACKAGES in package com.android.packageinstaller
07-12 01:27:10.741 W/PackageManager( 466): Not granting permission android.permission.DELETE_PACKAGES to package com.svox.pico (protectionLevel=18 flags=0x3808be45)
07-12 01:27:10.741 W/PackageManager( 466): Unknown permission com.google.android.gallery3d.permission.PICASA_STORE in package com.android.dreams.phototable
07-12 01:27:10.742 W/PackageManager( 466): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.settings
07-12 01:27:10.742 W/PackageManager( 466): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.android.settings
07-12 01:27:10.742 W/PackageManager( 466): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.android.settings
07-12 01:27:10.743 W/PackageManager( 466): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.DeviceTest
07-12 01:27:10.743 W/PackageManager( 466): Unknown permission com.google.android.gallery3d.permission.GALLERY_PROVIDER in package com.android.bluetooth
07-12 01:27:10.743 W/PackageManager( 466): Unknown permission rockchip.permission.FULL_SCREEN in package android.rk.RockVideoPlayer
07-12 01:27:10.743 W/PackageManager( 466): Unknown permission android.permission.RAISED_THREAD_PRIORITY in package android.rk.RockVideoPlayer
07-12 01:27:10.743 W/PackageManager( 466): Unknown permission android.permission.FULL_SCREEN in package android.rk.RockVideoPlayer
07-12 01:27:10.743 W/PackageManager( 466): Unknown permission archos.permission.FULL_SCREEN in package android.rk.RockVideoPlayer
07-12 01:27:10.775 I/ActivityManager( 466): Config changes=200 {1.0 dualscreenflag=DISABLE ?mcc?mnc [en_US] ldltr sw600dp w1024dp h528dp 160dpi lrg land finger -keyb/v/h -nav/h s.5}
07-12 01:27:10.776 W/MountService( 466): No primary storage mounted!
07-12 01:27:10.776 D/VoldConnector( 466): SND → {2 asec list}
07-12 01:27:10.777 D/VoldConnector( 466): RCV ← {200 2 asec operation succeeded}
07-12 01:27:10.779 I/SystemServer( 466): StartLockSettingsService
07-12 01:27:10.779 I/SystemServiceManager( 466): Starting com.android.server.LockSettingsService$Lifecycle
07-12 01:27:10.788 I/SystemServiceManager( 466): Starting com.android.server.DeviceIdleController
07-12 01:27:10.792 I/SystemServiceManager( 466): Starting com.android.server.devicepolicy.DevicePolicyManagerService$Lifecycle
07-12 01:27:10.803 I/SystemServer( 466): StartStatusBarManagerService
07-12 01:27:10.804 I/SystemServer( 466): StartClipboardService
07-12 01:27:10.805 I/SystemServer( 466): StartNetworkManagementService
07-12 01:27:10.808 I/NetworkManagement( 466): onDaemonConnected()
07-12 01:27:10.810 I/SystemServiceManager( 466): Starting com.android.server.TextServicesManagerService$Lifecycle
07-12 01:27:10.815 I/SystemServer( 466): StartNetworkScoreService
07-12 01:27:10.817 I/SystemServer( 466): StartNetworkStatsService
07-12 01:27:10.826 I/SystemServer( 466): StartNetworkPolicyManagerService
07-12 01:27:10.832 I/SystemServer( 466): No Wi-Fi NAN Service (NAN support Not Present)
07-12 01:27:10.843 I/SystemServiceManager( 466): Starting com.android.server.wifi.p2p.WifiP2pService
07-12 01:27:10.876 I/SystemServiceManager( 466): Starting com.android.server.wifi.WifiService
07-12 01:27:10.902 I/chatty ( 466): uid=1000(system) IpManager.wlan0 expire 2 lines
07-12 01:27:10.903 D/CommandListener( 241): Clearing all IP addresses on wlan0
07-12 01:27:10.904 I/chatty ( 466): uid=1000(system) WifiStateMachin expire 68 lines
07-12 01:27:10.909 I/SystemServiceManager( 466): Starting com.android.server.wifi.scanner.WifiScanningService
07-12 01:27:10.910 I/SystemServiceManager( 466): Starting com.android.server.wifi.RttService
07-12 01:27:10.912 I/SystemServer( 466): StartEthernetService
07-12 01:27:10.912 I/SystemServiceManager( 466): Starting com.android.server.ethernet.EthernetService
07-12 01:27:10.914 I/SystemServer( 466): StartConnectivityService
07-12 01:27:10.918 D/ConnectivityService( 466): ConnectivityService starting up
07-12 01:27:10.920 D/ConnectivityService( 466): wifiOnly=false
07-12 01:27:10.920 D/ConnectivityService( 466): naString=wifi,1,1,2,-1,true config=android.net.NetworkConfig@62952f1
07-12 01:27:10.920 D/ConnectivityService( 466): naString=mobile,0,0,0,-1,true config=android.net.NetworkConfig@e43eed6
07-12 01:27:10.920 D/ConnectivityService( 466): naString=mobile_mms,2,0,2,60000,false config=android.net.NetworkConfig@5361557
07-12 01:27:10.920 D/ConnectivityService( 466): naString=mobile_supl,3,0,2,60000,true config=android.net.NetworkConfig@ad1c844
07-12 01:27:10.920 D/ConnectivityService( 466): naString=mobile_dun,4,0,2,60000,true config=android.net.NetworkConfig@eef2d2d
07-12 01:27:10.920 D/ConnectivityService( 466): naString=mobile_hipri,5,0,3,60000,true config=android.net.NetworkConfig@9682262
07-12 01:27:10.920 D/ConnectivityService( 466): naString=mobile_fota,10,0,2,60000,true config=android.net.NetworkConfig@59caff3
07-12 01:27:10.920 D/ConnectivityService( 466): naString=mobile_ims,11,0,2,60000,true config=android.net.NetworkConfig@a4524b0
07-12 01:27:10.920 D/ConnectivityService( 466): naString=mobile_cbs,12,0,2,60000,true config=android.net.NetworkConfig@be6f29
07-12 01:27:10.920 D/ConnectivityService( 466): naString=bluetooth,7,7,0,-1,true config=android.net.NetworkConfig@9aa02ae
07-12 01:27:10.921 D/ConnectivityService( 466): naString=ethernet,9,9,9,-1,true config=android.net.NetworkConfig@ac8584f
07-12 01:27:10.921 D/ConnectivityService( 466): naString=pppoe,15,15,5,-1,true config=android.net.NetworkConfig@e4fdbdc
07-12 01:27:10.921 D/ConnectivityService( 466): mNetworksDefined=13
07-12 01:27:10.921 E/ConnectivityService( 466): Ignoring protectedNetwork 14
07-12 01:27:10.929 I/SystemServer( 466): StartNsdService
07-12 01:27:10.937 I/SystemServer( 466): StartUpdateLockService
07-12 01:27:10.938 I/SystemServiceManager( 466): Starting com.android.server.RecoverySystemService
07-12 01:27:10.939 I/SystemServiceManager( 466): Starting com.android.server.notification.NotificationManagerService
07-12 01:27:10.956 D/ConditionProviders.SCP( 466): new ScheduleConditionProvider()
07-12 01:27:10.959 D/ZenLog ( 466): config: readXml,ZenModeConfig[user=0,allowCalls=true,allowRepeatCallers=false,allowMessages=false,allowCallsFrom=contacts,allowMessagesFrom=contacts,allowReminders=true,allowEvents=true,allowWhenScreenOff=true,allowWhenScreenOn=true,automaticRules={b3f935479ff748d7b51d23186c5386de=ZenRule[enabled=false,snoozing=false,name=Weekend,zenMode=ZEN_MODE_ALARMS,conditionId=condition://android/schedule?days=6.7&start=23.30&end=10.0&exitAtAlarm=false,condition=Condition[id=condition://android/schedule?days=6.7&start=23.30&end=10.0&exitAtAlarm=false,summary=…,line1=…,line2=…,icon=0,state=STATE_FALSE,flags=2],component=ComponentInfo{android/com.android.server.notification.ScheduleConditionProvider},id=b3f935479ff748d7b51d23186c5386de,creationTime=1562847837753,enabler=null], be6521301839475bb0e0997eabce9ee3=ZenRule[enabled=false,snoozing=false,name=Event,zenMode=ZEN_MODE_ALARMS,conditionId=condition://android/event?userId=-10000&calendar=&reply=1,condition=Condition[id=condition://android/event?userId=-10000&calendar=&reply=1,summary=…,line1=…,line2=…,icon=0,state=STATE_FALSE,flags=2],component=ComponentInfo{android/com.android.server.notification.EventConditionProvider},id=be6521301839475bb0e0997eabce9ee3,creationTime=1562847837753,enabler=null], a92cb1ba6ce84048bd14a5b316216de7=ZenRule[enabled=false,snoozing=false,name=Weeknight,zenMode=ZEN_MODE_ALARMS,conditionId=condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false,condition=Condition[id=condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false,summary=…,line1=…,line2=…,icon=0,state=STATE_TRUE,flags=2],component=ComponentInfo{android/com.android.server.notification.ScheduleConditionProvider},id=a92cb1ba6ce84048bd14a5b316216de7,creationTime=1562847837752,enabler=null]},manualRule=null],Diff[automaticRule[c455b769744145469c1c88f304d3a667]:delete,automaticRule[b3f935479ff748d7b51d23186c5386de]:insert,automaticRule[9610df33c5b84bdc9598cc287fc660f1]:delete,automaticRule[be6521301839475bb0e0997eabce9ee3]:insert,automaticRule[8d316e2b8e394f8baa4f6f3a275343cb]:delete,automaticRule[a92cb1ba6ce84048bd14a5b316216de7]:insert]
07-12 01:27:10.966 D/ZenLog ( 466): set_zen_mode: off,init
07-12 01:27:10.968 I/SystemServiceManager( 466): Starting com.android.server.storage.DeviceStorageMonitorService
07-12 01:27:10.971 I/SystemServer( 466): StartLocationManagerService
07-12 01:27:10.975 I/SystemServer( 466): StartCountryDetectorService
07-12 01:27:10.977 I/SystemServer( 466): StartSearchManagerService
07-12 01:27:10.977 I/SystemServiceManager( 466): Starting com.android.server.search.SearchManagerService$Lifecycle
07-12 01:27:10.979 I/SystemServiceManager( 466): Starting com.android.server.DropBoxManagerService
07-12 01:27:10.980 I/SystemServer( 466): StartWallpaperManagerService
07-12 01:27:10.980 I/SystemServiceManager( 466): Starting com.android.server.wallpaper.WallpaperManagerService$Lifecycle
07-12 01:27:10.984 I/SystemServer( 466): StartAudioService
07-12 01:27:10.984 I/SystemServiceManager( 466): Starting com.android.server.audio.AudioService$Lifecycle
07-12 01:27:10.991 D/PermissionCache( 232): checking android.permission.MODIFY_AUDIO_SETTINGS for uid=1000 => granted (388 us)
07-12 01:27:10.997 W/AudioFlinger( 232): no wake lock to update, system not ready yet
07-12 01:27:11.008 D/AudioHardwareTiny( 232): adev_set_parameters: kvpairs = orientation=undefined
07-12 01:27:11.010 I/SystemServiceManager( 466): Starting com.android.server.DockObserver
07-12 01:27:11.010 W/DockObserver( 466): This kernel does not have dock station support
07-12 01:27:11.011 I/SystemServer( 466): StartWiredAccessoryManager
07-12 01:27:11.011 W/WiredAccessoryManager( 466): This kernel does not have usb audio support
07-12 01:27:11.012 W/WiredAccessoryManager( 466): This kernel does not have dp audio support
07-12 01:27:11.012 I/SystemServiceManager( 466): Starting com.android.server.usb.UsbService$Lifecycle
07-12 01:27:11.018 E/UsbDeviceManager( 466): failed to write to /sys/class/android_usb/android0/f_rndis/ethaddr
07-12 01:27:11.023 I/SystemServer( 466): StartSerialService
07-12 01:27:11.025 I/SystemServiceManager( 466): Starting com.android.server.twilight.TwilightService
07-12 01:27:11.025 I/SystemServiceManager( 466): Starting com.android.server.job.JobSchedulerService
07-12 01:27:11.031 I/SystemServiceManager( 466): Starting com.android.server.soundtrigger.SoundTriggerService
07-12 01:27:11.032 I/SystemServiceManager( 466): Starting com.android.server.backup.BackupManagerService$Lifecycle
07-12 01:27:11.034 I/SystemServiceManager( 466): Starting com.android.server.appwidget.AppWidgetService
07-12 01:27:11.041 I/SystemServiceManager( 466): Starting com.android.server.voiceinteraction.VoiceInteractionManagerService
07-12 01:27:11.043 I/SystemServer( 466): Gesture Launcher Service
07-12 01:27:11.043 I/SystemServiceManager( 466): Starting com.android.server.GestureLauncherService
07-12 01:27:11.043 I/SystemServiceManager( 466): Starting com.android.server.SensorNotificationService
07-12 01:27:11.043 I/SystemServiceManager( 466): Starting com.android.server.ContextHubSystemService
07-12 01:27:11.045 I/SystemServer( 466): StartDiskStatsService
07-12 01:27:11.046 I/SystemServer( 466): StartSamplingProfilerService
07-12 01:27:11.049 I/SystemServer( 466): StartNetworkTimeUpdateService
07-12 01:27:11.050 I/SystemServer( 466): StartCommonTimeManagementService
07-12 01:27:11.051 I/SystemServer( 466): CertBlacklister
07-12 01:27:11.052 I/SystemServiceManager( 466): Starting com.android.server.emergency.EmergencyAffordanceService
07-12 01:27:11.052 I/SystemServiceManager( 466): Starting com.android.server.dreams.DreamManagerService
07-12 01:27:11.054 I/SystemServer( 466): StartAssetAtlasService
07-12 01:27:11.056 I/SystemServiceManager( 466): Starting com.android.server.print.PrintManagerService
07-12 01:27:11.056 I/chatty ( 466): uid=1000 system_server expire 5 lines
07-12 01:27:11.061 I/SystemServiceManager( 466): Starting com.android.server.restrictions.RestrictionsManagerService
07-12 01:27:11.064 I/SystemServiceManager( 466): Starting com.android.server.media.MediaSessionService
07-12 01:27:11.071 I/SystemServer( 466): StartMediaRouterService
07-12 01:27:11.076 I/SystemServiceManager( 466): Starting com.android.server.trust.TrustManagerService
07-12 01:27:11.091 E/SELinux ( 219): avc: denied { add } for service=drm_device_management pid=466 uid=1000 scontext=u:r:system_server:s0 tcontext=u:object_r:default_android_service:s0 tclass=service_manager permissive=1
07-12 01:27:11.091 I/SystemServer( 466): StartBackgroundDexOptService
07-12 01:27:11.092 I/SystemServiceManager( 466): Starting com.android.server.pm.ShortcutService$Lifecycle
07-12 01:27:11.097 I/SystemServiceManager( 466): Starting com.android.server.pm.LauncherAppsService
07-12 01:27:11.099 I/SystemServiceManager( 466): Starting com.android.server.media.projection.MediaProjectionManagerService
07-12 01:27:11.107 I/SystemServiceManager( 466): Starting com.android.server.MmsServiceBroker
07-12 01:27:11.138 E/LockSettingsStorage( 466): Cannot read file java.io.FileNotFoundException: /data/system/gatekeeper.password.key: open failed: ENOENT (No such file or directory)
07-12 01:27:11.138 E/LockSettingsStorage( 466): Cannot read file java.io.FileNotFoundException: /data/system/password.key: open failed: ENOENT (No such file or directory)
07-12 01:27:11.138 E/LockSettingsStorage( 466): Cannot read file java.io.FileNotFoundException: /data/system/gatekeeper.pattern.key: open failed: ENOENT (No such file or directory)
07-12 01:27:11.139 E/LockSettingsStorage( 466): Cannot read file java.io.FileNotFoundException: /data/system/gatekeeper.gesture.key: open failed: ENOENT (No such file or directory)
07-12 01:27:11.139 E/LockSettingsStorage( 466): Cannot read file java.io.FileNotFoundException: /data/system/gesture.key: open failed: ENOENT (No such file or directory)
07-12 01:27:11.139 I/SystemServiceManager( 466): Starting phase 480
07-12 01:27:11.143 I/DevicePolicyManagerService( 466): Set ro.device_owner property to false
07-12 01:27:11.145 I/SystemServiceManager( 466): Starting phase 500
07-12 01:27:11.151 D/ConnectivityService( 466): listenForNetwork for uid/pid:1000/466 NetworkRequest [ LISTEN id=3, ]
07-12 01:27:11.153 I/WifiService( 466): WifiService starting up with Wi-Fi enabled
07-12 01:27:11.155 D/WifiService( 466): setWifiEnabled: true pid=466, uid=1000
07-12 01:27:11.156 I/chatty ( 466): uid=1000(system) WifiService expire 2 lines
07-12 01:27:11.162 D/ConnectivityService( 466): Got NetworkFactory Messenger for Ethernet
07-12 01:27:11.162 D/ConnectivityService( 466): NetworkFactory connected
07-12 01:27:11.162 I/chatty ( 466): uid=1000(system) EthernetService expire 1 line
07-12 01:27:11.165 D/CommandListener( 241): Setting iface cfg
07-12 01:27:11.165 D/CommandListener( 241): Trying to bring up eth0
07-12 01:27:11.179 D/ZenLog ( 466): config: cleanUpZenRules,ZenModeConfig[user=0,allowCalls=true,allowRepeatCallers=false,allowMessages=false,allowCallsFrom=contacts,allowMessagesFrom=contacts,allowReminders=true,allowEvents=true,allowWhenScreenOff=true,allowWhenScreenOn=true,automaticRules={b3f935479ff748d7b51d23186c5386de=ZenRule[enabled=false,snoozing=false,name=Weekend,zenMode=ZEN_MODE_ALARMS,conditionId=condition://android/schedule?days=6.7&start=23.30&end=10.0&exitAtAlarm=false,condition=Condition[id=condition://android/schedule?days=6.7&start=23.30&end=10.0&exitAtAlarm=false,summary=…,line1=…,line2=…,icon=0,state=STATE_FALSE,flags=2],component=ComponentInfo{android/com.android.server.notification.ScheduleConditionProvider},id=b3f935479ff748d7b51d23186c5386de,creationTime=1562847837753,enabler=null], be6521301839475bb0e0997eabce9ee3=ZenRule[enabled=false,snoozing=false,name=Event,zenMode=ZEN_MODE_ALARMS,conditionId=condition://android/event?userId=-10000&calendar=&reply=1,condition=Condition[id=condition://android/event?userId=-10000&calendar=&reply=1,summary=…,line1=…,line2=…,icon=0,state=STATE_FALSE,flags=2],component=ComponentInfo{android/com.android.server.notification.EventConditionProvider},id=be6521301839475bb0e0997eabce9ee3,creationTime=1562847837753,enabler=null], a92cb1ba6ce84048bd14a5b316216de7=ZenRule[enabled=false,snoozing=false,name=Weeknight,zenMode=ZEN_MODE_ALARMS,conditionId=condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false,condition=Condition[id=condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false,summary=…,line1=…,line2=…,icon=0,state=STATE_TRUE,flags=2],component=ComponentInfo{android/com.android.server.notification.ScheduleConditionProvider},id=a92cb1ba6ce84048bd14a5b316216de7,creationTime=1562847837752,enabler=null]},manualRule=null],Diff
07-12 01:27:11.180 D/ZenLog ( 466): set_zen_mode: off,onSystemReady
07-12 01:27:11.181 D/PermissionCache( 232): checking android.permission.CAPTURE_AUDIO_HOTWORD for uid=1000 => granted (108 us)
07-12 01:27:11.181 W/SoundTriggerHelper( 466): listModules status=0, # of modules=0
07-12 01:27:11.198 V/UserManagerService( 466): Found /data/user_de/0 with serial number 0
07-12 01:27:11.198 V/UserManagerService( 466): Found /data/user/0 with serial number 0
07-12 01:27:11.198 V/UserManagerService( 466): Found /data/system_de/0 with serial number 0
07-12 01:27:11.198 V/UserManagerService( 466): Found /data/system_ce/0 with serial number 0
07-12 01:27:11.198 W/KeyguardServiceDelegate( 466): onScreenTurningOn(): no keyguard service!
07-12 01:27:11.199 D/ActivityManager( 466): OK, system ready!
07-12 01:27:11.199 I/ActivityManager( 466): System now ready
07-12 01:27:11.202 I/SystemServer( 466): Making services ready
07-12 01:27:11.202 I/SystemServiceManager( 466): Starting phase 550
07-12 01:27:11.203 W/VoiceInteractionManagerService( 466): no available voice interaction services found for user 0
07-12 01:27:11.203 W/VoiceInteractionManagerService( 466): no available voice recognition services found for user 0
07-12 01:27:11.216 I/art ( 231): Starting a blocking GC HeapTrim
07-12 01:27:11.226 I/ActivityManager( 466): Start proc 618:com.android.phone/1001 for added application com.android.phone
07-12 01:27:11.237 I/ActivityManager( 466): Start proc 623:com.android.systemui/u0a19 for added application com.android.systemui
07-12 01:27:11.238 I/ActivityManager( 466): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000100 cmp=com.android.settings/.FallbackHome} from uid 0 on display 0
07-12 01:27:11.250 I/ActivityManager( 466): Loaded persisted task ids for user 0
07-12 01:27:11.264 I/ActivityManager( 466): Start proc 646:com.android.settings/1000 for activity com.android.settings/.FallbackHome
07-12 01:27:11.265 E/Build ( 466): Mismatched fingerprints; system reported Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys but vendor reported Android/rk3288/rk3288:7.1.2/NHG47K/waysio07111949:userdebug/test-keys
07-12 01:27:11.265 E/ActivityManager( 466): Build fingerprint is not consistent, warning user
07-12 01:27:11.266 I/SystemServer( 466): Enabled StrictMode for system server main thread.
07-12 01:27:11.271 D/ConditionProviders.SCP( 466): onConnected
07-12 01:27:11.272 D/ZenLog ( 466): set_zen_mode: off,readXml
07-12 01:27:11.272 D/ConditionProviders( 466): Subscribing to condition://android/schedule?days=6.7&start=23.30&end=10.0&exitAtAlarm=false with ComponentInfo{android/com.android.server.notification.ScheduleConditionProvider}
07-12 01:27:11.272 D/ZenLog ( 466): subscribe: condition://android/schedule?days=6.7&start=23.30&end=10.0&exitAtAlarm=false,ok
07-12 01:27:11.272 D/ConditionProviders( 466): Subscribing to condition://android/event?userId=-10000&calendar=&reply=1 with ComponentInfo{android/com.android.server.notification.EventConditionProvider}
07-12 01:27:11.273 D/ZenLog ( 466): subscribe: condition://android/event?userId=-10000&calendar=&reply=1,ok
07-12 01:27:11.273 D/ConditionProviders( 466): Subscribing to condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false with ComponentInfo{android/com.android.server.notification.ScheduleConditionProvider}
07-12 01:27:11.273 D/ZenLog ( 466): subscribe: condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false,ok
07-12 01:27:11.281 D/BluetoothManagerService( 466): Bluetooth boot completed
07-12 01:27:11.282 E/InputMethodManagerService( 466): Ignoring updateSystemUiLocked due to an invalid token. uid:1000 token:null
07-12 01:27:11.297 I/chatty ( 466): uid=1000(system) WifiScanningSer expire 1 line
07-12 01:27:11.298 I/chatty ( 466): uid=1000(system) WifiRttService expire 1 line
07-12 01:27:11.298 D/ZenLog ( 466): set_zen_mode: off,cleanUpZenRules
07-12 01:27:11.302 W/System ( 618): ClassLoader referenced unknown path: /system/priv-app/TeleService/lib/arm
07-12 01:27:11.325 I/ActivityManager( 466): Start proc 669:com.android.inputmethod.latin/u0a39 for service com.android.inputmethod.latin/.LatinIME
07-12 01:27:11.325 V/InputMethodManagerService( 466): Adding window token: android.os.Binder@1113de
07-12 01:27:11.328 W/System ( 646): ClassLoader referenced unknown path: /system/priv-app/Settings/lib/arm
07-12 01:27:11.328 D/MountService( 466): Thinking about init, mSystemReady=true, mDaemonConnected=true
07-12 01:27:11.328 D/MountService( 466): Setting up emulation state, initlocked=false
07-12 01:27:11.328 D/CryptdConnector( 466): SND → {2 cryptfs unlock_user_key 0 0 ! !}
07-12 01:27:11.329 D/vold ( 205): e4crypt_unlock_user_key 0 serial=0 token_present=0
07-12 01:27:11.329 D/AudioHardwareTiny( 232): adev_set_parameters: kvpairs = A2dpSuspended=false
07-12 01:27:11.330 D/CryptdConnector( 466): RCV ← {200 2 Command succeeded}
07-12 01:27:11.330 D/MountService( 466): Thinking about reset, mSystemReady=true, mDaemonConnected=true
07-12 01:27:11.331 D/VoldConnector( 466): SND → {3 volume reset}
07-12 01:27:11.331 D/VoldConnector( 466): RCV ← {651 emulated 7}
07-12 01:27:11.331 D/UsbAlsaManager( 466): Adding ALSA device AlsaDevice: [card: 0, device: 0, type: 1]
07-12 01:27:11.331 D/VoldConnector( 466): RCV ← {659 emulated}
07-12 01:27:11.331 D/UsbAlsaManager( 466): Adding ALSA device AlsaDevice: [card: 0, device: 0, type: 2]
07-12 01:27:11.332 D/VoldConnector( 466): RCV ← {650 emulated 2 “” “”}
07-12 01:27:11.332 D/VoldConnector( 466): RCV ← {651 emulated 0}
07-12 01:27:11.332 I/chatty ( 466): uid=1000(system) ActivityManager expire 38 lines
07-12 01:27:11.332 D/VoldConnector( 466): RCV ← {200 3 Command succeeded}
07-12 01:27:11.333 D/VoldConnector( 466): SND → {4 volume user_added 0 0}
07-12 01:27:11.333 D/VoldConnector( 466): RCV ← {200 4 Command succeeded}
07-12 01:27:11.334 V/MountService( 466): Found primary storage at VolumeInfo{emulated}:
07-12 01:27:11.334 V/MountService( 466): type=EMULATED diskId=null partGuid=null mountFlags=0 mountUserId=-1
07-12 01:27:11.334 V/MountService( 466): state=UNMOUNTED
07-12 01:27:11.334 V/MountService( 466): fsType=null fsUuid=null fsLabel=null
07-12 01:27:11.334 V/MountService( 466): path=null internalPath=null
07-12 01:27:11.335 I/SystemServer( 466): WebViewFactory preparation
07-12 01:27:11.336 I/Binder:240_1( 240): type=1400 audit(0.0:11): avc: denied { search } for name=“466” dev=“proc” ino=11992 scontext=u:r:mediaserver:s0 tcontext=u:r:system_server:s0 tclass=dir permissive=1
07-12 01:27:11.336 I/Binder:240_1( 240): type=1400 audit(0.0:12): avc: denied { read } for name=“cmdline” dev=“proc” ino=12659 scontext=u:r:mediaserver:s0 tcontext=u:r:system_server:s0 tclass=file permissive=1
07-12 01:27:11.336 I/Binder:240_1( 240): type=1400 audit(0.0:13): avc: denied { open } for path=“/proc/466/cmdline” dev=“proc” ino=12659 scontext=u:r:mediaserver:s0 tcontext=u:r:system_server:s0 tclass=file permissive=1
07-12 01:27:11.337 D/BluetoothManagerService( 466): Trying to bind to profile: 1, while Bluetooth was disabled
07-12 01:27:11.340 I/MediaPlayerService( 240): processName cmdline:/proc/466/cmdline
07-12 01:27:11.340 D/VoldConnector( 466): SND → {5 volume mount emulated 3 -1}
07-12 01:27:11.343 V/vold ( 205): Waiting for FUSE to spin up…
07-12 01:27:11.343 D/VoldConnector( 466): RCV ← {651 emulated 1}
07-12 01:27:11.343 D/VoldConnector( 466): RCV ← {656 emulated /data/media}
07-12 01:27:11.343 D/VoldConnector( 466): RCV ← {655 emulated /storage/emulated}
07-12 01:27:11.344 I/AudioFlinger( 232): systemReady
07-12 01:27:11.357 I/ActivityManager( 466): Start proc 683:WebViewLoader-armeabi-v7a/1037 [android.webkit.WebViewFactory$RelroFileCreator] for
07-12 01:27:11.359 D/NetworkManagement( 466): enabling bandwidth control
07-12 01:27:11.375 D/NuPlayerDriver( 240): notifyListener_l(0xb0b07000), (1, 0, 0), loop setting(0, 0)
07-12 01:27:11.377 V/WebViewFactory( 683): RelroFileCreator (64bit = false), 32-bit lib: /system/app/webview/webview.apk!/lib/armeabi-v7a/libwebviewchromium.so, 64-bit lib:
07-12 01:27:11.391 I/chatty ( 466): uid=1000(system) Timer-0 expire 8 lines
07-12 01:27:11.393 V/vold ( 205): Waiting for FUSE to spin up…
07-12 01:27:11.397 D/NuPlayerDriver( 240): reset(0xb0b07000) at state 4
07-12 01:27:11.397 D/NuPlayerDriver( 240): notifyListener_l(0xb0b07000), (8, 0, 0), loop setting(0, 0)
07-12 01:27:11.397 D/NuPlayerDriver( 240): notifyResetComplete(0xb0b07000)
07-12 01:27:11.398 D/NuPlayerDriver( 240): reset(0xb0b07000) at state 0
07-12 01:27:11.402 I/MediaPlayerService( 240): processName cmdline:/proc/466/cmdline
07-12 01:27:11.408 W/sdcard ( 678): Device explicitly enabled sdcardfs
07-12 01:27:11.417 W/System ( 618): ClassLoader referenced unknown path: /system/priv-app/TelephonyProvider/lib/arm
07-12 01:27:11.418 D/ApplicationLoaders( 618): ignored Vulkan layer search path /system/priv-app/TelephonyProvider/lib/arm:/system/lib:/vendor/lib for namespace 0xb0574090
07-12 01:27:11.421 D/NuPlayerDriver( 240): notifyListener_l(0xb0b07180), (1, 0, 0), loop setting(0, 0)
07-12 01:27:11.423 I/chatty ( 466): uid=1000(system) SoundPoolThread expire 6 lines
07-12 01:27:11.423 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:11.426 D/NuPlayerDriver( 240): start(0xb0b07180), state is 4, eos is 0
07-12 01:27:11.426 I/GenericSource( 240): start
07-12 01:27:11.435 I/MediaCodec( 240): callingProcessName:system_server
07-12 01:27:11.444 D/VoldConnector( 466): RCV ← {651 emulated 2}
07-12 01:27:11.444 D/VoldConnector( 466): RCV ← {200 5 Command succeeded}
07-12 01:27:11.462 I/libstagefrighthw( 240): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.avc
07-12 01:27:11.462 I/libstagefrighthw( 240): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.m4v
07-12 01:27:11.462 I/libstagefrighthw( 240): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.h263
07-12 01:27:11.462 I/libstagefrighthw( 240): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.flv1
07-12 01:27:11.462 I/libstagefrighthw( 240): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.m2v
07-12 01:27:11.462 I/libstagefrighthw( 240): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.rv
07-12 01:27:11.462 I/libstagefrighthw( 240): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.vp6
07-12 01:27:11.462 I/libstagefrighthw( 240): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.vp8
07-12 01:27:11.462 I/libstagefrighthw( 240): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.vp9
07-12 01:27:11.462 I/libstagefrighthw( 240): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.vc1
07-12 01:27:11.462 I/libstagefrighthw( 240): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.wmv3
07-12 01:27:11.462 I/libstagefrighthw( 240): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.hevc
07-12 01:27:11.462 I/libstagefrighthw( 240): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.mjpeg
07-12 01:27:11.462 I/libstagefrighthw( 240): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.avc.secure
07-12 01:27:11.462 I/libstagefrighthw( 240): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.hevc.securevideo_decoder.hevc
07-12 01:27:11.462 I/libstagefrighthw( 240): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.m2v.secure
07-12 01:27:11.462 I/libstagefrighthw( 240): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.m4v.secure
07-12 01:27:11.462 I/libstagefrighthw( 240): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.vp8.secure
07-12 01:27:11.462 I/libstagefrighthw( 240): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.vp9.secure
07-12 01:27:11.462 I/libstagefrighthw( 240): OMX IL core libOMX_Core.so: declares component OMX.rk.video_encoder.avc
07-12 01:27:11.462 I/libstagefrighthw( 240): OMX IL core libOMX_Core.so: declares component OMX.rk.video_encoder.hevc
07-12 01:27:11.463 I/libstagefrighthw( 240): OMX IL core libOMX_Core.so: declares component OMX.rk.video_encoder.vp8video_en
07-12 01:27:11.463 I/libstagefrighthw( 240): OMX IL core libOMX_Core.so: contains 22 components
07-12 01:27:11.471 I/vpu_api ( 237): dlopen vpu lib success
07-12 01:27:11.472 I/libstagefrighthw( 237): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.avc
07-12 01:27:11.473 I/libstagefrighthw( 237): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.m4v
07-12 01:27:11.473 I/libstagefrighthw( 237): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.h263
07-12 01:27:11.473 I/libstagefrighthw( 237): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.flv1
07-12 01:27:11.473 I/libstagefrighthw( 237): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.m2v
07-12 01:27:11.473 I/libstagefrighthw( 237): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.rv
07-12 01:27:11.473 I/libstagefrighthw( 237): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.vp6
07-12 01:27:11.473 I/libstagefrighthw( 237): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.vp8
07-12 01:27:11.473 I/libstagefrighthw( 237): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.vp9
07-12 01:27:11.473 I/libstagefrighthw( 237): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.vc1
07-12 01:27:11.473 I/libstagefrighthw( 237): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.wmv3
07-12 01:27:11.473 I/libstagefrighthw( 237): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.hevc
07-12 01:27:11.473 I/libstagefrighthw( 237): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.mjpeg
07-12 01:27:11.473 I/libstagefrighthw( 237): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.avc.secure
07-12 01:27:11.473 I/libstagefrighthw( 237): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.hevc.securevideo_decoder.hevc
07-12 01:27:11.473 I/libstagefrighthw( 237): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.m2v.secure
07-12 01:27:11.473 I/libstagefrighthw( 237): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.m4v.secure
07-12 01:27:11.473 I/libstagefrighthw( 237): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.vp8.secure
07-12 01:27:11.473 I/libstagefrighthw( 237): OMX IL core libOMX_Core.so: declares component OMX.rk.video_decoder.vp9.secure
07-12 01:27:11.473 I/libstagefrighthw( 237): OMX IL core libOMX_Core.so: declares component OMX.rk.video_encoder.avc
07-12 01:27:11.473 I/libstagefrighthw( 237): OMX IL core libOMX_Core.so: declares component OMX.rk.video_encoder.hevc
07-12 01:27:11.473 I/libstagefrighthw( 237): OMX IL core libOMX_Core.so: declares component OMX.rk.video_encoder.vp8video_en
07-12 01:27:11.473 I/libstagefrighthw( 237): OMX IL core libOMX_Core.so: contains 22 components
07-12 01:27:11.474 I/OMXClient( 240): MuxOMX ctor
07-12 01:27:11.480 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:11.483 I/OMXClient( 240): MuxOMX ctor
07-12 01:27:11.484 I/OMXMaster( 237): makeComponentInstance(OMX.google.mp3.decoder) in mediacodec process
07-12 01:27:11.533 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:11.533 I/OMXClient( 240): MuxOMX ctor
07-12 01:27:11.534 I/OMXMaster( 237): makeComponentInstance(OMX.google.amrnb.decoder) in mediacodec process
07-12 01:27:11.542 V/SystemUIService( 623): Starting SystemUI services for user 0.
07-12 01:27:11.543 D/TelephonyProvider( 618): dbh.onOpen: ok, queried table=siminfo
07-12 01:27:11.544 D/TelephonyProvider( 618): dbh.onOpen: ok, queried table=carriers
07-12 01:27:11.548 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:11.548 I/OMXClient( 240): MuxOMX ctor
07-12 01:27:11.549 I/OMXMaster( 237): makeComponentInstance(OMX.google.amrwb.decoder) in mediacodec process
07-12 01:27:11.552 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:11.555 I/OMXClient( 240): MuxOMX ctor
07-12 01:27:11.555 I/OMXMaster( 237): makeComponentInstance(OMX.google.aac.decoder) in mediacodec process
07-12 01:27:11.572 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:11.573 I/OMXClient( 240): MuxOMX ctor
07-12 01:27:11.573 I/OMXMaster( 237): makeComponentInstance(OMX.google.g711.alaw.decoder) in mediacodec process
07-12 01:27:11.586 D/BluetoothManagerService( 466): Trying to bind to profile: 1, while Bluetooth was disabled
07-12 01:27:11.591 I/Telecom ( 466): SystemStateProvider: Registering car mode receiver: android.content.IntentFilter@cd2be05: TS.init@AAA
07-12 01:27:11.593 D/NetworkPolicy( 466): setRestrictBackgroundUL(): false
07-12 01:27:11.609 I/Telecom ( 466): Telecom: Non-call EVENT: AUDIO_ROUTE, Entering state QuiescentEarpieceRoute
07-12 01:27:11.612 I/Telecom ( 466): CallAudioModeStateMachine: Message received: null.: TS.init->CAMSM.pM_1@AAA_0
07-12 01:27:11.628 I/mali_so ( 646): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 876; [Func] : base_context_deal_with_version_affairs_rk_ext;
07-12 01:27:11.628 I/mali_so ( 646): arm_release_ver of this mali_so is ‘r18p0-01rel0’, rk_so_ver is ‘3@0’.
07-12 01:27:11.628 D/mali_so ( 646): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 881; [Func] : base_context_deal_with_version_affairs_rk_ext;
07-12 01:27:11.628 D/mali_so ( 646): current process is NOT sf, to bail out.
07-12 01:27:11.631 I/OpenGLRenderer( 646): Initialized EGL, version 1.4
07-12 01:27:11.631 D/OpenGLRenderer( 646): Swap behavior 1
07-12 01:27:11.640 D/mali_winsys( 646): EGLint new_window_surface(egl_winsys_display , void , EGLSurface, EGLConfig, egl_winsys_surface , egl_color_buffer_format , EGLBoolean) returns 0x3000
07-12 01:27:11.644 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:11.645 I/OMXClient( 240): MuxOMX ctor
07-12 01:27:11.646 I/OMXMaster( 237): makeComponentInstance(OMX.google.g711.mlaw.decoder) in mediacodec process
07-12 01:27:11.647 D/BluetoothManagerService( 466): Trying to bind to profile: 1, while Bluetooth was disabled
07-12 01:27:11.651 I/Telecom ( 466): Class: TelecomSystem.INSTANCE being set
07-12 01:27:11.652 W/ContextImpl( 466): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1357 android.content.ContextWrapper.startService:613 com.android.server.telecom.components.TelecomService.initializeTelecomSystem:186 com.android.server.telecom.components.TelecomService.onBind:62 android.app.ActivityThread.handleBindService:3224
07-12 01:27:11.654 D/ConditionProviders.SCP( 466): onSubscribe condition://android/schedule?days=6.7&start=23.30&end=10.0&exitAtAlarm=false
07-12 01:27:11.654 D/ConditionProviders.SCP( 466): setRegistered true
07-12 01:27:11.655 D/ConditionProviders.SCP( 466): notifyCondition condition://android/schedule?days=6.7&start=23.30&end=10.0&exitAtAlarm=false STATE_FALSE reason=!meetsSchedule
07-12 01:27:11.656 E/ActivityThread( 466): Failed to find provider info for call_log
07-12 01:27:11.676 I/LatinIME( 669): Hardware accelerated drawing: true
07-12 01:27:11.692 I/art ( 683): System.exit called, status: 0
07-12 01:27:11.692 I/AndroidRuntime( 683): VM exiting with result code 0, cleanup skipped.
07-12 01:27:11.704 V/MediaRouter( 623): Adding route: RouteInfo{ name=Tablet, description=null, status=null, category=RouteCategory{ name=null types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
07-12 01:27:11.713 V/MediaRouter( 623): Updating audio routes: AudioRoutesInfo{ type=SPEAKER }
07-12 01:27:11.727 V/MediaRouter( 623): Selecting route: RouteInfo{ name=Tablet, description=null, status=null, category=RouteCategory{ name=null types=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO groupable=false }, supportedTypes=ROUTE_TYPE_LIVE_AUDIO ROUTE_TYPE_LIVE_VIDEO , presentationDisplay=null }
07-12 01:27:11.753 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:11.755 I/OMXClient( 240): MuxOMX ctor
07-12 01:27:11.755 I/OMXMaster( 237): makeComponentInstance(OMX.google.vorbis.decoder) in mediacodec process
07-12 01:27:11.774 V/FingerprintManager( 623): FingerprintManagerService was null
07-12 01:27:11.777 D/ConditionProviders.SCP( 466): Scheduling evaluate for Fri Jul 12 10:00:00 GMT+00:00 2019 (1562925600000), in +8h32m48s345ms, now=Fri Jul 12 01:27:11 GMT+00:00 2019 (1562894831655)
07-12 01:27:11.777 D/ConditionProviders.SCP( 466): onSubscribe condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false
07-12 01:27:11.778 D/ConditionProviders.SCP( 466): notifyCondition condition://android/schedule?days=6.7&start=23.30&end=10.0&exitAtAlarm=false STATE_FALSE reason=!meetsSchedule
07-12 01:27:11.778 D/ConditionProviders.SCP( 466): notifyCondition condition://android/schedule?days=1.2.3.4.5&start=22.0&end=7.0&exitAtAlarm=false STATE_TRUE reason=meetsSchedule
07-12 01:27:11.778 D/ConditionProviders.SCP( 466): Scheduling evaluate for Fri Jul 12 07:00:00 GMT+00:00 2019 (1562914800000), in +5h32m48s222ms, now=Fri Jul 12 01:27:11 GMT+00:00 2019 (1562894831778)
07-12 01:27:11.779 I/SystemServiceManager( 466): Starting phase 600
07-12 01:27:11.779 W/FingerprintManager( 623): isFingerprintHardwareDetected(): Service not connected!
07-12 01:27:11.780 W/FingerprintManager( 623): addLockoutResetCallback(): Service not connected!
07-12 01:27:11.788 W/ContextImpl( 466): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1357 com.android.server.content.SyncManager$13.run:658 android.os.Handler.handleCallback:755 android.os.Handler.dispatchMessage:95 android.os.Looper.loop:154
07-12 01:27:11.791 D/SensorNotificationService( 466): Cannot obtain dynamic meta sensor, not supported.
07-12 01:27:11.792 I/Telecom ( 466): WiredHeadsetManager: ACTION_HEADSET_PLUG event, plugged in: false, : WHC.oADA@AAE
07-12 01:27:11.799 I/ActivityManager( 466): user 0 is still locked. Cannot load recents
07-12 01:27:11.805 I/SyncManager( 466): Got SyncJobService instance.
07-12 01:27:11.809 E/ActivityThread( 466): Failed to find provider info for com.android.calendar
07-12 01:27:11.810 E/ActivityThread( 466): Failed to find provider info for com.android.calendar
07-12 01:27:11.822 W/InputAttributes( 669): No editor info for this field. Bug?
07-12 01:27:11.828 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:11.829 I/OMXClient( 240): MuxOMX ctor
07-12 01:27:11.831 I/OMXMaster( 237): makeComponentInstance(OMX.google.opus.decoder) in mediacodec process
07-12 01:27:11.845 W/LocationManagerService( 466): no network location provider found
07-12 01:27:11.848 E/LocationManagerService( 466): no geocoder provider found
07-12 01:27:11.848 D/LocationManagerService( 466): FLP HAL not supported
07-12 01:27:11.850 D/LocationManagerService( 466): Unable to bind FLP Geofence proxy.
07-12 01:27:11.850 D/LocationManagerService( 466): Hardware Activity-Recognition not supported.
07-12 01:27:11.851 D/LocationManagerService( 466): Unable to bind ActivityRecognitionProxy.
07-12 01:27:11.860 I/MmsServiceBroker( 466): Delay connecting to MmsService until an API is called
07-12 01:27:11.873 I/ActivityManager( 466): Force stopping com.android.providers.media appid=10007 user=-1: vold reset
07-12 01:27:11.875 W/KeyguardServiceDelegate( 466): onScreenTurningOn(): no keyguard service!
07-12 01:27:11.889 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:11.889 I/OMXClient( 240): MuxOMX ctor
07-12 01:27:11.889 I/OMXMaster( 237): makeComponentInstance(OMX.google.raw.decoder) in mediacodec process
07-12 01:27:11.901 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:11.902 I/OMXClient( 240): MuxOMX ctor
07-12 01:27:11.902 I/OMXMaster( 237): makeComponentInstance(OMX.google.aac.encoder) in mediacodec process
07-12 01:27:11.903 I/chatty ( 466): uid=1000(system) android.bg expire 34 lines
07-12 01:27:11.907 D/ConnectivityService( 466): listenForNetwork for uid/pid:1000/466 NetworkRequest [ LISTEN id=4, [ Transports: CELLULAR|WIFI Capabilities: NOT_RESTRICTED&TRUSTED&NOT_VPN] ]
07-12 01:27:11.923 I/LatinIME:LogUtils( 669): Dictionary info: dictionary = userunigram.en_US ; version = 1562894831 ; date = ?
07-12 01:27:11.923 E/ActivityThread( 669): Failed to find provider info for user_dictionary
07-12 01:27:11.924 I/LatinIME:LogUtils( 669): Dictionary info: dictionary = UserHistoryDictionary.en_US ; version = 1562894831 ; date = ?
07-12 01:27:11.928 I/MediaCodec( 623): callingProcessName:com.android.systemui
07-12 01:27:11.932 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:11.934 I/OMXClient( 240): MuxOMX ctor
07-12 01:27:11.934 I/OMXMaster( 237): makeComponentInstance(OMX.google.amrnb.encoder) in mediacodec process
07-12 01:27:11.937 V/WiredAccessoryManager( 466): init()
07-12 01:27:11.953 V/UsbDeviceManager( 466): USB UEVENT: {USB_STATE=CONNECTED, SUBSYSTEM=android_usb, SEQNUM=1917, ACTION=change, DEVPATH=/devices/virtual/android_usb/android0}
07-12 01:27:11.958 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:11.958 I/OMXClient( 240): MuxOMX ctor
07-12 01:27:11.958 I/OMXMaster( 237): makeComponentInstance(OMX.google.amrwb.encoder) in mediacodec process
07-12 01:27:11.961 V/UsbDeviceManager( 466): USB UEVENT: {USB_STATE=CONFIGURED, SUBSYSTEM=android_usb, SEQNUM=1919, ACTION=change, DEVPATH=/devices/virtual/android_usb/android0}
07-12 01:27:11.976 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:11.976 I/OMXClient( 240): MuxOMX ctor
07-12 01:27:11.977 I/OMXMaster( 237): makeComponentInstance(OMX.google.flac.encoder) in mediacodec process
07-12 01:27:12.053 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:12.054 I/OMXClient( 240): MuxOMX ctor
07-12 01:27:12.054 I/OMXMaster( 237): makeComponentInstance(OMX.rk.video_decoder.avc) in mediacodec process
07-12 01:27:12.055 E/ROCKCHIP_LOG( 237): Rockchip_OSAL_SharedMemory_Open(395): 222ion_client_create Error: 8
07-12 01:27:12.055 E/ROCKCHIP_RM( 237): Rockchip_OMX_Check_Resource(282): pRockchipComponent->codecType 1, Line:282
07-12 01:27:12.057 E/ROCKCHIP_VIDEO_DECCONTROL( 237): Rkvpu_OMX_GetExtensionIndex(2033): OMX_IndexParamdescribeColorFormat get
07-12 01:27:12.058 E/OMXNodeInstance( 237): getExtensionIndex(ed000e:rk._decoder.avc, OMX.google.android.index.configureVideoTunnelMode) ERROR: BadParameter(0x80001005)
07-12 01:27:12.058 W/OMXNodeInstance( 237): [ed000e:rk._decoder.avc] component does not support metadata mode; using fallback
07-12 01:27:12.067 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:12.067 I/OMXClient( 240): MuxOMX ctor
07-12 01:27:12.067 I/OMXMaster( 237): makeComponentInstance(OMX.rk.video_decoder.m2v) in mediacodec process
07-12 01:27:12.068 E/ROCKCHIP_LOG( 237): Rockchip_OSAL_SharedMemory_Open(395): 222ion_client_create Error: 8
07-12 01:27:12.068 E/ROCKCHIP_RM( 237): Rockchip_OMX_Check_Resource(282): pRockchipComponent->codecType 1, Line:282
07-12 01:27:12.069 E/ROCKCHIP_VIDEO_DECCONTROL( 237): Rkvpu_OMX_GetExtensionIndex(2033): OMX_IndexParamdescribeColorFormat get
07-12 01:27:12.070 E/ROCKCHIP_VIDEO_DECCONTROL( 237): Rkvpu_OMX_GetExtensionIndex(2033): OMX_IndexParamdescribeColorFormat get
07-12 01:27:12.071 E/OMXNodeInstance( 237): getExtensionIndex(ed000f:rk._decoder.m2v, OMX.google.android.index.configureVideoTunnelMode) ERROR: BadParameter(0x80001005)
07-12 01:27:12.071 W/OMXNodeInstance( 237): [ed000f:rk._decoder.m2v] component does not support metadata mode; using fallback
07-12 01:27:12.078 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:12.079 I/OMXClient( 240): MuxOMX ctor
07-12 01:27:12.079 I/OMXMaster( 237): makeComponentInstance(OMX.rk.video_decoder.vp8) in mediacodec process
07-12 01:27:12.080 E/ROCKCHIP_LOG( 237): Rockchip_OSAL_SharedMemory_Open(395): 222ion_client_create Error: 8
07-12 01:27:12.080 E/ROCKCHIP_RM( 237): Rockchip_OMX_Check_Resource(282): pRockchipComponent->codecType 1, Line:282
07-12 01:27:12.081 E/ROCKCHIP_VIDEO_DECCONTROL( 237): Rkvpu_OMX_GetExtensionIndex(2033): OMX_IndexParamdescribeColorFormat get
07-12 01:27:12.082 E/ROCKCHIP_VIDEO_DECCONTROL( 237): Rkvpu_OMX_GetExtensionIndex(2033): OMX_IndexParamdescribeColorFormat get
07-12 01:27:12.083 E/OMXNodeInstance( 237): getExtensionIndex(ed0010:rk._decoder.vp8, OMX.google.android.index.configureVideoTunnelMode) ERROR: BadParameter(0x80001005)
07-12 01:27:12.083 W/OMXNodeInstance( 237): [ed0010:rk._decoder.vp8] component does not support metadata mode; using fallback
07-12 01:27:12.087 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:12.088 I/OMXClient( 240): MuxOMX ctor
07-12 01:27:12.088 I/OMXMaster( 237): makeComponentInstance(OMX.rk.video_decoder.h263) in mediacodec process
07-12 01:27:12.089 E/ROCKCHIP_LOG( 237): Rockchip_OSAL_SharedMemory_Open(395): 222ion_client_create Error: 8
07-12 01:27:12.089 E/ROCKCHIP_RM( 237): Rockchip_OMX_Check_Resource(282): pRockchipComponent->codecType 1, Line:282
07-12 01:27:12.091 E/ROCKCHIP_VIDEO_DECCONTROL( 237): Rkvpu_OMX_GetExtensionIndex(2033): OMX_IndexParamdescribeColorFormat get
07-12 01:27:12.092 E/ROCKCHIP_VIDEO_DECCONTROL( 237): Rkvpu_OMX_GetExtensionIndex(2033): OMX_IndexParamdescribeColorFormat get
07-12 01:27:12.093 E/OMXNodeInstance( 237): getExtensionIndex(ed0011:rk._decoder.h263, OMX.google.android.index.configureVideoTunnelMode) ERROR: BadParameter(0x80001005)
07-12 01:27:12.093 W/OMXNodeInstance( 237): [ed0011:rk._decoder.h263] component does not support metadata mode; using fallback
07-12 01:27:12.102 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:12.103 I/OMXClient( 240): MuxOMX ctor
07-12 01:27:12.103 I/OMXMaster( 237): makeComponentInstance(OMX.rk.video_decoder.m4v) in mediacodec process
07-12 01:27:12.104 E/ROCKCHIP_LOG( 237): Rockchip_OSAL_SharedMemory_Open(395): 222ion_client_create Error: 8
07-12 01:27:12.104 E/ROCKCHIP_RM( 237): Rockchip_OMX_Check_Resource(282): pRockchipComponent->codecType 1, Line:282
07-12 01:27:12.107 E/ROCKCHIP_VIDEO_DECCONTROL( 237): Rkvpu_OMX_GetExtensionIndex(2033): OMX_IndexParamdescribeColorFormat get
07-12 01:27:12.108 E/OMXNodeInstance( 237): getExtensionIndex(ed0012:rk._decoder.m4v, OMX.google.android.index.configureVideoTunnelMode) ERROR: BadParameter(0x80001005)
07-12 01:27:12.108 W/OMXNodeInstance( 237): [ed0012:rk._decoder.m4v] component does not support metadata mode; using fallback
07-12 01:27:12.112 W/SystemConfig( 618): No directory /system/etc/sysconfig, skipping
07-12 01:27:12.120 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:12.121 I/OMXClient( 240): MuxOMX ctor
07-12 01:27:12.121 I/OMXMaster( 237): makeComponentInstance(OMX.rk.video_decoder.hevc) in mediacodec process
07-12 01:27:12.122 E/ROCKCHIP_LOG( 237): Rockchip_OSAL_SharedMemory_Open(395): 222ion_client_create Error: 8
07-12 01:27:12.122 E/ROCKCHIP_RM( 237): Rockchip_OMX_Check_Resource(282): pRockchipComponent->codecType 1, Line:282
07-12 01:27:12.125 E/ROCKCHIP_VIDEO_DECCONTROL( 237): Rkvpu_OMX_GetExtensionIndex(2033): OMX_IndexParamdescribeColorFormat get
07-12 01:27:12.126 E/ROCKCHIP_VIDEO_DECCONTROL( 237): Rkvpu_OMX_GetExtensionIndex(2033): OMX_IndexParamdescribeColorFormat get
07-12 01:27:12.127 E/OMXNodeInstance( 237): getExtensionIndex(ed0013:rk._decoder.hevc, OMX.google.android.index.configureVideoTunnelMode) ERROR: BadParameter(0x80001005)
07-12 01:27:12.127 W/OMXNodeInstance( 237): [ed0013:rk._decoder.hevc] component does not support metadata mode; using fallback
07-12 01:27:12.129 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:12.129 I/OMXClient( 240): MuxOMX ctor
07-12 01:27:12.129 I/OMXMaster( 237): makeComponentInstance(OMX.rk.video_encoder.avc) in mediacodec process
07-12 01:27:12.131 E/ROCKCHIP_LOG( 237): Rockchip_OSAL_SharedMemory_Open(395): 222ion_client_create Error: 8
07-12 01:27:12.131 E/ROCKCHIP_RM( 237): Rockchip_OMX_Check_Resource(282): pRockchipComponent->codecType 2, Line:282
07-12 01:27:12.136 W/ACodec ( 240): [OMX.rk.video_encoder.avc] stopping checking profiles after 32: 8/1
07-12 01:27:12.137 W/ACodec ( 240): do not know color format 0x7f000789 = 2130708361
07-12 01:27:12.137 E/OMXNodeInstance( 237): getConfig(ed0014:rk._encoder.avc, ConfigAndroidIntraRefresh(0x6f60000a)) ERROR: UnsupportedIndex(0x8000101a)
07-12 01:27:12.166 I/vol.Events( 623): writeEvent collection_started
07-12 01:27:12.168 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:12.169 I/OMXClient( 240): MuxOMX ctor
07-12 01:27:12.169 I/LatinIME:LogUtils( 669): Dictionary info: dictionary = main:en ; version = 54 ; date = 1414726273
07-12 01:27:12.169 I/OMXMaster( 237): makeComponentInstance(OMX.google.h264.decoder) in mediacodec process
07-12 01:27:12.173 I/vol.Events( 623): writeEvent external_ringer_mode_changed normal
07-12 01:27:12.173 I/vol.Events( 623): writeEvent internal_ringer_mode_changed normal
07-12 01:27:12.175 I/chatty ( 466): uid=1000(system) notification-sq expire 1 line
07-12 01:27:12.175 D/PhoneSwitcherNetworkRequstListener( 618): Registering NetworkFactory
07-12 01:27:12.176 D/ConnectivityService( 466): Got NetworkFactory Messenger for PhoneSwitcherNetworkRequstListener
07-12 01:27:12.176 D/ConnectivityService( 466): NetworkFactory connected
07-12 01:27:12.183 D/ConnectivityService( 466): Got NetworkFactory Messenger for TelephonyNetworkFactory[0]
07-12 01:27:12.183 D/ConnectivityService( 466): NetworkFactory connected
07-12 01:27:12.202 W/art ( 623): Suspending all threads took: 7.958ms
07-12 01:27:12.206 I/art ( 623): Background sticky concurrent mark sweep GC freed 9572(1022KB) AllocSpace objects, 1(20KB) LOS objects, 30% free, 2MB/4MB, paused 8.443ms total 32.931ms
07-12 01:27:12.210 D/CarrierConfigLoader( 618): CarrierConfigLoader has started
07-12 01:27:12.213 D/BluetoothManagerService( 466): Trying to bind to profile: 1, while Bluetooth was disabled
07-12 01:27:12.222 E/ActivityThread( 618): Failed to find provider info for com.android.contacts
07-12 01:27:12.222 W/CallerInfoCache( 618): cursor is null
07-12 01:27:12.240 W/ACodec ( 240): [OMX.google.h264.decoder] stopping checking profiles after 32: 2/8000
07-12 01:27:12.241 E/OMXNodeInstance( 237): getExtensionIndex(ed0015:google.h264.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
07-12 01:27:12.241 W/OMXNodeInstance( 237): [ed0015:google.h264.decoder] component does not support metadata mode; using fallback
07-12 01:27:12.242 I/Telephony( 618): TtyManager: updateUiTtyMode -1 → 0
07-12 01:27:12.245 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:12.245 I/OMXClient( 240): MuxOMX ctor
07-12 01:27:12.245 I/OMXMaster( 237): makeComponentInstance(OMX.google.hevc.decoder) in mediacodec process
07-12 01:27:12.301 I/chatty ( 466): uid=1000(system) android.fg expire 5 lines
07-12 01:27:12.303 I/chatty ( 466): uid=1000(system) android.io expire 3 lines
07-12 01:27:12.309 E/OMXNodeInstance( 237): getExtensionIndex(ed0016:google.hevc.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
07-12 01:27:12.309 W/OMXNodeInstance( 237): [ed0016:google.hevc.decoder] component does not support metadata mode; using fallback
07-12 01:27:12.314 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:12.314 I/OMXClient( 240): MuxOMX ctor
07-12 01:27:12.315 I/OMXMaster( 237): makeComponentInstance(OMX.google.vp8.decoder) in mediacodec process
07-12 01:27:12.330 I/vol.Events( 623): writeEvent level_changed STREAM_ALARM 6
07-12 01:27:12.332 I/vol.Events( 623): writeEvent level_changed STREAM_BLUETOOTH_SCO 7
07-12 01:27:12.334 I/vol.Events( 623): writeEvent level_changed STREAM_MUSIC 11
07-12 01:27:12.338 I/vol.Events( 623): writeEvent level_changed STREAM_RING 5
07-12 01:27:12.339 I/vol.Events( 623): writeEvent level_changed STREAM_SYSTEM 5
07-12 01:27:12.344 I/vol.Events( 623): writeEvent level_changed STREAM_VOICE_CALL 4
07-12 01:27:12.357 D/WifiHW ( 241): uevent path:/sys/bus/sdio/devices/./uevent
07-12 01:27:12.357 D/WifiHW ( 241): uevent path:/sys/bus/sdio/devices/../uevent
07-12 01:27:12.357 D/WifiHW ( 241): uevent path:/sys/bus/sdio/devices/mmc2:0001:1/uevent
07-12 01:27:12.357 D/WifiHW ( 241): found device pid:vid : 02d0:4335
07-12 01:27:12.357 D/WifiHW ( 241): wifi detectd return ret:0
07-12 01:27:12.357 D/WifiHW ( 241): SDIO WIFI identify sucess
07-12 01:27:12.357 D/WifiHW ( 241): check_wifi_chip_type_string: AP6335
07-12 01:27:12.358 D/SoftapController( 241): Softap fwReload - Ok
07-12 01:27:12.360 D/CommandListener( 241): Setting iface cfg
07-12 01:27:12.360 D/CommandListener( 241): Trying to bring down wlan0
07-12 01:27:12.361 D/CommandListener( 241): Clearing all IP addresses on wlan0
07-12 01:27:12.364 E/OMXNodeInstance( 237): getExtensionIndex(ed0017:google.vp8.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
07-12 01:27:12.365 W/OMXNodeInstance( 237): [ed0017:google.vp8.decoder] component does not support metadata mode; using fallback
07-12 01:27:12.367 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:12.367 I/OMXClient( 240): MuxOMX ctor
07-12 01:27:12.367 I/OMXMaster( 237): makeComponentInstance(OMX.google.vp9.decoder) in mediacodec process
07-12 01:27:12.377 D/StorageNotification( 623): Notifying about private volume: VolumeInfo{private}:
07-12 01:27:12.377 D/StorageNotification( 623): type=PRIVATE diskId=null partGuid=null mountFlags=0 mountUserId=-1
07-12 01:27:12.377 D/StorageNotification( 623): state=MOUNTED
07-12 01:27:12.377 D/StorageNotification( 623): fsType=null fsUuid=null fsLabel=null
07-12 01:27:12.377 D/StorageNotification( 623): path=/data internalPath=null
07-12 01:27:12.381 D/PhoneSwitcherNetworkRequstListener( 618): got request NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 0
07-12 01:27:12.382 D/TelephonyDebugService( 618): TelephonyDebugService()
07-12 01:27:12.382 D/CarrierConfigLoader( 618): mHandler: 12 phoneId: 0
07-12 01:27:12.387 E/PhoneInterfaceManager( 618): [PhoneIntfMgr] getIccId: No UICC
07-12 01:27:12.397 W/Telecom ( 466): : registerPhoneAccount not allowed on non-voice capable device.: TSI.rPA@AAM
07-12 01:27:12.398 I/Telephony( 618): AccountEntry: Registered phoneAccount: [[ ] PhoneAccount: ComponentInfo{com.android.phone/com.android.services.telephony.TelephonyConnectionService}, [e0184adedf913b076626646d3f52c3b49c39ad6d], UserHandle{0} Capabilities: CallProvider MultiUser PlaceEmerg SimSub Audio Routes: BESW Schemes: tel voicemail Extras: null GroupId: [da39a3ee5e6b4b0d3255bfef95601890afd80709]] with handle: ComponentInfo{com.android.phone/com.android.services.telephony.TelephonyConnectionService}, [e0184adedf913b076626646d3f52c3b49c39ad6d], UserHandle{0}
07-12 01:27:12.401 I/Telephony( 618): PstnIncomingCallNotifier: Registering: Handler (com.android.internal.telephony.GsmCdmaPhone) {5dcaa0d}
07-12 01:27:12.406 I/chatty ( 466): uid=1000(system) android.ui expire 1 line
07-12 01:27:12.411 E/OMXNodeInstance( 237): getExtensionIndex(ed0018:google.vp9.decoder, OMX.google.android.index.configureVideoTunnelMode) ERROR: UnsupportedIndex(0x8000101a)
07-12 01:27:12.411 W/OMXNodeInstance( 237): [ed0018:google.vp9.decoder] component does not support metadata mode; using fallback
07-12 01:27:12.415 E/PhoneInterfaceManager( 618): [PhoneIntfMgr] getIccId: No UICC
07-12 01:27:12.416 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:12.416 I/OMXClient( 240): MuxOMX ctor
07-12 01:27:12.416 I/OMXMaster( 237): makeComponentInstance(OMX.google.h263.encoder) in mediacodec process
07-12 01:27:12.421 W/Telecom ( 466): : registerPhoneAccount not allowed on non-voice capable device.: TSI.rPA@AAY
07-12 01:27:12.454 I/StatusBarManagerService( 466): registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@42d8fb7
07-12 01:27:12.460 I/SoftMPEG4Encoder( 237): Construct SoftMPEG4Encoder
07-12 01:27:12.463 W/ACodec ( 240): do not know color format 0x7f000789 = 2130708361
07-12 01:27:12.466 E/OMXNodeInstance( 237): getConfig(ed0019:google.h263.encoder, ConfigAndroidIntraRefresh(0x6f60000a)) ERROR: Undefined(0x80001001)
07-12 01:27:12.468 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:12.468 I/OMXClient( 240): MuxOMX ctor
07-12 01:27:12.469 I/OMXMaster( 237): makeComponentInstance(OMX.google.mpeg4.encoder) in mediacodec process
07-12 01:27:12.513 I/SoftMPEG4Encoder( 237): Construct SoftMPEG4Encoder
07-12 01:27:12.515 W/ACodec ( 240): do not know color format 0x7f000789 = 2130708361
07-12 01:27:12.516 E/OMXNodeInstance( 237): getConfig(ed001a:google.mpeg4.encoder, ConfigAndroidIntraRefresh(0x6f60000a)) ERROR: Undefined(0x80001001)
07-12 01:27:12.520 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:12.520 I/OMXClient( 240): MuxOMX ctor
07-12 01:27:12.520 I/OMXMaster( 237): makeComponentInstance(OMX.google.vp8.encoder) in mediacodec process
07-12 01:27:12.566 W/ACodec ( 240): do not know color format 0x7f000789 = 2130708361
07-12 01:27:12.567 E/OMXNodeInstance( 237): getConfig(ed001b:google.vp8.encoder, ConfigAndroidIntraRefresh(0x6f60000a)) ERROR: Undefined(0x80001001)
07-12 01:27:12.573 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:12.574 I/OMXClient( 240): MuxOMX ctor
07-12 01:27:12.577 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:12.577 I/OMXClient( 240): MuxOMX ctor
07-12 01:27:12.578 W/MediaCodecList( 240): unable to open media codecs configuration xml file: /data/misc/media/media_codecs_profiling_results.xml
07-12 01:27:12.578 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:12.579 I/OMXClient( 240): MuxOMX ctor
07-12 01:27:12.579 I/ACodec ( 240): onAllocateComponent:6752 mSoftCodecPref:0 componentName:
07-12 01:27:12.579 I/ACodec ( 240): onAllocateComponent:6783 mSoftCodecPref:0 componentName:OMX.google.vorbis.decoder
07-12 01:27:12.579 I/OMXMaster( 237): makeComponentInstance(OMX.google.vorbis.decoder) in mediacodec process
07-12 01:27:12.580 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:12.581 I/chatty ( 466): uid=1000 system_server expire 3 lines
07-12 01:27:12.584 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:12.585 I/OMXClient( 623): MuxOMX ctor
07-12 01:27:12.585 I/ACodec ( 623): onAllocateComponent:6752 mSoftCodecPref:0 componentName:
07-12 01:27:12.586 I/ACodec ( 623): onAllocateComponent:6783 mSoftCodecPref:0 componentName:OMX.google.vorbis.decoder
07-12 01:27:12.624 I/OMXMaster( 237): makeComponentInstance(OMX.google.vorbis.decoder) in mediacodec process
07-12 01:27:12.625 I/OMXMaster( 237): makeComponentInstance(OMX.google.vorbis.decoder) in mediacodec process
07-12 01:27:12.629 E/OMXNodeInstance( 237): setConfig(ed001c:google.vorbis.decoder, ConfigPriority(0x6f800002)) ERROR: Undefined(0x80001001)
07-12 01:27:12.629 I/ACodec ( 240): codec does not support config priority (err -2147483648)
07-12 01:27:12.632 I/MediaCodec( 240): MediaCodec will operate in async mode
07-12 01:27:12.655 D/AudioTrack( 240): Client defaulted notificationFrames to 11264 for frameCount 22528
07-12 01:27:12.671 W/System ( 623): ClassLoader referenced unknown path:
07-12 01:27:12.673 D/ApplicationLoaders( 623): ignored Vulkan layer search path /system/app/Camera2/lib/arm:/system/app/Camera2/Camera2.apk!/lib/armeabi-v7a:/system/lib:/vendor/lib for namespace 0xb0574090
07-12 01:27:12.687 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:12.688 I/chatty ( 466): uid=1000 system_server expire 3 lines
07-12 01:27:12.691 I/OMXMaster( 237): makeComponentInstance(OMX.google.vorbis.decoder) in mediacodec process
07-12 01:27:12.699 I/MediaCodec( 623): callingProcessName:com.android.systemui
07-12 01:27:12.702 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:12.704 I/OMXClient( 623): MuxOMX ctor
07-12 01:27:12.704 I/ACodec ( 623): onAllocateComponent:6752 mSoftCodecPref:0 componentName:
07-12 01:27:12.705 I/ACodec ( 623): onAllocateComponent:6783 mSoftCodecPref:0 componentName:OMX.google.vorbis.decoder
07-12 01:27:12.706 I/OMXMaster( 237): makeComponentInstance(OMX.google.vorbis.decoder) in mediacodec process
07-12 01:27:12.738 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:12.740 I/chatty ( 466): uid=1000 system_server expire 3 lines
07-12 01:27:12.741 I/OMXMaster( 237): makeComponentInstance(OMX.google.vorbis.decoder) in mediacodec process
07-12 01:27:12.783 I/MediaCodec( 623): callingProcessName:com.android.systemui
07-12 01:27:12.783 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:12.784 I/OMXClient( 623): MuxOMX ctor
07-12 01:27:12.784 I/ACodec ( 623): onAllocateComponent:6752 mSoftCodecPref:0 componentName:
07-12 01:27:12.784 I/ACodec ( 623): onAllocateComponent:6783 mSoftCodecPref:0 componentName:OMX.google.vorbis.decoder
07-12 01:27:12.785 I/OMXMaster( 237): makeComponentInstance(OMX.google.vorbis.decoder) in mediacodec process
07-12 01:27:12.805 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:12.806 I/chatty ( 466): uid=1000 system_server expire 3 lines
07-12 01:27:12.808 I/OMXMaster( 237): makeComponentInstance(OMX.google.vorbis.decoder) in mediacodec process
07-12 01:27:12.824 D/LocalBluetoothProfileManager( 623): Adding local MAP profile
07-12 01:27:12.825 D/BluetoothMap( 623): Create BluetoothMap proxy object
07-12 01:27:12.826 E/BluetoothMap( 623): Could not bind to Bluetooth MAP Service with Intent { act=android.bluetooth.IBluetoothMap }
07-12 01:27:12.828 E/BluetoothPbap( 623): Could not bind to Bluetooth Pbap Service with Intent { act=android.bluetooth.IBluetoothPbap }
07-12 01:27:12.828 D/LocalBluetoothProfileManager( 623): LocalBluetoothProfileManager construction complete
07-12 01:27:12.836 D/ConnectivityService( 466): listenForNetwork for uid/pid:10019/623 NetworkRequest [ LISTEN id=5, [] ]
07-12 01:27:12.846 I/CameraManagerGlobal( 623): Connecting to camera service
07-12 01:27:12.852 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:12.853 I/chatty ( 466): uid=1000 system_server expire 3 lines
07-12 01:27:12.854 I/OMXMaster( 237): makeComponentInstance(OMX.google.vorbis.decoder) in mediacodec process
07-12 01:27:12.875 W/WindowManager( 466): Keyguard drawn timeout. Setting mKeyguardDrawComplete
07-12 01:27:12.883 I/AudioOut_D( 232): type=1400 audit(0.0:14): avc: denied { read } for name=“audioformat” dev=“sysfs” ino=17976 scontext=u:r:audioserver:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
07-12 01:27:12.883 I/AudioOut_D( 232): type=1400 audit(0.0:15): avc: denied { open } for path=“/sys/devices/platform/display-subsystem/drm/card0/card0-HDMI-A-1/audioformat” dev=“sysfs” ino=17976 scontext=u:r:audioserver:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
07-12 01:27:12.883 I/AudioOut_D( 232): type=1400 audit(0.0:16): avc: denied { getattr } for path=“/sys/devices/platform/display-subsystem/drm/card0/card0-HDMI-A-1/audioformat” dev=“sysfs” ino=17976 scontext=u:r:audioserver:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
07-12 01:27:12.887 E/AudioFlinger( 232): no wake lock to update, but system ready!
07-12 01:27:12.887 D/AudioHardwareTiny( 232): start_output_stream
07-12 01:27:12.889 D/NuPlayerDriver( 240): notifyListener_l(0xb0b07180), (6, 0, 0), loop setting(0, 0)
07-12 01:27:12.889 D/alsa_route( 232): route_info->sound_card 0, route_info->devices 0
07-12 01:27:12.890 D/alsa_route( 232): route_set_controls() set route 0
07-12 01:27:12.910 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:12.911 I/chatty ( 466): uid=1000 system_server expire 3 lines
07-12 01:27:12.913 I/OMXMaster( 237): makeComponentInstance(OMX.google.vorbis.decoder) in mediacodec process
07-12 01:27:12.947 E/ActivityThread( 623): Failed to find provider info for com.android.contacts
07-12 01:27:12.951 D/OpenGLRenderer( 623): profile bars disabled
07-12 01:27:12.951 D/OpenGLRenderer( 623): ambientRatio = 1.50
07-12 01:27:12.956 D/PhoneStatusBar( 623): disable: < EXPAND icons alerts system_info BACK HOME RECENT clock SEARCH quick_settings >
07-12 01:27:12.997 D/PhoneStatusBar( 623): heads up is enabled
07-12 01:27:13.033 W/KeyguardUpdateMonitor( 623): invalid subId in handleSimStateChange()
07-12 01:27:13.035 W/KeyguardUpdateMonitor( 623): invalid subId in handleServiceStateChange()
07-12 01:27:13.042 I/chatty ( 466): uid=1000(system) Binder:466_4 expire 3 lines
07-12 01:27:13.045 W/FingerprintManager( 623): isFingerprintHardwareDetected(): Service not connected!
07-12 01:27:13.052 D/ViewRootImplStatusBar: changeCanvasOpacity: opaque=true
07-12 01:27:13.067 D/AudioHardwareTiny( 232): out_set_parameters: kvpairs = routing=2
07-12 01:27:13.090 D/AudioHardwareTiny( 232): out_set_parameters: kvpairs = routing=2
07-12 01:27:13.094 I/SystemServiceManager( 466): Starting phase 1000
07-12 01:27:13.107 I/ActivityManager( 466): Start proc 952:android.ext.services/u0a8 for on-hold
07-12 01:27:13.108 D/ActivityManager( 466): Finishing user boot 0
07-12 01:27:13.113 D/CryptdConnector( 466): SND → {3 cryptfs prepare_user_storage ! 0 0 2}
07-12 01:27:13.114 D/vold ( 205): e4crypt_prepare_user_storage for volume null, user 0, serial 0, flags 2
07-12 01:27:13.114 D/vold ( 205): Preparing: /data/system_ce/0
07-12 01:27:13.114 D/vold ( 205): Preparing: /data/misc_ce/0
07-12 01:27:13.114 D/vold ( 205): Preparing: /data/media/0
07-12 01:27:13.115 D/vold ( 205): Preparing: /data/data
07-12 01:27:13.115 D/CryptdConnector( 466): RCV ← {200 3 Command succeeded}
07-12 01:27:13.115 V/UserManagerService( 466): Found /data/user/0 with serial number 0
07-12 01:27:13.116 V/UserManagerService( 466): Found /data/system_ce/0 with serial number 0
07-12 01:27:13.116 V/PackageManager( 466): reconcileAppsData for null u0 0x2
07-12 01:27:13.121 D/skia ( 623): JPEG Decode 109
07-12 01:27:13.123 D/AudioHardwareTiny( 232): out_set_parameters: kvpairs = routing=2
07-12 01:27:13.128 I/bootstat( 957): Service started: /system/bin/bootstat --record_boot_complete
07-12 01:27:13.129 I/bootstat( 957): Logging histogram: bootstat_mtime_matches_content 1
07-12 01:27:13.132 I/bootstat( 957): Logging histogram: bootstat_mtime_matches_content 1
07-12 01:27:13.132 E/bootstat( 957): Failed to read /data/misc/bootstat/post_decrypt_time_elapsed: No such file or directory
07-12 01:27:13.132 E/bootstat( 957): Failed to parse boot time record: /data/misc/bootstat/post_decrypt_time_elapsed
07-12 01:27:13.145 I/bootstat( 966): Service started: /system/bin/bootstat --record_boot_reason
07-12 01:27:13.145 I/bootstat( 966): Unknown boot reason:
07-12 01:27:13.146 D/AudioHardwareTiny( 232): out_set_parameters: kvpairs = routing=2
07-12 01:27:13.160 I/bootstat( 970): Service started: /system/bin/bootstat --record_time_since_factory_reset
07-12 01:27:13.160 I/bootstat( 970): Logging histogram: factory_reset_current_time 1562894833
07-12 01:27:13.162 I/bootstat( 970): Logging histogram: bootstat_mtime_matches_content 1
07-12 01:27:13.162 I/bootstat( 970): Logging histogram: factory_reset_record_value 1562847841
07-12 01:27:13.174 I/bootstat( 971): Service started: /system/bin/bootstat -l
07-12 01:27:13.174 I/bootstat( 971): Logging histogram: bootstat_mtime_matches_content 1
07-12 01:27:13.175 I/bootstat( 971): Logging histogram: bootstat_mtime_matches_content 1
07-12 01:27:13.176 I/bootstat( 971): Logging histogram: bootstat_mtime_matches_content 1
07-12 01:27:13.176 I/bootstat( 971): Logging histogram: last_boot_time_utc 1562894833
07-12 01:27:13.176 I/bootstat( 971): Logging histogram: build_date 1562730393
07-12 01:27:13.176 I/bootstat( 971): Logging histogram: ota_boot_complete_no_encryption 94
07-12 01:27:13.176 I/bootstat( 971): Logging histogram: ota_boot_complete 94
07-12 01:27:13.176 I/bootstat( 971): Logging histogram: boot_reason 1
07-12 01:27:13.176 I/bootstat( 971): Logging histogram: factory_reset_current_time 1562894833
07-12 01:27:13.176 I/bootstat( 971): Logging histogram: factory_reset 1562847841
07-12 01:27:13.176 I/bootstat( 971): Logging histogram: time_since_last_boot 389
07-12 01:27:13.176 I/bootstat( 971): Logging histogram: boot_complete_no_encryption 10
07-12 01:27:13.176 I/bootstat( 971): Logging histogram: boot_complete 10
07-12 01:27:13.176 I/bootstat( 971): Logging histogram: factory_reset_record_value 1562847841
07-12 01:27:13.176 I/bootstat( 971): Logging histogram: time_since_factory_reset 46992
07-12 01:27:13.332 V/PackageManager( 466): reconcileAppsData finished 85 packages
07-12 01:27:13.333 D/BluetoothManagerService( 466): User 0 unlocked
07-12 01:27:13.333 D/MountService( 466): onUnlockUser 0
07-12 01:27:13.333 D/VoldConnector( 466): SND → {6 volume user_started 0}
07-12 01:27:13.334 D/vold ( 205): Linking /storage/emulated/0 to /mnt/user/0/primary
07-12 01:27:13.334 D/VoldConnector( 466): RCV ← {200 6 Command succeeded}
07-12 01:27:13.334 I/chatty ( 466): uid=1000(system) Binder:466_5 expire 1 line
07-12 01:27:13.335 D/BluetoothManagerService( 466): MESSAGE_USER_UNLOCKED
07-12 01:27:13.336 D/MountService( 466): Volume emulated broadcasting mounted to UserHandle{0}
07-12 01:27:13.347 I/ActivityManager( 466): Start proc 977:com.android.deskclock/u0a31 for broadcast com.android.deskclock/.AlarmInitReceiver
07-12 01:27:13.350 I/chatty ( 466): uid=1000(system) Binder:466_3 expire 1 line
07-12 01:27:13.377 W/WindowManager( 466): App freeze timeout expired.
07-12 01:27:13.385 V/BackupManagerService( 466): No ancestral data
07-12 01:27:13.396 W/System ( 952): ClassLoader referenced unknown path: /system/priv-app/ExtServices/lib/arm
07-12 01:27:13.400 V/BackupManagerService( 466): Starting with transport android/com.android.internal.backup.LocalTransport
07-12 01:27:13.400 V/BackupManagerService( 466): Found transports: 1
07-12 01:27:13.400 W/BackupManagerService( 466): Proposed transport ComponentInfo{android/com.android.internal.backup.LocalTransportService} not whitelisted; ignoring
07-12 01:27:13.401 I/BackupManagerService( 466): Backup enabled => true
07-12 01:27:13.405 V/KeyValueBackupJob( 466): Scheduling k/v pass in 247 minutes
07-12 01:27:13.416 I/BackupManagerService( 466): Found stale backup journal, scheduling
07-12 01:27:13.419 I/InputAttributes( 669): InputType.TYPE_NULL is specified
07-12 01:27:13.422 W/VoiceInteractionManagerService( 466): no available voice interaction services found for user 0
07-12 01:27:13.422 W/VoiceInteractionManagerService( 466): no available voice recognition services found for user 0
07-12 01:27:13.422 I/ActivityManager( 466): Loading recents for user 0 into memory.
07-12 01:27:13.433 I/mali_so ( 623): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 876; [Func] : base_context_deal_with_version_affairs_rk_ext;
07-12 01:27:13.433 I/mali_so ( 623): arm_release_ver of this mali_so is ‘r18p0-01rel0’, rk_so_ver is ‘3@0’.
07-12 01:27:13.433 D/mali_so ( 623): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 881; [Func] : base_context_deal_with_version_affairs_rk_ext;
07-12 01:27:13.433 D/mali_so ( 623): current process is NOT sf, to bail out.
07-12 01:27:13.435 I/OpenGLRenderer( 623): Initialized EGL, version 1.4
07-12 01:27:13.435 D/OpenGLRenderer( 623): Swap behavior 1
07-12 01:27:13.446 D/mali_winsys( 623): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:27:13.465 I/ActivityManager( 466): Start proc 1006:com.android.nfc/1027 for added application com.android.nfc
07-12 01:27:13.476 W/System ( 977): ClassLoader referenced unknown path: /system/app/DeskClock/lib/arm
07-12 01:27:13.481 I/ActivityManager( 466): Start proc 1020:com.cghs.stresstest/1000 for added application com.cghs.stresstest
07-12 01:27:13.483 D/ActivityManager( 466): Sending BOOT_COMPLETE user #0
07-12 01:27:13.500 I/ActivityManager( 466): Start proc 1039:com.android.printspooler/u0a50 for service com.android.printspooler/.model.PrintSpoolerService
07-12 01:27:13.508 D/FallbackHome( 646): User unlocked and real home found; let’s go!
07-12 01:27:13.509 D/CarrierSvcBindHelper( 618): Received android.intent.action.USER_UNLOCKED
07-12 01:27:13.510 E/PhoneInterfaceManager( 618): [PhoneIntfMgr] getCarrierPackageNamesForIntent: No UICC
07-12 01:27:13.510 D/CarrierSvcBindHelper( 618): No carrier app for: 0
07-12 01:27:13.564 D/mali_winsys( 623): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:27:13.566 I/ActivityManager( 466): Start proc 1062:com.android.smspush/u0a55 for service com.android.smspush/.WapPushManager
07-12 01:27:13.571 W/System ( 1020): ClassLoader referenced unknown path: /system/priv-app/StressTest/lib/arm
07-12 01:27:13.572 D/WifiService( 466): New client listening to asynchronous messages
07-12 01:27:13.581 I/ActivityManager( 466): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000100 cmp=com.android.launcher3/.Launcher} from uid 0 on display 0
07-12 01:27:13.615 I/chatty ( 466): uid=1000(system) HeapTaskDaemon expire 1 line
07-12 01:27:13.617 I/ActivityManager( 466): Start proc 1087:com.android.launcher3/u0a40 for activity com.android.launcher3/.Launcher
07-12 01:27:13.652 I/chatty ( 1006): uid=1027(nfc) com.android.nfc expire 51 lines
07-12 01:27:13.653 W/System ( 1062): ClassLoader referenced unknown path: /system/app/WAPPushManager/lib/arm
07-12 01:27:13.663 I/ActivityManager( 466): Start proc 1112:com.android.keychain/1000 for service com.android.keychain/.KeyChainService
07-12 01:27:13.699 W/System ( 1087): ClassLoader referenced unknown path: /system/app/Launcher3/lib/arm
07-12 01:27:13.710 I/NuPlayerDecoder( 240): [audio] saw output EOS
07-12 01:27:13.730 I/chatty ( 466): uid=1000(system) Thread-7 expire 2 lines
07-12 01:27:13.734 D/mali_winsys( 623): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:27:13.753 D/LauncherProvider( 1087): Launcher process started
07-12 01:27:13.773 V/Launcher( 1087): LauncherAppState inited
07-12 01:27:13.773 W/System ( 1112): ClassLoader referenced unknown path: /system/app/KeyChain/lib/arm
07-12 01:27:13.827 I/wpa_supplicant( 1140): Successfully initialized wpa_supplicant
07-12 01:27:13.828 D/WifiHW ( 1140): uevent path:/sys/bus/sdio/devices/./uevent
07-12 01:27:13.828 D/WifiHW ( 1140): uevent path:/sys/bus/sdio/devices/../uevent
07-12 01:27:13.828 D/WifiHW ( 1140): uevent path:/sys/bus/sdio/devices/mmc2:0001:1/uevent
07-12 01:27:13.828 D/WifiHW ( 1140): found device pid:vid : 02d0:4335
07-12 01:27:13.828 D/WifiHW ( 1140): wifi detectd return ret:0
07-12 01:27:13.828 D/WifiHW ( 1140): SDIO WIFI identify sucess
07-12 01:27:13.828 D/WifiHW ( 1140): check_wifi_chip_type_string: AP6335
07-12 01:27:13.841 I/wpa_supplicant( 1140): rfkill: Cannot open RFKILL control device
07-12 01:27:13.864 I/chatty ( 1006): uid=1027(nfc) com.android.nfc expire 186 lines
07-12 01:27:13.871 I/chatty ( 1006): uid=1027(nfc) AsyncTask #1 expire 2 lines
07-12 01:27:13.871 I/chatty ( 1006): uid=1027(nfc) com.android.nfc expire 2 lines
07-12 01:27:13.891 I/chatty ( 1006): uid=1027(nfc) AsyncTask #1 expire 1014 lines
07-12 01:27:13.897 I/chatty ( 1006): uid=1027(nfc) AsyncTask #1 expire 456 lines
07-12 01:27:13.905 I/wpa_supplicant( 1140): rfkill: Cannot get wiphy information
07-12 01:27:13.922 W/System ( 1087): ClassLoader referenced unknown path:
07-12 01:27:13.923 W/System ( 1087): ClassLoader referenced unknown path: /system/app/QuickSearchBox/lib/arm
07-12 01:27:13.923 D/ApplicationLoaders( 1087): ignored Vulkan layer search path /system/app/QuickSearchBox/lib/arm:/system/lib:/vendor/lib for namespace 0xb0574090
07-12 01:27:13.935 I/AlarmClock( 977): AlarmInitReceiver android.intent.action.LOCKED_BOOT_COMPLETED
07-12 01:27:13.958 D/AlarmClock/Events( 977): [Stopwatch] [Reset] [Reboot]
07-12 01:27:14.022 V/AlarmClock( 977): AlarmInitReceiver finished
07-12 01:27:14.027 E/VRMountReceiver( 1020): ---------------- action = android.intent.action.MEDIA_MOUNTED
07-12 01:27:14.027 E/VRMountReceiver( 1020): ------------- mount path = /storage/emulated/0
07-12 01:27:14.028 E/VRMountReceiver( 1020): ---------------- pathUri is null
07-12 01:27:14.036 V/GridSizeMigrationTask( 1087): Workspace migration completed in 18
07-12 01:27:14.037 D/Launcher.Model( 1087): loadWorkspace: loading default favorites
07-12 01:27:14.051 W/KeyguardUpdateMonitor( 623): invalid subId in handleSimStateChange()
07-12 01:27:14.068 I/mali_so ( 1087): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 876; [Func] : base_context_deal_with_version_affairs_rk_ext;
07-12 01:27:14.068 I/mali_so ( 1087): arm_release_ver of this mali_so is ‘r18p0-01rel0’, rk_so_ver is ‘3@0’.
07-12 01:27:14.068 D/mali_so ( 1087): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 881; [Func] : base_context_deal_with_version_affairs_rk_ext;
07-12 01:27:14.068 D/mali_so ( 1087): current process is NOT sf, to bail out.
07-12 01:27:14.072 I/OpenGLRenderer( 1087): Initialized EGL, version 1.4
07-12 01:27:14.072 D/OpenGLRenderer( 1087): Swap behavior 1
07-12 01:27:14.080 D/mali_winsys( 1087): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface , egl_color_buffer_format , EGLBoolean) returns 0x3000
07-12 01:27:14.180 I/chatty ( 466): uid=1000 system_server expire 1 line
07-12 01:27:14.276 I/chatty ( 1006): uid=1027(nfc) AsyncTask #1 expire 103 lines
07-12 01:27:14.298 D/NuPlayerDriver( 240): notifyListener_l(0xb0b07180), (2, 0, 0), loop setting(0, 0)
07-12 01:27:14.315 E/AudioFlinger( 232): no wake lock to update, but system ready!
07-12 01:27:14.339 D/AudioHardwareTiny( 232): adev_set_parameters: kvpairs = A2dpSuspended=false
07-12 01:27:14.734 D/ConnectivityService( 466): Got NetworkFactory Messenger for WIFI
07-12 01:27:14.735 D/ConnectivityService( 466): Got NetworkFactory Messenger for WIFI_UT
07-12 01:27:14.735 D/ConnectivityService( 466): NetworkFactory connected
07-12 01:27:14.737 I/chatty ( 1006): uid=1027(nfc) Thread-2 expire 18 lines
07-12 01:27:14.743 I/chatty ( 1006): uid=1027(nfc) Thread-4 expire 11 lines
07-12 01:27:14.745 I/chatty ( 1006): uid=1027(nfc) AsyncTask #1 expire 1 line
07-12 01:27:14.745 I/chatty ( 1006): uid=1027(nfc) Thread-4 expire 6 lines
07-12 01:27:14.746 D/BrcmNfcJni( 1006): P2pServer:
serverJniHandle: 3; connJniHandle: 4; wait for incoming connection
07-12 01:27:14.749 D/USERIAL_LINUX( 1006): USERIAL_Write len = 26, ret = 26
07-12 01:27:14.750 D/USERIAL_LINUX( 1006): my_read: return 5(0x5) bytes, errno=0 count=2, n=1, timeout=-1
07-12 01:27:14.750 D/USERIAL_LINUX( 1006): userial_read_thread(): enqueued p_buf=0x9422ddc8, count=1, length=5
07-12 01:27:14.750 D/USERIAL_LINUX( 1006): my_read: enter, pbuf=9422e820, len = 507
07-12 01:27:14.750 I/BrcmNci ( 1006): –
07-12 01:27:14.751 I/BrcmNci ( 1006): RECV NCI Type:RSP Name: CORE_SET_CONFIG(0x2) PBF:No/Last Param Len: 2/2 f:0x0
07-12 01:27:14.751 I/BrcmNci ( 1006): Status : OK (0x00)
07-12 01:27:14.751 I/BrcmNci ( 1006): Num Params : 0 (0x00)
07-12 01:27:14.751 D/BrcmNci ( 1006): Raw NCI Packet
07-12 01:27:14.751 D/BrcmNci ( 1006): 0000: 40 02 02 00 00 @…
07-12 01:27:14.751 I/BrcmNci ( 1006): –
07-12 01:27:14.751 I/NfcNciHal( 1006): nfc_hal_nci_preproc_rx_nci_msg() HAL State: 1
07-12 01:27:14.751 I/NfcNciHal( 1006): nfc_hal_dm_wake_nfcc () snooze_mode=8
07-12 01:27:14.751 D/NfcNciHal( 1006): BroadcomHalDataCallback: enter; len=5
07-12 01:27:14.751 D/NfcAdaptation( 1006): NfcAdaptation::HalDeviceContextDataCallback: len=5
07-12 01:27:14.751 I/BrcmNfcNfa( 1006): NFC received rsp gid:0
07-12 01:27:14.751 I/BrcmNfcNfa( 1006): nci_proc_core_rsp opcode:0x2
07-12 01:27:14.751 I/BrcmNfcNfa( 1006): nfa_dm_nfc_response_cback () NFC_SET_CONFIG_REVT(0x5002)
07-12 01:27:14.751 D/NfcAdaptation( 1006): NfcAdaptation::HalWrite
07-12 01:27:14.751 D/NfcNciHal( 1006): HaiWrite: enter; len=29
07-12 01:27:14.751 I/NfcNciHal( 1006): HAL_NfcWrite ()
07-12 01:27:14.751 D/NfcNciHal( 1006): HaiWrite: exit 0
07-12 01:27:14.751 I/NfcNciHal( 1006): nfc_hal_main_send_message() ls:0x1
07-12 01:27:14.751 I/NfcNciHal( 1006): p_buf->len: 29
07-12 01:27:14.752 I/BrcmNci ( 1006): –
07-12 01:27:14.752 I/BrcmNci ( 1006): SENT NCI Type:CMD Name: CORE_SET_CONFIG(0x2) PBF:No/Last Param Len: 26/26 f:0x0
07-12 01:27:14.752 I/BrcmNci ( 1006): Num Params : 2 (0x02)
07-12 01:27:14.752 I/BrcmNci ( 1006): Param ID [0] : (97/0x61) ATR_RES_GEN_BYTES
07-12 01:27:14.752 I/BrcmNci ( 1006): Param Len[0] : 20 (0x14)
07-12 01:27:14.752 I/BrcmNci ( 1006): Param Val[0] : 46 66 6d 01 01 12 02 02 07 ff 03 02 00 13 04 01
07-12 01:27:14.752 I/BrcmNci ( 1006): 10 : 64 07 01 03
07-12 01:27:14.752 I/BrcmNci ( 1006): Param ID [1] : (96/0x60) WT
07-12 01:27:14.752 I/BrcmNci ( 1006): Param Len[1] : 1 (0x01)
07-12 01:27:14.752 I/BrcmNci ( 1006): Param Val[1] : 09
07-12 01:27:14.752 D/BrcmNci ( 1006): Raw NCI Packet
07-12 01:27:14.752 D/BrcmNci ( 1006): 0000: 20 02 1a 02 61 14 46 66 6d 01 01 12 02 02 07 ff …a.Ffm…
07-12 01:27:14.752 D/BrcmNci ( 1006): 0010: 03 02 00 13 04 01 64 07 01 03 60 01 09 …d…`..
07-12 01:27:14.752 D/USERIAL_LINUX( 1006): USERIAL_Write: (29 bytes)
07-12 01:27:14.752 D/USERIAL_LINUX( 1006): doWriteDelay() delay 2 ms
07-12 01:27:14.756 D/NdefPushServer( 1006): about create LLCP service socket
07-12 01:27:14.756 D/BrcmNfcJni( 1006): nfcManager_doCreateLlcpServiceSocket: enter: sap=16; name=com.android.npp; miu=248; rw=1; buffLen=1024
07-12 01:27:14.756 D/BrcmNfcJni( 1006): PeerToPeer::registerServer: enter; service name: com.android.npp JNI handle: 5
07-12 01:27:14.756 D/BrcmNfcJni( 1006): PeerToPeer::registerServer: added new p2p server index: 2 handle: 5 name: com.android.npp
07-12 01:27:14.756 D/BrcmNfcJni( 1006): P2pServer::registerWithStack: enter; service name: com.android.npp JNI handle: 5
07-12 01:27:14.757 I/BrcmNfcNfa( 1006): NFA_P2pSetLLCPConfig ():link_miu:2175, opt:0x03, wt:9, link_timeout:1000
07-12 01:27:14.757 I/BrcmNfcNfa( 1006): inact_timeout(init:0, target:0), symm_delay:20, data_link_timeout:2000
07-12 01:27:14.757 I/BrcmNfcNfa( 1006): delay_first_pdu_timeout:50
07-12 01:27:14.757 I/BrcmNfcNfa( 1006): NFA got event 0x030C
07-12 01:27:14.757 D/BrcmNfcJni( 1006): P2pServer::registerWithStack: wait for listen-completion event
07-12 01:27:14.757 I/BrcmNfcNfa( 1006): nfa_p2p_evt_hdlr (): Event API_SET_LLCP_CFG_EVT
07-12 01:27:14.757 I/BrcmNfcNfa( 1006): LLCP_SetConfig () link_miu:2175, opt:0x03, wt:9, link_timeout:1000
07-12 01:27:14.757 I/BrcmNfcNfa( 1006): inact_timeout (init:0,target:0), symm_delay:20, data_link_timeout:2000
07-12 01:27:14.757 I/BrcmNfcNfa( 1006): NFA got event 0x0300
07-12 01:27:14.757 I/BrcmNfcNfa( 1006): nfa_p2p_evt_hdlr (): Event API_REG_SERVER
07-12 01:27:14.757 I/BrcmNfcNfa( 1006): nfa_p2p_reg_server ()
07-12 01:27:14.757 I/BrcmNfcNfa( 1006): LLCP_RegisterServer (): SAP:0xff, link_type:0x2, ServiceName:<com.android.npp>
07-12 01:27:14.757 I/BrcmNfcNfa( 1006): LLCP_RegisterServer (): Registered SAP = 0x11
07-12 01:27:14.757 D/BrcmNfcJni( 1006): PeerToPeer::nfaServerCallback: enter; event=0x0
07-12 01:27:14.757 D/BrcmNfcJni( 1006): PeerToPeer::nfaServerCallback: NFA_P2P_REG_SERVER_EVT; handle: 0x0511; service sap=0x11 name: com.android.npp
07-12 01:27:14.757 D/BrcmNfcJni( 1006): PeerToPeer::nfaServerCallback: exit
07-12 01:27:14.757 D/BrcmNfcJni( 1006): PeerToPeer::registerServer: got new p2p server h=0x511
07-12 01:27:14.758 D/BrcmNfcJni( 1006): nfcManager_doCreateLlcpServiceSocket: socket Handle = 0x5
07-12 01:27:14.758 D/BrcmNfcJni( 1006): nfcManager_doCreateLlcpServiceSocket: buffer length = 1024
07-12 01:27:14.758 D/BrcmNfcJni( 1006): nfcManager_doCreateLlcpServiceSocket: MIU = 248
07-12 01:27:14.758 D/BrcmNfcJni( 1006): nfcManager_doCreateLlcpServiceSocket: RW = 1
07-12 01:27:14.758 D/BrcmNfcJni( 1006): nfcManager_doCreateLlcpServiceSocket: exit
07-12 01:27:14.758 D/NdefPushServer( 1006): created LLCP service socket
07-12 01:27:14.758 D/NdefPushServer( 1006): about to accept
07-12 01:27:14.758 D/BrcmNfcJni( 1006): nativeLlcpServiceSocket_doAccept: enter
07-12 01:27:14.758 D/BrcmNfcJni( 1006): PeerToPeer:
enter; server jni handle: 5; conn jni handle: 6; maxInfoUnit: 248; recvWindow: 1
07-12 01:27:14.758 D/BrcmNfcJni( 1006): P2pServer:
serverJniHandle: 5; connJniHandle: 6; wait for incoming connection
07-12 01:27:14.762 D/USERIAL_LINUX( 1006): USERIAL_Write len = 29, ret = 29
07-12 01:27:14.764 D/USERIAL_LINUX( 1006): my_read: return 5(0x5) bytes, errno=0 count=2, n=1, timeout=-1
07-12 01:27:14.764 D/USERIAL_LINUX( 1006): userial_read_thread(): enqueued p_buf=0x9422e818, count=1, length=5
07-12 01:27:14.764 D/USERIAL_LINUX( 1006): my_read: enter, pbuf=9422e400, len = 507
07-12 01:27:14.764 I/BrcmNci ( 1006): –
07-12 01:27:14.764 I/BrcmNci ( 1006): RECV NCI Type:RSP Name: CORE_SET_CONFIG(0x2) PBF:No/Last Param Len: 2/2 f:0x0
07-12 01:27:14.764 I/BrcmNci ( 1006): Status : OK (0x00)
07-12 01:27:14.764 I/BrcmNci ( 1006): Num Params : 0 (0x00)
07-12 01:27:14.764 D/BrcmNci ( 1006): Raw NCI Packet
07-12 01:27:14.764 D/BrcmNci ( 1006): 0000: 40 02 02 00 00 @…
07-12 01:27:14.764 I/NfcNciHal( 1006): nfc_hal_nci_preproc_rx_nci_msg() HAL State: 1
07-12 01:27:14.764 I/NfcNciHal( 1006): nfc_hal_dm_wake_nfcc () snooze_mode=8
07-12 01:27:14.764 D/NfcNciHal( 1006): BroadcomHalDataCallback: enter; len=5
07-12 01:27:14.764 D/NfcAdaptation( 1006): NfcAdaptation::HalDeviceContextDataCallback: len=5
07-12 01:27:14.764 I/BrcmNfcNfa( 1006): NFC received rsp gid:0
07-12 01:27:14.764 I/BrcmNfcNfa( 1006): nci_proc_core_rsp opcode:0x2
07-12 01:27:14.764 I/BrcmNfcNfa( 1006): nfa_dm_nfc_response_cback () NFC_SET_CONFIG_REVT(0x5002)
07-12 01:27:14.770 I/NfcService( 1006): enableInternal(); screenState=3
07-12 01:27:14.770 D/NativeNfcManager( 1006): power state=4
07-12 01:27:14.771 D/BrcmNfcJni( 1006): PowerSwitch::com_android_nfc_NativeNfcManager_doSetPowerMode: mode=0x4; screen on unlocked
07-12 01:27:14.771 D/BrcmNfcJni( 1006): nfcManager_enableDiscovery: enter
07-12 01:27:14.771 D/BrcmNfcJni( 1006): stopDiscoveryDeferredAbortNow
07-12 01:27:14.771 D/BrcmNfcJni( 1006): nfcManager_enableDiscoveryImpl: enter; tech_mask = 0x000000ef reader_mode=0 mpos_mode=0 bit_transparent_mode=0 enable_p2p=1
07-12 01:27:14.771 D/BrcmNfcJni( 1006): com_android_nfc_broadcom_AidFilter_doDisableFilterCondition: enter
07-12 01:27:14.771 D/BrcmNfcJni( 1006): DisableFilterCondition tag=0xf1
07-12 01:27:14.771 D/NfcAdaptation( 1006): const CNfcParam CNfcConfig::find(const char ) const found ENABLE_AID_FILTERING=(0x0)
07-12 01:27:14.771 D/BrcmNfcJni( 1006): IsEnabled: ENABLE_AID_FILTERING=0
07-12 01:27:14.771 D/BrcmNfcJni( 1006): Aid Filter feature is disabled.
07-12 01:27:14.771 D/BrcmNfcJni( 1006): com_android_nfc_broadcom_AidFilter_doDisableFilterCondition: exit; return=1
07-12 01:27:14.772 D/BrcmNfcJni( 1006): stopPolling_rfDiscoveryDisabled: disable polling
07-12 01:27:14.772 I/BrcmNfcNfa( 1006): NFA_DisablePolling ()
07-12 01:27:14.772 I/BrcmNfcNfa( 1006): NFA got event 0x0107
07-12 01:27:14.772 I/BrcmNfcNfa( 1006): nfa_dm_evt_hdlr event: NFA_DM_API_DISABLE_POLLING_EVT (0x07)
07-12 01:27:14.772 I/BrcmNfcNfa( 1006): nfa_dm_act_disable_polling ()
07-12 01:27:14.772 D/BrcmNfcJni( 1006): nfaConnectionCallback: event= 1
07-12 01:27:14.772 D/BrcmNfcJni( 1006): nfaConnectionCallback: NFA_POLL_DISABLED_EVT: status = 8194
07-12 01:27:14.773 I/BrcmNfcNfa( 1006): NFA_GetConfig (): num_ids: 1
07-12 01:27:14.773 I/BrcmNfcNfa( 1006): NFA got event 0x0103
07-12 01:27:14.773 I/BrcmNfcNfa( 1006): nfa_dm_evt_hdlr event: NFA_DM_API_GET_CONFIG_EVT (0x03)
07-12 01:27:14.773 D/NfcAdaptation( 1006): NfcAdaptation::HalWrite
07-12 01:27:14.773 D/NfcNciHal( 1006): HaiWrite: enter; len=5
07-12 01:27:14.773 I/NfcNciHal( 1006): HAL_NfcWrite ()
07-12 01:27:14.773 D/NfcNciHal( 1006): HaiWrite: exit 0
07-12 01:27:14.773 I/NfcNciHal( 1006): nfc_hal_main_send_message() ls:0x1
07-12 01:27:14.773 I/NfcNciHal( 1006): nfc_hal_dm_wake_nfcc () snooze_mode=8
07-12 01:27:14.773 I/NfcNciHal( 1006): p_buf->len: 5
07-12 01:27:14.773 I/BrcmNci ( 1006): –
07-12 01:27:14.773 I/BrcmNci ( 1006): SENT NCI Type:CMD Name: CORE_GET_CONFIG(0x3) PBF:No/Last Param Len: 2/2 f:0x0
07-12 01:27:14.773 I/BrcmNci ( 1006): Num Params : 1 (0x01)
07-12 01:27:14.773 I/BrcmNci ( 1006): Param ID[0] : (185/0xb9) TAGSNIFF_CFG
07-12 01:27:14.773 D/BrcmNci ( 1006): Raw NCI Packet
07-12 01:27:14.773 D/BrcmNci ( 1006): 0000: 20 03 02 01 b9 …
07-12 01:27:14.773 D/USERIAL_LINUX( 1006): USERIAL_Write: (5 bytes)
07-12 01:27:14.774 D/wifi ( 466): android_net_wifi_get_firmware_version = 0xada6bf20
07-12 01:27:14.775 D/WifiHAL ( 466): In DebugCommand::handleResponse
07-12 01:27:14.775 D/WifiHAL ( 466): len = 116, expected len = 256
07-12 01:27:14.775 D/wifi ( 466): buffer is 0x99c63d00, length is 256
07-12 01:27:14.775 D/wifi ( 466): android_net_wifi_get_driver_version = 0xada6bf20
07-12 01:27:14.775 D/WifiHAL ( 466): len = 48, expected len = 256
07-12 01:27:14.775 D/wifi ( 466): android_net_wifi_set_log_handler = 0xada6bf20
07-12 01:27:14.775 D/wifi ( 466): android_net_wifi_get_ring_buffer_status = 0xada6bf20
07-12 01:27:14.775 D/wifi ( 466): status is 0x9c918880, number is 4
07-12 01:27:14.776 D/wifi ( 466): android_net_wifi_start_logging_ring_buffer = 0xada6bf20
07-12 01:27:14.779 D/USERIAL_LINUX( 1006): USERIAL_Write len = 5, ret = 5
07-12 01:27:14.784 D/USERIAL_LINUX( 1006): my_read: return 41(0x29) bytes, errno=0 count=38, n=1, timeout=-1
07-12 01:27:14.784 D/USERIAL_LINUX( 1006): userial_read_thread(): enqueued p_buf=0x9422e3f8, count=1, length=41
07-12 01:27:14.784 D/USERIAL_LINUX( 1006): my_read: enter, pbuf=9422d380, len = 507
07-12 01:27:14.784 I/BrcmNci ( 1006): –
07-12 01:27:14.784 I/BrcmNci ( 1006): RECV NCI Type:RSP Name: CORE_GET_CONFIG(0x3) PBF:No/Last Param Len: 38/38 f:0x0
07-12 01:27:14.784 I/BrcmNci ( 1006): Status : OK (0x00)
07-12 01:27:14.784 I/BrcmNci ( 1006): Num Params : 1 (0x01)
07-12 01:27:14.784 I/BrcmNci ( 1006): Param ID [0] : (185/0xb9) TAGSNIFF_CFG
07-12 01:27:14.784 I/BrcmNci ( 1006): Param Len[0] : 34 (0x22)
07-12 01:27:14.784 I/BrcmNci ( 1006): Param Val[0] : 10 00 00 06 00 00 00 2d 00 07 16 00 06 00 00 b8
07-12 01:27:14.784 I/BrcmNci ( 1006): 10 : 01 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00
07-12 01:27:14.784 I/BrcmNci ( 1006): 20 : 00 00
07-12 01:27:14.784 D/BrcmNci ( 1006): Raw NCI Packet
07-12 01:27:14.784 D/BrcmNci ( 1006): 0000: 40 03 26 00 01 b9 22 10 00 00 06 00 00 00 2d 00 @.&…“…-.
07-12 01:27:14.784 D/BrcmNci ( 1006): 0010: 07 16 00 06 00 00 b8 01 00 00 00 03 00 00 00 00 …
07-12 01:27:14.784 D/BrcmNci ( 1006): 0020: 00 00 00 00 00 00 00 00 00 …
07-12 01:27:14.785 I/BrcmNci ( 1006): –
07-12 01:27:14.785 I/NfcNciHal( 1006): nfc_hal_nci_preproc_rx_nci_msg() HAL State: 1
07-12 01:27:14.785 I/NfcNciHal( 1006): nfc_hal_dm_wake_nfcc () snooze_mode=8
07-12 01:27:14.785 D/NfcNciHal( 1006): BroadcomHalDataCallback: enter; len=41
07-12 01:27:14.785 D/NfcAdaptation( 1006): NfcAdaptation::HalDeviceContextDataCallback: len=41
07-12 01:27:14.785 I/BrcmNfcNfa( 1006): NFC received rsp gid:0
07-12 01:27:14.785 I/BrcmNfcNfa( 1006): nci_proc_core_rsp opcode:0x3
07-12 01:27:14.785 I/BrcmNfcNfa( 1006): nfa_dm_nfc_response_cback () NFC_GET_CONFIG_REVT(0x5003)
07-12 01:27:14.785 D/BrcmNfcJni( 1006): nfaDeviceManagementCallback: enter; event=0x3
07-12 01:27:14.785 D/BrcmNfcJni( 1006): nfaDeviceManagementCallback: NFA_DM_GET_CONFIG_EVT
07-12 01:27:14.785 I/BrcmNfcNfa( 1006): NFA_SetConfig (): param_id:0xB9
07-12 01:27:14.785 I/BrcmNfcNfa( 1006): NFA got event 0x0102
07-12 01:27:14.785 I/BrcmNfcNfa( 1006): nfa_dm_evt_hdlr event: NFA_DM_API_SET_CONFIG_EVT (0x02)
07-12 01:27:14.785 I/BrcmNfcNfa( 1006): nfa_dm_check_set_config ()
07-12 01:27:14.785 D/NfcAdaptation( 1006): NfcAdaptation::HalWrite
07-12 01:27:14.785 D/NfcNciHal( 1006): HaiWrite: enter; len=7
07-12 01:27:14.785 I/NfcNciHal( 1006): HAL_NfcWrite ()
07-12 01:27:14.785 D/NfcNciHal( 1006): HaiWrite: exit 0
07-12 01:27:14.785 I/NfcNciHal( 1006): nfc_hal_main_send_message() ls:0x1
07-12 01:27:14.785 I/NfcNciHal( 1006): p_buf->len: 7
07-12 01:27:14.785 I/BrcmNci ( 1006): SENT NCI Type:CMD Name: CORE_SET_CONFIG(0x2) PBF:No/Last Param Len: 4/4 f:0x0
07-12 01:27:14.785 I/BrcmNci ( 1006): Num Params : 1 (0x01)
07-12 01:27:14.785 I/BrcmNci ( 1006): Param ID [0] : (185/0xb9) TAGSNIFF_CFG
07-12 01:27:14.785 I/BrcmNci ( 1006): Param Len[0] : 1 (0x01)
07-12 01:27:14.786 I/BrcmNci ( 1006): Param Val[0] : 01
07-12 01:27:14.786 D/BrcmNci ( 1006): Raw NCI Packet
07-12 01:27:14.786 D/BrcmNci ( 1006): 0000: 20 02 04 01 b9 01 01 …
07-12 01:27:14.786 I/BrcmNci ( 1006): –
07-12 01:27:14.786 D/USERIAL_LINUX( 1006): USERIAL_Write: (7 bytes)
07-12 01:27:14.790 I/com.android.nfc( 1006): type=1400 audit(0.0:21): avc: denied { read } for comm=4E444B204D65646961436F6465635F name=“u:object_r:ctsgts_prop:s0” dev=“tmpfs” ino=10967 scontext=u:r:nfc:s0 tcontext=u:object_r:ctsgts_prop:s0 tclass=file permissive=1
07-12 01:27:14.790 D/wifi ( 466): start logging for ring fw_verbose
07-12 01:27:14.790 D/wifi ( 466): android_net_wifi_start_logging_ring_buffer = 0xada6bf20
07-12 01:27:14.792 D/wifi ( 466): start logging for ring fw_event
07-12 01:27:14.792 D/wifi ( 466): android_net_wifi_start_logging_ring_buffer = 0xada6bf20
07-12 01:27:14.792 D/wifi ( 466): start logging for ring dhd_event
07-12 01:27:14.792 D/USERIAL_LINUX( 1006): USERIAL_Write len = 7, ret = 7
07-12 01:27:14.793 I/com.android.nfc( 1006): type=1400 audit(0.0:22): avc: denied { open } for comm=4E444B204D65646961436F6465635F path=”/dev/properties/u:object_r:ctsgts_prop:s0" dev=“tmpfs” ino=10967 scontext=u:r:nfc:s0 tcontext=u:object_r:ctsgts_prop:s0 tclass=file permissive=1
07-12 01:27:14.793 I/com.android.nfc( 1006): type=1400 audit(0.0:23): avc: denied { getattr } for comm=4E444B204D65646961436F6465635F path=“/dev/properties/u:object_r:ctsgts_prop:s0” dev=“tmpfs” ino=10967 scontext=u:r:nfc:s0 tcontext=u:object_r:ctsgts_prop:s0 tclass=file permissive=1
07-12 01:27:14.793 I/MediaCodec( 1006): callingProcessName:com.android.nfc
07-12 01:27:14.793 D/wifi ( 466): start logging for ring nan_event
07-12 01:27:14.793 D/wifi ( 466): android_net_wifi_start_logging_ring_buffer = 0xada6bf20
07-12 01:27:14.795 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:14.795 I/OMXClient( 1006): MuxOMX ctor
07-12 01:27:14.796 I/ACodec ( 1006): onAllocateComponent:6752 mSoftCodecPref:0 componentName:
07-12 01:27:14.797 D/USERIAL_LINUX( 1006): my_read: return 5(0x5) bytes, errno=0 count=2, n=1, timeout=-1
07-12 01:27:14.797 D/USERIAL_LINUX( 1006): userial_read_thread(): enqueued p_buf=0x9422d378, count=1, length=5
07-12 01:27:14.797 D/USERIAL_LINUX( 1006): my_read: enter, pbuf=9422dbc0, len = 507
07-12 01:27:14.797 I/ACodec ( 1006): onAllocateComponent:6783 mSoftCodecPref:0 componentName:OMX.google.vorbis.decoder
07-12 01:27:14.797 I/BrcmNci ( 1006): –
07-12 01:27:14.797 I/BrcmNci ( 1006): RECV NCI Type:RSP Name: CORE_SET_CONFIG(0x2) PBF:No/Last Param Len: 2/2 f:0x0
07-12 01:27:14.797 I/BrcmNci ( 1006): Status : OK (0x00)
07-12 01:27:14.797 I/BrcmNci ( 1006): Num Params : 0 (0x00)
07-12 01:27:14.797 D/BrcmNci ( 1006): Raw NCI Packet
07-12 01:27:14.797 D/BrcmNci ( 1006): 0000: 40 02 02 00 00 @…
07-12 01:27:14.797 I/NfcNciHal( 1006): nfc_hal_nci_preproc_rx_nci_msg() HAL State: 1
07-12 01:27:14.797 I/NfcNciHal( 1006): nfc_hal_dm_wake_nfcc () snooze_mode=8
07-12 01:27:14.797 D/NfcNciHal( 1006): BroadcomHalDataCallback: enter; len=5
07-12 01:27:14.797 D/NfcAdaptation( 1006): NfcAdaptation::HalDeviceContextDataCallback: len=5
07-12 01:27:14.797 I/BrcmNfcNfa( 1006): NFC received rsp gid:0
07-12 01:27:14.797 I/BrcmNfcNfa( 1006): nci_proc_core_rsp opcode:0x2
07-12 01:27:14.797 I/BrcmNfcNfa( 1006): nfa_dm_nfc_response_cback () NFC_SET_CONFIG_REVT(0x5002)
07-12 01:27:14.797 D/BrcmNfcJni( 1006): nfaDeviceManagementCallback: enter; event=0x2
07-12 01:27:14.797 D/BrcmNfcJni( 1006): nfaDeviceManagementCallback: NFA_DM_SET_CONFIG_EVT
07-12 01:27:14.797 D/BrcmNfcJni( 1006): startPolling_rfDiscoveryDisabled: enable polling
07-12 01:27:14.798 I/BrcmNfcNfa( 1006): NFA_EnablePolling () 0xEF
07-12 01:27:14.798 D/BrcmNfcJni( 1006): startPolling_rfDiscoveryDisabled: wait for enable event
07-12 01:27:14.798 I/BrcmNfcNfa( 1006): NFA got event 0x0106
07-12 01:27:14.798 I/BrcmNfcNfa( 1006): nfa_dm_evt_hdlr event: NFA_DM_API_ENABLE_POLLING_EVT (0x06)
07-12 01:27:14.798 I/BrcmNfcNfa( 1006): nfa_dm_act_enable_polling ()
07-12 01:27:14.798 I/BrcmNfcNfa( 1006): nfa_dm_add_poll_discovery_mask (0xEF)
07-12 01:27:14.798 I/OMXMaster( 237): makeComponentInstance(OMX.google.vorbis.decoder) in mediacodec process
07-12 01:27:14.798 I/BrcmNfcNfa( 1006): nfa_dm_add_rf_discovery_mask() disc_mask=0xef
07-12 01:27:14.798 D/BrcmNfcJni( 1006): nfaConnectionCallback: event= 0
07-12 01:27:14.798 D/BrcmNfcJni( 1006): nfaConnectionCallback: NFA_POLL_ENABLED_EVT: status = 0
07-12 01:27:14.798 D/BrcmNfcJni( 1006): nfcManager_enableDiscoveryImpl: Enable p2pListening; sP2pEnabled=0
07-12 01:27:14.798 D/BrcmNfcJni( 1006): PeerToPeer::enableP2pListening: enter isEnable: 1 mIsP2pListening: 0
07-12 01:27:14.798 D/BrcmNfcJni( 1006): RoutingManager::adjustP2pListenTechMask: original mask 0x1A40000
07-12 01:27:14.798 D/BrcmNfcJni( 1006): RoutingManager::adjustP2pListenTechMask: new mask 0x1A40000
07-12 01:27:14.798 I/BrcmNfcNfa( 1006): NFA_SetP2pListenTech (): listen_mask:0x1A40000
07-12 01:27:14.798 I/BrcmNfcNfa( 1006): NFA got event 0x010F
07-12 01:27:14.798 I/BrcmNfcNfa( 1006): nfa_dm_evt_hdlr event: NFA_DM_API_SET_P2P_LISTEN_TECH_EVT (0x0f)
07-12 01:27:14.798 I/BrcmNfcNfa( 1006): nfa_dm_set_p2p_listen_tech () listen_mask = 0x1a40000
07-12 01:27:14.799 D/wifi ( 466): start logging for ring fw_verbose
07-12 01:27:14.799 D/wifi ( 466): android_net_wifi_start_logging_ring_buffer = 0xada6bf20
07-12 01:27:14.801 D/wifi ( 466): start logging for ring fw_event
07-12 01:27:14.801 D/wifi ( 466): android_net_wifi_start_logging_ring_buffer = 0xada6bf20
07-12 01:27:14.801 D/wifi ( 466): start logging for ring dhd_event
07-12 01:27:14.803 D/wifi ( 466): start logging for ring nan_event
07-12 01:27:14.803 D/WifiHAL ( 466): Start get packet fate command
07-12 01:27:14.803 D/WifiHAL ( 466): createRequest Monitor packet fate request
07-12 01:27:14.804 D/WifiHW ( 1140): check_wifi_chip_type_string: AP6335
07-12 01:27:14.809 D/USERIAL_LINUX( 1006): USERIAL_Write len = 20, ret = 20
07-12 01:27:14.810 D/USERIAL_LINUX( 1006): my_read: return 4(0x4) bytes, errno=0 count=1, n=1, timeout=-1
07-12 01:27:14.810 D/USERIAL_LINUX( 1006): userial_read_thread(): enqueued p_buf=0x9422dbb8, count=1, length=4
07-12 01:27:14.810 D/USERIAL_LINUX( 1006): my_read: enter, pbuf=9422e610, len = 507
07-12 01:27:14.810 I/BrcmNci ( 1006): –
07-12 01:27:14.810 I/BrcmNci ( 1006): RECV NCI Type:RSP Name: RF_SET_ROUTING(0x1) PBF:No/Last Param Len: 1/1 f:0x0
07-12 01:27:14.810 I/BrcmNci ( 1006): Status : OK (0x00)
07-12 01:27:14.810 D/BrcmNci ( 1006): Raw NCI Packet
07-12 01:27:14.810 D/BrcmNci ( 1006): 0000: 41 01 01 00 A…
07-12 01:27:14.810 I/NfcNciHal( 1006): nfc_hal_nci_preproc_rx_nci_msg() HAL State: 1
07-12 01:27:14.810 I/NfcNciHal( 1006): nfc_hal_dm_wake_nfcc () snooze_mode=8
07-12 01:27:14.810 D/NfcNciHal( 1006): BroadcomHalDataCallback: enter; len=4
07-12 01:27:14.810 D/NfcAdaptation( 1006): NfcAdaptation::HalDeviceContextDataCallback: len=4
07-12 01:27:14.811 I/BrcmNfcNfa( 1006): NFC received rsp gid:1
07-12 01:27:14.811 I/BrcmNfcNfa( 1006): nfa_dm_nfc_response_cback () NFC_SET_ROUTING_REVT(0x500a)
07-12 01:27:14.811 I/BrcmNfcNfa( 1006): nfa_ee_proc_evt: event=0x500a int_event:0x21b
07-12 01:27:14.811 I/BrcmNfcNfa( 1006): nfa_ee_evt_hdlr (): Event NCI_WAIT_RSP(0x21b), State: INIT_DONE(1)
07-12 01:27:14.811 I/BrcmNfcNfa( 1006): nfa_ee_nci_wait_rsp() ee_wait_evt:0x70 wait_rsp:1
07-12 01:27:14.811 I/BrcmNfcNfa( 1006): nfa_ee_report_update_evt ee_wait_evt:0x70, wait_rsp:0
07-12 01:27:14.811 D/BrcmNfcJni( 1006): RoutingManager::nfaEeCallback: NFA_EE_UPDATED_EVT
07-12 01:27:14.812 I/BrcmNfcNfa( 1006): nfa_ee_report_update_evt ee_wait_evt:0x40 lpm_rsp:0 lpm_ntf:0
07-12 01:27:14.812 D/BrcmNfcJni( 1006): RoutingManager::nfaEeCallback: NFA_EE_LPM_UPDATED_EVT
07-12 01:27:14.812 D/BrcmNfcJni( 1006): startRfDiscovery: locked; start=1
07-12 01:27:14.812 I/BrcmNfcNfa( 1006): NFA_StartRfDiscovery ()
07-12 01:27:14.812 I/BrcmNfcNfa( 1006): NFA got event 0x0110
07-12 01:27:14.812 I/BrcmNfcNfa( 1006): nfa_dm_evt_hdlr event: NFA_DM_API_START_RF_DISCOVERY_EVT (0x10)
07-12 01:27:14.812 I/BrcmNfcNfa( 1006): nfa_dm_act_start_rf_discovery ()
07-12 01:27:14.812 I/BrcmNfcNfa( 1006): nfa_dm_start_rf_discover () flags:0x00000003 disc_flags = 0x11
07-12 01:27:14.812 I/BrcmNfcNfa( 1006): nfa_ee_find_ecb ()
07-12 01:27:14.812 I/BrcmNfcNfa( 1006): nfa_ee_check_isodep_route_to_host: no route to DH
07-12 01:27:14.812 I/BrcmNfcNfa( 1006): nfa_ee_get_default_tech_routes(): 0x1
07-12 01:27:14.812 I/BrcmNfcNfa( 1006): default tech routes: 0x0, 0x0, 0x0, 0x0
07-12 01:27:14.812 I/BrcmNfcNfa( 1006): entry = 0, poll_mask = 0x00000000, listen_mask = 0x000A0000
07-12 01:27:14.812 I/BrcmNfcNfa( 1006): entry = 1, poll_mask = 0x000000EF, listen_mask = 0x00000000
07-12 01:27:14.812 I/BrcmNfcNfa( 1006): entry = 2, poll_mask = 0x00000000, listen_mask = 0x01A40000
07-12 01:27:14.812 I/BrcmNfcNfa( 1006): nfa_p2p_set_config ()
07-12 01:27:14.812 I/BrcmNfcNfa( 1006): LLCP_GetDiscoveryConfig ()
07-12 01:27:14.812 I/BrcmNfcNfa( 1006): nfa_dm_check_set_config ()
07-12 01:27:14.812 I/BrcmNfcNfa( 1006): dm_disc_mask = 0x1ae00ef
07-12 01:27:14.812 I/BrcmNfcNfa( 1006): nfa_dm_set_rf_listen_mode_config () tech_proto_mask = 0x01AE00EF
07-12 01:27:14.812 D/NfcAdaptation( 1006): NfcAdaptation::HalWrite
07-12 01:27:14.812 D/NfcNciHal( 1006): HaiWrite: enter; len=19
07-12 01:27:14.812 I/NfcNciHal( 1006): HAL_NfcWrite ()
07-12 01:27:14.812 D/NfcNciHal( 1006): HaiWrite: exit 0
07-12 01:27:14.812 I/NfcNciHal( 1006): nfc_hal_main_send_message() ls:0x1
07-12 01:27:14.813 I/BrcmNfcNfa( 1006): nfa_dm_set_total_duration ()
07-12 01:27:14.813 I/NfcNciHal( 1006): nfc_hal_dm_wake_nfcc () snooze_mode=8
07-12 01:27:14.813 I/BrcmNfcNfa( 1006): nfa_dm_check_set_config ()
07-12 01:27:14.813 I/NfcNciHal( 1006): p_buf->len: 19
07-12 01:27:14.813 I/BrcmNfcNfa( 1006): NFC_DiscoveryStart: enter
07-12 01:27:14.822 D/USERIAL_LINUX( 1006): USERIAL_Write len = 19, ret = 19
07-12 01:27:14.824 D/USERIAL_LINUX( 1006): my_read: return 5(0x5) bytes, errno=0 count=2, n=1, timeout=-1
07-12 01:27:14.824 D/USERIAL_LINUX( 1006): userial_read_thread(): enqueued p_buf=0x9422e608, count=1, length=5
07-12 01:27:14.824 D/USERIAL_LINUX( 1006): my_read: enter, pbuf=9422ddd0, len = 507
07-12 01:27:14.824 I/BrcmNci ( 1006): –
07-12 01:27:14.824 I/BrcmNci ( 1006): RECV NCI Type:RSP Name: CORE_SET_CONFIG(0x2) PBF:No/Last Param Len: 2/2 f:0x0
07-12 01:27:14.824 I/BrcmNci ( 1006): Status : OK (0x00)
07-12 01:27:14.824 I/BrcmNci ( 1006): Num Params : 0 (0x00)
07-12 01:27:14.824 D/BrcmNci ( 1006): Raw NCI Packet
07-12 01:27:14.824 D/BrcmNci ( 1006): 0000: 40 02 02 00 00 @…
07-12 01:27:14.824 I/NfcNciHal( 1006): nfc_hal_nci_preproc_rx_nci_msg() HAL State: 1
07-12 01:27:14.824 I/NfcNciHal( 1006): nfc_hal_dm_wake_nfcc () snooze_mode=8
07-12 01:27:14.824 D/NfcNciHal( 1006): BroadcomHalDataCallback: enter; len=5
07-12 01:27:14.824 D/NfcAdaptation( 1006): NfcAdaptation::HalDeviceContextDataCallback: len=5
07-12 01:27:14.824 I/BrcmNfcNfa( 1006): NFC received rsp gid:0
07-12 01:27:14.824 I/BrcmNfcNfa( 1006): nci_proc_core_rsp opcode:0x2
07-12 01:27:14.824 I/BrcmNfcNfa( 1006): nfa_dm_nfc_response_cback () NFC_SET_CONFIG_REVT(0x5002)
07-12 01:27:14.824 D/NfcAdaptation( 1006): NfcAdaptation::HalWrite
07-12 01:27:14.824 D/NfcNciHal( 1006): HaiWrite: enter; len=8
07-12 01:27:14.824 I/NfcNciHal( 1006): HAL_NfcWrite ()
07-12 01:27:14.824 D/NfcNciHal( 1006): HaiWrite: exit 0
07-12 01:27:14.825 I/NfcNciHal( 1006): nfc_hal_main_send_message() ls:0x1
07-12 01:27:14.825 I/NfcNciHal( 1006): nfc_hal_dm_wake_nfcc () snooze_mode=8
07-12 01:27:14.825 I/NfcNciHal( 1006): p_buf->len: 8
07-12 01:27:14.825 I/BrcmNci ( 1006): –
07-12 01:27:14.825 I/BrcmNci ( 1006): SENT NCI Type:CMD Name: CORE_SET_CONFIG(0x2) PBF:No/Last Param Len: 5/5 f:0x0
07-12 01:27:14.825 I/BrcmNci ( 1006): Num Params : 1 (0x01)
07-12 01:27:14.825 I/BrcmNci ( 1006): Param ID [0] : (0/0x00) TOTAL_DURATION
07-12 01:27:14.825 I/BrcmNci ( 1006): Param Len[0] : 2 (0x02)
07-12 01:27:14.825 I/BrcmNci ( 1006): Param Val[0] : f4 01
07-12 01:27:14.825 D/BrcmNci ( 1006): Raw NCI Packet
07-12 01:27:14.825 D/BrcmNci ( 1006): 0000: 20 02 05 01 00 02 f4 01 …
07-12 01:27:14.825 D/USERIAL_LINUX( 1006): USERIAL_Write: (8 bytes)
07-12 01:27:14.825 D/USERIAL_LINUX( 1006): doWriteDelay() delay 2 ms
07-12 01:27:14.829 D/NuPlayerDriver( 240): reset(0xb0b07180) at state 6
07-12 01:27:14.829 D/NuPlayerDriver( 240): notifyListener_l(0xb0b07180), (8, 0, 0), loop setting(0, 0)
07-12 01:27:14.832 D/USERIAL_LINUX( 1006): USERIAL_Write len = 8, ret = 8
07-12 01:27:14.833 D/wifi ( 466): android_net_wifi_setLinkLayerStats: 1
07-12 01:27:14.833 D/RttService( 466): SCAN_AVAILABLE : 3
07-12 01:27:14.833 I/WifiConnectivityManager( 466): Set WiFi enabled
07-12 01:27:14.834 I/WifiConnectivityManager( 466): scheduleWatchdogTimer
07-12 01:27:14.834 D/RttService( 466): DefaultState got{ when=-1ms what=160512 target=com.android.internal.util.StateMachine$SmHandler }
07-12 01:27:14.836 I/WifiHAL ( 466): Got channel list with 13 channels
07-12 01:27:14.837 D/USERIAL_LINUX( 1006): my_read: return 5(0x5) bytes, errno=0 count=2, n=1, timeout=-1
07-12 01:27:14.837 D/USERIAL_LINUX( 1006): userial_read_thread(): enqueued p_buf=0x9422ddc8, count=1, length=5
07-12 01:27:14.837 D/USERIAL_LINUX( 1006): my_read: enter, pbuf=9422e820, len = 507
07-12 01:27:14.837 I/BrcmNci ( 1006): –
07-12 01:27:14.837 I/BrcmNci ( 1006): RECV NCI Type:RSP Name: CORE_SET_CONFIG(0x2) PBF:No/Last Param Len: 2/2 f:0x0
07-12 01:27:14.837 I/BrcmNci ( 1006): Status : OK (0x00)
07-12 01:27:14.837 I/BrcmNci ( 1006): Num Params : 0 (0x00)
07-12 01:27:14.837 D/BrcmNci ( 1006): Raw NCI Packet
07-12 01:27:14.837 D/BrcmNci ( 1006): 0000: 40 02 02 00 00 @…
07-12 01:27:14.837 I/NfcNciHal( 1006): nfc_hal_nci_preproc_rx_nci_msg() HAL State: 1
07-12 01:27:14.837 I/NfcNciHal( 1006): nfc_hal_dm_wake_nfcc () snooze_mode=8
07-12 01:27:14.837 D/NfcNciHal( 1006): BroadcomHalDataCallback: enter; len=5
07-12 01:27:14.837 D/NfcAdaptation( 1006): NfcAdaptation::HalDeviceContextDataCallback: len=5
07-12 01:27:14.837 I/BrcmNfcNfa( 1006): NFC received rsp gid:0
07-12 01:27:14.838 I/BrcmNfcNfa( 1006): nci_proc_core_rsp opcode:0x2
07-12 01:27:14.838 I/BrcmNfcNfa( 1006): nfa_dm_nfc_response_cback () NFC_SET_CONFIG_REVT(0x5002)
07-12 01:27:14.838 D/NfcAdaptation( 1006): NfcAdaptation::HalPrediscover
07-12 01:27:14.838 D/NfcNciHal( 1006): HaiPreDiscover: enter
07-12 01:27:14.838 I/NfcNciHal( 1006): HAL_NfcPreDiscover ()
07-12 01:27:14.838 I/NfcNciHal( 1006): HAL_NfcPreDiscover status:0
07-12 01:27:14.838 D/NfcNciHal( 1006): HaiPreDiscover: exit 0
07-12 01:27:14.838 D/NfcAdaptation( 1006): NfcAdaptation::HalWrite
07-12 01:27:14.838 D/NfcNciHal( 1006): HaiWrite: enter; len=28
07-12 01:27:14.838 I/NfcNciHal( 1006): HAL_NfcWrite ()
07-12 01:27:14.838 D/NfcNciHal( 1006): HaiWrite: exit 0
07-12 01:27:14.838 I/NfcNciHal( 1006): nfc_hal_main_send_message() ls:0x1
07-12 01:27:14.838 I/NfcNciHal( 1006): nfc_hal_dm_wake_nfcc () snooze_mode=8
07-12 01:27:14.838 I/NfcNciHal( 1006): p_buf->len: 28
07-12 01:27:14.838 I/BrcmNci ( 1006): –
07-12 01:27:14.838 I/BrcmNci ( 1006): SENT NCI Type:CMD Name: RF_DISCOVER(0x3) PBF:No/Last Param Len: 25/25 f:0x0
07-12 01:27:14.838 I/BrcmNci ( 1006): Num Discovery Cfg : 12 (0x0c)
07-12 01:27:14.838 I/BrcmNci ( 1006): Poll_A : 0 (0x00)
07-12 01:27:14.838 I/BrcmNci ( 1006): Frequency : 1 (0x01)
07-12 01:27:14.838 I/BrcmNci ( 1006): Poll_B : 1 (0x01)
07-12 01:27:14.838 I/BrcmNci ( 1006): Poll_F : 2 (0x02)
07-12 01:27:14.838 I/BrcmNci ( 1006): POLL_A_ACTIVE : 3 (0x03)
07-12 01:27:14.838 I/BrcmNci ( 1006): POLL_F_ACTIVE : 5 (0x05)
07-12 01:27:14.838 I/BrcmNci ( 1006): Listen_A : 128 (0x80)
07-12 01:27:14.838 I/BrcmNci ( 1006): Listen_B : 129 (0x81)
07-12 01:27:14.838 I/BrcmNci ( 1006): Listen_F : 130 (0x82)
07-12 01:27:14.838 I/BrcmNci ( 1006): LISTEN_A_ACTIVE : 131 (0x83)
07-12 01:27:14.838 I/BrcmNci ( 1006): LISTEN_F_ACTIVE : 133 (0x85)
07-12 01:27:14.838 I/BrcmNci ( 1006): POLL_ISO15693 : 6 (0x06)
07-12 01:27:14.838 I/BrcmNci ( 1006): POLL_KOVIO : 119 (0x77)
07-12 01:27:14.839 D/BrcmNci ( 1006): Raw NCI Packet
07-12 01:27:14.839 D/BrcmNci ( 1006): 0000: 21 03 19 0c 00 01 01 01 02 01 03 01 05 01 80 01 !..
07-12 01:27:14.839 D/BrcmNci ( 1006): 0010: 81 01 82 01 83 01 85 01 06 01 77 01 …w.
07-12 01:27:14.839 I/BrcmNci ( 1006): –
07-12 01:27:14.839 D/USERIAL_LINUX( 1006): USERIAL_Write: (28 bytes)
07-12 01:27:14.839 I/WifiHAL ( 466): Got channel list with 9 channels
07-12 01:27:14.839 W/AMessage( 240): failed to post message as target looper for handler 0 is gone.
07-12 01:27:14.840 D/NuPlayerDriver( 240): notifyResetComplete(0xb0b07180)
07-12 01:27:14.841 I/WifiHAL ( 466): Got channel list with 4 channels
07-12 01:27:14.841 W/CommandListener( 241): Failed to retrieve HW addr for p2p0 (No such device)
07-12 01:27:14.843 D/CommandListener( 241): Setting iface cfg
07-12 01:27:14.846 E/WifiP2pService( 466): Unable to change interface settings: java.lang.IllegalStateException: command ‘32 interface setcfg p2p0 0.0.0.0 0 up’ failed with ‘400 32 Failed to clear address (No such device)’
07-12 01:27:14.846 D/WifiMonitor( 466): startMonitoring(p2p0) with mConnected = true
07-12 01:27:14.849 D/USERIAL_LINUX( 1006): USERIAL_Write len = 28, ret = 28
07-12 01:27:14.850 D/WIFI ( 466): got request NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 0
07-12 01:27:14.850 I/WifiScanningService( 466): wifi driver loaded with scan capabilities: max buckets=8
07-12 01:27:14.850 I/WifiConnectivityManager( 466): Set WiFiConnectivityManager enabled
07-12 01:27:14.850 D/USERIAL_LINUX( 1006): my_read: return 4(0x4) bytes, errno=0 count=1, n=1, timeout=-1
07-12 01:27:14.850 D/USERIAL_LINUX( 1006): userial_read_thread(): enqueued p_buf=0x9422e818, count=1, length=4
07-12 01:27:14.850 D/USERIAL_LINUX( 1006): my_read: enter, pbuf=9422e400, len = 507
07-12 01:27:14.851 I/BrcmNci ( 1006): –
07-12 01:27:14.851 I/BrcmNci ( 1006): RECV NCI Type:RSP Name: RF_DISCOVER(0x3) PBF:No/Last Param Len: 1/1 f:0x0
07-12 01:27:14.851 I/BrcmNci ( 1006): Status : OK (0x00)
07-12 01:27:14.851 D/BrcmNci ( 1006): Raw NCI Packet
07-12 01:27:14.851 D/BrcmNci ( 1006): 0000: 41 03 01 00 A…
07-12 01:27:14.851 I/NfcNciHal( 1006): nfc_hal_nci_preproc_rx_nci_msg() HAL State: 1
07-12 01:27:14.851 I/NfcNciHal( 1006): nfc_hal_dm_wake_nfcc () snooze_mode=8
07-12 01:27:14.851 D/NfcNciHal( 1006): BroadcomHalDataCallback: enter; len=4
07-12 01:27:14.851 D/NfcAdaptation( 1006): NfcAdaptation::HalDeviceContextDataCallback: len=4
07-12 01:27:14.851 I/BrcmNfcNfa( 1006): NFC received rsp gid:1
07-12 01:27:14.851 I/BrcmNfcNfa( 1006): p2p priority is running under bail out mode ONLY.
07-12 01:27:14.851 I/BrcmNfcNfa( 1006): nfc_ncif_rf_management_status: callback for discovery start
07-12 01:27:14.851 D/WIFI_UT ( 466): got request NetworkRequest [ REQUEST id=1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 0
07-12 01:27:14.851 I/BrcmNfcNfa( 1006): nfa_dm_disc_discovery_cback (): event:0x4000
07-12 01:27:14.851 I/BrcmNfcNfa( 1006): nfa_dm_disc_sm_execute (): state: IDLE (0), event: DISCOVER_RSP(1) disc_flags: 0x31
07-12 01:27:14.851 I/BrcmNfcNfa( 1006): nfa_dm_disc_new_state (): old_state: IDLE (0), new_state: DISCOVERY (1) disc_flags: 0x11
07-12 01:27:14.851 D/BrcmNfcJni( 1006): nfaConnectionCallback: event= 30
07-12 01:27:14.851 D/BrcmNfcJni( 1006): nfaConnectionCallback: NFA_RF_DISCOVERY_STARTED_EVT: status = 0
07-12 01:27:14.851 I/BrcmNfcNfa( 1006): nfa_dm_disc_sm_execute (): new state: DISCOVERY (1), disc_flags: 0x1
07-12 01:27:14.851 D/BrcmNfcJni( 1006): startRfDiscovery: unlocked
07-12 01:27:14.851 D/BrcmNfcJni( 1006): PowerSwitch::setModeOn(activated=0x1) : mCurrActivity=0x1
07-12 01:27:14.851 D/BrcmNfcJni( 1006): nfcManager_enableDiscoveryImpl: exit
07-12 01:27:14.851 D/BrcmNfcJni( 1006): nfcManager_enableDiscovery: exit
07-12 01:27:14.852 D/BrcmNfcJni( 1006): nfcManager_reRouteAid: enter; aid len=1; ee id=0x0
07-12 01:27:14.852 D/BrcmNfcJni( 1006): nfcManager_reRouteAid: stop discovery
07-12 01:27:14.852 D/BrcmNfcJni( 1006): startRfDiscovery: locked; start=0
07-12 01:27:14.852 I/BrcmNfcNfa( 1006): NFA_StopRfDiscovery ()
07-12 01:27:14.852 I/BrcmNfcNfa( 1006): NFA got event 0x0111
07-12 01:27:14.852 I/BrcmNfcNfa( 1006): nfa_dm_evt_hdlr event: NFA_DM_API_STOP_RF_DISCOVERY_EVT (0x11)
07-12 01:27:14.852 I/BrcmNfcNfa( 1006): nfa_dm_act_stop_rf_discovery ()
07-12 01:27:14.852 I/BrcmNfcNfa( 1006): nfa_dm_rf_deactivate () deactivate_type:0x0
07-12 01:27:14.852 I/BrcmNfcNfa( 1006): nfa_dm_disc_sm_execute (): state: DISCOVERY (1), event: DEACTIVATE_CMD(6) disc_flags: 0x2
07-12 01:27:14.852 I/BrcmNfcNfa( 1006): nfa_dm_disc_sm_discovery () flags:0x00000003 disc_flags = 0x2
07-12 01:27:14.852 I/BrcmNfcNfa( 1006): NFC_Deactivate 4 (IDLE) deactivate_type:0
07-12 01:27:14.852 D/NfcAdaptation( 1006): NfcAdaptation::HalWrite
07-12 01:27:14.852 D/NfcNciHal( 1006): HaiWrite: enter; len=4
07-12 01:27:14.852 I/NfcNciHal( 1006): HAL_NfcWrite ()
07-12 01:27:14.852 D/NfcNciHal( 1006): HaiWrite: exit 0
07-12 01:27:14.852 I/BrcmNfcNfa( 1006): nfa_dm_disc_sm_execute (): new state: DISCOVERY (1), disc_flags: 0x22
07-12 01:27:14.852 I/NfcNciHal( 1006): nfc_hal_main_send_message() ls:0x1
07-12 01:27:14.852 I/NfcNciHal( 1006): nfc_hal_dm_wake_nfcc () snooze_mode=8
07-12 01:27:14.852 I/NfcNciHal( 1006): p_buf->len: 4
07-12 01:27:14.852 I/BrcmNci ( 1006): –
07-12 01:27:14.852 I/BrcmNci ( 1006): SENT NCI Type:CMD Name: RF_DEACTIVATE(0x6) PBF:No/Last Param Len: 1/1 f:0x0
07-12 01:27:14.852 I/BrcmNci ( 1006): De-Activate Type : Idle Mode (0/0x00)
07-12 01:27:14.852 D/BrcmNci ( 1006): Raw NCI Packet
07-12 01:27:14.852 D/BrcmNci ( 1006): 0000: 21 06 01 00 !..
07-12 01:27:14.852 D/USERIAL_LINUX( 1006): USERIAL_Write: (4 bytes)
07-12 01:27:14.852 D/USERIAL_LINUX( 1006): doWriteDelay() delay 1 ms
07-12 01:27:14.854 D/WifiNative-HAL( 466): p2pGetDeviceAddress
07-12 01:27:14.858 D/WifiNative-HAL( 466): p2pGetDeviceAddress returning 2a:ed:e0:3d:84:ab
07-12 01:27:14.859 D/USERIAL_LINUX( 1006): USERIAL_Write len = 4, ret = 4
07-12 01:27:14.863 I/WifiHAL ( 466): Got channel list with 13 channels
07-12 01:27:14.863 I/WifiHAL ( 466): Got channel list with 9 channels
07-12 01:27:14.863 D/USERIAL_LINUX( 1006): my_read: return 4(0x4) bytes, errno=0 count=1, n=1, timeout=-1
07-12 01:27:14.864 D/USERIAL_LINUX( 1006): userial_read_thread(): enqueued p_buf=0x9422e3f8, count=1, length=4
07-12 01:27:14.864 D/USERIAL_LINUX( 1006): my_read: enter, pbuf=9422d380, len = 507
07-12 01:27:14.864 I/WifiHAL ( 466): Got channel list with 4 channels
07-12 01:27:14.865 I/BrcmNci ( 1006): –
07-12 01:27:14.865 I/BrcmNci ( 1006): RECV NCI Type:RSP Name: RF_DEACTIVATE(0x6) PBF:No/Last Param Len: 1/1 f:0x0
07-12 01:27:14.865 I/BrcmNci ( 1006): Status : OK (0x00)
07-12 01:27:14.865 D/BrcmNci ( 1006): Raw NCI Packet
07-12 01:27:14.866 D/BrcmNci ( 1006): 0000: 41 06 01 00 A…
07-12 01:27:14.866 I/BrcmNci ( 1006): –
07-12 01:27:14.866 I/NfcNciHal( 1006): nfc_hal_nci_preproc_rx_nci_msg() HAL State: 1
07-12 01:27:14.866 I/NfcNciHal( 1006): nfc_hal_dm_wake_nfcc () snooze_mode=8
07-12 01:27:14.866 D/NfcNciHal( 1006): BroadcomHalDataCallback: enter; len=4
07-12 01:27:14.866 D/NfcAdaptation( 1006): NfcAdaptation::HalDeviceContextDataCallback: len=4
07-12 01:27:14.866 I/BrcmNfcNfa( 1006): NFC received rsp gid:1
07-12 01:27:14.866 I/BrcmNfcNfa( 1006): p2p priority is running under bail out mode ONLY.
07-12 01:27:14.866 I/BrcmNfcNfa( 1006): nfc_set_state 4 (IDLE)->4 (IDLE)
07-12 01:27:14.866 I/BrcmNfcNfa( 1006): nfa_dm_disc_data_cback ()
07-12 01:27:14.866 I/BrcmNfcNfa( 1006): nfa_dm_disc_discovery_cback (): event:0x4005
07-12 01:27:14.866 I/BrcmNfcNfa( 1006): nfa_dm_disc_sm_execute (): state: DISCOVERY (1), event: DEACTIVATE_RSP(7) disc_flags: 0x22
07-12 01:27:14.866 I/BrcmNfcNfa( 1006): nfa_dm_disc_sm_discovery () flags:0x00000003 disc_flags = 0x22
07-12 01:27:14.866 I/BrcmNfcNfa( 1006): nfa_dm_disc_new_state (): old_state: DISCOVERY (1), new_state: IDLE (0) disc_flags: 0x2
07-12 01:27:14.866 D/BrcmNfcJni( 1006): nfaConnectionCallback: event= 31
07-12 01:27:14.866 D/BrcmNfcJni( 1006): nfaConnectionCallback: NFA_RF_DISCOVERY_STOPPED_EVT: status = 0
07-12 01:27:14.866 I/BrcmNfcNfa( 1006): nfa_dm_start_rf_discover () flags:0x00000003 disc_flags = 0x0
07-12 01:27:14.866 I/BrcmNfcNfa( 1006): nfa_dm_disc_sm_execute (): new state: IDLE (0), disc_flags: 0x0
07-12 01:27:14.866 D/BrcmNfcJni( 1006): startRfDiscovery: unlocked
07-12 01:27:14.866 D/BrcmNfcJni( 1006): nfcManager_reRouteAid: exit
07-12 01:27:14.866 D/BrcmNfcJni( 1006): nfcManager_reRouteAid: enter; aid len=1; ee id=0x0
07-12 01:27:14.866 D/BrcmNfcJni( 1006): RoutingManager::updateRouting: enter, screenState=4 mDefaultEe=0xf5
07-12 01:27:14.866 D/BrcmNfcJni( 1006): RoutingManager::applyStaticRoutes: set tech routing; ee id=0xF5; tech mask=0x0
07-12 01:27:14.866 D/BrcmNfcJni( 1006): SecureElement::applyTechnologyRoutes: enter
07-12 01:27:14.866 D/BrcmNfcJni( 1006): SecureElement::applyTechnologyRoutes: exit
07-12 01:27:14.866 D/BrcmNfcJni( 1006): RoutingManager::applyStaticRoutes: set proto routing; ee id=0xF5; proto mask=0x8
07-12 01:27:14.866 D/BrcmNfcJni( 1006): SecureElement::applyProtocolRoutes: enter
07-12 01:27:14.866 D/BrcmNfcJni( 1006): SecureElement::applyProtocolRoutes: exit
07-12 01:27:14.866 D/BrcmNfcJni( 1006): RoutingManager::applyStaticRoutes: set aid static routing
07-12 01:27:14.866 D/BrcmNfcJni( 1006): SecureElement::applyAidRoutes: enter
07-12 01:27:14.866 D/BrcmNfcJni( 1006): SecureElement::applyAidRoutes: exit
07-12 01:27:14.866 D/BrcmNfcJni( 1006): RoutingManager::updateRouting: update now
07-12 01:27:14.866 I/BrcmNfcNfa( 1006): NFA_EeUpdateNow()
07-12 01:27:14.867 I/BrcmNfcNfa( 1006): NFA got event 0x0209
07-12 01:27:14.867 I/BrcmNfcNfa( 1006): nfa_ee_evt_hdlr (): Event API_UPDATE_NOW(0x209), State: INIT_DONE(1)
07-12 01:27:14.867 I/BrcmNfcNfa( 1006): nfa_ee_api_update_now() ee_wait_evt:0x0, wait_rsp:0, em_state:1
07-12 01:27:14.867 I/BrcmNfcNfa( 1006): nfa_ee_update_route()
07-12 01:27:14.867 I/BrcmNfcNfa( 1006): last_active: 0xf6
07-12 01:27:14.867 I/BrcmNfcNfa( 1006): nfa_ee_add_aid_routing() num_aid = 0
07-12 01:27:14.867 I/BrcmNfcNfa( 1006): nfa_ee_route_add_one_ecb() nfcee_id:0x0, more:1, num_tlv_in_buff:0, tlv_size_in_buff:0
07-12 01:27:14.867 I/BrcmNfcNfa( 1006): nfa_ee_check_set_routing() next_tlv_size:15, current:0, max_tlv:253
07-12 01:27:14.867 I/BrcmNfcNfa( 1006): nfa_ee_route_add_one_ecb() nfcee_id:0xf2, more:1, num_tlv_in_buff:3, tlv_size_in_buff:15
07-12 01:27:14.867 I/BrcmNfcNfa( 1006): nfa_ee_check_set_routing() next_tlv_size:0, current:15, max_tlv:253
07-12 01:27:14.867 I/BrcmNfcNfa( 1006): nfa_ee_route_add_one_ecb() nfcee_id:0xf6, more:0, num_tlv_in_buff:3, tlv_size_in_buff:15
07-12 01:27:14.867 I/BrcmNfcNfa( 1006): nfa_ee_route_add_one_ecb(): set last routing total_lmrt_size:15
07-12 01:27:14.867 D/NfcAdaptation( 1006): NfcAdaptation::HalWrite
07-12 01:27:14.867 D/NfcNciHal( 1006): HaiWrite: enter; len=20
07-12 01:27:14.867 I/NfcNciHal( 1006): HAL_NfcWrite ()
07-12 01:27:14.867 D/NfcNciHal( 1006): HaiWrite: exit 0
07-12 01:27:14.867 I/NfcNciHal( 1006): nfc_hal_main_send_message() ls:0x1
07-12 01:27:14.867 I/BrcmNfcNfa( 1006): nfa_ee_vsc_to_nfcc() em_state:1
07-12 01:27:14.867 I/NfcNciHal( 1006): nfc_hal_dm_wake_nfcc () snooze_mode=8
07-12 01:27:14.867 I/BrcmNfcNfa( 1006): nfa_ee_get_default_tech_routes(): 0x2
07-12 01:27:14.867 I/NfcNciHal( 1006): p_buf->len: 20
07-12 01:27:14.867 I/BrcmNfcNfa( 1006): default tech routes: 0x0, 0x0, 0x0, 0x0
07-12 01:27:14.867 I/BrcmNci ( 1006): –
07-12 01:27:14.867 I/BrcmNfcNfa( 1006): nfa_ee_brcm_get_aa_data(): 0x00 00
07-12 01:27:14.867 D/NfcAdaptation( 1006): NfcAdaptation::HalGetInfo: paramId=0x10002
07-12 01:27:14.867 I/BrcmNci ( 1006): SENT NCI Type:CMD Name: RF_SET_ROUTING(0x1) PBF:No/Last Param Len: 17/17 f:0x0
07-12 01:27:14.867 D/NfcNciHal( 1006): HaiRunVendorCommand: enter; command id=0x10002
07-12 01:27:14.867 I/BrcmNci ( 1006): More : FALSE (0x00)
07-12 01:27:14.867 I/NfcNciHal( 1006): ACCESS_APP_VSC_NOT_SUPPORTED: 1
07-12 01:27:14.867 I/BrcmNci ( 1006): Num Routing : 3 (0x03)
07-12 01:27:14.867 I/NfcNciHal( 1006): HAL_NfcInfo: 0x10002 ret:1
07-12 01:27:14.867 I/BrcmNci ( 1006): Route : 0 (0x00)
07-12 01:27:14.867 D/NfcNciHal( 1006): HaiRunVendorCommand: exit 0
07-12 01:27:14.867 I/BrcmNci ( 1006): TECH (0) : F/2 On
07-12 01:27:14.867 I/BrcmNfcNfa( 1006): for update now old_lpm_rsp; 0, lpm_rsp: 0
07-12 01:27:14.867 I/BrcmNfcNfa( 1006): ee_wait_evt:0x40 lpm_rsp:0 lpm_ntf:0
07-12 01:27:14.867 I/BrcmNci ( 1006): PROTO (1) : T3T On Off B_Off
07-12 01:27:14.867 I/BrcmNfcNfa( 1006): nfa_ee_update_route() ee_wait_evt:0x60, wait_rsp:1 st:1
07-12 01:27:14.867 I/BrcmNci ( 1006): PROTO (1) : NFC On
07-12 01:27:14.867 D/BrcmNci ( 1006): Raw NCI Packet
07-12 01:27:14.867 D/BrcmNci ( 1006): 0000: 21 01 11 00 03 00 03 00 01 02 01 03 00 07 03 01 !..
07-12 01:27:14.867 D/BrcmNci ( 1006): 0010: 03 00 01 05 …
07-12 01:27:14.867 D/USERIAL_LINUX( 1006): USERIAL_Write: (20 bytes)
07-12 01:27:14.877 D/USERIAL_LINUX( 1006): my_read: return 4(0x4) bytes, errno=0 count=1, n=1, timeout=-1
07-12 01:27:14.877 D/USERIAL_LINUX( 1006): userial_read_thread(): enqueued p_buf=0x9422d378, count=1, length=4
07-12 01:27:14.877 D/USERIAL_LINUX( 1006): my_read: enter, pbuf=9422dbc0, len = 507
07-12 01:27:14.877 D/USERIAL_LINUX( 1006): USERIAL_Write len = 20, ret = 20
07-12 01:27:14.877 I/BrcmNci ( 1006): –
07-12 01:27:14.877 I/BrcmNci ( 1006): RECV NCI Type:RSP Name: RF_SET_ROUTING(0x1) PBF:No/Last Param Len: 1/1 f:0x0
07-12 01:27:14.877 I/BrcmNci ( 1006): Status : OK (0x00)
07-12 01:27:14.877 D/BrcmNci ( 1006): Raw NCI Packet
07-12 01:27:14.877 D/BrcmNci ( 1006): 0000: 41 01 01 00 A…
07-12 01:27:14.877 I/NfcNciHal( 1006): nfc_hal_nci_preproc_rx_nci_msg() HAL State: 1
07-12 01:27:14.877 I/NfcNciHal( 1006): nfc_hal_dm_wake_nfcc () snooze_mode=8
07-12 01:27:14.877 D/NfcNciHal( 1006): BroadcomHalDataCallback: enter; len=4
07-12 01:27:14.877 D/NfcAdaptation( 1006): NfcAdaptation::HalDeviceContextDataCallback: len=4
07-12 01:27:14.877 I/BrcmNfcNfa( 1006): NFC received rsp gid:1
07-12 01:27:14.877 I/BrcmNfcNfa( 1006): nfa_dm_nfc_response_cback () NFC_SET_ROUTING_REVT(0x500a)
07-12 01:27:14.877 I/BrcmNfcNfa( 1006): nfa_ee_proc_evt: event=0x500a int_event:0x21b
07-12 01:27:14.877 I/BrcmNfcNfa( 1006): nfa_ee_evt_hdlr (): Event NCI_WAIT_RSP(0x21b), State: INIT_DONE(1)
07-12 01:27:14.878 I/BrcmNfcNfa( 1006): nfa_ee_nci_wait_rsp() ee_wait_evt:0x70 wait_rsp:1
07-12 01:27:14.878 I/BrcmNfcNfa( 1006): nfa_ee_report_update_evt ee_wait_evt:0x70, wait_rsp:0
07-12 01:27:14.878 D/BrcmNfcJni( 1006): RoutingManager::nfaEeCallback: NFA_EE_UPDATED_EVT
07-12 01:27:14.878 I/BrcmNfcNfa( 1006): nfa_ee_report_update_evt ee_wait_evt:0x40 lpm_rsp:0 lpm_ntf:0
07-12 01:27:14.878 D/BrcmNfcJni( 1006): RoutingManager::nfaEeCallback: NFA_EE_LPM_UPDATED_EVT
07-12 01:27:14.878 D/BrcmNfcJni( 1006): nfcManager_reRouteAid: start discovery
07-12 01:27:14.878 D/BrcmNfcJni( 1006): startRfDiscovery: locked; start=1
07-12 01:27:14.878 I/BrcmNfcNfa( 1006): NFA_StartRfDiscovery ()
07-12 01:27:14.878 I/BrcmNfcNfa( 1006): NFA got event 0x0110
07-12 01:27:14.878 I/BrcmNfcNfa( 1006): nfa_dm_evt_hdlr event: NFA_DM_API_START_RF_DISCOVERY_EVT (0x10)
07-12 01:27:14.878 I/BrcmNfcNfa( 1006): nfa_dm_act_start_rf_discovery ()
07-12 01:27:14.878 I/BrcmNfcNfa( 1006): nfa_dm_start_rf_discover () flags:0x00000003 disc_flags = 0x11
07-12 01:27:14.878 I/BrcmNfcNfa( 1006): nfa_ee_find_ecb ()
07-12 01:27:14.878 I/BrcmNfcNfa( 1006): nfa_ee_check_isodep_route_to_host: no route to DH
07-12 01:27:14.878 I/BrcmNfcNfa( 1006): nfa_ee_get_default_tech_routes(): 0x1
07-12 01:27:14.878 I/BrcmNfcNfa( 1006): default tech routes: 0x0, 0x0, 0x0, 0x0
07-12 01:27:14.878 I/BrcmNfcNfa( 1006): entry = 0, poll_mask = 0x00000000, listen_mask = 0x000A0000
07-12 01:27:14.878 I/BrcmNfcNfa( 1006): entry = 1, poll_mask = 0x000000EF, listen_mask = 0x00000000
07-12 01:27:14.878 I/BrcmNfcNfa( 1006): entry = 2, poll_mask = 0x00000000, listen_mask = 0x01A40000
07-12 01:27:14.878 I/BrcmNfcNfa( 1006): nfa_p2p_set_config ()
07-12 01:27:14.878 I/BrcmNfcNfa( 1006): LLCP_GetDiscoveryConfig ()
07-12 01:27:14.878 I/BrcmNfcNfa( 1006): nfa_dm_check_set_config ()
07-12 01:27:14.878 I/BrcmNfcNfa( 1006): dm_disc_mask = 0x1ae00ef
07-12 01:27:14.878 I/BrcmNfcNfa( 1006): nfa_dm_set_rf_listen_mode_config () tech_proto_mask = 0x01AE00EF
07-12 01:27:14.878 I/BrcmNfcNfa( 1006): nfa_dm_set_total_duration ()
07-12 01:27:14.878 I/BrcmNfcNfa( 1006): NFC_DiscoveryStart: enter
07-12 01:27:14.878 D/NfcAdaptation( 1006): NfcAdaptation::HalPrediscover
07-12 01:27:14.878 D/NfcNciHal( 1006): HaiPreDiscover: enter
07-12 01:27:14.878 I/NfcNciHal( 1006): HAL_NfcPreDiscover ()
07-12 01:27:14.878 I/NfcNciHal( 1006): HAL_NfcPreDiscover status:0
07-12 01:27:14.878 D/NfcNciHal( 1006): HaiPreDiscover: exit 0
07-12 01:27:14.878 D/NfcAdaptation( 1006): NfcAdaptation::HalWrite
07-12 01:27:14.878 D/NfcNciHal( 1006): HaiWrite: enter; len=28
07-12 01:27:14.878 I/NfcNciHal( 1006): HAL_NfcWrite ()
07-12 01:27:14.878 D/NfcNciHal( 1006): HaiWrite: exit 0
07-12 01:27:14.878 I/NfcNciHal( 1006): nfc_hal_main_send_message() ls:0x1
07-12 01:27:14.878 I/BrcmNfcNfa( 1006): NFC_DiscoveryStart: exit; status: 0x0
07-12 01:27:14.878 I/NfcNciHal( 1006): nfc_hal_dm_wake_nfcc () snooze_mode=8
07-12 01:27:14.878 I/NfcNciHal( 1006): p_buf->len: 28
07-12 01:27:14.878 I/BrcmNci ( 1006): –
07-12 01:27:14.878 I/BrcmNci ( 1006): SENT NCI Type:CMD Name: RF_DISCOVER(0x3) PBF:No/Last Param Len: 25/25 f:0x0
07-12 01:27:14.879 I/BrcmNci ( 1006): Num Discovery Cfg : 12 (0x0c)
07-12 01:27:14.879 I/BrcmNci ( 1006): Poll_A : 0 (0x00)
07-12 01:27:14.879 I/BrcmNci ( 1006): Frequency : 1 (0x01)
07-12 01:27:14.879 I/BrcmNci ( 1006): Poll_B : 1 (0x01)
07-12 01:27:14.879 I/BrcmNci ( 1006): Poll_F : 2 (0x02)
07-12 01:27:14.879 I/BrcmNci ( 1006): POLL_A_ACTIVE : 3 (0x03)
07-12 01:27:14.879 I/BrcmNci ( 1006): POLL_F_ACTIVE : 5 (0x05)
07-12 01:27:14.879 I/BrcmNci ( 1006): Listen_A : 128 (0x80)
07-12 01:27:14.879 I/BrcmNci ( 1006): Listen_B : 129 (0x81)
07-12 01:27:14.879 I/BrcmNci ( 1006): Listen_F : 130 (0x82)
07-12 01:27:14.879 I/BrcmNci ( 1006): LISTEN_A_ACTIVE : 131 (0x83)
07-12 01:27:14.879 I/BrcmNci ( 1006): LISTEN_F_ACTIVE : 133 (0x85)
07-12 01:27:14.879 I/BrcmNci ( 1006): POLL_ISO15693 : 6 (0x06)
07-12 01:27:14.879 I/BrcmNci ( 1006): POLL_KOVIO : 119 (0x77)
07-12 01:27:14.879 D/BrcmNci ( 1006): Raw NCI Packet
07-12 01:27:14.879 D/BrcmNci ( 1006): 0000: 21 03 19 0c 00 01 01 01 02 01 03 01 05 01 80 01 !..
07-12 01:27:14.879 D/BrcmNci ( 1006): 0010: 81 01 82 01 83 01 85 01 06 01 77 01 …w.
07-12 01:27:14.879 I/BrcmNci ( 1006): –
07-12 01:27:14.879 D/USERIAL_LINUX( 1006): USERIAL_Write: (28 bytes)
07-12 01:27:14.879 D/USERIAL_LINUX( 1006): doWriteDelay() delay 2 ms
07-12 01:27:14.889 D/USERIAL_LINUX( 1006): USERIAL_Write len = 28, ret = 28
07-12 01:27:14.890 D/USERIAL_LINUX( 1006): my_read: return 4(0x4) bytes, errno=0 count=1, n=1, timeout=-1
07-12 01:27:14.890 D/USERIAL_LINUX( 1006): userial_read_thread(): enqueued p_buf=0x9422dbb8, count=1, length=4
07-12 01:27:14.890 D/USERIAL_LINUX( 1006): my_read: enter, pbuf=9422e610, len = 507
07-12 01:27:14.890 I/BrcmNci ( 1006): –
07-12 01:27:14.890 I/BrcmNci ( 1006): RECV NCI Type:RSP Name: RF_DISCOVER(0x3) PBF:No/Last Param Len: 1/1 f:0x0
07-12 01:27:14.890 I/BrcmNci ( 1006): Status : OK (0x00)
07-12 01:27:14.890 D/BrcmNci ( 1006): Raw NCI Packet
07-12 01:27:14.890 D/BrcmNci ( 1006): 0000: 41 03 01 00 A…
07-12 01:27:14.890 I/NfcNciHal( 1006): nfc_hal_nci_preproc_rx_nci_msg() HAL State: 1
07-12 01:27:14.890 I/NfcNciHal( 1006): nfc_hal_dm_wake_nfcc () snooze_mode=8
07-12 01:27:14.890 D/NfcNciHal( 1006): BroadcomHalDataCallback: enter; len=4
07-12 01:27:14.890 D/NfcAdaptation( 1006): NfcAdaptation::HalDeviceContextDataCallback: len=4
07-12 01:27:14.890 I/BrcmNfcNfa( 1006): NFC received rsp gid:1
07-12 01:27:14.890 I/BrcmNfcNfa( 1006): p2p priority is running under bail out mode ONLY.
07-12 01:27:14.890 I/BrcmNfcNfa( 1006): nfc_ncif_rf_management_status: callback for discovery start
07-12 01:27:14.890 I/BrcmNfcNfa( 1006): nfa_dm_disc_discovery_cback (): event:0x4000
07-12 01:27:14.890 I/BrcmNfcNfa( 1006): nfa_dm_disc_sm_execute (): state: IDLE (0), event: DISCOVER_RSP(1) disc_flags: 0x31
07-12 01:27:14.890 I/BrcmNfcNfa( 1006): nfa_dm_disc_new_state (): old_state: IDLE (0), new_state: DISCOVERY (1) disc_flags: 0x11
07-12 01:27:14.890 D/BrcmNfcJni( 1006): nfaConnectionCallback: event= 30
07-12 01:27:14.890 D/BrcmNfcJni( 1006): nfaConnectionCallback: NFA_RF_DISCOVERY_STARTED_EVT: status = 0
07-12 01:27:14.890 I/BrcmNfcNfa( 1006): nfa_dm_disc_sm_execute (): new state: DISCOVERY (1), disc_flags: 0x1
07-12 01:27:14.890 D/BrcmNfcJni( 1006): startRfDiscovery: unlocked
07-12 01:27:14.890 D/BrcmNfcJni( 1006): nfcManager_reRouteAid: exit
07-12 01:27:14.914 I/MediaCodec( 1006): callingProcessName:com.android.nfc
07-12 01:27:14.915 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:14.915 I/OMXClient( 1006): MuxOMX ctor
07-12 01:27:14.915 I/ACodec ( 1006): onAllocateComponent:6752 mSoftCodecPref:0 componentName:
07-12 01:27:14.916 I/ACodec ( 1006): onAllocateComponent:6783 mSoftCodecPref:0 componentName:OMX.google.vorbis.decoder
07-12 01:27:14.916 I/OMXMaster( 237): makeComponentInstance(OMX.google.vorbis.decoder) in mediacodec process
07-12 01:27:14.996 I/MediaCodec( 1006): callingProcessName:com.android.nfc
07-12 01:27:14.997 I/NfcNciHal( 1006): nci_brcm_snooze_timeout_cback ()
07-12 01:27:14.997 I/NfcNciHal( 1006): nfc_hal_dm_set_nfc_wake () DEASSERT
07-12 01:27:14.997 D/USERIAL_LINUX( 1006): UPIO_Set: upio=NFC_WAKE; state=OFF
07-12 01:27:14.997 D/USERIAL_LINUX( 1006): control_nfc_wake: state=OFF
07-12 01:27:14.997 D/USERIAL_LINUX( 1006): control_nfc_wake: ioctl return 0
07-12 01:27:14.997 I/MediaPlayerService( 240): MediaPlayerService::getOMX
07-12 01:27:14.997 I/OMXClient( 1006): MuxOMX ctor
07-12 01:27:14.997 I/ACodec ( 1006): onAllocateComponent:6752 mSoftCodecPref:0 componentName:
07-12 01:27:14.998 I/ACodec ( 1006): onAllocateComponent:6783 mSoftCodecPref:0 componentName:OMX.google.vorbis.decoder
07-12 01:27:14.998 I/OMXMaster( 237): makeComponentInstance(OMX.google.vorbis.decoder) in mediacodec process
07-12 01:27:15.436 I/LatinIME( 669): Timeout waiting for dictionary load
07-12 01:27:15.562 D/RecoveryReceiver( 1020): RECOVERY_STATE_FILE_TF:/mnt/external_sd/Recovery_state
07-12 01:27:15.589 I/ActivityManager( 466): Start proc 1219:android.rockchip.update.service/1000 for broadcast android.rockchip.update.service/.RKUpdateReceiver
07-12 01:27:15.654 D/RKUpdateReceiver( 1219): action = android.intent.action.MEDIA_MOUNTED
07-12 01:27:15.666 I/ActivityManager( 466): Start proc 1235:android.process.media/u0a7 for broadcast com.android.providers.downloads/.DownloadReceiver
07-12 01:27:15.697 W/System ( 1235): ClassLoader referenced unknown path: /system/priv-app/DownloadProvider/lib/arm
07-12 01:27:15.728 W/System ( 1235): ClassLoader referenced unknown path: /system/priv-app/MediaProvider/lib/arm
07-12 01:27:15.729 D/ApplicationLoaders( 1235): ignored Vulkan layer search path /system/priv-app/MediaProvider/lib/arm:/system/priv-app/MediaProvider/MediaProvider.apk!/lib/armeabi-v7a:/system/lib:/vendor/lib for namespace 0xb0574090
07-12 01:27:15.821 D/MediaScannerReceiver( 1235): action: android.intent.action.MEDIA_MOUNTED path: /storage/emulated/0
07-12 01:27:15.835 I/ActivityManager( 466): Start proc 1255:com.android.quicksearchbox/u0a51 for broadcast com.android.quicksearchbox/.SearchWidgetProvider
07-12 01:27:15.872 W/System ( 1255): ClassLoader referenced unknown path: /system/app/QuickSearchBox/lib/arm
07-12 01:27:16.043 D/xzj ( 466): ----keygurad drawn done,exit bootanim----
07-12 01:27:16.053 D/NfcService( 1006): Discovery configuration equal, not updating.
07-12 01:27:16.058 I/RecoverySystem( 466): No recovery log file
07-12 01:27:16.061 E/DisplayOutputManager( 646): Unable to connect to display device management service! - is it running yet?
07-12 01:27:16.061 D/HdmiReceiver( 646): hdmi receiver action=android.intent.action.BOOT_COMPLETED
07-12 01:27:16.061 D/HdmiReceiver( 646): BOOT_COMPLETED
07-12 01:27:16.065 D/Sensors ( 466): set batch: handle = 2, period_ns = 20000000ns, timeout = 0ns
07-12 01:27:16.065 D/Sensors ( 466): setDelay : 20000000 ns, (50.00 Hz)
07-12 01:27:16.065 I/Sensors ( 466): set active: handle = 2, enable = 1
07-12 01:27:16.069 D/PhoneStatusBar( 623): disable: < expand icons alerts system_info back home recent clock search quick_settings >
07-12 01:27:16.140 I/BootReceiver( 466): Copying audit failures to DropBox
07-12 01:27:16.140 I/BootReceiver( 466): Checking for fsck errors
07-12 01:27:16.145 W/System.err( 646): java.io.FileNotFoundException: /sys/class/graphics/fb0/dual_mode: open failed: ENOENT (No such file or directory)
07-12 01:27:16.146 W/System.err( 646): at libcore.io.IoBridge.open(IoBridge.java:455)
07-12 01:27:16.146 W/System.err( 646): at java.io.RandomAccessFile.(RandomAccessFile.java:247)
07-12 01:27:16.146 W/System.err( 646): at com.android.settings.HdmiReceiver$InitDualModeTask.doInBackground(HdmiReceiver.java:213)
07-12 01:27:16.146 W/System.err( 646): at com.android.settings.HdmiReceiver$InitDualModeTask.doInBackground(HdmiReceiver.java:208)
07-12 01:27:16.146 W/System.err( 646): at android.os.AsyncTask$2.call(AsyncTask.java:305)
07-12 01:27:16.147 W/System.err( 646): at java.util.concurrent.FutureTask.run(FutureTask.java:237)
07-12 01:27:16.147 W/System.err( 646): at android.os.AsyncTask$SerialExecutor$1.run(AsyncTask.java:243)
07-12 01:27:16.147 W/System.err( 646): at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1133)
07-12 01:27:16.147 W/System.err( 646): at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:607)
07-12 01:27:16.147 W/System.err( 646): at java.lang.Thread.run(Thread.java:761)
07-12 01:27:16.147 W/System.err( 646): Caused by: android.system.ErrnoException: open failed: ENOENT (No such file or directory)
07-12 01:27:16.147 W/System.err( 646): at libcore.io.Posix.open(Native Method)
07-12 01:27:16.147 W/System.err( 646): at libcore.io.BlockGuardOs.open(BlockGuardOs.java:187)
07-12 01:27:16.148 W/System.err( 646): at libcore.io.IoBridge.open(IoBridge.java:441)
07-12 01:27:16.148 W/System.err( 646): … 9 more
07-12 01:27:16.203 V/MediaScanner( 1235): pruneDeadThumbnailFiles… android.content.ContentProviderClient$CursorWrapperInner@4533cb2
07-12 01:27:16.222 V/MediaScanner( 1235): /pruneDeadThumbnailFiles… android.content.ContentProviderClient$CursorWrapperInner@4533cb2
07-12 01:27:16.224 D/StressTest( 1020): =========onReceive===rebootFlag:0
07-12 01:27:16.232 D/CarrierConfigLoader( 618): mHandler: 13 phoneId: 0
07-12 01:27:16.233 D/CarrierConfigLoader( 618): mHandler: 7 phoneId: 0
07-12 01:27:16.233 E/CarrierConfigLoader( 618): Failed to get package version for: com.android.carrierconfig
07-12 01:27:16.233 D/CarrierConfigLoader( 618): Binding to com.android.carrierconfig for phone 0
07-12 01:27:16.234 D/RKUpdateReceiver( 1219): action = android.intent.action.BOOT_COMPLETED
07-12 01:27:16.234 D/RKUpdateReceiver( 1219): RKUpdateReceiver recv ACTION_BOOT_COMPLETED.
07-12 01:27:16.234 W/ContextImpl( 1219): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1357 android.content.ContextWrapper.startService:613 android.content.ContextWrapper.startService:613 android.rockchip.update.service.RKUpdateReceiver.onReceive:59 android.app.ActivityThread.handleReceiver:3046
07-12 01:27:16.236 W/ActivityManager( 466): Unable to start service Intent { act=android.service.carrier.CarrierService pkg=com.android.carrierconfig } U=0: not found
07-12 01:27:16.237 W/ContextImpl( 1219): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1357 android.content.ContextWrapper.startService:613 android.content.ContextWrapper.startService:613 android.rockchip.update.service.RKUpdateReceiver.onReceive:65 android.app.ActivityThread.handleReceiver:3046
07-12 01:27:16.243 I/android_rockchip_update_UpdateService.cpp( 1219): JNI_OnLoad
07-12 01:27:16.250 I/ActivityManager( 466): Start proc 1290:com.android.calendar/u0a26 for broadcast com.android.calendar/.alerts.AlertReceiver
07-12 01:27:16.252 D/RKUpdateService( 1219): starting RKUpdateService, version is 1.8.0
07-12 01:27:16.253 D/RKUpdateService( 1219): remote uri is http://www.rockchip.com:2300/OtaUpdater/android?product=rk3288&version=1.0.0&sn=3GKL24GMUB&country=US&language=en
07-12 01:27:16.253 D/RKUpdateService( 1219): remote uri backup is http://192.168.1.143:2300/OtaUpdater/android?product=rk3288&version=1.0.0&sn=3GKL24GMUB&country=US&language=en
07-12 01:27:16.254 I/Telecom ( 466): PhoneAccountRegistrar: SimCallManager queried, returning: null: TSI.gSCMFU@AAo
07-12 01:27:16.260 D/RKUpdateService( 1219): first startup!!!
07-12 01:27:16.266 D/RKUpdateService( 1219): onStartCommand…
07-12 01:27:16.266 D/RKUpdateService( 1219): command = 1 delaytime = 20000
07-12 01:27:16.266 D/RKUpdateService( 1219): command = 2 delaytime = 25000
07-12 01:27:16.292 W/System ( 1290): ClassLoader referenced unknown path: /system/app/Calendar/lib/arm
07-12 01:27:16.409 D/ExtensionsFactory( 1290): No custom extensions.
07-12 01:27:16.412 D/AlertReceiver( 1290): onReceive: a=android.intent.action.BOOT_COMPLETED Intent { act=android.intent.action.BOOT_COMPLETED flg=0x9000010 cmp=com.android.calendar/.alerts.AlertReceiver (has extras) }
07-12 01:27:16.426 I/AlarmClock( 977): AlarmInitReceiver android.intent.action.BOOT_COMPLETED
07-12 01:27:16.480 D/AlertService( 1290): 0 Action = android.intent.action.BOOT_COMPLETED
07-12 01:27:16.481 V/AlarmClock( 977): AlarmInitReceiver finished
07-12 01:27:16.494 I/ActivityManager( 466): Start proc 1320:com.android.email/u0a33 for broadcast com.android.email/.service.EmailBroadcastReceiver
07-12 01:27:16.501 D/AlertService( 1290): Scheduling next alarm with AlarmScheduler. sEventReminderReceived: null
07-12 01:27:16.519 I/ActivityManager( 466): Start proc 1334:com.android.providers.calendar/u0a2 for content provider com.android.providers.calendar/.CalendarProvider2
07-12 01:27:16.522 W/System ( 1320): ClassLoader referenced unknown path: /system/app/Email/lib/arm
07-12 01:27:16.553 W/System ( 1334): ClassLoader referenced unknown path: /system/priv-app/CalendarProvider/lib/arm
07-12 01:27:16.626 I/CalendarProvider2( 1334): Created com.android.providers.calendar.CalendarAlarmManager@bc61c11(com.android.providers.calendar.CalendarProvider2@60d5176)
07-12 01:27:16.631 W/ActivityManager( 466): Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
07-12 01:27:16.643 D/ActivityThread( 1320): Loading provider com.android.email.provider;com.android.email.notifier: com.android.email.provider.EmailProvider
07-12 01:27:16.644 W/ActivityManager( 466): Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
07-12 01:27:16.665 I/SystemBroadcastReceiver( 669): Boot has been completed
07-12 01:27:16.665 I/SystemBroadcastReceiver( 669): toggleAppIcon() : FLAG_SYSTEM = true
07-12 01:27:16.687 I/ActivityManager( 466): Start proc 1364:com.android.managedprovisioning/u0a10 for broadcast com.android.managedprovisioning/.BootReminder
07-12 01:27:16.694 D/AlarmScheduler( 1290): No events found starting within 1 week.
07-12 01:27:16.715 W/System ( 1364): ClassLoader referenced unknown path: /system/priv-app/ManagedProvisioning/lib/arm
07-12 01:27:16.729 W/ActivityManager( 466): Unable to start service Intent { cmp=com.android.email/.service.AttachmentService } U=0: not found
07-12 01:27:16.729 W/ActivityManager( 466): Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
07-12 01:27:16.733 W/ActivityManager( 466): Unable to start service Intent { cmp=com.android.email/.service.AttachmentService } U=0: not found
07-12 01:27:16.752 I/Email ( 1320): Observing account changes for notifications
07-12 01:27:16.762 I/ActivityManager( 466): Start proc 1382:com.android.onetimeinitializer/u0a12 for broadcast com.android.onetimeinitializer/.OneTimeInitializerReceiver
07-12 01:27:16.764 W/ActivityManager( 466): Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
07-12 01:27:16.775 W/ActivityManager( 466): Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
07-12 01:27:16.778 W/ActivityManager( 466): Unable to start service Intent { act=com.android.email.EXCHANGE_INTENT pkg=com.android.exchange } U=0: not found
07-12 01:27:16.783 E/ActivityThread( 1320): Service com.android.email.service.EmailBroadcastProcessorService has leaked ServiceConnection com.android.emailcommon.service.ServiceProxy$ProxyConnection@4533cb2 that was originally bound here
07-12 01:27:16.783 E/ActivityThread( 1320): android.app.ServiceConnectionLeaked: Service com.android.email.service.EmailBroadcastProcessorService has leaked ServiceConnection com.android.emailcommon.service.ServiceProxy$ProxyConnection@4533cb2 that was originally bound here
07-12 01:27:16.783 E/ActivityThread( 1320): at android.app.LoadedApk$ServiceDispatcher.(LoadedApk.java:1336)
07-12 01:27:16.783 E/ActivityThread( 1320): at android.app.LoadedApk.getServiceDispatcher(LoadedApk.java:1231)
07-12 01:27:16.783 E/ActivityThread( 1320): at android.app.ContextImpl.bindServiceCommon(ContextImpl.java:1450)
07-12 01:27:16.783 E/ActivityThread( 1320): at android.app.ContextImpl.bindService(ContextImpl.java:1422)
07-12 01:27:16.783 E/ActivityThread( 1320): at android.content.ContextWrapper.bindService(ContextWrapper.java:636)
07-12 01:27:16.783 E/ActivityThread( 1320): at com.android.emailcommon.service.ServiceProxy.setTask(ServiceProxy.java:181)
07-12 01:27:16.783 E/ActivityThread( 1320): at com.android.emailcommon.service.ServiceProxy.test(ServiceProxy.java:224)
07-12 01:27:16.783 E/ActivityThread( 1320): at com.android.email.service.EmailServiceUtils.isServiceAvailable(EmailServiceUtils.java:160)
07-12 01:27:16.783 E/ActivityThread( 1320): at com.android.email.provider.AccountReconciler.reconcileAccountsInternal(AccountReconciler.java:171)
07-12 01:27:16.783 E/ActivityThread( 1320): at com.android.email.provider.AccountReconciler.reconcileAccounts(AccountReconciler.java:115)
07-12 01:27:16.783 E/ActivityThread( 1320): at com.android.email.service.EmailBroadcastProcessorService.reconcileAndStartServices(EmailBroadcastProcessorService.java:305)
07-12 01:27:16.783 E/ActivityThread( 1320): at com.android.email.service.EmailBroadcastProcessorService.onBootCompleted(EmailBroadcastProcessorService.java:295)
07-12 01:27:16.783 E/ActivityThread( 1320): at com.android.email.service.EmailBroadcastProcessorService.onHandleIntent(EmailBroadcastProcessorService.java:130)
07-12 01:27:16.783 E/ActivityThread( 1320): at android.app.IntentService$ServiceHandler.handleMessage(IntentService.java:68)
07-12 01:27:16.783 E/ActivityThread( 1320): at android.os.Handler.dispatchMessage(Handler.java:102)
07-12 01:27:16.783 E/ActivityThread( 1320): at android.os.Looper.loop(Looper.java:154)
07-12 01:27:16.783 E/ActivityThread( 1320): at android.os.HandlerThread.run(HandlerThread.java:61)
07-12 01:27:16.783 W/ActivityManager( 466): Unbind failed: could not find connection for android.os.BinderProxy@336a668
07-12 01:27:16.787 W/System ( 1382): ClassLoader referenced unknown path: /system/priv-app/OneTimeInitializer/lib/arm
07-12 01:27:16.812 V/OneTimeInitializerRece( 1382): OneTimeInitializerReceiver.onReceive
07-12 01:27:16.821 V/VvmBootCompletedRcvr( 618): processing subId list
07-12 01:27:17.116 I/VvmSimChangeReceiver( 618): Received SIM change for invalid subscription id.
07-12 01:27:17.187 D/alsa_route( 232): route_set_controls() set route 24
07-12 01:27:17.187 D/AudioHardwareTiny( 232): close device
07-12 01:27:17.642 W/MediaScanner( 1235): Error opening directory ‘/oem/media/’, skipping: No such file or directory.
07-12 01:27:17.693 V/MediaScanner( 1235): pruneDeadThumbnailFiles… android.content.ContentProviderClient$CursorWrapperInner@7f1fb6a
07-12 01:27:17.694 V/MediaScanner( 1235): /pruneDeadThumbnailFiles… android.content.ContentProviderClient$CursorWrapperInner@7f1fb6a
07-12 01:27:17.713 I/CalendarProvider2( 1334): Sending notification intent: Intent { act=android.intent.action.PROVIDER_CHANGED dat=content://com.android.calendar flg=0x20000000 }
07-12 01:27:17.713 W/ContentResolver( 1334): Failed to get type for: content://com.android.calendar (Unknown URL content://com.android.calendar)
07-12 01:27:17.716 D/AlertReceiver( 1290): onReceive: a=android.intent.action.PROVIDER_CHANGED Intent { act=android.intent.action.PROVIDER_CHANGED dat=content://com.android.calendar flg=0x20000010 cmp=com.android.calendar/.alerts.AlertReceiver }
07-12 01:27:17.721 D/AlertService( 1290): 0 Action = android.intent.action.PROVIDER_CHANGED
07-12 01:27:21.325 I/ActivityManager( 466): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.android.settings/.Settings bnds=[9,331][177,411] (has extras)} from uid 10040 on display 0
07-12 01:27:21.326 I/AudioOut_D( 232): type=1400 audit(0.0:24): avc: denied { read } for name=“audioformat” dev=“sysfs” ino=17976 scontext=u:r:audioserver:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
07-12 01:27:21.326 I/AudioOut_D( 232): type=1400 audit(0.0:25): avc: denied { open } for path=“/sys/devices/platform/display-subsystem/drm/card0/card0-HDMI-A-1/audioformat” dev=“sysfs” ino=17976 scontext=u:r:audioserver:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
07-12 01:27:21.326 I/AudioOut_D( 232): type=1400 audit(0.0:26): avc: denied { getattr } for path=“/sys/devices/platform/display-subsystem/drm/card0/card0-HDMI-A-1/audioformat” dev=“sysfs” ino=17976 scontext=u:r:audioserver:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
07-12 01:27:21.327 W/AudioTrack( 466): AUDIO_OUTPUT_FLAG_FAST denied by client; transfer 4, track 48000 Hz, output 44100 Hz
07-12 01:27:21.332 D/AudioHardwareTiny( 232): start_output_stream
07-12 01:27:21.333 D/alsa_route( 232): route_info->sound_card 0, route_info->devices 0
07-12 01:27:21.333 D/alsa_route( 232): route_set_controls() set route 0
07-12 01:27:21.457 E/Typeface( 466): Error mapping font file /system/fonts/DroidSansFallback.ttf
07-12 01:27:21.480 W/System ( 646): ClassLoader referenced unknown path:
07-12 01:27:21.481 W/System ( 646): ClassLoader referenced unknown path: /system/priv-app/TeleService/lib/arm
07-12 01:27:21.484 D/ApplicationLoaders( 646): ignored Vulkan layer search path /system/priv-app/TeleService/lib/arm:/system/lib:/vendor/lib for namespace 0xb0574090
07-12 01:27:21.511 I/IndexDatabaseHelper( 646): Using schema version: 115
07-12 01:27:21.513 I/IndexDatabaseHelper( 646): Index is fine
07-12 01:27:21.515 D/Index ( 646): Locale ‘en_US’ is already indexed
07-12 01:27:21.537 D/Index ( 646): Indexing locale ‘en_US’ took 21 millis
07-12 01:27:21.563 D/Index ( 646): Indexing locale ‘en_US’ took 7 millis
07-12 01:27:21.586 D/LocalBluetoothProfileManager( 646): Adding local MAP profile
07-12 01:27:21.588 D/BluetoothMap( 646): Create BluetoothMap proxy object
07-12 01:27:21.590 E/BluetoothMap( 646): Could not bind to Bluetooth MAP Service with Intent { act=android.bluetooth.IBluetoothMap }
07-12 01:27:21.591 E/BluetoothPbap( 646): Could not bind to Bluetooth Pbap Service with Intent { act=android.bluetooth.IBluetoothPbap }
07-12 01:27:21.591 D/LocalBluetoothProfileManager( 646): LocalBluetoothProfileManager construction complete
07-12 01:27:21.620 D/mali_winsys( 646): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:27:21.667 D/DashboardSummary( 646): onConditionsChanged
07-12 01:27:21.668 I/ProcessStatsService( 466): Added stats: 2019-07-12-00-16-04, over +30m0s789ms
07-12 01:27:21.673 I/ActivityManager( 466): Displayed com.android.settings/.Settings: +331ms
07-12 01:27:21.674 I/ProcessStatsService( 466): Added stats: 2019-07-11-21-49-05, over +2h0m2s248ms
07-12 01:27:21.686 W/ProcStatsManager( 646): No process com.android.providers.calendar/10002 for service com.android.providers.calendar.EmptyService
07-12 01:27:21.687 W/ProcStatsManager( 646): No process com.android.providers.calendar/10002 for service com.android.providers.calendar.CalendarProviderIntentService
07-12 01:27:21.687 W/ProcStatsManager( 646): No process android.process.media/10007 for service com.android.providers.media.MediaScannerService
07-12 01:27:21.688 W/ProcStatsManager( 646): No process com.android.calendar/10026 for service com.android.calendar.alerts.InitAlarmsService
07-12 01:27:21.688 W/ProcStatsManager( 646): No process com.android.calendar/10026 for service com.android.calendar.alerts.AlertService
07-12 01:27:21.688 W/ProcStatsManager( 646): No process com.android.printspooler/10050 for service com.android.printspooler.model.PrintSpoolerService
07-12 01:27:21.688 W/ProcStatsManager( 646): No process com.android.onetimeinitializer/10012 for service com.android.onetimeinitializer.OneTimeInitializerService
07-12 01:27:21.688 W/ProcStatsManager( 646): No process com.android.keychain/1000 for service com.android.keychain.KeyChainService
07-12 01:27:21.688 W/ProcStatsManager( 646): No process android.ext.services/10008 for service android.ext.services.notification.Ranker
07-12 01:27:21.688 W/ProcStatsManager( 646): No process com.android.inputmethod.latin/10039 for service com.android.inputmethod.latin.LatinIME
07-12 01:27:21.688 W/ProcStatsManager( 646): No process com.android.smspush/10055 for service com.android.smspush.WapPushManager
07-12 01:27:21.688 W/ProcStatsManager( 646): No process com.android.email/10033 for service com.android.email.service.EmailBroadcastProcessorService
07-12 01:27:21.688 W/ProcStatsManager( 646): No process com.android.bluetooth/1002 for service com.android.bluetooth.btservice.AdapterService
07-12 01:27:21.688 W/ProcStatsManager( 646): No process com.android.bluetooth/1002 for service com.android.bluetooth.gatt.GattService
07-12 01:27:21.729 W/DataUsageController( 646): Failed to get data usage, no subscriber id
07-12 01:27:21.802 E/BatteryStatsService( 466): no controller energy info supplied
07-12 01:27:21.813 E/BatteryStatsService( 466): modem info is invalid: ModemActivityInfo{ mTimestamp=0 mSleepTimeMs=0 mIdleTimeMs=0 mTxTimeMs=[0, 0, 0, 0, 0] mRxTimeMs=0 mEnergyUsed=0}
07-12 01:27:22.765 I/GlobalDismissManager( 1290): no sender configured
07-12 01:27:22.769 D/AlertService( 1290): Beginning updateAlertNotification
07-12 01:27:22.802 D/AlertService( 1290): No fired or scheduled alerts
07-12 01:27:22.808 D/AlertService( 1290): Scheduling next alarm with AlarmScheduler. sEventReminderReceived: null
07-12 01:27:22.817 D/AlarmScheduler( 1290): No events found starting within 1 week.
07-12 01:27:22.873 I/ActivityManager( 466): START u0 {flg=0x8000 cmp=com.android.settings/.Settings$BluetoothSettingsActivity (has extras)} from uid 1000 on display 0
07-12 01:27:22.987 D/Index ( 646): Indexing locale ‘en_US’ took 7 millis
07-12 01:27:22.987 D/LocalBluetoothManager( 646): setting foreground activity to non-null context
07-12 01:27:23.001 D/Index ( 646): Indexing locale ‘en_US’ took 5 millis
07-12 01:27:23.051 D/mali_winsys( 646): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:27:23.063 D/Index ( 646): Deleting data for locale ‘en_US’ took 1 millis
07-12 01:27:23.064 D/Index ( 646): Indexing locale ‘en_US’ took 1 millis
07-12 01:27:23.100 I/ActivityManager( 466): Displayed com.android.settings/.Settings$BluetoothSettingsActivity: +220ms
07-12 01:27:23.165 D/OpenGLRenderer( 646): endAllActiveAnimators on 0x90d25580 (RippleDrawable) with handle 0x90d1e580
07-12 01:27:25.610 D/BluetoothManagerService( 466): enable(com.android.settings): mBluetooth =null mBinding = false mState = OFF
07-12 01:27:25.610 D/BluetoothManagerService( 466): MESSAGE_ENABLE(0): mBluetooth = null
07-12 01:27:25.610 D/BluetoothManagerService( 466): enable returning
07-12 01:27:25.622 I/ActivityManager( 466): Start proc 1429:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:27:25.722 I/chatty ( 1429): uid=1002(bluetooth) com.android.bluetooth expire 39 lines
07-12 01:27:25.815 I/chatty ( 1429): uid=1002(bluetooth) com.android.bluetooth expire 12 lines
07-12 01:27:25.815 I/chatty ( 1429): uid=1002(bluetooth) com.android.bluetooth expire 35 lines
07-12 01:27:25.817 I/chatty ( 1429): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:27:25.819 I/chatty ( 1429): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:27:25.822 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:27:25.822 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:27:25.843 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:27:25.843 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:27:25.844 I/chatty ( 1429): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:27:25.845 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:27:25.845 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@bdda13d
07-12 01:27:25.846 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@d1777e8
07-12 01:27:25.846 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@a0f503b
07-12 01:27:25.846 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@cf6ace7
07-12 01:27:25.846 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@54b0426
07-12 01:27:25.847 I/chatty ( 1429): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:27:25.848 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:27:25.848 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:27:25.850 I/chatty ( 1429): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:27:25.865 I/chatty ( 1429): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:27:26.043 I/chatty ( 1429): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:27:28.721 D/alsa_route( 232): route_set_controls() set route 24
07-12 01:27:28.723 D/AudioHardwareTiny( 232): close device
07-12 01:27:31.240 I/ActivityManager( 466): Waited long enough for: ServiceRecord{bcad6e4 u0 android.rockchip.update.service/.RKUpdateService}
07-12 01:27:31.484 I/ActivityManager( 466): Waited long enough for: ServiceRecord{918713 u0 com.android.calendar/.alerts.InitAlarmsService}
--------- beginning of crash
07-12 01:27:33.231 F/libc ( 1429): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:27:33.233 F/libc ( 1429): Fatal signal 6 (SIGABRT), code -6 in tid 1456 (hci_thread)
07-12 01:27:33.235 W/ ( 204): debuggerd: handling request: pid=1429 uid=1002 gid=1002 tid=1456
07-12 01:27:33.340 F/DEBUG ( 1459): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:27:33.341 F/DEBUG ( 1459): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:27:33.341 F/DEBUG ( 1459): Revision: ‘0’
07-12 01:27:33.341 F/DEBUG ( 1459): ABI: ‘arm’
07-12 01:27:33.343 F/DEBUG ( 1459): pid: 1429, tid: 1456, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:27:33.343 F/DEBUG ( 1459): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:27:33.368 F/DEBUG ( 1459): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:27:33.368 F/DEBUG ( 1459): r0 00000000 r1 000005b0 r2 00000006 r3 00000008
07-12 01:27:33.368 F/DEBUG ( 1459): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:27:33.368 F/DEBUG ( 1459): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:27:33.368 F/DEBUG ( 1459): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:27:33.381 F/DEBUG ( 1459):
07-12 01:27:33.381 F/DEBUG ( 1459): backtrace:
07-12 01:27:33.381 F/DEBUG ( 1459): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:27:33.381 F/DEBUG ( 1459): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:27:33.381 F/DEBUG ( 1459): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:27:33.381 F/DEBUG ( 1459): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:27:33.381 F/DEBUG ( 1459): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:27:33.381 F/DEBUG ( 1459): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:27:33.381 F/DEBUG ( 1459): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:27:33.381 F/DEBUG ( 1459): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:27:33.381 F/DEBUG ( 1459): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:27:33.382 F/DEBUG ( 1459): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:27:33.382 F/DEBUG ( 1459): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:27:33.382 F/DEBUG ( 1459): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:27:33.666 W/ ( 204): debuggerd: resuming target 1429
07-12 01:27:33.666 I/BootReceiver( 466): Copying /data/tombstones/tombstone_09 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:27:33.693 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:27:33.694 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:27:33.694 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:27:33.694 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@bdda13d
07-12 01:27:33.694 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@d1777e8
07-12 01:27:33.694 I/Zygote ( 231): Process 1429 exited due to signal (6)
07-12 01:27:33.694 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@a0f503b
07-12 01:27:33.695 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@cf6ace7
07-12 01:27:33.695 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@54b0426
07-12 01:27:33.695 I/ActivityManager( 466): Process com.android.bluetooth (pid 1429) has died
07-12 01:27:33.695 D/ActivityManager( 466): cleanUpApplicationRecord – 1429
07-12 01:27:33.695 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:27:33.696 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.btservice.AdapterService in 1000ms
07-12 01:27:33.749 I/OpenGLRenderer( 466): Initialized EGL, version 1.4
07-12 01:27:33.749 D/OpenGLRenderer( 466): Swap behavior 1
07-12 01:27:33.755 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:27:33.893 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:27:33.905 I/ActivityManager( 466): Start proc 1473:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:27:33.956 I/chatty ( 1473): uid=1002(bluetooth) com.android.bluetooth expire 39 lines
07-12 01:27:34.009 I/chatty ( 1473): uid=1002(bluetooth) com.android.bluetooth expire 12 lines
07-12 01:27:34.009 I/chatty ( 1473): uid=1002(bluetooth) com.android.bluetooth expire 35 lines
07-12 01:27:34.011 I/chatty ( 1473): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:27:34.012 I/chatty ( 1473): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:27:34.015 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:27:34.015 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:27:34.033 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:27:34.033 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:27:34.033 I/chatty ( 1473): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:27:34.035 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:27:34.035 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@5babedb
07-12 01:27:34.035 I/chatty ( 1473): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:27:34.035 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@ef6ee01
07-12 01:27:34.035 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@b995358
07-12 01:27:34.035 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@7988867
07-12 01:27:34.035 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@f603094
07-12 01:27:34.037 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:27:34.037 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:27:34.039 I/chatty ( 1473): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:27:34.052 I/chatty ( 1473): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:27:34.232 I/chatty ( 1473): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:27:34.867 I/WifiHAL ( 466): Got channel list with 13 channels
07-12 01:27:34.870 I/WifiHAL ( 466): Got channel list with 9 channels
07-12 01:27:34.872 I/WifiHAL ( 466): Got channel list with 4 channels
07-12 01:27:36.043 V/UsbDeviceManager( 466): USB UEVENT: {USB_STATE=DISCONNECTED, SUBSYSTEM=android_usb, SEQNUM=1941, ACTION=change, DEVPATH=/devices/virtual/android_usb/android0}
07-12 01:27:36.045 I/chatty ( 1473): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:27:36.047 W/art ( 1020): Receiving file descriptor from ADB failed (socket 30): Connection reset by peer
07-12 01:27:36.047 W/art ( 1062): Receiving file descriptor from ADB failed (socket 27): Connection reset by peer
07-12 01:27:36.048 W/art ( 646): Receiving file descriptor from ADB failed (socket 9): Connection reset by peer
07-12 01:27:36.049 W/art ( 623): Receiving file descriptor from ADB failed (socket 26): Connection reset by peer
07-12 01:27:36.307 D/RKUpdateService( 1219): WorkHandler::handleMessage() : To perform ‘COMMAND_CHECK_LOCAL_UPDATING’.
07-12 01:27:36.309 D/RKUpdateService( 1219): getValidFirmwareImageFile() : Target image file path : /data/media/0/update.zip
07-12 01:27:36.310 D/RKUpdateService( 1219): getValidFirmwareImageFile() : Target image file path : /storage/emulated/0/update.zip
07-12 01:27:36.972 V/UsbDeviceManager( 466): USB UEVENT: {USB_STATE=CONNECTED, SUBSYSTEM=android_usb, SEQNUM=1943, ACTION=change, DEVPATH=/devices/virtual/android_usb/android0}
07-12 01:27:36.986 V/UsbDeviceManager( 466): USB UEVENT: {USB_STATE=CONFIGURED, SUBSYSTEM=android_usb, SEQNUM=1944, ACTION=change, DEVPATH=/devices/virtual/android_usb/android0}
07-12 01:27:37.008 D/RKUpdateReceiver( 1219): action = android.hardware.usb.action.USB_STATE
07-12 01:27:37.041 D/RKUpdateReceiver( 1219): action = android.hardware.usb.action.USB_STATE
07-12 01:27:41.344 D/NetworkSecurityConfig( 1219): No Network Security Config specified, using platform default
07-12 01:27:41.374 D/RKUpdateService( 1219): request remote server error…
07-12 01:27:41.396 F/libc ( 1473): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:27:41.396 F/libc ( 1473): Fatal signal 6 (SIGABRT), code -6 in tid 1500 (hci_thread)
07-12 01:27:41.397 W/ ( 204): debuggerd: handling request: pid=1473 uid=1002 gid=1002 tid=1500
07-12 01:27:41.478 F/DEBUG ( 1512): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:27:41.479 F/DEBUG ( 1512): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:27:41.480 F/DEBUG ( 1512): Revision: ‘0’
07-12 01:27:41.480 F/DEBUG ( 1512): ABI: ‘arm’
07-12 01:27:41.481 F/DEBUG ( 1512): pid: 1473, tid: 1500, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:27:41.482 F/DEBUG ( 1512): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:27:41.507 F/DEBUG ( 1512): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:27:41.508 F/DEBUG ( 1512): r0 00000000 r1 000005dc r2 00000006 r3 00000008
07-12 01:27:41.508 F/DEBUG ( 1512): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:27:41.508 F/DEBUG ( 1512): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:27:41.508 F/DEBUG ( 1512): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:27:41.519 F/DEBUG ( 1512):
07-12 01:27:41.519 F/DEBUG ( 1512): backtrace:
07-12 01:27:41.519 F/DEBUG ( 1512): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:27:41.519 F/DEBUG ( 1512): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:27:41.519 F/DEBUG ( 1512): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:27:41.519 F/DEBUG ( 1512): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:27:41.519 F/DEBUG ( 1512): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:27:41.520 F/DEBUG ( 1512): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:27:41.520 F/DEBUG ( 1512): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:27:41.520 F/DEBUG ( 1512): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:27:41.520 F/DEBUG ( 1512): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:27:41.520 F/DEBUG ( 1512): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:27:41.520 F/DEBUG ( 1512): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:27:41.520 F/DEBUG ( 1512): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:27:41.762 E/ ( 1512): debuggerd: failed to kill process 1473: No such process
07-12 01:27:41.768 W/ ( 204): debuggerd: resuming target 1473
07-12 01:27:41.773 I/BootReceiver( 466): Copying /data/tombstones/tombstone_00 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:27:41.800 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:27:41.800 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:27:41.800 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 6 receivers.
07-12 01:27:41.801 E/BluetoothManagerService( 466): Unable to call onBluetoothServiceDown() on callback #0
07-12 01:27:41.801 E/BluetoothManagerService( 466): android.os.DeadObjectException
07-12 01:27:41.801 E/BluetoothManagerService( 466): at android.os.BinderProxy.transactNative(Native Method)
07-12 01:27:41.801 E/BluetoothManagerService( 466): at android.os.BinderProxy.transact(Binder.java:615)
07-12 01:27:41.801 E/BluetoothManagerService( 466): at android.bluetooth.IBluetoothManagerCallback$Stub$Proxy.onBluetoothServiceDown(IBluetoothManagerCallback.java:105)
07-12 01:27:41.801 E/BluetoothManagerService( 466): at com.android.server.BluetoothManagerService.sendBluetoothServiceDownCallback(BluetoothManagerService.java:1129)
07-12 01:27:41.801 E/BluetoothManagerService( 466): at com.android.server.BluetoothManagerService.-wrap12(BluetoothManagerService.java)
07-12 01:27:41.801 E/BluetoothManagerService( 466): at com.android.server.BluetoothManagerService$BluetoothHandler.handleMessage(BluetoothManagerService.java:1530)
07-12 01:27:41.801 E/BluetoothManagerService( 466): at android.os.Handler.dispatchMessage(Handler.java:102)
07-12 01:27:41.801 E/BluetoothManagerService( 466): at android.os.Looper.loop(Looper.java:154)
07-12 01:27:41.801 E/BluetoothManagerService( 466): at android.os.HandlerThread.run(HandlerThread.java:61)
07-12 01:27:41.801 E/BluetoothManagerService( 466): at com.android.server.ServiceThread.run(ServiceThread.java:46)
07-12 01:27:41.801 I/Zygote ( 231): Process 1473 exited due to signal (6)
07-12 01:27:41.801 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@5babedb
07-12 01:27:41.801 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@ef6ee01
07-12 01:27:41.801 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@b995358
07-12 01:27:41.801 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@f603094
07-12 01:27:41.802 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@7988867
07-12 01:27:41.803 I/ActivityManager( 466): Process com.android.bluetooth (pid 1473) has died
07-12 01:27:41.803 D/ActivityManager( 466): cleanUpApplicationRecord – 1473
07-12 01:27:41.803 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:27:41.803 W/ActivityManager( 466): Service crashed 2 times, stopping: ServiceRecord{2e60fe8 u0 com.android.bluetooth/.btservice.AdapterService}
07-12 01:27:41.833 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:27:42.000 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:27:42.039 I/ActivityManager( 466): Start proc 1520:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:27:42.109 I/chatty ( 1520): uid=1002(bluetooth) com.android.bluetooth expire 39 lines
07-12 01:27:42.163 I/chatty ( 1520): uid=1002(bluetooth) com.android.bluetooth expire 12 lines
07-12 01:27:42.164 I/chatty ( 1520): uid=1002(bluetooth) com.android.bluetooth expire 35 lines
07-12 01:27:42.165 I/chatty ( 1520): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:27:42.166 I/chatty ( 1520): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:27:42.169 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:27:42.169 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:27:42.184 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:27:42.184 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:27:42.184 I/chatty ( 1520): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:27:42.186 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:27:42.186 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@79ccf9f
07-12 01:27:42.186 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@16dd4a6
07-12 01:27:42.186 I/chatty ( 1520): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:27:42.186 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@5bd7cb1
07-12 01:27:42.186 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@c2ba614
07-12 01:27:42.186 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@139f73d
07-12 01:27:42.187 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:27:42.187 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:27:42.189 I/chatty ( 1520): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:27:42.204 I/chatty ( 1520): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:27:42.385 I/chatty ( 1520): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:27:46.401 D/RKUpdateService( 1219): request remote server error…
07-12 01:27:46.544 D/InitAlarmsService( 1290): Clearing and rescheduling alarms.
07-12 01:27:49.559 F/libc ( 1520): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:27:49.561 F/libc ( 1520): Fatal signal 6 (SIGABRT), code -6 in tid 1547 (hci_thread)
07-12 01:27:49.563 W/ ( 204): debuggerd: handling request: pid=1520 uid=1002 gid=1002 tid=1547
07-12 01:27:49.657 F/DEBUG ( 1549): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:27:49.658 F/DEBUG ( 1549): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:27:49.658 F/DEBUG ( 1549): Revision: ‘0’
07-12 01:27:49.658 F/DEBUG ( 1549): ABI: ‘arm’
07-12 01:27:49.660 F/DEBUG ( 1549): pid: 1520, tid: 1547, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:27:49.661 F/DEBUG ( 1549): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:27:49.679 F/DEBUG ( 1549): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:27:49.679 F/DEBUG ( 1549): r0 00000000 r1 0000060b r2 00000006 r3 00000008
07-12 01:27:49.679 F/DEBUG ( 1549): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:27:49.679 F/DEBUG ( 1549): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:27:49.679 F/DEBUG ( 1549): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:27:49.690 F/DEBUG ( 1549):
07-12 01:27:49.690 F/DEBUG ( 1549): backtrace:
07-12 01:27:49.690 F/DEBUG ( 1549): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:27:49.691 F/DEBUG ( 1549): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:27:49.691 F/DEBUG ( 1549): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:27:49.691 F/DEBUG ( 1549): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:27:49.691 F/DEBUG ( 1549): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:27:49.691 F/DEBUG ( 1549): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:27:49.691 F/DEBUG ( 1549): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:27:49.691 F/DEBUG ( 1549): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:27:49.691 F/DEBUG ( 1549): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:27:49.691 F/DEBUG ( 1549): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:27:49.691 F/DEBUG ( 1549): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:27:49.691 F/DEBUG ( 1549): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:27:49.939 E/ ( 1549): debuggerd: failed to kill process 1520: No such process
07-12 01:27:49.940 W/ ( 204): debuggerd: resuming target 1520
07-12 01:27:49.941 I/BootReceiver( 466): Copying /data/tombstones/tombstone_01 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:27:49.967 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:27:49.967 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:27:49.967 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:27:49.967 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@79ccf9f
07-12 01:27:49.968 I/ActivityManager( 466): Process com.android.bluetooth (pid 1520) has died
07-12 01:27:49.968 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@16dd4a6
07-12 01:27:49.968 D/ActivityManager( 466): cleanUpApplicationRecord – 1520
07-12 01:27:49.968 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@5bd7cb1
07-12 01:27:49.968 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:27:49.968 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.btservice.AdapterService in 1000ms
07-12 01:27:49.968 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@139f73d
07-12 01:27:49.969 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@c2ba614
07-12 01:27:49.970 I/Zygote ( 231): Process 1520 exited due to signal (6)
07-12 01:27:50.006 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:27:50.168 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:27:50.206 I/ActivityManager( 466): Start proc 1558:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:27:50.269 I/chatty ( 1558): uid=1002(bluetooth) com.android.bluetooth expire 39 lines
07-12 01:27:50.328 I/chatty ( 1558): uid=1002(bluetooth) com.android.bluetooth expire 12 lines
07-12 01:27:50.328 I/chatty ( 1558): uid=1002(bluetooth) com.android.bluetooth expire 35 lines
07-12 01:27:50.329 I/chatty ( 1558): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:27:50.330 I/chatty ( 1558): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:27:50.331 I/chatty ( 1558): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:27:50.334 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:27:50.334 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:27:50.348 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:27:50.348 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:27:50.349 I/chatty ( 1558): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:27:50.350 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:27:50.350 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@ddc5bb4
07-12 01:27:50.350 I/chatty ( 1558): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:27:50.350 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@f24ee7
07-12 01:27:50.350 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@f923596
07-12 01:27:50.350 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@2a7febd
07-12 01:27:50.350 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@5310b32
07-12 01:27:50.351 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:27:50.352 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:27:50.353 I/chatty ( 1558): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:27:50.365 I/chatty ( 1558): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:27:50.545 I/chatty ( 1558): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:27:57.725 F/libc ( 1558): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:27:57.727 F/libc ( 1558): Fatal signal 6 (SIGABRT), code -6 in tid 1585 (hci_thread)
07-12 01:27:57.728 W/ ( 204): debuggerd: handling request: pid=1558 uid=1002 gid=1002 tid=1585
07-12 01:27:57.827 F/DEBUG ( 1588): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:27:57.828 F/DEBUG ( 1588): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:27:57.828 F/DEBUG ( 1588): Revision: ‘0’
07-12 01:27:57.828 F/DEBUG ( 1588): ABI: ‘arm’
07-12 01:27:57.830 F/DEBUG ( 1588): pid: 1558, tid: 1585, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:27:57.830 F/DEBUG ( 1588): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:27:57.843 F/DEBUG ( 1588): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:27:57.843 F/DEBUG ( 1588): r0 00000000 r1 00000631 r2 00000006 r3 00000008
07-12 01:27:57.843 F/DEBUG ( 1588): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:27:57.843 F/DEBUG ( 1588): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:27:57.843 F/DEBUG ( 1588): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:27:57.855 F/DEBUG ( 1588):
07-12 01:27:57.855 F/DEBUG ( 1588): backtrace:
07-12 01:27:57.855 F/DEBUG ( 1588): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:27:57.855 F/DEBUG ( 1588): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:27:57.855 F/DEBUG ( 1588): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:27:57.855 F/DEBUG ( 1588): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:27:57.855 F/DEBUG ( 1588): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:27:57.855 F/DEBUG ( 1588): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:27:57.855 F/DEBUG ( 1588): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:27:57.855 F/DEBUG ( 1588): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:27:57.855 F/DEBUG ( 1588): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:27:57.855 F/DEBUG ( 1588): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:27:57.855 F/DEBUG ( 1588): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:27:57.855 F/DEBUG ( 1588): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:27:58.103 E/ ( 1588): debuggerd: failed to kill process 1558: No such process
07-12 01:27:58.104 W/ ( 204): debuggerd: resuming target 1558
07-12 01:27:58.107 I/BootReceiver( 466): Copying /data/tombstones/tombstone_02 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:27:58.130 I/Zygote ( 231): Process 1558 exited due to signal (6)
07-12 01:27:58.130 I/ActivityManager( 466): Process com.android.bluetooth (pid 1558) has died
07-12 01:27:58.130 D/ActivityManager( 466): cleanUpApplicationRecord – 1558
07-12 01:27:58.130 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:27:58.131 W/ActivityManager( 466): Service crashed 2 times, stopping: ServiceRecord{4ab9bf2 u0 com.android.bluetooth/.btservice.AdapterService}
07-12 01:27:58.131 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:27:58.131 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:27:58.131 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:27:58.131 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@ddc5bb4
07-12 01:27:58.131 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@f24ee7
07-12 01:27:58.131 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@f923596
07-12 01:27:58.131 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@5310b32
07-12 01:27:58.131 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@2a7febd
07-12 01:27:58.165 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:27:58.331 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:27:58.352 I/ActivityManager( 466): Start proc 1597:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:27:58.462 I/chatty ( 1597): uid=1002(bluetooth) com.android.bluetooth expire 39 lines
07-12 01:27:58.534 I/chatty ( 1597): uid=1002(bluetooth) com.android.bluetooth expire 12 lines
07-12 01:27:58.534 I/chatty ( 1597): uid=1002(bluetooth) com.android.bluetooth expire 35 lines
07-12 01:27:58.537 I/chatty ( 1597): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:27:58.538 I/chatty ( 1597): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:27:58.541 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:27:58.541 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:27:58.556 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:27:58.556 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:27:58.556 I/chatty ( 1597): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:27:58.558 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:27:58.558 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@8a07968
07-12 01:27:58.558 I/chatty ( 1597): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:27:58.558 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@8e02a94
07-12 01:27:58.558 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@598b517
07-12 01:27:58.558 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@1f73083
07-12 01:27:58.558 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@4533cb2
07-12 01:27:58.560 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:27:58.560 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:27:58.561 I/chatty ( 1597): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:27:58.573 I/chatty ( 1597): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:27:58.753 I/chatty ( 1597): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:28:05.938 F/libc ( 1597): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:28:05.940 F/libc ( 1597): Fatal signal 6 (SIGABRT), code -6 in tid 1624 (hci_thread)
07-12 01:28:05.941 W/ ( 204): debuggerd: handling request: pid=1597 uid=1002 gid=1002 tid=1624
07-12 01:28:06.040 F/DEBUG ( 1626): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:28:06.040 F/DEBUG ( 1626): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:28:06.041 F/DEBUG ( 1626): Revision: ‘0’
07-12 01:28:06.041 F/DEBUG ( 1626): ABI: ‘arm’
07-12 01:28:06.042 F/DEBUG ( 1626): pid: 1597, tid: 1624, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:28:06.043 F/DEBUG ( 1626): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:28:06.059 F/DEBUG ( 1626): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:28:06.059 F/DEBUG ( 1626): r0 00000000 r1 00000658 r2 00000006 r3 00000008
07-12 01:28:06.059 F/DEBUG ( 1626): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:28:06.059 F/DEBUG ( 1626): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:28:06.059 F/DEBUG ( 1626): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:28:06.071 F/DEBUG ( 1626):
07-12 01:28:06.071 F/DEBUG ( 1626): backtrace:
07-12 01:28:06.071 F/DEBUG ( 1626): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:28:06.071 F/DEBUG ( 1626): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:28:06.071 F/DEBUG ( 1626): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:28:06.071 F/DEBUG ( 1626): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:28:06.071 F/DEBUG ( 1626): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:28:06.071 F/DEBUG ( 1626): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:28:06.071 F/DEBUG ( 1626): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:28:06.071 F/DEBUG ( 1626): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:28:06.071 F/DEBUG ( 1626): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:28:06.071 F/DEBUG ( 1626): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:28:06.071 F/DEBUG ( 1626): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:28:06.071 F/DEBUG ( 1626): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:28:06.328 E/ ( 1626): debuggerd: failed to kill process 1597: No such process
07-12 01:28:06.329 W/ ( 204): debuggerd: resuming target 1597
07-12 01:28:06.329 I/BootReceiver( 466): Copying /data/tombstones/tombstone_03 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:28:06.350 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:28:06.350 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:28:06.350 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:28:06.350 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@8a07968
07-12 01:28:06.351 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@8e02a94
07-12 01:28:06.351 I/ActivityManager( 466): Process com.android.bluetooth (pid 1597) has died
07-12 01:28:06.351 D/ActivityManager( 466): cleanUpApplicationRecord – 1597
07-12 01:28:06.351 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@598b517
07-12 01:28:06.351 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:28:06.351 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.btservice.AdapterService in 1000ms
07-12 01:28:06.351 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@1f73083
07-12 01:28:06.351 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@4533cb2
07-12 01:28:06.353 I/Zygote ( 231): Process 1597 exited due to signal (6)
07-12 01:28:06.383 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:28:06.551 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:28:06.572 I/ActivityManager( 466): Start proc 1634:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:28:06.696 I/chatty ( 1634): uid=1002(bluetooth) com.android.bluetooth expire 39 lines
07-12 01:28:06.765 I/chatty ( 1634): uid=1002(bluetooth) com.android.bluetooth expire 12 lines
07-12 01:28:06.766 I/chatty ( 1634): uid=1002(bluetooth) com.android.bluetooth expire 35 lines
07-12 01:28:06.767 I/chatty ( 1634): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:28:06.769 I/chatty ( 1634): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:28:06.772 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:28:06.772 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:28:06.789 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:28:06.789 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:28:06.790 I/chatty ( 1634): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:28:06.791 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:28:06.791 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@2edbdba
07-12 01:28:06.791 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@6e3693d
07-12 01:28:06.791 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@ffc4d04
07-12 01:28:06.792 I/chatty ( 1634): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:28:06.792 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@f59c200
07-12 01:28:06.792 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@79b4403
07-12 01:28:06.794 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:28:06.794 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:28:06.795 I/chatty ( 1634): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:28:06.809 I/chatty ( 1634): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:28:06.988 I/chatty ( 1634): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:28:14.158 F/libc ( 1634): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:28:14.160 F/libc ( 1634): Fatal signal 6 (SIGABRT), code -6 in tid 1662 (hci_thread)
07-12 01:28:14.162 W/ ( 204): debuggerd: handling request: pid=1634 uid=1002 gid=1002 tid=1662
07-12 01:28:14.263 F/DEBUG ( 1666): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:28:14.264 F/DEBUG ( 1666): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:28:14.264 F/DEBUG ( 1666): Revision: ‘0’
07-12 01:28:14.265 F/DEBUG ( 1666): ABI: ‘arm’
07-12 01:28:14.266 F/DEBUG ( 1666): pid: 1634, tid: 1662, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:28:14.266 F/DEBUG ( 1666): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:28:14.292 F/DEBUG ( 1666): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:28:14.293 F/DEBUG ( 1666): r0 00000000 r1 0000067e r2 00000006 r3 00000008
07-12 01:28:14.293 F/DEBUG ( 1666): r4 93370978 r5 00000006 r6 93370920 r7 0000010c
07-12 01:28:14.293 F/DEBUG ( 1666): r8 00000000 r9 933704b0 sl ada58180 fp a4abb564
07-12 01:28:14.294 F/DEBUG ( 1666): ip 00000000 sp 93370410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:28:14.312 F/DEBUG ( 1666):
07-12 01:28:14.312 F/DEBUG ( 1666): backtrace:
07-12 01:28:14.312 F/DEBUG ( 1666): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:28:14.312 F/DEBUG ( 1666): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:28:14.312 F/DEBUG ( 1666): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:28:14.312 F/DEBUG ( 1666): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:28:14.312 F/DEBUG ( 1666): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:28:14.312 F/DEBUG ( 1666): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:28:14.312 F/DEBUG ( 1666): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:28:14.312 F/DEBUG ( 1666): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:28:14.312 F/DEBUG ( 1666): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:28:14.312 F/DEBUG ( 1666): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:28:14.312 F/DEBUG ( 1666): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:28:14.312 F/DEBUG ( 1666): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:28:14.567 E/ ( 1666): debuggerd: failed to kill process 1634: No such process
07-12 01:28:14.569 W/ ( 204): debuggerd: resuming target 1634
07-12 01:28:14.569 I/BootReceiver( 466): Copying /data/tombstones/tombstone_04 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:28:14.600 I/Zygote ( 231): Process 1634 exited due to signal (6)
07-12 01:28:14.601 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:28:14.601 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:28:14.601 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:28:14.601 I/ActivityManager( 466): Process com.android.bluetooth (pid 1634) has died
07-12 01:28:14.601 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@2edbdba
07-12 01:28:14.601 D/ActivityManager( 466): cleanUpApplicationRecord – 1634
07-12 01:28:14.601 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@6e3693d
07-12 01:28:14.601 W/ActivityManager( 466): Service crashed 2 times, stopping: ServiceRecord{a0ed06f u0 com.android.bluetooth/.btservice.AdapterService}
07-12 01:28:14.602 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:28:14.602 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@ffc4d04
07-12 01:28:14.602 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@f59c200
07-12 01:28:14.602 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@79b4403
07-12 01:28:14.638 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:28:14.802 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:28:14.822 I/ActivityManager( 466): Start proc 1673:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:28:14.865 I/WifiHAL ( 466): Got channel list with 13 channels
07-12 01:28:14.866 I/WifiHAL ( 466): Got channel list with 9 channels
07-12 01:28:14.867 I/WifiHAL ( 466): Got channel list with 4 channels
07-12 01:28:14.936 I/chatty ( 1673): uid=1002(bluetooth) com.android.bluetooth expire 39 lines
07-12 01:28:15.005 I/chatty ( 1673): uid=1002(bluetooth) com.android.bluetooth expire 12 lines
07-12 01:28:15.006 I/chatty ( 1673): uid=1002(bluetooth) com.android.bluetooth expire 35 lines
07-12 01:28:15.007 I/chatty ( 1673): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:28:15.009 I/chatty ( 1673): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:28:15.012 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:28:15.012 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:28:15.028 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:28:15.029 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:28:15.029 I/chatty ( 1673): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:28:15.030 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:28:15.031 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@5584a27
07-12 01:28:15.031 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@b129532
07-12 01:28:15.031 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@e53ca39
07-12 01:28:15.031 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@2fc32ed
07-12 01:28:15.031 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@9270f80
07-12 01:28:15.031 I/chatty ( 1673): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:28:15.032 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:28:15.032 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:28:15.034 I/chatty ( 1673): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:28:15.046 I/chatty ( 1673): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:28:15.225 I/chatty ( 1673): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:28:22.384 F/libc ( 1673): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:28:22.385 F/libc ( 1673): Fatal signal 6 (SIGABRT), code -6 in tid 1702 (hci_thread)
07-12 01:28:22.387 W/ ( 204): debuggerd: handling request: pid=1673 uid=1002 gid=1002 tid=1702
07-12 01:28:22.493 F/DEBUG ( 1705): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:28:22.494 F/DEBUG ( 1705): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:28:22.495 F/DEBUG ( 1705): Revision: ‘0’
07-12 01:28:22.495 F/DEBUG ( 1705): ABI: ‘arm’
07-12 01:28:22.496 F/DEBUG ( 1705): pid: 1673, tid: 1702, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:28:22.497 F/DEBUG ( 1705): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:28:22.516 F/DEBUG ( 1705): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:28:22.517 F/DEBUG ( 1705): r0 00000000 r1 000006a6 r2 00000006 r3 00000008
07-12 01:28:22.517 F/DEBUG ( 1705): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:28:22.517 F/DEBUG ( 1705): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:28:22.517 F/DEBUG ( 1705): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:28:22.550 F/DEBUG ( 1705):
07-12 01:28:22.550 F/DEBUG ( 1705): backtrace:
07-12 01:28:22.550 F/DEBUG ( 1705): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:28:22.550 F/DEBUG ( 1705): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:28:22.550 F/DEBUG ( 1705): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:28:22.550 F/DEBUG ( 1705): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:28:22.550 F/DEBUG ( 1705): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:28:22.551 F/DEBUG ( 1705): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:28:22.551 F/DEBUG ( 1705): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:28:22.551 F/DEBUG ( 1705): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:28:22.551 F/DEBUG ( 1705): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:28:22.551 F/DEBUG ( 1705): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:28:22.551 F/DEBUG ( 1705): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:28:22.551 F/DEBUG ( 1705): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:28:22.796 E/ ( 1705): debuggerd: failed to kill process 1673: No such process
07-12 01:28:22.799 W/ ( 204): debuggerd: resuming target 1673
07-12 01:28:22.799 I/BootReceiver( 466): Copying /data/tombstones/tombstone_05 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:28:22.834 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:28:22.834 I/ActivityManager( 466): Process com.android.bluetooth (pid 1673) has died
07-12 01:28:22.834 D/ActivityManager( 466): cleanUpApplicationRecord – 1673
07-12 01:28:22.834 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:28:22.834 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:28:22.834 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:28:22.834 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@5584a27
07-12 01:28:22.834 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.btservice.AdapterService in 1000ms
07-12 01:28:22.834 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@b129532
07-12 01:28:22.835 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@2fc32ed
07-12 01:28:22.835 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@e53ca39
07-12 01:28:22.835 I/Zygote ( 231): Process 1673 exited due to signal (6)
07-12 01:28:22.835 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@9270f80
07-12 01:28:22.855 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:28:23.035 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:28:23.054 I/ActivityManager( 466): Start proc 1713:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:28:23.159 I/chatty ( 1713): uid=1002(bluetooth) com.android.bluetooth expire 39 lines
07-12 01:28:23.240 I/chatty ( 1713): uid=1002(bluetooth) com.android.bluetooth expire 12 lines
07-12 01:28:23.240 I/chatty ( 1713): uid=1002(bluetooth) com.android.bluetooth expire 35 lines
07-12 01:28:23.242 I/chatty ( 1713): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:28:23.243 I/chatty ( 1713): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:28:23.246 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:28:23.247 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:28:23.263 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:28:23.263 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:28:23.264 I/chatty ( 1713): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:28:23.265 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:28:23.265 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@d099e46
07-12 01:28:23.265 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@70af283
07-12 01:28:23.266 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@d341522
07-12 01:28:23.266 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@260a87e
07-12 01:28:23.266 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@95ac9b9
07-12 01:28:23.266 I/chatty ( 1713): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:28:23.267 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:28:23.267 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:28:23.269 I/chatty ( 1713): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:28:23.282 I/chatty ( 1713): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:28:23.462 I/chatty ( 1713): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:28:30.642 F/libc ( 1713): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:28:30.644 F/libc ( 1713): Fatal signal 6 (SIGABRT), code -6 in tid 1740 (hci_thread)
07-12 01:28:30.645 W/ ( 204): debuggerd: handling request: pid=1713 uid=1002 gid=1002 tid=1740
07-12 01:28:30.752 F/DEBUG ( 1743): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:28:30.753 F/DEBUG ( 1743): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:28:30.754 F/DEBUG ( 1743): Revision: ‘0’
07-12 01:28:30.754 F/DEBUG ( 1743): ABI: ‘arm’
07-12 01:28:30.755 F/DEBUG ( 1743): pid: 1713, tid: 1740, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:28:30.756 F/DEBUG ( 1743): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:28:30.781 F/DEBUG ( 1743): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:28:30.782 F/DEBUG ( 1743): r0 00000000 r1 000006cc r2 00000006 r3 00000008
07-12 01:28:30.782 F/DEBUG ( 1743): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:28:30.783 F/DEBUG ( 1743): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:28:30.783 F/DEBUG ( 1743): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:28:30.799 F/DEBUG ( 1743):
07-12 01:28:30.799 F/DEBUG ( 1743): backtrace:
07-12 01:28:30.799 F/DEBUG ( 1743): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:28:30.799 F/DEBUG ( 1743): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:28:30.799 F/DEBUG ( 1743): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:28:30.799 F/DEBUG ( 1743): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:28:30.799 F/DEBUG ( 1743): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:28:30.799 F/DEBUG ( 1743): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:28:30.799 F/DEBUG ( 1743): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:28:30.799 F/DEBUG ( 1743): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:28:30.799 F/DEBUG ( 1743): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:28:30.799 F/DEBUG ( 1743): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:28:30.799 F/DEBUG ( 1743): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:28:30.799 F/DEBUG ( 1743): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:28:31.042 W/ ( 204): debuggerd: resuming target 1713
07-12 01:28:31.043 I/BootReceiver( 466): Copying /data/tombstones/tombstone_06 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:28:31.080 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:28:31.081 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:28:31.081 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:28:31.081 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@d099e46
07-12 01:28:31.081 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@70af283
07-12 01:28:31.081 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@95ac9b9
07-12 01:28:31.081 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@260a87e
07-12 01:28:31.081 I/ActivityManager( 466): Process com.android.bluetooth (pid 1713) has died
07-12 01:28:31.081 D/ActivityManager( 466): cleanUpApplicationRecord – 1713
07-12 01:28:31.081 W/ActivityManager( 466): Service crashed 2 times, stopping: ServiceRecord{db213c5 u0 com.android.bluetooth/.btservice.AdapterService}
07-12 01:28:31.082 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:28:31.084 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@d341522
07-12 01:28:31.086 I/Zygote ( 231): Process 1713 exited due to signal (6)
07-12 01:28:31.112 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:28:31.281 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:28:31.303 I/ActivityManager( 466): Start proc 1751:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:28:31.426 I/chatty ( 1751): uid=1002(bluetooth) com.android.bluetooth expire 39 lines
07-12 01:28:31.495 I/chatty ( 1751): uid=1002(bluetooth) com.android.bluetooth expire 12 lines
07-12 01:28:31.495 I/chatty ( 1751): uid=1002(bluetooth) com.android.bluetooth expire 35 lines
07-12 01:28:31.497 I/chatty ( 1751): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:28:31.498 I/chatty ( 1751): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:28:31.501 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:28:31.501 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:28:31.518 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:28:31.518 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:28:31.519 I/chatty ( 1751): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:28:31.520 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:28:31.521 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@ff47d01
07-12 01:28:31.521 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@9df5c00
07-12 01:28:31.521 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@7e98bb3
07-12 01:28:31.521 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@5f251df
07-12 01:28:31.521 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@33471fe
07-12 01:28:31.522 I/chatty ( 1751): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:28:31.523 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:28:31.523 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:28:31.524 I/chatty ( 1751): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:28:31.538 I/chatty ( 1751): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:28:31.719 I/chatty ( 1751): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:28:38.896 F/libc ( 1751): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:28:38.898 F/libc ( 1751): Fatal signal 6 (SIGABRT), code -6 in tid 1778 (hci_thread)
07-12 01:28:38.899 W/ ( 204): debuggerd: handling request: pid=1751 uid=1002 gid=1002 tid=1778
07-12 01:28:38.991 F/DEBUG ( 1781): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:28:38.992 F/DEBUG ( 1781): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:28:38.993 F/DEBUG ( 1781): Revision: ‘0’
07-12 01:28:38.993 F/DEBUG ( 1781): ABI: ‘arm’
07-12 01:28:38.994 F/DEBUG ( 1781): pid: 1751, tid: 1778, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:28:38.995 F/DEBUG ( 1781): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:28:39.007 F/DEBUG ( 1781): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:28:39.007 F/DEBUG ( 1781): r0 00000000 r1 000006f2 r2 00000006 r3 00000008
07-12 01:28:39.007 F/DEBUG ( 1781): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:28:39.007 F/DEBUG ( 1781): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:28:39.007 F/DEBUG ( 1781): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:28:39.018 F/DEBUG ( 1781):
07-12 01:28:39.018 F/DEBUG ( 1781): backtrace:
07-12 01:28:39.018 F/DEBUG ( 1781): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:28:39.018 F/DEBUG ( 1781): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:28:39.018 F/DEBUG ( 1781): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:28:39.019 F/DEBUG ( 1781): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:28:39.019 F/DEBUG ( 1781): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:28:39.019 F/DEBUG ( 1781): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:28:39.019 F/DEBUG ( 1781): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:28:39.019 F/DEBUG ( 1781): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:28:39.019 F/DEBUG ( 1781): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:28:39.019 F/DEBUG ( 1781): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:28:39.019 F/DEBUG ( 1781): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:28:39.019 F/DEBUG ( 1781): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:28:39.262 E/ ( 1781): debuggerd: failed to kill process 1751: No such process
07-12 01:28:39.263 W/ ( 204): debuggerd: resuming target 1751
07-12 01:28:39.264 I/BootReceiver( 466): Copying /data/tombstones/tombstone_07 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:28:39.294 I/Zygote ( 231): Process 1751 exited due to signal (6)
07-12 01:28:39.294 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:28:39.294 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:28:39.294 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:28:39.294 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@ff47d01
07-12 01:28:39.294 I/ActivityManager( 466): Process com.android.bluetooth (pid 1751) has died
07-12 01:28:39.294 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@9df5c00
07-12 01:28:39.294 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@7e98bb3
07-12 01:28:39.294 D/ActivityManager( 466): cleanUpApplicationRecord – 1751
07-12 01:28:39.294 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@5f251df
07-12 01:28:39.295 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:28:39.295 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.btservice.AdapterService in 1000ms
07-12 01:28:39.295 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@33471fe
07-12 01:28:39.329 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:28:39.495 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:28:39.506 I/ActivityManager( 466): Start proc 1789:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:28:39.576 I/chatty ( 1789): uid=1002(bluetooth) com.android.bluetooth expire 39 lines
07-12 01:28:39.634 I/chatty ( 1789): uid=1002(bluetooth) com.android.bluetooth expire 12 lines
07-12 01:28:39.634 I/chatty ( 1789): uid=1002(bluetooth) com.android.bluetooth expire 35 lines
07-12 01:28:39.635 I/chatty ( 1789): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:28:39.637 I/chatty ( 1789): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:28:39.639 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:28:39.640 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:28:39.654 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:28:39.654 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:28:39.654 I/chatty ( 1789): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:28:39.656 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:28:39.656 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@bacda2e
07-12 01:28:39.656 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@a225c39
07-12 01:28:39.656 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@6733570
07-12 01:28:39.656 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@e98fe2c
07-12 01:28:39.656 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@841d5f
07-12 01:28:39.656 I/chatty ( 1789): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:28:39.658 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:28:39.658 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:28:39.659 I/chatty ( 1789): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:28:39.671 I/chatty ( 1789): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:28:39.852 I/chatty ( 1789): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:28:47.010 F/libc ( 1789): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:28:47.012 F/libc ( 1789): Fatal signal 6 (SIGABRT), code -6 in tid 1816 (hci_thread)
07-12 01:28:47.013 W/ ( 204): debuggerd: handling request: pid=1789 uid=1002 gid=1002 tid=1816
07-12 01:28:47.116 F/DEBUG ( 1819): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:28:47.117 F/DEBUG ( 1819): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:28:47.117 F/DEBUG ( 1819): Revision: ‘0’
07-12 01:28:47.117 F/DEBUG ( 1819): ABI: ‘arm’
07-12 01:28:47.118 F/DEBUG ( 1819): pid: 1789, tid: 1816, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:28:47.119 F/DEBUG ( 1819): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:28:47.135 F/DEBUG ( 1819): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:28:47.135 F/DEBUG ( 1819): r0 00000000 r1 00000718 r2 00000006 r3 00000008
07-12 01:28:47.135 F/DEBUG ( 1819): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:28:47.135 F/DEBUG ( 1819): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:28:47.135 F/DEBUG ( 1819): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:28:47.146 F/DEBUG ( 1819):
07-12 01:28:47.146 F/DEBUG ( 1819): backtrace:
07-12 01:28:47.146 F/DEBUG ( 1819): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:28:47.146 F/DEBUG ( 1819): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:28:47.147 F/DEBUG ( 1819): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:28:47.147 F/DEBUG ( 1819): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:28:47.147 F/DEBUG ( 1819): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:28:47.147 F/DEBUG ( 1819): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:28:47.147 F/DEBUG ( 1819): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:28:47.147 F/DEBUG ( 1819): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:28:47.147 F/DEBUG ( 1819): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:28:47.147 F/DEBUG ( 1819): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:28:47.147 F/DEBUG ( 1819): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:28:47.147 F/DEBUG ( 1819): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:28:47.383 E/ ( 1819): debuggerd: failed to kill process 1789: No such process
07-12 01:28:47.384 W/ ( 204): debuggerd: resuming target 1789
07-12 01:28:47.385 I/BootReceiver( 466): Copying /data/tombstones/tombstone_08 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:28:47.410 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:28:47.410 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:28:47.410 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:28:47.411 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@bacda2e
07-12 01:28:47.411 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@841d5f
07-12 01:28:47.411 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@6733570
07-12 01:28:47.411 I/ActivityManager( 466): Process com.android.bluetooth (pid 1789) has died
07-12 01:28:47.411 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@a225c39
07-12 01:28:47.411 D/ActivityManager( 466): cleanUpApplicationRecord – 1789
07-12 01:28:47.411 W/ActivityManager( 466): Service crashed 2 times, stopping: ServiceRecord{6e492fc u0 com.android.bluetooth/.btservice.AdapterService}
07-12 01:28:47.411 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@e98fe2c
07-12 01:28:47.411 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:28:47.413 I/Zygote ( 231): Process 1789 exited due to signal (6)
07-12 01:28:47.468 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:28:47.611 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:28:47.624 I/ActivityManager( 466): Start proc 1827:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:28:47.682 I/chatty ( 1827): uid=1002(bluetooth) com.android.bluetooth expire 39 lines
07-12 01:28:47.728 I/chatty ( 1827): uid=1002(bluetooth) com.android.bluetooth expire 12 lines
07-12 01:28:47.728 I/chatty ( 1827): uid=1002(bluetooth) com.android.bluetooth expire 35 lines
07-12 01:28:47.729 I/chatty ( 1827): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:28:47.730 I/chatty ( 1827): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:28:47.731 I/chatty ( 1827): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:28:47.733 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:28:47.733 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:28:47.745 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:28:47.745 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:28:47.745 I/chatty ( 1827): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:28:47.746 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:28:47.746 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@7d0fb89
07-12 01:28:47.746 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@5d0d27e
07-12 01:28:47.746 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@df610e9
07-12 01:28:47.747 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@fada3ac
07-12 01:28:47.747 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@69dd0f5
07-12 01:28:47.747 I/chatty ( 1827): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:28:47.748 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:28:47.748 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:28:47.749 I/chatty ( 1827): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:28:47.759 I/chatty ( 1827): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:28:47.940 I/chatty ( 1827): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:28:55.097 F/libc ( 1827): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:28:55.099 F/libc ( 1827): Fatal signal 6 (SIGABRT), code -6 in tid 1854 (hci_thread)
07-12 01:28:55.101 W/ ( 204): debuggerd: handling request: pid=1827 uid=1002 gid=1002 tid=1854
07-12 01:28:55.205 F/DEBUG ( 1856): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:28:55.206 F/DEBUG ( 1856): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:28:55.207 F/DEBUG ( 1856): Revision: ‘0’
07-12 01:28:55.207 F/DEBUG ( 1856): ABI: ‘arm’
07-12 01:28:55.208 F/DEBUG ( 1856): pid: 1827, tid: 1854, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:28:55.208 F/DEBUG ( 1856): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:28:55.225 F/DEBUG ( 1856): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:28:55.226 F/DEBUG ( 1856): r0 00000000 r1 0000073e r2 00000006 r3 00000008
07-12 01:28:55.226 F/DEBUG ( 1856): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:28:55.226 F/DEBUG ( 1856): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:28:55.226 F/DEBUG ( 1856): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:28:55.237 F/DEBUG ( 1856):
07-12 01:28:55.237 F/DEBUG ( 1856): backtrace:
07-12 01:28:55.237 F/DEBUG ( 1856): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:28:55.237 F/DEBUG ( 1856): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:28:55.237 F/DEBUG ( 1856): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:28:55.237 F/DEBUG ( 1856): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:28:55.237 F/DEBUG ( 1856): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:28:55.237 F/DEBUG ( 1856): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:28:55.237 F/DEBUG ( 1856): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:28:55.238 F/DEBUG ( 1856): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:28:55.238 F/DEBUG ( 1856): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:28:55.238 F/DEBUG ( 1856): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:28:55.238 F/DEBUG ( 1856): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:28:55.238 F/DEBUG ( 1856): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:28:55.571 W/ ( 204): debuggerd: resuming target 1827
07-12 01:28:55.576 I/BootReceiver( 466): Copying /data/tombstones/tombstone_09 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:28:55.600 I/Zygote ( 231): Process 1827 exited due to signal (6)
07-12 01:28:55.602 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:28:55.603 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:28:55.603 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:28:55.603 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@5d0d27e
07-12 01:28:55.603 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@7d0fb89
07-12 01:28:55.603 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@df610e9
07-12 01:28:55.603 I/ActivityManager( 466): Process com.android.bluetooth (pid 1827) has died
07-12 01:28:55.603 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@69dd0f5
07-12 01:28:55.604 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@fada3ac
07-12 01:28:55.604 D/ActivityManager( 466): cleanUpApplicationRecord – 1827
07-12 01:28:55.606 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.btservice.AdapterService in 1000ms
07-12 01:28:55.607 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 10999ms
07-12 01:28:55.675 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:28:55.802 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:28:55.814 I/ActivityManager( 466): Start proc 1863:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:28:55.866 I/chatty ( 1863): uid=1002(bluetooth) com.android.bluetooth expire 39 lines
07-12 01:28:55.927 I/chatty ( 1863): uid=1002(bluetooth) com.android.bluetooth expire 12 lines
07-12 01:28:55.928 I/chatty ( 1863): uid=1002(bluetooth) com.android.bluetooth expire 35 lines
07-12 01:28:55.930 I/chatty ( 1863): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:28:55.932 I/chatty ( 1863): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:28:55.935 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:28:55.935 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:28:55.951 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:28:55.951 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:28:55.952 I/chatty ( 1863): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:28:55.953 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:28:55.954 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@d904916
07-12 01:28:55.954 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@58033df
07-12 01:28:55.954 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@822616e
07-12 01:28:55.954 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@95ace8a
07-12 01:28:55.954 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@7d54875
07-12 01:28:55.955 I/chatty ( 1863): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:28:55.956 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:28:55.956 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:28:55.959 I/chatty ( 1863): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:28:55.974 I/chatty ( 1863): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:28:56.155 I/chatty ( 1863): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:29:03.325 F/libc ( 1863): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:29:03.327 F/libc ( 1863): Fatal signal 6 (SIGABRT), code -6 in tid 1890 (hci_thread)
07-12 01:29:03.328 W/ ( 204): debuggerd: handling request: pid=1863 uid=1002 gid=1002 tid=1890
07-12 01:29:03.424 F/DEBUG ( 1892): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:29:03.425 F/DEBUG ( 1892): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:29:03.425 F/DEBUG ( 1892): Revision: ‘0’
07-12 01:29:03.426 F/DEBUG ( 1892): ABI: ‘arm’
07-12 01:29:03.427 F/DEBUG ( 1892): pid: 1863, tid: 1890, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:29:03.428 F/DEBUG ( 1892): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:29:03.440 F/DEBUG ( 1892): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:29:03.440 F/DEBUG ( 1892): r0 00000000 r1 00000762 r2 00000006 r3 00000008
07-12 01:29:03.440 F/DEBUG ( 1892): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:29:03.440 F/DEBUG ( 1892): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:29:03.440 F/DEBUG ( 1892): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:29:03.451 F/DEBUG ( 1892):
07-12 01:29:03.451 F/DEBUG ( 1892): backtrace:
07-12 01:29:03.451 F/DEBUG ( 1892): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:29:03.451 F/DEBUG ( 1892): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:29:03.452 F/DEBUG ( 1892): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:29:03.452 F/DEBUG ( 1892): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:29:03.452 F/DEBUG ( 1892): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:29:03.452 F/DEBUG ( 1892): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:29:03.452 F/DEBUG ( 1892): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:29:03.452 F/DEBUG ( 1892): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:29:03.452 F/DEBUG ( 1892): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:29:03.452 F/DEBUG ( 1892): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:29:03.452 F/DEBUG ( 1892): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:29:03.452 F/DEBUG ( 1892): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:29:03.693 E/ ( 1892): debuggerd: failed to kill process 1863: No such process
07-12 01:29:03.695 I/BootReceiver( 466): Copying /data/tombstones/tombstone_00 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:29:03.695 W/ ( 204): debuggerd: resuming target 1863
07-12 01:29:03.717 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:29:03.717 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:29:03.717 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:29:03.717 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@d904916
07-12 01:29:03.717 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@58033df
07-12 01:29:03.717 I/Zygote ( 231): Process 1863 exited due to signal (6)
07-12 01:29:03.717 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@822616e
07-12 01:29:03.717 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@7d54875
07-12 01:29:03.718 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@95ace8a
07-12 01:29:03.718 I/ActivityManager( 466): Process com.android.bluetooth (pid 1863) has died
07-12 01:29:03.718 D/ActivityManager( 466): cleanUpApplicationRecord – 1863
07-12 01:29:03.718 W/ActivityManager( 466): Service crashed 2 times, stopping: ServiceRecord{a60ec24 u0 com.android.bluetooth/.btservice.AdapterService}
07-12 01:29:03.719 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:29:03.762 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:29:03.918 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:29:03.939 I/ActivityManager( 466): Start proc 1900:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:29:04.039 I/chatty ( 1900): uid=1002(bluetooth) com.android.bluetooth expire 21 lines
07-12 01:29:04.107 I/chatty ( 1900): uid=1002(bluetooth) com.android.bluetooth expire 8 lines
07-12 01:29:04.107 I/chatty ( 1900): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:29:04.109 I/chatty ( 1900): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:29:04.110 I/chatty ( 1900): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:29:04.114 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:29:04.114 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:29:04.130 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:29:04.130 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:29:04.131 I/chatty ( 1900): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:29:04.132 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:29:04.132 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@7208895
07-12 01:29:04.132 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@4de382c
07-12 01:29:04.133 I/chatty ( 1900): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:29:04.133 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@967300f
07-12 01:29:04.133 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@f542cfb
07-12 01:29:04.133 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@161b00a
07-12 01:29:04.135 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:29:04.135 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:29:04.136 I/chatty ( 1900): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:29:04.137 I/chatty ( 1900): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:29:04.140 I/chatty ( 1900): uid=1002(bluetooth) com.android.bluetooth expire 18 lines
07-12 01:29:04.150 I/chatty ( 1900): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:29:04.151 I/chatty ( 1900): uid=1002(bluetooth) com.android.bluetooth expire 18 lines
07-12 01:29:04.152 I/chatty ( 1900): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:29:04.332 I/chatty ( 1900): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:29:11.512 F/libc ( 1900): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:29:11.514 F/libc ( 1900): Fatal signal 6 (SIGABRT), code -6 in tid 1927 (hci_thread)
07-12 01:29:11.515 W/ ( 204): debuggerd: handling request: pid=1900 uid=1002 gid=1002 tid=1927
07-12 01:29:11.619 F/DEBUG ( 1929): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:29:11.620 F/DEBUG ( 1929): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:29:11.621 F/DEBUG ( 1929): Revision: ‘0’
07-12 01:29:11.621 F/DEBUG ( 1929): ABI: ‘arm’
07-12 01:29:11.622 F/DEBUG ( 1929): pid: 1900, tid: 1927, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:29:11.623 F/DEBUG ( 1929): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:29:11.648 F/DEBUG ( 1929): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:29:11.648 F/DEBUG ( 1929): r0 00000000 r1 00000787 r2 00000006 r3 00000008
07-12 01:29:11.649 F/DEBUG ( 1929): r4 93471978 r5 00000006 r6 93471920 r7 0000010c
07-12 01:29:11.649 F/DEBUG ( 1929): r8 00000000 r9 934714b0 sl ada580e0 fp ada582f4
07-12 01:29:11.650 F/DEBUG ( 1929): ip 00000000 sp 93471410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:29:11.665 F/DEBUG ( 1929):
07-12 01:29:11.665 F/DEBUG ( 1929): backtrace:
07-12 01:29:11.665 F/DEBUG ( 1929): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:29:11.666 F/DEBUG ( 1929): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:29:11.666 F/DEBUG ( 1929): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:29:11.666 F/DEBUG ( 1929): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:29:11.666 F/DEBUG ( 1929): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:29:11.666 F/DEBUG ( 1929): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:29:11.666 F/DEBUG ( 1929): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:29:11.666 F/DEBUG ( 1929): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:29:11.666 F/DEBUG ( 1929): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:29:11.666 F/DEBUG ( 1929): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:29:11.666 F/DEBUG ( 1929): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:29:11.666 F/DEBUG ( 1929): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:29:11.913 W/ ( 204): debuggerd: resuming target 1900
07-12 01:29:11.914 I/BootReceiver( 466): Copying /data/tombstones/tombstone_01 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:29:11.937 I/ActivityManager( 466): Process com.android.bluetooth (pid 1900) has died
07-12 01:29:11.937 D/ActivityManager( 466): cleanUpApplicationRecord – 1900
07-12 01:29:11.937 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.btservice.AdapterService in 1000ms
07-12 01:29:11.937 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 10999ms
07-12 01:29:11.937 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:29:11.937 I/Zygote ( 231): Process 1900 exited due to signal (6)
07-12 01:29:11.937 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:29:11.937 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:29:11.937 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@7208895
07-12 01:29:11.938 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@4de382c
07-12 01:29:11.938 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@967300f
07-12 01:29:11.938 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@f542cfb
07-12 01:29:11.938 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@161b00a
07-12 01:29:11.980 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:29:12.138 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:29:12.158 I/ActivityManager( 466): Start proc 1936:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:29:12.242 I/chatty ( 1936): uid=1002(bluetooth) com.android.bluetooth expire 39 lines
07-12 01:29:12.305 I/chatty ( 1936): uid=1002(bluetooth) com.android.bluetooth expire 12 lines
07-12 01:29:12.305 I/chatty ( 1936): uid=1002(bluetooth) com.android.bluetooth expire 35 lines
07-12 01:29:12.307 I/chatty ( 1936): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:29:12.308 I/chatty ( 1936): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:29:12.312 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:29:12.312 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:29:12.328 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:29:12.328 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:29:12.329 I/chatty ( 1936): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:29:12.330 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:29:12.331 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@a0a9903
07-12 01:29:12.331 I/chatty ( 1936): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:29:12.331 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@5c382f5
07-12 01:29:12.331 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@c2e389c
07-12 01:29:12.331 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@bf7307b
07-12 01:29:12.331 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@1add118
07-12 01:29:12.333 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:29:12.333 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:29:12.334 I/chatty ( 1936): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:29:12.348 I/chatty ( 1936): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:29:12.529 I/chatty ( 1936): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:29:19.717 F/libc ( 1936): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:29:19.719 F/libc ( 1936): Fatal signal 6 (SIGABRT), code -6 in tid 1964 (hci_thread)
07-12 01:29:19.720 W/ ( 204): debuggerd: handling request: pid=1936 uid=1002 gid=1002 tid=1964
07-12 01:29:19.817 F/DEBUG ( 1966): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:29:19.818 F/DEBUG ( 1966): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:29:19.818 F/DEBUG ( 1966): Revision: ‘0’
07-12 01:29:19.819 F/DEBUG ( 1966): ABI: ‘arm’
07-12 01:29:19.820 F/DEBUG ( 1966): pid: 1936, tid: 1964, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:29:19.821 F/DEBUG ( 1966): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:29:19.833 F/DEBUG ( 1966): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:29:19.833 F/DEBUG ( 1966): r0 00000000 r1 000007ac r2 00000006 r3 00000008
07-12 01:29:19.833 F/DEBUG ( 1966): r4 93370978 r5 00000006 r6 93370920 r7 0000010c
07-12 01:29:19.833 F/DEBUG ( 1966): r8 00000000 r9 933704b0 sl ada58180 fp a4abb564
07-12 01:29:19.833 F/DEBUG ( 1966): ip 00000000 sp 93370410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:29:19.845 F/DEBUG ( 1966):
07-12 01:29:19.845 F/DEBUG ( 1966): backtrace:
07-12 01:29:19.845 F/DEBUG ( 1966): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:29:19.845 F/DEBUG ( 1966): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:29:19.845 F/DEBUG ( 1966): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:29:19.845 F/DEBUG ( 1966): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:29:19.845 F/DEBUG ( 1966): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:29:19.845 F/DEBUG ( 1966): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:29:19.845 F/DEBUG ( 1966): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:29:19.845 F/DEBUG ( 1966): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:29:19.845 F/DEBUG ( 1966): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:29:19.845 F/DEBUG ( 1966): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:29:19.845 F/DEBUG ( 1966): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:29:19.845 F/DEBUG ( 1966): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:29:20.101 W/ ( 204): debuggerd: resuming target 1936
07-12 01:29:20.102 I/BootReceiver( 466): Copying /data/tombstones/tombstone_02 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:29:20.120 I/ActivityManager( 466): Process com.android.bluetooth (pid 1936) has died
07-12 01:29:20.120 D/ActivityManager( 466): cleanUpApplicationRecord – 1936
07-12 01:29:20.120 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:29:20.120 W/ActivityManager( 466): Service crashed 2 times, stopping: ServiceRecord{c053220 u0 com.android.bluetooth/.btservice.AdapterService}
07-12 01:29:20.121 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:29:20.122 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:29:20.122 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:29:20.122 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@a0a9903
07-12 01:29:20.122 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@5c382f5
07-12 01:29:20.122 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@c2e389c
07-12 01:29:20.122 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@1add118
07-12 01:29:20.123 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@bf7307b
07-12 01:29:20.124 I/Zygote ( 231): Process 1936 exited due to signal (6)
07-12 01:29:20.159 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:29:20.322 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:29:20.338 I/ActivityManager( 466): Start proc 1973:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:29:20.422 I/chatty ( 1973): uid=1002(bluetooth) com.android.bluetooth expire 25 lines
07-12 01:29:20.484 I/chatty ( 1973): uid=1002(bluetooth) com.android.bluetooth expire 10 lines
07-12 01:29:20.484 I/chatty ( 1973): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:29:20.485 I/chatty ( 1973): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:29:20.486 I/chatty ( 1973): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:29:20.487 I/chatty ( 1973): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:29:20.490 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:29:20.491 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:29:20.507 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:29:20.507 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:29:20.508 I/chatty ( 1973): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:29:20.509 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:29:20.509 I/chatty ( 1973): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:29:20.509 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@2ad0686
07-12 01:29:20.509 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@4a3988a
07-12 01:29:20.509 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@995d2a5
07-12 01:29:20.510 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@3274e98
07-12 01:29:20.510 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@d478771
07-12 01:29:20.511 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:29:20.511 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:29:20.513 I/chatty ( 1973): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:29:20.519 I/chatty ( 1973): uid=1002(bluetooth) com.android.bluetooth expire 14 lines
07-12 01:29:20.524 I/chatty ( 1973): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:29:20.525 I/chatty ( 1973): uid=1002(bluetooth) com.android.bluetooth expire 18 lines
07-12 01:29:20.526 I/chatty ( 1973): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:29:20.705 I/chatty ( 1973): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:29:27.890 F/libc ( 1973): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:29:27.892 F/libc ( 1973): Fatal signal 6 (SIGABRT), code -6 in tid 2000 (hci_thread)
07-12 01:29:27.894 W/ ( 204): debuggerd: handling request: pid=1973 uid=1002 gid=1002 tid=2000
07-12 01:29:28.000 F/DEBUG ( 2002): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:29:28.001 F/DEBUG ( 2002): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:29:28.001 F/DEBUG ( 2002): Revision: ‘0’
07-12 01:29:28.002 F/DEBUG ( 2002): ABI: ‘arm’
07-12 01:29:28.003 F/DEBUG ( 2002): pid: 1973, tid: 2000, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:29:28.004 F/DEBUG ( 2002): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:29:28.021 F/DEBUG ( 2002): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:29:28.021 F/DEBUG ( 2002): r0 00000000 r1 000007d0 r2 00000006 r3 00000008
07-12 01:29:28.021 F/DEBUG ( 2002): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:29:28.021 F/DEBUG ( 2002): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:29:28.021 F/DEBUG ( 2002): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:29:28.032 F/DEBUG ( 2002):
07-12 01:29:28.032 F/DEBUG ( 2002): backtrace:
07-12 01:29:28.032 F/DEBUG ( 2002): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:29:28.032 F/DEBUG ( 2002): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:29:28.032 F/DEBUG ( 2002): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:29:28.032 F/DEBUG ( 2002): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:29:28.033 F/DEBUG ( 2002): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:29:28.033 F/DEBUG ( 2002): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:29:28.033 F/DEBUG ( 2002): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:29:28.033 F/DEBUG ( 2002): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:29:28.033 F/DEBUG ( 2002): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:29:28.033 F/DEBUG ( 2002): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:29:28.033 F/DEBUG ( 2002): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:29:28.033 F/DEBUG ( 2002): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:29:28.271 E/ ( 2002): debuggerd: failed to kill process 1973: No such process
07-12 01:29:28.272 W/ ( 204): debuggerd: resuming target 1973
07-12 01:29:28.273 I/BootReceiver( 466): Copying /data/tombstones/tombstone_03 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:29:28.293 I/Zygote ( 231): Process 1973 exited due to signal (6)
07-12 01:29:28.293 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:29:28.294 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:29:28.294 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:29:28.294 I/ActivityManager( 466): Process com.android.bluetooth (pid 1973) has died
07-12 01:29:28.294 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@2ad0686
07-12 01:29:28.294 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@4a3988a
07-12 01:29:28.294 D/ActivityManager( 466): cleanUpApplicationRecord – 1973
07-12 01:29:28.294 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:29:28.294 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@995d2a5
07-12 01:29:28.294 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.btservice.AdapterService in 1000ms
07-12 01:29:28.294 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@d478771
07-12 01:29:28.294 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@3274e98
07-12 01:29:28.333 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:29:28.494 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:29:28.514 I/ActivityManager( 466): Start proc 2009:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:29:28.616 I/chatty ( 2009): uid=1002(bluetooth) com.android.bluetooth expire 39 lines
07-12 01:29:28.677 I/chatty ( 2009): uid=1002(bluetooth) com.android.bluetooth expire 12 lines
07-12 01:29:28.677 I/chatty ( 2009): uid=1002(bluetooth) com.android.bluetooth expire 35 lines
07-12 01:29:28.678 I/chatty ( 2009): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:29:28.680 I/chatty ( 2009): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:29:28.682 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:29:28.682 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:29:28.697 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:29:28.697 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:29:28.698 I/chatty ( 2009): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:29:28.699 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:29:28.699 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@b50532f
07-12 01:29:28.699 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@6de2efb
07-12 01:29:28.699 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@b97267a
07-12 01:29:28.700 I/chatty ( 2009): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:29:28.700 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@51f4956
07-12 01:29:28.700 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@33ef6f1
07-12 01:29:28.701 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:29:28.701 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:29:28.703 I/chatty ( 2009): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:29:28.715 I/chatty ( 2009): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:29:28.895 I/chatty ( 2009): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:29:34.879 I/WifiHAL ( 466): Got channel list with 13 channels
07-12 01:29:34.881 I/WifiHAL ( 466): Got channel list with 9 channels
07-12 01:29:34.884 I/WifiHAL ( 466): Got channel list with 4 channels
07-12 01:29:36.060 F/libc ( 2009): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:29:36.062 F/libc ( 2009): Fatal signal 6 (SIGABRT), code -6 in tid 2036 (hci_thread)
07-12 01:29:36.064 W/ ( 204): debuggerd: handling request: pid=2009 uid=1002 gid=1002 tid=2036
07-12 01:29:36.162 F/DEBUG ( 2038): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:29:36.162 F/DEBUG ( 2038): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:29:36.163 F/DEBUG ( 2038): Revision: ‘0’
07-12 01:29:36.163 F/DEBUG ( 2038): ABI: ‘arm’
07-12 01:29:36.164 F/DEBUG ( 2038): pid: 2009, tid: 2036, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:29:36.165 F/DEBUG ( 2038): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:29:36.185 F/DEBUG ( 2038): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:29:36.185 F/DEBUG ( 2038): r0 00000000 r1 000007f4 r2 00000006 r3 00000008
07-12 01:29:36.185 F/DEBUG ( 2038): r4 93471978 r5 00000006 r6 93471920 r7 0000010c
07-12 01:29:36.185 F/DEBUG ( 2038): r8 00000000 r9 934714b0 sl ada580e0 fp ada582f4
07-12 01:29:36.185 F/DEBUG ( 2038): ip 00000000 sp 93471410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:29:36.197 F/DEBUG ( 2038):
07-12 01:29:36.197 F/DEBUG ( 2038): backtrace:
07-12 01:29:36.197 F/DEBUG ( 2038): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:29:36.197 F/DEBUG ( 2038): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:29:36.197 F/DEBUG ( 2038): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:29:36.197 F/DEBUG ( 2038): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:29:36.197 F/DEBUG ( 2038): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:29:36.197 F/DEBUG ( 2038): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:29:36.197 F/DEBUG ( 2038): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:29:36.197 F/DEBUG ( 2038): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:29:36.197 F/DEBUG ( 2038): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:29:36.197 F/DEBUG ( 2038): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:29:36.197 F/DEBUG ( 2038): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:29:36.197 F/DEBUG ( 2038): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:29:36.448 E/ ( 2038): debuggerd: failed to kill process 2009: No such process
07-12 01:29:36.449 I/BootReceiver( 466): Copying /data/tombstones/tombstone_04 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:29:36.450 W/ ( 204): debuggerd: resuming target 2009
07-12 01:29:36.477 I/ActivityManager( 466): Process com.android.bluetooth (pid 2009) has died
07-12 01:29:36.477 D/ActivityManager( 466): cleanUpApplicationRecord – 2009
07-12 01:29:36.477 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:29:36.477 W/ActivityManager( 466): Service crashed 2 times, stopping: ServiceRecord{3c25e5 u0 com.android.bluetooth/.btservice.AdapterService}
07-12 01:29:36.477 I/Zygote ( 231): Process 2009 exited due to signal (6)
07-12 01:29:36.477 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:29:36.478 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:29:36.478 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:29:36.478 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@b50532f
07-12 01:29:36.478 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@6de2efb
07-12 01:29:36.478 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@b97267a
07-12 01:29:36.478 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@51f4956
07-12 01:29:36.479 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@33ef6f1
07-12 01:29:36.510 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:29:36.678 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:29:36.697 I/ActivityManager( 466): Start proc 2045:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:29:36.786 I/chatty ( 2045): uid=1002(bluetooth) com.android.bluetooth expire 34 lines
07-12 01:29:36.838 I/chatty ( 2045): uid=1002(bluetooth) com.android.bluetooth expire 10 lines
07-12 01:29:36.839 I/chatty ( 2045): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:29:36.840 I/chatty ( 2045): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:29:36.841 I/chatty ( 2045): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:29:36.844 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:29:36.844 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:29:36.857 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:29:36.857 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:29:36.858 I/chatty ( 2045): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:29:36.859 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:29:36.859 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@10cde22
07-12 01:29:36.859 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@cab18
07-12 01:29:36.859 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@970be2b
07-12 01:29:36.859 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@72c2d6
07-12 01:29:36.859 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@52e9dd7
07-12 01:29:36.860 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:29:36.861 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:29:36.862 I/chatty ( 2045): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:29:36.873 I/chatty ( 2045): uid=1002(bluetooth) com.android.bluetooth expire 5 lines
07-12 01:29:36.874 I/chatty ( 2045): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:29:36.875 I/chatty ( 2045): uid=1002(bluetooth) com.android.bluetooth expire 18 lines
07-12 01:29:36.876 I/chatty ( 2045): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:29:37.055 I/chatty ( 2045): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:29:44.222 F/libc ( 2045): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:29:44.224 F/libc ( 2045): Fatal signal 6 (SIGABRT), code -6 in tid 2072 (hci_thread)
07-12 01:29:44.225 W/ ( 204): debuggerd: handling request: pid=2045 uid=1002 gid=1002 tid=2072
07-12 01:29:44.337 F/DEBUG ( 2074): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:29:44.337 F/DEBUG ( 2074): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:29:44.338 F/DEBUG ( 2074): Revision: ‘0’
07-12 01:29:44.338 F/DEBUG ( 2074): ABI: ‘arm’
07-12 01:29:44.338 F/DEBUG ( 2074): pid: 2045, tid: 2072, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:29:44.338 F/DEBUG ( 2074): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:29:44.356 F/DEBUG ( 2074): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:29:44.357 F/DEBUG ( 2074): r0 00000000 r1 00000818 r2 00000006 r3 00000008
07-12 01:29:44.357 F/DEBUG ( 2074): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:29:44.358 F/DEBUG ( 2074): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:29:44.358 F/DEBUG ( 2074): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:29:44.372 F/DEBUG ( 2074):
07-12 01:29:44.372 F/DEBUG ( 2074): backtrace:
07-12 01:29:44.372 F/DEBUG ( 2074): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:29:44.372 F/DEBUG ( 2074): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:29:44.372 F/DEBUG ( 2074): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:29:44.372 F/DEBUG ( 2074): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:29:44.373 F/DEBUG ( 2074): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:29:44.373 F/DEBUG ( 2074): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:29:44.373 F/DEBUG ( 2074): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:29:44.373 F/DEBUG ( 2074): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:29:44.373 F/DEBUG ( 2074): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:29:44.373 F/DEBUG ( 2074): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:29:44.373 F/DEBUG ( 2074): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:29:44.373 F/DEBUG ( 2074): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:29:44.624 W/ ( 204): debuggerd: resuming target 2045
07-12 01:29:44.630 I/BootReceiver( 466): Copying /data/tombstones/tombstone_05 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:29:44.657 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:29:44.657 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:29:44.657 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:29:44.657 I/Zygote ( 231): Process 2045 exited due to signal (6)
07-12 01:29:44.657 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@10cde22
07-12 01:29:44.657 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@cab18
07-12 01:29:44.657 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@970be2b
07-12 01:29:44.657 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@72c2d6
07-12 01:29:44.657 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@52e9dd7
07-12 01:29:44.657 I/ActivityManager( 466): Process com.android.bluetooth (pid 2045) has died
07-12 01:29:44.657 D/ActivityManager( 466): cleanUpApplicationRecord – 2045
07-12 01:29:44.658 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:29:44.658 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.btservice.AdapterService in 1000ms
07-12 01:29:44.706 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:29:44.856 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:29:44.877 I/ActivityManager( 466): Start proc 2081:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:29:44.962 I/chatty ( 2081): uid=1002(bluetooth) com.android.bluetooth expire 39 lines
07-12 01:29:45.027 I/chatty ( 2081): uid=1002(bluetooth) com.android.bluetooth expire 12 lines
07-12 01:29:45.027 I/chatty ( 2081): uid=1002(bluetooth) com.android.bluetooth expire 35 lines
07-12 01:29:45.028 I/chatty ( 2081): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:29:45.029 I/chatty ( 2081): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:29:45.030 I/chatty ( 2081): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:29:45.033 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:29:45.033 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:29:45.050 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:29:45.050 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:29:45.050 I/chatty ( 2081): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:29:45.052 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:29:45.052 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@80e7e64
07-12 01:29:45.052 I/chatty ( 2081): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:29:45.052 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@e165971
07-12 01:29:45.052 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@f344288
07-12 01:29:45.053 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@fbe5957
07-12 01:29:45.053 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@43ae6c4
07-12 01:29:45.054 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:29:45.054 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:29:45.056 I/chatty ( 2081): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:29:45.073 I/chatty ( 2081): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:29:45.256 I/chatty ( 2081): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:29:52.439 F/libc ( 2081): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:29:52.441 F/libc ( 2081): Fatal signal 6 (SIGABRT), code -6 in tid 2108 (hci_thread)
07-12 01:29:52.443 W/ ( 204): debuggerd: handling request: pid=2081 uid=1002 gid=1002 tid=2108
07-12 01:29:52.557 F/DEBUG ( 2110): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:29:52.557 F/DEBUG ( 2110): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:29:52.558 F/DEBUG ( 2110): Revision: ‘0’
07-12 01:29:52.558 F/DEBUG ( 2110): ABI: ‘arm’
07-12 01:29:52.560 F/DEBUG ( 2110): pid: 2081, tid: 2108, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:29:52.560 F/DEBUG ( 2110): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:29:52.576 F/DEBUG ( 2110): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:29:52.576 F/DEBUG ( 2110): r0 00000000 r1 0000083c r2 00000006 r3 00000008
07-12 01:29:52.576 F/DEBUG ( 2110): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:29:52.576 F/DEBUG ( 2110): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:29:52.576 F/DEBUG ( 2110): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:29:52.588 F/DEBUG ( 2110):
07-12 01:29:52.588 F/DEBUG ( 2110): backtrace:
07-12 01:29:52.588 F/DEBUG ( 2110): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:29:52.588 F/DEBUG ( 2110): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:29:52.588 F/DEBUG ( 2110): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:29:52.588 F/DEBUG ( 2110): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:29:52.588 F/DEBUG ( 2110): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:29:52.588 F/DEBUG ( 2110): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:29:52.588 F/DEBUG ( 2110): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:29:52.588 F/DEBUG ( 2110): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:29:52.588 F/DEBUG ( 2110): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:29:52.588 F/DEBUG ( 2110): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:29:52.588 F/DEBUG ( 2110): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:29:52.588 F/DEBUG ( 2110): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:29:52.840 E/ ( 2110): debuggerd: failed to kill process 2081: No such process
07-12 01:29:52.842 I/BootReceiver( 466): Copying /data/tombstones/tombstone_06 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:29:52.843 W/ ( 204): debuggerd: resuming target 2081
07-12 01:29:52.870 I/Zygote ( 231): Process 2081 exited due to signal (6)
07-12 01:29:52.870 I/ActivityManager( 466): Process com.android.bluetooth (pid 2081) has died
07-12 01:29:52.870 D/ActivityManager( 466): cleanUpApplicationRecord – 2081
07-12 01:29:52.870 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:29:52.871 W/ActivityManager( 466): Service crashed 2 times, stopping: ServiceRecord{dccf9b1 u0 com.android.bluetooth/.btservice.AdapterService}
07-12 01:29:52.871 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:29:52.871 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:29:52.871 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 6 receivers.
07-12 01:29:52.872 E/BluetoothManagerService( 466): Unable to call onBluetoothServiceDown() on callback #0
07-12 01:29:52.872 E/BluetoothManagerService( 466): android.os.DeadObjectException
07-12 01:29:52.872 E/BluetoothManagerService( 466): at android.os.BinderProxy.transactNative(Native Method)
07-12 01:29:52.872 E/BluetoothManagerService( 466): at android.os.BinderProxy.transact(Binder.java:615)
07-12 01:29:52.872 E/BluetoothManagerService( 466): at android.bluetooth.IBluetoothManagerCallback$Stub$Proxy.onBluetoothServiceDown(IBluetoothManagerCallback.java:105)
07-12 01:29:52.872 E/BluetoothManagerService( 466): at com.android.server.BluetoothManagerService.sendBluetoothServiceDownCallback(BluetoothManagerService.java:1129)
07-12 01:29:52.872 E/BluetoothManagerService( 466): at com.android.server.BluetoothManagerService.-wrap12(BluetoothManagerService.java)
07-12 01:29:52.872 E/BluetoothManagerService( 466): at com.android.server.BluetoothManagerService$BluetoothHandler.handleMessage(BluetoothManagerService.java:1530)
07-12 01:29:52.872 E/BluetoothManagerService( 466): at android.os.Handler.dispatchMessage(Handler.java:102)
07-12 01:29:52.872 E/BluetoothManagerService( 466): at android.os.Looper.loop(Looper.java:154)
07-12 01:29:52.872 E/BluetoothManagerService( 466): at android.os.HandlerThread.run(HandlerThread.java:61)
07-12 01:29:52.872 E/BluetoothManagerService( 466): at com.android.server.ServiceThread.run(ServiceThread.java:46)
07-12 01:29:52.872 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@80e7e64
07-12 01:29:52.872 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@e165971
07-12 01:29:52.872 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@f344288
07-12 01:29:52.872 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@43ae6c4
07-12 01:29:52.872 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@fbe5957
07-12 01:29:52.904 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:29:53.072 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:29:53.086 I/ActivityManager( 466): Start proc 2117:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:29:53.182 I/chatty ( 2117): uid=1002(bluetooth) com.android.bluetooth expire 34 lines
07-12 01:29:53.250 I/chatty ( 2117): uid=1002(bluetooth) com.android.bluetooth expire 10 lines
07-12 01:29:53.251 I/chatty ( 2117): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:29:53.252 I/chatty ( 2117): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:29:53.254 I/chatty ( 2117): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:29:53.257 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:29:53.257 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:29:53.273 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:29:53.273 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:29:53.274 I/chatty ( 2117): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:29:53.275 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:29:53.276 I/chatty ( 2117): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:29:53.276 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@f8c24fb
07-12 01:29:53.276 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@d2ab356
07-12 01:29:53.276 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@2b5f421
07-12 01:29:53.276 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@38ebc44
07-12 01:29:53.276 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@efc29ad
07-12 01:29:53.278 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:29:53.278 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:29:53.279 I/chatty ( 2117): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:29:53.295 I/chatty ( 2117): uid=1002(bluetooth) com.android.bluetooth expire 5 lines
07-12 01:29:53.296 I/chatty ( 2117): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:29:53.297 I/chatty ( 2117): uid=1002(bluetooth) com.android.bluetooth expire 18 lines
07-12 01:29:53.298 I/chatty ( 2117): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:29:53.479 I/chatty ( 2117): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:30:00.655 F/libc ( 2117): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:30:00.657 F/libc ( 2117): Fatal signal 6 (SIGABRT), code -6 in tid 2144 (hci_thread)
07-12 01:30:00.658 W/ ( 204): debuggerd: handling request: pid=2117 uid=1002 gid=1002 tid=2144
07-12 01:30:00.763 F/DEBUG ( 2146): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:30:00.764 F/DEBUG ( 2146): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:30:00.764 F/DEBUG ( 2146): Revision: ‘0’
07-12 01:30:00.764 F/DEBUG ( 2146): ABI: ‘arm’
07-12 01:30:00.765 F/DEBUG ( 2146): pid: 2117, tid: 2144, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:30:00.766 F/DEBUG ( 2146): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:30:00.779 F/DEBUG ( 2146): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:30:00.779 F/DEBUG ( 2146): r0 00000000 r1 00000860 r2 00000006 r3 00000008
07-12 01:30:00.779 F/DEBUG ( 2146): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:30:00.779 F/DEBUG ( 2146): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:30:00.779 F/DEBUG ( 2146): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:30:00.790 F/DEBUG ( 2146):
07-12 01:30:00.790 F/DEBUG ( 2146): backtrace:
07-12 01:30:00.790 F/DEBUG ( 2146): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:30:00.791 F/DEBUG ( 2146): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:30:00.791 F/DEBUG ( 2146): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:30:00.791 F/DEBUG ( 2146): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:30:00.791 F/DEBUG ( 2146): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:30:00.791 F/DEBUG ( 2146): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:30:00.791 F/DEBUG ( 2146): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:30:00.791 F/DEBUG ( 2146): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:30:00.791 F/DEBUG ( 2146): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:30:00.791 F/DEBUG ( 2146): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:30:00.791 F/DEBUG ( 2146): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:30:00.791 F/DEBUG ( 2146): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:30:01.030 E/ ( 2146): debuggerd: failed to kill process 2117: No such process
07-12 01:30:01.031 W/ ( 204): debuggerd: resuming target 2117
07-12 01:30:01.031 I/BootReceiver( 466): Copying /data/tombstones/tombstone_07 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:30:01.055 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:30:01.055 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:30:01.055 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:30:01.055 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@f8c24fb
07-12 01:30:01.055 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@d2ab356
07-12 01:30:01.055 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@2b5f421
07-12 01:30:01.055 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@efc29ad
07-12 01:30:01.055 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@38ebc44
07-12 01:30:01.056 I/ActivityManager( 466): Process com.android.bluetooth (pid 2117) has died
07-12 01:30:01.056 D/ActivityManager( 466): cleanUpApplicationRecord – 2117
07-12 01:30:01.056 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:30:01.056 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.btservice.AdapterService in 1000ms
07-12 01:30:01.058 I/Zygote ( 231): Process 2117 exited due to signal (6)
07-12 01:30:01.101 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:30:01.255 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:30:01.270 I/ActivityManager( 466): Start proc 2153:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:30:01.352 I/chatty ( 2153): uid=1002(bluetooth) com.android.bluetooth expire 39 lines
07-12 01:30:01.413 I/chatty ( 2153): uid=1002(bluetooth) com.android.bluetooth expire 12 lines
07-12 01:30:01.413 I/chatty ( 2153): uid=1002(bluetooth) com.android.bluetooth expire 35 lines
07-12 01:30:01.414 I/chatty ( 2153): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:30:01.416 I/chatty ( 2153): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:30:01.418 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:30:01.419 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:30:01.433 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:30:01.433 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:30:01.433 I/chatty ( 2153): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:30:01.435 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:30:01.435 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@d09119
07-12 01:30:01.435 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@856bfd7
07-12 01:30:01.435 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@a613046
07-12 01:30:01.435 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@edea4e2
07-12 01:30:01.435 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@1bb112d
07-12 01:30:01.436 I/chatty ( 2153): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:30:01.437 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:30:01.437 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:30:01.438 I/chatty ( 2153): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:30:01.453 I/chatty ( 2153): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:30:01.636 I/chatty ( 2153): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:30:08.819 F/libc ( 2153): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:30:08.821 F/libc ( 2153): Fatal signal 6 (SIGABRT), code -6 in tid 2180 (hci_thread)
07-12 01:30:08.822 W/ ( 204): debuggerd: handling request: pid=2153 uid=1002 gid=1002 tid=2180
07-12 01:30:08.920 F/DEBUG ( 2182): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:30:08.921 F/DEBUG ( 2182): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:30:08.922 F/DEBUG ( 2182): Revision: ‘0’
07-12 01:30:08.922 F/DEBUG ( 2182): ABI: ‘arm’
07-12 01:30:08.923 F/DEBUG ( 2182): pid: 2153, tid: 2180, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:30:08.924 F/DEBUG ( 2182): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:30:08.936 F/DEBUG ( 2182): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:30:08.936 F/DEBUG ( 2182): r0 00000000 r1 00000884 r2 00000006 r3 00000008
07-12 01:30:08.936 F/DEBUG ( 2182): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:30:08.937 F/DEBUG ( 2182): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:30:08.937 F/DEBUG ( 2182): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:30:08.948 F/DEBUG ( 2182):
07-12 01:30:08.948 F/DEBUG ( 2182): backtrace:
07-12 01:30:08.948 F/DEBUG ( 2182): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:30:08.948 F/DEBUG ( 2182): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:30:08.948 F/DEBUG ( 2182): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:30:08.948 F/DEBUG ( 2182): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:30:08.948 F/DEBUG ( 2182): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:30:08.948 F/DEBUG ( 2182): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:30:08.948 F/DEBUG ( 2182): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:30:08.948 F/DEBUG ( 2182): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:30:08.949 F/DEBUG ( 2182): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:30:08.949 F/DEBUG ( 2182): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:30:08.949 F/DEBUG ( 2182): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:30:08.949 F/DEBUG ( 2182): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:30:09.203 I/BootReceiver( 466): Copying /data/tombstones/tombstone_08 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:30:09.203 W/ ( 204): debuggerd: resuming target 2153
07-12 01:30:09.230 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:30:09.230 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:30:09.230 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:30:09.230 I/Zygote ( 231): Process 2153 exited due to signal (6)
07-12 01:30:09.230 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@d09119
07-12 01:30:09.230 I/ActivityManager( 466): Process com.android.bluetooth (pid 2153) has died
07-12 01:30:09.230 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@856bfd7
07-12 01:30:09.230 D/ActivityManager( 466): cleanUpApplicationRecord – 2153
07-12 01:30:09.231 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@a613046
07-12 01:30:09.231 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:30:09.231 W/ActivityManager( 466): Service crashed 2 times, stopping: ServiceRecord{280007e u0 com.android.bluetooth/.btservice.AdapterService}
07-12 01:30:09.231 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@edea4e2
07-12 01:30:09.231 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@1bb112d
07-12 01:30:09.278 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:30:09.431 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:30:09.450 I/ActivityManager( 466): Start proc 2189:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:30:09.536 I/chatty ( 2189): uid=1002(bluetooth) com.android.bluetooth expire 25 lines
07-12 01:30:09.591 I/chatty ( 2189): uid=1002(bluetooth) com.android.bluetooth expire 10 lines
07-12 01:30:09.592 I/chatty ( 2189): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:30:09.593 I/chatty ( 2189): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:30:09.594 I/chatty ( 2189): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:30:09.597 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:30:09.597 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:30:09.611 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:30:09.612 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:30:09.612 I/chatty ( 2189): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:30:09.613 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:30:09.614 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@14306c0
07-12 01:30:09.614 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@2ad60c4
07-12 01:30:09.614 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@43b1207
07-12 01:30:09.614 I/chatty ( 2189): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:30:09.614 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@3d54073
07-12 01:30:09.614 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@1b03662
07-12 01:30:09.615 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:30:09.615 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:30:09.617 I/chatty ( 2189): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:30:09.626 I/chatty ( 2189): uid=1002(bluetooth) com.android.bluetooth expire 14 lines
07-12 01:30:09.633 I/chatty ( 2189): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:30:09.634 I/chatty ( 2189): uid=1002(bluetooth) com.android.bluetooth expire 18 lines
07-12 01:30:09.635 I/chatty ( 2189): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:30:09.810 I/chatty ( 2189): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:30:16.984 F/libc ( 2189): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:30:16.985 F/libc ( 2189): Fatal signal 6 (SIGABRT), code -6 in tid 2216 (hci_thread)
07-12 01:30:16.987 W/ ( 204): debuggerd: handling request: pid=2189 uid=1002 gid=1002 tid=2216
07-12 01:30:17.104 F/DEBUG ( 2218): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:30:17.105 F/DEBUG ( 2218): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:30:17.105 F/DEBUG ( 2218): Revision: ‘0’
07-12 01:30:17.106 F/DEBUG ( 2218): ABI: ‘arm’
07-12 01:30:17.107 F/DEBUG ( 2218): pid: 2189, tid: 2216, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:30:17.108 F/DEBUG ( 2218): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:30:17.124 F/DEBUG ( 2218): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:30:17.124 F/DEBUG ( 2218): r0 00000000 r1 000008a8 r2 00000006 r3 00000008
07-12 01:30:17.124 F/DEBUG ( 2218): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:30:17.124 F/DEBUG ( 2218): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:30:17.125 F/DEBUG ( 2218): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:30:17.141 F/DEBUG ( 2218):
07-12 01:30:17.141 F/DEBUG ( 2218): backtrace:
07-12 01:30:17.141 F/DEBUG ( 2218): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:30:17.141 F/DEBUG ( 2218): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:30:17.141 F/DEBUG ( 2218): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:30:17.141 F/DEBUG ( 2218): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:30:17.141 F/DEBUG ( 2218): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:30:17.141 F/DEBUG ( 2218): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:30:17.141 F/DEBUG ( 2218): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:30:17.141 F/DEBUG ( 2218): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:30:17.141 F/DEBUG ( 2218): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:30:17.141 F/DEBUG ( 2218): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:30:17.142 F/DEBUG ( 2218): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:30:17.142 F/DEBUG ( 2218): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:30:17.395 I/BootReceiver( 466): Copying /data/tombstones/tombstone_09 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:30:17.395 W/ ( 204): debuggerd: resuming target 2189
07-12 01:30:17.430 I/Zygote ( 231): Process 2189 exited due to signal (6)
07-12 01:30:17.430 I/ActivityManager( 466): Process com.android.bluetooth (pid 2189) has died
07-12 01:30:17.431 D/ActivityManager( 466): cleanUpApplicationRecord – 2189
07-12 01:30:17.431 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:30:17.431 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:30:17.431 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:30:17.431 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.btservice.AdapterService in 1000ms
07-12 01:30:17.431 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:30:17.431 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@14306c0
07-12 01:30:17.431 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@2ad60c4
07-12 01:30:17.432 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@3d54073
07-12 01:30:17.432 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@1b03662
07-12 01:30:17.432 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@43b1207
07-12 01:30:17.455 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:30:17.631 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:30:17.646 I/ActivityManager( 466): Start proc 2225:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:30:17.742 I/chatty ( 2225): uid=1002(bluetooth) com.android.bluetooth expire 39 lines
07-12 01:30:17.805 I/chatty ( 2225): uid=1002(bluetooth) com.android.bluetooth expire 12 lines
07-12 01:30:17.805 I/chatty ( 2225): uid=1002(bluetooth) com.android.bluetooth expire 35 lines
07-12 01:30:17.806 I/chatty ( 2225): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:30:17.807 I/chatty ( 2225): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:30:17.808 I/chatty ( 2225): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:30:17.811 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:30:17.811 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:30:17.828 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:30:17.828 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:30:17.828 I/chatty ( 2225): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:30:17.830 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:30:17.830 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@e572ec6
07-12 01:30:17.830 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@2e61bad
07-12 01:30:17.830 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@50eff34
07-12 01:30:17.830 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@a6533f3
07-12 01:30:17.830 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@761ab30
07-12 01:30:17.832 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:30:17.832 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:30:17.834 I/chatty ( 2225): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:30:17.854 I/chatty ( 2225): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:30:18.035 I/chatty ( 2225): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:30:25.213 F/libc ( 2225): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:30:25.215 F/libc ( 2225): Fatal signal 6 (SIGABRT), code -6 in tid 2251 (hci_thread)
07-12 01:30:25.216 W/ ( 204): debuggerd: handling request: pid=2225 uid=1002 gid=1002 tid=2251
07-12 01:30:25.310 F/DEBUG ( 2253): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:30:25.311 F/DEBUG ( 2253): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:30:25.311 F/DEBUG ( 2253): Revision: ‘0’
07-12 01:30:25.312 F/DEBUG ( 2253): ABI: ‘arm’
07-12 01:30:25.313 F/DEBUG ( 2253): pid: 2225, tid: 2251, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:30:25.314 F/DEBUG ( 2253): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:30:25.332 F/DEBUG ( 2253): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:30:25.332 F/DEBUG ( 2253): r0 00000000 r1 000008cb r2 00000006 r3 00000008
07-12 01:30:25.332 F/DEBUG ( 2253): r4 93570978 r5 00000006 r6 93570920 r7 0000010c
07-12 01:30:25.332 F/DEBUG ( 2253): r8 00000000 r9 935704b0 sl ada580e0 fp a4abb4c4
07-12 01:30:25.332 F/DEBUG ( 2253): ip 00000000 sp 93570410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:30:25.344 F/DEBUG ( 2253):
07-12 01:30:25.344 F/DEBUG ( 2253): backtrace:
07-12 01:30:25.344 F/DEBUG ( 2253): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:30:25.344 F/DEBUG ( 2253): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:30:25.344 F/DEBUG ( 2253): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:30:25.344 F/DEBUG ( 2253): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:30:25.344 F/DEBUG ( 2253): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:30:25.344 F/DEBUG ( 2253): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:30:25.344 F/DEBUG ( 2253): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:30:25.344 F/DEBUG ( 2253): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:30:25.344 F/DEBUG ( 2253): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:30:25.344 F/DEBUG ( 2253): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:30:25.344 F/DEBUG ( 2253): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:30:25.344 F/DEBUG ( 2253): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:30:25.589 E/ ( 2253): debuggerd: failed to kill process 2225: No such process
07-12 01:30:25.591 I/BootReceiver( 466): Copying /data/tombstones/tombstone_00 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:30:25.591 W/ ( 204): debuggerd: resuming target 2225
07-12 01:30:25.627 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:30:25.628 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:30:25.628 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:30:25.628 I/ActivityManager( 466): Process com.android.bluetooth (pid 2225) has died
07-12 01:30:25.628 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@e572ec6
07-12 01:30:25.628 D/ActivityManager( 466): cleanUpApplicationRecord – 2225
07-12 01:30:25.628 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@2e61bad
07-12 01:30:25.628 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:30:25.628 W/ActivityManager( 466): Service crashed 2 times, stopping: ServiceRecord{3c090a7 u0 com.android.bluetooth/.btservice.AdapterService}
07-12 01:30:25.628 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@50eff34
07-12 01:30:25.628 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@a6533f3
07-12 01:30:25.630 I/Zygote ( 231): Process 2225 exited due to signal (6)
07-12 01:30:25.632 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@761ab30
07-12 01:30:25.652 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:30:25.828 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:30:25.845 I/ActivityManager( 466): Start proc 2260:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:30:25.936 I/chatty ( 2260): uid=1002(bluetooth) com.android.bluetooth expire 26 lines
07-12 01:30:26.016 I/chatty ( 2260): uid=1002(bluetooth) com.android.bluetooth expire 10 lines
07-12 01:30:26.016 I/chatty ( 2260): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:30:26.017 I/chatty ( 2260): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:30:26.018 I/chatty ( 2260): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:30:26.019 I/chatty ( 2260): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:30:26.022 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:30:26.022 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:30:26.039 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:30:26.039 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:30:26.040 I/chatty ( 2260): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:30:26.041 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:30:26.041 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@5d72805
07-12 01:30:26.041 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@d36aee2
07-12 01:30:26.042 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@ddeb3a9
07-12 01:30:26.042 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@3dd58b0
07-12 01:30:26.045 I/chatty ( 2260): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:30:26.046 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:30:26.046 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:30:26.047 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@f5cb15d
07-12 01:30:26.048 I/chatty ( 2260): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:30:26.056 I/chatty ( 2260): uid=1002(bluetooth) com.android.bluetooth expire 13 lines
07-12 01:30:26.061 I/chatty ( 2260): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:30:26.062 I/chatty ( 2260): uid=1002(bluetooth) com.android.bluetooth expire 18 lines
07-12 01:30:26.063 I/chatty ( 2260): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:30:26.245 I/chatty ( 2260): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:30:33.426 F/libc ( 2260): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:30:33.428 F/libc ( 2260): Fatal signal 6 (SIGABRT), code -6 in tid 2288 (hci_thread)
07-12 01:30:33.430 W/ ( 204): debuggerd: handling request: pid=2260 uid=1002 gid=1002 tid=2288
07-12 01:30:33.530 F/DEBUG ( 2290): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:30:33.531 F/DEBUG ( 2290): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:30:33.531 F/DEBUG ( 2290): Revision: ‘0’
07-12 01:30:33.532 F/DEBUG ( 2290): ABI: ‘arm’
07-12 01:30:33.533 F/DEBUG ( 2290): pid: 2260, tid: 2288, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:30:33.534 F/DEBUG ( 2290): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:30:33.548 F/DEBUG ( 2290): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:30:33.548 F/DEBUG ( 2290): r0 00000000 r1 000008f0 r2 00000006 r3 00000008
07-12 01:30:33.548 F/DEBUG ( 2290): r4 93275978 r5 00000006 r6 93275920 r7 0000010c
07-12 01:30:33.548 F/DEBUG ( 2290): r8 00000000 r9 932754b0 sl ada58180 fp a4abb564
07-12 01:30:33.548 F/DEBUG ( 2290): ip 00000000 sp 93275410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:30:33.559 F/DEBUG ( 2290):
07-12 01:30:33.559 F/DEBUG ( 2290): backtrace:
07-12 01:30:33.560 F/DEBUG ( 2290): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:30:33.560 F/DEBUG ( 2290): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:30:33.560 F/DEBUG ( 2290): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:30:33.560 F/DEBUG ( 2290): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:30:33.560 F/DEBUG ( 2290): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:30:33.560 F/DEBUG ( 2290): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:30:33.560 F/DEBUG ( 2290): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:30:33.560 F/DEBUG ( 2290): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:30:33.560 F/DEBUG ( 2290): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:30:33.560 F/DEBUG ( 2290): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:30:33.560 F/DEBUG ( 2290): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:30:33.560 F/DEBUG ( 2290): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:30:33.814 E/ ( 2290): debuggerd: failed to kill process 2260: No such process
07-12 01:30:33.816 I/BootReceiver( 466): Copying /data/tombstones/tombstone_01 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:30:33.817 W/ ( 204): debuggerd: resuming target 2260
07-12 01:30:33.840 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:30:33.840 I/ActivityManager( 466): Process com.android.bluetooth (pid 2260) has died
07-12 01:30:33.840 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:30:33.840 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:30:33.840 D/ActivityManager( 466): cleanUpApplicationRecord – 2260
07-12 01:30:33.841 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@5d72805
07-12 01:30:33.841 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.btservice.AdapterService in 1000ms
07-12 01:30:33.841 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@d36aee2
07-12 01:30:33.841 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 11000ms
07-12 01:30:33.841 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@ddeb3a9
07-12 01:30:33.841 I/Zygote ( 231): Process 2260 exited due to signal (6)
07-12 01:30:33.841 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@3dd58b0
07-12 01:30:33.842 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@f5cb15d
07-12 01:30:33.890 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:30:34.053 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:30:34.075 I/ActivityManager( 466): Start proc 2297:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:30:34.159 I/chatty ( 2297): uid=1002(bluetooth) com.android.bluetooth expire 39 lines
07-12 01:30:34.212 I/chatty ( 2297): uid=1002(bluetooth) com.android.bluetooth expire 12 lines
07-12 01:30:34.212 I/chatty ( 2297): uid=1002(bluetooth) com.android.bluetooth expire 35 lines
07-12 01:30:34.214 I/chatty ( 2297): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:30:34.215 I/chatty ( 2297): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:30:34.218 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:30:34.218 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:30:34.232 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:30:34.232 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:30:34.233 I/chatty ( 2297): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:30:34.234 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:30:34.234 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@26ed04f
07-12 01:30:34.234 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@e5d8273
07-12 01:30:34.234 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@3700ad2
07-12 01:30:34.234 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@e649329
07-12 01:30:34.234 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@462d2e
07-12 01:30:34.235 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:30:34.235 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:30:34.239 I/chatty ( 2297): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:30:34.252 I/chatty ( 2297): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:30:34.432 I/chatty ( 2297): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:30:41.606 F/libc ( 2297): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:30:41.607 F/libc ( 2297): Fatal signal 6 (SIGABRT), code -6 in tid 2324 (hci_thread)
07-12 01:30:41.609 W/ ( 204): debuggerd: handling request: pid=2297 uid=1002 gid=1002 tid=2324
07-12 01:30:41.707 F/DEBUG ( 2326): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:30:41.708 F/DEBUG ( 2326): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:30:41.708 F/DEBUG ( 2326): Revision: ‘0’
07-12 01:30:41.709 F/DEBUG ( 2326): ABI: ‘arm’
07-12 01:30:41.710 F/DEBUG ( 2326): pid: 2297, tid: 2324, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:30:41.710 F/DEBUG ( 2326): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:30:41.723 F/DEBUG ( 2326): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:30:41.723 F/DEBUG ( 2326): r0 00000000 r1 00000914 r2 00000006 r3 00000008
07-12 01:30:41.723 F/DEBUG ( 2326): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:30:41.723 F/DEBUG ( 2326): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:30:41.723 F/DEBUG ( 2326): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:30:41.735 F/DEBUG ( 2326):
07-12 01:30:41.735 F/DEBUG ( 2326): backtrace:
07-12 01:30:41.735 F/DEBUG ( 2326): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:30:41.735 F/DEBUG ( 2326): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:30:41.735 F/DEBUG ( 2326): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:30:41.735 F/DEBUG ( 2326): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:30:41.735 F/DEBUG ( 2326): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:30:41.735 F/DEBUG ( 2326): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:30:41.735 F/DEBUG ( 2326): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:30:41.735 F/DEBUG ( 2326): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:30:41.735 F/DEBUG ( 2326): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:30:41.735 F/DEBUG ( 2326): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:30:41.735 F/DEBUG ( 2326): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:30:41.735 F/DEBUG ( 2326): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:30:41.986 E/ ( 2326): debuggerd: failed to kill process 2297: No such process
07-12 01:30:41.988 W/ ( 204): debuggerd: resuming target 2297
07-12 01:30:41.989 I/BootReceiver( 466): Copying /data/tombstones/tombstone_02 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:30:42.023 I/Zygote ( 231): Process 2297 exited due to signal (6)
07-12 01:30:42.024 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:30:42.024 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:30:42.024 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:30:42.024 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@26ed04f
07-12 01:30:42.024 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@e5d8273
07-12 01:30:42.024 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@3700ad2
07-12 01:30:42.024 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@462d2e
07-12 01:30:42.024 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@e649329
07-12 01:30:42.025 I/ActivityManager( 466): Process com.android.bluetooth (pid 2297) has died
07-12 01:30:42.025 D/ActivityManager( 466): cleanUpApplicationRecord – 2297
07-12 01:30:42.025 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:30:42.025 W/ActivityManager( 466): Service crashed 2 times, stopping: ServiceRecord{41fd650 u0 com.android.bluetooth/.btservice.AdapterService}
07-12 01:30:42.071 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:30:42.223 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:30:42.249 I/ActivityManager( 466): Start proc 2333:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:30:42.329 I/chatty ( 2333): uid=1002(bluetooth) com.android.bluetooth expire 21 lines
07-12 01:30:42.381 I/chatty ( 2333): uid=1002(bluetooth) com.android.bluetooth expire 10 lines
07-12 01:30:42.381 I/chatty ( 2333): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:30:42.382 I/chatty ( 2333): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:30:42.384 I/chatty ( 2333): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:30:42.386 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:30:42.386 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:30:42.401 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:30:42.401 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:30:42.402 I/chatty ( 2333): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:30:42.403 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:30:42.403 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@55e6e09
07-12 01:30:42.403 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@381c530
07-12 01:30:42.403 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@a6cc7a3
07-12 01:30:42.403 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@5f56ae
07-12 01:30:42.403 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@f3970cf
07-12 01:30:42.405 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:30:42.405 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:30:42.409 I/chatty ( 2333): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:30:42.412 I/chatty ( 2333): uid=1002(bluetooth) com.android.bluetooth expire 18 lines
07-12 01:30:42.421 I/chatty ( 2333): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:30:42.421 I/chatty ( 2333): uid=1002(bluetooth) com.android.bluetooth expire 18 lines
07-12 01:30:42.422 I/chatty ( 2333): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:30:42.602 I/chatty ( 2333): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:30:49.784 F/libc ( 2333): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:30:49.785 F/libc ( 2333): Fatal signal 6 (SIGABRT), code -6 in tid 2360 (hci_thread)
07-12 01:30:49.787 W/ ( 204): debuggerd: handling request: pid=2333 uid=1002 gid=1002 tid=2360
07-12 01:30:49.886 F/DEBUG ( 2362): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:30:49.886 F/DEBUG ( 2362): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:30:49.886 F/DEBUG ( 2362): Revision: ‘0’
07-12 01:30:49.886 F/DEBUG ( 2362): ABI: ‘arm’
07-12 01:30:49.886 F/DEBUG ( 2362): pid: 2333, tid: 2360, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:30:49.886 F/DEBUG ( 2362): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:30:49.890 F/DEBUG ( 2362): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:30:49.890 F/DEBUG ( 2362): r0 00000000 r1 00000938 r2 00000006 r3 00000008
07-12 01:30:49.890 F/DEBUG ( 2362): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:30:49.890 F/DEBUG ( 2362): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:30:49.890 F/DEBUG ( 2362): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:30:49.904 F/DEBUG ( 2362):
07-12 01:30:49.904 F/DEBUG ( 2362): backtrace:
07-12 01:30:49.904 F/DEBUG ( 2362): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:30:49.905 F/DEBUG ( 2362): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:30:49.905 F/DEBUG ( 2362): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:30:49.905 F/DEBUG ( 2362): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:30:49.905 F/DEBUG ( 2362): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:30:49.905 F/DEBUG ( 2362): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:30:49.905 F/DEBUG ( 2362): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:30:49.905 F/DEBUG ( 2362): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:30:49.905 F/DEBUG ( 2362): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:30:49.905 F/DEBUG ( 2362): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:30:49.905 F/DEBUG ( 2362): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:30:49.905 F/DEBUG ( 2362): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:30:50.165 W/ ( 204): debuggerd: resuming target 2333
07-12 01:30:50.165 I/BootReceiver( 466): Copying /data/tombstones/tombstone_03 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:30:50.196 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:30:50.197 I/Zygote ( 231): Process 2333 exited due to signal (6)
07-12 01:30:50.197 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:30:50.197 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 6 receivers.
07-12 01:30:50.197 E/BluetoothManagerService( 466): Unable to call onBluetoothServiceDown() on callback #0
07-12 01:30:50.197 E/BluetoothManagerService( 466): android.os.DeadObjectException
07-12 01:30:50.197 E/BluetoothManagerService( 466): at android.os.BinderProxy.transactNative(Native Method)
07-12 01:30:50.197 E/BluetoothManagerService( 466): at android.os.BinderProxy.transact(Binder.java:615)
07-12 01:30:50.197 E/BluetoothManagerService( 466): at android.bluetooth.IBluetoothManagerCallback$Stub$Proxy.onBluetoothServiceDown(IBluetoothManagerCallback.java:105)
07-12 01:30:50.197 E/BluetoothManagerService( 466): at com.android.server.BluetoothManagerService.sendBluetoothServiceDownCallback(BluetoothManagerService.java:1129)
07-12 01:30:50.197 E/BluetoothManagerService( 466): at com.android.server.BluetoothManagerService.-wrap12(BluetoothManagerService.java)
07-12 01:30:50.197 E/BluetoothManagerService( 466): at com.android.server.BluetoothManagerService$BluetoothHandler.handleMessage(BluetoothManagerService.java:1530)
07-12 01:30:50.197 E/BluetoothManagerService( 466): at android.os.Handler.dispatchMessage(Handler.java:102)
07-12 01:30:50.197 E/BluetoothManagerService( 466): at android.os.Looper.loop(Looper.java:154)
07-12 01:30:50.197 E/BluetoothManagerService( 466): at android.os.HandlerThread.run(HandlerThread.java:61)
07-12 01:30:50.197 E/BluetoothManagerService( 466): at com.android.server.ServiceThread.run(ServiceThread.java:46)
07-12 01:30:50.198 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@55e6e09
07-12 01:30:50.198 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@381c530
07-12 01:30:50.198 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@a6cc7a3
07-12 01:30:50.198 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@f3970cf
07-12 01:30:50.198 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@5f56ae
07-12 01:30:50.199 I/ActivityManager( 466): Process com.android.bluetooth (pid 2333) has died
07-12 01:30:50.199 D/ActivityManager( 466): cleanUpApplicationRecord – 2333
07-12 01:30:50.200 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.btservice.AdapterService in 1000ms
07-12 01:30:50.200 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 11000ms
07-12 01:30:50.244 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:30:50.397 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:30:50.422 I/ActivityManager( 466): Start proc 2369:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:30:50.502 I/chatty ( 2369): uid=1002(bluetooth) com.android.bluetooth expire 39 lines
07-12 01:30:50.566 I/chatty ( 2369): uid=1002(bluetooth) com.android.bluetooth expire 12 lines
07-12 01:30:50.566 I/chatty ( 2369): uid=1002(bluetooth) com.android.bluetooth expire 35 lines
07-12 01:30:50.568 I/chatty ( 2369): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:30:50.569 I/chatty ( 2369): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:30:50.573 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:30:50.573 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:30:50.589 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:30:50.589 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:30:50.590 I/chatty ( 2369): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:30:50.591 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:30:50.591 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@f93e917
07-12 01:30:50.591 I/chatty ( 2369): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:30:50.591 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@b75c5a9
07-12 01:30:50.592 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@36daa0
07-12 01:30:50.592 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@d951c4f
07-12 01:30:50.592 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@aee4a5c
07-12 01:30:50.593 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:30:50.594 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:30:50.599 I/chatty ( 2369): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:30:50.614 I/chatty ( 2369): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:30:50.795 I/chatty ( 2369): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:30:57.971 F/libc ( 2369): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:30:57.973 F/libc ( 2369): Fatal signal 6 (SIGABRT), code -6 in tid 2396 (hci_thread)
07-12 01:30:57.975 W/ ( 204): debuggerd: handling request: pid=2369 uid=1002 gid=1002 tid=2396
07-12 01:30:58.093 F/DEBUG ( 2398): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:30:58.094 F/DEBUG ( 2398): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:30:58.094 F/DEBUG ( 2398): Revision: ‘0’
07-12 01:30:58.094 F/DEBUG ( 2398): ABI: ‘arm’
07-12 01:30:58.096 F/DEBUG ( 2398): pid: 2369, tid: 2396, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:30:58.096 F/DEBUG ( 2398): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:30:58.113 F/DEBUG ( 2398): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:30:58.113 F/DEBUG ( 2398): r0 00000000 r1 0000095c r2 00000006 r3 00000008
07-12 01:30:58.113 F/DEBUG ( 2398): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:30:58.113 F/DEBUG ( 2398): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:30:58.113 F/DEBUG ( 2398): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:30:58.124 F/DEBUG ( 2398):
07-12 01:30:58.124 F/DEBUG ( 2398): backtrace:
07-12 01:30:58.124 F/DEBUG ( 2398): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:30:58.124 F/DEBUG ( 2398): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:30:58.124 F/DEBUG ( 2398): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:30:58.124 F/DEBUG ( 2398): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:30:58.124 F/DEBUG ( 2398): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:30:58.125 F/DEBUG ( 2398): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:30:58.125 F/DEBUG ( 2398): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:30:58.125 F/DEBUG ( 2398): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:30:58.125 F/DEBUG ( 2398): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:30:58.125 F/DEBUG ( 2398): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:30:58.125 F/DEBUG ( 2398): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:30:58.125 F/DEBUG ( 2398): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:30:58.370 W/ ( 204): debuggerd: resuming target 2369
07-12 01:30:58.370 I/BootReceiver( 466): Copying /data/tombstones/tombstone_04 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:30:58.407 I/Zygote ( 231): Process 2369 exited due to signal (6)
07-12 01:30:58.407 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:30:58.407 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:30:58.407 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:30:58.407 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@f93e917
07-12 01:30:58.407 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@b75c5a9
07-12 01:30:58.407 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@36daa0
07-12 01:30:58.408 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@d951c4f
07-12 01:30:58.408 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@aee4a5c
07-12 01:30:58.408 I/ActivityManager( 466): Process com.android.bluetooth (pid 2369) has died
07-12 01:30:58.408 D/ActivityManager( 466): cleanUpApplicationRecord – 2369
07-12 01:30:58.408 W/ActivityManager( 466): Service crashed 2 times, stopping: ServiceRecord{b70d0a4 u0 com.android.bluetooth/.btservice.AdapterService}
07-12 01:30:58.409 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:30:58.421 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:30:58.608 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:30:58.622 I/ActivityManager( 466): Start proc 2405:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:30:58.707 I/chatty ( 2405): uid=1002(bluetooth) com.android.bluetooth expire 21 lines
07-12 01:30:58.777 I/chatty ( 2405): uid=1002(bluetooth) com.android.bluetooth expire 5 lines
07-12 01:30:58.777 I/chatty ( 2405): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:30:58.779 I/chatty ( 2405): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:30:58.780 I/chatty ( 2405): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:30:58.783 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:30:58.784 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:30:58.800 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:30:58.800 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:30:58.801 I/chatty ( 2405): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:30:58.802 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:30:58.803 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@2e5baf6
07-12 01:30:58.803 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@d14d72e
07-12 01:30:58.803 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@5b80659
07-12 01:30:58.803 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@145e165
07-12 01:30:58.804 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@b374fdc
07-12 01:30:58.808 I/chatty ( 2405): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:30:58.809 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:30:58.809 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:30:58.809 I/chatty ( 2405): uid=1002(bluetooth) com.android.bluetooth expire 7 lines
07-12 01:30:58.811 I/chatty ( 2405): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:30:58.815 I/chatty ( 2405): uid=1002(bluetooth) com.android.bluetooth expire 18 lines
07-12 01:30:58.824 I/chatty ( 2405): uid=1002(bluetooth) com.android.bluetooth expire 18 lines
07-12 01:30:58.825 I/chatty ( 2405): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:30:59.006 I/chatty ( 2405): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:06.181 F/libc ( 2405): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:31:06.183 F/libc ( 2405): Fatal signal 6 (SIGABRT), code -6 in tid 2432 (hci_thread)
07-12 01:31:06.184 W/ ( 204): debuggerd: handling request: pid=2405 uid=1002 gid=1002 tid=2432
07-12 01:31:06.279 F/DEBUG ( 2434): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:31:06.280 F/DEBUG ( 2434): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:31:06.280 F/DEBUG ( 2434): Revision: ‘0’
07-12 01:31:06.280 F/DEBUG ( 2434): ABI: ‘arm’
07-12 01:31:06.280 F/DEBUG ( 2434): pid: 2405, tid: 2432, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:31:06.280 F/DEBUG ( 2434): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:31:06.283 F/DEBUG ( 2434): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:31:06.283 F/DEBUG ( 2434): r0 00000000 r1 00000980 r2 00000006 r3 00000008
07-12 01:31:06.283 F/DEBUG ( 2434): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:31:06.283 F/DEBUG ( 2434): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:31:06.283 F/DEBUG ( 2434): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:31:06.299 F/DEBUG ( 2434):
07-12 01:31:06.299 F/DEBUG ( 2434): backtrace:
07-12 01:31:06.299 F/DEBUG ( 2434): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:31:06.299 F/DEBUG ( 2434): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:31:06.299 F/DEBUG ( 2434): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:31:06.299 F/DEBUG ( 2434): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:31:06.300 F/DEBUG ( 2434): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:31:06.300 F/DEBUG ( 2434): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:31:06.300 F/DEBUG ( 2434): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:31:06.300 F/DEBUG ( 2434): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:31:06.300 F/DEBUG ( 2434): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:31:06.300 F/DEBUG ( 2434): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:31:06.300 F/DEBUG ( 2434): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:31:06.300 F/DEBUG ( 2434): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:31:06.562 E/ ( 2434): debuggerd: failed to kill process 2405: No such process
07-12 01:31:06.563 W/ ( 204): debuggerd: resuming target 2405
07-12 01:31:06.564 I/BootReceiver( 466): Copying /data/tombstones/tombstone_05 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:31:06.590 I/Zygote ( 231): Process 2405 exited due to signal (6)
07-12 01:31:06.590 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:31:06.590 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:31:06.590 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:31:06.590 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@2e5baf6
07-12 01:31:06.590 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@d14d72e
07-12 01:31:06.591 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@145e165
07-12 01:31:06.591 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@5b80659
07-12 01:31:06.591 I/ActivityManager( 466): Process com.android.bluetooth (pid 2405) has died
07-12 01:31:06.591 D/ActivityManager( 466): cleanUpApplicationRecord – 2405
07-12 01:31:06.591 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:31:06.591 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.btservice.AdapterService in 1000ms
07-12 01:31:06.593 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@b374fdc
07-12 01:31:06.617 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:31:06.791 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:31:06.806 I/ActivityManager( 466): Start proc 2441:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:31:06.899 I/chatty ( 2441): uid=1002(bluetooth) com.android.bluetooth expire 39 lines
07-12 01:31:06.968 I/chatty ( 2441): uid=1002(bluetooth) com.android.bluetooth expire 12 lines
07-12 01:31:06.969 I/chatty ( 2441): uid=1002(bluetooth) com.android.bluetooth expire 35 lines
07-12 01:31:06.970 I/chatty ( 2441): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:06.972 I/chatty ( 2441): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:31:06.975 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:31:06.975 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:31:06.991 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:31:06.991 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:31:06.992 I/chatty ( 2441): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:31:06.993 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:31:06.994 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@31dd8df
07-12 01:31:06.994 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@703d2cf
07-12 01:31:06.994 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@320021e
07-12 01:31:06.994 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@e8bee3a
07-12 01:31:06.995 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@10a38e5
07-12 01:31:06.997 I/chatty ( 2441): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:06.998 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:31:06.998 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:31:06.999 I/chatty ( 2441): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:07.018 I/chatty ( 2441): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:31:07.199 I/chatty ( 2441): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:14.387 F/libc ( 2441): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:31:14.389 F/libc ( 2441): Fatal signal 6 (SIGABRT), code -6 in tid 2468 (hci_thread)
07-12 01:31:14.390 W/ ( 204): debuggerd: handling request: pid=2441 uid=1002 gid=1002 tid=2468
07-12 01:31:14.493 F/DEBUG ( 2470): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:31:14.494 F/DEBUG ( 2470): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:31:14.494 F/DEBUG ( 2470): Revision: ‘0’
07-12 01:31:14.494 F/DEBUG ( 2470): ABI: ‘arm’
07-12 01:31:14.495 F/DEBUG ( 2470): pid: 2441, tid: 2468, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:31:14.496 F/DEBUG ( 2470): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:31:14.512 F/DEBUG ( 2470): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:31:14.512 F/DEBUG ( 2470): r0 00000000 r1 000009a4 r2 00000006 r3 00000008
07-12 01:31:14.512 F/DEBUG ( 2470): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:31:14.512 F/DEBUG ( 2470): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:31:14.512 F/DEBUG ( 2470): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:31:14.523 F/DEBUG ( 2470):
07-12 01:31:14.523 F/DEBUG ( 2470): backtrace:
07-12 01:31:14.523 F/DEBUG ( 2470): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:31:14.523 F/DEBUG ( 2470): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:31:14.523 F/DEBUG ( 2470): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:31:14.523 F/DEBUG ( 2470): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:31:14.523 F/DEBUG ( 2470): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:31:14.523 F/DEBUG ( 2470): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:31:14.523 F/DEBUG ( 2470): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:31:14.524 F/DEBUG ( 2470): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:31:14.524 F/DEBUG ( 2470): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:31:14.524 F/DEBUG ( 2470): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:31:14.524 F/DEBUG ( 2470): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:31:14.524 F/DEBUG ( 2470): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:31:14.762 E/ ( 2470): debuggerd: failed to kill process 2441: No such process
07-12 01:31:14.763 W/ ( 204): debuggerd: resuming target 2441
07-12 01:31:14.765 I/BootReceiver( 466): Copying /data/tombstones/tombstone_06 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:31:14.790 I/Zygote ( 231): Process 2441 exited due to signal (6)
07-12 01:31:14.790 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:31:14.791 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:31:14.791 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:31:14.791 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@31dd8df
07-12 01:31:14.791 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@703d2cf
07-12 01:31:14.791 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@e8bee3a
07-12 01:31:14.791 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@10a38e5
07-12 01:31:14.791 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@320021e
07-12 01:31:14.792 I/ActivityManager( 466): Process com.android.bluetooth (pid 2441) has died
07-12 01:31:14.792 D/ActivityManager( 466): cleanUpApplicationRecord – 2441
07-12 01:31:14.792 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:31:14.792 W/ActivityManager( 466): Service crashed 2 times, stopping: ServiceRecord{4bd8315 u0 com.android.bluetooth/.btservice.AdapterService}
07-12 01:31:14.809 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:31:14.991 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:31:15.006 I/ActivityManager( 466): Start proc 2477:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:31:15.096 I/chatty ( 2477): uid=1002(bluetooth) com.android.bluetooth expire 16 lines
07-12 01:31:15.166 I/chatty ( 2477): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:15.166 I/chatty ( 2477): uid=1002(bluetooth) com.android.bluetooth expire 9 lines
07-12 01:31:15.167 I/chatty ( 2477): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:15.168 I/chatty ( 2477): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:15.168 I/chatty ( 2477): uid=1002(bluetooth) com.android.bluetooth expire 7 lines
07-12 01:31:15.169 I/chatty ( 2477): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:15.169 I/chatty ( 2477): uid=1002(bluetooth) com.android.bluetooth expire 4 lines
07-12 01:31:15.171 I/chatty ( 2477): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:31:15.172 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:31:15.172 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:31:15.193 I/chatty ( 2477): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:15.193 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:31:15.194 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:31:15.194 I/chatty ( 2477): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:15.196 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:31:15.196 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@817c363
07-12 01:31:15.197 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@1f6045c
07-12 01:31:15.197 I/chatty ( 2477): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:15.197 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@67a3aff
07-12 01:31:15.197 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@f064aeb
07-12 01:31:15.198 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@4ce2fba
07-12 01:31:15.199 I/chatty ( 2477): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:15.199 I/chatty ( 2477): uid=1002(bluetooth) com.android.bluetooth expire 11 lines
07-12 01:31:15.200 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:31:15.200 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:31:15.202 I/chatty ( 2477): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:15.205 I/chatty ( 2477): uid=1002(bluetooth) com.android.bluetooth expire 18 lines
07-12 01:31:15.214 I/chatty ( 2477): uid=1002(bluetooth) com.android.bluetooth expire 18 lines
07-12 01:31:15.215 I/chatty ( 2477): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:31:15.397 I/chatty ( 2477): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:22.566 F/libc ( 2477): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:31:22.568 F/libc ( 2477): Fatal signal 6 (SIGABRT), code -6 in tid 2504 (hci_thread)
07-12 01:31:22.569 W/ ( 204): debuggerd: handling request: pid=2477 uid=1002 gid=1002 tid=2504
07-12 01:31:22.673 F/DEBUG ( 2506): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:31:22.674 F/DEBUG ( 2506): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:31:22.674 F/DEBUG ( 2506): Revision: ‘0’
07-12 01:31:22.675 F/DEBUG ( 2506): ABI: ‘arm’
07-12 01:31:22.676 F/DEBUG ( 2506): pid: 2477, tid: 2504, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:31:22.676 F/DEBUG ( 2506): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:31:22.702 F/DEBUG ( 2506): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:31:22.702 F/DEBUG ( 2506): r0 00000000 r1 000009c8 r2 00000006 r3 00000008
07-12 01:31:22.703 F/DEBUG ( 2506): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:31:22.703 F/DEBUG ( 2506): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:31:22.703 F/DEBUG ( 2506): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:31:22.719 F/DEBUG ( 2506):
07-12 01:31:22.719 F/DEBUG ( 2506): backtrace:
07-12 01:31:22.719 F/DEBUG ( 2506): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:31:22.719 F/DEBUG ( 2506): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:31:22.719 F/DEBUG ( 2506): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:31:22.719 F/DEBUG ( 2506): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:31:22.719 F/DEBUG ( 2506): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:31:22.719 F/DEBUG ( 2506): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:31:22.719 F/DEBUG ( 2506): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:31:22.719 F/DEBUG ( 2506): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:31:22.719 F/DEBUG ( 2506): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:31:22.719 F/DEBUG ( 2506): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:31:22.719 F/DEBUG ( 2506): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:31:22.720 F/DEBUG ( 2506): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:31:22.972 E/ ( 2506): debuggerd: failed to kill process 2477: No such process
07-12 01:31:22.973 W/ ( 204): debuggerd: resuming target 2477
07-12 01:31:22.976 I/BootReceiver( 466): Copying /data/tombstones/tombstone_07 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:31:23.007 I/Zygote ( 231): Process 2477 exited due to signal (6)
07-12 01:31:23.007 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:31:23.008 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:31:23.008 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:31:23.008 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@817c363
07-12 01:31:23.008 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@1f6045c
07-12 01:31:23.008 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@67a3aff
07-12 01:31:23.008 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@f064aeb
07-12 01:31:23.009 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@4ce2fba
07-12 01:31:23.009 I/ActivityManager( 466): Process com.android.bluetooth (pid 2477) has died
07-12 01:31:23.009 D/ActivityManager( 466): cleanUpApplicationRecord – 2477
07-12 01:31:23.009 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.btservice.AdapterService in 1000ms
07-12 01:31:23.009 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 11000ms
07-12 01:31:23.061 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:31:23.208 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:31:23.220 I/ActivityManager( 466): Start proc 2513:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:31:23.289 I/chatty ( 2513): uid=1002(bluetooth) com.android.bluetooth expire 39 lines
07-12 01:31:23.342 I/chatty ( 2513): uid=1002(bluetooth) com.android.bluetooth expire 12 lines
07-12 01:31:23.342 I/chatty ( 2513): uid=1002(bluetooth) com.android.bluetooth expire 35 lines
07-12 01:31:23.344 I/chatty ( 2513): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:23.345 I/chatty ( 2513): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:31:23.348 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:31:23.348 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:31:23.366 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:31:23.366 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:31:23.367 I/chatty ( 2513): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:23.368 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:31:23.369 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@4465da8
07-12 01:31:23.369 I/chatty ( 2513): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:31:23.369 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@63c1365
07-12 01:31:23.369 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@3f00cc
07-12 01:31:23.369 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@d43b048
07-12 01:31:23.370 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@2312e6b
07-12 01:31:23.371 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:31:23.371 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:31:23.373 I/chatty ( 2513): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:23.386 I/chatty ( 2513): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:31:23.569 I/chatty ( 2513): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:30.750 F/libc ( 2513): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:31:30.751 F/libc ( 2513): Fatal signal 6 (SIGABRT), code -6 in tid 2540 (hci_thread)
07-12 01:31:30.753 W/ ( 204): debuggerd: handling request: pid=2513 uid=1002 gid=1002 tid=2540
07-12 01:31:30.850 F/DEBUG ( 2542): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:31:30.851 F/DEBUG ( 2542): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:31:30.852 F/DEBUG ( 2542): Revision: ‘0’
07-12 01:31:30.852 F/DEBUG ( 2542): ABI: ‘arm’
07-12 01:31:30.853 F/DEBUG ( 2542): pid: 2513, tid: 2540, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:31:30.854 F/DEBUG ( 2542): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:31:30.866 F/DEBUG ( 2542): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:31:30.866 F/DEBUG ( 2542): r0 00000000 r1 000009ec r2 00000006 r3 00000008
07-12 01:31:30.866 F/DEBUG ( 2542): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:31:30.866 F/DEBUG ( 2542): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:31:30.866 F/DEBUG ( 2542): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:31:30.878 F/DEBUG ( 2542):
07-12 01:31:30.878 F/DEBUG ( 2542): backtrace:
07-12 01:31:30.878 F/DEBUG ( 2542): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:31:30.878 F/DEBUG ( 2542): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:31:30.878 F/DEBUG ( 2542): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:31:30.878 F/DEBUG ( 2542): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:31:30.878 F/DEBUG ( 2542): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:31:30.878 F/DEBUG ( 2542): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:31:30.878 F/DEBUG ( 2542): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:31:30.878 F/DEBUG ( 2542): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:31:30.878 F/DEBUG ( 2542): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:31:30.879 F/DEBUG ( 2542): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:31:30.879 F/DEBUG ( 2542): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:31:30.879 F/DEBUG ( 2542): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:31:31.130 W/ ( 204): debuggerd: resuming target 2513
07-12 01:31:31.131 I/BootReceiver( 466): Copying /data/tombstones/tombstone_08 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:31:31.160 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:31:31.160 I/ActivityManager( 466): Process com.android.bluetooth (pid 2513) has died
07-12 01:31:31.160 D/ActivityManager( 466): cleanUpApplicationRecord – 2513
07-12 01:31:31.160 W/ActivityManager( 466): Service crashed 2 times, stopping: ServiceRecord{e481706 u0 com.android.bluetooth/.btservice.AdapterService}
07-12 01:31:31.160 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:31:31.161 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:31:31.161 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:31:31.161 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@4465da8
07-12 01:31:31.161 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@63c1365
07-12 01:31:31.161 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@3f00cc
07-12 01:31:31.162 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@d43b048
07-12 01:31:31.162 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@2312e6b
07-12 01:31:31.163 I/Zygote ( 231): Process 2513 exited due to signal (6)
07-12 01:31:31.209 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:31:31.362 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:31:31.382 I/ActivityManager( 466): Start proc 2549:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:31:31.452 I/chatty ( 2549): uid=1002(bluetooth) com.android.bluetooth expire 16 lines
07-12 01:31:31.506 I/chatty ( 2549): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:31.506 I/chatty ( 2549): uid=1002(bluetooth) com.android.bluetooth expire 35 lines
07-12 01:31:31.507 I/chatty ( 2549): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:31.508 I/chatty ( 2549): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:31.509 I/chatty ( 2549): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:31:31.509 I/chatty ( 2549): uid=1002(bluetooth) com.android.bluetooth expire 23 lines
07-12 01:31:31.512 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:31:31.512 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:31:31.530 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:31:31.530 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:31:31.530 I/chatty ( 2549): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:31:31.532 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:31:31.532 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@c8e11ab
07-12 01:31:31.532 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@a9b383a
07-12 01:31:31.533 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@6d9af15
07-12 01:31:31.533 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@5382ee1
07-12 01:31:31.533 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@cd78dc8
07-12 01:31:31.534 I/chatty ( 2549): uid=1002(bluetooth) com.android.bluetooth expire 11 lines
07-12 01:31:31.534 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:31:31.534 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:31:31.535 I/chatty ( 2549): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:31.547 I/chatty ( 2549): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:31:31.729 I/chatty ( 2549): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:38.926 F/libc ( 2549): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:31:38.928 F/libc ( 2549): Fatal signal 6 (SIGABRT), code -6 in tid 2576 (hci_thread)
07-12 01:31:38.929 W/ ( 204): debuggerd: handling request: pid=2549 uid=1002 gid=1002 tid=2576
07-12 01:31:39.033 F/DEBUG ( 2578): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:31:39.034 F/DEBUG ( 2578): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:31:39.034 F/DEBUG ( 2578): Revision: ‘0’
07-12 01:31:39.034 F/DEBUG ( 2578): ABI: ‘arm’
07-12 01:31:39.035 F/DEBUG ( 2578): pid: 2549, tid: 2576, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:31:39.036 F/DEBUG ( 2578): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:31:39.055 F/DEBUG ( 2578): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:31:39.055 F/DEBUG ( 2578): r0 00000000 r1 00000a10 r2 00000006 r3 00000008
07-12 01:31:39.055 F/DEBUG ( 2578): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:31:39.055 F/DEBUG ( 2578): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:31:39.055 F/DEBUG ( 2578): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:31:39.066 F/DEBUG ( 2578):
07-12 01:31:39.066 F/DEBUG ( 2578): backtrace:
07-12 01:31:39.066 F/DEBUG ( 2578): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:31:39.066 F/DEBUG ( 2578): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:31:39.066 F/DEBUG ( 2578): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:31:39.066 F/DEBUG ( 2578): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:31:39.066 F/DEBUG ( 2578): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:31:39.066 F/DEBUG ( 2578): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:31:39.066 F/DEBUG ( 2578): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:31:39.066 F/DEBUG ( 2578): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:31:39.067 F/DEBUG ( 2578): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:31:39.067 F/DEBUG ( 2578): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:31:39.067 F/DEBUG ( 2578): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:31:39.067 F/DEBUG ( 2578): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:31:39.305 E/ ( 2578): debuggerd: failed to kill process 2549: No such process
07-12 01:31:39.306 W/ ( 204): debuggerd: resuming target 2549
07-12 01:31:39.307 I/BootReceiver( 466): Copying /data/tombstones/tombstone_09 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:31:39.330 I/Zygote ( 231): Process 2549 exited due to signal (6)
07-12 01:31:39.331 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:31:39.331 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:31:39.331 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:31:39.331 I/ActivityManager( 466): Process com.android.bluetooth (pid 2549) has died
07-12 01:31:39.331 D/ActivityManager( 466): cleanUpApplicationRecord – 2549
07-12 01:31:39.331 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@c8e11ab
07-12 01:31:39.331 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@a9b383a
07-12 01:31:39.331 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:31:39.331 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.btservice.AdapterService in 1000ms
07-12 01:31:39.331 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@6d9af15
07-12 01:31:39.331 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@5382ee1
07-12 01:31:39.332 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@cd78dc8
07-12 01:31:39.385 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:31:39.530 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:31:39.554 I/ActivityManager( 466): Start proc 2585:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:31:39.622 I/chatty ( 2585): uid=1002(bluetooth) com.android.bluetooth expire 39 lines
07-12 01:31:39.681 I/chatty ( 2585): uid=1002(bluetooth) com.android.bluetooth expire 12 lines
07-12 01:31:39.681 I/chatty ( 2585): uid=1002(bluetooth) com.android.bluetooth expire 35 lines
07-12 01:31:39.682 I/chatty ( 2585): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:39.683 I/chatty ( 2585): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:39.684 I/chatty ( 2585): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:31:39.687 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:31:39.687 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:31:39.708 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:31:39.708 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:31:39.709 I/chatty ( 2585): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:31:39.711 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:31:39.711 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@2924950
07-12 01:31:39.711 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@614cceb
07-12 01:31:39.711 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@d46222a
07-12 01:31:39.712 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@a3ab406
07-12 01:31:39.712 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@5aa7e61
07-12 01:31:39.713 I/chatty ( 2585): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:39.714 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:31:39.714 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:31:39.715 I/chatty ( 2585): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:39.728 I/chatty ( 2585): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:31:39.909 I/chatty ( 2585): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:47.085 F/libc ( 2585): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:31:47.086 F/libc ( 2585): Fatal signal 6 (SIGABRT), code -6 in tid 2612 (hci_thread)
07-12 01:31:47.088 W/ ( 204): debuggerd: handling request: pid=2585 uid=1002 gid=1002 tid=2612
07-12 01:31:47.184 F/DEBUG ( 2614): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:31:47.185 F/DEBUG ( 2614): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:31:47.185 F/DEBUG ( 2614): Revision: ‘0’
07-12 01:31:47.185 F/DEBUG ( 2614): ABI: ‘arm’
07-12 01:31:47.187 F/DEBUG ( 2614): pid: 2585, tid: 2612, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:31:47.187 F/DEBUG ( 2614): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:31:47.200 F/DEBUG ( 2614): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:31:47.200 F/DEBUG ( 2614): r0 00000000 r1 00000a34 r2 00000006 r3 00000008
07-12 01:31:47.200 F/DEBUG ( 2614): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:31:47.200 F/DEBUG ( 2614): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:31:47.200 F/DEBUG ( 2614): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:31:47.211 F/DEBUG ( 2614):
07-12 01:31:47.211 F/DEBUG ( 2614): backtrace:
07-12 01:31:47.211 F/DEBUG ( 2614): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:31:47.211 F/DEBUG ( 2614): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:31:47.211 F/DEBUG ( 2614): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:31:47.212 F/DEBUG ( 2614): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:31:47.212 F/DEBUG ( 2614): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:31:47.212 F/DEBUG ( 2614): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:31:47.212 F/DEBUG ( 2614): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:31:47.212 F/DEBUG ( 2614): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:31:47.212 F/DEBUG ( 2614): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:31:47.212 F/DEBUG ( 2614): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:31:47.212 F/DEBUG ( 2614): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:31:47.212 F/DEBUG ( 2614): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:31:47.463 E/ ( 2614): debuggerd: failed to kill process 2585: No such process
07-12 01:31:47.464 W/ ( 204): debuggerd: resuming target 2585
07-12 01:31:47.464 I/BootReceiver( 466): Copying /data/tombstones/tombstone_00 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:31:47.493 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:31:47.493 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:31:47.493 I/ActivityManager( 466): Process com.android.bluetooth (pid 2585) has died
07-12 01:31:47.493 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:31:47.493 D/ActivityManager( 466): cleanUpApplicationRecord – 2585
07-12 01:31:47.493 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@2924950
07-12 01:31:47.494 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@614cceb
07-12 01:31:47.494 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:31:47.494 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@a3ab406
07-12 01:31:47.494 W/ActivityManager( 466): Service crashed 2 times, stopping: ServiceRecord{3aebaee u0 com.android.bluetooth/.btservice.AdapterService}
07-12 01:31:47.494 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@d46222a
07-12 01:31:47.494 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@5aa7e61
07-12 01:31:47.495 I/Zygote ( 231): Process 2585 exited due to signal (6)
07-12 01:31:47.555 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:31:47.694 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:31:47.710 I/ActivityManager( 466): Start proc 2621:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:31:47.799 I/chatty ( 2621): uid=1002(bluetooth) com.android.bluetooth expire 16 lines
07-12 01:31:47.852 I/chatty ( 2621): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:47.852 I/chatty ( 2621): uid=1002(bluetooth) com.android.bluetooth expire 8 lines
07-12 01:31:47.853 I/chatty ( 2621): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:47.854 I/chatty ( 2621): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:47.854 I/chatty ( 2621): uid=1002(bluetooth) com.android.bluetooth expire 27 lines
07-12 01:31:47.855 I/chatty ( 2621): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:31:47.855 I/chatty ( 2621): uid=1002(bluetooth) com.android.bluetooth expire 23 lines
07-12 01:31:47.857 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:31:47.858 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:31:47.875 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:31:47.875 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:31:47.876 I/chatty ( 2621): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:31:47.877 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:31:47.878 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@2e97c57
07-12 01:31:47.878 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@60d0a48
07-12 01:31:47.878 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@bc1881b
07-12 01:31:47.878 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@7caac7
07-12 01:31:47.878 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@c1f8d86
07-12 01:31:47.879 I/chatty ( 2621): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:47.879 I/chatty ( 2621): uid=1002(bluetooth) com.android.bluetooth expire 11 lines
07-12 01:31:47.880 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:31:47.880 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:31:47.881 I/chatty ( 2621): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:47.893 I/chatty ( 2621): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:31:48.073 I/chatty ( 2621): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:55.247 F/libc ( 2621): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:31:55.248 F/libc ( 2621): Fatal signal 6 (SIGABRT), code -6 in tid 2648 (hci_thread)
07-12 01:31:55.250 W/ ( 204): debuggerd: handling request: pid=2621 uid=1002 gid=1002 tid=2648
07-12 01:31:55.343 F/DEBUG ( 2650): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:31:55.343 F/DEBUG ( 2650): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:31:55.343 F/DEBUG ( 2650): Revision: ‘0’
07-12 01:31:55.343 F/DEBUG ( 2650): ABI: ‘arm’
07-12 01:31:55.344 F/DEBUG ( 2650): pid: 2621, tid: 2648, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:31:55.344 F/DEBUG ( 2650): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:31:55.347 F/DEBUG ( 2650): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:31:55.347 F/DEBUG ( 2650): r0 00000000 r1 00000a58 r2 00000006 r3 00000008
07-12 01:31:55.347 F/DEBUG ( 2650): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:31:55.347 F/DEBUG ( 2650): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:31:55.347 F/DEBUG ( 2650): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:31:55.362 F/DEBUG ( 2650):
07-12 01:31:55.362 F/DEBUG ( 2650): backtrace:
07-12 01:31:55.362 F/DEBUG ( 2650): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:31:55.362 F/DEBUG ( 2650): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:31:55.362 F/DEBUG ( 2650): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:31:55.362 F/DEBUG ( 2650): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:31:55.362 F/DEBUG ( 2650): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:31:55.362 F/DEBUG ( 2650): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:31:55.362 F/DEBUG ( 2650): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:31:55.362 F/DEBUG ( 2650): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:31:55.362 F/DEBUG ( 2650): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:31:55.363 F/DEBUG ( 2650): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:31:55.363 F/DEBUG ( 2650): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:31:55.363 F/DEBUG ( 2650): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:31:55.624 E/ ( 2650): debuggerd: failed to kill process 2621: No such process
07-12 01:31:55.626 I/BootReceiver( 466): Copying /data/tombstones/tombstone_01 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:31:55.627 W/ ( 204): debuggerd: resuming target 2621
07-12 01:31:55.657 I/ActivityManager( 466): Process com.android.bluetooth (pid 2621) has died
07-12 01:31:55.657 D/ActivityManager( 466): cleanUpApplicationRecord – 2621
07-12 01:31:55.657 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:31:55.657 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:31:55.657 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:31:55.658 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.btservice.AdapterService in 1000ms
07-12 01:31:55.658 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:31:55.658 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@2e97c57
07-12 01:31:55.658 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@60d0a48
07-12 01:31:55.658 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@bc1881b
07-12 01:31:55.658 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@7caac7
07-12 01:31:55.658 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@c1f8d86
07-12 01:31:55.659 I/Zygote ( 231): Process 2621 exited due to signal (6)
07-12 01:31:55.717 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:31:55.858 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:31:55.876 I/ActivityManager( 466): Start proc 2657:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:31:55.962 I/chatty ( 2657): uid=1002(bluetooth) com.android.bluetooth expire 39 lines
07-12 01:31:56.008 I/chatty ( 2657): uid=1002(bluetooth) com.android.bluetooth expire 12 lines
07-12 01:31:56.008 I/chatty ( 2657): uid=1002(bluetooth) com.android.bluetooth expire 35 lines
07-12 01:31:56.009 I/chatty ( 2657): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:56.010 I/chatty ( 2657): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:31:56.013 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:31:56.013 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:31:56.029 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:31:56.029 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:31:56.030 I/chatty ( 2657): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:31:56.031 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:31:56.031 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@119ef0c
07-12 01:31:56.031 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@85f80e1
07-12 01:31:56.031 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@8c15db8
07-12 01:31:56.031 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@2324647
07-12 01:31:56.031 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@e0788f4
07-12 01:31:56.032 I/chatty ( 2657): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:56.033 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:31:56.033 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:31:56.034 I/chatty ( 2657): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:31:56.044 I/chatty ( 2657): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:31:56.225 I/chatty ( 2657): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:32:03.395 F/libc ( 2657): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:32:03.397 F/libc ( 2657): Fatal signal 6 (SIGABRT), code -6 in tid 2684 (hci_thread)
07-12 01:32:03.398 W/ ( 204): debuggerd: handling request: pid=2657 uid=1002 gid=1002 tid=2684
07-12 01:32:03.499 F/DEBUG ( 2686): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:32:03.500 F/DEBUG ( 2686): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:32:03.500 F/DEBUG ( 2686): Revision: ‘0’
07-12 01:32:03.501 F/DEBUG ( 2686): ABI: ‘arm’
07-12 01:32:03.502 F/DEBUG ( 2686): pid: 2657, tid: 2684, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:32:03.503 F/DEBUG ( 2686): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:32:03.519 F/DEBUG ( 2686): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:32:03.519 F/DEBUG ( 2686): r0 00000000 r1 00000a7c r2 00000006 r3 00000008
07-12 01:32:03.519 F/DEBUG ( 2686): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:32:03.519 F/DEBUG ( 2686): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:32:03.519 F/DEBUG ( 2686): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:32:03.530 F/DEBUG ( 2686):
07-12 01:32:03.530 F/DEBUG ( 2686): backtrace:
07-12 01:32:03.531 F/DEBUG ( 2686): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:32:03.531 F/DEBUG ( 2686): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:32:03.531 F/DEBUG ( 2686): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:32:03.531 F/DEBUG ( 2686): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:32:03.531 F/DEBUG ( 2686): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:32:03.531 F/DEBUG ( 2686): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:32:03.531 F/DEBUG ( 2686): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:32:03.531 F/DEBUG ( 2686): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:32:03.531 F/DEBUG ( 2686): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:32:03.531 F/DEBUG ( 2686): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:32:03.531 F/DEBUG ( 2686): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:32:03.531 F/DEBUG ( 2686): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:32:03.783 W/ ( 204): debuggerd: resuming target 2657
07-12 01:32:03.783 I/BootReceiver( 466): Copying /data/tombstones/tombstone_02 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:32:03.817 I/ActivityManager( 466): Process com.android.bluetooth (pid 2657) has died
07-12 01:32:03.817 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:32:03.817 D/ActivityManager( 466): cleanUpApplicationRecord – 2657
07-12 01:32:03.817 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:32:03.817 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:32:03.817 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:32:03.817 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@119ef0c
07-12 01:32:03.817 W/ActivityManager( 466): Service crashed 2 times, stopping: ServiceRecord{1788f0a u0 com.android.bluetooth/.btservice.AdapterService}
07-12 01:32:03.817 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@85f80e1
07-12 01:32:03.817 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@8c15db8
07-12 01:32:03.817 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@e0788f4
07-12 01:32:03.818 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@2324647
07-12 01:32:03.818 I/Zygote ( 231): Process 2657 exited due to signal (6)
07-12 01:32:03.861 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:32:04.017 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:32:04.032 I/ActivityManager( 466): Start proc 2693:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:32:04.099 I/chatty ( 2693): uid=1002(bluetooth) com.android.bluetooth expire 16 lines
07-12 01:32:04.153 I/chatty ( 2693): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:32:04.153 I/chatty ( 2693): uid=1002(bluetooth) com.android.bluetooth expire 35 lines
07-12 01:32:04.155 I/chatty ( 2693): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:32:04.157 I/chatty ( 2693): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:32:04.157 I/chatty ( 2693): uid=1002(bluetooth) com.android.bluetooth expire 23 lines
07-12 01:32:04.159 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:32:04.160 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:32:04.180 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:32:04.180 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:32:04.181 I/chatty ( 2693): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:32:04.182 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:32:04.183 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@556841f
07-12 01:32:04.183 I/chatty ( 2693): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:32:04.183 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@8f49e06
07-12 01:32:04.183 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@9332791
07-12 01:32:04.183 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@2bbbe74
07-12 01:32:04.184 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@5a7d81d
07-12 01:32:04.184 I/chatty ( 2693): uid=1002(bluetooth) com.android.bluetooth expire 11 lines
07-12 01:32:04.185 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:32:04.185 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:32:04.187 I/chatty ( 2693): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:32:04.200 I/chatty ( 2693): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:32:04.382 I/chatty ( 2693): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:32:11.566 F/libc ( 2693): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:32:11.567 F/libc ( 2693): Fatal signal 6 (SIGABRT), code -6 in tid 2720 (hci_thread)
07-12 01:32:11.569 W/ ( 204): debuggerd: handling request: pid=2693 uid=1002 gid=1002 tid=2720
07-12 01:32:11.664 F/DEBUG ( 2722): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:32:11.664 F/DEBUG ( 2722): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:32:11.665 F/DEBUG ( 2722): Revision: ‘0’
07-12 01:32:11.665 F/DEBUG ( 2722): ABI: ‘arm’
07-12 01:32:11.666 F/DEBUG ( 2722): pid: 2693, tid: 2720, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:32:11.667 F/DEBUG ( 2722): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:32:11.685 F/DEBUG ( 2722): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:32:11.685 F/DEBUG ( 2722): r0 00000000 r1 00000aa0 r2 00000006 r3 00000008
07-12 01:32:11.685 F/DEBUG ( 2722): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:32:11.685 F/DEBUG ( 2722): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:32:11.685 F/DEBUG ( 2722): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:32:11.697 F/DEBUG ( 2722):
07-12 01:32:11.697 F/DEBUG ( 2722): backtrace:
07-12 01:32:11.697 F/DEBUG ( 2722): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:32:11.697 F/DEBUG ( 2722): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:32:11.697 F/DEBUG ( 2722): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:32:11.697 F/DEBUG ( 2722): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:32:11.697 F/DEBUG ( 2722): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:32:11.697 F/DEBUG ( 2722): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:32:11.697 F/DEBUG ( 2722): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:32:11.697 F/DEBUG ( 2722): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:32:11.698 F/DEBUG ( 2722): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:32:11.698 F/DEBUG ( 2722): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:32:11.698 F/DEBUG ( 2722): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:32:11.698 F/DEBUG ( 2722): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:32:11.949 E/ ( 2722): debuggerd: failed to kill process 2693: No such process
07-12 01:32:11.950 W/ ( 204): debuggerd: resuming target 2693
07-12 01:32:11.951 I/BootReceiver( 466): Copying /data/tombstones/tombstone_03 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:32:11.974 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:32:11.974 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:32:11.974 I/Zygote ( 231): Process 2693 exited due to signal (6)
07-12 01:32:11.974 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:32:11.974 I/ActivityManager( 466): Process com.android.bluetooth (pid 2693) has died
07-12 01:32:11.974 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@556841f
07-12 01:32:11.974 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@8f49e06
07-12 01:32:11.974 D/ActivityManager( 466): cleanUpApplicationRecord – 2693
07-12 01:32:11.974 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@9332791
07-12 01:32:11.974 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:32:11.974 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@5a7d81d
07-12 01:32:11.974 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.btservice.AdapterService in 1000ms
07-12 01:32:11.975 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@2bbbe74
07-12 01:32:12.015 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:32:12.063 W/art ( 466): Suspending all threads took: 7.575ms
07-12 01:32:12.071 I/art ( 466): Background sticky concurrent mark sweep GC freed 3943(478KB) AllocSpace objects, 22(3MB) LOS objects, 32% free, 9MB/13MB, paused 9.758ms total 36.597ms
07-12 01:32:12.173 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:32:12.185 I/ActivityManager( 466): Start proc 2730:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:32:12.262 I/chatty ( 2730): uid=1002(bluetooth) com.android.bluetooth expire 39 lines
07-12 01:32:12.310 I/chatty ( 2730): uid=1002(bluetooth) com.android.bluetooth expire 12 lines
07-12 01:32:12.311 I/chatty ( 2730): uid=1002(bluetooth) com.android.bluetooth expire 35 lines
07-12 01:32:12.312 I/chatty ( 2730): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:32:12.313 I/chatty ( 2730): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:32:12.314 I/chatty ( 2730): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:32:12.317 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:32:12.317 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:32:12.320 I/AudioOut_D( 232): type=1400 audit(0.0:27): avc: denied { read } for name=“audioformat” dev=“sysfs” ino=17976 scontext=u:r:audioserver:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
07-12 01:32:12.320 I/AudioOut_D( 232): type=1400 audit(0.0:28): avc: denied { open } for path=“/sys/devices/platform/display-subsystem/drm/card0/card0-HDMI-A-1/audioformat” dev=“sysfs” ino=17976 scontext=u:r:audioserver:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
07-12 01:32:12.320 I/AudioOut_D( 232): type=1400 audit(0.0:29): avc: denied { getattr } for path=“/sys/devices/platform/display-subsystem/drm/card0/card0-HDMI-A-1/audioformat” dev=“sysfs” ino=17976 scontext=u:r:audioserver:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
07-12 01:32:12.321 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{2a889d2 0:com.android.bluetooth/1002}
07-12 01:32:12.323 D/AudioHardwareTiny( 232): start_output_stream
07-12 01:32:12.324 D/alsa_route( 232): route_info->sound_card 0, route_info->devices 0
07-12 01:32:12.324 D/alsa_route( 232): route_set_controls() set route 0
07-12 01:32:12.346 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:32:12.346 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:32:12.346 I/chatty ( 2730): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:32:12.348 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:32:12.348 I/chatty ( 2730): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:32:12.348 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@9a87dff
07-12 01:32:12.348 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@6f14cc7
07-12 01:32:12.348 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@bfc36f6
07-12 01:32:12.348 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@faf9f9d
07-12 01:32:12.349 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@fbe0a92
07-12 01:32:12.350 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:32:12.350 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:32:12.351 I/chatty ( 2730): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:32:12.364 I/chatty ( 2730): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:32:12.506 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:12.540 I/chatty ( 2730): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:32:13.033 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{a9c85f6 0:com.android.bluetooth/1002}
07-12 01:32:13.205 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{32d86cd 0:com.android.bluetooth/1002}
07-12 01:32:13.280 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:13.390 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{74c02d0 0:com.android.bluetooth/1002}
07-12 01:32:13.458 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:13.560 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:13.564 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{162e4ef 0:com.android.bluetooth/1002}
07-12 01:32:13.796 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:13.917 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{ac288da 0:com.android.bluetooth/1002}
07-12 01:32:14.062 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{1810201 0:com.android.bluetooth/1002}
07-12 01:32:14.118 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:14.222 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{f304e94 0:com.android.bluetooth/1002}
07-12 01:32:14.300 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:14.380 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{c246683 0:com.android.bluetooth/1002}
07-12 01:32:14.391 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:14.524 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{5ffd67e 0:com.android.bluetooth/1002}
07-12 01:32:14.570 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:14.682 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{1f156f5 0:com.android.bluetooth/1002}
07-12 01:32:14.689 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:14.870 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{8238f18 0:com.android.bluetooth/1002}
07-12 01:32:14.876 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:14.876 D/OpenGLRenderer( 466): endAllActiveAnimators on 0x90ae1480 (RippleDrawable) with handle 0x910d8090
07-12 01:32:14.946 I/WifiHAL ( 466): Got channel list with 13 channels
07-12 01:32:14.947 I/WifiHAL ( 466): Got channel list with 9 channels
07-12 01:32:14.947 I/WifiHAL ( 466): Got channel list with 4 channels
07-12 01:32:15.054 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{3f5f3d7 0:com.android.bluetooth/1002}
07-12 01:32:15.055 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:15.197 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{2f672e2 0:com.android.bluetooth/1002}
07-12 01:32:15.224 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:15.342 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{3fb59a9 0:com.android.bluetooth/1002}
07-12 01:32:15.403 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:15.500 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{517a85c 0:com.android.bluetooth/1002}
07-12 01:32:15.502 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:15.682 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:15.698 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{54dc0eb 0:com.android.bluetooth/1002}
07-12 01:32:15.871 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{3692206 0:com.android.bluetooth/1002}
07-12 01:32:15.879 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:16.027 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{2439e1d 0:com.android.bluetooth/1002}
07-12 01:32:16.058 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:16.186 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{d193e60 0:com.android.bluetooth/1002}
07-12 01:32:16.236 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:16.356 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:16.370 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{88bc1bf 0:com.android.bluetooth/1002}
07-12 01:32:16.529 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{e5f67ea 0:com.android.bluetooth/1002}
07-12 01:32:16.554 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:16.702 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{e0a7851 0:com.android.bluetooth/1002}
07-12 01:32:16.733 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:16.845 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{453b524 0:com.android.bluetooth/1002}
07-12 01:32:16.911 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:16.990 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{1cdaa53 0:com.android.bluetooth/1002}
07-12 01:32:17.011 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:17.122 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{109888e 0:com.android.bluetooth/1002}
07-12 01:32:17.189 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:17.280 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{5ffc45 0:com.android.bluetooth/1002}
07-12 01:32:17.288 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:17.425 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{5d530a8 0:com.android.bluetooth/1002}
07-12 01:32:17.467 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:17.572 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{882eea7 0:com.android.bluetooth/1002}
07-12 01:32:17.586 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:17.716 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{a6487f2 0:com.android.bluetooth/1002}
07-12 01:32:17.785 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:17.848 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{517fdf9 0:com.android.bluetooth/1002}
07-12 01:32:17.904 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:18.023 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:18.164 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{21294ec 0:com.android.bluetooth/1002}
07-12 01:32:18.325 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{ac0c2bb 0:com.android.bluetooth/1002}
07-12 01:32:18.340 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:18.468 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{59e2a16 0:com.android.bluetooth/1002}
07-12 01:32:18.539 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:18.638 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:19.188 F/libc ( 2730): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:32:19.189 F/libc ( 2730): Fatal signal 6 (SIGABRT), code -6 in tid 2758 (hci_thread)
07-12 01:32:19.191 W/ ( 204): debuggerd: handling request: pid=2730 uid=1002 gid=1002 tid=2758
07-12 01:32:19.292 F/DEBUG ( 2761): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:32:19.293 F/DEBUG ( 2761): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:32:19.293 F/DEBUG ( 2761): Revision: ‘0’
07-12 01:32:19.294 F/DEBUG ( 2761): ABI: ‘arm’
07-12 01:32:19.295 F/DEBUG ( 2761): pid: 2730, tid: 2758, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:32:19.296 F/DEBUG ( 2761): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:32:19.313 F/DEBUG ( 2761): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:32:19.313 F/DEBUG ( 2761): r0 00000000 r1 00000ac6 r2 00000006 r3 00000008
07-12 01:32:19.313 F/DEBUG ( 2761): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:32:19.313 F/DEBUG ( 2761): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:32:19.313 F/DEBUG ( 2761): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:32:19.324 F/DEBUG ( 2761):
07-12 01:32:19.324 F/DEBUG ( 2761): backtrace:
07-12 01:32:19.324 F/DEBUG ( 2761): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:32:19.324 F/DEBUG ( 2761): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:32:19.324 F/DEBUG ( 2761): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:32:19.324 F/DEBUG ( 2761): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:32:19.324 F/DEBUG ( 2761): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:32:19.324 F/DEBUG ( 2761): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:32:19.324 F/DEBUG ( 2761): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:32:19.324 F/DEBUG ( 2761): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:32:19.325 F/DEBUG ( 2761): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:32:19.325 F/DEBUG ( 2761): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:32:19.325 F/DEBUG ( 2761): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:32:19.325 F/DEBUG ( 2761): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:32:19.559 E/ ( 2761): debuggerd: failed to kill process 2730: No such process
07-12 01:32:19.561 I/BootReceiver( 466): Copying /data/tombstones/tombstone_04 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:32:19.561 W/ ( 204): debuggerd: resuming target 2730
07-12 01:32:19.562 W/ActivityManager( 466): Process com.android.bluetooth has crashed too many times: killing!
07-12 01:32:19.563 I/ActivityManager( 466): Killing 2730:com.android.bluetooth/1002 (adj -700): crash
07-12 01:32:19.563 D/ActivityManager( 466): cleanUpApplicationRecord – 2730
07-12 01:32:19.567 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:32:19.568 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:32:19.568 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 6 receivers.
07-12 01:32:19.568 E/BluetoothManagerService( 466): Unable to call onBluetoothServiceDown() on callback #0
07-12 01:32:19.568 E/BluetoothManagerService( 466): android.os.DeadObjectException
07-12 01:32:19.568 E/BluetoothManagerService( 466): at android.os.BinderProxy.transactNative(Native Method)
07-12 01:32:19.568 E/BluetoothManagerService( 466): at android.os.BinderProxy.transact(Binder.java:615)
07-12 01:32:19.568 E/BluetoothManagerService( 466): at android.bluetooth.IBluetoothManagerCallback$Stub$Proxy.onBluetoothServiceDown(IBluetoothManagerCallback.java:105)
07-12 01:32:19.568 E/BluetoothManagerService( 466): at com.android.server.BluetoothManagerService.sendBluetoothServiceDownCallback(BluetoothManagerService.java:1129)
07-12 01:32:19.568 E/BluetoothManagerService( 466): at com.android.server.BluetoothManagerService.-wrap12(BluetoothManagerService.java)
07-12 01:32:19.568 E/BluetoothManagerService( 466): at com.android.server.BluetoothManagerService$BluetoothHandler.handleMessage(BluetoothManagerService.java:1530)
07-12 01:32:19.568 E/BluetoothManagerService( 466): at android.os.Handler.dispatchMessage(Handler.java:102)
07-12 01:32:19.568 E/BluetoothManagerService( 466): at android.os.Looper.loop(Looper.java:154)
07-12 01:32:19.568 E/BluetoothManagerService( 466): at android.os.HandlerThread.run(HandlerThread.java:61)
07-12 01:32:19.568 E/BluetoothManagerService( 466): at com.android.server.ServiceThread.run(ServiceThread.java:46)
07-12 01:32:19.569 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@9a87dff
07-12 01:32:19.569 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@6f14cc7
07-12 01:32:19.569 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@bfc36f6
07-12 01:32:19.569 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@fbe0a92
07-12 01:32:19.569 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@faf9f9d
07-12 01:32:19.587 I/Zygote ( 231): Process 2730 exited due to signal (6)
07-12 01:32:19.768 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:32:19.811 I/ActivityManager( 466): Start proc 2768:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:32:19.882 I/chatty ( 2768): uid=1002(bluetooth) com.android.bluetooth expire 16 lines
07-12 01:32:19.936 I/chatty ( 2768): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:32:19.937 I/chatty ( 2768): uid=1002(bluetooth) com.android.bluetooth expire 7 lines
07-12 01:32:19.938 I/chatty ( 2768): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:32:19.938 I/chatty ( 2768): uid=1002(bluetooth) com.android.bluetooth expire 28 lines
07-12 01:32:19.939 I/chatty ( 2768): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:32:19.939 I/chatty ( 2768): uid=1002(bluetooth) com.android.bluetooth expire 23 lines
07-12 01:32:19.942 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:32:19.942 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:32:19.959 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:32:19.959 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:32:19.960 I/chatty ( 2768): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:32:19.961 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:32:19.961 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@561a8f
07-12 01:32:19.961 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@30c82f4
07-12 01:32:19.961 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@b668af7
07-12 01:32:19.962 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@a0f2c63
07-12 01:32:19.962 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@d6fc12
07-12 01:32:19.962 I/chatty ( 2768): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:32:19.963 I/chatty ( 2768): uid=1002(bluetooth) com.android.bluetooth expire 11 lines
07-12 01:32:19.963 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:32:19.963 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:32:19.965 I/chatty ( 2768): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:32:19.977 I/chatty ( 2768): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:32:20.158 I/chatty ( 2768): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:32:21.585 D/alsa_route( 232): route_set_controls() set route 24
07-12 01:32:21.587 D/AudioHardwareTiny( 232): close device
07-12 01:32:27.357 F/libc ( 2768): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:32:27.359 F/libc ( 2768): Fatal signal 6 (SIGABRT), code -6 in tid 2795 (hci_thread)
07-12 01:32:27.361 W/ ( 204): debuggerd: handling request: pid=2768 uid=1002 gid=1002 tid=2795
07-12 01:32:27.461 F/DEBUG ( 2797): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:32:27.462 F/DEBUG ( 2797): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:32:27.463 F/DEBUG ( 2797): Revision: ‘0’
07-12 01:32:27.463 F/DEBUG ( 2797): ABI: ‘arm’
07-12 01:32:27.464 F/DEBUG ( 2797): pid: 2768, tid: 2795, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:32:27.465 F/DEBUG ( 2797): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:32:27.479 F/DEBUG ( 2797): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:32:27.479 F/DEBUG ( 2797): r0 00000000 r1 00000aeb r2 00000006 r3 00000008
07-12 01:32:27.479 F/DEBUG ( 2797): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:32:27.479 F/DEBUG ( 2797): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:32:27.480 F/DEBUG ( 2797): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:32:27.491 F/DEBUG ( 2797):
07-12 01:32:27.491 F/DEBUG ( 2797): backtrace:
07-12 01:32:27.491 F/DEBUG ( 2797): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:32:27.491 F/DEBUG ( 2797): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:32:27.491 F/DEBUG ( 2797): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:32:27.491 F/DEBUG ( 2797): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:32:27.491 F/DEBUG ( 2797): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:32:27.491 F/DEBUG ( 2797): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:32:27.491 F/DEBUG ( 2797): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:32:27.491 F/DEBUG ( 2797): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:32:27.491 F/DEBUG ( 2797): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:32:27.492 F/DEBUG ( 2797): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:32:27.492 F/DEBUG ( 2797): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:32:27.492 F/DEBUG ( 2797): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:32:27.746 I/BootReceiver( 466): Copying /data/tombstones/tombstone_05 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:32:27.747 W/ ( 204): debuggerd: resuming target 2768
07-12 01:32:27.770 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:32:27.770 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:32:27.770 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:32:27.771 I/Zygote ( 231): Process 2768 exited due to signal (6)
07-12 01:32:27.771 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@561a8f
07-12 01:32:27.771 I/ActivityManager( 466): Process com.android.bluetooth (pid 2768) has died
07-12 01:32:27.771 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@30c82f4
07-12 01:32:27.771 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@b668af7
07-12 01:32:27.771 D/ActivityManager( 466): cleanUpApplicationRecord – 2768
07-12 01:32:27.771 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@a0f2c63
07-12 01:32:27.771 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.btservice.AdapterService in 1000ms
07-12 01:32:27.771 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 10999ms
07-12 01:32:27.771 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@d6fc12
07-12 01:32:27.833 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:32:27.971 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:32:28.007 I/ActivityManager( 466): Start proc 2804:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:32:28.106 I/chatty ( 2804): uid=1002(bluetooth) com.android.bluetooth expire 39 lines
07-12 01:32:28.169 I/chatty ( 2804): uid=1002(bluetooth) com.android.bluetooth expire 12 lines
07-12 01:32:28.170 I/chatty ( 2804): uid=1002(bluetooth) com.android.bluetooth expire 35 lines
07-12 01:32:28.171 I/chatty ( 2804): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:32:28.173 I/chatty ( 2804): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:32:28.175 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:32:28.176 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:32:28.194 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:32:28.194 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:32:28.195 I/chatty ( 2804): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:32:28.197 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:32:28.197 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@580be49
07-12 01:32:28.197 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@8f24a1d
07-12 01:32:28.198 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@442ffe3
07-12 01:32:28.198 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@b0a9d64
07-12 01:32:28.198 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@f8e4060
07-12 01:32:28.201 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:32:28.201 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:32:28.203 I/chatty ( 2804): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:32:28.219 I/chatty ( 2804): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:32:28.399 I/chatty ( 2804): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:32:33.685 W/ActivityManager( 466): Ignoring remove of inactive process: ProcessRecord{1c5765a 0:com.android.bluetooth/1002}
07-12 01:32:33.905 W/AppOps ( 466): Finishing op nesting under-run: uid 1000 pkg android code 24 time=0 duration=0 nesting=0
07-12 01:32:35.587 F/libc ( 2804): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:32:35.588 F/libc ( 2804): Fatal signal 6 (SIGABRT), code -6 in tid 2831 (hci_thread)
07-12 01:32:35.590 W/ ( 204): debuggerd: handling request: pid=2804 uid=1002 gid=1002 tid=2831
07-12 01:32:35.693 F/DEBUG ( 2833): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:32:35.694 F/DEBUG ( 2833): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:32:35.694 F/DEBUG ( 2833): Revision: ‘0’
07-12 01:32:35.694 F/DEBUG ( 2833): ABI: ‘arm’
07-12 01:32:35.695 F/DEBUG ( 2833): pid: 2804, tid: 2831, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:32:35.696 F/DEBUG ( 2833): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:32:35.707 F/DEBUG ( 2833): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:32:35.707 F/DEBUG ( 2833): r0 00000000 r1 00000b0f r2 00000006 r3 00000008
07-12 01:32:35.707 F/DEBUG ( 2833): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:32:35.707 F/DEBUG ( 2833): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:32:35.707 F/DEBUG ( 2833): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:32:35.718 F/DEBUG ( 2833):
07-12 01:32:35.718 F/DEBUG ( 2833): backtrace:
07-12 01:32:35.718 F/DEBUG ( 2833): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:32:35.718 F/DEBUG ( 2833): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:32:35.718 F/DEBUG ( 2833): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:32:35.718 F/DEBUG ( 2833): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:32:35.719 F/DEBUG ( 2833): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:32:35.719 F/DEBUG ( 2833): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:32:35.719 F/DEBUG ( 2833): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:32:35.719 F/DEBUG ( 2833): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:32:35.719 F/DEBUG ( 2833): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:32:35.719 F/DEBUG ( 2833): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:32:35.719 F/DEBUG ( 2833): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:32:35.719 F/DEBUG ( 2833): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:32:35.968 W/ActivityManager( 466): Process com.android.bluetooth has crashed too many times: killing!
07-12 01:32:35.968 I/ActivityManager( 466): Killing 2804:com.android.bluetooth/1002 (adj -700): crash
07-12 01:32:35.968 D/ActivityManager( 466): cleanUpApplicationRecord – 2804
07-12 01:32:35.969 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:32:35.969 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:32:35.969 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 6 receivers.
07-12 01:32:35.969 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@580be49
07-12 01:32:35.969 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@8f24a1d
07-12 01:32:35.969 E/ ( 2833): debuggerd: failed to kill process 2804: No such process
07-12 01:32:35.969 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@b0a9d64
07-12 01:32:35.969 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@f8e4060
07-12 01:32:35.970 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@442ffe3
07-12 01:32:35.970 W/ ( 204): debuggerd: resuming target 2804
07-12 01:32:35.971 I/BootReceiver( 466): Copying /data/tombstones/tombstone_06 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:32:35.997 I/Zygote ( 231): Process 2804 exited due to signal (6)
07-12 01:32:36.169 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:32:36.220 I/ActivityManager( 466): Start proc 2841:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:32:36.336 I/chatty ( 2841): uid=1002(bluetooth) com.android.bluetooth expire 16 lines
07-12 01:32:36.405 I/chatty ( 2841): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:32:36.405 I/chatty ( 2841): uid=1002(bluetooth) com.android.bluetooth expire 7 lines
07-12 01:32:36.407 I/chatty ( 2841): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:32:36.407 I/chatty ( 2841): uid=1002(bluetooth) com.android.bluetooth expire 28 lines
07-12 01:32:36.408 I/chatty ( 2841): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:32:36.409 I/chatty ( 2841): uid=1002(bluetooth) com.android.bluetooth expire 23 lines
07-12 01:32:36.411 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:32:36.412 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:32:36.430 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:32:36.431 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:32:36.431 I/chatty ( 2841): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:32:36.433 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:32:36.433 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@234f603
07-12 01:32:36.433 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@12c9492
07-12 01:32:36.433 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@ed1abcd
07-12 01:32:36.434 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@7104de0
07-12 01:32:36.434 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@16ed919
07-12 01:32:36.434 I/chatty ( 2841): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:32:36.434 I/chatty ( 2841): uid=1002(bluetooth) com.android.bluetooth expire 11 lines
07-12 01:32:36.435 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:32:36.435 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:32:36.437 I/chatty ( 2841): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:32:36.450 I/chatty ( 2841): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:32:36.632 I/chatty ( 2841): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:32:43.820 F/libc ( 2841): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:32:43.822 F/libc ( 2841): Fatal signal 6 (SIGABRT), code -6 in tid 2868 (hci_thread)
07-12 01:32:43.823 W/ ( 204): debuggerd: handling request: pid=2841 uid=1002 gid=1002 tid=2868
07-12 01:32:43.925 F/DEBUG ( 2870): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:32:43.926 F/DEBUG ( 2870): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:32:43.926 F/DEBUG ( 2870): Revision: ‘0’
07-12 01:32:43.927 F/DEBUG ( 2870): ABI: ‘arm’
07-12 01:32:43.928 F/DEBUG ( 2870): pid: 2841, tid: 2868, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:32:43.928 F/DEBUG ( 2870): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:32:43.943 F/DEBUG ( 2870): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:32:43.943 F/DEBUG ( 2870): r0 00000000 r1 00000b34 r2 00000006 r3 00000008
07-12 01:32:43.943 F/DEBUG ( 2870): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:32:43.943 F/DEBUG ( 2870): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:32:43.943 F/DEBUG ( 2870): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:32:43.954 F/DEBUG ( 2870):
07-12 01:32:43.954 F/DEBUG ( 2870): backtrace:
07-12 01:32:43.954 F/DEBUG ( 2870): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:32:43.954 F/DEBUG ( 2870): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:32:43.955 F/DEBUG ( 2870): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:32:43.955 F/DEBUG ( 2870): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:32:43.955 F/DEBUG ( 2870): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:32:43.955 F/DEBUG ( 2870): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:32:43.955 F/DEBUG ( 2870): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:32:43.955 F/DEBUG ( 2870): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:32:43.955 F/DEBUG ( 2870): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:32:43.955 F/DEBUG ( 2870): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:32:43.955 F/DEBUG ( 2870): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:32:43.955 F/DEBUG ( 2870): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:32:44.206 E/ ( 2870): debuggerd: failed to kill process 2841: No such process
07-12 01:32:44.207 W/ ( 204): debuggerd: resuming target 2841
07-12 01:32:44.208 I/BootReceiver( 466): Copying /data/tombstones/tombstone_07 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:32:44.230 I/ActivityManager( 466): Process com.android.bluetooth (pid 2841) has died
07-12 01:32:44.230 D/ActivityManager( 466): cleanUpApplicationRecord – 2841
07-12 01:32:44.230 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:32:44.230 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:32:44.230 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:32:44.230 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.btservice.AdapterService in 1000ms
07-12 01:32:44.230 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:32:44.231 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@234f603
07-12 01:32:44.231 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@12c9492
07-12 01:32:44.231 I/Zygote ( 231): Process 2841 exited due to signal (6)
07-12 01:32:44.231 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@ed1abcd
07-12 01:32:44.231 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@16ed919
07-12 01:32:44.231 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@7104de0
07-12 01:32:44.297 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:32:44.431 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:32:44.455 I/ActivityManager( 466): Start proc 2877:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:32:44.549 I/chatty ( 2877): uid=1002(bluetooth) com.android.bluetooth expire 39 lines
07-12 01:32:44.616 I/chatty ( 2877): uid=1002(bluetooth) com.android.bluetooth expire 12 lines
07-12 01:32:44.616 I/chatty ( 2877): uid=1002(bluetooth) com.android.bluetooth expire 35 lines
07-12 01:32:44.617 I/chatty ( 2877): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:32:44.618 I/chatty ( 2877): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:32:44.619 I/chatty ( 2877): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:32:44.622 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:32:44.622 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:32:44.638 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:32:44.638 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:32:44.639 I/chatty ( 2877): uid=1002(bluetooth) com.android.bluetooth expire 2 lines
07-12 01:32:44.640 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:32:44.641 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@1db4061
07-12 01:32:44.641 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@2bee63
07-12 01:32:44.641 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@f2ccc82
07-12 01:32:44.642 I/chatty ( 2877): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:32:44.642 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@4ae3dde
07-12 01:32:44.642 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@4eb9899
07-12 01:32:44.643 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:32:44.643 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:32:44.644 I/chatty ( 2877): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:32:44.656 I/chatty ( 2877): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:32:44.830 I/chatty ( 2877): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:32:52.011 F/libc ( 2877): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:32:52.012 F/libc ( 2877): Fatal signal 6 (SIGABRT), code -6 in tid 2904 (hci_thread)
07-12 01:32:52.014 W/ ( 204): debuggerd: handling request: pid=2877 uid=1002 gid=1002 tid=2904
07-12 01:32:52.109 F/DEBUG ( 2906): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:32:52.110 F/DEBUG ( 2906): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:32:52.110 F/DEBUG ( 2906): Revision: ‘0’
07-12 01:32:52.111 F/DEBUG ( 2906): ABI: ‘arm’
07-12 01:32:52.112 F/DEBUG ( 2906): pid: 2877, tid: 2904, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:32:52.112 F/DEBUG ( 2906): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:32:52.129 F/DEBUG ( 2906): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:32:52.129 F/DEBUG ( 2906): r0 00000000 r1 00000b58 r2 00000006 r3 00000008
07-12 01:32:52.129 F/DEBUG ( 2906): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:32:52.129 F/DEBUG ( 2906): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:32:52.129 F/DEBUG ( 2906): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:32:52.140 F/DEBUG ( 2906):
07-12 01:32:52.140 F/DEBUG ( 2906): backtrace:
07-12 01:32:52.140 F/DEBUG ( 2906): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:32:52.140 F/DEBUG ( 2906): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:32:52.140 F/DEBUG ( 2906): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:32:52.140 F/DEBUG ( 2906): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:32:52.140 F/DEBUG ( 2906): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:32:52.140 F/DEBUG ( 2906): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:32:52.140 F/DEBUG ( 2906): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:32:52.141 F/DEBUG ( 2906): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:32:52.141 F/DEBUG ( 2906): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:32:52.141 F/DEBUG ( 2906): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:32:52.141 F/DEBUG ( 2906): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:32:52.141 F/DEBUG ( 2906): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:32:52.380 E/ ( 2906): debuggerd: failed to kill process 2877: No such process
07-12 01:32:52.383 W/ ( 204): debuggerd: resuming target 2877
07-12 01:32:52.383 I/BootReceiver( 466): Copying /data/tombstones/tombstone_08 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:32:52.414 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:32:52.414 I/Zygote ( 231): Process 2877 exited due to signal (6)
07-12 01:32:52.414 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:32:52.414 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:32:52.414 I/ActivityManager( 466): Process com.android.bluetooth (pid 2877) has died
07-12 01:32:52.414 D/ActivityManager( 466): cleanUpApplicationRecord – 2877
07-12 01:32:52.414 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@1db4061
07-12 01:32:52.414 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@2bee63
07-12 01:32:52.414 W/ActivityManager( 466): Service crashed 2 times, stopping: ServiceRecord{c549e26 u0 com.android.bluetooth/.btservice.AdapterService}
07-12 01:32:52.414 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@4ae3dde
07-12 01:32:52.414 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@f2ccc82
07-12 01:32:52.414 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:32:52.414 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@4eb9899
07-12 01:32:52.463 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:32:52.613 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:32:52.636 I/ActivityManager( 466): Start proc 2913:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:32:52.729 I/chatty ( 2913): uid=1002(bluetooth) com.android.bluetooth expire 16 lines
07-12 01:32:52.793 I/chatty ( 2913): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:32:52.793 I/chatty ( 2913): uid=1002(bluetooth) com.android.bluetooth expire 35 lines
07-12 01:32:52.794 I/chatty ( 2913): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:32:52.795 I/chatty ( 2913): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:32:52.796 I/chatty ( 2913): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:32:52.796 I/chatty ( 2913): uid=1002(bluetooth) com.android.bluetooth expire 23 lines
07-12 01:32:52.799 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:32:52.799 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:32:52.818 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:32:52.818 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:32:52.819 I/chatty ( 2913): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:32:52.820 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:32:52.820 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@a3402f
07-12 01:32:52.820 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@8e8da60
07-12 01:32:52.821 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@aeedf93
07-12 01:32:52.821 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@24c75e
07-12 01:32:52.821 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@cbe2bbf
07-12 01:32:52.822 I/chatty ( 2913): uid=1002(bluetooth) com.android.bluetooth expire 11 lines
07-12 01:32:52.822 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:32:52.822 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:32:52.824 I/chatty ( 2913): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:32:52.835 I/chatty ( 2913): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:32:53.016 I/chatty ( 2913): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:33:00.208 F/libc ( 2913): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:33:00.210 F/libc ( 2913): Fatal signal 6 (SIGABRT), code -6 in tid 2941 (hci_thread)
07-12 01:33:00.211 W/ ( 204): debuggerd: handling request: pid=2913 uid=1002 gid=1002 tid=2941
07-12 01:33:00.304 F/DEBUG ( 2943): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:33:00.305 F/DEBUG ( 2943): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:33:00.306 F/DEBUG ( 2943): Revision: ‘0’
07-12 01:33:00.306 F/DEBUG ( 2943): ABI: ‘arm’
07-12 01:33:00.307 F/DEBUG ( 2943): pid: 2913, tid: 2941, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:33:00.308 F/DEBUG ( 2943): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:33:00.319 F/DEBUG ( 2943): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:33:00.320 F/DEBUG ( 2943): r0 00000000 r1 00000b7d r2 00000006 r3 00000008
07-12 01:33:00.320 F/DEBUG ( 2943): r4 93370978 r5 00000006 r6 93370920 r7 0000010c
07-12 01:33:00.320 F/DEBUG ( 2943): r8 00000000 r9 933704b0 sl ada58180 fp a4abb564
07-12 01:33:00.320 F/DEBUG ( 2943): ip 00000000 sp 93370410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:33:00.331 F/DEBUG ( 2943):
07-12 01:33:00.331 F/DEBUG ( 2943): backtrace:
07-12 01:33:00.331 F/DEBUG ( 2943): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:33:00.331 F/DEBUG ( 2943): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:33:00.331 F/DEBUG ( 2943): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:33:00.331 F/DEBUG ( 2943): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:33:00.331 F/DEBUG ( 2943): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:33:00.331 F/DEBUG ( 2943): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:33:00.331 F/DEBUG ( 2943): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:33:00.331 F/DEBUG ( 2943): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:33:00.331 F/DEBUG ( 2943): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:33:00.331 F/DEBUG ( 2943): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:33:00.331 F/DEBUG ( 2943): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:33:00.331 F/DEBUG ( 2943): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:33:00.587 W/ ( 204): debuggerd: resuming target 2913
07-12 01:33:00.587 I/BootReceiver( 466): Copying /data/tombstones/tombstone_09 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:33:00.613 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:33:00.613 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:33:00.613 I/ActivityManager( 466): Process com.android.bluetooth (pid 2913) has died
07-12 01:33:00.613 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:33:00.613 D/ActivityManager( 466): cleanUpApplicationRecord – 2913
07-12 01:33:00.614 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@a3402f
07-12 01:33:00.614 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@8e8da60
07-12 01:33:00.614 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.btservice.AdapterService in 1000ms
07-12 01:33:00.614 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 11000ms
07-12 01:33:00.614 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@24c75e
07-12 01:33:00.614 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@aeedf93
07-12 01:33:00.614 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@cbe2bbf
07-12 01:33:00.615 I/Zygote ( 231): Process 2913 exited due to signal (6)
07-12 01:33:00.638 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:33:00.814 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:33:00.837 I/ActivityManager( 466): Start proc 2950:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:33:00.956 I/chatty ( 2950): uid=1002(bluetooth) com.android.bluetooth expire 39 lines
07-12 01:33:01.025 I/chatty ( 2950): uid=1002(bluetooth) com.android.bluetooth expire 12 lines
07-12 01:33:01.025 I/chatty ( 2950): uid=1002(bluetooth) com.android.bluetooth expire 35 lines
07-12 01:33:01.027 I/chatty ( 2950): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:33:01.028 I/chatty ( 2950): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:33:01.031 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:33:01.031 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:33:01.050 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:33:01.050 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:33:01.051 I/chatty ( 2950): uid=1002(bluetooth) com.android.bluetooth expire 3 lines
07-12 01:33:01.053 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:33:01.053 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@74c94ed
07-12 01:33:01.053 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@3ee6b19
07-12 01:33:01.054 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@51bb73f
07-12 01:33:01.054 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@e862bd0
07-12 01:33:01.054 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@307028c
07-12 01:33:01.055 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:33:01.055 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:33:01.057 I/chatty ( 2950): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:33:01.070 I/chatty ( 2950): uid=1002(bluetooth) com.android.bluetooth expire 17 lines
07-12 01:33:01.253 I/chatty ( 2950): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:33:08.447 F/libc ( 2950): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:33:08.449 F/libc ( 2950): Fatal signal 6 (SIGABRT), code -6 in tid 2977 (hci_thread)
07-12 01:33:08.450 W/ ( 204): debuggerd: handling request: pid=2950 uid=1002 gid=1002 tid=2977
07-12 01:33:08.553 F/DEBUG ( 2979): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:33:08.554 F/DEBUG ( 2979): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:33:08.554 F/DEBUG ( 2979): Revision: ‘0’
07-12 01:33:08.554 F/DEBUG ( 2979): ABI: ‘arm’
07-12 01:33:08.555 F/DEBUG ( 2979): pid: 2950, tid: 2977, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:33:08.556 F/DEBUG ( 2979): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:33:08.572 F/DEBUG ( 2979): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:33:08.572 F/DEBUG ( 2979): r0 00000000 r1 00000ba1 r2 00000006 r3 00000008
07-12 01:33:08.572 F/DEBUG ( 2979): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:33:08.572 F/DEBUG ( 2979): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:33:08.572 F/DEBUG ( 2979): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:33:08.583 F/DEBUG ( 2979):
07-12 01:33:08.583 F/DEBUG ( 2979): backtrace:
07-12 01:33:08.583 F/DEBUG ( 2979): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:33:08.583 F/DEBUG ( 2979): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:33:08.583 F/DEBUG ( 2979): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:33:08.583 F/DEBUG ( 2979): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:33:08.584 F/DEBUG ( 2979): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:33:08.584 F/DEBUG ( 2979): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:33:08.584 F/DEBUG ( 2979): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:33:08.584 F/DEBUG ( 2979): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:33:08.584 F/DEBUG ( 2979): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:33:08.584 F/DEBUG ( 2979): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:33:08.584 F/DEBUG ( 2979): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:33:08.584 F/DEBUG ( 2979): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:33:08.829 W/ ( 204): debuggerd: resuming target 2950
07-12 01:33:08.830 I/BootReceiver( 466): Copying /data/tombstones/tombstone_00 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:33:08.867 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:33:08.867 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:33:08.867 I/Zygote ( 231): Process 2950 exited due to signal (6)
07-12 01:33:08.867 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:33:08.867 I/ActivityManager( 466): Process com.android.bluetooth (pid 2950) has died
07-12 01:33:08.867 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@74c94ed
07-12 01:33:08.867 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@3ee6b19
07-12 01:33:08.867 D/ActivityManager( 466): cleanUpApplicationRecord – 2950
07-12 01:33:08.868 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:33:08.868 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@307028c
07-12 01:33:08.868 W/ActivityManager( 466): Service crashed 2 times, stopping: ServiceRecord{b0347c2 u0 com.android.bluetooth/.btservice.AdapterService}
07-12 01:33:08.868 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@e862bd0
07-12 01:33:08.868 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@51bb73f
07-12 01:33:08.897 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:33:09.068 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:33:09.088 I/ActivityManager( 466): Start proc 2986:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:33:09.186 I/chatty ( 2986): uid=1002(bluetooth) com.android.bluetooth expire 16 lines
07-12 01:33:09.254 I/chatty ( 2986): uid=1002(bluetooth) com.android.bluetooth expire 1 line
07-12 01:33:09.254 I/chatty ( 2986): uid=1002(bluetooth) com.android.bluetooth expire 4 lines
07-12 01:33:09.255 I/bt_core_module( 2986): module_init Initializing module “bt_utils_module”
07-12 01:33:09.255 I/bt_core_module( 2986): module_init Initialized module “bt_utils_module”
07-12 01:33:09.255 I/bt_core_module( 2986): module_init Initializing module “btif_config_module”
07-12 01:33:09.256 W/bt_osi_thread( 2986): run_thread: thread id 3006, thread name alarm_default_ca started
07-12 01:33:09.256 W/bt_osi_thread( 2986): run_thread: thread id 3007, thread name alarm_dispatcher started
07-12 01:33:09.256 I/bt_core_module( 2986): module_init Initialized module “btif_config_module”
07-12 01:33:09.256 I/bt_core_module( 2986): module_init Initializing module “interop_module”
07-12 01:33:09.256 I/bt_core_module( 2986): module_init Initialized module “interop_module”
07-12 01:33:09.256 I/bt_core_module( 2986): module_init Initializing module “stack_config_module”
07-12 01:33:09.256 I/bt_stack_config( 2986): init attempt to load stack conf from /etc/bluetooth/bt_stack.conf
07-12 01:33:09.257 I/bt_core_module( 2986): module_init Initialized module “stack_config_module”
07-12 01:33:09.257 E/bt_btif ( 2986): vendor_storage open fail
07-12 01:33:09.257 E/bt_btif ( 2986): btif_fetch_local_bdaddr, local bdaddr is stored in /data/misc/bluetooth/bdaddr
07-12 01:33:09.257 E/bt_btif ( 2986): local bdaddr from bt_config.xml is 22:22:d2:b5:04:c4
07-12 01:33:09.257 W/bt_osi_thread( 2986): run_thread: thread id 3008, thread name bt_jni_workqueue started
07-12 01:33:09.257 I/bt_stack_manager( 2986): event_init_stack finished
07-12 01:33:09.257 I/bt_osi_wakelock( 2986): wakelock_set_os_callouts set to non-native
07-12 01:33:09.257 I/bt_btif ( 2986): get_profile_interface socket
07-12 01:33:09.258 D/BluetoothAdapterProperties( 2986): Address is:22:22:D2:B5:04:C4
07-12 01:33:09.260 D/BluetoothAdapterProperties( 2986): Name is: rk3288
07-12 01:33:09.260 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:33:09.260 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:33:09.270 I/bt_btif ( 2986): get_profile_interface sdp
07-12 01:33:09.273 D/BluetoothAdapterService( 2986): setAdapterService() - set to: null
07-12 01:33:09.275 D/BluetoothAdapterService( 2986): onBind()
07-12 01:33:09.276 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:33:09.276 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:33:09.277 I/bt_btif ( 2986): config_hci_snoop_log
07-12 01:33:09.278 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:33:09.278 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@8c27a1b
07-12 01:33:09.278 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@f7b67de
07-12 01:33:09.278 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@35a37c9
07-12 01:33:09.279 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@10aedd5
07-12 01:33:09.279 D/BluetoothAdapter( 2986): onBluetoothServiceUp: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@4533cb2
07-12 01:33:09.279 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@85c680c
07-12 01:33:09.279 D/BluetoothAdapterService( 2986): enable() - Enable called with quiet mode status = false
07-12 01:33:09.280 D/BluetoothAdapterState( 2986): Current state: OFF, message: 0
07-12 01:33:09.280 D/BluetoothAdapterProperties( 2986): Setting state to 14
07-12 01:33:09.280 I/BluetoothAdapterState( 2986): Bluetooth adapter state changed: 10-> 14
07-12 01:33:09.280 D/BluetoothAdapterService( 2986): updateAdapterState() - Broadcasting state to 1 receivers.
07-12 01:33:09.280 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:33:09.280 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:33:09.281 D/BluetoothAdapterService( 2986): BleOnProcessStart()
07-12 01:33:09.281 D/BluetoothAdapterService( 2986): BleOnProcessStart() - Make Bond State Machine
07-12 01:33:09.281 D/BluetoothBondStateMachine( 2986): make
07-12 01:33:09.282 I/BluetoothBondStateMachine( 2986): StableState(): Entering Off State
07-12 01:33:09.283 D/BluetoothAdapterService( 2986): setProfileServiceState() - Starting service com.android.bluetooth.gatt.GattService
07-12 01:33:09.284 I/BluetoothAdapterState( 2986): Entering PendingCommandState
07-12 01:33:09.285 I/BtGatt.JNI( 2986): classInitNative(L922): classInitNative: Success!
07-12 01:33:09.287 D/BtGatt.DebugUtils( 2986): handleDebugAction() action=null
07-12 01:33:09.287 D/BluetoothAdapterService( 2986): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@7988867
07-12 01:33:09.287 D/BtGatt.GattService( 2986): Received start request. Starting profile…
07-12 01:33:09.287 D/BtGatt.GattService( 2986): start()
07-12 01:33:09.287 I/bt_btif ( 2986): get_profile_interface gatt
07-12 01:33:09.288 D/BluetoothAdapterService( 2986): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@7988867
07-12 01:33:09.288 D/BtGatt.AdvertiseManager( 2986): advertise manager created
07-12 01:33:09.291 D/BluetoothAdapterService( 2986): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@7988867
07-12 01:33:09.291 D/BluetoothAdapterService( 2986): handleMessage() - Message: 1
07-12 01:33:09.291 D/BluetoothAdapterService( 2986): handleMessage() - MESSAGE_PROFILE_SERVICE_STATE_CHANGED
07-12 01:33:09.291 D/BluetoothAdapterService( 2986): processProfileServiceStateChanged() serviceName=com.android.bluetooth.gatt.GattService, state=12, doUpdate=true
07-12 01:33:09.291 V/BluetoothAdapterState( 2986): isTurningOff()=false
07-12 01:33:09.292 V/BluetoothAdapterState( 2986): isTurningOn()=false
07-12 01:33:09.292 V/BluetoothAdapterState( 2986): isBleTurningOn()=true
07-12 01:33:09.292 V/BluetoothAdapterState( 2986): isBleTurningOff()=false
07-12 01:33:09.292 D/BluetoothAdapterService( 2986): processProfileServiceStateChanged() - serviceName=com.android.bluetooth.gatt.GattService isTurningOn=false isTurningOff=false isBleTurningOn=true isBleTurningOff=false
07-12 01:33:09.292 D/BluetoothAdapterService( 2986): GattService is started
07-12 01:33:09.292 D/BluetoothAdapterState( 2986): Current state: PENDING_COMMAND, message: 4
07-12 01:33:09.293 I/bt_btif ( 2986): enable: start restricted = 0
07-12 01:33:09.293 I/bt_stack_manager( 2986): event_start_up_stack is bringing up the stack
07-12 01:33:09.293 I/bt_core_module( 2986): module_start_up Starting module “btif_config_module”
07-12 01:33:09.293 I/bt_core_module( 2986): module_start_up Started module “btif_config_module”
07-12 01:33:09.293 I/bt_core_module( 2986): module_start_up Starting module “btsnoop_module”
07-12 01:33:09.293 I/bt_core_module( 2986): module_start_up Started module “btsnoop_module”
07-12 01:33:09.293 I/bt_core_module( 2986): module_start_up Starting module “hci_module”
07-12 01:33:09.293 I/bt_hci ( 2986): start_up
07-12 01:33:09.294 W/bt_osi_thread( 2986): run_thread: thread id 3013, thread name hci_thread started
07-12 01:33:09.295 I/bt_vendor( 2986): alloc value 0x94183295
07-12 01:33:09.295 I/bt_vendor( 2986): init
07-12 01:33:09.295 I/bt_vnd_conf( 2986): Attempt to load conf from /system/etc/bluetooth/bt_vendor.conf
07-12 01:33:09.296 D/bt_vendor( 2986): op for 0
07-12 01:33:09.296 D/bt_upio ( 2986): is_emulator_context : 0
07-12 01:33:09.296 D/bt_upio ( 2986): is_rfkill_disabled ? [0]
07-12 01:33:09.319 D/bt_vendor( 2986): op for 0
07-12 01:33:09.319 D/bt_upio ( 2986): is_emulator_context : 0
07-12 01:33:09.319 D/bt_upio ( 2986): is_rfkill_disabled ? [0]
07-12 01:33:09.471 D/bt_hci ( 2986): start_up starting async portion
07-12 01:33:09.471 I/bt_hci ( 2986): event_finish_startup
07-12 01:33:09.472 I/bt_hci_h4( 2986): hal_open
07-12 01:33:09.472 D/bt_vendor( 2986): op for 3
07-12 01:33:09.472 I/bt_userial_vendor( 2986): userial vendor open: opening /dev/ttyS0
07-12 01:33:09.473 I/bt_userial_vendor( 2986): device fd = 74 open
07-12 01:33:09.475 W/bt_osi_thread( 2986): run_thread: thread id 3014, thread name hci_single_chann started
07-12 01:33:09.476 D/bt_vendor( 2986): op for 1
07-12 01:33:09.486 I/bt_hwcfg( 2986): bt vendor lib: set UART baud 115200
07-12 01:33:09.712 D/bt_hwcfg( 2986): Chipset BCM4335C0
07-12 01:33:09.712 D/bt_hwcfg( 2986): Target name = [BCM4335C0]
07-12 01:33:09.713 D/bt_hwcfg( 2986): ###AMPAK FW Auto detection patch version = [v1.1 20161117]###
07-12 01:33:09.713 D/bt_hwcfg( 2986): Updated Target name = [BCM4339A0]
07-12 01:33:09.714 I/bt_hwcfg( 2986): Found patchfile: /system/etc/firmware//bcm4339a0.hcd
07-12 01:33:16.265 I/bt_hwcfg( 2986): bt vendor lib: set UART baud 115200
07-12 01:33:16.466 D/bt_hwcfg( 2986): Settlement delay – 200 ms
07-12 01:33:16.467 I/bt_hwcfg( 2986): Setting fw settlement delay to 200
07-12 01:33:16.668 E/bt_hci_h4( 2986): event_uart_has_bytes Unknown HCI message type 0x0 (min=0x2 max=0x4). Aborting…
07-12 01:33:16.669 F/libc ( 2986): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:33:16.671 F/libc ( 2986): Fatal signal 6 (SIGABRT), code -6 in tid 3013 (hci_thread)
07-12 01:33:16.672 W/ ( 204): debuggerd: handling request: pid=2986 uid=1002 gid=1002 tid=3013
07-12 01:33:16.776 F/DEBUG ( 3015): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:33:16.777 F/DEBUG ( 3015): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:33:16.777 F/DEBUG ( 3015): Revision: ‘0’
07-12 01:33:16.778 F/DEBUG ( 3015): ABI: ‘arm’
07-12 01:33:16.779 F/DEBUG ( 3015): pid: 2986, tid: 3013, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:33:16.779 F/DEBUG ( 3015): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:33:16.805 F/DEBUG ( 3015): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:33:16.805 F/DEBUG ( 3015): r0 00000000 r1 00000bc5 r2 00000006 r3 00000008
07-12 01:33:16.805 F/DEBUG ( 3015): r4 933f0978 r5 00000006 r6 933f0920 r7 0000010c
07-12 01:33:16.806 F/DEBUG ( 3015): r8 00000000 r9 933f04b0 sl ada580e0 fp ada582f4
07-12 01:33:16.806 F/DEBUG ( 3015): ip 00000000 sp 933f0410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:33:16.822 F/DEBUG ( 3015):
07-12 01:33:16.822 F/DEBUG ( 3015): backtrace:
07-12 01:33:16.822 F/DEBUG ( 3015): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:33:16.822 F/DEBUG ( 3015): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:33:16.822 F/DEBUG ( 3015): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:33:16.822 F/DEBUG ( 3015): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:33:16.822 F/DEBUG ( 3015): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:33:16.822 F/DEBUG ( 3015): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:33:16.822 F/DEBUG ( 3015): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:33:16.822 F/DEBUG ( 3015): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:33:16.822 F/DEBUG ( 3015): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:33:16.823 F/DEBUG ( 3015): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:33:16.823 F/DEBUG ( 3015): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:33:16.823 F/DEBUG ( 3015): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:33:17.083 E/ ( 3015): debuggerd: failed to kill process 2986: No such process
07-12 01:33:17.084 W/ ( 204): debuggerd: resuming target 2986
07-12 01:33:17.085 I/BootReceiver( 466): Copying /data/tombstones/tombstone_01 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:33:17.107 I/ActivityManager( 466): Process com.android.bluetooth (pid 2986) has died
07-12 01:33:17.107 D/ActivityManager( 466): cleanUpApplicationRecord – 2986
07-12 01:33:17.107 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.btservice.AdapterService in 1000ms
07-12 01:33:17.107 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:33:17.107 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 10999ms
07-12 01:33:17.107 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:33:17.107 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:33:17.107 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@8c27a1b
07-12 01:33:17.107 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@f7b67de
07-12 01:33:17.107 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@35a37c9
07-12 01:33:17.108 I/Zygote ( 231): Process 2986 exited due to signal (6)
07-12 01:33:17.109 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@10aedd5
07-12 01:33:17.109 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@85c680c
07-12 01:33:17.126 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:33:17.308 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:33:17.327 I/ActivityManager( 466): Start proc 3022:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:33:17.439 E/RTKBT ( 3022): jniRegisterNativeMethods
07-12 01:33:17.457 D/AdapterServiceConfig( 3022): Adding A2dpService
07-12 01:33:17.458 D/AdapterServiceConfig( 3022): Adding HidService
07-12 01:33:17.458 D/AdapterServiceConfig( 3022): Adding PanService
07-12 01:33:17.458 D/AdapterServiceConfig( 3022): Adding GattService
07-12 01:33:17.462 D/WifiHW ( 3022): uevent path:/sys/bus/sdio/devices/./uevent
07-12 01:33:17.462 D/WifiHW ( 3022): uevent path:/sys/bus/sdio/devices/../uevent
07-12 01:33:17.462 D/WifiHW ( 3022): uevent path:/sys/bus/sdio/devices/mmc2:0001:1/uevent
07-12 01:33:17.463 D/WifiHW ( 3022): found device pid:vid : 02d0:4335
07-12 01:33:17.463 D/WifiHW ( 3022): wifi detectd return ret:0
07-12 01:33:17.463 D/WifiHW ( 3022): SDIO WIFI identify sucess
07-12 01:33:17.463 D/WifiHW ( 3022): check_wifi_chip_type_string: AP6335
07-12 01:33:17.463 D/BluetoothServiceJni( 3022): void android::classInitNative(JNIEnv *, jclass), load bluetooth.default.so
07-12 01:33:17.503 D/BluetoothAdapterService( 3022): onCreate()
07-12 01:33:17.505 D/BluetoothAdapterState( 3022): make() - Creating AdapterState
07-12 01:33:17.507 I/bt_btif ( 3022): init
07-12 01:33:17.507 I/BluetoothAdapterState( 3022): Entering OffState
07-12 01:33:17.507 W/bt_osi_thread( 3022): run_thread: thread id 3040, thread name stack_manager started
07-12 01:33:17.507 I/bt_stack_manager( 3022): event_init_stack is initializing the stack
07-12 01:33:17.508 I/bt_core_module( 3022): module_init Initializing module “osi_module”
07-12 01:33:17.508 I/bt_core_module( 3022): module_init Initialized module “osi_module”
07-12 01:33:17.508 I/bt_core_module( 3022): module_init Initializing module “bt_utils_module”
07-12 01:33:17.508 I/bt_core_module( 3022): module_init Initialized module “bt_utils_module”
07-12 01:33:17.508 I/bt_core_module( 3022): module_init Initializing module “btif_config_module”
07-12 01:33:17.508 W/bt_osi_thread( 3022): run_thread: thread id 3043, thread name alarm_default_ca started
07-12 01:33:17.509 W/bt_osi_thread( 3022): run_thread: thread id 3044, thread name alarm_dispatcher started
07-12 01:33:17.509 I/bt_core_module( 3022): module_init Initialized module “btif_config_module”
07-12 01:33:17.509 I/bt_core_module( 3022): module_init Initializing module “interop_module”
07-12 01:33:17.509 I/bt_core_module( 3022): module_init Initialized module “interop_module”
07-12 01:33:17.509 I/bt_core_module( 3022): module_init Initializing module “stack_config_module”
07-12 01:33:17.509 I/bt_stack_config( 3022): init attempt to load stack conf from /etc/bluetooth/bt_stack.conf
07-12 01:33:17.509 I/bt_core_module( 3022): module_init Initialized module “stack_config_module”
07-12 01:33:17.510 E/bt_btif ( 3022): vendor_storage open fail
07-12 01:33:17.510 E/bt_btif ( 3022): btif_fetch_local_bdaddr, local bdaddr is stored in /data/misc/bluetooth/bdaddr
07-12 01:33:17.510 E/bt_btif ( 3022): local bdaddr from bt_config.xml is 22:22:d2:b5:04:c4
07-12 01:33:17.510 W/bt_osi_thread( 3022): run_thread: thread id 3045, thread name bt_jni_workqueue started
07-12 01:33:17.510 I/bt_stack_manager( 3022): event_init_stack finished
07-12 01:33:17.510 I/bt_osi_wakelock( 3022): wakelock_set_os_callouts set to non-native
07-12 01:33:17.510 I/bt_btif ( 3022): get_profile_interface socket
07-12 01:33:17.511 D/BluetoothAdapterProperties( 3022): Address is:22:22:D2:B5:04:C4
07-12 01:33:17.512 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:33:17.513 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:33:17.513 D/BluetoothAdapterProperties( 3022): Name is: rk3288
07-12 01:33:17.523 I/bt_btif ( 3022): get_profile_interface sdp
07-12 01:33:17.526 D/BluetoothAdapterService( 3022): setAdapterService() - set to: null
07-12 01:33:17.529 D/BluetoothAdapterService( 3022): onBind()
07-12 01:33:17.529 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:33:17.530 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:33:17.530 I/bt_btif ( 3022): config_hci_snoop_log
07-12 01:33:17.531 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:33:17.532 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@d80471
07-12 01:33:17.532 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@4e50dbf
07-12 01:33:17.532 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@8df2ece
07-12 01:33:17.532 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@ddc59ea
07-12 01:33:17.532 D/BluetoothAdapter( 3022): onBluetoothServiceUp: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@4533cb2
07-12 01:33:17.533 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@c542555
07-12 01:33:17.533 D/BluetoothAdapterService( 3022): enable() - Enable called with quiet mode status = false
07-12 01:33:17.533 D/BluetoothAdapterState( 3022): Current state: OFF, message: 0
07-12 01:33:17.533 D/BluetoothAdapterProperties( 3022): Setting state to 14
07-12 01:33:17.533 I/BluetoothAdapterState( 3022): Bluetooth adapter state changed: 10-> 14
07-12 01:33:17.533 D/BluetoothAdapterService( 3022): updateAdapterState() - Broadcasting state to 1 receivers.
07-12 01:33:17.534 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:33:17.534 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:33:17.534 D/BluetoothAdapterService( 3022): BleOnProcessStart()
07-12 01:33:17.534 D/BluetoothAdapterService( 3022): BleOnProcessStart() - Make Bond State Machine
07-12 01:33:17.535 D/BluetoothBondStateMachine( 3022): make
07-12 01:33:17.536 I/BluetoothBondStateMachine( 3022): StableState(): Entering Off State
07-12 01:33:17.536 D/BluetoothAdapterService( 3022): setProfileServiceState() - Starting service com.android.bluetooth.gatt.GattService
07-12 01:33:17.538 I/BluetoothAdapterState( 3022): Entering PendingCommandState
07-12 01:33:17.538 I/BtGatt.JNI( 3022): classInitNative(L922): classInitNative: Success!
07-12 01:33:17.541 D/BtGatt.DebugUtils( 3022): handleDebugAction() action=null
07-12 01:33:17.541 D/BluetoothAdapterService( 3022): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@7988867
07-12 01:33:17.541 D/BtGatt.GattService( 3022): Received start request. Starting profile…
07-12 01:33:17.541 D/BtGatt.GattService( 3022): start()
07-12 01:33:17.541 I/bt_btif ( 3022): get_profile_interface gatt
07-12 01:33:17.542 D/BluetoothAdapterService( 3022): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@7988867
07-12 01:33:17.542 D/BtGatt.AdvertiseManager( 3022): advertise manager created
07-12 01:33:17.545 D/BluetoothAdapterService( 3022): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@7988867
07-12 01:33:17.545 D/BluetoothAdapterService( 3022): handleMessage() - Message: 1
07-12 01:33:17.545 D/BluetoothAdapterService( 3022): handleMessage() - MESSAGE_PROFILE_SERVICE_STATE_CHANGED
07-12 01:33:17.545 D/BluetoothAdapterService( 3022): processProfileServiceStateChanged() serviceName=com.android.bluetooth.gatt.GattService, state=12, doUpdate=true
07-12 01:33:17.545 V/BluetoothAdapterState( 3022): isTurningOff()=false
07-12 01:33:17.545 V/BluetoothAdapterState( 3022): isTurningOn()=false
07-12 01:33:17.545 V/BluetoothAdapterState( 3022): isBleTurningOn()=true
07-12 01:33:17.545 V/BluetoothAdapterState( 3022): isBleTurningOff()=false
07-12 01:33:17.545 D/BluetoothAdapterService( 3022): processProfileServiceStateChanged() - serviceName=com.android.bluetooth.gatt.GattService isTurningOn=false isTurningOff=false isBleTurningOn=true isBleTurningOff=false
07-12 01:33:17.546 D/BluetoothAdapterService( 3022): GattService is started
07-12 01:33:17.546 D/BluetoothAdapterState( 3022): Current state: PENDING_COMMAND, message: 4
07-12 01:33:17.546 I/bt_btif ( 3022): enable: start restricted = 0
07-12 01:33:17.546 I/bt_stack_manager( 3022): event_start_up_stack is bringing up the stack
07-12 01:33:17.547 I/bt_core_module( 3022): module_start_up Starting module “btif_config_module”
07-12 01:33:17.547 I/bt_core_module( 3022): module_start_up Started module “btif_config_module”
07-12 01:33:17.547 I/bt_core_module( 3022): module_start_up Starting module “btsnoop_module”
07-12 01:33:17.547 I/bt_core_module( 3022): module_start_up Started module “btsnoop_module”
07-12 01:33:17.547 I/bt_core_module( 3022): module_start_up Starting module “hci_module”
07-12 01:33:17.547 I/bt_hci ( 3022): start_up
07-12 01:33:17.547 W/bt_osi_thread( 3022): run_thread: thread id 3049, thread name hci_thread started
07-12 01:33:17.549 I/bt_vendor( 3022): alloc value 0x940b6295
07-12 01:33:17.549 I/bt_vendor( 3022): init
07-12 01:33:17.549 I/bt_vnd_conf( 3022): Attempt to load conf from /system/etc/bluetooth/bt_vendor.conf
07-12 01:33:17.549 D/bt_vendor( 3022): op for 0
07-12 01:33:17.549 D/bt_upio ( 3022): is_emulator_context : 0
07-12 01:33:17.549 D/bt_upio ( 3022): is_rfkill_disabled ? [0]
07-12 01:33:17.572 D/bt_vendor( 3022): op for 0
07-12 01:33:17.572 D/bt_upio ( 3022): is_emulator_context : 0
07-12 01:33:17.573 D/bt_upio ( 3022): is_rfkill_disabled ? [0]
07-12 01:33:17.724 D/bt_hci ( 3022): start_up starting async portion
07-12 01:33:17.725 I/bt_hci ( 3022): event_finish_startup
07-12 01:33:17.725 I/bt_hci_h4( 3022): hal_open
07-12 01:33:17.725 D/bt_vendor( 3022): op for 3
07-12 01:33:17.726 I/bt_userial_vendor( 3022): userial vendor open: opening /dev/ttyS0
07-12 01:33:17.727 I/bt_userial_vendor( 3022): device fd = 74 open
07-12 01:33:17.729 W/bt_osi_thread( 3022): run_thread: thread id 3050, thread name hci_single_chann started
07-12 01:33:17.730 D/bt_vendor( 3022): op for 1
07-12 01:33:17.741 I/bt_hwcfg( 3022): bt vendor lib: set UART baud 115200
07-12 01:33:17.967 D/bt_hwcfg( 3022): Chipset BCM4335C0
07-12 01:33:17.968 D/bt_hwcfg( 3022): Target name = [BCM4335C0]
07-12 01:33:17.968 D/bt_hwcfg( 3022): ###AMPAK FW Auto detection patch version = [v1.1 20161117]###
07-12 01:33:17.968 D/bt_hwcfg( 3022): Updated Target name = [BCM4339A0]
07-12 01:33:17.970 I/bt_hwcfg( 3022): Found patchfile: /system/etc/firmware//bcm4339a0.hcd
07-12 01:33:24.507 I/bt_hwcfg( 3022): bt vendor lib: set UART baud 115200
07-12 01:33:24.708 D/bt_hwcfg( 3022): Settlement delay – 200 ms
07-12 01:33:24.708 I/bt_hwcfg( 3022): Setting fw settlement delay to 200
07-12 01:33:24.909 E/bt_hci_h4( 3022): event_uart_has_bytes Unknown HCI message type 0x0 (min=0x2 max=0x4). Aborting…
07-12 01:33:24.910 F/libc ( 3022): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:33:24.912 F/libc ( 3022): Fatal signal 6 (SIGABRT), code -6 in tid 3049 (hci_thread)
07-12 01:33:24.913 W/ ( 204): debuggerd: handling request: pid=3022 uid=1002 gid=1002 tid=3049
07-12 01:33:25.016 F/DEBUG ( 3051): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:33:25.017 F/DEBUG ( 3051): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:33:25.017 F/DEBUG ( 3051): Revision: ‘0’
07-12 01:33:25.017 F/DEBUG ( 3051): ABI: ‘arm’
07-12 01:33:25.018 F/DEBUG ( 3051): pid: 3022, tid: 3049, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:33:25.019 F/DEBUG ( 3051): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:33:25.035 F/DEBUG ( 3051): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:33:25.035 F/DEBUG ( 3051): r0 00000000 r1 00000be9 r2 00000006 r3 00000008
07-12 01:33:25.035 F/DEBUG ( 3051): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:33:25.035 F/DEBUG ( 3051): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:33:25.035 F/DEBUG ( 3051): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:33:25.046 F/DEBUG ( 3051):
07-12 01:33:25.046 F/DEBUG ( 3051): backtrace:
07-12 01:33:25.046 F/DEBUG ( 3051): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:33:25.047 F/DEBUG ( 3051): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:33:25.047 F/DEBUG ( 3051): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:33:25.047 F/DEBUG ( 3051): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:33:25.047 F/DEBUG ( 3051): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:33:25.047 F/DEBUG ( 3051): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:33:25.047 F/DEBUG ( 3051): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:33:25.047 F/DEBUG ( 3051): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:33:25.047 F/DEBUG ( 3051): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:33:25.047 F/DEBUG ( 3051): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:33:25.047 F/DEBUG ( 3051): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:33:25.047 F/DEBUG ( 3051): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:33:25.293 E/ ( 3051): debuggerd: failed to kill process 3022: No such process
07-12 01:33:25.294 W/ ( 204): debuggerd: resuming target 3022
07-12 01:33:25.295 I/BootReceiver( 466): Copying /data/tombstones/tombstone_02 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:33:25.320 I/ActivityManager( 466): Process com.android.bluetooth (pid 3022) has died
07-12 01:33:25.320 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:33:25.320 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:33:25.320 D/ActivityManager( 466): cleanUpApplicationRecord – 3022
07-12 01:33:25.320 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:33:25.320 I/Zygote ( 231): Process 3022 exited due to signal (6)
07-12 01:33:25.320 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:33:25.320 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@d80471
07-12 01:33:25.320 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@4e50dbf
07-12 01:33:25.320 W/ActivityManager( 466): Service crashed 2 times, stopping: ServiceRecord{961dc1e u0 com.android.bluetooth/.btservice.AdapterService}
07-12 01:33:25.321 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@8df2ece
07-12 01:33:25.321 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@ddc59ea
07-12 01:33:25.321 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@c542555
07-12 01:33:25.366 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:33:25.521 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:33:25.545 I/ActivityManager( 466): Start proc 3058:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:33:25.632 E/RTKBT ( 3058): jniRegisterNativeMethods
07-12 01:33:25.654 D/AdapterServiceConfig( 3058): Adding A2dpService
07-12 01:33:25.655 D/AdapterServiceConfig( 3058): Adding HidService
07-12 01:33:25.655 D/AdapterServiceConfig( 3058): Adding PanService
07-12 01:33:25.655 D/AdapterServiceConfig( 3058): Adding GattService
07-12 01:33:25.662 D/WifiHW ( 3058): uevent path:/sys/bus/sdio/devices/./uevent
07-12 01:33:25.662 D/WifiHW ( 3058): uevent path:/sys/bus/sdio/devices/../uevent
07-12 01:33:25.662 D/WifiHW ( 3058): uevent path:/sys/bus/sdio/devices/mmc2:0001:1/uevent
07-12 01:33:25.663 D/WifiHW ( 3058): found device pid:vid : 02d0:4335
07-12 01:33:25.663 D/WifiHW ( 3058): wifi detectd return ret:0
07-12 01:33:25.663 D/WifiHW ( 3058): SDIO WIFI identify sucess
07-12 01:33:25.663 D/WifiHW ( 3058): check_wifi_chip_type_string: AP6335
07-12 01:33:25.663 D/BluetoothServiceJni( 3058): void android::classInitNative(JNIEnv *, jclass), load bluetooth.default.so
07-12 01:33:25.713 D/BluetoothAdapterService( 3058): onCreate()
07-12 01:33:25.715 D/BluetoothAdapterState( 3058): make() - Creating AdapterState
07-12 01:33:25.717 I/bt_btif ( 3058): init
07-12 01:33:25.717 I/BluetoothAdapterState( 3058): Entering OffState
07-12 01:33:25.717 W/bt_osi_thread( 3058): run_thread: thread id 3076, thread name stack_manager started
07-12 01:33:25.717 I/bt_stack_manager( 3058): event_init_stack is initializing the stack
07-12 01:33:25.718 I/bt_core_module( 3058): module_init Initializing module “osi_module”
07-12 01:33:25.718 I/bt_core_module( 3058): module_init Initialized module “osi_module”
07-12 01:33:25.718 I/bt_core_module( 3058): module_init Initializing module “bt_utils_module”
07-12 01:33:25.718 I/bt_core_module( 3058): module_init Initialized module “bt_utils_module”
07-12 01:33:25.718 I/bt_core_module( 3058): module_init Initializing module “btif_config_module”
07-12 01:33:25.719 W/bt_osi_thread( 3058): run_thread: thread id 3079, thread name alarm_default_ca started
07-12 01:33:25.719 W/bt_osi_thread( 3058): run_thread: thread id 3080, thread name alarm_dispatcher started
07-12 01:33:25.719 I/bt_core_module( 3058): module_init Initialized module “btif_config_module”
07-12 01:33:25.719 I/bt_core_module( 3058): module_init Initializing module “interop_module”
07-12 01:33:25.719 I/bt_core_module( 3058): module_init Initialized module “interop_module”
07-12 01:33:25.719 I/bt_core_module( 3058): module_init Initializing module “stack_config_module”
07-12 01:33:25.719 I/bt_stack_config( 3058): init attempt to load stack conf from /etc/bluetooth/bt_stack.conf
07-12 01:33:25.720 I/bt_core_module( 3058): module_init Initialized module “stack_config_module”
07-12 01:33:25.720 E/bt_btif ( 3058): vendor_storage open fail
07-12 01:33:25.720 E/bt_btif ( 3058): btif_fetch_local_bdaddr, local bdaddr is stored in /data/misc/bluetooth/bdaddr
07-12 01:33:25.720 E/bt_btif ( 3058): local bdaddr from bt_config.xml is 22:22:d2:b5:04:c4
07-12 01:33:25.720 W/bt_osi_thread( 3058): run_thread: thread id 3081, thread name bt_jni_workqueue started
07-12 01:33:25.720 I/bt_stack_manager( 3058): event_init_stack finished
07-12 01:33:25.721 I/bt_osi_wakelock( 3058): wakelock_set_os_callouts set to non-native
07-12 01:33:25.721 I/bt_btif ( 3058): get_profile_interface socket
07-12 01:33:25.722 D/BluetoothAdapterProperties( 3058): Address is:22:22:D2:B5:04:C4
07-12 01:33:25.723 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:33:25.723 D/BluetoothAdapterProperties( 3058): Name is: rk3288
07-12 01:33:25.723 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:33:25.735 I/bt_btif ( 3058): get_profile_interface sdp
07-12 01:33:25.739 D/BluetoothAdapterService( 3058): setAdapterService() - set to: null
07-12 01:33:25.742 D/BluetoothAdapterService( 3058): onBind()
07-12 01:33:25.743 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:33:25.743 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:33:25.744 I/bt_btif ( 3058): config_hci_snoop_log
07-12 01:33:25.745 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:33:25.745 D/BluetoothAdapter( 3058): onBluetoothServiceUp: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@79b4403
07-12 01:33:25.745 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@57a50bf
07-12 01:33:25.745 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@713c8c
07-12 01:33:25.745 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@89de1ef
07-12 01:33:25.746 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@7f1fb6a
07-12 01:33:25.746 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@f33c4db
07-12 01:33:25.746 D/BluetoothAdapterService( 3058): enable() - Enable called with quiet mode status = false
07-12 01:33:25.747 D/BluetoothAdapterState( 3058): Current state: OFF, message: 0
07-12 01:33:25.747 D/BluetoothAdapterProperties( 3058): Setting state to 14
07-12 01:33:25.747 I/BluetoothAdapterState( 3058): Bluetooth adapter state changed: 10-> 14
07-12 01:33:25.747 D/BluetoothAdapterService( 3058): updateAdapterState() - Broadcasting state to 1 receivers.
07-12 01:33:25.747 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:33:25.747 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:33:25.747 D/BluetoothAdapterService( 3058): BleOnProcessStart()
07-12 01:33:25.747 D/BluetoothAdapterService( 3058): BleOnProcessStart() - Make Bond State Machine
07-12 01:33:25.748 D/BluetoothBondStateMachine( 3058): make
07-12 01:33:25.749 I/BluetoothBondStateMachine( 3058): StableState(): Entering Off State
07-12 01:33:25.749 D/BluetoothAdapterService( 3058): setProfileServiceState() - Starting service com.android.bluetooth.gatt.GattService
07-12 01:33:25.751 I/BluetoothAdapterState( 3058): Entering PendingCommandState
07-12 01:33:25.752 I/BtGatt.JNI( 3058): classInitNative(L922): classInitNative: Success!
07-12 01:33:25.755 D/BtGatt.DebugUtils( 3058): handleDebugAction() action=null
07-12 01:33:25.755 D/BluetoothAdapterService( 3058): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@c2ba614
07-12 01:33:25.755 D/BtGatt.GattService( 3058): Received start request. Starting profile…
07-12 01:33:25.755 D/BtGatt.GattService( 3058): start()
07-12 01:33:25.755 I/bt_btif ( 3058): get_profile_interface gatt
07-12 01:33:25.756 D/BluetoothAdapterService( 3058): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@c2ba614
07-12 01:33:25.756 D/BtGatt.AdvertiseManager( 3058): advertise manager created
07-12 01:33:25.759 D/BluetoothAdapterService( 3058): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@c2ba614
07-12 01:33:25.759 D/BluetoothAdapterService( 3058): handleMessage() - Message: 1
07-12 01:33:25.760 D/BluetoothAdapterService( 3058): handleMessage() - MESSAGE_PROFILE_SERVICE_STATE_CHANGED
07-12 01:33:25.760 D/BluetoothAdapterService( 3058): processProfileServiceStateChanged() serviceName=com.android.bluetooth.gatt.GattService, state=12, doUpdate=true
07-12 01:33:25.760 V/BluetoothAdapterState( 3058): isTurningOff()=false
07-12 01:33:25.760 V/BluetoothAdapterState( 3058): isTurningOn()=false
07-12 01:33:25.760 V/BluetoothAdapterState( 3058): isBleTurningOn()=true
07-12 01:33:25.760 V/BluetoothAdapterState( 3058): isBleTurningOff()=false
07-12 01:33:25.760 D/BluetoothAdapterService( 3058): processProfileServiceStateChanged() - serviceName=com.android.bluetooth.gatt.GattService isTurningOn=false isTurningOff=false isBleTurningOn=true isBleTurningOff=false
07-12 01:33:25.760 D/BluetoothAdapterService( 3058): GattService is started
07-12 01:33:25.760 D/BluetoothAdapterState( 3058): Current state: PENDING_COMMAND, message: 4
07-12 01:33:25.761 I/bt_btif ( 3058): enable: start restricted = 0
07-12 01:33:25.761 I/bt_stack_manager( 3058): event_start_up_stack is bringing up the stack
07-12 01:33:25.761 I/bt_core_module( 3058): module_start_up Starting module “btif_config_module”
07-12 01:33:25.761 I/bt_core_module( 3058): module_start_up Started module “btif_config_module”
07-12 01:33:25.761 I/bt_core_module( 3058): module_start_up Starting module “btsnoop_module”
07-12 01:33:25.762 I/bt_core_module( 3058): module_start_up Started module “btsnoop_module”
07-12 01:33:25.762 I/bt_core_module( 3058): module_start_up Starting module “hci_module”
07-12 01:33:25.762 I/bt_hci ( 3058): start_up
07-12 01:33:25.762 W/bt_osi_thread( 3058): run_thread: thread id 3085, thread name hci_thread started
07-12 01:33:25.764 I/bt_vendor( 3058): alloc value 0x93fce295
07-12 01:33:25.764 I/bt_vendor( 3058): init
07-12 01:33:25.764 I/bt_vnd_conf( 3058): Attempt to load conf from /system/etc/bluetooth/bt_vendor.conf
07-12 01:33:25.764 D/bt_vendor( 3058): op for 0
07-12 01:33:25.764 D/bt_upio ( 3058): is_emulator_context : 0
07-12 01:33:25.764 D/bt_upio ( 3058): is_rfkill_disabled ? [0]
07-12 01:33:25.786 D/bt_vendor( 3058): op for 0
07-12 01:33:25.786 D/bt_upio ( 3058): is_emulator_context : 0
07-12 01:33:25.786 D/bt_upio ( 3058): is_rfkill_disabled ? [0]
07-12 01:33:25.937 D/bt_hci ( 3058): start_up starting async portion
07-12 01:33:25.938 I/bt_hci ( 3058): event_finish_startup
07-12 01:33:25.938 I/bt_hci_h4( 3058): hal_open
07-12 01:33:25.938 D/bt_vendor( 3058): op for 3
07-12 01:33:25.939 I/bt_userial_vendor( 3058): userial vendor open: opening /dev/ttyS0
07-12 01:33:25.940 I/bt_userial_vendor( 3058): device fd = 74 open
07-12 01:33:25.942 W/bt_osi_thread( 3058): run_thread: thread id 3086, thread name hci_single_chann started
07-12 01:33:25.943 D/bt_vendor( 3058): op for 1
07-12 01:33:25.953 I/bt_hwcfg( 3058): bt vendor lib: set UART baud 115200
07-12 01:33:26.180 D/bt_hwcfg( 3058): Chipset BCM4335C0
07-12 01:33:26.180 D/bt_hwcfg( 3058): Target name = [BCM4335C0]
07-12 01:33:26.181 D/bt_hwcfg( 3058): ###AMPAK FW Auto detection patch version = [v1.1 20161117]###
07-12 01:33:26.181 D/bt_hwcfg( 3058): Updated Target name = [BCM4339A0]
07-12 01:33:26.183 I/bt_hwcfg( 3058): Found patchfile: /system/etc/firmware//bcm4339a0.hcd
07-12 01:33:32.717 I/bt_hwcfg( 3058): bt vendor lib: set UART baud 115200
07-12 01:33:32.918 D/bt_hwcfg( 3058): Settlement delay – 200 ms
07-12 01:33:32.918 I/bt_hwcfg( 3058): Setting fw settlement delay to 200
07-12 01:33:33.119 E/bt_hci_h4( 3058): event_uart_has_bytes Unknown HCI message type 0x0 (min=0x2 max=0x4). Aborting…
07-12 01:33:33.120 F/libc ( 3058): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:33:33.122 F/libc ( 3058): Fatal signal 6 (SIGABRT), code -6 in tid 3085 (hci_thread)
07-12 01:33:33.123 W/ ( 204): debuggerd: handling request: pid=3058 uid=1002 gid=1002 tid=3085
07-12 01:33:33.228 F/DEBUG ( 3087): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:33:33.229 F/DEBUG ( 3087): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:33:33.230 F/DEBUG ( 3087): Revision: ‘0’
07-12 01:33:33.230 F/DEBUG ( 3087): ABI: ‘arm’
07-12 01:33:33.231 F/DEBUG ( 3087): pid: 3058, tid: 3085, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:33:33.232 F/DEBUG ( 3087): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:33:33.251 F/DEBUG ( 3087): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:33:33.252 F/DEBUG ( 3087): r0 00000000 r1 00000c0d r2 00000006 r3 00000008
07-12 01:33:33.252 F/DEBUG ( 3087): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:33:33.253 F/DEBUG ( 3087): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:33:33.253 F/DEBUG ( 3087): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:33:33.274 F/DEBUG ( 3087):
07-12 01:33:33.274 F/DEBUG ( 3087): backtrace:
07-12 01:33:33.274 F/DEBUG ( 3087): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:33:33.274 F/DEBUG ( 3087): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:33:33.274 F/DEBUG ( 3087): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:33:33.274 F/DEBUG ( 3087): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:33:33.274 F/DEBUG ( 3087): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:33:33.274 F/DEBUG ( 3087): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:33:33.274 F/DEBUG ( 3087): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:33:33.274 F/DEBUG ( 3087): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:33:33.274 F/DEBUG ( 3087): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:33:33.274 F/DEBUG ( 3087): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:33:33.274 F/DEBUG ( 3087): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:33:33.275 F/DEBUG ( 3087): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:33:33.515 E/ ( 3087): debuggerd: failed to kill process 3058: No such process
07-12 01:33:33.516 W/ ( 204): debuggerd: resuming target 3058
07-12 01:33:33.517 I/BootReceiver( 466): Copying /data/tombstones/tombstone_03 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:33:33.543 I/Zygote ( 231): Process 3058 exited due to signal (6)
07-12 01:33:33.543 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:33:33.544 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:33:33.544 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:33:33.544 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@57a50bf
07-12 01:33:33.544 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@713c8c
07-12 01:33:33.544 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@89de1ef
07-12 01:33:33.544 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@f33c4db
07-12 01:33:33.544 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@7f1fb6a
07-12 01:33:33.544 I/ActivityManager( 466): Process com.android.bluetooth (pid 3058) has died
07-12 01:33:33.544 D/ActivityManager( 466): cleanUpApplicationRecord – 3058
07-12 01:33:33.545 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:33:33.545 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.btservice.AdapterService in 1000ms
07-12 01:33:33.597 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:33:33.744 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:33:33.766 I/ActivityManager( 466): Start proc 3094:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:33:33.872 E/RTKBT ( 3094): jniRegisterNativeMethods
07-12 01:33:33.898 D/AdapterServiceConfig( 3094): Adding A2dpService
07-12 01:33:33.898 D/AdapterServiceConfig( 3094): Adding HidService
07-12 01:33:33.898 D/AdapterServiceConfig( 3094): Adding PanService
07-12 01:33:33.899 D/AdapterServiceConfig( 3094): Adding GattService
07-12 01:33:33.905 D/WifiHW ( 3094): uevent path:/sys/bus/sdio/devices/./uevent
07-12 01:33:33.906 D/WifiHW ( 3094): uevent path:/sys/bus/sdio/devices/../uevent
07-12 01:33:33.906 D/WifiHW ( 3094): uevent path:/sys/bus/sdio/devices/mmc2:0001:1/uevent
07-12 01:33:33.906 D/WifiHW ( 3094): found device pid:vid : 02d0:4335
07-12 01:33:33.906 D/WifiHW ( 3094): wifi detectd return ret:0
07-12 01:33:33.906 D/WifiHW ( 3094): SDIO WIFI identify sucess
07-12 01:33:33.906 D/WifiHW ( 3094): check_wifi_chip_type_string: AP6335
07-12 01:33:33.906 D/BluetoothServiceJni( 3094): void android::classInitNative(JNIEnv *, jclass), load bluetooth.default.so
07-12 01:33:33.958 D/BluetoothAdapterService( 3094): onCreate()
07-12 01:33:33.960 D/BluetoothAdapterState( 3094): make() - Creating AdapterState
07-12 01:33:33.962 I/bt_btif ( 3094): init
07-12 01:33:33.962 I/BluetoothAdapterState( 3094): Entering OffState
07-12 01:33:33.963 W/bt_osi_thread( 3094): run_thread: thread id 3112, thread name stack_manager started
07-12 01:33:33.963 I/bt_stack_manager( 3094): event_init_stack is initializing the stack
07-12 01:33:33.963 I/bt_core_module( 3094): module_init Initializing module “osi_module”
07-12 01:33:33.963 I/bt_core_module( 3094): module_init Initialized module “osi_module”
07-12 01:33:33.963 I/bt_core_module( 3094): module_init Initializing module “bt_utils_module”
07-12 01:33:33.963 I/bt_core_module( 3094): module_init Initialized module “bt_utils_module”
07-12 01:33:33.963 I/bt_core_module( 3094): module_init Initializing module “btif_config_module”
07-12 01:33:33.964 W/bt_osi_thread( 3094): run_thread: thread id 3115, thread name alarm_default_ca started
07-12 01:33:33.964 W/bt_osi_thread( 3094): run_thread: thread id 3116, thread name alarm_dispatcher started
07-12 01:33:33.964 I/bt_core_module( 3094): module_init Initialized module “btif_config_module”
07-12 01:33:33.965 I/bt_core_module( 3094): module_init Initializing module “interop_module”
07-12 01:33:33.965 I/bt_core_module( 3094): module_init Initialized module “interop_module”
07-12 01:33:33.965 I/bt_core_module( 3094): module_init Initializing module “stack_config_module”
07-12 01:33:33.965 I/bt_stack_config( 3094): init attempt to load stack conf from /etc/bluetooth/bt_stack.conf
07-12 01:33:33.965 I/bt_core_module( 3094): module_init Initialized module “stack_config_module”
07-12 01:33:33.965 E/bt_btif ( 3094): vendor_storage open fail
07-12 01:33:33.965 E/bt_btif ( 3094): btif_fetch_local_bdaddr, local bdaddr is stored in /data/misc/bluetooth/bdaddr
07-12 01:33:33.965 E/bt_btif ( 3094): local bdaddr from bt_config.xml is 22:22:d2:b5:04:c4
07-12 01:33:33.966 W/bt_osi_thread( 3094): run_thread: thread id 3117, thread name bt_jni_workqueue started
07-12 01:33:33.966 I/bt_stack_manager( 3094): event_init_stack finished
07-12 01:33:33.966 I/bt_osi_wakelock( 3094): wakelock_set_os_callouts set to non-native
07-12 01:33:33.966 I/bt_btif ( 3094): get_profile_interface socket
07-12 01:33:33.967 D/BluetoothAdapterProperties( 3094): Address is:22:22:D2:B5:04:C4
07-12 01:33:33.969 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:33:33.969 D/BluetoothAdapterProperties( 3094): Name is: rk3288
07-12 01:33:33.969 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:33:33.981 I/bt_btif ( 3094): get_profile_interface sdp
07-12 01:33:33.985 D/BluetoothAdapterService( 3094): setAdapterService() - set to: null
07-12 01:33:33.988 D/BluetoothAdapterService( 3094): onBind()
07-12 01:33:33.988 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:33:33.989 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:33:33.989 I/bt_btif ( 3094): config_hci_snoop_log
07-12 01:33:33.991 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:33:33.991 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@4aab5fd
07-12 01:33:33.991 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@f19fd5
07-12 01:33:33.991 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@3ea34fc
07-12 01:33:33.991 D/BluetoothAdapter( 3094): onBluetoothServiceUp: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@4533cb2
07-12 01:33:33.992 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@b67bb78
07-12 01:33:33.992 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@a9e885b
07-12 01:33:33.993 D/BluetoothAdapterService( 3094): enable() - Enable called with quiet mode status = false
07-12 01:33:33.993 D/BluetoothAdapterState( 3094): Current state: OFF, message: 0
07-12 01:33:33.993 D/BluetoothAdapterProperties( 3094): Setting state to 14
07-12 01:33:33.993 I/BluetoothAdapterState( 3094): Bluetooth adapter state changed: 10-> 14
07-12 01:33:33.993 D/BluetoothAdapterService( 3094): updateAdapterState() - Broadcasting state to 1 receivers.
07-12 01:33:33.993 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:33:33.993 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:33:33.994 D/BluetoothAdapterService( 3094): BleOnProcessStart()
07-12 01:33:33.994 D/BluetoothAdapterService( 3094): BleOnProcessStart() - Make Bond State Machine
07-12 01:33:33.994 D/BluetoothBondStateMachine( 3094): make
07-12 01:33:33.995 I/BluetoothBondStateMachine( 3094): StableState(): Entering Off State
07-12 01:33:33.996 D/BluetoothAdapterService( 3094): setProfileServiceState() - Starting service com.android.bluetooth.gatt.GattService
07-12 01:33:33.998 I/BluetoothAdapterState( 3094): Entering PendingCommandState
07-12 01:33:33.998 I/BtGatt.JNI( 3094): classInitNative(L922): classInitNative: Success!
07-12 01:33:34.001 D/BtGatt.DebugUtils( 3094): handleDebugAction() action=null
07-12 01:33:34.001 D/BluetoothAdapterService( 3094): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@7988867
07-12 01:33:34.001 D/BtGatt.GattService( 3094): Received start request. Starting profile…
07-12 01:33:34.001 D/BtGatt.GattService( 3094): start()
07-12 01:33:34.001 I/bt_btif ( 3094): get_profile_interface gatt
07-12 01:33:34.002 D/BluetoothAdapterService( 3094): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@7988867
07-12 01:33:34.002 D/BtGatt.AdvertiseManager( 3094): advertise manager created
07-12 01:33:34.005 D/BluetoothAdapterService( 3094): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@7988867
07-12 01:33:34.006 D/BluetoothAdapterService( 3094): handleMessage() - Message: 1
07-12 01:33:34.006 D/BluetoothAdapterService( 3094): handleMessage() - MESSAGE_PROFILE_SERVICE_STATE_CHANGED
07-12 01:33:34.006 D/BluetoothAdapterService( 3094): processProfileServiceStateChanged() serviceName=com.android.bluetooth.gatt.GattService, state=12, doUpdate=true
07-12 01:33:34.006 V/BluetoothAdapterState( 3094): isTurningOff()=false
07-12 01:33:34.006 V/BluetoothAdapterState( 3094): isTurningOn()=false
07-12 01:33:34.006 V/BluetoothAdapterState( 3094): isBleTurningOn()=true
07-12 01:33:34.006 V/BluetoothAdapterState( 3094): isBleTurningOff()=false
07-12 01:33:34.006 D/BluetoothAdapterService( 3094): processProfileServiceStateChanged() - serviceName=com.android.bluetooth.gatt.GattService isTurningOn=false isTurningOff=false isBleTurningOn=true isBleTurningOff=false
07-12 01:33:34.006 D/BluetoothAdapterService( 3094): GattService is started
07-12 01:33:34.006 D/BluetoothAdapterState( 3094): Current state: PENDING_COMMAND, message: 4
07-12 01:33:34.007 I/bt_btif ( 3094): enable: start restricted = 0
07-12 01:33:34.007 I/bt_stack_manager( 3094): event_start_up_stack is bringing up the stack
07-12 01:33:34.007 I/bt_core_module( 3094): module_start_up Starting module “btif_config_module”
07-12 01:33:34.008 I/bt_core_module( 3094): module_start_up Started module “btif_config_module”
07-12 01:33:34.008 I/bt_core_module( 3094): module_start_up Starting module “btsnoop_module”
07-12 01:33:34.008 I/bt_core_module( 3094): module_start_up Started module “btsnoop_module”
07-12 01:33:34.008 I/bt_core_module( 3094): module_start_up Starting module “hci_module”
07-12 01:33:34.008 I/bt_hci ( 3094): start_up
07-12 01:33:34.008 W/bt_osi_thread( 3094): run_thread: thread id 3121, thread name hci_thread started
07-12 01:33:34.010 I/bt_vendor( 3094): alloc value 0x94184295
07-12 01:33:34.010 I/bt_vendor( 3094): init
07-12 01:33:34.011 I/bt_vnd_conf( 3094): Attempt to load conf from /system/etc/bluetooth/bt_vendor.conf
07-12 01:33:34.011 D/bt_vendor( 3094): op for 0
07-12 01:33:34.011 D/bt_upio ( 3094): is_emulator_context : 0
07-12 01:33:34.011 D/bt_upio ( 3094): is_rfkill_disabled ? [0]
07-12 01:33:34.032 D/bt_vendor( 3094): op for 0
07-12 01:33:34.033 D/bt_upio ( 3094): is_emulator_context : 0
07-12 01:33:34.033 D/bt_upio ( 3094): is_rfkill_disabled ? [0]
07-12 01:33:34.184 D/bt_hci ( 3094): start_up starting async portion
07-12 01:33:34.185 I/bt_hci ( 3094): event_finish_startup
07-12 01:33:34.185 I/bt_hci_h4( 3094): hal_open
07-12 01:33:34.185 D/bt_vendor( 3094): op for 3
07-12 01:33:34.186 I/bt_userial_vendor( 3094): userial vendor open: opening /dev/ttyS0
07-12 01:33:34.187 I/bt_userial_vendor( 3094): device fd = 74 open
07-12 01:33:34.189 W/bt_osi_thread( 3094): run_thread: thread id 3122, thread name hci_single_chann started
07-12 01:33:34.190 D/bt_vendor( 3094): op for 1
07-12 01:33:34.200 I/bt_hwcfg( 3094): bt vendor lib: set UART baud 115200
07-12 01:33:34.427 D/bt_hwcfg( 3094): Chipset BCM4335C0
07-12 01:33:34.427 D/bt_hwcfg( 3094): Target name = [BCM4335C0]
07-12 01:33:34.428 D/bt_hwcfg( 3094): ###AMPAK FW Auto detection patch version = [v1.1 20161117]###
07-12 01:33:34.428 D/bt_hwcfg( 3094): Updated Target name = [BCM4339A0]
07-12 01:33:34.429 I/bt_hwcfg( 3094): Found patchfile: /system/etc/firmware//bcm4339a0.hcd
07-12 01:33:40.970 I/bt_hwcfg( 3094): bt vendor lib: set UART baud 115200
07-12 01:33:41.171 D/bt_hwcfg( 3094): Settlement delay – 200 ms
07-12 01:33:41.171 I/bt_hwcfg( 3094): Setting fw settlement delay to 200
07-12 01:33:41.372 E/bt_hci_h4( 3094): event_uart_has_bytes Unknown HCI message type 0x0 (min=0x2 max=0x4). Aborting…
07-12 01:33:41.374 F/libc ( 3094): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:33:41.375 F/libc ( 3094): Fatal signal 6 (SIGABRT), code -6 in tid 3121 (hci_thread)
07-12 01:33:41.377 W/ ( 204): debuggerd: handling request: pid=3094 uid=1002 gid=1002 tid=3121
07-12 01:33:41.483 F/DEBUG ( 3123): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:33:41.484 F/DEBUG ( 3123): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:33:41.484 F/DEBUG ( 3123): Revision: ‘0’
07-12 01:33:41.485 F/DEBUG ( 3123): ABI: ‘arm’
07-12 01:33:41.486 F/DEBUG ( 3123): pid: 3094, tid: 3121, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:33:41.486 F/DEBUG ( 3123): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:33:41.512 F/DEBUG ( 3123): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:33:41.512 F/DEBUG ( 3123): r0 00000000 r1 00000c31 r2 00000006 r3 00000008
07-12 01:33:41.513 F/DEBUG ( 3123): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:33:41.513 F/DEBUG ( 3123): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:33:41.513 F/DEBUG ( 3123): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:33:41.532 F/DEBUG ( 3123):
07-12 01:33:41.532 F/DEBUG ( 3123): backtrace:
07-12 01:33:41.532 F/DEBUG ( 3123): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:33:41.532 F/DEBUG ( 3123): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:33:41.532 F/DEBUG ( 3123): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:33:41.532 F/DEBUG ( 3123): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:33:41.532 F/DEBUG ( 3123): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:33:41.532 F/DEBUG ( 3123): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:33:41.532 F/DEBUG ( 3123): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:33:41.532 F/DEBUG ( 3123): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:33:41.532 F/DEBUG ( 3123): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:33:41.532 F/DEBUG ( 3123): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:33:41.532 F/DEBUG ( 3123): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:33:41.532 F/DEBUG ( 3123): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:33:41.792 E/ ( 3123): debuggerd: failed to kill process 3094: No such process
07-12 01:33:41.794 W/ ( 204): debuggerd: resuming target 3094
07-12 01:33:41.794 I/BootReceiver( 466): Copying /data/tombstones/tombstone_04 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:33:41.820 I/Zygote ( 231): Process 3094 exited due to signal (6)
07-12 01:33:41.821 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:33:41.821 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:33:41.821 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 6 receivers.
07-12 01:33:41.821 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@4aab5fd
07-12 01:33:41.821 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@3ea34fc
07-12 01:33:41.821 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@f19fd5
07-12 01:33:41.822 I/ActivityManager( 466): Process com.android.bluetooth (pid 3094) has died
07-12 01:33:41.822 D/ActivityManager( 466): cleanUpApplicationRecord – 3094
07-12 01:33:41.822 E/BluetoothManagerService( 466): Unable to call onBluetoothServiceDown() on callback #3
07-12 01:33:41.822 E/BluetoothManagerService( 466): android.os.DeadObjectException
07-12 01:33:41.822 E/BluetoothManagerService( 466): at android.os.BinderProxy.transactNative(Native Method)
07-12 01:33:41.822 E/BluetoothManagerService( 466): at android.os.BinderProxy.transact(Binder.java:615)
07-12 01:33:41.822 E/BluetoothManagerService( 466): at android.bluetooth.IBluetoothManagerCallback$Stub$Proxy.onBluetoothServiceDown(IBluetoothManagerCallback.java:105)
07-12 01:33:41.822 E/BluetoothManagerService( 466): at com.android.server.BluetoothManagerService.sendBluetoothServiceDownCallback(BluetoothManagerService.java:1129)
07-12 01:33:41.822 E/BluetoothManagerService( 466): at com.android.server.BluetoothManagerService.-wrap12(BluetoothManagerService.java)
07-12 01:33:41.822 E/BluetoothManagerService( 466): at com.android.server.BluetoothManagerService$BluetoothHandler.handleMessage(BluetoothManagerService.java:1530)
07-12 01:33:41.822 E/BluetoothManagerService( 466): at android.os.Handler.dispatchMessage(Handler.java:102)
07-12 01:33:41.822 E/BluetoothManagerService( 466): at android.os.Looper.loop(Looper.java:154)
07-12 01:33:41.822 E/BluetoothManagerService( 466): at android.os.HandlerThread.run(HandlerThread.java:61)
07-12 01:33:41.822 E/BluetoothManagerService( 466): at com.android.server.ServiceThread.run(ServiceThread.java:46)
07-12 01:33:41.822 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:33:41.822 W/ActivityManager( 466): Service crashed 2 times, stopping: ServiceRecord{2d81392 u0 com.android.bluetooth/.btservice.AdapterService}
07-12 01:33:41.823 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@b67bb78
07-12 01:33:41.823 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@a9e885b
07-12 01:33:41.863 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:33:42.021 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:33:42.037 I/ActivityManager( 466): Start proc 3130:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:33:42.115 E/RTKBT ( 3130): jniRegisterNativeMethods
07-12 01:33:42.132 D/AdapterServiceConfig( 3130): Adding A2dpService
07-12 01:33:42.133 D/AdapterServiceConfig( 3130): Adding HidService
07-12 01:33:42.133 D/AdapterServiceConfig( 3130): Adding PanService
07-12 01:33:42.133 D/AdapterServiceConfig( 3130): Adding GattService
07-12 01:33:42.137 D/WifiHW ( 3130): uevent path:/sys/bus/sdio/devices/./uevent
07-12 01:33:42.137 D/WifiHW ( 3130): uevent path:/sys/bus/sdio/devices/../uevent
07-12 01:33:42.137 D/WifiHW ( 3130): uevent path:/sys/bus/sdio/devices/mmc2:0001:1/uevent
07-12 01:33:42.137 D/WifiHW ( 3130): found device pid:vid : 02d0:4335
07-12 01:33:42.137 D/WifiHW ( 3130): wifi detectd return ret:0
07-12 01:33:42.137 D/WifiHW ( 3130): SDIO WIFI identify sucess
07-12 01:33:42.137 D/WifiHW ( 3130): check_wifi_chip_type_string: AP6335
07-12 01:33:42.137 D/BluetoothServiceJni( 3130): void android::classInitNative(JNIEnv *, jclass), load bluetooth.default.so
07-12 01:33:42.174 D/BluetoothAdapterService( 3130): onCreate()
07-12 01:33:42.176 D/BluetoothAdapterState( 3130): make() - Creating AdapterState
07-12 01:33:42.178 I/bt_btif ( 3130): init
07-12 01:33:42.178 I/BluetoothAdapterState( 3130): Entering OffState
07-12 01:33:42.178 W/bt_osi_thread( 3130): run_thread: thread id 3148, thread name stack_manager started
07-12 01:33:42.179 I/bt_stack_manager( 3130): event_init_stack is initializing the stack
07-12 01:33:42.179 I/bt_core_module( 3130): module_init Initializing module “osi_module”
07-12 01:33:42.179 I/bt_core_module( 3130): module_init Initialized module “osi_module”
07-12 01:33:42.179 I/bt_core_module( 3130): module_init Initializing module “bt_utils_module”
07-12 01:33:42.179 I/bt_core_module( 3130): module_init Initialized module “bt_utils_module”
07-12 01:33:42.179 I/bt_core_module( 3130): module_init Initializing module “btif_config_module”
07-12 01:33:42.180 W/bt_osi_thread( 3130): run_thread: thread id 3151, thread name alarm_default_ca started
07-12 01:33:42.180 W/bt_osi_thread( 3130): run_thread: thread id 3152, thread name alarm_dispatcher started
07-12 01:33:42.180 I/bt_core_module( 3130): module_init Initialized module “btif_config_module”
07-12 01:33:42.181 I/bt_core_module( 3130): module_init Initializing module “interop_module”
07-12 01:33:42.181 I/bt_core_module( 3130): module_init Initialized module “interop_module”
07-12 01:33:42.181 I/bt_core_module( 3130): module_init Initializing module “stack_config_module”
07-12 01:33:42.181 I/bt_stack_config( 3130): init attempt to load stack conf from /etc/bluetooth/bt_stack.conf
07-12 01:33:42.181 I/bt_core_module( 3130): module_init Initialized module “stack_config_module”
07-12 01:33:42.181 E/bt_btif ( 3130): vendor_storage open fail
07-12 01:33:42.181 E/bt_btif ( 3130): btif_fetch_local_bdaddr, local bdaddr is stored in /data/misc/bluetooth/bdaddr
07-12 01:33:42.181 E/bt_btif ( 3130): local bdaddr from bt_config.xml is 22:22:d2:b5:04:c4
07-12 01:33:42.182 W/bt_osi_thread( 3130): run_thread: thread id 3153, thread name bt_jni_workqueue started
07-12 01:33:42.182 I/bt_stack_manager( 3130): event_init_stack finished
07-12 01:33:42.182 I/bt_osi_wakelock( 3130): wakelock_set_os_callouts set to non-native
07-12 01:33:42.182 I/bt_btif ( 3130): get_profile_interface socket
07-12 01:33:42.183 D/BluetoothAdapterProperties( 3130): Address is:22:22:D2:B5:04:C4
07-12 01:33:42.184 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:33:42.185 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:33:42.185 D/BluetoothAdapterProperties( 3130): Name is: rk3288
07-12 01:33:42.197 I/bt_btif ( 3130): get_profile_interface sdp
07-12 01:33:42.202 D/BluetoothAdapterService( 3130): setAdapterService() - set to: null
07-12 01:33:42.205 D/BluetoothAdapterService( 3130): onBind()
07-12 01:33:42.206 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:33:42.207 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:33:42.207 I/bt_btif ( 3130): config_hci_snoop_log
07-12 01:33:42.209 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:33:42.209 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@8367608
07-12 01:33:42.209 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@95223ea
07-12 01:33:42.209 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@dc58785
07-12 01:33:42.210 D/BluetoothAdapter( 3130): onBluetoothServiceUp: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@4533cb2
07-12 01:33:42.210 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@46df8f8
07-12 01:33:42.210 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@d199251
07-12 01:33:42.210 D/BluetoothAdapterService( 3130): enable() - Enable called with quiet mode status = false
07-12 01:33:42.211 D/BluetoothAdapterState( 3130): Current state: OFF, message: 0
07-12 01:33:42.211 D/BluetoothAdapterProperties( 3130): Setting state to 14
07-12 01:33:42.211 I/BluetoothAdapterState( 3130): Bluetooth adapter state changed: 10-> 14
07-12 01:33:42.211 D/BluetoothAdapterService( 3130): updateAdapterState() - Broadcasting state to 1 receivers.
07-12 01:33:42.211 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:33:42.211 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:33:42.211 D/BluetoothAdapterService( 3130): BleOnProcessStart()
07-12 01:33:42.212 D/BluetoothAdapterService( 3130): BleOnProcessStart() - Make Bond State Machine
07-12 01:33:42.212 D/BluetoothBondStateMachine( 3130): make
07-12 01:33:42.213 I/BluetoothBondStateMachine( 3130): StableState(): Entering Off State
07-12 01:33:42.214 D/BluetoothAdapterService( 3130): setProfileServiceState() - Starting service com.android.bluetooth.gatt.GattService
07-12 01:33:42.216 I/BluetoothAdapterState( 3130): Entering PendingCommandState
07-12 01:33:42.217 I/BtGatt.JNI( 3130): classInitNative(L922): classInitNative: Success!
07-12 01:33:42.220 D/BtGatt.DebugUtils( 3130): handleDebugAction() action=null
07-12 01:33:42.220 D/BluetoothAdapterService( 3130): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@7988867
07-12 01:33:42.220 D/BtGatt.GattService( 3130): Received start request. Starting profile…
07-12 01:33:42.220 D/BtGatt.GattService( 3130): start()
07-12 01:33:42.221 I/bt_btif ( 3130): get_profile_interface gatt
07-12 01:33:42.221 D/BluetoothAdapterService( 3130): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@7988867
07-12 01:33:42.221 D/BtGatt.AdvertiseManager( 3130): advertise manager created
07-12 01:33:42.225 D/BluetoothAdapterService( 3130): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@7988867
07-12 01:33:42.225 D/BluetoothAdapterService( 3130): handleMessage() - Message: 1
07-12 01:33:42.226 D/BluetoothAdapterService( 3130): handleMessage() - MESSAGE_PROFILE_SERVICE_STATE_CHANGED
07-12 01:33:42.226 D/BluetoothAdapterService( 3130): processProfileServiceStateChanged() serviceName=com.android.bluetooth.gatt.GattService, state=12, doUpdate=true
07-12 01:33:42.226 V/BluetoothAdapterState( 3130): isTurningOff()=false
07-12 01:33:42.226 V/BluetoothAdapterState( 3130): isTurningOn()=false
07-12 01:33:42.226 V/BluetoothAdapterState( 3130): isBleTurningOn()=true
07-12 01:33:42.226 V/BluetoothAdapterState( 3130): isBleTurningOff()=false
07-12 01:33:42.226 D/BluetoothAdapterService( 3130): processProfileServiceStateChanged() - serviceName=com.android.bluetooth.gatt.GattService isTurningOn=false isTurningOff=false isBleTurningOn=true isBleTurningOff=false
07-12 01:33:42.226 D/BluetoothAdapterService( 3130): GattService is started
07-12 01:33:42.226 D/BluetoothAdapterState( 3130): Current state: PENDING_COMMAND, message: 4
07-12 01:33:42.227 I/bt_btif ( 3130): enable: start restricted = 0
07-12 01:33:42.227 I/bt_stack_manager( 3130): event_start_up_stack is bringing up the stack
07-12 01:33:42.228 I/bt_core_module( 3130): module_start_up Starting module “btif_config_module”
07-12 01:33:42.228 I/bt_core_module( 3130): module_start_up Started module “btif_config_module”
07-12 01:33:42.228 I/bt_core_module( 3130): module_start_up Starting module “btsnoop_module”
07-12 01:33:42.228 I/bt_core_module( 3130): module_start_up Started module “btsnoop_module”
07-12 01:33:42.228 I/bt_core_module( 3130): module_start_up Starting module “hci_module”
07-12 01:33:42.228 I/bt_hci ( 3130): start_up
07-12 01:33:42.229 W/bt_osi_thread( 3130): run_thread: thread id 3157, thread name hci_thread started
07-12 01:33:42.231 I/bt_vendor( 3130): alloc value 0x94189295
07-12 01:33:42.231 I/bt_vendor( 3130): init
07-12 01:33:42.231 I/bt_vnd_conf( 3130): Attempt to load conf from /system/etc/bluetooth/bt_vendor.conf
07-12 01:33:42.231 D/bt_vendor( 3130): op for 0
07-12 01:33:42.232 D/bt_upio ( 3130): is_emulator_context : 0
07-12 01:33:42.232 D/bt_upio ( 3130): is_rfkill_disabled ? [0]
07-12 01:33:42.253 D/bt_vendor( 3130): op for 0
07-12 01:33:42.253 D/bt_upio ( 3130): is_emulator_context : 0
07-12 01:33:42.253 D/bt_upio ( 3130): is_rfkill_disabled ? [0]
07-12 01:33:42.404 D/bt_hci ( 3130): start_up starting async portion
07-12 01:33:42.405 I/bt_hci ( 3130): event_finish_startup
07-12 01:33:42.405 I/bt_hci_h4( 3130): hal_open
07-12 01:33:42.405 D/bt_vendor( 3130): op for 3
07-12 01:33:42.406 I/bt_userial_vendor( 3130): userial vendor open: opening /dev/ttyS0
07-12 01:33:42.407 I/bt_userial_vendor( 3130): device fd = 74 open
07-12 01:33:42.409 W/bt_osi_thread( 3130): run_thread: thread id 3158, thread name hci_single_chann started
07-12 01:33:42.410 D/bt_vendor( 3130): op for 1
07-12 01:33:42.420 I/bt_hwcfg( 3130): bt vendor lib: set UART baud 115200
07-12 01:33:42.647 D/bt_hwcfg( 3130): Chipset BCM4335C0
07-12 01:33:42.647 D/bt_hwcfg( 3130): Target name = [BCM4335C0]
07-12 01:33:42.648 D/bt_hwcfg( 3130): ###AMPAK FW Auto detection patch version = [v1.1 20161117]###
07-12 01:33:42.648 D/bt_hwcfg( 3130): Updated Target name = [BCM4339A0]
07-12 01:33:42.649 I/bt_hwcfg( 3130): Found patchfile: /system/etc/firmware//bcm4339a0.hcd
07-12 01:33:49.190 I/bt_hwcfg( 3130): bt vendor lib: set UART baud 115200
07-12 01:33:49.391 D/bt_hwcfg( 3130): Settlement delay – 200 ms
07-12 01:33:49.391 I/bt_hwcfg( 3130): Setting fw settlement delay to 200
07-12 01:33:49.592 E/bt_hci_h4( 3130): event_uart_has_bytes Unknown HCI message type 0x0 (min=0x2 max=0x4). Aborting…
07-12 01:33:49.594 F/libc ( 3130): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:33:49.595 F/libc ( 3130): Fatal signal 6 (SIGABRT), code -6 in tid 3157 (hci_thread)
07-12 01:33:49.597 W/ ( 204): debuggerd: handling request: pid=3130 uid=1002 gid=1002 tid=3157
07-12 01:33:49.702 F/DEBUG ( 3159): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:33:49.703 F/DEBUG ( 3159): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:33:49.704 F/DEBUG ( 3159): Revision: ‘0’
07-12 01:33:49.704 F/DEBUG ( 3159): ABI: ‘arm’
07-12 01:33:49.705 F/DEBUG ( 3159): pid: 3130, tid: 3157, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:33:49.706 F/DEBUG ( 3159): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:33:49.731 F/DEBUG ( 3159): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:33:49.731 F/DEBUG ( 3159): r0 00000000 r1 00000c55 r2 00000006 r3 00000008
07-12 01:33:49.732 F/DEBUG ( 3159): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:33:49.732 F/DEBUG ( 3159): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:33:49.733 F/DEBUG ( 3159): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:33:49.749 F/DEBUG ( 3159):
07-12 01:33:49.749 F/DEBUG ( 3159): backtrace:
07-12 01:33:49.749 F/DEBUG ( 3159): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:33:49.749 F/DEBUG ( 3159): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:33:49.749 F/DEBUG ( 3159): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:33:49.749 F/DEBUG ( 3159): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:33:49.749 F/DEBUG ( 3159): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:33:49.749 F/DEBUG ( 3159): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:33:49.749 F/DEBUG ( 3159): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:33:49.749 F/DEBUG ( 3159): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:33:49.749 F/DEBUG ( 3159): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:33:49.749 F/DEBUG ( 3159): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:33:49.749 F/DEBUG ( 3159): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:33:49.749 F/DEBUG ( 3159): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:33:50.003 E/ ( 3159): debuggerd: failed to kill process 3130: No such process
07-12 01:33:50.004 W/ ( 204): debuggerd: resuming target 3130
07-12 01:33:50.004 I/BootReceiver( 466): Copying /data/tombstones/tombstone_05 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:33:50.033 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:33:50.033 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:33:50.033 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:33:50.033 I/ActivityManager( 466): Process com.android.bluetooth (pid 3130) has died
07-12 01:33:50.033 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@8367608
07-12 01:33:50.033 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@95223ea
07-12 01:33:50.034 D/ActivityManager( 466): cleanUpApplicationRecord – 3130
07-12 01:33:50.034 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@dc58785
07-12 01:33:50.034 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.btservice.AdapterService in 1000ms
07-12 01:33:50.034 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 11000ms
07-12 01:33:50.034 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@d199251
07-12 01:33:50.034 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@46df8f8
07-12 01:33:50.035 I/Zygote ( 231): Process 3130 exited due to signal (6)
07-12 01:33:50.060 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:33:50.234 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:33:50.255 I/ActivityManager( 466): Start proc 3166:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:33:50.376 E/RTKBT ( 3166): jniRegisterNativeMethods
07-12 01:33:50.394 D/AdapterServiceConfig( 3166): Adding A2dpService
07-12 01:33:50.395 D/AdapterServiceConfig( 3166): Adding HidService
07-12 01:33:50.395 D/AdapterServiceConfig( 3166): Adding PanService
07-12 01:33:50.395 D/AdapterServiceConfig( 3166): Adding GattService
07-12 01:33:50.399 D/WifiHW ( 3166): uevent path:/sys/bus/sdio/devices/./uevent
07-12 01:33:50.399 D/WifiHW ( 3166): uevent path:/sys/bus/sdio/devices/../uevent
07-12 01:33:50.399 D/WifiHW ( 3166): uevent path:/sys/bus/sdio/devices/mmc2:0001:1/uevent
07-12 01:33:50.400 D/WifiHW ( 3166): found device pid:vid : 02d0:4335
07-12 01:33:50.400 D/WifiHW ( 3166): wifi detectd return ret:0
07-12 01:33:50.400 D/WifiHW ( 3166): SDIO WIFI identify sucess
07-12 01:33:50.400 D/WifiHW ( 3166): check_wifi_chip_type_string: AP6335
07-12 01:33:50.400 D/BluetoothServiceJni( 3166): void android::classInitNative(JNIEnv *, jclass), load bluetooth.default.so
07-12 01:33:50.441 D/BluetoothAdapterService( 3166): onCreate()
07-12 01:33:50.443 D/BluetoothAdapterState( 3166): make() - Creating AdapterState
07-12 01:33:50.445 I/bt_btif ( 3166): init
07-12 01:33:50.445 I/BluetoothAdapterState( 3166): Entering OffState
07-12 01:33:50.445 W/bt_osi_thread( 3166): run_thread: thread id 3184, thread name stack_manager started
07-12 01:33:50.445 I/bt_stack_manager( 3166): event_init_stack is initializing the stack
07-12 01:33:50.446 I/bt_core_module( 3166): module_init Initializing module “osi_module”
07-12 01:33:50.446 I/bt_core_module( 3166): module_init Initialized module “osi_module”
07-12 01:33:50.446 I/bt_core_module( 3166): module_init Initializing module “bt_utils_module”
07-12 01:33:50.446 I/bt_core_module( 3166): module_init Initialized module “bt_utils_module”
07-12 01:33:50.446 I/bt_core_module( 3166): module_init Initializing module “btif_config_module”
07-12 01:33:50.446 W/bt_osi_thread( 3166): run_thread: thread id 3187, thread name alarm_default_ca started
07-12 01:33:50.447 W/bt_osi_thread( 3166): run_thread: thread id 3188, thread name alarm_dispatcher started
07-12 01:33:50.447 I/bt_core_module( 3166): module_init Initialized module “btif_config_module”
07-12 01:33:50.447 I/bt_core_module( 3166): module_init Initializing module “interop_module”
07-12 01:33:50.447 I/bt_core_module( 3166): module_init Initialized module “interop_module”
07-12 01:33:50.447 I/bt_core_module( 3166): module_init Initializing module “stack_config_module”
07-12 01:33:50.447 I/bt_stack_config( 3166): init attempt to load stack conf from /etc/bluetooth/bt_stack.conf
07-12 01:33:50.448 I/bt_core_module( 3166): module_init Initialized module “stack_config_module”
07-12 01:33:50.448 E/bt_btif ( 3166): vendor_storage open fail
07-12 01:33:50.448 E/bt_btif ( 3166): btif_fetch_local_bdaddr, local bdaddr is stored in /data/misc/bluetooth/bdaddr
07-12 01:33:50.448 E/bt_btif ( 3166): local bdaddr from bt_config.xml is 22:22:d2:b5:04:c4
07-12 01:33:50.448 W/bt_osi_thread( 3166): run_thread: thread id 3189, thread name bt_jni_workqueue started
07-12 01:33:50.448 I/bt_stack_manager( 3166): event_init_stack finished
07-12 01:33:50.448 I/bt_osi_wakelock( 3166): wakelock_set_os_callouts set to non-native
07-12 01:33:50.448 I/bt_btif ( 3166): get_profile_interface socket
07-12 01:33:50.450 D/BluetoothAdapterProperties( 3166): Address is:22:22:D2:B5:04:C4
07-12 01:33:50.451 D/BluetoothAdapterProperties( 3166): Name is: rk3288
07-12 01:33:50.451 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:33:50.451 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:33:50.464 I/bt_btif ( 3166): get_profile_interface sdp
07-12 01:33:50.468 D/BluetoothAdapterService( 3166): setAdapterService() - set to: null
07-12 01:33:50.471 D/BluetoothAdapterService( 3166): onBind()
07-12 01:33:50.472 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:33:50.472 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:33:50.473 I/bt_btif ( 3166): config_hci_snoop_log
07-12 01:33:50.474 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:33:50.474 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@ac4515a
07-12 01:33:50.475 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@fe6c6db
07-12 01:33:50.475 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@24369da
07-12 01:33:50.475 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@c7ec1d1
07-12 01:33:50.475 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@a1e2ab6
07-12 01:33:50.475 D/BluetoothAdapter( 3166): onBluetoothServiceUp: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@4533cb2
07-12 01:33:50.476 D/BluetoothAdapterService( 3166): enable() - Enable called with quiet mode status = false
07-12 01:33:50.476 D/BluetoothAdapterState( 3166): Current state: OFF, message: 0
07-12 01:33:50.476 D/BluetoothAdapterProperties( 3166): Setting state to 14
07-12 01:33:50.476 I/BluetoothAdapterState( 3166): Bluetooth adapter state changed: 10-> 14
07-12 01:33:50.476 D/BluetoothAdapterService( 3166): updateAdapterState() - Broadcasting state to 1 receivers.
07-12 01:33:50.476 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:33:50.477 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:33:50.477 D/BluetoothAdapterService( 3166): BleOnProcessStart()
07-12 01:33:50.477 D/BluetoothAdapterService( 3166): BleOnProcessStart() - Make Bond State Machine
07-12 01:33:50.477 D/BluetoothBondStateMachine( 3166): make
07-12 01:33:50.478 I/BluetoothBondStateMachine( 3166): StableState(): Entering Off State
07-12 01:33:50.479 D/BluetoothAdapterService( 3166): setProfileServiceState() - Starting service com.android.bluetooth.gatt.GattService
07-12 01:33:50.480 I/BluetoothAdapterState( 3166): Entering PendingCommandState
07-12 01:33:50.481 I/BtGatt.JNI( 3166): classInitNative(L922): classInitNative: Success!
07-12 01:33:50.484 D/BtGatt.DebugUtils( 3166): handleDebugAction() action=null
07-12 01:33:50.484 D/BluetoothAdapterService( 3166): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@7988867
07-12 01:33:50.484 D/BtGatt.GattService( 3166): Received start request. Starting profile…
07-12 01:33:50.484 D/BtGatt.GattService( 3166): start()
07-12 01:33:50.484 I/bt_btif ( 3166): get_profile_interface gatt
07-12 01:33:50.485 D/BluetoothAdapterService( 3166): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@7988867
07-12 01:33:50.485 D/BtGatt.AdvertiseManager( 3166): advertise manager created
07-12 01:33:50.488 D/BluetoothAdapterService( 3166): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@7988867
07-12 01:33:50.489 D/BluetoothAdapterService( 3166): handleMessage() - Message: 1
07-12 01:33:50.489 D/BluetoothAdapterService( 3166): handleMessage() - MESSAGE_PROFILE_SERVICE_STATE_CHANGED
07-12 01:33:50.489 D/BluetoothAdapterService( 3166): processProfileServiceStateChanged() serviceName=com.android.bluetooth.gatt.GattService, state=12, doUpdate=true
07-12 01:33:50.489 V/BluetoothAdapterState( 3166): isTurningOff()=false
07-12 01:33:50.489 V/BluetoothAdapterState( 3166): isTurningOn()=false
07-12 01:33:50.489 V/BluetoothAdapterState( 3166): isBleTurningOn()=true
07-12 01:33:50.489 V/BluetoothAdapterState( 3166): isBleTurningOff()=false
07-12 01:33:50.489 D/BluetoothAdapterService( 3166): processProfileServiceStateChanged() - serviceName=com.android.bluetooth.gatt.GattService isTurningOn=false isTurningOff=false isBleTurningOn=true isBleTurningOff=false
07-12 01:33:50.489 D/BluetoothAdapterService( 3166): GattService is started
07-12 01:33:50.489 D/BluetoothAdapterState( 3166): Current state: PENDING_COMMAND, message: 4
07-12 01:33:50.490 I/bt_btif ( 3166): enable: start restricted = 0
07-12 01:33:50.490 I/bt_stack_manager( 3166): event_start_up_stack is bringing up the stack
07-12 01:33:50.490 I/bt_core_module( 3166): module_start_up Starting module “btif_config_module”
07-12 01:33:50.491 I/bt_core_module( 3166): module_start_up Started module “btif_config_module”
07-12 01:33:50.491 I/bt_core_module( 3166): module_start_up Starting module “btsnoop_module”
07-12 01:33:50.491 I/bt_core_module( 3166): module_start_up Started module “btsnoop_module”
07-12 01:33:50.491 I/bt_core_module( 3166): module_start_up Starting module “hci_module”
07-12 01:33:50.491 I/bt_hci ( 3166): start_up
07-12 01:33:50.491 W/bt_osi_thread( 3166): run_thread: thread id 3193, thread name hci_thread started
07-12 01:33:50.494 I/bt_vendor( 3166): alloc value 0x94184295
07-12 01:33:50.494 I/bt_vendor( 3166): init
07-12 01:33:50.494 I/bt_vnd_conf( 3166): Attempt to load conf from /system/etc/bluetooth/bt_vendor.conf
07-12 01:33:50.494 D/bt_vendor( 3166): op for 0
07-12 01:33:50.494 D/bt_upio ( 3166): is_emulator_context : 0
07-12 01:33:50.494 D/bt_upio ( 3166): is_rfkill_disabled ? [0]
07-12 01:33:50.516 D/bt_vendor( 3166): op for 0
07-12 01:33:50.516 D/bt_upio ( 3166): is_emulator_context : 0
07-12 01:33:50.516 D/bt_upio ( 3166): is_rfkill_disabled ? [0]
07-12 01:33:50.668 D/bt_hci ( 3166): start_up starting async portion
07-12 01:33:50.669 I/bt_hci ( 3166): event_finish_startup
07-12 01:33:50.669 I/bt_hci_h4( 3166): hal_open
07-12 01:33:50.670 D/bt_vendor( 3166): op for 3
07-12 01:33:50.670 I/bt_userial_vendor( 3166): userial vendor open: opening /dev/ttyS0
07-12 01:33:50.671 I/bt_userial_vendor( 3166): device fd = 74 open
07-12 01:33:50.673 W/bt_osi_thread( 3166): run_thread: thread id 3194, thread name hci_single_chann started
07-12 01:33:50.674 D/bt_vendor( 3166): op for 1
07-12 01:33:50.685 I/bt_hwcfg( 3166): bt vendor lib: set UART baud 115200
07-12 01:33:50.911 D/bt_hwcfg( 3166): Chipset BCM4335C0
07-12 01:33:50.912 D/bt_hwcfg( 3166): Target name = [BCM4335C0]
07-12 01:33:50.912 D/bt_hwcfg( 3166): ###AMPAK FW Auto detection patch version = [v1.1 20161117]###
07-12 01:33:50.912 D/bt_hwcfg( 3166): Updated Target name = [BCM4339A0]
07-12 01:33:50.914 I/bt_hwcfg( 3166): Found patchfile: /system/etc/firmware//bcm4339a0.hcd
07-12 01:33:57.463 I/bt_hwcfg( 3166): bt vendor lib: set UART baud 115200
07-12 01:33:57.664 D/bt_hwcfg( 3166): Settlement delay – 200 ms
07-12 01:33:57.664 I/bt_hwcfg( 3166): Setting fw settlement delay to 200
07-12 01:33:57.865 E/bt_hci_h4( 3166): event_uart_has_bytes Unknown HCI message type 0x0 (min=0x2 max=0x4). Aborting…
07-12 01:33:57.866 F/libc ( 3166): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:33:57.868 F/libc ( 3166): Fatal signal 6 (SIGABRT), code -6 in tid 3193 (hci_thread)
07-12 01:33:57.870 W/ ( 204): debuggerd: handling request: pid=3166 uid=1002 gid=1002 tid=3193
07-12 01:33:57.988 F/DEBUG ( 3195): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:33:57.988 F/DEBUG ( 3195): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:33:57.989 F/DEBUG ( 3195): Revision: ‘0’
07-12 01:33:57.989 F/DEBUG ( 3195): ABI: ‘arm’
07-12 01:33:57.990 F/DEBUG ( 3195): pid: 3166, tid: 3193, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:33:57.991 F/DEBUG ( 3195): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:33:58.015 F/DEBUG ( 3195): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:33:58.015 F/DEBUG ( 3195): r0 00000000 r1 00000c79 r2 00000006 r3 00000008
07-12 01:33:58.015 F/DEBUG ( 3195): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:33:58.015 F/DEBUG ( 3195): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:33:58.015 F/DEBUG ( 3195): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:33:58.026 F/DEBUG ( 3195):
07-12 01:33:58.026 F/DEBUG ( 3195): backtrace:
07-12 01:33:58.027 F/DEBUG ( 3195): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:33:58.027 F/DEBUG ( 3195): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:33:58.027 F/DEBUG ( 3195): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:33:58.027 F/DEBUG ( 3195): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:33:58.027 F/DEBUG ( 3195): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:33:58.027 F/DEBUG ( 3195): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:33:58.027 F/DEBUG ( 3195): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:33:58.027 F/DEBUG ( 3195): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:33:58.027 F/DEBUG ( 3195): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:33:58.027 F/DEBUG ( 3195): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:33:58.027 F/DEBUG ( 3195): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:33:58.027 F/DEBUG ( 3195): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:33:58.288 E/ ( 3195): debuggerd: failed to kill process 3166: No such process
07-12 01:33:58.289 W/ ( 204): debuggerd: resuming target 3166
07-12 01:33:58.290 I/BootReceiver( 466): Copying /data/tombstones/tombstone_06 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:33:58.307 I/ActivityManager( 466): Process com.android.bluetooth (pid 3166) has died
07-12 01:33:58.307 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:33:58.307 D/ActivityManager( 466): cleanUpApplicationRecord – 3166
07-12 01:33:58.307 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:33:58.307 W/ActivityManager( 466): Service crashed 2 times, stopping: ServiceRecord{9d9e98f u0 com.android.bluetooth/.btservice.AdapterService}
07-12 01:33:58.307 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:33:58.307 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:33:58.308 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@ac4515a
07-12 01:33:58.308 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@fe6c6db
07-12 01:33:58.308 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@24369da
07-12 01:33:58.308 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@a1e2ab6
07-12 01:33:58.308 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@c7ec1d1
07-12 01:33:58.308 I/Zygote ( 231): Process 3166 exited due to signal (6)
07-12 01:33:58.337 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:33:58.508 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:33:58.529 I/ActivityManager( 466): Start proc 3202:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:33:58.649 E/RTKBT ( 3202): jniRegisterNativeMethods
07-12 01:33:58.668 D/AdapterServiceConfig( 3202): Adding A2dpService
07-12 01:33:58.668 D/AdapterServiceConfig( 3202): Adding HidService
07-12 01:33:58.668 D/AdapterServiceConfig( 3202): Adding PanService
07-12 01:33:58.668 D/AdapterServiceConfig( 3202): Adding GattService
07-12 01:33:58.673 D/WifiHW ( 3202): uevent path:/sys/bus/sdio/devices/./uevent
07-12 01:33:58.673 D/WifiHW ( 3202): uevent path:/sys/bus/sdio/devices/../uevent
07-12 01:33:58.673 D/WifiHW ( 3202): uevent path:/sys/bus/sdio/devices/mmc2:0001:1/uevent
07-12 01:33:58.673 D/WifiHW ( 3202): found device pid:vid : 02d0:4335
07-12 01:33:58.673 D/WifiHW ( 3202): wifi detectd return ret:0
07-12 01:33:58.673 D/WifiHW ( 3202): SDIO WIFI identify sucess
07-12 01:33:58.673 D/WifiHW ( 3202): check_wifi_chip_type_string: AP6335
07-12 01:33:58.673 D/BluetoothServiceJni( 3202): void android::classInitNative(JNIEnv *, jclass), load bluetooth.default.so
07-12 01:33:58.713 D/BluetoothAdapterService( 3202): onCreate()
07-12 01:33:58.715 D/BluetoothAdapterState( 3202): make() - Creating AdapterState
07-12 01:33:58.716 I/bt_btif ( 3202): init
07-12 01:33:58.717 I/BluetoothAdapterState( 3202): Entering OffState
07-12 01:33:58.717 W/bt_osi_thread( 3202): run_thread: thread id 3220, thread name stack_manager started
07-12 01:33:58.717 I/bt_stack_manager( 3202): event_init_stack is initializing the stack
07-12 01:33:58.717 I/bt_core_module( 3202): module_init Initializing module “osi_module”
07-12 01:33:58.717 I/bt_core_module( 3202): module_init Initialized module “osi_module”
07-12 01:33:58.717 I/bt_core_module( 3202): module_init Initializing module “bt_utils_module”
07-12 01:33:58.717 I/bt_core_module( 3202): module_init Initialized module “bt_utils_module”
07-12 01:33:58.717 I/bt_core_module( 3202): module_init Initializing module “btif_config_module”
07-12 01:33:58.718 W/bt_osi_thread( 3202): run_thread: thread id 3223, thread name alarm_default_ca started
07-12 01:33:58.718 W/bt_osi_thread( 3202): run_thread: thread id 3224, thread name alarm_dispatcher started
07-12 01:33:58.718 I/bt_core_module( 3202): module_init Initialized module “btif_config_module”
07-12 01:33:58.719 I/bt_core_module( 3202): module_init Initializing module “interop_module”
07-12 01:33:58.719 I/bt_core_module( 3202): module_init Initialized module “interop_module”
07-12 01:33:58.719 I/bt_core_module( 3202): module_init Initializing module “stack_config_module”
07-12 01:33:58.719 I/bt_stack_config( 3202): init attempt to load stack conf from /etc/bluetooth/bt_stack.conf
07-12 01:33:58.719 I/bt_core_module( 3202): module_init Initialized module “stack_config_module”
07-12 01:33:58.719 E/bt_btif ( 3202): vendor_storage open fail
07-12 01:33:58.719 E/bt_btif ( 3202): btif_fetch_local_bdaddr, local bdaddr is stored in /data/misc/bluetooth/bdaddr
07-12 01:33:58.719 E/bt_btif ( 3202): local bdaddr from bt_config.xml is 22:22:d2:b5:04:c4
07-12 01:33:58.719 W/bt_osi_thread( 3202): run_thread: thread id 3225, thread name bt_jni_workqueue started
07-12 01:33:58.719 I/bt_stack_manager( 3202): event_init_stack finished
07-12 01:33:58.720 I/bt_osi_wakelock( 3202): wakelock_set_os_callouts set to non-native
07-12 01:33:58.720 I/bt_btif ( 3202): get_profile_interface socket
07-12 01:33:58.721 D/BluetoothAdapterProperties( 3202): Address is:22:22:D2:B5:04:C4
07-12 01:33:58.722 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:33:58.722 D/BluetoothAdapterProperties( 3202): Name is: rk3288
07-12 01:33:58.722 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:33:58.733 I/bt_btif ( 3202): get_profile_interface sdp
07-12 01:33:58.737 D/BluetoothAdapterService( 3202): setAdapterService() - set to: null
07-12 01:33:58.740 D/BluetoothAdapterService( 3202): onBind()
07-12 01:33:58.740 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:33:58.741 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:33:58.741 I/bt_btif ( 3202): config_hci_snoop_log
07-12 01:33:58.742 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:33:58.743 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@55095b0
07-12 01:33:58.743 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@e3b9578
07-12 01:33:58.743 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@990ae0b
07-12 01:33:58.743 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@e9fd3b7
07-12 01:33:58.743 D/BluetoothAdapter( 3202): onBluetoothServiceUp: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@4533cb2
07-12 01:33:58.743 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@9ac6436
07-12 01:33:58.744 D/BluetoothAdapterService( 3202): enable() - Enable called with quiet mode status = false
07-12 01:33:58.744 D/BluetoothAdapterState( 3202): Current state: OFF, message: 0
07-12 01:33:58.744 D/BluetoothAdapterProperties( 3202): Setting state to 14
07-12 01:33:58.744 I/BluetoothAdapterState( 3202): Bluetooth adapter state changed: 10-> 14
07-12 01:33:58.744 D/BluetoothAdapterService( 3202): updateAdapterState() - Broadcasting state to 1 receivers.
07-12 01:33:58.745 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:33:58.745 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:33:58.745 D/BluetoothAdapterService( 3202): BleOnProcessStart()
07-12 01:33:58.745 D/BluetoothAdapterService( 3202): BleOnProcessStart() - Make Bond State Machine
07-12 01:33:58.745 D/BluetoothBondStateMachine( 3202): make
07-12 01:33:58.746 I/BluetoothBondStateMachine( 3202): StableState(): Entering Off State
07-12 01:33:58.747 D/BluetoothAdapterService( 3202): setProfileServiceState() - Starting service com.android.bluetooth.gatt.GattService
07-12 01:33:58.748 I/BluetoothAdapterState( 3202): Entering PendingCommandState
07-12 01:33:58.749 I/BtGatt.JNI( 3202): classInitNative(L922): classInitNative: Success!
07-12 01:33:58.751 D/BtGatt.DebugUtils( 3202): handleDebugAction() action=null
07-12 01:33:58.751 D/BluetoothAdapterService( 3202): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@7988867
07-12 01:33:58.751 D/BtGatt.GattService( 3202): Received start request. Starting profile…
07-12 01:33:58.751 D/BtGatt.GattService( 3202): start()
07-12 01:33:58.751 I/bt_btif ( 3202): get_profile_interface gatt
07-12 01:33:58.752 D/BluetoothAdapterService( 3202): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@7988867
07-12 01:33:58.752 D/BtGatt.AdvertiseManager( 3202): advertise manager created
07-12 01:33:58.755 D/BluetoothAdapterService( 3202): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@7988867
07-12 01:33:58.755 D/BluetoothAdapterService( 3202): handleMessage() - Message: 1
07-12 01:33:58.755 D/BluetoothAdapterService( 3202): handleMessage() - MESSAGE_PROFILE_SERVICE_STATE_CHANGED
07-12 01:33:58.755 D/BluetoothAdapterService( 3202): processProfileServiceStateChanged() serviceName=com.android.bluetooth.gatt.GattService, state=12, doUpdate=true
07-12 01:33:58.756 V/BluetoothAdapterState( 3202): isTurningOff()=false
07-12 01:33:58.756 V/BluetoothAdapterState( 3202): isTurningOn()=false
07-12 01:33:58.756 V/BluetoothAdapterState( 3202): isBleTurningOn()=true
07-12 01:33:58.756 V/BluetoothAdapterState( 3202): isBleTurningOff()=false
07-12 01:33:58.756 D/BluetoothAdapterService( 3202): processProfileServiceStateChanged() - serviceName=com.android.bluetooth.gatt.GattService isTurningOn=false isTurningOff=false isBleTurningOn=true isBleTurningOff=false
07-12 01:33:58.756 D/BluetoothAdapterService( 3202): GattService is started
07-12 01:33:58.756 D/BluetoothAdapterState( 3202): Current state: PENDING_COMMAND, message: 4
07-12 01:33:58.757 I/bt_btif ( 3202): enable: start restricted = 0
07-12 01:33:58.757 I/bt_stack_manager( 3202): event_start_up_stack is bringing up the stack
07-12 01:33:58.757 I/bt_core_module( 3202): module_start_up Starting module “btif_config_module”
07-12 01:33:58.757 I/bt_core_module( 3202): module_start_up Started module “btif_config_module”
07-12 01:33:58.757 I/bt_core_module( 3202): module_start_up Starting module “btsnoop_module”
07-12 01:33:58.757 I/bt_core_module( 3202): module_start_up Started module “btsnoop_module”
07-12 01:33:58.757 I/bt_core_module( 3202): module_start_up Starting module “hci_module”
07-12 01:33:58.757 I/bt_hci ( 3202): start_up
07-12 01:33:58.758 W/bt_osi_thread( 3202): run_thread: thread id 3229, thread name hci_thread started
07-12 01:33:58.760 I/bt_vendor( 3202): alloc value 0x94189295
07-12 01:33:58.760 I/bt_vendor( 3202): init
07-12 01:33:58.760 I/bt_vnd_conf( 3202): Attempt to load conf from /system/etc/bluetooth/bt_vendor.conf
07-12 01:33:58.760 D/bt_vendor( 3202): op for 0
07-12 01:33:58.760 D/bt_upio ( 3202): is_emulator_context : 0
07-12 01:33:58.760 D/bt_upio ( 3202): is_rfkill_disabled ? [0]
07-12 01:33:58.782 D/bt_vendor( 3202): op for 0
07-12 01:33:58.782 D/bt_upio ( 3202): is_emulator_context : 0
07-12 01:33:58.783 D/bt_upio ( 3202): is_rfkill_disabled ? [0]
07-12 01:33:58.934 D/bt_hci ( 3202): start_up starting async portion
07-12 01:33:58.935 I/bt_hci ( 3202): event_finish_startup
07-12 01:33:58.935 I/bt_hci_h4( 3202): hal_open
07-12 01:33:58.935 D/bt_vendor( 3202): op for 3
07-12 01:33:58.936 I/bt_userial_vendor( 3202): userial vendor open: opening /dev/ttyS0
07-12 01:33:58.937 I/bt_userial_vendor( 3202): device fd = 74 open
07-12 01:33:58.939 W/bt_osi_thread( 3202): run_thread: thread id 3230, thread name hci_single_chann started
07-12 01:33:58.940 D/bt_vendor( 3202): op for 1
07-12 01:33:58.951 I/bt_hwcfg( 3202): bt vendor lib: set UART baud 115200
07-12 01:33:59.178 D/bt_hwcfg( 3202): Chipset BCM4335C0
07-12 01:33:59.178 D/bt_hwcfg( 3202): Target name = [BCM4335C0]
07-12 01:33:59.178 D/bt_hwcfg( 3202): ###AMPAK FW Auto detection patch version = [v1.1 20161117]###
07-12 01:33:59.179 D/bt_hwcfg( 3202): Updated Target name = [BCM4339A0]
07-12 01:33:59.180 I/bt_hwcfg( 3202): Found patchfile: /system/etc/firmware//bcm4339a0.hcd
07-12 01:34:05.724 I/bt_hwcfg( 3202): bt vendor lib: set UART baud 115200
07-12 01:34:05.924 D/bt_hwcfg( 3202): Settlement delay – 200 ms
07-12 01:34:05.925 I/bt_hwcfg( 3202): Setting fw settlement delay to 200
07-12 01:34:06.125 E/bt_hci_h4( 3202): event_uart_has_bytes Unknown HCI message type 0x0 (min=0x2 max=0x4). Aborting…
07-12 01:34:06.127 F/libc ( 3202): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:34:06.128 F/libc ( 3202): Fatal signal 6 (SIGABRT), code -6 in tid 3229 (hci_thread)
07-12 01:34:06.130 W/ ( 204): debuggerd: handling request: pid=3202 uid=1002 gid=1002 tid=3229
07-12 01:34:06.259 F/DEBUG ( 3231): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:34:06.260 F/DEBUG ( 3231): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:34:06.260 F/DEBUG ( 3231): Revision: ‘0’
07-12 01:34:06.260 F/DEBUG ( 3231): ABI: ‘arm’
07-12 01:34:06.260 F/DEBUG ( 3231): pid: 3202, tid: 3229, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:34:06.260 F/DEBUG ( 3231): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:34:06.266 F/DEBUG ( 3231): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:34:06.266 F/DEBUG ( 3231): r0 00000000 r1 00000c9d r2 00000006 r3 00000008
07-12 01:34:06.266 F/DEBUG ( 3231): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:34:06.266 F/DEBUG ( 3231): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:34:06.266 F/DEBUG ( 3231): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:34:06.287 F/DEBUG ( 3231):
07-12 01:34:06.287 F/DEBUG ( 3231): backtrace:
07-12 01:34:06.288 F/DEBUG ( 3231): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:34:06.288 F/DEBUG ( 3231): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:34:06.288 F/DEBUG ( 3231): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:34:06.288 F/DEBUG ( 3231): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:34:06.288 F/DEBUG ( 3231): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:34:06.288 F/DEBUG ( 3231): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:34:06.288 F/DEBUG ( 3231): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:34:06.288 F/DEBUG ( 3231): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:34:06.288 F/DEBUG ( 3231): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:34:06.289 F/DEBUG ( 3231): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:34:06.289 F/DEBUG ( 3231): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:34:06.289 F/DEBUG ( 3231): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:34:06.528 W/ ( 204): debuggerd: resuming target 3202
07-12 01:34:06.528 I/BootReceiver( 466): Copying /data/tombstones/tombstone_07 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:34:06.557 I/Zygote ( 231): Process 3202 exited due to signal (6)
07-12 01:34:06.557 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:34:06.557 I/ActivityManager( 466): Process com.android.bluetooth (pid 3202) has died
07-12 01:34:06.557 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:34:06.557 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:34:06.557 D/ActivityManager( 466): cleanUpApplicationRecord – 3202
07-12 01:34:06.557 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@55095b0
07-12 01:34:06.557 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.btservice.AdapterService in 1000ms
07-12 01:34:06.557 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 11000ms
07-12 01:34:06.558 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@990ae0b
07-12 01:34:06.558 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@e3b9578
07-12 01:34:06.558 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@e9fd3b7
07-12 01:34:06.558 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@9ac6436
07-12 01:34:06.627 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:34:06.758 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:34:06.769 I/ActivityManager( 466): Start proc 3238:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:34:06.822 E/RTKBT ( 3238): jniRegisterNativeMethods
07-12 01:34:06.833 D/AdapterServiceConfig( 3238): Adding A2dpService
07-12 01:34:06.833 D/AdapterServiceConfig( 3238): Adding HidService
07-12 01:34:06.833 D/AdapterServiceConfig( 3238): Adding PanService
07-12 01:34:06.833 D/AdapterServiceConfig( 3238): Adding GattService
07-12 01:34:06.836 D/WifiHW ( 3238): uevent path:/sys/bus/sdio/devices/./uevent
07-12 01:34:06.836 D/WifiHW ( 3238): uevent path:/sys/bus/sdio/devices/../uevent
07-12 01:34:06.836 D/WifiHW ( 3238): uevent path:/sys/bus/sdio/devices/mmc2:0001:1/uevent
07-12 01:34:06.836 D/WifiHW ( 3238): found device pid:vid : 02d0:4335
07-12 01:34:06.836 D/WifiHW ( 3238): wifi detectd return ret:0
07-12 01:34:06.836 D/WifiHW ( 3238): SDIO WIFI identify sucess
07-12 01:34:06.836 D/WifiHW ( 3238): check_wifi_chip_type_string: AP6335
07-12 01:34:06.836 D/BluetoothServiceJni( 3238): void android::classInitNative(JNIEnv *, jclass), load bluetooth.default.so
07-12 01:34:06.857 D/BluetoothAdapterService( 3238): onCreate()
07-12 01:34:06.859 D/BluetoothAdapterState( 3238): make() - Creating AdapterState
07-12 01:34:06.860 I/bt_btif ( 3238): init
07-12 01:34:06.860 I/BluetoothAdapterState( 3238): Entering OffState
07-12 01:34:06.860 W/bt_osi_thread( 3238): run_thread: thread id 3256, thread name stack_manager started
07-12 01:34:06.860 I/bt_stack_manager( 3238): event_init_stack is initializing the stack
07-12 01:34:06.861 I/bt_core_module( 3238): module_init Initializing module “osi_module”
07-12 01:34:06.861 I/bt_core_module( 3238): module_init Initialized module “osi_module”
07-12 01:34:06.861 I/bt_core_module( 3238): module_init Initializing module “bt_utils_module”
07-12 01:34:06.861 I/bt_core_module( 3238): module_init Initialized module “bt_utils_module”
07-12 01:34:06.861 I/bt_core_module( 3238): module_init Initializing module “btif_config_module”
07-12 01:34:06.861 W/bt_osi_thread( 3238): run_thread: thread id 3259, thread name alarm_default_ca started
07-12 01:34:06.861 W/bt_osi_thread( 3238): run_thread: thread id 3260, thread name alarm_dispatcher started
07-12 01:34:06.862 I/bt_core_module( 3238): module_init Initialized module “btif_config_module”
07-12 01:34:06.862 I/bt_core_module( 3238): module_init Initializing module “interop_module”
07-12 01:34:06.862 I/bt_core_module( 3238): module_init Initialized module “interop_module”
07-12 01:34:06.862 I/bt_core_module( 3238): module_init Initializing module “stack_config_module”
07-12 01:34:06.862 I/bt_stack_config( 3238): init attempt to load stack conf from /etc/bluetooth/bt_stack.conf
07-12 01:34:06.862 I/bt_core_module( 3238): module_init Initialized module “stack_config_module”
07-12 01:34:06.862 E/bt_btif ( 3238): vendor_storage open fail
07-12 01:34:06.862 E/bt_btif ( 3238): btif_fetch_local_bdaddr, local bdaddr is stored in /data/misc/bluetooth/bdaddr
07-12 01:34:06.862 E/bt_btif ( 3238): local bdaddr from bt_config.xml is 22:22:d2:b5:04:c4
07-12 01:34:06.862 W/bt_osi_thread( 3238): run_thread: thread id 3261, thread name bt_jni_workqueue started
07-12 01:34:06.862 I/bt_stack_manager( 3238): event_init_stack finished
07-12 01:34:06.863 I/bt_osi_wakelock( 3238): wakelock_set_os_callouts set to non-native
07-12 01:34:06.863 I/bt_btif ( 3238): get_profile_interface socket
07-12 01:34:06.864 D/BluetoothAdapterProperties( 3238): Address is:22:22:D2:B5:04:C4
07-12 01:34:06.865 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:34:06.865 D/BluetoothAdapterProperties( 3238): Name is: rk3288
07-12 01:34:06.866 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:34:06.874 I/bt_btif ( 3238): get_profile_interface sdp
07-12 01:34:06.877 D/BluetoothAdapterService( 3238): setAdapterService() - set to: null
07-12 01:34:06.878 D/BluetoothAdapterService( 3238): onBind()
07-12 01:34:06.879 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:34:06.879 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:34:06.879 I/bt_btif ( 3238): config_hci_snoop_log
07-12 01:34:06.880 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:34:06.880 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@f00c2c2
07-12 01:34:06.881 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@9b96451
07-12 01:34:06.881 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@f23a4e8
07-12 01:34:06.881 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@3191724
07-12 01:34:06.881 D/BluetoothAdapter( 3238): onBluetoothServiceUp: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@4533cb2
07-12 01:34:06.881 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@cb34f37
07-12 01:34:06.881 D/BluetoothAdapterService( 3238): enable() - Enable called with quiet mode status = false
07-12 01:34:06.882 D/BluetoothAdapterState( 3238): Current state: OFF, message: 0
07-12 01:34:06.882 D/BluetoothAdapterProperties( 3238): Setting state to 14
07-12 01:34:06.882 I/BluetoothAdapterState( 3238): Bluetooth adapter state changed: 10-> 14
07-12 01:34:06.882 D/BluetoothAdapterService( 3238): updateAdapterState() - Broadcasting state to 1 receivers.
07-12 01:34:06.882 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:34:06.882 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:34:06.882 D/BluetoothAdapterService( 3238): BleOnProcessStart()
07-12 01:34:06.882 D/BluetoothAdapterService( 3238): BleOnProcessStart() - Make Bond State Machine
07-12 01:34:06.882 D/BluetoothBondStateMachine( 3238): make
07-12 01:34:06.883 I/BluetoothBondStateMachine( 3238): StableState(): Entering Off State
07-12 01:34:06.884 D/BluetoothAdapterService( 3238): setProfileServiceState() - Starting service com.android.bluetooth.gatt.GattService
07-12 01:34:06.885 I/BluetoothAdapterState( 3238): Entering PendingCommandState
07-12 01:34:06.886 I/BtGatt.JNI( 3238): classInitNative(L922): classInitNative: Success!
07-12 01:34:06.887 D/BtGatt.DebugUtils( 3238): handleDebugAction() action=null
07-12 01:34:06.887 D/BluetoothAdapterService( 3238): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@7988867
07-12 01:34:06.888 D/BtGatt.GattService( 3238): Received start request. Starting profile…
07-12 01:34:06.888 D/BtGatt.GattService( 3238): start()
07-12 01:34:06.888 I/bt_btif ( 3238): get_profile_interface gatt
07-12 01:34:06.888 D/BluetoothAdapterService( 3238): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@7988867
07-12 01:34:06.888 D/BtGatt.AdvertiseManager( 3238): advertise manager created
07-12 01:34:06.891 D/BluetoothAdapterService( 3238): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@7988867
07-12 01:34:06.891 D/BluetoothAdapterService( 3238): handleMessage() - Message: 1
07-12 01:34:06.891 D/BluetoothAdapterService( 3238): handleMessage() - MESSAGE_PROFILE_SERVICE_STATE_CHANGED
07-12 01:34:06.891 D/BluetoothAdapterService( 3238): processProfileServiceStateChanged() serviceName=com.android.bluetooth.gatt.GattService, state=12, doUpdate=true
07-12 01:34:06.891 V/BluetoothAdapterState( 3238): isTurningOff()=false
07-12 01:34:06.891 V/BluetoothAdapterState( 3238): isTurningOn()=false
07-12 01:34:06.891 V/BluetoothAdapterState( 3238): isBleTurningOn()=true
07-12 01:34:06.891 V/BluetoothAdapterState( 3238): isBleTurningOff()=false
07-12 01:34:06.891 D/BluetoothAdapterService( 3238): processProfileServiceStateChanged() - serviceName=com.android.bluetooth.gatt.GattService isTurningOn=false isTurningOff=false isBleTurningOn=true isBleTurningOff=false
07-12 01:34:06.891 D/BluetoothAdapterService( 3238): GattService is started
07-12 01:34:06.892 D/BluetoothAdapterState( 3238): Current state: PENDING_COMMAND, message: 4
07-12 01:34:06.892 I/bt_btif ( 3238): enable: start restricted = 0
07-12 01:34:06.892 I/bt_stack_manager( 3238): event_start_up_stack is bringing up the stack
07-12 01:34:06.892 I/bt_core_module( 3238): module_start_up Starting module “btif_config_module”
07-12 01:34:06.892 I/bt_core_module( 3238): module_start_up Started module “btif_config_module”
07-12 01:34:06.892 I/bt_core_module( 3238): module_start_up Starting module “btsnoop_module”
07-12 01:34:06.893 I/bt_core_module( 3238): module_start_up Started module “btsnoop_module”
07-12 01:34:06.893 I/bt_core_module( 3238): module_start_up Starting module “hci_module”
07-12 01:34:06.893 I/bt_hci ( 3238): start_up
07-12 01:34:06.893 W/bt_osi_thread( 3238): run_thread: thread id 3265, thread name hci_thread started
07-12 01:34:06.894 I/bt_vendor( 3238): alloc value 0x940d8295
07-12 01:34:06.894 I/bt_vendor( 3238): init
07-12 01:34:06.894 I/bt_vnd_conf( 3238): Attempt to load conf from /system/etc/bluetooth/bt_vendor.conf
07-12 01:34:06.894 D/bt_vendor( 3238): op for 0
07-12 01:34:06.895 D/bt_upio ( 3238): is_emulator_context : 0
07-12 01:34:06.895 D/bt_upio ( 3238): is_rfkill_disabled ? [0]
07-12 01:34:06.916 D/bt_vendor( 3238): op for 0
07-12 01:34:06.916 D/bt_upio ( 3238): is_emulator_context : 0
07-12 01:34:06.916 D/bt_upio ( 3238): is_rfkill_disabled ? [0]
07-12 01:34:07.067 D/bt_hci ( 3238): start_up starting async portion
07-12 01:34:07.068 I/bt_hci ( 3238): event_finish_startup
07-12 01:34:07.069 I/bt_hci_h4( 3238): hal_open
07-12 01:34:07.069 D/bt_vendor( 3238): op for 3
07-12 01:34:07.069 I/bt_userial_vendor( 3238): userial vendor open: opening /dev/ttyS0
07-12 01:34:07.071 I/bt_userial_vendor( 3238): device fd = 74 open
07-12 01:34:07.072 W/bt_osi_thread( 3238): run_thread: thread id 3266, thread name hci_single_chann started
07-12 01:34:07.073 D/bt_vendor( 3238): op for 1
07-12 01:34:07.084 I/bt_hwcfg( 3238): bt vendor lib: set UART baud 115200
07-12 01:34:07.311 D/bt_hwcfg( 3238): Chipset BCM4335C0
07-12 01:34:07.311 D/bt_hwcfg( 3238): Target name = [BCM4335C0]
07-12 01:34:07.311 D/bt_hwcfg( 3238): ###AMPAK FW Auto detection patch version = [v1.1 20161117]###
07-12 01:34:07.311 D/bt_hwcfg( 3238): Updated Target name = [BCM4339A0]
07-12 01:34:07.313 I/bt_hwcfg( 3238): Found patchfile: /system/etc/firmware//bcm4339a0.hcd
07-12 01:34:13.830 I/bt_hwcfg( 3238): bt vendor lib: set UART baud 115200
07-12 01:34:14.031 D/bt_hwcfg( 3238): Settlement delay – 200 ms
07-12 01:34:14.031 I/bt_hwcfg( 3238): Setting fw settlement delay to 200
07-12 01:34:14.232 E/bt_hci_h4( 3238): event_uart_has_bytes Unknown HCI message type 0x0 (min=0x2 max=0x4). Aborting…
07-12 01:34:14.233 F/libc ( 3238): system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed
07-12 01:34:14.236 F/libc ( 3238): Fatal signal 6 (SIGABRT), code -6 in tid 3265 (hci_thread)
07-12 01:34:14.237 W/ ( 204): debuggerd: handling request: pid=3238 uid=1002 gid=1002 tid=3265
07-12 01:34:14.337 F/DEBUG ( 3270): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
07-12 01:34:14.338 F/DEBUG ( 3270): Build fingerprint: ‘Android/rk3288/rk3288:7.1.2/NHG47K/waysio07101146:userdebug/test-keys’
07-12 01:34:14.338 F/DEBUG ( 3270): Revision: ‘0’
07-12 01:34:14.338 F/DEBUG ( 3270): ABI: ‘arm’
07-12 01:34:14.340 F/DEBUG ( 3270): pid: 3238, tid: 3265, name: hci_thread >>> com.android.bluetooth <<<
07-12 01:34:14.340 F/DEBUG ( 3270): signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
07-12 01:34:14.350 F/DEBUG ( 3270): Abort message: ‘system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed’
07-12 01:34:14.350 F/DEBUG ( 3270): r0 00000000 r1 00000cc1 r2 00000006 r3 00000008
07-12 01:34:14.350 F/DEBUG ( 3270): r4 93470978 r5 00000006 r6 93470920 r7 0000010c
07-12 01:34:14.350 F/DEBUG ( 3270): r8 00000000 r9 934704b0 sl a4abb8f0 fp ada57d54
07-12 01:34:14.350 F/DEBUG ( 3270): ip 00000000 sp 93470410 lr b0162857 pc b01650c0 cpsr 600f0010
07-12 01:34:14.362 F/DEBUG ( 3270):
07-12 01:34:14.362 F/DEBUG ( 3270): backtrace:
07-12 01:34:14.362 F/DEBUG ( 3270): #00 pc 0004a0c0 /system/lib/libc.so (tgkill+12)
07-12 01:34:14.362 F/DEBUG ( 3270): #01 pc 00047853 /system/lib/libc.so (pthread_kill+34)
07-12 01:34:14.362 F/DEBUG ( 3270): #02 pc 0001d8b5 /system/lib/libc.so (raise+10)
07-12 01:34:14.362 F/DEBUG ( 3270): #03 pc 00019401 /system/lib/libc.so (__libc_android_abort+34)
07-12 01:34:14.362 F/DEBUG ( 3270): #04 pc 00017048 /system/lib/libc.so (abort+4)
07-12 01:34:14.362 F/DEBUG ( 3270): #05 pc 0001b8b3 /system/lib/libc.so (__libc_fatal+22)
07-12 01:34:14.362 F/DEBUG ( 3270): #06 pc 000195fb /system/lib/libc.so (__assert2+18)
07-12 01:34:14.362 F/DEBUG ( 3270): #07 pc 0007dc15 /system/lib/hw/bluetooth.default.so
07-12 01:34:14.362 F/DEBUG ( 3270): #08 pc 000e53bb /system/lib/hw/bluetooth.default.so
07-12 01:34:14.362 F/DEBUG ( 3270): #09 pc 000e6183 /system/lib/hw/bluetooth.default.so
07-12 01:34:14.362 F/DEBUG ( 3270): #10 pc 00047323 /system/lib/libc.so (_ZL15__pthread_startPv+22)
07-12 01:34:14.362 F/DEBUG ( 3270): #11 pc 00019e5d /system/lib/libc.so (__start_thread+6)
07-12 01:34:14.602 E/ ( 3270): debuggerd: failed to kill process 3238: No such process
07-12 01:34:14.603 W/ ( 204): debuggerd: resuming target 3238
07-12 01:34:14.604 I/BootReceiver( 466): Copying /data/tombstones/tombstone_08 to DropBox (SYSTEM_TOMBSTONE)
07-12 01:34:14.634 I/ActivityManager( 466): Process com.android.bluetooth (pid 3238) has died
07-12 01:34:14.634 D/ActivityManager( 466): cleanUpApplicationRecord – 3238
07-12 01:34:14.634 W/ActivityManager( 466): Service crashed 2 times, stopping: ServiceRecord{8455a57 u0 com.android.bluetooth/.btservice.AdapterService}
07-12 01:34:14.634 I/Zygote ( 231): Process 3238 exited due to signal (6)
07-12 01:34:14.634 W/ActivityManager( 466): Scheduling restart of crashed service com.android.bluetooth/.gatt.GattService in 1000ms
07-12 01:34:14.635 D/BluetoothManagerService( 466): BluetoothServiceConnection, disconnected: com.android.bluetooth.btservice.AdapterService
07-12 01:34:14.635 E/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_DISCONNECTED(1)
07-12 01:34:14.635 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceDown() to 5 receivers.
07-12 01:34:14.635 D/BluetoothAdapter( 466): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@f00c2c2
07-12 01:34:14.636 D/BluetoothAdapter( 646): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@9b96451
07-12 01:34:14.636 D/BluetoothAdapter( 623): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@3191724
07-12 01:34:14.636 D/BluetoothAdapter( 618): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@f23a4e8
07-12 01:34:14.636 D/BluetoothAdapter( 1006): onBluetoothServiceDown: android.bluetooth.IBluetooth$Stub$Proxy@cb34f37
07-12 01:34:14.646 D/mali_winsys( 466): EGLint new_window_surface(egl_winsys_display *, void *, EGLSurface, EGLConfig, egl_winsys_surface **, egl_color_buffer_format *, EGLBoolean) returns 0x3000
07-12 01:34:14.836 D/BluetoothManagerService( 466): MESSAGE_RESTART_BLUETOOTH_SERVICE
07-12 01:34:14.856 I/ActivityManager( 466): Start proc 3277:com.android.bluetooth/1002 for service com.android.bluetooth/.btservice.AdapterService
07-12 01:34:14.966 E/RTKBT ( 3277): jniRegisterNativeMethods
07-12 01:34:14.984 D/AdapterServiceConfig( 3277): Adding A2dpService
07-12 01:34:14.985 D/AdapterServiceConfig( 3277): Adding HidService
07-12 01:34:14.985 D/AdapterServiceConfig( 3277): Adding PanService
07-12 01:34:14.985 D/AdapterServiceConfig( 3277): Adding GattService
07-12 01:34:14.989 D/WifiHW ( 3277): uevent path:/sys/bus/sdio/devices/./uevent
07-12 01:34:14.990 D/WifiHW ( 3277): uevent path:/sys/bus/sdio/devices/../uevent
07-12 01:34:14.990 D/WifiHW ( 3277): uevent path:/sys/bus/sdio/devices/mmc2:0001:1/uevent
07-12 01:34:14.990 D/WifiHW ( 3277): found device pid:vid : 02d0:4335
07-12 01:34:14.990 D/WifiHW ( 3277): wifi detectd return ret:0
07-12 01:34:14.990 D/WifiHW ( 3277): SDIO WIFI identify sucess
07-12 01:34:14.990 D/WifiHW ( 3277): check_wifi_chip_type_string: AP6335
07-12 01:34:14.990 D/BluetoothServiceJni( 3277): void android::classInitNative(JNIEnv *, jclass), load bluetooth.default.so
07-12 01:34:15.033 D/BluetoothAdapterService( 3277): onCreate()
07-12 01:34:15.035 D/BluetoothAdapterState( 3277): make() - Creating AdapterState
07-12 01:34:15.037 I/bt_btif ( 3277): init
07-12 01:34:15.037 I/BluetoothAdapterState( 3277): Entering OffState
07-12 01:34:15.038 W/bt_osi_thread( 3277): run_thread: thread id 3295, thread name stack_manager started
07-12 01:34:15.038 I/bt_stack_manager( 3277): event_init_stack is initializing the stack
07-12 01:34:15.038 I/bt_core_module( 3277): module_init Initializing module “osi_module”
07-12 01:34:15.038 I/bt_core_module( 3277): module_init Initialized module “osi_module”
07-12 01:34:15.038 I/bt_core_module( 3277): module_init Initializing module “bt_utils_module”
07-12 01:34:15.038 I/bt_core_module( 3277): module_init Initialized module “bt_utils_module”
07-12 01:34:15.039 I/bt_core_module( 3277): module_init Initializing module “btif_config_module”
07-12 01:34:15.039 W/bt_osi_thread( 3277): run_thread: thread id 3298, thread name alarm_default_ca started
07-12 01:34:15.040 W/bt_osi_thread( 3277): run_thread: thread id 3299, thread name alarm_dispatcher started
07-12 01:34:15.040 I/bt_core_module( 3277): module_init Initialized module “btif_config_module”
07-12 01:34:15.040 I/bt_core_module( 3277): module_init Initializing module “interop_module”
07-12 01:34:15.040 I/bt_core_module( 3277): module_init Initialized module “interop_module”
07-12 01:34:15.041 I/bt_core_module( 3277): module_init Initializing module “stack_config_module”
07-12 01:34:15.041 I/bt_stack_config( 3277): init attempt to load stack conf from /etc/bluetooth/bt_stack.conf
07-12 01:34:15.041 I/bt_core_module( 3277): module_init Initialized module “stack_config_module”
07-12 01:34:15.041 E/bt_btif ( 3277): vendor_storage open fail
07-12 01:34:15.041 E/bt_btif ( 3277): btif_fetch_local_bdaddr, local bdaddr is stored in /data/misc/bluetooth/bdaddr
07-12 01:34:15.041 E/bt_btif ( 3277): local bdaddr from bt_config.xml is 22:22:d2:b5:04:c4
07-12 01:34:15.042 W/bt_osi_thread( 3277): run_thread: thread id 3300, thread name bt_jni_workqueue started
07-12 01:34:15.042 I/bt_stack_manager( 3277): event_init_stack finished
07-12 01:34:15.042 I/bt_osi_wakelock( 3277): wakelock_set_os_callouts set to non-native
07-12 01:34:15.042 I/bt_btif ( 3277): get_profile_interface socket
07-12 01:34:15.043 D/BluetoothAdapterProperties( 3277): Address is:22:22:D2:B5:04:C4
07-12 01:34:15.045 D/BluetoothManagerService( 466): Bluetooth Adapter name changed to rk3288
07-12 01:34:15.045 D/BluetoothManagerService( 466): Stored Bluetooth name: rk3288
07-12 01:34:15.045 D/BluetoothAdapterProperties( 3277): Name is: rk3288
07-12 01:34:15.057 I/bt_btif ( 3277): get_profile_interface sdp
07-12 01:34:15.060 D/BluetoothAdapterService( 3277): setAdapterService() - set to: null
07-12 01:34:15.062 D/BluetoothAdapterService( 3277): onBind()
07-12 01:34:15.063 D/BluetoothManagerService( 466): BluetoothServiceConnection: com.android.bluetooth.btservice.AdapterService
07-12 01:34:15.063 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_SERVICE_CONNECTED: 1
07-12 01:34:15.064 I/bt_btif ( 3277): config_hci_snoop_log
07-12 01:34:15.065 D/BluetoothManagerService( 466): Broadcasting onBluetoothServiceUp() to 6 receivers.
07-12 01:34:15.065 D/BluetoothAdapter( 466): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@7a0ca22
07-12 01:34:15.065 D/BluetoothAdapter( 646): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@82694b6
07-12 01:34:15.065 D/BluetoothAdapter( 618): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@1dc1701
07-12 01:34:15.065 D/BluetoothAdapter( 1006): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@605aca4
07-12 01:34:15.065 D/BluetoothAdapter( 3277): onBluetoothServiceUp: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@4533cb2
07-12 01:34:15.065 D/BluetoothAdapter( 623): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@94028d
07-12 01:34:15.066 D/BluetoothAdapterService( 3277): enable() - Enable called with quiet mode status = false
07-12 01:34:15.066 D/BluetoothAdapterState( 3277): Current state: OFF, message: 0
07-12 01:34:15.066 D/BluetoothAdapterProperties( 3277): Setting state to 14
07-12 01:34:15.066 I/BluetoothAdapterState( 3277): Bluetooth adapter state changed: 10-> 14
07-12 01:34:15.067 D/BluetoothAdapterService( 3277): updateAdapterState() - Broadcasting state to 1 receivers.
07-12 01:34:15.067 D/BluetoothManagerService( 466): MESSAGE_BLUETOOTH_STATE_CHANGE: OFF > BLE_TURNING_ON
07-12 01:34:15.067 D/BluetoothManagerService( 466): Sending BLE State Change: OFF > BLE_TURNING_ON
07-12 01:34:15.067 D/BluetoothAdapterService( 3277): BleOnProcessStart()
07-12 01:34:15.067 D/BluetoothAdapterService( 3277): BleOnProcessStart() - Make Bond State Machine
07-12 01:34:15.068 D/BluetoothBondStateMachine( 3277): make
07-12 01:34:15.069 I/BluetoothBondStateMachine( 3277): StableState(): Entering Off State
07-12 01:34:15.069 D/BluetoothAdapterService( 3277): setProfileServiceState() - Starting service com.android.bluetooth.gatt.GattService
07-12 01:34:15.071 I/BluetoothAdapterState( 3277): Entering PendingCommandState
07-12 01:34:15.072 I/BtGatt.JNI( 3277): classInitNative(L922): classInitNative: Success!
07-12 01:34:15.074 D/BtGatt.DebugUtils( 3277): handleDebugAction() action=null
07-12 01:34:15.074 D/BluetoothAdapterService( 3277): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@7988867
07-12 01:34:15.075 D/BtGatt.GattService( 3277): Received start request. Starting profile…
07-12 01:34:15.075 D/BtGatt.GattService( 3277): start()
07-12 01:34:15.075 I/bt_btif ( 3277): get_profile_interface gatt
07-12 01:34:15.075 D/BluetoothAdapterService( 3277): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@7988867
07-12 01:34:15.076 D/BtGatt.AdvertiseManager( 3277): advertise manager created
07-12 01:34:15.079 D/BluetoothAdapterService( 3277): getAdapterService() - returning com.android.bluetooth.btservice.AdapterService@7988867
07-12 01:34:15.079 D/BluetoothAdapterService( 3277): handleMessage() - Message: 1
07-12 01:34:15.079 D/BluetoothAdapterService( 3277): handleMessage() - MESSAGE_PROFILE_SERVICE_STATE_CHANGED
07-12 01:34:15.079 D/BluetoothAdapterService( 3277): processProfileServiceStateChanged() serviceName=com.android.bluetooth.gatt.GattService, state=12, doUpdate=true
07-12 01:34:15.079 V/BluetoothAdapterState( 3277): isTurningOff()=false
07-12 01:34:15.079 V/BluetoothAdapterState( 3277): isTurningOn()=false
07-12 01:34:15.079 V/BluetoothAdapterState( 3277): isBleTurningOn()=true
07-12 01:34:15.079 V/BluetoothAdapterState( 3277): isBleTurningOff()=false
07-12 01:34:15.079 D/BluetoothAdapterService( 3277): processProfileServiceStateChanged() - serviceName=com.android.bluetooth.gatt.GattService isTurningOn=false isTurningOff=false isBleTurningOn=true isBleTurningOff=false
07-12 01:34:15.080 D/BluetoothAdapterService( 3277): GattService is started
07-12 01:34:15.080 D/BluetoothAdapterState( 3277): Current state: PENDING_COMMAND, message: 4
07-12 01:34:15.081 I/bt_btif ( 3277): enable: start restricted = 0
07-12 01:34:15.081 I/bt_stack_manager( 3277): event_start_up_stack is bringing up the stack
07-12 01:34:15.081 I/bt_core_module( 3277): module_start_up Starting module “btif_config_module”
07-12 01:34:15.081 I/bt_core_module( 3277): module_start_up Started module “btif_config_module”
07-12 01:34:15.081 I/bt_core_module( 3277): module_start_up Starting module “btsnoop_module”
07-12 01:34:15.081 I/bt_core_module( 3277): module_start_up Started module “btsnoop_module”
07-12 01:34:15.081 I/bt_core_module( 3277): module_start_up Starting module “hci_module”
07-12 01:34:15.081 I/bt_hci ( 3277): start_up
07-12 01:34:15.082 W/bt_osi_thread( 3277): run_thread: thread id 3304, thread name hci_thread started
07-12 01:34:15.084 I/bt_vendor( 3277): alloc value 0x94189295
07-12 01:34:15.084 I/bt_vendor( 3277): init
07-12 01:34:15.084 I/bt_vnd_conf( 3277): Attempt to load conf from /system/etc/bluetooth/bt_vendor.conf
07-12 01:34:15.084 D/bt_vendor( 3277): op for 0
07-12 01:34:15.084 D/bt_upio ( 3277): is_emulator_context : 0
07-12 01:34:15.084 D/bt_upio ( 3277): is_rfkill_disabled ? [0]
07-12 01:34:15.106 D/bt_vendor( 3277): op for 0
07-12 01:34:15.106 D/bt_upio ( 3277): is_emulator_context : 0
07-12 01:34:15.106 D/bt_upio ( 3277): is_rfkill_disabled ? [0]
07-12 01:34:15.259 D/bt_hci ( 3277): start_up starting async portion
07-12 01:34:15.259 I/bt_hci ( 3277): event_finish_startup
07-12 01:34:15.260 I/bt_hci_h4( 3277): hal_open
07-12 01:34:15.260 D/bt_vendor( 3277): op for 3
07-12 01:34:15.260 I/bt_userial_vendor( 3277): userial vendor open: opening /dev/ttyS0
07-12 01:34:15.261 I/bt_userial_vendor( 3277): device fd = 74 open
07-12 01:34:15.263 W/bt_osi_thread( 3277): run_thread: thread id 3305, thread name hci_single_chann started
07-12 01:34:15.264 D/bt_vendor( 3277): op for 1
07-12 01:34:15.275 I/bt_hwcfg( 3277): bt vendor lib: set UART baud 115200
07-12 01:34:15.502 D/bt_hwcfg( 3277): Chipset BCM4335C0
07-12 01:34:15.502 D/bt_hwcfg( 3277): Target name = [BCM4335C0]
07-12 01:34:15.503 D/bt_hwcfg( 3277): ###AMPAK FW Auto detection patch version = [v1.1 20161117]###
07-12 01:34:15.503 D/bt_hwcfg( 3277): Updated Target name = [BCM4339A0]
07-12 01:34:15.504 I/bt_hwcfg( 3277): Found patchfile: /system/etc/firmware//bcm4339a0.hcd
加载固件什么的好像也都没问题
1740755014 发表于 2019-7-12 11:20
加载固件什么的好像也都没问题
system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion “false && “Unknown HCI message type”” failed 看看硬件uart到那些配对了没有,或者是否被复用了
jpchen 发表于 2019-7-12 17:12
system/bt/hci/src/hci_hal_h4.c:241: event_uart_has_bytes: assertion "false && "Unknown HCI message …
硬件引脚没问题,IO状态也确认过了,都OK的,硬件上也是没问题,用5.1的系统能正常打开
不是说RK3288不支持7.1的系统吗?请问你这个是自己适配的吗?
rk官方有支持7.1
这个问题有解决吗?
