rk3288开机发生panic后重启
rk3288w芯片,开机发生panic,但是走重启流程的话是没有问题的。Log如下,有哪位大侠告知下:
[ 5.892104] rk808-rtc rk808-rtc: setting system clock to 2019-09-25 09:57:27 UTC (1569405447)
[ 5.901723] vcc_3g: disabling
[ 5.911817] rockchip-pm-domain ff730000.power-management:power-controller: failed to set idle on domain ‘pd_hevc’, target_idle = 1, val=0
[ 5.911830] Kernel panic - not syncing: panic_on_set_idle set …
[ 5.911830]
[ 6.325586] dwmmc_rockchip ff0d0000.dwmmc: Unexpected CMD11 timeout
[ 6.342251] dwmmc_rockchip ff0d0000.dwmmc: Busy; trying anyway
[ 6.342257] mmc_host mmc2: Timeout sending command (cmd 0x202000 arg 0x0 status 0x0)
[ 6.542875] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 4.4.132 #14
[ 6.548954] Hardware name: Generic DT based system
[ 6.553762] [] (unwind_backtrace) from [] (show_stack+0x10/0x14)
[ 6.561501] [] (show_stack) from [] (dump_stack+0x7c/0x98)
[ 6.568715] [] (dump_stack) from [] (panic+0x94/0x204)
[ 6.575596] [] (panic) from [] (rockchip_pmu_set_idle_request+0x1b4/0x1d8)
[ 6.584202] [] (rockchip_pmu_set_idle_request) from [] (rockchip_pd_power+0x78/0x218)
[ 6.593763] [] (rockchip_pd_power) from [] (genpd_power_off.part.0+0x2c/0x88)
[ 6.602624] [] (genpd_power_off.part.0) from [] (genpd_poweroff+0x114/0x148)
[ 6.611402] [] (genpd_poweroff) from [] (pm_genpd_runtime_suspend+0xfc/0x170)
[ 6.620269] [] (pm_genpd_runtime_suspend) from [] (__rpm_callback+0x2c/0x5c)
[ 6.629048] [] (__rpm_callback) from [] (rpm_callback+0x70/0x80)
[ 6.636781] [] (rpm_callback) from [] (rpm_suspend+0x284/0x52c)
[ 6.644431] [] (rpm_suspend) from [] (__pm_runtime_idle+0x30/0x7c)
[ 6.652338] [] (__pm_runtime_idle) from [] (rk_iommu_runtime_put+0x34/0x44)
[ 6.661027] [] (rk_iommu_runtime_put) from [] (do_one_initcall+0x5c/0x1dc)
[ 6.669636] [] (do_one_initcall) from [] (kernel_init_freeable+0x208/0x254)
[ 6.678328] [] (kernel_init_freeable) from [] (kernel_init+0x8/0x108)
[ 6.686505] [] (kernel_init) from [] (ret_from_fork+0x14/0x24)
[ 6.694064] CPU3: stopping
[ 6.696779] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 4.4.132 #14
[ 6.702859] Hardware name: Generic DT based system
[ 6.707655] [] (unwind_backtrace) from [] (show_stack+0x10/0x14)
[ 6.715389] [] (show_stack) from [] (dump_stack+0x7c/0x98)
[ 6.722601] [] (dump_stack) from [] (handle_IPI+0x100/0x318)
[ 6.729986] [] (handle_IPI) from [] (gic_handle_irq+0x6c/0x74)
[ 6.737544] [] (gic_handle_irq) from [] (__irq_svc+0x54/0x90)
[ 6.745017] Exception stack(0xdf0f7f98 to 0xdf0f7fe0)
[ 6.750064] 7f80: 00000001 00000000
[ 6.758236] 7fa0: 00000000 c0117940 df0f6000 00000000 00000000 df0f7ff0 0000406a c1003a3c
[ 6.766409] 7fc0: 00000000 00000000 00000000 df0f7fe8 c0107dfc c0107dec 60000013 ffffffff
[ 6.774583] [] (__irq_svc) from [] (arch_cpu_idle+0x1c/0x38)
[ 6.781973] [] (arch_cpu_idle) from [] (cpu_startup_entry+0x1c4/0x364)
[ 6.790230] [] (cpu_startup_entry) from [<0010186c>] (0x10186c)
[ 6.797007] CPU2: stopping
[ 6.799711] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 4.4.132 #14
[ 6.805791] Hardware name: Generic DT based system
[ 6.810586] [] (unwind_backtrace) from [] (show_stack+0x10/0x14)
[ 6.818320] [] (show_stack) from [] (dump_stack+0x7c/0x98)
[ 6.825531] [] (dump_stack) from [] (handle_IPI+0x100/0x318)
[ 6.832915] [] (handle_IPI) from [] (gic_handle_irq+0x6c/0x74)
[ 6.840473] [] (gic_handle_irq) from [] (__irq_svc+0x54/0x90)
[ 6.847946] Exception stack(0xdf0f5f98 to 0xdf0f5fe0)
[ 6.852992] 5f80: 00000001 00000000
[ 6.861165] 5fa0: 00000000 c0117940 df0f4000 00000000 00000000 df0f5ff0 0000406a c1003a3c
[ 6.869338] 5fc0: 00000000 00000000 00000000 df0f5fe8 c0107dfc c0107dec 60000013 ffffffff
[ 6.877511] [] (__irq_svc) from [] (arch_cpu_idle+0x1c/0x38)
[ 6.884897] [] (arch_cpu_idle) from [] (cpu_startup_entry+0x1c4/0x364)
[ 6.893152] [] (cpu_startup_entry) from [<0010186c>] (0x10186c)
[ 6.899929] CPU0: stopping
[ 6.902642] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.4.132 #14
[ 6.908722] Hardware name: Generic DT based system
[ 6.913518] [] (unwind_backtrace) from [] (show_stack+0x10/0x14)
[ 6.921252] [] (show_stack) from [] (dump_stack+0x7c/0x98)
[ 6.928463] [] (dump_stack) from [] (handle_IPI+0x100/0x318)
[ 6.935847] [] (handle_IPI) from [] (gic_handle_irq+0x6c/0x74)
[ 6.943405] [] (gic_handle_irq) from [] (__irq_svc+0x54/0x90)
[ 6.950879] Exception stack(0xc1001f60 to 0xc1001fa8)
[ 6.955927] 1f60: 00000001 00000000 00000000 c0117940 c1000000 00000000 00000000 c1001fb8
[ 6.964100] 1f80: c100394c c1003a3c c0f6423c 00000000 00000000 c1001fb0 c0107dfc c0107dec
[ 6.972270] 1fa0: 60000113 ffffffff
[ 6.975762] [] (__irq_svc) from [] (arch_cpu_idle+0x1c/0x38)
[ 6.983148] [] (arch_cpu_idle) from [] (cpu_startup_entry+0x1c4/0x364)
[ 6.991404] [] (cpu_startup_entry) from [] (start_kernel+0x3c0/0x450)
[ 6.999577] [] (start_kernel) from [<0000807c>] (0x807c)
[ 7.005752] PMU:
[ 7.007599] 00000000: 00000000 00000000 00000000 00000000 00000200 02000000 00000000 80000001
[ 7.016114] 00000020: 00005dc0 10004000 00005dc0 00005dc0 00005dc0 00000018 00000018 00000018
[ 7.024628] 00000040: 00000018 00005dc0 00000000 0000000f 00000000 020e0000 00000000 00000008
[ 7.033142] 00000060: 00020000 00004558 00000a85 00000018 0000555a 00005555 00000015 00000000
[ 7.041655] 00000080: 00000006 00000001 00004000 00000001 00000000 c3524200 00000000 1000caa0
[ 7.050168] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 7.058681] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 7.067195] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 7.075707] rockchip-thermal ff280000.tsadc: channal 0: temperature(49 C)
[ 7.082483] THERMAL REGS:
[ 7.085103] 00000000: 00000200 00030061 00000602 00000000 00000000 00000000 00000000 00000000
[ 7.093614] 00000020: 00000e2b 00000e22 00000e25 00000000 00000000 00000deb 00000000 00000000
[ 7.102124] 00000040: 00000000 00000d6d 00000d6d 00000000 00000000 00000000 00000000 00000000
[ 7.110635] 00000060: 00000004 00000004 000000fa 00000032 00000000 00000000 00000000 00000000
[ 7.119143] 00000080: 00000000 00000000
[ 7.129999] Rebooting in 5 seconds..
DDR Version 1.06 20171020
