RK3399一直重启
参考firefly rk3399设计了板子,sdk版本为firefly rk3399 android7.1 ,烧录固件后,板子重启,log如下,请问是什么原因?
U-Boot 2014.10-RK3399-06 (Sep 17 2019 - 08:54:39)
CPU: rk3399
cpu version = 0
CPU’s clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
aclk_periph_l0 = 100000000HZ, hclk_periph_l0 = 100000000HZ, pclk_periph_l0 = 50000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
Reserve memory for trust os.
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
remotectl v0.1
pwm freq=0xb8320
pwm_freq_nstime=0x52d
Load FDT from resource image.
power key: bank-0 pin-5
can’t find dts node for fixed
pmic:rk808
can’t find dts node for pwm1
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
#Boot ver: 2019-09-17#1.09
empty serial no.
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
failed to find phy node
failed to find panel driver
no fuel gauge found
can’t find dts node for deviceinfo
dw_rk_hdmi_register:fail to read deviceinfo
hdmi baseparamer -1x-1@-1–1
rockchip_panel_deinit: failed to find panel deinit funcs
failed to display kernel logo
checkKey
vbus = 1
got recovery cmd from misc.
load fdt from resouce.
vendor read error!
Set oem_unlocked=0Secure Boot state: 0
kernel @ 0x00280000 (0x0125a008)
ramdisk @ 0x04bf0000 (0x007b1d9c)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000004600000, end 0000000004616416 … OK
Add bank:000000000a200000, 00000000ede00000
[ 0.000000] Linux version 4.4.103 (panda@panda) (gcc version 4.9 20150123 (prerelease) (GCC) ) #1 SMP PREEMPT Mon Sep 16 19:30:45 CST 2019
[ 0.000000] cma: Reserved 16 MiB at 0x00000000f7000000
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f6eed000 s45504 r8192 d32320 u86016
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 991752
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x0000C000@0x00010000(kernel),0x00010000@0x0001C000(boot),0x00010000@0x0002C000(recovery),0x00038000@0x0003C000(backup),0x00040000@0x00074000(cache),0x00300000@0x000B4000(system),0x00008000@0x003B4000(metadata),0x00002000@0x003BC000(baseparamer),-@0x003BE000(userdata) storagemedia=emmc uboot_logo=0x02000000@0xf5c00000 loader.timestamp=2019-09-17_08:54:39 hdmi.vic=-1 SecureBootCheckOk=0
[ 0.000000] software IO TLB [mem 0xf6ea5000-0xf6ee5000] (0MB) mapped at [ffffffc0f6ea5000-ffffffc0f6ee4fff]
[ 0.000000] Memory: 3912624K/4030464K available (11006K kernel code, 1640K rwdata, 5256K rodata, 832K init, 1073K bss, 101456K reserved, 16384K cma-reserved)
[ 0.000000] .init : 0xffffff8009070000 - 0xffffff8009140000 ( 832 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008b40000 ( 11008 KB)
[ 0.000000] .rodata : 0xffffff8008b40000 - 0xffffff8009070000 ( 5312 KB)
[ 0.000000] .data : 0xffffff8009140000 - 0xffffff80092da008 ( 1641 KB)
[ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc3e00000 ( 61 MB actual)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc0f8000000 ( 3966 MB)
[ 0.009944] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.021229] pid_max: default: 32768 minimum: 301
[ 0.026383] Security Framework initialized
[ 0.030889] SELinux: Initializing.
[ 0.034808] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.042174] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.050833] Initializing cgroup subsys freezer
[ 0.055731] Initializing cgroup subsys debug
[ 0.061337] sched-energy: Sched-energy-costs installed from DT
[ 0.067761] CPU0: update cpu_capacity 401
[ 0.072218] ASID allocator initialised with 65536 entries
[ 0.095034] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.105130] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.128798] Detected VIPT I-cache on CPU1
[ 0.128830] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.128870] CPU1: using LPI pending table @0x00000000f1c00000
[ 0.128914] CPU1: update cpu_capacity 401
[ 0.128917] CPU1: Booted secondary processor [410fd034]
[ 0.138791] Detected VIPT I-cache on CPU2
[ 0.138811] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.138843] CPU2: using LPI pending table @0x00000000f1c30000
[ 0.138871] CPU2: update cpu_capacity 401
[ 0.138874] CPU2: Booted secondary processor [410fd034]
[ 0.148829] Detected VIPT I-cache on CPU3
[ 0.148847] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.148879] CPU3: using LPI pending table @0x00000000f1c70000
[ 0.148906] CPU3: update cpu_capacity 401
[ 0.148910] CPU3: Booted secondary processor [410fd034]
[ 0.158878] Detected PIPT I-cache on CPU4
[ 0.158905] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.158944] CPU4: using LPI pending table @0x00000000f1cb0000
[ 0.158986] CPU4: update cpu_capacity 1024
[ 0.158989] CPU4: Booted secondary processor [410fd082]
[ 0.168899] Detected PIPT I-cache on CPU5
[ 0.168917] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.168954] CPU5: using LPI pending table @0x00000000f1cf0000
[ 0.168981] CPU5: update cpu_capacity 1024
[ 0.168984] CPU5: Booted secondary processor [410fd082]
[ 0.169070] Brought up 6 CPUs
[ 0.311528] SMP: Total of 6 processors activated.
[ 0.316689] CPU features: detected feature: GIC system register CPU interface
[ 0.324531] CPU: All CPU(s) started at EL2
[ 0.329068] alternatives: patching kernel code
[ 0.336491] devtmpfs: initialized
[ 0.354385] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.365120] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.372713] pinctrl core: initialized pinctrl subsystem
[ 0.379936] Failed to find legacy iommu devices
[ 0.385293] NET: Registered protocol family 16
[ 0.390543] schedtune: init normalization constants…
[ 0.396194] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[ 0.403367] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 0.410540] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[ 0.417711] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 0.424882] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 0.432053] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[ 0.439224] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[ 0.446394] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[ 0.453565] schedtune: SYSTEM min_pwr: 121 max_pwr: 4434
[ 0.460736] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[ 0.469152] schedtune: verify normalization constants…
[ 0.474987] schedtune: max_pwr/2^0: 4313 => norm_pwr: 1024
[ 0.481107] schedtune: max_pwr/2^1: 2156 => norm_pwr: 511
[ 0.487226] schedtune: max_pwr/2^2: 1078 => norm_pwr: 255
[ 0.493347] schedtune: max_pwr/2^3: 539 => norm_pwr: 127
[ 0.499467] schedtune: max_pwr/2^4: 269 => norm_pwr: 63
[ 0.505585] schedtune: max_pwr/2^5: 134 => norm_pwr: 31
[ 0.511706] schedtune: configured to support 5 boost groups
[ 0.531193] cpuidle: using governor ladder
[ 0.545728] cpuidle: using governor menu
[ 0.550050] Registered FIQ tty driver
[ 0.554425] vdso: 2 pages (1 code @ ffffff8008b46000, 1 data @ ffffff8009144000)
[ 0.562580] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.571411] DMA: preallocated 2048 KiB pool for atomic allocations
[ 0.598347] console [pstore0] enabled
[ 0.602579] pstore: Registered ramoops as persistent store backend
[ 0.609376] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.617577] fiq debugger fiq mode enabled
[[ 0.622221] console [ttyFIQ0] enabled
[[ 0.629898] bootconsole [uart0] disabled
[ 0.638270] Registered fiq debugger ttyFIQ0
[ 0.672524] Rockchip hdmi driver version 2.0
[ 0.674871] iommu: Adding device ff650000.vpu_service to group 0
[ 0.674947] iommu: Adding device ff660000.rkvdec to group 1
[ 0.675013] iommu: Adding device ff670000.iep to group 2
[ 0.675112] iommu: Adding device ff8f0000.vop to group 3
[ 0.675188] iommu: Adding device ff900000.vop to group 4
[ 0.675296] iommu: Adding device ff910000.isp to group 5
[ 0.675375] iommu: Adding device ff920000.isp to group 6
[ 0.676074] rk_iommu ff670800.iommu: can’t get aclk
[ 0.676090] rk_iommu ff670800.iommu: can’t get hclk
[ 0.676956] SCSI subsystem initialized
[ 0.677302] usbcore: registered new interface driver usbfs
[ 0.677347] usbcore: registered new interface driver hub
[ 0.677423] usbcore: registered new device driver usb
[ 0.677799] media: Linux media interface: v0.10
[ 0.677841] Linux video capture interface: v2.00
[ 0.677972] pps_core: LinuxPPS API ver. 1 registered
[ 0.677984] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.678009] PTP clock support registered
[ 0.679503] Advanced Linux Sound Architecture Driver Initialized.
[ 0.679965] Bluetooth: Core ver 2.21
[ 0.680014] NET: Registered protocol family 31
[ 0.680024] Bluetooth: HCI device and connection manager initialized
[ 0.680041] Bluetooth: HCI socket layer initialized
[ 0.680056] Bluetooth: L2CAP socket layer initialized
[ 0.680087] Bluetooth: SCO socket layer initialized
[ 0.681113] rockchip-cpuinfo cpuinfo: Serial : 3befb003dc777422
[ 0.681628] clocksource: Switched to clocksource arch_sys_counter
[ 0.725740] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.725980] NET: Registered protocol family 2
[ 0.726407] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.726673] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.727208] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.727292] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.727402] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.727634] NET: Registered protocol family 1
[ 0.728163] Trying to unpack rootfs image as initramfs…
[ 1.069442] Freeing initrd memory: 7876K
[ 1.069996] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 1.070081] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 1.072874] audit: initializing netlink subsys (disabled)
[ 1.072936] audit: type=2000 audit(0.950:1): initialized
[ 1.077891] VFS: Disk quotas dquot_6.6.0
[ 1.078017] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.079404] fuse init (API version 7.23)
[ 1.080487]
[ 1.080487] TEE Core Framework initialization (ver 1:0.1)
[ 1.080515] TEE armv7 Driver initialization
[ 1.080883] tz_tee_probe: name=“armv7sec”, id=0, pdev_name=“armv7sec.0”
[ 1.080899] TEE core: Alloc the misc device “opteearmtz00” (id=0)
[ 1.081076] TEE Core: Register the misc device “opteearmtz00” (id=0,minor=62)
[ 1.085071] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.085099] io scheduler noop registered
[ 1.085265] io scheduler cfq registered (default)
[ 1.086565] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned
[ 1.091680] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 1.091702] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 1.091720] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 1.615006] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 1.615185] rockchip-pcie: probe of f8000000.pcie faZith error -110
[ 1.616523] iep: failed to find iep power down clock source.
[ 1.617111] IEP Power ON
[ 1.617324] IEP Power OFF
[ 1.617407] IEP Driver loaded succesfully
[ 1.617627] Module initialized.
[ 1.618229] rk-vcodec ff650000.vpu_service: probe device
[ 1.618305] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc0f1ecf010
[ 1.618479] rk-vcodec ff650000.vpu_service: allocator is drm
[ 1.618538] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 1.618999] rk-vcodec ff650000.vpu_service: init success
[ 1.619589] rk-vcodec ff660000.rkvdec: probe device
[ 1.619633] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc0f1ecf810
[ 1.619767] rk-vcodec ff660000.rkvdec: allocator is drm
[ 1.619821] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 1.620128] rk-vcodec ff660000.rkvdec: init success
[ 1.621801] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.621819] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 1.623115] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.623134] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.624745] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 1.626224] console [ttyS0] disabled
[ 1.626269] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
[ 1.626797] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 37, base_baud = 1500000) is a 16550A
[ 1.627337] ff370000.serial: ttyS4 at MMIO 0xff370000 (irq = 40, base_baud = 1500000) is a 16550A
[ 1.627699] [drm:drm_core_init] Initialized drm 1.1.0 20060810
[ 1.632433] mali ff9a0000.gpu: Failed to get regulator
[ 1.632450] mali ff9a0000.gpu: Power control initialization failed
[ 1.632750] Unable to detect cache hierarchy from DT for CPU 0
[ 1.649088] brd: module loaded
[ 1.653620] loop: module loaded
[ 1.654127] zram: Added device: zram0
[ 1.654720] SCSI Media Changer driver v0.25
[ 1.655926] rockchip-pinctrl pinctrl: pin gpio1-8 already requested by ff370000.serial; cannot claim for ff1d0000.spi
[ 1.655948] rockchip-pinctrl pinctrl: pin-40 (ff1d0000.spi) status -22
[ 1.655963] rockchip-pinctrl pinctrl: could not request pin 40 (gpio1-8) from group spi1-tx on device rockchip-pinctrl
[ 1.655980] rockchip-spi ff1d0000.spi: Error applying setting, reverse things back
[ 1.656119] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[ 1.656134] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[ 1.656778] register spi return v = :0
[ 1.656832] tun: Universal TUN/TAP device driver, 1.6
[ 1.656842] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.657715] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 1.657809] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.657829] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 1.657843] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[ 1.657869] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 1.658039] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.663059] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.663190] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.663201] Ring mode enabled
[ 1.663210] DMA HW capability register supported
[ 1.663219] Normal descriptors
[ 1.663230] RX Checksum Offload Engine supported (type 2)
[ 1.663240] Wake-Up On Lan supported
[ 1.663281] Enable RX Mitigation via HW Watchdog Timer
[ 1.731060] libphy: stmmac: probed
[ 1.731075] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.731087] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 1.731974] PPP generic driver version 2.4.2
[ 1.732134] PPP BSD Compression module registered
[ 1.732149] PPP Deflate Compression module registered
[ 1.732179] PPP MPPE Compression module registered
[ 1.732197] NET: Registered protocol family 24
[ 1.732234] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.732248] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.732312] usbcore: registered new interface driver mt7601u
[ 1.732333] Rockchip WiFi SYS interface (V1.00) …
[ 1.732393] usbcore: registered new interface driver catc
[ 1.732445] usbcore: registered new interface driver kaweth
[ 1.732461] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.732500] usbcore: registered new interface driver pegasus
[ 1.732541] usbcore: registered new interface driver rtl8150
[ 1.732582] usbcore: registered new interface driver r8152
[ 1.732597] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.732652] usbcore: registered new interface driver hso
[ 1.732701] usbcore: registered new interface driver asix
[ 1.732743] usbcore: registered new interface driver ax88179_178a
[ 1.732785] usbcore: registered new interface driver cdc_ether
[ 1.732826] usbcore: registered new interface driver cdc_eem
[ 1.732867] usbcore: registered new interface driver dm9601
[ 1.732920] usbcore: registered new interface driver smsc75xx
[ 1.732969] usbcore: registered new interface driver smsc95xx
[ 1.733010] usbcore: registered new interface driver gl620a
[ 1.733051] usbcore: registered new interface driver net1080
[ 1.733091] usbcore: registered new interface driver plusb
[ 1.733136] usbcore: registered new interface driver rndis_host
[ 1.733178] usbcore: registered new interface driver cdc_subset
[ 1.733220] usbcore: registered new interface driver zaurus
[ 1.733262] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.733319] usbcore: registered new interface driver int51x1
[ 1.733363] usbcore: registered new interface driver kalmia
[ 1.733409] usbcore: registered new interface driver ipheth
[ 1.733452] usbcore: registered new interface driver sierra_net
[ 1.733494] usbcore: registered new interface driver cx82310_eth
[ 1.733546] usbcore: registered new interface driver cdc_ncm
[ 1.733587] usbcore: registered new interface driver qmi_wwan
[ 1.733633] usbcore: registered new interface driver cdc_mbim
[ 1.734825] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[ 1.739192] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[ 1.739837] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.739855] ehci-pci: EHCI PCI platform driver
[ 1.739916] ehci-platform: EHCI generic platform driver
[ 1.743740] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.743769] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 1.743946] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 1.751650] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.751782] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.751799] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.751814] usb usb1: Product: EHCI Host Controller
[ 1.751826] usb usb1: Manufacturer: Linux 4.4.103 ehci_hcd
[ 1.751838] usb usb1: SerialNumber: fe3c0000.usb
[ 1.752314] hub 1-0:1.0: USB hub found
[ 1.752348] hub 1-0:1.0: 1 port detected
[ 1.752859] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.752889] ohci-platform: OHCI generic platform driver
[ 1.753352] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.753378] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[ 1.753506] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 1.809108] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.809125] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.809139] usb usb2: Product: Generic Platform OHCI controller
[ 1.809152] usb usb2: Manufacturer: Linux 4.4.103 ohci_hcd
[ 1.809164] usb usb2: SerialNumber: fe3e0000.usb
[ 1.809584] hub 2-0:1.0: USB hub found
[ 1.809618] hub 2-0:1.0: 1 port detected
[ 1.810441] usbcore: registered new interface driver cdc_acm
[ 1.810454] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.810517] usbcore: registered new interface driver usblp
[ 1.810564] usbcore: registered new interface driver cdc_wdm
[ 1.810612] usbcore: registered new interface driver uas
[ 1.810686] usbcore: registered new interface driver usb-storage
[ 1.810728] usbcore: registered new interface driver ums-alauda
[ 1.810773] usbcore: registered new interface driver ums-cypress
[ 1.810818] usbcore: registered new interface driver ums-datafab
[ 1.810861] usbcore: registered new interface driver ums_eneub6250
[ 1.810902] usbcore: registered new interface driver ums-freecom
[ 1.810945] usbcore: registered new interface driver ums-isd200
[ 1.810986] usbcore: registered new interface driver ums-jumpshot
[ 1.811028] usbcore: registered new interface driver ums-karma
[ 1.811070] usbcore: registered new interface driver ums-onetouch
[ 1.811112] usbcore: registered new interface driver ums-sddr09
[ 1.811158] usbcore: registered new interface driver ums-sddr55
[ 1.811199] usbcore: registered new interface driver ums-usbat
[ 1.811281] usbcore: registered new interface driver usbserial
[ 1.811319] usbcore: registered new interface driver usbserial_generic
[ 1.811349] usbserial: USB Serial support registered for generic
[ 1.811393] usbcore: registered new interface driver ch341
[ 1.811425] usbserial: USB Serial support registered for ch341-uart
[ 1.811469] usbcore: registered new interface driver cp210x
[ 1.811497] usbserial: USB Serial support registered for cp210x
[ 1.811550] usbcore: registered new interface driver option
[ 1.811579] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.811725] usbcore: registered new interface driver pl2303
[ 1.811754] usbserial: USB Serial support registered for pl2303
[ 1.811809] usbcore: registered new interface driver trancevibrator
[ 1.811826] usb20_otg: version 3.10a 21-DEC-2012
[ 1.812019] usb20_host: version 3.10a 21-DEC-2012
[ 1.812463] usbcore: registered new interface driver xpad
[ 1.812513] usbcore: registered new interface driver usb_acecad
[ 1.812565] usbcore: registered new interface driver aiptek
[ 1.812615] usbcore: registered new interface driver gtco
[ 1.812662] usbcore: registered new interface driver hanwang
[ 1.812708] usbcore: registered new interface driver kbtab
[ 1.812724] ==gsl_ts_init==
[ 1.812753] ret=0
[ 1.813146] .. rk pwm remotectl v1.1 init
[ 1.813375] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 1.813771] sensor_register_slave:mma8452,id=17
[ 1.813789] sensor_register_slave:lis3dh,id=7
[ 1.813804] sensor_register_slave:mma7660,id=18
[ 1.813820] sensor_register_slave:lsm303d,id=22
[ 1.813835] sensor_register_slave:gs_mc3230,id=23
[ 1.813845] [Gsensor] gsensor_init
[ 1.813860] sensor_register_slave:mpu6880_acc,id=24
[ 1.813876] sensor_register_slave:mpu6500_acc,id=25
[ 1.813892] sensor_register_slave:lsm330_acc,id=26
[ 1.813908] sensor_register_slave:akm8975,id=29
[ 1.813923] sensor_register_slave:akm8963,id=30
[ 1.813939] sensor_register_slave:l3g4200d,id=44
[ 1.813954] sensor_register_slave:l3g20d,id=45
[ 1.813969] sensor_register_slave:ewtsa,id=46
[ 1.813985] sensor_register_slave:lsm330_gyro,id=50
[ 1.814000] sensor_register_slave:cm3217,id=52
[ 1.814016] sensor_register_slave:cm3218,id=53
[ 1.814705] i2c /dev entries driver
[ 1.815785] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 1.815855] fan53555-reg: supplied by vcc5v0_sys
[ 1.817529] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 1.817579] fan53555-reg: supplied by vcc5v0_sys
[ 1.819287] rk808 0-001b: Pmic Chip id: 0x0
[ 1.822404] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.822466] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.822551] DCDC_REG1: supplied by vcc3v3_sys
[ 1.823234] DCDC_REG2: supplied by vcc3v3_sys
[ 1.823716] DCDC_REG3: supplied by vcc3v3_sys
[ 1.823923] DCDC_REG4: supplied by vcc3v3_sys
[ 1.824291] LDO_REG1: supplied by vcc3v3_sys
[ 1.825337] LDO_REG2: supplied by vcc3v3_sys
[ 1.826228] LDO_REG3: supplied by vcc3v3_sys
[ 1.827117] LDO_REG4: supplied by vcc3v3_sys
[ 1.828026] LDO_REG5: supplied by vcc3v3_sys
[ 1.828921] LDO_REG6: supplied by vcc3v3_sys
[ 1.829812] LDO_REG7: supplied by vcc3v3_sys
[ 1.830717] LDO_REG8: supplied by vcc3v3_sys
[ 1.831607] SWITCH_REG1: supplied by vcc3v3_sys
[ 1.831863] SWITCH_REG2: supplied by vcc3v3_sys
[ 1.835192] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 1.835614] rk808 0-001b: Can not read property pmic,hold-gpio
[ 1.835637] rk808 0-001b: Can not read property pmic,stby-gpio
[ 1.835666] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80098ac000
[ 1.836221] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80098ae000
[ 1.836306] rockchip-pinctrl pinctrl: pin gpio4-17 already requested by ff940000.hdmi; cannot claim for ff130000.i2c
[ 1.836324] rockchip-pinctrl pinctrl: pin-145 (ff130000.i2c) status -22
[ 1.836339] rockchip-pinctrl pinctrl: could not request pin 145 (gpio4-17) from group i2c3-xfer on device rockchip-pinctrl
[ 1.836355] rk3x-i2c ff130000.i2c: Error applying setting, reverse things back
[ 1.836673] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff80098b0000
[ 1.837747] fusb302 4-0022: Can’t get property of role, set role to default DRP
[ 1.845951] fusb302 4-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 1.845984] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80098b2000
[ 1.846856] IR NEC protocol handler initialized
[ 1.846872] IR RC5(x/sz) protocol handler initialized
[ 1.846885] IR RC6 protocol handler initialized
[ 1.846898] IR JVC protocol handler initialized
[ 1.846911] IR Sony protocol handler initialized
[ 1.846925] IR SANYO protocol handler initialized
[ 1.846938] IR Sharp protocol handler initialized
[ 1.846951] IR MCE Keyboard/mouse protocol handler initialized
[ 1.846965] IR XMP protocol handler initialized
[ 1.847154] usbcore: registered new interface driver uvcvideo
[ 1.847165] USB Video Class driver (1.1.1)
[ 1.847182] CamSys driver version: v0.38.0, CamSys head file version: v1.0.0
[ 1.851367] __power_supply_register: Expected proper parent device for ‘test_ac’
[ 1.851498] __power_supply_register: Expected proper parent device for ‘test_battery’
[ 1.851853] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 1.851953] __power_supply_register: Expected proper parent device for ‘test_usb’
[ 1.854252] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 1.855025] device-mapper: uevent: version 1.0.3
[ 1.855297] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 1.855457] Bluetooth: HCI UART driver ver 2.3
[ 1.855470] Bluetooth: HCI UART protocol H4 registered
[ 1.855482] Bluetooth: HCI UART protocol LL registered
[ 1.855497] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[ 1.855508] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[ 1.855520] rtk_btusb: Register usb char device interface for BT driver
[ 1.855702] usbcore: registered new interface driver rtk_btusb
[ 1.856089] cpu cpu0: leakage=19
[ 1.872419] cpu cpu0: temp=30555, pvtm=149290 (150555 + -1265)
[ 1.872649] cpu cpu0: pvtm-sel=2
[ 1.872942] cpu cpu4: leakage=31
[ 1.885123] cpu cpu4: temp=30000, pvtm=156491 (157272 + -781)
[ 1.885269] cpu cpu4: pvtm-sel=2
[ 1.889635] sdhci: Secure Digital Host Controller Interface driver
[ 1.889651] sdhci: Copyright(c) Pierre Ossman
[ 1.889666] Synopsys Designware Multimedia Card Interface Driver
[ 1.890507] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.890728] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.890750] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.890801] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.890837] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.890886] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.890899] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.891692] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.891753] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 1.891773] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 1.891813] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 1.891837] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.891954] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 1.892208] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.892479] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.905103] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.919517] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 1.920063] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.922258] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 1.922274] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 1.951757] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 1.955594] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.957581] usbcore: registered new interface driver usbhid
[ 1.957593] usbhid: USB HID core driver
[ 1.957689] inv_mpu_iio: inv_mpu_init:746
[ 1.958114] ashmem: initialized
[ 1.959275] ff100000.saradc supply vref not found, using dummy regulator
[ 1.960079] rknandbase v1.1 2016-11-08
[ 1.960423] usbcore: registered new interface driver snd-usb-audio
[ 1.961346] rt5640 1-001c: rt5640 have no aux_det_adc_value defined
[ 1.961403] rt5640 1-001c: Can not read property hp-con-gpio
[ 1.961412] rt5640 1-001c: Can not read property: linein-mute.
[ 1.977759] u32 classifier
[ 1.977779] Actions configured
[ 1.977848] Netfilter messages via NETLINK v0.30.
[ 1.977935] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.978504] ctnetlink v0.93: registering with nfnetlink.
[ 1.979424] xt_time: kernel timezone is -0000
[ 1.980220] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.980469] arp_tables: (C) 2002 David S. Miller
[ 1.980837] Initializing XFRM netlink socket
[ 1.981452] NET: Registered protocol family 10
[ 1.991934] mip6: Mobile IPv6
[ 1.991960] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.993044] mmc1: MAN_BKOPS_EN bit is not set
[ 1.993436] sit: IPv6 over IPv4 tunneling driver
[ 1.993739] NET: Registered protocol family 17
[ 1.993760] NET: Registered protocol family 15
[ 1.993787] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 1.994631] Bridge firewalling registered
[ 1.994642] Ebtables v2.0 registered
[ 1.994797] Bluetooth: RFCOMM TTY layer initialized
[ 1.994808] Bluetooth: RFCOMM socket layer initialized
[ 1.994828] Bluetooth: RFCOMM ver 1.11
[ 1.994842] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.994849] Bluetooth: BNEP filters: protocol multicast
[ 1.994858] Bluetooth: BNEP socket layer initialized
[ 1.994868] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.994877] Bluetooth: HIDP socket layer initialized
[ 1.994903] l2tp_core: L2TP core driver, V2.0
[ 1.994917] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.994928] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.995180] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.995220] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[ 1.995228] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.995236] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.995286] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 1.995294] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.995302] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.995341] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.995559] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 1.995588] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[ 1.995609] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[ 1.995630] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[ 1.996003] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.996075] [BT_RFKILL]: ** disable irq
[ 1.996244] [BT_RFKILL]: bt_default device registered.
[ 1.996496] sensor_register_slave:mpu6880_gyro,id=49
[ 1.998103] Registered cp15_barrier emulation handler
[ 1.998204] Registered setend emulation handler
[ 1.999270] registered taskstats version 1
[ 2.000474] rockchip ion idev is NULL
[ 2.000494] rga2 ff680000.rga: rga ion client create success!
[ 2.000721] rga: Driver loaded successfully ver:3.02
[ 2.002355] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: vbus_drv is not assigned
[ 2.005386] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 2.005692] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 2.006391] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 2.006436] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 2.006454] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[ 2.006531] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 2.007031] mmcblk1: mmc1:0001 032G00 29.1 GiB
[ 2.007275] mmcblk1boot0: mmc1:0001 032G00 partition 1 8.00 MiB
[ 2.007513] mmcblk1boot1: mmc1:0001 032G00 partition 2 8.00 MiB
[ 2.007805] mmcblk1rpmb: mmc1:0001 032G00 partition 3 4.00 MiB
[ 2.008262] parameter: 0x000000000 – 0x000400000 (4 MB)
[ 2.008277] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 2.008396] trust: 0x000800000 – 0x000c00000 (4 MB)
[ 2.008410] misc: 0x000c00000 – 0x001000000 (4 MB)
[ 2.008423] resource: 0x001000000 – 0x002000000 (16 MB)
[ 2.008434] kernel: 0x002000000 – 0x003800000 (24 MB)
[ 2.008446] boot: 0x003800000 – 0x005800000 (32 MB)
[ 2.008457] recovery: 0x005800000 – 0x007800000 (32 MB)
[ 2.008469] backup: 0x007800000 – 0x00e800000 (112 MB)
[ 2.008481] cache: 0x00e800000 – 0x016800000 (128 MB)
[ 2.008493] system: 0x016800000 – 0x076800000 (1536 MB)
[ 2.008505] metadata: 0x076800000 – 0x077800000 (16 MB)
[ 2.008541] baseparamer: 0x077800000 – 0x077c00000 (4 MB)
[ 2.008554] userdata: 0x077c00000 – 0x747800000 (27900 MB)
[ 2.008626] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 2.011392] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[ 2.012106] i2c i2c-10: of_i2c: modalias failure on /dp@fec00000/ports
[ 2.012359] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops)
[ 2.012371] [drm:drm_vblank_init] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.012379] [drm:drm_vblank_init] No driver support for vblank timestamp query.
[ 2.012564] rockchip-drm display-subsystem: connector[HDMI-A-1] can’t found any modes
[ 2.012577] rockchip-drm display-subsystem: can’t not find any loader display
[ 2.012587] rockchip-drm display-subsystem: failed to show loader logo
[ 2.012654] Freeing drm_logo memory: 488K
[ 2.012665] rockchip-drm display-subsystem: No connectors reported connected with modes
[ 2.012675] [drm:drm_fb_helper_single_fb_probe] Cannot find any crtc or sizes - going 1024x768
[ 2.016324] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 2.016385] rockchip-drm display-subsystem: fb0: frame buffer device
[ 2.039371] mali ff9a0000.gpu: leakage=25
[ 2.052599] Unable to handle kernel paging request at virtual address 7fffffc0f6f44ad8
[ 2.072968] fusb302 4-0022: CC connected in CC2 as UFP
[ 2.075547] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 3.809258] pgd = ffffff80093ea000
[ 3.812662] [7fffffc0f6f44ad8] *pgd=00000000f6ff6003, *pud=00000000f6ff6003, *pmd=00e80000f6e00711
[ 3.821686] Internal error: Oops: 96000044 [#1] PREEMPT SMP
[ 3.827261] Modules linked in:
[ 3.830352] CPU: 4 PID: 0 Comm: swapper/4 Not tainted 4.4.103 #1
[ 3.836361] Hardware name: Firefly-RK3399 Board BOX (Android) (DT)
[ 3.842546] task: ffffffc00a3b4100 task.stack: ffffffc00a3cc000
[ 3.848487] PC is at cpumask_next_and+0x8/0x6c
[ 3.852945] LR is at select_energy_cpu_brute+0x2c4/0x1128
[ 3.858345] pc : [] lr : [] pstate: 004001c5
[ 3.865737] sp : ffffffc0f6f44ac0
[ 3.869053] x29: ffffffc0f6f44ac0 x28: 0000000000000000
[ 3.874401] x27: 00000000ffffffff x26: ffffffffffffffff
[ 3.879746] x25: 0000000000000000 x24: 00000000ffffffff
[ 3.885101] x23: 0000000000000004 x22: 00000000ffffffff
[ 3.890446] x21: ffffff8009117000 x20: ffffffc0f189a700
[ 3.895800] x19: ffffff8009120000 x18: 0000000030d00800
[ 3.901144] x17: 0000000000000000 x16: 0000000000000000
[ 3.906487] x15: 0000000000000000 x14: 0000000000000000
[ 3.911831] x13: 0000000000000004 x12: 0000000400000000
[ 3.917164] x11: 0000000000000330 x10: 0000000000000940
[ 3.922507] x9 : 0000000000000001 x8 : 0000000000000002
[ 3.927851] x7 : ffffffc0f20000a0 x6 : ffffffc0f198b958
[ 3.933194] x5 : 000000000000003f x4 : 0000000000000000
[ 3.938537] x3 : 0000000000000000 x2 : 7dff77c0f1c898a0
[ 3.943881] x1 : ffffffc0f189aac0 x0 : 00000000ffffffff
[ 3.949226]
[ 3.949226] PC: 0xffffff8008381a6c:
[ 3.954200] 1a6c aa1403e0 97fffd78 aa0003f5 aa1403e1 aa1303e0 aa1503e2 97fffd97 35000180
[ 3.962579] 1a8c 8b150273 39400260 7100b01f 1a9f17e1 6b1f001f 1a9f17e0 2a000020 34000080
[ 3.970952] 1aac 1400000a 340000a0 91000673 39400260 7100b01f 54ffff81 7100b01f 1a9f17e0
[ 3.979325] 1acc 8b000273 17ffffe5 a94153f3 f94013f5 a8c37bfd d65f03c0 a9bd7bfd 910003fd
[ 3.987697] 1aec a90153f3 d0006e33 aa0103f4 a9025bf5 912f4273 aa0203f5 52800816 11000402
[ 3.996069] 1b0c d2800101 aa1403e0 93407c42 94004c30 aa0003e2 b9400261 6b01005f 540000ca
[ 4.004441] 1b2c 1ad60c41 937d7c21 f8616aa1 9ac22422 3607fe62 a94153f3 a9425bf5 a8c37bfd
[ 4.012813] 1b4c d65f03c0 a9bc7bfd 910003fd a90153f3 2a0003f3 d0003e20 a9025bf5 f9001fa1
[ 4.021187]
[ 4.021187] LR: 0xffffff80080d9da0:
[ 4.026150] 9da0 12800016 1a9fd7e1 b9010ba1 8b1a0361 f90083a1 f94073a1 9280001a f9006fa0
[ 4.034521] 9dc0 b0008440 91364000 2a1603fc f9400821 2a1603f8 f9007ba1 12b00001 b900afa1
[ 4.042894] 9de0 d0008361 912f4021 f9007fbf f90077ba f9006bba f9005bba f9003fa1 f90053a0
[ 4.051265] 9e00 910f0280 1280001b f90043a0 f9407ba2 2a1b03e0 f94043a1 91008042 940a9f32
[ 4.059637] 9e20 2a0003fb f9403fa1 b9400021 6b01001f 540012ea 97ffff38 f9004fa0 f0008363
[ 4.068009] 9e40 93407f60 910c4063 f9406fa1 f9004ba0 f87bd860 8b000020 52800801 1ac10f61
[ 4.076381] 9e60 f9447c02 d0005360 937d7c21 f944e400 f9005fa0 f8616800 9adb2400 3607fc80
[ 4.084752] 9e80 aa1403e1 2a1b03e0 f90037a3 f9003ba2 97ffd688 f9415681 93407c04 f94083a0
[ 4.093125]
[ 4.093125] SP: 0xffffffc0f6f44a40:
[ 4.098098] 4a40 ffffffff 00000000 00000004 00000000 ffffffff 00000000 00000000 00000000
[ 4.106470] 4a60 ffffffff ffffffff ffffffff 00000000 00000000 00000000 f6f44ac0 ffffffc0
[ 4.114842] 4a80 080d9e20 ffffff80 f6f44ac0 ffffffc0 08381aec ffffff80 004001c5 00000000
[ 4.123214] 4aa0 f6f44ab0 ffffffc0 083aa228 ffffff80 00000000 00000080 08381b1c ffffff80
[ 4.131586] 4ac0 f6f44b20 ffffffc0 080d9e20 ffffff80 09120000 ffffff80 f189a700 ffffffc0
[ 4.139957] 4ae0 09117000 ffffff80 ffffffff 00000000 0a2ea600 ffffffc0 0000002f 00000000
[ 4.148329] 4b00 f6f44b20 ffffffc0 080f4ec8 ffffff80 0a2ea600 ffffffc0 0a2ea620 ffffffc0
[ 4.156701] 4b20 f6f44cf0 ffffffc0 080db004 ffffff80 09117000 ffffff80 00000004 00000000
[ 4.165078]
[ 4.165078] X1: 0xffffffc0f189aa40:
[ 4.170050] aa40 00000000 00000000 00000000 00000000 00000001 00000000 00000000 00000000
[ 4.178422] aa60 f189aa60 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.186793] aa80 00000000 00000000 080e36f4 ffffff80 f6ef2bc0 ffffffc0 00000000 ffffffff
[ 4.195165] aaa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000006
[ 4.203536] aac0 0000003f 00000000 00000000 00000000 f189aad0 ffffffc0 f189aad0 ffffffc0
[ 4.211908] aae0 00000000 00000000 0000002a 00000000 00070f4b 00000000 7a471528 00000000
[ 4.220279] ab00 00000000 00000000 f1b28408 ffffffc0 f1899e08 ffffffc0 0000008c 00000000
[ 4.228650] ab20 f189ab20 ffffffc0 f189ab20 ffffffc0 f189ab30 ffffffc0 f189ab30 ffffffc0
[ 4.237026]
[ 4.237026] X6: 0xffffffc0f198b8d8:
[ 4.241998] b8d8 00000000 00000000 f1fc9c80 ffffffc0 00000003 00000000 fe809b18 ffffffbf
[ 4.250369] b8f8 00000000 00000000 f198b920 ffffffc0 08b2e270 ffffff80 f198ba10 ffffffc0
[ 4.258740] b918 dc8ba667[ 4.260842] phy phy-ff770000.syscon:usb2-phy@e450.6: charger = USB_CDP_CHARGER
[ 4.268511] cb88537f f198b9c0 ffffffc0 08b2e2c4 ffffff80 000186a0 00000000
[ 4.275816] b938 09146000 ffffff80 7316d72f 00000000 000003e8 00000000 f1ea5800 ffffffc0
[ 4.284188] b958 f198b958 ffffffc0 00000000 00000000 00000000 00000000 73185ef3 00000000
[ 4.292559] b978 7316d853 00000000 08106c28 ffffff80 f6f46bc0 ffffffc0 00000000 00000034
[ 4.300930] b998 08b2e264 ffffff80 726f776b 2f72656b 3a323175 00000031 00000000 00000000
[ 4.309302] b9b8 dc8ba667 cb88537f f198b9d0 ffffffc0 08b2dd38 ffffff80 f198ba20 ffffffc0
[ 4.317676]
[ 4.317676] X7: 0xffffffc0f2000020:
[ 4.322648] 0020 f2000018 ffffffc0 00000000 00000000 00204a00 ffffffc0 00204c00 ffffffc0
[ 4.331021] 0040 00204e00 ffffffc0 00205000 ffffffc0 00205200 ffffffc0 00205400 ffffffc0
[ 4.339392] 0060 00205600 ffffffc0 00205800 ffffffc0 00205a00 ffffffc0 00205c00 ffffffc0
[ 4.347765] 0080 00205e00 ffffffc0 0022e000 ffffffc0 0022e200 ffffffc0 0022e400 ffffffc0
[ 4.356136] 00a0 0022e600 ffffffc0 0022e800 ffffffc0 0a2ea600 ffffffc0 f1e9b400 ffffffc0
[ 4.364507] 00c0 f1e9b600 ffffffc0 f1e9b800 ffffffc0 f1e9ba00 ffffffc0 f1e9bc00 ffffffc0
[ 4.372878] 00e0 f1e9be00 ffffffc0 f1e96000 ffffffc0 f1e96200 ffffffc0 f1e96400 ffffffc0
[ 4.381250] 0100 f1e96600 ffffffc0 f1e96800 ffffffc0 f1e96a00 ffffffc0 f1e96c00 ffffffc0
[ 4.389631]
[ 4.389631] X19: 0xffffff800911ff80:
[ 4.394680] ff80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.403052] ffa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.411422] ffc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.419793] ffe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.428164] 0000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.436535] 0020 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.444906] 0040 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.453277] 0060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.461650]
[ 4.461650] X20: 0xffffffc0f189a680:
[ 4.466699] a680 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.475070] a6a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.483441] a6c0 00000000 00000000 00000000 00000000 00000000 00000000[ 4.489424] fusb302 4-0022: port 0, state 19
[ 4.492053] fusb302 4-0022: port 0, state 20
[ 4.494061] fusb302 4-0022: port 0, state 21
[ 4.502822] 00000000 00000000
[ 4.506110] a6e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.514481] a700 00000000 00000000 ffffffff ffffffff 014dd000 00000000 00000002 00000000
[ 4.522852] a720 00000100 00000000 f1988000 ffffffc0 00000002 04208060 00000000 00000000
[ 4.531224] a740 00000000 00000000 00000000 00000004 00000014 00000000 fffea289 00000000
[ 4.539596] a760 f1c45b00 ffffffc0 00000004 00000000 00000078 00000078 00000078 00000000
[ 4.547970]
[ 4.547970] X21: 0xffffff8009116f80:
[ 4.553019] 6f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.561390] 6fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.569762] 6fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.578134] 6fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.586506] 7000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.594878] 7020 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.603249] 7040 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.611620] 7060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.619999]
[ 4.619999] X29: 0xffffffc0f6f44a40:
[ 4.625048] 4a40 ffffffff 00000000 00000004 00000000 ffffffff 00000000 00000000 00000000
[ 4.633420] 4a60 ffffffff ffffffff ffffffff 00000000 00000000 00000000 f6f44ac0 ffffffc0
[ 4.641792] 4a80 080d9e20 ffffff80 f6f44ac0 ffffffc0 08381aec ffffff80 004001c5 00000000
[ 4.650165] 4aa0 f6f44ab0 ffffffc0 083aa228 ffffff80 00000000 00000080 08381b1c ffffff80
[ 4.658537] 4ac0 f6f44b20 ffffffc0 080d9e20 ffffff80 09120000 ffffff80 f189a700 ffffffc0
[ 4.666910] 4ae0 09117000 ffffff80 ffffffff 00000000 0a2ea600 ffffffc0 0000002f 00000000
[ 4.675282] 4b00 f6f44b20 ffffffc0 080f4ec8 ffffff80 0a2ea600 ffffffc0 0a2ea620 ffffffc0
[ 4.683655] 4b20 f6f44cf0 ffffffc0 080db004 ffffff80 09117000 ffffff80 00000004 00000000
[ 4.692027]
[ 4.693525] Process swapper/4 (pid: 0, stack limit = 0xffffffc00a3cc000)
[ 4.700223] Stack: (0xffffffc0f6f44ac0 to 0xffffffc00a3d0000)
[ 4.705968] Call trace:
[ 4.708425] Exception stack(0xffffffc0f6f448d0 to 0xffffffc0f6f44a00)
[ 4.714874] 48c0: ffffff8009120000 0000008000000000
[ 4.722710] 48e0: 00000000014dd000 ffffff8008381aec 00000000004001c5 0000000000000000
[ 4.730543] 4900: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 4.738377] 4920: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 4.746211] 4940: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 4.754044] 4960: ffffffc0f6f44970 ffffff80080cfd68 ffffffc0f6f44a60 ffffff80080da6b0
[ 4.761878] 4980: ffffff8009120000 cb88537fdc8ba667 00000000ffffffff ffffffc0f189aac0
[ 4.769713] 49a0: 7dff77c0f1c898a0 0000000000000000 0000000000000000 000000000000003f
[ 4.777536] 49c0: ffffffc0f198b958 ffffffc0f20000a0 0000000000000002 0000000000000001
[ 4.785370] 49e0: 0000000000000940 0000000000000330 0000000400000000 0000000000000004
[ 4.793207] [] cpumask_next_and+0x8/0x6c
[ 4.798699] [] select_energy_cpu_brute+0x2c4/0x1128
[ 4.805149] [] select_task_rq_fair+0x380/0xc0c
[ 4.811165] [] try_to_wake_up+0x228/0x388
[ 4.816742] [] wake_up_process+0x18/0x20
[ 4.822232] [] hrtimer_wakeup+0x1c/0x28
[ 4.827632] [] __hrtimer_run_queues+0x1b0/0x358
[ 4.833731] [] hrtimer_interrupt+0x9c/0x1bc
[ 4.839487] [] arch_timer_handler_phys+0x2c/0x38
[ 4.845676] [] handle_percpu_devid_irq+0xe4/0x1e0
[ 4.851950] [] generic_handle_irq+0x1c/0x2c
[ 4.857699] [] __handle_domain_irq+0x80/0xac
[ 4.863538] [] gic_handle_irq+0xbc/0x154
[ 4.869024] Exception stack(0xffffffc00a3cfde0 to 0xffffffc00a3cff10)
[ 4.875474] fde0: 00000040ede2a000 00000000ffffffff ffffffc0f6f4ae80 ffffffc0f6f4ae80
[ 4.883309] fe00: 0000000000000018 00376ead0829405d 000000000000048a 0000000000000000
[ 4.891143] fe20: ffffffc00a3b4aa0 ffffffc00a3cfeb0 0000000000000940 0000000000000330
[ 4.898977] fe40: 0000000400000000 0000000000000004 0000000000000000 0000000000000000
[ 4.906811] fe60: 0000000000000000 0000000000000000 0000000030d00800 0000000073185f99
[ 4.914645] fe80: 0000000000000000 0000000073099b53 ffffffc004ea7a00 0000000000000004
[ 4.922480] fea0: 0000000000000000 00000000015e7000 00000000015ea000 0000000000d2f234
[ 4.930313] fec0: 0000000000000000 ffffffc00a3cff10 ffffff800878bb3c ffffffc00a3cff10
[ 4.938147] fee0: ffffff800878bb70 0000000060400145 ffffff800925e910 0000000000000000
[ 4.945978] ff00: ffffffffffffffff ffffffc004ea7a00
[ 4.950867] [] el1_irq+0xe0/0x170
[ 4.955757] [] cpuidle_enter_state+0x248/0x314
[ 4.961769] [] cpuidle_enter+0x18/0x20
[ 4.967087] [] cpu_startup_entry+0x2f4/0x3a8
[ 4.972927] [] secondary_start_kernel+0x140/0x14c
[ 4.979199] [<0000000000d2f178>] 0xd2f178
[ 4.983222] Code: a8c37bfd d65f03c0 a9bd7bfd 910003fd (a90153f3)
[ 4.989331] —[ end trace cc46165bf073197a ]—
[ 4.998528] fusb302 4-0022: port 0, state 0
[ 4.998586] Kernel panic - not syncing: Fatal exception in interrupt
[ 4.998642] fusb302 4-0022: PD disabled
[ 5.012967] CPU5: stopping
[ 5.015696] CPU: 5 PID: 0 Comm: swapper/5 Tainted: G D 4.4.103 #1
[ 5.022916] Hardware name: Firefly-RK3399 Board BOX (Android) (DT)
[ 5.029098] Call trace:
[ 5.031566] [] dump_backtrace+0x0/0x1cc
[ 5.036972] [] show_stack+0x14/0x1c
[ 5.042028] [] dump_stack+0x94/0xb4
[ 5.047083] [] handle_IPI+0x150/0x2a0
[ 5.052309] [] gic_handle_irq+0x10c/0x154
[ 5.057882] Exception stack(0xffffffc00a3d3de0 to 0xffffffc00a3d3f10)
[ 5.064335] 3de0: 00000040ede3f000 00000000ffffffff ffffffc0f6f5fe80 ffffffc0f6f5fe80
[ 5.072171] 3e00: 0000000000000018 00350c543176dd5b 0000000000000a60 0000000000000000
[ 5.080007] 3e20: ffffffc00a3b57a0 ffffffc00a3d3eb0 0000000000000940 000000000000000f
[ 5.087842] 3e40: 0000000000000062 0000000000000004 0000000000000000 00000000c91cea31
[ 5.095676] 3e60: 0000000026c23dde 00000000dd6a9644 0000000000000000 00000001238c0584
[ 5.103510] 3e80: 0000000000000000 00000000f56081a3 ffffffc004ea7c00 0000000000000005
[ 5.111344] 3ea0: 0000000000000000 00000000015e7000 00000000015ea000 0000000000d2f234
[ 5.119178] 3ec0: 0000000000000000 ffffffc00a3d3f10 ffffff800878bb3c ffffffc00a3d3f10
[ 5.127013] 3ee0: ffffff800878bb70 0000000060400045 ffffff800925e910 0000000000000000
[ 5.134844] 3f00: ffffffffffffffff ffffffc004ea7c00
[ 5.139732] [] el1_irq+0xe0/0x170
[ 5.144621] [] cpuidle_enter_state+0x248/0x314
[ 5.150632] [] cpuidle_enter+0x18/0x20
[ 5.155951] [] cpu_startup_entry+0x2f4/0x3a8
[ 5.161789] [] secondary_start_kernel+0x140/0x14c
[ 5.168060] [<0000000000d2f178>] 0xd2f178
[ 5.172079] CPU0: stopping
[ 5.174826] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G D 4.4.103 #1
[ 5.182053] Hardware name: Firefly-RK3399 Board BOX (Android) (DT)
[ 5.188241] Call trace:
[ 5.190713] [] dump_backtrace+0x0/0x1cc
[ 5.196122] [] show_stack+0x14/0x1c
[ 5.201185] [] dump_stack+0x94/0xb4
[ 5.206254] [] handle_IPI+0x150/0x2a0
[ 5.211491] [] gic_handle_irq+0x10c/0x154
[ 5.217067] Exception stack(0xffffff8009143d90 to 0xffffff8009143ec0)
[ 5.223512] 3d80: 0000000000000000 0000000000000000
[ 5.231352] 3da0: ffffff80087adc70 0000000029aaaaf1 0000000000000018 00350c543176dd5b
[ 5.239191] 3dc0: 0000000000000a60 0000000000000000 ffffff8009143df0 0000000000000000
[ 5.247030] 3de0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 5.254867] 3e00: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 5.262707] 3e20: 0000000030d00800 00000001238d1406 0000000000000002 0000000122d0f4d7
[ 5.270547] 3e40: ffffffc004ea7200 0000000000000000 0000000000000001 ffffffc0f6f6d4c0
[ 5.278388] 3e60: 00000000015ea000 0000000000d2f22c 000000000127001c ffffff8009143ec0
[ 5.286228] 3e80: ffffff800878bb6c ffffff8009143ec0 ffffff800878bb70 0000000020400145
[ 5.294067] 3ea0: 0000000000d2f22c 0000000000000002 ffffffffffffffff ffffff800878bb6c
[ 5.301906] [] el1_irq+0xe0/0x170
[ 5.306796] [] cpuidle_enter_state+0x248/0x314
[ 5.312808] [] cpuidle_enter+0x18/0x20
[ 5.318135] [] cpu_startup_entry+0x2f4/0x3a8
[ 5.323982] [] rest_init+0x7c/0x84
[ 5.328959] [] start_kernel+0x410/0x43c
[ 5.334366] [] __primary_switched+0x30/0x6c
[ 5.340120] CPU1: stopping
[ 5.342853] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G D 4.4.103 #1
[ 5.350081] Hardware name: Firefly-RK3399 Board BOX (Android) (DT)
[ 5.356267] Call trace:
[ 5.358733] [] dump_backtrace+0x0/0x1cc
[ 5.364142] [] show_stack+0x14/0x1c
[ 5.369203] [] dump_stack+0x94/0xb4
[ 5.374269] [] handle_IPI+0x150/0x2a0
[ 5.379504] [] gic_handle_irq+0x10c/0x154
[ 5.385087] Exception stack(0xffffffc00a3bfde0 to 0xffffffc00a3bff10)
[ 5.391536] fde0: 0000000000000000 0000000000000000 ffffff80087adc70 0000000029aaaaf1
[ 5.399375] fe00: 0000000000000018 00350c543176dd5b 0000000000000a60 0000000000000001
[ 5.407216] fe20: 00000032b5193519 ffffff8008081000 0000000000001000 0000000000000000
[ 5.415056] fe40: 0000000034d5d91d 00000040eddeb000 ffffffc00a3b1a00 0000000000000000
[ 5.422895] fe60: 0000000000000000 0000000000000000 0000000030d00800 00000001238d83ad
[ 5.430735] fe80: 0000000000000002 00000000f302789b ffffffc004ea7400 0000000000000001
[ 5.438575] fea0: 0000000000000001 00000000015e7000 00000000015ea000 0000000000d2f234
[ 5.446416] fec0: 0000000000000000 ffffffc00a3bff10 ffffff800878bb6c ffffffc00a3bff10
[ 5.454255] fee0: ffffff800878bb70 0000000020400145 0000000000d2f234 0000000000000002
[ 5.462092] ff00: ffffffffffffffff ffffff800878bb6c
[ 5.466979] [] el1_irq+0xe0/0x170
[ 5.471866] [] cpuidle_enter_state+0x248/0x314
[ 5.477878] [] cpuidle_enter+0x18/0x20
[ 5.483203] [] cpu_startup_entry+0x2f4/0x3a8
[ 5.489045] [] secondary_start_kernel+0x140/0x14c
[ 5.495321] [<0000000000d2f178>] 0xd2f178
[ 5.499334] CPU2: stopping
[ 5.502065] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G D 4.4.103 #1
[ 5.509292] Hardware name: Firefly-RK3399 Board BOX (Android) (DT)
[ 5.515468] Call trace:
[ 5.517934] [] dump_backtrace+0x0/0x1cc
[ 5.523343] [] show_stack+0x14/0x1c
[ 5.528411] [] dump_stack+0x94/0xb4
[ 5.533470] [] handle_IPI+0x150/0x2a0
[ 5.538705] [] gic_handle_irq+0x10c/0x154
[ 5.544288] Exception stack(0xffffffc00a3c7de0 to 0xffffffc00a3c7f10)
[ 5.550737] 7de0: 0000000000000000 0000000000000000 ffffff80087adc70 0000000029aaaaf1
[ 5.558576] 7e00: 0000000000000018 00350c543176dd5b 0000000000000a60 0000000000000002
[ 5.566416] 7e20: 00000032b5193519 ffffff8008081000 0000000000001000 0000000000000000
[ 5.574257] 7e40: 0000000034d5d91d 00000040ede00000 ffffffc00a3b2700 0000000000000000
[ 5.582096] 7e60: 0000000000000000 0000000000000000 0000000030d00800 00000001238deda2
[ 5.589936] 7e80: 0000000000000002 00000000f39b1f8c ffffffc004ea7600 0000000000000002
[ 5.597776] 7ea0: 0000000000000001 00000000015e7000 00000000015ea000 0000000000d2f234
[ 5.605616] 7ec0: 0000000000000000 ffffffc00a3c7f10 ffffff800878bb6c ffffffc00a3c7f10
[ 5.613456] 7ee0: ffffff800878bb70 0000000020400145 0000000000d2f234 0000000000000002
[ 5.621293] 7f00: ffffffffffffffff ffffff800878bb6c
[ 5.626180] [] el1_irq+0xe0/0x170
[ 5.631067] [] cpuidle_enter_state+0x248/0x314
[ 5.637079] [] cpuidle_enter+0x18/0x20
[ 5.642404] [] cpu_startup_entry+0x2f4/0x3a8
[ 5.648246] [] secondary_start_kernel+0x140/0x14c
[ 5.654521] [<0000000000d2f178>] 0xd2f178
[ 5.658535] CPU3: stopping
[ 5.661258] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G D 4.4.103 #1
[ 5.668487] Hardware name: Firefly-RK3399 Board BOX (Android) (DT)
[ 5.674673] Call trace:
[ 5.677138] [] dump_backtrace+0x0/0x1cc
[ 5.682547] [] show_stack+0x14/0x1c
[ 5.687615] [] dump_stack+0x94/0xb4
[ 5.692675] [] handle_IPI+0x150/0x2a0
[ 5.697913] [] gic_handle_irq+0x10c/0x154
[ 5.703496] Exception stack(0xffffffc00a3cbde0 to 0xffffffc00a3cbf10)
[ 5.709945] bde0: 0000000000000000 0000000000000000 ffffff80087adc70 0000000029aaaaf1
[ 5.717784] be00: 0000000000000018 00350c543176dd5b 0000000000000a60 0000000000000003
[ 5.725624] be20: 00000032b5193519 ffffff8008081000 0000000000001000 0000000000000000
[ 5.733465] be40: 0000000034d5d91d 00000040ede15000 ffffffc00a3b3400 0000000000000000
[ 5.741304] be60: 0000000000000000 0000000000000000 0000000030d00800 00000001238e47a4
[ 5.749144] be80: 0000000000000001 0000000123797155 ffffffc004ea7800 0000000000000003
[ 5.756984] bea0: 0000000000000001 00000000015e7000 00000000015ea000 0000000000d2f234
[ 5.764825] bec0: 0000000000000000 ffffffc00a3cbf10 ffffff800878bb6c ffffffc00a3cbf10
[ 5.772664] bee0: ffffff800878bb70 0000000020400145 0000000000d2f234 0000000000000001
[ 5.780501] bf00: ffffffffffffffff ffffff800878bb6c
[ 5.785388] [] el1_irq+0xe0/0x170
[ 5.790275] [] cpuidle_enter_state+0x248/0x314
[ 5.796287] [] cpuidle_enter+0x18/0x20
[ 5.801611] [] cpu_startup_entry+0x2f4/0x3a8
[ 5.807454] [] secondary_start_kernel+0x140/0x14c
[ 5.813728] [<0000000000d2f178>] 0xd2f178
[ 5.817742] CRU:
[ 5.819603] 00000000: 00000044 00002201 80000000 00000108 00000007 00007f00 00000000 00000000
[ 5.828131] 00000020: 00000044 00002201 80000000 00000108 00000007 00007f00 00000000 00000000
[ 5.836658] 00000040: 00000064 00001301 8000031f 00000108 00000007 00007f00 00000000 00000000
[ 5.845185] 00000060: 00000190 00001206 80000000 00000108 00000007 00007f00 00000000 00000000
[ 5.853711] 00000080: 00000190 00001206 80000000 00000108 00000007 00007f00 00000000 00000000
[ 5.862237] 000000a0: 0000004b 00001301 80000000 00000108 00000007 00007f00 00000000 00000000
[ 5.870763] 000000c0: 000000c6 00001202 8000031f 00000008 00000007 00007f00 00000000 00000000
[ 5.879288] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 5.887814] 00000100: 00000100 00000202 00000140 00006202 00000083 00008581 00008320 00000141
[ 5.896340] 00000120: 00000181 00008181 00000141 00000141 00004141 00008343 00003185 00000103
[ 5.904866] 00000140: 0000041d 00000300 00002e87 00000113 00009381 00008387 00001103 00001087
[ 5.913392] 00000160: 00008247 00000187 00001743 0000001f 00000380 00000380 00000380 00000001
[ 5.921918] 00000180: 00006380 00009200 00000200 00000200 00000200 00000200 00003f3f 00000081
[ 5.930444] 000001a0: 00000000 00000000 00004141 00000421 00008700 000002dc 00000005 00000381
[ 5.938971] 000001c0: 00000381 00000001 00000003 00000087 00000087 00000141 00000141 00008181
[ 5.947496] 000001e0: 0000833f 00000007 00008f1f 00008f8f 00008f8f 00008787 00008787 00008787
[ 5.956022] 00000200: 000000cf 000000cf 00000000 00000000 00000000 00000000 00000000 00000000
[ 5.964547] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 5.973072] 00000240: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 5.981597] 00000260: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 5.990124] 00000280: 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60
[ 5.998650] 000002a0: 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 00000000 00000000 00000000 00000000
[ 6.007175] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.015700] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.024226] 00000300: 00000080 00000080 00000202 00000000 00000430 00000000 00000005 00000000
[ 6.032752] 00000320: 00008000 00002000 00000001 00000000 0000001e 000000f1 00000000 00000000
[ 6.041278] 00000340: 00000505 00000000 00000000 00000000 00000c04 00000000 00004440 00000800
[ 6.049804] 00000360: 00000000 00000020 00000000 00000000 00000000 00000000 00000116 00000038
[ 6.058329] 00000380: 00000000 00000000 00000018 00000000 00000000 00000000 00000000 00000000
[ 6.066854] 000003a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.075379] 000003c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.083904] 000003e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.092428] 00000400: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.100954] 00000420: 00000000 00007070 00000000 00000014 00000000 00000000 00000000 00000000
[ 6.109479] 00000440: 00000000 00000000 00000000 00000000 00003000 00000000 00000000 00000000
[ 6.118003] 00000460: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.126528] 00000480: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.135053] 000004a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.143577] 000004c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.152102] 000004e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.160628] 00000500: 00000000 00000000 00640064 00000000 00000003 00000000 00000000 00000000
[ 6.169152] 00000520: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.177677] 00000540: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.186202] 00000560: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.194723] 00000580: 00000004 00000000 00000004 00000000 00000004
[ 6.200903] PMU CRU:
[ 6.203109] 00000000: 000000a9 00001203 80000000 00000108 00000007 00007f00 00000000 00000000
[ 6.211635] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.220163] 00000040: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.228689] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.237217] 00000080: 0000060d 00001986 00000d0d 0000000d 000002dc 00000600 0bb8ea60 0bb8ea60
[ 6.245744] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.254270] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.262796] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.271323] 00000100: 00000600 00004188 0000000f 00000000 00000024 00000000 00000000 00000000
[ 6.279846] 00000120: 00000000 00000000 00000000 00000000 00000003
[ 6.286029] Kernel Offset: disabled
[ 6.289518] Memory Limit: none
[ 6.292594] rockchip-thermal ff260000.tsadc: channal 0: temperature(30 C)
[ 6.299376] THERMAL REGS:
[ 6.302017] 00000000: 00000200 00030133 00000031 00000002 00000000 00000000 00000000 00000000
[ 6.310543] 00000020: 0000020d 0000020d 00000000 00000000 0000024e 00000000 00000000 00000000
[ 6.319069] 00000040: 00000279 00000279 00000000 00000000 00000000 00000000 00000000 00000000
[ 6.327595] 00000060: 00000004 00000004 00000753 00000753 00000000 00000000 00000000 00000000
[ 6.336113] 00000080: 00000000 00000000
[ 6.369105] Rebooting in 5 seconds..
烧录进去 串口乱码 一直重启 我的更坑 我改了几组IO口 现在改成和开发板一模一样 希望能解决
楼主,这个问题怎么样了,怎么解决的啊?!求教。
