在inudstry版的安卓SDK里编译3399J的固件,使用统编命令时出错,日志如下,望得到解答。
ma@U1404:~/proj/industry-rk3399$ ./FFTools/make.sh -d rk3399-firefly-aio -j4 -l rk3399_firefly_aio_box-userdebug
~/proj/industry-rk3399/u-boot ~/proj/industry-rk3399
CHK include/config.h
GEN include/autoconf.mk
GEN include/autoconf.mk.dep
CHK include/config/uboot.release
CHK include/generated/timestamp_autogenerated.h
UPD include/generated/timestamp_autogenerated.h
CHK include/generated/version_autogenerated.h
HOSTCC tools/dumpimage.o
HOSTCC tools/image-host.o
HOSTCC tools/loaderimage.o
HOSTCC tools/mkenvimage.o
tools/loaderimage.c: In function ‘main’:
tools/loaderimage.c:116:28: warning: variable ‘name’ set but not used [-Wunused-but-set-variable]
char *magic, *version, *name;
tools/loaderimage.c:116:18: warning: variable ‘version’ set but not used [-Wunused-but-set-variable]
tools/loaderimage.c:339:8: warning: ignoring return value of ‘fread’, declared with attribute warn_unused_result [-Wunused-result]
fread(hdr, sizeof(struct tag_second_loader_hdr), 1, fi);
HOSTCC tools/mkimage.o
HOSTCC tools/boot_merger
HOSTLD tools/mkenvimage
HOSTLD tools/dumpimage
HOSTLD tools/mkimage
HOSTLD tools/loaderimage
HOSTLD tools/trust_merger
HOSTLD tools/checksum
CC board/rockchip/rk33xx/rk33xx.o
LD board/rockchip/rk33xx/built-in.o
CC board/rockchip/common/rkboot/fastboot.o
CC common/main.o
CC common/board_f.o
LD board/rockchip/common/built-in.o
CC common/cmd_version.o
CC common/cmd_fastboot.o
CC common/cmd_bootrk.o
CC lib/display_options.o
LD lib/built-in.o
LD common/built-in.o
LD u-boot
OBJCOPY u-boot.bin
start=$(/home/ma/proj/industry-rk3399/u-boot/../prebuilts/gcc/linux-x86/aarch64/aarch64-linux-android-4.9/bin/aarch64-linux-android-nm u-boot | grep __rel_dyn_start | cut -f 1 -d ’ '); end=$(/home/ma/proj/industry-rk3399/u-boot/../prebuilts/gcc/linux-x86/aarch64/aarch64-linux-android-4.9/bin/aarch64-linux-android-nm u-boot | grep __rel_dyn_end | cut -f 1 -d ’ '); tools/relocate-rela u-boot.bin 0x00200000 $start $end
OBJCOPY u-boot.srec
./tools/boot_merger ./tools/rk_tools/RKBOOT/RK3399MINIALL.ini
out:rk3399_loader_v1.23.115.bin
fix opt:rk3399_loader_v1.23.115.bin
merge success(rk3399_loader_v1.23.115.bin)
./tools/trust_merger ./tools/rk_tools/RKTRUST/RK3399TRUST.ini
out:trust.img
merge success(trust.img)
./tools/loaderimage --pack --uboot u-boot.bin uboot.img
load addr is 0x200000!
pack input u-boot.bin
pack file size: 541444
crc = 0xb936818d
pack uboot.img success!
~/proj/industry-rk3399/kernel ~/proj/industry-rk3399
CHK scripts/mod/devicetable-offsets.h
make[1]: “arch/arm64/boot/dts/rockchip/rk3399-firefly-aio.dtb”是最新的。
CHK include/generated/timeconst.h
Pack to resource.img successed!
Image: resource.img (with rk3399-firefly-aio.dtb logo.bmp ) is ready
CHK include/generated/bounds.h
CHK include/generated/asm-offsets.h
CALL scripts/checksyscalls.sh
make[1]: “include/generated/vdso-offsets.h”是最新的。
CHK include/generated/compile.h
GZIP kernel/config_data.gz
CHK kernel/config_data.h
make[1]: “arch/arm64/boot/Image”是最新的。
Image: kernel.img is ready
make[2]: “include/generated/vdso-offsets.h”是最新的。
Building modules, stage 2.
MODPOST 12 modules
Image: boot.img (with Image resource.img) is ready
including device/rockchip/rk3399/vendorsetup.sh
including sdk/bash_completion/adb.bash
build/core/product_config.mk:234: *** Can not locate config makefile for product “rk3399_firefly_aio_box”。 停止。
