在使用Firefly-api时出现的问题
E/AndroidRuntime: FATAL EXCEPTION: main
Process: cn.panport.fids, PID: 3385
java.lang.NoClassDefFoundError: Failed resolution of: Landroid/app/FireflyManager;
at com.firefly.api.FireflyApi.shutDown(FireflyApi.java:178)
at cn.panport.fids.ui.setting.SettingActivity$3.onClick(SettingActivity.java:117)
at android.view.View.performClick(View.java:4809)
at android.view.View$PerformClick.run(View.java:20006)
at android.os.Handler.handleCallback(Handler.java:739)
at android.os.Handler.dispatchMessage(Handler.java:95)
at android.os.Looper.loop(Looper.java:135)
at android.app.ActivityThread.main(ActivityThread.java:5280)
at java.lang.reflect.Method.invoke(Native Method)
at java.lang.reflect.Method.invoke(Method.java:372)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:963)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:758)
Caused by: java.lang.ClassNotFoundException: Didn’t find class “android.app.FireflyManager” on path: DexPathList[[zip file “/data/app/cn.panport.fids-1/base.apk”],nativeLibraryDirectories=[/data/app/cn.panport.fids-1/lib/arm, /vendor/lib, /system/lib]]
at dalvik.system.BaseDexClassLoader.findClass(BaseDexClassLoader.java:56)
at java.lang.ClassLoader.loadClass(ClassLoader.java:511)
at java.lang.ClassLoader.loadClass(ClassLoader.java:469)
Suppressed: java.lang.ClassNotFoundException: android.app.FireflyManager
at java.lang.Class.classForName(Native Method)
at java.lang.BootClassLoader.findClass(ClassLoader.java:781)
at java.lang.BootClassLoader.loadClass(ClassLoader.java:841)
at java.lang.ClassLoader.loadClass(ClassLoader.java:504)
… 13 more
Caused by: java.lang.NoClassDefFoundError: Class not found using the boot class loader; no stack available
是导入问题吗还是其他的?大佬们帮帮忙{:4_106:}
