我的RK3288开发板,从指定的云盘上下载了固件,现在显示,输出这些都正常.但在ANDROID界面中打开WIFI,搜索不到任何WIFI热点,下载的是Firefly-RK3288_Android5.1.1_VGA_HDMI_181010这个固件。板子上的WIFI芯片型号是AP6335。麻烦帮忙看一下,是需要固件中作调整吗?还是怎样?
固件是没有问题的,请先确认板子天线是否有装上,或是把log贴出来看一下是什么原因
看了几个文档,是说把 dts里面的wifi type改成ap6335,我来试一下
您是说下载的固件,WIFI可以直接工作起来吗?
我把日志贴出来,麻烦您帮忙看一下。
DDR Version 1.00 20160530
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-10 (Oct 10 2018 - 17:23:17)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
Adding bank:0000000000000000(0000000100000000)
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 400
SdmmcInit = 2 0
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
pmic:act8846
can’t find dts node for pwm1
#Boot ver: 2018-10-10#2.30
empty serial no.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
no fuel gauge found
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x02000000 (0x006ae930)
ramdisk @ 0x05bf0000 (0x001464cc)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0561c4d8 … OK
Add bank:0000000000000000, 00000000fe000000
2018
[ 0.000000] rockchip_uboot_logo_setup: mem: 0x02000000@0xfbc00000, offset:0x00000000
[ 0.000000] rockchip_uboot_mem_reserve: reserve 0x02000000@0xfbc00000 for uboot logo
[ 0.000000] ion heap(cma): base(0) size(1000000) align(0)
[ 0.000000] cma: CMA: reserved 16 MiB at fac00000
[ 0.000000] ion_reserve: cma reserved base fac00000 size 16777216
[ 0.000000] cma: CMA: reserved 16 MiB at 1f000000
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c2eed000 s13376 r8192 d15296 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1039360
00(userdata) storagemedia=emmc uboot_logo=0x02000000@0xfbc00000 loader.timestamp=2018-10-10_17:23:17
[ 0.000000] allocated 8323072 bytes of page_cgroup
[ 0.000000] Memory: 4064MB = 4064MB total
[ 0.000000] Memory: 4037820k/4037820k available, 123716k reserved, 3588096K highmem
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0bbbd80 (11984 kB)
[ 0.000000] .init : 0xc0bbc000 - 0xc0c15440 ( 358 kB)
[ 0.000000] .data : 0xc0c16000 - 0xc0da86c0 (1610 kB)
[ 0.000000] .bss : 0xc0da86c0 - 0xc0ecbdbc (1166 kB)
[ 0.000000] rk_clk_tree_init start!
[ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div
[ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error
[ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1
[ 0.000000] rkclk_init_clks: cnt_rate = 29
[ 0.000000] rk3288 set GPLL BW 20 for HDMI!
[ 0.000000] process version: 3
[ 0.000000] channel:0, lkg:12
[ 0.000000] target-temp:80
[ 0.000000] channel:2, lkg:0
[ 0.000000] channel:1, lkg:11
[ 1.013425] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 1.013440] pid_max: default: 32768 minimum: 301
[ 1.013556] Security Framework initialized
[ 1.013572] SELinux: Initializing.
[ 1.013645] Mount-cache hash table entries: 512
[ 1.014289] Initializing cgroup subsys debug
[ 1.014303] Initializing cgroup subsys memory
[ 1.014328] Initializing cgroup subsys freezer
[ 1.014358] CPU: Testing write buffer coherency: ok
[ 1.014676] /cpus/cpu@0 missing clock-frequency property
[ 1.014689] /cpus/cpu@1 missing clock-frequency property
[ 1.014699] /cpus/cpu@2 missing clock-frequency property
[ 1.014708] /cpus/cpu@3 missing clock-frequency property
[ 1.014758] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 1.014808] Setting up static identity map for 0xc0869720 - 0xc0869778
[ 1.017123] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x17e6 (version 3.1)
[ 1.091554] CPU1: Booted secondary processor
[ 1.091588] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 1.111239] CPU2: Booted secondary processor
[ 1.111263] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 1.130943] CPU3: Booted secondary processor
[ 1.130967] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 1.131067] Brought up 4 CPUs
[ 1.131096] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 1.131105] CPU: All CPU(s) started in SVC mode.
[ 1.131831] devtmpfs: initialized
[ 1.136226] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 1.137324] pinctrl core: initialized pinctrl subsystem
[ 1.137573] regulator-dummy: no parameters
[ 1.151588] NET: Registered protocol family 16
[ 1.153453] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 1.153822] ion_snapshot: 0x1ea98000 map to 0xe0907000 and copy to 0xc0ea704c (version 0.1)
[ 1.154046] Registered FIQ tty driver
[ 1.154449] fiq-debugger is disabled in device tree
[ 1.155171] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[ 1.155193] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[ 1.155210] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 1.155226] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[ 1.155321] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 1.155385] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 1.155448] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 1.155510] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 1.155572] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 1.155634] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[ 1.155696] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 1.155759] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[ 1.155826] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 1.155891] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 1.155904] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 1.155916] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 1.155927] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 1.156544] rockchip_interrupts_register:bank_num=7
[ 1.158446] of_get_gpio_init_config:gpio[0] = 256, value = 0
[ 1.158466] of_get_gpio_init_config:gpio[1] = 136, value = 0
[ 1.158518] rockchip_pinctrl_probe:init ok
[ 1.165594] rk_iommu ff900800.iep_mmu: (iep) Enter
[ 1.165681] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 1.165694] rk_iommu ff900800.iep_mmu: (iep) Initialized
[ 1.165863] rk_iommu ff950800.vip_mmu: (vip) Enter
[ 1.165940] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 1.165952] rk_iommu ff950800.vip_mmu: (vip) Initialized
[ 1.166114] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[ 1.166186] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 1.166198] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[ 1.166356] rk_iommu ff940300.vopl_mmu: (vopl) Enter
[ 1.166436] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 1.166448] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[ 1.166620] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[ 1.166696] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 1.166708] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[ 1.166873] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[ 1.166951] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 1.166963] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[ 1.167132] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[ 1.167218] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 1.167231] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
[ 1.169043] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 1.169056] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 1.169642] rk3368_init_rockchip_pmu_ops: could not find pmu dt node
[ 1.169665] DDR DEBUG: version 1.00 20150126
[ 1.169693] DDR DEBUG: Channel a:
[ 1.169702] DDR DEBUG: DDR3 Device
[ 1.169715] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=2 Total Capability=2048MB
[ 1.169724] DDR DEBUG: Channel b:
[ 1.169731] DDR DEBUG: DDR3 Device
[ 1.169743] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=2 Total Capability=2048MB
[ 1.169752] DDR DEBUG: addr=0xdb2000
[ 1.169762] DDR DEBUG: stride=13, size=256, halfcap=80000000
[ 1.169771] DDR DEBUG: socAddr[0]=0xdb2000, socAddr[1]=0xdb2100
[ 1.169779] DDR DEBUG: chAddr[0]=0xdb2000, chAddr[1]=0xdb2000
[ 1.169791] DDR DEBUG: dtar[0]=0x201b6000, dtar[1]=0x201b6000
[ 1.169844] DDR DEBUG: init success!!! freq=200MHz
[ 1.169851] DDR DEBUG: Channel a:
[ 1.169864] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,4, DGSL=1,1 extra clock, DGPS=180,180
[ 1.169877] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,4, DGSL=1,1 extra clock, DGPS=180,180
[ 1.169889] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,4, DGSL=1,1 extra clock, DGPS=180,180
[ 1.169901] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,4, DGSL=1,1 extra clock, DGPS=180,180
[ 1.169913] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 1.169922] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 1.169930] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 1.169937] DDR DEBUG: Channel b:
[ 1.169949] DDR DEBUG: DT, DGPS=180,180
[ 1.169961] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,4, DGSL=1,1 extra clock, DGPS=180,180
[ 1.169973] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,4, DGSL=1,1 extra clock, DGPS=180,180
[ 1.169985] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,4, DGSL=1,1 extra clock, DGPS=180,180
[ 1.169996] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 1.170005] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 1.170013] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 1.194452] bio: create slab at 0
[ 1.194977] Rockchip hdmi driver version 2.0
[ 1.194977] .
[ 1.196187] SCSI subsystem initialized
[ 1.196344] usbcore: registered new interface driver usbfs
[ 1.196388] usbcore: registered new interface driver hub
[ 1.196476] usbcore: registered new device driver usb
[ 1.198747] host_en_gpio= -2
[ 1.201182] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 1.201651] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
[ 1.202101] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
[ 1.202340] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 1.203315] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 1.203438] media: Linux media interface: v0.10
[ ps_core: LinuxPPS API ver. 1 registered
[ 1.203551] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.203570] PTP clock support registered
[ 1.203630] i2c-core: driver [bq24296] using legacy suspend method
[ 1.203639] i2c-core: driver [bq24296] using legacy resume method
[ 1.203965] RK29 Watchdog Timer, (c) 2011 Rockchip Electronics
[ 1.204649] ion_drm_heap_create: 0@0
[ 1.204776] Rockchip ion module is successfully loaded (v1.1)
[ 1.204937] Advanced Linux Sound Architecture Driver Initialized.
[ 1.205361] Bluetooth: Core ver 2.16
[ 1.205399] NET: Registered protocol family 31
[ 1.205408] Bluetooth: HCI device and connection manager initialized
[ 1.205425] Bluetooth: HCI socket layer initialized
[ 1.205438] Bluetooth: L2CAP socket layer initialized
[ 1.205464] Bluetooth: SCO socket layer initialized
[ 1.205696] cfg80211: Calling CRDA to update world regulatory domain
[ 1.206392] act8846_i2c_probe,line=898
[ 1.207403] act8846_parse_dt,line=746
[ 1.207886] act8846_i2c_probe: act8846_pmic_hold=1
[ 1.207908] act8846_i2c_probe: act8846_pmic_sleep=1
[ 1.207923] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
[ 1.207937] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
[ 1.210069] act_dcdc1: 1200 mV
[ 1.213034] vccio: 3300 mV
[ 1.214895] vdd_logic: 700 ↔ 1500 mV at 1100 mV
[ 1.217851] act_dcdc4: 2000 mV
[ 1.219088] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
[ 1.221390] act_ldo2: 1050 mV
[ 1.223688] act_ldo3: 2800 mV
[ 1.225999] act_ldo4: 3300 mV
[ 1.228298] act_ldo5: 3300 mV
[ 1.230707] act_ldo6: 1100 mV
[ 1.233015] vcc_18: 1800 mV
[ 1.235321] act_ldo8: 1850 mV
[ 1.240102] vdd_arm: 712 ↔ 1500 mV at 1000 mV
[ 1.244809] vdd_gpu: 712 ↔ 1500 mV at 1000 mV
[ 1.245578] rk808_i2c_probe,line=1355
[ 1.246908] The device is not rk808 -11
[ 1.246992] rk808: probe of 0-001b failed with error -11
[ 1.247068] i2c-core: driver [rk818] using legacy suspend method
[ 1.247078] i2c-core: driver [rk818] using legacy resume method
[ 1.249020] Switching to clocksource arch_sys_counter
[ 1.272736] rga: Module initialized.
[ 1.273451] rga2 ff920000.rga: rga ion client create success!
[ 1.273621] rga: Driver loaded succesfully
[ 1.273817] fb disp policy is box
[ 1.273859] rk-fb rockchip-fb: rk fb ion client create success!
[ 1.273873] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 1.274211] rk-screen rk_screen.8: rockchip screen probe success
[ 1.274477] rk32-lvds rk32-lvds: rk32 lvds driver probe success
[ 1.274849] rk32-edp ff970000.edp: screen is not edp!
[ 1.274871] rk32-edp: probe of ff970000.edp failed with error -22
[ 1.275357] rk3288-lcdc lcdc0: can’t find power_ctr node for lcdc0
[ 1.275581] graphics fb0: rockchip framebuffer registerd:fb0
[ 1.275885] graphics fb1: rockchip framebuffer registerd:fb1
[ 1.276063] graphics fb2: rockchip framebuffer registerd:fb2
[ 1.276223] graphics fb3: rockchip framebuffer registerd:fb3
[ 1.276938] rk3288-lcdc lcdc0: lcdc0: dclk:297000000>>fps:120
[ 1.276954] rk3288-lcdc lcdc0: wakeup from standby!
[ 1.307621] alloc_buffer:ion_phy_addr=0x10000000
[ 1.320622] fb0:phy:10000000>>vir:e0991000>>len:0x1800000
[ 1.327528] rk_iommu ff930300.vopb_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eab6000
[ 1.327561] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
[ 1.327773] rk3288-lcdc lcdc1: can’t find power_ctr node for lcdc1
[ 1.327811] rk_fb_trsm_ops_get:un supported transmitter:0!
[ 1.328079] graphics fb4: rockchip framebuffer registerd:fb4
[ 1.328418] graphics fb5: rockchip framebuffer registerd:fb5
[ 1.328591] graphics fb6: rockchip framebuffer registerd:fb6
[ 1.328764] graphics fb7: rockchip framebuffer registerd:fb7
[ 1.329592] unknow screen type: 0
[ 1.329610] vop ver:3007236,unsupport output color:1
[ 1.329671] rk3288-lcdc lcdc1: lcdc1: dclk:148500000>>fps:868
[ 1.329684] rk3288-lcdc lcdc1: wakeup from standby!
[ 1.333466] fb4:phy:10000000>>vir:e0991000>>len:0x1800000
[ 1.333480] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu enabled
[ 1.334372] rockchip_set_mux:warning ignore bank num 15
[ 1.334507] rockchip_set_mux:warning ignore bank num 15
[ 1.334619] rockchip_set_mux:warning ignore bank num 15
[ 1.334747] rockchip_set_mux:warning ignore bank num 15
[ 1.334862] rockchip_set_mux:warning ignore bank num 15
[ 1.334981] rockchip_set_mux:warning ignore bank num 15
[ 1.335549] rockchip_set_mux:warning ignore bank num 15
[ 1.335714] rockchip_set_mux:warning ignore bank num 15
[ 1.336266] rockchip_set_mux:warning ignore bank num 15
[ 1.336430] rockchip_set_mux:warning ignore bank num 15
[ 1.336970] rockchip_set_mux:warning ignore bank num 15
[ 1.337120] rockchip_set_mux:warning ignore bank num 15
[ 1.337665] rockchip_set_mux:warning ignore bank num 15
[ 1.337813] rockchip_set_mux:warning ignore bank num 15
[ 1.339365] NET: Registered protocol family 2
[ 1.340054] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 1.340129] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 1.340201] TCP: Hash tables configured (established 4096 bind 4096)
[ 1.340258] TCP: reno registered
[ 1.340273] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 1.340296] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 1.340495] NET: Registered protocol family 1
[ 1.341128] Unpacking initramfs…
[ 1.411871] Freeing initrd memory: 1304K (c5bf0000 - c5d36000)
[ 1.412702] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 1.413271] vcodec_service: probe device ff9a0000.vpu_service
[ 1.413511] vcodec_service: No reset resource define
[ 1.413681] vcodec_service: ff9a0000.vpu_service: power on
[ 1.413767] vcodec_service: probe device ff9a0000.vpu_service
[ 1.413784] vcodec_service: checking hw id 4831
[ 1.414776] vcodec_service: ff9a0000.vpu_service: power off…
[ 1.414820] vcodec_service: done
[ 1.414829] vcodec_service: init success
[ 1.414896] vcodec_service: probe device ff9c0000.hevc_service
[ 1.415234] vcodec_service: ff9c0000.hevc_service: power on
[ 1.415292] vcodec_service: probe device ff9c0000.hevc_service
[ 1.415306] vcodec_service: checking hw id 6867
[ 1.415899] vcodec_service: ff9c0000.hevc_service: power off…
[ 1.415940] vcodec_service: done
[ 1.415948] vcodec_service: init success
[ 1.416088] rknandbase v1.0 2014-03-31
[ 1.416226] rknand: probe of ff400000.nandc failed with error -1
[ 1.416381] rknand_driver:ret = 0
[ 1.418338] audit: initializing netlink socket (disabled)
[ 1.418382] type=2000 audit(0.410:1): initialized
[ 1.419376] bounce pool size: 64 pages
[ 1.424018] fuse init (API version 7.22)
[ 1.424389] msgmni has been set to 912
[ 1.426287] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.426302] io scheduler noop registered
[ 1.426311] io scheduler deadline registered
[ 1.426409] io scheduler cfq registered (default)
[ 1.427630] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess.
[ 1.428328] IEP Driver loaded succesfully
[ 1.428416] Module initialized.
[ 1.429236] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.429271] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 1.430625] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.430641] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.430941] pwm-voltage-regulator pwm_regulator.22: unable to request PWM, trying legacy API
[ 1.430955] pwm-voltage-regulator pwm_regulator.22: unable to request legacy PWM
[ 1.430965] pwm_regulator_probe:error
[ 1.430987] platform pwm_regulator.22: Driver pwm-voltage-regulator requests probe deferral
[ 1.431176] rk_serial.c v1.8 2014-03-04
[ 1.431411] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[ 1.431618] serial ff180000.serial: membase e0972000
[ 1.431793] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1
[ 1.431959] serial ff190000.serial: membase e097e000
[ 1.432106] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
[ 1.433720] console [ttyS2] enabled
[ 1.433903] serial ff690000.serial: membase fed60000
[ 1.434077] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90) is a rk29_serial.3
[ 1.434300] serial ff1b0000.serial: membase e41be000
[ 1.436075] --11
[ 1.437208] loop: module loaded
[ 1.437575] zram: Created 1 device(s) …
[ 1.437661] i2c-core: driver [mpu6050B1] using legacy suspend method
[ 1.437674] i2c-core: driver [mpu6050B1] using legacy resume method
[ 1.437692] mpu_init: Probe name mpu6050B1
[ 1.437841] ak8963_mod_init: Probe name ak8963_mod
[ 1.438561] SCSI Media Changer driver v0.25
[ 1.438839] dws->regs: e41e2000
[ 1.440274] rockchip_spi_probe:num_cs=2,bus_num=0,irq=76,freq=45692308 ok
[ 1.440550] tun: Universal TUN/TAP device driver, 1.6
[ 1.440562] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.440695] vmac_init.
[ 1.441270] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 1.441287] stmmac_probe_config_dt: clock input/output? (input).
[ 1.441299] stmmac_probe_config_dt: TX delay(0x1d).
[ 1.441311] stmmac_probe_config_dt: RX delay(0x16).
[ 1.441362] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[ 1.441373] stmmc_pltfr_init:
[ 1.441382] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[ 1.441406] gmac_phy_reset: ERROR: Request pin stmmc_pltfr_init failed.
[ 1.441417] stmmc_pltfr_init: init for RGMII
[ 1.441428] tx delay=0x1d
[ 1.441428] rx delay=0x16
[ 1.441445] tx delay=0x1d
[ 1.441445] rx delay=0x16
[ 1.441938] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.441950] Normal descriptors
[ 1.441960] Ring mode enabled
[ 1.441970] DMA HW capability register supported
[ 1.441983] RX Checksum Offload Engine supported (type 2)
[ 1.441993] TX Checksum insertion supported
[ 1.442002] Wake-Up On Lan supported
[ 1.442038] Enable RX Mitigation via HW Watchdog Timer
[ 1.442499] PPP generic driver version 2.4.2
[ 1.442641] PPP BSD Compression module registered
[ 1.442654] PPP Deflate Compression module registered
[ 1.442679] PPP MPPE Compression module registered
[ 1.442692] NET: Registered protocol family 24
[ 1.442730] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.442744] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.442756] Rockchip WiFi SYS interface (V1.00) …
[ 1.442797] esp_mem_init enter date Apr 18 2018 10:10:02
[ 1.442808] esp_mem_init VERSION [V2.5]
[ 1.442871] esp_mem_init complete
[ 1.442959] usbcore: registered new interface driver catc
[ 1.443000] usbcore: registered new interface driver kaweth
[ 1.443014] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.443054] usbcore: registered new interface driver pegasus
[ 1.443094] usbcore: registered new interface driver rtl8150
[ 1.443133] usbcore: registered new interface driver r8152
[ 1.443144] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.443213] usbcore: registered new interface driver hso
[ 1.443264] usbcore: registered new interface driver asix
[ 1.443304] usbcore: registered new interface driver ax88179_178a
[ 1.443346] usbcore: registered new interface driver cdc_ether
[ 1.443383] usbcore: registered new interface driver cdc_eem
[ 1.443421] usbcore: registered new interface driver dm9601
[ 1.443459] usbcore: registered new interface driver dm9620
[ 1.443510] usbcore: registered new interface driver smsc75xx
[ 1.443557] usbcore: registered new interface driver smsc95xx
[ 1.443597] usbcore: registered new interface driver gl620a
[ 1.443636] usbcore: registered new interface driver net1080
[ 1.443675] usbcore: registered new interface driver plusb
[ 1.443715] usbcore: registered new interface driver rndis_host
[ 1.443754] usbcore: registered new interface driver cdc_subset
[ 1.443800] usbcore: registered new interface driver zaurus
[ 1.443843] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.443909] usbcore: registered new interface driver int51x1
[ 1.443948] usbcore: registered new interface driver kalmia
[ 1.444006] usbcore: registered new interface driver ipheth
[ 1.444051] usbcore: registered new interface driver sierra_net
[ 1.444092] usbcore: registered new interface driver cx82310_eth
[ 1.444147] usbcore: registered new interface driver cdc_ncm
[ 1.444188] usbcore: registered new interface driver qmi_wwan
[ 1.444228] usbcore: registered new interface driver cdc_mbim
[ 1.444242] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.446690] EHCI: ehci_rk_probe e4240000 e4240010
[ 1.446709] rockchip_ehci_host ff500000.usb: EHCI Host Controller
[ 1.446740] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[ 1.447080] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
[ 1.465565] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00
[ 1.465651] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.465668] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.465682] usb usb1: Product: EHCI Host Controller
[ 1.465696] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 1.465709] usb usb1: SerialNumber: ff500000.usb
[ 1.466188] hub 1-0:1.0: USB hub found
[ 1.466214] hub 1-0:1.0: 1 port detected
[ 1.466387] EHCI: ehci_rk_probe ok
[ 1.466496] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.466831] usbcore: registered new interface driver cdc_acm
[ 1.466845] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.466904] usbcore: registered new interface driver usblp
[ 1.466969] usbcore: registered new interface driver cdc_wdm
[ 1.467044] usbcore: registered new interface driver usb-storage
[ 1.467088] usbcore: registered new interface driver ums-alauda
[ 1.467127] usbcore: registered new interface driver ums-cypress
[ 1.467167] usbcore: registered new interface driver ums-datafab
[ 1.467205] usbcore: registered new interface driver ums_eneub6250
[ 1.467244] usbcore: registered new interface driver ums-freecom
[ 1.467284] usbcore: registered new interface driver ums-isd200
[ 1.467323] usbcore: registered new interface driver ums-jumpshot
[ 1.467362] usbcore: registered new interface driver ums-karma
[ 1.467408] usbcore: registered new interface driver ums-onetouch
[ 1.467449] usbcore: registered new interface driver ums-sddr09
[ 1.467490] usbcore: registered new interface driver ums-sddr55
[ 1.467530] usbcore: registered new interface driver ums-usbat
[ 1.467619] usbcore: registered new interface driver usbserial
[ 1.467660] usbcore: registered new interface driver usbserial_generic
[ 1.467695] usbserial: USB Serial support registered for generic
[ 1.467736] usbcore: registered new interface driver ch341
[ 1.467791] usbserial: USB Serial support registered for ch341-uart
[ 1.467838] usbcore: registered new interface driver cp210x
[ 1.467869] usbserial: USB Serial support registered for cp210x
[ 1.467917] usbcore: registered new interface driver option
[ 1.467948] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.468020] usbcore: registered new interface driver pl2303
[ 1.468053] usbserial: USB Serial support registered for pl2303
[ 1.468102] usbcore: registered new interface driver trancevibrator
[ 1.468114] usb20_otg: version 3.10a 21-DEC-2012
[ 1.468550] e4280040
[ 1.468564] Core Release: 3.10a
[ 1.468577] Setting default values for core params
[ 1.468727] Using Buffer DMA mode
[ 1.468739] Periodic Transfer Interrupt Enhancement - disabled
[ 1.468749] Multiprocessor Interrupt Enhancement - disabled
[ 1.468761] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.468772] ^^^^^^^^^^^^^^^^^Device Mode
[ 1.468787] Dedicated Tx FIFOs mode
[ 1.468808] pcd_init otg_dev = ddf3be80
[ 1.469128] usb20_otg ff580000.usb: DWC OTG Controller
[ 1.469160] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
[ 1.469194] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 1.469262] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.469279] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.469293] usb usb2: Product: DWC OTG Controller
[ 1.469307] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 1.469320] usb usb2: SerialNumber: ff580000.usb
[ 1.469759] hub 2-0:1.0: USB hub found
[ 1.469784] hub 2-0:1.0: 1 port detected
[ 1.470101] usb20_host: version 3.10a 21-DEC-2012
[ 1.472632] e4300040
[ 1.472645] Core Release: 3.10a
[ 1.472661] Setting default values for core params
[ 1.472775] Using Buffer DMA mode
[ 1.472786] Periodic Transfer Interrupt Enhancement - disabled
[ 1.472797] Multiprocessor Interrupt Enhancement - disabled
[ 1.472808] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.472818] ^^^^^^^^^^^^^^^^^^Host Mode
[ 1.472847] usb20_host ff540000.usb: DWC OTG Controller
[ 1.472875] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
[ 1.472921] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[ 1.473014] Init: Power Port (0)
[ 1.473073] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.473089] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.473103] usb usb3: Product: DWC OTG Controller
[ 1.473116] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 1.473130] usb usb3: SerialNumber: ff540000.usb
[ 1.473543] hub 3-0:1.0: USB hub found
[ 1.473567] hub 3-0:1.0: 1 port detected
[ 1.474292] usbcore: registered new interface driver xpad
[ 1.474350] usbcore: registered new interface driver usb_acecad
[ 1.474397] usbcore: registered new interface driver aiptek
[ 1.474442] usbcore: registered new interface driver gtco
[ 1.474487] usbcore: registered new interface driver hanwang
[ 1.474536] usbcore: registered new interface driver kbtab
[ 1.474610] usbcore: registered new interface driver wacom
[ 1.474622] ==gsl_ts_init==
[ 1.474692] ret=0
[ 1.474960] sensor_register_slave:mma8452,id=17
[ 1.474974] sensor_register_slave:gs_mc3230,id=23
[ 1.474985] gsensor_init
[ 1.474994] sensor_register_slave:mpu6880_acc,id=24
[ 1.475006] sensor_register_slave:mpu6500_acc,id=25
[ 1.475018] sensor_register_slave:cm3217,id=48
[ 1.475029] sensor_register_slave:cm3218,id=49
[ 1.475275] .. rk pwm remotectl v1.1 init
[ 1.475543] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
[ 1.478901] rtc_hym8563 0-0051: clock/calendar information is no longer guaranteed
[ 1.484227] hdmi->edidread:1[ 1.489607] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 1.491272] i2c /dev entries driver
[ 1.491977] IR NEC protocol handler initialized
[ 1.491991] IR RC5(x) protocol handler initialized
[ 1.492001] IR RC6 protocol handler initialized
[ 1.492012] IR JVC protocol handler initialized
[ 1.492022] IR Sony protocol handler initialized
[ 1.492032] IR RC5 (streamzap) protocol handler initialized
[ 1.492043] IR SANYO protocol handler initialized
[ 1.492052] IR MCE Keyboard/mouse protocol handler initialized
[ 1.492217] usbcore: registered new interface driver uvcvideo
[ 1.492230] USB Video Class driver (1.1.1)
[ 1.492243] CamSys driver version: v0.32.0, CamSys head file version: v0.11.0
[ 1.493721] D1:camsys_platform_probe(1300): 1-gpios-cifpower: gpio=236
[ 1.493744] D1:camsys_platform_probe(1303): gpios-cifpower: gpio_request
[ 1.493765] D1:camsys_platform_probe(1305): 1-gpios-cifpower: gpio_request=0
[ 1.493787] D1:camsys_platform_probe(1314): gpios-cifpower: 236 high
[ 1.493826] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288
[ 1.493826]
[ 1.493917] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 1.494068] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe41f8000 size: 0x4000)
[ 1.494726] D1:camsys_platform_probe(1446): ff910000.isp memory:
[ 1.494744] D1:camsys_platform_probe(1456): Register memory (phy: 0xff910000 vir: 0xe4220000 size: 0x10000)
[ 1.494762] D1:camsys_platform_probe(1451): I2c memory (phy: 0x1e02c000 vir: 0xde02c000 size: 0x1000)
[ 1.494777] D1:camsys_init_ext_fsh_module(20): init external flash module
[ 1.494790] D1:camsys_platform_probe(1471): Probe ff910000.isp device success
[ 1.495228] not find test_power_init dev node
[ 1.495287] i2c-core: driver [bq27320] using legacy suspend method
[ 1.495299] i2c-core: driver [bq27320] using legacy resume method
[ 1.495645] rockchip_temp_probe,line=364
[ 1.554132] tsadc ff280000.tsadc: initialized
[ 1.554543] device-mapper: uevent: version 1.0.3
[ 1.554788] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 1.555106] Bluetooth: HCI UART driver ver 2.2
[ 1.555123] Bluetooth: HCI H4 protocol initialized
[ 1.555135] Bluetooth: HCILL protocol initialized
[ 1.555147] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21
[ 1.555160] rtk_btusb: Register usb char device interface for BT driver
[ 1.555357] usbcore: registered new interface driver rtk_btusb
[ 1.555980] DVFS WARNING: clk_enable_dvfs: clk(aclk_vio1) freq table all value are smaller than default(594000), use default, just enable dvfs
[ 1.560024] cpufreq version 1.0, suspend freq 1200 MHz
[ 1.560231] cpuidle: using governor ladder
[ 1.560245] cpuidle: using governor menu
[ 1.560283] Synopsys Designware Multimedia Card Interface Driver
[ 1.560295] MHSC version = Ver 2.00 2015-06-10
[ 1.560612] dw cru_regsbase addr 0x1d8.
[ 1.560627] dw cru_reset_offset val 3.
[ 1.560642] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[ 1.560704] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc
[ 1.561013] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
[ 1.561182] dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
[ 1.561313] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.573809] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.580374] hdmi output corlor mode is 3
[ 1.580391] hdmi connect to lcdc1
[ 1.580403] switch:en=1,lcdc_id=1,screen type=6,cur type=0
[ 1.593521] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 1.593552] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
[ 1.593591] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[ 1.593919] dw cru_regsbase addr 0x1d8.
[ 1.593932] dw cru_reset_offset val 0.
[ 1.593946] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[ 1.594002] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc
[ 1.594719] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
[ 1.594892] dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
[ 1.595415] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
[ 1.595484] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.613165] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.625635] mmc0: BKOPS_EN bit is not set
[ 1.627507] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0]
[ 1.629787] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 1.629816] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 1.629838] [mmc0] tuning regsbase addr 0x218.
[ 1.630423] [mmc0] Data transmission error !!! MINTSTS: [0x00002000]
[ 1.630433] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 1.630454] dwmmc_rockchip ff0f0000.rksdmmc: data FIFO error (status=00002000)
[ 1.630479] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-5
[ 1.630709] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-192 (18 len)
[ 1.630721] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 214-282 (7 len)
[ 1.630732] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-192 (18 len)
[ 1.630742] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 102
[ 1.630785] mmc0: new HS200 MMC card at address 0001
[ 1.631074] mmcblk0: mmc0:0001 BGND3R 29.1 GiB
[ 1.631202] mmcblk0rpmb: mmc0:0001 BGND3R partition 3 4.00 MiB
[ 1.631515] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 1.631527] misc: 0x000800000 – 0x000c00000 (4 MB)
[ 1.631537] resource: 0x000c00000 – 0x001c00000 (16 MB)
[ 1.631546] kernel: 0x001c00000 – 0x002c00000 (16 MB)
[ 1.631555] boot: 0x002c00000 – 0x004c00000 (32 MB)
[ 1.631563] recovery: 0x004c00000 – 0x006c00000 (32 MB)
[ 1.631572] backup: 0x006c00000 – 0x00a000000 (52 MB)
[ 1.631581] cache: 0x00a000000 – 0x012000000 (128 MB)
[ 1.631589] kpanic: 0x012000000 – 0x012400000 (4 MB)
[ 1.631598] system: 0x012400000 – 0x072400000 (1536 MB)
[ 1.631606] metadata: 0x072400000 – 0x073400000 (16 MB)
[ 1.631615] baseparamer: 0x073400000 – 0x073800000 (4 MB)
[ 1.631624] userdata: 0x077800000 – 0x747800000 (27904 MB)
[ 1.632916] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
[ 1.633235] dw cru_regsbase addr 0x1d8.
[ 1.633245] dw cru_reset_offset val 1.
[ 1.633255] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[ 1.633295] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc
[ 1.633538] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
[ 1.633655] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
[ 1.633901] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.652537] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.672233] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
[ 1.672245] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[ 1.672536] leds-gpio leds.29: pins are not configured from the driver
[ 1.672747] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.672809] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.674164] usbcore: registered new interface driver usbhid
[ 1.674175] usbhid: USB HID core driver
[ 1.674286] ashmem: initialized
[ 1.674404] logger: created 256K log ‘log_main’
[ 1.674504] logger: created 256K log ‘log_events’
[ 1.674599] logger: created 256K log ‘log_radio’
[ 1.674691] logger: created 256K log ‘log_system’
[ 1.675831] input: rk29-keypad as /devices/ff100000.adc/key.32/input/input1
[ 1.676736] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ff890000.rockchip-i2s; cannot claim for 2-0010
[ 1.676753] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
[ 1.676765] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl
[ 1.676776] ES8323 2-0010: Error applying setting, reverse things back
[ 1.676824] es8323_adc = 0
[ 1.676836] jp es8323_line_det_gpio:-1
[ 1.677100] es8323 probe i2c recv ok
[ 1.678054] rockchip-spdif ff880000.rockchip-spdif: spdif ready.
[ 1.678646] es8323_probe
[ 1.829635] rk_fb_switch_screen: wait update_regs_wait timeout
[ 1.829689] rk3288-lcdc lcdc1: lcdc1: dclk:74250000>>fps:60
[ 1.829722] pixel clk is 74250000 tmds clk is 74250000
[ 1.830883] rockchip-hdmiv2 ff980000.hdmi: [hdmi_dev_config_video] sucess output HDMI.
[ 1.898519] hdmi remove from lcdc1
[ 1.898527] switch:en=0,lcdc_id=1,screen type=6,cur type=6
[ 2.154352] rk_fb_switch_screen: wait update_regs_wait timeout
[ 2.154389] rk3288-lcdc lcdc1: no layer is used,go to standby!
[ 2.312166] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → NULL → Left Line Mux
[ 2.312177] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → NULL → Left Line Mux
[ 2.312188] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → NULL → Left Line Mux
[ 2.312197] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → NULL → Left Line Mux
[ 2.312206] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → NULL → Left Line Mux
[ 2.312214] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → NULL → Left Line Mux
[ 2.312224] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → NULL → Right Line Mux
[ 2.312232] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → NULL → Right Line Mux
[ 2.312241] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → NULL → Right Line Mux
[ 2.312249] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → NULL → Right Line Mux
[ 2.312259] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → NULL → Right Line Mux
[ 2.312266] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → NULL → Right Line Mux
[ 2.312275] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left PGA Mux
[ 2.312283] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left PGA Mux
[ 2.312291] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left PGA Mux
[ 2.312299] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left PGA Mux
[ 2.312307] ES8323 2-0010: ASoC: no dapm match for Differential Mux → LAMP → Left PGA Mux
[ 2.312316] ES8323 2-0010: ASoC: Failed to add route Differential Mux → LAMP → Left PGA Mux
[ 2.312326] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right PGA Mux
[ 2.312334] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right PGA Mux
[ 2.312343] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right PGA Mux
[ 2.312351] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right PGA Mux
[ 2.312360] ES8323 2-0010: ASoC: no dapm match for Differential Mux → RAMP → Right PGA Mux
[ 2.312368] ES8323 2-0010: ASoC: Failed to add route Differential Mux → RAMP → Right PGA Mux
[ 2.312377] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Differential Mux
[ 2.312384] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Differential Mux
[ 2.312393] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Differential Mux
[ 2.312402] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Differential Mux
[ 2.312410] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Differential Mux
[ 2.312419] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Differential Mux
[ 2.312428] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Differential Mux
[ 2.312436] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Differential Mux
[ 2.312457] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left Line Mux
[ 2.312464] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left Line Mux
[ 2.312473] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left Line Mux
[ 2.312482] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left Line Mux
[ 2.312491] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → LAMP → Left Line Mux
[ 2.312499] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → LAMP → Left Line Mux
[ 2.312508] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right Line Mux
[ 2.312515] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right Line Mux
[ 2.312524] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right Line Mux
[ 2.312532] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right Line Mux
[ 2.312540] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → RAMP → Right Line Mux
[ 2.312548] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → RAMP → Right Line Mux
[ 2.312685] ES8323 2-0010: ASoC: mux Right Line Mux has no paths
[ 2.312697] ES8323 2-0010: ASoC: mux Left Line Mux has no paths
[ 2.312707] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths
[ 2.312717] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths
[ 2.312737] ES8323 2-0010: ASoC: mux Differential Mux has no paths
[ 2.319058] rockchip-es8323 rockchip-es8323.27: ES8323 HiFi ↔ ff890000.rockchip-i2s mapping ok
[ 2.319457] input: RK_ES8323 Headphone Jack as /devices/rockchip-es8323.27/sound/card0/input2
[ 2.319882] u32 classifier
[ 2.319889] Actions configured
[ 2.319899] Netfilter messages via NETLINK v0.30.
[ 2.319952] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 2.320241] ctnetlink v0.93: registering with nfnetlink.
[ 2.320305] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 2.320312] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 2.320531] xt_time: kernel timezone is -0000
[ 2.320702] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.320810] arp_tables: (C) 2002 David S. Miller
[ 2.320843] TCP: cubic registered
[ 2.320849] Initializing XFRM netlink socket
[ 2.321018] NET: Registered protocol family 10
[ 2.321485] mip6: Mobile IPv6
[ 2.321509] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 2.321612] sit: IPv6 over IPv4 tunneling driver
[ 2.321941] NET: Registered protocol family 17
[ 2.321964] NET: Registered protocol family 15
[ 2.322012] Bridge firewalling registered
[ 2.322022] Ebtables v2.0 registered
[ 2.322186] Bluetooth: RFCOMM TTY layer initialized
[ 2.322208] Bluetooth: RFCOMM socket layer initialized
[ 2.322214] Bluetooth: RFCOMM ver 1.11
[ 2.322221] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.322226] Bluetooth: BNEP filters: protocol multicast
[ 2.322236] Bluetooth: BNEP socket layer initialized
[ 2.322242] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.322252] Bluetooth: HIDP socket layer initialized
[ 2.322276] l2tp_core: L2TP core driver, V2.0
[ 2.322288] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 2.322295] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.322495] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 2.322504] [WLAN_RFKILL]: can’t find rockchip,grf property
[ 2.322511] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[ 2.322519] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 2.322527] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 2.322534] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 2.322554] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
[ 2.322571] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
[ 2.322578] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 2.322603] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
[ 2.322611] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 2.322649] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.322767] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
[ 2.322781] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155.
[ 2.322794] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
[ 2.322806] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
[ 2.322818] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
[ 2.322864] [BT_RFKILL]: Request irq for bt wakeup host
[ 2.322955] [BT_RFKILL]: ** disable irq
[ 2.323022] [BT_RFKILL]: ap6335 device registered.
[ 2.323711] rk3288_init_suspend
[ 2.323722] rk3288_suspend_init enter
[ 2.323919] rk3288_suspend_init: pm_ctrbits =200007
[ 2.323947] gpio_get_dts_info suspend:4
[ 2.323954] gpio_get_dts_info resume:4
[ 2.323959] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 2.323983] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 2.324110] clks_gating_suspend_init:clkgt info ok
[ 2.324194] Registering SWP/SWPB emulation handler
[ 2.324204] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 0x02000000@0xfbc00000
[ 2.326797] ddrfreq: verion 1.2 20140526
[ 2.326810] ddrfreq: normal 528MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 528MHz
[ 2.326818] ddrfreq: auto-freq=0
[ 2.326823] ddrfreq: auto-freq-table[0] 240MHz
[ 2.326829] ddrfreq: auto-freq-table[1] 324MHz
[ 2.326834] ddrfreq: auto-freq-table[2] 456MHz
[ 2.326839] ddrfreq: auto-freq-table[3] 528MHz
[ 2.336929] act_ldo3: operation not allowed
[ 2.336937] vga_edid_probe: turn on ldo3 done.
[ 2.337182] act_ldo4: operation not allowed
[ 2.337188] vga_edid_probe: turn on ldo done.
[ 2.337444] act_ldo2: operation not allowed
[ 2.337450] vga_edid_probe: turn on ldo2 done.
[ 2.337693] act_ldo8: operation not allowed
[ 2.337699] vga_edid_probe: turn on ldo done.
[ 2.342753] unable to read EDID block.
[ 2.377309] unable to read EDID block.
[ 2.411869] unable to read EDID block.
[ 2.411880] vga-ddc: read and parse edid failed errno:-5.
[ 2.411886] vga_edid_probe: success. 10
[ 2.412002] firefly_vga_get_enable 180, 0
[ 2.412009] firefly_vga_get_status 186
[ 2.412014] firefly_vga_set_enable 159 enable:1
[ 2.412032] firefly_vga_enable 130 start
[ 2.412040] firefly_switch_fb 55
[ 2.412048] switch:en=1,lcdc_id=0,screen type=1,cur type=1
[ 2.412094] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60
[ 2.412144] VGA ENABLE
[ 2.412171] regulator-dummy: disabling
[ 2.412409] register spi return v = :0
[ 2.412417] =======================================================
[ 2.412423] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 2.412428] =======================================================
[ 2.412434] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init.
[ 2.412485] dhd_module_init: in
[ 2.412492] ======== dhd_wlan_init_plat_data ========
[ 2.412498] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[ 2.412503] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[ 2.412508] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 2.412528] dhd_wlan_init_gpio: host_oob_irq: 196
[ 2.412533] pcd_pullup, is_on 0
[ 2.412538] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[ 2.412541] dhd_wifi_platform_load: Enter
[ 2.412554] Power-up adapter ‘DHD generic adapter’
[ 2.412575] wifi_platform_set_power = 1
[ 2.412580] file system registered
[ 2.412585] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 2.412591] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 2.412597] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
[ 2.412603] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 2.413100] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 2.413108] android_usb gadget: Number of LUNs=2
[ 2.413115] lun0: LUN: removable file: (no medium)
[ 2.413121] lun1: LUN: removable file: (no medium)
[ 2.413257] android_usb gadget: android_usb ready
[ 2.413333] sensor_init: Probe name sensors
[ 2.413348] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 2.414827] rtc_hym8563 0-0051: hctosys: invalid date/time
[ 2.420947] rockchip-spdif-card rockchip-spdif-card.25: rk-hdmi-spdif-hifi ↔ ff880000.rockchip-spdif mapping ok
[ 2.421968] ret 1024
[ 2.422334] usbcore: registered new interface driver snd-usb-audio
[ 2.422342] ALSA device list:
[ 2.422347] #0: RK_ES8323
[ 2.422351] #1: RK-SPDIF-CARD
[ 2.422728] Freeing unused kernel memory: 356K (c0bbc000 - c0c15000)
[ 2.518438] [WLAN_RFKILL]: wifi turn on power. 156
[ 2.620105] type=1403 audit(1.630:2): policy loaded auid=4294967295 ses=4294967295
[ 2.647236] init: invalid gid ‘trace’
[ 2.725086] wifi_platform_bus_enumerate device present 1
[ 2.725103] ======== Card detection to detect SDIO card! ========
[ 2.725117] mmc2:mmc host rescan start!
[ 2.745868] init: /dev/hw_random not found
[ 2.745929] keychord: using input dev ff680000.pwm for fevent
[ 2.745945] keychord: using input dev rk29-keypad for fevent
[ 2.750796] init: /dev/hw_random not found
[ 2.751686] fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
[ 2.752499] resize2fs: resize2fs 1.42.9 (28-Dec-2013)resize2fs: The filesystem is already 393216 blocks long. Nothing to do!resize2fs:
[ 2.755256] EXT4-fs (mmcblk0p10): Ignoring removed nomblk_io_submit option
[ 2.768322] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 2.768412] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/system,/system,ext4)=0
[ 2.769093] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
[ 2.773924] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.773969] e2fsck: system: clean, 1926/86592 files, 117987/393216 blocks
[ 2.777641] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 2.777710] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/system,target=/system,type=ext4)=0
[ 2.784321] EXT4-fs (mmcblk0p8): recovery complete
[ 2.784621] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.784681] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/cache,target=/cache,type=ext4)=0
[ 2.785025] EXT4-fs (mmcblk0p11): Ignoring removed nomblk_io_submit option
[ 2.788434] EXT4-fs (mmcblk0p11): recovery complete
[ 2.788451] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 2.788503] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,/metadata,ext4)=0
[ 2.789119] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata
[ 2.793183] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.793221] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata: clean, 11/1024 files, 1102/4096 blocks
[ 2.797027] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.797094] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,target=/metadata,type=ext4)=0
[ 2.797136] fs_mgr: Running /system/bin/fsck.f2fs -f /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
[ 2.797982] fsck.f2fs: executing /system/bin/fsck.f2fs failed: No such file or directory
[ 2.798017] fsck.f2fs: fsck.f2fs terminated by exit(255)
[ 2.798268] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=f2fs)=-1
[ 2.798612] EXT4-fs (mmcblk0p13): Ignoring removed nomblk_io_submit option
[ 2.823497] --11
[ 2.871431] hdmi->edidread:1[ 2.894982] EXT4-fs (mmcblk0p13): recovery complete
[ 2.895292] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 2.895378] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,/data,ext4)=0
[ 2.897469] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
[ 2.925559] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.925599] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata: clean, 580/1785856 files, 178713/7143424 blocks
[ 2.929947] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard,errors=panic
[ 2.930016] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=ext4)=0
[ 2.930040] fs_mgr: mount_with_alternatives(): Mounted /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata on /data with fs_type=ext4 instead of f2fs
[ 2.941573] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2]
Continuing without Mali clock control
[ 2.946085] mali pd enabled
[ 2.946097] clk enabled
[ 2.946110] MALI_DVFS_STEP = 4, div_dvfs = 10
[ 2.946121] mali_dvfs_infotbl[0].clock=198000,min_threshold=0,max_threshold=70
[ 2.946130] mali_dvfs_infotbl[1].clock=297000,min_threshold=70,max_threshold=80
[ 2.946140] mali_dvfs_infotbl[2].clock=417000,min_threshold=80,max_threshold=90
[ 2.946150] mali_dvfs_infotbl[3].clock=480000,min_threshold=94,max_threshold=100
[ 2.946246] turn on mali power
[ 2.946258] kbase_platform_rk_init,register_reboot_notifier
[ 2.946300] hrtimer: interrupt took 11084 ns
[ 2.946396] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
[ 2.948630] mali ffa30000.gpu: Probed as mali0
[ 2.949608] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 2.950228] rk29_ipp: version magic '3.0.36+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 2.950801] rk29_ipp: version magic '3.0.101+ SMP preempt mod_unload ARMv7 ’ should be ‘3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 2.951551] zram0: detected capacity change from 0 to 533413888
[ 2.967520] hdmi output corlor mode is 3
[ 2.967539] hdmi connect to lcdc1
[ 2.967552] switch:en=1,lcdc_id=1,screen type=6,cur type=6
[ 2.995658] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
[ 3.027619] EXT4-fs (mmcblk0p13): Unrecognized mount option “background_gc=on” or missing value
[ 3.035585] drmboot: module license ‘unspecified’ taints kernel.
[ 3.035607] Disabling lock debugging due to kernel taint
[ 3.035820] drm init, 20140910
[ 3.036306] drm init ok
[ 3.037726] bat_cap: oldcap path is /sys/devices/ff100000.adc
[ 3.037784] bat_cap: oldcap_path no exist
[ 3.037930] binder: 158:158 transaction failed 29189, size 0-0
[ 3.038543] init: Warning! Service displayd needs a SELinux domain defined; please fix!
r:init:s0 tcontext=u:r:su:s0 tclass=process permissive=1
[ 3.047894] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 3.047914] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
[ 3.048123] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
[ 3.048593] rtk_btusb: btchr_open: BT usb char device is opening
[ 3.048607] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 3.048627] rtk_btusb: btchr_open: BT usb char device is opening
[ 3.048636] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 3.048658] rtk_btusb: btchr_open: BT usb char device is opening
[ 3.048668] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 3.048683] rtk_btusb: btchr_open: BT usb char device is opening
[ 3.048692] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
ve=1
[ 3.054066] init: cannot find ‘/system/bin/debuggerd64’, disabling ‘debuggerd64’
[ 3.055445] init: cannot find ‘/system/bin/install-recovery.sh’, disabling ‘flash_recovery’
[ 3.055813] init: cannot find ‘/system/bin/bplus_helper’, disabling ‘bplus_helper’
[ 3.056001] init: Warning! Service drmservice needs a SELinux domain defined; please fix!
[ 3.056201] init: cannot find ‘/system/bin/akmd’, disabling ‘akmd’
[ 3.057523] android_usb: already disabled
[ 3.063406] read descriptors
[ 3.063419] read strings
[ 3.063436] mtp_bind_config
[ 3.063461] pcd_pullup, is_on 1
[ 3.217096] rk_fb_switch_screen: wait update_regs_wait timeout
[ 3.217114] rk3288_load_screen,clk_on = 0
[ 3.217169] rk3288-lcdc lcdc1: lcdc1: dclk:74250000>>fps:60
[ 3.217178] rk3288-lcdc lcdc1: wakeup from standby!
[ 3.315649] pixel clk is 74250000 tmds clk is 74250000
[ 3.316823] rockchip-hdmiv2 ff980000.hdmi: [hdmi_dev_config_video] sucess output HDMI.
[ 3.426511] RKNAND_GET_SN_SECTOR
[ 3.426525] return ret = 0
[ 3.427270] RKNAND_GET_DRM_KEY
[ 3.427281] return ret = 0
[ 3.443407] EHCI: rk_ehci_hcd_enable, disable host controller
[ 3.443432] dwc_otg_hcd_enable, enable host controller
e
[ 3.577237] logd.auditd: start
[ 3.595925] Using Buffer DMA mode
[ 3.595934] Periodic Transfer Interrupt Enhancement - disabled
[ 3.595940] Multiprocessor Interrupt Enhancement - disabled
[ 3.595946] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.595951] ^^^^^^^^^^^^^^^^^^Host Mode
[ 3.640299] Init: Power Port (0)
[ 3.905932] Indeed it is in host mode hprt0 = 00021501
[ 4.005076] firefly_vga_get_enable 180, 1
[ 4.005179] firefly_vga_get_status 186
[ 4.005740] firefly_vga_set_mode 203
[ 4.006394] firefly_vga_set_enable 159 enable:1
[ 4.024978] healthd: No charger supplies found
[ 4.024993] healthd: No battery devices found
[ 4.083225] usb 3-1: new high-speed USB device number 2 using usb20_host
[ 4.083306] Indeed it is in host mode hprt0 = 00001101
[ 4.083745] rk3288-lcdc lcdc0: blank mode:0
[ 4.103023] rk_iommu ff940300.vopl_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eab9000
[ 4.280021] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101
[ 4.280034] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 4.280041] usb 3-1: Product: USB 2.0 Hub [MTT]
[ 4.280479] hub 3-1:1.0: USB hub found
[ 4.280546] hub 3-1:1.0: 4 ports detected
[ 4.555439] usb 3-1.1: new low-speed USB device number 3 using usb20_host
[ 4.657840] usb 3-1.1: New USB device found, idVendor=17ef, idProduct=6019
[ 4.657853] usb 3-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.657861] usb 3-1.1: Product: Lenovo USB Optical Mouse
[ 4.657868] usb 3-1.1: Manufacturer: PixArt
[ 4.661263] input: PixArt Lenovo USB Optical Mouse as /devices/ff540000.usb/usb3/3-1/3-1.1/3-1.1:1.0/input/input3
[ 4.661571] hid-generic 0003:17EF:6019.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt Lenovo USB Optical Mouse] on usb-ff540000.usb-1.1/input0
[ 4.693096] failed to power up DHD generic adapter, 0 retry left
[ 4.708929] wifi_platform_set_power = 0
[ 4.708939] ======== PULL WL_REG_ON(-1) LOW! ========
[ 4.708946] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 4.725843] mmc2: error -110 whilst initialising SDIO card
[ 4.742291] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 300000Hz, actual 297619HZ div = 84)
[ 4.742313] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 600000Hz for init[mmc2]
[ 4.791516] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 200000Hz, actual 200000HZ div = 125)
[ 4.791556] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 400000Hz for init[mmc2]
[ 4.811167] [WLAN_RFKILL]: wifi shut off power.
[ 4.811179] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
[ 4.811186] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 4.811194] wifi_platform_bus_enumerate device present 0
[ 4.811199] ======== Card detection to remove SDIO card! ========
[ 4.811205] mmc2:mmc host rescan start!
[ 4.811219] failed to power up DHD generic adapter, max retry reached**
[ 4.811240] unregister wifi platform drivers
[ 4.811246] wifi_platform_bus_enumerate device present 0
[ 4.811251] ======== Card detection to remove SDIO card! ========
[ 4.811256] mmc2:mmc host rescan start!
[ 4.811262] ======== dhd_wlan_deinit_plat_data ========
[ 4.811269] dhd_module_init: Failed to load the driver, try cnt 0
[ 4.811287] dhd_module_init: Failed to load driver max retry reached**
[ 4.811293] dhd_module_init: Exit err=-19
[ 5.600319] warning: `system_server’ uses 32-bit capabilities (legacy support in use)
[ 6.580542] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 6.580554] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 6.580561] D1:camsys_open(739): camsys_marvin(ddf40a10) is opened!
[ 6.580643] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
[ 6.580655] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
[ 6.580666] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
[ 6.580683] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 6.580703] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
[ 6.585747] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 6.585758] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 6.585862] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 6.585887] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 6.586955] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
[ 6.588016] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
[ 6.589082] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
[ 6.592307] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
[ 6.593518] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 6.593598] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
[ 6.593611] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
[ 6.593622] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
[ 6.594727] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 6.594755] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 6.596817] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
[ 6.596834] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 6.596845] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 6.596853] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 6.596862] D1:camsys_release(763): camsys_marvin(ddf40a10) is closed
[ 6.606819] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 6.606830] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 6.606838] D1:camsys_open(739): camsys_marvin(ddf40a10) is opened!
[ 6.606923] D1:camsys_extdev_register(243): Get RK30_PIN3_PB4(108) gpio(active: 1) for dev_id 0x4000000 success!
[ 6.606935] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x4000000 success!
[ 6.606946] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x4000000 success!
[ 6.606954] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit
[ 6.607045] D1:camsys_extdev_register(268): Extdev(dev_id: 0x4000000 dev_name: OV5640) register success
[ 6.612076] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 6.612085] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 6.612190] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 6.612216] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 6.613277] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
[ 6.614341] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
[ 6.615396] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(108) set 0
[ 6.618611] E:camsys_i2c_write(78): i2c write dev(addr:0x78) failed!
[ 6.618681] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(108) set 1
[ 6.618693] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
[ 6.618704] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
[ 6.619781] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 6.619805] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 6.621867] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x4000000) is deregister success
[ 6.621881] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 6.621891] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 6.621898] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 6.621907] D1:camsys_release(763): camsys_marvin(ddf40a10) is closed
[ 6.627120] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 6.627131] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 6.627138] D1:camsys_open(739): camsys_marvin(ddf40a10) is opened!
[ 6.627215] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default
[ 6.627237] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: TC358749XBG) register success
[ 6.632263] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 6.632272] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 6.632377] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 6.632400] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on
[ 6.633454] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
[ 6.634509] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
[ 6.635560] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
[ 6.639043] E:camsys_i2c_write(78): i2c write dev(addr:0x1f) failed!
[ 6.640494] E:camsys_i2c_write(78): i2c write dev(addr:0xf) failed!
[ 6.640562] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
[ 6.640570] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
[ 6.640577] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
[ 6.641664] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 6.641694] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 6.643753] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
[ 6.643768] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 6.643778] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 6.643785] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 6.643792] D1:camsys_release(763): camsys_marvin(ddf40a10) is closed
:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
ntext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
iaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
xt=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
shell@firefly:/ $ [ 8.395423] healthd: battery none chg=
[ 8.553194] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
[ 8.553218] lowmemorykiller: oom_adj 0 => oom_score_adj 0
[ 8.553225] lowmemorykiller: oom_adj 1 => oom_score_adj 58
[ 8.553230] lowmemorykiller: oom_adj 2 => oom_score_adj 117
[ 8.553236] lowmemorykiller: oom_adj 3 => oom_score_adj 176
[ 8.553241] lowmemorykiller: oom_adj 9 => oom_score_adj 529
[ 8.553246] lowmemorykiller: oom_adj 15 => oom_score_adj 1000
[ 8.918705] acc_open
[ 8.918730] acc_release
[ 9.056533] Current WiFi chip is AP6210.
[ 9.056650] Current WiFi chip is AP6210.
[ 9.062598] Current WiFi chip is AP6210.
[ 9.072125] phy_power_on: enable = 1
[ 9.111525] Read the Ethernet MAC address from IDB:00:00:00:00:00:00
[ 9.111566] eth0: device MAC address f2:9a:56:a3:99:66
[ 9.115598] libphy: stmmac: probed
[ 9.115609] eth0: PHY ID 001cc915 at 0 IRQ 0 (stmmac-0:00) active
[ 9.115617] eth0: PHY ID 001cc915 at 1 IRQ 0 (stmmac-0:01) active
[ 9.347419] [otg id chg] last id -1 current id 1
[ 9.347443] PortPower off
[ 9.347451] rk_battery_charger_detect_cb , battery_charger_detect 6
[ 9.447053] Using Buffer DMA mode
[ 9.447070] Periodic Transfer Interrupt Enhancement - disabled
[ 9.447077] Multiprocessor Interrupt Enhancement - disabled
[ 9.447084] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 9.447090] ^^^^^^^^^^^^^^^^^Device Mode
[ 9.593778] es8323_mic_state_ctrl read: 0
[ 9.593798] mic_state_switch 0
[ 9.593807] hp_det = 0,insert hp
[ 9.593812] hp mic use intern
[ 9.614901] Current WiFi chip is AP6210.
[ 9.937984] rk_battery_charger_detect_cb , battery_charger_detect 0
[ 10.092571] pm policy 0 → 1
[ 11.457945] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 11.457967] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 11.457976] D1:camsys_open(739): camsys_marvin(ddf40a10) is opened!
[ 11.458069] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
[ 11.458082] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
[ 11.458093] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
[ 11.458109] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 11.458131] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
[ 11.463161] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 11.463172] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 11.463277] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 11.463303] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 11.464367] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
[ 11.465424] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
[ 11.466483] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
[ 11.469697] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
[ 11.470882] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 11.470953] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
[ 11.470964] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
[ 11.470975] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
[ 11.472046] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 11.472071] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 11.474119] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
[ 11.474132] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 11.474140] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 11.474153] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 11.474161] D1:camsys_release(763): camsys_marvin(ddf40a10) is closed
[ 11.475278] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 11.475287] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 11.475295] D1:camsys_open(739): camsys_marvin(ddf40a10) is opened!
[ 11.475388] D1:camsys_extdev_register(243): Get RK30_PIN3_PB4(108) gpio(active: 1) for dev_id 0x4000000 success!
[ 11.475401] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x4000000 success!
[ 11.475412] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x4000000 success!
[ 11.475420] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit
[ 11.475515] D1:camsys_extdev_register(268): Extdev(dev_id: 0x4000000 dev_name: OV5640) register success
[ 11.480536] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 11.480551] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 11.480655] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 11.480681] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 11.481740] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
[ 11.482810] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
[ 11.483872] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(108) set 0
[ 11.487086] E:camsys_i2c_write(78): i2c write dev(addr:0x78) failed!
[ 11.487150] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(108) set 1
[ 11.487162] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
[ 11.487174] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
[ 11.488241] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 11.488262] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 11.490305] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x4000000) is deregister success
[ 11.490318] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 11.490326] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 11.490333] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 11.490341] D1:camsys_release(763): camsys_marvin(ddf40a10) is closed
[ 11.490897] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 11.490906] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 11.490913] D1:camsys_open(739): camsys_marvin(ddf40a10) is opened!
[ 11.490976] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default
[ 11.490997] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: TC358749XBG) register success
[ 11.496020] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 11.496031] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 11.496136] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 11.496156] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on
[ 11.497217] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
[ 11.498271] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
[ 11.499321] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
[ 11.502780] E:camsys_i2c_write(78): i2c write dev(addr:0x1f) failed!
[ 11.504242] E:camsys_i2c_write(78): i2c write dev(addr:0xf) failed!
[ 11.504301] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
[ 11.504310] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
[ 11.504318] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
[ 11.505385] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 11.505411] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 11.507452] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
[ 11.507463] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 11.507472] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 11.507479] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 11.507490] D1:camsys_release(763): camsys_marvin(ddf40a10) is closed
[ 11.512585] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 11.512596] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 11.512604] D1:camsys_open(739): camsys_marvin(ddf40a10) is opened!
[ 11.512683] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
[ 11.512695] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
[ 11.512707] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
[ 11.512723] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 11.512742] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
[ 11.517763] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 11.517772] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 11.517877] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 11.517900] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 11.518960] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
[ 11.520015] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
[ 11.521069] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
[ 11.524285] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
[ 11.525470] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 11.525530] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
[ 11.525542] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
[ 11.525552] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
[ 11.526624] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 11.526645] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 11.528691] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
[ 11.528702] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 11.528711] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 11.528718] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 11.528724] D1:camsys_release(763): camsys_marvin(ddf40a10) is closed
[ 11.529784] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 11.529795] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 11.529803] D1:camsys_open(739): camsys_marvin(ddf40a10) is opened!
[ 11.529888] D1:camsys_extdev_register(243): Get RK30_PIN3_PB4(108) gpio(active: 1) for dev_id 0x4000000 success!
[ 11.529901] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x4000000 success!
[ 11.529911] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x4000000 success!
[ 11.529920] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit
[ 11.530013] D1:camsys_extdev_register(268): Extdev(dev_id: 0x4000000 dev_name: OV5640) register success
[ 11.535040] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 11.535055] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 11.535160] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 11.535187] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 11.536250] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
[ 11.537406] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
[ 11.538466] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(108) set 0
[ 11.541680] E:camsys_i2c_write(78): i2c write dev(addr:0x78) failed!
[ 11.541767] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(108) set 1
[ 11.541779] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
[ 11.541790] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
[ 11.542898] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 11.542921] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 11.544975] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x4000000) is deregister success
[ 11.544988] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 11.544998] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 11.545004] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 11.545011] D1:camsys_release(763): camsys_marvin(ddf40a10) is closed
[ 11.545602] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 11.545612] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 11.545620] D1:camsys_open(739): camsys_marvin(ddf40a10) is opened!
[ 11.545688] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default
[ 11.545712] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: TC358749XBG) register success
[ 11.550737] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 11.550746] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 11.550851] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 11.550871] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on
[ 11.551946] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
[ 11.553003] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
[ 11.554055] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
[ 11.557549] E:camsys_i2c_write(78): i2c write dev(addr:0x1f) failed!
[ 11.559014] E:camsys_i2c_write(78): i2c write dev(addr:0xf) failed!
[ 11.559071] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
[ 11.559080] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
[ 11.559087] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
[ 11.560192] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 11.560223] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 11.562275] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
[ 11.562292] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 11.562302] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 11.562309] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 11.562316] D1:camsys_release(763): camsys_marvin(ddf40a10) is closed
[ 12.683173] dwmmc_rockchip ff0d0000.rksdmmc: req failed (CMD52): error = -110, timeout = 8000ms
[ 12.683193] [mmc2] – Timeout recovery procedure start –
52 scontext=u:r:install_recovery:s0 tcontext=u:object_r:system_file:s0 tclass=file permissive=1
[ 13.175164] dwmmc_rockchip ff0d0000.rksdmmc: Timeout resetting block (ctrl reset 0x6)
[ 13.175193] 1358..dw_mci_set_ios: no card. [mmc2]
[ 13.177173] 1358..dw_mci_set_ios: no card. [mmc2]
[ 13.178177] 1358..dw_mci_set_ios: no card. [mmc2]
[ 13.461578] Current WiFi chip is AP6210.
[ 13.756829] Current WiFi chip is AP6210.
[ 13.766888] Current WiFi chip is AP6210.
[ 13.795109] [BT_RFKILL]: bt shut off power
[ 14.405477] [BT_RFKILL]: ENABLE UART_RTS
[ 14.513612] [BT_RFKILL]: DISABLE UART_RTS
[ 14.513875] [BT_RFKILL]: bt turn on power
[ 16.026299] type=1400 audit(15.250:14): avc: denied { write } for pid=1212 comm=“chip.devicetest” name=“force_usb_mode” dev=“sysfs” ino=12837 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[ 16.027247] force_usb_mode_store 0->0
[ 16.737391] [BT_RFKILL]: bt shut off power
[ 20.977835] Current WiFi chip is AP6210.
[ 21.142916] Current WiFi chip is AP6210.
[ 21.143490] Current WiFi chip is AP6210.
[ 21.165258] [BT_RFKILL]: bt shut off power
[ 21.775355] [BT_RFKILL]: ENABLE UART_RTS
[ 21.883778] [BT_RFKILL]: DISABLE UART_RTS
[ 21.883947] [BT_RFKILL]: bt turn on power
[ 24.127385] [BT_RFKILL]: bt shut off power
[ 28.510183] Current WiFi chip is AP6210.
[ 28.671920] Current WiFi chip is AP6210.
[ 28.672548] Current WiFi chip is AP6210.
[ 28.692868] [BT_RFKILL]: bt shut off power
[ 29.303237] [BT_RFKILL]: ENABLE UART_RTS
[ 29.411333] [BT_RFKILL]: DISABLE UART_RTS
[ 29.411545] [BT_RFKILL]: bt turn on power
[ 31.644919] [BT_RFKILL]: bt shut off power
[ 36.028816] Current WiFi chip is AP6210.
[ 36.168029] Current WiFi chip is AP6210.
[ 36.168579] Current WiFi chip is AP6210.
[ 36.190924] [BT_RFKILL]: bt shut off power
[ 36.801291] [BT_RFKILL]: ENABLE UART_RTS
[ 36.909460] [BT_RFKILL]: DISABLE UART_RTS
[ 36.909625] [BT_RFKILL]: bt turn on power
[ 39.153031] [BT_RFKILL]: bt shut off power
[ 43.512926] Current WiFi chip is AP6210.
[ 43.675516] Current WiFi chip is AP6210.
[ 43.676179] Current WiFi chip is AP6210.
[ 43.698899] [BT_RFKILL]: bt shut off power
[ 44.309214] [BT_RFKILL]: ENABLE UART_RTS
[ 44.417406] [BT_RFKILL]: DISABLE UART_RTS
[ 44.417585] [BT_RFKILL]: bt turn on power
[ 46.660840] [BT_RFKILL]: bt shut off power
[ 51.097069] Current WiFi chip is AP6210.
[ 51.256603] Current WiFi chip is AP6210.
[ 51.257231] Current WiFi chip is AP6210.
[ 51.285489] [BT_RFKILL]: bt shut off power
[ 51.895965] [BT_RFKILL]: ENABLE UART_RTS
[ 52.004029] [BT_RFKILL]: DISABLE UART_RTS
[ 52.004262] [BT_RFKILL]: bt turn on power
[ 54.237852] [BT_RFKILL]: bt shut off power
[ 58.765615] Current WiFi chip is AP6210.
[ 58.946890] Current WiFi chip is AP6210.
[ 58.947625] Current WiFi chip is AP6210.
[ 58.970521] [BT_RFKILL]: bt shut off power
[ 59.580860] [BT_RFKILL]: ENABLE UART_RTS
[ 59.689086] [BT_RFKILL]: DISABLE UART_RTS
[ 59.689266] [BT_RFKILL]: bt turn on power
[ 61.932521] [BT_RFKILL]: bt shut off power
[ 68.638352] phy_power_on: enable = 0
[ 68.677089] phy_power_on: enable = 1
[ 68.716616] eth0: device MAC address f2:9a:56:a3:99:66
[ 68.733068] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
r123qq 发表于 2019-8-15 11:12
您是说下载的固件,WIFI可以直接工作起来吗?
我把日志贴出来,麻烦您帮忙看一下。
DDR Version 1.00 2 …
看上去好像wifi模组坏了
