DDR Version 1.12 20180518
Channel 0: LPDDR3, 800MHz
CS = 0
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x2
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=32 Size=1024MB
Channel 1: LPDDR3, 800MHz
CS = 0
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x2
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
256B stride
pmugrf_os_reg[2] = 0x3280D280, stride = 0x9
Boot1: 2018-04-08, version: 1.12
CPUId = 0x0
ChipType = 0x10, 217
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=7456MB
FwPartOffset=2000 , 100000
mmc0:cmd8,32
mmc0:cmd5,32
mmc0:cmd55,32
mmc0:cmd1,32
mmc0:cmd8,32
mmc0:cmd5,32
mmc0:cmd55,32
mmc0:cmd1,32
mmc0:cmd8,32
mmc0:cmd5,32
mmc0:cmd55,32
mmc0:cmd1,32
SdmmcInit=0 1
StorageInit ok = 67805
LoadTrustBL
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xa7790
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):d98d16e
NOTICE: BL31: Built : 15:03:07, May 10 2018
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1151): pd status 3e
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-170-gc4654a6 #16 Wed May 30 08:54:30 UTC 2018 aarch64)
INFO: SPSR = 0x3c9
U-Boot 2017.09-01617-g9c62995 (Jul 03 2018 - 08:51:18 +0800)
Model: Firefly-RK3399 Board
DRAM: 2 GiB
Relocation Offset is: 7fd18000
rk8xx_read: read reg 0x17 failed, ret=-121
MMC: dwmmc@fe320000: 1, sdhci@fe330000: 0
*** Warning - bad CRC, using default environment
In: serial@ff1a0000
Out: serial@ff1a0000
Err: serial@ff1a0000
mmc_init: -95, time 9
switch to partitions #0, OK
enter Recovery mode!
Net: eth0: ethernet@fe300000
FDT load addr 0x10f00000 size 260 KiB
Booting kernel at 0x207f800 with fdt at 36c5800…
## Booting Android Image at 0x0207f800 …
Kernel load addr 0x02080000 size 18845 KiB
RAM disk load addr 0x11000000 size 3958 KiB
## Flattened Device Tree blob at 036c5800
Booting using the fdt blob at 0x36c5800
XIP Kernel Image … OK
Loading Ramdisk to 07e22000, end 081ff565 … OK
Loading Device Tree to 0000000007e0c000, end 0000000007e210f6 … OK
Adding bank: start=0x00200000, size=0x08200000
Adding bank: start=0x0a200000, size=0x75e00000
[ 0.000000] Linux version 4.4.132 (wxt@SYS3) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #4 SMP Mon Jul 2 19:58:20 CST 2018
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07fefa000 s45800 r8192 d32024 u86016
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.mode=emmc androidboot.slot_suffix= androidboot.serialno=29d4e64533db6ee9 rw rootwait earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 console=ttyFIQ0 root=PARTUUID=614e0000-0000 rootfstype=ext4
[ 0.000000] software IO TLB [mem 0x7feb2000-0x7fef2000] (0MB) mapped at [ffffffc07feb2000-ffffffc07fef1fff]
[ 0.000000] Memory: 2003500K/2064384K available (11582K kernel code, 1692K rwdata, 4400K rodata, 1088K init, 756K bss, 60884K reserved, 0K cma-reserved)
[ 0.000000] .init : 0xffffff8009030000 - 0xffffff8009140000 ( 1088 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008bd0000 ( 11584 KB)
[ 0.000000] .rodata : 0xffffff8008bd0000 - 0xffffff8009030000 ( 4480 KB)
[ 0.000000] .data : 0xffffff8009140000 - 0xffffff80092e7008 ( 1693 KB)
[ 0.000000] ITS: allocated 65536 Devices @a300000 (psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x000000000a290000
[ 0.000000] CPU0: using LPI pending table @0x000000000a2a0000
[ 0.002001] Console: colour dummy device 80x25
[ 0.002434] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.003398] pid_max: default: 32768 minimum: 301
[ 0.003971] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.004606] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.005980] Initializing cgroup subsys devices
[ 0.006407] Initializing cgroup subsys freezer
[ 0.006852] ftrace: allocating 41878 entries in 164 pages
[ 0.110911] sched-energy: Sched-energy-costs installed from DT
[ 0.111464] CPU0: update cpu_capacity 401
[ 0.111903] ASID allocator initialised with 32768 entries
[ 0.115552] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.116826] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.118961] Detected VIPT I-cache on CPU1
[ 0.118995] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.119025] CPU1: using LPI pending table @0x0000000000320000
[ 0.119070] CPU1: update cpu_capacity 401
[ 0.119074] CPU1: Booted secondary processor [410fd034]
[ 0.119599] Detected VIPT I-cache on CPU2
[ 0.119620] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.119648] CPU2: using LPI pending table @0x0000000000340000
[ 0.119676] CPU2: update cpu_capacity 401
[ 0.119679] CPU2: Booted secondary processor [410fd034]
[ 0.120202] Detected VIPT I-cache on CPU3
[ 0.120223] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.120250] CPU3: using LPI pending table @0x0000000000390000
[ 0.120278] CPU3: update cpu_capacity 401
[ 0.120282] CPU3: Booted secondary processor [410fd034]
[ 0.120800] Detected PIPT I-cache on CPU4
[ 0.120826] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.120866] CPU4: using LPI pending table @0x00000000003d0000
[ 0.120904] CPU4: update cpu_capacity 1024
[ 0.120908] CPU4: Booted secondary processor [410fd082]
[ 0.121439] Detected PIPT I-cache on CPU5
[ 0.121459] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.121498] CPU5: using LPI pending table @0x000000007d000000
[ 0.121525] CPU5: update cpu_capacity 1024
[ 0.121528] CPU5: Booted secondary processor [410fd082]
[ 0.121615] Brought up 6 CPUs
[ 0.133677] SMP: Total of 6 processors activated.
[ 0.134118] CPU features: detected feature: GIC system register CPU interface
[ 0.134793] CPU: All CPU(s) started at EL2
[ 0.135214] alternatives: patching kernel code
[ 0.137029] devtmpfs: initialized
[ 0.151268] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.152244] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.153313] pinctrl core: initialized pinctrl subsystem
[ 0.154572] NET: Registered protocol family 16
[ 0.160297] cpuidle: using governor ladder
[ 0.164305] cpuidle: using governor menu
[ 0.164704] Registered FIQ tty driver
[ 0.165365] vdso: 2 pages (1 code @ ffffff8008bd6000, 1 data @ ffffff8009144000)
[ 0.166109] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.166932] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.190229] console [ttyFIQ0] enabled
[ 0.190910] bootconsole [uart0] disabled
[ 0.191829] Registered fiq debugger ttyFIQ0
[ 0.221086] iommu: Adding device ff650000.vpu_service to group 0
[ 0.221690] iommu: Adding device ff660000.rkvdec to group 1
[ 0.222277] iommu: Adding device ff8f0000.vop to group 2
[ 0.222822] iommu: Adding device ff900000.vop to group 3
[ 0.224608] SCSI subsystem initialized
[ 0.225113] usbcore: registered new interface driver usbfs
[ 0.225649] usbcore: registered new interface driver hub
[ 0.226195] usbcore: registered new device driver usb
[ 0.226726] media: Linux media interface: v0.10
[ 0.227164] Linux video capture interface: v2.00
[ 0.227608] pps_core: LinuxPPS API ver. 1 registered
[ 0.228057] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.228867] PTP clock support registered
[ 0.230236] Advanced Linux Sound Architecture Driver Initialized.
[ 0.231244] Bluetooth: Core ver 2.21
[ 0.231587] NET: Registered protocol family 31
[ 0.231981] Bluetooth: HCI device and connection manager initialized
[ 0.232553] Bluetooth: HCI socket layer initialized
[ 0.232986] Bluetooth: L2CAP socket layer initialized
[ 0.233467] Bluetooth: SCO socket layer initialized
[ 0.234996] clocksource: Switched to clocksource arch_sys_counter
[ 0.283267] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.284179] NET: Registered protocol family 2
[ 0.285019] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.285749] TCP bind hash table entries: 16384 (order: 7, 524288 bytes)
[ 0.286781] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.287452] UDP hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.288080] UDP-Lite hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.288923] NET: Registered protocol family 1
[ 0.289619] RPC: Registered named UNIX socket transport module.
[ 0.290160] RPC: Registered udp transport module.
[ 0.290577] RPC: Registered tcp transport module.
[ 0.291002] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.292195] Trying to unpack rootfs image as initramfs…
[ 0.493420] Freeing initrd memory: 3956K
[ 0.494271] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.495083] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.499108] Initialise system trusted keyring
[ 0.507406] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.508702] NFS: Registering the id_resolver key type
[ 0.509188] Key type id_resolver registered
[ 0.509559] Key type id_legacy registered
[ 0.509996] fuse init (API version 7.23)
[ 0.510716] SGI XFS with security attributes, no debug enabled
[ 0.515897] NET: Registered protocol family 38
[ 0.516319] Key type asymmetric registered
[ 0.516694] Asymmetric key parser ‘x509’ registered
[ 0.517296] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.517957] io scheduler noop registered
[ 0.518327] io scheduler deadline registered
[ 0.518835] io scheduler cfq registered (default)
[ 0.520643] phy phy-ff770000.syscon:usb2-phy@e460.0: Failed to get VBUS supply regulator
[ 0.526150] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.526731] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.527329] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 1.069042] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 1.069762] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 1.071491] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 1.072398] rk-vcodec ff650000.vpu_service: probe device
[ 1.072916] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc07d22a410
[ 1.073769] rk-vcodec ff650000.vpu_service: allocator is drm
[ 1.074350] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 1.075523] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 1.076161] rk-vcodec ff650000.vpu_service: init success
[ 1.077047] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 1.078060] rk-vcodec ff660000.rkvdec: probe device
[ 1.078530] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc07d22ac10
[ 1.079276] rk-vcodec ff660000.rkvdec: allocator is drm
[ 1.079794] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 1.080635] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 1.081236] rk-vcodec ff660000.rkvdec: init success
[ 1.083137] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.083808] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 1.086071] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.086741] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
