AIO3399C(AI)的板子很容易死机
因为项目的需要,之前使用3399J的板子来开发,后面想做升级,降低成本,使用3399C板,发现经常死机,时间随机,死机时画面卡死、adb卡死,不知道是什么原因?
不知道社区大佬们有没有类似的发现,或者有木有解决思路
我觉得可能是散热的问题,不过应该是60度都能正常工作吧
还有可能是cat处理器的温度太频繁了
不行的话只能用回3399J了,折腾!
一般60 度是可以正常工作的,不过如果CPU处理太高,太频繁的东西,也可能会导致这样类似的情况。adb卡死,有没有试过使用串口,有无log信息呢?
开机绿屏,串口的log如图所示,帮忙查看是什么原因?
印象是太热引起的,可是另一块板不会出现这种现象。
公版固件的4G可以上网,自己编译(tvbox版)的不可以,也不知道是什么原因?
另外,这个日志可以看出为什么不能通过4G上网吗
请烧录公版固件验证,如果公版固件后有问题,可以log发出来
烧错了,烧成AIO3399C的固件,
{:4_104:}
公版固件
出现开机异常,停留在安卓logo,串口信息
x#0 = 0xUnhandled Exception in EL#.
x#0 = 0x
断电重启,卡在萤火虫logo,串口信息:
[ 3.007696] SMP: failed to stop secondary CPUs
[ 3.008098] Unable to handle kernel paging request at virtual address ffffef800888ad34
[ 3.008793] pgd = ffffff80094a9000
[ 3.009099] [ffffef800888ad34] *pgd=00000000f6ffe003, *pud=00000000f6ffe003, *pmd=00c8000000a00f11
死机,画面不更新,触摸无反应,串口无反应,日志如下:
[ 498.651406] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 498.651414] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 498.662325] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 498.662500] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 498.686251] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 498.686434] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 498.699415] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 498.699481] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 498.699492] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 498.699503] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 498.699511] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 498.712423] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 498.712599] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 498.757214] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 498.757378] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 498.768385] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 498.768423] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 498.768434] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 498.768451] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 498.768464] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 498.779343] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 498.779439] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 498.803485] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 498.803599] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 498.816545] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 498.816585] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 498.816596] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 498.816606] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 498.816614] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 498.829653] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 498.829812] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 498.968111] init: Untracked pid 3822 exited with status 0
[ 499.054750] init: Untracked pid 3834 exited with status 0
[ 499.126442] init: Untracked pid 3846 exited with status 0
[ 499.392813] init: Untracked pid 3825 exited with status 0
[ 499.552321] init: Untracked pid 3849 exited with status 0
[ 499.649613] init: Untracked pid 3837 exited with status 0
[ 502.264811] init: Untracked pid 3887 exited with status 0
[ 502.371913] init: Untracked pid 3898 exited with status 0
[ 502.394526] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 502.394610] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 502.404611] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 502.404624] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 502.404631] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 502.404637] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 502.404642] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 502.415445] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 502.415665] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 502.439900] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 502.440018] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 502.454220] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 502.454250] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 502.454266] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 502.454280] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 502.454291] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 502.467100] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 502.467222] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 502.536841] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 502.537032] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 502.549760] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 502.549805] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 502.549826] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 502.549844] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 502.549857] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 502.560800] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 502.560922] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 502.586631] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 502.586801] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 502.601794] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 502.601834] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 502.601856] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 502.601875] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 502.601888] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 502.615007] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 502.615241] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 502.683259] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 502.683364] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 502.692718] init: Untracked pid 3890 exited with status 0
[ 502.694698] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 502.694723] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 502.694737] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 502.694749] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 502.694758] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 502.705648] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 502.705848] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 502.730512] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 502.730766] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 502.744073] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 502.744098] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 502.744111] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 502.744123] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 502.744132] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 502.757173] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 502.757335] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 502.800470] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 502.800567] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 502.806960] init: Untracked pid 3901 exited with status 0
[ 502.813552] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 502.813678] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 502.813709] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 502.813735] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 502.813754] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 502.824840] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 502.825116] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 502.849174] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 502.849514] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 502.862691] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 502.862753] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 502.862767] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 502.862778] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 502.862787] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 502.875819] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 502.876138] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 502.944287] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 502.944419] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 502.955629] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 502.955673] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 502.955685] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 502.955695] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 502.955702] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 502.966909] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 502.967174] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 502.991594] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 502.991855] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 503.004711] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 503.004751] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 503.004763] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 503.004772] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 503.004780] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 503.017965] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 503.018213] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 503.086977] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 503.087115] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 503.098309] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 503.098353] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 503.098369] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 503.098385] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 503.098393] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 503.109365] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 503.109590] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 503.133337] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 503.133561] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 503.146470] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 503.146508] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 503.146519] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 503.146529] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 503.146536] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 503.159843] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 503.160107] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 503.293759] init: Untracked pid 3925 exited with status 0
[ 503.389388] init: Untracked pid 3937 exited with status 0
[ 503.457476] init: Untracked pid 3949 exited with status 0
[ 503.715284] init: Untracked pid 3928 exited with status 0
[ 503.892986] init: Untracked pid 3952 exited with status 0
[ 503.984794] init: Untracked pid 3940 exited with status 0
[ 506.574036] init: Untracked pid 3992 exited with status 0
[ 506.650591] init: Untracked pid 4004 exited with status 0
[ 506.676931] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 506.677055] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 506.687637] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 506.687692] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 506.687703] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 506.687712] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 506.687719] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 506.698592] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 506.698762] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 506.722514] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 506.722773] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 506.735574] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 506.735627] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 506.735638] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 506.735647] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 506.735654] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 506.748638] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 506.748927] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 506.817131] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 506.817291] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 506.828814] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 506.828843] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 506.828857] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 506.828869] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 506.828877] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 506.839852] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 506.840138] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 506.864735] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 506.865068] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 506.881169] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 506.881320] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 506.882131] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 506.882340] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 506.882557] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 506.896157] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 506.896322] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 506.966996] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 506.967140] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 506.980362] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 506.980493] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 506.980705] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 506.980923] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 506.981141] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 506.992299] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 506.992508] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 507.018695] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 507.018947] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 507.033863] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 507.033907] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 507.033930] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 507.033949] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 507.033966] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 507.047169] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 507.047307] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 507.067572] init: Untracked pid 3995 exited with status 0
[ 507.092047] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 507.092151] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 507.102200] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 507.102215] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 507.102222] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 507.102228] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 507.102232] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 507.113035] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 507.113132] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 507.118208] init: Untracked pid 4007 exited with status 0
[ 507.138707] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 507.138992] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 507.153258] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 507.153356] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 507.153377] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 507.153396] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 507.153409] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 507.166506] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 507.166765] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 507.224006] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 507.224165] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 507.235427] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 507.235460] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 507.235472] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 507.235482] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 507.235490] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 507.246212] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 507.246405] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 507.270082] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 507.270268] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 507.283707] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 507.283763] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 507.283776] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 507.283788] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 507.283797] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 507.296775] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 507.296932] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 507.345237] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 507.345578] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 507.356836] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 507.356889] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 507.356902] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 507.356914] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 507.356922] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 507.367822] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 507.367950] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 507.392387] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 507.392708] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 507.405861] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 507.405923] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 507.405936] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 507.405948] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 507.405957] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 507.419163] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 507.419483] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 507.572187] init: Untracked pid 4031 exited with status 0
[ 507.668996] init: Untracked pid 4043 exited with status 0
[ 507.747051] init: Untracked pid 4055 exited with status 0
[ 507.973970] init: Untracked pid 4034 exited with status 0
[ 508.177537] init: Untracked pid 4058 exited with status 0
[ 508.230437] init: Untracked pid 4046 exited with status 0
[ 510.876493] init: Untracked pid 4095 exited with status 0
[ 510.954057] init: Untracked pid 4106 exited with status 0
[ 510.980600] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 510.980738] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 510.991861] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 510.991885] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 510.991897] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 510.991908] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 510.991916] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 511.002764] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 511.002867] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 511.026808] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 511.026916] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 511.040136] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 511.040161] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 511.040173] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 511.040183] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 511.040190] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 511.053021] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 511.053193] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 511.128071] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 511.128205] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 511.139870] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 511.139900] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 511.139914] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 511.139926] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 511.139936] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 511.150784] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 511.151014] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 511.176896] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 511.177324] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 511.193482] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 511.193543] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 511.193574] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 511.193599] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 511.193617] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 511.207086] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 511.207481] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 511.278172] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 511.278320] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 511.289956] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 511.289984] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 511.289998] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 511.290011] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 511.290020] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 511.300973] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 511.301082] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 511.319147] init: Untracked pid 4098 exited with status 0
[ 511.325623] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 511.325943] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 511.342378] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 511.342432] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 511.342462] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 511.342488] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 511.342508] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 511.355661] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 511.355815] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 511.380647] init: Untracked pid 4109 exited with status 0
[ 511.432444] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 511.432616] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 511.443884] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 511.443923] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 511.443936] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 511.443948] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 511.443957] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 511.454772] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 511.454907] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 511.479011] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 511.479220] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 511.492458] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 511.492525] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 511.492538] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 511.492550] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 511.492559] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 511.505464] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 511.505684] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 511.570553] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 511.570694] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 511.581932] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 511.581995] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 511.582009] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 511.582022] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 511.582031] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 511.593298] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 511.593427] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 511.617518] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 511.617673] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 511.630768] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 511.630830] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 511.630843] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 511.630855] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 511.630863] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 511.644198] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 511.644400] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 511.714166] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 511.714290] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 511.725458] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 511.725485] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 511.725498] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 511.725510] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 511.725518] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 511.736404] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 511.736590] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 511.762897] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 511.763100] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 511.776228] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 511.776279] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 511.776293] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 511.776305] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 511.776314] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 511.789196] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 511.789395] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 511.944291] init: Untracked pid 4133 exited with status 0
[ 512.037446] init: Untracked pid 4145 exited with status 0
[ 512.108119] init: Untracked pid 4157 exited with status 0
[ 512.378374] init: Untracked pid 4136 exited with status 0
[ 512.532057] init: Untracked pid 4160 exited with status 0
[ 512.637524] init: Untracked pid 4148 exited with status 0
[ 514.998607] Kernel panic - not syncing: stack-protector: Kernel stack is corrupted in: ffffff80080953d8
[ 514.998607]
桌面非正常,触摸无响应,再启动,灯不亮,黑屏,串口信息如下:
DDR Version 1.23 20190709
channel 0
CS = 0
MR0=0x98
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 416MHz 0,1
Channel 0: LPDDR4,416MHz
W FF != R
Cap error!
Channel 1: LPDDR4,416MHz
no stride
channel 1
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
好像越来越容易花屏了,截得串口日志:
[ 341.447002] X29: 0xffffffc00a3bfe40:
[ 341.447032] fe40 00000001 00000000 7f737d74 0000004f 0930acf8 ffffff80 00000018 00000000
[ 341.447061] fe60 016a9000 00000000 00d77234 00000000 00000000 00000000 0a3bfec0 ffffffc0
[ 341.447091] fe80 08095430 ffffff80 0a3bfec0 ffffffc0 087d14a0 ffffff80 604001c5 00000000
[ 341.447120] fea0 0a3bfee0 ffffffc0 087b1740 ffffff80 ffffffff ffffffff 00000002 00000000
[ 341.447150] fec0 0a3bfed0 ffffffc0 08095430 ffffff80 0a3bfee0 ffffffc0 087b174c ffffff80
[ 341.447179] fee0 0a3bff00 ffffffc0 087afaa8 ffffff80 0930add0 ffffff80 00000002 00000000
[ 341.447209] ff00 0a3bff50 ffffffc0 087afbec ffffff80 f1331c00 ffffffc0 0a3a9b00 ffffffc0
[ 341.447239] ff20 0930acf8 ffffff80 091ab000 ffffff80 091ab000 ffffff80 091ab000 ffffff80
[ 341.447242]
[ 341.447255] Process swapper/1 (pid: 0, stack limit = 0xffffffc00a3bc000)
[ 341.447263] Stack: (0xffffffc00a3bfec0 to 0xffffffc00a3c0000)
[ 341.447279] fec0: ffffffc00a3bfed0 ffffff8008095430 ffffffc00a3bfee0 ffffff80087b174c
[ 341.447293] fee0: ffffffc00a3bff00 ffffff80087afaa8 ffffff800930add0 0000000000000002
[ 341.447307] ff00: ffffffc00a3bff50 ffffff80087afbec ffffffc0f1331c00 ffffffc00a3a9b00
[ 341.447321] ff20: ffffff800930acf8 ffffff80091ab000 ffffff80091ab000 ffffff80091ab000
[ 341.447335] ff40: 00000000016a6000 ffffffc0f6f0b2ec ffffffc00a3bff60 ffffff80080e6c5c
[ 341.447348] ff60: ffffffc00a3bff80 ffffff80080e6ea8 ffffffc0f1331c00 ffffff80080e6e98
[ 341.447361] ff80: ffffffc00a3bffd0 ffffff800808ee1c 0000000000000001 0000000000000001
[ 341.447374] ffa0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 341.447387] ffc0: 00000000016a6000 00000000016a9000 0000000000000000 0000000000d77178
[ 341.447400] ffe0: 0000000000000000 0000000000000e12 2000000000000000 4400000002000000
[ 341.447404] Call trace:
[ 341.532776] CPU3: stopping
[ 341.533050] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 4.4.126 #3
[ 341.533589] Hardware name: AIO-3399C(AI) HDMI(Android) (DT)
[ 341.534090] Call trace:
[ 341.534339] [] dump_backtrace+0x0/0x1ec
[ 342.699348] SMP: failed to stop secondary CPUs
[ 342.702186] Unable to handle kernel paging request at virtual address ffffff800806d000
[ 342.702963] Unable to handle kernel paging request at virtual address ffffff800806b000
[ 342.703745] Unable to handle kernel paging request at virtual address ffffff8008069000
加上官方的风扇就好了,温度能控制在室温加4℃。
感觉是高温温度影响周围某些器件的正常工作,3399自己应该50多℃也能正常工作。
