Hi 大神们,紧急求救啊,我现在用自己编译的Android 5.1镜像写入后,启动中每次显示"Starting kernel …"就又重启了,检查log感觉好像尝试进入recovery系统了,但是因为烧写的镜像是Firefly-RK3288_Android5.1.1_Public_190708.img
这个文件里面包含了recovery系统吗?
我要如何才能擦除misc分区使其进入正常系统啊,还请帮忙解答下,十分感谢!
以下是我现在反复重启的log:
DDR Version 1.00 20160530
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-10 (Jul 08 2019 - 16:00:15)
CPU: rk3288
cpu version = 0
CPU's clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 400
SdmmcInit = 2 0
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
pmic:act8846
can't find dts node for pwm1
#Boot ver: 2019-07-08#2.30
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
can't find power_ctr node for lcdc0
no fuel gauge found
got recovery cmd from misc.
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x02000000 (0x006ae928)
ramdisk @ 0x05bf0000 (0x002ad1d0)
bootrk: do_bootm_linux...
Loading Device Tree to 05600000, end 0561c4d8 ... OK
Starting kernel ...
Memory OK
Memory OK
CPU: rk3288
cpu version = 0
