1.”Rockusb Device”无法识别是电脑驱动问题,还是板子问题?
2.此时能不能强行进入maskrom模式?
板子无限重启,打印如下:
DDR Version 1.19 20190305
Channel 0: DDR3, 800MHz
Channel 1: DDR3, 800MHz
256B stride
pmugrf_os_reg[2] = 0x3AA17AA1, stride = 0xD
Boot1: 2019-03-14, version: 1.19
CPUId = 0x0
ChipType = 0x10, 231
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=119276MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 67347
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
atags_set_bootdev: ret:(0)
GPT part: 2, name: boot, start:0xa000, size:0x10000
GPT part: 3, name: backup, start:0x2a000, size:0x10000
GPT part: 4, name: rootfs, start:0x5a000, size:0xe89bfdf
find part:uboot OK. first_lba:0x4000.
find part:trust OK. first_lba:0x6000.
LoadTrust Addr:0x6000
No find bl30.bin
Load uboot, ReadLba = 4000
Load OK, addr=0x200000, size=0xd6fac
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):370ab80
NOTICE: BL31: Built : 09:23:41, Mar 4 2019
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1181): pd status 3e
INFO: BL31: Initializing BL32
INFO: SPSR = 0x3c9
U-Boot 2017.09-02577-g0b1f585 (Apr 03 2019 - 10:12:37 +0800)
Model: Firefly-RK3399 Board
PreSerial: 2
DRAM: 3.8 GiB
Relocation Offset is: f5bee000
Sysmem: init
Bootdev(atags): mmc 0
PartType: EFI
get part misc fail -1
boot mode: None
bad resource image magic:
DTB: rk-kernel.dtb
invalid entry tag
invalid entry tag
invalid entry tag
invalid entry tag
invalid entry tag
invalid entry tag
invalid entry tag
invalid entry tag
"Synchronous Abort" handler, esr 0x96000010
* Relocate offset = 00000000f5bee000
* ELR(PC) = 000000000028407c
* LR = 0000000000203a8c
* SP = 00000000e9de2020
* ESR_EL2 = 0000000096000010
EC[31:26] == 100101, Exception from a Data abort, from current exception level
IL[25] == 1, 32-bit instruction trapped
* DAIF = 00000000000003c0
D[9] == 1, DBG masked
A[8] == 1, ABORT masked
I[7] == 1, IRQ masked
F[6] == 1, FIQ masked
* SPSR_EL2 = 0000000020000349
I[7] == 0, IRQ not masked
M[4] == 0, Exception taken from AArch64
M[3:0] == 1001, EL2h
* SCTLR_EL2 = 0000000030c51835
I[12] == 1, Icaches enabled
C[2] == 1, Dcache enabled
M[0] == 1, MMU enabled
* HCR_EL2 = 000000000800003a
* VBAR_EL2 = 00000000f5dee800
* TTBR0_EL2 = 00000000f7ff0000
x0 : 000000000841e600 x1 : 00000000f5e8fb8e
x2 : 0000000000000004 x3 : 00000000ff1a0000
x4 : 0000000000000000 x5 : 0000000000000004
x6 : 000000000841e600 x7 : 00000000f5ea7f40
x8 : 00000000e9de20c0 x9 : 0000000000000008
x10: 00000000ffffffd8 x11: 0000000000000006
x12: 000000000001869f x13: 0000000000000200
x14: 00000000e9de2418 x15: 0000000000000002
x16: 0000000000000000 x17: 0000000000000000
x18: 00000000e9de5d98 x19: 00000000f5ea5000
x20: 0000000008300000 x21: 000000000841e600
x22: 0000000000000000 x23: 000000000001f600
x24: 0000000008300000 x25: 00000000f5ec2000
x26: 0000000000000000 x27: 0000000000000000
x28: 0000000000000000 x29: 00000000e9de2200
SP:
e9de2020: 00000000 00000000 00000000 00000000
e9de2030: 00000000 00000000 f5e9be9f 00000000
e9de2040: 00000000 00000000 00000000 00000000
e9de2050: f5e9bee6 00000000 f5e9bf0c 00000000
e9de2060: f5e9bf59 00000000 f5e9bfa6 00000000
e9de2070: f5e9bfe6 00000000 f5e9c026 00000000
e9de2080: f5e9c063 00000000 00000000 00000000
e9de2090: 00000000 00000000 f5e9c0a0 00000000
e9de20a0: e9de2200 00000000 f5deea0c 00000000
e9de20b0: f5ea5000 00000000 08300000 00000000
e9de20c0: f7ff0000 00000000 0800003a 00000000
e9de20d0: 30c51835 00000000 e9de2020 00000000
e9de20e0: 20000349 00000000 f5dee800 00000000
e9de20f0: 000003c0 00000000 96000010 00000000
e9de2100: f5e7207c 00000000 0841e600 00000000
e9de2110: f5e8fb8e 00000000 00000004 00000000
Resetting CPU ...
WAR▒DDR Version 1.19 20190305
soft reset
SRX
256B stride
CPUId = 0x0
ChipType = 0x10, 293
SdmmcInit=2 0
BootCapSize=100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 67846
SecureMode = 0
No find bl30.bin
RunBL31 0x10000
INFO: SPSR = 0x3c9
PreSerial: 2
DRAM: 3.8 GiB
Sysmem: init
PartType: EFI
boot mode: normal
DTB: rk-kernel.dtb
invalid entry tag
invalid entry tag
invalid entry tag
invalid entry tag
invalid entry tag
invalid entry tag
invalid entry tag
invalid entry tag
SP:
Resetting CPU ...
soft reset
SRX
256B stride
CPUId = 0x0
ChipType = 0x10, 292
SdmmcInit=2 0
BootCapSize=100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 67906
SecureMode = 0
No find bl30.bin
RunBL31 0x10000
INFO: SPSR = 0x3c9
PreSerial: 2
DRAM: 3.8 GiB
Sysmem: init
PartType: EFI
boot mode: normal
DTB: rk-kernel.dtb
invalid entry tag
invalid entry tag
invalid entry tag
invalid entry tag
invalid entry tag
invalid entry tag
invalid entry tag
invalid entry tag
SP:
Resetting CPU ...
soft reset
SRX
256B stride
CPUId = 0x0
SdmmcInit=2 0
BootCapSize=100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 67988
SecureMode = 0
No find bl30.bin
RunBL31 0x10000
INFO: SPSR = 0x3c9
PreSerial: 2
DRAM: 3.8 GiB
S
