kernel message, 還望高人指點!
<6>[ 0.000000] Booting Linux on physical CPU 0x500
<6>[ 0.000000] Initializing cgroup subsys cpu
<6>[ 0.000000] Initializing cgroup subsys cpuacct
<5>[ 0.000000] Linux version 3.10.0 (leo@UBUNTU1404) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #13 SMP PREEMPT Mon May 11 16:57:12 CST 2015
<4>[ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d
<4>[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
<6>[ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288
<4>[ 0.000000] rockchip_ion_reserve
<6>[ 0.000000] ion heap(cma): base(40000000) size(28000000) align(0)
<6>[ 0.000000] ion heap(vmalloc): base(0) size(0) align(0)
<6>[ 0.000000] cma: CMA: reserved 640 MiB at 40000000
<6>[ 0.000000] ion_reserve: cma reserved base 40000000 size 671088640
<6>[ 0.000000] cma: CMA: reserved 16 MiB at 2e800000
<4>[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
<7>[ 0.000000] On node 0 totalpages: 524288
<7>[ 0.000000] free_area_init_node: node 0, pgdat c0c78340, node_mem_map c0d9e000
<7>[ 0.000000] Normal zone: 1520 pages used for memmap
<7>[ 0.000000] Normal zone: 0 pages reserved
<7>[ 0.000000] Normal zone: 194560 pages, LIFO batch:31
<7>[ 0.000000] HighMem zone: 2576 pages used for memmap
<7>[ 0.000000] HighMem zone: 329728 pages, LIFO batch:31
<6>[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1dda000 s14016 r8192 d14656 u36864
<7>[ 0.000000] pcpu-alloc: s14016 r8192 d14656 u36864 alloc=9*4096
<7>[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
<4>[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 522768
<5>[ 0.000000] Kernel command line: console=ttyS2 earlyprintk androidboot.hardware=rk30board androidboot.console=ttyS2 board.ap_has_alsa=0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00180000@0x00092000(system),0x00002000@0x00212000(metadata),0x00200000@0x00214000(userdata),0x00020000@0x00414000(radical_update),-@0x00434000(user) storagemedia=emmc loader.timestamp=2014-11-27_16:44:27 androidboot.serialno=10061200000002AD
<6>[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
<6>[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
<6>[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
<6>[ 0.000000] allocated 4194304 bytes of page_cgroup
<6>[ 0.000000] please try ‘cgroup_disable=memory’ option if you don’t want memory cgroups
<6>[ 0.000000] Memory: 2048MB = 2048MB total
<5>[ 0.000000] Memory: 1388500k/1388500k available, 708652k reserved, 663552K highmem
<5>[ 0.000000] Virtual kernel memory layout:
<5>[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
<5>[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
<5>[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
<5>[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
<5>[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
<5>[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
<5>[ 0.000000] .text : 0xc0008000 - 0xc0adb590 (11086 kB)
<5>[ 0.000000] .init : 0xc0adc000 - 0xc0b706c0 ( 594 kB)
<5>[ 0.000000] .data : 0xc0b72000 - 0xc0c7fb78 (1079 kB)
<5>[ 0.000000] .bss : 0xc0c7fb78 - 0xc0d9da84 (1144 kB)
<6>[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
<6>[ 0.000000] Preemptible hierarchical RCU implementation.
<6>[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
<6>[ 0.000000] NR_IRQS:16 nr_irqs:16 16
<4>[ 0.000000] rk_clk_tree_init start! cru base = 0xfed00000
<4>[ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 0
<4>[ 0.000000] rkclk_init_clks: cnt_parent = 7
<4>[ 0.000000] rkclk_init_clks: cnt_rate = 31
<6>[ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
<6>[ 0.000000] Switching to timer-based delay loop
<6>[ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns
<6>[ 0.000000] process version: 1
<6>[ 0.000000] channel:0, lkg:29
<6>[ 0.000000] target-temp:80
<6>[ 0.000000] channel:2, lkg:0
<6>[ 0.000000] channel:1, lkg:24
<6>[ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms
<6>[ 0.304305] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
<6>[ 0.304320] pid_max: default: 32768 minimum: 301
<6>[ 0.304424] Security Framework initialized
<6>[ 0.304440] SELinux: Initializing.
<7>[ 0.304466] SELinux: Starting in permissive mode
<6>[ 0.304511] Mount-cache hash table entries: 512
<6>[ 0.305147] Initializing cgroup subsys debug
<6>[ 0.305161] Initializing cgroup subsys memory
<6>[ 0.305187] Initializing cgroup subsys freezer
<6>[ 0.305216] CPU: Testing write buffer coherency: ok
<3>[ 0.305526] /cpus/cpu@0 missing clock-frequency property
<3>[ 0.305539] /cpus/cpu@1 missing clock-frequency property
<3>[ 0.305548] /cpus/cpu@2 missing clock-frequency property
<3>[ 0.305557] /cpus/cpu@3 missing clock-frequency property
<6>[ 0.305620] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
<6>[ 0.305671] Setting up static identity map for 0xc07dca28 - 0xc07dca80
<6>[ 0.308626] last_log: 0x2e100000 map to 0xf0004000 and copy to 0xf0086000, size 0x80000 early 0x1681 (version 3.0)
<4>[ 0.382419] CPU1: Booted secondary processor
<6>[ 0.382452] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
<4>[ 0.402104] CPU2: Booted secondary processor
<6>[ 0.402128] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
<4>[ 0.421813] CPU3: Booted secondary processor
<6>[ 0.421837] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
<6>[ 0.421939] Brought up 4 CPUs
<6>[ 0.421967] SMP: Total of 4 processors activated (192.00 BogoMIPS).
<6>[ 0.421977] CPU: All CPU(s) started in SVC mode.
<6>[ 0.422695] devtmpfs: initialized
<6>[ 0.427692] pinctrl core: initialized pinctrl subsystem
<6>[ 0.427937] regulator-dummy: no parameters
<6>[ 0.439363] NET: Registered protocol family 16
<6>[ 0.441204] DMA: preallocated 256 KiB pool for atomic coherent allocations
<6>[ 0.441514] ion_snapshot: 0x2e1e0000 map to 0xf0107000 and copy to 0xc0d79084 (version 0.1)
<6>[ 0.441848] Registered FIQ tty driver
<3>[ 0.442258] fiq-debugger is disabled in device tree
<4>[ 0.442893] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
<4>[ 0.442914] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
<4>[ 0.442930] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
<4>[ 0.442946] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
<4>[ 0.443039] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
<4>[ 0.443103] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
<4>[ 0.443163] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
<4>[ 0.443223] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
<4>[ 0.443282] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
<4>[ 0.443341] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
<4>[ 0.443401] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
<4>[ 0.443461] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
<4>[ 0.443526] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
<4>[ 0.443588] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
<4>[ 0.443601] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
<4>[ 0.443613] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
<4>[ 0.443623] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
<7>[ 0.443692] gpiochip_add: registered GPIOs 0 to 31 on device: gpio0
<7>[ 0.443739] gpiochip_add: registered GPIOs 32 to 63 on device: gpio1
<7>[ 0.443784] gpiochip_add: registered GPIOs 64 to 95 on device: gpio2
<7>[ 0.443834] gpiochip_add: registered GPIOs 96 to 127 on device: gpio3
<7>[ 0.443879] gpiochip_add: registered GPIOs 128 to 159 on device: gpio4
<7>[ 0.443923] gpiochip_add: registered GPIOs 160 to 191 on device: gpio5
<7>[ 0.443972] gpiochip_add: registered GPIOs 192 to 223 on device: gpio6
<7>[ 0.444017] gpiochip_add: registered GPIOs 224 to 255 on device: gpio7
<7>[ 0.444061] gpiochip_add: registered GPIOs 256 to 287 on device: gpio8
<7>[ 0.444106] gpiochip_add: registered GPIOs 288 to 319 on device: gpio15
<4>[ 0.444137] rockchip_interrupts_register:bank_num=7
<4>[ 0.446059] rockchip_pinctrl_probe:init ok
<6>[ 0.452162] rk_iommu ff900800.iep_mmu: (iep) Enter
<6>[ 0.452249] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.452262] rk_iommu ff900800.iep_mmu: (iep) Initialized
<6>[ 0.452424] rk_iommu ff950800.vip_mmu: (vip) Enter
<6>[ 0.452496] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.452509] rk_iommu ff950800.vip_mmu: (vip) Initialized
<6>[ 0.452665] rk_iommu ff930300.vopb_mmu: (vopb) Enter
<6>[ 0.452739] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.452752] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
<6>[ 0.452909] rk_iommu ff940300.vopl_mmu: (vopl) Enter
<6>[ 0.452979] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.452991] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
<6>[ 0.453159] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
<6>[ 0.453233] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.453245] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
<6>[ 0.453401] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
<6>[ 0.453470] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.453482] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
<6>[ 0.453648] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
<6>[ 0.453722] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.453734] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
<6>[ 0.455349] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
<6>[ 0.455361] hw-breakpoint: maximum watchpoint size is 4 bytes.
<4>[ 0.455558] DDR DEBUG: version 1.00 20140603
<4>[ 0.455586] DDR DEBUG: Channel a:
<4>[ 0.455594] DDR DEBUG: DDR3 Device
<4>[ 0.455608] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
<4>[ 0.455617] DDR DEBUG: Channel b:
<4>[ 0.455624] DDR DEBUG: DDR3 Device
<4>[ 0.455636] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
<4>[ 0.455646] DDR DEBUG: addr=0xc87000
<4>[ 0.455655] DDR DEBUG: stride=9, size=256, halfcap=40000000
<4>[ 0.455664] DDR DEBUG: socAddr[0]=0xc87000, socAddr[1]=0xc87100
<4>[ 0.455673] DDR DEBUG: chAddr[0]=0xc87000, chAddr[1]=0xc87000
<4>[ 0.455684] DDR DEBUG: dtar[0]=0x70190000, dtar[1]=0x70190000
<4>[ 0.455924] DDR DEBUG: init success!!! freq=300MHz
<4>[ 0.455933] DDR DEBUG: Channel a:
<4>[ 0.455945] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
<4>[ 0.455957] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
<4>[ 0.455969] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
<4>[ 0.455981] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
<4>[ 0.455992] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
<4>[ 0.456001] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
<4>[ 0.456010] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
<4>[ 0.456017] DDR DEBUG: Channel b:
<4>[ 0.456028] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
<4>[ 0.456040] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
<4>[ 0.456052] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
<4>[ 0.456064] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270
<4>[ 0.456075] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
<4>[ 0.456083] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
<4>[ 0.456092] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
<6>[ 0.478109] bio: create slab at 0
<5>[ 0.478878] SCSI subsystem initialized
<6>[ 0.479022] usbcore: registered new interface driver usbfs
<6>[ 0.479064] usbcore: registered new interface driver hub
<6>[ 0.479142] usbcore: registered new device driver usb
<7>[ 0.479384] of_get_named_gpio_flags exited with status 14
<7>[ 0.479411] of_get_named_gpio_flags exited with status 12
<7>[ 0.480314] of_get_named_gpio_flags exited with status 15
<7>[ 0.480333] of_get_named_gpio_flags exited with status 16
<6>[ 0.480487] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
<7>[ 0.482456] of_get_named_gpio_flags exited with status 260
<7>[ 0.482476] of_get_named_gpio_flags exited with status 261
<6>[ 0.482622] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
<7>[ 0.483915] of_get_named_gpio_flags exited with status 201
<7>[ 0.483935] of_get_named_gpio_flags exited with status 202
<6>[ 0.484072] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
<7>[ 0.484837] of_get_named_gpio_flags exited with status 81
<7>[ 0.484856] of_get_named_gpio_flags exited with status 80
<6>[ 0.484993] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
<7>[ 0.485086] of_get_named_gpio_flags exited with status 241
<7>[ 0.485103] of_get_named_gpio_flags exited with status 242
<6>[ 0.485231] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
<6>[ 0.485686] media: Linux media interface: v0.10
<6>[ 0.485730] Linux video capture interface: v2.00
<6>[ 0.485776] pps_core: LinuxPPS API ver. 1 registered
<6>[ 0.485786] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
<6>[ 0.485805] PTP clock support registered
<6>[ 0.486293] Rockchip ion module is successfully loaded (v1.0)
<6>[ 0.486445] Advanced Linux Sound Architecture Driver Initialized.
<6>[ 0.486808] Bluetooth: Core ver 2.16
<6>[ 0.486847] NET: Registered protocol family 31
<6>[ 0.486857] Bluetooth: HCI device and connection manager initialized
<6>[ 0.486872] Bluetooth: HCI socket layer initialized
<6>[ 0.486885] Bluetooth: L2CAP socket layer initialized
<6>[ 0.486909] Bluetooth: SCO socket layer initialized
<6>[ 0.487123] cfg80211: Calling CRDA to update world regulatory domain
<4>[ 0.487804] act8846_i2c_probe,line=898
<4>[ 0.488753] act8846_parse_dt,line=746
<7>[ 0.489384] of_get_named_gpio_flags exited with status 238
<7>[ 0.489397] of_get_named_gpio_flags exited with status 1
<7>[ 0.489409] of_get_named_gpio_flags exited with status 234
<7>[ 0.489421] of_get_named_gpio_flags exited with status 259
<4>[ 0.489440] act8846_i2c_probe: act8846_pmic_hold=1
<4>[ 0.489459] act8846_i2c_probe: act8846_pmic_sleep=1
<4>[ 0.489473] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
<4>[ 0.489487] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
<6>[ 0.491322] act_dcdc1: 1200 mV
<6>[ 0.494046] vccio: 3300 mV
<6>[ 0.495891] vdd_logic: 700 ↔ 1500 mV at 1100 mV
<6>[ 0.498582] act_dcdc4: 2000 mV
<6>[ 0.499807] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
<6>[ 0.501868] act_ldo2: 1000 mV
<6>[ 0.503927] act_ldo3: 2800 mV
<6>[ 0.506010] act_ldo4: 3300 mV
<6>[ 0.508074] act_ldo5: 3300 mV
<6>[ 0.510143] act_ldo6: 1000 mV
<6>[ 0.512230] vcc_18: 1800 mV
<6>[ 0.514297] act_ldo8: 1800 mV
<6>[ 0.519041] vdd_arm: 712 ↔ 1500 mV at 1000 mV
<6>[ 0.523737] vdd_gpu: 712 ↔ 1500 mV at 1000 mV
<6>[ 0.524561] Switching to clocksource arch_sys_counter
<7>[ 0.544389] uboot-logo-on:0
<6>[ 0.544433] rk-fb rockchip-fb: rk fb ion client create success!
<6>[ 0.544445] rk-fb rockchip-fb: rockchip framebuffer driver probe
<6>[ 0.544835] rk-screen rk_screen.8: rockchip screen probe success
<3>[ 0.544990] rk32-lvds ff96c000.lvds: screen is not lvds/rgb!
<4>[ 0.545009] rk32-lvds: probe of ff96c000.lvds failed with error -22
<6>[ 0.545578] rk32-edp rk32-edp: rk32 edp driver probe success
<6>[ 0.546263] graphics fb0: rockchip framebuffer registerd:fb0
<6>[ 0.546561] graphics fb1: rockchip framebuffer registerd:fb1
<6>[ 0.546713] graphics fb2: rockchip framebuffer registerd:fb2
<6>[ 0.546864] graphics fb3: rockchip framebuffer registerd:fb3
<6>[ 0.548088] rk3288-lcdc lcdc0: lcdc0: dclk:360000000>>fps:42
<6>[ 0.548292] rk32-edp rk32-edp: edp pll locked
<6>[ 0.548927] rk32-edp rk32-edp: max link rate:5.40Gps max number of lanes:4
<4>[ 0.548940] rk32-edp rk32-edp: Rx Max Link Rate is abnormal :14 !use default link rate:2.70Gps
<6>[ 0.551920] rk32-edp rk32-edp: link training success.
<4>[ 0.576130] rk_battery_charger_detect_cb , battery_charger_detect 1
<6>[ 0.652070] rk3288-lcdc lcdc0: wakeup from standby!
<6>[ 0.746081] alloc_buffer:ion_phy_addr=0x40000000
<6>[ 0.794806] fb0:phy:40000000>>vir:f018a000>>len:0x6000000
<6>[ 0.798339] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu disabled
<3>[ 0.798515] rk3288-lcdc lcdc1: can’t find power_ctr node for lcdc1
<4>[ 0.798527] rk_fb_trsm_ops_get:un supported transmitter:0!
<6>[ 0.798770] graphics fb4: rockchip framebuffer registerd:fb4
<6>[ 0.799071] graphics fb5: rockchip framebuffer registerd:fb5
<6>[ 0.799226] graphics fb6: rockchip framebuffer registerd:fb6
<6>[ 0.799374] graphics fb7: rockchip framebuffer registerd:fb7
<6>[ 0.799388] fb0:phy:40000000>>vir:f018a000>>len:0x6000000
<6>[ 0.799400] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu disabled
<4>[ 0.800022] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.800170] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.800283] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.800391] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.800492] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.800598] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.801170] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.801309] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.801840] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.801977] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.802508] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.802640] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.803181] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.803320] rockchip_set_mux:warning ignore bank num 15
<6>[ 0.804653] NET: Registered protocol family 2
<6>[ 0.805095] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
<6>[ 0.805249] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
<6>[ 0.805382] TCP: Hash tables configured (established 8192 bind 8192)
<6>[ 0.805434] TCP: reno registered
<6>[ 0.805448] UDP hash table entries: 512 (order: 2, 16384 bytes)
<6>[ 0.805482] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
<6>[ 0.805686] NET: Registered protocol family 1
<6>[ 0.805869] Unpacking initramfs…
<6>[ 0.868036] Freeing initrd memory: 1160K (c4bf0000 - c4d12000)
<6>[ 0.868672] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
<6>[ 0.869207] probe device ff9a0000.vpu_service
<4>[ 0.869388] vpu_service: power on
<6>[ 0.870443] checking hw id 4831
<6>[ 0.870788] vpu_service set to auto frequency mode
<6>[ 0.870822] vpu_service: power off…
<6>[ 0.870856] done
<6>[ 0.870864] init success
<6>[ 0.870913] probe device ff9c0000.hevc_service
<4>[ 0.871116] hevc_service: power on
<6>[ 0.872150] checking hw id 6867
<6>[ 0.872364] hevc_service: power off…
<6>[ 0.872399] done
<6>[ 0.872407] init success
<4>[ 0.872511] rknandbase v1.0 2014-03-31
<3>[ 0.872606] rknand ff400000.nandc0: no irq resource?
<4>[ 0.872722] rknand_driver:ret = 0
<6>[ 0.873384] audit: initializing netlink socket (disabled)
<5>[ 0.873421] type=2000 audit(0.570:1): initialized
<4>[ 0.874167] bounce pool size: 64 pages
<6>[ 0.878604] fuse init (API version 7.22)
<6>[ 0.878979] msgmni has been set to 1450
<7>[ 0.879025] SELinux: Registering netfilter hooks
<6>[ 0.880703] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
<6>[ 0.880717] io scheduler noop registered
<6>[ 0.880726] io scheduler deadline registered
<6>[ 0.880808] io scheduler cfq registered (default)
<6>[ 0.884273] rga2 ff920000.rga: rga ion client create success!
<6>[ 0.884408] rga: Driver loaded succesfully
<4>[ 0.885004] IEP Driver loaded succesfully
<4>[ 0.885088] Module initialized.
<6>[ 0.885920] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
<6>[ 0.885937] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
<6>[ 0.887188] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
<6>[ 0.887204] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
<6>[ 0.887558] vdd_logic: 925 ↔ 1400 mV at 1000 mV
<4>[ 0.887606] vdd_logic: Failed to create debugfs directory
<4>[ 0.888018] rk_serial.c v1.8 2014-03-04
<6>[ 0.888225] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
<6>[ 0.888406] serial ff180000.serial: membase f619e000
<6>[ 0.888537] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
<6>[ 2.537282] console [ttyS2] enabled
<6>[ 2.540890] serial ff690000.serial: membase fed60000
<6>[ 2.548417] loop: module loaded
<6>[ 2.552075] SCSI Media Changer driver v0.25
<6>[ 2.556578] tun: Universal TUN/TAP device driver, 1.6
<6>[ 2.561578] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
<4>[ 2.567764] vmac_init.
<3>[ 2.570585] stmmac_probe_config_dt: Can not read property: pmu_regulator.
<3>[ 2.577278] stmmac_probe_config_dt: Can not read property: pmu_enable_level.
<6>[ 2.584232] stmmac_probe_config_dt: clock input or output? (input).
<6>[ 2.590394] stmmac_probe_config_dt: TX delay(0x30).
<6>[ 2.595206] stmmac_probe_config_dt: RX delay(0x20).
<7>[ 2.600003] of_get_named_gpio_flags: can’t parse gpios property
<7>[ 2.600017] of_get_named_gpio_flags exited with status 136
<7>[ 2.600028] of_get_named_gpio_flags exited with status 6
<4>[ 2.600039] stmmac_probe_config_dt: is rockchip,rk3288-gmac
<6>[ 2.605355] stmmc_pltfr_init:
<6>[ 2.608561] stmmc_pltfr_init: init for RGMII
<6>[ 2.612773] tx delay=0x30
<6>[ 2.612773] rx delay=0x20
<6>[ 2.618341] stmmac - user ID: 0x10, Synopsys ID: 0x35
<6>[ 2.623322] Normal descriptors
<6>[ 2.626410] Ring mode enabled
<6>[ 2.629414] DMA HW capability register supported
<6>[ 2.633893] RX Checksum Offload Engine supported (type 2)
<6>[ 2.639465] TX Checksum insertion supported
<6>[ 2.643670] Wake-Up On Lan supported
<6>[ 2.647298] Enable RX Mitigation via HW Watchdog Timer
<6>[ 2.652836] PPP generic driver version 2.4.2
<6>[ 2.657182] PPP BSD Compression module registered
<6>[ 2.661826] PPP Deflate Compression module registered
<6>[ 2.666803] PPP MPPE Compression module registered
<6>[ 2.671524] NET: Registered protocol family 24
<6>[ 2.675914] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
<6>[ 2.685424] CSLIP: code copyright 1989 Regents of the University of California.
<4>[ 2.692619] Rockchip WiFi SYS interface (V1.00) …
<4>[ 2.697521] esp_mem_init enter date Apr 30 2015 15:39:34
<4>[ 2.702794] esp_mem_init complete
<6>[ 2.706210] usbcore: registered new interface driver catc
<6>[ 2.711562] usbcore: registered new interface driver kaweth
<6>[ 2.717042] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
<6>[ 2.724363] usbcore: registered new interface driver pegasus
<6>[ 2.729966] usbcore: registered new interface driver rtl8150
<6>[ 2.735556] usbcore: registered new interface driver r8152
<6>[ 2.740960] hso: drivers/net/usb/hso.c: Option Wireless
<6>[ 2.746153] usbcore: registered new interface driver hso
<6>[ 2.751441] usbcore: registered new interface driver asix
<6>[ 2.756778] usbcore: registered new interface driver ax88179_178a
<6>[ 2.762810] usbcore: registered new interface driver cdc_ether
<6>[ 2.768584] usbcore: registered new interface driver cdc_eem
<6>[ 2.774187] usbcore: registered new interface driver dm9601
<6>[ 2.779703] usbcore: registered new interface driver dm9620
<6>[ 2.785218] usbcore: registered new interface driver smsc75xx
<6>[ 2.790918] usbcore: registered new interface driver smsc95xx
<6>[ 2.796611] usbcore: registered new interface driver gl620a
<6>[ 2.802130] usbcore: registered new interface driver net1080
<6>[ 2.807733] usbcore: registered new interface driver plusb
<6>[ 2.813155] usbcore: registered new interface driver rndis_host
<6>[ 2.819025] usbcore: registered new interface driver cdc_subset
<6>[ 2.824870] usbcore: registered new interface driver zaurus
<6>[ 2.830393] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
<6>[ 2.837724] usbcore: registered new interface driver int51x1
<6>[ 2.843329] usbcore: registered new interface driver kalmia
<6>[ 2.848858] usbcore: registered new interface driver ipheth
<6>[ 2.854367] usbcore: registered new interface driver sierra_net
<6>[ 2.860228] usbcore: registered new interface driver cx82310_eth
<6>[ 2.866186] usbcore: registered new interface driver cdc_ncm
<6>[ 2.871793] usbcore: registered new interface driver qmi_wwan
<6>[ 2.877484] usbcore: registered new interface driver cdc_mbim
<6>[ 2.883133] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
<4>[ 2.891929] ehci_rk_probe f6200000 f6200010
<6>[ 2.896063] rockchip_ehci_host ff500000.usb: Rockchip On-Chip EHCI Host Controller
<6>[ 2.903521] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
<6>[ 2.911936] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
<6>[ 2.935421] rockchip_ehci_host ff500000.usb: USB 0.0 started, EHCI 1.00
<6>[ 2.941986] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 2.948673] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 2.955786] usb usb1: Product: Rockchip On-Chip EHCI Host Controller
<6>[ 2.962048] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
<6>[ 2.967369] usb usb1: SerialNumber: ff500000.usb
<6>[ 2.972332] hub 1-0:1.0: USB hub found
<6>[ 2.976048] hub 1-0:1.0: 1 port detected
<4>[ 3.004295] ehci_rk_probe ok
<6>[ 3.007262] usbcore: registered new interface driver cdc_acm
<6>[ 3.012826] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
<6>[ 3.020751] usbcore: registered new interface driver usblp
<6>[ 3.026189] usbcore: registered new interface driver cdc_wdm
<6>[ 3.031825] usbcore: registered new interface driver usb-storage
<6>[ 3.037777] usbcore: registered new interface driver ums-alauda
<6>[ 3.043624] usbcore: registered new interface driver ums-cypress
<6>[ 3.049568] usbcore: registered new interface driver ums-datafab
<6>[ 3.055524] usbcore: registered new interface driver ums_eneub6250
<6>[ 3.061626] usbcore: registered new interface driver ums-freecom
<6>[ 3.067570] usbcore: registered new interface driver ums-isd200
<6>[ 3.073472] usbcore: registered new interface driver ums-jumpshot
<6>[ 3.079505] usbcore: registered new interface driver ums-karma
<6>[ 3.085292] usbcore: registered new interface driver ums-onetouch
<6>[ 3.091310] usbcore: registered new interface driver ums-sddr09
<6>[ 3.097175] usbcore: registered new interface driver ums-sddr55
<6>[ 3.103054] usbcore: registered new interface driver ums-usbat
<6>[ 3.108857] usbcore: registered new interface driver usbserial
<6>[ 3.114634] usbcore: registered new interface driver usbserial_generic
<6>[ 3.121084] usbserial: USB Serial support registered for generic
<6>[ 3.127030] usbcore: registered new interface driver option
<6>[ 3.132537] usbserial: USB Serial support registered for GSM modem (1-port)
<6>[ 3.139435] usbcore: registered new interface driver trancevibrator
<6>[ 3.145619] usb20_otg: version 3.10a 21-DEC-2012
<4>[ 3.150540] f6280040
<4>[ 3.152711] Core Release: 3.10a
<4>[ 3.155802] Setting default values for core params
<4>[ 3.160611] Using Buffer DMA mode
<4>[ 3.163885] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 3.169632] Multiprocessor Interrupt Enhancement - disabled
<4>[ 3.175121] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 3.179404] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 3.183272] Dedicated Tx FIFOs mode
<4>[ 3.186711] pcd_init otg_dev = ed66b200
<6>[ 3.190611] usb20_otg ff580000.usb: DWC OTG Controller
<6>[ 3.195706] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
<6>[ 3.203089] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
<6>[ 3.208780] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 3.215481] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 3.222592] usb usb2: Product: DWC OTG Controller
<6>[ 3.227218] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
<6>[ 3.232791] usb usb2: SerialNumber: ff580000.usb
<6>[ 3.237696] hub 2-0:1.0: USB hub found
<6>[ 3.241424] hub 2-0:1.0: 1 port detected
<6>[ 3.245562] usb20_host: version 3.10a 21-DEC-2012
<4>[ 3.252644] f6300040
<4>[ 3.254799] Core Release: 3.10a
<4>[ 3.257889] Setting default values for core params
<4>[ 3.262717] Using Buffer DMA mode
<4>[ 3.265979] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 3.271725] Multiprocessor Interrupt Enhancement - disabled
<4>[ 3.277203] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 3.281495] ^^^^^^^^^^^^^^^^^^Host Mode
<6>[ 3.285297] usb20_host ff540000.usb: DWC OTG Controller
<6>[ 3.290461] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
<6>[ 3.297918] usb20_host ff540000.usb: irq 57, io mem 0x00000000
<4>[ 3.303766] Init: Power Port (0)
<6>[ 3.306987] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 3.313688] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 3.320801] usb usb3: Product: DWC OTG Controller
<6>[ 3.325428] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
<6>[ 3.331002] usb usb3: SerialNumber: ff540000.usb
<6>[ 3.335898] hub 3-0:1.0: USB hub found
<6>[ 3.339647] hub 3-0:1.0: 1 port detected
<4>[ 3.339660] dwc_otg_hcd_suspend, usb device mode
<4>[ 3.348549] .. rk pwm remotectl v1.0 init
<4>[ 3.352583] remotectl probe j=0x0
<6>[ 3.355986] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
<4>[ 3.362500] pwm enable val=0x646205
<6>[ 3.366260] usbcore: registered new interface driver xpad
<6>[ 3.371626] usbcore: registered new interface driver usb_acecad
<6>[ 3.377478] usbcore: registered new interface driver aiptek
<6>[ 3.383024] usbcore: registered new interface driver gtco
<6>[ 3.388381] usbcore: registered new interface driver hanwang
<6>[ 3.393976] usbcore: registered new interface driver kbtab
<6>[ 3.399421] usbcore: registered new interface driver wacom
<4>[ 3.404825] ==ft5x0x_ts_init==
<4>[ 3.407902] [FTS] ft5x0x_ts_probe, driver version is 3.0.
<7>[ 3.413219] of_get_named_gpio_flags exited with status 263
<6>[ 3.413527] input: ft5x0x_ts as /devices/virtual/input/input1
<4>[ 3.575048] rockchip_i2c ff140000.i2c: Warning: addr[0x0038] msg[0].scl_rate( = 3993452Khz) is too high!
<4>[ 3.584506] rockchip_i2c ff140000.i2c: Warning: addr[0x0038] msg[0].scl_rate( = 3993452Khz) is too high!
<4>[ 3.593983] rockchip_i2c ff140000.i2c: Warning: addr[0x0038] msg[0].scl_rate( = 3993452Khz) is too high!
<3>[ 3.603437] msg ft5x0x_read_reg i2c read error: -11
<4>[ 3.608244] [FTS] Firmware version = 0xff
<4>[ 3.612216] rockchip_i2c ff140000.i2c: Warning: addr[0x0038] msg[0].scl_rate( = 3993452Khz) is too high!
<4>[ 3.621690] rockchip_i2c ff140000.i2c: Warning: addr[0x0038] msg[0].scl_rate( = 3993452Khz) is too high!
<4>[ 3.631160] rockchip_i2c ff140000.i2c: Warning: addr[0x0038] msg[0].scl_rate( = 3993452Khz) is too high!
<3>[ 3.640615] msg ft5x0x_read_reg i2c read error: -11
<4>[ 3.645422] [FTS] report rate is 2550Hz.
<4>[ 3.649299] rockchip_i2c ff140000.i2c: Warning: addr[0x0038] msg[0].scl_rate( = 3993452Khz) is too high!
<4>[ 3.658768] rockchip_i2c ff140000.i2c: Warning: addr[0x0038] msg[0].scl_rate( = 3993452Khz) is too high!
<4>[ 3.668245] rockchip_i2c ff140000.i2c: Warning: addr[0x0038] msg[0].scl_rate( = 3993452Khz) is too high!
<3>[ 3.677693] msg ft5x0x_read_reg i2c read error: -11
<4>[ 3.682498] [FTS] touch threshold is 1020.
<4>[ 3.686550] ft5x0x:ft5x0x_ts_probe() - sysfs_create_group() succeeded.
<4>[ 3.692966] [FTS] ==probe over =
<4>[ 3.696207] ret=0
<7>[ 3.701046] of_get_named_gpio_flags exited with status 228
<6>[ 3.702941] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
<6>[ 3.709246] i2c /dev entries driver
<6>[ 3.713356] IR NEC protocol handler initialized
<6>[ 3.717812] IR RC5(x) protocol handler initialized
<6>[ 3.722520] IR RC6 protocol handler initialized
<6>[ 3.726988] IR JVC protocol handler initialized
<6>[ 3.731446] IR Sony protocol handler initialized
<6>[ 3.735995] IR RC5 (streamzap) protocol handler initialized
<6>[ 3.741472] IR SANYO protocol handler initialized
<6>[ 3.746104] IR MCE Keyboard/mouse protocol handler initialized
<6>[ 3.751963] usbcore: registered new interface driver uvcvideo
<6>[ 3.757637] USB Video Class driver (1.1.1)
<4>[ 3.761668] CamSys driver version: v0.23.0, CamSys head file version: v0.9.0
<7>[ 3.770059] of_get_named_gpio_flags exited with status 236
<4>[ 3.770073] D1:camsys_platform_probe(1067): 1-gpios-cifpower: gpio=236
<7>[ 3.776692] of_get_named_gpio_flags exited with status 236
<4>[ 3.776702] D1:camsys_platform_probe(1070): gpios-cifpower: gpio_request
<4>[ 3.783478] D1:camsys_platform_probe(1072): 1-gpios-cifpower: gpio_request=0
<4>[ 3.790583] D1:camsys_platform_probe(1079): gpios-cifpower: 236 high
<4>[ 3.797082] D1:camsys_mipiphy_probe_cb(163): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
<4>[ 3.807915] D1:camsys_mipiphy_probe_cb(160): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xf61d8000 size: 0x4000)
<4>[ 3.820666] D1:camsys_platform_probe(1183): ff910000.isp memory:
<4>[ 3.826604] D1:camsys_platform_probe(1193): Register memory (phy: 0xff910000 vir: 0xf61e0000 size: 0x10000)
<4>[ 3.836530] D1:camsys_platform_probe(1188): I2c memory (phy: 0x2d67e000 vir: 0xed67e000 size: 0x1000)
<4>[ 3.845941] D1:camsys_platform_probe(1208): Probe ff910000.isp device success
<4>[ 3.854232] rockchip_temp_probe,line=362
<6>[ 3.909585] tsadc ff280000.tsadc: initialized
<6>[ 3.914221] device-mapper: uevent: version 1.0.3
<6>[ 3.919004] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
<6>[ 3.927562] Bluetooth: HCI UART driver ver 2.2
<6>[ 3.931950] Bluetooth: HCI H4 protocol initialized
<6>[ 3.936661] Bluetooth: HCILL protocol initialized
<4>[ 3.943851] cpufreq version 1.0, suspend freq 1200 MHz
<6>[ 3.949087] cpuidle: using governor ladder
<6>[ 3.953117] cpuidle: using governor menu
<6>[ 3.956997] Synopsys Designware Multimedia Card Interface Driver
<6>[ 3.963154] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
<6>[ 3.969284] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
<4>[ 3.976268] 3379..dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
<4>[ 3.982705] mmc0 : Rockchip specific MHSC: Ver 1.13 2014-09-05
<7>[ 3.988489] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 3.988594] 1390..dw_mci_set_ios: no card. [mmc0]
<4>[ 4.007994] 1390..dw_mci_set_ios: no card. [mmc0]
<4>[ 4.027711] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
<6>[ 4.027764] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
<6>[ 4.027789] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
<6>[ 4.028406] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
<6>[ 4.058510] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
<4>[ 4.065553] 3379..dw_mci_init_slot: fmin=400000, fmax=50000000 [mmc1]
<4>[ 4.071939] mmc1 : Rockchip specific MHSC: Ver 1.13 2014-09-05
<7>[ 4.077726] of_get_named_gpio_flags: can’t parse gpios property
<6>[ 4.077797] mmc1: no vmmc regulator found
<4>[ 4.081919] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
<4>[ 4.088744] 1390..dw_mci_set_ios: no card. [mmc1]
<4>[ 4.106385] 1390..dw_mci_set_ios: no card. [mmc1]
<6>[ 4.111133] mmc0: BKOPS_EN bit is not set
<6>[ 4.116990] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1)
<4>[ 4.126691] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
<6>[ 4.126773] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
<6>[ 4.126782] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
<6>[ 4.127120] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
<4>[ 4.156841] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=8bits.[mmc0]
<6>[ 4.156877] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
<4>[ 4.157009] 3379..dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
<4>[ 4.157015] mmc2 : Rockchip specific MHSC: Ver 1.13 2014-09-05
<7>[ 4.157032] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 4.157315] 1390..dw_mci_set_ios: no card. [mmc2]
<4>[ 4.175273] 1390..dw_mci_set_ios: no card. [mmc2]
<6>[ 4.191763] mmc0: new high speed MMC card at address 0001
<6>[ 4.194988] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
<6>[ 4.194997] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
<4>[ 4.195255] leds-gpio leds.32: pins are not configured from the driver
<7>[ 4.195269] of_get_named_gpio_flags exited with status 257
<7>[ 4.195277] of_get_named_gpio_flags exited with status 258
<7>[ 4.195286] of_get_named_gpio_flags exited with status 257
<7>[ 4.195384] of_get_named_gpio_flags exited with status 258
<6>[ 4.195515] hidraw: raw HID events driver (C) Jiri Kosina
<6>[ 4.197376] usbcore: registered new interface driver usbhid
<6>[ 4.197382] usbhid: USB HID core driver
<6>[ 4.197753] zram: Created 1 device(s) …
<6>[ 4.198081] ashmem: initialized
<6>[ 4.198226] logger: created 256K log ‘log_main’
<6>[ 4.198353] logger: created 256K log ‘log_events’
<6>[ 4.198474] logger: created 256K log ‘log_radio’
<6>[ 4.198615] logger: created 256K log ‘log_system’
<7>[ 4.199659] of_get_named_gpio_flags exited with status 5
<7>[ 4.199668] of_get_named_gpio_flags exited with status 5
<6>[ 4.199935] input: rk29-keypad as /devices/ff100000.adc/key.34/input/input2
<7>[ 4.200631] of_get_named_gpio_flags exited with status 10
<7>[ 4.200643] of_get_named_gpio_flags exited with status 239
<4>[ 4.266158] es8323 probe i2c recv ok
<6>[ 4.266298] mmcblk0: mmc0:0001 AWMB3R 14.5 GiB
<6>[ 4.266673] uboot: 0x000400000 – 0x000800000 (4 MB)
<6>[ 4.266682] misc: 0x000800000 – 0x000c00000 (4 MB)
<6>[ 4.266690] resource: 0x000c00000 – 0x001c00000 (16 MB)
<6>[ 4.266697] kernel: 0x001c00000 – 0x002c00000 (16 MB)
<6>[ 4.266705] boot: 0x002c00000 – 0x004c00000 (32 MB)
<6>[ 4.266711] recovery: 0x004c00000 – 0x006c00000 (32 MB)
<6>[ 4.266718] backup: 0x006c00000 – 0x00a000000 (52 MB)
<6>[ 4.266725] cache: 0x00a000000 – 0x012000000 (128 MB)
<6>[ 4.266732] kpanic: 0x012000000 – 0x012400000 (4 MB)
<6>[ 4.266744] system: 0x012400000 – 0x042400000 (768 MB)
<6>[ 4.266778] metadata: 0x042400000 – 0x042800000 (4 MB)
<6>[ 4.266797] userdata: 0x042800000 – 0x082800000 (1024 MB)
<6>[ 4.266823] radical_update: 0x082800000 – 0x086800000 (64 MB)
<6>[ 4.266845] user: 0x086800000 – 0x3a3a00000 (12754 MB)
<6>[ 4.268103] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p141390..dw_mci_set_ios: no card. [mmc1]
<4>[ 4.269097] 1390..dw_mci_set_ios: no card. [mmc2]
<4>[ 4.364458] i2c-core: driver [ES8323] using legacy suspend method
<4>[ 4.370450] i2c-core: driver [ES8323] using legacy resume method
<3>[ 4.377080] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: ASoC: CPU DAI (null) not registered
<4>[ 4.385354] rockchip_hdmi_spdif_audio_probe() register card failed:-517
<6>[ 4.391868] platform rockchip-hdmi-spdif.27: Driver rockchip-hdmi-spdif requests probe deferral
<4>[ 4.400598] es8323_probe
<4>[ 5.042429] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → NULL → Left Line Mux
<3>[ 5.050225] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → NULL → Left Line Mux
<4>[ 5.058689] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → NULL → Left Line Mux
<3>[ 5.066529] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → NULL → Left Line Mux
<4>[ 5.074616] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → NULL → Left Line Mux
<3>[ 5.082766] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → NULL → Left Line Mux
<4>[ 5.090953] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → NULL → Right Line Mux
<3>[ 5.098743] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → NULL → Right Line Mux
<4>[ 5.106550] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → NULL → Right Line Mux
<3>[ 5.114425] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → NULL → Right Line Mux
<4>[ 5.122284] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → NULL → Right Line Mux
<3>[ 5.130658] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → NULL → Right Line Mux
<4>[ 5.139024] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left PGA Mux
<3>[ 5.146704] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left PGA Mux
<4>[ 5.154650] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left PGA Mux
<3>[ 5.162290] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left PGA Mux
<4>[ 5.169925] ES8323 2-0010: ASoC: no dapm match for Differential Mux → LAMP → Left PGA Mux
<3>[ 5.178305] ES8323 2-0010: ASoC: Failed to add route Differential Mux → LAMP → Left PGA Mux
<4>[ 5.186717] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right PGA Mux
<3>[ 5.194471] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right PGA Mux
<4>[ 5.202222] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right PGA Mux
<3>[ 5.209987] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right PGA Mux
<4>[ 5.217725] ES8323 2-0010: ASoC: no dapm match for Differential Mux → RAMP → Right PGA Mux
<3>[ 5.226248] ES8323 2-0010: ASoC: Failed to add route Differential Mux → RAMP → Right PGA Mux
<4>[ 5.234989] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Differential Mux
<3>[ 5.242948] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Differential Mux
<4>[ 5.250930] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Differential Mux
<3>[ 5.258889] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Differential Mux
<4>[ 5.266841] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Differential Mux
<3>[ 5.274828] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Differential Mux
<4>[ 5.282789] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Differential Mux
<3>[ 5.290751] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Differential Mux
<4>[ 5.298741] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left Line Mux
<3>[ 5.306437] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left Line Mux
<4>[ 5.314149] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left Line Mux
<4>[ 5.321864] dwc_otg_hcd_enable, enable host controller
<3>[ 5.326937] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left Line Mux
<4>[ 5.334636] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → LAMP → Left Line Mux
<3>[ 5.342771] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → LAMP → Left Line Mux
<4>[ 5.350907] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right Line Mux
<3>[ 5.358703] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right Line Mux
<4>[ 5.366489] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right Line Mux
<3>[ 5.374267] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right Line Mux
<4>[ 5.382054] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → RAMP → Right Line Mux
<3>[ 5.390347] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → RAMP → Right Line Mux
<3>[ 5.398767] ES8323 2-0010: ASoC: mux Right Line Mux has no paths
<3>[ 5.404672] ES8323 2-0010: ASoC: mux Left Line Mux has no paths
<3>[ 5.410497] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths
<3>[ 5.416326] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths
<3>[ 5.422069] ES8323 2-0010: ASoC: mux Differential Mux has no paths
<4>[ 5.430277] Using Buffer DMA mode
<4>[ 5.433536] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 5.439284] Multiprocessor Interrupt Enhancement - disabled
<4>[ 5.444793] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 5.449077] ^^^^^^^^^^^^^^^^^^Host Mode
<6>[ 5.453654] rockchip-es8323 rockchip-es8323.29: ES8323 HiFi ↔ rockchip-i2s.0 mapping ok
<6>[ 5.462121] input: RK_ES8323 Headphone Jack as /devices/rockchip-es8323.29/sound/card0/input3
<6>[ 5.471167] rockchip-hdmi-i2s rockchip-hdmi-i2s.26: rk-hdmi-i2s-hifi ↔ rockchip-i2s.0 mapping ok
<6>[ 5.480372] u32 classifier
<6>[ 5.483032] Actions configured
<6>[ 5.486385] Netfilter messages via NETLINK v0.30.
<6>[ 5.491045] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
<4>[ 5.493895] Init: Power Port (0)
<4>[ 5.493921] ff540000.usb resume, HPRT0:0x21401
<6>[ 5.504904] ctnetlink v0.93: registering with nfnetlink.
<6>[ 5.510170] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
<6>[ 5.517016] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
<6>[ 5.522955] xt_time: kernel timezone is -0000
<6>[ 5.527397] ip_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 5.532714] arp_tables: (C) 2002 David S. Miller
<6>[ 5.537287] TCP: cubic registered
<6>[ 5.540543] Initializing XFRM netlink socket
<6>[ 5.544909] NET: Registered protocol family 10
<6>[ 5.549659] mip6: Mobile IPv6
<6>[ 5.552592] ip6_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 5.558017] sit: IPv6 over IPv4 tunneling driver
<6>[ 5.562813] NET: Registered protocol family 17
<6>[ 5.567191] NET: Registered protocol family 15
<5>[ 5.571589] Bridge firewalling registered
<6>[ 5.575541] Ebtables v2.0 registered
<6>[ 5.579161] Bluetooth: RFCOMM TTY layer initialized
<6>[ 5.583975] Bluetooth: RFCOMM socket layer initialized
<6>[ 5.589022] Bluetooth: RFCOMM ver 1.11
<6>[ 5.592714] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
<6>[ 5.597930] Bluetooth: BNEP filters: protocol multicast
<6>[ 5.603069] Bluetooth: BNEP socket layer initialized
<6>[ 5.607945] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
<6>[ 5.613768] Bluetooth: HIDP socket layer initialized
<6>[ 5.618659] l2tp_core: L2TP core driver, V2.0
<6>[ 5.622949] l2tp_ppp: PPPoL2TP kernel driver, V2.0
<6>[ 5.627654] [WLAN_RFKILL]: Enter rfkill_wlan_init
<4>[ 5.631616] Indeed it is in host mode hprt0 = 00021501
<6>[ 5.637461] [WLAN_RFKILL]: Enter rfkill_wlan_probe
<6>[ 5.642174] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
<6>[ 5.649013] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
<6>[ 5.656040] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
<6>[ 5.664428] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
<7>[ 5.671704] of_get_named_gpio_flags exited with status 156
<6>[ 5.671710] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
<7>[ 5.680679] of_get_named_gpio_flags: can’t parse gpios property
<7>[ 5.680685] of_get_named_gpio_flags exited with status 158
<6>[ 5.680690] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
<6>[ 5.689750] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
<6>[ 5.694900] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
<6>[ 5.703223] [WLAN_RFKILL]: Exit rfkill_wlan_probe
<6>[ 5.707875] [BT_RFKILL]: Enter rfkill_rk_init
<7>[ 5.712267] of_get_named_gpio_flags exited with status 147
<6>[ 5.712273] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
<7>[ 5.720315] of_get_named_gpio_flags exited with status 155
<6>[ 5.720320] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155.
<7>[ 5.728266] of_get_named_gpio_flags exited with status 157
<6>[ 5.728271] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
<7>[ 5.736223] of_get_named_gpio_flags exited with status 154
<6>[ 5.736228] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
<7>[ 5.744094] of_get_named_gpio_flags exited with status 159
<6>[ 5.744099] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
<6>[ 5.752334] [BT_RFKILL]: Request irq for bt wakeup host
<6>[ 5.757534] [BT_RFKILL]: ** disable irq
<6>[ 5.761386] [BT_RFKILL]: ap6335 device registered.
<6>[ 5.766889] rk3288-hdmi ff980000.hdmi: rk3288 hdmi probe sucess.
<6>[ 5.773468] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
<4>[ 5.781019] rk3288_init_suspend
<4>[ 5.784107] rk3288_suspend_init enter
<4>[ 5.787812] rk3288_suspend_init: pm_ctrbits =200007
<4>[ 5.792631] gpio_get_dts_info suspend:4
<4>[ 5.796399] gpio_get_dts_info resume:4
<6>[ 5.798866] usb 3-1: new high-speed USB device number 2 using usb20_host
<4>[ 5.798932] Indeed it is in host mode hprt0 = 00001101
<4>[ 5.811705] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
<4>[ 5.819787] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
<4>[ 5.827782] clks_gating_suspend_init:clkgt info ok
<5>[ 5.832568] Registering SWP/SWPB emulation handler
<6>[ 5.837571] ddrfreq: verion 1.2 20140526
<6>[ 5.841437] ddrfreq: normal 396MHz video_1080p 240MHz video_4k 396MHz dualview 396MHz idle 0MHz suspend 200MHz reboot 396MHz
<6>[ 5.852468] ddrfreq: auto-freq=0
<6>[ 5.855639] ddrfreq: auto-freq-table[0] 240MHz
<6>[ 5.860019] ddrfreq: auto-freq-table[1] 324MHz
<6>[ 5.864383] ddrfreq: auto-freq-table[2] 396MHz
<6>[ 5.868762] ddrfreq: auto-freq-table[3] 528MHz
<7>[ 5.881105] ddrfreq: change freq to 396 MHz when normal
<6>[ 5.881471] regulator-dummy: disabling
<3>[ 5.885429] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: ASoC: CPU DAI (null) not registered
<4>[ 5.893667] rockchip_hdmi_spdif_audio_probe() register card failed:-517
<6>[ 5.900195] platform rockchip-hdmi-spdif.27: Driver rockchip-hdmi-spdif requests probe deferral
<4>[ 5.908840] pcd_pullup, is_on 0
<6>[ 5.911955] file system registered
<6>[ 5.915789] android_usb gadget: Mass Storage Function, version: 2009/09/11
<6>[ 5.922565] android_usb gadget: Number of LUNs=2
<6>[ 5.927114] lun0: LUN: removable file: (no medium)
<6>[ 5.931904] lun1: LUN: removable file: (no medium)
<6>[ 5.936822] android_usb gadget: android_usb ready
<6>[ 5.941973] rtc_hym8563 0-0051: setting system clock to 2011-01-01 12:04:27 UTC (1293883467)
<6>[ 5.954824] rk_spdif:rk_spdif_init
<6>[ 5.958364] rk_spdif:Entered spdif_probe
<6>[ 5.962396] rk_spdif:spdif:spdif probe ok!
<6>[ 5.966903] usbcore: registered new interface driver snd-usb-audio
<6>[ 5.972982] ALSA device list:
<6>[ 5.975924] #0: RK_ES8323
<6>[ 5.978715] #1: RK-HDMI-I2S
<6>[ 5.978816] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: rk-hdmi-spdif-hifi ↔ rockchip-spdif mapping ok
<6>[ 5.991048] #2: RK-HDMI-SPDIF
<6>[ 5.994469] Freeing unused kernel memory: 592K (c0adc000 - c0b70000)
<7>[ 6.004113] SELinux: 512 avtab hash slots, 1338 rules.
<7>[ 6.004489] SELinux: 512 avtab hash slots, 1338 rules.
<7>[ 6.004501] SELinux: 1 users, 2 roles, 288 types, 1 bools, 1 sens, 1024 cats
<7>[ 6.004509] SELinux: 84 classes, 1338 rules
<6>[ 6.005138] SELinux: Permission attach_queue in class tun_socket not defined in policy.
<6>[ 6.005788] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101
<6>[ 6.005794] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
<6>[ 6.005799] usb 3-1: Product: USB 2.0 Hub [MTT]
<6>[ 6.006116] hub 3-1:1.0: USB hub found
<6>[ 6.006167] hub 3-1:1.0: 4 ports detected
<6>[ 6.038779] SELinux: the above unknown classes and permissions will be denied
<7>[ 6.045814] SELinux: Completing initialization.
<7>[ 6.045820] SELinux: Setting up existing superblocks.
<7>[ 6.045838] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
<7>[ 6.045851] SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts
<7>[ 6.045904] SELinux: initialized (dev bdev, type bdev), not configured for labeling
<7>[ 6.045914] SELinux: initialized (dev proc, type proc), uses genfs_contexts
<7>[ 6.045937] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 6.045954] SELinux: initialized (dev devtmpfs, type devtmpfs), uses transition SIDs
<7>[ 6.046146] SELinux: initialized (dev debugfs, type debugfs), uses genfs_contexts
<7>[ 6.050571] SELinux: initialized (dev sockfs, type sockfs), uses task SIDs
<7>[ 6.050585] SELinux: initialized (dev pipefs, type pipefs), uses task SIDs
<7>[ 6.050596] SELinux: initialized (dev anon_inodefs, type anon_inodefs), not configured for labeling
<7>[ 6.050608] SELinux: initialized (dev devpts, type devpts), uses transition SIDs
<7>[ 6.050624] SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts
<7>[ 6.050682] SELinux: initialized (dev configfs, type configfs), not configured for labeling
<7>[ 6.050692] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 6.050718] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
<4>[ 6.123601] ff540000.usb suspend, HPRT0:0x1485
<5>[ 6.402863] type=1403 audit(1293883467.960:2): policy loaded auid=4294967295 ses=4294967295
<12>[ 6.411208] SELinux: Loaded policy from /sepolicy
<5>[ 6.417708] type=1404 audit(1293883467.970:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
<11>[ 7.423001] init: could not import file ‘/init.usbstorage.rc’ from ‘/init.rc’
<4>[ 7.430084] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
<11>[ 7.488995] init: /dev/hw_random not found
<6>[ 7.493114] keychord: using input dev ff680000.pwm for fevent
<6>[ 7.498764] keychord: using input dev rk29-keypad for fevent
<7>[ 7.504799] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<7>[ 7.505011] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 7.505269] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<7>[ 7.506149] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 7.506420] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 7.506546] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 7.507365] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<7>[ 7.508721] SELinux: initialized (dev functionfs, type functionfs), not configured for labeling
<11>[ 7.509474] fs_mgr: parse_link_device : path = NULL
<11>[ 7.514322] fs_mgr: parse_link_device : path = NULL
<11>[ 7.519135] fs_mgr: parse_link_device : path = NULL
<14>[ 7.524016] fs_mgr: ---------------resize_fs blk_dev /dev/block/platform/ff0f0000.rksdmmc/by-name/system, type ext4fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
<14>[ 7.543960] resize2fs: resize2fs 1.41.14 (22-Dec-2010)resize2fs: The filesystem is already 196608 blocks long. Nothing to do!resize2fs:
<6>[ 7.562420] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
<7>[ 7.571795] SELinux: initialized (dev mmcblk0p10, type ext4), uses xattr
<4>[ 7.579974] EXT4-fs (mmcblk0p8): warning: maximal mount count reached, running e2fsck is recommended
<6>[ 7.589595] EXT4-fs (mmcblk0p8): recovery complete
<6>[ 7.594920] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
<7>[ 7.604357] SELinux: initialized (dev mmcblk0p8, type ext4), uses xattr
<6>[ 7.606664] EXT4-fs (mmcblk0p11): recovery complete
<6>[ 7.611481] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
<7>[ 7.620989] SELinux: initialized (dev mmcblk0p11, type ext4), uses xattr
<4>[ 7.836169] EXT4-fs (mmcblk0p12): warning: maximal mount count reached, running e2fsck is recommended
<6>[ 7.845899] EXT4-fs (mmcblk0p12): recovery complete
<6>[ 7.851263] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
<7>[ 7.860781] SELinux: initialized (dev mmcblk0p12, type ext4), uses xattr
<4>[ 7.877403] mali pd enabled
<4>[ 7.880157] clk enabled
<4>[ 7.883714] MALI_DVFS_STEP=5,div_dvfs=7
<6>[ 7.887521] mali_dvfs_infotbl[0].clock=99000,min_threshold=0,max_threshold=70
<6>[ 7.894545] mali_dvfs_infotbl[1].clock=179000,min_threshold=66,max_threshold=77
<6>[ 7.901743] mali_dvfs_infotbl[2].clock=297000,min_threshold=73,max_threshold=84
<6>[ 7.908931] mali_dvfs_infotbl[3].clock=417000,min_threshold=82,max_threshold=91
<6>[ 7.916126] mali_dvfs_infotbl[4].clock=480000,min_threshold=94,max_threshold=100
<6>[ 7.923498] gpufreq_input_connect
<3>[ 7.926770] turn on mali power
<6>[ 7.929773] kbase_platform_rk_init,register_reboot_notifier
<6>[ 7.935293] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
<6>[ 7.942115] mali ffa30000.gpu: Probed as mali0
<3>[ 7.949333] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ’ should be ‘3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
<11>[ 7.970223] init: /dev/hw_random not found
<6>[ 7.991395] binder: 159:159 transaction failed 29189, size 0-0
<11>[ 7.997854] init: cannot find ‘/system/vendor/bin/pvrsrvctl’, disabling ‘pvrsrvctl’
<11>[ 8.007934] init: cannot find ‘/system/bin/rild3’, disabling ‘ril-daemon3’
<11>[ 8.042872] init: cannot find ‘/system/etc/install-recovery.sh’, disabling ‘flash_recovery’
<11>[ 8.052555] init: cannot find ‘/system/bin/chrome.sh’, disabling ‘chrome’
<11>[ 8.060213] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
<11>[ 8.068138] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
<11>[ 8.077942] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
<7>[ 8.163463] SELinux: initialized (dev fuse, type fuse), uses genfs_contexts
<11>[ 8.250114] init: property ‘sys.powerctl’ doesn’t exist while expanding ‘${sys.powerctl}’
<11>[ 8.258223] init: powerctl: cannot expand ‘${sys.powerctl}’
<11>[ 8.263885] init: property ‘sys.sysctl.extra_free_kbytes’ doesn’t exist while expanding ‘${sys.sysctl.extra_free_kbytes}’
<11>[ 8.274718] init: cannot expand ‘${sys.sysctl.extra_free_kbytes}’ while writing to ‘/proc/sys/vm/extra_free_kbytes’
<11>[ 8.285022] init: property ‘sys.sysctl.tcp_def_init_rwnd’ doesn’t exist while expanding ‘${sys.sysctl.tcp_def_init_rwnd}’
<11>[ 8.295830] init: cannot expand ‘${sys.sysctl.tcp_def_init_rwnd}’ while writing to ‘/proc/sys/net/ipv4/tcp_default_init_rwnd’
<3>[ 8.307725] android_usb: already disabled
<6>[ 8.313622] read descriptors
<11>[ 8.315917] fs_mgr: parse_link_device : path = NULL
<11>[ 8.315942] fs_mgr: parse_link_device : path = NULL
<11>[ 8.315964] fs_mgr: parse_link_device : path = NULL
<6>[ 8.330908] read strings
<4>[ 8.333453] pcd_pullup, is_on 1
<4>[ 8.944596] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
<4>[ 8.951986] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
<4>[ 8.959360] D1:camsys_open(717): camsys_marvin(ed65b010) is opened!
<7>[ 8.965572] of_get_named_gpio_flags exited with status 237
<7>[ 8.965581] of_get_named_gpio_flags exited with status 237
<4>[ 8.965589] rockchip_gpio_request:GPIO7-13
<4>[ 8.969638] rockchip_gpio_set:GPIO7-13 level = 1
<4>[ 8.974178] rockchip_gpio_direction_output:set GPIO7-13 level 1
<4>[ 8.980021] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
<4>[ 8.986698] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x7400,result=0x7400
<4>[ 8.997232] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
<4>[ 9.004009] D1:camsys_extdev_register(255): Extdev(dev_id: 0x2000000 dev_name: OV8825) register success
<7>[ 9.039032] ddrfreq: change freq to 528 MHz when isp
<4>[ 9.039132] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 9.047114] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
<4>[ 9.052099] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
<4>[ 9.057031] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
<3>[ 9.066326] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
<3>[ 9.074663] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
<3>[ 9.082967] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
<3>[ 9.093470] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
<3>[ 9.099797] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
<3>[ 9.107102] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
<3>[ 9.114294] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
<7>[ 9.132706] ddrfreq: change freq to 396 MHz when normal
<4>[ 9.132759] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
<4>[ 9.139417] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
<4>[ 9.148259] D1:camsys_extdev_deregister(315): Extdev(dev_id: 0x2000000) is deregister success
<4>[ 9.156690] D1:camsys_irq_disconnect(642): All thread disconnect camsys_marvin irq success!
<4>[ 9.164947] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
<4>[ 9.172395] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
<4>[ 9.179890] D1:camsys_release(741): camsys_marvin(ed65b010) is closed
<4>[ 9.189605] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
<4>[ 9.197004] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
<4>[ 9.204380] D1:camsys_open(717): camsys_marvin(ed65b010) is opened!
<7>[ 9.210593] of_get_named_gpio_flags exited with status 237
<7>[ 9.210604] of_get_named_gpio_flags exited with status 237
<7>[ 9.210612] _gpio_request: gpio-237 (camsys_gpio) status -16
<4>[ 9.210621] rockchip_gpio_set:GPIO7-13 level = 1
<4>[ 9.215236] rockchip_gpio_direction_output:set GPIO7-13 level 1
<4>[ 9.221093] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
<4>[ 9.227799] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x7400,result=0x7400
<4>[ 9.238394] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
<4>[ 9.245208] D1:camsys_extdev_register(255): Extdev(dev_id: 0x2000000 dev_name: OV8858) register success
<7>[ 9.273208] ddrfreq: change freq to 528 MHz when isp
<4>[ 9.273252] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 9.281206] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
<4>[ 9.286202] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
<4>[ 9.291112] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
<3>[ 9.300400] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
<3>[ 9.308731] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
<3>[ 9.317030] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
<3>[ 9.327483] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
<3>[ 9.334966] E:camsys_i2c_write(77): i2c write dev(addr:0x20) failed!
<3>[ 9.341299] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
<3>[ 9.348511] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
<3>[ 9.355745] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
<7>[ 9.390296] ddrfreq: change freq to 396 MHz when normal
<4>[ 9.390329] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
<4>[ 9.396964] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
<4>[ 9.405800] D1:camsys_extdev_deregister(315): Extdev(dev_id: 0x2000000) is deregister success
<4>[ 9.414231] D1:camsys_irq_disconnect(642): All thread disconnect camsys_marvin irq success!
<4>[ 9.422492] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
<4>[ 9.429945] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
<4>[ 9.437386] D1:camsys_release(741): camsys_marvin(ed65b010) is closed
<4>[ 9.447303] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
<4>[ 9.454684] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
<4>[ 9.462069] D1:camsys_open(717): camsys_marvin(ed65b010) is opened!
<4>[ 9.468282] D1:camsys_extdev_register(230): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 9.478221] D1:camsys_extdev_register(230): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
<4>[ 9.488163] D1:camsys_extdev_register(230): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
<7>[ 9.498104] of_get_named_gpio_flags exited with status 237
<7>[ 9.498112] of_get_named_gpio_flags exited with status 237
<7>[ 9.498119] _gpio_request: gpio-237 (camsys_gpio) status -16
<4>[ 9.498128] rockchip_gpio_set:GPIO7-13 level = 1
<4>[ 9.502747] rockchip_gpio_direction_output:set GPIO7-13 level 1
<4>[ 9.508620] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
<4>[ 9.515322] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x7400,result=0x7400
<4>[ 9.525903] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
<4>[ 9.532709] D1:camsys_extdev_register(255): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
<7>[ 9.554114] ddrfreq: change freq to 528 MHz when isp
<4>[ 9.554177] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 9.562152] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
<4>[ 9.567134] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
<4>[ 9.572063] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
<4>[ 9.581349] D1:camsys_sysctl_extdev(335): Sysctl 11 success, gpio(11) set 1
<4>[ 9.589285] D1:camsys_sysctl_extdev(339): Sysctl 8 success, gpio(79) set 1
<4>[ 9.597138] D1:camsys_sysctl_extdev(339): Sysctl 7 success, gpio(78) set 1
<3>[ 9.607158] E:camsys_i2c_write(77): i2c write dev(addr:0x20) failed!
<3>[ 9.614643] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
<4>[ 9.620999] D1:camsys_sysctl_extdev(335): Sysctl 7 success, gpio(78) set 0
<4>[ 9.627814] D1:camsys_sysctl_extdev(335): Sysctl 8 success, gpio(79) set 0
<4>[ 9.634598] D1:camsys_sysctl_extdev(339): Sysctl 11 success, gpio(11) set 0
<7>[ 9.671244] ddrfreq: change freq to 396 MHz when normal
<4>[ 9.671273] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
<4>[ 9.677910] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
<4>[ 9.686730] D1:camsys_extdev_deregister(315): Extdev(dev_id: 0x2000000) is deregister success
<4>[ 9.695118] D1:camsys_irq_disconnect(642): All thread disconnect camsys_marvin irq success!
<4>[ 9.703371] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
<4>[ 9.710863] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
<4>[ 9.718337] D1:camsys_release(741): camsys_marvin(ed65b010) is closed
<4>[ 9.732171] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
<4>[ 9.739562] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
<4>[ 9.739568] D1:camsys_open(717): camsys_marvin(ed65b010) is opened!
<4>[ 9.739611] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit
<4>[ 9.739719] D1:camsys_extdev_register(255): Extdev(dev_id: 0x1000000 dev_name: OV2659) register success
<7>[ 9.788267] ddrfreq: change freq to 528 MHz when isp
<4>[ 9.788342] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 9.796322] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
<4>[ 9.801303] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
<4>[ 9.806241] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
<3>[ 9.815526] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
<3>[ 9.823848] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
<3>[ 9.832105] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
<3>[ 9.842585] E:camsys_i2c_write(77): i2c write dev(addr:0x60) failed!
<3>[ 9.848914] E:camsys_sysctl_extdev(342): Sysctl 7 failed, because gpio is NULL!
<3>[ 9.856127] E:camsys_sysctl_extdev(342): Sysctl 8 failed, because gpio is NULL!
<3>[ 9.863332] E:camsys_sysctl_extdev(342): Sysctl 11 failed, because gpio is NULL!
<7>[ 9.881951] ddrfreq: change freq to 396 MHz when normal
<4>[ 9.882013] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
<4>[ 9.882048] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
<6>[ 9.882114] rk3288-lcdc lcdc0: blank mode:0
<4>[ 9.888802] D1:camsys_extdev_deregister(315): Extdev(dev_id: 0x1000000) is deregister success
<4>[ 9.888815] D1:camsys_irq_disconnect(642): All thread disconnect camsys_marvin irq success!
<4>[ 9.888825] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
<4>[ 9.888830] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
<4>[ 9.888834] D1:camsys_release(741): camsys_marvin(ed65b010) is closed
<11>[ 9.981889] init: sys_prop: permission denied uid:1003 name:sys.gmali.version
<6>[ 11.069466] warning: `zygote’ uses 32-bit capabilities (legacy support in use)
<4>[ 11.076640] vbus detect**
<4>[ 11.262206] Using Buffer DMA mode
<4>[ 11.265471] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 11.271208] Multiprocessor Interrupt Enhancement - disabled
<4>[ 11.276681] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 11.280974] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 11.284870] soft connect!!!
<4>[ 11.393652] USB RESET
<6>[ 11.432086] android_work: sent uevent USB_STATE=CONNECTED
<4>[ 11.437437] USB RESET
<6>[ 11.515725] android_usb gadget: high-speed config #1: android
<6>[ 11.521560] android_work: sent uevent USB_STATE=CONFIGURED
<6>[ 12.057133] rk3288-lcdc lcdc0: win0:new_addr:0x4a000000 cur_addr:0x48000000–1
<6>[ 14.605687] rk3288-lcdc lcdc0: win0:new_addr:0x46000000 cur_addr:0x4a000000–1
<6>[ 15.097681] rk3288-lcdc lcdc0: win0:new_addr:0x46000000 cur_addr:0x4a000000–1
<6>[ 19.938980] rk3288-lcdc lcdc0: win0:new_addr:0x4a000000 cur_addr:0x48000000–1
<6>[ 20.430974] rk3288-lcdc lcdc0: win0:new_addr:0x4a000000 cur_addr:0x48000000–1
<14>[ 20.726457] healthd: battery l=50 v=3 t=2.6 h=2 st=3 chg=au
<6>[ 20.835046] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
<6>[ 20.842067] lowmemorykiller: oom_adj 0 => oom_score_adj 0
<6>[ 20.847411] lowmemorykiller: oom_adj 1 => oom_score_adj 58
<6>[ 20.852801] lowmemorykiller: oom_adj 2 => oom_score_adj 117
<6>[ 20.858295] lowmemorykiller: oom_adj 3 => oom_score_adj 176
<6>[ 20.863770] lowmemorykiller: oom_adj 9 => oom_score_adj 529
<6>[ 20.869263] lowmemorykiller: oom_adj 15 => oom_score_adj 1000
<4>[ 21.122562] phy_power_on: enable = 1
<4>[ 21.165558] Read the Ethernet MAC address from IDB:00:00:00:00:00:00
<4>[ 21.171909] eth0: device MAC address b6:81:ce:9f:89:86
<6>[ 21.181143] libphy: stmmac: probed
<6>[ 21.184491] eth0: PHY ID 001cc915 at 0 IRQ 0 (stmmac-0:00) active
<6>[ 21.190491] eth0: PHY ID 001cc915 at 1 IRQ 0 (stmmac-0:01) active
<4>[ 21.304026] wifi_driver_write: wifi driver already rmmod
<6>[ 21.359979] acc_open
<6>[ 21.362143] acc_release
<4>[ 21.992204] dwc_otg_hcd_resume, usb device mode
<4>[ 21.996880] dwc_otg_hcd_suspend, usb device mode
<4>[ 22.001618] ff540000.usb resume, HPRT0:0x1485
<4>[ 22.054618] ff540000.usb suspend, HPRT0:0x1485
<5>[ 22.061841] type=1400 audit(1293883483.870:4): avc: denied { getattr } for pid=635 comm=“utmethod.zhuyin” path=“/data/app” dev=“mmcblk0p12” ino=24578 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:apk_data_file:s0 tclass=dir permissive=1
<4>[ 22.063965] ff540000.usb resume, HPRT0:0x1485
<4>[ 22.095056] ff540000.usb suspend, HPRT0:0x1005
<4>[ 22.413825] FAT-fs (mmcblk0p14): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
<7>[ 22.423746] SELinux: initialized (dev mmcblk0p14, type vfat), uses genfs_contexts
<12>[ 22.446923] avc: denied { set } for property=sys.vold.hasAsec scontext=u:r:vold:s0 tcontext=u:object_r:system_prop:s0 tclass=property_service
<11>[ 22.459802] init: sys_prop: permission denied uid:0 name:sys.vold.hasAsec
<11>[ 22.467568] init: no such service ‘fuse_internal_sd’
<5>[ 22.512510] type=1400 audit(1293883484.330:5): avc: denied { getattr } for pid=765 comm=“gle.android.gms” path=“/data/app” dev=“mmcblk0p12” ino=24578 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:apk_data_file:s0 tclass=dir permissive=1
<11>[ 22.632115] init: sys_prop: permission denied uid:10012 name:sys.gmali.version
<11>[ 23.100751] init: sys_prop: permission denied uid:10037 name:sys.gmali.version
<11>[ 23.915967] init: sys_prop: permission denied uid:1003 name:service.bootanim.exit
<4>[ 23.955895] vmap allocation for size 33181696 failed: use vmalloc= to increase size.
<4>[ 24.025200] vmap allocation for size 33181696 failed: use vmalloc= to increase size.
<6>[ 24.033492] f6fee234,f6fee234,f6fee234
<5>[ 26.272781] type=1400 audit(1293883488.150:6): avc: denied { execute } for pid=1089 comm=“Thread-80” name=“libestool2.so” dev=“mmcblk0p12” ino=1250 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:app_data_file:s0 tclass=file permissive=1
<5>[ 26.294323] type=1400 audit(1293883488.170:7): avc: denied { execute_no_trans } for pid=1089 comm=“Thread-80” path=“/data/data/com.estrongs.android.pop/files/libestool2.so” dev=“mmcblk0p12” ino=1250 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:app_data_file:s0 tclass=file permissive=1
<5>[ 37.023795] type=1400 audit(1293883499.080:8): avc: denied { execute } for pid=1295 comm=“Icing-Worker-0” path=“/data/data/com.google.android.gms/files/libAppDataSearchExt_armeabi_v7a.so” dev=“mmcblk0p12” ino=1055 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:app_data_file:s0 tclass=file permissive=1
<6>[ 46.378405] binder: release 540:540 transaction 5239 out, still active
<6>[ 46.378739] f62d9234,f62d9234,f62d9234
<6>[ 46.389453] binder: undelivered transaction 12791
<6>[ 46.394333] binder: undelivered transaction 12790
<6>[ 46.402272] binder: 165:506 transaction failed 29189, size 24-0
<6>[ 46.408570] binder: send failed reply for transaction 5239, target dead
<6>[ 46.604498] binder: 476:476 transaction failed 29189, size 2248-8
<6>[ 48.383172] binder: 1313:1329 transaction failed 29189, size 300-0
<6>[ 58.224168] binder: 1313:1329 transaction failed 29189, size 300-0
