调试rk3399的LVDS屏!
屏尺寸:15inch
分辨率:1024x768
接口:单八LVDS
由于rk3399没有原生LVDS接口,需要用到toshiba_tc358775芯片mipi2lvds,因此配置屏参需要在两部分配置,一部分是配置mipi的初始化指令,一部分是配置lvds的参数。
一.由于要用到mipi接口,所以先要在menuconfig里打开mipi。
(1)-> Device Drivers
| → Graphics support
| → Rockchip Misc Video drive
| → LCD Panel Select (rk mipi dsi lcd)
(2)-> Device Drivers
| → Graphics support
| → Rockchip Misc Video driver
| → RockChip display transmitter support
                 RK32 RGB to DisplayPort transmitter support
                 Rockchip MIPI DSI support
配置完上面的驱动保存后,打开.config文件,如果文件里面有如下3条数据,说明配置成功。
CONFIG_LCD_MIPI=y
CONFIG_MIPI_DSI=y
CONFIG_RK32_MIPI_DSI=y
还有个驱动需要勾选上
→ Device Drivers
| → Graphics support
| → Display Panels —><*> support for simple panel
不管是edp,还是mipi,在rk3399里面都要用到这个panel-simple驱动
二.设备树配置
1.由于要用到MIPI_DSI_MODE_VIDEO等宏定义,所以设备树里先添加头文件
#include <dt-bindings/display/drm_mipi_dsi.h>
2.绑定vop
&dsi_in_vopl {
status = “okay”;
&dsi_in_vopb {
status = “disabled”;
rk3399有两路vop,vopb支持到4k,vopl支持到2k,由于lvds的4k屏很少(目前为止我还没接触过),所以这里我把lvds绑定到vopl上,hdmi的4k屏比较常见,可以绑定到vopb上。
3.在pinctrl 节点上添加en脚和reset脚
两个脚的GPIO号需要自行查看自己的原理图来确定
&pinctrl {
/add lcd panel by louhn/
lcd-panel {
lcd_panel_reset: lcd-panel-reset {
rockchip,pins = <4 29 RK_FUNC_GPIO &pcfg_pull_down>;
        lcd_panel_pwr_en: lcd-panel-pwr-en {
            rockchip,pins = <4 30 RK_FUNC_GPIO &pcfg_pull_down>;
4.添加dsi节点
先附上我的dsi配置:
&dsi {
enable-gpios = <&gpio4 30 GPIO_ACTIVE_HIGH>;
reset-gpios = <&gpio4 29 GPIO_ACTIVE_LOW>;
status = “okay”;
rockchip,lane-rate = <891>;
panel@0 {
compatible =“simple-panel-dsi”;
reg = <0>;
backlight = <&backlight>;
            bus-format = <MEDIA_BUS_FMT_RGB888_1X24>;
            dsi,lanes = <4>;
            panel-init-sequence = [
                    29 00 06 3C 01 08 00 06 00
                    29 00 06 14 01 05 00 00 00
                    29 00 06 64 01 12 00 00 00
                    29 00 06 68 01 12 00 00 00
                    29 00 06 6C 01 12 00 00 00
                    29 00 06 70 01 12 00 00 00
                    29 00 06 34 01 1F 00 00 00
                    29 00 06 10 02 1F 00 00 00
                    29 00 06 04 01 01 00 00 00
                    29 00 06 04 02 01 00 00 00
                    29 00 06 50 04 20 01 F0 03
                    29 00 06 54 04 88 00 A0 00
                    29 00 06 58 04 00 04 58 00
                    29 00 06 5C 04 06 00 1D 00
                    29 00 06 60 04 00 03 03 00
                    29 00 06 64 04 01 00 00 00
                    29 01 06 A0 04 06 80 44 00
                    29 00 06 A0 04 06 80 04 00
                    29 00 06 04 05 04 00 00 00
                    29 00 06 80 04 00 01 02 03
                    29 00 06 84 04 04 07 05 08
                    29 00 06 88 04 09 0A 0E 0F
                    29 00 06 8C 04 0B 0C 0D 10
                    29 00 06 90 04 16 17 11 12
                    29 00 06 94 04 13 14 15 1B
                    29 00 06 98 04 18 19 1A 06
                    29 78 06 9C 04 61 02 00 00
     panel-exit-sequence = [
         05 05 01 28
         05 78 01 10
    display-timings {
        native-mode = <&timing_15inch>;
                    timing0: timing0 {
                    hactive = <1024>;
                        vactive = <768>;
                        hback-porch = <160>;
                        hfront-porch = <24>;
                        vback-porch = <29>;
                        vfront-porch = <3>;
                        hsync-len = <136>;
                        vsync-len = <6>;
                        hsync-active = <0>;
                        vsync-active = <0>;
                        de-active = <0>;
                        pixelclk-active = <0>;
dsi节点分析
1.enable和reset的gpio脚:按照前面pinctrl里面配置的写
2.rockchip,lane-rate:
先在附上我调试的屏的屏参(在2楼)
dsi时钟计算公式:dsi_hs_clk = ((h_active + hfp + hbp + h_sync) * (v_active + vfp + vbp + v_sync) * fps * bpp) / lane_number
即:dsi_hs_clk = 1344x806x60x24/4 = 390M
而实际的dsi clk会比设定的要小100左右,所以这里填写490比较合理,但是当我设置rockchip,lane-rate = <490>时,发现屏幕显示不正常,测量了下dsi的clock引脚的频率,发现没有达到390M。而瑞芯微官方文档里有这么一句话:
MIPI_DSI_HS_CLK 是各个 LANE 传输时的速率(ddr 双边沿),最小值 80Mbps,
最大 1Gbps,默认是 1Gbps,这个也基本上不用改,除非板子布线有问题,跑不了
1Gbps 的。
因此这里直接写rockchip,lane-rate = <1000>,应该也没问题。
3.,flags,format。flags照抄就行,瑞芯微已经设置好了会去自动匹配对应的flags,format根据屏幕来选择,如果是24位就用MIPI_DSI_FMT_RGB888,18为就用MIPI_DSI_FMT_RGB666
3.panel-init-sequence:mipi 的初始化指令是通过TC358764_5_774_5XBG_DSI-LVDS_Tv11p_nm.xls的excel工具导出的,该工具只要在对应地方输入屏参,配置完后就能导出对应的指令。(3楼附上我配好的对应的我调试的屏的excel表,供参考)
4.panel-exit-sequence这个是标准的退出指令,默认照抄就行,不用改。
5.display-timings:配置一些屏参,也没啥好说的。
屏参
execl初始化指令计算工具
TC358764_5_774_5XBG_DSI-LVDS_Tv11p_nm-15inch.zip (278 KB)
1就iayou学习加油
学习学习
新人报道,学习学习
display-timings:配置一些屏参 如何写?楼主写的跟手册表对不上啊,还有clock-frequency = ???
学习 学习
学习学习
支不支持10bit显示哈?
{:4_211:}
好东西,收下了, 谢谢啦!
11111111111111111111111111111
版主,我的rk33999pro从hdmi改为lvds 发现内核启动阶段不显示 logo ,请问是否遇到了整个问题,怎么解决的
设备树里打开
&route_dsi {
status = “okay”;
新用户,还不能下载,感谢分享,正在调这个芯片,有点头大。
Good Study
good
Good Study,学习学习
execl初始化指令计算工具,具体如何使用。完全搞不懂,能不能指点一二
