购买firefly-rk3399板子,按照以下方式,刷UBUNTU系统失败。
以下所有的系统固件和工具都是从firefly官网提供的百度账号下载的。
之前系统由于某些原因无法启动,因此采用以下步骤,进行了系统更新:
- 进入MaskRom模式,使用Android_tool_2.38擦除Flash;
- 使用Android_tool_2.38下载固件Firefly-RK3399_Android7.1.2_MP_190103,成功,可以正常启动;
- 进入Loader模式,使用Android_tool_2.38擦除Flash;
- 使用Android_tool_2.58下载UBUNTU系统FIREFLY-RK3399-UBUNTU16.04-GPT-20190218-1757,提示下载成功,启动log如下,无法进入系统:
DDR Version 1.19 20190305
Channel 0: DDR3, 800MHz
Channel 1: DDR3, 800MHz
256B stride
Boot1: 2019-03-14, version: 1.19
CPUId = 0x0
ChipType = 0x10, 232
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 66966
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
atags_set_bootdev: ret:(0)
GPT part: 2, name: boot, start:0xa000, size:0x10000
GPT part: 3, name: backup, start:0x2a000, size:0x10000
GPT part: 4, name: rootfs, start:0x5a000, size:0x1cc4fdf
find part:uboot OK. first_lba:0x4000.
find part:trust OK. first_lba:0x6000.
LoadTrust Addr:0x6000
No find bl30.bin
Load uboot, ReadLba = 4000
Load OK, addr=0x200000, size=0xd6fac
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):370ab80
NOTICE: BL31: Built : 09:23:41, Mar 4 2019
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1181): pd status 3e
INFO: BL31: Initializing BL32
INFO: SPSR = 0x3c9
U-Boot 2017.09-02577-g0b1f585 (Apr 03 2019 - 10:12:37 +0800)
Model: Firefly-RK3399 Board
PreSerial: 2
DRAM: 2 GiB
Relocation Offset is: 7dbee000
Sysmem: init
Bootdev(atags): mmc 0
PartType: EFI
get part misc fail -1
boot mode: None
Load FDT from boot part
DTB: rk-kernel.dtb
I2c speed: 400000Hz
PMIC: RK808
vdd_center 900000 uV
vdd_cpu_l 900000 uV
vdd_log 900000 uV
In: serial
Out: serial
Err: serial
Model: Firefly-RK3399 Board (Linux Opensource)
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 24000 KHz, init 24000 KHz, kernel 0N/A)
aplll 816000 KHz
apllb 24000 KHz
dpll 800000 KHz
cpll 24000 KHz
gpll 800000 KHz
npll 600000 KHz
vpll 24000 KHz
aclk_perihp 133333 KHz
hclk_perihp 66666 KHz
pclk_perihp 33333 KHz
aclk_perilp0 266666 KHz
hclk_perilp0 88888 KHz
pclk_perilp0 44444 KHz
hclk_perilp1 100000 KHz
pclk_perilp1 50000 KHz
Net: eth0: ethernet@fe300000
Hit key to stop autoboot(‘CTRL+C’): 2 1 0
android_bootloader_boot_flow Could not find misc partition
Fdt Ramdisk skip relocation
FDT load addr 0x10f00000 size 223 KiB
Booting kernel at 0x00280000 with fdt at 0x8300000…
## Booting Android Image at 0x0027f800 …
Kernel load addr 0x00280000 size 19663 KiB
## Flattened Device Tree blob at 08300000
Booting using the fdt blob at 0x8300000
XIP Kernel Image … OK
Using Device Tree in place at 0000000008300000, end 000000000831afc7
Can’t find file:logo_kernel.bmp
Total: 2737.161 ms
[ 0.000000] Linux version 4.4.167 (daijh@tchip14) (firefly-merged-20190124-neibu: 73be38b49619e07116807739acff5ef7ef7bebec add) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #21 SMP Wed Apr 3 09:30:52 CST 2019
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07fee8000 s46120 r8192 d31704 u86016
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.mode=emmc androidboot.slot_suffix= androidboot.serialno=531d2007b1784b0b rw rootwait earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 console=ttyFIQ0 root=PARTUUID=614e0000-0000 rootfstype=ext4 systemd.gpt_auto=0
[ 0.000000] software IO TLB [mem 0x7fea0000-0x7fee0000] (0MB) mapped at [ffffffc07fea0000-ffffffc07fedffff]
[ 0.000000] Memory: 2005920K/2064384K available (12094K kernel code, 1742K rwdata, 4688K rodata, 1088K init, 767K bss, 58464K reserved, 0K cma-reserved)
[ 0.000000] .init : 0xffffff80090f0000 - 0xffffff8009200000 ( 1088 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008c50000 ( 12096 KB)
[ 0.000000] .rodata : 0xffffff8008c50000 - 0xffffff80090f0000 ( 4736 KB)
[ 0.000000] .data : 0xffffff8009200000 - 0xffffff80093b3808 ( 1743 KB)
[ 0.000000] ITS: allocated 65536 Devices @a280000 (psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x000000000a210000
[ 0.000000] CPU0: using LPI pending table @0x000000000a220000
之后陆续试过其他系统:
Firefly-RK3399_Android8.1.0_HDMI_190213 — 成功
FIREFLY-RK3399-UBUNTU16.04-GPT-20190403-1019 — 失败,log停止位置与上述log相同
FIREFLY-RK3399-UBUNTU18.04-GPT-20190403-1012 — 失败,log停止位置与上述log相同
不知是否有大神指导一下,个人感觉不是硬件问题,因为Android系统启动成功。
是否是我的操作有问题,我的操作基本都是遵循上述步骤。
坐等。。。。。。
