firefly升级固件后无限重启,串口查看打印信息
[ 8.996102] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 8.996108] ^^^^^^^^^^^^^^^^^Device Mode
[ 9.093168] es8323_mic_state_ctrl read:
[ 9.093217] mic_state_switch 0
[ 9.093224] hp_det = 0,insert hp
[ 9.093229] hp mic use intern
[ 9.486246] vbus detect**
[ 9.488827] rk_battery_charger_detect_cb , battery_charger_detect 3
[ 9.666557] Using Buffer DMA mode
[ 9.666575] Periodic Transfer Interrupt Enhancement - disabled
[ 9.666581] Multiprocessor Interrupt Enhancement - disabled
[ 9.666587] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 9.666592] ^^^^^^^^^^^^^^^^^Device Mode
[ 9.666632] soft connect!!!
[ 9.885874] USB RESET
[ 9.936316] android_work: sent uevent USB_STATE=CONNECTED
[ 9.940812] USB RESET
[ 10.019232] android_usb gadget: high-speed config #1: android
[ 10.019445] android_work: sent uevent USB_STATE=CONFIGURED
DDR Version 1.00 20160530
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-10 (Nov 20 2017 - 17:19:35)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
你好,请问以下你烧写的固件是哪个固件?烧写方法有没有按照我们WIKI教程 http://wiki.t-firefly.com/zh_CN/Firefly-RK3288/upgrade_firmware-preface.html
的方法做吗?
可以试下楼上兄台的方案,根据教程排查下
