libsoxr 0.1.2 Extracting
xzcat /home/test/share/buildroot/dl/soxr-0.1.2-Source.tar.xz | tar --strip-compo nents=1 -C /home/test/share/buildroot/output/firefly_rk3308_release/build/libsox r-0.1.2 -xf -
libsoxr 0.1.2 Patching
libsoxr 0.1.2 Configuring
(mkdir -p /home/test/share/buildroot/output/firefly_rk3308_release/build/libsoxr -0.1.2/ && cd /home/test/share/buildroot/output/firefly_rk3308_release/build/lib soxr-0.1.2/ && rm -f CMakeCache.txt && PATH=“/home/test/share/buildroot/output/f irefly_rk3308_release/host/bin:/home/test/share/buildroot/output/firefly_rk3308_ release/host/sbin:/home/test/bin:/home/test/.local/bin:/usr/local/sbin:/usr/loca l/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin” /usr /bin/cmake /home/test/share/buildroot/output/firefly_rk3308_release/build/libsox r-0.1.2/ -DCMAKE_TOOLCHAIN_FILE=“/home/test/share/buildroot/output/firefly_rk330 8_release/host/share/buildroot/toolchainfile.cmake” -DCMAKE_INSTALL_PREFIX="/usr " -DCMAKE_COLOR_MAKEFILE=OFF -DBUILD_DOC=OFF -DBUILD_DOCS=OFF -DBUILD_EXAMPLE=OF F -DBUILD_EXAMPLES=OFF -DBUILD_TEST=OFF -DBUILD_TESTS=OFF -DBUILD_TESTING=OFF -D BUILD_SHARED_LIBS=ON -DWITH_OPENMP=OFF -DHAVE_WORDS_BIGENDIAN=0 )
– The C compiler identification is unknown
CMake Error at CMakeLists.txt:6 (project):
The CMAKE_C_COMPILER:
/home/test/output/firefly_rk3308_release/host/bin/aarch64-rockchip-linux-gnu -gcc
is not a full path to an existing compiler tool.
Tell CMake where to find the compiler by setting either the environment
variable “CC” or the CMake cache entry CMAKE_C_COMPILER to the full path to
the compiler, or to the compiler name if it is in the PATH.
– Configuring incomplete, errors occurred!
See also “/home/test/share/buildroot/output/firefly_rk3308_release/build/libsoxr -0.1.2/CMakeFiles/CMakeOutput.log”.
