尊敬的瑞芯微的技术大神:
你好!本人用Rk3288,Android5.1原生自带录像机录完像点击关闭,然后就卡住了,除非打断这个摄像机进程。这是捕获的LOG信息,log在这里卡住了
W/ALooperRoster( 166): failed to deliver message. Target handler 37 registered, but object gone.
下面是整个log
下面是整个log
--------- beginning of system
E/DrmService( 169): ----------------running drmservice---------------
I/Vold ( 155): Vold 2.1 (the revenge) firing up
E/Vold ( 155): Volume::Volume mDiskVolumeLabel = USB_DISK0
E/Vold ( 155): Volume::Volume mLabel = internal_sd
D/Vold ( 155): Volume internal_sd state changing -1 (Initializing) → 0 (No-Media)
E/Vold ( 155): label internal_sd addPath /devices/ff0f0000.rksdmmc/mmc_host/mmc
E/Vold ( 155): Volume::Volume mLabel = external_sd
I/Vold ( 155): Error(call No.1) opening /sys/sd-sdio/rescan in the file of Volume.cpp
D/Vold ( 155): Volume external_sd state changing -1 (Initializing) → 0 (No-Media)
E/Vold ( 155): label external_sd addPath /devices/ff0c0000.rksdmmc/mmc_host/mmc
E/Vold ( 155): Volume::Volume mLabel = usb_storage
D/Vold ( 155): Volume usb_storage state changing -1 (Initializing) → 0 (No-Media)
E/Vold ( 155): label usb_storage addPath /devices/ff580000.usb
E/Vold ( 155): Volume::Volume mDiskVolumeLabel = USB_DISK1
E/Vold ( 155): label usb_storage addPath /devices/ff500000.usb
E/Vold ( 155): Volume::Volume mDiskVolumeLabel = USB_DISK2
E/Vold ( 155): label usb_storage addPath /devices/ff540000.usb
E/Vold ( 155): Volume::Volume mDiskVolumeLabel = USB_DISK3
E/Vold ( 155): Volume::Volume mDiskVolumeLabel = USB_DISK4
E/Vold ( 155): Volume::Volume mDiskVolumeLabel = USB_DISK5
E/Vold ( 155): Start Misc devices Manager…
D/Vold ( 155): Vendor path: /sys/bus/usb/devices/1-1/idVendor
D/Vold ( 155): === config_file is: 0000_0000
D/DirectVolume( 155): directvolume DEVPATH = /devices/virtual/block/loop0.
W/Vold ( 155): No volumes handled block event for ‘/devices/virtual/block/loop0’
D/DirectVolume( 155): directvolume DEVPATH = /devices/virtual/block/loop1.
W/Vold ( 155): No volumes handled block event for ‘/devices/virtual/block/loop1’
D/DirectVolume( 155): directvolume DEVPATH = /devices/virtual/block/loop2.
W/Vold ( 155): No volumes handled block event for ‘/devices/virtual/block/loop2’
D/DirectVolume( 155): directvolume DEVPATH = /devices/virtual/block/loop3.
W/Vold ( 155): No volumes handled block event for ‘/devices/virtual/block/loop3’
D/DirectVolume( 155): directvolume DEVPATH = /devices/virtual/block/loop4.
W/Vold ( 155): No volumes handled block event for ‘/devices/virtual/block/loop4’
D/DirectVolume( 155): directvolume DEVPATH = /devices/virtual/block/loop5.
W/Vold ( 155): No volumes handled block event for ‘/devices/virtual/block/loop5’
D/DirectVolume( 155): directvolume DEVPATH = /devices/virtual/block/loop6.
W/Vold ( 155): No volumes handled block event for ‘/devices/virtual/block/loop6’
D/DirectVolume( 155): directvolume DEVPATH = /devices/virtual/block/loop7.
W/Vold ( 155): No volumes handled block event for ‘/devices/virtual/block/loop7’
D/DirectVolume( 155): directvolume DEVPATH = /devices/virtual/block/zram0.
W/Vold ( 155): No volumes handled block event for ‘/devices/virtual/block/zram0’
D/DirectVolume( 155): directvolume DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0.
W/DirectVolume( 155): Deprecated implied prefix pattern detected, please use ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc*’ instead
D/DirectVolume( 155): DEVTYPE = disk.
D/DirectVolume( 155): getLabel = internal_sd,devtype = disk,getDevPath = (null).
D/DirectVolume( 155): ----handleDiskAdded,mDiskNumParts =15,mDiskMajor=179,mDiskMinor=0
D/DirectVolume( 155): Dv::diskIns - waiting for 15 pending partitions
D/Vold ( 155): Volume internal_sd state changing 0 (No-Media) → 2 (Pending)
D/Vold ( 155): Device ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0’ event handled by volume internal_sd
D/DirectVolume( 155): directvolume DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p1.
D/DirectVolume( 155): DEVTYPE = partition.
D/DirectVolume( 155): getLabel = internal_sd,devtype = partition,getDevPath = (null).
D/DirectVolume( 155): —handlePartitionAdded,part_num=1,major=179,minor=1,mDiskMajor=179
D/DirectVolume( 155): Dv:partAdd: part_num = 1, minor = 1
D/DirectVolume( 155): Dv:partAdd: pending 14 disk
D/Vold ( 155): Device ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p1’ event handled by volume internal_sd
D/DirectVolume( 155): directvolume DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p2.
D/DirectVolume( 155): —handlePartitionAdded,part_num=2,major=179,minor=2,mDiskMajor=179
D/DirectVolume( 155): Dv:partAdd: part_num = 2, minor = 2
D/DirectVolume( 155): Dv:partAdd: pending 13 disk
D/Vold ( 155): Device ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p2’ event handled by volume internal_sd
D/DirectVolume( 155): directvolume DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p3.
D/DirectVolume( 155): —handlePartitionAdded,part_num=3,major=179,minor=3,mDiskMajor=179
D/DirectVolume( 155): Dv:partAdd: part_num = 3, minor = 3
D/DirectVolume( 155): Dv:partAdd: pending 12 disk
D/Vold ( 155): Device ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p3’ event handled by volume internal_sd
D/DirectVolume( 155): directvolume DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p4.
D/DirectVolume( 155): —handlePartitionAdded,part_num=4,major=179,minor=4,mDiskMajor=179
D/DirectVolume( 155): Dv:partAdd: part_num = 4, minor = 4
D/DirectVolume( 155): Dv:partAdd: pending 11 disk
D/Vold ( 155): Device ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p4’ event handled by volume internal_sd
D/DirectVolume( 155): directvolume DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p5.
D/DirectVolume( 155): —handlePartitionAdded,part_num=5,major=179,minor=5,mDiskMajor=179
D/DirectVolume( 155): Dv:partAdd: part_num = 5, minor = 5
D/DirectVolume( 155): Dv:partAdd: pending 10 disk
D/Vold ( 155): Device ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p5’ event handled by volume internal_sd
D/DirectVolume( 155): directvolume DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p6.
D/DirectVolume( 155): —handlePartitionAdded,part_num=6,major=179,minor=6,mDiskMajor=179
D/DirectVolume( 155): Dv:partAdd: part_num = 6, minor = 6
D/DirectVolume( 155): Dv:partAdd: pending 9 disk
D/Vold ( 155): Device ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p6’ event handled by volume internal_sd
D/DirectVolume( 155): directvolume DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p7.
D/DirectVolume( 155): —handlePartitionAdded,part_num=7,major=179,minor=7,mDiskMajor=179
D/DirectVolume( 155): Dv:partAdd: part_num = 7, minor = 7
D/DirectVolume( 155): Dv:partAdd: pending 8 disk
D/Vold ( 155): Device ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p7’ event handled by volume internal_sd
D/DirectVolume( 155): directvolume DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p8.
D/DirectVolume( 155): —handlePartitionAdded,part_num=8,major=179,minor=8,mDiskMajor=179
D/DirectVolume( 155): Dv:partAdd: part_num = 8, minor = 8
D/DirectVolume( 155): Dv:partAdd: pending 7 disk
D/Vold ( 155): Device ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p8’ event handled by volume internal_sd
D/DirectVolume( 155): directvolume DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p9.
D/DirectVolume( 155): —handlePartitionAdded,part_num=9,major=179,minor=9,mDiskMajor=179
D/DirectVolume( 155): Dv:partAdd: part_num = 9, minor = 9
D/DirectVolume( 155): Dv:partAdd: pending 6 disk
D/Vold ( 155): Device ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p9’ event handled by volume internal_sd
D/DirectVolume( 155): directvolume DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p10.
D/DirectVolume( 155): —handlePartitionAdded,part_num=10,major=179,minor=10,mDiskMajor=179
D/DirectVolume( 155): Dv:partAdd: part_num = 10, minor = 10
D/DirectVolume( 155): Dv:partAdd: pending 5 disk
D/Vold ( 155): Device ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p10’ event handled by volume internal_sd
D/DirectVolume( 155): directvolume DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p11.
D/DirectVolume( 155): —handlePartitionAdded,part_num=11,major=179,minor=11,mDiskMajor=179
D/DirectVolume( 155): Dv:partAdd: part_num = 11, minor = 11
D/DirectVolume( 155): Dv:partAdd: pending 4 disk
D/Vold ( 155): Device ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p11’ event handled by volume internal_sd
D/DirectVolume( 155): directvolume DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p12.
D/DirectVolume( 155): —handlePartitionAdded,part_num=12,major=179,minor=12,mDiskMajor=179
D/DirectVolume( 155): Dv:partAdd: part_num = 12, minor = 12
D/DirectVolume( 155): Dv:partAdd: pending 3 disk
D/Vold ( 155): Device ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p12’ event handled by volume internal_sd
D/DirectVolume( 155): directvolume DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p13.
D/DirectVolume( 155): —handlePartitionAdded,part_num=13,major=179,minor=13,mDiskMajor=179
D/DirectVolume( 155): Dv:partAdd: part_num = 13, minor = 13
D/DirectVolume( 155): Dv:partAdd: pending 2 disk
D/Vold ( 155): Device ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p13’ event handled by volume internal_sd
D/DirectVolume( 155): directvolume DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p14.
D/DirectVolume( 155): —handlePartitionAdded,part_num=14,major=179,minor=14,mDiskMajor=179
D/DirectVolume( 155): Dv:partAdd: part_num = 14, minor = 14
D/DirectVolume( 155): Dv:partAdd: pending 1 disk
D/Vold ( 155): Device ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p14’ event handled by volume internal_sd
D/DirectVolume( 155): directvolume DEVPATH = /devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p15.
D/DirectVolume( 155): —handlePartitionAdded,part_num=15,major=179,minor=15,mDiskMajor=179
D/DirectVolume( 155): Dv:partAdd: part_num = 15, minor = 15
D/DirectVolume( 155): Dv:partAdd: Got all partitions - ready to rock!
D/Vold ( 155): Volume internal_sd state changing 2 (Pending) → 1 (Idle-Unmounted)
D/Vold ( 155): Device ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p15’ event handled by volume internal_sd
E/DrmService( 169): ----------serianno =GB8ZAB4TRD
E/DrmService( 169): auto generate serialno,serialno = GB8ZAB4TRD
E/DrmService( 169): rknand_sys_storage open fail
E/DrmService( 169): detect keybox disabled
I/InstallerConnection( 453): disconnecting…
I/SystemServer( 453): Entered the Android system server!
I/SystemServiceManager( 453): Starting com.android.server.pm.Installer
I/Installer( 453): Waiting for installd to be ready.
I/InstallerConnection( 453): connecting…
I/SystemServiceManager( 453): Starting com.android.server.am.ActivityManagerService$Lifecycle
I/ActivityManagerService( 453): Memory class: 400
I/ServiceThread( 453): Enabled StrictMode logging for ActivityManagerService looper.
I/AppOps ( 453): No existing app ops /data/system/appops.xml; starting empty
I/IntentFirewall( 453): Read new rules (A:0 B:0 S:0)
I/ServiceThread( 453): Enabled StrictMode logging for android.ui looper.
I/ServiceThread( 453): Enabled StrictMode logging for android.display looper.
D/AppOps ( 453): AppOpsService published
I/SystemServiceManager( 453): Starting com.android.server.display.DisplayManagerService
I/SystemServiceManager( 453): Starting com.android.server.power.PowerManagerService
I/ServiceThread( 453): Enabled StrictMode logging for PowerManagerService looper.
I/SystemServiceManager( 453): Starting phase 100
I/DisplayManagerService( 453): Display device added: DisplayDeviceInfo{“内置屏幕”: uniqueId=“local:0”, 720 x 1280, 59.527 fps, supportedRefreshRates [59.527], density 320, 160.42105 x 160.15764 dpi, appVsyncOff 0, presDeadline 17799099, touch INTERNAL, rotation 0, type BUILT_IN, state UNKNOWN, FLAG_DEFAULT_DISPLAY, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
I/SystemServer( 453): Package Manager
W/SystemConfig( 453): No directory /system/etc/sysconfig, skipping
D/SELinuxMMAC( 453): Using policy file /system/etc/security/mac_permissions.xml
W/PackageParser( 453): No actions in intent filter at /system/priv-app/StressTest/StressTest.apk Binary XML file line #42
W/PackageParser( 453): Unknown element under : android at /system/priv-app/Telecom/Telecom.apk Binary XML file line #232
W/PackageParser( 453): No actions in intent filter at /system/app/Bluetooth/Bluetooth.apk Binary XML file line #209
W/PackageParser( 453): Unknown element under : permission at /system/app/Gallery2/Gallery2.apk Binary XML file line #243
W/PackageParser( 453): Unknown element under : permission at /system/app/Gallery2/Gallery2.apk Binary XML file line #246
W/PackageManager( 453): Package com.android.gallery3d desires unavailable shared library com.google.android.media.effects; ignoring!
I/PackageManager( 453): Adjusting ABI for : android.rk.RockVideoPlayer to armeabi-v7a
I/PackageManager( 453): Adjusting ABI for : com.android.winstart to armeabi-v7a
I/PackageManager( 453): Adjusting ABI for : com.cghs.stresstest to armeabi-v7a
I/PackageManager( 453): Adjusting ABI for : com.android.settings to armeabi-v7a
I/PackageManager( 453): Adjusting ABI for : com.android.server.telecom to armeabi-v7a
I/PackageManager( 453): Adjusting ABI for : com.android.inputdevices to armeabi-v7a
I/PackageManager( 453): Adjusting ABI for : com.android.providers.settings to armeabi-v7a
I/PackageManager( 453): Adjusting ABI for : com.android.location.fused to armeabi-v7a
I/PackageManager( 453): Adjusting ABI for : com.android.keychain to armeabi-v7a
I/PackageManager( 453): Time to scan packages: 1.699 seconds
W/PackageManager( 453): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.providers.calendar
W/PackageManager( 453): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.cl in package com.android.providers.calendar
W/PackageManager( 453): Not granting permission android.permission.GLOBAL_SEARCH to package com.android.quicksearchbox (protectionLevel=18 flags=0x8be45)
W/PackageManager( 453): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.android.winstart
W/PackageManager( 453): Not granting permission android.permission.ACCESS_DOWNLOAD_MANAGER to package com.android.browser (protectionLevel=18 flags=0x9be45)
W/PackageManager( 453): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.browser (protectionLevel=2 flags=0x9be45)
W/PackageManager( 453): Not granting permission android.permission.BIND_WALLPAPER to package com.android.camera2 (protectionLevel=18 flags=0x58bc45)
W/PackageManager( 453): Not granting permission android.permission.BIND_APPWIDGET to package com.android.launcher3 (protectionLevel=18 flags=0x583e45)
W/PackageManager( 453): Unknown permission android.permission.READ_SETTINGS in package com.android.launcher3
W/PackageManager( 453): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.android.launcher3
W/PackageManager( 453): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.android.launcher3
W/PackageManager( 453): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH.mail in package com.android.calendar
W/PackageManager( 453): Not granting permission android.permission.INSTALL_PACKAGES to package com.android.apkinstaller (protectionLevel=18 flags=0x8be45)
W/PackageManager( 453): Not granting permission android.permission.DELETE_PACKAGES to package com.android.apkinstaller (protectionLevel=18 flags=0x8be45)
W/PackageManager( 453): Unknown permission android.Manifest.permission.INJECT_EVENTS in package com.rockchip.devicetest
W/PackageManager( 453): Not granting permission android.permission.WRITE_MEDIA_STORAGE to package com.estrongs.android.pop (protectionLevel=18 flags=0x58be45)
W/PackageManager( 453): Unknown permission android.permission.ACCESS_SUPERUSER in package com.estrongs.android.pop
W/PackageManager( 453): Unknown permission .PERMISSION in package com.estrongs.android.pop
W/PackageManager( 453): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.android.onetimeinitializer
W/PackageManager( 453): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.android.onetimeinitializer
W/PackageManager( 453): Unknown permission android.permission.READ_MEDIA_STORAGE in package com.android.packageinstaller
W/PackageManager( 453): Not granting permission android.permission.DELETE_PACKAGES to package com.svox.pico (protectionLevel=18 flags=0x8be45)
W/PackageManager( 453): Unknown permission com.google.android.gallery3d.permission.PICASA_STORE in package com.android.dreams.phototable
W/PackageManager( 453): Unknown permission com.google.android.googleapps.permission.GOOGLE_AUTH in package com.android.settings
W/PackageManager( 453): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.android.settings
W/PackageManager( 453): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.android.settings
W/PackageManager( 453): Not granting permission android.permission.DEVICE_POWER to package com.android.deskclock (protectionLevel=2 flags=0x48be45)
W/PackageManager( 453): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.android.systemui
W/PackageManager( 453): Unknown permission com.google.android.gallery3d.permission.GALLERY_PROVIDER in package com.android.bluetooth
W/PackageManager( 453): Unknown permission android.permission.MMS_SEND_OUTBOX_MSG in package com.android.bluetooth
W/PackageManager( 453): Unknown permission rockchip.permission.FULL_SCREEN in package android.rk.RockVideoPlayer
W/PackageManager( 453): Unknown permission android.permission.RAISED_THREAD_PRIORITY in package android.rk.RockVideoPlayer
W/PackageManager( 453): Unknown permission android.permission.FULL_SCREEN in package android.rk.RockVideoPlayer
W/PackageManager( 453): Unknown permission archos.permission.FULL_SCREEN in package android.rk.RockVideoPlayer
I/SystemServer( 453): User Service
I/SystemServiceManager( 453): Starting com.android.server.lights.LightsService
I/SystemServiceManager( 453): Starting com.android.server.BatteryService
I/SystemServiceManager( 453): Starting com.android.server.usage.UsageStatsService
I/UsageStatsService( 453): User[0] Rollover scheduled @ 2000-01-02 08:00:00(946771200000)
I/SystemServiceManager( 453): Starting com.android.server.webkit.WebViewUpdateService
I/SystemServer( 453): Reading configuration…
I/SystemServer( 453): Scheduling Policy
I/SystemServiceManager( 453): Starting com.android.server.telecom.TelecomLoaderService
I/SystemServer( 453): Telephony Registry
I/SystemServer( 453): Entropy Mixer
I/EntropyMixer( 453): Writing entropy…
I/SystemServer( 453): Account Manager
I/SystemServer( 453): Start SimStateChange Service
W/ActivityManagerService( 453): Unable to start service Intent { cmp=com.android.contacts/.SimStateChangedService } U=0: not found
I/SystemServer( 453): Content Manager
I/SystemServer( 453): System Content Providers
I/SystemServer( 453): Vibrator Service
I/SystemServer( 453): Consumer IR Service
I/SystemServiceManager( 453): Starting com.android.server.AlarmManagerService
D/AlarmManager( 453): Failed while trying resolve alarm filter file, not exists
I/SystemServer( 453): Init Watchdog
I/SystemServer( 453): Input Manager
I/InputManager( 453): Initializing input manager, mUseDevInputEventForAudioJack=false
I/SystemServer( 453): Window Manager
I/WindowManagerService( 453): No existing display settings /data/system/display_settings.xml; starting empty
I/InputManager( 453): Starting input manager
I/SystemServer( 453): Bluetooth Manager Service
I/SystemServer( 453): Input Method Service
W/InputMethodManagerService( 453): Couldn’t create dir.: /data/system/inputmethod
I/SystemServer( 453): Accessibility Manager
I/ActivityManagerService( 453): Config changes=80009df8 {1.15 multiwindowflag=DISABLE dualscreenflag=DISABLE ?mcc?mnc zh_CN ?layoutDir sw360dp w360dp h640dp 320dpi nrml long port ?uimode ?night -touch -keyb/v/h dpad/v s.2}
D/ActivityManagerService( 453): ---------clean the all task
D/ActivityManagerService( 453): ---------Move Home To Top & CLEAN THE ALL TASK
I/ActivityManagerService( 453): Config changes=508 {1.15 multiwindowflag=DISABLE dualscreenflag=DISABLE ?mcc?mnc zh_CN ?layoutDir sw360dp w360dp h567dp 320dpi nrml port ?uimode ?night finger -keyb/v/h dpad/v s.3}
I/SystemServer( 453): Mount Service
D/MountService( 453): got storage path: /storage/sdcard0 description: SD卡 primary: true removable: true emulated: true mtpReserve: 100 allowMassStorage: false maxFileSize: 0
D/MountService( 453): —getMaxSupportedUsers,we has UMS,ignore emulated storage—
D/MountService( 453): got storage path: /mnt/internal_sd description: NAND FLASH primary: false removable: true emulated: false mtpReserve: 100 allowMassStorage: true maxFileSize: 0
D/MountService( 453): —getMaxSupportedUsers,we has UMS,force NAND FLASH to primary storage—
D/MountService( 453): addVolumeLocked() StorageVolume:
D/MountService( 453): mStorageId=0 mPath=/mnt/internal_sd mDescriptionId=17041224 mPrimary=true
D/MountService( 453): mRemovable=true mEmulated=false mMtpReserveSpace=100
D/MountService( 453): mAllowMassStorage=true mMaxFileSize=0 mOwner=null mUuid=null
D/MountService( 453): mUserLabel=null mState=null
D/MountService( 453): got storage path: /mnt/external_sd description: SD卡 primary: false removable: true emulated: false mtpReserve: 100 allowMassStorage: true maxFileSize: 0
D/MountService( 453): mStorageId=0 mPath=/mnt/external_sd mDescriptionId=17040811 mPrimary=false
D/MountService( 453): got storage path: /mnt/usb_storage/USB_DISK0 description: USB storage 0 primary: false removable: true emulated: false mtpReserve: 100 allowMassStorage: true maxFileSize: 0
D/MountService( 453): mStorageId=0 mPath=/mnt/usb_storage/USB_DISK0 mDescriptionId=17041128
D/MountService( 453): mPrimary=false mRemovable=true mEmulated=false mMtpReserveSpace=100
D/MountService( 453): got storage path: /mnt/usb_storage/USB_DISK1 description: USB storage 1 primary: false removable: true emulated: false mtpReserve: 100 allowMassStorage: true maxFileSize: 0
D/MountService( 453): mStorageId=0 mPath=/mnt/usb_storage/USB_DISK1 mDescriptionId=17041129
D/MountService( 453): got storage path: /mnt/usb_storage/USB_DISK2 description: USB storage 2 primary: false removable: true emulated: false mtpReserve: 100 allowMassStorage: true maxFileSize: 0
D/MountService( 453): mStorageId=0 mPath=/mnt/usb_storage/USB_DISK2 mDescriptionId=17041130
D/MountService( 453): got storage path: /mnt/usb_storage/USB_DISK3 description: USB storage 3 primary: false removable: true emulated: false mtpReserve: 100 allowMassStorage: true maxFileSize: 0
D/MountService( 453): mStorageId=0 mPath=/mnt/usb_storage/USB_DISK3 mDescriptionId=17041131
D/MountService( 453): got storage path: /mnt/usb_storage/USB_DISK4 description: USB storage 4 primary: false removable: true emulated: false mtpReserve: 100 allowMassStorage: true maxFileSize: 0
D/MountService( 453): mStorageId=0 mPath=/mnt/usb_storage/USB_DISK4 mDescriptionId=17041132
D/MountService( 453): got storage path: /mnt/usb_storage/USB_DISK5 description: USB storage 5 primary: false removable: true emulated: false mtpReserve: 100 allowMassStorage: true maxFileSize: 0
D/MountService( 453): mStorageId=0 mPath=/mnt/usb_storage/USB_DISK5 mDescriptionId=17041133
D/VoldCmdListener( 155): volume list broadcast
D/Vold ( 155): listVolumes :internal_sd /mnt/internal_sd 1
D/Vold ( 155): listVolumes :external_sd /mnt/external_sd 0
D/Vold ( 155): listVolumes :usb_storage /mnt/usb_storage/USB_DISK0 0
D/Vold ( 155): listVolumes :usb_storage /mnt/usb_storage/USB_DISK1 0
D/Vold ( 155): listVolumes :usb_storage /mnt/usb_storage/USB_DISK2 0
D/Vold ( 155): listVolumes :usb_storage /mnt/usb_storage/USB_DISK3 0
D/Vold ( 155): listVolumes :usb_storage /mnt/usb_storage/USB_DISK4 0
D/Vold ( 155): listVolumes :usb_storage /mnt/usb_storage/USB_DISK5 0
I/MountService( 453): /mnt/internal_sdUpdating valid state unmounted st 1
D/MountService( 453): volume state changed for /mnt/internal_sd (mounted → unmounted)
I/MountService( 453): /mnt/external_sdUpdating valid state removed st 0
D/MountService( 453): volume state changed for /mnt/external_sd (unmounted → removed)
I/MountService( 453): /mnt/usb_storage/USB_DISK0Updating valid state removed st 0
D/MountService( 453): volume state changed for /mnt/usb_storage/USB_DISK0 (unmounted → removed)
I/MountService( 453): /mnt/usb_storage/USB_DISK1Updating valid state removed st 0
D/MountService( 453): volume state changed for /mnt/usb_storage/USB_DISK1 (unmounted → removed)
I/MountService( 453): /mnt/usb_storage/USB_DISK2Updating valid state removed st 0
D/MountService( 453): volume state changed for /mnt/usb_storage/USB_DISK2 (unmounted → removed)
I/MountService( 453): /mnt/usb_storage/USB_DISK3Updating valid state removed st 0
D/MountService( 453): volume state changed for /mnt/usb_storage/USB_DISK3 (unmounted → removed)
I/MountService( 453): /mnt/usb_storage/USB_DISK4Updating valid state removed st 0
D/MountService( 453): volume state changed for /mnt/usb_storage/USB_DISK4 (unmounted → removed)
I/MountService( 453): /mnt/usb_storage/USB_DISK5Updating valid state removed st 0
D/MountService( 453): volume state changed for /mnt/usb_storage/USB_DISK5 (unmounted → removed)
D/VoldCmdListener( 155): cryptfs getfield SystemLocale
I/SystemServer( 453): LockSettingsService
W/MountService( 453): getSecureContainerList() called when storage not mounted
D/VoldCmdListener( 155): asec list
I/SystemServiceManager( 453): Starting com.android.server.devicepolicy.DevicePolicyManagerService$Lifecycle
I/SystemServer( 453): Status Bar
I/SystemServer( 453): Clipboard Service
I/SystemServer( 453): NetworkManagement Service
I/SystemServer( 453): Text Service Manager Service
I/SystemServer( 453): Network Score Service
I/SystemServer( 453): NetworkStats Service
I/SystemServer( 453): NetworkPolicy Service
I/SystemServiceManager( 453): Starting com.android.server.wifi.p2p.WifiP2pService
I/SystemServiceManager( 453): Starting com.android.server.wifi.WifiService
I/SystemServiceManager( 453): Starting com.android.server.wifi.WifiScanningService
I/SystemServiceManager( 453): Starting com.android.server.wifi.RttService
I/SystemServiceManager( 453): Starting com.android.server.ethernet.EthernetService
I/SystemServer( 453): PppoeService
I/SystemServiceManager( 453): Starting com.android.server.pppoe.PppoeService
I/SystemServer( 453): Connectivity Service
D/ConnectivityService( 453): ConnectivityService starting up
D/ConnectivityService( 453): wifiOnly=false
E/ConnectivityService( 453): Ignoring protectedNetwork 14
I/SystemServer( 453): Network Service Discovery Service
D/NsdService( 453): Network service discovery enabled true
I/SystemServer( 453): UpdateLock Service
I/SystemServiceManager( 453): Starting com.android.server.notification.NotificationManagerService
D/ZenLog ( 453): set_zen_mode: off,setting
I/SystemServiceManager( 453): Starting com.android.server.storage.DeviceStorageMonitorService
I/SystemServer( 453): Location Manager
I/SystemServer( 453): Country Detector
I/SystemServer( 453): Search Service
I/SystemServer( 453): DropBox Service
I/SystemServer( 453): Wallpaper Service
I/SystemServer( 453): Audio Service
I/SystemServiceManager( 453): Starting com.android.server.DockObserver
W/DockObserver( 453): This kernel does not have dock station support
I/SystemServer( 453): Wired Accessory Manager
W/WiredAccessoryManager( 453): This kernel does not have wired headset support
I/SystemServiceManager( 453): Starting com.android.server.usb.UsbService$Lifecycle
I/SystemServer( 453): Serial Service
I/SystemServiceManager( 453): Starting com.android.server.twilight.TwilightService
I/SystemServiceManager( 453): Starting com.android.server.UiModeManagerService
I/SystemServiceManager( 453): Starting com.android.server.job.JobSchedulerService
I/SystemServiceManager( 453): Starting com.android.server.backup.BackupManagerService$Lifecycle
I/SystemServiceManager( 453): Starting com.android.server.appwidget.AppWidgetService
I/SystemServiceManager( 453): Starting com.android.server.voiceinteraction.VoiceInteractionManagerService
W/SoundTriggerHelper( 453): listModules status=0, # of modules=0
I/SystemServer( 453): DiskStats Service
I/SystemServer( 453): SamplingProfiler Service
I/SystemServer( 453): NetworkTimeUpdateService
I/SystemServer( 453): CommonTimeManagementService
I/SystemServer( 453): CertBlacklister
I/SystemServiceManager( 453): Starting com.android.server.dreams.DreamManagerService
I/SystemServer( 453): Assets Atlas Service
I/SystemServiceManager( 453): Starting com.android.server.print.PrintManagerService
I/SystemServiceManager( 453): Starting com.android.server.restrictions.RestrictionsManagerService
I/SystemServiceManager( 453): Starting com.android.server.media.MediaSessionService
I/SystemServiceManager( 453): Starting com.android.server.hdmi.HdmiControlService
I/HdmiControlService( 453): Device does not support HDMI-CEC.
I/SystemServer( 453): Media Router Service
I/SystemServer( 453): DisplayDeviceManagementService Service
D/DisplayDeviceManagementService( 453): DisplayDeviceManagementService start
I/SystemServiceManager( 453): Starting com.android.server.trust.TrustManagerService
I/SystemServiceManager( 453): Starting com.android.server.fingerprint.FingerprintService
I/SystemServer( 453): BackgroundDexOptService
I/SystemServiceManager( 453): Starting com.android.server.pm.LauncherAppsService
I/SystemServiceManager( 453): Starting com.android.server.media.projection.MediaProjectionManagerService
I/SystemServiceManager( 453): Starting com.android.server.MmsServiceBroker
E/LockSettingsStorage( 453): Cannot read file java.io.FileNotFoundException: /data/system/password.key: open failed: ENOENT (No such file or directory)
E/LockSettingsStorage( 453): Cannot read file java.io.FileNotFoundException: /data/system/gesture.key: open failed: ENOENT (No such file or directory)
I/SystemServiceManager( 453): Starting phase 480
I/SystemServiceManager( 453): Starting phase 500
I/WifiService( 453): WifiService starting up with Wi-Fi disabled
D/WifiService( 453): New client listening to asynchronous messages
D/WifiScanningService( 453): New client, channel: null messenger: null
D/ConnectivityService( 453): Got NetworkFactory Messenger for Ethernet
D/ConnectivityService( 453): Got NetworkFactory Messenger for PPPOE
I/ActivityManagerService( 453): Config changes=200 {1.15 multiwindowflag=DISABLE dualscreenflag=DISABLE ?mcc?mnc zh_CN ?layoutDir sw360dp w360dp h567dp 320dpi nrml port finger -keyb/v/h dpad/v s.4}
V/BackupManagerService( 453): No ancestral data
D/BackupManagerService( 453): Now staging backup of com.android.browser
D/BackupManagerService( 453): Now staging backup of android
D/BackupManagerService( 453): Now staging backup of com.android.calendar
D/BackupManagerService( 453): Now staging backup of com.android.providers.settings
D/BackupManagerService( 453): Now staging backup of com.android.sharedstoragebackup
D/BackupManagerService( 453): Now staging backup of com.android.providers.userdictionary
V/BackupManagerService( 453): Starting with transport android/com.android.internal.backup.LocalTransport
V/BackupManagerService( 453): Found transports: 1
I/BackupManagerService( 453): Binding to transport host ComponentInfo{android/com.android.internal.backup.LocalTransportService}
I/BackupManagerService( 453): Found stale backup journal, scheduling
D/DisplayPowerController( 453): button lights toggle
D/DisplayPowerController( 453): send timeout msg after 1500
I/DisplayManagerService( 453): Display device changed: DisplayDeviceInfo{“内置屏幕”: uniqueId=“local:0”, 720 x 1280, 59.527 fps, supportedRefreshRates [59.527], density 320, 160.42105 x 160.15764 dpi, appVsyncOff 0, presDeadline 17799099, touch INTERNAL, rotation 0, type BUILT_IN, state ON, FLAG_DEFAULT_DISPLAY, FLAG_ROTATES_WITH_CONTENT, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
D/ActivityManagerService( 453): OK, system ready!
I/ActivityManagerService( 453): System now ready
D/WifiDisplayAdapter( 453): getWifiDisplayStatusLocked: result=WifiDisplayStatus{featureState=1, scanState=0, activeDisplayState=0, activeDisplay=null, displays=, sessionInfo=WifiDisplaySessionInfo:
D/WifiDisplayAdapter( 453): Client/Owner: Client
D/WifiDisplayAdapter( 453): GroupId:
D/WifiDisplayAdapter( 453): Passphrase:
D/WifiDisplayAdapter( 453): SessionId: 0
D/WifiDisplayAdapter( 453): IP Address: }
I/SystemServer( 453): Making services ready
I/SystemServiceManager( 453): Starting phase 550
D/UsbDeviceManager( 453): Usb state is false false true
D/MountService( 453): sharedvolumeNum: 0 ;avail: false
I/SystemServer( 453): WebViewFactory preparation
I/ActivityManagerService( 453): Start proc 558:android.process.media/u0a4 for broadcast com.android.providers.media/.MtpReceiver
I/ActivityManagerService( 453): Start proc 576:WebViewLoader-armeabi-v7a/1037 [android.webkit.WebViewFactory$RelroFileCreator] for
I/ActivityManagerService( 453): Start proc 594:com.android.systemui/u0a10 for service com.android.systemui/.SystemUIService
I/MountService( 453): doMountVolume: Mouting /mnt/internal_sd
D/VoldCmdListener( 155): volume mount /mnt/internal_sd
D/Vold ( 155): volume status = 1----------------------
D/NetworkManagementService( 453): enabling bandwidth control
D/DirectVolume( 155): getDeviceNodes mPartIdx = 15, mDiskNumParts = 15.
E/Vold ( 155): deviceNodes[0]= 0x0000b30f,[1]= 0x00000000,[2]= 0x00000000,[3]= 0x00000000
I/Vold ( 155): /dev/block/vold/179:15 being considered for volume internal_sd,1
I/Vold ( 155):
D/Vold ( 155): Volume internal_sd state changing 1 (Idle-Unmounted) → 3 (Checking)
I/MountService( 453): onEvent:: raw= 605 Volume internal_sd /mnt/internal_sd state changed from 1 (Idle-Unmounted) to 3 (Checking) cooked = 605 Volume internal_sd /mnt/internal_sd state changed from 1 (Idle-Unmounted) to 3 (Checking)
I/MountService( 453): notifyVolumeStateChange::unmounted
I/MountService( 453): updating volume state checking
D/MountService( 453): volume state changed for /mnt/internal_sd (unmounted → checking)
D/MountService( 453): sendStorageIntent Intent { act=android.intent.action.MEDIA_CHECKING dat=file:///mnt/internal_sd flg=0x4000000 (has extras) } to UserHandle{-1}
I/ActivityManagerService( 453): Start proc 649:android.rockchip.update.service/1000 for broadcast android.rockchip.update.service/.RKUpdateReceiver
I/Vold ( 155): Filesystem check completed OK
E/Vold ( 155): ---------set mSkipAsec to enable app2sd because mount Vfat succeed for internal_sd, mountpoint =/mnt/internal_sd
I/MountService( 453): onEvent:: raw= 613 internal_sd /mnt/internal_sd “1C01-07D0” cooked = 613 internal_sd /mnt/internal_sd 1C01-07D0
I/MountService( 453): onEvent:: raw= 614 internal_sd /mnt/internal_sd “ROCKCHIP” cooked = 614 internal_sd /mnt/internal_sd ROCKCHIP
D/Vold ( 155): Volume internal_sd state changing 3 (Checking) → 4 (Mounted)
I/MountService( 453): onEvent:: raw= 605 Volume internal_sd /mnt/internal_sd state changed from 3 (Checking) to 4 (Mounted) cooked = 605 Volume internal_sd /mnt/internal_sd state changed from 3 (Checking) to 4 (Mounted)
I/MountService( 453): notifyVolumeStateChange::checking
I/MountService( 453): updating volume state mounted
D/MountService( 453): volume state changed for /mnt/internal_sd (checking → mounted)
D/MountService( 453): sendStorageIntent Intent { act=android.intent.action.MEDIA_MOUNTED dat=file:///mnt/internal_sd flg=0x4000000 (has extras) } to UserHandle{-1}
I/SystemServiceManager( 453): Starting phase 600
I/ActivityManagerService( 453): Start proc 680:com.cghs.stresstest/1000 for broadcast com.cghs.stresstest/.test.receiver.RecoveryReceiver
I/BackupManagerService( 453): Backup enabled => false
I/BackupManagerService( 453): Opting out of backup
E/InputMethodManagerService( 453): Ignoring setImeWindowStatus due to an invalid token. uid:1000 token:null
I/ActivityManagerService( 453): Start proc 702:com.android.inputmethod.latin/u0a26 for service com.android.inputmethod.latin/.LatinIME
V/InputMethodManagerService( 453): Adding window token: android.os.Binder@1f0b8fb8
W/PackageManager( 453): Not granting permission android.permission.GLOBAL_SEARCH to package com.android.quicksearchbox (protectionLevel=18 flags=0x88be45)
W/PackageManager( 453): Not granting permission android.permission.ACCESS_DOWNLOAD_MANAGER to package com.android.browser (protectionLevel=18 flags=0x89be45)
W/PackageManager( 453): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.browser (protectionLevel=2 flags=0x89be45)
W/PackageManager( 453): Not granting permission android.permission.BIND_WALLPAPER to package com.android.camera2 (protectionLevel=18 flags=0xd8bc45)
W/PackageManager( 453): Not granting permission android.permission.BIND_APPWIDGET to package com.android.launcher3 (protectionLevel=18 flags=0xd83e45)
W/PackageManager( 453): Not granting permission android.permission.INSTALL_PACKAGES to package com.android.apkinstaller (protectionLevel=18 flags=0x88be45)
W/PackageManager( 453): Not granting permission android.permission.DELETE_PACKAGES to package com.android.apkinstaller (protectionLevel=18 flags=0x88be45)
W/PackageManager( 453): Not granting permission android.permission.WRITE_MEDIA_STORAGE to package com.estrongs.android.pop (protectionLevel=18 flags=0xd8be45)
W/PackageManager( 453): Not granting permission android.permission.DELETE_PACKAGES to package com.svox.pico (protectionLevel=18 flags=0x88be45)
W/PackageManager( 453): Not granting permission android.permission.DEVICE_POWER to package com.android.deskclock (protectionLevel=2 flags=0xc8be45)
V/FingerprintService( 453): startListening(android.service.fingerprint.IFingerprintServiceReceiver$Stub$Proxy@10c5ef64)
--------- beginning of main
E/OMXNodeInstance( 166): getParameter(b:google.amrnb.encoder, ParamVideoPortFormat(0x6000001)) ERROR: UnsupportedIndex(0x8000101a)
I/System ( 453): Loaded time zone names for “en_US” in 20ms (18ms in ICU)
D/DisplayManager( 594): getDisplayInfo: displayId=0, info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 720 x 1184, real 720 x 1280, largest app 1280 x 1134, smallest app 720 x 574, 59.527 fps, supportedRefreshRates [59.527], rotation 0, density 320 (160.42105 x 160.15764) dpi, layerStack 0, appVsyncOff 0, presDeadline 17799099, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
E/OMXNodeInstance( 166): getParameter(c:google.amrwb.encoder, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance( 166): getParameter(c:google.amrwb.encoder, ParamVideoPortFormat(0x6000001)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance( 166): getParameter(d:google.flac.encoder, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: UnsupportedIndex(0x8000101a)
E/OMXNodeInstance( 166): getParameter(d:google.flac.encoder, ParamVideoPortFormat(0x6000001)) ERROR: UnsupportedIndex(0x8000101a)
E/ROCKCHIP_VIDEO_DECCONTROL( 166): OMX_IndexParamdescribeColorFormat get
E/ROCKCHIP_OSAL_Android( 166): OMX_ERRORTYPE Rockchip_OSAL_GetANBParameter(OMX_HANDLETYPE, OMX_INDEXTYPE, OMX_PTR): Rockchip_OMX_Check_SizeVersion(DescribeColorFormatParams) is failed
E/OMXNodeInstance( 166): getParameter(e:rk._decoder.avc, ??(0x7f000017)) ERROR: BadParameter(0x80001005)
W/OMXNodeInstance( 166): [e:rk._decoder.avc] component does not support metadata mode; using fallback
E/OMXNodeInstance( 166): getParameter(f:rk._decoder.m2v, ??(0x7f000017)) ERROR: BadParameter(0x80001005)
W/OMXNodeInstance( 166): [f:rk._decoder.m2v] component does not support metadata mode; using fallback
E/OMXNodeInstance( 166): getParameter(10:rk._decoder.vp8, ??(0x7f000017)) ERROR: BadParameter(0x80001005)
W/OMXNodeInstance( 166): [10:rk._decoder.vp8] component does not support metadata mode; using fallback
I/System ( 453): Loaded time zone names for “zh_CN” in 20ms (18ms in ICU)
E/GpsLocationProvider( 453): no GPS configuration interface in configuraiton_update
D/GpsLocationProvider( 453): final config = #Sat Jan 01 10:19:03 GMT+08:00 2000
D/GpsLocationProvider( 453): SUPL_VER=0x20000
D/GpsLocationProvider( 453): SUPL_HOST=supl.google.com
D/GpsLocationProvider( 453): NTP_SERVER=europe.pool.ntp.org
D/GpsLocationProvider( 453): XTRA_SERVER_1=http://alp.u-blox.com/current_7d.bin
D/GpsLocationProvider( 453): SUPL_PORT=7275
D/GpsLocationProvider( 453): SUPL_MODE=1
W/OMXNodeInstance( 166): [11:google.vp9.decoder] component does not support metadata mode; using fallback
W/ServiceWatcher( 453): com.google.android.gms not found
E/OMXNodeInstance( 166): getParameter(12:rk._decoder.h263, ??(0x7f000017)) ERROR: BadParameter(0x80001005)
W/OMXNodeInstance( 166): [12:rk._decoder.h263] component does not support metadata mode; using fallback
W/LocationManagerService( 453): no network location provider found
E/LocationManagerService( 453): no geocoder provider found
E/FlpHardwareProvider( 453): Error hw_get_module ‘flp’: -2
E/LocationManagerService( 453): FLP HAL not supported
E/LocationManagerService( 453): Unable to bind FLP Geofence proxy.
E/ActivityRecognitionHardware( 453): Error hw_get_module: -2
E/LocationManagerService( 453): Hardware Activity-Recognition not supported.
E/OMXNodeInstance( 166): getParameter(13:rk._decoder.m4v, ??(0x7f000017)) ERROR: BadParameter(0x80001005)
W/OMXNodeInstance( 166): [13:rk._decoder.m4v] component does not support metadata mode; using fallback
E/OMXNodeInstance( 166): getParameter(14:rk._decoder.flv1, ??(0x7f000017)) ERROR: BadParameter(0x80001005)
W/OMXNodeInstance( 166): [14:rk._decoder.flv1] component does not support metadata mode; using fallback
E/OMXNodeInstance( 166): getParameter(15:rk._decoder.mjpeg, ??(0x7f000017)) ERROR: BadParameter(0x80001005)
W/OMXNodeInstance( 166): [15:rk._decoder.mjpeg] component does not support metadata mode; using fallback
E/OMXNodeInstance( 166): getParameter(16:rk._decoder.hevc, ??(0x7f000017)) ERROR: BadParameter(0x80001005)
W/OMXNodeInstance( 166): [16:rk._decoder.hevc] component does not support metadata mode; using fallback
D/gps_ql ( 453): GPS DRIVER VERSION: Quectel_Android_GPS_SR01A05V05
D/gps_ql ( 453): ql_gps_init(callbacks=0xb3ccb508)
W/ACodec ( 166): do not know color format 0x7f000789 = 2130708361
I/CommonTimeManagementService( 453): No common time service detected on this platform. Common time services will be unavailable.
I/InputReader( 453): Reconfiguring input devices. changes=0x00000020
I/MmsServiceBroker( 453): Delay connecting to MmsService until an API is called
W/VoiceInteractionManagerService( 453): no available voice interaction services found for user 0
W/VoiceInteractionManagerService( 453): no available voice recognition services found for user 0
I/InputReader( 453): Reconfiguring input devices. changes=0x00000010
W/OMXNodeInstance( 166): [18:google.h264.decoder] component does not support metadata mode; using fallback
W/OMXNodeInstance( 166): [19:google.vp9.decoder] component does not support metadata mode; using fallback
D/gps_ql ( 453): [EC20] [/dev/ttyUSB1] [115200]
D/gps_ql ( 453): MODULE_TYPE:EC20
D/gps_ql ( 453): QL_GPS_CHANNEL:/dev/ttyUSB1
D/gps_ql ( 453): BAUD_RATE:115200
D/gps_ql ( 453): gps_state_init start
D/gps_ql ( 453): GPS channel </dev/ttyUSB1> not exist. errno: 2 (No such file or directory)
W/GpsLocationProvider( 453): Failed to enable location provider
I/SoftMPEG4Encoder( 166): Construct SoftMPEG4Encoder
I/OMXCodec( 166): —>InstantiateSoftwareCodec create OMX.google.vorbis.decoder codec
I/OMXCodec( 166): Successfully allocated OMX node ‘OMX.google.vorbis.decoder’
I/OMXCodec( 166): mOutputPortSettingsHaveChanged set true
I/OMXCodec( 166): found informat change ComponentName = OMX.google.vorbis.decoder
I/ActivityManagerService( 453): Start proc 787:com.android.phone/1001 for added application com.android.phone
I/ActivityStackSupervisor( 453): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000000 cmp=com.android.launcher3/.Launcher} from uid 0 on display 0
I/System.out( 453): com.android.launcher3.LauncheraddAppToken taskId:9
I/ActivityManagerService( 453): Start proc 807:com.android.launcher3/u0a27 for activity com.android.launcher3/.Launcher
I/SystemServer( 453): Enabled StrictMode for system server main thread.
I/FrameQueueManage( 166): FrameQueueManage::~FrameQueueManage end!
I/AwesomePlayer( 166): AwesomePlayer::AwesomePlayer()in
I/AwesomePlayer( 166): AwesomePlayer::AwesomePlayer()aftermClient.connect()
W/AudioCache( 166): Battery track warning: refCount is already 0
I/art ( 170): Explicit concurrent mark sweep GC freed 701(30KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1861KB/3MB, paused 141us total 10.719ms
I/art ( 170): Explicit concurrent mark sweep GC freed 8(256B) AllocSpace objects, 0(0B) LOS objects, 39% free, 1861KB/3MB, paused 136us total 6.602ms
I/art ( 170): Explicit concurrent mark sweep GC freed 5(160B) AllocSpace objects, 0(0B) LOS objects, 39% free, 1861KB/3MB, paused 115us total 6.271ms
I/LatinIME( 702): Hardware accelerated drawing: true
I/ActivityManagerService( 453): Start proc 834:com.android.printspooler/u0a38 for service com.android.printspooler/.model.PrintSpoolerService
V/ActivityStackSupervisor( 453): Display changed displayId=0
D/WifiScanningService( 453): SCAN_AVAILABLE : 1
D/RttService( 453): SCAN_AVAILABLE : 1
D/RttService( 453): DefaultState got{ when=0 what=160513 target=com.android.internal.util.StateMachine$SmHandler }
D/DisplayManager( 453): getDisplayInfo: displayId=0, info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 720 x 1184, real 720 x 1280, largest app 1280 x 1134, smallest app 720 x 574, 59.527 fps, supportedRefreshRates [59.527], rotation 0, density 320 (160.42105 x 160.15764) dpi, layerStack 0, appVsyncOff 0, presDeadline 17799099, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
D/WifiScanningService( 453): DefaultState got{ when=-1ms what=160007 target=com.android.internal.util.StateMachine$SmHandler }
D/DisplayManager( 453): onDisplayEvent: displayId=0, event=2
D/DisplayManager( 558): onDisplayEvent: displayId=0, event=2
D/DisplayManager( 594): onDisplayEvent: displayId=0, event=2
D/DisplayManager( 702): onDisplayEvent: displayId=0, event=2
D/DisplayManager( 680): onDisplayEvent: displayId=0, event=2
D/DisplayManager( 649): onDisplayEvent: displayId=0, event=2
D/DisplayManager( 787): getDisplayInfo: displayId=0, info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 720 x 1184, real 720 x 1280, largest app 1280 x 1134, smallest app 720 x 574, 59.527 fps, supportedRefreshRates [59.527], rotation 0, density 320 (160.42105 x 160.15764) dpi, layerStack 0, appVsyncOff 0, presDeadline 17799099, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
D/DisplayManager( 807): getDisplayInfo: displayId=0, info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 720 x 1184, real 720 x 1280, largest app 1280 x 1134, smallest app 720 x 574, 59.527 fps, supportedRefreshRates [59.527], rotation 0, density 320 (160.42105 x 160.15764) dpi, layerStack 0, appVsyncOff 0, presDeadline 17799099, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
D/DisplayManager( 834): getDisplayInfo: displayId=0, info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 720 x 1184, real 720 x 1280, largest app 1280 x 1134, smallest app 720 x 574, 59.527 fps, supportedRefreshRates [59.527], rotation 0, density 320 (160.42105 x 160.15764) dpi, layerStack 0, appVsyncOff 0, presDeadline 17799099, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
I/Choreographer( 453): Skipped 52 frames! The application may be doing too much work on its main thread.
D/ViewRootImpl( 453): onAttachToWindow register content observer attrs=WM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 sim=#10 ty=2029 fl=#1110900 pfl=0x1 fmt=-3 or=5 surfaceInsets=Rect(0, 0 - 0, 0)packageName=androidtoken=null}
D/ViewRootImpl( 453): 720<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 sim=#10 ty=2029 fl=#1110900 pfl=0x1 fmt=-3 or=5 vsysui=0x3610000 surfaceInsets=Rect(0, 0 - 0, 0)packageName=androidtoken=null}
I/Telecom ( 453): TelecomGlobals: TelecomGlobals initializing
D/DisplayManager( 702): getDisplayInfo: displayId=0, info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 720 x 1184, real 720 x 1280, largest app 1280 x 1134, smallest app 720 x 574, 59.527 fps, supportedRefreshRates [59.527], rotation 0, density 320 (160.42105 x 160.15764) dpi, layerStack 0, appVsyncOff 0, presDeadline 17799099, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
I/art ( 453): Background sticky concurrent mark sweep GC freed 23623(1802KB) AllocSpace objects, 5(80KB) LOS objects, 24% free, 6MB/8MB, paused 10.019ms total 35.543ms
I/ActivityManagerService( 453): Start proc 878:android.process.acore/u0a2 for content provider com.android.providers.contacts/.CallLogProvider
D/BluetoothManagerService( 453): Trying to bind to profile: 1, while Bluetooth was disabled
D/BluetoothManagerService( 453): Message: 30
I/PrintSpoolerService( 834): No existing print spooler state.
D/PhoneWindow( 702): DecorView - SCREEN_WEITH = 720 - SCREE_HEIGHT = 1184
W/ResourceType( 594): No package identifier when getting value for resource number 0x00000000
W/PackageManager( 594): Failure retrieving resources for com.android.settings: Resource ID #0x0
I/Telecom ( 453): TelecomGlobals: CallsManager initialized
W/ContextImpl( 453): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1709 android.content.ContextWrapper.startService:516 com.android.server.telecom.BluetoothPhoneService.start:440 com.android.server.telecom.TelecomGlobals.initialize:93 com.android.server.telecom.TelecomService.onCreate:164
W/InputAttributes( 702): No editor info for this field. Bug?
D/Tethering( 453): UsbManager.ACTION_USB_STATE: false, false, false
D/ZenLog ( 453): downtime: Autotrigger skipped: not in downtime
W/ResourcesManager( 453): Asset path ‘/system/framework/com.android.location.provider.jar’ does not exist or contains no resources.
I/ResourceUtils( 702): Found default value: resource=keypress_vibration_durations build=[HARDWARE=rk30board MODEL=RT6000S BRAND=Nuctech MANUFACTURER=Nuctech] default=-1
I/ResourceUtils( 702): Found default value: resource=keypress_volumes build=[HARDWARE=rk30board MODEL=RT6000S BRAND=Nuctech MANUFACTURER=Nuctech] default=-1.0f
D/GpsNetInitiatedHandler( 453): location enabled :true
V/WiredAccessoryManager( 453): init()
W/PackageManager( 594): Failure retrieving resources for com.android.camera2: Resource ID #0x0
D/DisplayManager( 878): getDisplayInfo: displayId=0, info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 720 x 1184, real 720 x 1280, largest app 1280 x 1134, smallest app 720 x 574, 59.527 fps, supportedRefreshRates [59.527], rotation 0, density 320 (160.42105 x 160.15764) dpi, layerStack 0, appVsyncOff 0, presDeadline 17799099, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
W/art ( 594): Suspending all threads took: 14.552ms
I/art ( 594): Background partial concurrent mark sweep GC freed 724(94KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 3MB/5MB, paused 15.784ms total 40.900ms
I/LatinIME:LogUtils( 702): Dictionary info: dictionary = userunigram.en_US.dict ; version = ? ; date = ?
D/PhoneWindow( 594): DecorView - SCREEN_WEITH = 720 - SCREE_HEIGHT = 1184
D/BluetoothManagerService( 453): Message: 300
D/BluetoothManagerService( 453): MESSAGE_USER_SWITCHED
D/PermissionCache( 156): checking android.permission.HARDWARE_TEST for uid=1000 => granted (121 us)
I/LatinIME:LogUtils( 702): Dictionary info: dictionary = main:en ; version = 42 ; date = 1381226429
W/AppOps ( 453): Bad call: specified package media under uid 1000 but it is really 1013
D/Launcher.LauncherProvider( 807): 11683562 - initializeMaxScreenId(): 3
V/Launcher( 807): LauncherAppState inited
V/BackupManagerService( 453): Connected to transport ComponentInfo{android/com.android.internal.backup.LocalTransportService}
V/BackupManagerService( 453): Registering transport android/com.android.internal.backup.LocalTransportService::android/com.android.internal.backup.LocalTransport = android.app.backup.BackupTransport$TransportImpl@99ee97b
I/FusedLocation( 453): engine started (com.android.location.fused)
D/TelephonyProvider( 787): dbh.onOpen: ok, queried table=siminfo
D/TelephonyProvider( 787): dbh.onOpen: ok, queried table=carriers
D/Launcher.Model( 807): Old launcher provider: content://com.android.launcher2.settings/favorites?notify=true
D/Launcher.Model( 807): Old launcher provider does not exist.
W/Launcher( 807): setApplicationContext called twice! old=com.android.launcher3.LauncherApplication@1b293b7 new=com.android.launcher3.LauncherApplication@1b293b7
D/VolumeUI( 594): Registering volume controller
I/ActivityManagerService( 453): Start proc 935:com.android.smspush/u0a44 for service com.android.smspush/.WapPushManager
E/DcSwitchStateMachine-0( 787): DctController is not ready
E/ConnectivityService( 453): Failed to find Messenger in unregisterNetworkFactory
D/GpsLocationProvider( 453): received SIM realted action:
D/ConnectivityService( 453): Got NetworkFactory Messenger for Telephony
D/DisplayManager( 935): getDisplayInfo: displayId=0, info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 720 x 1184, real 720 x 1280, largest app 1280 x 1134, smallest app 720 x 574, 59.527 fps, supportedRefreshRates [59.527], rotation 0, density 320 (160.42105 x 160.15764) dpi, layerStack 0, appVsyncOff 0, presDeadline 17799099, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
D/PhoneWindow( 807): DecorView - SCREEN_WEITH = 720 - SCREE_HEIGHT = 1184
I/art ( 453): Background sticky concurrent mark sweep GC freed 14665(1538KB) AllocSpace objects, 4(74KB) LOS objects, 20% free, 6MB/8MB, paused 6.335ms total 17.083ms
D/GpsLocationProvider( 453): SIM MCC/MNC is still not available
I/LatinIME:LogUtils( 702): Dictionary info: dictionary = PersonalizationPredictionDictio ; version = ? ; date = 946684875
I/LatinIME:LogUtils( 702): Dictionary info: dictionary = UserHistoryDictionary.en_US.dic ; version = ? ; date = 946684875
I/LatinIME:LogUtils( 702): Dictionary info: dictionary = personalization.en_US.dict ; version = ? ; date = 946684875
D/BluetoothManagerService( 453): Message: 20
D/BluetoothManagerService( 453): Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@3877e7d2:true
I/ContactLocale( 878): AddressBook Labels [zh-CN]: [, A, B, C, D, E, F, G, H, I, J, K, L, M, N, O, P, Q, R, S, T, U, V, W, X, Y, Z, Α, Β, Γ, Δ, Ε, Ζ, Η, Θ, Ι, Κ, Λ, Μ, Ν, Ξ, Ο, Π, Ρ, Σ, Τ, Υ, Φ, Χ, Ψ, Ω, , А, Б, В, Г, Д, Ђ, Е, Є, Ж, З, И, І, Ї, Й, Ј, К, Л, Љ, М, Н, Њ, О, П, Р, С, Т, Ћ, У, Ф, Х, Ц, Ч, Џ, Ш, Щ, Ю, Я, , א, ב, ג, ד, ה, ו, ז, ח, ט, י, כ, ל, מ, נ, ס, ע, פ, צ, ק, ר, ש, ת, , ا, ب, ت, ث, ج, ح, خ, د, ذ, ر, ز, س, ش, ص, ض, ط, ظ, ع, غ, ف, ق, ك, ل, م, ن, ه, و, ي, , ก, ข, ฃ, ค, ฅ, ฆ, ง, จ, ฉ, ช, ซ, ฌ, ญ, ฎ, ฏ, ฐ, ฑ, ฒ, ณ, ด, ต, ถ, ท, ธ, น, บ, ป, ผ, ฝ, พ, ฟ, ภ, ม, ย, ร, ฤ, ล, ฦ, ว, ศ, ษ, ส, ห, ฬ, อ, ฮ, , ㄱ, ㄴ, ㄷ, ㄹ, ㅁ, ㅂ, ㅅ, ㅇ, ㅈ, ㅊ, ㅋ, ㅌ, ㅍ, ㅎ, , あ, か, さ, た, な, は, ま, や, ら, わ, #, ]
I/Telephony( 787): TtyManager: updateUiTtyMode -1 → 0
W/ResourceType( 807): Attempt to retrieve bag 0x7f0d0008 which is invalid or in a cycle.
I/art ( 594): Background sticky concurrent mark sweep GC freed 7717(684KB) AllocSpace objects, 0(0B) LOS objects, 12% free, 4MB/5MB, paused 1.457ms total 102.917ms
I/StatusBarManagerService( 453): registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@35cc9f2a
D/DisplayPowerController( 453): MSG_BUTTON_LIGHTS_TIME_OUT
E/Lights ( 453): write_int failed to open sys/class/leds/rk29_key_led/brightness
I/Lights ( 453): >>> Enter set_keyboard_light
D/TelephonyDebugService( 787): TelephonyDebugService()
D/Launcher.Model( 807): 11683562 - loadWorkspace()
D/Launcher.Model( 807): 11683562 - loadedOldDb: false
I/ValidateNoPeople( 453): skipping global notification
D/OpenGLRenderer( 807): Use EGL_SWAP_BEHAVIOR_PRESERVED: true
D/Atlas ( 807): Validating map…
W/Atlas ( 807): Pointer 0x0, not in getPreloadedDrawables?
V/WindowManagerService( 453): Based on layer: Adding window Window{209b2cf5 u0 com.android.launcher3/com.android.launcher3.Launcher} at 0 of 1
D/ViewRootImpl( 807): onAttachToWindow register content observer attrs=WM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=9 sim=#120 ty=1 fl=#81910100 fmt=-2 wanim=0x1030469 vsysui=0x700 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.android.launcher3token=android.os.BinderProxy@3a65b795}
D/Launcher.Model( 807): 11683562 - loadWorkspaceScreensDb()
D/Launcher.Model( 807): 11683562 - screens: { 0: 3 }
D/Launcher.Model( 807): 11683562 - sBgWorkspaceScreens: 3
I/Telephony( 787): PstnIncomingCallNotifier: Registering: Handler (com.android.internal.telephony.gsm.GSMPhone) {160847e4}
D/ViewRootImpl( 807): 720<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=9 sim=#120 ty=1 fl=#81910100 fmt=-2 wanim=0x1030469 vsysui=0x600 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.android.launcher3token=android.os.BinderProxy@3a65b795}
I/mali_so ( 807): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 780; [Func] : base_context_deal_with_version_affairs_rk_ext;
I/mali_so ( 807): arm_release_ver of this mali_so is ‘r6p0-02rel0’, rk_so_ver is ‘11@0’, built at ‘15:38:28’ for 3288w, on ‘Aug 2 2016’.
I/mali_so ( 807): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 807; [Func] : base_context_deal_with_version_affairs_rk_ext;
I/mali_so ( 807): mali_ver_property has been set to ‘r6p0-02rel0-13-11@0’, to return.
I/OpenGLRenderer( 807): Initialized EGL, version 1.4
D/OpenGLRenderer( 807): Enabling debug mode 0
W/art ( 594): Suspending all threads took: 8.625ms
I/ActivityManagerService( 453): Displayed com.android.launcher3/.Launcher: +927ms
I/art ( 594): Background sticky concurrent mark sweep GC freed 706(29KB) AllocSpace objects, 0(0B) LOS objects, 2% free, 5MB/5MB, paused 9.494ms total 29.619ms
D/Launcher( 807): 11683562 - bindAddScreens()
D/Launcher( 807): 11683562 - orderedScreenIds: 3
D/Launcher.Workspace( 807): 11683562 - insertNewWorkspaceScreen(): 3 at index: 0
V/KeyguardServiceDelegate( 453): *** Keyguard: can’t bind to com.android.systemui.keyguard.KeyguardService
W/KeyguardServiceDelegate( 453): onScreenTurnedOn(): no keyguard service!
D/WindowManagerService( 453): Window{209b2cf5 u0 com.android.launcher3/com.android.launcher3.Launcher} ==========setInputFocusLw ========== =======
D/ViewRootImpl( 453): 720<<<<<< BACK FROM relayoutnull
W/InputMethodManagerService( 453): Starting input on non-focused client android.view.inputmethod.InputMethodManager$1@160994c0 (uid=1000 pid=453)
V/RenderScript( 807): 0xb8f1b818 Launching thread(s), CPUs 4
D/HSbar ( 594): app_bar_item_size=(160,160)
W/PackageManager( 594): Failure retrieving resources for com.android.providers.media: Resource ID #0x0
W/PackageManager( 594): Failure retrieving resources for com.android.wallpapercropper: Resource ID #0x0
W/PackageManager( 594): Failure retrieving resources for com.android.documentsui: Resource ID #0x0
W/PackageManager( 594): Failure retrieving resources for com.android.externalstorage: Resource ID #0x0
W/PackageManager( 594): Failure retrieving resources for com.android.htmlviewer: Resource ID #0x0
W/PackageManager( 594): Failure retrieving resources for com.android.mms.service: Resource ID #0x0
W/PackageManager( 594): Failure retrieving resources for com.android.winstart: Resource ID #0x0
W/PackageManager( 594): Failure retrieving resources for com.android.defcontainer: Resource ID #0x0
W/PackageManager( 594): Failure retrieving resources for com.android.pacprocessor: Resource ID #0x0
W/PackageManager( 594): Failure retrieving resources for com.android.certinstaller: Resource ID #0x0
W/PackageManager( 594): Failure retrieving resources for com.android.backupconfirm: Resource ID #0x0
W/PackageManager( 594): Failure retrieving resources for com.android.provision: Resource ID #0x0
W/PackageManager( 594): Failure retrieving resources for com.android.wallpaper.holospiral: Resource ID #0x0
W/PackageManager( 594): Failure retrieving resources for com.android.sharedstoragebackup: Resource ID #0x0
W/PackageManager( 594): Failure retrieving resources for com.android.printspooler: Resource ID #0x0
W/PackageManager( 594): Failure retrieving resources for com.android.dreams.basic: Resource ID #0x0
W/PackageManager( 594): Failure retrieving resources for com.android.inputdevices: Resource ID #0x0
W/PackageManager( 594): Failure retrieving resources for com.android.onetimeinitializer: Resource ID #0x0
W/PackageManager( 594): Failure retrieving resources for com.android.keychain: Resource ID #0x0
W/PackageManager( 594): Failure retrieving resources for com.android.packageinstaller: Resource ID #0x0
W/PackageManager( 594): Failure retrieving resources for com.svox.pico: Resource ID #0x0
W/PackageManager( 594): Failure retrieving resources for com.android.proxyhandler: Resource ID #0x0
W/PackageManager( 594): Failure retrieving resources for com.android.managedprovisioning: Resource ID #0x0
W/PackageManager( 594): Failure retrieving resources for com.android.smspush: Resource ID #0x0
W/PackageManager( 594): Failure retrieving resources for jp.co.omronsoft.openwnn: Resource ID #0x0
W/PackageManager( 594): Failure retrieving resources for com.android.vpndialogs: Resource ID #0x0
W/PackageManager( 594): Failure retrieving resources for com.android.shell: Resource ID #0x0
W/PackageManager( 594): Failure retrieving resources for com.android.providers.userdictionary: Resource ID #0x0
W/PackageManager( 594): Failure retrieving resources for com.android.location.fused: Resource ID #0x0
W/PackageManager( 594): Failure retrieving resources for com.android.Listappinfo: Resource ID #0x0
W/PackageManager( 594): Failure retrieving resources for com.android.captiveportallogin: Resource ID #0x0
V/Sensors ( 453): int poll__activate(sensors_poll_device_t*, int, int)
V/Sensors ( 453): int sensors_poll_context_t::activate(int, int)
V/Sensors ( 453): enable - sensor Accelerometer (handle 4) dis → en
E/Sensors ( 453): MPU is not available
V/Sensors ( 453): int poll__setDelay(sensors_poll_device_t*, int, int64_t)
V/Sensors ( 453): int sensors_poll_context_t::setDelay(int, int64_t)
V/Sensors ( 453): setDelay - sensor Accelerometer (handle 4), rate 66 ms (15.00 Hz)
D/BluetoothManagerService( 453): Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@3a51a9de:true
D/BluetoothAdapter( 594): 588588870: getState() : mService = null. Returning STATE_OFF
E/BluetoothA2dpSink( 594): Could not bind to Bluetooth A2DP Service with Intent { act=android.bluetooth.IBluetoothA2dpSink }
E/BluetoothAvrcpController( 594): Could not bind to Bluetooth AVRCP Controller Service with Intent { act=android.bluetooth.IBluetoothAvrcpController }
E/BluetoothHeadsetClient( 594): Could not bind to Bluetooth Headset Client Service with Intent { act=android.bluetooth.IBluetoothHeadsetClient }
D/BluetoothMap( 594): Create BluetoothMap proxy object
E/BluetoothMap( 594): Could not bind to Bluetooth MAP Service with Intent { act=android.bluetooth.IBluetoothMap }
D/ConnectivityService( 453): listenForNetwork for NetworkRequest [ id=2, legacyType=-1, ]
E/blb ( 594): mmEthernetVisible: false
I/CameraManagerGlobal( 594): getCameraService: Reconnecting to camera service
D/mmk ( 594): onStatusChangedLocked.+++++++
E/CameraManagerGlobal( 594): Camera id 0 has status changed to 0x1
I/CameraService( 166): getCameraCharacteristics: Switching to HAL1 shim implementation…
D/CameraHal( 166): camera_get_camera_info(1337): camera_get_camera_info(1337): camera_0 facing(1), orientation(180)
I/AwesomePlayer( 166): setDataSource_l()
I/mediaserver( 1012): type=1400 audit(0.0:10): avc: denied { write } for name=“/” dev=“mmcblk0p13” ino=2 scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=dir permissive=1
I/CameraClient( 166): Opening camera 0
I/CameraHal( 166): camera_device_open(500): camera_device open
D/CameraHal( 166): gCameraHalLogLevel: 0
E/CameraManagerGlobal( 594): Camera id 0 has status changed to 0x80000000
D/CameraHal( 166): CameraHal(125): it is a isp soc camera
D/CameraHal( 166): Calling process is: /system/bin/mediaserver
I/vpu_mem_pool( 166): pid 166, open_vpu_memory_pool:473: success
I/vpu_mem_pool( 166): pid 166, vpu_mem_allocator:717: vpu memory pool size (80000)
I/vpu_mem_pool( 166): pid 166, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 34
I/vpu_mem_pool( 166): pid 166, vpu_mem_allocator:717: vpu memory pool size (160000)
I/vpu_mem_pool( 166): pid 166, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 37
I/vpu_mem_pool( 166): pid 166, vpu_mem_allocator:717: vpu memory pool size (240000)
I/vpu_mem_pool( 166): pid 166, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 39
I/vpu_mem_pool( 166): pid 166, vpu_mem_allocator:717: vpu memory pool size (320000)
I/vpu_mem_pool( 166): pid 166, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 38
I/vpu_mem_pool( 166): pid 166, vpu_mem_allocator:717: vpu memory pool size (400000)
I/vpu_mem_pool( 166): pid 166, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 41
I/vpu_mem_pool( 166): pid 166, vpu_mem_allocator:717: vpu memory pool size (480000)
I/vpu_mem_pool( 166): pid 166, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 42
I/vpu_mem_pool( 166): pid 166, vpu_mem_allocator:717: vpu memory pool size (560000)
I/vpu_mem_pool( 166): pid 166, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 44
I/vpu_mem_pool( 166): pid 166, vpu_mem_allocator:717: vpu memory pool size (640000)
I/vpu_mem_pool( 166): pid 166, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 45
I/vpu_mem_pool( 166): pid 166, vpu_mem_allocator:717: vpu memory pool size (720000)
I/vpu_mem_pool( 166): pid 166, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 46
I/vpu_mem_pool( 166): pid 166, vpu_mem_allocator:717: vpu memory pool size (800000)
I/vpu_mem_pool( 166): pid 166, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 47
E/CameraHal( 166): disconnectCamera(1784): getFocusLimits failed!
I/mediaserver( 1012): type=1400 audit(0.0:11): avc: denied { remove_name } for name=“vpumem_observer” dev=“mmcblk0p13” ino=14 scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=dir permissive=1
I/mediaserver( 1012): type=1400 audit(0.0:12): avc: denied { unlink } for name=“vpumem_observer” dev=“mmcblk0p13” ino=14 scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=sock_file permissive=1
I/mediaserver( 1012): type=1400 audit(0.0:13): avc: denied { add_name } for name=“vpumem_observer” scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=dir permissive=1
I/mediaserver( 1012): type=1400 audit(0.0:14): avc: denied { create } for name=“vpumem_observer” scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=sock_file permissive=1
I/vpu_mem_pool( 166): pid 166, vpu_memory_status_observer:927: observer: /data/vpumem_observer
I/ActivityManagerService( 453): Start proc 1021:com.rockchip.devicetest/1000 for broadcast com.rockchip.devicetest/.BootReceiver
E/CameraHal_Marvin( 166): CAM_API_CAMENGINE: openSensor (IsiMdiInitMotoDrive failed)
D/CameraHal_Marvin( 166):
D/CameraHal_Marvin( 166): CameraHal Version Check:
D/CameraHal_Marvin( 166): CamSys_Head.h version:
D/CameraHal_Marvin( 166): kernel: (0x) v0.b.0
D/CameraHal_Marvin( 166): libisp_siliconimage_isp.so: (0x) v0.b.0
D/CameraHal_Marvin( 166): LibIsp version:
D/CameraHal_Marvin( 166): local: (0x) v1.27.0
D/CameraHal_Marvin( 166): camera.rk30board.so: (0x) v1.27.0
D/CameraHal_Marvin( 166): Sensor ISI version:
D/CameraHal_Marvin( 166): libisp_isi_drv_XXX: (0x) v0.a.0
D/CameraHal_Marvin( 166): libisp_siliconimage_isp.so: (0x) v0.a.0
D/CameraHal_Marvin( 166): sensor name OV5640:
D/CameraHal_Marvin( 166): sensor drv version: (0x) v0.8.0
D/DisplayManager( 1021): getDisplayInfo: displayId=0, info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 720 x 1184, real 720 x 1280, largest app 1280 x 1134, smallest app 720 x 574, 59.527 fps, supportedRefreshRates [59.527], rotation 0, density 320 (160.42105 x 160.15764) dpi, layerStack 0, appVsyncOff 0, presDeadline 17799099, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
V/TestService( 1021): action:android.intent.action.MEDIA_MOUNTED
V/TestService( 1021): pathfile:///mnt/internal_sd,bootcomplete=false
V/TestService( 1021): path1:file:///mnt/internal_sd
W/ContextImpl( 1021): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1709 android.content.ContextWrapper.startService:516 android.content.ContextWrapper.startService:516 com.rockchip.devicetest.BootReceiver.onReceive:58 android.app.ActivityThread.handleReceiver:2629
D/TestService( 1021): onCreate
I/ActivityManagerService( 453): Start proc 1045:com.android.externalstorage/u0a5 for broadcast com.android.externalstorage/.MountReceiver
D/TestService( 1021): onStartCommand,from:app
D/StorageList( 1021): VolumnState:mounted
D/StorageList( 1021): Storage’paths:/mnt/internal_sd state:mounted
D/StorageList( 1021): VolumnState:removed
D/StorageList( 1021): Storage’paths:/mnt/external_sd state:removed
D/StorageList( 1021): Storage’paths:/mnt/usb_storage/USB_DISK0 state:removed
D/StorageList( 1021): Storage’paths:/mnt/usb_storage/USB_DISK1 state:removed
D/StorageList( 1021): Storage’paths:/mnt/usb_storage/USB_DISK2 state:removed
D/StorageList( 1021): Storage’paths:/mnt/usb_storage/USB_DISK3 state:removed
D/StorageList( 1021): Storage’paths:/mnt/usb_storage/USB_DISK4 state:removed
D/StorageList( 1021): Storage’paths:/mnt/usb_storage/USB_DISK5 state:removed
D/DeviceTest-FileUitls( 1021): find path:/mnt/internal_sd
D/DeviceTest-FileUitls( 1021): find path:/mnt/external_sd
D/DeviceTest-FileUitls( 1021): find path:/mnt/usb_storage/USB_DISK0
D/DeviceTest-FileUitls( 1021): find path:/mnt/usb_storage/USB_DISK1
D/DeviceTest-FileUitls( 1021): find path:/mnt/usb_storage/USB_DISK2
D/DeviceTest-FileUitls( 1021): find path:/mnt/usb_storage/USB_DISK3
D/DeviceTest-FileUitls( 1021): find path:/mnt/usb_storage/USB_DISK4
D/DeviceTest-FileUitls( 1021): find path:/mnt/usb_storage/USB_DISK5
D/DeviceTest-FileUitls( 1021): find file:/mnt/internal_sd/LOST.DIR
D/DeviceTest-FileUitls( 1021): find file:/mnt/internal_sd/.android_secure
D/DeviceTest-FileUitls( 1021): find file:/mnt/internal_sd/Music
D/DeviceTest-FileUitls( 1021): find file:/mnt/internal_sd/Podcasts
D/DeviceTest-FileUitls( 1021): find file:/mnt/internal_sd/Ringtones
D/DeviceTest-FileUitls( 1021): find file:/mnt/internal_sd/Alarms
D/DeviceTest-FileUitls( 1021): find file:/mnt/internal_sd/Notifications
D/DeviceTest-FileUitls( 1021): find file:/mnt/internal_sd/Pictures
D/DeviceTest-FileUitls( 1021): find file:/mnt/internal_sd/Movies
D/DeviceTest-FileUitls( 1021): find file:/mnt/internal_sd/Download
D/DeviceTest-FileUitls( 1021): find file:/mnt/internal_sd/DCIM
D/DeviceTest-FileUitls( 1021): find file:/mnt/internal_sd/.estrongs
D/DeviceTest-FileUitls( 1021): find file:/mnt/internal_sd/backups
D/DeviceTest-FileUitls( 1021): find file:/mnt/internal_sd/Android
D/DeviceTest-FileUitls( 1021): find file:/mnt/internal_sd/.userReturn
D/TestService( 1021): no DeviceTest.apk
V/TestService( 1021): isSystemReady()=trueisBootComplete()=false
D/TestService( 1021): check home ,if need will set default home
E/CameraHal_Marvin( 166): HAL-MOCKUP: PHY ADDR (0x10000000),iommu addr (0x10000000)
E/CameraHal_Marvin( 166): HAL-MOCKUP: PHY ADDR (0x1133b000),iommu addr (0x1133b000)
E/CameraHal_Marvin( 166): HAL-MOCKUP: PHY ADDR (0x12676000),iommu addr (0x12676000)
E/CameraHal_Marvin( 166): HAL-MOCKUP: PHY ADDR (0x139b1000),iommu addr (0x139b1000)
E/CameraHal_Marvin( 166): OV5640: OV5640_IsiMdiFocusSet: Position:1
E/CameraHal_Marvin( 166): ADPF: AdpfStart: Can’t enable CamerIc DPF (8)
E/CameraHal_Marvin( 166): ADPCC: AdpccStart: Can’t enable CamerIc DPCC (8)
D/CameraHal( 166): enableSensor(213): orientation = 0xb8262cc8 (MPL accel)
V/Sensors ( 453): setDelay - sensor Accelerometer (handle 4), rate 20 ms (50.00 Hz)
W/CameraService( 166): CameraService::connect X (id 0, this pid is 166, name media)
D/CameraHal( 166): commandThread(983): commandThread(983): receive CMD_PREVIEW_CAPTURE_CANCEL
D/CameraHal( 166): commandThread(991): commandThread(991): CMD_PREVIEW_CAPTURE_CANCEL out
D/CameraHal( 166): cancelPicture(561): cancel picture OK.
D/CameraHal( 166): commandThread(911): commandThread(911):receive CMD_PREVIEW_STOP
D/CameraHal( 166): commandThread(932): commandThread(932): CMD_PREVIEW_STOP out
D/CameraHal( 166): stopPreview(362): stop preview OK.
I/CameraClient( 166): Destroying camera 0
D/CameraHal( 166): camera_device_close(451): camera_device_close
D/CameraHal( 166): disableSensor(237): orientation = 0xb8262cc8 (MPL accel)
D/CameraHal( 166): ~SensorListener(110): Kill looper thread
D/CameraHal( 166): ~SensorListener(122): Kill looper
D/CameraHal( 166): ~SensorListener(128): SensorListener destroyed
D/CameraHal( 166): displayThread(622): displayThread(622): receive CMD_DISPLAY_STOP
D/CameraHal( 166): cameraDisplayBufferDestory(399): cameraDisplayBufferDestory(399): mANativeWindow is NULL, destory is ignore
D/CameraHal( 166): encProcessThread(1632): encProcessThread(1632): receive CMD_ENCPROCESS_EXIT
I/vpu_mem_pool( 166): pid 166, close_vpu_memory_pool:501: vpu memory pool size (720000)
I/vpu_mem_pool( 166): pid 166, close_vpu_memory_pool:501: vpu memory pool size (640000)
I/vpu_mem_pool( 166): pid 166, close_vpu_memory_pool:501: vpu memory pool size (560000)
I/vpu_mem_pool( 166): pid 166, close_vpu_memory_pool:501: vpu memory pool size (480000)
I/vpu_mem_pool( 166): pid 166, close_vpu_memory_pool:501: vpu memory pool size (400000)
I/vpu_mem_pool( 166): pid 166, close_vpu_memory_pool:501: vpu memory pool size (320000)
I/vpu_mem_pool( 166): pid 166, close_vpu_memory_pool:501: vpu memory pool size (240000)
I/vpu_mem_pool( 166): pid 166, close_vpu_memory_pool:501: vpu memory pool size (160000)
I/vpu_mem_pool( 166): pid 166, close_vpu_memory_pool:501: vpu memory pool size (80000)
I/vpu_mem_pool( 166): pid 166, close_vpu_memory_pool:501: vpu memory pool size (0)
I/vpu_mem_pool( 166): pid 166, close_vpu_memory_pool:552:
D/DisplayManager( 1045): getDisplayInfo: displayId=0, info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 720 x 1184, real 720 x 1280, largest app 1280 x 1134, smallest app 720 x 574, 59.527 fps, supportedRefreshRates [59.527], rotation 0, density 320 (160.42105 x 160.15764) dpi, layerStack 0, appVsyncOff 0, presDeadline 17799099, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
E/CameraHal_Marvin( 166): OV5640: OV5640_IsiMdiFocusSet: Position:0
E/CameraHal_Marvin( 166): OV5640: OV5640_IsiMdiFocusSet: download firmware and one shot focus failed
D/TestService( 1021): factoryFilePath: agingFilePath: externalStorageFilePath:/mnt/internal_sd
I/chip.devicetest( 1021): type=1400 audit(0.0:15): avc: denied { write } for name=“force_usb_mode” dev=“sysfs” ino=14564 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
D/TestService( 1021): onDestroy
D/ExternalStorage( 1045): After updating volumes, found 1 active roots
D/MediaScannerReceiver( 558): action: android.intent.action.MEDIA_MOUNTED path: /mnt/internal_sd
D/RKUpdateReceiver( 649): action = android.intent.action.MEDIA_MOUNTED
I/ActivityManagerService( 453): Start proc 1069:com.estrongs.android.pop/u0a41 for broadcast com.estrongs.android.pop/.EnableOEMConfig
W/PhoneWindowManager( 453): Keyguard drawn timeout. Setting mKeyguardDrawComplete
D/CameraHal( 166): commandThread(1095): commandThread(1095): receive CMD_EXIT
D/CameraHal( 166): ~CameraHal(293): CameraHal destory success
W/CameraService( 166): removeClient: clear camera 0, package name media
D/MediaScannerService( 558): start scanning volume external: [/mnt/internal_sd]
W/MediaProvider( 558): no database for scanned volume external
D/DisplayManager( 1069): getDisplayInfo: displayId=0, info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 720 x 1184, real 720 x 1280, largest app 1280 x 1134, smallest app 720 x 574, 59.527 fps, supportedRefreshRates [59.527], rotation 0, density 320 (160.42105 x 160.15764) dpi, layerStack 0, appVsyncOff 0, presDeadline 17799099, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
E/SQLiteLog( 558): (283) recovered 98 frames from WAL file /data/data/com.android.providers.media/databases/external-ffffffff.db-wal
D/UserManager( 594): —getMaxSupportedUsers,we has UMS,force disabled M-user—
D/OpenGLRenderer( 594): Use EGL_SWAP_BEHAVIOR_PRESERVED: true
D/Atlas ( 594): Validating map…
W/Atlas ( 594): Pointer 0x0, not in getPreloadedDrawables?
I/System.out( 594): ============================================================FourScreenCircleMenuView
D/PhoneStatusBar( 594): disable: < EXPAND* icons alerts system_info BACK* HOME* RECENT* clock SEARCH* >
D/PhoneStatusBar( 594): heads up is enabled
V/KeyguardUpdateMonitor( 594): action android.intent.action.SIM_STATE_CHANGED state: NOT_READY slotId: 0 subid: 0
D/MediaScanner( 558): Skipping: /mnt/internal_sd/Android/
I/mali_so ( 594): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 780; [Func] : base_context_deal_with_version_affairs_rk_ext;
I/mali_so ( 594): arm_release_ver of this mali_so is ‘r6p0-02rel0’, rk_so_ver is ‘11@0’, built at ‘15:38:28’ for 3288w, on ‘Aug 2 2016’.
I/mali_so ( 594): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 807; [Func] : base_context_deal_with_version_affairs_rk_ext;
I/mali_so ( 594): mali_ver_property has been set to ‘r6p0-02rel0-13-11@0’, to return.
D/ViewRootImpl( 807): 720<<<<<< BACK FROM relayoutnull
D/MediaScannerService( 558): done scanning volume external
I/SurfaceFlinger( 156): Boot is finished (9217 ms)
I/Choreographer( 594): Skipped 104 frames! The application may be doing too much work on its main thread.
D/ViewRootImpl( 594): changeCanvasOpacity: opaque=true
D/mmk ( 594): updateCallbackLocked.+++++++
D/mmk ( 594): postSingleUpdate.+++++++++ status = 1
D/ViewRootImpl( 594): onAttachToWindow register content observer attrs=WM.LayoutParams{(0,0)(fillx50)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 gr=#30 sim=#10 ty=2000 fl=#81840048 fmt=-3 surfaceInsets=Rect(0, 0 - 0, 0)packageName=com.android.systemuitoken=null}
D/ViewRootImpl( 594): 720<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillx50)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 gr=#30 sim=#10 ty=2000 fl=#81840048 fmt=-3 surfaceInsets=Rect(0, 0 - 0, 0)packageName=com.android.systemuitoken=null}
I/OpenGLRenderer( 594): Initialized EGL, version 1.4
D/OpenGLRenderer( 594): Enabling debug mode 0
D/ViewRootImpl( 594): onAttachToWindow register content observer attrs=WM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 gr=#800053 sim=#31 ty=2024 fl=#1820100 fmt=-3 surfaceInsets=Rect(0, 0 - 0, 0)packageName=com.android.systemuitoken=null}
D/ViewRootImpl( 594): 720<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 gr=#800053 sim=#31 ty=2024 fl=#1820100 fmt=-3 surfaceInsets=Rect(0, 0 - 0, 0)packageName=com.android.systemuitoken=null}
D/ViewRootImpl( 594): onAttachToWindow register content observer attrs=WM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 ty=2019 fl=#1840068 fmt=-3 surfaceInsets=Rect(0, 0 - 0, 0)packageName=com.android.systemuitoken=null}
D/ViewRootImpl( 594): 720<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 sim=#20 ty=2019 fl=#1840068 fmt=-3 surfaceInsets=Rect(0, 0 - 0, 0)packageName=com.android.systemuitoken=null}
D/ViewRootImpl( 594): onAttachToWindow register content observer attrs=WM.LayoutParams{(0,0)(fillx500)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 gr=#30 ty=2014 fl=#1820328 fmt=-3 wanim=0x7f0b002e surfaceInsets=Rect(0, 0 - 0, 0)packageName=com.android.systemuitoken=null}
D/ViewRootImpl( 594): 720<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillx500)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=-1 gr=#30 sim=#20 ty=2014 fl=#1820328 fmt=-3 wanim=0x7f0b002e surfaceInsets=Rect(0, 0 - 0, 0)packageName=com.android.systemuitoken=null}
D/PhoneStatusBar( 594): disable: < expand* icons alerts system_info back* home* recent* clock search* >
W/Vold ( 155): subsystem found in netlink event
D/Vold ( 155): handleEvent usb, 1
D/Vold ( 155): == current usb device: 2C7C/0125 ===
D/UsbHostManager( 453): Added device UsbDevice[mName=/dev/bus/usb/004/002,mVendorId=11388,mProductId=293,mClass=239,mSubclass=2,mProtocol=1,mManufacturerName=Android,mProductName=Android,mSerialNumber=null,mConfigurations=[
D/UsbHostManager( 453): UsbConfiguration[mId=1,mName=null,mAttributes=160,mMaxPower=250,mInterfaces=[
D/UsbHostManager( 453): UsbInterface[mId=0,mAlternateSetting=0,mName=null,mClass=255,mSubclass=255,mProtocol=255,mEndpoints=[
D/UsbHostManager( 453): UsbEndpoint[mAddress=129,mAttributes=2,mMaxPacketSize=512,mInterval=0]
D/UsbHostManager( 453): UsbEndpoint[mAddress=1,mAttributes=2,mMaxPacketSize=512,mInterval=0]]
D/UsbHostManager( 453): UsbInterface[mId=1,mAlternateSetting=0,mName=null,mClass=255,mSubclass=0,mProtocol=0,mEndpoints=[
D/UsbHostManager( 453): UsbEndpoint[mAddress=131,mAttributes=3,mMaxPacketSize=10,mInterval=9]
D/UsbHostManager( 453): UsbEndpoint[mAddress=130,mAttributes=2,mMaxPacketSize=512,mInterval=0]
D/UsbHostManager( 453): UsbEndpoint[mAddress=2,mAttributes=2,mMaxPacketSize=512,mInterval=0]]
D/UsbHostManager( 453): UsbInterface[mId=2,mAlternateSetting=0,mName=null,mClass=255,mSubclass=0,mProtocol=0,mEndpoints=[
D/UsbHostManager( 453): UsbEndpoint[mAddress=133,mAttributes=3,mMaxPacketSize=10,mInterval=9]
D/UsbHostManager( 453): UsbEndpoint[mAddress=132,mAttributes=2,mMaxPacketSize=512,mInterval=0]
D/UsbHostManager( 453): UsbEndpoint[mAddress=3,mAttributes=2,mMaxPacketSize=512,mInterval=0]]
D/UsbHostManager( 453): UsbInterface[mId=3,mAlternateSetting=0,mName=null,mClass=255,mSubclass=0,mProtocol=0,mEndpoints=[
D/UsbHostManager( 453): UsbEndpoint[mAddress=135,mAttributes=3,mMaxPacketSize=10,mInterval=9]
D/UsbHostManager( 453): UsbEndpoint[mAddress=134,mAttributes=2,mMaxPacketSize=512,mInterval=0]
D/UsbHostManager( 453): UsbEndpoint[mAddress=4,mAttributes=2,mMaxPacketSize=512,mInterval=0]]
D/UsbHostManager( 453): UsbInterface[mId=4,mAlternateSetting=0,mName=null,mClass=255,mSubclass=255,mProtocol=255,mEndpoints=[
D/UsbHostManager( 453): UsbEndpoint[mAddress=137,mAttributes=3,mMaxPacketSize=8,mInterval=9]
D/UsbHostManager( 453): UsbEndpoint[mAddress=136,mAttributes=2,mMaxPacketSize=512,mInterval=0]
D/UsbHostManager( 453): UsbEndpoint[mAddress=5,mAttributes=2,mMaxPacketSize=512,mInterval=0]]]]
W/UsbSettingsManager( 453): no meta-data for ResolveInfo{2034092d com.estrongs.android.pop/.view.FileExplorerActivity m=0x108000}
W/ContextImpl( 453): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1344 com.android.server.usb.UsbSettingsManager.deviceAttached:741 com.android.server.usb.UsbHostManager.endUsbDeviceAdded:224 com.android.server.usb.UsbHostManager.monitorUsbHostBus:-2 com.android.server.usb.UsbHostManager.access$000:42
D/KeyguardUpdateMonitor( 594): handleSimStateChange(subId=0, slotId=0, state=NOT_READY)
D/OpenGLRenderer( 594): setting property extraRasterBucket to 0.95
D/OpenGLRenderer( 594): failed
D/OpenGLRenderer( 594): setting property extraRasterBucket to 0.0
V/KeyguardUpdateMonitor( 594): onSubscriptionInfoChanged()
V/KeyguardUpdateMonitor( 594): onSubscriptionInfoChanged: list is null
I/MultiDex( 1069): VM with version 2.1.0 has multidex support
I/MultiDex( 1069): install
I/MultiDex( 1069): VM has multidex support, MultiDex support library is disabled.
W/art ( 1069): Suspending all threads took: 20.002ms
I/ActivityManagerService( 453): Start proc 1113:com.estrongs.android.pop:local/u0a41 for service com.estrongs.android.pop/com.android.apps.pros.LocalCService
I/internationalization( 1069): 屏保 SDK V3.3 - 2016.11.22 - Trigger广告入口
D/DisplayManager( 1113): getDisplayInfo: displayId=0, info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 720 x 1184, real 720 x 1280, largest app 1280 x 1134, smallest app 720 x 574, 59.527 fps, supportedRefreshRates [59.527], rotation 0, density 320 (160.42105 x 160.15764) dpi, layerStack 0, appVsyncOff 0, presDeadline 17799099, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
I/internationalization( 1069): DuSwipe SDK V3.3 - 2016.11.22 - 去除拉绳、Adunlock、老虎机
W/ResourceType( 1069): No package identifier when getting value for resource number 0x00000000
D/BluetoothManagerService( 453): Added callback: android.bluetooth.IBluetoothManagerCallback$Stub$Proxy@21c18372:true
D/BluetoothManagerService( 453): checkIfCallerIsForegroundUser: valid=true callingUser=0 parentUser=-10000 foregroundUser=0
E/SQLiteLog( 1069): (1) no such table: app_folder_map_user
W/System.err( 1069): android.database.sqlite.SQLiteException: no such table: app_folder_map_user (code 1): , while compiling: SELECT folder FROM app_folder_map_user WHERE package_name=?
W/System.err( 1069): at android.database.sqlite.SQLiteConnection.nativePrepareStatement(Native Method)
W/System.err( 1069): at android.database.sqlite.SQLiteConnection.acquirePreparedStatement(SQLiteConnection.java:889)
W/System.err( 1069): at android.database.sqlite.SQLiteConnection.prepare(SQLiteConnection.java:500)
W/System.err( 1069): at android.database.sqlite.SQLiteSession.prepare(SQLiteSession.java:588)
W/System.err( 1069): at android.database.sqlite.SQLiteProgram.(SQLiteProgram.java:58)
W/System.err( 1069): at android.database.sqlite.SQLiteQuery.(SQLiteQuery.java:37)
W/System.err( 1069): at android.database.sqlite.SQLiteDirectCursorDriver.query(SQLiteDirectCursorDriver.java:44)
W/System.err( 1069): at android.database.sqlite.SQLiteDatabase.rawQueryWithFactory(SQLiteDatabase.java:1316)
W/System.err( 1069): at android.database.sqlite.SQLiteDatabase.queryWithFactory(SQLiteDatabase.java:1163)
W/System.err( 1069): at android.database.sqlite.SQLiteDatabase.query(SQLiteDatabase.java:1034)
W/System.err( 1069): at android.database.sqlite.SQLiteDatabase.query(SQLiteDatabase.java:1202)
W/System.err( 1069): at com.estrongs.android.appinfo.AppFolderInfoManager.i(Unknown Source)
W/System.err( 1069): at com.estrongs.fs.impl.c.a.a(Unknown Source)
W/System.err( 1069): at com.estrongs.android.a.j.i(Unknown Source)
W/System.err( 1069): at com.estrongs.android.scanner.b.b.c(Unknown Source)
W/System.err( 1069): at com.estrongs.android.scanner.b.b.d(Unknown Source)
W/System.err( 1069): at com.estrongs.android.scanner.c.n.a(Unknown Source)
W/System.err( 1069): at com.estrongs.android.scanner.l.b(Unknown Source)
W/System.err( 1069): at com.estrongs.android.scanner.service.k.run(Unknown Source)
W/System.err( 1069): at java.lang.Thread.run(Thread.java:818)
I/AppsFlyer_3.2( 1069): AsendTrackingWithEvent from activity: com.estrongs.android.pop.FexApplication
E/ActivityThread( 1069): Failed to find provider info for com.facebook.katana.provider.AttributionIdProvider
I/AppsFlyer_3.2( 1069): com.google.android.gms.common.GooglePlayServicesNotAvailableException
I/System.out( 1069): AppsFlyerLib.sendTrackingWithEvent
E/AppsFlyer_3.2-93147765( 1069): length=0; regionStart=0; regionLength=7
E/AppsFlyer_3.2-93147765( 1069): java.lang.StringIndexOutOfBoundsException: length=0; regionStart=0; regionLength=7
E/AppsFlyer_3.2-93147765( 1069): at java.lang.String.startEndAndLength(String.java:504)
E/AppsFlyer_3.2-93147765( 1069): at java.lang.String.substring(String.java:1333)
E/AppsFlyer_3.2-93147765( 1069): at com.appsflyer.HashUtils.a(Unknown Source)
E/AppsFlyer_3.2-93147765( 1069): at com.appsflyer.AppsFlyerLib$SendToServerRunnable.run(Unknown Source)
E/AppsFlyer_3.2-93147765( 1069): at com.appsflyer.AppsFlyerLib.c(Unknown Source)
E/AppsFlyer_3.2-93147765( 1069): at com.appsflyer.AppsFlyerLib.a(Unknown Source)
E/AppsFlyer_3.2-93147765( 1069): at com.appsflyer.AppsFlyerLib$DataCollector.run(Unknown Source)
E/AppsFlyer_3.2-93147765( 1069): at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:422)
E/AppsFlyer_3.2-93147765( 1069): at java.util.concurrent.FutureTask.run(FutureTask.java:237)
E/AppsFlyer_3.2-93147765( 1069): at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:152)
E/AppsFlyer_3.2-93147765( 1069): at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:265)
E/AppsFlyer_3.2-93147765( 1069): at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1112)
E/AppsFlyer_3.2-93147765( 1069): at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:587)
E/AppsFlyer_3.2-93147765( 1069): at java.lang.Thread.run(Thread.java:818)
E/SQLiteLog( 1069): (1) no such table: folder_table
I/MultiDex( 1113): VM with version 2.1.0 has multidex support
I/MultiDex( 1113): install
I/MultiDex( 1113): VM has multidex support, MultiDex support library is disabled.
W/System.err( 1069): java.lang.InterruptedException
W/System.err( 1069): at at at java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.reportInterruptAfterWait(AbstractQueuedSynchronizer.java:1991)
W/System.err( 1069): at java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.reportInterruptAfterWait(AbstractQueuedSynchronizer.java:1991)
W/System.err( 1069): at java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.await(AbstractQueuedSynchronizer.java:2025)
W/System.err( 1069): at java.util.concurrent.LinkedBlockingQueue.take(LinkedBlockingQueue.java:410)
W/System.err( 1069): at com.estrongs.android.scanner.al.run(Unknown Source)
W/System.err( 1069): at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1112)
W/System.err( 1069): java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1112)
W/System.err( 1069): at at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:587)
W/System.err( 1069): at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:587)
W/System.err( 1069): java.lang.Thread.run(Thread.java:818)
W/System.err( 1069): java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.reportInterruptAfterWait(AbstractQueuedSynchronizer.java:1991)
I/ActivityManagerService( 453): Start proc 1201:.esfm/u0a41 for service com.estrongs.android.pop/com.estrongs.android.scanner.service.FileMonitorService
D/DisplayManager( 1201): getDisplayInfo: displayId=0, info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 720 x 1184, real 720 x 1280, largest app 1280 x 1134, smallest app 720 x 574, 59.527 fps, supportedRefreshRates [59.527], rotation 0, density 320 (160.42105 x 160.15764) dpi, layerStack 0, appVsyncOff 0, presDeadline 17799099, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
I/SystemServiceManager( 453): Starting phase 1000
V/WindowManagerService( 453): Not allow rotate, force to ROTATION_0
I/RecoverySystem( 453): No recovery log file
I/BootReceiver( 453): Copying /proc/last_kmsg to DropBox (SYSTEM_LAST_KMSG)
I/ActivityManagerService( 453): Start proc 1224:com.android.keychain/1000 for service com.android.keychain/.KeyChainService
I/BootReceiver( 453): Copying audit failures to DropBox
I/BootReceiver( 453): Copied 0 worth of audits to DropBox
I/ActivityManagerService( 453): Start proc 1242:com.android.settings/1000 for broadcast com.android.settings/.HdmiReceiver
I/BootReceiver( 453): Checking for fsck errors
D/DisplayManager( 1224): getDisplayInfo: displayId=0, info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 720 x 1184, real 720 x 1280, largest app 1280 x 1134, smallest app 720 x 574, 59.527 fps, supportedRefreshRates [59.527], rotation 0, density 320 (160.42105 x 160.15764) dpi, layerStack 0, appVsyncOff 0, presDeadline 17799099, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
D/DisplayManager( 1242): getDisplayInfo: displayId=0, info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 720 x 1184, real 720 x 1280, largest app 1280 x 1134, smallest app 720 x 574, 59.527 fps, supportedRefreshRates [59.527], rotation 0, density 320 (160.42105 x 160.15764) dpi, layerStack 0, appVsyncOff 0, presDeadline 17799099, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
E/DisplayOutputManager( 1242): Error listing main interfaces :java.lang.NullPointerException: Attempt to get length of null array
D/DisplayOutputManager( 1242): aux display iface num is 1
D/DisplayOutputManager( 1242): HDMI
D/HdmiReceiver( 1242): hdmi receiver action=android.intent.action.BOOT_COMPLETED
D/HdmiReceiver( 1242): BOOT_COMPLETED
D/StressTest( 680): =========onReceive===rebootFlag:0
E/SystemUIBootReceiver( 594): BootReceiver:config.disable_systemui=true
V/TestService( 1021): action:android.intent.action.BOOT_COMPLETED
V/TestService( 1021): getSystemAbnormalRestartTime0:8
V/TestService( 1021): setSystemStart0:true
V/TestService( 1021): SystemUtils.isBootComplete()=true
V/TestService( 1021): setLastShutDownIsUnsafety =false
V/TestService( 1021): setSystemStart1:true
W/ContextImpl( 1021): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1709 android.content.ContextWrapper.startService:516 android.content.ContextWrapper.startService:516 com.rockchip.devicetest.BootReceiver.onReceive:85 android.app.ActivityThread.handleReceiver:2629
V/TestService( 1021): getSystemAbnormalRestartTime1:9
D/WIFI ( 453): Registering NetworkFactory
D/WIFI_UT ( 453): Registering NetworkFactory
D/ConnectivityService( 453): Got NetworkFactory Messenger for WIFI
D/ConnectivityService( 453): Got NetworkFactory Messenger for WIFI_UT
D/WIFI ( 453): got request NetworkRequest [ id=1, legacyType=-1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 0
D/WIFI_UT ( 453): got request NetworkRequest [ id=1, legacyType=-1, [ Capabilities: INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN] ] with score 0
I/ActivityManagerService( 453): Start proc 1269:com.android.providers.calendar/u0a1 for broadcast com.android.providers.calendar/.CalendarReceiver
I/art ( 170): Explicit concurrent mark sweep GC freed 704(30KB) AllocSpace objects, 0(0B) LOS objects, 39% free, 1861KB/3MB, paused 127us total 6.799ms
D/TestService( 1021): onStartCommand,from:boot
I/art ( 170): Explicit concurrent mark sweep GC freed 5(160B) AllocSpace objects, 0(0B) LOS objects, 39% free, 1861KB/3MB, paused 108us total 6.320ms
I/art ( 170): Explicit concurrent mark sweep GC freed 5(160B) AllocSpace objects, 0(0B) LOS objects, 39% free, 1861KB/3MB, paused 109us total 5.671ms
D/DisplayManager( 1269): getDisplayInfo: displayId=0, info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 720 x 1184, real 720 x 1280, largest app 1280 x 1134, smallest app 720 x 574, 59.527 fps, supportedRefreshRates [59.527], rotation 0, density 320 (160.42105 x 160.15764) dpi, layerStack 0, appVsyncOff 0, presDeadline 17799099, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
D/TestService( 1021): Rock Recv boot action. 13719
W/ResourcesManager( 1269): Asset path ‘/system/framework/android.test.runner.jar’ does not exist or contains no resources.
D/TestService( 1021): Rock check storage inter_path=/mnt/internal_sd
D/TestService( 1021): Rock check storage, mounted.
I/MultiDex( 1201): VM with version 2.1.0 has multidex support
I/MultiDex( 1201): install
I/MultiDex( 1201): VM has multidex support, MultiDex support library is disabled.
I/CalendarProvider2( 1269): Created com.android.providers.calendar.CalendarAlarmManager@36c3eab6(com.android.providers.calendar.CalendarProvider2@1b293b7)
I/ActivityManagerService( 453): Start proc 1293:com.android.managedprovisioning/u0a6 for broadcast com.android.managedprovisioning/.BootReminder
D/DisplayManager( 1293): getDisplayInfo: displayId=0, info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 720 x 1184, real 720 x 1280, largest app 1280 x 1134, smallest app 720 x 574, 59.527 fps, supportedRefreshRates [59.527], rotation 0, density 320 (160.42105 x 160.15764) dpi, layerStack 0, appVsyncOff 0, presDeadline 17799099, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
D/MediaScannerService( 558): start scanning volume internal: [/system/media, /oem/media]
D/xzj ( 558): false---------------------------ooooooooooo,stop mtp service---------------false
E/SQLiteLog( 558): (283) recovered 8 frames from WAL file /data/data/com.android.providers.media/databases/internal.db-wal
I/ActivityManagerService( 453): Start proc 1320:com.android.onetimeinitializer/u0a7 for broadcast com.android.onetimeinitializer/.OneTimeInitializerReceiver
W/MediaScanner( 558): Error opening directory ‘/oem/media/’, skipping: No such file or directory.
D/MediaScannerService( 558): done scanning volume internal
D/MediaScannerService( 558): start scanning volume external: [/mnt/external_sd]
D/DisplayManager( 1320): getDisplayInfo: displayId=0, info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 720 x 1184, real 720 x 1280, largest app 1280 x 1134, smallest app 720 x 574, 59.527 fps, supportedRefreshRates [59.527], rotation 0, density 320 (160.42105 x 160.15764) dpi, layerStack 0, appVsyncOff 0, presDeadline 17799099, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
W/MediaScanner( 558): Error opening directory ‘/mnt/external_sd/’, skipping: Permission denied.
V/OneTimeInitializerRece( 1320): OneTimeInitializerReceiver.onReceive
D/MediaScannerService( 558): start scanning volume external: [/mnt/usb_storage]
I/ActivityManagerService( 453): Start proc 1341:com.android.calendar/u0a15 for broadcast com.android.calendar/.alerts.AlertReceiver
D/DisplayManager( 1341): getDisplayInfo: displayId=0, info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 720 x 1184, real 720 x 1280, largest app 1280 x 1134, smallest app 720 x 574, 59.527 fps, supportedRefreshRates [59.527], rotation 0, density 320 (160.42105 x 160.15764) dpi, layerStack 0, appVsyncOff 0, presDeadline 17799099, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
I/CalendarProvider2( 1269): Sending notification intent: Intent { act=android.intent.action.PROVIDER_CHANGED dat=content://com.android.calendar }
W/ContentResolver( 1269): Failed to get type for: content://com.android.calendar (Unknown URL content://com.android.calendar)
D/ExtensionsFactory( 1341): No custom extensions.
D/AlertReceiver( 1341): onReceive: a=android.intent.action.BOOT_COMPLETED Intent { act=android.intent.action.BOOT_COMPLETED flg=0x8000010 cmp=com.android.calendar/.alerts.AlertReceiver (has extras) }
I/ActivityManagerService( 453): Start proc 1365:com.android.deskclock/u0a19 for broadcast com.android.deskclock/.AlarmInitReceiver
D/AlertService( 1341): 0 Action = android.intent.action.BOOT_COMPLETED
D/DisplayManager( 1365): getDisplayInfo: displayId=0, info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 720 x 1184, real 720 x 1280, largest app 1280 x 1134, smallest app 720 x 574, 59.527 fps, supportedRefreshRates [59.527], rotation 0, density 320 (160.42105 x 160.15764) dpi, layerStack 0, appVsyncOff 0, presDeadline 17799099, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
D/AlertService( 1341): Scheduling next alarm with AlarmScheduler. sEventReminderReceived: null
D/AlarmScheduler( 1341): No events found starting within 1 week.
V/AlarmClock( 1365): AlarmInitReceiver android.intent.action.BOOT_COMPLETED
V/AlarmClock( 1365): AlarmInitReceiver - Reset timers and clear stopwatch data
V/AlarmClock( 1365): AlarmInitReceiver finished
I/LauncherIconVisibilityManager( 702): Boot has been completed
I/LauncherIconVisibilityManager( 702): Activity has already been disabled: ComponentInfo{com.android.inputmethod.latin/com.android.inputmethod.latin.setup.SetupActivity}
D/RKUpdateReceiver( 649): action = android.intent.action.BOOT_COMPLETED
D/RKUpdateReceiver( 649): RKUpdateReceiver recv ACTION_BOOT_COMPLETED.
W/ContextImpl( 649): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1709 android.content.ContextWrapper.startService:516 android.content.ContextWrapper.startService:516 android.rockchip.update.service.RKUpdateReceiver.onReceive:59 android.app.ActivityThread.handleReceiver:2629
W/ContextImpl( 649): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1709 android.content.ContextWrapper.startService:516 android.content.ContextWrapper.startService:516 android.rockchip.update.service.RKUpdateReceiver.onReceive:65 android.app.ActivityThread.handleReceiver:2629
D/AlertReceiver( 1341): onReceive: a=android.intent.action.PROVIDER_CHANGED Intent { act=android.intent.action.PROVIDER_CHANGED dat=content://com.android.calendar flg=0x10 cmp=com.android.calendar/.alerts.AlertReceiver }
D/AlertService( 1341): 0 Action = android.intent.action.PROVIDER_CHANGED
I/android_rockchip_update_UpdateService.cpp( 649): JNI_OnLoad
D/RKUpdateService( 649): starting RKUpdateService, version is 1.8.1
D/RKUpdateService( 649): remote uri is http://www.rockchip.com:2300/OtaUpdater/android?product=RT6000S&version=1.0.0&sn=GB8ZAB4TRD&country=CN&language=zh
D/RKUpdateService( 649): remote uri backup is http://192.168.1.143:2300/OtaUpdater/android?product=RT6000S&version=1.0.0&sn=GB8ZAB4TRD&country=CN&language=zh
D/RKUpdateService( 649): first startup!!!
D/RKUpdateService( 649): onStartCommand…
D/RKUpdateService( 649): command = 1 delaytime = 20000
D/RKUpdateService( 649): command = 2 delaytime = 25000
D/SurfaceFlinger( 156): shader cache generated - 24 shaders in 211.024918 ms
I/Telephony( 787): PstnIncomingCallNotifier: Unregistering: Handler (com.android.internal.telephony.gsm.GSMPhone) {160847e4}
D/TestService( 1021): It is not in factory/aging test mode.
W/ActivityManagerService( 453): getTasks: caller 10041 does not hold GET_TASKS; limiting output
I/sh ( 1400): type=1400 audit(0.0:16): avc: denied { write } for name=“control” dev=“sysfs” ino=17801 scontext=u:r:rild:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
V/KeyguardUpdateMonitor( 594): action android.intent.action.SIM_STATE_CHANGED state: ABSENT slotId: 0 subid: 0
D/KeyguardUpdateMonitor( 594): handleSimStateChange(subId=0, slotId=0, state=ABSENT)
E/SQLiteLog( 1269): (284) automatic index on view_events(_id)
I/GlobalDismissManager( 1341): no sender configured
D/AlertService( 1341): Beginning updateAlertNotification
D/AlertService( 1341): No fired or scheduled alerts
I/ActivityManagerService( 453): Waited long enough for: ServiceRecord{2d09405b u0 com.estrongs.android.pop/com.android.apps.pros.LocalCService}
I/ActivityManagerService( 453): Waited long enough for: ServiceRecord{16758100 u0 com.android.calendar/.alerts.InitAlarmsService}
I/ActivityManagerService( 453): Waited long enough for: ServiceRecord{23561d39 u0 android.rockchip.update.service/.RKUpdateService}
W/AudioTrack( 453): AUDIO_OUTPUT_FLAG_FAST denied by client
D/AudioHardwareTiny( 166): start_output_stream
D/AudioHardwareTiny( 166): Device : 0x80400
D/AudioHardwareTiny( 166): SampleRate : 44100
D/AudioHardwareTiny( 166): Channels : 2
D/AudioHardwareTiny( 166): Formate : 0
D/AudioHardwareTiny( 166): PreiodSize : 2048
D/AudioHardwareTiny( 166): The current HDMI is DVI mode
E/AudioHardwareTiny( 166): pcm_open(PCM_CARD_SPDIF) failed: cannot open device ‘/dev/snd/pcmC1D0p’: No such file or directory
I/ActivityStackSupervisor( 453): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=com.android.camera2/com.android.camera.CameraLauncher (has extras)} from uid 10027 on display 0
I/System.out( 453): com.android.camera.CameraActivityaddAppToken taskId:10
D/WindowManagerService( 453): null ==========setInputFocusLw ========== =======
D/PhoneWindow( 453): DecorView - SCREEN_WEITH = 720 - SCREE_HEIGHT = 1184
D/TypefaceImpl( 453): makeFontCollection adding /system/fonts/Roboto-Regular.ttf
E/Minikin ( 453): addFont failed to create font /system/fonts/NanumGothic.ttf
E/Minikin ( 453): addFont failed to create font /system/fonts/DroidSansFallback.ttf
I/ActivityManagerService( 453): Start proc 1413:com.android.camera2/u0a16 for activity com.android.camera2/com.android.camera.CameraLauncher
W/art ( 453): Long monitor contention event with owner method=void com.android.server.am.ActivityManagerService.attachApplication(android.app.IApplicationThread) from ActivityManagerService.java:6278 waiters=1 for 106ms
D/DisplayManager( 1413): getDisplayInfo: displayId=0, info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 720 x 1184, real 720 x 1280, largest app 1280 x 1134, smallest app 720 x 574, 59.527 fps, supportedRefreshRates [59.527], rotation 0, density 320 (160.42105 x 160.15764) dpi, layerStack 0, appVsyncOff 0, presDeadline 17799099, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
D/OpenGLRenderer( 453): Use EGL_SWAP_BEHAVIOR_PRESERVED: true
D/Atlas ( 453): Validating map…
W/Atlas ( 453): Pointer 0x0, not in getPreloadedDrawables?
V/WindowManagerService( 453): Adding window Window{8200763 u0 Starting com.android.camera2} at 2 of 7 (after Window{209b2cf5 u0 com.android.launcher3/com.android.launcher3.Launcher EXITING})
D/ViewRootImpl( 453): onAttachToWindow register content observer attrs=WM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=10 ty=3 fl=#81830518 pfl=0x12 wanim=0x1030469 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.android.camera2token=Token{1ef1753a ActivityRecord{3b412465 u0 com.android.camera2/com.android.camera.CameraLauncher t10}}}
E/EmojiFactory_jni( 453): Failed to load libemoji.so: dlopen failed: library “libemoji.so” not found
D/ViewRootImpl( 453): 720<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=10 sim=#20 ty=3 fl=#81830518 pfl=0x12 wanim=0x1030469 vsysui=0x600 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.android.camera2token=Token{1ef1753a ActivityRecord{3b412465 u0 com.android.camera2/com.android.camera.CameraLauncher t10}}}
I/OpenGLRenderer( 453): Initialized EGL, version 1.4
D/OpenGLRenderer( 453): Enabling debug mode 0
D/CAM_MemoryManagerImpl( 1413): Max native memory: 358 MB
V/CAM_QuickActivity( 1413): START onCreate: Activity = com.android.camera.CameraActivity@229a84db
V/CAM_QuickActivity( 1413): Intent Action = android.intent.action.MAIN
D/RKUpdateService( 649): WorkHandler::handleMessage() : To perform ‘COMMAND_CHECK_LOCAL_UPDATING’.
D/RKUpdateService( 649): getValidFirmwareImageFile() : Target image file path : /data/media/0/update.zip
D/RKUpdateService( 649): getValidFirmwareImageFile() : Target image file path : /mnt/internal_sd/update.zip
D/RKUpdateService( 649): getValidFirmwareImageFile() : Target image file path : /mnt/external_sd/update.zip
D/RKUpdateService( 649): getValidFirmwareImageFile() : Target image file path : /mnt/usb_storage/update.zip
I/CameraManagerGlobal( 1413): getCameraService: Reconnecting to camera service
D/mmk ( 1413): onStatusChangedLocked.+++++++
E/CameraManagerGlobal( 1413): Camera id 0 has status changed to 0x1
D/DisplayManager( 594): getDisplayInfo: displayId=0, info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 720 x 1184, real 720 x 1280, largest app 1280 x 1134, smallest app 720 x 574, 59.527 fps, supportedRefreshRates [59.527], rotation 0, density 320 (160.42105 x 160.15764) dpi, layerStack 0, appVsyncOff 0, presDeadline 17799099, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
D/PhoneWindow( 1413): DecorView - SCREEN_WEITH = 720 - SCREE_HEIGHT = 1184
I/System.out( 1413): action Title!
D/CAM_LocationManager( 1413): Using legacy location provider.
D/SensorManager( 1413): aidl getSensorManager:null
V/CAM_SettingsManager( 1413): listeners: [com.android.camera.app.CameraAppUI@2752196]
V/CAM_SettingsManager( 1413): listeners: [com.android.camera.app.CameraAppUI@2752196, com.android.camera.ButtonManager@ebd0eed]
V/CAM_SettingsManager( 1413): listeners: [com.android.camera.app.CameraAppUI@2752196, com.android.camera.ButtonManager@ebd0eed, com.android.camera.widget.IndicatorIconController@265bc7b3]
D/CAM_Storage( 1413): External storage state=mounted
V/CAM_CameraController( 1413): requestCamera
V/CAM_CameraController( 1413): checkAndOpenCamera
I/CAM2PORT_AndCamAgntImp( 1413): Opening camera 0 with camera1 API
W/AudioFlinger( 166): acquireAudioSessionId() unknown client 1413 for session 11
I/AwesomePlayer( 166): AwesomePlayer::AwesomePlayer()in
I/AwesomePlayer( 166): AwesomePlayer::AwesomePlayer()aftermClient.connect()
E/NFC ( 1413): could not retrieve NFC service
V/CAM_QuickActivity( 1413): END onCreate: Activity = com.android.camera.CameraActivity@229a84db
V/CAM_QuickActivity( 1413): START onStart: Activity = com.android.camera.CameraActivity@229a84db
I/OMXCodec( 166): —>InstantiateSoftwareCodec create OMX.google.vorbis.decoder codec
I/OMXCodec( 166): Successfully allocated OMX node ‘OMX.google.vorbis.decoder’
W/AudioFlinger( 166): acquireAudioSessionId() unknown client 1413 for session 12
V/CAM_QuickActivity( 1413): END onStart: Activity = com.android.camera.CameraActivity@229a84db
V/CAM_QuickActivity( 1413): START onResume: Activity = com.android.camera.CameraActivity@229a84db
V/CAM_CameraActivity( 1413): Build info: rk3288_box-userdebug 5.1.1 LMY49F eng.hk.20181127.232142 test-keys
V/CAM_QuickActivity( 1413): END onResume: Activity = com.android.camera.CameraActivity@229a84db
E/CameraManagerGlobal( 1413): Camera id 0 has status changed to 0x80000000
D/mmk ( 594): postSingleUpdate.+++++++++ status = -2147483648
D/CameraHal( 166): Calling process is: com.android.camera2
I/vpu_mem_pool( 166): pid 166, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 43
I/vpu_mem_pool( 166): pid 166, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 49
I/vpu_mem_pool( 166): pid 166, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 50
I/vpu_mem_pool( 166): pid 166, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 51
I/vpu_mem_pool( 166): pid 166, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 52
I/vpu_mem_pool( 166): pid 166, vpu_mem_allocator:720: ion_alloc_fd success, memory fd 53
D/OpenGLRenderer( 1413): Use EGL_SWAP_BEHAVIOR_PRESERVED: true
V/CAM_CameraDataAdapter( 1413): retrieved photo metadata, number of items: 1
D/Atlas ( 1413): Validating map…
V/CAM_CameraDataAdapter( 1413): retrieved video metadata, number of items: 0
W/Atlas ( 1413): Pointer 0x0, not in getPreloadedDrawables?
V/CAM_CameraDataAdapter( 1413): sorting video/photo metadata
V/CAM_CameraDataAdapter( 1413): sorted video/photo metadata
V/WindowManagerService( 453): Adding window Window{ed18f53 u0 com.android.camera2/com.android.camera.CameraLauncher} at 2 of 8 (before Window{8200763 u0 Starting com.android.camera2})
V/CAM_CameraActivity( 1413): ignoring storage callback after activity pause
D/ViewRootImpl( 1413): onAttachToWindow register content observer attrs=WM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=10 sim=#123 ty=1 fl=#81810580 wanim=0x1030469 rotAnim=1 vsysui=0x501 sysuil=true surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.android.camera2token=android.os.BinderProxy@a58b6d2}
D/CAM_MemoryQuery( 1413): timestamp=35681, availMem=1572, totalMem=2012, totalPSS=13, lastTrimLevel=0, largeMemoryClass=512, nativePSS=3, dalvikPSS=4, otherPSS=5,threshold=720, lowMemory=false
D/WindowManagerService( 453): Window{ed18f53 u0 com.android.camera2/com.android.camera.CameraLauncher} ==========setInputFocusLw ========== =======
D/ViewRootImpl( 1413): 720<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=10 sim=#123 ty=1 fl=#81810580 wanim=0x1030469 rotAnim=1 vsysui=0x501 sysuil=true surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.android.camera2token=android.os.BinderProxy@a58b6d2}
I/mali_so ( 1413): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 780; [Func] : base_context_deal_with_version_affairs_rk_ext;
I/mali_so ( 1413): arm_release_ver of this mali_so is ‘r6p0-02rel0’, rk_so_ver is ‘11@0’, built at ‘15:38:28’ for 3288w, on ‘Aug 2 2016’.
I/mali_so ( 1413): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 807; [Func] : base_context_deal_with_version_affairs_rk_ext;
I/mali_so ( 1413): mali_ver_property has been set to ‘r6p0-02rel0-13-11@0’, to return.
I/OpenGLRenderer( 1413): Initialized EGL, version 1.4
D/OpenGLRenderer( 1413): Enabling debug mode 0
V/CAM_TexViewHelper( 1413): onLayoutChange
V/CAM_TexViewHelper( 1413): updateTransform
V/CAM_FilmstripView( 1413): suggesting item bounds: 504x829
V/CAM_CameraDataAdapter( 1413): updating media metadata with photos newer than id: 31
V/CAM_CameraAppUI( 1413): SurfaceTexture is available
I/CAM_VideoModule( 1413): startPreview
W/ResourceType( 1413): No package identifier when getting value for resource number 0x00000000
W/PackageManager( 1413): Failure retrieving resources for com.android.gallery3d: Resource ID #0x0
I/ActivityManagerService( 453): Displayed com.android.camera2/com.android.camera.CameraLauncher: +783ms
D/ViewRootImpl( 453): onDetachedFromWindow ungister contentObserver
V/CAM_CameraDataAdapter( 1413): new photos query return num items: 0
E/CameraHal( 166): cameraCreate(137): sensor name OV5640
W/CameraService( 166): CameraService::connect X (id 0, this pid is 166, name com.android.camera2)
V/CAM_CameraController( 1413): onCameraOpened
V/CAM_CameraActivity( 1413): onCameraOpened
D/CAM_VideoModule( 1413): Selected video quality for ‘small’ is 4
V/CAM_VideoModule( 1413): Selected =640x480 on WYSIWYG Priority
V/CAM_TexViewHelper( 1413): updateAspectRatio
V/CAM_TexViewHelper( 1413): setAspectRatio: 1.3333334
V/CAM_TexViewHelper( 1413): aspect ratio changed from: 0.0
V/CAM_VideoModule( 1413): Updated DesiredPreview=640x480
D/CAM_VideoModule( 1413): Video snapshot size is Size: (640 x 480)
V/CAM_FocusOverlayMgr( 1413): stored focus setting for camera: fixed
V/CAM_FocusOverlayMgr( 1413): focus mode resolved from setting: FIXED
V/CAM_VideoModule( 1413): on L, no one shot callback necessary
V/CAM_CameraActivity( 1413): invoking onChangeCamera
W/CAM_IndicatorIconCtrlr( 1413): Trying to sync a pano indicator that is not initialized.
D/CameraHal( 166): commandThread(937): commandThread(937):receive CMD_SET_PREVIEW_WINDOW
D/CameraHal( 166): commandThread(953): commandThread(953): CMD_SET_PREVIEW_WINDOW out
D/CameraHal( 166): commandThread(832): commandThread(832):receive CMD_PREVIEW_START
D/CameraHal( 166): stop(1859): m_camDevice->stopPreview success!
E/CameraHal_Marvin( 166): CAM_API_CAMENGINE: changeResolution (can’t change resolution of sensor)
D/CameraHal( 166): start(1814): m_camDevice->startPreview success
D/CameraHal( 166): displayThread(596): displayThread(596): receive CMD_DISPLAY_START
V/CAM_CameraAppUI( 1413): onPreviewStarted
D/CameraHal( 166): commandThread(905): commandThread(905): CMD_PREVIEW_START out
E/CameraHal_Marvin( 166): CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,g_miFrameNum == 1;numFramesToSkip == 1
V/CAM_CameraAppUI( 1413): hiding cover via onSurfaceTextureUpdated
D/CameraPerformanceTracker( 1413): First preview frame received
D/TaskPersister( 453): removeObsoleteFile: deleting file=8_task.xml
W/ActivityThread( 649): ClassLoader.loadClass: The class loader returned by Thread.getContextClassLoader() may fail for processes that host multiple applications. You should explicitly specify a context class loader. For example: Thread.setContextClassLoader(getClass().getClassLoader());
D/RKUpdateService( 649): request remote server error…
D/ViewRootImpl( 1413): 720<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=10 sim=#23 ty=1 fl=#81810580 wanim=0x1030469 rotAnim=1 vsysui=0x501 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.android.camera2token=android.os.BinderProxy@a58b6d2}
I/CAM_VideoModule( 1413): startVideoRecording: Thread[main,5,main]
D/ViewRootImpl( 1413): 720<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=10 sim=#23 ty=1 fl=#81810580 wanim=0x1030469 rotAnim=1 vsysui=0x501 sysuil=true surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.android.camera2token=android.os.BinderProxy@a58b6d2}
I/CAM_VideoModule( 1413): initializeRecorder: Thread[main,5,main]
D/MediaProfiles( 166): CameraGroupFound(668): media_profiles_id: 0x0
D/MediaProfiles( 166): getInstance(763): Create instance from /data/camera/media_profiles.xml
W/StagefrightRecorder( 166): Max file duration is not positive: 0 us. Disabling duration limit.
W/StagefrightRecorder( 166): Target duration (0 us) too short to be respected
V/CAM_VideoModule( 1413): New video filename: /mnt/internal_sd/DCIM/Camera/VID_20000101_101936.mp4.tmp
D/bunchen ( 1413): setOrientationHint 0
I/MediaFocusControl( 453): AudioFocus requestAudioFocus() from android.media.AudioManager@3af0c348 req=1flags=0x0
W/ACodec ( 166): do not know color format 0x7f000789 = 2130708361
D/CameraSource( 166): Camera does not support setVideoSize()
I/ACodec ( 166): setupVideoEncoder succeeded
I/MediaCodec( 166): MediaCodec will operate in async mode
E/ROCKCHIP_VIDEO_ENC( 166): EncParam.framerate = 15 outPort->sPortParam.format.video.xFramerate = 983040 256000
E/ROCKCHIP_VIDEO_ENC( 166): ConvertOmxAvcLevelToAvcSpecLevel: 512
D/pv_avcenc_api( 166): cml->cabacintIdc 0 cml->enablaCabac 0 cml->intraPicRate 15
E/AudioHardwareTiny( 166): adev_open_input_stream:channel is not support
D/AudioHardwareTiny( 166): in->mSpeexFrameSize:512
I/AudioFlinger( 166): AudioFlinger’s thread 0xacf52008 ready to run
W/AudioFlinger( 166): acquireAudioSessionId() unknown client 1413 for session 13
D/pv_avcenc_api( 166): init intraPeriodCnt 15
D/ACodec ( 166): MEDIA_MIMETYPE_AUDIO_AAC sampleRate 44100 wifidisplay_flag 0 info b82f4330
W/MPEG4Writer( 166): 32-bit file size limit (7118376832 bytes) too big. It is changed to 4294967295 bytes
I/MPEG4Writer( 166): limits: 4294967295/0 bytes/us, bit rate: 317000 bps and the estimated moov size 405000 bytes
I/MPEG4Writer( 166): Start time offset: 1000000 us
I/MediaCodecSource( 166): MediaCodecSource (video) starting
I/OMXCodec( 166): mOutputPortSettingsHaveChanged set true
I/OMXCodec( 166): found informat change ComponentName = OMX.google.vorbis.decoder
D/AudioSink( 166): open(48000, 1, 0x0, 0x1, 4, 12 0x0)
I/AudioTrack( 166): minFrameCount: 8916, afFrameCount=2048, minBufCount=4, sampleRate=48000, afSampleRate=44100, afLatency=185
D/InitAlarmsService( 1341): Clearing and rescheduling alarms.
I/MediaCodecSource( 166): MediaCodecSource (video) started
I/MediaCodecSource( 166): MediaCodecSource (audio) starting
E/CameraHal( 166): processVideoCb(1416): processVideoCb(1416):no available buffer
I/MediaCodecSource( 166): MediaCodecSource (audio) started
I/MPEG4Writer( 166): setStartTimestampUs: 3399166
I/MPEG4Writer( 166): Earliest track starting time: 3399166
V/CAM_VideoModule( 1413): stopVideoRecording
D/MPEG4Writer( 166): Video track stopping
D/MPEG4Writer( 166): Video track source stopping
I/MediaCodecSource( 166): encoder (video) stopping
I/MPEG4Writer( 166): Received total/0-length (320/0) buffers and encoded 319 frames. - Video
I/MediaCodecSource( 166): encoder (video) stopped
I/MediaCodecSource( 166): puller (video) stopping
D/CameraSource( 166): reset: E
W/CameraSource( 166): 1 long delays between neighboring video frames
D/CameraSource( 166): reset: X
I/MediaCodecSource( 166): puller (video) stopped
D/MPEG4Writer( 166): Video track source stopped
D/MPEG4Writer( 166): Video track stopped
D/MPEG4Writer( 166): Audio track stopping
D/MPEG4Writer( 166): Audio track source stopping
I/MediaCodecSource( 166): encoder (audio) stopping
E/MPEG4Writer( 166): The number of recorded samples is 0
W/MPEG4Writer( 166): 0-duration samples found: 1
I/MPEG4Writer( 166): Received total/0-length (1/0) buffers and encoded 0 frames. - Audio
I/MPEG4Writer( 166): Audio track drift time: 0 us
I/MediaCodecSource( 166): encoder (audio) stopped
I/MediaCodecSource( 166): puller (audio) stopping
W/ALooperRoster( 166): failed to deliver message. Target handler 37 registered, but object gone. 卡在这里了
W/ResourceType( 594): No package identifier when getting value for resource number 0x00000000
W/PackageManager( 594): Failure retrieving resources for com.android.camera2: Resource ID #0x0
I/ActivityStackSupervisor( 453): START u0 {act=com.android.systemui.recents.SHOW_RECENTS flg=0x10804000 cmp=com.android.systemui/.recents.RecentsActivity} from uid 10010 on display 0
I/System.out( 453): com.android.systemui.recents.RecentsActivityaddAppToken taskId:11
D/DisplayManager( 453): getDisplayInfo: displayId=0, info=DisplayInfo{“内置屏幕”, uniqueId “local:0”, app 720 x 1184, real 720 x 1280, largest app 1280 x 1134, smallest app 720 x 574, 59.527 fps, supportedRefreshRates [59.527], rotation 0, density 320 (160.42105 x 160.15764) dpi, layerStack 0, appVsyncOff 0, presDeadline 17799099, type BUILT_IN, state ON, FLAG_SECURE, FLAG_SUPPORTS_PROTECTED_BUFFERS}
D/PermissionCache( 156): checking android.permission.READ_FRAME_BUFFER for uid=1000 => granted (203 us)
D/PhoneWindow( 594): DecorView - SCREEN_WEITH = 720 - SCREE_HEIGHT = 1184
D/OpenGLRenderer( 594): setting property ambientRatio to 1.5
D/OpenGLRenderer( 594): ambientRatio = 1.50
V/WindowManagerService( 453): Adding window Window{2a2787bb u0 com.android.systemui/com.android.systemui.recents.RecentsActivity} at 3 of 8 (after Window{209b2cf5 u0 com.android.launcher3/com.android.launcher3.Launcher})
D/ViewRootImpl( 594): onAttachToWindow register content observer attrs=WM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=11 sim=#100 ty=1 fl=#81910100 fmt=-2 wanim=0x7f0b000a vsysui=0x700 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.android.systemuitoken=android.os.BinderProxy@2c8e57ab}
D/WindowManagerService( 453): Window{2a2787bb u0 com.android.systemui/com.android.systemui.recents.RecentsActivity} ==========setInputFocusLw ========== =======
D/ViewRootImpl( 594): 720<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=11 sim=#120 ty=1 fl=#81910100 fmt=-2 wanim=0x7f0b000a vsysui=0x700 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.android.systemuitoken=android.os.BinderProxy@2c8e57ab}
I/ActivityManagerService( 453): Displayed com.android.systemui/.recents.RecentsActivity: +197ms
D/ViewRootImpl( 594): 720<<<<<< BACK FROM relayoutnull
W/hwcomposer( 156): PCfg err[720,1280]w[3],a[1],z_win[3,2],[0,0,626,104]=>[47,634,627,104],w_h_f[627,104,1]
D/hwcomposer( 156): PCfg error: win[0],area[0],z_win[0,1],[240,0,720,1280]=>[0,0,720,1280],w_h_f[960,1280,2],fd=40,addr=0,fbFd=15
D/hwcomposer( 156): PCfg error: win[1],area[0],z_win[1,3],[0,0,720,1280]=>[0,0,720,1280],w_h_f[720,1280,1],fd=74,addr=0,fbFd=15
D/hwcomposer( 156): PCfg error: win[2],area[0],z_win[2,0],[0,560,720,720]=>[47,111,627,627],w_h_f[720,1280,1],fd=51,addr=0,fbFd=15
D/hwcomposer( 156): PCfg error: win[3],area[0],z_win[3,2],[0,0,720,96]=>[0,0,720,96],w_h_f[720,96,1],fd=67,addr=0,fbFd=15
D/hwcomposer( 156): PCfg error: win[3],area[1],z_win[3,2],[0,0,626,104]=>[47,634,627,104],w_h_f[627,104,1],fd=39,addr=0,fbFd=15
D/hwcomposer( 156): PCfg error: win[3],area[2],z_win[3,2],[0,0,720,50]=>[0,1230,720,50],w_h_f[720,50,1],fd=52,addr=0,fbFd=15
W/InputMethodManagerService( 453): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@3d3bebfa attribute=null, token = android.os.BinderProxy@17cbdc4a
I/ActivityStackSupervisor( 453): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10300000 cmp=com.android.settings/.Settings} from uid 10027 on display 0
I/System.out( 453): com.android.settings.SettingsaddAppToken taskId:4
D/PhoneWindow( 1242): DecorView - SCREEN_WEITH = 720 - SCREE_HEIGHT = 1184
I/System.out( 1242): action Title!
I/IndexDatabaseHelper( 1242): Using schema version: 115
I/IndexDatabaseHelper( 1242): Index is fine
D/Index ( 1242): Locale ‘zh_CN’ is already indexed
D/OpenGLRenderer( 1242): Use EGL_SWAP_BEHAVIOR_PRESERVED: true
D/Atlas ( 1242): Validating map…
W/Atlas ( 1242): Pointer 0x0, not in getPreloadedDrawables?
V/WindowManagerService( 453): Adding window Window{254b7f9b u0 com.android.settings/com.android.settings.Settings} at 2 of 9 (after Window{ed18f53 u0 com.android.camera2/com.android.camera.CameraLauncher})
E/NFC ( 1242): could not retrieve NFC service
D/UserManager( 1242): —getMaxSupportedUsers,we has UMS,force disabled M-user—
D/DashboardSummary( 1242): rebuildUI took: 69 ms
D/ViewRootImpl( 1242): onAttachToWindow register content observer attrs=WM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=4 sim=#100 ty=1 fl=#81810100 wanim=0x1030469 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.android.settingstoken=android.os.BinderProxy@d2ff9f2}
D/WindowManagerService( 453): Window{254b7f9b u0 com.android.settings/com.android.settings.Settings} ==========setInputFocusLw ========== =======
D/ViewRootImpl( 1242): 720<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=4 sim=#110 ty=1 fl=#81810100 wanim=0x1030469 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.android.settingstoken=android.os.BinderProxy@d2ff9f2}
I/mali_so ( 1242): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 780; [Func] : base_context_deal_with_version_affairs_rk_ext;
I/mali_so ( 1242): arm_release_ver of this mali_so is ‘r6p0-02rel0’, rk_so_ver is ‘11@0’, built at ‘15:38:28’ for 3288w, on ‘Aug 2 2016’.
I/mali_so ( 1242): [File] : hardware/arm/maliT760/driver/product/base/src/mali_base_kbase.c; [Line] : 807; [Func] : base_context_deal_with_version_affairs_rk_ext;
I/mali_so ( 1242): mali_ver_property has been set to ‘r6p0-02rel0-13-11@0’, to return.
I/OpenGLRenderer( 1242): Initialized EGL, version 1.4
D/OpenGLRenderer( 1242): Enabling debug mode 0
I/ActivityManagerService( 453): Displayed com.android.settings/.Settings: +374ms
I/ActivityStackSupervisor( 453): START u0 {act=android.intent.action.MAIN cmp=com.android.settings/.SubSettings (has extras)} from uid 1000 on display 0
I/System.out( 453): com.android.settings.SubSettingsaddAppToken taskId:4
D/SubSettings( 1242): Launching fragment com.android.settings.WirelessSettings
D/WirelessSettings( 1242): onCreate: mManageMobilePlanMessage=null
D/WirelessSettings( 1242): initSmsApplicationSetting:
V/WindowManagerService( 453): Adding window Window{b47858b u0 com.android.settings/com.android.settings.SubSettings} at 5 of 10 (after Window{254b7f9b u0 com.android.settings/com.android.settings.Settings})
D/ViewRootImpl( 1242): onAttachToWindow register content observer attrs=WM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=4 sim=#100 ty=1 fl=#81810100 wanim=0x1030469 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.android.settingstoken=android.os.BinderProxy@31c4391}
D/WindowManagerService( 453): Window{b47858b u0 com.android.settings/com.android.settings.SubSettings} ==========setInputFocusLw ========== =======
D/ViewRootImpl( 1242): 720<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=4 sim=#110 ty=1 fl=#81810100 wanim=0x1030469 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.android.settingstoken=android.os.BinderProxy@31c4391}
I/ActivityManagerService( 453): Displayed com.android.settings/.SubSettings: +235ms
D/OpenGLRenderer( 1242): endAllStagingAnimators on 0xb8ef9958 (RippleDrawable) with handle 0xb9022d00
D/ViewRootImpl( 1242): 720<<<<<< BACK FROM relayoutnull
D/ViewRootImpl( 1242): 720<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=4 sim=#20 ty=1 fl=#81810100 wanim=0x1030469 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.android.settingstoken=android.os.BinderProxy@d2ff9f2}
I/ActivityStackSupervisor( 453): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10200000 cmp=com.android.launcher3/.Launcher} from uid 1000 on display 0
D/WindowManagerService( 453): Window{209b2cf5 u0 com.android.launcher3/com.android.launcher3.Launcher} ==========setInputFocusLw ========== =======
D/ViewRootImpl( 807): 720<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=9 sim=#120 ty=1 fl=#81910100 fmt=-2 wanim=0x1030469 vsysui=0x600 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.android.launcher3token=android.os.BinderProxy@3a65b795}
D/ViewRootImpl( 1242): 720<<<<<< BACK FROM relayoutWM.LayoutParams{(0,0)(fillxfill)mPosX=0mPosY=0mHScale=1.0mVScale=1.0 align=UNDEFINE taskId=4 sim=#20 ty=1 fl=#81810100 wanim=0x1030469 surfaceInsets=Rect(0, 0 - 0, 0) needsMenuKey=2packageName=com.android.settingstoken=android.os.BinderProxy@31c4391}
W/PackageManager( 594): Failure retrieving resources for com.android.settings: Resource ID #0x0
W/ActivityManagerService( 453): Activity stop timeout for ActivityRecord{3b412465 u0 com.android.camera2/com.android.camera.CameraLauncher t10}
I/ActivityManagerService( 453): Activity reported stop, but no longer stopping: ActivityRecord{3b412465 u0 com.android.camera2/com.android.camera.CameraLauncher t10}
I/InputDispatcher( 453): Dropped event because the current application is not responding and the user has started interacting with a different application.
I/ActivityManagerService( 453): Killing 1413:com.android.camera2/u0a16 (adj 2): remove task
E/Surface ( 166): queueBuffer: error queuing buffer to SurfaceTexture, -2147483646
E/CameraHal( 166): displayThread(763): displayThread(763): enqueue buffer 1 to mANativeWindow failed(-2147483646),so display pause
W/MediaFocusControl( 453): AudioFocus audio focus client died
I/MediaFocusControl( 453): AudioFocus removeFocusStackEntry(): removing entry for android.os.BinderProxy@ad319ae
V/Sensors ( 453): int poll__setDelay(sensors_poll_device_t*, int, int64_t)
V/Sensors ( 453): int sensors_poll_context_t::setDelay(int, int64_t)
V/Sensors ( 453): setDelay - sensor Accelerometer (handle 4), rate 66 ms (15.00 Hz)
E/Sensors ( 453): MPU is not available
I/WindowState( 453): WIN DEATH: Window{ed18f53 u0 com.android.camera2/com.android.camera.CameraLauncher}
W/ActivityManagerService( 453): 1413cleanUpRemovedTaskLocked of task: TaskRecord{3849234f #10 A=com.android.camera.CameraActivity U=0 sz=1}
W/CameraClient( 166): native_window_api_disconnect failed: Broken pipe (-32)
D/CameraHal( 166): pauseDisplay(159): pauseDisplay(159): display thread is already stop
D/mmk ( 594): onStatusChangedLocked.+++++++
E/CameraManagerGlobal( 594): Camera id 0 has status changed to 0x1
I/FrameQueueManage( 166): FrameQueueManage::~FrameQueueManage end!
W/AudioCache( 166): Battery track warning: refCount is already 0
W/AudioFlinger( 166): session id 12 not found for pid 1413
D/TaskPersister( 453): removeObsoleteFile: deleting file=10_task.xml
D/TaskPersister( 453): removeObsoleteFile: deleting file=10_task_thumbnail.png
I/ActivityManagerService( 453): Killing 1242:com.android.settings/1000 (adj 9): remove task
I/WindowState( 453): WIN DEATH: Window{254b7f9b u0 com.android.settings/com.android.settings.Settings}
I/WindowState( 453): WIN DEATH: Window{b47858b u0 com.android.settings/com.android.settings.SubSettings}
W/ActivityManagerService( 453): 1242cleanUpRemovedTaskLocked of task: TaskRecord{1e004adc #4 A=com.android.settings U=0 sz=2}
W/art ( 453): Long monitor contention event with owner method=boolean com.android.server.am.ActivityManagerService.removeTask(int) from ActivityManagerService.java:8695 waiters=0 for 208ms
I/ActivityStackSupervisor( 453): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10200000 cmp=com.android.launcher3/.Launcher} from uid 10010 on display 0
D/TaskPersister( 453): removeObsoleteFile: deleting file=4_task.xml
D/TaskPersister( 453): removeObsoleteFile: deleting file=4_task_thumbnail.png
