DDR Version 1.20 20190314
Channel 0: LPDDR3, 800MHz
CS = 0
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x3
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
CS = 1
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x3
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=32 Size=2048MB
Channel 1: LPDDR3, 800MHz
CS = 0
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x3
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
CS = 1
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x3
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
256B stride
pmugrf_os_reg[2] = 0x3AA0DAA0, stride = 0xD
CPUId = 0x0
ChipType = 0x10, 216
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 67663
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
GPT 0x3190d20 signature is wrong
LoadTrust Addr:0x4000
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xec2c8
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):cd61876
NOTICE: BL31: Built : 16:25:54, Jan 23 2019
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1181): pd status 3e
INFO: BL31: Initializing BL32
INFO: SPSR = 0x3c9
U-Boot 2017.09 (Jul 20 2019 - 17:41:42 +0800)
Model: Rockchip RK3399 Evaluation Board
PreSerial: 2
DRAM: 3.8 GiB
Sysmem: init
Relocation Offset is: f5bd9000
mmc_init: -95, time 9
switch to partitions #0, OK
Bootdev: mmc 0
PartType: RKPARM
boot mode: None
Load FDT from resource part
DTB: rk-kernel.dtb
I2c speed: 400000Hz
PMIC: RK8090 (on=0x69, off=0x00)
vdd_center 900000 uV
vdd_cpu_l 900000 uV
Model: RK3399pro-firefly-aiojd4 board
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 24000 KHz, init 24000 KHz, kernel 0N/A)
aplll 816000 KHz
apllb 24000 KHz
dpll 800000 KHz
cpll 24000 KHz
gpll 800000 KHz
npll 600000 KHz
vpll 24000 KHz
aclk_perihp 133333 KHz
hclk_perihp 66666 KHz
pclk_perihp 33333 KHz
aclk_perilp0 266666 KHz
hclk_perilp0 88888 KHz
pclk_perilp0 44444 KHz
hclk_perilp1 100000 KHz
pclk_perilp1 50000 KHz
Net: eth0: ethernet@fe300000
SecureBoot disabled, AVB skip
** Invalid Android Image header **
=Booting Rockchip format image=
fdt @ 0x08300000 (0x00019580)
kernel @ 0x00280000 (0x012e3808)
ramdisk @ 0x0a200000 (0x00178918)
Fdt Ramdisk skip relocation
## Flattened Device Tree blob at 08300000
Booting using the fdt blob at 0x8300000
Using Device Tree in place at 0000000008300000, end 000000000831c57f
Adding bank: 0x0a200000 - 0xf8000000 (size: 0xede00000)
Can’t find file:logo_kernel.bmp
Total: 714.172 ms
[ 0.000000] Linux version 4.4.167 (lkd@mid-server) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #83 SMP PREEMPT Tue Jul 30 14:31:53 CST 2019
[ 0.000000] cma: Reserved 16 MiB at 0x00000000f7000000
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f6edc000 s45528 r8192 d32296 u86016
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 991752
[ 0.000000] Kernel command line: console=ttyFIQ0 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.veritymode=enforcing androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x00010000@0x00010000(kernel),0x00010000@0x00020000(boot),0x00020000@0x00030000(recovery),0x00038000@0x00050000(backup),0x00002000@0x00088000(security),0x00100000@0x0008a000(cache),0x00500000@0x0018a000(system),0x00008000@0x0068a000(metadata),0x00100000@0x00692000(vendor),0x00100000@0x00794000(oem),0x00000400@0x00894000(frp),-@0x00894400(userdata) storagemedia=emmc androidboot.mode=normal androidboot.verifiedbootstate=orange earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 coherent_pool=1m
[ 0.000000] software IO TLB [mem 0xf6e94000-0xf6ed4000] (0MB) mapped at [ffffffc0f6e94000-ffffffc0f6ed3fff]
[ 0.000000] Memory: 3916856K/4030464K available (11326K kernel code, 1678K rwdata, 5540K rodata, 768K init, 2440K bss, 97224K reserved, 16384K cma-reserved)
[ 0.000000] .init : 0xffffff8009100000 - 0xffffff80091c0000 ( 768 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008b90000 ( 11328 KB)
[ 0.000000] .rodata : 0xffffff8008b90000 - 0xffffff8009100000 ( 5568 KB)
[ 0.000000] .data : 0xffffff80091c0000 - 0xffffff8009363808 ( 1679 KB)
[ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc3e00000 ( 61 MB actual)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc0f8000000 ( 3966 MB)
[ 0.000000] ITS: allocated 65536 Devices @200000 (psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x00000000f2000000
[ 0.000000] CPU0: using LPI pending table @0x00000000f2010000
[ 0.002041] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.003022] pid_max: default: 32768 minimum: 301
[ 0.003542] Security Framework initialized
[ 0.003938] SELinux: Initializing.
[ 0.004352] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.004993] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.006469] Initializing cgroup subsys memory
[ 0.006909] Initializing cgroup subsys freezer
[ 0.008275] sched-energy: Sched-energy-costs installed from DT
[ 0.008834] CPU0: update cpu_capacity 401
[ 0.009295] ASID allocator initialised with 32768 entries
[ 0.026124] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.027419] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.039518] Detected VIPT I-cache on CPU1
[ 0.039548] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.039578] CPU1: using LPI pending table @0x00000000f2180000
[ 0.039617] CPU1: update cpu_capacity 401
[ 0.039621] CPU1: Booted secondary processor [410fd034]
[ 0.049510] Detected VIPT I-cache on CPU2
[ 0.049532] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.049558] CPU2: using LPI pending table @0x00000000f21b0000
[ 0.049583] CPU2: update cpu_capacity 401
[ 0.049586] CPU2: Booted secondary processor [410fd034]
[ 0.059542] Detected VIPT I-cache on CPU3
[ 0.059562] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.059589] CPU3: using LPI pending table @0x00000000f21f0000
[ 0.059614] CPU3: update cpu_capacity 401
[ 0.059617] CPU3: Booted secondary processor [410fd034]
[ 0.069596] Detected PIPT I-cache on CPU4
[ 0.069622] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.069660] CPU4: using LPI pending table @0x00000000f2230000
[ 0.069697] CPU4: update cpu_capacity 1024
[ 0.069700] CPU4: Booted secondary processor [410fd082]
[ 0.079618] Detected PIPT I-cache on CPU5
[ 0.079635] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.079671] CPU5: using LPI pending table @0x00000000f2260000
[ 0.079697] CPU5: update cpu_capacity 1024
[ 0.079700] CPU5: Booted secondary processor [410fd082]
[ 0.079782] Brought up 6 CPUs
[ 0.092107] SMP: Total of 6 processors activated.
[ 0.092559] CPU features: detected feature: GIC system register CPU interface
[ 0.093239] CPU features: detected feature: 32-bit EL0 Support
[ 0.093806] CPU: All CPU(s) started at EL2
[ 0.094234] alternatives: patching kernel code
[ 0.096527] devtmpfs: initialized
[ 0.118649] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.119572] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.120825] pinctrl core: initialized pinctrl subsystem
[ 0.122936] Failed to find legacy iommu devices
[ 0.123764] NET: Registered protocol family 16
[ 0.124584] schedtune: init normalization constants…
[ 0.125069] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[ 0.125681] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 0.126292] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[ 0.126909] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 0.127518] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 0.128126] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[ 0.128734] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[ 0.129340] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[ 0.129945] schedtune: SYSTEM min_pwr: 121 max_pwr: 4434
[ 0.130558] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[ 0.131268] schedtune: verify normalization constants…
[ 0.131763] schedtune: max_pwr/2^0: 4313 => norm_pwr: 1024
[ 0.132283] schedtune: max_pwr/2^1: 2156 => norm_pwr: 511
[ 0.132804] schedtune: max_pwr/2^2: 1078 => norm_pwr: 255
[ 0.133323] schedtune: max_pwr/2^3: 539 => norm_pwr: 127
[ 0.133842] schedtune: max_pwr/2^4: 269 => norm_pwr: 63
[ 0.134368] schedtune: max_pwr/2^5: 134 => norm_pwr: 31
[ 0.134887] schedtune: configured to support 5 boost groups
[ 0.144404] cpuidle: using governor ladder
[ 0.154407] cpuidle: using governor menu
[ 0.154785] Registered FIQ tty driver
[ 0.155493] vdso: 2 pages (1 code @ ffffff8008b96000, 1 data @ ffffff80091c4000)
[ 0.156209] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.157865] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.178975] console [pstore-1] enabled
[ 0.179552] pstore: Registered ramoops as persistent store backend
[ 0.180130] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.183044] fiq debugger fiq mode enabled
[ [ 0.183689] console [ttyFIQ0] enabled
[ 0.184365] bootconsole [uart0] disabled
[ 0.184938] Registered fiq debugger ttyFIQ0
[ 0.218289] iommu: Adding device ff650000.vpu_service to group 0
[ 0.218379] iommu: Adding device ff660000.rkvdec to group 1
[ 0.218458] iommu: Adding device ff670000.iep to group 2
[ 0.218559] iommu: Adding device ff8f0000.vop to group 3
[ 0.218642] iommu: Adding device ff900000.vop to group 4
[ 0.218755] iommu: Adding device ff910000.isp to group 5
[ 0.218840] iommu: Adding device ff920000.isp to group 6
[ 0.219262] rk_iommu ff650800.iommu: can’t get sclk
[ 0.219503] rk_iommu ff660480.iommu: can’t get sclk
[ 0.219595] rk_iommu ff670800.iommu: can’t get aclk
[ 0.219607] rk_iommu ff670800.iommu: can’t get hclk
[ 0.219617] rk_iommu ff670800.iommu: can’t get sclk
[ 0.219786] rk_iommu ff8f3f00.iommu: can’t get sclk
[ 0.219955] rk_iommu ff903f00.iommu: can’t get sclk
[ 0.220110] rk_iommu ff914000.iommu: can’t get sclk
[ 0.220262] rk_iommu ff924000.iommu: can’t get sclk
[ 0.220569] SCSI subsystem initialized
[ 0.220896] usbcore: registered new interface driver usbfs
[ 0.220948] usbcore: registered new interface driver hub
[ 0.221018] usbcore: registered new device driver usb
[ 0.221413] media: Linux media interface: v0.10
[ 0.221451] Linux video capture interface: v2.00
[ 0.221624] pps_core: LinuxPPS API ver. 1 registered
[ 0.221633] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.221652] PTP clock support registered
[ 0.223394] Advanced Linux Sound Architecture Driver Initialized.
[ 0.223885] Bluetooth: Core ver 2.21
[ 0.223915] NET: Registered protocol family 31
[ 0.223924] Bluetooth: HCI device and connection manager initialized
[ 0.223937] Bluetooth: HCI socket layer initialized
[ 0.223948] Bluetooth: L2CAP socket layer initialized
[ 0.223974] Bluetooth: SCO socket layer initialized
[ 0.224579] rockchip-cpuinfo cpuinfo: Serial : 3a61820afab28091
[ 0.225229] clocksource: Switched to clocksource arch_sys_counter
[ 0.268746] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.268984] NET: Registered protocol family 2
[ 0.269421] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.269692] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.270229] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.270310] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.270417] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.270656] NET: Registered protocol family 1
[ 0.271582] Trying to unpack rootfs image as initramfs…
[ 0.339206] Freeing initrd memory: 1504K
[ 0.339782] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.339869] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.342813] audit: initializing netlink subsys (disabled)
[ 0.342878] audit: type=2000 audit(0.340:1): initialized
[ 0.348287] VFS: Disk quotas dquot_6.6.0
[ 0.348418] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.349320] Registering sdcardfs 0.1
[ 0.349861] fuse init (API version 7.23)
[ 0.351029]
[ 0.351029] TEE Core Framework initialization (ver 1:0.1)
[ 0.351058] TEE armv7 Driver initialization
[ 0.351432] tz_tee_probe: name=“armv7sec”, id=0, pdev_name=“armv7sec.0”
[ 0.351449] TEE core: Alloc the misc device “opteearmtz00” (id=0)
[ 0.351625] TEE Core: Register the misc device “opteearmtz00” (id=0,minor=62)
[ 0.355971] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.355999] io scheduler noop registered
[ 0.356165] io scheduler cfq registered (default)
[ 0.357071] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: failed to create phy
[ 0.357390] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: failed to create phy
[ 0.362760] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.362788] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.362803] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 0.362813] rockchip-pcie f8000000.pcie: missing “memory-region” property
[ 0.362827] PCI host bridge /pcie@f8000000 ranges:
[ 0.362858] MEM 0xfa000000..0xfbdfffff → 0xfa000000
[ 0.362869] IO 0xfbe00000..0xfbefffff → 0xfbe00000
[ 0.908605] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 0.908673] rockchip-pcie f8000000.pcie: deferred probe failed
[ 0.908793] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 0.909661] iep: failed to find iep power down clock source.
[ 0.910229] IEP Power ON
[ 0.910440] IEP Power OFF
[ 0.910564] IEP Driver loaded succesfully
[ 0.910849] Module initialized.
[ 0.911243] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 0.911511] rk-vcodec ff650000.vpu_service: probe device
[ 0.911718] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[ 0.912330] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 0.912345] rk-vcodec ff650000.vpu_service: init success
[ 0.912599] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 0.913100] rk-vcodec ff660000.rkvdec: probe device
[ 0.913310] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[ 0.913746] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 0.913769] rk-vcodec ff660000.rkvdec: init success
[ 0.915692] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.915715] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.917093] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.917108] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.918082] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 0.918937] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.919503] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 35, base_baud = 1500000) is a 16550A
[ 0.919945] [drm] Initialized drm 1.1.0 20060810
[ 0.923476] [drm] Rockchip DRM driver version: v1.0.1
[ 0.923797] rockchip-drm display-subsystem: defer getting devfreq
[ 0.924080] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 0.924344] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 0.924396] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 0.924572] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 0.924819] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 0.924843] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 0.924944] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 0.925750] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[ 0.925768] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.925776] [drm] No driver support for vblank timestamp query.
[ 0.926082] rockchip-drm display-subsystem: connector[HDMI-A-1] can’t found any modes
[ 0.926118] rockchip-drm display-subsystem: can’t not find any loader display
[ 0.926156] rockchip-drm display-subsystem: failed to show loader logo
[ 0.926275] Freeing drm_logo memory: 616K
[ 0.926292] rockchip-drm display-subsystem: No connectors reported connected with modes
[ 0.926309] [drm] Cannot find any crtc or sizes - going 1024x768
[ 0.931222] rockchip-drm display-subsystem: fb0: frame buffer device
[ 0.947607] Unable to detect cache hierarchy for CPU 0
[ 0.960369] brd: module loaded
[ 0.969645] loop: module loaded
[ 0.970241] zram: Added device: zram0
[ 0.971466] SCSI Media Changer driver v0.25
[ 0.973095] rockchip-spi ff1d0000.spi: no high_speed pinctrl state
[ 0.974193] rockchip-spi ff1e0000.spi: no high_speed pinctrl state
[ 0.975357] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[ 0.975390] wk2xxx_probe() Can not read property power-gpio
[ 1.145753] wk2xxx_serial_init()
[ 1.145770] wk2xxx_request_port
[ 1.145782] ttysWK0 at I/O 0x1 (irq = 140, base_baud = 460800) is a wk2xxx
[ 1.146028] uart_add_one_port success for line i:= 0 with right 0
[ 1.146042] wk2xxx_request_port
[ 1.146053] ttysWK1 at I/O 0x2 (irq = 140, base_baud = 460800) is a wk2xxx
[ 1.146235] uart_add_one_port success for line i:= 1 with right 0
[ 1.146248] wk2xxx_request_port
[ 1.146258] ttysWK2 at I/O 0x3 (irq = 140, base_baud = 460800) is a wk2xxx
[ 1.146437] uart_add_one_port success for line i:= 2 with right 0
[ 1.146449] wk2xxx_request_port
[ 1.146459] ttysWK3 at I/O 0x4 (irq = 140, base_baud = 460800) is a wk2xxx
[ 1.146642] uart_add_one_port success for line i:= 3 with right 0
[ 1.146655] uart_add_one_port = 0x0
[ 1.146682] register spi return v = :0
[ 1.146723] register firefly_spi_init spi return v = :0
[ 1.146783] tun: Universal TUN/TAP device driver, 1.6
[ 1.146794] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.146969] CAN device driver interface
[ 1.147828] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.147849] rk_gmac-dwmac fe300000.ethernet: TX delay(0x26).
[ 1.147860] rk_gmac-dwmac fe300000.ethernet: RX delay(0x23).
[ 1.147884] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 1.148055] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 1.148064] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.153078] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.153204] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.153218] Ring mode enabled
[ 1.153226] DMA HW capability register supported
[ 1.153232] Normal descriptors
[ 1.153242] RX Checksum Offload Engine supported (type 2)
[ 1.153249] TX Checksum insertion supported
[ 1.153255] Wake-Up On Lan supported
[ 1.153293] Enable RX Mitigation via HW Watchdog Timer
[ 1.221947] libphy: stmmac: probed
[ 1.222011] eth%d: PHY ID 001cc916 at 0 IRQ POLL (stmmac-0:00) active
[ 1.222023] eth%d: PHY ID 001cc916 at 1 IRQ POLL (stmmac-0:01)
[ 1.223400] PPP generic driver version 2.4.2
[ 1.223652] PPP BSD Compression module registered
[ 1.223693] PPP Deflate Compression module registered
[ 1.223733] PPP MPPE Compression module registered
[ 1.223760] NET: Registered protocol family 24
[ 1.223823] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.223853] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.223874] Rockchip WiFi SYS interface (V1.00) …
[ 1.224003] usbcore: registered new interface driver catc
[ 1.224065] usbcore: registered new interface driver kaweth
[ 1.224101] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.224149] usbcore: registered new interface driver pegasus
[ 1.224204] usbcore: registered new interface driver rtl8150
[ 1.224258] usbcore: registered new interface driver r8152
[ 1.224293] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.224361] usbcore: registered new interface driver hso
[ 1.224418] usbcore: registered new interface driver asix
[ 1.224473] usbcore: registered new interface driver ax88179_178a
[ 1.224550] usbcore: registered new interface driver cdc_ether
[ 1.224601] usbcore: registered new interface driver cdc_eem
[ 1.224654] usbcore: registered new interface driver dm9601
[ 1.224719] usbcore: registered new interface driver smsc75xx
[ 1.224806] usbcore: registered new interface driver smsc95xx
[ 1.224858] usbcore: registered new interface driver gl620a
[ 1.224912] usbcore: registered new interface driver net1080
[ 1.224984] usbcore: registered new interface driver plusb
[ 1.225035] usbcore: registered new interface driver rndis_host
[ 1.225087] usbcore: registered new interface driver cdc_subset
[ 1.225147] usbcore: registered new interface driver zaurus
[ 1.225245] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.225321] usbcore: registered new interface driver int51x1
[ 1.225377] usbcore: registered new interface driver kalmia
[ 1.225452] usbcore: registered new interface driver ipheth
[ 1.225509] usbcore: registered new interface driver sierra_net
[ 1.225565] usbcore: registered new interface driver cx82310_eth
[ 1.225657] usbcore: registered new interface driver cdc_ncm
[ 1.225709] usbcore: registered new interface driver qmi_wwan
[ 1.225762] usbcore: registered new interface driver cdc_mbim
[ 1.227542] rockchip-dwc3 usb0: failed to get drvdata dwc3
[ 1.228739] rockchip-dwc3 usb1: failed to get drvdata dwc3
[ 1.230053] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.230093] ehci-pci: EHCI PCI platform driver
[ 1.230186] ehci-platform: EHCI generic platform driver
[ 1.231018] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.231073] ohci-platform: OHCI generic platform driver
[ 1.232319] usbcore: registered new interface driver cdc_acm
[ 1.232362] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.232439] usbcore: registered new interface driver usblp
[ 1.232496] usbcore: registered new interface driver cdc_wdm
[ 1.232552] usbcore: registered new interface driver uas
[ 1.232641] usbcore: registered new interface driver usb-storage
[ 1.232690] usbcore: registered new interface driver ums-alauda
[ 1.232739] usbcore: registered new interface driver ums-cypress
[ 1.232797] usbcore: registered new interface driver ums-datafab
[ 1.232868] usbcore: registered new interface driver ums_eneub6250
[ 1.232917] usbcore: registered new interface driver ums-freecom
[ 1.232971] usbcore: registered new interface driver ums-isd200
[ 1.233022] usbcore: registered new interface driver ums-jumpshot
[ 1.233093] usbcore: registered new interface driver ums-karma
[ 1.233142] usbcore: registered new interface driver ums-onetouch
[ 1.233194] usbcore: registered new interface driver ums-sddr09
[ 1.233244] usbcore: registered new interface driver ums-sddr55
[ 1.233307] usbcore: registered new interface driver ums-usbat
[ 1.233411] usbcore: registered new interface driver usbserial
[ 1.233458] usbcore: registered new interface driver usbserial_generic
[ 1.233504] usbserial: USB Serial support registered for generic
[ 1.233555] usbcore: registered new interface driver option
[ 1.233589] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.233651] usbcore: registered new interface driver trancevibrator
[ 1.233678] usb20_otg: version 3.10a 21-DEC-2012
[ 1.233908] usb20_host: version 3.10a 21-DEC-2012
[ 1.234723] usbcore: registered new interface driver xpad
[ 1.234796] usbcore: registered new interface driver usb_acecad
[ 1.234855] usbcore: registered new interface driver aiptek
[ 1.234912] usbcore: registered new interface driver gtco
[ 1.234968] usbcore: registered new interface driver hanwang
[ 1.235032] usbcore: registered new interface driver kbtab
[ 1.235053] ==gsl_ts_init==
[ 1.235096] ret=0
[ 1.235623] .. rk pwm remotectl v1.1 init
[ 1.235858] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 1.236408] sensor_register_slave:kxtj9,id=11
[ 1.236458] sensor_register_slave:mma8452,id=17
[ 1.236476] sensor_register_slave:lis3dh,id=7
[ 1.236519] sensor_register_slave:mma7660,id=18
[ 1.236535] sensor_register_slave:lsm303d,id=22
[ 1.236551] sensor_register_slave:gs_mc3230,id=23
[ 1.236560] [Gsensor] gsensor_init
[ 1.236576] sensor_register_slave:mpu6880_acc,id=24
[ 1.236592] sensor_register_slave:mpu6500_acc,id=25
[ 1.236608] sensor_register_slave:lsm330_acc,id=26
[ 1.236624] sensor_register_slave:bma2xx_acc,id=27
[ 1.236640] sensor_register_slave:akm8975,id=30
[ 1.236657] sensor_register_slave:akm8963,id=31
[ 1.236673] sensor_register_slave:l3g4200d,id=45
[ 1.236689] sensor_register_slave:l3g20d,id=46
[ 1.236705] sensor_register_slave:ewtsa,id=47
[ 1.236746] sensor_register_slave:lsm330_gyro,id=51
[ 1.236762] sensor_register_slave:cm3217,id=53
[ 1.236778] sensor_register_slave:cm3218,id=54
[ 1.236794] sensor_register_slave:ls_stk3410,id=62
[ 1.236811] sensor_register_slave:ps_stk3410,id=67
[ 1.237964] i2c /dev entries driver
[ 1.239619] rk808 0-0020: Pmic Chip id: 0x8090
[ 1.239990] rk808 0-0020: source: on=0x40, off=0x00
[ 1.240835] rk808 0-0020: support dcdc3 fb mode:-22, -248243168
[ 1.241157] rk808 0-0020: support pmic reset mode:0,0
[ 1.244453] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.244559] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.244688] DCDC_REG1: supplied by vcc5v0_sys
[ 1.246327] DCDC_REG2: supplied by vcc5v0_sys
[ 1.248010] DCDC_REG3: supplied by vcc5v0_sys
[ 1.249388] DCDC_REG4: supplied by vcc5v0_sys
[ 1.250806] DCDC_REG5: supplied by vcc5v0_sys
[ 1.252009] LDO_REG1: supplied by vcc_buck5
[ 1.253864] LDO_REG2: supplied by vcc_buck5
[ 1.255760] LDO_REG3: supplied by vcc_buck5
[ 1.257652] LDO_REG4: supplied by vcc_buck5
[ 1.259560] LDO_REG5: supplied by vcc_buck5
[ 1.261422] LDO_REG6: supplied by vcc_buck5
[ 1.263275] LDO_REG7: supplied by vcc3v3_sys
[ 1.265161] LDO_REG8: supplied by vcc3v3_sys
[ 1.267179] LDO_REG9: supplied by vcc3v3_sys
[ 1.269168] SWITCH_REG1: supplied by vcc5v0_sys
[ 1.270080] SWITCH_REG2: supplied by vcc3v3_sys
[ 1.271391] rk817-battery rk817-battery: Failed to find matching dt id
[ 1.271623] rk817-charger rk817-charger: Failed to find matching dt id
[ 1.273956] input: rk8xx_pwrkey as /devices/platform/ff3c0000.i2c/i2c-0/0-0020/input/input1
[ 1.277809] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 1.280121] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected!
[ 1.280238] fan53555-reg: supplied by vcc5v0_sys
[ 1.282695] fan53555-regulator 0-0010: FAN53555 Option[0] Rev[15] Detected!
[ 1.282768] fan53555-reg: supplied by vcc5v0_sys
[ 1.284527] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff800987e000
[ 1.285204] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80099ae000
[ 1.285911] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80099b0000
[ 1.287247] IR NEC protocol handler initialized
[ 1.287285] IR RC5(x/sz) protocol handler initialized
[ 1.287302] IR RC6 protocol handler initialized
[ 1.287317] IR JVC protocol handler initialized
[ 1.287330] IR Sony protocol handler initialized
[ 1.287362] IR SANYO protocol handler initialized
[ 1.287376] IR Sharp protocol handler initialized
[ 1.287389] IR MCE Keyboard/mouse protocol handler initialized
[ 1.287402] IR XMP protocol handler initialized
[ 1.288165] usbcore: registered new interface driver uvcvideo
[ 1.288196] USB Video Class driver (1.1.1)
[ 1.288214] CamSys driver version: v0.48.0, CamSys head file version: v1.0.0
[ 1.294084] test_power_init: could not find dev node
[ 1.297727] Boot mode: coldboot
[ 1.298969] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 1.299260] rockchip-thermal ff260000.tsadc: tsadc is probed successfully!
[ 1.300149] device-mapper: uevent: version 1.0.3
[ 1.300578] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 1.300801] device-mapper: verity-avb: AVB error handler initialized with vbmeta device:
[ 1.300838] Bluetooth: HCI UART driver ver 2.3
[ 1.300851] Bluetooth: HCI UART protocol H4 registered
[ 1.300860] Bluetooth: HCI UART protocol LL registered
[ 1.300874] rtk_btusb: RTKBT_RELEASE_NAME: 20180702_BT_ANDROID_8.1
[ 1.300883] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.5
[ 1.300890] rtk_btusb: Register usb char device interface for BT driver
[ 1.301147] usbcore: registered new interface driver rtk_btusb
[ 1.301843] cpu cpu0: leakage=0
[ 1.315500] cpu cpu0: temp=43333, pvtm=147021 (146889 + 132)
[ 1.316537] cpu cpu0: pvtm-volt-sel=1
[ 1.316921] cpu cpu4: leakage=0
[ 1.329349] cpu cpu4: temp=43333, pvtm=158868 (158798 + 70)
[ 1.330196] cpu cpu4: pvtm-volt-sel=2
[ 1.331577] cpu cpu0: avs=0
[ 1.331692] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 1.333151] cpu cpu0: failed to find power_model node
[ 1.334117] cpu cpu4: avs=0
[ 1.334249] cpu cpu4: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 1.335870] cpu cpu4: failed to find power_model node
[ 1.336942] sdhci: Secure Digital Host Controller Interface driver
[ 1.336997] sdhci: Copyright(c) Pierre Ossman
[ 1.337015] Synopsys Designware Multimedia Card Interface Driver
[ 1.338263] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.338649] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.338671] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.338731] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.338759] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.338815] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.338826] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.340048] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.340115] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 1.340133] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 1.340193] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 1.340219] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.340476] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 1.341462] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.341650] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.352215] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.366350] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 1.366898] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.368941] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 1.368955] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 1.395354] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 1.399219] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.402837] usbcore: registered new interface driver usbhid
[ 1.402883] usbhid: USB HID core driver
[ 1.403054] inv_mpu_iio: inv_mpu_init:746
[ 1.404043] ashmem: initialized
[ 1.406610] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[ 1.413037] rknandbase v1.2 2018-05-08
[ 1.413951] usbcore: registered new interface driver snd-usb-audio
[ 1.415764] invalid rk817->hp_det_gpio: -2
[ 1.420035] rk-hdmi-dp-sound hdmi-dp-sound: i2s-hifi ↔ ff8a0000.i2s mapping ok
[ 1.422113] u32 classifier
[ 1.422175] Actions configured
[ 1.422250] Netfilter messages via NETLINK v0.30.
[ 1.422378] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.422871] ctnetlink v0.93: registering with nfnetlink.
[ 1.423622] xt_time: kernel timezone is -0000
[ 1.423826] IPv4 over IPsec tunneling driver
[ 1.425636] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.426004] arp_tables: (C) 2002 David S. Miller
[ 1.426974] Initializing XFRM netlink socket
[ 1.427639] NET: Registered protocol family 10
[ 1.428981] mip6: Mobile IPv6
[ 1.429037] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.430805] sit: IPv6 over IPv4 tunneling driver
[ 1.431635] NET: Registered protocol family 17
[ 1.431682] NET: Registered protocol family 15
[ 1.431719] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 1.432473] Bridge firewalling registered
[ 1.432503] Ebtables v2.0 registered
[ 1.432560] can: controller area network core (rev 20120528 abi 9)
[ 1.432610] NET: Registered protocol family 29
[ 1.432627] can: raw protocol (rev 20120528)
[ 1.432641] can: broadcast manager protocol (rev 20120528 t)
[ 1.432658] can: netlink gateway (rev 20130117) max_hops=1
[ 1.433221] Bluetooth: RFCOMM TTY layer initialized
[ 1.433256] Bluetooth: RFCOMM socket layer initialized
[ 1.433288] Bluetooth: RFCOMM ver 1.11
[ 1.433319] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.433327] Bluetooth: BNEP filters: protocol multicast
[ 1.433339] Bluetooth: BNEP socket layer initialized
[ 1.433354] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.433365] Bluetooth: HIDP socket layer initialized
[ 1.433444] l2tp_core: L2TP core driver, V2.0
[ 1.433473] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.433488] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.433808] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.433870] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6255
[ 1.433881] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.433890] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.433963] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 1.433975] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 1.433983] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.433994] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.434064] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.434407] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 1.434455] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 92.
[ 1.434487] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[ 1.434517] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 5.
[ 1.434743] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.434797] [BT_RFKILL]: ** disable irq
[ 1.434927] [BT_RFKILL]: bt_default device registered.
[ 1.435121] sensor_register_slave:mpu6500_gyro,id=49
[ 1.435151] sensor_register_slave:mpu6880_gyro,id=50
[ 1.435727] Error: Driver ‘gc0312’ is already registered, aborting…
[ 1.435886] Error: Driver ‘gc2145’ is already registered, aborting…
[ 1.437166] Registered cp15_barrier emulation handler
[ 1.437326] Registered setend emulation handler
[ 1.438502] registered taskstats version 1
[ 1.440726] Key type encrypted registered
[ 1.441645] rockchip ion idev is NULL
[ 1.441675] rga2 ff680000.rga: rga ion client create success!
[ 1.442016] rga2: Driver loaded successfully ver:3.02
[ 1.442329] rga2: Module initialized.
[ 1.443983] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: vbus_drv is not assigned
[ 1.444038] lkd: vbus-5v-gpios = 149
[ 1.445314] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned
[ 1.450056] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 1.450358] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 1
[ 1.450595] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 1.450645] xhci-hcd xhci-hcd.10.auto: irq 230, io mem 0xfe800000
[ 1.450900] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.450918] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.450929] usb usb1: Product: xHCI Host Controller
[ 1.450938] usb usb1: Manufacturer: Linux 4.4.167 xhci-hcd
[ 1.450948] usb usb1: SerialNumber: xhci-hcd.10.auto
[ 1.451481] hub 1-0:1.0: USB hub found
[ 1.451687] hub 1-0:1.0: 1 port detected
[ 1.452191] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 1.452501] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 2
[ 1.452625] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.452881] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.452898] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.452907] usb usb2: Product: xHCI Host Controller
[ 1.452916] usb usb2: Manufacturer: Linux 4.4.167 xhci-hcd
[ 1.452925] usb usb2: SerialNumber: xhci-hcd.10.auto
[ 1.453379] hub 2-0:1.0: USB hub found
[ 1.453442] hub 2-0:1.0: 1 port detected
[ 1.455597] xhci-hcd xhci-hcd.10.auto: remove, state 1
[ 1.455627] usb usb2: USB disconnect, device number 1
[ 1.460019] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 1.460330] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 3
[ 1.460651] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 1.460902] xhci-hcd xhci-hcd.11.auto: irq 231, io mem 0xfe900000
[ 1.461275] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.461325] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.461543] usb usb3: Product: xHCI Host Controller
[ 1.461763] usb usb3: Manufacturer: Linux 4.4.167 xhci-hcd
[ 1.461985] usb usb3: SerialNumber: xhci-hcd.11.auto
[ 1.462639] hub 3-0:1.0: USB hub found
[ 1.462701] hub 3-0:1.0: 1 port detected
[ 1.463112] mmc1: MAN_BKOPS_EN bit is not set
[ 1.463189] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 1.463503] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 4
[ 1.463639] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.463886] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.464035] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.464256] usb usb4: Product: xHCI Host Controller
[ 1.464477] usb usb4: Manufacturer: Linux 4.4.167 xhci-hcd
[ 1.464699] usb usb4: SerialNumber: xhci-hcd.11.auto
[ 1.465363] hub 4-0:1.0: USB hub found
[ 1.465434] hub 4-0:1.0: 1 port detected
[ 1.468604] ehci-platform fe380000.usb: EHCI Host Controller
[ 1.468790] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5
[ 1.468978] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 1.475313] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[ 1.479513] xhci-hcd xhci-hcd.10.auto: Host not halted after 16000 microseconds.
[ 1.479557] xhci-hcd xhci-hcd.10.auto: Host controller not halted, aborting reset.
[ 1.479728] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 1.479860] xhci-hcd xhci-hcd.10.auto: USB bus 2 deregistered
[ 1.479949] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.479985] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.479996] usb usb5: Product: EHCI Host Controller
[ 1.480006] usb usb5: Manufacturer: Linux 4.4.167 ehci_hcd
[ 1.480015] usb usb5: SerialNumber: fe380000.usb
[ 1.480186] mmcblk1: mmc1:0001 AJTD4R 14.6 GiB
[ 1.480531] hub 5-0:1.0: USB hub found
[ 1.480585] hub 5-0:1.0: 1 port detected
[ 1.480759] mmcblk1boot0: mmc1:0001 AJTD4R partition 1 4.00 MiB
[ 1.481181] xhci-hcd xhci-hcd.10.auto: remove, state 1
[ 1.481242] usb usb1: USB disconnect, device number 1
[ 1.481270] mmcblk1boot1: mmc1:0001 AJTD4R partition 2 4.00 MiB
[ 1.481750] mmcblk1rpmb: mmc1:0001 AJTD4R partition 3 4.00 MiB
[ 1.482034] xhci-hcd xhci-hcd.10.auto: USB bus 1 deregistered
[ 1.482289] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 1.482312] trust: 0x000800000 – 0x000c00000 (4 MB)
[ 1.482323] misc: 0x000c00000 – 0x001000000 (4 MB)
[ 1.482334] resource: 0x001000000 – 0x002000000 (16 MB)
[ 1.482345] kernel: 0x002000000 – 0x004000000 (32 MB)
[ 1.482356] boot: 0x004000000 – 0x006000000 (32 MB)
[ 1.482366] recovery: 0x006000000 – 0x00a000000 (64 MB)
[ 1.482377] backup: 0x00a000000 – 0x011000000 (112 MB)
[ 1.482388] security: 0x011000000 – 0x011400000 (4 MB)
[ 1.482399] cache: 0x011400000 – 0x031400000 (512 MB)
[ 1.482410] system: 0x031400000 – 0x0d1400000 (2560 MB)
[ 1.482420] metadata: 0x0d1400000 – 0x0d2400000 (16 MB)
[ 1.482431] vendor: 0x0d2400000 – 0x0f2400000 (512 MB)
[ 1.482442] oem: 0x0f2800000 – 0x112800000 (512 MB)
[ 1.482452] frp: 0x112800000 – 0x112880000 (0 MB)
[ 1.482463] userdata: 0x112880000 – 0x3a3a00000 (10513 MB)
[ 1.482547] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16
[ 1.483455] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.483716] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 1.483937] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 1.492077] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.492228] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.492257] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.492269] usb usb1: Product: EHCI Host Controller
[ 1.492279] usb usb1: Manufacturer: Linux 4.4.167 ehci_hcd
[ 1.492289] usb usb1: SerialNumber: fe3c0000.usb
[ 1.492938] hub 1-0:1.0: USB hub found
[ 1.492996] hub 1-0:1.0: 1 port detected
[ 1.493708] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 1.493958] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 2
[ 1.494137] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 1.549605] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.549672] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.549696] usb usb2: Product: Generic Platform OHCI controller
[ 1.549716] usb usb2: Manufacturer: Linux 4.4.167 ohci_hcd
[ 1.549768] usb usb2: SerialNumber: fe3a0000.usb
[ 1.550719] hub 2-0:1.0: USB hub found
[ 1.550793] hub 2-0:1.0: 1 port detected
[ 1.551982] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.552280] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 6
[ 1.552622] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 1.609765] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.609860] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.609888] usb usb6: Product: Generic Platform OHCI controller
[ 1.609912] usb usb6: Manufacturer: Linux 4.4.167 ohci_hcd
[ 1.609989] usb usb6: SerialNumber: fe3e0000.usb
[ 1.611177] hub 6-0:1.0: USB hub found
[ 1.611301] hub 6-0:1.0: 1 port detected
[ 1.613088] input: adc-keys as /devices/platform/adc-keys/input/input2
[ 1.615783] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.616047] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.616127] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.616244] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.616313] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.616407] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.616470] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.617193] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 1.628805] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.642178] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 1.644314] rockchip-dmc dmc: Failed to get leakage
[ 1.644718] rockchip-dmc dmc: Failed to get pvtm
[ 1.645379] rockchip-dmc dmc: avs=0
[ 1.645946] rockchip-dmc dmc: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[ 1.646022] rockchip-dmc dmc: could not find power_model node
[ 1.653184] devfreq dmc: Couldn’t update frequency transition information.
[ 1.658255] asoc-simple-card rk809-sound: rk817-hifi ↔ ff890000.i2s mapping ok
[ 1.658327] asoc-simple-card rk809-sound: ASoC: no source widget found for MICBIAS1
[ 1.658357] asoc-simple-card rk809-sound: ASoC: Failed to add route MICBIAS1 → direct → Mic Jack
[ 1.658398] asoc-simple-card rk809-sound: ASoC: no sink widget found for IN1P
[ 1.658424] asoc-simple-card rk809-sound: ASoC: Failed to add route Mic Jack → direct → IN1P
[ 1.658448] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOL
[ 1.658473] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOL → direct → Headphone Jack
[ 1.658498] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOR
[ 1.658522] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOR → direct → Headphone Jack
[ 1.660178] input: rockchip,rk809-codec Headphone Jack as /devices/platform/rk809-sound/sound/card1/input3
[ 1.663969] rk808-rtc rk808-rtc: setting system clock to 2017-08-05 09:00:03 UTC (1501923603)
[ 1.665640] It doesn’t contain Rogue gpu
[ 1.680209] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.681950] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.683674] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.686685] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.690335] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
[ 1.696491] ret 1024
[ 1.698028] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘’, rk_ko_ver is ‘5’, built at ‘15:22:04’, on ‘Jul 29 2019’.
[ 1.698896] Mali: Mali device driver loaded
[ 1.699723] ALSA device list:
[ 1.699745] #0: rk-hdmi-dp-sound
[ 1.699757] #1: rockchip,rk809-codec
[ 1.700407] Freeing unused kernel memory: 768K
[ 1.711032] init: init first stage started!
[ 1.711401] init: Using Android DT directory /proc/device-tree/firmware/android/
[ 1.745078] mmc_host mmc2: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0)
[ 1.798639] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 1.835791] init: [libfs_mgr]Failed to get verity metadata ‘/dev/block/by-name/system’: File exists
[ 1.835986] init: [libfs_mgr]Allow invalid metadata when the device is unlocked
[ 1.836261] init: Verity disabled/skipped for ‘/system’
[ 1.843444] EXT4-fs (mmcblk1p11): mounted filesystem with ordered data mode. Opts: barrier=1,inode_readahead_blks=8
[ 1.843570] init: [libfs_mgr]__mount(source=/dev/block/by-name/system,target=/system,type=ext4)=0: Success
[ 1.844588] init: [libfs_mgr]Failed to get verity metadata ‘/dev/block/by-name/vendor’: Success
[ 1.844692] init: [libfs_mgr]Allow invalid metadata when the device is unlocked
[ 1.844852] init: Verity disabled/skipped for ‘/vendor’
[ 1.848210] EXT4-fs (mmcblk1p13): mounted filesystem with ordered data mode. Opts: barrier=1,inode_readahead_blks=8
[ 1.848272] init: [libfs_mgr]__mount(source=/dev/block/by-name/vendor,target=/vendor,type=ext4)=0: Success
[ 1.848383] init: Skipped setting INIT_AVB_VERSION (not in recovery mode)
[ 1.848405] init: Loading SELinux policy
[ 1.884413] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 150
[ 1.890067] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 1.890224] mmc2: new ultra high speed SDR104 SDIO card at address 0001
[ 1.924424] usb 1-1: New USB device found, idVendor=1a40, idProduct=0201
[ 1.924579] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.924605] usb 1-1: Product: USB 2.0 Hub [MTT]
[ 1.926865] hub 1-1:1.0: USB hub found
[ 1.927142] hub 1-1:1.0: 7 ports detected
[ 1.939270] vendor storage:20160801 ret = 0
[ 1.972827] audit: type=1403 audit(1501923603.806:2): policy loaded auid=4294967295 ses=4294967295
[ 1.973267] selinux: SELinux: Loaded policy from /vendor/etc/selinux/precompiled_sepolicy
[ 1.973267]
[ 1.980947] selinux: SELinux: Loaded file_contexts
[ 1.980947]
[ 1.983598] random: init: uninitialized urandom read (40 bytes read, 35 bits of entropy available)
[ 1.985925] init: init second stage started!
[ 1.993425] init: Using Android DT directory /proc/device-tree/firmware/android/
[ 1.994044] init: property_set(“ro.boot.mode”, “emmc”) failed: property already set
[ 1.994163] init: property_set(“ro.boot.verifiedbootstate”, “green”) failed: property already set
[ 1.994205] init: Set boot.mode to emmc
[ 1.996833] selinux: SELinux: Loaded file_contexts
[ 1.996833]
[ 1.997491] selinux: SELinux: Loaded property_contexts from /system/etc/selinux/plat_property_contexts & /vendor/etc/selinux/nonplat_property_contexts.
[ 1.997491]
[ 1.997541] init: Running restorecon…
[ 2.003584] init: waitid failed: No child processes
[ 2.004540] init: Couldn’t load property file: Unable to open ‘/odm/default.prop’: No such file or directory: No such file or directory
[ 2.006062] init: Created socket ‘/dev/socket/property_service’, mode 666, user 0, group 0
[ 2.006267] init: Parsing file /init.rc…
[ 2.006722] init: Added ‘/init.environ.rc’ to import list
[ 2.006767] init: Added ‘/init.usb.rc’ to import list
[ 2.006798] init: Added ‘/init.rk30board.rc’ to import list
[ 2.006857] init: Added ‘/vendor/etc/init/hw/init.rk30board.rc’ to import list
[ 2.006879] init: Added ‘/init.usb.configfs.rc’ to import list
[ 2.006904] init: Added ‘/init.zygote64_32.rc’ to import list
[ 2.008294] init: Parsing file /init.environ.rc…
[ 2.008444] init: Parsing file /init.usb.rc…
[ 2.008984] init: Parsing file /init.rk30board.rc…
[ 2.009255] init: Added ‘init.rk30board.bootmode.emmc.rc’ to import list
[ 2.009295] init: Added ‘init.rockchip.rc’ to import list
[ 2.009317] init: Added ‘init.connectivity.rc’ to import list
[ 2.009340] init: Added ‘init.box.samba.rc’ to import list
[ 2.009368] init: Added ‘init.rk3399pro.rc’ to import list
[ 2.009395] init: Added ‘init.tablet.rc’ to import list
[ 2.009414] init: Added ‘init.car.rc’ to import list
[ 2.009434] init: Added ‘init.optee.rc’ to import list
[ 2.010221] init: Parsing file init.rk30board.bootmode.emmc.rc…
[ 2.010331] init: Parsing file init.rockchip.rc…
[ 2.010441] init: Added ‘init.rk30board.usb.rc’ to import list
[ 2.010486] init: Added ‘init.rk30board.environment.rc’ to import list
[ 2.010507] init: Added ‘/init.debug.rc’ to import list
[ 2.010892] init: Parsing file init.rk30board.usb.rc…
[ 2.011205] init: Parsing file init.rk30board.environment.rc…
[ 2.011293] init: Parsing file /init.debug.rc…
[ 2.011337] init: Unable to open ‘/init.debug.rc’: No such file or directory
[ 2.011364] init: /init.rc: 3: Could not import file ‘/init.debug.rc’: No such file or directory
[ 2.011396] init: Parsing file init.connectivity.rc…
[ 2.011684] init: Parsing file init.box.samba.rc…
[ 2.011731] init: Unable to open ‘init.box.samba.rc’: No such file or directory
[ 2.011756] init: /init.rc: 4: Could not import file ‘init.box.samba.rc’: No such file or directory
[ 2.011803] init: Parsing file init.rk3399pro.rc…
[ 2.011995] init: init.rk3399pro.rc: 25: invalid keyword ‘ioprio’
[ 2.012172] init: Parsing file init.tablet.rc…
[ 2.012214] init: Unable to open ‘init.tablet.rc’: No such file or directory
[ 2.012253] init: /init.rc: 6: Could not import file ‘init.tablet.rc’: No such file or directory
[ 2.012285] init: Parsing file init.car.rc…
[ 2.012324] init: Unable to open ‘init.car.rc’: No such file or directory
[ 2.012348] init: /init.rc: 7: Could not import file ‘init.car.rc’: No such file or directory
[ 2.012378] init: Parsing file init.optee.rc…
[ 2.012415] init: Unable to open ‘init.optee.rc’: No such file or directory
[ 2.012444] init: /init.rc: 8: Could not import file ‘init.optee.rc’: No such file or directory
[ 2.013475] init: Parsing file /vendor/etc/init/hw/init.rk30board.rc…
[ 2.013523] init: Unable to open ‘/vendor/etc/init/hw/init.rk30board.rc’: No such file or directory
[ 2.013551] init: /init.rc: 10: Could not import file ‘/vendor/etc/init/hw/init.rk30board.rc’: No such file or directory
[ 2.013583] init: Parsing file /init.usb.configfs.rc…
[ 2.014276] init: Parsing file /init.zygote64_32.rc…
[ 2.014571] init: Parsing directory /system/etc/init…
[ 2.015420] init: Parsing file /system/etc/init/android.hidl.allocator@1.0-service.rc…
[ 2.015891] init: Parsing file /system/etc/init/atrace.rc…
[ 2.016890] init: Parsing file /system/etc/init/atrace_userdebug.rc…
[ 2.017392] init: Parsing file /system/etc/init/audioserver.rc…
[ 2.017746] init: Parsing file /system/etc/init/bootanim.rc…
[ 2.018033] init: Parsing file /system/etc/init/bootstat.rc…
[ 2.018466] init: Parsing file /system/etc/init/cameraserver.rc…
[ 2.018848] init: Parsing file /system/etc/init/drmserver.rc…
[ 2.019160] init: Parsing file /system/etc/init/dumpstate.rc…
[ 2.019517] init: Parsing file /system/etc/init/gatekeeperd.rc…
[ 2.019817] init: Parsing file /system/etc/init/hwservicemanager.rc…
[ 2.020136] init: Parsing file /system/etc/init/init-debug.rc…
[ 2.020414] init: Parsing file /system/etc/init/installd.rc…
[ 2.020966] init: Parsing file /system/etc/init/keystore.rc…
[ 2.021264] init: Parsing file /system/etc/init/lmkd.rc…
[ 2.021588] init: Parsing file /system/etc/init/logcatd.rc…
[ 2.022040] init: Parsing file /system/etc/init/logd.rc…
[ 2.022521] init: Parsing file /system/etc/init/logtagd.rc…
[ 2.022840] init: Parsing file /system/etc/init/mdnsd.rc…
[ 2.023154] init: Parsing file /system/etc/init/mediadrmserver.rc…
[ 2.023491] init: Parsing file /system/etc/init/mediaextractor.rc…
[ 2.023798] init: Parsing file /system/etc/init/mediametrics.rc…
[ 2.024107] init: Parsing file /system/etc/init/mediaserver.rc…
[ 2.024454] init: Parsing file /system/etc/init/mtpd.rc…
[ 2.024765] init: Parsing file /system/etc/init/netd.rc…
[ 2.025079] init: Parsing file /system/etc/init/perfprofd.rc…
[ 2.025348] init: Parsing file /system/etc/init/racoon.rc…
[ 2.025641] init: Parsing file /system/etc/init/servicemanager.rc…
[ 2.025979] init: Parsing file /system/etc/init/storaged.rc…
[ 2.026256] init: Parsing file /system/etc/init/surfaceflinger.rc…
[ 2.026569] init: Parsing file /system/etc/init/thermalservice.rc…
[ 2.026833] init: Parsing file /system/etc/init/tombstoned.rc…
[ 2.027178] init: Parsing file /system/etc/init/uncrypt.rc…
[ 2.027473] init: Parsing file /system/etc/init/vdc.rc…
[ 2.027756] init: Parsing file /system/etc/init/vold.rc…
[ 2.028087] init: Parsing file /system/etc/init/webview_zygote32.rc…
[ 2.028386] init: Parsing file /system/etc/init/webview_zygote64.rc…
[ 2.028679] init: Parsing file /system/etc/init/wifi-events.rc…
[ 2.029121] init: Parsing file /system/etc/init/wificond.rc…
[ 2.029487] init: Parsing directory /vendor/etc/init…
[ 2.029790] init: Parsing file /vendor/etc/init/android.hardware.audio@2.0-service.rc…
[ 2.030220] init: Parsing file /vendor/etc/init/android.hardware.bluetooth@1.0-service.rc…
[ 2.030831] init: Parsing file /vendor/etc/init/android.hardware.camera.provider@2.4-service.rc…
[ 2.031158] init: Parsing file /vendor/etc/init/android.hardware.cas@1.0-service.rc…
[ 2.031430] init: Parsing file /vendor/etc/init/android.hardware.configstore@1.0-service.rc…
[ 2.031729] init: Parsing file /vendor/etc/init/android.hardware.drm@1.0-service.rc…
[ 2.032122] init: Parsing file /vendor/etc/init/android.hardware.drm@1.0-service.widevine.rc…
[ 2.032399] init: Parsing file /vendor/etc/init/android.hardware.gnss@1.0-service.rc…
[ 2.032712] init: /vendor/etc/init/android.hardware.gnss@1.0-service.rc: 1: ignored duplicate definition of service ‘gnss_service’
[ 2.032740] init: Parsing file /vendor/etc/init/android.hardware.graphics.allocator@2.0-service.rc…
[ 2.033018] init: Parsing file /vendor/etc/init/android.hardware.graphics.composer@2.1-service.rc…
[ 2.033294] init: Parsing file /vendor/etc/init/android.hardware.keymaster@3.0-service.rc…
[ 2.033807] init: Parsing file /vendor/etc/init/android.hardware.light@2.0-service.rc…
[ 2.034157] init: Parsing file /vendor/etc/init/android.hardware.media.omx@1.0-service.rc…
[ 2.034462] init: Parsing file /vendor/etc/init/android.hardware.neuralnetworks@1.0-service-armnn.rc…
[ 2.034726] init: Parsing file /vendor/etc/init/android.hardware.neuralnetworks@1.0-service-ovx.rc…
[ 2.035031] init: Parsing file /vendor/etc/init/android.hardware.power@1.0-service.rc…
[ 2.035337] init: Parsing file /vendor/etc/init/android.hardware.sensors@1.0-service.rc…
[ 2.035717] init: Parsing file /vendor/etc/init/android.hardware.wifi@1.0-service.rc…
[ 2.035988] init: Parsing file /vendor/etc/init/drmservice.rc…
[ 2.036243] init: Parsing file /vendor/etc/init/hostapd.android.rc…
[ 2.036561] init: Parsing file /vendor/etc/init/npu_monitor.rc…
[ 2.036842] init: Parsing file /vendor/etc/init/npu_powerctrl.rc…
[ 2.037161] init: Parsing file /vendor/etc/init/npu_transfer_proxy.rc…
[ 2.037446] init: Parsing file /vendor/etc/init/npu_upgrade.rc…
[ 2.037754] init: Parsing file /vendor/etc/init/rild.rc…
[ 2.038053] init: /vendor/etc/init/rild.rc: 1: ignored duplicate definition of service ‘ril-daemon’
[ 2.038125] init: Parsing file /vendor/etc/init/vndservicemanager.rc…
[ 2.038435] init: Parsing file /odm/etc/init…
[ 2.038477] init: Unable to open ‘/odm/etc/init’: No such file or directory
[ 2.038632] init: processing action (early-init) from (/init.rc:14)
[ 2.047261] init: starting service ‘ueventd’…
[ 2.048044] cgroup: init (1) created nested cgroup for controller “memory” which has incomplete hierarchy support. Nested cgroups may change behavior in the future.
[ 2.048078] cgroup: “memory” requires setting use_hierarchy to 1 on the root
[ 2.056684] init: processing action (early-init) from (init.rockchip.rc:5)
[ 2.063757] init: processing action (wait_for_coldboot_done) from (:0)
[ 2.066571] random: ueventd: uninitialized urandom read (40 bytes read, 38 bits of entropy available)
[ 2.070439] ueventd: ueventd started!
[ 2.070606] ueventd: Parsing file /ueventd.rc…
[ 2.072970] ueventd: Parsing file /vendor/ueventd.rc…
[ 2.073057] ueventd: Unable to open ‘/vendor/ueventd.rc’: No such file or directory
[ 2.073132] ueventd: Parsing file /odm/ueventd.rc…
[ 2.073218] ueventd: Unable to open ‘/odm/ueventd.rc’: No such file or directory
[ 2.073421] ueventd: Parsing file /ueventd.rk30board.rc…
[ 2.074632] ueventd: /ueventd.rk30board.rc: 56: invalid gid ‘net_bt_stack’
[ 2.074717] ueventd: /ueventd.rk30board.rc: 57: invalid gid ‘net_bt_stack’
[ 2.074795] ueventd: /ueventd.rk30board.rc: 58: invalid gid ‘net_bt_stack’
[ 2.074873] ueventd: /ueventd.rk30board.rc: 60: invalid gid ‘net_bt_stack’
[ 2.075719] ueventd: /ueventd.rk30board.rc: 114: invalid gid ‘trace’
[ 2.087964] selinux: SELinux: Loaded file_contexts
[ 2.087964]
[ 2.200497] selinux: SELinux: Loaded file_contexts
[ 2.200497]
[ 2.239404] ueventd: Coldboot took 0.15 seconds
[ 2.246864] init: Command ‘wait_for_coldboot_done’ action=wait_for_coldboot_done (:0) returned 0 took 182ms.
[ 2.246989] init: processing action (mix_hwrng_into_linux_rng) from (:0)
[ 2.247043] init: /dev/hw_random not found
[ 2.247102] init: processing action (set_mmap_rnd_bits) from (:0)
[ 2.247738] init: processing action (set_kptr_restrict) from (:0)
[ 2.247915] init: processing action (keychord_init) from (:0)
[ 2.248039] keychord: using input dev ff420030.pwm for fevent
[ 2.248073] keychord: using input dev rk8xx_pwrkey for fevent
[ 2.248082] keychord: using input dev adc-keys for fevent
[ 2.248122] init: processing action (console_init) from (:0)
[ 2.248201] init: processing action (init) from (/init.rc:44)
[ 2.248442] init: Unable to open ‘/default.prop’: Too many symbolic links encountered
[ 2.255123] init: Unable to open ‘/proc/cpu/alignment’: No such file or directory
[ 2.267818] Registered swp emulation handler
[ 2.268122] init: Unable to open ‘/sys/class/leds/vibrator/trigger’: No such file or directory
[ 2.268183] init: processing action (init) from (/init.environ.rc:2)
[ 2.268542] init: processing action (init) from (/init.rk30board.rc:49)
[ 2.268754] init: Unable to open ‘/sys/module/rockchip_pm/parameters/policy’: No such file or directory
[ 2.269006] init: processing action (init) from (init.rockchip.rc:16)
[ 2.269686] init: processing action (init) from (init.rk30board.environment.rc:1)
[ 2.269832] init: processing action (init) from (init.rk3399pro.rc:30)
[ 2.271581] audit: type=1400 audit(1501923604.103:3): avc: denied { setattr } for pid=1 comm=“init” name=“system_status” dev=“sysfs” ino=21962 scontext=u:r:init:s0 tcontext=u:object_r:sysfs:s0 tclass=lnk_file permissive=1
[ 2.271801] init: processing action (mix_hwrng_into_linux_rng) from (:0)
[ 2.271987] init: /dev/hw_random not found
[ 2.272229] init: processing action (late-init) from (/init.rc:270)
[ 2.272461] init: processing action (queue_property_triggers) from (:0)
[ 2.272702] init: processing action (fs) from (init.rk30board.bootmode.emmc.rc:1)
[ 2.272871] init: Unable to open ‘/sys/block/mmcblk0/bdi/read_ahead_kb’: No such file or directory
[ 2.275265] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/by-name/oem
[ 2.278069] EXT4-fs (mmcblk1p14): Ignoring removed nomblk_io_submit option
[ 2.281273] EXT4-fs (mmcblk1p14): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[ 2.281496] init: [libfs_mgr]check_fs(): mount(/dev/block/by-name/oem,/oem,ext4)=0: Success
[ 2.294619] init: [libfs_mgr]check_fs(): unmount(/oem) succeeded
[ 2.295685] init: [libfs_mgr]Running /system/bin/e2fsck on /dev/block/by-name/oem
[ 2.305074] random: e2fsck: uninitialized urandom read (40 bytes read, 41 bits of entropy available)
[ 2.342130] random: e2fsck: uninitialized urandom read (40 bytes read, 43 bits of entropy available)
[ 2.354750] e2fsck: e2fsck 1.43.3 (04-Sep-2016)
[ 2.354750]
[ 2.354827] e2fsck: oem: clean, 15/32768 files, 6356/131072 blocks
[ 2.354827]
[ 2.357363] EXT4-fs (mmcblk1p14): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 2.357615] init: [libfs_mgr]__mount(source=/dev/block/by-name/oem,target=/oem,type=ext4)=0: Success
[ 2.358415] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/by-name/cache
[ 2.358701] init: [libfs_mgr]Filesystem on /dev/block/by-name/cache was not cleanly shutdown; state flags: 0x1, incompat feature flags: 0x2c6
[ 2.359644] EXT4-fs (mmcblk1p10): Ignoring removed nomblk_io_submit option
[ 2.363531] EXT4-fs (mmcblk1p10): recovery complete
[ 2.363970] EXT4-fs (mmcblk1p10): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[ 2.364221] init: [libfs_mgr]check_fs(): mount(/dev/block/by-name/cache,/cache,ext4)=0: Success
[ 2.380829] init: [libfs_mgr]check_fs(): unmount(/cache) succeeded
[ 2.380949] init: [libfs_mgr]Running /system/bin/e2fsck on /dev/block/by-name/cache
[ 2.384300] random: e2fsck: uninitialized urandom read (40 bytes read, 45 bits of entropy available)
[ 2.410516] random: e2fsck: uninitialized urandom read (40 bytes read, 46 bits of entropy available)
[ 2.446931] e2fsck: e2fsck 1.43.3 (04-Sep-2016)
[ 2.446931]
[ 2.447129] e2fsck: Pass 1: Checking inodes, blocks, and sizes
[ 2.447129]
[ 2.447290] e2fsck: Pass 2: Checking directory structure
[ 2.447290]
[ 2.447493] e2fsck: Pass 3: Checking directory connectivity
[ 2.447493]
[ 2.447748] e2fsck: Pass 4: Checking reference counts
[ 2.447748]
[ 2.447805] e2fsck: Pass 5: Checking group summary information
[ 2.447805]
[ 2.447847] e2fsck: /dev/block/by-name/cache: 27/32768 files (0.0% non-contiguous), 6434/131072 blocks
[ 2.447847]
[ 2.453168] EXT4-fs (mmcblk1p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.453519] init: [libfs_mgr]__mount(source=/dev/block/by-name/cache,target=/cache,type=ext4)=0: Success
[ 2.454670] init: [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/by-name/metadata
[ 2.454861] init: [libfs_mgr]Filesystem on /dev/block/by-name/metadata was not cleanly shutdown; state flags: 0x1, incompat feature flags: 0x2c6
[ 2.456722] EXT4-fs (mmcblk1p12): Ignoring removed nomblk_io_submit option
[ 2.462462] EXT4-fs (mmcblk1p12): recovery complete
[ 2.462989] EXT4-fs (mmcblk1p12): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[ 2.463587] init: [libfs_mgr]check_fs(): mount(/dev/block/by-name/metadata,/metadata,ext4)=0: Success
[ 2.474428] init: [libfs_mgr]check_fs(): unmount(/metadata) succeeded
[ 2.474617] init: [libfs_mgr]Running /system/bin/e2fsck on /dev/block/by-name/metadata
[ 2.477438] random: e2fsck: uninitialized urandom read (40 bytes read, 49 bits of entropy available)
[ 2.502442] random: e2fsck: uninitialized urandom read (40 bytes read, 49 bits of entropy available)
[ 2.505981] audit: type=1400 audit(1501923604.340:4): avc: denied { read } for pid=217 comm=“e2fsck” name=“mmcblk1p12” dev=“tmpfs” ino=9454 scontext=u:r:fsck:s0 tcontext=u:object_r:metadata_block_device:s0 tclass=blk_file permissive=1
[ 2.506079] audit: type=1400 audit(1501923604.340:5): avc: denied { open } for pid=217 comm=“e2fsck” path=“/dev/block/mmcblk1p12” dev=“tmpfs” ino=9454 scontext=u:r:fsck:s0 tcontext=u:object_r:metadata_block_device:s0 tclass=blk_file permissive=1
[ 2.506200] audit: type=1400 audit(1501923604.340:6): avc: denied { write } for pid=217 comm=“e2fsck” name=“mmcblk1p12” dev=“tmpfs” ino=9454 scontext=u:r:fsck:s0 tcontext=u:object_r:metadata_block_device:s0 tclass=blk_file permissive=1
[ 2.506318] audit: type=1400 audit(1501923604.340:7): avc: denied { ioctl } for pid=217 comm=“e2fsck” path=“/dev/block/mmcblk1p12” dev=“tmpfs” ino=9454 ioctlcmd=127c scontext=u:r:fsck:s0 tcontext=u:object_r:metadata_block_device:s0 tclass=blk_file permissive=1
[ 2.529790] e2fsck: e2fsck 1.43.3 (04-Sep-2016)
[ 2.529790]
[ 2.529937] e2fsck: Pass 1: Checking inodes, blocks, and sizes
[ 2.529937]
[ 2.529982] e2fsck: Pass 2: Checking directory structure
[ 2.529982]
[ 2.530024] e2fsck: Pass 3: Checking directory connectivity
[ 2.530024]
[ 2.530111] e2fsck: Pass 4: Checking reference counts
[ 2.530111]
[ 2.530150] e2fsck: Pass 5: Checking group summary information
[ 2.530150]
[ 2.530191] e2fsck: /dev/block/by-name/metadata: 13/4096 files (7.7% non-contiguous), 1171/4096 blocks
[ 2.530191]
[ 2.535032] EXT4-fs (mmcblk1p12): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.535649] init: [libfs_mgr]__mount(source=/dev/block/by-name/metadata,target=/metadata,type=ext4)=0: Success
[ 2.536015] init: [libfs_mgr]Running /system/bin/fsck.f2fs -a /dev/block/by-name/userdata
[ 2.540223] random: fsck.f2fs: uninitialized urandom read (40 bytes read, 52 bits of entropy available)
[ 2.550628] random: fsck.f2fs: uninitialized urandom read (40 bytes read, 52 bits of entropy available)
[ 2.555825] fsck.f2fs: Info: Fix the reported corruption.
[ 2.555825]
[ 2.556006] fsck.f2fs: Info: Segments per section = 1
[ 2.556006]
[ 2.556199] fsck.f2fs: Info: Sections per zone = 1
[ 2.556199]
[ 2.556422] fsck.f2fs: Info: sector size = 512
[ 2.556422]
[ 2.556644] fsck.f2fs: Info: total sectors = 21531648 (10513 MB)
[ 2.556644]
[ 2.556866] fsck.f2fs: Can’t find a valid F2FS superblock at 0x0
[ 2.556866]
[ 2.557092] fsck.f2fs: Can’t find a valid F2FS superblock at 0x1
[ 2.557092]
[ 2.557329] fsck.f2fs: fsck.f2fs terminated by exit(255)
[ 2.557329]
[ 2.560395] F2FS-fs (mmcblk1p16): Magic Mismatch, valid(0xf2f52010) - read(0x95dad9b4)
[ 2.560468] F2FS-fs (mmcblk1p16): Can’t find valid F2FS filesystem in 1th superblock
[ 2.560989] F2FS-fs (mmcblk1p16): Invalid SB checksum offset: 2286099231
[ 2.561207] F2FS-fs (mmcblk1p16): Can’t find valid F2FS filesystem in 2th superblock
[ 2.561461] F2FS-fs (mmcblk1p16): Magic Mismatch, valid(0xf2f52010) - read(0x95dad9b4)
[ 2.561656] F2FS-fs (mmcblk1p16): Can’t find valid F2FS filesystem in 1th superblock
[ 2.561881] F2FS-fs (mmcblk1p16): Invalid SB checksum offset: 2286099231
[ 2.562130] F2FS-fs (mmcblk1p16): Can’t find valid F2FS filesystem in 2th superblock
[ 2.562686] init: [libfs_mgr]__mount(source=/dev/block/by-name/userdata,target=/data,type=f2fs)=-1: Invalid argument
[ 2.562896] init: [libfs_mgr]Running /system/bin/fsck.f2fs -a /dev/block/by-name/userdata
[ 2.597260] fsck.f2fs: Info: Fix the reported corruption.
[ 2.597260]
[ 2.597340] fsck.f2fs: Info: Segments per section = 1
[ 2.597340]
[ 2.597363] fsck.f2fs: Info: Sections per zone = 1
[ 2.597363]
[ 2.597382] fsck.f2fs: Info: sector size = 512
[ 2.597382]
[ 2.597401] fsck.f2fs: Info: total sectors = 21531648 (10513 MB)
[ 2.597401]
[ 2.597421] fsck.f2fs: Can’t find a valid F2FS superblock at 0x0
[ 2.597421]
[ 2.597440] fsck.f2fs: Can’t find a valid F2FS superblock at 0x1
[ 2.597440]
[ 2.597467] fsck.f2fs: fsck.f2fs terminated by exit(255)
[ 2.597467]
[ 2.598880] F2FS-fs (mmcblk1p16): Magic Mismatch, valid(0xf2f52010) - read(0x95dad9b4)
[ 2.598920] F2FS-fs (mmcblk1p16): Can’t find valid F2FS filesystem in 1th superblock
[ 2.599111] F2FS-fs (mmcblk1p16): Invalid SB checksum offset: 2286099231
[ 2.599142] F2FS-fs (mmcblk1p16): Can’t find valid F2FS filesystem in 2th superblock
[ 2.599177] F2FS-fs (mmcblk1p16): Magic Mismatch, valid(0xf2f52010) - read(0x95dad9b4)
[ 2.599198] F2FS-fs (mmcblk1p16): Can’t find valid F2FS filesystem in 1th superblock
[ 2.599207] F2FS-fs (mmcblk1p16): Invalid SB checksum offset: 2286099231
[ 2.599215] F2FS-fs (mmcblk1p16): Can’t find valid F2FS filesystem in 2th superblock
[ 2.599379] init: [libfs_mgr]__mount(source=/dev/block/by-name/userdata,target=/data,type=f2fs)=-1: Invalid argument
[ 2.599784] init: [libfs_mgr]fs_mgr_mount_all(): possibly an encryptable blkdev /dev/block/by-name/userdata for mount /data type f2fs
[ 2.604267] init: Parsing file /odm/etc/init…
[ 2.604353] init: Unable to open ‘/odm/etc/init’: No such file or directory
[ 2.604471] init: Command ‘mount_all fstab.rk30board’ action=fs (init.rk30board.bootmode.emmc.rc:7) returned 2 took 331ms.
[ 2.604645] init: processing action (fs) from (/system/etc/init/logd.rc:18)
[ 2.605445] init: processing action (fs) from (/system/etc/init/wifi-events.rc:17)
[ 2.605576] init: processing action (post-fs) from (/init.rc:303)
[ 2.608112] init: Couldn’t load property file: Unable to open ‘/odm/build.prop’: No such file or directory: No such file or directory
[ 2.608877] init: property_set(“ro.board.platform”, “rk3399pro”) failed: property already set
[ 2.610260] init: property_set(“ro.target.product”, “tablet”) failed: property already set
[ 2.610498] init: Couldn’t load property file: Unable to open ‘/factory/factory.prop’: No such file or directory: No such file or directory
[ 2.612311] init: /recovery not specified in fstab
[ 2.616547] init: starting service ‘logd’…
[ 2.619289] init: starting service ‘servicemanager’…
[ 2.621589] init: starting service ‘hwservicemanager’…
[ 2.622251] init: Created socket ‘/dev/socket/logd’, mode 666, user 1036, group 1036
[ 2.623180] init: Created socket ‘/dev/socket/logdr’, mode 666, user 1036, group 1036
[ 2.624036] init: Created socket ‘/dev/socket/logdw’, mode 222, user 1036, group 1036
[ 2.624259] init: Opened file ‘/proc/kmsg’, flags 0
[ 2.624369] init: Opened file ‘/dev/kmsg’, flags 1
[ 2.625537] init: starting service ‘vndservicemanager’…
[ 2.628952] selinux: SELinux: Skipping restorecon_recursive(/cache)
[ 2.628952]
[ 2.633279] init: processing action (post-fs) from (/init.rk30board.rc:10)
[ 2.633493] selinux: SELinux: Skipping restorecon_recursive(/metadata)
[ 2.633493]
[ 2.637051] init: insmod: open(“/system/lib/modules/ump.ko”) failed: No such file or directory
[ 2.637202] init: insmod: open(“/system/lib/modules/mali.ko”) failed: No such file or directory
[ 2.665963] logd.auditd: start
[ 2.666061] logd.klogd: 2664146618
[ 2.735287] binder: 224:224 ioctl 4018620d 7fd85c6460 returned -22
[ 2.737543] binder: 224:224 ioctl 620a 0 returned -22
[ 2.753802] mali ff9a0000.gpu: leakage=0
[ 2.777338] mali ff9a0000.gpu: temp=43333, pvtm=130041 (130017 + 24)
[ 2.778162] mali ff9a0000.gpu: pvtm-volt-sel=3
[ 2.779173] mali ff9a0000.gpu: avs=0
[ 2.779768] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 2.780075] mali ff9a0000.gpu: Protected mode not available
[ 2.781604] mali ff9a0000.gpu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 2.781696] mali ff9a0000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
[ 2.782516] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 423; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 2.786944] mali ff9a0000.gpu: Probed as mali0
[ 2.787407] init: Command ‘insmod /vendor/lib/modules/mali_kbase.ko’ action=post-fs (/init.rk30board.rc:14) returned 0 took 150ms.
[ 2.788547] init: insmod: open(“/system/lib/modules/rk30_mirroring.ko”) failed: No such file or directory
[ 2.789474] init: finit_module for “/system/lib/modules/rk29-ipp.ko” failed: Exec format error
[ 2.789556] init: insmod: open(“/system/lib/modules/pvrsrvkm.ko”) failed: No such file or directory
[ 2.794157] zram0: detected capacity change from 0 to 2015297536
[ 2.833589] mkswap: Swapspace size: 1968060k, UUID=1b5b3b08-6a7e-406a-b081-d4b2496cde35
[ 2.835673] Adding 1968060k swap on /dev/block/zram0. Priority:-1 extents:1 across:1968060k SS
[ 2.835984] init: processing action (post-fs) from (init.rockchip.rc:34)
[ 2.836202] init: processing action (post-fs) from (/system/etc/init/atrace.rc:3)
[ 2.840629] init: Unable to open ‘/sys/kernel/tracing/tracing_on’: No such file or directory
[ 2.840828] init: processing action (post-fs) from (/system/etc/init/atrace_userdebug.rc:6)
[ 2.842147] init: processing action (late-fs) from (/init.rc:363)
[ 2.843243] init: starting service ‘keymaster-3-0’…
[ 2.844541] init: processing action (post-fs-data) from (/init.rc:371)
[ 2.846078] init: starting service ‘vold’…
[ 2.849879] init: Unable to open ‘/data/system/entropy.dat’: No such file or directory
[ 2.851115] init: Unable to open ‘/data/misc/recovery/ro.build.fingerprint’: No such file or directory
[ 2.853402] init: Created socket ‘/dev/socket/vold’, mode 660, user 0, group 1009
[ 2.854005] init: Created socket ‘/dev/socket/cryptd’, mode 660, user 0, group 1009
[ 2.854520] init: Unable to open ‘/data/misc/recovery/proc/version’: No such file or directory
[ 2.890774] init: starting service ‘exec 1 (/system/bin/vdc --wait cryptfs init_user0)’…
[ 2.892970] init: SVC_EXEC pid 239 (uid 0 gid 0+0 context default) started; waiting…
[ 2.990700] init: Service ‘exec 1 (/system/bin/vdc --wait cryptfs init_user0)’ (pid 239) exited with status 0 waiting took 0.100000 seconds
[ 3.012075] init: starting service ‘exec 2 (/system/bin/tzdatacheck /system/usr/share/zoneinfo /data/misc/zoneinfo)’…
[ 3.013756] init: SVC_EXEC pid 243 (uid 1000 gid 1000+0 context default) started; waiting…
[ 3.033455] init: Service ‘exec 2 (/system/bin/tzdatacheck /system/usr/share/zoneinfo /data/misc/zoneinfo)’ (pid 243) exited with status 0 waiting took 0.021000 seconds
[ 3.033663] init: processing action (post-fs-data) from (/init.usb.rc:6)
[ 3.034612] init: processing action (post-fs-data) from (/init.rk30board.rc:25)
[ 3.035897] init: Unable to find GID for ‘system’: getpwnam failed: No such file or directory
[ 3.036847] init: Unable to open ‘/etc/ppp/pap-secrets’: No such file or directory
[ 3.038264] init: processing action (post-fs-data) from (init.rockchip.rc:38)
[ 3.039056] tmpfs: Bad mount option background_gc
[ 3.039978] init: processing action (post-fs-data) from (init.rk3399pro.rc:37)
[ 3.040160] init: processing action (post-fs-data) from (/system/etc/init/bootstat.rc:3)
[ 3.041083] init: processing action (post-fs-data) from (/system/etc/init/logtagd.rc:4)
[ 3.041822] init: processing action (post-fs-data) from (/vendor/etc/init/hostapd.android.rc:9)
[ 3.042771] init: processing action (load_persist_props_action) from (/init.rc:260)
[ 3.042869] init: Couldn’t load property file: Unable to open ‘/data/local.prop’: No such file or directory: No such file or directory
[ 3.043214] init: starting service ‘logd-reinit’…
[ 3.044577] init: processing action (load_persist_props_action) from (/system/etc/init/logcatd.rc:31)
[ 3.044971] init: processing action (firmware_mounts_complete) from (/init.rc:266)
[ 3.045321] init: processing action (early-boot) from (init.rk3399pro.rc:9)
[ 3.048204] init: [libfs_mgr]Failed to query DM_TABLE_STATUS for system: No such device or address
[ 3.048342] init: [libfs_mgr]Failed to query DM_TABLE_STATUS for vendor: No such device or address
[ 3.048679] init: processing action (early-boot) from (/system/etc/init/installd.rc:5)
[ 3.059261] init: processing action (boot) from (/init.rc:554)
[ 3.060207] init: Unable to open ‘/proc/sys/vm/min_free_order_shift’: No such file or directory
[ 3.062096] logd.daemon: reinit
[ 3.062744] init: Service ‘logd-reinit’ (pid 244) exited with status 0
[ 3.065321] init: starting service ‘gnss_service’…
[ 3.067979] init: starting service ‘hidl_memory’…
[ 3.069944] init: starting service ‘audio-hal-2-0’…
[ 3.071771] init: starting service ‘bluetooth-1-0’…
[ 3.074151] init: starting service ‘camera-provider-2-4’…
[ 3.076983] init: couldn’t write 249 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[ 3.078313] init: starting service ‘cas-hal-1-0’…
[ 3.080324] init: starting service ‘configstore-hal-1-0’…
[ 3.082461] init: starting service ‘drm-hal-1-0’…
[ 3.084706] init: starting service ‘drm-widevine-hal-1-0’…
[ 3.087157] init: starting service ‘gralloc-2-0’…
[ 3.090022] init: starting service ‘hwcomposer-2-1’…
[ 3.092565] init: starting service ‘light-hal-2-0’…
[ 3.095033] init: starting service ‘neuralnetworks_hal_service_armnn’…
[ 3.097586] init: starting service ‘neuralnetworks_hal_service_ovx’…
[ 3.100198] init: starting service ‘power-hal-1-0’…
[ 3.102634] init: starting service ‘sensors-hal-1-0’…
[ 3.105175] init: starting service ‘wifi_hal_legacy’…
[ 3.107864] init: starting service ‘healthd’…
[ 3.109837] init: cannot find ‘/system/bin/displayd’, disabling ‘displayd’: No such file or directory
[ 3.110891] init: starting service ‘lmkd’…
[ 3.113396] init: starting service ‘surfaceflinger’…
[ 3.116091] init: starting service ‘thermalservice’…
[ 3.118254] init: starting service ‘npu_transfer_proxy’…
[ 3.118466] init: Created socket ‘/dev/socket/lmkd’, mode 660, user 1000, group 1000
[ 3.120613] init: starting service ‘npu_upgrade’…
[ 3.122757] init: processing action (boot) from (/init.usb.rc:25)
[ 3.123032] init: processing action (persist.sys.usb.config=* && boot) from (/init.usb.rc:106)
[ 3.123167] init: processing action (boot) from (/init.rk30board.rc:56)
[ 3.127449] init: Unable to open ‘/proc/sys/vm/lazy_vfree_tlb_flush_all_threshold’: No such file or directory
[ 3.136118] init: Failed to bind socket ‘pdx/system/vr/display/client’: No such file or directory
[ 3.148969] selinux: SELinux: Could not stat /metadata/tee: No such file or directory.
[ 3.148969]
[ 3.151523] init: processing action (boot) from (/init.rk30board.rc:343)
[ 3.152106] init: starting service ‘vm_daemon’…
[ 3.152755] type=1400 audit(1501923604.983:8): avc: denied { getattr } for pid=1 comm=“init” path=“/vendor/bin/vm” dev=“mmcblk1p13” ino=223 scontext=u:r:init:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[ 3.153822] init: processing action (boot) from (init.rockchip.rc:56)
[ 3.154035] init: Unable to find GID for ‘net_bt_stack’: getpwnam failed: No such file or directory
[ 3.154070] init: processing action (boot) from (init.rk30board.usb.rc:1)
[ 3.155730] init: Failed to bind socket ‘pdx/system/vr/display/manager’: No such file or directory
[ 3.156317] init: Failed to bind socket ‘pdx/system/vr/display/vsync’: No such file or directory
[ 3.163595] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 3.163681] type=1400 audit(1501923604.983:8): avc: denied { getattr } for pid=1 comm=“init” path=“/vendor/bin/vm” dev=“mmcblk1p13” ino=223 scontext=u:r:init:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[ 3.163701] type=1400 audit(1501923604.996:10): avc: denied { read open } for pid=268 comm=“init” path=“/vendor/bin/vm” dev=“mmcblk1p13” ino=223 scontext=u:r:init:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[ 3.164246] type=1400 audit(1501923604.996:10): avc: denied { read open } for pid=268 comm=“init” path=“/vendor/bin/vm” dev=“mmcblk1p13” ino=223 scontext=u:r:init:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[ 3.164436] type=1400 audit(1501923604.996:11): avc: denied { transition } for pid=268 comm=“init” path=“/vendor/bin/vm” dev=“mmcblk1p13” ino=223 scontext=u:r:init:s0 tcontext=u:r:sudaemon:s0 tclass=proc
[ 3.165480] init: write: cannot expand ‘${ro.serialno}’
[ 3.178710] file system registered
[ 3.183936] using random self ethernet address
[ 3.183967] using random host ethernet address
[ 3.184054] init: Unable to open ‘/config/usb_gadget/g1/functions/rndis.gs4/wceis’: Permission denied
[ 3.186075] init: processing action (boot) from (init.connectivity.rc:2)
[ 3.188484] init: processing action (boot) from (init.rk3399pro.rc:13)
[ 3.193735] init: processing action (boot) from (/system/etc/init/bootstat.rc:57)
[ 3.193817] init: processing action (boot) from (/system/etc/init/dumpstate.rc:1)
[ 3.193916] init: processing action (enable_property_trigger) from (:0)
[ 3.194128] init: processing action (security.perf_harden=1) from (/init.rc:702)
[ 3.194240] init: processing action (ro.debuggable=1) from (/init.rc:730)
[ 3.202039] init: starting service ‘console’…
[ 3.204647] type=1400 audit(1501923604.996:11): avc: denied { transition } for pid=268 comm=“init” path=“/vendor/bin/vm” dev=“mmcblk1p13” ino=223 scontext=u:r:init:s0 tcontext=u:r:sudaemon:s0 tclass=proc
[ 3.205130] init: processing action (ro.boot.storagemedia=emmc) from (/init.rk30board.rc:277)
[ 3.205629] drmboot: disagrees about version of symbol module_layout
[ 3.205798] init: finit_module for “/drmboot.ko” failed: Exec format error
[ 3.205863] init: processing action (ro.boot.mode=normal) from (/init.rk30board.rc:281)
[ 3.206014] init: processing action (ro.factory.hasUMS=false) from (init.rockchip.rc:130)
[ 3.206315] init: processing action (sys.usb.config=mtp,adb && sys.usb.configfs=1) from (init.rk30board.usb.rc:43)
[ 3.206505] init: processing action (sys.usb.config=mtp,adb && sys.usb.configfs=1) from (/init.usb.configfs.rc:33)
[ 3.206661] init: starting service ‘adbd’…
[ 3.208523] init: setpgid failed for console: Operation not permitted
[ 3.209880] init: processing action (defaultcrypto) from (/system/etc/init/vdc.rc:2)
[ 3.210770] init: starting service ‘exec 3 (/system/bin/vdc --wait cryptfs mountdefaultencrypted)’…
[ 3.216723] init: Created socket ‘/dev/socket/adbd’, mode 660, user 1000, group 1000
[ 3.219605] init: SVC_EXEC pid 276 (uid 0 gid 0+0 context default) started; waiting…
[ 3.222796] type=1400 audit(1501923605.026:21): avc: granted { read } for pid=1 comm=“init” name=“ttyFIQ0” dev=“tmpfs” ino=408 scontext=u:r:init:s0 tcontext=u:object_r:serial_device:s0
[ 3.239062] audit: audit_lost=1 audit_rate_limit=20 audit_backlog_limit=64
[ 3.239099] audit: rate limit exceeded
[ 3.249703] type=1400 audit(1501923605.026:21): avc: granted { read } for pid=1 comm=“init” name=“ttyFIQ0” dev=“tmpfs” ino=408 scontext=u:r:init:s0 tcontext=u:object_r:serial_device:s0
[ 3.249749] type=1400 audit(1501923605.026:22): avc: granted { read open } for pid=1 comm=“init” path=“/dev/ttyFIQ0” dev=“tmpfs” ino=408 scontext=u:r:init:s0 tcontext=u:object_r:serial_device:s0
[ 3.249860] type=1400 audit(1501923605.026:22): avc: granted { read open } for pid=1 comm=“init” path=“/dev/ttyFIQ0” dev=“tmpfs” ino=408 scontext=u:r:init:s0 tcontext=u:object_r:serial_device:s0
[ 3.249880] type=1400 audit(1501923605.033:23): avc: denied { read } for pid=266 comm=“npu_transfer_pr” name=“/” dev=“tmpfs” ino=15867 scontext=u:r:npu_transfer_proxy:s0 tcontext=u:object_r:device:s0 tclass=
[ 3.249990] type=1400 audit(1501923605.033:23): avc: denied { read } for pid=266 comm=“npu_transfer_pr” name=“/” dev=“tmpfs” ino=15867 scontext=u:r:npu_transfer_proxy:s0 tcontext=u:object_r:device:s0 tclass=
[ 3.250003] type=1400 audit(1501923605.033:24): avc: denied { open } for pid=266 comm=“npu_transfer_pr” path=“/dev” dev=“tmpfs” ino=15867 scontext=u:r:npu_transfer_proxy:s0 tcontext=u:object_r:device:s0 tclass=
[ 3.250092] type=1400 audit(1501923605.033:24): avc: denied { open } for pid=266 comm=“npu_transfer_pr” path=“/dev” dev=“tmpfs” ino=15867 scontext=u:r:npu_transfer_proxy:s0 tcontext=u:object_r:device:s0 tclass=
[ 3.250109] type=1400 audit(1501923605.040:25): avc: granted { read } for pid=273 comm=“init” name=“ttyFIQ0” dev=“tmpfs” ino=408 scontext=u:r:init:s0 tcontext=u:object_r:serial_device:s0
[ 3.250585] type=1400 audit(1501923605.040:25): avc: granted { read } for pid=273 comm=“init” name=“ttyFIQ0” dev=“tmpfs” ino=408 scontext=u:r:init:s0 tcontext=u:object_r:serial_device:s0
[ 3.250616] type=1400 audit(1501923605.040:26): avc: granted { read open } for pid=273 comm=“init” path=“/dev/ttyFIQ0” dev=“tmpfs” ino=408 scontext=u:r:init:s0 tcontext=u:object_r:serial_device:s0
[ 3.250708] type=1400 audit(1501923605.040:26): avc: granted { read open } for pid=273 comm=“init” path=“/dev/ttyFIQ0” dev=“tmpfs” ino=408 scontext=u:r:init:s0 tcontext=u:object_r:serial_device:s0
[ 3.250720] type=1400 audit(1501923605.046:27): avc: denied { read } for pid=266 comm=“npu_transfer_pr” name=“busnum” dev=“sysfs” ino=21577 scontext=u:r:npu_transfer_proxy:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 3.250802] type=1400 audit(1501923605.046:27): avc: denied { read } for pid=266 comm=“npu_transfer_pr” name=“busnum” dev=“sysfs” ino=21577 scontext=u:r:npu_transfer_proxy:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 3.250820] type=1400 audit(1501923605.050:28): avc: denied { open } for pid=266 comm=“npu_transfer_pr” path=“/sys/devices/platform/fe3a0000.usb/usb2/busnum” dev=“sysfs” ino=21577 scontext=u:r:npu_transfer_proxy:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 3.250902] type=1400 audit(1501923605.050:28): avc: denied { open } for pid=266 comm=“npu_transfer_pr” path=“/sys/devices/platform/fe3a0000.usb/usb2/busnum” dev=“sysfs” ino=21577 scontext=u:r:npu_transfer_proxy:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 3.250915] type=1400 audit(1501923605.050:29): avc: denied { getattr } for pid=266 comm=“npu_transfer_pr” path=“/sys/devices/platforrk3399pro_firefly_aiojd4:/ $ m/fe3a0000.usb/usb2/busnum” dev=“sysfs” ino=21577 scontext=u:r:npu_transfer_proxy:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 3.251003] type=1400 audit(1501923605.050:29): avc: denied { getattr } for pid=266 comm=“npu_transfer_pr” path=“/sys/devices/platform/fe3a0000.usb/usb2/busnum” dev=“sysfs” ino=21577 scontext=u:r:npu_transfer_proxy:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 3.251020] type=1400 audit(1501923605.056:30): avc: denied { read write } for pid=245 comm=“android.hardwar” name=“vndbinder” dev=“tmpfs” ino=1109 scontext=u:r:hal_gnss_default:s0 tcontext=u:object_r:vndbinder_device:s0 tclass=chr_f
[ 3.251124] type=1400 audit(1501923605.056:30): avc: denied { read write } for pid=245 comm=“android.hardwar” name=“vndbinder” dev=“tmpfs” ino=1109 scontext=u:r:hal_gnss_default:s0 tcontext=u:object_r:vndbinder_device:s0 tclass=chr_f
[ 3.251136] type=1400 audit(1501923605.056:31): avc: denied { open } for pid=245 comm=“android.hardwar” path=“/dev/vndbinder” dev=“tmpfs” ino=1109 scontext=u:r:hal_gnss_default:s0 tcontext=u:object_r:vndbinder_device:s0 tclass=chr_f
[ 3.251222] type=1400 audit(1501923605.056:31): avc: denied { open } for pid=245 comm=“android.hardwar” path=“/dev/vndbinder” dev=“tmpfs” ino=1109 scontext=u:r:hal_gnss_default:s0 tcontext=u:object_r:vndbinder_device:s0 tclass=chr_f
[ 3.251239] type=1400 audit(1501923605.056:32): avc: denied { ioctl } for pid=245 comm=“android.hardwar” path=“/dev/vndbinder” dev=“tmpfs” ino=1109 ioctlcmd=6209 scontext=u:r:hal_gnss_default:s0 tcontext=u:object_r:vndbinder_device:s0 tclass=chr_f
[ 3.251322] type=1400 audit(1501923605.056:32): avc: denied { ioctl } for pid=245 comm=“android.hardwar” path=“/dev/vndbinder” dev=“tmpfs” ino=1109 ioctlcmd=6209 scontext=u:r:hal_gnss_default:s0 tcontext=u:object_r:vndbinder_device:s0 tclass=chr_f
[ 3.251335] type=1400 audit(1501923605.060:33): avc: denied { read } for pid=266 comm=“npu_transfer_pr” name=“nvmem” dev=“sysfs” ino=8589 scontext=u:r:npu_transfer_proxy:s0 tcontext=u:object_r:sysfs_armnn:s0 tclass=f
[ 3.251443] type=1400 audit(1501923605.060:33): avc: denied { read } for pid=266 comm=“npu_transfer_pr” name=“nvmem” dev=“sysfs” ino=8589 scontext=u:r:npu_transfer_proxy:s0 tcontext=u:object_r:sysfs_armnn:s0 tclass=f
[ 3.251462] type=1400 audit(1501923605.060:34): avc: denied { open } for pid=266 comm=“npu_transfer_pr” path=“/sys/devices/platform/ff690000.efuse/rockchip-efuse0/nvmem” dev=“sysfs” ino=8589 scontext=u:r:npu_transfer_proxy:s0 tcontext=u:object_r:sysfs_armnn:s0 tclass=f
[ 3.251547] type=1400 audit(1501923605.060:34): avc: denied { open } for pid=266 comm=“npu_transfer_pr” path=“/sys/devices/platform/ff690000.efuse/rockchip-efuse0/nvmem” dev=“sysfs” ino=8589 scontext=u:r:npu_transfer_proxy:s0 tcontext=u:object_r:sysfs_armnn:s0 tclass=f
[ 3.251561] type=1400 audit(1501923605.060:35): avc: denied { getattr } for pid=266 comm=“npu_transfer_pr” path=“/sys/devices/platform/ff690000.efuse/rockchip-efuse0/nvmem” dev=“sysfs” ino=8589 scontext=u:r:npu_transfer_proxy:s0 tcontext=u:object_r:sysfs_armnn:s0 tclass=f
[ 3.251673] type=1400 audit(1501923605.060:35): avc: denied { getattr } for pid=266 comm=“npu_transfer_pr” path=“/sys/devices/platform/ff690000.efuse/rockchip-efuse0/nvmem” dev=“sysfs” ino=8589 scontext=u:r:npu_transfer_proxy:s0 tcontext=u:object_r:sysfs_armnn:s0 tclass=f
[ 3.251691] type=1400 audit(1501923605.060:36): avc: denied { read } for pid=266 comm=“npu_transfer_pr” scontext=u:r:npu_transfer_proxy:s0 tcontext=u:r:init:s0 tclass=f
[ 3.251773] type=1400 audit(1501923605.060:36): avc: denied { read } for pid=266 comm=“npu_transfer_pr” scontext=u:r:npu_transfer_proxy:s0 tcontext=u:r:init:s0 tclass=f
[ 3.251785] type=1400 audit(1501923605.060:37): avc: denied { read } for pid=266 comm=“npu_transfer_pr” scontext=u:r:npu_transfer_proxy:s0 tcontext=u:r:kernel:s0 tclass=f
[ 3.251868] type=1400 audit(1501923605.060:37): avc: denied { read } for pid=266 comm=“npu_transfer_pr” scontext=u:r:npu_transfer_proxy:s0 tcontext=u:r:kernel:s0 tclass=f
[ 3.262895] init: Service ‘exec 3 (/system/bin/vdc --wait cryptfs mountdefaultencrypted)’ (pid 276) exited with status 0 waiting took 0.052000 seconds
[ 3.272909] type=1400 audit(1501923605.063:38): avc: denied { search } for pid=266 comm=“npu_transfer_pr” name=“1” dev=“proc” ino=2168 scontext=u:r:npu_transfer_proxy:s0 tcontext=u:r:init:s0 tclass=
[ 3.273289] type=1400 audit(1501923605.063:38): avc: denied { search } for pid=266 comm=“npu_transfer_pr” name=“1” dev=“proc” ino=2168 scontext=u:r:npu_transfer_proxy:s0 tcontext=u:r:init:s0 tclass=
[ 3.273319] type=1400 audit(1501923605.063:39): avc: denied { open } for pid=266 comm=“npu_transfer_pr” path=“/proc/1/comm” dev=“proc” ino=9542 scontext=u:r:npu_transfer_proxy:s0 tcontext=u:r:init:s0 tclass=f
[ 3.273482] type=1400 audit(1501923605.063:39): avc: denied { open } for pid=266 comm=“npu_transfer_pr” path=“/proc/1/comm” dev=“proc” ino=9542 scontext=u:r:npu_transfer_proxy:s0 tcontext=u:r:init:s0 tclass=f
[ 3.273502] type=1400 audit(1501923605.063:40): avc: denied { getattr } for pid=266 comm=“npu_transfer_pr” path=“/proc/1/comm” dev=“proc” ino=9542 scontext=u:r:npu_transfer_proxy:s0 tcontext=u:r:init:s0 tclass=f
[ 3.273595] type=1400 audit(1501923605.063:40): avc: denied { getattr } for pid=266 comm=“npu_transfer_pr” path=“/proc/1/comm” dev=“proc” ino=9542 scontext=u:r:npu_transfer_proxy:s0 tcontext=u:r:init:s0 tclass=f
[ 3.273633] type=1400 audit(1501923605.063:41): avc: denied { search } for pid=266 comm=“npu_transfer_pr” name=“2” dev=“proc” ino=9619 scontext=u:r:npu_transfer_proxy:s0 tcontext=u:r:kernel:s0 tclass=
[ 3.273715] type=1400 audit(1501923605.063:41): avc: denied { search } for pid=266 comm=“npu_transfer_pr” name=“2” dev=“proc” ino=9619 scontext=u:r:npu_transfer_proxy:s0 tcontext=u:r:kernel:s0 tclass=
[ 3.273728] type=1400 audit(1501923605.063:42): avc: denied { open } for pid=266 comm=“npu_transfer_pr” path=“/proc/2/comm” dev=“proc” ino=9713 scontext=u:r:npu_transfer_proxy:s0 tcontext=u:r:kernel:s0 tclass=f
[ 3.273808] type=1400 audit(1501923605.063:42): avc: denied { open } for pid=266 comm=“npu_transfer_pr” path=“/proc/2/comm” dev=“proc” ino=9713 scontext=u:r:npu_transfer_proxy:s0 tcontext=u:r:kernel:s0 tclass=f
[ 3.273826] type=1400 audit(1501923605.063:43): avc: denied { getattr } for pid=266 comm=“npu_transfer_pr” path=“/proc/2/comm” dev=“proc” ino=9713 scontext=u:r:npu_transfer_proxy:s0 tcontext=u:r:kernel:s0 tclass=f
[ 3.273924] type=1400 audit(1501923605.063:43): avc: denied { getattr } for pid=266 comm=“npu_transfer_pr” path=“/proc/2/comm” dev=“proc” ino=9713 scontext=u:r:npu_transfer_proxy:s0 tcontext=u:r:kernel:s0 tclass=f
[ 3.273937] type=1400 audit(1501923605.073:44): avc: denied { sys_ptrace } for pid=266 comm=“npu_transfer_pr” capability=19 scontext=u:r:npu_transfer_proxy:s0 tcontext=u:r:npu_transfer_proxy:s0 tclass=capabil
[ 3.274022] type=1400 audit(1501923605.073:44): avc: denied { sys_ptrace } for pid=266 comm=“npu_transfer_pr” capability=19 scontext=u:r:npu_transfer_proxy:s0 tcontext=u:r:npu_transfer_proxy:s0 tclass=capabil
[ 3.274043] type=1400 audit(1501923605.073:45): avc: denied { read } for pid=266 comm=“npu_transfer_pr” scontext=u:r:npu_transfer_proxy:s0 tcontext=u:r:ueventd:s0 tclass=f
[ 3.274132] type=1400 audit(1501923605.073:45): avc: denied { read } for pid=266 comm=“npu_transfer_pr” scontext=u:r:npu_transfer_proxy:s0 tcontext=u:r:ueventd:s0 tclass=f
[ 3.274144] type=1400 audit(1501923605.073:46): avc: denied { read } for pid=266 comm=“npu_transfer_pr” scontext=u:r:npu_transfer_proxy:s0 tcontext=u:r:logd:s0 tclass=f
[ 3.280868] healthd: unable to get HAL interface, using defaults
[ 3.296260] healthd: No battery devices found
[ 3.296370] healthd: battery l=100 v=0 t=42.4 h=2 st=2 chg=a
[ 3.297829] read descriptors
[ 3.297880] read strings
[ 3.588660] usb 3-1: new high-speed USB device number 2 using xhci-hcd
[ 3.712417] usb 3-1: New USB device found, idVendor=2207, idProduct=180a
[ 3.712468] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.756221] init: starting service ‘bootanim’…
[ 3.976524] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff1e0000.spi; cannot claim for ff910000.isp
[ 3.976546] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[ 3.976556] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 3.976566] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[ 3.976572] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 3.987383] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 3.987557] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 3.999413] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff1e0000.spi; cannot claim for ff920000.isp
[ 3.999436] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 3.999446] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 3.999456] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 3.999463] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 4.010414] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 4.010646] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 4.047703] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff1e0000.spi; cannot claim for ff910000.isp
[ 4.047754] rockchip-pinctrl pinctrl: pin-75 (ff910000.isp) status -22
[ 4.047786] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 4.047813] RockChip-CamSys ff910000.isp: Error applying setting, reverse things back
[ 4.047844] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 4.059063] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 4.059400] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 4.073701] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff1e0000.spi; cannot claim for ff920000.isp
[ 4.073751] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 4.073781] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 4.073807] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 4.073826] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 4.078722] random: nonblocking pool is initialized
[ 4.084967] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 4.085203] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 4.396262] type=1400 audit(1501923605.073:46): avc: denied { read } for pid=266 comm=“npu_transfer_pr” scontext=u:r:npu_transfer_proxy:s0 tcontext=u:r:logd:s0 tclass=f
[ 4.396358] type=1400 audit(1501923606.230:191): avc: denied { write } for pid=267 comm=“npu_upgrade” name=“/” dev=“tmpfs” ino=16002 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:system_data_file:s0 tclass=
[ 4.397452] type=1400 audit(1501923606.230:191): avc: denied { write } for pid=267 comm=“npu_upgrade” name=“/” dev=“tmpfs” ino=16002 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:system_data_file:s0 tclass=
[ 4.397535] type=1400 audit(1501923606.230:192): avc: denied { add_name } for pid=267 comm=“npu_upgrade” name=“npu.log” scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:system_data_file:s0 tclass=
[ 4.397859] type=1400 audit(1501923606.230:192): avc: denied { add_name } for pid=267 comm=“npu_upgrade” name=“npu.log” scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:system_data_file:s0 tclass=
[ 4.397907] type=1400 audit(1501923606.230:193): avc: denied { create } for pid=267 comm=“npu_upgrade” name=“npu.log” scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:system_data_file:s0 tclass=f
[ 4.398342] type=1400 audit(1501923606.230:193): avc: denied { create } for pid=267 comm=“npu_upgrade” name=“npu.log” scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:system_data_file:s0 tclass=f
[ 4.398388] type=1400 audit(1501923606.230:194): avc: denied { write open } for pid=267 comm=“npu_upgrade” path=“/data/npu.log” dev=“tmpfs” ino=850 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:system_data_file:s0 tclass=f
[ 4.432003] type=1400 audit(1501923606.230:194): avc: denied { write open } for pid=267 comm=“npu_upgrade” path=“/data/npu.log” dev=“tmpfs” ino=850 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:system_data_file:s0 tclass=f
[ 4.432157] type=1400 audit(1501923606.263:195): avc: denied { read } for pid=359 comm=“upgrade_tool” name=“busnum” dev=“sysfs” ino=23024 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 4.432976] type=1400 audit(1501923606.263:195): avc: denied { read } for pid=359 comm=“upgrade_tool” name=“busnum” dev=“sysfs” ino=23024 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 4.433026] type=1400 audit(1501923606.263:196): avc: denied { open } for pid=359 comm=“upgrade_tool” path=“/sys/devices/platform/usb1/fe900000.dwc3/xhci-hcd.11.auto/usb3/3-1/busnum” dev=“sysfs” ino=23024 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 4.434393] type=1400 audit(1501923606.263:196): avc: denied { open } for pid=359 comm=“upgrade_tool” path=“/sys/devices/platform/usb1/fe900000.dwc3/xhci-hcd.11.auto/usb3/3-1/busnum” dev=“sysfs” ino=23024 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 4.434445] type=1400 audit(1501923606.263:197): avc: denied { getattr } for pid=359 comm=“upgrade_tool” path=“/sys/devices/platform/usb1/fe900000.dwc3/xhci-hcd.11.auto/usb3/3-1/busnum” dev=“sysfs” ino=23024 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 4.706942] type=1400 audit(1501923606.263:197): avc: denied { getattr } for pid=359 comm=“upgrade_tool” path=“/sys/devices/platform/usb1/fe900000.dwc3/xhci-hcd.11.auto/usb3/3-1/busnum” dev=“sysfs” ino=23024 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 4.707048] type=1400 audit(1501923606.540:198): avc: denied { read } for pid=366 comm=“upgrade_tool” name=“busnum” dev=“sysfs” ino=23024 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 4.708233] type=1400 audit(1501923606.540:198): avc: denied { read } for pid=366 comm=“upgrade_tool” name=“busnum” dev=“sysfs” ino=23024 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 4.708301] type=1400 audit(1501923606.540:199): avc: denied { open } for pid=366 comm=“upgrade_tool” path=“/sys/devices/platform/usb1/fe900000.dwc3/xhci-hcd.11.auto/usb3/3-1/busnum” dev=“sysfs” ino=23024 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 4.708715] type=1400 audit(1501923606.540:199): avc: denied { open } for pid=366 comm=“upgrade_tool” path=“/sys/devices/platform/usb1/fe900000.dwc3/xhci-hcd.11.auto/usb3/3-1/busnum” dev=“sysfs” ino=23024 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 4.708781] type=1400 audit(1501923606.540:200): avc: denied { getattr } for pid=366 comm=“upgrade_tool” path=“/sys/devices/platform/usb1/fe900000.dwc3/xhci-hcd.11.auto/usb3/3-1/busnum” dev=“sysfs” ino=23024 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 5.122731] fsck.f2fs: Info: Fix the reported corruption.
[ 5.122731]
[ 5.122805] fsck.f2fs: Info: Segments per section = 1
[ 5.122805]
[ 5.122814] fsck.f2fs: Info: Sections per zone = 1
[ 5.122814]
[ 5.122823] fsck.f2fs: Info: sector size = 512
[ 5.122823]
[ 5.122830] fsck.f2fs: Info: total sectors = 21531648 (10513 MB)
[ 5.122830]
[ 5.122838] fsck.f2fs: Info: MKFS version
[ 5.122838]
[ 5.122848] fsck.f2fs: “Linux version 4.4.167 (lkd@mid-server) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #83 SMP PREEMPT Tue Jul 30 14:31:53 CST 2019”
[ 5.122848]
[ 5.122856] fsck.f2fs: Info: FSCK version
[ 5.122856]
[ 5.122865] fsck.f2fs: from “Linux version 4.4.167 (lkd@mid-server) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #83 SMP PREEMPT Tue Jul 30 14:31:53 CST 2019”
[ 5.122865]
[ 5.122874] fsck.f2fs: to “Linux version 4.4.167 (lkd@mid-server) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #83 SMP PREEMPT Tue Jul 30 14:31:53 CST 2019”
[ 5.122874]
[ 5.122882] fsck.f2fs: Info: superblock features = 0 :
[ 5.122882]
[ 5.122891] fsck.f2fs: Info: superblock encrypt level = 0, salt = 00000000000000000000000000000000
[ 5.122891]
[ 5.122898] fsck.f2fs: Info: total FS sectors = 21531648 (10513 MB)
[ 5.122898]
[ 5.122906] fsck.f2fs: Info: CKPT version = 798042fa
[ 5.122906]
[ 5.122914] fsck.f2fs: Info: checkpoint state = 54 : fsck compacted_summary sudden-power-off
[ 5.122914]
[ 5.122922] fsck.f2fs:
[ 5.122922]
[ 5.122930] fsck.f2fs: [FSCK] Unreachable nat entries [Ok..] [0x0]
[ 5.122930]
[ 5.122937] fsck.f2fs: [FSCK] SIT valid block bitmap checking [Ok..]
[ 5.122937]
[ 5.122946] fsck.f2fs: [FSCK] Hard link checking for regular file [Ok..] [0x0]
[ 5.122946]
[ 5.122954] fsck.f2fs: [FSCK] valid_block_count matching with CP [Ok..] [0x2836]
[ 5.122954]
[ 5.122962] fsck.f2fs: [FSCK] valid_node_count matcing with CP (de lookup) [Ok..] [0x528]
[ 5.122962]
[ 5.122970] fsck.f2fs: [FSCK] valid_node_count matcing with CP (nat lookup) [Ok..] [0x528]
[ 5.122970]
[ 5.122978] fsck.f2fs: [FSCK] valid_inode_count matched with CP [Ok..] [0x524]
[ 5.122978]
[ 5.122986] fsck.f2fs: [FSCK] free segment_count matched with CP [Ok..] [0x1446]
[ 5.122986]
[ 5.122995] fsck.f2fs: [FSCK] next block offset is free [Ok..]
[ 5.122995]
[ 5.123003] fsck.f2fs: [FSCK] fixing SIT types
[ 5.123003]
[ 5.123010] fsck.f2fs: [FSCK] other corrupted bugs [Ok..]
[ 5.123010]
[ 5.123018] fsck.f2fs: Info: Write valid nat_bits in checkpoint
[ 5.123018]
[ 5.123026] fsck.f2fs:
[ 5.123026]
[ 5.123033] fsck.f2fs: Done.
[ 5.123033]
[ 5.136947] F2FS-fs (dm-0): Found nat_bits in checkpoint
[ 5.168867] usb 3-1: reset high-speed USB device number 2 using xhci-hcd
[ 5.171010] F2FS-fs (dm-0): Mounted with checkpoint version = 798042fa
[ 5.174369] init: processing action (vold.decrypt=trigger_post_fs_data) from (/init.rc:668)
[ 5.174596] init: processing action (post-fs-data) from (/init.rc:371)
[ 5.205940] init: starting service ‘exec 4 (/system/bin/vdc --wait cryptfs init_user0)’…
[ 5.207024] init: SVC_EXEC pid 374 (uid 0 gid 0+0 context default) started; waiting…
[ 5.218503] init: Service ‘exec 4 (/system/bin/vdc --wait cryptfs init_user0)’ (pid 374) exited with status 0 waiting took 0.012000 seconds
[ 5.218844] selinux: SELinux: Skipping restorecon_recursive(/data)
[ 5.218844]
[ 5.219096] init: starting service ‘exec 5 (/system/bin/tzdatacheck /system/usr/share/zoneinfo /data/misc/zoneinfo)’…
[ 5.220071] init: SVC_EXEC pid 375 (uid 1000 gid 1000+0 context default) started; waiting…
[ 5.229117] init: Service ‘exec 5 (/system/bin/tzdatacheck /system/usr/share/zoneinfo /data/misc/zoneinfo)’ (pid 375) exited with status 0 waiting took 0.010000 seconds
[ 5.229303] init: processing action (post-fs-data) from (/init.usb.rc:6)
[ 5.230842] init: processing action (post-fs-data) from (/init.rk30board.rc:25)
[ 5.231351] init: Unable to find GID for ‘system’: getpwnam failed: No such file or directory
[ 5.231826] init: Unable to open ‘/etc/ppp/pap-secrets’: No such file or directory
[ 5.233214] init: processing action (post-fs-data) from (init.rockchip.rc:38)
[ 5.234956] F2FS-fs (dm-0): acl options not supported
[ 5.234979] F2FS-fs (dm-0): Unrecognized mount option “errors=panic” or missing value
[ 5.236526] init: processing action (post-fs-data) from (init.rk3399pro.rc:37)
[ 5.236704] init: processing action (post-fs-data) from (/system/etc/init/bootstat.rc:3)
[ 5.240509] init: processing action (init.svc.bootanim=running && ro.crypto.type=block && post-fs-data) from (/system/etc/init/bootstat.rc:44)
[ 5.240841] init: starting service ‘exec 6 (/system/bin/bootstat -r post_decrypt_time_elapsed)’…
[ 5.242011] init: SVC_EXEC pid 376 (uid 1000 gid 1007+0 context default) started; waiting…
[ 5.252380] init: Service ‘exec 6 (/system/bin/bootstat -r post_decrypt_time_elapsed)’ (pid 376) exited with status 0 waiting took 0.011000 seconds
[ 5.252570] init: processing action (post-fs-data) from (/system/etc/init/logtagd.rc:4)
[ 5.253936] init: processing action (post-fs-data) from (/vendor/etc/init/hostapd.android.rc:9)
[ 5.254571] init: processing action (vold.decrypt=trigger_load_persist_props) from (/init.rc:663)
[ 5.254623] init: Couldn’t load property file: Unable to open ‘/data/local.prop’: No such file or directory: No such file or directory
[ 5.261281] init: property_set(“ro.persistent_properties.ready”, “true”) failed: property already set
[ 5.261526] init: starting service ‘logd-reinit’…
[ 5.262641] init: property_set(“ro.boottime.logd-reinit”, “5260149670”) failed: property already set
[ 5.262921] init: processing action (vold.decrypt=trigger_restart_framework) from (/init.rc:676)
[ 5.262941] init: ExecStart(update_verifier): Service not found
[ 5.263138] init: cannot find ‘/system/bin/install-recovery.sh’, disabling ‘flash_recovery’: No such file or directory
[ 5.263184] init: cannot find ‘/system/bin/bplus_helper’, disabling ‘bplus_helper’: No such file or directory
[ 5.263489] init: service up_eth0 does not have a SELinux domain defined
[ 5.263536] init: cannot find ‘/vendor/bin/rk_store_keybox’, disabling ‘rk_store_keybox’: No such file or directory
[ 5.263753] init: starting service ‘akmd’…
[ 5.265360] init: starting service ‘ril-daemon’…
[ 5.267308] init: starting service ‘zygote’…
[ 5.269125] init: starting service ‘zygote_secondary’…
[ 5.270851] init: Created socket ‘/dev/socket/zygote’, mode 660, user 0, group 1000
[ 5.271589] init: starting service ‘audioserver’…
[ 5.273508] init: starting service ‘cameraserver’…
[ 5.275018] init: couldn’t write 383 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[ 5.276973] init: Created socket ‘/dev/socket/zygote_secondary’, mode 660, user 0, group 1000
[ 5.277853] init: starting service ‘drm’…
[ 5.283344] init: starting service ‘installd’…
[ 5.286423] init: starting service ‘keystore’…
[ 5.288739] usb 3-1: device descriptor read/64, error -71
[ 5.289029] init: starting service ‘mediadrm’…
[ 5.291164] init: starting service ‘mediaextractor’…
[ 5.297224] init: starting service ‘mediametrics’…
[ 5.300234] init: starting service ‘media’…
[ 5.303429] init: starting service ‘netd’…
[ 5.306672] init: starting service ‘storaged’…
[ 5.307029] init: Created socket ‘/dev/socket/netd’, mode 660, user 0, group 1000
[ 5.308141] init: Created socket ‘/dev/socket/dnsproxyd’, mode 660, user 0, group 3003
[ 5.309932] logd.daemon: reinit
[ 5.312248] init: Created socket ‘/dev/socket/mdns’, mode 660, user 0, group 1000
[ 5.313324] init: Created socket ‘/dev/socket/fwmarkd’, mode 660, user 0, group 3003
[ 5.314844] init: Failed to open file ‘/d/mmc0/mmc0:0001/ext_csd’: No such file or directory
[ 5.317681] init: starting service ‘wificond’…
[ 5.321469] init: starting service ‘mediacodec’…
[ 5.326915] init: starting service ‘drmservice’…
[ 5.329228] init: starting service ‘npu_monitor’…
[ 5.330996] init: Command ‘class_start main’ action=vold.decrypt=trigger_restart_framework (/init.rc:679) returned 0 took 67ms.
[ 5.331630] init: Service ‘logd-reinit’ (pid 377) exited with status 0
[ 5.332214] init: Service ‘akmd’ (pid 378) killed by signal 126
[ 5.333843] init: starting service ‘gatekeeperd’…
[ 5.339467] init: cannot find ‘/system/xbin/perfprofd’, disabling ‘perfprofd’: No such file or directory
[ 5.340392] init: starting service ‘tombstoned’…
[ 5.342786] init: processing action (persist.sys.usb.config=adb && vold.decrypt=trigger_restart_framework) from (/init.rk30board.rc:22)
[ 5.344488] init: processing action (persist.sys.usb.config=adb && vold.decrypt=trigger_restart_framework) from (/init.rk30board.rc:22)
[ 5.357771] init: processing action (sys.usb.config=adb && sys.usb.configfs=1) from (init.rk30board.usb.rc:64)
[ 5.358185] init: processing action (sys.usb.config=adb && sys.usb.configfs=1) from (/init.usb.configfs.rc:18)
[ 5.358283] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/init.usb.configfs.rc:21)
[ 5.367297] init: Created socket ‘/dev/socket/tombstoned_crash’, mode 666, user 1000, group 1000
[ 5.367706] init: Created socket ‘/dev/socket/tombstoned_intercept’, mode 666, user 1000, group 1000
[ 5.367931] init: Created socket ‘/dev/socket/tombstoned_java_trace’, mode 666, user 1000, group 1000
[ 5.382770] init: processing action (sys.usb.config=adb && sys.usb.configfs=1) from (init.rk30board.usb.rc:64)
[ 5.383161] init: processing action (sys.usb.config=adb && sys.usb.configfs=1) from (/init.usb.configfs.rc:18)
[ 5.383258] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/init.usb.configfs.rc:21)
[ 5.383439] init: Unable to write to ‘/config/usb_gadget/g1/UDC’: Device or resource busy
[ 5.475787] selinux: avc: denied { set } for property=telephony.lteOnCdmaDevice pid=379 uid=0 gid=1001 scontext=u:r:rild:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=1
[ 5.475787]
[ 5.512502] usb 3-1: device firmware changed
[ 5.513021] usb 3-1: USB disconnect, device number 2
[ 5.663458] ret = ffffffffffffffff
[ 5.672808] init: processing action (sys.serialno=) from (/init.rk30board.rc:298)
[ 5.672968] init: Sending signal 9 to service ‘adbd’ (pid 274) process group…
[ 5.674045] configfs-gadget gadget: unbind function ‘Function FS Gadget’/ffffffc0f06a1038
[ 5.674275] android_work: did not send uevent (0 0 (null))
[ 5.679119] init: Successfully killed process cgroup uid 0 pid 274 in 6ms
[ 5.682587] init: Service ‘adbd’ (pid 274) killed by signal 9
[ 5.684231] init: Service ‘drmservice’ (pid 396) exited with status 0
[ 5.738667] usb 3-1: new high-speed USB device number 3 using xhci-hcd
[ 5.859127] usb 3-1: New USB device found, idVendor=2207, idProduct=180a
[ 5.859166] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 5.861361] type=1400 audit(1501923606.540:200): avc: denied { getattr } for pid=366 comm=“upgrade_tool” path=“/sys/devices/platform/usb1/fe900000.dwc3/xhci-hcd.11.auto/usb3/3-1/busnum” dev=“sysfs” ino=23024 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 5.861403] type=1400 audit(1501923607.693:201): avc: denied { read } for pid=366 comm=“upgrade_tool” name=“speed” dev=“sysfs” ino=23030 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 5.861710] type=1400 audit(1501923607.693:201): avc: denied { read } for pid=366 comm=“upgrade_tool” name=“speed” dev=“sysfs” ino=23030 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 5.861741] type=1400 audit(1501923607.693:202): avc: denied { open } for pid=366 comm=“upgrade_tool” path=“/sys/devices/platform/usb1/fe900000.dwc3/xhci-hcd.11.auto/usb3/3-1/speed” dev=“sysfs” ino=23030 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 5.861957] type=1400 audit(1501923607.693:202): avc: denied { open } for pid=366 comm=“upgrade_tool” path=“/sys/devices/platform/usb1/fe900000.dwc3/xhci-hcd.11.auto/usb3/3-1/speed” dev=“sysfs” ino=23030 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 5.863321] type=1400 audit(1501923607.693:203): avc: denied { getattr } for pid=366 comm=“upgrade_tool” path=“/sys/devices/platform/usb1/fe900000.dwc3/xhci-hcd.11.auto/usb3/3-1/speed” dev=“sysfs” ino=23030 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 5.932591] type=1400 audit(1501923607.693:203): avc: denied { getattr } for pid=366 comm=“upgrade_tool” path=“/sys/devices/platform/usb1/fe900000.dwc3/xhci-hcd.11.auto/usb3/3-1/speed” dev=“sysfs” ino=23030 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 5.932639] type=1400 audit(1501923607.766:204): avc: denied { execute_no_trans } for pid=444 comm=“HwBinder:247_1” path=“/vendor/bin/sh” dev=“mmcblk1p13” ino=168 scontext=u:r:hal_audio_default:s0 tcontext=u:object_r:vendor_shell_exec:s0 tclass=f
[ 5.944503] type=1400 audit(1501923607.766:204): avc: denied { execute_no_trans } for pid=444 comm=“HwBinder:247_1” path=“/vendor/bin/sh” dev=“mmcblk1p13” ino=168 scontext=u:r:hal_audio_default:s0 tcontext=u:object_r:vendor_shell_exec:s0 tclass=f
[ 5.944559] type=1400 audit(1501923607.776:205): avc: denied { getattr } for pid=444 comm=“sh” path=“/vendor/bin/vm” dev=“mmcblk1p13” ino=223 scontext=u:r:hal_audio_default:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[ 5.945731] type=1400 audit(1501923607.776:205): avc: denied { getattr } for pid=444 comm=“sh” path=“/vendor/bin/vm” dev=“mmcblk1p13” ino=223 scontext=u:r:hal_audio_default:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[ 5.945779] type=1400 audit(1501923607.776:207): avc: denied { read open } for pid=446 comm=“sh” path=“/vendor/bin/vm” dev=“mmcblk1p13” ino=223 scontext=u:r:hal_audio_default:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[ 5.946421] type=1400 audit(1501923607.776:207): avc: denied { read open } for pid=446 comm=“sh” path=“/vendor/bin/vm” dev=“mmcblk1p13” ino=223 scontext=u:r:hal_audio_default:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[ 5.946457] type=1400 audit(1501923607.780:208): avc: denied { execute_no_trans } for pid=446 comm=“sh” path=“/vendor/bin/vm” dev=“mmcblk1p13” ino=223 scontext=u:r:hal_audio_default:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[ 5.989041] audit: audit_lost=145 audit_rate_limit=20 audit_backlog_limit=64
[ 5.989095] audit: rate limit exceeded
[ 5.991604] init: Untracked pid 449 exited with status 0
[ 6.062846] init: Untracked pid 457 exited with status 0
[ 6.674615] init: Untracked pid 460 killed by signal 1
[ 6.683282] init: Untracked pid 452 killed by signal 1
[ 7.087109] capability: warning: `main’ uses 32-bit capabilities (legacy support in use)
[ 7.721060] type=1400 audit(1501923607.780:208): avc: denied { execute_no_trans } for pid=446 comm=“sh” path=“/vendor/bin/vm” dev=“mmcblk1p13” ino=223 scontext=u:r:hal_audio_default:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[ 7.721145] type=1400 audit(1501923609.553:258): avc: denied { read } for pid=496 comm=“upgrade_tool” name=“bConfigurationValue” dev=“sysfs” ino=23013 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 7.724521] type=1400 audit(1501923609.553:258): avc: denied { read } for pid=496 comm=“upgrade_tool” name=“bConfigurationValue” dev=“sysfs” ino=23013 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 7.725221] type=1400 audit(1501923609.553:259): avc: denied { open } for pid=496 comm=“upgrade_tool” path=“/sys/devices/platform/usb1/fe900000.dwc3/xhci-hcd.11.auto/usb3/3-1/bConfigurationValue” dev=“sysfs” ino=23013 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 7.827995] type=1400 audit(1501923609.553:259): avc: denied { open } for pid=496 comm=“upgrade_tool” path=“/sys/devices/platform/usb1/fe900000.dwc3/xhci-hcd.11.auto/usb3/3-1/bConfigurationValue” dev=“sysfs” ino=23013 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 7.829384] type=1400 audit(1501923609.660:260): avc: denied { append } for pid=267 comm=“npu_upgrade” name=“npu.log” dev=“dm-0” ino=1581 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:system_data_file:s0 tclass=f
[ 7.829926] type=1400 audit(1501923609.660:260): avc: denied { append } for pid=267 comm=“npu_upgrade” name=“npu.log” dev=“dm-0” ino=1581 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:system_data_file:s0 tclass=f
[ 7.829982] type=1400 audit(1501923609.660:261): avc: denied { open } for pid=267 comm=“npu_upgrade” path=“/data/npu.log” dev=“dm-0” ino=1581 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:system_data_file:s0 tclass=f
[ 7.859425] type=1400 audit(1501923609.660:261): avc: denied { open } for pid=267 comm=“npu_upgrade” path=“/data/npu.log” dev=“dm-0” ino=1581 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:system_data_file:s0 tclass=f
[ 7.859499] type=1400 audit(1501923609.690:262): avc: denied { getattr } for pid=525 comm=“upgrade_tool” path=“/sys/devices/platform/usb1/fe900000.dwc3/xhci-hcd.11.auto/usb3/3-1/busnum” dev=“sysfs” ino=23031 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 8.207517] init: starting service ‘adbd’…
[ 8.208993] init: property_set(“ro.boottime.adbd”, “8206217841”) failed: property already set
[ 8.209618] init: Created socket ‘/dev/socket/adbd’, mode 660, user 1000, group 1000
[ 8.216921] read descriptors
[ 8.216948] read strings
[ 8.217514] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/init.usb.configfs.rc:21)
[ 8.347933] healthd: battery l=100 v=0 t=42.4 h=2 st=2 chg=a
[ 8.469378] healthd: battery l=100 v=0 t=42.4 h=2 st=2 chg=a
[ 8.649232] init: processing action (sys.sysctl.extra_free_kbytes=) from (/init.rc:692)
[ 9.166796] acc_open
[ 9.166862] acc_release
[ 9.373465] phy_rtl8211f_led_fixup in
[ 9.610395] sdcardfs version 2.0
[ 9.610472] sdcardfs: dev_name → /data/media
[ 9.610479] sdcardfs: options → fsuid=1023,fsgid=1023,multiuser,derive_gid,mask=6,userid=0,gid=1015
[ 9.610485] sdcardfs: mnt → ffffffc0ddc616e0
[ 9.611432] sdcardfs: mounted on top of /data/media type f2fs
[ 9.614025] Remount options were mask=23,gid=9997 for vfsmnt ffffffc0def66aa0.
[ 9.614083] sdcardfs : options - debug:1
[ 9.614093] sdcardfs : options - gid:9997
[ 9.614103] sdcardfs : options - mask:23
[ 9.614994] Remount options were mask=7,gid=9997 for vfsmnt ffffffc0def3a560.
[ 9.615043] sdcardfs : options - debug:1
[ 9.615052] sdcardfs : options - gid:9997
[ 9.615061] sdcardfs : options - mask:7
[ 9.636368] type=1400 audit(1501923609.690:262): avc: denied { getattr } for pid=525 comm=“upgrade_tool” path=“/sys/devices/platform/usb1/fe900000.dwc3/xhci-hcd.11.auto/usb3/3-1/busnum” dev=“sysfs” ino=23031 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 9.636435] type=1400 audit(1564559683.140:263): avc: denied { read } for pid=388 comm=“Binder:388_1” name=“u:object_r:ctsgts_prop:s0” dev=“tmpfs” ino=2122 scontext=u:r:mediaextractor:s0 tcontext=u:object_r:ctsgts_prop:s0 tclass=f
[ 9.636743] type=1400 audit(1564559683.140:263): avc: denied { read } for pid=388 comm=“Binder:388_1” name=“u:object_r:ctsgts_prop:s0” dev=“tmpfs” ino=2122 scontext=u:r:mediaextractor:s0 tcontext=u:object_r:ctsgts_prop:s0 tclass=f
[ 9.636771] type=1400 audit(1564559683.140:264): avc: denied { open } for pid=388 comm=“Binder:388_1” path=“/dev/properties/u:object_r:ctsgts_prop:s0” dev=“tmpfs” ino=2122 scontext=u:r:mediaextractor:s0 tcontext=u:object_r:ctsgts_prop:s0 tclass=f
[ 9.636919] type=1400 audit(1564559683.140:264): avc: denied { open } for pid=388 comm=“Binder:388_1” path=“/dev/properties/u:object_r:ctsgts_prop:s0” dev=“tmpfs” ino=2122 scontext=u:r:mediaextractor:s0 tcontext=u:object_r:ctsgts_prop:s0 tclass=f
[ 9.636961] type=1400 audit(1564559683.140:265): avc: denied { getattr } for pid=388 comm=“Binder:388_1” path=“/dev/properties/u:object_r:ctsgts_prop:s0” dev=“tmpfs” ino=2122 scontext=u:r:mediaextractor:s0 tcontext=u:object_r:ctsgts_prop:s0 tclass=f
[ 9.735761] init: starting service ‘webview_zygote32’…
[ 9.738467] init: Created socket ‘/dev/socket/webview_zygote’, mode 660, user 1053, group 1000
[ 9.909570] type=1400 audit(1564559683.140:265): avc: denied { getattr } for pid=388 comm=“Binder:388_1” path=“/dev/properties/u:object_r:ctsgts_prop:s0” dev=“tmpfs” ino=2122 scontext=u:r:mediaextractor:s0 tcontext=u:object_r:ctsgts_prop:s0 tclass=f
[ 9.909629] type=1400 audit(1564559683.413:266): avc: denied { read } for pid=626 comm=“upgrade_tool” name=“bConfigurationValue” dev=“sysfs” ino=23013 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 9.912696] type=1400 audit(1564559683.413:266): avc: denied { read } for pid=626 comm=“upgrade_tool” name=“bConfigurationValue” dev=“sysfs” ino=23013 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 9.912750] type=1400 audit(1564559683.413:267): avc: denied { open } for pid=626 comm=“upgrade_tool” path=“/sys/devices/platform/usb1/fe900000.dwc3/xhci-hcd.11.auto/usb3/3-1/bConfigurationValue” dev=“sysfs” ino=23013 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 9.929250] type=1400 audit(1564559683.413:267): avc: denied { open } for pid=626 comm=“upgrade_tool” path=“/sys/devices/platform/usb1/fe900000.dwc3/xhci-hcd.11.auto/usb3/3-1/bConfigurationValue” dev=“sysfs” ino=23013 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 9.929300] type=1400 audit(1564559683.433:268): avc: denied { append } for pid=267 comm=“npu_upgrade” name=“npu.log” dev=“dm-0” ino=1581 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:system_data_file:s0 tclass=f
[ 9.929615] type=1400 audit(1564559683.433:268): avc: denied { append } for pid=267 comm=“npu_upgrade” name=“npu.log” dev=“dm-0” ino=1581 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:system_data_file:s0 tclass=f
[ 9.929851] type=1400 audit(1564559683.433:269): avc: denied { open } for pid=267 comm=“npu_upgrade” path=“/data/npu.log” dev=“dm-0” ino=1581 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:system_data_file:s0 tclass=f
[ 9.931504] init: Service ‘npu_upgrade’ (pid 267) exited with status 0
[ 9.988634] usb 1-1.6: new high-speed USB device number 3 using ehci-platform
[ 10.095874] usb 1-1.6: New USB device found, idVendor=2c7c, idProduct=0125
[ 10.095919] usb 1-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 10.095929] usb 1-1.6: Product: Android
[ 10.095938] usb 1-1.6: Manufacturer: Android
[ 10.100816] option 1-1.6:1.0: GSM modem (1-port) converter detected
[ 10.102220] usb 1-1.6: GSM modem (1-port) converter now attached to ttyUSB0
[ 10.107191] option 1-1.6:1.1: GSM modem (1-port) converter detected
[ 10.108263] usb 1-1.6: GSM modem (1-port) converter now attached to ttyUSB1
[ 10.109182] option 1-1.6:1.2: GSM modem (1-port) converter detected
[ 10.115794] usb 1-1.6: GSM modem (1-port) converter now attached to ttyUSB2
[ 10.116645] option 1-1.6:1.3: GSM modem (1-port) converter detected
[ 10.118019] usb 1-1.6: GSM modem (1-port) converter now attached to ttyUSB3
[ 10.119745] qmi_wwan 1-1.6:1.4: cdc-wdm0: USB WDM device
[ 10.119794] qmi_wwan 1-1.6:1.4: Quectel EC21&EC25&EC20 R2.0 work on RawIP mode
[ 10.121095] qmi_wwan 1-1.6:1.4 wwan0: register ‘qmi_wwan’ at usb-fe3c0000.usb-1.6, WWAN/QMI device, b2:ee:ac:fe:c2:72
[ 11.903587] init: Service ‘bootanim’ (pid 327) exited with status 0
[ 12.033521] init: processing action (sys.usb.config=none && sys.usb.configfs=1) from (init.rk30board.usb.rc:31)
[ 12.034002] init: processing action (sys.usb.config=none && sys.usb.configfs=1) from (/init.usb.configfs.rc:1)
[ 12.034267] configfs-gadget gadget: unbind function ‘Function FS Gadget’/ffffffc0f06a1038
[ 12.034356] android_work: did not send uevent (0 0 (null))
[ 12.034694] init: Sending signal 9 to service ‘adbd’ (pid 548) process group…
[ 12.040725] init: Successfully killed process cgroup uid 0 pid 548 in 5ms
[ 12.041485] init: Service ‘adbd’ (pid 548) killed by signal 9
[ 12.042693] init: processing action (sys.boot_completed=1) from (/init.rc:686)
[ 12.042777] init: processing action (sys.boot_completed=1) from (/init.rk30board.rc:252)
[ 12.046867] init: cannot find ‘/system/bin/glgps’, disabling ‘gpsd’: No such file or directory
[ 12.048204] init: starting service ‘mode_switch’…
[ 12.049945] init: processing action (sys.boot_completed=1) from (init.rk3399pro.rc:1)
[ 12.051217] init: processing action (sys.boot_completed=1 && sys.logbootcomplete=1) from (/system/etc/init/bootstat.rc:66)
[ 12.051831] init: starting service ‘exec 7 (/system/bin/bootstat --record_boot_complete)’…
[ 12.052351] type=1400 audit(1564559683.433:269): avc: denied { open } for pid=267 comm=“npu_upgrade” path=“/data/npu.log” dev=“dm-0” ino=1581 scontext=u:r:npu_upgrade:s0 tcontext=u:object_r:system_data_file:s0 tclass=f
[ 12.052394] type=1400 audit(1564559685.553:270): avc: denied { entrypoint } for pid=993 comm=“init” path=“/system/bin/usb_mode_switch.sh” dev=“mmcblk1p11” ino=836 scontext=u:r:mode_switch:s0 tcontext=u:object_r:mode_switch_exec:s0 tclass=f
[ 12.053831] init: SVC_EXEC pid 994 (uid 1000 gid 1007+0 context default) started; waiting…
[ 12.054838] type=1400 audit(1564559685.553:270): avc: denied { entrypoint } for pid=993 comm=“init” path=“/system/bin/usb_mode_switch.sh” dev=“mmcblk1p11” ino=836 scontext=u:r:mode_switch:s0 tcontext=u:object_r:mode_switch_exec:s0 tclass=f
[ 12.054876] type=1400 audit(1564559685.556:271): avc: denied { getattr } for pid=993 comm=“usb_mode_switch” path=“/system/bin/sh” dev=“mmcblk1p11” ino=807 scontext=u:r:mode_switch:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[ 12.058166] type=1400 audit(1564559685.556:271): avc: denied { getattr } for pid=993 comm=“usb_mode_switch” path=“/system/bin/sh” dev=“mmcblk1p11” ino=807 scontext=u:r:mode_switch:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[ 12.058213] type=1400 audit(1564559685.560:272): avc: denied { read } for pid=993 comm=“usb_mode_switch” path=“/system/bin/sh” dev=“mmcblk1p11” ino=807 scontext=u:r:mode_switch:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[ 12.064026] type=1400 audit(1564559685.560:272): avc: denied { read } for pid=993 comm=“usb_mode_switch” path=“/system/bin/sh” dev=“mmcblk1p11” ino=807 scontext=u:r:mode_switch:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[ 12.064087] type=1400 audit(1564559685.566:273): avc: denied { read } for pid=993 comm=“usb_mode_switch” name=“usb_mode_switch.sh” dev=“mmcblk1p11” ino=836 scontext=u:r:mode_switch:s0 tcontext=u:object_r:mode_switch_exec:s0 tclass=f
[ 12.064323] type=1400 audit(1564559685.566:273): avc: denied { read } for pid=993 comm=“usb_mode_switch” name=“usb_mode_switch.sh” dev=“mmcblk1p11” ino=836 scontext=u:r:mode_switch:s0 tcontext=u:object_r:mode_switch_exec:s0 tclass=f
[ 12.064353] type=1400 audit(1564559685.566:274): avc: denied { open } for pid=993 comm=“usb_mode_switch” path=“/system/bin/usb_mode_switch.sh” dev=“mmcblk1p11” ino=836 scontext=u:r:mode_switch:s0 tcontext=u:object_r:mode_switch_exec:s0 tclass=f
[ 12.066735] type=1400 audit(1564559685.566:274): avc: denied { open } for pid=993 comm=“usb_mode_switch” path=“/system/bin/usb_mode_switch.sh” dev=“mmcblk1p11” ino=836 scontext=u:r:mode_switch:s0 tcontext=u:object_r:mode_switch_exec:s0 tclass=f
[ 12.066781] type=1400 audit(1564559685.570:275): avc: denied { getattr } for pid=995 comm=“usb_mode_switch” path=“/system/bin/toybox” dev=“mmcblk1p11” ino=1008 scontext=u:r:mode_switch:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[ 12.067391] type=1400 audit(1564559685.570:275): avc: denied { getattr } for pid=995 comm=“usb_mode_switch” path=“/system/bin/toybox” dev=“mmcblk1p11” ino=1008 scontext=u:r:mode_switch:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[ 12.067436] type=1400 audit(1564559685.570:276): avc: denied { execute } for pid=995 comm=“usb_mode_switch” name=“toybox” dev=“mmcblk1p11” ino=1008 scontext=u:r:mode_switch:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[ 12.067565] type=1400 audit(1564559685.570:276): avc: denied { execute } for pid=995 comm=“usb_mode_switch” name=“toybox” dev=“mmcblk1p11” ino=1008 scontext=u:r:mode_switch:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[ 12.067585] type=1400 audit(1564559685.570:277): avc: denied { read open } for pid=995 comm=“usb_mode_switch” path=“/system/bin/toybox” dev=“mmcblk1p11” ino=1008 scontext=u:r:mode_switch:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[ 12.067667] type=1400 audit(1564559685.570:277): avc: denied { read open } for pid=995 comm=“usb_mode_switch” path=“/system/bin/toybox” dev=“mmcblk1p11” ino=1008 scontext=u:r:mode_switch:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[ 12.067680] type=1400 audit(1564559685.570:278): avc: denied { execute_no_trans } for pid=995 comm=“usb_mode_switch” path=“/system/bin/toybox” dev=“mmcblk1p11” ino=1008 scontext=u:r:mode_switch:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[ 12.072610] init: Service ‘exec 7 (/system/bin/bootstat --record_boot_complete)’ (pid 994) exited with status 0 waiting took 0.021000 seconds
[ 12.073129] init: starting service ‘exec 8 (/system/bin/bootstat --record_boot_reason)’…
[ 12.074373] init: SVC_EXEC pid 996 (uid 1000 gid 1007+0 context default) started; waiting…
[ 12.086548] type=1400 audit(1564559685.570:278): avc: denied { execute_no_trans } for pid=995 comm=“usb_mode_switch” path=“/system/bin/toybox” dev=“mmcblk1p11” ino=1008 scontext=u:r:mode_switch:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[ 12.086599] type=1400 audit(1564559685.590:279): avc: denied { getattr } for pid=993 comm=“usb_mode_switch” path=“/sys/devices/platform/usb0/dwc3_mode” dev=“sysfs” ino=20026 scontext=u:r:mode_switch:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 12.086805] type=1400 audit(1564559685.590:279): avc: denied { getattr } for pid=993 comm=“usb_mode_switch” path=“/sys/devices/platform/usb0/dwc3_mode” dev=“sysfs” ino=20026 scontext=u:r:mode_switch:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 12.086822] type=1400 audit(1564559685.590:280): avc: denied { write } for pid=993 comm=“usb_mode_switch” name=“dwc3_mode” dev=“sysfs” ino=20026 scontext=u:r:mode_switch:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 12.086922] type=1400 audit(1564559685.590:280): avc: denied { write } for pid=993 comm=“usb_mode_switch” name=“dwc3_mode” dev=“sysfs” ino=20026 scontext=u:r:mode_switch:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 12.086936] type=1400 audit(1564559685.590:281): avc: denied { open } for pid=993 comm=“usb_mode_switch” path=“/sys/devices/platform/usb0/dwc3_mode” dev=“sysfs” ino=20026 scontext=u:r:mode_switch:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 12.092707] init: Service ‘exec 8 (/system/bin/bootstat --record_boot_reason)’ (pid 996) exited with status 0 waiting took 0.019000 seconds
[ 12.094761] init: starting service ‘exec 9 (/system/bin/bootstat --record_time_since_factory_reset)’…
[ 12.098078] init: SVC_EXEC pid 997 (uid 1000 gid 1007+0 context default) started; waiting…
[ 12.100585] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 12.100981] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 7
[ 12.102062] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 12.102100] xhci-hcd xhci-hcd.10.auto: irq 230, io mem 0xfe800000
[ 12.102318] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002
[ 12.102329] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 12.102336] usb usb7: Product: xHCI Host Controller
[ 12.102343] usb usb7: Manufacturer: Linux 4.4.167 xhci-hcd
[ 12.102349] usb usb7: SerialNumber: xhci-hcd.10.auto
[ 12.102853] hub 7-0:1.0: USB hub found
[ 12.102882] hub 7-0:1.0: 1 port detected
[ 12.103067] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 12.103445] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 8
[ 12.103507] usb usb8: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 12.103577] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003
[ 12.103584] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 12.103590] usb usb8: Product: xHCI Host Controller
[ 12.103596] usb usb8: Manufacturer: Linux 4.4.167 xhci-hcd
[ 12.103601] usb usb8: SerialNumber: xhci-hcd.10.auto
[ 12.104484] hub 8-0:1.0: USB hub found
[ 12.104515] hub 8-0:1.0: 1 port detected
[ 12.104707] rockchip-dwc3 usb0: USB HOST connected
[ 12.104779] rockchip-dwc3 usb0: set new mode successfully
[ 12.105989] init: Service ‘mode_switch’ (pid 993) exited with status 0
[ 12.118638] init: Service ‘exec 9 (/system/bin/bootstat --record_time_since_factory_reset)’ (pid 997) exited with status 0 waiting took 0.025000 seconds
[ 12.119553] init: starting service ‘exec 10 (/system/bin/bootstat -l)’…
[ 12.120694] init: SVC_EXEC pid 998 (uid 1000 gid 1007+0 context default) started; waiting…
[ 12.139300] init: Service ‘exec 10 (/system/bin/bootstat -l)’ (pid 998) exited with status 0 waiting took 0.020000 seconds
[ 12.139585] init: processing action (sys.boot_completed=1 && sys.wifitracing.started=0) from (/system/etc/init/wifi-events.rc:20)
[ 12.190779] init: Command ‘mkdir /sys/kernel/debug/tracing/instances/wifi 711’ action=sys.boot_completed=1 && sys.wifitracing.started=0 (/system/etc/init/wifi-events.rc:22) returned 0 took 51ms.
[ 12.231503] init: processing action (init.svc.adbd=stopped) from (init.rk30board.usb.rc:35)
[ 12.231684] init: processing action (init.svc.adbd=stopped) from (/init.usb.configfs.rc:15)
[ 12.233695] init: processing action (sys.usb.config=adb && sys.usb.configfs=1) from (init.rk30board.usb.rc:64)
[ 12.233978] init: processing action (sys.usb.config=adb && sys.usb.configfs=1) from (/init.usb.configfs.rc:18)
[ 12.234099] init: starting service ‘adbd’…
[ 12.235944] init: property_set(“ro.boottime.adbd”, “12232856745”) failed: property already set
[ 12.237004] init: Created socket ‘/dev/socket/adbd’, mode 660, user 1000, group 1000
[ 12.241846] read descriptors
[ 12.241987] read strings
[ 12.243216] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) from (/init.usb.configfs.rc:21)
[ 12.244127] dwc3 fe800000.dwc3: failed to enable ep0out
[ 12.504218] type=1400 audit(1564559685.590:281): avc: denied { open } for pid=993 comm=“usb_mode_switch” path=“/sys/devices/platform/usb0/dwc3_mode” dev=“sysfs” ino=20026 scontext=u:r:mode_switch:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 12.504266] type=1400 audit(1564559686.006:282): avc: denied { getattr } for pid=379 comm=“rild” path=“/dev/cdc-wdm0” dev=“tmpfs” ino=17814 scontext=u:r:rild:s0 tcontext=u:object_r:device:s0 tclass=chr_f
[ 12.622107] usb 4-1: new SuperSpeed USB device number 2 using xhci-hcd
[ 12.636806] usb 4-1: New USB device found, idVendor=2207, idProduct=1808
[ 12.636846] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 12.636857] usb 4-1: Product: rk3xxx
[ 12.636866] usb 4-1: Manufacturer: rockchip
[ 12.636874] usb 4-1: SerialNumber: 0123456789ABCDEF
[ 13.864970] type=1400 audit(1564559686.006:282): avc: denied { getattr } for pid=379 comm=“rild” path=“/dev/cdc-wdm0” dev=“tmpfs” ino=17814 scontext=u:r:rild:s0 tcontext=u:object_r:device:s0 tclass=chr_f
[ 13.865149] type=1400 audit(1564559687.366:283): avc: denied { connectto } for pid=245 comm=“gnss@1.0-servic” path=0072696C642D677073 scontext=u:r:hal_gnss_default:s0 tcontext=u:r:rild:s0 tclass=unix_stream_soc
[ 13.865971] type=1400 audit(1564559687.366:283): avc: denied { connectto } for pid=245 comm=“gnss@1.0-servic” path=0072696C642D677073 scontext=u:r:hal_gnss_default:s0 tcontext=u:r:rild:s0 tclass=unix_stream_soc
[ 13.866027] type=1400 audit(1564559687.366:284): avc: denied { connectto } for pid=245 comm=“gnss@1.0-servic” path=0072696C642D6E6D6561 scontext=u:r:hal_gnss_default:s0 tcontext=u:r:rild:s0 tclass=unix_stream_soc
[ 14.630375] type=1400 audit(1564559687.366:284): avc: denied { connectto } for pid=245 comm=“gnss@1.0-servic” path=0072696C642D6E6D6561 scontext=u:r:hal_gnss_default:s0 tcontext=u:r:rild:s0 tclass=unix_stream_soc
[ 14.630427] type=1400 audit(1564559688.133:285): avc: denied { getattr } for pid=1262 comm=“sh” path=“/vendor/bin/vm” dev=“mmcblk1p13” ino=223 scontext=u:r:system_app:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[ 14.636185] type=1400 audit(1564559688.133:285): avc: denied { getattr } for pid=1262 comm=“sh” path=“/vendor/bin/vm” dev=“mmcblk1p13” ino=223 scontext=u:r:system_app:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[ 14.636238] type=1400 audit(1564559688.140:287): avc: denied { read open } for pid=1263 comm=“sh” path=“/vendor/bin/vm” dev=“mmcblk1p13” ino=223 scontext=u:r:system_app:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[ 14.637174] type=1400 audit(1564559688.140:287): avc: denied { read open } for pid=1263 comm=“sh” path=“/vendor/bin/vm” dev=“mmcblk1p13” ino=223 scontext=u:r:system_app:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[ 14.637212] type=1400 audit(1564559688.140:288): avc: denied { execute_no_trans } for pid=1263 comm=“sh” path=“/vendor/bin/vm” dev=“mmcblk1p13” ino=223 scontext=u:r:system_app:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[ 14.677822] init: Untracked pid 1266 exited with status 0
[ 14.720816] init: Untracked pid 1274 exited with status 0
[ 14.742209] selinux: avc: denied { set } for property=devicetest.bootcomplete pid=1198 uid=1000 gid=1000 scontext=u:r:system_app:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=1
[ 14.742209]
[ 14.816939] type=1400 audit(1564559688.140:288): avc: denied { execute_no_trans } for pid=1263 comm=“sh” path=“/vendor/bin/vm” dev=“mmcblk1p13” ino=223 scontext=u:r:system_app:s0 tcontext=u:object_r:su_exec:s0 tclass=f
[ 14.817126] type=1400 audit(1564559688.320:315): avc: denied { open } for pid=1215 comm=“.update.service” path=“/dev/properties/u:object_r:serialno_prop:s0” dev=“tmpfs” ino=2136 scontext=u:r:system_app:s0 tcontext=u:object_r:serialno_prop:s0 tclass=f
[ 14.819082] type=1400 audit(1564559688.320:315): avc: denied { open } for pid=1215 comm=“.update.service” path=“/dev/properties/u:object_r:serialno_prop:s0” dev=“tmpfs” ino=2136 scontext=u:r:system_app:s0 tcontext=u:object_r:serialno_prop:s0 tclass=f
[ 14.819271] type=1400 audit(1564559688.320:316): avc: denied { getattr } for pid=1215 comm=“.update.service” path=“/dev/properties/u:object_r:serialno_prop:s0” dev=“tmpfs” ino=2136 scontext=u:r:system_app:s0 tcontext=u:object_r:serialno_prop:s0 tclass=f
[ 14.973046] audit: audit_lost=172 audit_rate_limit=20 audit_backlog_limit=64
[ 14.973075] audit: rate limit exceeded
[ 16.000707] type=1400 audit(1564559688.320:316): avc: denied { getattr } for pid=1215 comm=“.update.service” path=“/dev/properties/u:object_r:serialno_prop:s0” dev=“tmpfs” ino=2136 scontext=u:r:system_app:s0 tcontext=u:object_r:serialno_prop:s0 tclass=f
[ 16.000786] type=1400 audit(1564559689.503:340): avc: denied { execute_no_trans } for pid=1461 comm=“rild” path=“/vendor/bin/sh” dev=“mmcblk1p13” ino=168 scontext=u:r:rild:s0 tcontext=u:object_r:vendor_shell_exec:s0 tclass=f
[ 16.019432] type=1400 audit(1564559689.503:340): avc: denied { execute_no_trans } for pid=1461 comm=“rild” path=“/vendor/bin/sh” dev=“mmcblk1p13” ino=168 scontext=u:r:rild:s0 tcontext=u:object_r:vendor_shell_exec:s0 tclass=f
[ 16.019511] type=1400 audit(1564559689.520:341): avc: denied { write } for pid=1461 comm=“sh” name=“control” dev=“sysfs” ino=23318 scontext=u:r:rild:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 16.044797] type=1400 audit(1564559689.520:341): avc: denied { write } for pid=1461 comm=“sh” name=“control” dev=“sysfs” ino=23318 scontext=u:r:rild:s0 tcontext=u:object_r:sysfs:s0 tclass=f
[ 16.044875] type=1400 audit(1564559689.546:342): avc: denied { read } for pid=379 comm=“rild” name=“rild” dev=“dm-0” ino=1329 scontext=u:r:rild:s0 tcontext=u:object_r:system_data_file:s0 tclass=
[ 16.059404] type=1400 audit(1564559689.546:342): avc: denied { read } for pid=379 comm=“rild” name=“rild” dev=“dm-0” ino=1329 scontext=u:r:rild:s0 tcontext=u:object_r:system_data_file:s0 tclass=
[ 16.059489] type=1400 audit(1564559689.563:343): avc: denied { write } for pid=1463 comm=“sh” name=“preferred_network_mode” dev=“dm-0” ino=1330 scontext=u:r:rild:s0 tcontext=u:object_r:system_data_file:s0 tclass=f
[ 16.060163] type=1400 audit(1564559689.563:343): avc: denied { write } for pid=1463 comm=“sh” name=“preferred_network_mode” dev=“dm-0” ino=1330 scontext=u:r:rild:s0 tcontext=u:object_r:system_data_file:s0 tclass=f
[ 16.060211] type=1400 audit(1564559689.563:344): avc: denied { open } for pid=1463 comm=“sh” path=“/data/misc/rild/preferred_network_mode” dev=“dm-0” ino=1330 scontext=u:r:rild:s0 tcontext=u:object_r:system_data_file:s0 tclass=f
[ 16.304732] type=1400 audit(1564559689.563:344): avc: denied { open } for pid=1463 comm=“sh” path=“/data/misc/rild/preferred_network_mode” dev=“dm-0” ino=1330 scontext=u:r:rild:s0 tcontext=u:object_r:system_data_file:s0 tclass=f
[ 16.304787] type=1400 audit(1564559689.806:345): avc: denied { use } for pid=498 comm=“Binder:498_5” path=“/dev/null” dev=“tmpfs” ino=9422 scontext=u:r:system_server:s0 tcontext=u:r:sudaemon:s0 tclass
[ 16.307143] type=1400 audit(1564559689.806:345): avc: denied { use } for pid=498 comm=“Binder:498_5” path=“/dev/null” dev=“tmpfs” ino=9422 scontext=u:r:system_server:s0 tcontext=u:r:sudaemon:s0 tclass
[ 16.307755] type=1400 audit(1564559689.806:346): avc: denied { call } for pid=498 comm=“Binder:498_3” scontext=u:r:system_server:s0 tcontext=u:r:sudaemon:s0 tclass=bin
[ 16.355180] init: Untracked pid 1269 exited with status 0
[ 16.358058] init: Untracked pid 1277 exited with status 0
