rk3399开机自动进入loader模式
各位大佬,如题,rk3399板开机时boot mode显示是空:boot mode:none,接着板子自动重启进入loader模式,请问这是啥原因呀?
DDR Version 1.22 20190506
channel 0
CS = 0
MR0=0x98
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 416MHz 0,1
Channel 0: LPDDR4,416MHz
Channel 1: LPDDR4,416MHz
256B stride
channel 0
CS = 0
MR0=0x98
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0, cs 0, advanced training done
channel 1, cs 0, advanced training done
change freq to 856MHz 1,0
pmugrf_os_reg[2] = 0x3281F281, stride = 0x9
Boot1: 2019-03-14, version: 1.19
CPUId = 0x0
ChipType = 0x10, 255
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=7456MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 67874
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
atags_set_bootdev: ret:(0)
GPT part: 2, name: misc, start:0x8000, size:0x2000
GPT part: 3, name: resource, start:0xa000, size:0x8000
GPT part: 4, name: kernel, start:0x12000, size:0x10000
GPT part: 5, name: dtb, start:0x22000, size:0x2000
GPT part: 6, name: dtbo, start:0x24000, size:0x2000
GPT part: 7, name: vbmeta, start:0x26000, size:0x800
GPT part: 8, name: boot, start:0x26800, size:0x10000
GPT part: 9, name: recovery, start:0x36800, size:0x20000
GPT part: 10, name: backup, start:0x56800, size:0x38000
GPT part: 11, name: security, start:0x8e800, size:0x2000
GPT part: 12, name: cache, start:0x90800, size:0x100000
GPT part: 13, name: system, start:0x190800, size:0x500000
GPT part: 14, name: metadata, start:0x690800, size:0x8000
GPT part: 15, name: vendor, start:0x698800, size:0x100000
GPT part: 16, name: oem, start:0x798800, size:0x100000
GPT part: 17, name: frp, start:0x898800, size:0x400
GPT part: 18, name: userdata, start:0x898c00, size:0x5f73df
find part:uboot OK. first_lba:0x4000.
find part:trust OK. first_lba:0x6000.
LoadTrust Addr:0x6000
No find bl30.bin
Load uboot, ReadLba = 4000
Load OK, addr=0x200000, size=0xe3774
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):51f2096
NOTICE: BL31: Built : 16:24:31, May 6 2019
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1181): pd status 3e
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-221-gda2bcfdc #139 Mon Jun 17 03:14:33 UTC 2019 aarch64)
INFO: SPSR = 0x3c9
U-Boot 2017.09-g06c1e1b-dirty (Sep 03 2019 - 12:25:52 +0800)
Model: Rockchip RK3399 Evaluation Board
PreSerial: 2
DRAM: 2 GiB
Sysmem: init
Relocation Offset is: 7dbe2000
Bootdev(atags): mmc 0
MMC0: HS400, 150Mhz
PartType: EFI
boot mode: None
Load FDT from boot part
DTB: rk-kernel.dtb
ANDROID: fdt overlay OK
I2c speed: 100000Hz
PMIC: RK808
vdd_log 900000 uV
vdd_cpu_l 900000 uV
vdd_center 900000 uV
Warn: can’t find connect driver
Failed to found available display route
Model: Rockchip RK3399 Excavator Board edp avb (Android)
rkgpios_parse_gpios_dt,boot_gpio invalid
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 24000 KHz, init 24000 KHz, kernel 0N/A)
aplll 816000 KHz
apllb 24000 KHz
dpll 856000 KHz
cpll 24000 KHz
gpll 800000 KHz
npll 600000 KHz
vpll 24000 KHz
aclk_perihp 133333 KHz
hclk_perihp 66666 KHz
pclk_perihp 33333 KHz
aclk_perilp0 266666 KHz
hclk_perilp0 88888 KHz
pclk_perilp0 44444 KHz
hclk_perilp1 100000 KHz
pclk_perilp1 50000 KHz
Net: No ethernet found.
Vboot=0, AVB images, AVB verify
read_is_device_unlocked() ops returned that device is UNLOCKED
avb_slot_verify.c:638: ERROR: vbmeta: Error verifying vbmeta image: OK_NOT_SIGNED
Fdt Ramdisk skip relocation
Booting IMAGE kernel at 0x00280000 with fdt at 0x8300000…
## Booting Android Image at 0x0027f800 …
Kernel load addr 0x00280000 size 19081 KiB
## Flattened Device Tree blob at 08300000
Booting using the fdt blob at 0x8300000
XIP Kernel Image … OK
Using Device Tree in place at 0000000008300000, end 000000000831c8f5
Total: 717.37 ms
[ 0.000000] Linux version 4.4.167 (root@lodge-ThinkPad-E560) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #2 SMP PREEM9
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07eee9000 s45528 r8192 d32296 u86016
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal androidboot.dtbo_idx=0m
[ 0.000000] software IO TLB [mem 0x7eea1000-0x7eee1000] (0MB) mapped at [ffffffc07eea1000-ffffffc07eee0fff]
[ 0.000000] Memory: 1989092K/2064384K available (11134K kernel code, 1736K rwdata, 5384K rodata, 768K init, 2411K bss, 58908K re)
[ 0.000000] .init : 0xffffff80090b0000 - 0xffffff8009170000 ( 768 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008b60000 ( 11136 KB)
[ 0.000000] .rodata : 0xffffff8008b60000 - 0xffffff80090b0000 ( 5440 KB)
[ 0.000000] .data : 0xffffff8009170000 - 0xffffff8009322008 ( 1737 KB)
[ 0.002047] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.003026] pid_max: default: 32768 minimum: 301
[ 0.003550] Security Framework initialized
[ 0.003946] SELinux: Initializing.
[ 0.004362] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.005001] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.006387] Initializing cgroup subsys memory
[ 0.006826] Initializing cgroup subsys freezer
[ 0.008180] sched-energy: Sched-energy-costs installed from DT
[ 0.008737] CPU0: update cpu_capacity 401
[ 0.009200] ASID allocator initialised with 32768 entries
[ 0.026035] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.027391] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.039424] Detected VIPT I-cache on CPU1
[ 0.039458] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.039487] CPU1: using LPI pending table @0x000000000a3f0000
[ 0.039529] CPU1: update cpu_capacity 401
[ 0.039532] CPU1: Booted secondary processor [410fd034]
[ 0.049415] Detected VIPT I-cache on CPU2
[ 0.049435] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.049462] CPU2: using LPI pending table @0x000000007c020000
[ 0.049487] CPU2: update cpu_capacity 401
[ 0.049491] CPU2: Booted secondary processor [410fd034]
[ 0.059443] Detected VIPT I-cache on CPU3
[ 0.059462] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.059489] CPU3: using LPI pending table @0x000000007c060000
[ 0.059514] CPU3: update cpu_capacity 401
[ 0.059517] CPU3: Booted secondary processor [410fd034]
[ 0.069491] Detected PIPT I-cache on CPU4
[ 0.069519] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.069557] CPU4: using LPI pending table @0x000000007c0b0000
[ 0.069595] CPU4: update cpu_capacity 1024
[ 0.069598] CPU4: Booted secondary processor [410fd082]
[ 0.079515] Detected PIPT I-cache on CPU5
[ 0.079533] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.079568] CPU5: using LPI pending table @0x000000007c0d0000
[ 0.079594] CPU5: update cpu_capacity 1024
[ 0.079597] CPU5: Booted secondary processor [410fd082]
[ 0.079680] Brought up 6 CPUs
[ 0.091984] SMP: Total of 6 processors activated.
[ 0.092434] CPU features: detected feature: GIC system register CPU interface
[ 0.093113] CPU features: detected feature: 32-bit EL0 Support
[ 0.093678] CPU: All CPU(s) started at EL2
[ 0.094106] alternatives: patching kernel code
[ 0.096496] devtmpfs: initialized
[ 0.118824] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.119755] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.120999] pinctrl core: initialized pinctrl subsystem
[ 0.123161] Failed to find legacy iommu devices
[ 0.123977] NET: Registered protocol family 16
[ 0.124990] schedtune: init normalization constants…
[ 0.125476] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[ 0.126082] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 0.126701] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[ 0.127302] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 0.127906] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 0.128514] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[ 0.129123] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[ 0.129725] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[ 0.130336] schedtune: SYSTEM min_pwr: 121 max_pwr: 4434
[ 0.130941] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[ 0.131649] schedtune: verify normalization constants…
[ 0.132142] schedtune: max_pwr/2^0: 4313 => norm_pwr: 1024
[ 0.132659] schedtune: max_pwr/2^1: 2156 => norm_pwr: 511
[ 0.133180] schedtune: max_pwr/2^2: 1078 => norm_pwr: 255
[ 0.133697] schedtune: max_pwr/2^3: 539 => norm_pwr: 127
[ 0.134214] schedtune: max_pwr/2^4: 269 => norm_pwr: 63
[ 0.134727] schedtune: max_pwr/2^5: 134 => norm_pwr: 31
[ 0.135237] schedtune: configured to support 5 boost groups
[ 0.143732] cpuidle: using governor ladder
[ 0.153734] cpuidle: using governor menu
[ 0.154114] Registered FIQ tty driver
[ 0.155002] vdso: 2 pages (1 code @ ffffff8008b66000, 1 data @ ffffff8009174000)
[ 0.155710] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.157384] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.179862] console [pstore-1] enabled
[ 0.180447] pstore: Registered ramoops as persistent store backend
[ 0.181038] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.182676] fiq debugger fiq mode enabled
[ [ 0.183307] console [ttyFIQ0] enabled
[ 0.183974] bootconsole [uart0] disabled
[ 0.184514] Registered fiq debugger ttyFIQ0
[ 0.217862] vcc_lcd: supplied by vcc5v0_sys
[ 0.243603] iommu: Adding device ff650000.vpu_service to group 0
[ 0.243708] iommu: Adding device ff660000.rkvdec to group 1
[ 0.243801] iommu: Adding device ff670000.iep to group 2
[ 0.243907] iommu: Adding device ff8f0000.vop to group 3
[ 0.243992] iommu: Adding device ff900000.vop to group 4
[ 0.244102] iommu: Adding device ff910000.rkisp1 to group 5
[ 0.244189] iommu: Adding device ff920000.rkisp1 to group 6
[ 0.244658] rk_iommu ff650800.iommu: can’t get sclk
[ 0.244926] rk_iommu ff660480.iommu: can’t get sclk
[ 0.245015] rk_iommu ff670800.iommu: can’t get aclk
[ 0.245027] rk_iommu ff670800.iommu: can’t get hclk
[ 0.245037] rk_iommu ff670800.iommu: can’t get sclk
[ 0.245205] rk_iommu ff8f3f00.iommu: can’t get sclk
[ 0.245361] rk_iommu ff903f00.iommu: can’t get sclk
[ 0.245515] rk_iommu ff914000.iommu: can’t get sclk
[ 0.245666] rk_iommu ff924000.iommu: can’t get sclk
[ 0.245981] SCSI subsystem initialized
[ 0.246151] usbcore: registered new interface driver usbfs
[ 0.246195] usbcore: registered new interface driver hub
[ 0.246269] usbcore: registered new device driver usb
[ 0.246682] media: Linux media interface: v0.10
[ 0.246720] Linux video capture interface: v2.00
[ 0.246901] pps_core: LinuxPPS API ver. 1 registered
[ 0.246910] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.246929] PTP clock support registered
[ 0.248651] Advanced Linux Sound Architecture Driver Initialized.
[ 0.249157] Bluetooth: Core ver 2.21
[ 0.249189] NET: Registered protocol family 31
[ 0.249197] Bluetooth: HCI device and connection manager initialized
[ 0.249213] Bluetooth: HCI socket layer initialized
[ 0.249225] Bluetooth: L2CAP socket layer initialized
[ 0.249251] Bluetooth: SCO socket layer initialized
[ 0.249957] rockchip-cpuinfo cpuinfo: Serial : 423b24192f3e9fbc
[ 0.250804] clocksource: Switched to clocksource arch_sys_counter
[ 0.295008] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.295278] NET: Registered protocol family 2
[ 0.295729] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.295871] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 0.296144] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.296228] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.296296] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.296470] NET: Registered protocol family 1
[ 0.298133] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.298229] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.300986] audit: initializing netlink subsys (disabled)
[ 0.301046] audit: type=2000 audit(0.300:1): initialized
[ 0.309668] VFS: Disk quotas dquot_6.6.0
[ 0.309801] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.310646] Registering sdcardfs 0.1
[ 0.314531] fuse init (API version 7.23)
[ 0.315701]
[ 0.315701] TEE Core Framework initialization (ver 1:0.1)
[ 0.315728] TEE armv7 Driver initialization
[ 0.316115] tz_tee_probe: name=“armv7sec”, id=0, pdev_name=“armv7sec.0”
[ 0.316131] TEE core: Alloc the misc device “opteearmtz00” (id=0)
[ 0.316308] TEE Core: Register the misc device “opteearmtz00” (id=0,minor=62)
[ 0.320495] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.320522] io scheduler noop registered
[ 0.320692] io scheduler cfq registered (default)
[ 0.322264] phy phy-ff770000.syscon:usb2-phy@e460.1: Failed to get VBUS supply regulator
[ 0.323866] rockchip-mipi-dphy-rx ff770000.syscon:mipi-dphy-rx0: invalid resource
[ 0.327763] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.327786] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.327801] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 0.327812] rockchip-pcie f8000000.pcie: missing “memory-region” property
[ 0.327827] PCI host bridge /pcie@f8000000 ranges:
[ 0.327861] MEM 0xfa000000..0xfbdfffff → 0xfa000000
[ 0.327873] IO 0xfbe00000..0xfbefffff → 0xfbe00000
[ 1.330821] pll lock timeout!
[ 1.330875] phy phy-pcie-phy.5: phy poweron failed → -22
[ 1.330892] rockchip-pcie f8000000.pcie: fail to power on phy, err -22
[ 1.330906] rockchip-pcie f8000000.pcie: deferred probe failed
[ 1.331048] rockchip-pcie: probe of f8000000.pcie failed with error -22
[ 1.331820] backlight supply power not found, using dummy regulator
[ 1.332411] iep: failed to find iep power down clock source.
[ 1.332995] IEP Power ON
[ 1.333223] IEP Power OFF
[ 1.333348] IEP Driver loaded succesfully
[ 1.333611] Module initialized.
[ 1.333981] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 1.337634] rk-vcodec ff650000.vpu_service: probe device
[ 1.337871] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[ 1.338489] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 1.338509] rk-vcodec ff650000.vpu_service: init success
[ 1.338739] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 1.342588] rk-vcodec ff660000.rkvdec: probe device
[ 1.342799] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[ 1.343241] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 1.343261] rk-vcodec ff660000.rkvdec: init success
[ 1.345346] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.345375] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 1.347129] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.347154] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.349858] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 1.350641] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
[ 1.351305] [drm] Initialized drm 1.1.0 20060810
[ 1.356758] [drm] Rockchip DRM driver version: v1.0.1
[ 1.360995] Unable to detect cache hierarchy for CPU 0
[ 1.370969] brd: module loaded
[ 1.376862] loop: module loaded
[ 1.377458] zram: Added device: zram0
[ 1.378756] SCSI Media Changer driver v0.25
[ 1.379737] tun: Universal TUN/TAP device driver, 1.6
[ 1.379756] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.380712] PPP generic driver version 2.4.2
[ 1.380928] PPP BSD Compression module registered
[ 1.380954] PPP Deflate Compression module registered
[ 1.381000] PPP MPPE Compression module registered
[ 1.381035] NET: Registered protocol family 24
[ 1.381102] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.381111] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.381134] Rockchip WiFi SYS interface (V1.00) …
[ 1.381248] usbcore: registered new interface driver catc
[ 1.381315] usbcore: registered new interface driver kaweth
[ 1.381335] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.381382] usbcore: registered new interface driver pegasus
[ 1.381438] usbcore: registered new interface driver rtl8150
[ 1.381505] usbcore: registered new interface driver r8152
[ 1.381523] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.381592] usbcore: registered new interface driver hso
[ 1.381659] usbcore: registered new interface driver asix
[ 1.381729] usbcore: registered new interface driver ax88179_178a
[ 1.381783] usbcore: registered new interface driver cdc_ether
[ 1.381837] usbcore: registered new interface driver cdc_eem
[ 1.381892] usbcore: registered new interface driver dm9601
[ 1.381967] usbcore: registered new interface driver smsc75xx
[ 1.382034] usbcore: registered new interface driver smsc95xx
[ 1.382090] usbcore: registered new interface driver gl620a
[ 1.382145] usbcore: registered new interface driver net1080
[ 1.382208] usbcore: registered new interface driver plusb
[ 1.382267] usbcore: registered new interface driver rndis_host
[ 1.382324] usbcore: registered new interface driver cdc_subset
[ 1.382390] usbcore: registered new interface driver zaurus
[ 1.382450] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.382524] usbcore: registered new interface driver int51x1
[ 1.382576] usbcore: registered new interface driver kalmia
[ 1.382638] usbcore: registered new interface driver ipheth
[ 1.382699] usbcore: registered new interface driver sierra_net
[ 1.382752] usbcore: registered new interface driver cx82310_eth
[ 1.382814] usbcore: registered new interface driver cdc_ncm
[ 1.382872] usbcore: registered new interface driver qmi_wwan
[ 1.382929] usbcore: registered new interface driver cdc_mbim
[ 1.384577] rockchip-dwc3 usb0: failed to get drvdata dwc3
[ 1.389670] rockchip-dwc3 usb1: fail to get drvdata hcd
[ 1.390897] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.390912] ehci-pci: EHCI PCI platform driver
[ 1.390976] ehci-platform: EHCI generic platform driver
[ 1.394797] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.394968] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 1.395151] ehci-platform fe3c0000.usb: irq 29, io mem 0xfe3c0000
[ 1.404171] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.404302] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.404318] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.404330] usb usb1: Product: EHCI Host Controller
[ 1.404340] usb usb1: Manufacturer: Linux 4.4.167 ehci_hcd
[ 1.404349] usb usb1: SerialNumber: fe3c0000.usb
[ 1.404834] hub 1-0:1.0: USB hub found
[ 1.404872] hub 1-0:1.0: 1 port detected
[ 1.405383] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.405419] ohci-platform: OHCI generic platform driver
[ 1.405860] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.406027] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[ 1.406156] ohci-platform fe3e0000.usb: irq 30, io mem 0xfe3e0000
[ 1.461623] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.461662] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.461673] usb usb2: Product: Generic Platform OHCI controller
[ 1.461683] usb usb2: Manufacturer: Linux 4.4.167 ohci_hcd
[ 1.461693] usb usb2: SerialNumber: fe3e0000.usb
[ 1.462183] hub 2-0:1.0: USB hub found
[ 1.462236] hub 2-0:1.0: 1 port detected
[ 1.463104] usbcore: registered new interface driver cdc_acm
[ 1.463137] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.463200] usbcore: registered new interface driver usblp
[ 1.463266] usbcore: registered new interface driver cdc_wdm
[ 1.463310] usbcore: registered new interface driver uas
[ 1.463378] usbcore: registered new interface driver usb-storage
[ 1.463420] usbcore: registered new interface driver ums-alauda
[ 1.463478] usbcore: registered new interface driver ums-cypress
[ 1.463517] usbcore: registered new interface driver ums-datafab
[ 1.463555] usbcore: registered new interface driver ums_eneub6250
[ 1.463592] usbcore: registered new interface driver ums-freecom
[ 1.463630] usbcore: registered new interface driver ums-isd200
[ 1.463686] usbcore: registered new interface driver ums-jumpshot
[ 1.463724] usbcore: registered new interface driver ums-karma
[ 1.463766] usbcore: registered new interface driver ums-onetouch
[ 1.463804] usbcore: registered new interface driver ums-sddr09
[ 1.463842] usbcore: registered new interface driver ums-sddr55
[ 1.463880] usbcore: registered new interface driver ums-usbat
[ 1.463974] usbcore: registered new interface driver usbserial
[ 1.464010] usbcore: registered new interface driver usbserial_generic
[ 1.464037] usbserial: USB Serial support registered for generic
[ 1.464082] usbcore: registered new interface driver option
[ 1.464145] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.464243] usbcore: registered new interface driver trancevibrator
[ 1.464256] usb20_otg: version 3.10a 21-DEC-2012
[ 1.464457] usb20_host: version 3.10a 21-DEC-2012
[ 1.465130] usbcore: registered new interface driver xpad
[ 1.465198] usbcore: registered new interface driver usb_acecad
[ 1.465242] usbcore: registered new interface driver aiptek
[ 1.465286] usbcore: registered new interface driver gtco
[ 1.465349] usbcore: registered new interface driver hanwang
[ 1.465394] usbcore: registered new interface driver kbtab
[ 1.465847] sensor_register_slave:kxtj9,id=11
[ 1.465881] sensor_register_slave:mma8452,id=17
[ 1.465894] sensor_register_slave:lis3dh,id=7
[ 1.465907] sensor_register_slave:mma7660,id=18
[ 1.465919] sensor_register_slave:lsm303d,id=22
[ 1.465932] sensor_register_slave:gs_mc3230,id=23
[ 1.465939] [Gsensor] gsensor_init
[ 1.465951] sensor_register_slave:mpu6880_acc,id=24
[ 1.465964] sensor_register_slave:mpu6500_acc,id=25
[ 1.465976] sensor_register_slave:lsm330_acc,id=26
[ 1.466010] sensor_register_slave:bma2xx_acc,id=27
[ 1.466022] sensor_register_slave:akm8975,id=30
[ 1.466035] sensor_register_slave:akm8963,id=31
[ 1.466047] sensor_register_slave:l3g4200d,id=45
[ 1.466059] sensor_register_slave:l3g20d,id=46
[ 1.466072] sensor_register_slave:ewtsa,id=47
[ 1.466084] sensor_register_slave:lsm330_gyro,id=51
[ 1.466096] sensor_register_slave:cm3217,id=53
[ 1.466108] sensor_register_slave:cm3218,id=54
[ 1.466120] sensor_register_slave:ls_stk3410,id=62
[ 1.466133] sensor_register_slave:ps_stk3410,id=67
[ 1.467201] i2c /dev entries driver
[ 1.469137] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 1.469309] fan53555-reg: supplied by vcc5v0_sys
[ 1.474672] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 1.474789] fan53555-reg: supplied by vcc5v0_sys
[ 1.480177] rk808 0-001b: Pmic Chip id: 0x0
[ 1.490421] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.490617] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.490884] DCDC_REG1: supplied by vcc3v3_sys
[ 1.492713] DCDC_REG2: supplied by vcc3v3_sys
[ 1.493928] DCDC_REG3: supplied by vcc3v3_sys
[ 1.494294] DCDC_REG4: supplied by vcc3v3_sys
[ 1.495212] LDO_REG1: supplied by vcc3v3_sys
[ 1.497046] LDO_REG2: supplied by vcc3v3_sys
[ 1.498402] LDO_REG3: supplied by vcc3v3_sys
[ 1.499746] LDO_REG4: supplied by vcc3v3_sys
[ 1.501107] LDO_REG5: supplied by vcc3v3_sys
[ 1.502459] LDO_REG6: supplied by vcc3v3_sys
[ 1.503820] LDO_REG7: supplied by vcc3v3_sys
[ 1.505161] LDO_REG8: supplied by vcc3v3_sys
[ 1.506508] SWITCH_REG1: supplied by vcc3v3_sys
[ 1.506793] SWITCH_REG2: supplied by vcc3v3_sys
[ 1.516798] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 1.518002] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80098f2000
[ 1.519258] input: gsl3673 as /devices/platform/ff110000.i2c/i2c-1/1-0040/input/input0
[ 1.577662] gsl3673 1-0040: GSL3673 test_i2c error!
[ 1.577698] gsl3673 1-0040: gsl_probe: init_chip failed
[ 1.590978] gsl3673: probe of 1-0040 failed with error -1
[ 1.591288] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80098f4000
[ 1.592094] goodix_ts_probe() start
[ 1.710820] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 1.721177] <<-GTP-ERROR->> I2C Read: 0x8000, 10 bytes failed, errcode: -6! Process reset.
[ 1.804515] <<-GTP-ERROR->> I2C Read: 0x8000, 10 bytes failed, errcode: -6! Process reset.
[ 1.835702] usb 1-1: New USB device found, idVendor=0bda, idProduct=8152
[ 1.835730] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.835741] usb 1-1: Product: USB 10/100 LAN
[ 1.835752] usb 1-1: Manufacturer: Realtek
[ 1.835761] usb 1-1: SerialNumber: 000000000000
[ 1.887848] <<-GTP-ERROR->> I2C Read: 0x8000, 10 bytes failed, errcode: -6! Process reset.
[ 1.947503] usb 1-1: reset high-speed USB device number 2 using ehci-platform
[ 1.971177] <<-GTP-ERROR->> I2C Read: 0x8000, 10 bytes failed, errcode: -6! Process reset.
[ 2.054543] <<-GTP-ERROR->> I2C Read: 0x8000, 10 bytes failed, errcode: -6! Process reset.
[ 2.098327] r8152 1-1:1.0 (unnamed net_device) (uninitialized): Invalid ether addr 00:00:00:00:00:00
[ 2.098952] r8152 1-1:1.0 (unnamed net_device) (uninitialized): Random ether addr fe:23:52:52:9d:94
[ 2.099952] r8152 1-1:1.0 eth0: v1.08.3
[ 2.137841] <<-GTP-ERROR->> I2C Read: 0x8000, 10 bytes failed, errcode: -6! Process reset.
[ 2.220839] <<-GTP-ERROR->> I2C read 0x8000, 10 bytes, double check failed!
[ 2.220869] <<-GTP-ERROR->> Failed to get chip-type, set chip type default: GOODIX_GT9
[ 2.221242] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -6! Process reset.
[ 2.304177] <<-GTP-ERROR->> GTP i2c test failed time 1.
[ 2.317832] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -6! Process reset.
[ 2.400838] <<-GTP-ERROR->> GTP i2c test failed time 2.
[ 2.414498] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -6! Process reset.
[ 2.497504] <<-GTP-ERROR->> GTP i2c test failed time 3.
[ 2.511164] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -6! Process reset.
[ 2.594171] <<-GTP-ERROR->> GTP i2c test failed time 4.
[ 2.607829] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -6! Process reset.
[ 2.690838] <<-GTP-ERROR->> GTP i2c test failed time 5.
[ 2.704167] <goodix_ts_probe>_2749 I2C communication ERROR!
[ 2.704197] <goodix_ts_probe>_2817 prob error !!!
[ 2.704311] rk3x-i2c ff120000.i2c: Initialized RK3xxx I2C bus at ffffff80098f6000
[ 2.705953] fusb302 4-0022: Can’t get property of role, set role to default DRP
[ 2.709292] fusb302 4-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 2.709480] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80098f8000
[ 2.710915] IR NEC protocol handler initialized
[ 2.710954] IR RC5(x/sz) protocol handler initialized
[ 2.710970] IR RC6 protocol handler initialized
[ 2.710985] IR JVC protocol handler initialized
[ 2.711000] IR Sony protocol handler initialized
[ 2.711013] IR SANYO protocol handler initialized
[ 2.711025] IR Sharp protocol handler initialized
[ 2.711039] IR MCE Keyboard/mouse protocol handler initialized
[ 2.711052] IR XMP protocol handler initialized
[ 2.711878] rkisp1 ff910000.rkisp1: rkisp1 driver version: v00.01.03
[ 2.711935] rkisp1 ff910000.rkisp1: Missing rockchip,grf property
[ 2.713654] rkisp1 ff920000.rkisp1: rkisp1 driver version: v00.01.03
[ 2.713711] rkisp1 ff920000.rkisp1: Missing rockchip,grf property
[ 2.715386] usbcore: registered new interface driver uvcvideo
[ 2.715418] USB Video Class driver (1.1.1)
[ 2.715438] CamSys driver version: v0.48.0, CamSys head file version: v1.0.0
[ 2.716202] __power_supply_register: Expected proper parent device for ‘test_ac’
[ 2.716380] __power_supply_register: Expected proper parent device for ‘test_battery’
[ 2.716712] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 2.716837] _power_supply_register: Expected proper parent device for ‘test_usb’
[ 2.718991] Boot mode: coldboot
[ 2.720260] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 2.720513] rockchip-thermal ff260000.tsadc: tsadc is probed successfully!
[ 2.721342] device-mapper: uevent: version 1.0.3
[ 2.721757] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.722003] device-mapper: verity-avb: AVB error handler initialized with vbmeta device:
[ 2.722048] Bluetooth: HCI UART driver ver 2.3
[ 2.722061] Bluetooth: HCI UART protocol H4 registered
[ 2.722072] Bluetooth: HCI UART protocol LL registered
[ 2.722087] rtk_btusb: RTKBT_RELEASE_NAME: 20180702_BT_ANDROID_8.1
[ 2.722116] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.5
[ 2.722125] rtk_btusb: Register usb char device interface for BT driver
[ 2.722402] usbcore: registered new interface driver rtk_btusb
[ 2.723056] cpu cpu0: bin=1
[ 2.723146] cpu cpu0: leakage=30
[ 2.736936] cpu cpu0: temp=51666, pvtm=151843 (151183 + 660)
[ 2.741161] cpu cpu0: pvtm-volt-sel=2
[ 2.741276] cpu cpu0: bin-scale=34
[ 2.741651] cpu cpu4: bin=1
[ 2.741735] cpu cpu4: leakage=56
[ 2.756916] cpu cpu4: temp=51666, pvtm=158642 (158292 + 350)
[ 2.757011] cpu cpu4: pvtm-volt-sel=2
[ 2.757095] cpu cpu4: bin-scale=17
[ 2.759727] cpu cpu0: avs=0, target-scale=34
[ 2.759860] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 2.761008] cpu cpu0: failed to find power_model node
[ 2.762294] cpu cpu4: avs=0, target-scale=17
[ 2.762423] cpu cpu4: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 2.771479] cpu cpu4: failed to find power_model node
[ 2.772530] sdhci: Secure Digital Host Controller Interface driver
[ 2.772562] sdhci: Copyright(c) Pierre Ossman
[ 2.772580] Synopsys Designware Multimedia Card Interface Driver
[ 2.773831] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.773983] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 2.774025] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 2.774102] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 24,32 bit host data width,256 deep fifo
[ 2.774211] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.774289] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 2.774301] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 2.775456] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.775563] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 2.775584] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 2.775663] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.775688] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.776770] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 2.777139] vcc_sd: unsupportable voltage range: 3300000-3000000uV
[ 2.780017] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 2.783236] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 2.794278] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.808674] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 2.809173] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.811261] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 2.811300] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 2.837606] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 2.838650] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.842826] usbcore: registered new interface driver usbhid
[ 2.842846] usbhid: USB HID core driver
[ 2.843276] inv-mpu-iio 4-0068: int_config=0,level_shifter=0,client.addr=68,client.irq=7a
[ 2.843296] inv-mpu-iio 4-0068: 0
[ 2.843307] inv-mpu-iio 4-0068: -1
[ 2.843318] inv-mpu-iio 4-0068: 0
[ 2.843329] inv-mpu-iio 4-0068: 1
[ 2.843339] inv-mpu-iio 4-0068: 0
[ 2.843351] inv-mpu-iio 4-0068: 0
[ 2.843362] inv-mpu-iio 4-0068: 0
[ 2.843381] inv-mpu-iio 4-0068: 0
[ 2.843392] inv-mpu-iio 4-0068: 1
[ 2.843402] inv-mpu-iio 4-0068:
[ 2.843410] inv_mpu_iio: secondary_i2c_addr=0
[ 2.843591] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 2.878346] mmc1: MAN_BKOPS_EN bit is not set
[ 2.890672] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[ 2.891753] mmcblk1: mmc1:0001 8GTF4R 7.28 GiB
[ 2.892518] mmcblk1boot0: mmc1:0001 8GTF4R partition 1 4.00 MiB
[ 2.893294] mmcblk1boot1: mmc1:0001 8GTF4R partition 2 4.00 MiB
[ 2.893833] mmcblk1rpmb: mmc1:0001 8GTF4R partition 3 512 KiB
[ 2.896982] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19
[ 2.944459] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 3.047962] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 3.151255] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 3.254576] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 3.357909] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 3.461286] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 3.564645] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 3.667929] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 3.763727] random: nonblocking pool is initialized
[ 3.771253] inv_mpu_iio: inv_mpu: reset chip failed, err = -6
[ 3.977955] i2c i2c-4: inv_mpu_probe failed -6
[ 3.978057] inv-mpu-iio: probe of 4-0068 failed with error -5
[ 3.978221] inv_mpu_iio: inv_mpu_init:746
[ 3.979927] ashmem: initialized
[ 3.981254] rk808-clkout: probe of rk808-clkout failed with error -17
[ 3.984029] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[ 3.990173] ff100000.saradc supply vref not found, using dummy regulator
[ 3.993360] rknandbase v1.2 2018-05-08
[ 3.994640] usbcore: registered new interface driver snd-usb-audio
[ 3.998722] rt5651 1-001a: Device with ID register 0xffffffc0 is not rt5651
[ 4.011065] tc358749x 1-000f: tc358749x_i2c_probe success
[ 4.018264] rk3399-rt5651-tc358749x hdmiin-sound: rockchip_sound_probe
[ 4.018408] rk3399-rt5651-tc358749x hdmiin-sound: ASoC: CODEC DAI rt5651-aif1 not registered
[ 4.018457] rk3399-rt5651-tc358749x hdmiin-sound: rockchip_sound_probe register card failed -517
[ 4.018474] rk3399-rt5651-tc358749x hdmiin-sound: snd_soc_register_card successful
[ 4.019030] u32 classifier
[ 4.019076] Actions configured
[ 4.019174] Netfilter messages via NETLINK v0.30.
[ 4.019309] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 4.019991] ctnetlink v0.93: registering with nfnetlink.
[ 4.021213] xt_time: kernel timezone is -0000
[ 4.021426] IPv4 over IPsec tunneling driver
[ 4.023086] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 4.023537] arp_tables: (C) 2002 David S. Miller
[ 4.024191] Initializing XFRM netlink socket
[ 4.024956] NET: Registered protocol family 10
[ 4.026728] mip6: Mobile IPv6
[ 4.026815] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 4.029314] sit: IPv6 over IPv4 tunneling driver
[ 4.030736] NET: Registered protocol family 17
[ 4.030875] NET: Registered protocol family 15
[ 4.030950] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if yo.
[ 4.032209] Bridge firewalling registered
[ 4.032235] Ebtables v2.0 registered
[ 4.032631] Bluetooth: RFCOMM TTY layer initialized
[ 4.032670] Bluetooth: RFCOMM socket layer initialized
[ 4.032721] Bluetooth: RFCOMM ver 1.11
[ 4.032772] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 4.032785] Bluetooth: BNEP filters: protocol multicast
[ 4.032805] Bluetooth: BNEP socket layer initialized
[ 4.032828] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.032845] Bluetooth: HIDP socket layer initialized
[ 4.032947] l2tp_core: L2TP core driver, V2.0
[ 4.032981] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 4.033005] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 4.033577] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 4.033684] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6354
[ 4.033697] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 4.033710] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 4.033849] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 4.033869] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 4.033882] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 4.033898] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 4.034012] [BT_RFKILL]: Enter rfkill_rk_init
[ 4.034764] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 4.034837] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[ 4.034891] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[ 4.034944] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[ 4.034971] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[ 4.035068] [BT_RFKILL]: Request irq for bt wakeup host
[ 4.035143] [BT_RFKILL]: ** disable irq
[ 4.035349] [BT_RFKILL]: bt_default device registered.
[ 4.035746] sensor_register_slave:mpu6500_gyro,id=49
[ 4.035861] sensor_register_slave:mpu6880_gyro,id=50
[ 4.036912] vendor storage:20160801 ret = 0
[ 4.037271] Error: Driver ‘gc0312’ is already registered, aborting…
[ 4.037717] Error: Driver ‘gc2145’ is already registered, aborting…
[ 4.039846] Registered cp15_barrier emulation handler
[ 4.040171] Registered setend emulation handler
[ 4.041192] registered taskstats version 1
[ 4.044021] Key type encrypted registered
[ 4.045132] rockchip ion idev is NULL
[ 4.045173] rga2 ff680000.rga: rga ion client create success!
[ 4.045557] rga: Driver loaded successfully ver:3.02
[ 4.045889] rga2: Module initialized.
[ 4.048112] phy phy-ff770000.syscon:usb2-phy@e450.7: Failed to get VBUS supply regulator
[ 4.051149] rockchip-drm display-subsystem: defer getting devfreq
[ 4.051805] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 4.052414] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 4.052535] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 4.052964] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 4.053437] rockchip-dp ff970000.edp: no DP phy configured
[ 4.054664] i2c i2c-9: of_i2c: modalias failure on /edp@ff970000/ports
[ 4.055046] rockchip-drm display-subsystem: bound ff970000.edp (ops rockchip_dp_component_ops)
[ 4.055668] i2c i2c-10: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 4.055735] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 4.055889] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 4.058099] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[ 4.058969] i2c i2c-11: of_i2c: modalias failure on /dp@fec00000/ports
[ 4.059605] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[ 4.059641] cdn-dp fec00000.dp: Falling back to user helper
[ 4.059804] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops)
[ 4.059842] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 4.059851] [drm] No driver support for vblank timestamp query.
[ 4.060303] rockchip-drm display-subsystem: failed to parse loader memory
[ 4.085629] rockchip-drm display-subsystem: fb0: frame buffer device
[ 4.204186] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[ 4.304362] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[ 4.404449] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[ 4.504520] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[ 4.604612] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[ 4.604646] phy phy-ff7c0000.phy.9: phy poweron failed → -110
[ 4.604823] dwc3 fe800000.dwc3: failed to initialize core
[ 4.604920] dwc3: probe of fe800000.dwc3 failed with error -110
[ 4.605276] rockchip-dwc3 usb0: failed to get drvdata dwc3
[ 4.611044] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 4.611441] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 3
[ 4.611785] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 4.611857] xhci-hcd xhci-hcd.11.auto: irq 233, io mem 0xfe900000
[ 4.612142] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.612173] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.612185] usb usb3: Product: xHCI Host Controller
[ 4.612195] usb usb3: Manufacturer: Linux 4.4.167 xhci-hcd
[ 4.612205] usb usb3: SerialNumber: xhci-hcd.11.auto
[ 4.612807] hub 3-0:1.0: USB hub found
[ 4.612859] hub 3-0:1.0: 1 port detected
[ 4.613172] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 4.613558] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 4
[ 4.613648] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 4.613749] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 4.613777] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.613788] usb usb4: Product: xHCI Host Controller
[ 4.613798] usb usb4: Manufacturer: Linux 4.4.167 xhci-hcd
[ 4.613808] usb usb4: SerialNumber: xhci-hcd.11.auto
[ 4.614532] hub 4-0:1.0: USB hub found
[ 4.614593] hub 4-0:1.0: 1 port detected
[ 4.619173] ehci-platform fe380000.usb: EHCI Host Controller
[ 4.619563] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5
[ 4.619820] ehci-platform fe380000.usb: irq 27, io mem 0xfe380000
[ 4.627516] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 4.627698] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.627729] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.627747] usb usb5: Product: EHCI Host Controller
[ 4.627757] usb usb5: Manufacturer: Linux 4.4.167 ehci_hcd
[ 4.627767] usb usb5: SerialNumber: fe380000.usb
[ 4.628442] hub 5-0:1.0: USB hub found
[ 4.628491] hub 5-0:1.0: 1 port detected
[ 4.629394] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 4.629791] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6
[ 4.629980] ohci-platform fe3a0000.usb: irq 28, io mem 0xfe3a0000
[ 4.685191] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 4.685279] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.685308] usb usb6: Product: Generic Platform OHCI controller
[ 4.685333] usb usb6: Manufacturer: Linux 4.4.167 ohci_hcd
[ 4.685399] usb usb6: SerialNumber: fe3a0000.usb
[ 4.686678] hub 6-0:1.0: USB hub found
[ 4.686761] hub 6-0:1.0: 1 port detected
[ 4.689776] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 4.690019] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 4.690119] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 4.690214] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 24,32 bit host data width,256 deep fifo
[ 4.690324] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 4.690418] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 4.690443] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 4.693127] rockchip-dmc dmc: Failed to get leakage
[ 4.693386] rockchip-dmc dmc: Failed to get pvtm
[ 4.694127] rockchip-dmc dmc: failed to get vop pn to msch rl
[ 4.694662] rockchip-dmc dmc: could not find power_model node
[ 4.701380] rk-hdmi-dp-sound hdmi-dp-sound: control 3:0:0:ELD:0 is already present
[ 4.701462] hdmi-audio-codec hdmi-audio-codec.10.auto: ASoC: Failed to add ELD: -16
[ 4.702705] rk-hdmi-dp-sound hdmi-dp-sound: multicodec ↔ ff8a0000.i2s mapping ok
[ 4.702889] hdmi-audio-codec hdmi-audio-codec.10.auto: ASoC: Failed to create Playback debugfs file
[ 4.705649] rk3399-rt5651-tc358749x hdmiin-sound: rockchip_sound_probe
[ 4.705810] rk3399-rt5651-tc358749x hdmiin-sound: ASoC: CODEC DAI rt5651-aif1 not registered
[ 4.705836] rk3399-rt5651-tc358749x hdmiin-sound: rockchip_sound_probe register card failed -517
[ 4.705859] rk3399-rt5651-tc358749x hdmiin-sound: snd_soc_register_card successful
[ 4.826471] phy phy-ff770000.syscon:usb2-phy@e450.7: charger = USB_SDP_CHARGER
[ 4.926855] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[ 4.934295] usb 5-1: new high-speed USB device number 2 using ehci-platform
[ 5.026958] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[ 5.059402] usb 5-1: New USB device found, idVendor=05e3, idProduct=0608
[ 5.059482] usb 5-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 5.059506] usb 5-1: Product: USB2.0 Hub
[ 5.060768] hub 5-1:1.0: USB hub found
[ 5.061263] hub 5-1:1.0: 4 ports detected
[ 5.127055] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[ 5.227157] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[ 5.327248] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[ 5.327283] phy phy-ff7c0000.phy.9: phy poweron failed → -110
[ 5.327397] dwc3 fe800000.dwc3: failed to initialize core
[ 5.327522] usb 5-1.1: new high-speed USB device number 3 using ehci-platform
[ 5.327528] dwc3: probe of fe800000.dwc3 failed with error -110
[ 5.327941] rockchip-dwc3 usb0: failed to get drvdata dwc3
[ 5.329722] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 5.329919] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 5.329956] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 5.330002] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 24,32 bit host data width,256 deep fifo
[ 5.330046] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 5.330112] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 5.330131] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 5.331326] rk3399-rt5651-tc358749x hdmiin-sound: rockchip_sound_probe
[ 5.331422] rk3399-rt5651-tc358749x hdmiin-sound: ASoC: CODEC DAI rt5651-aif1 not registered
[ 5.331436] rk3399-rt5651-tc358749x hdmiin-sound: rockchip_sound_probe register card failed -517
[ 5.331447] rk3399-rt5651-tc358749x hdmiin-sound: snd_soc_register_card successful
[ 5.344175] iep dpi mode inactivity
[ 5.412773] usb 5-1.1: New USB device found, idVendor=05e3, idProduct=0608
[ 5.412854] usb 5-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 5.412878] usb 5-1.1: Product: USB2.0 Hub
[ 5.414375] hub 5-1.1:1.0: USB hub found
[ 5.414760] hub 5-1.1:1.0: 4 ports detected
[ 5.434998] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[ 5.535103] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[ 5.635180] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[ 5.680944] usb 5-1.1.2: new full-speed USB device number 4 using ehci-platform
[ 5.735271] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[ 5.765915] usb 5-1.1.2: New USB device found, idVendor=1a86, idProduct=7523
[ 5.765996] usb 5-1.1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 5.766019] usb 5-1.1.2: Product: USB2.0-Serial
[ 5.835365] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[ 5.835402] phy phy-ff7c0000.phy.9: phy poweron failed → -110
[ 5.835519] dwc3 fe800000.dwc3: failed to initialize core
[ 5.835607] dwc3: probe of fe800000.dwc3 failed with error -110
[ 5.835965] rockchip-dwc3 usb0: failed to get drvdata dwc3
[ 5.837539] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 5.837746] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 5.837783] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 5.837827] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 24,32 bit host data width,256 deep fifo
[ 5.837870] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 5.837930] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 5.837941] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 5.839060] rk3399-rt5651-tc358749x hdmiin-sound: rockchip_sound_probe
[ 5.839128] rk3399-rt5651-tc358749x hdmiin-sound: ASoC: CODEC DAI rt5651-aif1 not registered
[ 5.839164] rk3399-rt5651-tc358749x hdmiin-sound: rockchip_sound_probe register card failed -517
[ 5.839181] rk3399-rt5651-tc358749x hdmiin-sound: snd_soc_register_card successful
[ 5.942667] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[ 6.042814] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[ 6.142900] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[ 6.242995] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[ 6.343090] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[ 6.343136] phy phy-ff7c0000.phy.9: phy poweron failed → -110
[ 6.343256] dwc3 fe800000.dwc3: failed to initialize core
[ 6.343343] dwc3: probe of fe800000.dwc3 failed with error -110
[ 6.343716] rockchip-dwc3 usb0: failed to get drvdata dwc3
[ 6.347489] rk808-rtc rk808-rtc: setting system clock to 2013-01-19 05:16:21 UTC (1358572581)
[ 6.349330] It doesn’t contain Rogue gpu
[ 6.374951] vcc_lcd: disabling
[ 6.375505] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn
[ 6.375918] Mali: Mali device driver loaded
[ 6.376624] input: rk29-keypad as /devices/platform/rockchip-key/input/input1
[ 6.378277] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 6.378446] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 6.378471] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 6.378545] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 24,32 bit host data width,256 deep fifo
[ 6.378570] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 6.378624] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 6.378633] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 6.379703] rk3399-rt5651-tc358749x hdmiin-sound: rockchip_sound_probe
[ 6.379775] rk3399-rt5651-tc358749x hdmiin-sound: ASoC: CODEC DAI rt5651-aif1 not registered
[ 6.379785] rk3399-rt5651-tc358749x hdmiin-sound: rockchip_sound_probe register card failed -517
[ 6.379794] rk3399-rt5651-tc358749x hdmiin-sound: snd_soc_register_card successful
[ 6.381746] ALSA device list:
[ 6.381785] #0: rk-hdmi-dp-sound
[ 6.483167] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[ 6.583296] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[ 6.683426] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[ 6.783544] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[ 6.883686] rockchip-typec-phy ff7c0000.phy: wait pma ready timeout
[ 6.883763] phy phy-ff7c0000.phy.9: phy poweron failed → -110
[ 6.884079] dwc3 fe800000.dwc3: failed to initialize core
[ 6.884268] dwc3: probe of fe800000.dwc3 failed with error -110
[ 6.884843] rockchip-dwc3 usb0: failed to get drvdata dwc3
[ 6.886059] EXT4-fs (mmcblk1p14): couldn’t mount as ext3 due to feature incompatibilities
[ 6.886509] EXT4-fs (mmcblk1p14): couldn’t mount as ext2 due to feature incompatibilities
[ 6.891185] EXT4-fs (mmcblk1p14): mounted filesystem without journal. Opts: (null)
[ 6.891349] VFS: Mounted root (ext4 filesystem) readonly on device 179:14.
[ 6.892119] Freeing unused kernel memory: 768K
[ 6.917289] init: init first stage started!
[ 6.918156] init: Using Android DT directory /proc/device-tree/firmware/android/
[ 7.014892] init: [libfs_mgr]Returning avb_handle with status: 3
[ 7.015025] init: [libfs_mgr]AVB HASHTREE disabled on: /system
[ 7.021438] init: [libfs_mgr]__mount(source=/dev/block/by-name/system,target=/system,type=ext4)=0: Success
[ 7.021604] init: [libfs_mgr]AVB HASHTREE disabled on: /vendor
[ 7.029757] EXT4-fs (mmcblk1p16): mounted filesystem without journal. Opts: barrier=1,inode_readahead_blks=8
[ 7.029899] init: [libfs_mgr]__mount(source=/dev/block/by-name/vendor,target=/vendor,type=ext4)=0: Success
[ 7.030153] init: Skipped setting INIT_AVB_VERSION (not in recovery mode)
[ 7.030324] init: Loading SELinux policy
[ 7.030496] selinux: SELinux: Could not open /sepolicy: No such file or directory
[ 7.030496]
[ 7.030515] init: Failed to load monolithic SELinux policy: No such file or directory
[ 7.030529] init: Unable to load SELinux policy
[ 7.030550] init: Reboot start, reason: reboot, rebootTarget: bootloader
[ 7.030634] init: Reboot ending, jumping to kernel
[ 7.030721] cpu4 limit freq=816000 min=816000 max=816000
[ 7.030852] cdn-dp fec00000.dp: [drm:cdn_dp_request_firmware] ERROR failed to request firmware: -11
[ 7.030905] cpu0 limit freq=816000 min=816000 max=816000
[ 7.040098] rk-vcodec ff660000.rkvdec: shutdown
[ 7.040523] rk-vcodec ff650000.vpu_service: shutdown
[ 7.063626] reboot: Restarting system with command ‘bootloader’
[ 7.064567] rk3x-i2c ff3c0000.i2c: unexpected irq in STOP: 0x10
[ 8.814860] rk3x-i2c ff3c0000.i2c: restart timeout, ipd: 0x00, state: 4
soft reset
SRX
channel 0
CS = 0
MR0=0x98
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
256B stride
channel 0
CS = 0
MR0=0x98
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CPUId = 0x0
ChipType = 0x10, 325
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=7456MB
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 68320
SecureMode = 0
No find bl30.bin
RunBL31 0x10000
INFO: SPSR = 0x3c9
PreSerial: 2
DRAM: 2 GiB
Sysmem: init
MMC0: HS400, 150Mhz
PartType: EFI
boot mode: loader
DTB: rk-kernel.dtb
I2c speed: 100000Hz
PMIC: RK808
vdd_log 900000 uV
vdd_cpu_l 900000 uV
enter Rockusb!
aplll 816000 KHz
apllb 24000 KHz
dpll 856000 KHz
cpll 24000 KHz
gpll 800000 KHz
npll 600000 KHz
vpll 24000 KHz
RKUSB: LUN 0, dev 0, hwpart 0, sector 0x0, count 0xe90000
