host:ubuntu16.04
os:android8.1.0
使用sd卡启动后uboot 跳转到kernel后无法正常启动卡在那里了
下面是log
[ 0.001897] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.002862] pid_max: default: 32768 minimum: 301
[ 0.003355] Security Framework initialized
[ 0.003744] SELinux: Initializing.
[ 0.004177] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.004808] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.006311] Initializing cgroup subsys memory
[ 0.006742] Initializing cgroup subsys freezer
[ 0.008055] sched-energy: Sched-energy-costs installed from DT
[ 0.008605] CPU0: update cpu_capacity 401
[ 0.009055] ASID allocator initialised with 32768 entries
[ 0.025882] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.027144] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.039293] Detected VIPT I-cache on CPU1
[ 0.039325] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.039365] CPU1: using LPI pending table @0x00000000f1c00000
[ 0.039408] CPU1: update cpu_capacity 401
[ 0.039411] CPU1: Booted secondary processor [410fd034]
[ 0.049280] Detected VIPT I-cache on CPU2
[ 0.049298] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.049331] CPU2: using LPI pending table @0x00000000f1c30000
[ 0.049359] CPU2: update cpu_capacity 401
[ 0.049362] CPU2: Booted secondary processor [410fd034]
[ 0.059309] Detected VIPT I-cache on CPU3
[ 0.059328] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.059360] CPU3: using LPI pending table @0x00000000f1c70000
[ 0.059387] CPU3: update cpu_capacity 401
[ 0.059390] CPU3: Booted secondary processor [410fd034]
[ 0.069357] Detected PIPT I-cache on CPU4
[ 0.069384] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.069424] CPU4: using LPI pending table @0x00000000f1cc0000
[ 0.069464] CPU4: update cpu_capacity 1024
[ 0.069467] CPU4: Booted secondary processor [410fd082]
[ 0.079383] Detected PIPT I-cache on CPU5
[ 0.079401] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.079436] CPU5: using LPI pending table @0x00000000f1cf0000
[ 0.079464] CPU5: update cpu_capacity 1024
[ 0.079467] CPU5: Booted secondary processor [410fd082]
[ 0.079551] Brought up 6 CPUs
[ 0.091653] SMP: Total of 6 processors activated.
[ 0.092095] CPU features: detected feature: GIC system register CPU interface
[ 0.092766] CPU: All CPU(s) started at EL2
[ 0.093189] alternatives: patching kernel code
[ 0.095493] devtmpfs: initialized
[ 0.115365] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.116339] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.117635] pinctrl core: initialized pinctrl subsystem
[ 0.119615] Failed to find legacy iommu devices
[ 0.120437] NET: Registered protocol family 16
[ 0.121264] schedtune: init normalization constants…
[ 0.121767] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[ 0.122401] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 0.123035] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[ 0.123677] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 0.124310] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 0.124943] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[ 0.125576] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[ 0.126208] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[ 0.126839] schedtune: SYSTEM min_pwr: 121 max_pwr: 4434
[ 0.127479] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[ 0.128218] schedtune: verify normalization constants…
[ 0.128734] schedtune: max_pwr/2^0: 4313 => norm_pwr: 1024
[ 0.129274] schedtune: max_pwr/2^1: 2156 => norm_pwr: 511
[ 0.129814] schedtune: max_pwr/2^2: 1078 => norm_pwr: 255
[ 0.130353] schedtune: max_pwr/2^3: 539 => norm_pwr: 127
[ 0.130899] schedtune: max_pwr/2^4: 269 => norm_pwr: 63
[ 0.131439] schedtune: max_pwr/2^5: 134 => norm_pwr: 31
[ 0.131979] schedtune: configured to support 5 boost groups
[ 0.140937] cpuidle: using governor ladder
[ 0.150939] cpuidle: using governor menu
[ 0.151335] Registered FIQ tty driver
[ 0.152045] vdso: 2 pages (1 code @ ffffff8008b46000, 1 data @ ffffff8009164000)
[ 0.152781] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.154809] DMA: preallocated 2048 KiB pool for atomic allocations
[ 0.175536] console [pstore-1] enabled
[ 0.176133] pstore: Registered ramoops as persistent store backend
[ 0.176736] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.179530] fiq debugger fiq mode enabled
[ [ 0.180179] console [ttyFIQ0] enabled
[ 0.180868] bootconsole [uart0] disabled
[ 0.181450] Registered fiq debugger ttyFIQ0
[ 0.215044] iommu: Adding device ff650000.vpu_service to group 0
[ 0.215125] iommu: Adding device ff660000.rkvdec to group 1
[ 0.215194] iommu: Adding device ff670000.iep to group 2
[ 0.215284] iommu: Adding device ff8f0000.vop to group 3
[ 0.215353] iommu: Adding device ff900000.vop to group 4
[ 0.215458] iommu: Adding device ff910000.isp to group 5
[ 0.215527] iommu: Adding device ff920000.isp to group 6
[ 0.216202] rk_iommu ff670800.iommu: can’t get aclk
[ 0.216216] rk_iommu ff670800.iommu: can’t get hclk
[ 0.217064] SCSI subsystem initialized
[ 0.217464] usbcore: registered new interface driver usbfs
[ 0.217516] usbcore: registered new interface driver hub
[ 0.217596] usbcore: registered new device driver usb
[ 0.217959] media: Linux media interface: v0.10
[ 0.217994] Linux video capture interface: v2.00
[ 0.218164] pps_core: LinuxPPS API ver. 1 registered
[ 0.218172] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.218197] PTP clock support registered
[ 0.219828] Advanced Linux Sound Architecture Driver Initialized.
[ 0.220356] Bluetooth: Core ver 2.21
[ 0.220391] NET: Registered protocol family 31
[ 0.220399] Bluetooth: HCI device and connection manager initialized
[ 0.220413] Bluetooth: HCI socket layer initialized
[ 0.220424] Bluetooth: L2CAP socket layer initialized
[ 0.220449] Bluetooth: SCO socket layer initialized
[ 0.221187] rockchip-cpuinfo cpuinfo: Serial : ee64a61886e2157c
[ 0.221684] clocksource: Switched to clocksource arch_sys_counter
[ 0.263615] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.263850] NET: Registered protocol family 2
[ 0.264279] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.264506] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.264766] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.264845] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.264890] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.265109] NET: Registered protocol family 1
[ 0.265959] Trying to unpack rootfs image as initramfs…
[ 0.640482] Freeing initrd memory: 8596K
[ 0.641041] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.641126] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.643921] audit: initializing netlink subsys (disabled)
[ 0.643992] audit: type=2000 audit(0.640:1): initialized
[ 0.649100] VFS: Disk quotas dquot_6.6.0
[ 0.649223] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.650222] Registering sdcardfs 0.1
[ 0.650785] fuse init (API version 7.23)
[ 0.651868]
[ 0.651868] TEE Core Framework initialization (ver 1:0.1)
[ 0.651894] TEE armv7 Driver initialization
[ 0.652241] tz_tee_probe: name=“armv7sec”, i657789] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned
[ 0.657810] phy phy-ff770000.syscon:usb2-phy@e460.0: Failed to get VBUS supply regulator
[ 0.662928] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.662951] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.662965] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 1.185104] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 1.185277] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 1.186223] iep: failed to find iep power down clock source.
[ 1.186876] IEP Power ON
[ 1.187132] IEP Power OFF
[ 1.187247] IEP Driver loaded succesfully
[ 1.187523] Module initialized.
[ 1.187953] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 1.188256] rk-vcodec ff650000.vpu_service: probe device
[ 1.188310] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc0f1eddc10
[ 1.188495] rk-vcodec ff650000.vpu_service: allocator is drm
[ 1.188553] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 1.189071] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 1.189087] rk-vcodec ff650000.vpu_service: init success
[ 1.189286] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 1.189680] rk-vcodec ff660000.rkvdec: probe device
[ 1.189722] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc0f1ede410
[ 1.189857] rk-vcodec ff660000.rkvdec: allocator is drm
[ 1.189917] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 1.190259] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 1.190273] rk-vcodec ff660000.rkvdec: init success
[ 1.192005] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.192022] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 1.193338] dma-pl330 ff6e0000.dma-controller: Loaded driver for PLS
Fkek&F66?
[ 1.193356] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.195099] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 1.196836] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 38, base_baud = 1500000) is a 16550A
[ 1.197149] rockchip-pinctrl pinctrl: pin gpio4-19 already requested by fiq-debugger; cannot claim for ff1a0000.serial
[ 1.197165] rockchip-pinctrl pinctrl: pin-147 (ff1a0000.serial) status -22
[ 1.197177] rockchip-pinctrl pinctrl: could not request pin 147 (gpio4-19) from group uart2c-xfer on device rockchip-pinctrl
[ 1.197188] dw-apb-uart ff1a0000.serial: Error applying setting, reverse things back
[ 1.197464] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 39, base_baud = 1500000) is a 16550A
[ 1.198028] ff370000.serial: ttyS4 at MMIO 0xff370000 (irq = 41, base_baud = 1500000) is a 16550A
[ 1.198422] [drm] Initialized drm 1.1.0 20060810
[ 1.201842] [drm] Rockchip DRM driver version: v1.0.1
[ 1.203932] Unable to detect cache hierarchy for CPU 0
[ 1.214127] brd: module loaded
[ 1.220364] loop: module loaded
[ 1.224371] zram: Added device: zram0
[ 1.225725] SCSI Media Changer driver v0.25
[ 1.227567] register spi return v = :0
[ 1.227627] register firefly_spi_init spi return v = :0
[ 1.227706] tun: Universal TUN/TAP device driver, 1.6
[ 1.227715] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.229161] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 1.229293] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.229313] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 1.229337] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[ 1.229366] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 1.229583] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 1.229602] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.234621] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.234798] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.234813] Ring mode enabled
[ 1.234822] DMA HW capability register supported
[ 1.234829] Normal descriptors
[ 1.234839] RX Checksum Offload Engine supported (type 2)
[ 1.234846] Wake-Up On Lan supported
[ 1.234899] Enable RX Mitigation via HW Watchdog Timer
[ 1.304611] libphy: stmmac: probed
[ 1.304663] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.304676] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 1.306146] PPP generic driver version 2.4.2
[ 1.306471] PPP BSD Compression module registered
[ 1.306489] PPP Deflate Compression module registered
[ 1.306560] PPP MPPE Compression module registered
[ 1.306583] NET: Registered protocol family 24
[ 1.306639] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.306648] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.306668] Rockchip WiFi SYS interface (V1.00) …
[ 1.306802] usbcore: registered new interface driver catc
[ 1.306893] usbcore: registered new interface driver kaweth
[ 1.306910] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.306962] usbcore: registered new interface driver pegasus
[ 1.307056] usbcore: registered new interface driver rtl8150
[ 1.307110] usbcore: registered new interface driver r8152
[ 1.307126] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.307201] usbcore: registered new interface driver hso
[ 1.307302] usbcore: registered new interface driver asix
[ 1.307358] usbcore: registered new interface driver ax88179_178a
[ 1.307420] usbcore: registered new interface driver cdc_ether
[ 1.307508] usbcore: registered new interface driver cdc_eem
[ 1.307562] usbcore: registered new interface driver dm9601
[ 1.307635] usbcore: registered new interface driver smsc75xx
[ 1.307744] usbcore: registered new interface driver smsc95xx
[ 1.307799] usbcore: registered new interface driver gl620a
[ 1.307856] usbcore: registered new interface driver net1080
[ 1.307915] usbcore: registered new interface driver plusb
[ 1.308004] usbcore: registered new interface driver rndis_host
[ 1.308060] usbcore: registered new interface driver cdc_subset
[ 1.308119] usbcore: registered new interface driver zaurus
[ 1.308208] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.308288] usbcore: registered new interface driver int51x1
[ 1.308374] usbcore: registered new interface driver kalmia
[ 1.308466] usbcore: registered new interface driver ipheth
[ 1.308527] usbcore: registered new interface driver sierra_net
[ 1.308584] usbcore: registered new interface driver cx82310_eth
[ 1.308683] usbcore: registered new interface driver cdc_ncm
[ 1.308746] usbcore: registered new interface driver qmi_wwan
[ 1.308805] usbcore: registered new interface driver cdc_mbim
[ 1.310642] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[ 1.315553] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[ 1.317279] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.317333] ehci-pci: EHCI PCI platform driver
[ 1.317433] ehci-platform: EHCI generic platform driver
[ 1.321498] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.321868] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 1.322201] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 1.331771] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.332004] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.332050] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.332064] usb usb1: Product: EHCI Host Controller
[ 1.332076] usb usb1: Manufacturer: Linux 4.4.126 ehci_hcd
[ 1.332125] usb usb1: SerialNumber: fe3c0000.usb
[ 1.332765] hub 1-0:1.0: USB hub found
[ 1.332844] hub 1-0:1.0: 1 port detected
[ 1.333695] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.333763] ohci-platform: OHCI generic platform driver
[ 1.334414] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.334710] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[ 1.334933] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 1.389236] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.389285] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.389301] usb usb2: Product: Generic Platform OHCI controller
[ 1.389314] usb usb2: Manufacturer: Linux 4.4.126 ohci_hcd
[ 1.389326] usb usb2: SerialNumber: fe3e0000.usb
[ 1.389947] hub 2-0:1.0: USB hub found
[ 1.390018] hub 2-0:1.0: 1 port detected
[ 1.391415] usbcore: registered new interface driver cdc_acm
[ 1.391460] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.391546] usbcore: registered new interface driver usblp
[ 1.391644] usbcore: registered new interface driver cdc_wdm
[ 1.391733] usbcore: registered new interface driver uas
[ 1.391872] usbcore: registered new interface driver usb-storage
[ 1.391928] usbcore: registered new interface driver ums-alauda
[ 1.391985] usbcore: registered new interface driver ums-cypress
[ 1.392074] usbcore: registered new interface driver ums-datafab
[ 1.392132] usbcore: registered new interface driver ums_eneub6250
[ 1.392191] usbcore: registered new interface driver ums-freecom
[ 1.392279] usbcore: registered new interface driver ums-isd200
[ 1.392334] usbcore: registered new interface driver ums-jumpshot
[ 1.392392] usbcore: registered new interface driver ums-karma
[ 1.392486] usbcore: registered new interface driver ums-onetouch
[ 1.392541] usbcore: registered new interface driver ums-sddr09
[ 1.392597] usbcore: registered new interface driver ums-sddr55
[ 1.392660] usbcore: registered new interface driver ums-usbat
[ 1.392805] usbcore: registered new interface driver usbserial
[ 1.392861] usbcore: registered new interface driver usbserial_generic
[ 1.392935] usbserial: USB Serial support registered for generic
[ 1.392994] usbcore: registered new interface driver option
[ 1.393032] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.393200] usbcore: registered new interface driver trancevibrator
[ 1.393251] usb20_otg: version 3.10a 21-DEC-2012
[ 1.393552] usb20_host: version 3.10a 21-DEC-2012
[ 1.394356] usbcore: registered new interface driver xpad
[ 1.394436] usbcore: registered new interface driver usb_acecad
[ 1.394533] usbcore: registered new interface driver aiptek
[ 1.394595] usbcore: registered new interface driver gtco
[ 1.394661] usbcore: registered new interface driver hanwang
[ 1.394755] usbcore: registered new interface driver kbtab
[ 1.394773] ==gsl_ts_init==
[ 1.394812] ret=0
[ 1.395543] .. rk pwm remotectl v1.1 init
[ 1.395886] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 1.396470] sensor_register_slave:kxtj9,id=11
[ 1.396499] sensor_register_slave:mma8452,id=17
[ 1.396518] sensor_register_slave:lis3dh,id=7
[ 1.396537] sensor_register_slave:mma7660,id=18
[ 1.396555] sensor_register_slave:lsm303d,id=22
[ 1.396579] sensor_register_slave:gs_mc3230,id=23
[ 1.396587] [Gsensor] gsensor_init
[ 1.396605] sensor_register_slave:mpu6880_acc,id=24
[ 1.396623] sensor_register_slave:mpu6500_acc,id=25
[ 1.396640] sensor_register_slave:lsm330_acc,id=26
[ 1.396654] sensor_register_slave:bma2xx_acc,id=27
[ 1.396668] sensor_register_slave:akm8975,id=30
[ 1.396681] sensor_register_slave:akm8963,id=31
[ 1.396694] sensor_register_slave:l3g4200d,id=45
[ 1.396707] sensor_register_slave:l3g20d,id=46
[ 1.396720] sensor_register_slave:ewtsa,id=47
[ 1.396733] sensor_register_slave:lsm330_gyro,id=51
[ 1.396746] sensor_register_slave:cm3217,id=53
[ 1.396761] sensor_register_slave:cm3218,id=54
[ 1.396775] sensor_register_slave:ls_stk3410,id=62
[ 1.396794] sensor_register_slave:ps_stk3410,id=67
[ 1.397771] i2c /dev entries driver
[ 1.399647] fusb302 4-0022: Can’t get property of role, set role to default DRP
[ 1.408146] fusb302 4-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 1.408224] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80098ce000
[ 1.409564] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 1.409711] fan53555-reg: supplied by vcc5v0_sys
[ 1.411774] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 1.411848] fan53555-reg: supplied by vcc5v0_sys
[ 1.414218] rk808 0-001b: Pmic Chip id: 0x0
[ 1.417837] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.417952] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.418125] DCDC_REG1: supplied by vcc3v3_sys
[ 1.419020] DCDC_REG2: supplied by vcc3v3_sys
[ 1.419687] DCDC_REG3: supplied by vcc3v3_sys
[ 1.420073] DCDC_REG4: supplied by vcc3v3_sys
[ 1.420650] LDO_REG1: supplied by vcc3v3_sys
[ 1.421928] LDO_REG2: supplied by vcc3v3_sys
[ 1.423042] LDO_REG3: supplied by vcc3v3_sys
[ 1.424166] LDO_REG4: supplied by vcc3v3_sys
[ 1.425248] LDO_REG5: supplied by vcc3v3_sys
[ 1.426342] LDO_REG6: supplied by vcc3v3_sys
[ 1.427443] LDO_REG7: supplied by vcc3v3_sys
[ 1.428592] LDO_REG8: supplied by vcc3v3_sys
[ 1.429720] SWITCH_REG1: supplied by vcc3v3_sys
[ 1.430147] SWITCH_REG2: supplied by vcc3v3_sys
[ 1.434026] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 1.434678] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80098d0000
[ 1.435537] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80098d2000
[ 1.435715] rockchip-pinctrl pinctrl: pin gpio4-17 already requested by ff940000.hdmi; cannot claim for ff130000.i2c
[ 1.435762] rockchip-pinctrl pinctrl: pin-145 (ff130000.i2c) status -22
[ 1.435778] rockchip-pinctrl pinctrl: could not request pin 145 (gpio4-17) from group i2c3-xfer on device rockchip-pinctrl
[ 1.435790] rk3x-i2c ff130000.i2c: Error applying setting, reverse things back
[ 1.436241] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff80098d4000
[ 1.437549] IR NEC protocol handler initialized
[ 1.437599] IR RC5(x/sz) protocol handler initialized
[ 1.437615] IR RC6 protocol handler initialized
[ 1.437630] IR JVC protocol handler initialized
[ 1.437645] IR Sony protocol handler initialized
[ 1.437659] IR SANYO protocol handler initialized
[ 1.437674] IR Sharp protocol handler initialized
[ 1.437690] IR MCE Keyboard/mouse protocol handler initialized
[ 1.437706] IR XMP protocol handler initialized
[ 1.438032] usbcore: registered new interface driver uvcvideo
[ 1.438073] USB Video Class driver (1.1.1)
[ 1.438093] CamSys driver version: v0.41.0, CamSys head file version: v1.0.0
[ 1.443818] __power_supply_register: Expected proper parent device for ‘test_ac’
[ 1.444028] __power_supply_register: Expected proper parent device for ‘test_battery’
[ 1.444382] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 1.444511] __power_supply_register: Expected proper parent device for ‘test_usb’
[ 1.448089] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 1.449179] device-mapper: uevent: version 1.0.3
[ 1.449631] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 1.449911] Bluetooth: HCI UART driver ver 2.3
[ 1.449956] Bluetooth: HCI UART protocol H4 registered
[ 1.449965] Bluetooth: HCI UART protocol LL registered
[ 1.449984] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[ 1.449993] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[ 1.450002] rtk_btusb: Register usb char device interface for BT driver
[ 1.450278] usbcore: registered new interface driver rtk_btusb
[ 1.450963] cpu cpu0: cpu_leakage=18
[ 1.451041] cpu cpu0: cpu_leakage=18
[ 1.475915] cpu cpu0: temp=46250, pvtm=145597 (145267 + 330)
[ 1.476752] cpu cpu4: cpu_leakage=32
[ 1.476864] cpu cpu4: cpu_leakage=32
[ 1.489375] cpu cpu4: temp=45625, pvtm=151345 (151205 + 140)
[ 1.495335] sdhci: Secure Digital Host Controller Interface driver
[ 1.495394] sdhci: Copyright(c) Pierre Ossman
[ 1.495411] Synopsys Designware Multimedia Card Interface Driver
[ 1.496629] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.496817] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.496870] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.496938] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.496980] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.497066] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.497078] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.498157] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.498271] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 1.498321] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 1.498406] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 1.498431] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.498576] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 1.498968] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.499165] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.511821] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.526192] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 1.528671] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.530403] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 1.530418] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 1.555230] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 1.555609] mmc0: new high speed SDHC card at address 0001
[ 1.556362] mmcblk0: mmc0:0001 SD16G 29.5 GiB
[ 1.556950] parameter: 0x000000000 – 0x000400000 (4 MB)
[ 1.556972] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 1.556983] trust: 0x000800000 – 0x000c00000 (4 MB)
[ 1.557003] misc: 0x000c00000 – 0x001000000 (4 MB)
[ 1.557013] resource: 0x001000000 – 0x002000000 (16 MB)
[ 1.557024] kernel: 0x002000000 – 0x004000000 (32 MB)
[ 1.557034] boot: 0x004000000 – 0x006000000 (32 MB)
[ 1.557045] recovery: 0x006000000 – 0x00a000000 (64 MB)
[ 1.557055] backup: 0x00a000000 – 0x011000000 (112 MB)
[ 1.557066] security: 0x011000000 – 0x011400000 (4 MB)
[ 1.557076] cache: 0x011400000 – 0x031400000 (512 MB)
[ 1.557087] system: 0x031400000 – 0x0d1400000 (2560 MB)
[ 1.557098] metadata: 0x0d1400000 – 0x0d2400000 (16 MB)
[ 1.557108] vendor: 0x0d2400000 – 0x0f2400000 (512 MB)
[ 1.557119] oem: 0x0f2800000 – 0x112800000 (512 MB)
[ 1.557129] frp: 0x112800000 – 0x112880000 (0 MB)
[ 1.557139] userdata: 0x112880000 – 0x761c00000 (25843 MB)
[ 1.557260] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[ 1.558479] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 1.560731] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.565410] usbcore: registered new interface driver usbhid
[ 1.565465] usbhid: USB HID core driver
[ 1.565641] inv_mpu_iio: inv_mpu_init:746
[ 1.566721] ashmem: initialized
[ 1.571983] ff100000.saradc supply vref not found, using dummy regulator
[ 1.573914] rknandbase v1.2 2018-05-08
[ 1.574424] usbcore: registered new interface driver snd-usb-audio
[ 1.575887] rt5640 1-001c: rt5640 have no aux_det_adc_value defined
[ 1.575970] rt5640 1-001c: Can not read property hp-con-gpio
[ 1.575979] rt5640 1-001c: Can not read property: linein-mute.
[ 1.580934] u32 classifier
[ 1.580967] Actions configured
[ 1.581012] Netfilter messages via NETLINK v0.30.
[ 1.581072] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.581483] ctnetlink v0.93: registering with nfnetlink.
[ 1.582211] xt_time: kernel timezone is -0000
[ 1.583163] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.583475] arp_tables: (C) 2002 David S. Miller
[ 1.583925] Initializing XFRM netlink socket
[ 1.584424] NET: Registered protocol family 10
[ 1.585360] mip6: Mobile IPv6
[ 1.585396] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.586728] sit: IPv6 over IPv4 tunneling driver
[ 1.587197] NET: Registered protocol family 17
[ 1.587226] NET: Registered protocol family 15
[ 1.587261] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 1.587970] Bridge firewalling registered
[ 1.587986] Ebtables v2.0 registered
[ 1.588222] Bluetooth: RFCOMM TTY layer initialized
[ 1.588240] Bluetooth: RFCOMM socket layer initialized
[ 1.588263] Bluetooth: RFCOMM ver 1.11
[ 1.588281] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.588297] Bluetooth: BNEP filters: protocol multicast
[ 1.588309] Bluetooth: BNEP socket layer initialized
[ 1.588321] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.588332] Bluetooth: HIDP socket layer initialized
[ 1.588384] l2tp_core: L2TP core driver, V2.0
[ 1.588403] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.588416] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.588685] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.588735] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[ 1.588747] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.588755] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.588831] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 1.588840] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.588849] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.588897] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.589226] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 1.589273] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[ 1.589303] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[ 1.589332] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[ 1.589726] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.589809] [BT_RFKILL]: ** disable irq
[ 1.589982] [BT_RFKILL]: bt_default device registered.
[ 1.590237] sensor_register_slave:mpu6500_gyro,id=49
[ 1.590260] sensor_register_slave:mpu6880_gyro,id=50
[ 1.592338] Registered cp15_barrier emulation handler
[ 1.592438] Registered setend emulation handler
[ 1.593400] registered taskstats version 1
[ 1.594399] rockchip ion idev is NULL
[ 1.594423] rga2 ff680000.rga: rga ion client create success!
[ 1.594662] rga: Driver loaded successfully ver:3.02
[ 1.594772] vendor storage:20160801 ret = 0
[ 1.596341] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: vbus_drv is not assigned
[ 1.596375] phy phy-ff770000.syscon:usb2-phy@e450.6: Failed to get VBUS supply regulator
[ 1.598623] rockchip-drm display-subsystem: dmc is disabled
[ 1.599021] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 1.599369] rockchip-vop ff900000.vop: unable to request PWM
[ 1.599404] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 1.599468] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 1.599704] rockchip-vop ff8f0000.vop: unable to request PWM
[ 1.599730] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 1.600398] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 1.600452] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 1.600591] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 1.602978] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[ 1.603615] i2c i2c-10: of_i2c: modalias failure on /dp@fec00000/ports
[ 1.604364] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 1.604444] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops)
[ 1.604460] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.604468] [drm] No driver support for vblank timestamp query.
[ 1.606124] dwhdmi-rockchip ff940000.hdmi: failed to get edid
[ 1.631251] dwhdmi-rockchip ff940000.hdmi: failed to get edid
[ 1.637045] rockchip-drm display-subsystem: fb0: frame buffer device
[ 1.654761] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 1.655195] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 3
[ 1.655684] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 1.655840] xhci-hcd xhci-hcd.11.auto: irq 234, io mem 0xfe800000
[ 1.656187] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.656269] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.656493] usb usb3: Product: xHCI Host Controller
[ 1.656715] usb usb3: Manufacturer: Linux 4.4.126 xhci-hcd
[ 1.656937] usb usb3: SerialNumber: xhci-hcd.11.auto
[ 1.657778] hub 3-0:1.0: USB hub found
[ 1.657928] hub 3-0:1.0: 1 port detected
[ 1.658474] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[ 1.659076] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 4
[ 1.659186] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.659443] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.659581] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.659801] usb usb4: Product: xHCI Host Controller
[ 1.660025] usb usb4: Manufacturer: Linux 4.4.126 xhci-hcd
[ 1.660249] usb usb4: SerialNumber: xhci-hcd.11.auto
[ 1.661040] hub 4-0:1.0: USB hub found
[ 1.661230] hub 4-0:1.0: 1 port detected
[ 1.663489] xhci-hcd xhci-hcd.11.auto: remove, state 1
[ 1.663683] usb usb4: USB disconnect, device number 1
[ 1.687903] xhci-hcd xhci-hcd.11.auto: Host not halted after 16000 microseconds.
[ 1.687937] xhci-hcd xhci-hcd.11.auto: Host controller not halted, aborting reset.
[ 1.688045] xhci-hcd xhci-hcd.11.auto: USB bus 4 deregistered
[ 1.688369] xhci-hcd xhci-hcd.11.auto: remove, state 1
[ 1.688409] usb usb3: USB disconnect, device number 1
[ 1.688970] xhci-hcd xhci-hcd.11.auto: USB bus 3 deregistered
[ 1.696183] xhci-hcd xhci-hcd.12.auto: xHCI Host Controller
[ 1.696462] xhci-hcd xhci-hcd.12.auto: new USB bus registered, assigned bus number 3
[ 1.696816] xhci-hcd xhci-hcd.12.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 1.696889] xhci-hcd xhci-hcd.12.auto: irq 235, io mem 0xfe900000
[ 1.697058] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.697088] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.697098] usb usb3: Product: xHCI Host Controller
[ 1.697108] usb usb3: Manufacturer: Linux 4.4.126 xhci-hcd
[ 1.697117] usb usb3: SerialNumber: xhci-hcd.12.auto
[ 1.697625] hub 3-0:1.0: USB hub found
[ 1.697681] hub 3-0:1.0: 1 port detected
[ 1.697977] xhci-hcd xhci-hcd.12.auto: xHCI Host Controller
[ 1.698242] xhci-hcd xhci-hcd.12.auto: new USB bus registered, assigned bus number 4
[ 1.698326] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.698456] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.698484] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.698495] usb usb4: Product: xHCI Host Controller
[ 1.698504] usb usb4: Manufacturer: Linux 4.4.126 xhci-hcd
[ 1.698514] usb usb4: SerialNumber: xhci-hcd.12.auto
[ 1.698979] hub 4-0:1.0: USB hub found
[ 1.699027] hub 4-0:1.0: 1 port detected
[ 1.703475] ehci-platform fe380000.usb: EHCI Host Controller
[ 1.703706] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5
[ 1.703982] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 1.711778] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 1.711964] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.711994] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.712005] usb usb5: Product: EHCI Host Controller
[ 1.712015] usb usb5: Manufacturer: Linux 4.4.126 ehci_hcd
[ 1.712024] usb usb5: SerialNumber: fe380000.usb
[ 1.712577] hub 5-0:1.0: USB hub found
[ 1.712634] hub 5-0:1.0: 1 port detected
[ 1.713565] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 1.713798] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6
[ 1.714024] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 1.772945] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.773043] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.773069] usb usb6: Product: Generic Platform OHCI controller
[ 1.773092] usb usb6: Manufacturer: Linux 4.4.126 ohci_hcd
[ 1.773114] usb usb6: SerialNumber: fe3a0000.usb
[ 1.774498] hub 6-0:1.0: USB hub found
[ 1.774585] hub 6-0:1.0: 1 port detected
[ 1.777428] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.777832] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.777912] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.777995] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.778083] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.778180] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.778242] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.779005] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 1.791932] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.805302] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 1.806289] rt5640 1-001c: rt5640 have no aux_det_adc_value defined
[ 1.806486] rt5640 1-001c: Can not read property hp-con-gpio
[ 1.806525] rt5640 1-001c: Can not read property: linein-mute.
[ 1.809869] asoc-simple-card spdif-sound: dit-hifi ↔ ff870000.spdif mapping ok
[ 1.811898] rk-hdmi-dp-sound hdmi-dp-sound: control 3:0:0:ELD:0 is already present
[ 1.811939] hdmi-audio-codec hdmi-audio-codec.10.auto: ASoC: Failed to add ELD: -16
[ 1.812965] rk-hdmi-dp-sound hdmi-dp-sound: multicodec ↔ ff8a0000.i2s mapping ok
[ 1.813065] hdmi-audio-codec hdmi-audio-codec.10.auto: ASoC: Failed to create Playback debugfs file
[ 1.814452] rt5640 1-001c: rt5640 have no aux_det_adc_value defined
[ 1.814594] rt5640 1-001c: Can not read property hp-con-gpio
[ 1.814619] rt5640 1-001c: Can not read property: linein-mute.
[ 1.817610] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:58:22 UTC (1358499502)
[ 1.818997] It doesn’t contain Rogue gpu
[ 1.828515] mmc_host mmc2: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[ 1.847638] u?
[ 1.868796] mmc_host mmc2: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
