我烧录的韦山东的sdcard.img镜像,提示如下信息。请问是什么情况
DDR Version 1.00 20160530
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-10 (Nov 20 2017 - 17:19:35)
CPU: rk3288
cpu version = 0
CPU's clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 0
SDCard Update.
storage init OK!
GetParam
W: Invalid Parameter's tag (0x00000000)!
Invalid parameter
No pmic detect.
SDM_Write error = 0x1f80 ret = 0x1
#Boot ver: 0000-00-00#0.00
empty serial no.
Writing env to storage...
SDM_Write error = 0x1fc0 ret = 0x1
write_env failed at 0
failed
unknown reboot type 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
'recovery' does not seem to be a partition nor an address
Unable to boot:recovery
try to start backup
'backup' does not seem to be a partition nor an address
Unable to boot:backup
try to start rockus
