<6>[ 0.000000] Booting Linux on physical CPU 0x500
<6>[ 0.000000] Initializing cgroup subsys cpu
<6>[ 0.000000] Initializing cgroup subsys cpuacct
<5>[ 0.000000] Linux version 3.10.0 (likun@shutuo28) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #29 SMP PREEMPT Fri Jul 26 11:40:06 CST 2019
<4>[ 0.000000] cpu_do_switch_mm is cpu_v7_btbinv_switch_mm
<4>[ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d
<4>[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
<6>[ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288
<6>[ 0.000000] rockchip_uboot_logo_setup: mem: 0x02000000@0x7dc00000, offset:0x00000000
<6>[ 0.000000] rockchip_uboot_mem_reserve: reserve 0x02000000@0x7dc00000 for uboot logo
<4>[ 0.000000] rockchip_ion_reserve
<6>[ 0.000000] ion heap(drm): base(0) size(0) align(0)
<6>[ 0.000000] ion heap(cma): base(0) size(2000000) align(0)
<6>[ 0.000000] ion heap(vmalloc): base(0) size(0) align(0)
<6>[ 0.000000] cma: CMA: reserved 32 MiB at 7bc00000
<6>[ 0.000000] ion_reserve: cma reserved base 7bc00000 size 33554432
<6>[ 0.000000] cma: CMA: reserved 16 MiB at 1f000000
<4>[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
<4>[ 0.000000] Boot mode: REBOOT (6) flag: NORMAL (0xc3524200)
<7>[ 0.000000] On node 0 totalpages: 524288
<7>[ 0.000000] free_area_init_node: node 0, pgdat c0c612c0, node_mem_map c0d88000
<7>[ 0.000000] Normal zone: 1024 pages used for memmap
<7>[ 0.000000] Normal zone: 0 pages reserved
<7>[ 0.000000] Normal zone: 131072 pages, LIFO batch:31
<7>[ 0.000000] HighMem zone: 3072 pages used for memmap
<7>[ 0.000000] HighMem zone: 393216 pages, LIFO batch:31
<6>[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1de2000 s13376 r8192 d15296 u36864
<7>[ 0.000000] pcpu-alloc: s13376 r8192 d15296 u36864 alloc=9*4096
<7>[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
<4>[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523264
<5>[ 0.000000] Kernel command line: vmalloc=496M console=ttyFIQ0 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00200000@0x00092000(system),0x00008000@0x00292000(metadata),0x00020000@0x0029A000(radical_update),-@0x002BA000(userdata) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2018-08-22_08:11:24 androidboot.serialno=AH3219020178
<6>[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
<6>[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
<6>[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
<6>[ 0.000000] allocated 4194304 bytes of page_cgroup
<6>[ 0.000000] please try ‘cgroup_disable=memory’ option if you don’t want memory cgroups
<6>[ 0.000000] Memory: 2048MB = 2048MB total
<5>[ 0.000000] Memory: 1978536k/1978536k available, 118616k reserved, 1507328K highmem
<5>[ 0.000000] Virtual kernel memory layout:
<5>[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
<5>[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
<5>[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
<5>[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
<5>[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
<5>[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
<5>[ 0.000000] .text : 0xc0008000 - 0xc0b23d9c (11376 kB)
<5>[ 0.000000] .init : 0xc0b24000 - 0xc0b7c440 ( 354 kB)
<5>[ 0.000000] .data : 0xc0b7e000 - 0xc0c68928 ( 939 kB)
<5>[ 0.000000] .bss : 0xc0c68928 - 0xc0d87dfc (1150 kB)
<6>[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
<6>[ 0.000000] Preemptible hierarchical RCU implementation.
<6>[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
<6>[ 0.000000] NR_IRQS:16 nr_irqs:16 16
<4>[ 0.000000] rk_clk_tree_init start!
<3>[ 0.000000] rkclk: rkclk_add_provider: fail to get ehci1phy_12m_div
<3>[ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error
<4>[ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1
<4>[ 0.000000] rkclk_init_clks: cnt_parent = 7
<4>[ 0.000000] rkclk_init_clks: cnt_rate = 29
<4>[ 0.000000] rk3288 set GPLL BW 20 for HDMI!
<6>[ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
<6>[ 0.000000] Switching to timer-based delay loop
<6>[ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns
<6>[ 0.000000] process version: 0
<6>[ 0.000000] channel:0, lkg:21
<6>[ 0.000000] target-temp:80
<6>[ 0.000000] channel:2, lkg:0
<6>[ 0.000000] channel:1, lkg:14
<6>[ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms
<6>[ 0.486119] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
<6>[ 0.486133] pid_max: default: 32768 minimum: 301
<6>[ 0.486243] Security Framework initialized
<6>[ 0.486256] SELinux: Initializing.
<7>[ 0.486290] SELinux: Starting in permissive mode
<6>[ 0.486325] Mount-cache hash table entries: 512
<6>[ 0.486917] Initializing cgroup subsys debug
<6>[ 0.486930] Initializing cgroup subsys memory
<6>[ 0.486953] Initializing cgroup subsys freezer
<6>[ 0.486980] CPU: Testing write buffer coherency: ok
<3>[ 0.487226] /cpus/cpu@0 missing clock-frequency property
<3>[ 0.487239] /cpus/cpu@1 missing clock-frequency property
<3>[ 0.487248] /cpus/cpu@2 missing clock-frequency property
<3>[ 0.487257] /cpus/cpu@3 missing clock-frequency property
<6>[ 0.487298] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
<6>[ 0.487343] Setting up static identity map for 0xc0804b90 - 0xc0804be8
<6>[ 0.488850] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x1848 (version 3.1)
<4>[ 0.564178] CPU1: Booted secondary processor
<6>[ 0.564206] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
<4>[ 0.583858] CPU2: Booted secondary processor
<6>[ 0.583882] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
<4>[ 0.603566] CPU3: Booted secondary processor
<6>[ 0.603589] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
<6>[ 0.603687] Brought up 4 CPUs
<6>[ 0.603714] SMP: Total of 4 processors activated (192.00 BogoMIPS).
<6>[ 0.603723] CPU: All CPU(s) started in SVC mode.
<6>[ 0.604371] devtmpfs: initialized
<6>[ 0.608547] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
<6>[ 0.609485] pinctrl core: initialized pinctrl subsystem
<6>[ 0.609704] regulator-dummy: no parameters
<6>[ 0.623602] NET: Registered protocol family 16
<6>[ 0.625155] DMA: preallocated 256 KiB pool for atomic coherent allocations
<6>[ 0.625440] ion_snapshot: 0x1e9b8000 map to 0xe0907000 and copy to 0xc0d633cc (version 0.1)
<6>[ 0.625596] Registered FIQ tty driver
<6>[ 0.626718] console [ttyFIQ0] enabled
<6>[ 0.626909] Registered fiq debugger ttyFIQ0
<4>[ 0.627490] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
<4>[ 0.627518] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
<4>[ 0.627538] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
<4>[ 0.627557] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
<4>[ 0.627641] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
<4>[ 0.627707] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
<4>[ 0.627772] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
<4>[ 0.627837] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
<4>[ 0.627901] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
<4>[ 0.627966] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
<4>[ 0.628030] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
<4>[ 0.628095] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
<4>[ 0.628165] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
<4>[ 0.628233] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
<4>[ 0.628248] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
<4>[ 0.628262] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
<4>[ 0.628276] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
<7>[ 0.628350] gpiochip_add: registered GPIOs 0 to 31 on device: gpio0
<7>[ 0.628409] gpiochip_add: registered GPIOs 32 to 63 on device: gpio1
<7>[ 0.628462] gpiochip_add: registered GPIOs 64 to 95 on device: gpio2
<7>[ 0.628519] gpiochip_add: registered GPIOs 96 to 127 on device: gpio3
<7>[ 0.628573] gpiochip_add: registered GPIOs 128 to 159 on device: gpio4
<7>[ 0.628627] gpiochip_add: registered GPIOs 160 to 191 on device: gpio5
<7>[ 0.628683] gpiochip_add: registered GPIOs 192 to 223 on device: gpio6
<7>[ 0.628741] gpiochip_add: registered GPIOs 224 to 255 on device: gpio7
<7>[ 0.628794] gpiochip_add: registered GPIOs 256 to 287 on device: gpio8
<7>[ 0.628848] gpiochip_add: registered GPIOs 288 to 319 on device: gpio15
<4>[ 0.628872] rockchip_interrupts_register:bank_num=7
<7>[ 0.630719] of_get_named_gpio_flags exited with status 6
<4>[ 0.630730] of_get_gpio_init_config:gpio[0] = 6, value = 0
<4>[ 0.630779] rockchip_pinctrl_probe:init ok
<6>[ 0.637578] rk_iommu ff900800.iep_mmu: (iep) Enter
<6>[ 0.637644] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.637660] rk_iommu ff900800.iep_mmu: (iep) Initialized
<6>[ 0.637826] rk_iommu ff950800.vip_mmu: (vip) Enter
<6>[ 0.637889] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.637905] rk_iommu ff950800.vip_mmu: (vip) Initialized
<6>[ 0.638065] rk_iommu ff930300.vopb_mmu: (vopb) Enter
<6>[ 0.638123] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.638139] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
<6>[ 0.638298] rk_iommu ff940300.vopl_mmu: (vopl) Enter
<6>[ 0.638360] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.638375] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
<6>[ 0.638543] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
<6>[ 0.638604] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.638620] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
<6>[ 0.638782] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
<6>[ 0.638843] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.638859] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
<6>[ 0.639030] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
<6>[ 0.639092] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.639108] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
<6>[ 0.640905] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
<6>[ 0.640920] hw-breakpoint: maximum watchpoint size is 4 bytes.
<3>[ 0.641436] rk3368_init_rockchip_pmu_ops: could not find pmu dt node
<4>[ 0.641459] DDR DEBUG: version 1.00 20150126
<4>[ 0.641553] DDR DEBUG: Channel a:
<4>[ 0.641563] DDR DEBUG: DDR3 Device
<4>[ 0.641577] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 DDR DEBUG: CS=1 Total Capability=1024MB
<4>[ 0.641593] DDR DEBUG: Channel b:
<4>[ 0.641602] DDR DEBUG: DDR3 Device
<4>[ 0.641614] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 DDR DEBUG: CS=1 Total Capability=1024MB
<4>[ 0.641629] DDR DEBUG: addr=0xc72000
<4>[ 0.641640] DDR DEBUG: stride=9, size=256, halfcap=40000000
<4>[ 0.641650] DDR DEBUG: socAddr[0]=0xc72000, socAddr[1]=0xc72100
<4>[ 0.641661] DDR DEBUG: chAddr[0]=0xc72000, chAddr[1]=0xc72000
<4>[ 0.641674] DDR DEBUG: dtar[0]=0x2018e000, dtar[1]=0x2018e000
<4>[ 0.641730] DDR DEBUG: init success!!! freq=396MHz
<4>[ 0.641740] DDR DEBUG: Channel a:
<4>[ 0.641750] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DDR DEBUG: DTPASS=4,0, DGSL=1,0 extra clock, DDR DEBUG: DGPS=90,270
<4>[ 0.641770] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DDR DEBUG: DTPASS=4,0, DGSL=1,0 extra clock, DDR DEBUG: DGPS=90,270
<4>[ 0.641789] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DDR DEBUG: DTPASS=4,0, DGSL=1,0 extra clock, DDR DEBUG: DGPS=90,270
<4>[ 0.641807] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DDR DEBUG: DTPASS=4,0, DGSL=1,0 extra clock, DDR DEBUG: DGPS=90,270
<4>[ 0.641826] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, DDR DEBUG: ZPU=0x0, OPD=0x0, OPU=0x0
<4>[ 0.641841] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
<4>[ 0.641851] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
<4>[ 0.641860] DDR DEBUG: Channel b:
<4>[ 0.641870] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DDR DEBUG: DTPASS=4,0, DGSL=1,0 extra clock, DDR DEBUG: DGPS=90,270
<4>[ 0.641888] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DDR DEBUG: DTPASS=4,0, DGSL=1,0 extra clock, DDR DEBUG: DGPS=90,270
<4>[ 0.641906] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DDR DEBUG: DTPASS=4,0, DGSL=1,0 extra clock, DDR DEBUG: DGPS=90,270
<4>[ 0.641925] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DDR DEBUG: DTPASS=4,0, DGSL=1,0 extra clock, DDR DEBUG: DGPS=90,270
<4>[ 0.641943] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, DDR DEBUG: ZPU=0x0, OPD=0x0, OPU=0x0
<4>[ 0.641957] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
<4>[ 0.641968] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
<6>[ 0.666911] bio: create slab at 0
<6>[ 0.667381] Rockchip hdmi driver version 2.0
<6>[ 0.667381] .
<5>[ 0.668514] SCSI subsystem initialized
<6>[ 0.668663] usbcore: registered new interface driver usbfs
<6>[ 0.668708] usbcore: registered new interface driver hub
<6>[ 0.668795] usbcore: registered new device driver usb
<7>[ 0.669043] of_get_named_gpio_flags: can’t parse gpios property
<3>[ 0.669058] rk3288-usb-control usb_control.33: invalid host gpio-2
<7>[ 0.669071] of_get_named_gpio_flags: can’t parse gpios property
<3>[ 0.669082] rk3288-usb-control usb_control.33: invalid otg gpio-2
<7>[ 0.670082] of_get_named_gpio_flags exited with status 15
<7>[ 0.670101] of_get_named_gpio_flags exited with status 16
<6>[ 0.671128] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
<7>[ 0.671228] of_get_named_gpio_flags exited with status 260
<7>[ 0.671246] of_get_named_gpio_flags exited with status 261
<6>[ 0.671742] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
<7>[ 0.671843] of_get_named_gpio_flags exited with status 201
<7>[ 0.671861] of_get_named_gpio_flags exited with status 202
<6>[ 0.672176] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
<7>[ 0.672270] of_get_named_gpio_flags exited with status 81
<7>[ 0.672287] of_get_named_gpio_flags exited with status 80
<6>[ 0.672416] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
<7>[ 0.672533] of_get_named_gpio_flags exited with status 241
<7>[ 0.672551] of_get_named_gpio_flags exited with status 242
<6>[ 0.673065] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
<6>[ 0.673175] media: Linux media interface: v0.10
<6>[ 0.673215] Linux video capture interface: v2.00
<6>[ 0.673260] pps_core: LinuxPPS API ver. 1 registered
<6>[ 0.673271] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
<6>[ 0.673294] PTP clock support registered
<4>[ 0.673662] ion_drm_heap_create: 0@0
<6>[ 0.673779] Rockchip ion module is successfully loaded (v1.1)
<6>[ 0.673937] Advanced Linux Sound Architecture Driver Initialized.
<6>[ 0.674297] Bluetooth: Core ver 2.16
<6>[ 0.674334] NET: Registered protocol family 31
<6>[ 0.674345] Bluetooth: HCI device and connection manager initialized
<6>[ 0.674362] Bluetooth: HCI socket layer initialized
<6>[ 0.674377] Bluetooth: L2CAP socket layer initialized
<6>[ 0.674404] Bluetooth: SCO socket layer initialized
<6>[ 0.674633] cfg80211: Calling CRDA to update world regulatory domain
<4>[ 0.675246] act8846_i2c_probe,line=1031
<7>[ 0.676588] of_get_named_gpio_flags exited with status 225
<7>[ 0.676603] of_get_named_gpio_flags exited with status 10
<7>[ 0.676616] of_get_named_gpio_flags exited with status 18
<4>[ 0.676634] act8846_i2c_probe: act8846_pmic_hold=1
<4>[ 0.676651] act8846_i2c_probe: act8846_pmic_sleep=0
<4>[ 0.676667] ##################sta_power_gpio################################
<6>[ 0.678708] act_dcdc1: 1200 mV
<6>[ 0.681649] vccio: 3300 mV
<6>[ 0.683496] vdd_logic: 700 ↔ 1500 mV at 1100 mV
<6>[ 0.686424] act_dcdc4: 2000 mV
<6>[ 0.687663] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
<6>[ 0.689957] act_ldo2: 1000 mV
<6>[ 0.692261] act_ldo3: 3300 mV
<6>[ 0.694548] act_ldo4: 3300 mV
<6>[ 0.696827] act_ldo5: 3300 mV
<6>[ 0.699113] act_ldo6: 1000 mV
<6>[ 0.701408] vcc_18: 1800 mV
<6>[ 0.703691] act_ldo8: 1800 mV
<6>[ 0.708403] vdd_arm: 712 ↔ 1500 mV at 1087 mV
<6>[ 0.713059] vdd_gpu: 712 ↔ 1500 mV at 900 mV
<4>[ 0.713816] i2c-core: driver [rk818] using legacy suspend method
<4>[ 0.713830] i2c-core: driver [rk818] using legacy resume method
<4>[ 0.715398] rknandbase v1.0 2014-03-31
<4>[ 0.715505] rknand: probe of ff400000.nandc failed with error -1
<4>[ 0.715650] rknand_probe clk rate = 148500000
<4>[ 0.715724] rknand: probe of ff400000.nandc0 failed with error -1
<4>[ 0.715831] rknand_driver:ret = 0
<6>[ 0.715844] Switching to clocksource arch_sys_counter
<6>[ 0.736954] rga: Module initialized.
<6>[ 0.737466] rga2 ff920000.rga: rga ion client create success!
<6>[ 0.737626] rga: Driver loaded succesfully
<7>[ 0.737804] uboot-logo-on:1
<6>[ 0.737833] rk-fb rockchip-fb: rk fb ion client create success!
<6>[ 0.737847] rk-fb rockchip-fb: rockchip framebuffer driver probe
<4>[ 0.738111] [clc] [89] [convert_lcd_param_to_screen] lcd_param 0
<4>[ 0.738125] [clc] [89] [convert_lcd_param_to_screen] lcd_param 0
<4>[ 0.738136] [clc] [89] [convert_lcd_param_to_screen] lcd_param 0
<4>[ 0.738147] [clc] [89] [convert_lcd_param_to_screen] lcd_param 0
<4>[ 0.738158] [clc] [89] [convert_lcd_param_to_screen] lcd_param 0
<4>[ 0.738168] [clc] [89] [convert_lcd_param_to_screen] lcd_param 0
<4>[ 0.738179] [clc] [89] [convert_lcd_param_to_screen] lcd_param 0
<4>[ 0.738189] [clc] [89] [convert_lcd_param_to_screen] lcd_param 0
<4>[ 0.738200] [clc] [89] [convert_lcd_param_to_screen] lcd_param 0
<4>[ 0.738210] [clc] [89] [convert_lcd_param_to_screen] lcd_param 0
<4>[ 0.738220] [clc] [89] [convert_lcd_param_to_screen] lcd_param 0
<4>[ 0.738231] [clc] [89] [convert_lcd_param_to_screen] lcd_param 0
<4>[ 0.738241] [clc] [89] [convert_lcd_param_to_screen] lcd_param 0
<4>[ 0.738252] [clc] [89] [convert_lcd_param_to_screen] lcd_param 0
<4>[ 0.738262] [clc] [89] [convert_lcd_param_to_screen] lcd_param 0
<4>[ 0.738273] [clc] [89] [convert_lcd_param_to_screen] lcd_param 0
<4>[ 0.738283] [clc] [89] [convert_lcd_param_to_screen] lcd_param 0
<4>[ 0.738293] [clc] [89] [convert_lcd_param_to_screen] lcd_param 0
<4>[ 0.738304] [clc] [89] [convert_lcd_param_to_screen] lcd_param 0
<4>[ 0.738314] [clc] [89] [convert_lcd_param_to_screen] lcd_param 0
<4>[ 0.738325] [clc] [89] [convert_lcd_param_to_screen] lcd_param 0
<4>[ 0.738335] [clc] [89] [convert_lcd_param_to_screen] lcd_param 0
<4>[ 0.738346] [clc] [89] [convert_lcd_param_to_screen] lcd_param 0
<4>[ 0.738356] [clc] [89] [convert_lcd_param_to_screen] lcd_param 0
<4>[ 0.738365] read parameter failed!
<6>[ 0.738378] rk-screen rk_screen.9: rockchip screen probe success
<6>[ 0.738612] rk32-lvds rk32-lvds: rk32 lvds driver probe success
<7>[ 0.739345] of_get_named_gpio_flags exited with status 227
<6>[ 0.739556] graphics fb0: rockchip framebuffer registerd:fb0
<6>[ 0.739857] graphics fb1: rockchip framebuffer registerd:fb1
<6>[ 0.740025] graphics fb2: rockchip framebuffer registerd:fb2
<6>[ 0.740194] graphics fb3: rockchip framebuffer registerd:fb3
<4>[ 0.740211] ===============rk_fb_open win_id[0]:dev_drv->win[win_id]->state = 0; fb_par->state = 1;dev_drv->name=lcdc1;dev_drv->id=1
<4>[ 0.740228] >>>>>>>>> rk3288_lcdc_open : sys_status=2048 dev_drv->id=1 open = 1 lcdc_dev->atv_layer_cnt = 0 win_id =0
<6>[ 0.740901] rk3288-lcdc lcdc1: lcdc1: dclk:148000000>>fps:60
<6>[ 0.765749] rk3288-lcdc lcdc1: wakeup from standby!
<4>[ 0.767378] rk_battery_charger_detect_cb , battery_charger_detect 1
<6>[ 0.810193] alloc_buffer:ion_phy_addr=0x10000000
<6>[ 0.822206] fb0:phy:10000000>>vir:e0991000>>len:0x1800000
<6>[ 0.825250] rk_iommu ff940300.vopl_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1ead4000
<6>[ 0.825270] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu enabled
<3>[ 0.825429] rk3288-lcdc lcdc0: can’t find power_ctr node for lcdc0
<4>[ 0.825443] rk_fb_trsm_ops_get:un supported transmitter:0!
<6>[ 0.825687] graphics fb4: rockchip framebuffer registerd:fb4
<6>[ 0.826002] graphics fb5: rockchip framebuffer registerd:fb5
<6>[ 0.826177] graphics fb6: rockchip framebuffer registerd:fb6
<6>[ 0.826350] graphics fb7: rockchip framebuffer registerd:fb7
<4>[ 0.826367] ===============rk_fb_open win_id[0]:dev_drv->win[win_id]->state = 0; fb_par->state = 1;dev_drv->name=lcdc0;dev_drv->id=0
<4>[ 0.826384] >>>>>>>>> rk3288_lcdc_open : sys_status=1024 dev_drv->id=0 open = 1 lcdc_dev->atv_layer_cnt = 0 win_id =0
<4>[ 0.827112] >>>>>>>>> rk3288_load_screen : screen->type=0 screen->face=0
<4>[ 0.827133] >>>>>>>>> x_res=320,y_res=240,left=100,top=100,right=100,bottom=100
<6>[ 0.827266] rk3288-lcdc lcdc0: lcdc0: dclk:148000000>>fps:857
<6>[ 0.851887] rk3288-lcdc lcdc0: wakeup from standby!
<6>[ 0.855127] fb4:phy:10000000>>vir:e0991000>>len:0x1800000
<6>[ 0.855143] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
<4>[ 0.855972] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.856098] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.856213] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.856335] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.856448] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.856564] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.857124] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.857283] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.857842] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.857983] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.858533] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.858679] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.859229] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.859378] rockchip_set_mux:warning ignore bank num 15
<6>[ 0.860696] NET: Registered protocol family 2
<6>[ 0.861310] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
<6>[ 0.861391] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
<6>[ 0.861466] TCP: Hash tables configured (established 4096 bind 4096)
<6>[ 0.861512] TCP: reno registered
<6>[ 0.861527] UDP hash table entries: 256 (order: 1, 8192 bytes)
<6>[ 0.861552] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
<6>[ 0.861732] NET: Registered protocol family 1
<6>[ 0.862082] Unpacking initramfs…
<6>[ 0.930778] Freeing initrd memory: 1304K (c5bf0000 - c5d36000)
<6>[ 0.931386] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
<6>[ 0.931873] vcodec_service: probe device ff9a0000.vpu_service
<4>[ 0.932019] vcodec_service: No reset resource define
<6>[ 0.932150] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 0.932234] vcodec_service: probe device ff9a0000.vpu_service
<6>[ 0.932253] vcodec_service: checking hw id 4831
<6>[ 0.933047] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 0.933090] vcodec_service: done
<6>[ 0.933100] vcodec_service: init success
<6>[ 0.933157] vcodec_service: probe device ff9c0000.hevc_service
<6>[ 0.933487] vcodec_service: ff9c0000.hevc_service: power on
<6>[ 0.933543] vcodec_service: probe device ff9c0000.hevc_service
<6>[ 0.933560] vcodec_service: checking hw id 6867
<6>[ 0.934093] vcodec_service: ff9c0000.hevc_service: power off…
<6>[ 0.934136] vcodec_service: done
<6>[ 0.934145] vcodec_service: init success
<6>[ 0.935333] audit: initializing netlink socket (disabled)
<5>[ 0.935370] type=2000 audit(0.450:1): initialized
<4>[ 0.936110] bounce pool size: 64 pages
<6>[ 0.940484] fuse init (API version 7.22)
<6>[ 0.940833] msgmni has been set to 954
<7>[ 0.940884] SELinux: Registering netfilter hooks
<6>[ 0.942578] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
<6>[ 0.942596] io scheduler noop registered
<6>[ 0.942606] io scheduler deadline registered
<6>[ 0.942694] io scheduler cfq registered (default)
<7>[ 0.943265] of_get_named_gpio_flags exited with status 226
<7>[ 0.943279] of_get_named_gpio_flags exited with status 234
<7>[ 0.943302] of_get_named_gpio_flags exited with status 237
<4>[ 0.943453] pwm_backlight_power_on: line 63, power on backlight
<6>[ 0.944152] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess.
<4>[ 0.944786] IEP Power ON
<4>[ 0.944822] iep ion client create success!
<6>[ 0.945192] rk_iommu ff900800.iep_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eacc000
<4>[ 0.945208] IEP Power OFF
<4>[ 0.945225] IEP Driver loaded succesfully
<4>[ 0.945321] Module initialized.
<6>[ 0.946216] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
<6>[ 0.946235] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
<6>[ 0.947572] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
<6>[ 0.947591] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
<3>[ 0.947827] pwm-voltage-regulator pwm_regulator.26: unable to request PWM, trying legacy API
<3>[ 0.947845] pwm-voltage-regulator pwm_regulator.26: unable to request legacy PWM
<4>[ 0.947856] pwm_regulator_probe:error
<6>[ 0.947876] platform pwm_regulator.26: Driver pwm-voltage-regulator requests probe deferral
<4>[ 0.948064] rk_serial.c v1.8 2014-03-04
<6>[ 0.948269] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
<6>[ 0.948442] serial ff180000.serial: membase e41c6000
<6>[ 0.948593] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1
<6>[ 0.948757] serial ff190000.serial: membase e41ce000
<6>[ 0.948889] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90) is a rk29_serial.3
<6>[ 0.949051] serial ff1b0000.serial: membase e41d6000
<6>[ 0.949204] ff1c0000.serial: ttyS4 at MMIO 0xff1c0000 (irq = 91) is a rk29_serial.4
<6>[ 0.949390] serial ff1c0000.serial: membase e41d8000
<6>[ 0.952101] loop: module loaded
<6>[ 0.952474] zram: Created 1 device(s) …
<7>[ 0.952559] of_get_named_gpio_flags exited with status 256
<6>[ 0.952625] i2c i2c-1: mpu_probe: 0
<6>[ 0.952742] 6mldl_cfg:Reset MPU6050 B1
<3>[ 0.953714] drivers/misc/inv_mpu/mlsl-kernel.c|inv_i2c_write|48 returning -11
<3>[ 0.953733] drivers/misc/inv_mpu/mldl_cfg.c|mpu60xx_pwr_mgmt|563 returning -11
<3>[ 0.953747] drivers/misc/inv_mpu/mldl_cfg.c|inv_mpu_open|1461 returning -11
<3>[ 0.953762] i2c i2c-1: Unable to open mpu6050B1 -11
<3>[ 0.953778] i2c i2c-1: mpu_probe failed -19
<4>[ 0.953824] i2c-core: driver [mpu6050B1] using legacy suspend method
<4>[ 0.953836] i2c-core: driver [mpu6050B1] using legacy resume method
<6>[ 0.953865] mpu_init: Probe name mpu6050B1
<4>[ 0.954052] bus=0,adapt_num=0,addr=d
<4>[ 0.954064] 1 0 0 0 1 0 0 0 -1
<6>[ 0.954092] i2c i2c-1: ak8963_mod_probe: (null)
<4>[ 0.954102] yemk:ak8963_mod_probe
<3>[ 0.954115] i2c i2c-1: inv_mpu_register_slave: Null mpu_private_data
<3>[ 0.954126] invensense: in ak8963_mod_probe, result is -22
<3>[ 0.954139] i2c i2c-1: Slave registration failed: (null), -22
<3>[ 0.954152] i2c i2c-1: ak8963_mod_probe failed -22
<4>[ 0.954168] ak8963_mod: probe of 1-000d failed with error -22
<6>[ 0.954203] ak8963_mod_init: Probe name ak8963_mod
<4>[ 0.954439] drivers/misc/rk29_modem/modem_longcheer_u9300c.c[293]: u9300c_ctrl_probe
<7>[ 0.954456] of_get_named_gpio_flags exited with status 3
<7>[ 0.954469] of_get_named_gpio_flags exited with status 172
<7>[ 0.954480] of_get_named_gpio_flags exited with status 173
<4>[ 0.954488] drivers/misc/rk29_modem/rk29_modem.c[283]: rk29_modem_init
<4>[ 0.954568] drivers/misc/rk29_modem/rk29_modem.c[209]: rk29_modem_dev_init
<4>[ 0.954598] drivers/misc/rk29_modem/rk29_modem.c[170]: install_irq
<4>[ 0.954628] install_irq: 173 ==> 193
<4>[ 0.954709] drivers/misc/rk29_modem/rk29_modem.c[314]: modem init fineshed
<4>[ 0.954721] func: u9300c_ctrl_probe, ret = 0
<4>[ 0.954867] drivers/misc/gps/zkw_atgm332d.c[217]: rk29_gps_probe
<7>[ 0.954888] of_get_named_gpio_flags exited with status 6
<4>[ 0.954897] rk29_gps_probe[236]: power-pin [6]; power-en [0]
<4>[ 0.955112] gps_power_up[43]
<4>[ 0.955129] rk29_gps_probe:rk29 GPS initialized
<6>[ 0.955696] SCSI Media Changer driver v0.25
<6>[ 0.956037] tun: Universal TUN/TAP device driver, 1.6
<6>[ 0.956050] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
<4>[ 0.956172] vmac_init.
<6>[ 0.956701] stmmac_probe_config_dt: ethernet phy power controled by pmu(act_ldo5).
<6>[ 0.956716] stmmac_probe_config_dt: clock input/output? (input).
<6>[ 0.956729] stmmac_probe_config_dt: TX delay(0x29).
<6>[ 0.956740] stmmac_probe_config_dt: RX delay(0x16).
<7>[ 0.956755] of_get_named_gpio_flags exited with status 9
<7>[ 0.956765] of_get_named_gpio_flags exited with status 8
<7>[ 0.956776] of_get_named_gpio_flags exited with status 136
<7>[ 0.956786] of_get_named_gpio_flags: can’t parse gpios property
<6>[ 0.956796] stmmac_probe_config_dt: is rockchip,rk3288-gmac
<6>[ 0.956806] stmmc_pltfr_init:
<3>[ 0.956815] stmmc_pltfr_init: ERROR: Get power-gpio failed.
<6>[ 0.956923] stmmc_pltfr_init: init for RGMII
<6>[ 0.956936] tx delay=0x29
<6>[ 0.956936] rx delay=0x16
<6>[ 0.956952] tx delay=0x29
<6>[ 0.956952] rx delay=0x16
<6>[ 0.957391] stmmac - user ID: 0x10, Synopsys ID: 0x35
<6>[ 0.957402] Normal descriptors
<6>[ 0.957410] Ring mode enabled
<6>[ 0.957420] DMA HW capability register supported
<6>[ 0.957431] RX Checksum Offload Engine supported (type 2)
<6>[ 0.957441] TX Checksum insertion supported
<6>[ 0.957450] Wake-Up On Lan supported
<6>[ 0.957495] Enable RX Mitigation via HW Watchdog Timer
<6>[ 0.957884] PPP generic driver version 2.4.2
<6>[ 0.958027] PPP BSD Compression module registered
<6>[ 0.958039] PPP Deflate Compression module registered
<6>[ 0.958061] PPP MPPE Compression module registered
<6>[ 0.958073] NET: Registered protocol family 24
<6>[ 0.958102] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
<6>[ 0.958116] CSLIP: code copyright 1989 Regents of the University of California.
<4>[ 0.958128] Rockchip WiFi SYS interface (V1.00) …
<4>[ 0.958157] RTL871X: module init start
<4>[ 0.958168] RTL871X: rtl8723bu v4.3.9.6_13610.20150310_BTCOEX20140929-5443
<4>[ 0.958178] RTL871X: build time: Jul 26 2019 11:39:46
<4>[ 0.958188] RTL871X: rtl8723bu BT-Coex version = BTCOEX20140929-5443
<6>[ 0.958257] usbcore: registered new interface driver rtl8723bu
<4>[ 0.958269] RTL871X: module init ret=0
<4>[ 0.958279] esp_mem_init enter date Jul 26 2019 11:39:44
<4>[ 0.958288] esp_mem_init VERSION [V2.5]
<4>[ 0.958328] esp_mem_init complete
<6>[ 0.958381] usbcore: registered new interface driver catc
<6>[ 0.958420] usbcore: registered new interface driver kaweth
<6>[ 0.958433] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
<6>[ 0.958475] usbcore: registered new interface driver pegasus
<6>[ 0.958514] usbcore: registered new interface driver rtl8150
<6>[ 0.958552] usbcore: registered new interface driver r8152
<6>[ 0.958563] hso: drivers/net/usb/hso.c: Option Wireless
<6>[ 0.958623] usbcore: registered new interface driver hso
<6>[ 0.958665] usbcore: registered new interface driver asix
<6>[ 0.958703] usbcore: registered new interface driver ax88179_178a
<6>[ 0.958743] usbcore: registered new interface driver cdc_ether
<6>[ 0.958781] usbcore: registered new interface driver cdc_eem
<6>[ 0.958817] usbcore: registered new interface driver dm9601
<6>[ 0.958854] usbcore: registered new interface driver dm9620
<6>[ 0.958900] usbcore: registered new interface driver smsc75xx
<6>[ 0.958945] usbcore: registered new interface driver smsc95xx
<6>[ 0.958987] usbcore: registered new interface driver gl620a
<6>[ 0.959029] usbcore: registered new interface driver net1080
<6>[ 0.959066] usbcore: registered new interface driver plusb
<6>[ 0.959104] usbcore: registered new interface driver rndis_host
<6>[ 0.959142] usbcore: registered new interface driver cdc_subset
<6>[ 0.959177] usbcore: registered new interface driver zaurus
<6>[ 0.959217] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
<6>[ 0.959270] usbcore: registered new interface driver int51x1
<6>[ 0.959313] usbcore: registered new interface driver kalmia
<6>[ 0.959352] usbcore: registered new interface driver ipheth
<6>[ 0.959394] usbcore: registered new interface driver sierra_net
<6>[ 0.959433] usbcore: registered new interface driver cx82310_eth
<6>[ 0.959479] usbcore: registered new interface driver cdc_ncm
<6>[ 0.959518] usbcore: registered new interface driver qmi_wwan
<6>[ 0.959556] usbcore: registered new interface driver cdc_mbim
<6>[ 0.959568] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
<6>[ 0.961978] EHCI: ehci_rk_probe e4240000 e4240010
<6>[ 0.961995] rockchip_ehci_host ff500000.usb: EHCI Host Controller
<6>[ 0.962023] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
<6>[ 0.962330] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
<6>[ 0.981590] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00
<6>[ 0.981664] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 0.981681] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 0.981695] usb usb1: Product: EHCI Host Controller
<6>[ 0.981707] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
<6>[ 0.981720] usb usb1: SerialNumber: ff500000.usb
<6>[ 0.982141] hub 1-0:1.0: USB hub found
<6>[ 0.982168] hub 1-0:1.0: 1 port detected
<6>[ 0.982327] EHCI: ehci_rk_probe ok
<6>[ 0.982428] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
<6>[ 0.982618] usbcore: registered new interface driver usblp
<6>[ 0.982668] usbcore: registered new interface driver cdc_wdm
<6>[ 0.982728] usbcore: registered new interface driver usb-storage
<6>[ 0.982765] usbcore: registered new interface driver ums-alauda
<6>[ 0.982802] usbcore: registered new interface driver ums-cypress
<6>[ 0.982839] usbcore: registered new interface driver ums-datafab
<6>[ 0.982881] usbcore: registered new interface driver ums_eneub6250
<6>[ 0.982918] usbcore: registered new interface driver ums-freecom
<6>[ 0.982956] usbcore: registered new interface driver ums-isd200
<6>[ 0.982993] usbcore: registered new interface driver ums-jumpshot
<6>[ 0.983029] usbcore: registered new interface driver ums-karma
<6>[ 0.983067] usbcore: registered new interface driver ums-onetouch
<6>[ 0.983104] usbcore: registered new interface driver ums-sddr09
<6>[ 0.983140] usbcore: registered new interface driver ums-sddr55
<6>[ 0.983177] usbcore: registered new interface driver ums-usbat
<6>[ 0.983264] usbcore: registered new interface driver usbserial
<6>[ 0.983305] usbcore: registered new interface driver usbserial_generic
<6>[ 0.983337] usbserial: USB Serial support registered for generic
<6>[ 0.983376] usbcore: registered new interface driver ch341
<6>[ 0.983407] usbserial: USB Serial support registered for ch341-uart
<6>[ 0.983446] usbcore: registered new interface driver option
<6>[ 0.983478] usbserial: USB Serial support registered for GSM modem (1-port)
<6>[ 0.983543] usbcore: registered new interface driver pl2303
<6>[ 0.983574] usbserial: USB Serial support registered for pl2303
<6>[ 0.983623] usbcore: registered new interface driver trancevibrator
<6>[ 0.983635] usb20_otg: version 3.10a 21-DEC-2012
<4>[ 0.984013] e4280040
<4>[ 0.984026] Core Release: 3.10a
<4>[ 0.984038] Setting default values for core params
<4>[ 0.984151] Using Buffer DMA mode
<4>[ 0.984162] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 0.984173] Multiprocessor Interrupt Enhancement - disabled
<4>[ 0.984184] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 0.984194] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 0.984209] Dedicated Tx FIFOs mode
<4>[ 0.984224] pcd_init otg_dev = ddf312c0
<6>[ 0.984372] usb20_otg ff580000.usb: DWC OTG Controller
<6>[ 0.984402] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
<6>[ 0.984435] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
<6>[ 0.984489] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 0.984505] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 0.984519] usb usb2: Product: DWC OTG Controller
<6>[ 0.984531] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
<6>[ 0.984544] usb usb2: SerialNumber: ff580000.usb
<6>[ 0.984963] hub 2-0:1.0: USB hub found
<6>[ 0.984985] hub 2-0:1.0: 1 port detected
<6>[ 0.985284] usb20_host: version 3.10a 21-DEC-2012
<4>[ 0.987764] e4300040
<4>[ 0.987777] Core Release: 3.10a
<4>[ 0.987788] Setting default values for core params
<4>[ 0.987903] Using Buffer DMA mode
<4>[ 0.987915] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 0.987925] Multiprocessor Interrupt Enhancement - disabled
<4>[ 0.987936] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 0.987946] ^^^^^^^^^^^^^^^^^^Host Mode
<6>[ 0.987970] usb20_host ff540000.usb: DWC OTG Controller
<6>[ 0.987994] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
<6>[ 0.988023] usb20_host ff540000.usb: irq 57, io mem 0x00000000
<4>[ 0.988113] Init: Power Port (0)
<6>[ 0.988164] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 0.988180] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 0.988193] usb usb3: Product: DWC OTG Controller
<6>[ 0.988206] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
<6>[ 0.988218] usb usb3: SerialNumber: ff540000.usb
<6>[ 0.988610] hub 3-0:1.0: USB hub found
<6>[ 0.988631] hub 3-0:1.0: 1 port detected
<6>[ 0.989291] usbcore: registered new interface driver xpad
<6>[ 0.989345] usbcore: registered new interface driver usb_acecad
<6>[ 0.989392] usbcore: registered new interface driver aiptek
<6>[ 0.989442] usbcore: registered new interface driver gtco
<6>[ 0.989491] usbcore: registered new interface driver Hanvon Stylus Pen
<6>[ 0.989537] usbcore: registered new interface driver kbtab
<6>[ 0.989588] usbcore: registered new interface driver wacom
<4>[ 0.989767] vtl_ts_probe() end
<4>[ 0.990077] sensor_register_slave:mma8452,id=17
<4>[ 0.990084] error tp_fw not node!!!
<3>[ 0.990094] vtl_ts 4-0001: VTL touch screen config Failed.
<4>[ 0.990102] vtl_ts_Kthread exit,vtl_ts_handler(684)
<4>[ 0.990118] sensor_register_slave:gs_mc3230,id=23
<4>[ 0.990128] gsensor_init
<4>[ 0.990137] sensor_register_slave:mpu6880_acc,id=24
<4>[ 0.990148] sensor_register_slave:mpu6500_acc,id=25
<4>[ 0.990158] sensor_register_slave:cm3217,id=48
<4>[ 0.990168] sensor_register_slave:cm3218,id=49
<7>[ 0.990387] of_get_named_gpio_flags exited with status 229
<4>[ 0.990494] remotectl probe, ID=0x0
<4>[ 0.990507] remotectl probe, ID=0x1
<4>[ 0.990516] remotectl probe, ID=0x2
<4>[ 0.990524] remotectl probe, ID=0x3
<6>[ 0.990660] input: rkxx-remotectl.32 as /devices/rkxx-remotectl.32/input/input0
<7>[ 0.993531] of_get_named_gpio_flags exited with status 263
<6>[ 0.995417] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
<6>[ 0.995462] i2c /dev entries driver
<6>[ 0.996081] IR NEC protocol handler initialized
<6>[ 0.996095] IR RC5(x) protocol handler initialized
<6>[ 0.996105] IR RC6 protocol handler initialized
<6>[ 0.996114] IR JVC protocol handler initialized
<6>[ 0.996124] IR Sony protocol handler initialized
<6>[ 0.996133] IR RC5 (streamzap) protocol handler initialized
<6>[ 0.996143] IR SANYO protocol handler initialized
<6>[ 0.996153] IR MCE Keyboard/mouse protocol handler initialized
<6>[ 0.996299] usbcore: registered new interface driver uvcvideo
<6>[ 0.996311] USB Video Class driver (1.1.1)
<4>[ 0.996623] rockchip_temp_probe,line=362
<6>[ 1.050465] tsadc ff280000.tsadc: initialized
<6>[ 1.050813] device-mapper: uevent: version 1.0.3
<6>[ 1.051039] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
<6>[ 1.051309] Bluetooth: HCI UART driver ver 2.2
<6>[ 1.051325] Bluetooth: HCI H4 protocol initialized
<6>[ 1.051336] Bluetooth: HCILL protocol initialized
<6>[ 1.051346] rtk_btusb: RTKBT_RELEASE_NAME: 20180321_BT_ANDROID_5.0_USB
<6>[ 1.051357] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.5
<6>[ 1.051368] rtk_btusb: Register usb char device interface for BT driver
<6>[ 1.051534] usbcore: registered new interface driver rtk_btusb
<4>[ 1.080249] dwc_otg_hcd_suspend, usb device mode
<4>[ 1.169735] cpufreq version 1.0, suspend freq 1200 MHz
<6>[ 1.170366] cpuidle: using governor ladder
<6>[ 1.170412] cpuidle: using governor menu
<6>[ 1.170532] Synopsys Designware Multimedia Card Interface Driver
<6>[ 1.170572] MHSC version = Ver 2.00 2015-06-10
<4>[ 1.171413] dw cru_regsbase addr 0x1d8.
<4>[ 1.171457] dw cru_reset_offset val 3.
<6>[ 1.171508] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
<3>[ 1.171625] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc
<6>[ 1.172640] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
<4>[ 1.173138] dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
<7>[ 1.173236] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 1.173534] 1358..dw_mci_set_ios: no card. [mmc0]
<4>[ 1.188319] 1358..dw_mci_set_ios: no card. [mmc0]
<4>[ 1.193865] ------edid base-----
<4>[ 1.193879]
<4>[ 1.193889] 0x 0,0xff,0xff,0xff,0xff,0xff,0xff,0x 0,0x 5,0xe3,0x 0,0x19,0x21,0x62,0x 0,0x 0,
<4>[ 1.193945] 0x21,0x14,0x 1,0x 3,0x80,0x29,0x17,0x78,0x2a,0xee,0xd1,0xa5,0x55,0x48,0x9b,0x26,
<4>[ 1.194000] 0x12,0x50,0x54,0xbf,0xee,0x 0,0x31,0x a,0x61,0x4c,0x 1,0x 1,0x 1,0x 1,0x 1,0x 1,
<4>[ 1.194054] 0x 1,0x 1,0x 1,0x 1,0x 1,0x 1,0x66,0x21,0x56,0xaa,0x51,0x 0,0x1e,0x30,0x46,0x8f,
<4>[ 1.194108] 0x33,0x 0,0x9d,0xea,0x10,0x 0,0x 0,0x1e,0x66,0x21,0x50,0xb0,0x51,0x 0,0x1b,0x30,
<4>[ 1.194161] 0x40,0x70,0x36,0x 0,0x22,0x13,0x 0,0x 0,0x 0,0x1e,0x 0,0x 0,0x 0,0xfd,0x 0,0x37,
<4>[ 1.194214] 0x4b,0x1e,0x51,0x 9,0x 0,0x a,0x20,0x20,0x20,0x20,0x20,0x20,0x 0,0x 0,0x 0,0xfc,
<4>[ 1.194267] 0x 0,0x46,0x31,0x39,0x a,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x 0,0xf8,edid base detail timing is [1]
<4>[ 1.194267] edid base detail timing is [1]
<4>[ 1.194267]
<6>[ 1.194381] rockchip-hdmiv2 ff980000.hdmi: warning: no CEA video mode parsed from EDID !!!
<6>[ 1.194417] hdmi output corlor mode is 1
<4>[ 1.194433] >>>>>>>>>rk_fb_switch_screen screen->type = 6
<4>[ 1.194449] hdmi connect to lcdc0
<6>[ 1.194463] switch:en=1,lcdc_id=0,screen type=6,cur type=6
<4>[ 1.207972] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
<6>[ 1.207992] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
<6>[ 1.208006] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
<4>[ 1.208334] dw cru_regsbase addr 0x1d8.
<4>[ 1.208351] dw cru_reset_offset val 0.
<6>[ 1.208370] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
<3>[ 1.208412] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc
<6>[ 1.209186] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
<4>[ 1.209384] dw_mci_init_slot: fmin=400000, fmax=50000000 [mmc1]
<7>[ 1.209443] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 1.209944] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
<4>[ 1.210085] 1358..dw_mci_set_ios: no card. [mmc1]
<4>[ 1.227618] 1358..dw_mci_set_ios: no card. [mmc1]
<6>[ 1.247310] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
<6>[ 1.247327] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
<4>[ 1.247672] dw cru_regsbase addr 0x1d8.
<4>[ 1.247684] dw cru_reset_offset val 1.
<6>[ 1.247697] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
<3>[ 1.247728] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc
<6>[ 1.247944] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
<4>[ 1.248103] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
<7>[ 1.248129] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 1.248387] 1358..dw_mci_set_ios: no card. [mmc2]
<6>[ 1.260183] mmc0: BKOPS_EN bit is not set
<4>[ 1.262066] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0]
<6>[ 1.264353] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
<4>[ 1.264381] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
<6>[ 1.264407] [mmc0] tuning regsbase addr 0x218.
<3>[ 1.265070] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
<3>[ 1.265084] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
<3>[ 1.265123] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
<3>[ 1.265154] [mmc0] Data transmission error !!! MINTSTS: [0x000000ce]
<3>[ 1.265166] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
<3>[ 1.265190] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
<3>[ 1.265477] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-180 (17 len)
<3>[ 1.265494] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 214-282 (7 len)
<3>[ 1.265509] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-180 (17 len)
<3>[ 1.265522] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 90
<6>[ 1.265573] mmc0: new HS200 MMC card at address 0001
<6>[ 1.265895] mmcblk0: mmc0:0001 008G70 7.28 GiB
<6>[ 1.266264] uboot: 0x000400000 – 0x000800000 (4 MB)
<6>[ 1.266281] misc: 0x000800000 – 0x000c00000 (4 MB)
<6>[ 1.266294] resource: 0x000c00000 – 0x001c00000 (16 MB)
<6>[ 1.266306] kernel: 0x001c00000 – 0x002c00000 (16 MB)
<6>[ 1.266318] boot: 0x002c00000 – 0x004c00000 (32 MB)
<6>[ 1.266330] recovery: 0x004c00000 – 0x006c00000 (32 MB)
<6>[ 1.266342] backup: 0x006c00000 – 0x00a000000 (52 MB)
<6>[ 1.266354] cache: 0x00a000000 – 0x012000000 (128 MB)
<6>[ 1.266365] kpanic: 0x012000000 – 0x012400000 (4 MB)
<6>[ 1.266377] system: 0x012400000 – 0x052400000 (1024 MB)
<6>[ 1.266389] metadata: 0x052400000 – 0x053400000 (16 MB)
<6>[ 1.266401] radical_update: 0x053400000 – 0x057400000 (64 MB)
<6>[ 1.266413] userdata: 0x057400000 – 0x1d1c00000 (6056 MB)
<4>[ 1.266995] 1358..dw_mci_set_ios: no card. [mmc2]
<6>[ 1.266456] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p131358..dw_mci_set_ios: no card. [mmc1]
<4>[ 1.286634] 1358..dw_mci_set_ios: no card. [mmc2]
<6>[ 1.286672] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
<6>[ 1.286684] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
<6>[ 1.286915] hidraw: raw HID events driver (C) Jiri Kosina
<6>[ 1.288312] usbcore: registered new interface driver usbhid
<6>[ 1.288321] usbhid: USB HID core driver
<6>[ 1.288422] ashmem: initialized
<6>[ 1.288524] logger: created 256K log ‘log_main’
<6>[ 1.288611] logger: created 256K log ‘log_events’
<6>[ 1.288699] logger: created 256K log ‘log_radio’
<6>[ 1.288788] logger: created 256K log ‘log_system’
<7>[ 1.289480] of_get_named_gpio_flags exited with status 5
<7>[ 1.289489] of_get_named_gpio_flags exited with status 5
<6>[ 1.289681] input: rk29-keypad as /devices/ff100000.adc/key.34/input/input1
<7>[ 1.290730] of_get_named_gpio_flags exited with status 228
<7>[ 1.290747] of_get_named_gpio_flags: can’t parse gpios property
<7>[ 1.290753] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 1.290766] es8323 probe i2c recv ok
<4>[ 1.291105] es8323_probe
<6>[ 1.296477] usb 1-1: new high-speed USB device number 2 using rockchip_ehci_host
<6>[ 1.445629] usb 1-1: New USB device found, idVendor=05e3, idProduct=0608
<6>[ 1.445640] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
<6>[ 1.445648] usb 1-1: Product: USB2.0 Hub
<6>[ 1.446187] hub 1-1:1.0: USB hub found
<6>[ 1.446489] hub 1-1:1.0: 4 ports detected
<6>[ 1.719920] usb 1-1.2: new high-speed USB device number 3 using rockchip_ehci_host
<6>[ 1.829016] usb 1-1.2: New USB device found, idVendor=14cd, idProduct=8601
<6>[ 1.829026] usb 1-1.2: New USB device strings: Mfr=1, Product=3, SerialNumber=0
<6>[ 1.829033] usb 1-1.2: Product: USB 2.0 Hub
<6>[ 1.829040] usb 1-1.2: Manufacturer: USB Device
<6>[ 1.829324] hub 1-1.2:1.0: USB hub found
<6>[ 1.829510] hub 1-1.2:1.0: 4 ports detected
<6>[ 1.906754] usb 1-1.3: new high-speed USB device number 4 using rockchip_ehci_host
<6>[ 1.975412] rk_fb_switch_screen: wait update_regs_wait timeout
<4>[ 1.975426] >>>>>>>>> x_res=1280,y_res=720,left=100,top=100,right=100,bottom=100
<6>[ 1.975473] rk3288-lcdc lcdc0: lcdc0: dclk:74250000>>fps:60
<6>[ 1.975500] pixel clk is 74250000 tmds clk is 74250000
<6>[ 1.975525] rockchip-hdmiv2 ff980000.hdmi: [hdmi_dev_config_video] sucess output DVI.
<6>[ 2.016222] usb 1-1.3: New USB device found, idVendor=05e3, idProduct=0608
<6>[ 2.016232] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
<6>[ 2.016239] usb 1-1.3: Product: USB2.0 Hub
<6>[ 2.016646] hub 1-1.3:1.0: USB hub found
<6>[ 2.016960] hub 1-1.3:1.0: 4 ports detected
<4>[ 2.063997] Using Buffer DMA mode
<4>[ 2.064005] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 2.064010] Multiprocessor Interrupt Enhancement - disabled
<4>[ 2.064016] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 2.064022] ^^^^^^^^^^^^^^^^^^Host Mode
<6>[ 2.066481] rockchip-es8323 rockchip-es8323.31: ES8323 HiFi ↔ ff890000.rockchip-i2s mapping ok
<6>[ 2.068249] rockchip-hdmi-i2s rockchip-hdmi-i2s.29: rk-hdmi-i2s-hifi ↔ ff890000.rockchip-i2s mapping ok
<6>[ 2.068554] u32 classifier
<6>[ 2.068560] Actions configured
<6>[ 2.068569] Netfilter messages via NETLINK v0.30.
<6>[ 2.068607] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
<6>[ 2.068834] ctnetlink v0.93: registering with nfnetlink.
<6>[ 2.068874] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
<6>[ 2.068880] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
<6>[ 2.069055] xt_time: kernel timezone is -0000
<6>[ 2.069203] ip_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 2.069296] arp_tables: (C) 2002 David S. Miller
<6>[ 2.069323] TCP: cubic registered
<6>[ 2.069328] Initializing XFRM netlink socket
<6>[ 2.069481] NET: Registered protocol family 10
<6>[ 2.069853] mip6: Mobile IPv6
<6>[ 2.069873] ip6_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 2.069958] sit: IPv6 over IPv4 tunneling driver
<6>[ 2.070193] NET: Registered protocol family 17
<6>[ 2.070212] NET: Registered protocol family 15
<5>[ 2.070249] Bridge firewalling registered
<6>[ 2.070258] Ebtables v2.0 registered
<6>[ 2.070362] Bluetooth: RFCOMM TTY layer initialized
<6>[ 2.070381] Bluetooth: RFCOMM socket layer initialized
<6>[ 2.070387] Bluetooth: RFCOMM ver 1.11
<6>[ 2.070393] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
<6>[ 2.070398] Bluetooth: BNEP filters: protocol multicast
<6>[ 2.070406] Bluetooth: BNEP socket layer initialized
<6>[ 2.070412] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
<6>[ 2.070421] Bluetooth: HIDP socket layer initialized
<6>[ 2.070437] l2tp_core: L2TP core driver, V2.0
<6>[ 2.070447] l2tp_ppp: PPPoL2TP kernel driver, V2.0
<6>[ 2.070453] [WLAN_RFKILL]: Enter rfkill_wlan_init
<6>[ 2.070580] [WLAN_RFKILL]: Enter rfkill_wlan_probe
<6>[ 2.070588] [WLAN_RFKILL]: can’t find rockchip,grf property
<6>[ 2.070594] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = rtl8188eu
<6>[ 2.070601] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power will enabled while kernel starting and keep on.
<6>[ 2.070609] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
<6>[ 2.070615] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
<7>[ 2.070627] of_get_named_gpio_flags exited with status 233
<6>[ 2.070632] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 233, flags = 1.
<7>[ 2.070638] of_get_named_gpio_flags: can’t parse gpios property
<7>[ 2.070643] of_get_named_gpio_flags: can’t parse gpios property
<6>[ 2.070647] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
<6>[ 2.070664] [WLAN_RFKILL]: rockchip_wifi_power: 1
<6>[ 2.070670] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
<6>[ 2.070676] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
<6>[ 2.070682] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
<4>[ 2.113223] Init: Power Port (0)
<4>[ 2.113252] ff580000.usb resume, HPRT0:0x1000
<6>[ 2.142795] usb 1-1.2.1: new full-speed USB device number 5 using rockchip_ehci_host
<6>[ 2.172216] [WLAN_RFKILL]: wifi turn on power. 233
<6>[ 2.172223] [WLAN_RFKILL]: rockchip_wifi_power: 0
<6>[ 2.172229] [WLAN_RFKILL]: rockchip_wifi_power: wifi power is setted to be remain on. skip anything to the power control
<6>[ 2.182078] [WLAN_RFKILL]: rockchip_wifi_power: 1
<6>[ 2.182084] [WLAN_RFKILL]: rockchip_wifi_power: wifi power is setted to be remain on. skip anything to the power control
<6>[ 2.182091] mmc2:mmc host rescan start!
<6>[ 2.182102] [WLAN_RFKILL]: rockchip_wifi_voltage_select: unsupport wifi & sdio reference voltage!
<6>[ 2.182109] [WLAN_RFKILL]: Exit rfkill_wlan_probe
<6>[ 2.182140] [BT_RFKILL]: Enter rfkill_rk_init
<7>[ 2.182225] of_get_named_gpio_flags: can’t parse gpios property
<6>[ 2.182231] [BT_RFKILL]: bluetooth_platdata_parse_dt: uart_rts_gpios is unvalid.
<6>[ 2.182238] [BT_RFKILL]: rfkill_rk_probe: No platform data specified
<4>[ 2.182248] rfkill_bt: probe of wireless-bluetooth.25 failed with error -22
<4>[ 2.182818] rk3288_init_suspend
<4>[ 2.182826] rk3288_suspend_init enter
<4>[ 2.182945] rk3288_suspend_init: pm_ctrbits =7
<4>[ 2.182968] gpio_get_dts_info suspend:4
<4>[ 2.182974] gpio_get_dts_info resume:4
<4>[ 2.182979] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
<4>[ 2.183003] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
<4>[ 2.183111] clks_gating_suspend_init:clkgt info ok
<5>[ 2.183184] Registering SWP/SWPB emulation handler
<6>[ 2.183194] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 0x02000000@0x7dc00000
<6>[ 2.185577] ddrfreq: verion 1.2 20140526
<6>[ 2.185587] ddrfreq: normal 396MHz video_1080p 240MHz video_4k 396MHz dualview 396MHz idle 0MHz suspend 200MHz reboot 396MHz
<6>[ 2.185593] ddrfreq: auto-freq=1
<6>[ 2.185599] ddrfreq: auto-freq-table[0] 240MHz
<6>[ 2.185603] ddrfreq: auto-freq-table[1] 324MHz
<6>[ 2.185608] ddrfreq: auto-freq-table[2] 396MHz
<6>[ 2.185613] ddrfreq: auto-freq-table[3] 528MHz
<6>[ 2.185999] regulator-dummy: disabling
<4>[ 2.186263] pcd_pullup, is_on 0
<4>[ 2.186278] WARN::dwc_otg_handle_mode_mismatch_intr:69: Mode Mismatch Interrupt: currently in Host mode
<4>[ 2.186278]
<6>[ 2.186324] file system registered
<6>[ 2.186861] android_usb gadget: Mass Storage Function, version: 2009/09/11
<6>[ 2.186870] android_usb gadget: Number of LUNs=2
<6>[ 2.186877] lun0: LUN: removable file: (no medium)
<6>[ 2.186883] lun1: LUN: removable file: (no medium)
<6>[ 2.187041] android_usb gadget: android_usb ready
<6>[ 2.187115] sensor_init: Probe name sensors
<4>[ 2.187132] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
<6>[ 2.187667] rtc_hym8563 0-0051: setting system clock to 2019-07-27 06:35:48 UTC (1564209348)
<6>[ 2.192848] usbcore: registered new interface driver snd-usb-audio
<6>[ 2.192859] ALSA device list:
<6>[ 2.192864] #0: RK_ES8323
<6>[ 2.192869] #1: RK-HDMI-I2S
<6>[ 2.193127] Freeing unused kernel memory: 352K (c0b24000 - c0b7c000)
<7>[ 2.196600] SELinux: 2048 avtab hash slots, 5489 rules.
<7>[ 2.198172] SELinux: 2048 avtab hash slots, 5489 rules.
<7>[ 2.198194] SELinux: 1 users, 2 roles, 445 types, 0 bools, 1 sens, 1024 cats
<7>[ 2.198202] SELinux: 86 classes, 5489 rules
<7>[ 2.199035] SELinux: Completing initialization.
<7>[ 2.199042] SELinux: Setting up existing superblocks.
<7>[ 2.199057] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
<7>[ 2.199072] SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts
<7>[ 2.199123] SELinux: initialized (dev bdev, type bdev), not configured for labeling
<7>[ 2.199135] SELinux: initialized (dev proc, type proc), uses genfs_contexts
<7>[ 2.199150] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 2.199164] SELinux: initialized (dev devtmpfs, type devtmpfs), uses transition SIDs
<7>[ 2.199343] SELinux: initialized (dev debugfs, type debugfs), uses genfs_contexts
<7>[ 2.209149] SELinux: initialized (dev sockfs, type sockfs), uses task SIDs
<7>[ 2.209164] SELinux: initialized (dev pipefs, type pipefs), uses task SIDs
<7>[ 2.209174] SELinux: initialized (dev anon_inodefs, type anon_inodefs), not configured for labeling
<7>[ 2.209184] SELinux: initialized (dev devpts, type devpts), uses transition SIDs
<7>[ 2.209202] SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts
<7>[ 2.209252] SELinux: initialized (dev configfs, type configfs), not configured for labeling
<7>[ 2.209260] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 2.209280] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
<5>[ 2.254065] type=1403 audit(1564209348.560:2): policy loaded auid=4294967295 ses=4294967295
<11>[ 2.276657] init: could not import file ‘init.box.samba.rc’ from ‘/init.rk30board.rc’
<11>[ 2.278351] init: invalid gid ‘trace’
<6>[ 2.281676] usb 1-1.2.1: New USB device found, idVendor=10c4, idProduct=ea60
<6>[ 2.281688] usb 1-1.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
<6>[ 2.281696] usb 1-1.2.1: Product: CP2102 USB to UART Bridge Controller
<6>[ 2.281702] usb 1-1.2.1: Manufacturer: Silicon Labs
<6>[ 2.281709] usb 1-1.2.1: SerialNumber: 0001
<11>[ 2.367267] init: /dev/hw_random not found
<6>[ 2.367327] keychord: using input dev rkxx-remotectl.32 for fevent
<6>[ 2.367337] keychord: using input dev rk29-keypad for fevent
<7>[ 2.367757] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<7>[ 2.368002] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 2.368260] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<7>[ 2.369417] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 2.369565] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 2.370594] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<11>[ 2.371808] init: /dev/hw_random not found
<14>[ 2.372727] fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
<14>[ 2.373546] resize2fs: resize2fs 1.42.9 (28-Dec-2013)resize2fs: The filesystem is already 262144 blocks long. Nothing to do!resize2fs:
<4>[ 2.376541] EXT4-fs (mmcblk0p10): Ignoring removed nomblk_io_submit option
<6>[ 2.378971] usb 1-1.2.2: new high-speed USB device number 6 using rockchip_ehci_host
<6>[ 2.380454] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
<7>[ 2.380477] SELinux: initialized (dev mmcblk0p10, type ext4), uses xattr
<14>[ 2.380539] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/system,/system,ext4)=0
<14>[ 2.381277] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
<14>[ 2.386247] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
<14>[ 2.386290] e2fsck: system: clean, 1836/64512 files, 257550/262144 blocks
<6>[ 2.389744] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
<7>[ 2.389764] SELinux: initialized (dev mmcblk0p10, type ext4), uses xattr
<14>[ 2.389808] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/system,target=/system,type=ext4)=0
<6>[ 2.393909] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
<7>[ 2.393930] SELinux: initialized (dev mmcblk0p8, type ext4), uses xattr
<14>[ 2.393972] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/cache,target=/cache,type=ext4)=0
<4>[ 2.394367] EXT4-fs (mmcblk0p11): Ignoring removed nomblk_io_submit option
<6>[ 2.397838] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
<7>[ 2.397854] SELinux: initialized (dev mmcblk0p11, type ext4), uses xattr
<14>[ 2.397887] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,/metadata,ext4)=0
<4>[ 2.398561] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2]
<14>[ 2.398592] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata
<14>[ 2.404690] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
<14>[ 2.404724] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata: clean, 11/1024 files, 1102/4096 blocks
<6>[ 2.408565] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
<7>[ 2.408584] SELinux: initialized (dev mmcblk0p11, type ext4), uses xattr
<14>[ 2.408629] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,target=/metadata,type=ext4)=0
<14>[ 2.408667] fs_mgr: Running /system/bin/fsck.f2fs -f /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
<14>[ 2.409543] fsck.f2fs: executing /system/bin/fsck.f2fs failed: No such file or directory
<14>[ 2.409577] fsck.f2fs: fsck.f2fs terminated by exit(255)
<14>[ 2.409806] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=f2fs)=-1
<4>[ 2.410187] EXT4-fs (mmcblk0p13): Ignoring removed nomblk_io_submit option
<7>[ 2.415437] EXT4-fs (mmcblk0p13): ext4_orphan_cleanup: deleting unreferenced inode 113816
<6>[ 2.415719] EXT4-fs (mmcblk0p13): 1 orphan inode deleted
<6>[ 2.415728] EXT4-fs (mmcblk0p13): recovery complete
<6>[ 2.419541] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
<7>[ 2.419561] SELinux: initialized (dev mmcblk0p13, type ext4), uses xattr
<14>[ 2.419605] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,/data,ext4)=0
<14>[ 2.420336] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
<14>[ 2.428661] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
<14>[ 2.428694] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata: clean, 4549/387840 files, 327189/1550336 blocks
<6>[ 2.432712] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard,errors=panic
<7>[ 2.432734] SELinux: initialized (dev mmcblk0p13, type ext4), uses xattr
<14>[ 2.432779] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=ext4)=0
<11>[ 2.432794] fs_mgr: mount_with_alternatives(): Mounted /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata on /data with fs_type=ext4 instead of f2fs
<4>[ 2.433446] drmboot: module license ‘unspecified’ taints kernel.
<4>[ 2.433457] Disabling lock debugging due to kernel taint
<4>[ 2.433674] drm init, 20140910
<4>[ 2.434208] drm init ok
<7>[ 2.434663] SELinux: initialized (dev functionfs, type functionfs), uses genfs_contexts
<6>[ 2.447805] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 300000Hz, actual 297619HZ div = 84)
<4>[ 2.447832] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 600000Hz for init[mmc2]
<6>[ 2.448088] arm_release_ver of this mali_ko is ‘r6p0-02rel0’, rk_ko_ver is ‘13’, built at ‘09:15:10’, on ‘Oct 22 2015’.
<6>[ 2.448158] mali ffa30000.gpu: Continuing without Mali clock control
<4>[ 2.449172] mali pd enabled
<4>[ 2.449180] clk enabled
<4>[ 2.450494] MALI_DVFS_STEP = 5, div_dvfs = 7
<6>[ 2.450502] mali_dvfs_infotbl[0].clock=99000,min_threshold=0,max_threshold=70
<6>[ 2.450509] mali_dvfs_infotbl[1].clock=198000,min_threshold=65,max_threshold=77
<6>[ 2.450516] mali_dvfs_infotbl[2].clock=297000,min_threshold=75,max_threshold=84
<6>[ 2.450523] mali_dvfs_infotbl[3].clock=417000,min_threshold=82,max_threshold=91
<6>[ 2.450530] mali_dvfs_infotbl[4].clock=480000,min_threshold=94,max_threshold=100
<3>[ 2.450617] turn on mali power
<6>[ 2.450626] kbase_platform_rk_init,register_reboot_notifier
<4>[ 2.450663] hrtimer: interrupt took 10208 ns
<6>[ 2.450749] mali ffa30000.gpu: GPU identified as 0x0750 r1p0 status 0
<6>[ 2.451427] mali ffa30000.gpu: Probed as mali0
<3>[ 2.452978] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
<3>[ 2.453573] rk29_ipp: version magic '3.0.36+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
<3>[ 2.454137] rk29_ipp: version magic '3.0.101+ SMP preempt mod_unload ARMv7 ’ should be ‘3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
<6>[ 2.455075] zram0: detected capacity change from 0 to 533413888
<6>[ 2.496981] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 200000Hz, actual 200000HZ div = 125)
<4>[ 2.497010] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 400000Hz for init[mmc2]
<6>[ 2.501792] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
<6>[ 2.545728] usb 1-1.2.2: New USB device found, idVendor=1871, idProduct=1130
<6>[ 2.545751] usb 1-1.2.2: New USB device strings: Mfr=2, Product=1, SerialNumber=3
<6>[ 2.545759] usb 1-1.2.2: Product: EP28WD
<6>[ 2.545765] usb 1-1.2.2: Manufacturer: C-ASPIRE
<6>[ 2.545771] usb 1-1.2.2: SerialNumber: Aspire1807250018
<3>[ 2.547621] EXT4-fs (mmcblk0p13): Unrecognized mount option “background_gc=on” or missing value
<6>[ 2.547756] uvcvideo: Found UVC 1.00 device EP28WD (1871:1130)
<6>[ 2.555442] input: EP28WD as /devices/ff500000.usb/usb1/1-1/1-1.2/1-1.2.2/1-1.2.2:1.0/input/input2
<14>[ 2.559740] bat_cap: oldcap path is /sys/devices/ff100000.adc
<14>[ 2.559782] bat_cap: oldcap path is /sys/devices/ff100000.adc/adc-battery.35/oldcap
<11>[ 2.559837] bat_cap: read capacity fopen error
<6>[ 2.559968] binder: 149:149 transaction failed 29189, size 0-0
<11>[ 2.560327] init: Warning! Service displayd needs a SELinux domain defined; please fix!
<11>[ 2.563864] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
<11>[ 2.563883] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
<11>[ 2.564076] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
<6>[ 2.564537] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 2.564547] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<6>[ 2.564562] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 2.564569] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<6>[ 2.564589] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 2.564595] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<6>[ 2.564619] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 2.564625] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<11>[ 2.573691] init: cannot find ‘/system/bin/debuggerd64’, disabling ‘debuggerd64’
<11>[ 2.574111] init: cannot find ‘/system/bin/rild3’, disabling ‘ril-daemon3’
<6>[ 2.575319] read descriptors
<6>[ 2.575334] read strings
<11>[ 2.581108] init: cannot find ‘/system/xbin/daemonsu’, disabling ‘daemonsu’
<11>[ 2.581362] init: Warning! Service up_eth0 needs a SELinux domain defined; please fix!
<11>[ 2.581630] init: cannot find ‘/system/bin/bplus_helper’, disabling ‘bplus_helper’
<11>[ 2.581819] init: Warning! Service lcdparamservice needs a SELinux domain defined; please fix!
<11>[ 2.582219] init: Warning! Service drmservice needs a SELinux domain defined; please fix!
<11>[ 2.582469] init: cannot find ‘/system/bin/akmd’, disabling ‘akmd’
<6>[ 2.644663] usb 1-1.2.4: new low-speed USB device number 7 using rockchip_ehci_host
<4>[ 2.652272] phy_power_on: enable = 1
<4>[ 2.652570] act_ldo5 is enabled before enableRead the Ethernet MAC address from IDB:30:12:5b:08:e0:4f
<4>[ 2.692006] eth0: device MAC address 30:12:5b:08:e0:4f
<6>[ 2.695982] libphy: stmmac: probed
<6>[ 2.695995] eth0: PHY ID 001cc915 at 0 IRQ 194 (stmmac-0:00) active
<6>[ 2.696002] PHY driver name: RTL8211E Gigabit Ethernet
<6>[ 2.696008] eth0: PHY ID 001cc915 at 1 IRQ 194 (stmmac-0:01) active
<6>[ 2.696014] PHY driver name: RTL8211E Gigabit Ethernetphy_disable_eee in
<6>[ 2.757802] usb 1-1.2.4: New USB device found, idVendor=413c, idProduct=301a
<6>[ 2.757816] usb 1-1.2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
<6>[ 2.757823] usb 1-1.2.4: Product: Dell MS116 USB Optical Mouse
<6>[ 2.757830] usb 1-1.2.4: Manufacturer: PixArt
<6>[ 2.761390] input: PixArt Dell MS116 USB Optical Mouse as /devices/ff500000.usb/usb1/1-1/1-1.2/1-1.2.4/1-1.2.4:1.0/input/input3
<6>[ 2.761642] hid-generic 0003:413C:301A.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt Dell MS116 USB Optical Mouse] on usb-ff500000.usb-1.2.4/input0
<4>[ 2.761772] ff580000.usb suspend, HPRT0:0x1000
<4>[ 2.766585] RKNAND_GET_VENDOR_SECTOR
<4>[ 2.766598] return ret = 0
<4>[ 2.766660] RKNAND_GET_SN_SECTOR
<4>[ 2.766669] return ret = 0
<4>[ 2.959429] dwc_otg_hcd_enable, enable host controller
<4>[ 3.013139] RKNAND_GET_DRM_KEY
<4>[ 3.013152] return ret = 0
<4>[ 3.082425] Using Buffer DMA mode
<4>[ 3.082438] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 3.082443] Multiprocessor Interrupt Enhancement - disabled
<4>[ 3.082449] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 3.082455] ^^^^^^^^^^^^^^^^^^Host Mode
<4>[ 3.126792] Init: Power Port (0)
<4>[ 3.126832] ff540000.usb resume, HPRT0:0x21401
<4>[ 3.264522] Indeed it is in host mode hprt0 = 00021501
<38>[ 3.333968] logd.auditd: start
<6>[ 3.441624] usb 3-1: new high-speed USB device number 2 using usb20_host
<4>[ 3.441710] Indeed it is in host mode hprt0 = 00001101
<11>[ 3.545182] healthd: No charger supplies found
<12>[ 3.545198] healthd: No battery devices found
<4>[ 3.638395] delayed_work_fun::line:1005 sn_len:[0xc][0x0]->12
<4>[ 3.638409] delayed_work_fun::line:1015 sn_num:AH3219020178
<4>[ 3.638409]
<6>[ 3.658655] usb 3-1: New USB device found, idVendor=0bda, idProduct=0179
<6>[ 3.658668] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
<6>[ 3.658676] usb 3-1: Product: 802.11n NIC
<6>[ 3.658683] usb 3-1: Manufacturer: Realtek
<4>[ 3.913978] yemk:mpu6050_load_cablic
<4>[ 3.913991] mpu6050_load_cablic: open file /dev/mtd/mtd6
<7>[ 4.047586] SELinux: initialized (dev fuse, type fuse), uses genfs_contexts
<3>[ 4.263993] android_usb: already disabled
<6>[ 4.264141] mtp_bind_config
<4>[ 4.264167] pcd_pullup, is_on 1
<4>[ 4.271080] ===============rk_fb_open win_id[0]:dev_drv->win[win_id]->state = 1; fb_par->state = 2;dev_drv->name=lcdc1;dev_drv->id=1
<4>[ 4.271127] ===============rk_fb_close win_id[0]:dev_drv->win[win_id]->state = 1; fb_par->state = 2;dev_drv->name=lcdc1;dev_drv->id=1
<4>[ 4.271333] ===============rk_fb_open win_id[0]:dev_drv->win[win_id]->state = 1; fb_par->state = 2;dev_drv->name=lcdc1;dev_drv->id=1
<4>[ 4.271367] ===============rk_fb_close win_id[0]:dev_drv->win[win_id]->state = 1; fb_par->state = 2;dev_drv->name=lcdc1;dev_drv->id=1
<4>[ 4.271439] ===============rk_fb_open win_id[0]:dev_drv->win[win_id]->state = 1; fb_par->state = 2;dev_drv->name=lcdc1;dev_drv->id=1
<4>[ 4.330606] ===============rk_fb_open win_id[0]:dev_drv->win[win_id]->state = 1; fb_par->state = 3;dev_drv->name=lcdc1;dev_drv->id=1
<4>[ 4.331078] ===============rk_fb_open win_id[0]:dev_drv->win[win_id]->state = 1; fb_par->state = 4;dev_drv->name=lcdc1;dev_drv->id=1
<4>[ 4.331114] ===============rk_fb_close win_id[0]:dev_drv->win[win_id]->state = 1; fb_par->state = 4;dev_drv->name=lcdc1;dev_drv->id=1
<4>[ 4.340643] ===============rk_fb_open win_id[0]:dev_drv->win[win_id]->state = 1; fb_par->state = 2;dev_drv->name=lcdc0;dev_drv->id=0
<6>[ 4.357070] rk3288-lcdc lcdc1: blank mode:0
<4>[ 4.368472] ===============rk_fb_open win_id[0]:dev_drv->win[win_id]->state = 1; fb_par->state = 4;dev_drv->name=lcdc1;dev_drv->id=1
<4>[ 4.368519] ===============rk_fb_close win_id[0]:dev_drv->win[win_id]->state = 1; fb_par->state = 4;dev_drv->name=lcdc1;dev_drv->id=1
<6>[ 4.385030] rk_iommu ff930300.vopb_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1ead1000
<7>[ 4.970994] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<6>[ 5.535725] warning: `system_server’ uses 32-bit capabilities (legacy support in use)
<6>[ 6.153773] stmmc_pltfr_fix_mac_speed: fix speed to 100
<6>[ 6.153783] stmmc_pltfr_fix_mac_speed: fix speed for RGMII
<6>[ 6.153791] libphy: stmmac-0:01 - Link is Up - 100/Full
<4>[ 6.683816] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 8.873289] [otg id chg] last id -1 current id 1
<12>[ 9.301444] healthd: battery none chg=
<6>[ 9.496008] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
<6>[ 9.496031] lowmemorykiller: oom_adj 0 => oom_score_adj 0
<6>[ 9.496038] lowmemorykiller: oom_adj 1 => oom_score_adj 58
<6>[ 9.496043] lowmemorykiller: oom_adj 2 => oom_score_adj 117
<6>[ 9.496048] lowmemorykiller: oom_adj 3 => oom_score_adj 176
<6>[ 9.496054] lowmemorykiller: oom_adj 9 => oom_score_adj 529
<6>[ 9.496059] lowmemorykiller: oom_adj 15 => oom_score_adj 1000
<6>[ 9.880475] acc_open
<6>[ 9.880510] acc_release
<4>[ 11.303024] ff580000.usb resume, HPRT0:0x1000
<4>[ 11.303220] ff580000.usb suspend, HPRT0:0x1000
<6>[ 12.368405] pm policy 0 → 1
<6>[ 12.446131] binder: undelivered transaction 3291
<38>[ 13.022768] type=1400 audit(1564209361.260:3): avc: denied { execute } for pid=1021 comm=“earl.magicshell” name=“libtoolbox-test.so” dev=“mmcblk0p13” ino=113333 scontext=u:r:system_app:s0 tcontext=u:object_r:system_app_data_file:s0 tclass=file permissive=1
<4>[ 13.693724] serial: 4, change default value to [VMIN]=10, [VTIME]=1
<38>[ 14.006042] type=1400 audit(1564209362.260:4): avc: denied { getattr } for pid=1196 comm=“sh” path=“/system/bin/logcat” dev=“mmcblk0p10” ino=165 scontext=u:r:system_app:s0 tcontext=u:object_r:logcat_exec:s0 tclass=file permissive=1
<38>[ 14.006425] type=1400 audit(1564209362.260:5): avc: denied { execute } for pid=1196 comm=“sh” name=“logcat” dev=“mmcblk0p10” ino=165 scontext=u:r:system_app:s0 tcontext=u:object_r:logcat_exec:s0 tclass=file permissive=1
<38>[ 14.007661] type=1400 audit(1564209362.260:6): avc: denied { read open } for pid=1198 comm=“sh” path=“/system/bin/logcat” dev=“mmcblk0p10” ino=165 scontext=u:r:system_app:s0 tcontext=u:object_r:logcat_exec:s0 tclass=file permissive=1
<38>[ 14.008060] type=1400 audit(1564209362.260:7): avc: denied { execute_no_trans } for pid=1198 comm=“sh” path=“/system/bin/logcat” dev=“mmcblk0p10” ino=165 scontext=u:r:system_app:s0 tcontext=u:object_r:logcat_exec:s0 tclass=file permissive=1
<4>[ 16.110907] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 21.094790] usb 1-1.2.3: new low-speed USB device number 8 using rockchip_ehci_host
<6>[ 21.208575] usb 1-1.2.3: New USB device found, idVendor=1c4f, idProduct=0002
<6>[ 21.208610] usb 1-1.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
<6>[ 21.208626] usb 1-1.2.3: Product: USB Keyboard
<6>[ 21.208640] usb 1-1.2.3: Manufacturer: SIGMACHIP
<6>[ 21.291950] input: SIGMACHIP USB Keyboard as /devices/ff500000.usb/usb1/1-1/1-1.2/1-1.2.3/1-1.2.3:1.0/input/input4
<6>[ 21.292685] keychord: using input dev SIGMACHIP USB Keyboard for fevent
<6>[ 21.294094] hid-generic 0003:1C4F:0002.0002: input,hidraw1: USB HID v1.10 Keyboard [SIGMACHIP USB Keyboard] on usb-ff500000.usb-1.2.3/input0
<6>[ 21.331790] input: SIGMACHIP USB Keyboard as /devices/ff500000.usb/usb1/1-1/1-1.2/1-1.2.3/1-1.2.3:1.1/input/input5
<6>[ 21.332515] keychord: using input dev SIGMACHIP USB Keyboard for fevent
<6>[ 21.332785] hid-generic 0003:1C4F:0002.0003: input,hidraw2: USB HID v1.10 Device [SIGMACHIP USB Keyboard] on usb-ff500000.usb-1.2.3/input1
<4>[ 30.260841] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 30.691545] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 36.424403] EHCI: rk_ehci_hcd_enable, enable host controller
<6>[ 41.857130] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 41.857244] vcodec_service: done
<4>[ 47.048730] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 47.383651] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 59.293512] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 59.293622] vcodec_service: done
<4>[ 70.492925] force_usb_mode_store 1->2
<4>[ 70.493001] PortPower off
<4>[ 70.493034] rk_battery_charger_detect_cb , battery_charger_detect 6
<4>[ 70.690959] Using Buffer DMA mode
<4>[ 70.691011] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 70.691041] Multiprocessor Interrupt Enhancement - disabled
<4>[ 70.691071] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 70.691096] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 70.691632] dwc_otg_hcd_resume, usb device mode
<4>[ 70.796631] dwc_otg_hcd_suspend, usb device mode
<4>[ 70.983728] vbus detect**
<4>[ 70.986090] rk_battery_charger_detect_cb , battery_charger_detect 1
<4>[ 71.163977] Using Buffer DMA mode
<4>[ 71.164036] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 71.164066] Multiprocessor Interrupt Enhancement - disabled
<4>[ 71.164096] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 71.164121] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 71.168186] soft connect!!!
<4>[ 71.263825] USB RESET
<6>[ 71.350643] android_work: sent uevent USB_STATE=CONNECTED
<6>[ 71.447933] android_usb gadget: high-speed config #1: android
<6>[ 71.448524] android_work: sent uevent USB_STATE=CONFIGURED
<6>[ 71.508685] mtp_open
<4>[ 100.026754] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 101.956059] vcodec_service: ff9a0000.vpu_service: power on
<4>[ 102.791360] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 111.927903] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 111.928018] vcodec_service: done
<4>[ 115.652963] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<11>[ 115.891953] init: untracked pid 1198 exited with status 13
<6>[ 116.061885] vcodec_service: ff9a0000.vpu_service: power on
<38>[ 119.567950] type=1400 audit(1564209469.540:8): avc: denied { getattr } for pid=2374 comm=“sh” path=“/system/bin/logcat” dev=“mmcblk0p10” ino=165 scontext=u:r:system_app:s0 tcontext=u:object_r:logcat_exec:s0 tclass=file permissive=1
<38>[ 119.573543] type=1400 audit(1564209469.540:9): avc: denied { execute } for pid=2374 comm=“sh” name=“logcat” dev=“mmcblk0p10” ino=165 scontext=u:r:system_app:s0 tcontext=u:object_r:logcat_exec:s0 tclass=file permissive=1
<38>[ 119.579876] type=1400 audit(1564209469.550:10): avc: denied { read open } for pid=2377 comm=“sh” path=“/system/bin/logcat” dev=“mmcblk0p10” ino=165 scontext=u:r:system_app:s0 tcontext=u:object_r:logcat_exec:s0 tclass=file permissive=1
<38>[ 119.582827] type=1400 audit(1564209469.550:11): avc: denied { execute_no_trans } for pid=2377 comm=“sh” path=“/system/bin/logcat” dev=“mmcblk0p10” ino=165 scontext=u:r:system_app:s0 tcontext=u:object_r:logcat_exec:s0 tclass=file permissive=1
<6>[ 121.560282] vcodec_service: ff9a0000.vpu_service: resetting…
vcodec_service: for 3288/3368…<6>[ 121.560374] vcodec_service: reset in
<6>[ 121.560423] vcodec_service: done
<4>[ 122.000617] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<4>[ 127.456320] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 136.284904] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[ 151.860225] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[ 222.478362] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[ 238.548808] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 238.548919] vcodec_service: done
<4>[ 245.156945] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 245.527838] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 264.378907] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 264.379021] vcodec_service: done
<4>[ 269.461726] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 270.168947] vcodec_service: ff9a0000.vpu_service: power on
<4>[ 272.924181] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 278.215835] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<4>[ 288.836806] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 289.982502] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 289.982619] vcodec_service: done
<6>[ 290.199697] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 310.236873] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<4>[ 337.328181] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 343.024487] vcodec_service: ff9a0000.vpu_service: resetting…
vcodec_service: for 3288/3368…<6>[ 343.024574] vcodec_service: reset in
<6>[ 343.024626] vcodec_service: done
<4>[ 350.995708] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 372.933784] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 372.933897] vcodec_service: done
<4>[ 382.267925] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 383.531046] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 407.570634] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 407.570886] vcodec_service: done
<4>[ 464.185292] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 465.390282] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 494.516673] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 494.516742] vcodec_service: done
<4>[ 496.962697] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 497.124577] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 500.206298] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[ 503.057806] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 503.057874] vcodec_service: done
<4>[ 529.040795] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 529.099651] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 559.433376] nf_conntrack: automatic helper assignment is deprecated and it will be removed soon. Use the iptables CT target to attach helpers instead.
<6>[ 564.843144] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 564.843210] vcodec_service: done
<4>[ 627.225416] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 627.261967] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 641.924268] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[ 652.955865] rk3288-lcdc lcdc0: win0:new_addr:0x11fed000 cur_addr:0x11802000–1
<6>[ 692.942921] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 692.943003] vcodec_service: done
<4>[ 736.369544] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 737.601144] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 758.957203] vcodec_service: ff9a0000.vpu_service: resetting…
vcodec_service: for 3288/3368…<6>[ 758.957265] vcodec_service: reset in
<6>[ 758.957304] vcodec_service: done
<6>[ 762.765912] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 762.766012] vcodec_service: done
<4>[ 766.017599] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 766.313895] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 797.155733] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 797.155821] vcodec_service: done
<4>[ 797.180634] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 797.389073] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 830.838948] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[ 843.098710] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 843.098792] vcodec_service: done
<4>[ 847.315672] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 847.466255] vcodec_service: ff9a0000.vpu_service: power on
<4>[ 865.814506] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 866.350625] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 866.350714] vcodec_service: done
<6>[ 867.067896] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 873.041825] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 873.041903] vcodec_service: done
<4>[ 873.854537] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 874.146040] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 877.488294] rk3288-lcdc lcdc0: win0:new_addr:0x11f0e000 cur_addr:0x126f9000–1
<6>[ 886.069956] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 886.070046] vcodec_service: done
<4>[ 886.852713] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 888.102514] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 917.193914] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 917.194018] vcodec_service: done
<4>[ 993.724779] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 994.936683] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 1014.018280] rk3288-lcdc lcdc0: win0:new_addr:0x11f0e000 cur_addr:0x126f9000–1
<6>[ 1014.018336] rk3288-lcdc lcdc0: win1:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[ 1035.145954] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 1035.146051] vcodec_service: done
<4>[ 1037.109611] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 1037.355575] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 1042.734727] rk3288-lcdc lcdc0: win0:new_addr:0x11fed000 cur_addr:0x11802000–1
<6>[ 1042.734773] rk3288-lcdc lcdc0: win1:new_addr:0x127d8000 cur_addr:0x12b5e000–1
<6>[ 1075.187073] vcodec_service: ff9a0000.vpu_service: resetting…
vcodec_service: for 3288/3368…<6>[ 1075.187147] vcodec_service: reset in
<6>[ 1075.187187] vcodec_service: done
<6>[ 1079.101220] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 1079.101303] vcodec_service: done
<4>[ 1081.615810] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 1081.684586] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 1088.607221] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[ 1115.391199] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 1115.391298] vcodec_service: done
<4>[ 1170.392387] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 1170.502937] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 1181.234193] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[ 1186.942957] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<4>[ 1200.014450] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 1243.698291] vcodec_service: ff9a0000.vpu_service: resetting…
vcodec_service: for 3288/3368…<6>[ 1243.698384] vcodec_service: reset in
<6>[ 1243.698434] vcodec_service: done
<4>[ 1243.925347] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 1256.311968] rk3288-lcdc lcdc0: win0:new_addr:0x11b88000 cur_addr:0x12373000–1
<4>[ 1347.790582] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 1375.975275] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[ 1468.206348] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[ 1504.422226] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[ 1569.280909] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[ 1614.733868] rk3288-lcdc lcdc0: win0:new_addr:0x12373000 cur_addr:0x11b88000–1
<6>[ 1692.404259] rk3288-lcdc lcdc0: win0:new_addr:0x11b88000 cur_addr:0x12373000–1
<6>[ 1769.025055] rk3288-lcdc lcdc0: win0:new_addr:0x11b88000 cur_addr:0x12373000–1
<6>[ 1786.774790] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[ 1857.847466] rk3288-lcdc lcdc0: win0:new_addr:0x11b88000 cur_addr:0x12373000–1
<6>[ 1913.538526] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[ 1914.575058] rk3288-lcdc lcdc0: win0:new_addr:0x12373000 cur_addr:0x11b88000–1
<6>[ 1939.274696] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 1939.274780] vcodec_service: done
<6>[ 1943.339719] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 1953.985544] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 1953.985637] vcodec_service: done
<4>[ 1955.988252] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 1957.215991] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 1959.040983] vcodec_service: ff9a0000.vpu_service: resetting…
vcodec_service: for 3288/3368…<6>[ 1959.041060] vcodec_service: reset in
<6>[ 1959.041093] vcodec_service: done
<6>[ 1962.172427] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 1962.172516] vcodec_service: done
<6>[ 1962.533647] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 1970.516934] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 1970.517019] vcodec_service: done
<4>[ 1971.979345] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 1972.218305] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 2102.471072] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 2102.471156] vcodec_service: done
<4>[ 2108.252826] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 2108.355855] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 2154.917106] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<4>[ 2245.326005] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 2272.525342] lowmemorykiller: Killing ‘om.instwall.zww’ (1541), adj 1000,
<6>[ 2272.525342] to free 23484kB on behalf of ‘CameraPreviewTh’ (5100) because
<6>[ 2272.525342] cache 174640kB is below limit 184320kB for oom_score_adj 1000
<6>[ 2272.525342] Free memory is 164944kB above reserved
<6>[ 2272.744723] lowmemorykiller: Killing ‘twall.autodebug’ (967), adj 1000,
<6>[ 2272.744723] to free 20276kB on behalf of ‘CameraPreviewTh’ (5100) because
<6>[ 2272.744723] cache 175448kB is below limit 184320kB for oom_score_adj 1000
<6>[ 2272.744723] Free memory is 167880kB above reserved
<6>[ 2272.998028] lowmemorykiller: Killing ‘m.instwall.menu’ (1514), adj 1000,
<6>[ 2272.998028] to free 18216kB on behalf of ‘CameraPreviewTh’ (5100) because
<6>[ 2272.998028] cache 180784kB is below limit 184320kB for oom_score_adj 1000
<6>[ 2272.998028] Free memory is 162688kB above reserved
<6>[ 2273.402962] binder: 461:480 transaction failed 29189, size 76-0
<6>[ 2273.783478] binder: undelivered transaction 1376714
<6>[ 2277.314780] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[ 2277.562274] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[ 2297.126991] binder: 461:740 transaction failed 29189, size 344-0
<6>[ 2297.129752] binder: 461:740 transaction failed 29189, size 80-0
<6>[ 2302.304035] binder: 162:3756 transaction failed 29189, size 96-0
<4>[ 2303.659876] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 2305.396614] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[ 2316.665617] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[ 2323.005993] lowmemorykiller: Killing ‘ndroid.settings’ (1619), adj 1000,
<6>[ 2323.005993] to free 32820kB on behalf of ‘kswapd0’ (72) because
<6>[ 2323.005993] cache 163836kB is below limit 184320kB for oom_score_adj 1000
<6>[ 2323.005993] Free memory is 179720kB above reserved
<6>[ 2325.200554] lowmemorykiller: Killing ‘.update.service’ (715), adj 1000,
<6>[ 2325.200554] to free 18416kB on behalf of ‘kswapd0’ (72) because
<6>[ 2325.200554] cache 164228kB is below limit 184320kB for oom_score_adj 1000
<6>[ 2325.200554] Free memory is 183240kB above reserved
<6>[ 2328.053907] binder: 461:1329 transaction failed 29189, size 344-0
<6>[ 2328.060792] binder: 461:1329 transaction failed 29189, size 80-0
<4>[ 2332.669366] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 2341.531681] lowmemorykiller: Killing ‘stwall.settings’ (1309), adj 1000,
<6>[ 2341.531681] to free 51268kB on behalf of ‘kswapd0’ (72) because
<6>[ 2341.531681] cache 170616kB is below limit 184320kB for oom_score_adj 1000
<6>[ 2341.531681] Free memory is 175560kB above reserved
<6>[ 2568.426656] rk3288-lcdc lcdc0: win0:new_addr:0x11b88000 cur_addr:0x12373000–1
<6>[ 2672.274753] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[ 2746.653534] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[ 2761.915361] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[ 2821.807734] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[ 2940.426883] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 2940.427123] vcodec_service: done
<6>[ 2949.234539] binder: 154:154 transaction failed 29189, size 84-0
<11>[ 2950.201543] init: untracked pid 5499 killed by signal 1
<6>[ 2998.040848] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 3042.997998] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 3042.998096] vcodec_service: done
<4>[ 3045.581452] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 3046.044995] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 3064.662974] binder: 461:929 transaction failed 29189, size 344-0
<6>[ 3064.671847] binder: 461:929 transaction failed 29189, size 80-0
<4>[ 3071.007854] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 3083.981569] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 3083.981651] vcodec_service: done
<4>[ 3087.303112] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 3087.536441] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 3099.384088] usb 1-1.2.1: USB disconnect, device number 5
<6>[ 3102.700220] vcodec_service: ff9a0000.vpu_service: resetting…
vcodec_service: for 3288/3368…<6>[ 3102.700283] vcodec_service: reset in
<6>[ 3102.700317] vcodec_service: done
<6>[ 3106.456527] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 3106.456613] vcodec_service: done
<4>[ 3109.207840] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 3109.348210] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 3128.892467] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[ 3129.368792] binder: 461:728 transaction failed 29189, size 344-0
<6>[ 3129.374739] binder: 461:728 transaction failed 29189, size 80-0
<4>[ 3133.876618] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 3169.594099] binder: send failed reply for transaction 2072149 to 154:154
<11>[ 3170.568669] init: untracked pid 8014 killed by signal 1
<6>[ 3177.591720] vcodec_service: ff9a0000.vpu_service: resetting…
vcodec_service: for 3288/3368…<6>[ 3177.591783] vcodec_service: reset in
<6>[ 3177.591824] vcodec_service: done
<6>[ 3180.944971] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 3180.945057] vcodec_service: done
<4>[ 3205.156347] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 3205.442050] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 3210.094865] libphy: stmmac-0:01 - Link is Down
<6>[ 3211.592435] stmmc_pltfr_fix_mac_speed: fix speed to 100
<6>[ 3211.592481] stmmc_pltfr_fix_mac_speed: fix speed for RGMII
<6>[ 3211.592504] libphy: stmmac-0:01 - Link is Up - 100/Full
<6>[ 3228.977159] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[ 3247.003676] binder: 461:929 transaction failed 29189, size 344-0
<6>[ 3247.004270] binder: 461:929 transaction failed 29189, size 80-0
<4>[ 3252.112912] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<3>[ 3252.370524] binder: 8432: binder_alloc_buf, no vma
<6>[ 3252.370579] binder: 461:948 transaction failed 29201, size 236-0
<6>[ 3252.370603] binder: send failed reply for transaction 2128335 to 8432:8432
<6>[ 3266.793548] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[ 3387.241192] binder: 154:154 transaction failed 29189, size 84-0
<11>[ 3388.210332] init: untracked pid 8649 killed by signal 1
<6>[ 3403.186664] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[ 3490.672309] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[ 3500.995933] binder: 461:929 transaction failed 29189, size 344-0
<6>[ 3500.996396] binder: 461:929 transaction failed 29189, size 80-0
<6>[ 3504.392199] vcodec_service: ff9a0000.vpu_service: resetting…
vcodec_service: for 3288/3368…<6>[ 3504.392257] vcodec_service: reset in
<6>[ 3504.392292] vcodec_service: done
<4>[ 3505.749334] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 3512.368876] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[ 3973.061979] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[ 3977.797323] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[ 3992.036470] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[ 4004.525493] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[ 4093.583132] lowmemorykiller: Killing ‘ll.roulettegame’ (8285), adj 1000,
<6>[ 4093.583132] to free 28116kB on behalf of ‘kswapd0’ (72) because
<6>[ 4093.583132] cache 181504kB is below limit 184320kB for oom_score_adj 1000
<6>[ 4093.583132] Free memory is 33508kB above reserved
<6>[ 4093.943071] lowmemorykiller: Killing ‘ayer:background’ (1264), adj 1000,
<6>[ 4093.943071] to free 20524kB on behalf of ‘kswapd0’ (72) because
<6>[ 4093.943071] cache 177912kB is below limit 184320kB for oom_score_adj 1000
<6>[ 4093.943071] Free memory is 49340kB above reserved
<6>[ 4095.058292] lowmemorykiller: Killing ‘m.shutuo.detect’ (8560), adj 1000,
<6>[ 4095.058292] to free 23752kB on behalf of ‘kswapd0’ (72) because
<6>[ 4095.058292] cache 184044kB is below limit 184320kB for oom_score_adj 1000
<6>[ 4095.058292] Free memory is 42992kB above reserved
<6>[ 4095.166890] binder: undelivered transaction 2855849
<6>[ 4095.223714] lowmemorykiller: Killing ‘om.shutuo.store’ (8618), adj 1000,
<6>[ 4095.223714] to free 23416kB on behalf of ‘kswapd0’ (72) because
<6>[ 4095.223714] cache 184228kB is below limit 184320kB for oom_score_adj 1000
<6>[ 4095.223714] Free memory is 45744kB above reserved
<6>[ 4143.484222] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[ 4153.168524] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[ 4179.765043] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[ 4182.990488] binder: 154:154 transaction failed 29189, size 84-0
<11>[ 4183.932838] init: untracked pid 9489 killed by signal 1
<6>[ 4239.145978] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[ 4265.445921] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[ 4471.917901] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[ 4502.532784] binder: 461:728 transaction failed 29189, size 344-0
<6>[ 4502.534627] binder: 461:728 transaction failed 29189, size 80-0
<6>[ 4506.208537] binder: undelivered transaction 3206993
<4>[ 4506.210363] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 4548.936578] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[ 4644.726546] libphy: stmmac-0:01 - Link is Down
<6>[ 4882.403661] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[ 4985.953546] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[ 5008.525379] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[ 5097.273877] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[ 5098.292062] lowmemorykiller: Killing ‘pheraldetection’ (646), adj 1000,
<6>[ 5098.292062] to free 18712kB on behalf of ‘kswapd0’ (72) because
<6>[ 5098.292062] cache 174744kB is below limit 184320kB for oom_score_adj 1000
<6>[ 5098.292062] Free memory is 17804kB above reserved
<6>[ 5114.548641] lowmemorykiller: Killing ‘stwall.settings’ (8319), adj 1000,
<6>[ 5114.548641] to free 50700kB on behalf of ‘kswapd0’ (72) because
<6>[ 5114.548641] cache 172916kB is below limit 184320kB for oom_score_adj 1000
<6>[ 5114.548641] Free memory is 18972kB above reserved
<6>[ 5114.731709] lowmemorykiller: Killing ‘ll.roulettegame’ (12083), adj 1000,
<6>[ 5114.731709] to free 27556kB on behalf of ‘kswapd0’ (72) because
<6>[ 5114.731709] cache 172356kB is below limit 184320kB for oom_score_adj 1000
<6>[ 5114.731709] Free memory is 24072kB above reserved
<6>[ 5115.232187] lowmemorykiller: Killing ‘ardware:nfcscan’ (1000), adj 1000,
<6>[ 5115.232187] to free 23104kB on behalf of ‘kswapd0’ (72) because
<6>[ 5115.232187] cache 172356kB is below limit 184320kB for oom_score_adj 1000
<6>[ 5115.232187] Free memory is 50936kB above reserved
<6>[ 5116.389704] lowmemorykiller: Killing ‘m.shutuo.detect’ (12166), adj 1000,
<6>[ 5116.389704] to free 23024kB on behalf of ‘kswapd0’ (72) because
<6>[ 5116.389704] cache 172252kB is below limit 184320kB for oom_score_adj 1000
<6>[ 5116.389704] Free memory is 52828kB above reserved
<6>[ 5116.550688] lowmemorykiller: Killing ‘om.shutuo.store’ (12204), adj 1000,
<6>[ 5116.550688] to free 22548kB on behalf of ‘kswapd0’ (72) because
<6>[ 5116.550688] cache 172252kB is below limit 184320kB for oom_score_adj 1000
<6>[ 5116.550688] Free memory is 66336kB above reserved
<6>[ 5116.737082] lowmemorykiller: Killing ‘m.instwall.menu’ (8670), adj 1000,
<6>[ 5116.737082] to free 22096kB on behalf of ‘kswapd0’ (72) because
<6>[ 5116.737082] cache 172252kB is below limit 184320kB for oom_score_adj 1000
<6>[ 5116.737082] Free memory is 67876kB above reserved
<6>[ 5275.951861] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[ 5324.807466] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[ 5412.872204] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[ 5539.844273] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[ 5583.557306] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[ 5592.896033] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[ 5903.694942] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[ 5931.738696] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[ 5959.444104] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[ 5970.993634] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[ 5974.903902] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[ 6084.129218] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[ 6106.255394] stmmc_pltfr_fix_mac_speed: fix speed to 100
<6>[ 6106.255434] stmmc_pltfr_fix_mac_speed: fix speed for RGMII
<6>[ 6106.255457] libphy: stmmac-0:01 - Link is Up - 100/Full
<6>[ 6113.273330] libphy: stmmac-0:01 - Link is Down
<6>[ 6116.457647] stmmc_pltfr_fix_mac_speed: fix speed to 100
<6>[ 6116.457695] stmmc_pltfr_fix_mac_speed: fix speed for RGMII
<6>[ 6116.457723] libphy: stmmac-0:01 - Link is Up - 100/Full
<6>[ 6142.084237] lowmemorykiller: Killing ‘om.instwall.zww’ (8694), adj 1000,
<6>[ 6142.084237] to free 38060kB on behalf of ‘kswapd0’ (72) because
<6>[ 6142.084237] cache 182748kB is below limit 184320kB for oom_score_adj 1000
<6>[ 6142.084237] Free memory is 31648kB above reserved
<6>[ 6142.375484] lowmemorykiller: Killing ‘GCDaemon’ (8709), adj 1000,
<6>[ 6142.375484] to free 38508kB on behalf of ‘kswapd0’ (72) because
<6>[ 6142.375484] cache 178700kB is below limit 184320kB for oom_score_adj 1000
<6>[ 6142.375484] Free memory is 45704kB above reserved
<6>[ 6197.546834] lowmemorykiller: Killing ‘.update.service’ (8826), adj 1000,
<6>[ 6197.546834] to free 19804kB on behalf of ‘kswapd0’ (72) because
<6>[ 6197.546834] cache 184044kB is below limit 184320kB for oom_score_adj 1000
<6>[ 6197.546834] Free memory is 33220kB above reserved
<6>[ 6205.001355] binder: release 11440:11483 transaction 4660972 in, still active
<6>[ 6205.001404] binder: send failed reply for transaction 4660972 to 461:1482
<6>[ 6208.546958] binder: 162:6985 transaction failed 29189, size 96-0
<4>[ 6209.982742] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 6210.246727] binder: release 17939:17979 transaction 4663329 in, still active
<6>[ 6210.246775] binder: send failed reply for transaction 4663329 to 461:478
<6>[ 6210.691789] binder: release 17981:18019 transaction 4663509 in, still active
<6>[ 6210.691843] binder: send failed reply for transaction 4663509 to 461:1970
<6>[ 6210.692452] binder: 461:1970 transaction failed 29189, size 80-0
<6>[ 6215.689528] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 6215.689607] vcodec_service: done
<6>[ 6222.584954] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 6233.071896] binder: 154:154 transaction failed 29189, size 84-0
<11>[ 6234.049189] init: untracked pid 11600 killed by signal 1
<6>[ 6238.727477] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[ 6283.345529] binder: 154:154 transaction failed 29189, size 140-0
<6>[ 6283.985045] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<11>[ 6284.305258] init: untracked pid 4764 killed by signal 1
<6>[ 6314.327294] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[ 6492.569043] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[ 6611.776350] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[ 6711.580658] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[ 6742.335181] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[ 6828.824453] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[ 6858.935696] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[ 6895.564153] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[ 6898.566991] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[ 6946.563372] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[ 7016.604027] binder: 461:1966 transaction failed 29189, size 344-0
<6>[ 7016.604392] binder: 461:1966 transaction failed 29189, size 80-0
<4>[ 7019.601962] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 7384.685420] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[ 7386.236372] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[ 7427.484551] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[ 7442.399999] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[ 7830.298177] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[ 7853.925481] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[ 7898.820289] rk3288-lcdc lcdc0: win0:new_addr:0x1237a000 cur_addr:0x11802000–1
<6>[ 7903.489130] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[ 7912.625289] lowmemorykiller: Killing ‘ll.roulettegame’ (17300), adj 764,
<6>[ 7912.625289] to free 22448kB on behalf of ‘kswapd0’ (72) because
<6>[ 7912.625289] cache 146688kB is below limit 147456kB for oom_score_adj 529
<6>[ 7912.625289] Free memory is 30724kB above reserved
<6>[ 7912.857368] lowmemorykiller: Killing ‘m.shutuo.detect’ (17783), adj 764,
<6>[ 7912.857368] to free 20720kB on behalf of ‘kswapd0’ (72) because
<6>[ 7912.857368] cache 146652kB is below limit 147456kB for oom_score_adj 529
<6>[ 7912.857368] Free memory is 27292kB above reserved
<6>[ 7913.046907] lowmemorykiller: Killing ‘om.shutuo.store’ (17856), adj 764,
<6>[ 7913.046907] to free 20496kB on behalf of ‘kswapd0’ (72) because
<6>[ 7913.046907] cache 146652kB is below limit 147456kB for oom_score_adj 529
<6>[ 7913.046907] Free memory is 26356kB above reserved
<6>[ 7913.307483] lowmemorykiller: Killing ‘om.instwall.zww’ (18106), adj 647,
<6>[ 7913.307483] to free 27532kB on behalf of ‘kswapd0’ (72) because
<6>[ 7913.307483] cache 146652kB is below limit 147456kB for oom_score_adj 529
<6>[ 7913.307483] Free memory is 32488kB above reserved
<6>[ 7916.094869] lowmemorykiller: Killing ‘twall.autodebug’ (8177), adj 1000,
<6>[ 7916.094869] to free 21744kB on behalf of ‘kswapd0’ (72) because
<6>[ 7916.094869] cache 166764kB is below limit 184320kB for oom_score_adj 1000
<6>[ 7916.094869] Free memory is 19972kB above reserved
<6>[ 7916.412554] lowmemorykiller: Killing ‘m.instwall.menu’ (18084), adj 1000,
<6>[ 7916.412554] to free 17464kB on behalf of ‘kswapd0’ (72) because
<6>[ 7916.412554] cache 166764kB is below limit 184320kB for oom_score_adj 1000
<6>[ 7916.412554] Free memory is 42188kB above reserved
<6>[ 7916.779039] binder: undelivered transaction 5862539
<6>[ 7943.862763] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[ 7992.035620] lowmemorykiller: Killing ‘.update.service’ (18144), adj 1000,
<6>[ 7992.035620] to free 16096kB on behalf of ‘kswapd0’ (72) because
<6>[ 7992.035620] cache 183176kB is below limit 184320kB for oom_score_adj 1000
<6>[ 7992.035620] Free memory is 35324kB above reserved
<6>[ 8243.342067] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[ 8354.067941] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x1237a000–1
<6>[ 8405.941770] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[ 8697.385148] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[ 8774.613422] lowmemorykiller: Killing ‘stwall.settings’ (18165), adj 764,
<6>[ 8774.613422] to free 28276kB on behalf of ‘kswapd0’ (72) because
<6>[ 8774.613422] cache 147276kB is below limit 147456kB for oom_score_adj 529
<6>[ 8774.613422] Free memory is 129824kB above reserved
<3>[ 8778.652481] binder: 1380: binder_alloc_buf, no vma
<6>[ 8778.652540] binder: 162:18551 transaction failed 29201, size 100-0
<6>[ 8778.768193] binder: undelivered transaction 6614879
<6>[ 8778.768357] binder: undelivered transaction 6614885
<6>[ 8778.768398] binder: undelivered transaction 6614916
<6>[ 8778.768436] binder: undelivered transaction 6614917
<6>[ 8778.768473] binder: undelivered transaction 6614926
<6>[ 8778.768508] binder: undelivered transaction 6614927
<6>[ 8778.768871] binder: undelivered transaction 6614892
<6>[ 8778.768913] binder: undelivered transaction 6614901
<6>[ 8778.769795] binder: send failed reply for transaction 6614888 to 162:18541
<6>[ 8778.770429] binder: undelivered transaction 6614891
<6>[ 8778.770481] binder: undelivered transaction 6614931
<6>[ 8778.979869] binder: 162:2008 transaction failed 29189, size 96-0
<6>[ 8779.169976] binder: 461:529 transaction failed 29189, size 316-0
<6>[ 8782.414323] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 8782.414559] vcodec_service: done
<6>[ 8792.062016] binder: 154:154 transaction failed 29189, size 84-0
<11>[ 8793.036338] init: untracked pid 18672 killed by signal 1
<4>[ 8851.555321] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[ 8851.792660] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 8989.420256] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[ 9031.743202] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[ 9132.904030] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[ 9272.172680] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[ 9482.058226] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[ 9503.523792] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[ 9729.943486] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[ 9742.318356] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[ 9879.476566] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[ 9965.371831] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[10046.795830] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[10086.113685] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[10098.637741] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[10448.982396] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[10531.299107] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[10545.911473] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[10557.960191] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[10609.199781] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[10609.256482] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[10697.729942] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[10761.066489] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[10934.870282] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[11280.713483] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[11544.073425] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[11625.960057] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[11852.560481] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[12067.661430] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[12090.909374] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[12227.993861] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[12455.494782] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[12473.255886] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[12584.369591] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[12599.070429] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[12631.729234] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[12683.356260] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[12698.854296] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[12707.569749] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[12975.518137] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[13168.922850] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[13178.261361] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[13263.876177] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[13385.921403] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[13386.129085] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[13471.767197] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[13540.767184] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[13878.391525] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[13890.478283] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[13924.573612] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[13927.939515] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[13955.790296] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[13978.476792] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[14104.778810] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[14202.867572] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[14281.074164] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[14513.086698] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[14804.711542] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[14897.784506] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[15026.263968] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[15079.804137] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[15081.421304] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[15238.989382] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[15417.728311] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[15418.237559] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[15420.139084] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[15478.293508] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[15502.318482] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[15619.710672] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[15704.698150] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[15733.274889] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[15734.297857] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[15817.899721] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[15872.132919] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[15944.433303] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[16034.238581] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[16076.757041] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[16217.088736] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[16479.570656] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[16767.433684] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[17013.586568] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[17313.510913] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[17314.748031] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[17421.562281] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[17460.403715] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[17838.450376] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[18090.280493] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[18197.063932] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[18262.186552] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[18296.535073] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[18377.417554] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[18401.341516] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[18482.666472] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[18495.222487] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[18498.703924] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[18611.756949] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[19013.297068] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[20422.352229] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[20455.037431] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[20566.787063] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[20580.399057] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[21945.699046] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[22676.171429] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[23123.169828] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[23376.631879] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[23472.030629] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[23709.076252] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[23823.515431] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[23900.603171] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[24207.816632] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[24987.292247] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[25123.576266] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[25458.792249] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[26274.075027] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[26529.843464] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[26627.866263] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[26794.145834] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[27110.354260] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[27718.007052] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[28410.300236] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<4>[28518.223090] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[28562.196285] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[28597.309508] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[28732.683225] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[28745.483445] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[28808.382014] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[28856.922863] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[28885.136691] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[28907.761513] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[28949.205594] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[29021.413492] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[29047.423874] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[29170.604252] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[29329.577931] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[29427.353241] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[29615.175459] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[29690.037926] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[29791.690473] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[29794.312656] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[29841.006716] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[29866.283221] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[29899.776784] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[29968.201860] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[29993.921937] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[30043.494259] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[30044.015410] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[30050.118384] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[30109.515716] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[30188.827755] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[30272.602257] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[30360.194677] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[30431.449876] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[30440.771892] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[30457.463737] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[30591.723853] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[30674.038791] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[30885.559673] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[30910.193098] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[30950.335855] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[30965.069738] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[31013.247609] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[31202.449533] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[31284.875924] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[31286.368320] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[31303.800036] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[31438.137240] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[31471.053318] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[31564.208284] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[31593.379037] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[31645.995330] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[31683.465134] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[31740.668177] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[31754.440659] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[31775.861130] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[31798.597128] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[31799.196254] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[31815.366651] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[31875.978808] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[31930.410894] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[32047.443065] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[32303.524856] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[32316.674753] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[32439.907998] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[32554.875489] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[32556.777877] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[32580.344698] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[32593.464657] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[32724.189103] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[32788.867885] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[32790.946729] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[32935.480470] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[32970.205560] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[33014.026307] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[33033.238770] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[33250.268339] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[33553.956214] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[33558.427559] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[33583.127719] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[33608.882369] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[33619.029512] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[33638.423508] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[33665.062454] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[33717.761156] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[33886.796327] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[33911.446299] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[34006.862544] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[34151.477861] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[34185.301453] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[34300.081514] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[34303.634492] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[34377.881127] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[34434.936020] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[34574.354905] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[34657.561053] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[34741.756870] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[34756.985206] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[34963.160305] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[34971.891053] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x12ee4000–1
<6>[35020.132320] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[35051.101480] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[35187.666824] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[35214.725474] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[35336.143510] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[35457.462309] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[35646.111456] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[35655.074379] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[35663.208540] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[35743.989042] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[35748.806819] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[35853.148628] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[36066.121341] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[36096.496273] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[36280.906265] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[36294.255880] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[36321.873454] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x12ee4000–1
<6>[36377.941173] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[36668.372689] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[36763.727450] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[36826.862261] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[36889.501526] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[36923.061342] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[37004.419019] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[37095.841657] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[37184.063354] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[37190.085508] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[37306.939449] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[37465.314461] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[37524.255953] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[37723.804676] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[37886.966124] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[37902.574176] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[38001.454463] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[38043.164620] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[38120.547222] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[38187.061867] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[38356.549579] vcodec_service: ff9a0000.vpu_service: resetting…
vcodec_service: for 3288/3368…<6>[38356.549631] vcodec_service: reset in
<6>[38356.549669] vcodec_service: done
<4>[38356.721745] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[38574.309623] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[38582.691254] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[38721.780683] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[38740.096530] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[38747.466295] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[38761.659032] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[38778.314698] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[38935.940997] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[39094.202835] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[39248.784390] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[39311.695818] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[39361.227042] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[39562.154906] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[39628.234583] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[39740.231698] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[39752.954318] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[39875.261927] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[39890.759495] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[39929.643511] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[39947.314248] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[40070.019428] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[40080.199588] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[40144.500256] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[40205.742599] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[40393.124974] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[40409.277761] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[40439.768492] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[40540.562581] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[40547.907441] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[40726.328068] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[40894.472271] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[41084.131596] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[41149.453036] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[41258.765464] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[41365.463869] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[41403.178290] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[41412.401480] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[41603.529135] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[41746.364534] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[41755.322565] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[41927.228627] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[41948.166743] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[42141.537847] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[42316.083806] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[42328.474801] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[42358.254398] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[42564.107170] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[42696.342867] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[42787.270897] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[42855.230992] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[43101.070362] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[43260.915495] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[43367.505809] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[43375.090535] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[43439.194656] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[43627.678105] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[43633.007445] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[43648.236224] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[43667.903542] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[43726.867105] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[43806.662343] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[43819.020323] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[43945.061640] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[43945.702451] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[43964.929646] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[43990.365426] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[44076.739754] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[44120.017506] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[44142.538313] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[44163.517216] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[44170.373722] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[44171.956544] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[44228.170004] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[44319.806697] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[44331.900671] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[44377.933710] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[44418.192259] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[44447.758771] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[44594.420807] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[44801.404359] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[44848.905879] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[44916.701367] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[44966.117745] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[45196.265255] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[45201.545017] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[45307.453943] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[45332.186396] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[45345.776773] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[45381.446642] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[45394.537216] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[45398.678498] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[45493.466979] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[45507.152688] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[45532.454781] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[45766.893099] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[45930.599042] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[45995.708983] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[46023.949470] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[46036.458427] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[46118.971729] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[46140.865925] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[46492.317206] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[46492.531731] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[46493.191683] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[46585.829859] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[46602.911954] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[46606.096349] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[46728.263858] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[46889.180755] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[46943.792744] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[47128.331694] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[47199.130149] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[47348.415740] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[47544.179744] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[47571.633849] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[47600.145296] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[47639.249879] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[47643.191952] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[47683.039100] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[47688.992325] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[47725.392553] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[47745.654393] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[47781.717859] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<6>[47855.654824] rk3288-lcdc lcdc1: win2:new_addr:0x10fd2000 cur_addr:0x107e9000–1
<6>[47902.296749] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[47953.967112] rk3288-lcdc lcdc0: win0:new_addr:0x11802000 cur_addr:0x126f9000–1
<6>[47984.215707] rk3288-lcdc lcdc1: win2:new_addr:0x107e9000 cur_addr:0x10000000–1
<6>[48036.749415] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<6>[48061.696348] rk3288-lcdc lcdc1: win2:new_addr:0x10000000 cur_addr:0x10fd2000–1
<4>[48195.844213] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[48202.492658] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11802000–1
<4>[48207.235340] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[48491.816337] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[48491.816384] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[48632.225166] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[48773.589884] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[48882.519334] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[48882.519386] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[49032.382360] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[49032.382412] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[49035.929795] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[49035.929853] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[49057.873745] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[49057.873815] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[49069.659031] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[49108.937021] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[49175.422742] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[49276.192304] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[49276.192365] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[49440.607692] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[49440.607750] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[49591.408632] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[49681.313468] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[49704.579851] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[49704.579899] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[49739.492328] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[49739.492379] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[49740.566672] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[49780.353046] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[49838.146646] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[49918.856026] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[49918.856103] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[49919.202494] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[50015.857041] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[50068.583038] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[50210.744926] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[50210.744991] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[50340.297288] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[50340.297358] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[50431.236447] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[50472.662644] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[50547.709859] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[50580.857068] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[50580.857114] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[50602.833967] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[50602.834023] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[50740.240306] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[50891.719967] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[50891.720030] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[50894.656851] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[51005.862010] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[51005.862060] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[51031.320419] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[51031.320464] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[51083.111661] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[51083.111708] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[51206.196371] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[51206.196647] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[51334.263810] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[51568.757018] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[51612.276792] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[51612.276837] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[51679.899438] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[51790.799580] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[51790.799634] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[51814.543423] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[51851.516461] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[51906.859079] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[51928.386618] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[51928.386684] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[52280.547394] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[52280.547440] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[52287.437478] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[52292.525864] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[52292.531261] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[52343.591040] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[52346.775528] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[52382.770615] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[52385.928402] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[52385.928465] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[52595.436277] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[52595.436324] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[52598.142159] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[52598.142235] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[52612.711052] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[52642.891049] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[52675.281063] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[52709.858850] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[52799.625837] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[52853.991838] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[53303.335568] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[53325.001717] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[53392.157836] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[53434.158280] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[53441.915656] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[53441.915711] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[53449.508640] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[53464.420690] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[53464.420740] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[53561.601507] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[53561.601558] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[53790.956654] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[53860.403559] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[53927.683479] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[53944.936234] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[54154.479049] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[54161.514699] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[54263.325888] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[54480.986744] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[54535.926716] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[54704.157956] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[54720.759002] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[54720.759050] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[54769.134789] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[54769.134854] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[54783.357174] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[54783.357234] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[54802.623454] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[54826.189336] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[54826.189394] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[55016.512236] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[55106.630241] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[55259.215864] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[55304.529040] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[55512.757620] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[55564.598452] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[55944.014543] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[55957.099901] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[55957.100032] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[56003.333077] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[56040.586495] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[56040.586543] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[56042.665192] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[56042.665267] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[56089.869749] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[56226.849172] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[56250.546631] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[56294.130831] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[56294.130886] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[56709.041454] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[56751.960239] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[56754.584238] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[56769.458783] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[56769.458836] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[56770.003230] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[56789.752870] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[56789.752926] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[56855.084335] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[56903.447062] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[56936.794954] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[56936.795028] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[56990.088228] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[56998.947364] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[56998.947412] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[57013.268750] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[57013.268811] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[57143.903838] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[57276.036356] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[57276.036411] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[57554.789451] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[57625.309759] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[57625.309814] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[57637.560233] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[57682.166327] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[57682.166392] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[57700.612880] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[57700.612940] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[57768.596306] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[57777.664204] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[57777.664254] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[57909.476976] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[57909.477039] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[57933.088470] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[57961.050336] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[58022.386221] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<4>[58035.077766] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[58036.916631] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[58043.781177] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[58118.159962] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[58118.160012] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[58314.336542] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[58314.336594] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[58482.002286] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[58482.002339] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[58489.523834] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[58536.020895] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[58536.020971] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[58540.607691] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[58540.607817] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[58730.423469] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[58736.158657] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[58736.158711] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[58914.874305] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[59219.176727] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[59219.980130] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[59255.752777] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[59255.762891] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[59263.062758] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[59405.546128] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[59524.970649] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[59558.811668] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[59558.811719] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[59600.373425] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[59600.373499] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[59606.790217] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[59699.748523] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[59699.748580] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[59930.214665] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[60006.453848] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[60006.453890] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[60090.705040] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[60093.652925] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[60093.652975] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[60422.798206] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[60422.798285] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[60633.971343] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[60633.971392] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[60695.348492] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[60695.348537] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[60726.566342] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[60744.021451] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[60744.024350] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[60830.246676] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[60830.246735] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[60899.569725] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[60908.535791] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[60908.535837] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[60928.039852] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[60938.535842] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[61209.548775] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[61209.548823] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[61571.081129] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[61571.081175] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[61640.411118] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[61640.411192] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[61860.576630] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[61933.179429] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[61960.009929] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[62023.117045] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[62137.917053] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[62165.896883] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[62165.896930] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[62447.374731] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[62447.374780] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[62619.663766] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[62619.663821] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[62631.209807] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[62631.209872] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[62643.897756] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[62643.897838] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[62652.345379] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[62652.345454] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[62654.539753] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[62654.539798] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[62937.663032] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[63103.601234] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[63103.601288] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[63109.392863] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[63109.392915] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[63185.619965] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[63185.620061] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[63289.820321] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[63486.070864] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[63486.070932] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[63530.441036] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[63532.384350] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[63532.384441] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[63718.514868] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[63718.514918] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[64169.565441] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[64176.087478] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[64176.087528] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[64245.714580] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[64245.714651] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[64499.895058] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[64537.834334] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[64537.834409] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[64578.274081] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[64578.274130] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[64623.218122] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[64623.218168] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[64651.905832] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[64679.031433] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[64737.954175] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[64737.954228] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[64755.542405] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[64755.542461] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[64933.272732] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[64933.272789] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[65060.102762] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[65060.102815] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[65061.637175] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[65061.637237] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[65084.736384] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[65084.736488] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[65119.355111] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[65318.960064] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[65318.960114] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[65576.669042] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[65595.775024] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[65680.294526] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[65680.294594] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[65689.960344] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[65696.405433] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[65935.012881] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[65935.012928] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[66168.376298] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[66168.378559] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[66310.175457] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[66344.341199] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[66344.341274] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[66537.135379] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[66537.138383] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[66598.397261] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[66598.397308] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[66669.756625] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[66669.756675] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[66765.304010] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[66794.729860] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[66900.334157] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[66900.334205] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[66989.201699] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[67150.067372] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[67150.067421] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[67321.596237] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[67336.258039] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[67623.547368] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[67623.547417] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[67672.900641] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[67762.247832] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[67787.536690] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<4>[67874.200970] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[67900.975511] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[67923.900429] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[67923.900498] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[68050.664405] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[68050.664453] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[68288.999441] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[68528.029435] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[68608.901591] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[68608.901645] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[68624.196263] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[68624.196311] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[68726.706505] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[68726.706558] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[68934.536460] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[68958.785222] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[68958.785267] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[68967.381279] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[68967.381326] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[69442.164759] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[69442.164816] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[69584.553552] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[69584.553608] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[69588.398040] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[69588.398226] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[69667.165496] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[69667.165548] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[69683.153310] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[69683.153362] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[69818.068009] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[69818.068054] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[69821.104406] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[70039.900873] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[70039.900923] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[70055.855687] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[70055.855740] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[70139.689304] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[70139.689381] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[70189.829909] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[70189.829981] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[70258.114676] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[70258.219968] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[70258.220015] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[70320.966899] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[70320.967034] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[70451.191985] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[70530.424695] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[70530.424740] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[70619.454816] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[70619.454866] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[70655.617835] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[70815.466385] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[70815.466448] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[70819.733097] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[71044.953891] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[71116.297913] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[71116.297975] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[71124.316494] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[71124.316543] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[71150.668512] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[71248.622161] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[71248.622213] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[71619.674698] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[71619.674780] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[71620.020228] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[71834.148809] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[71834.148861] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[72149.764630] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[72149.764676] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[72213.104427] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[72213.104491] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[72229.966711] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[72229.966765] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[72433.049844] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[72600.001834] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[72782.894692] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[72798.917439] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[72807.128283] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[72807.128347] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[73142.874659] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[73421.627658] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[73421.627722] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[73671.954813] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[73671.954872] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[73720.429711] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[73720.429763] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[73752.091862] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[73752.091935] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[73872.371673] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[73872.371735] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[73902.129072] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[73907.721454] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[73926.505831] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[73926.505894] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[74513.055472] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[74513.055526] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[74515.975836] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[74515.975897] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[74767.606242] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[74840.996249] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[75100.345843] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[75354.717104] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[75354.717150] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[75676.117037] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[75707.769669] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[75904.720749] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[75904.720803] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[76020.149782] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[76020.150096] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[76105.682080] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[76105.682147] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[76148.516444] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[76148.516505] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[76185.967589] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[76185.967658] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[76191.923848] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[76191.923917] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[76315.140511] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[76315.140561] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[76360.325743] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[76379.999202] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[76379.999260] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[76447.695760] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[76447.695812] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[76539.954547] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[76551.922400] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[76551.922487] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[76590.695835] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[76738.562006] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[76874.629054] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[76916.275521] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[76916.275573] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[76923.636226] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[76923.636310] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[77129.908291] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[77129.908335] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[77232.319355] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[77232.319409] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[77433.907644] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[77433.907694] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[77453.007883] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[77515.199602] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[77515.199653] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[77705.600637] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<4>[77713.565151] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[77782.009570] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[77782.009884] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[77975.265708] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[77975.265777] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[78268.656032] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[78268.656084] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[78826.770258] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[78844.118382] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[78844.118434] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[78863.438829] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[78863.438884] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[79025.148362] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[79025.148418] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[79194.150509] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[79194.150573] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[79238.649089] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[79238.649141] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[79241.706644] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[79373.332735] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[79373.332784] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[79488.382660] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[79488.382707] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[79523.327757] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[79523.327809] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[79986.924748] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[79986.924808] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[80143.395249] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[80156.174398] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[80156.174449] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[80171.370264] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[80171.370318] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[80327.239021] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[80327.239081] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[80539.650825] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[80677.073383] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[80677.073457] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[80784.159974] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[80803.085023] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[81217.919999] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[81217.920050] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[81429.548656] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[81482.024795] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[81482.024843] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[81676.666621] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[81676.666680] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[81683.579404] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[81683.579455] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[81763.190270] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[81792.161153] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[81792.161218] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[82035.249835] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[82116.207150] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[82116.207204] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[82497.762673] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[82582.015010] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[82582.020572] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[82614.858653] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[82955.839359] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[82955.839405] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[83005.122730] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[83005.122784] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[83149.269051] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[83235.700318] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[83235.700368] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[83512.376788] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[83512.376834] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[83559.136788] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[83559.136838] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[83675.440844] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[83675.440908] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[83939.098086] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[83939.098136] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[84031.889821] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[84031.889876] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[84207.277212] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[84207.277286] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[84210.758564] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[84210.758731] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[84302.681099] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[84369.215857] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[84474.930238] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[84554.521222] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[84554.521272] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[84615.469629] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[84615.469682] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[84754.030628] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[84754.030682] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[85156.415445] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[85234.291919] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[85234.291999] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[85551.309120] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[85551.309177] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[85556.539373] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[85556.539428] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[85733.925459] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[85812.120638] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[85997.928325] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[85997.931654] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[86024.311106] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[86024.311155] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[86126.903211] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[86126.903290] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[86415.378285] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[86463.719907] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[86463.719952] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[86520.945044] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[86560.616790] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[86579.676607] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[86579.676657] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[86615.786347] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[86686.493017] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[86686.493067] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[86688.274951] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[86688.274995] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[86718.942272] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[86970.264784] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[87232.388618] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[87232.388682] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[87304.176977] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[87304.177031] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[87464.005420] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[87464.005474] rk3288-lcdc lcdc1: win2:new_addr:0x11809000 cur_addr:0x15de1000–1
<6>[87537.286418] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[88367.388689] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[89032.359046] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[89185.092234] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[89206.920628] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[89672.943039] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[89836.500259] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[90070.856231] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[90408.811050] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[90926.559070] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[92038.380012] binder: 18557:18575 transaction failed 29189, size 604-0
<6>[92038.567306] binder: 461:1972 transaction failed 29189, size 524-0
<6>[92038.567649] binder: 461:1972 transaction failed 29189, size 80-0
<6>[92038.645382] binder: release 18557:18575 transaction 72219853 out, still active
<6>[92038.682296] binder: 461:1972 transaction failed 29189, size 4-0
<6>[92038.682333] binder: send failed reply for transaction 72219853, target dead
<6>[92237.394657] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[93258.505277] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[94093.497432] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[94589.433463] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[94663.036653] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[95054.980249] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[95107.197867] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[95112.626231] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[95325.104658] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[95548.735030] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[96371.867435] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[96431.776653] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[96878.594647] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[96919.611054] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[97341.435210] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[97344.781073] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<4>[97393.134502] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[97513.423781] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[97513.423834] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[97839.847834] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[97931.819036] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[97935.805533] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[97935.805577] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[98398.083427] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[98398.083479] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[98456.424055] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[98456.424099] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[98545.602647] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[98545.602701] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[98869.632223] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[98869.632268] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[99194.766839] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[99454.020372] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[99454.020424] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[99585.239201] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[99585.239251] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[99601.700090] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[99645.412122] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[99645.412169] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[99732.030665] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[99765.526906] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[99765.526972] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[99867.921137] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[99880.196918] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[99880.196970] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x165cc000–1
<6>[100147.229508] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[100152.683072] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[100152.683126] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[100234.535790] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[100234.535839] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[100316.969464] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[100325.759831] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[100678.267429] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[100678.267483] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[100766.307862] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[100766.307908] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[100978.529049] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[101055.576234] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[101069.729712] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[101095.171407] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[101095.171465] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[101118.207847] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[101187.897444] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[101187.897493] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[101258.927099] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[101258.927148] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[101344.314839] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[101415.092576] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[101415.092629] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[101487.029446] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[101487.029492] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[101552.878088] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[101552.878138] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[101626.837472] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[101633.015466] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[101633.015517] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[101748.853493] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[101809.937013] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[101809.937089] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[101848.132846] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[101848.132897] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[101961.053032] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[102190.790008] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[102190.790073] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[102281.932152] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[102281.932236] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[102301.401229] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[102301.401278] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[102352.750678] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[102634.207491] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[102684.283674] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[102684.283725] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[102686.917109] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[102888.899535] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[103030.224196] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[103030.224253] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[103204.440313] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[103204.440380] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[103436.889031] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[103505.424671] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[103621.291191] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[103849.347794] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[103849.347844] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[103857.549229] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[103903.469032] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[104084.246233] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[104090.352895] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[104090.352940] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[104159.996357] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[104159.996432] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[104178.673524] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[104178.673571] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[104223.498772] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[104310.027322] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[104310.027374] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[104346.884024] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[104346.884077] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[104381.779785] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[104381.779840] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[104502.643024] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[104531.642789] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[104531.642845] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[104592.442679] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[104592.442735] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[104601.666416] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[104601.666471] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[105156.619297] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[105156.619367] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[105220.520395] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[105278.334475] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[105278.334621] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[105495.432131] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[105495.432179] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[105556.067078] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[105556.067127] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[105636.600007] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[105636.600071] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[105899.598647] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[105899.598693] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[106068.930797] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[106068.930862] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[106265.387805] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[106265.387853] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[106482.402148] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[106527.907973] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[106527.908033] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[106769.771024] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[106769.771088] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[106800.905229] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[106800.905290] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[106888.532887] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[106888.532934] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[106977.534248] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[106996.197576] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[107042.951641] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[107042.951870] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[107111.194252] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[107128.498564] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[107128.498620] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[107175.499001] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<4>[107231.198764] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[107438.404590] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[107438.404641] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[107461.008666] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[107461.008715] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[107575.414646] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[107575.414700] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[107615.689490] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[107712.680663] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[108290.889715] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[108290.889771] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[108294.322539] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[108294.322587] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[108386.800137] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[108386.800185] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[108534.156644] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[108534.303720] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[108756.631590] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[108756.631644] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[108809.906251] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[108897.964592] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[108897.964653] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[108899.383413] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[108899.383458] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[108901.957325] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[108901.957374] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[108902.485546] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[108902.485594] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[108936.226358] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[108936.226407] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[109119.335554] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[109119.335601] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[109132.445138] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[109155.683838] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[109209.604134] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[109209.604198] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[109244.829050] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[109244.829099] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[109297.150246] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[109422.905467] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[109462.495066] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[109483.260147] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[109483.260202] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[109505.600556] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[109505.600613] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[109678.778222] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[109777.735841] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[109813.717483] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[109998.186401] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[109998.186451] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[110025.509404] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[110025.509453] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[110165.087587] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[110442.690242] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[110476.375836] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[110509.619977] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[110509.620025] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[110516.247476] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[110516.247523] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[110529.511852] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[110571.289116] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[110571.289174] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[110637.095832] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[110686.173635] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[110686.173683] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[110709.337841] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[110710.338237] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[110968.575412] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[110968.575459] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[111167.063243] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[111380.753855] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[111414.045843] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[111438.711710] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[111442.006431] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[111442.006487] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[111583.262705] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[111720.414908] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[111720.418591] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[111740.110641] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[111860.510348] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[111860.510408] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[111942.907776] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[111942.907834] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[111971.930024] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[111971.930071] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[112099.469514] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[112099.469579] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[112128.953758] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[112128.953842] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[112142.845435] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[112217.125955] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[112217.126006] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[112243.624006] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[112243.624052] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[112286.869271] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[112286.869325] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[112299.820375] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[112299.820457] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[112448.264459] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[112448.264509] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[112453.707483] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[112489.446678] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[112489.446726] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[112508.532654] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[112553.645513] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[112553.645559] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[112597.929451] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[112597.929502] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[112808.444052] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[112808.444097] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[112814.966634] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[112840.864995] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[112840.865047] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[112950.667954] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[112950.668008] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[113061.559412] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[113061.559462] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[113095.767438] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[113267.524664] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[113285.553798] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[113285.553843] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[113560.597305] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[113560.597369] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[113623.343624] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[113626.143435] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[113690.347731] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[113690.347781] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[113779.938788] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[114150.297879] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[114150.297951] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[114194.037645] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[114194.037712] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[114219.430014] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[114242.635828] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[114296.185548] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[114296.185626] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[114352.942103] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[114352.942148] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[114502.986621] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[114502.986666] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[114543.558623] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[114543.558674] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[114758.511184] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[114758.511255] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[114787.460236] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[114889.829035] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[115008.425744] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[115008.425814] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[115034.001690] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[115034.001756] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[115112.767315] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[115112.767375] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[115162.859021] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[115162.859069] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[115214.024232] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[115230.984641] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[115230.984709] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[115302.731842] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[115306.600824] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[115306.600878] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[115404.161094] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[115404.161143] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[115459.120560] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[115459.120640] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[115633.815042] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[115800.853454] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[115800.853524] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[115948.274594] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[115948.274640] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[116057.516387] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[116057.516480] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[116306.346289] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[116400.728235] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[116426.148274] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[116458.713024] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[116458.713080] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[116537.668230] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[116677.592528] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[116677.592575] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[116925.213815] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[116925.213866] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<4>[117070.426218] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<4>[117087.225951] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[117132.312870] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[117132.312928] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[117185.763499] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[117260.809871] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[117266.270576] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[117266.270642] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[117351.307904] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[117351.307953] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[117492.509075] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[117583.254870] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[117583.254919] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[117637.796643] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[117702.907702] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[117702.907752] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[117728.308253] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[117858.281602] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[117888.326699] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[117888.326743] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[117902.928616] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[118155.549145] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[118205.805942] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[118205.805992] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[118262.833447] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[118322.513034] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[118448.383255] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[118448.823967] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[118448.824018] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[118484.348264] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[118612.496860] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[118612.496917] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[118632.724981] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[118632.725029] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[118820.635347] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[118820.635397] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[118945.204642] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[119086.768865] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[119086.768908] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[119216.436734] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[119216.436807] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[119358.297641] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[119358.297695] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[119452.855045] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[119457.656377] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[119701.367763] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[119701.367815] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[119818.133812] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[119818.133882] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[119860.222472] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[119860.222523] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[119863.489593] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[119863.489646] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[119868.637024] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[119868.637080] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[119880.463873] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[120016.797072] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[120196.475436] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[120202.962071] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[120202.962124] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[120207.697426] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[120232.165794] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[120334.692372] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[120334.692419] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[120334.906863] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[120334.906909] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[120337.532139] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[120352.016620] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[120352.016674] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[120458.751468] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[120458.751522] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[120490.643622] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[120490.643676] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[120549.216096] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[120549.216151] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[120607.525171] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[120618.480254] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[120644.334516] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[120644.334560] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[120662.465083] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[120664.166624] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[120664.166688] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[120737.390510] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[120737.390559] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[120744.055032] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[120822.196884] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[120822.196944] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[121150.447038] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[121318.577996] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[121318.578064] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[121332.306676] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[121496.962635] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[121522.970979] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[121522.971029] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[121869.439436] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[121870.577977] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[121870.578030] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[121908.641824] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[121918.392882] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[121918.392947] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[122001.697910] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[122001.697963] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[122092.905842] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[122157.979027] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[122157.979075] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[122178.685679] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[122178.685741] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[122260.621116] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[122308.992236] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[122540.960474] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[122540.960540] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[122545.480231] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[122624.430391] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[122624.430436] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[122757.532240] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[122851.832252] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[122919.531472] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[122951.034165] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[123001.340215] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[123001.340266] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[123106.868637] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[123139.963852] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[123391.746184] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[123391.746248] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[123398.774865] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[123540.730636] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[123557.377273] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[123611.599459] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[123611.599507] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[123651.560461] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[123717.244145] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[123717.244195] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[123989.663810] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[124005.470131] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[124053.318123] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[124053.318174] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[124179.740235] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[124279.341819] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[124279.341868] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[124353.596642] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[124368.750238] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[124389.144574] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[124389.144624] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[124492.248614] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[124492.248683] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[124529.371829] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[124592.118301] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[124845.580232] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[125013.303047] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[125051.482559] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[125066.440244] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[125066.440300] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[125097.706427] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[125097.706500] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[125463.908079] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[125463.908159] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[125601.066635] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[125601.066706] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[125612.401643] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[125612.401697] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[125690.674318] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[125690.674366] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[125934.632976] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[125934.633022] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[125959.101149] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[125959.101205] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[126105.037574] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[126133.548113] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[126133.548169] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[126212.777672] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[126298.439838] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[126374.635971] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[126374.636041] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[126405.390338] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[126405.390385] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[126523.640752] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[126523.640803] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[126545.353871] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[126545.353923] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[126568.535333] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[126718.002336] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[126718.002386] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[126721.137196] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[126721.137248] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[126788.289367] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[126832.063026] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[126883.001477] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<4>[126909.470894] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[126927.707868] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[126940.991839] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[127073.487448] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[127081.228306] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[127085.361031] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[127190.096420] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[127190.096464] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[127287.130442] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[127345.222736] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[127345.222784] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[127370.961617] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[127370.961687] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[127478.850426] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[127478.850473] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[127506.189848] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[127506.189902] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[127631.139045] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[127631.139098] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[127775.161468] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[127801.401430] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[127954.178368] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[127954.178420] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[128002.108865] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[128002.108907] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[128078.253677] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[128078.253727] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[128114.782443] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[128114.782492] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[128212.012736] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[128212.012782] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[128251.017038] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[128251.017087] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[128285.168619] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[128308.899429] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[128574.513848] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[128611.015292] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[128611.015351] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[128693.233488] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[128973.273291] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[128973.273347] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[129460.398255] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[129460.398304] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[129643.028829] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[129643.028873] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[129647.929148] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[129647.929196] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[130105.224242] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[130295.743047] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[130560.406468] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[130713.172234] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[130742.607391] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[130742.607437] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[131159.941082] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[131318.432377] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[131318.432432] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[131806.300859] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[131806.300935] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[131851.376110] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[131851.376167] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[131867.726748] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[131867.726948] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[132035.947053] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[132091.690660] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[132118.680908] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[132118.680958] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[132450.431990] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[132450.432039] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[132530.700965] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[132530.701011] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[132622.206021] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[132622.206077] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[132726.387039] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[133101.182100] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[133101.182184] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[133102.160289] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[133111.493055] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[133111.493107] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[133157.953381] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[133282.232255] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[133409.889845] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[133620.957481] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[133620.961816] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[133868.380649] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[133868.380695] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[133870.921511] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[133870.921559] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[133898.491876] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[133898.491927] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[133915.075479] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[133931.262242] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[134051.440202] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[134051.440265] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[134109.963186] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[134109.963248] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[134207.110795] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[134231.218242] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[134381.393030] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[134694.153397] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[134694.153467] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[134819.961846] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[134859.624784] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[134859.624835] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[135066.327804] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[135066.327853] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[135118.366585] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[135118.366637] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[135190.421438] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[135325.086138] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[135325.086540] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[135333.806640] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[135415.155763] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[135415.155854] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[135461.304267] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[135461.304319] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[135574.624260] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[135711.103460] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[135711.103512] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[135747.154458] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[135747.154505] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[135784.888263] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[135784.888310] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[135859.787435] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[135891.537870] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[135898.143635] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[135898.143707] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[136100.178631] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[136208.959832] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[136304.850650] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[136559.826833] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[136559.826890] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<4>[136748.633649] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[136765.541165] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[136765.541223] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[136938.237912] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[136938.237968] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[137081.666170] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[137081.666239] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[137104.732175] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[137104.732315] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[137130.492323] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[137173.352708] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[137173.352756] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[137214.864905] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[137214.864962] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[137225.473928] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[137225.473980] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[137245.161050] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[137256.327807] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[137256.327855] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[137364.767127] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[137502.663291] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[137502.663348] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[137707.385088] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[137707.385159] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[137746.983376] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[137746.983445] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[137785.624710] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[137785.624761] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[137810.621205] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[137810.621260] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[138100.216606] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[138100.216656] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[138126.730971] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[138126.731026] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[138212.544097] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[138212.544149] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[138212.807746] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[138212.807798] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[138255.106059] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[138275.704239] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[138332.873095] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[138332.873145] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[138418.768571] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[138418.768619] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[138643.274191] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[138643.274242] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[138686.344132] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[138688.482173] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[138688.482222] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[138689.208158] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[138689.213374] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[138756.404684] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[138780.562140] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[138792.255035] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[138807.409070] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[138807.409116] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[138844.334406] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[138844.334459] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[138911.860242] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[138968.817485] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[139029.060440] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[139029.060491] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[139029.093575] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[139029.093644] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[139052.834636] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[139456.127955] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[139456.128006] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[139536.962682] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[139757.338970] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[139757.339022] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[140232.093031] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[140368.935284] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[140368.935334] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[140478.225022] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[140501.044858] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[140501.044917] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[140511.488350] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[140511.488418] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[140794.269646] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[140794.269725] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[140889.864290] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[140996.221042] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[140996.221092] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[141093.187169] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[141093.187219] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[141157.807537] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[141276.543761] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[141276.543825] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[141335.993439] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[141455.418247] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[141556.124176] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[141556.124238] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[141609.201035] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[141781.537638] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[141860.465432] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[141870.207035] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[141877.898641] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[142124.326574] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[142124.326624] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[142138.400508] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[142138.400582] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[142158.216146] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[142158.216199] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[142180.987052] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[142468.270784] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[142468.270847] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[142471.709828] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[142613.943421] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[142613.943470] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[142646.793002] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[142646.796459] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[142666.757140] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[142666.757194] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[142728.648646] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[142929.426210] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[142929.426257] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[142933.829060] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[143012.054197] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[143012.054246] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[143077.624232] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[143277.478225] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[143277.478273] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[143328.347459] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[143390.944467] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[143390.944517] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[143466.873557] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[143466.877702] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[143475.488245] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[143492.921448] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[143527.194956] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[143527.195008] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[143558.226328] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[143579.644639] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[143687.556626] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[143764.454770] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[143764.454848] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[143764.553632] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[143764.553683] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[143773.595259] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[143773.595331] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[144041.747431] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[144140.459054] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[144255.011440] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[144255.011493] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[144407.910345] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[144526.728247] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[144562.888155] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[144562.888223] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[144614.648634] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[144674.934776] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[144674.934827] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[144753.421927] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[144753.421977] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[144811.680925] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[144811.680980] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[144887.612912] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[144887.612960] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[144966.477867] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[145013.665132] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[145013.665176] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[145049.478246] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[145166.328269] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[145171.756631] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[145239.128018] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[145424.909851] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[145424.909905] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[145441.244141] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[145441.244196] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[145477.262084] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[145477.262136] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[145601.354643] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[145669.824630] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[145723.843930] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[145723.843978] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[145765.059153] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[145765.059200] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[145892.585839] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[146052.608756] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[146052.608811] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[146075.196239] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[146075.196288] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[146367.283835] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[146401.150115] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[146418.173097] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[146443.593016] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[146536.021293] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[146536.021341] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[146563.146149] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[146563.146197] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[146586.327651] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[146586.327697] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<4>[146587.932828] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[146798.590936] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[146798.590989] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[146832.001999] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[146832.002053] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[147012.197434] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[147152.270632] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[147228.199397] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[147533.221668] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[147533.221724] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[147865.374871] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[147873.771453] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[148289.285047] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[148289.285104] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[148496.829490] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[148496.829540] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[148532.526915] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[148580.595043] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[148591.436650] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[148970.243552] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[148970.243603] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[149093.193439] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[149574.484593] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[149611.769025] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[149611.769091] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[149639.157748] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[149639.157829] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[149765.019484] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[149766.862130] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[149766.862186] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[149817.911320] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[149817.911369] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[149821.986264] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[149838.688289] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[149897.351036] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[150177.017855] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[150177.017906] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[150226.647720] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[150226.647806] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[150497.519788] binder: release 18409:18413 transaction 124677226 in, still active
<6>[150497.519835] binder: send failed reply for transaction 124677226 to 154:154
<11>[150498.488696] init: untracked pid 18409 killed by signal 1
<6>[150693.997430] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[150820.952034] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[150820.952083] rk3288-lcdc lcdc1: win2:new_addr:0x11fed000 cur_addr:0x11802000–1
<6>[150849.087625] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[150849.087695] rk3288-lcdc lcdc1: win2:new_addr:0x11fed000 cur_addr:0x11802000–1
<6>[151378.495883] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[151378.495932] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x11fed000–1
<6>[151419.976262] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[151422.862719] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[151626.975694] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[151626.975748] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x11fed000–1
<6>[151758.342479] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[151758.342531] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x11fed000–1
<6>[151858.348298] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[151860.595091] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[151862.299917] usb 1-1.2.3: USB disconnect, device number 8
<6>[151868.596735] usb 1-1.2.2: USB disconnect, device number 6
<3>[151868.596888] uvcvideo: Failed to resubmit video URB (-19).
<3>[151868.600758] uvcvideo: Failed to resubmit video URB (-19).
<3>[151868.604705] uvcvideo: Failed to resubmit video URB (-19).
<6>[151868.851169] usb 1-1.2.2: new high-speed USB device number 9 using rockchip_ehci_host
<6>[151869.038683] usb 1-1.2.2: New USB device found, idVendor=1871, idProduct=1130
<6>[151869.038764] usb 1-1.2.2: New USB device strings: Mfr=2, Product=1, SerialNumber=3
<6>[151869.038794] usb 1-1.2.2: Product: EP28WD
<6>[151869.038821] usb 1-1.2.2: Manufacturer: C-ASPIRE
<6>[151869.038842] usb 1-1.2.2: SerialNumber: Aspire1807250018
<6>[151869.051806] uvcvideo: Found UVC 1.00 device EP28WD (1871:1130)
<6>[151869.060387] input: EP28WD as /devices/ff500000.usb/usb1/1-1/1-1.2/1-1.2.2/1-1.2.2:1.0/input/input6
<6>[151869.328026] usb 1-1.2.3: new low-speed USB device number 10 using rockchip_ehci_host
<6>[151869.448030] usb 1-1.2.3: New USB device found, idVendor=1c4f, idProduct=0002
<6>[151869.448079] usb 1-1.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
<6>[151869.448102] usb 1-1.2.3: Product: USB Keyboard
<6>[151869.448120] usb 1-1.2.3: Manufacturer: SIGMACHIP
<6>[151869.522140] input: SIGMACHIP USB Keyboard as /devices/ff500000.usb/usb1/1-1/1-1.2/1-1.2.3/1-1.2.3:1.0/input/input7
<6>[151869.522864] keychord: using input dev SIGMACHIP USB Keyboard for fevent
<6>[151869.526296] hid-generic 0003:1C4F:0002.0004: input,hidraw1: USB HID v1.10 Keyboard [SIGMACHIP USB Keyboard] on usb-ff500000.usb-1.2.3/input0
<6>[151869.574638] input: SIGMACHIP USB Keyboard as /devices/ff500000.usb/usb1/1-1/1-1.2/1-1.2.3/1-1.2.3:1.1/input/input8
<6>[151869.577289] keychord: using input dev SIGMACHIP USB Keyboard for fevent
<6>[151869.580578] hid-generic 0003:1C4F:0002.0005: input,hidraw2: USB HID v1.10 Device [SIGMACHIP USB Keyboard] on usb-ff500000.usb-1.2.3/input1
<6>[151869.587512] usb 1-1.2.4: USB disconnect, device number 7
<6>[151869.841346] libphy: stmmac-0:01 - Link is Down
<6>[151934.637325] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[151934.637382] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x11fed000–1
<6>[151967.998676] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[152100.182645] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[152191.530632] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[152194.088948] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[152194.089003] rk3288-lcdc lcdc1: win2:new_addr:0x11fed000 cur_addr:0x11802000–1
<6>[152206.677591] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[152206.677644] rk3288-lcdc lcdc1: win2:new_addr:0x11fed000 cur_addr:0x11802000–1
<6>[152241.911321] stmmc_pltfr_fix_mac_speed: fix speed to 100
<6>[152241.911358] stmmc_pltfr_fix_mac_speed: fix speed for RGMII
<6>[152241.911379] libphy: stmmac-0:01 - Link is Up - 100/Full
<6>[152247.061470] binder: release 162:4773 transaction 126210896 in, still active
<6>[152247.061512] binder: send failed reply for transaction 126210896 to 24846:24846
<6>[152247.061928] binder: send failed reply for transaction 126210963 to 24846:3977
<6>[152250.332417] vcodec_service: ff9a0000.vpu_service: power off…
<6>[152250.332516] vcodec_service: done
<6>[152252.126276] vcodec_service: ff9a0000.vpu_service: power on
<6>[152257.412859] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[152257.412915] rk3288-lcdc lcdc1: win2:new_addr:0x11fed000 cur_addr:0x11802000–1
<6>[152446.977047] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[152481.597490] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[152555.233446] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[152555.446639] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[152656.815038] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[152688.122649] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[152719.266245] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[152751.377436] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[152811.452702] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[152977.697426] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[152986.307440] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[153023.617436] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[153023.986234] rk3288-lcdc lcdc1: win0:new_addr:0x127d8000 cur_addr:0x14bde000–1
<6>[153023.986282] rk3288-lcdc lcdc1: win2:new_addr:0x11fed000 cur_addr:0x11802000–1
<6>[153025.651036] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[153141.303840] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[153249.986631] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[153265.916124] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[153265.916178] rk3288-lcdc lcdc1: win2:new_addr:0x11fed000 cur_addr:0x11802000–1
<6>[153301.581039] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[153361.277275] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[153539.935419] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[153539.935488] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x11fed000–1
<6>[153664.742635] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[153780.920249] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[153870.103445] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[153980.334368] rk3288-lcdc lcdc1: win0:new_addr:0x14bde000 cur_addr:0x139db000–1
<6>[153980.334422] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x11fed000–1
<6>[154053.624210] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[154053.624264] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x11fed000–1
<6>[154174.995842] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[154188.624255] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[154525.173808] rk3288-lcdc lcdc1: win0:new_addr:0x139db000 cur_addr:0x127d8000–1
<6>[154525.173965] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x11fed000–1
<6>[154581.633832] rk3288-lcdc lcdc0: win2:new_addr:0x11802000 cur_addr:0x11b88000–1
<6>[154842.016890] rk3288-lcdc lcdc0: win2:new_addr:0x11b88000 cur_addr:0x11802000–1
<6>[154850.257135] vcodec_service: ff9a0000.vpu_service: power off…
<6>[154850.257217] vcodec_service: done
<6>[154905.660974] vcodec_service: ff9a0000.vpu_service: power on
<6>[154936.087059] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11f0e000–1
<6>[154964.434339] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x11fed000–1
<6>[155021.158858] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x11fed000–1
<6>[155040.991023] rk3288-lcdc lcdc1: win2:new_addr:0x11fed000 cur_addr:0x11802000–1
<6>[155497.081856] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11f0e000–1
<6>[155602.907261] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x11fed000–1
<6>[155768.725052] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x11fed000–1
<6>[155926.012744] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x11fed000–1
<6>[155980.163408] rk3288-lcdc lcdc1: win2:new_addr:0x11fed000 cur_addr:0x11802000–1
<6>[156149.017089] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x11fed000–1
<6>[156149.226963] libphy: stmmac-0:01 - Link is Down
<6>[156154.463226] stmmc_pltfr_fix_mac_speed: fix speed to 100
<6>[156154.463269] stmmc_pltfr_fix_mac_speed: fix speed for RGMII
<6>[156154.463292] libphy: stmmac-0:01 - Link is Up - 100/Full
<6>[156170.679056] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11f0e000–1
<6>[156184.619051] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11f0e000–1
<6>[156295.778431] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11f0e000–1
<6>[156309.522694] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x11fed000–1
<6>[156326.318446] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x11fed000–1
<6>[156383.537946] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x11fed000–1
<6>[156504.205911] rk3288-lcdc lcdc0: win0:new_addr:0x126f9000 cur_addr:0x11f0e000–1
<6>[156579.169976] rk3288-lcdc lcdc1: win2:new_addr:0x11fed000 cur_addr:0x11802000–1
<6>[156587.617640] rk3288-lcdc lcdc1: win2:new_addr:0x11fed000 cur_addr:0x11802000–1
<6>[156598.012166] rk3288-lcdc lcdc1: win2:new_addr:0x11fed000 cur_addr:0x11802000–1
<6>[156605.132907] usb 1-1.2.4: new low-speed USB device number 11 using rockchip_ehci_host
<6>[156605.248262] usb 1-1.2.4: New USB device found, idVendor=413c, idProduct=301a
<6>[156605.248322] usb 1-1.2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
<6>[156605.248347] usb 1-1.2.4: Product: Dell MS116 USB Optical Mouse
<6>[156605.248382] usb 1-1.2.4: Manufacturer: PixArt
<6>[156605.264559] input: PixArt Dell MS116 USB Optical Mouse as /devices/ff500000.usb/usb1/1-1/1-1.2/1-1.2.4/1-1.2.4:1.0/input/input9
<6>[156605.266356] hid-generic 0003:413C:301A.0006: input,hidraw0: USB HID v1.11 Mouse [PixArt Dell MS116 USB Optical Mouse] on usb-ff500000.usb-1.2.4/input0
<6>[156767.322302] libphy: stmmac-0:01 - Link is Down
<6>[156814.449109] vcodec_service: ff9a0000.vpu_service: power off…
<6>[156814.449251] vcodec_service: done
<6>[156845.356301] stmmc_pltfr_fix_mac_speed: fix speed to 100
<6>[156845.356338] stmmc_pltfr_fix_mac_speed: fix speed for RGMII
<6>[156845.356361] libphy: stmmac-0:01 - Link is Up - 100/Full
<6>[156846.046895] vcodec_service: ff9a0000.vpu_service: power on
<6>[156849.649323] libphy: stmmac-0:01 - Link is Down
<6>[156855.733699] stmmc_pltfr_fix_mac_speed: fix speed to 100
<6>[156855.733743] stmmc_pltfr_fix_mac_speed: fix speed for RGMII
<6>[156855.733763] libphy: stmmac-0:01 - Link is Up - 100/Full
<6>[156874.414911] libphy: stmmac-0:01 - Link is Down
<6>[156875.014460] usb 1-1.2.2: reset high-speed USB device number 9 using rockchip_ehci_host
<6>[156876.951814] usb 1-1.2.2: USB disconnect, device number 9
<6>[156877.691062] usb 1-1.2.2: new high-speed USB device number 12 using rockchip_ehci_host
<3>[156877.860797] usb 1-1.2.2: unable to read config index 0 descriptor/all
<3>[156877.860858] usb 1-1.2.2: can’t read configurations, error -71
<6>[156880.209982] usb 1-1.2.2: new high-speed USB device number 14 using rockchip_ehci_host
<6>[156880.385625] usb 1-1.2.2: New USB device found, idVendor=1871, idProduct=1130
<6>[156880.385673] usb 1-1.2.2: New USB device strings: Mfr=2, Product=1, SerialNumber=3
<6>[156880.385700] usb 1-1.2.2: Product: EP28WD
<6>[156880.385718] usb 1-1.2.2: Manufacturer: C-ASPIRE
<6>[156880.385736] usb 1-1.2.2: SerialNumber: Aspire1807250018
<6>[156880.395041] uvcvideo: Found UVC 1.00 device EP28WD (1871:1130)
<6>[156880.405063] input: EP28WD as /devices/ff500000.usb/usb1/1-1/1-1.2/1-1.2.2/1-1.2.2:1.0/input/input10
<6>[156882.493965] usb 1-1.2.2: USB disconnect, device number 14
<6>[156883.230855] usb 1-1.2.2: new high-speed USB device number 15 using rockchip_ehci_host
<6>[156883.411415] usb 1-1.2.2: New USB device found, idVendor=1871, idProduct=1130
<6>[156883.411465] usb 1-1.2.2: New USB device strings: Mfr=2, Product=1, SerialNumber=3
<6>[156883.411491] usb 1-1.2.2: Product: EP28WD
<6>[156883.411509] usb 1-1.2.2: Manufacturer: C-ASPIRE
<6>[156883.411527] usb 1-1.2.2: SerialNumber: Aspire1807250018
<6>[156883.419880] uvcvideo: Found UVC 1.00 device EP28WD (1871:1130)
<6>[156883.436193] input: EP28WD as /devices/ff500000.usb/usb1/1-1/1-1.2/1-1.2.2/1-1.2.2:1.0/input/input11
<6>[156884.760971] usb 1-1.2.2: USB disconnect, device number 15
<6>[156885.100719] usb 1-1.2.2: new high-speed USB device number 16 using rockchip_ehci_host
<3>[156885.269736] usb 1-1.2.2: unable to read config index 0 descriptor/all
<3>[156885.269811] usb 1-1.2.2: can’t read configurations, error -71
<6>[156885.523706] usb 1-1.2.2: new high-speed USB device number 18 using rockchip_ehci_host
<3>[156885.697621] usb 1-1.2.2: unable to read config index 0 descriptor/all
<3>[156885.697680] usb 1-1.2.2: can’t read configurations, error -71
<6>[156885.986187] usb 1-1.2.2: new high-speed USB device number 20 using rockchip_ehci_host
<6>[156886.160860] usb 1-1.2.2: New USB device found, idVendor=1871, idProduct=1130
<6>[156886.160917] usb 1-1.2.2: New USB device strings: Mfr=2, Product=1, SerialNumber=3
<6>[156886.160941] usb 1-1.2.2: Product: EP28WD
<6>[156886.160960] usb 1-1.2.2: Manufacturer: C-ASPIRE
<6>[156886.160978] usb 1-1.2.2: SerialNumber: Aspire1807250018
<6>[156886.175056] uvcvideo: Found UVC 1.00 device EP28WD (1871:1130)
<6>[156886.186208] input: EP28WD as /devices/ff500000.usb/usb1/1-1/1-1.2/1-1.2.2/1-1.2.2:1.0/input/input12
<6>[156888.539534] usb 1-1.2.2: USB disconnect, device number 20
<6>[156889.528877] usb 1-1.2.2: new high-speed USB device number 21 using rockchip_ehci_host
<6>[156889.706598] usb 1-1.2.2: New USB device found, idVendor=1871, idProduct=1130
<6>[156889.706658] usb 1-1.2.2: New USB device strings: Mfr=2, Product=1, SerialNumber=3
<6>[156889.706681] usb 1-1.2.2: Product: EP28WD
<6>[156889.706698] usb 1-1.2.2: Manufacturer: C-ASPIRE
<6>[156889.706719] usb 1-1.2.2: SerialNumber: Aspire1807250018
<6>[156889.710740] uvcvideo: Found UVC 1.00 device EP28WD (1871:1130)
<6>[156889.723502] input: EP28WD as /devices/ff500000.usb/usb1/1-1/1-1.2/1-1.2.2/1-1.2.2:1.0/input/input13
<6>[156891.562250] usb 1-1.2.2: USB disconnect, device number 21
<6>[156899.335750] stmmc_pltfr_fix_mac_speed: fix speed to 100
<6>[156899.335785] stmmc_pltfr_fix_mac_speed: fix speed for RGMII
<6>[156899.335807] libphy: stmmac-0:01 - Link is Up - 100/Full
<6>[157043.030998] rk3288-lcdc lcdc1: win2:new_addr:0x11fed000 cur_addr:0x11802000–1
<6>[157141.717845] vcodec_service: ff9a0000.vpu_service: power off…
<6>[157141.717928] vcodec_service: done
<6>[157144.152788] vcodec_service: ff9a0000.vpu_service: power on
<6>[157158.855999] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[157448.353895] rk3288-lcdc lcdc0: win0:new_addr:0x11fed000 cur_addr:0x11802000–1
<6>[157485.558298] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11809000–1
<6>[157549.405272] binder: 461:1971 transaction failed 29189, size 344-0
<6>[157549.405694] binder: 461:1971 transaction failed 29189, size 80-0
<6>[157572.453033] rk3288-lcdc lcdc0: win0:new_addr:0x12373000 cur_addr:0x11b88000–1
<6>[157608.012110] binder: 154:154 transaction failed 29189, size 100-0
<11>[157608.989097] init: untracked pid 9025 killed by signal 1
<6>[157636.625835] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[157656.502668] rk3288-lcdc lcdc0: win0:new_addr:0x12373000 cur_addr:0x11b88000–1
<6>[157676.224039] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[157882.052640] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[158325.701963] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[158340.038255] rk3288-lcdc lcdc0: win0:new_addr:0x11b88000 cur_addr:0x12373000–1
<6>[158448.621746] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[158636.238658] rk3288-lcdc lcdc0: win0:new_addr:0x12373000 cur_addr:0x11b88000–1
<6>[158643.290655] rk3288-lcdc lcdc0: win0:new_addr:0x11b88000 cur_addr:0x12373000–1
<6>[158682.037056] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[158749.365853] rk3288-lcdc lcdc0: win0:new_addr:0x12373000 cur_addr:0x11b88000–1
<6>[158786.791043] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[158814.965886] rk3288-lcdc lcdc0: win0:new_addr:0x11b88000 cur_addr:0x12373000–1
<6>[158851.636240] rk3288-lcdc lcdc0: win0:new_addr:0x12373000 cur_addr:0x11b88000–1
<6>[159210.041866] rk3288-lcdc lcdc0: win0:new_addr:0x12373000 cur_addr:0x11b88000–1
<6>[159217.192272] rk3288-lcdc lcdc0: win0:new_addr:0x11b88000 cur_addr:0x12373000–1
<6>[159257.251690] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[159459.978386] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[159611.590362] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[159819.892259] rk3288-lcdc lcdc0: win0:new_addr:0x12373000 cur_addr:0x11b88000–1
<6>[159825.718204] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[159882.244645] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[159959.345876] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[160157.403231] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[160412.867088] rk3288-lcdc lcdc0: win0:new_addr:0x11b88000 cur_addr:0x12373000–1
<6>[160587.391161] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[161277.065061] rk3288-lcdc lcdc0: win0:new_addr:0x11b88000 cur_addr:0x12373000–1
<6>[161440.684739] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[161679.291456] rk3288-lcdc lcdc0: win0:new_addr:0x11b88000 cur_addr:0x12373000–1
<6>[161706.400678] rk3288-lcdc lcdc0: win0:new_addr:0x12373000 cur_addr:0x11b88000–1
<6>[161761.381382] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[161775.903849] rk3288-lcdc lcdc0: win0:new_addr:0x11b88000 cur_addr:0x12373000–1
<6>[161776.709447] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[161834.291739] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[161926.324731] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[162018.591345] rk3288-lcdc lcdc0: win0:new_addr:0x11b88000 cur_addr:0x12373000–1
<6>[162064.019062] rk3288-lcdc lcdc0: win0:new_addr:0x12373000 cur_addr:0x11b88000–1
<6>[162118.260965] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[162192.177776] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[162392.116105] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[162568.740971] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[162585.473468] rk3288-lcdc lcdc0: win0:new_addr:0x12373000 cur_addr:0x11b88000–1
<6>[162808.195104] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[162826.061519] rk3288-lcdc lcdc0: win0:new_addr:0x11b88000 cur_addr:0x12373000–1
<6>[162910.325671] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[162948.175063] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[163133.069455] rk3288-lcdc lcdc0: win0:new_addr:0x12373000 cur_addr:0x11b88000–1
<6>[163214.605538] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[163269.564657] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[163318.172833] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[163405.139301] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[163719.187256] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[163753.818741] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[163793.054035] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[163988.837855] rk3288-lcdc lcdc0: win0:new_addr:0x12373000 cur_addr:0x11b88000–1
<6>[164016.932831] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[164150.016076] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[164333.339671] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[164342.859768] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[164547.799552] rk3288-lcdc lcdc0: win0:new_addr:0x12373000 cur_addr:0x11b88000–1
<6>[164587.175457] rk3288-lcdc lcdc0: win0:new_addr:0x11b88000 cur_addr:0x12373000–1
<6>[164591.341060] rk3288-lcdc lcdc0: win0:new_addr:0x12373000 cur_addr:0x11b88000–1
<6>[164864.798179] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[165316.433220] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[165925.586819] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[165992.756092] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[166011.613863] rk3288-lcdc lcdc0: win0:new_addr:0x11b88000 cur_addr:0x12373000–1
<6>[166403.147510] rk3288-lcdc lcdc0: win0:new_addr:0x11b88000 cur_addr:0x12373000–1
<6>[166520.325555] rk3288-lcdc lcdc0: win0:new_addr:0x11b88000 cur_addr:0x12373000–1
<6>[166549.960617] rk3288-lcdc lcdc0: win0:new_addr:0x12373000 cur_addr:0x11b88000–1
<6>[166811.433471] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[166814.122864] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[166815.805793] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[166846.259082] rk3288-lcdc lcdc0: win0:new_addr:0x12373000 cur_addr:0x11b88000–1
<6>[167002.627270] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[167039.615050] rk3288-lcdc lcdc0: win0:new_addr:0x11b88000 cur_addr:0x12373000–1
<6>[167428.951151] rk3288-lcdc lcdc0: win0:new_addr:0x11b88000 cur_addr:0x12373000–1
<6>[167442.849561] vcodec_service: ff9a0000.vpu_service: power off…
<6>[167442.849647] vcodec_service: done
<6>[167499.237787] vcodec_service: ff9a0000.vpu_service: power on
<6>[167630.194116] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[167688.073804] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[167728.792248] rk3288-lcdc lcdc0: win0:new_addr:0x11b88000 cur_addr:0x12373000–1
<6>[167989.779565] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[168095.906262] rk3288-lcdc lcdc0: win0:new_addr:0x12373000 cur_addr:0x11b88000–1
<6>[168098.448638] binder: 461:478 transaction failed 29189, size 344-0
<6>[168098.456196] binder: 461:478 transaction failed 29189, size 80-0
<6>[168363.554259] rk3288-lcdc lcdc0: win0:new_addr:0x11b88000 cur_addr:0x12373000–1
<6>[168471.360780] rk3288-lcdc lcdc1: win2:new_addr:0x11802000 cur_addr:0x15de1000–1
<6>[168502.065866] rk3288-lcdc lcdc1: win2:new_addr:0x15de1000 cur_addr:0x11802000–1
<6>[168584.954591] rk3288-lcdc lcdc0: win0:new_addr:0x11b88000 cur_addr:0x12373000–1
<6>[168677.622134] usb 1-1.2.2: new high-speed USB device number 22 using rockchip_ehci_host
<6>[168677.802433] usb 1-1.2.2: New USB device found, idVendor=1871, idProduct=1130
<6>[168677.802484] usb 1-1.2.2: New USB device strings: Mfr=2, Product=1, SerialNumber=3
<6>[168677.802510] usb 1-1.2.2: Product: EP28WD
<6>[168677.802529] usb 1-1.2.2: Manufacturer: C-ASPIRE
<6>[168677.802607] usb 1-1.2.2: SerialNumber: Aspire1807250018
<6>[168677.807612] uvcvideo: Found UVC 1.00 device EP28WD (1871:1130)
<6>[168677.818107] input: EP28WD as /devices/ff500000.usb/usb1/1-1/1-1.2/1-1.2.2/1-1.2.2:1.0/input/input14
<6>[168678.302593] libphy: stmmac-0:01 - Link is Down
<6>[168688.123214] stmmc_pltfr_fix_mac_speed: fix speed to 100
<6>[168688.123257] stmmc_pltfr_fix_mac_speed: fix speed for RGMII
<6>[168688.123282] libphy: stmmac-0:01 - Link is Up - 100/Full
<4>[168692.396855] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<4>[168692.834404] stream->dev->udev->bus->busnum: 1, vdev->name: EP28WD, devpath: 1.2.2, set as: EP28WD
<6>[168697.839794] binder: send failed reply for transaction 137143342 to 154:154
<11>[168698.783023] init: untracked pid 9988 killed by signal 1
<1>[168707.347347] Unable to handle kernel paging request at virtual address 43ef6e3f
<1>[168707.354551] pgd = da8e0000
<1>[168707.357305] [43ef6e3f] *pgd=00000000
<0>[168707.360934] Internal error: Oops: 5 [#1] PREEMPT SMP ARM
<4>[168707.366244] Modules linked in: mali_kbase drmboot(P)
<4>[168707.371258] CPU: 3 PID: 24861 Comm: GCDaemon Tainted: P 3.10.0 #29
<4>[168707.378449] task: db948fc0 ti: d562e000 task.ti: d562e000
<4>[168707.383861] PC is at mem_cgroup_page_lruvec+0x54/0x80
<4>[168707.388922] LR is at mem_cgroup_page_lruvec+0x68/0x80
<4>[168707.393979] pc : [] lr : [] psr: 20070093
<4>[168707.393979] sp : d562fe98 ip : c0b7e9ff fp : 0000000e
<4>[168707.405440] r10: c589e908 r9 : cc160438 r8 : 00000003
<4>[168707.410673] r7 : 60070013 r6 : c0b87310 r5 : c0c61680 r4 : c158fb60
<4>[168707.417184] r3 : 43ef6cff r2 : 00000108 r1 : 00807b60 r0 : 43ef6e07
<4>[168707.423692] Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user
<4>[168707.430880] Control: 10c5387d Table: 1a8e006a DAC: 00000015
<4>[168707.436618]
<4>[168707.436618] PC: 0xc0105d80:
<4>[168707.440998] 5d80 e1a00006 ebfffcbb e2508000 0a000001 eb1bf60f e1a08006 e5943000 e1530004
<4>[168707.449225] 5da0 1affffd8 e8bd81f0 c0c612c0 e92d4070 e1a04000 e59f606c e1a05001 e596303c
<4>[168707.457454] 5dc0 e3530000 12810fb1 1a00000c ea00000f e5902000 e3120002 1a000003 e5962008
<4>[168707.465683] 5de0 e1530002 15802004 11a03002 e5940000 e3a02f42 e59331a4 e1a00f20 e0203092
<4>[168707.473913] 5e00 e5903038 e1530005 15805038 e8bd8070 eb000aef e5942000 e3120020 e5903004
<4>[168707.482142] 5e20 0affffea eafffff0 c0b87310 e59f301c e593303c e3530000 0281100e 00800101
<4>[168707.490374] 5e40 05903004 00822003 05802004 e12fff1e c0b87310 e92d4ff8 e1a06000 e1a00001
<4>[168707.498600] 5e60 e1a0b002 e1a0a003 e1a04001 eb000ad8 e1a0200d e3c28d7f e3c8803f e5983004
<4>[168707.506834]
<4>[168707.506834] LR: 0xc0105d94:
<4>[168707.511210] 5d94 e1a08006 e5943000 e1530004 1affffd8 e8bd81f0 c0c612c0 e92d4070 e1a04000
<4>[168707.519437] 5db4 e59f606c e1a05001 e596303c e3530000 12810fb1 1a00000c ea00000f e5902000
<4>[168707.527666] 5dd4 e3120002 1a000003 e5962008 e1530002 15802004 11a03002 e5940000 e3a02f42
<4>[168707.535895] 5df4 e59331a4 e1a00f20 e0203092 e5903038 e1530005 15805038 e8bd8070 eb000aef
<4>[168707.544118] 5e14 e5942000 e3120020 e5903004 0affffea eafffff0 c0b87310 e59f301c e593303c
<4>[168707.552344] 5e34 e3530000 0281100e 00800101 05903004 00822003 05802004 e12fff1e c0b87310
<4>[168707.560572] 5e54 e92d4ff8 e1a06000 e1a00001 e1a0b002 e1a0a003 e1a04001 eb000ad8 e1a0200d
<4>[168707.568804] 5e74 e3c28d7f e3c8803f e5983004 e2833001 e5883004 e1a07000 e1a09008 ea00000c
<4>[168707.577035]
<4>[168707.577035] SP: 0xd562fe18:
<4>[168707.581411] fe18 00000000 00000003 d562fe94 c0b7bcc0 0000000e c0012fd0 fed91000 d562fe60
<4>[168707.589639] fe38 c0b874b4 c0105e00 20070093 ffffffff d562fe84 c000d598 43ef6e07 00807b60
<4>[168707.597866] fe58 00000108 43ef6cff c158fb60 c0c61680 c0b87310 60070013 00000003 cc160438
<4>[168707.606092] fe78 c589e908 0000000e c0b7e9ff d562fe98 c0105e14 c0105e00 20070093 ffffffff
<4>[168707.614317] fe98 c158fb60 c0c61680 c0c61680 c00d57cc dcd8c210 00000000 c170d374 c1acc374
<4>[168707.622545] feb8 dc9a9cc0 cc160460 00000048 0000000e c19980a0 0000000e d562e000 cc160460
<4>[168707.630775] fed8 00000000 c00f9354 dcd8c210 00000000 cf8799f8 dcd8c058 dcd8c210 94704000
<4>[168707.639001] fef8 945b2000 c00ee0a0 cae7d180 00000000 dcd8c210 945b2000 94704000 bf000000
<4>[168707.647230]
<4>[168707.647230] IP: 0xc0b7e97f:
<4>[168707.651606] e97c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<4>[168707.659836] e99c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<4>[168707.668059] e9bc 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<4>[168707.676280] e9dc 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<4>[168707.684500] e9fc 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<4>[168707.692727] ea1c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<4>[168707.700950] ea3c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<4>[168707.709176] ea5c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<4>[168707.717405] ea7c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<4>[168707.725637]
<4>[168707.725637] R4: 0xc158fae0:
<4>[168707.730012] fae0 40080028 defa5aa1 000b9c18 00000000 00000001 c158fad4 c158f094 00000000
<4>[168707.738245] fb00 40080038 dd4a6161 0000004f 00000000 00000001 c1914e54 c1643fd4 00000000
<4>[168707.746477] fb20 40080028 dc264ae1 00000001 00000000 00000001 c17c5ef4 c17a7014 00000000
<4>[168707.754698] fb40 40080028 d1803761 0006e14b 00000000 00000001 c1678954 c1b544b4 00000000
<4>[168707.762919] fb60 40080068 dc486141 0000010d ffffffff 00000000 c1bbcdf4 c1551494 00000000
<4>[168707.771139] fb80 40080028 db361761 0007ad13 00000000 00000001 c1707994 c17a2af4 00000000
<4>[168707.779361] fba0 4002002c ccb1c644 00000034 ffffffff 00000001 c18a3c34 c1cc2ef4 00000000
<4>[168707.787581] fbc0 40080028 c986bf81 0008fa6d 00000000 00000001 c14dfef4 c158fbf4 00000000
<4>[168707.795803]
<4>[168707.795803] R5: 0xc0c61600:
<4>[168707.800179] 1600 00000fa7 00000467 00000000 fff29809 00004a05 00000005 00000000 00000000
<4>[168707.808400] 1620 00000000 00000005 00006b84 0000ab2b 00000000 00000927 00000001 00000000
<4>[168707.816620] 1640 c1d88040 00000200 00000009 c0c612c0 00000000 00020000 00020000 0001cc2a
<4>[168707.824841] 1660 c09fa76c 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<4>[168707.833062] 1680 00000080 00001491 000016cd 00000000 00000000 00000000 00000000 000016cd
<4>[168707.841282] 16a0 c0b7e9d8 59555955 00000000 00000000 00080000 00020000 c16caa94 c128fad4
<4>[168707.849505] 16c0 c0c616c0 c0c616c0 c1a93ff4 c15a0094 c0c616d0 c0c616d0 c0c616d8 c0c616d8
<4>[168707.857727] 16e0 c0c616e0 c0c616e0 00001c3b c11b7bd4 c1245ad4 c0c616f4 c0c616f4 c15b4c14
<4>[168707.865949]
<4>[168707.865949] R6: 0xc0b87290:
<4>[168707.870322] 7290 00000000 00000000 00000064 c1e06080 00000009 c1e060c0 00009000 0000000f
<4>[168707.878543] 72b0 c1e06100 00000004 0000002c c1de2000 c1e06000 c1e06040 00000001 00001000
<4>[168707.886764] 72d0 00000000 00000003 01269000 01272000 0127b000 01284000 0005e000 00000002
<4>[168707.894984] 72f0 0001eff1 0007ffff 0000f2b9 00002000 00000001 00000032 0000fffa 00000001
<4>[168707.903205] 7310 00000000 00000001 de804400 c07e51d4 c0107408 c0106450 c0103ac8 c0103cac
<4>[168707.911427] 7330 c01071c0 c0104028 c0103fdc 00000000 00000000 c0103410 00000003 00000000
<4>[168707.919650] 7350 00000000 00000001 c09ff975 c5b22000 c5b22010 c5b22010 de882a30 de882a30
<4>[168707.927872] 7370 00000000 00000001 00000000 00000000 00000000 00020002 c0b87394 dea9cb00
<4>[168707.936094]
<4>[168707.936094] R9: 0xcc1603b8:
<4>[168707.940468] 03b8 c18b9720 c189cb80 c16db320 c161c7e0 c168cca0 c1a405a0 c1b9a9e0 c162a140
<4>[168707.948691] 03d8 c15f8ca0 c17cd800 c19b7220 c1889f40 c1753320 c18bfbe0 c17235e0 c1913a60
<4>[168707.956911] 03f8 c1362f40 c193ab40 c14a4a40 c164efe0 c18b6700 c192a9e0 c192d400 c19a2120
<4>[168707.965131] 0418 c149dc80 c160b420 c1acc880 c14f8800 c1acc360 c1abcf80 c170d360 c158fb60
<4>[168707.973353] 0438 c1551480 c16edf20 c187c040 c18f4540 c1696720 c1a607e0 c1726e40 c19a2300
<4>[168707.981575] 0458 c19a5320 c19980a0 c17cdb60 c180e120 c171aa60 c1730140 c1731d60 c1732420
<4>[168707.989797] 0478 c1995700 c18b8dc0 c18bbf20 c187bfa0 c1b9bbc0 c1b9c880 c1692660 c1748a80
<4>[168707.998020] 0498 c174a180 c18956c0 c192ad80 c18d6c60 c18d6dc0 c192d500 c192e460 c1b9c8c0
<4>[168708.006243]
<4>[168708.006243] R10: 0xc589e888:
<4>[168708.010702] e888 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<4>[168708.018924] e8a8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<4>[168708.027144] e8c8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<4>[168708.035367] e8e8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 c5813800
<4>[168708.043587] e908 c1792a14 c19a9494 c13ce814 c1792a34 c16b4bd4 c18ac794 c16b1434 c16809f4
<4>[168708.051808] e928 c589e928 c589e928 0000c1f8 0000020f 0000caa5 000011ca c0c61680 0001378f
<4>[168708.060028] e948 00012bd0 00003481 00003577 00000000 00000000 00000000 00000000 00000000
<4>[168708.068248] e968 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<0>[168708.076476] Process GCDaemon (pid: 24861, stack limit = 0xd562e238)
<0>[168708.082725] Stack: (0xd562fe98 to 0xd5630000)
<0>[168708.087098] fe80: c158fb60 c0c61680
<0>[168708.095229] fea0: c0c61680 c00d57cc dcd8c210 00000000 c170d374 c1acc374 dc9a9cc0 cc160460
<0>[168708.103358] fec0: 00000048 0000000e c19980a0 0000000e d562e000 cc160460 00000000 c00f9354
<0>[168708.111490] fee0: dcd8c210 00000000 cf8799f8 dcd8c058 dcd8c210 94704000 945b2000 c00ee0a0
<0>[168708.119620] ff00: cae7d180 00000000 dcd8c210 945b2000 94704000 bf000000 00000000 00000152
<0>[168708.127750] ff20: 00000400 cc160000 00030002 de757b28 00000000 cae7d180 dcd8c210 94704000
<0>[168708.135881] ff40: dcd8c058 c00ee528 cae7d180 cae7d180 dcd8c210 94704000 945b2000 dcd8c058
<0>[168708.144011] ff60: 00000000 c00ef90c 94704000 945b2000 00152000 cae7d1c0 00152000 945b2000
<0>[168708.152142] ff80: cae7d180 c000db84 00000000 c00ef990 00000000 b520ea60 8085bf20 b8d71678
<0>[168708.160272] ffa0: 0000005b c000da00 b520ea60 8085bf20 945b2000 00152000 022c5f54 00000000
<0>[168708.168402] ffc0: b520ea60 8085bf20 b8d71678 0000005b b8bce050 8085bf20 00000060 00000000
<0>[168708.176532] ffe0: 0015180c a38133d8 b50ea3eb b6e2bea4 60070010 945b2000 000e0238 50b22070
<4>[168708.184685] [] (mem_cgroup_page_lruvec+0x54/0x80) from [] (release_pages+0xe0/0x1c8)
<4>[168708.194109] [] (release_pages+0xe0/0x1c8) from [] (free_pages_and_swap_cache+0x8c/0x9c)
<4>[168708.203781] [] (free_pages_and_swap_cache+0x8c/0x9c) from [] (unmap_region+0x124/0x178)
<4>[168708.213449] [] (unmap_region+0x124/0x178) from [] (do_munmap+0x180/0x1c8)
<4>[168708.221923] [] (do_munmap+0x180/0x1c8) from [] (vm_munmap+0x3c/0x50)
<4>[168708.229975] [] (vm_munmap+0x3c/0x50) from [] (ret_fast_syscall+0x0/0x30)
<0>[168708.238362] Code: e3a02f42 e59331a4 e1a00f20 e0203092 (e5903038)
<4>[168708.244442] —[ end trace bced2c14980d2f09 ]—
<0>[168708.249074] Kernel panic - not syncing: Fatal exception
<2>[168708.254305] CPU0: stopping
<4>[168708.257068] CPU: 0 PID: 0 Comm: swapper/0 Tainted: P D 3.10.0 #29
<4>[168708.264020] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
<4>[168708.272496] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x154/0x2c8)
<4>[168708.280716] [] (handle_IPI+0x154/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
<4>[168708.289276] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
<4>[168708.297570] Exception stack(0xc0b7ff08 to 0xc0b7ff50)
<4>[168708.302629] ff00: c0b7ff50 00029dba 0aca2aa9 00009bef c1de42e0 00000000
<4>[168708.310759] ff20: 0abde0fd 00009bef c0b91058 c0b7e000 c0b91068 00000000 1f8979f2 c0b7ff50
<4>[168708.318885] ff40: c0079bd4 c056e580 600f0013 ffffffff
<4>[168708.323953] [] (__irq_svc+0x40/0x70) from [] (cpuidle_enter_state+0x54/0xec)
<4>[168708.332687] [] (cpuidle_enter_state+0x54/0xec) from [] (cpuidle_idle_call+0x16c/0x27c)
<4>[168708.342272] [] (cpuidle_idle_call+0x16c/0x27c) from [] (arch_cpu_idle+0x8/0x44)
<4>[168708.351261] [] (arch_cpu_idle+0x8/0x44) from [] (cpu_idle_loop+0x1b8/0x224)
<4>[168708.359911] [] (cpu_idle_loop+0x1b8/0x224) from [] (freezing_slow_path+0x0/0x80)
<4>[168708.368984] [] (freezing_slow_path+0x0/0x80) from [] (0xffffffff)
<2>[168708.376771] CPU1: stopping
<4>[168708.379529] CPU: 1 PID: 0 Comm: swapper/1 Tainted: P D 3.10.0 #29
<4>[168708.386475] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
<4>[168708.394950] [] (show_stack+0x10/0x14) from [] (handle_IPI+0x154/0x2c8)
<4>[168708.403171] [] (handle_IPI+0x154/0x2c8) from [] (gic_handle_irq+0x54/0x5c)
<4>[168708.411730] [] (gic_handle_irq+0x54/0x5c) from [] (__irq_svc+0x40/0x70)
<4>[168708.420024] Exception stack(0xde8bdf30 to 0xde8bdf78)
<4>[168708.425080] df20: de8bdf78 00029dba 0aca2985 00009bef
<4>[168708.433211] df40: c1ded2e0 00000000 0ac4d5c0 00009bef c0b91058 de8bc000 c0b91068 00000000
<4>[168708.441339] df60: 1f8979f2 de8bdf78 c0079bd4 c056e580 600f0013 ffffffff
<4>[168708.447938] [] (__irq_svc+0x40/0x70) from [] (cpuidle_enter_state+0x54/0xec)
<4>[168708.456670] [] (cpuidle_enter_state+0x54/0xec) from [] (cpuidle_idle_call+0x16c/0x27c)
<4>[168708.466255] [] (cpuidle_idle_call+0x16c/0x27c) from [] (arch_cpu_idle+0x8/0x44)
<4>[168708.475241] [] (arch_cpu_idle+0x8/0x44) from [] (cpu_idle_loop+0x1b8/0x224)
<4>[168708.483886] [] (cpu_idle_loop+0x1b8/0x224) from [] (freezing_slow_path+0x0/0x80)
<4>[168709.402299] SMP: failed to stop secondary CPUs
<4>[168709.406755] CRU:
<4>[168709.408664] 00000000: 00000003 9fff005b 0fff002e 00000008 00000001 9fff0020 0fff000f 00000008
<4>[168709.417137] 00000020: 00000005 9fff0049 0fff0025 00000008 00000103 9fff00c5 0fff0014 00000008
<4>[168709.425610] 00000040: 00000b00 9fff0270 0fff0138 00000008 00005111 00000000 00000000 00000000
<4>[168709.434083] 00000060: 00004031 0000b108 00000003 00000200 00008100 00008200 00008342 00010014
<4>[168709.442556] 00000080: 01885091 00010014 0000a101 00002745 000043bb 00008a00 00000200 00000200
<4>[168709.451029] 000000a0: 00000200 0bb8ea60 00010014 00010014 00010014 00000910 00000900 001f05dc
<4>[168709.459502] 000000c0: 00001703 00000707 00000e40 00000701 00000242 00000102 00004141 00000040
<4>[168709.467974] 000000e0: 00004141 00000505 00008045 00008f8f 00000000 00000631 000083e5 00008307
<4>[168709.476446] 00000100: 00001200 00010014 00004141 00000000 00000000 00000000 00000000 00000000
<4>[168709.484918] 00000120: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<4>[168709.493392] 00000140: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<4>[168709.501864] 00000160: 00001000 0000ff00 00003f60 0000f2c0 00004ff0 0000aebd 0000ebf0 0000412b
<4>[168709.510337] 00000180: 00000fa4 00000000 00000c0d 000005cc 00000000 0000fe84 00000000 0000c01c
<4>[168709.518809] 000001a0: 0000017f 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<4>[168709.527279] 000001c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<4>[168709.535751] 000001e0: 00000000 00000000 00000000 00640064 00000004 00000000 00000002 00000000
<4>[168709.544222] 00000200: 00000002 00000000 00000002 00000000 00000002 00000000 00000004 000004e0
<4>[168709.552693] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<4>[168709.561164] 00000240: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<4>[168709.569636] 00000260: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<4>[168709.578107] 00000280: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<4>[168709.586578] 000002a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<4>[168709.595049] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<4>[168709.603520] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<4>[168709.611991] 00000300: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<4>[168709.620463] 00000320: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<4>[168709.628933] 00000340: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<4>[168709.637405] 00000360: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<4>[168709.645876] 00000380: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<4>[168709.654350] 000003a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<4>[168709.662821] 000003c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<4>[168709.671292] 000003e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
<4>[168709.679765] 00000400: 00000003 9fff005b 0fff002e 00000008 00000001 9fff0020 0fff000f 00000008
<0>[168709.688230] Rebooting in 5 seconds..
<4>[168715.760292] SMP: failed to stop secondary CPUs
Internal error: Oops 内存溢出
