Android5.1系统原厂镜像启动不成功,开机卡在logo处
Android5.1系统烧写原厂百度网盘里的镜像,烧写成功,启动运行不成功,卡在开机logo Firefly处,串口信息最后一行显示和spdif相关的信息,换个系统烧录Linux镜像,能烧写成功,运行成功,再重新烧写回Android5.1,依然和第一次启动Android5.1的情况一样,求帮忙分析下这是什么原因导致??附上调试串口输出信息:
[10:24:01][20191118_10:24:01]
[10:24:13]DDR Version 1.00 20160530
[10:24:13]In
[10:24:13]Channel a: DDR3 200MHz
[10:24:13]Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
[10:24:13]Channel b: DDR3 200MHz
[10:24:13]Memory OK
[10:24:13]Memory OK
[10:24:13]OUT
[10:24:13]
[10:24:13]
[10:24:13]U-Boot 2014.10-RK3288-10 (Oct 11 2018 - 16:11:54)
[10:24:13]
[10:24:13]CPU: rk3288
[10:24:13]cpu version = 0
[10:24:13]CPU’s clock information:
[10:24:13] arm pll = 600000000HZ
[10:24:13] periph pll = 297000000HZ
[10:24:13] ddr pll = 200000000HZ
[10:24:13] codec pll = 384000000HZ
[10:24:13]Board: Rockchip platform Board
[10:24:13]DRAM: Found dram banks: 1
[10:24:13]Adding bank:0000000000000000(0000000080000000)
[10:24:13]128 MiB
[10:24:13]GIC CPU mask = 0x00000001
[10:24:13]SdmmcInit = 0 400
[10:24:13]SdmmcInit = 2 0
[10:24:13]storage init OK!
[10:24:13]Using default environment
[10:24:13]
[10:24:13]GetParam
[10:24:13]Load FDT from resource image.
[10:24:13]power key: bank-0 pin-5
[10:24:14]pmic:act8846
[10:24:14]can’t find dts node for pwm1
[10:24:14]DCDC vdd_logic has been used, pwm regulator not init it.
[10:24:14]Can’t find dts node for fuel guage cw201x
[10:24:14]SecureBootEn = 0, SecureBootLock = 0
[10:24:14]
[10:24:14]#Boot ver: 2018-10-11#2.30
[10:24:14]empty serial no.
[10:24:14]checkKey
[10:24:14]vbus = 1
[10:24:14]no fuel gauge found
[10:24:14]read logo on state from dts [1]
[10:24:14]can’t find power_ctr node for lcdc0
[10:24:14]pll_src = 1, dclk_hz = 148500000, dclk_div = 2
[10:24:14]got recovery cmd from misc.
[10:24:14]load fdt from resouce.
[10:24:14]ERROR: [get_entry_ram]: Cannot find logo_kernel.bmp!
[10:24:14]Secure Boot state: 0
[10:24:14]kernel @ 0x02000000 (0x006ae930)
[10:24:14]ramdisk @ 0x05bf0000 (0x002ad1f4)
[10:24:14]bootrk: do_bootm_linux…
[10:24:14] Loading Device Tree to 05600000, end 0561bf37 … OK
[10:24:14]Add bank:0000000000000000, 0000000080000000
[10:24:14]
[10:24:14]Starting kernel …
[10:24:14]
[10:24:16][ 0.000000] Booting Linux on physical CPU 0x500
[10:24:16][ 0.000000] Initializing cgroup subsys cpu
[10:24:16][ 0.000000] Initializing cgroup subsys cpuacct
[10:24:16][ 0.000000] Linux version 3.10.0 (firefly@tchip-server) (gcc version 4.6.x-google 20120106 (prere8
[10:24:16][ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d
[10:24:16][ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[10:24:16][ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288
[10:24:16][ 0.000000] rockchip_uboot_logo_setup: mem: 0x02000000@0x7dc00000, offset:0x00000000
[10:24:16][ 0.000000] rockchip_uboot_mem_reserve: reserve 0x02000000@0x7dc00000 for uboot logo
[10:24:16][ 0.000000] rockchip_ion_reserve
[10:24:16][ 0.000000] ion heap(drm): base(0) size(0) align(0)
[10:24:16][ 0.000000] ion heap(cma): base(0) size(1000000) align(0)
[10:24:16][ 0.000000] ion heap(vmalloc): base(0) size(0) align(0)
[10:24:16][ 0.000000] cma: CMA: reserved 16 MiB at 7cc00000
[10:24:16][ 0.000000] ion_reserve: cma reserved base 7cc00000 size 16777216
[10:24:16][ 0.000000] cma: CMA: reserved 16 MiB at 1f000000
[10:24:16][ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[10:24:16][ 0.000000] Boot mode: RECOVERY (2) flag: RECOVER (0xc3524203)
[10:24:16][ 0.000000] PERCPU: Embedded 9 pages/cpu @c1f26000 s13376 r8192 d15296 u36864
[10:24:16][ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523264
[10:24:16][ 0.000000] Kernel command line: vmalloc=496M console=ttyS2 androidboot.selinux=permissive androi4
[10:24:16][ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[10:24:16][ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[10:24:16][ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[10:24:16][ 0.000000] allocated 4194304 bytes of page_cgroup
[10:24:16][ 0.000000] please try ‘cgroup_disable=memory’ option if you don’t want memory cgroups
[10:24:16][ 0.000000] Memory: 2048MB = 2048MB total
[10:24:16][ 0.000000] Memory: 1992188k/1992188k available, 104964k reserved, 1523712K highmem
[10:24:16][ 0.000000] Virtual kernel memory layout:
[10:24:16][ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[10:24:16][ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[10:24:16][ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[10:24:16][ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[10:24:16][ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[10:24:16][ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[10:24:16][ 0.000000] .text : 0xc0008000 - 0xc0bbbd80 (11984 kB)
[10:24:16][ 0.000000] .init : 0xc0bbc000 - 0xc0c15440 ( 358 kB)
[10:24:16][ 0.000000] .data : 0xc0c16000 - 0xc0da86c0 (1610 kB)
[10:24:16][ 0.000000] .bss : 0xc0da86c0 - 0xc0ecbdbc (1166 kB)
[10:24:16][ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[10:24:16][ 0.000000] Preemptible hierarchical RCU implementation.
[10:24:16][ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[10:24:16][ 0.000000] NR_IRQS:16 nr_irqs:16 16
[10:24:16][ 0.000000] rk_clk_tree_init start!
[10:24:16][ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div
[10:24:16][ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error
[10:24:16][ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1
[10:24:16][ 0.000000] rkclk_init_clks: cnt_parent = 7
[10:24:16][ 0.000000] rkclk_init_clks: cnt_rate = 29
[10:24:16][ 0.000000] rk3288 set GPLL BW 20 for HDMI!
[10:24:16][ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[10:24:16][ 0.000000] Switching to timer-based delay loop
[10:24:16][ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns
[10:24:16][ 0.000000] process version: 0
[10:24:16][ 0.000000] channel:0, lkg:25
[10:24:16][ 0.000000] target-temp:80
[10:24:16][ 0.000000] channel:2, lkg:0
[10:24:16][ 0.000000] channel:1, lkg:17
[10:24:16][ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms
[10:24:16][ 0.492053] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 Bogo)
[10:24:16][ 0.492068] pid_max: default: 32768 minimum: 301
[10:24:16][ 0.492184] Security Framework initialized
[10:24:16][ 0.492201] SELinux: Initializing.
[10:24:16][ 0.492274] Mount-cache hash table entries: 512
[10:24:16][ 0.492916] Initializing cgroup subsys debug
[10:24:16][ 0.492931] Initializing cgroup subsys memory
[10:24:16][ 0.492957] Initializing cgroup subsys freezer
[10:24:16][ 0.492985] CPU: Testing write buffer coherency: ok
[10:24:16][ 0.493295] /cpus/cpu@0 missing clock-frequency property
[10:24:16][ 0.493309] /cpus/cpu@1 missing clock-frequency property
[10:24:16][ 0.493318] /cpus/cpu@2 missing clock-frequency property
[10:24:16][ 0.493328] /cpus/cpu@3 missing clock-frequency property
[10:24:16][ 0.493377] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[10:24:16][ 0.493428] Setting up static identity map for 0xc0869720 - 0xc0869778
[10:24:16][ 0.496804] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x1)
[10:24:16][ 0.570212] CPU1: Booted secondary processor
[10:24:16][ 0.570246] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[10:24:16][ 0.589885] CPU2: Booted secondary processor
[10:24:16][ 0.589909] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[10:24:16][ 0.609594] CPU3: Booted secondary processor
[10:24:16][ 0.609619] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[10:24:16][ 0.609719] Brought up 4 CPUs
[10:24:16][ 0.609747] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[10:24:16][ 0.609756] CPU: All CPU(s) started in SVC mode.
[10:24:16][ 0.610507] devtmpfs: initialized
[10:24:16][ 0.614906] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[10:24:16][ 0.616014] pinctrl core: initialized pinctrl subsystem
[10:24:16][ 0.616263] regulator-dummy: no parameters
[10:24:16][ 0.630301] NET: Registered protocol family 16
[10:24:16][ 0.632135] DMA: preallocated 256 KiB pool for atomic coherent allocations
[10:24:16][ 0.632506] ion_snapshot: 0x1ea98000 map to 0xe0907000 and copy to 0xc0ea704c (version 0.1)
[10:24:16][ 0.632751] Registered FIQ tty driver
[10:24:16][ 0.633142] fiq-debugger is disabled in device tree
[10:24:16][ 0.633862] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[10:24:16][ 0.633884] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[10:24:16][ 0.633901] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[10:24:16][ 0.633918] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[10:24:16][ 0.634015] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff
[10:24:16][ 0.634082] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff
[10:24:16][ 0.634144] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff
[10:24:16][ 0.634205] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff
[10:24:16][ 0.634267] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff
[10:24:16][ 0.634328] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff
[10:24:16][ 0.634390] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff
[10:24:16][ 0.634453] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff
[10:24:16][ 0.634520] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xf
[10:24:16][ 0.634585] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[10:24:16][ 0.634598] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[10:24:16][ 0.634610] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[10:24:17][ 0.634621] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[10:24:17][ 0.635232] rockchip_interrupts_register:bank_num=7
[10:24:17][ 0.637145] of_get_gpio_init_config:gpio[0] = 136, value = 0
[10:24:17][ 0.637165] of_get_gpio_init_config:gpio[1] = 13, value = 1
[10:24:17][ 0.637220] rockchip_pinctrl_probe:init ok
[10:24:17][ 0.644031] rk_iommu ff900800.iep_mmu: (iep) Enter
[10:24:17][ 0.644123] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[10:24:17][ 0.644137] rk_iommu ff900800.iep_mmu: (iep) Initialized
[10:24:17][ 0.644305] rk_iommu ff950800.vip_mmu: (vip) Enter
[10:24:17][ 0.644384] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[10:24:17][ 0.644397] rk_iommu ff950800.vip_mmu: (vip) Initialized
[10:24:17][ 0.644556] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[10:24:17][ 0.644635] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[10:24:17][ 0.644647] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[10:24:17][ 0.644808] rk_iommu ff940300.vopl_mmu: (vopl) Enter
[10:24:17][ 0.644884] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[10:24:17][ 0.644896] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[10:24:17][ 0.645063] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[10:24:17][ 0.645145] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[10:24:17][ 0.645157] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[10:24:17][ 0.645324] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[10:24:17][ 0.645402] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[10:24:17][ 0.645414] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[10:24:17][ 0.645583] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[10:24:17][ 0.645673] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[10:24:17][ 0.645685] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
[10:24:17][ 0.647275] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[10:24:17][ 0.647287] hw-breakpoint: maximum watchpoint size is 4 bytes.
[10:24:17][ 0.647872] rk3368_init_rockchip_pmu_ops: could not find pmu dt node
[10:24:17][ 0.647894] DDR DEBUG: version 1.00 20150126
[10:24:17][ 0.647921] DDR DEBUG: Channel a:
[10:24:17][ 0.647930] DDR DEBUG: DDR3 Device
[10:24:17][ 0.647944] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[10:24:17][ 0.647953] DDR DEBUG: Channel b:
[10:24:17][ 0.647960] DDR DEBUG: DDR3 Device
[10:24:17][ 0.647972] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[10:24:17][ 0.647981] DDR DEBUG: addr=0xdb2000
[10:24:17][ 0.647991] DDR DEBUG: stride=9, size=256, halfcap=40000000
[10:24:17][ 0.648000] DDR DEBUG: socAddr[0]=0xdb2000, socAddr[1]=0xdb2100
[10:24:17][ 0.648009] DDR DEBUG: chAddr[0]=0xdb2000, chAddr[1]=0xdb2000
[10:24:17][ 0.648021] DDR DEBUG: dtar[0]=0x201b6000, dtar[1]=0x201b6000
[10:24:17][ 0.648074] DDR DEBUG: init success!!! freq=200MHz
[10:24:17][ 0.648082] DDR DEBUG: Channel a:
[10:24:17][ 0.648094] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=10
[10:24:17][ 0.648108] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=10
[10:24:17][ 0.648120] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=10
[10:24:17][ 0.648133] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=10
[10:24:17][ 0.648144] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[10:24:17][ 0.648153] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[10:24:17][ 0.648161] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[10:24:17][ 0.648168] DDR DEBUG: Channel b:
[10:24:17][ 0.648180] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=10
[10:24:17][ 0.648192] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=10
[10:24:17][ 0.648205] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=10
[10:24:17][ 0.648217] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=10
[10:24:17][ 0.648228] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[10:24:17][ 0.648237] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[10:24:17][ 0.648245] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[10:24:17][ 0.672767] bio: create slab at 0
[10:24:17][ 0.673296] Rockchip hdmi driver version 2.0
[10:24:17][ 0.673296] .
[10:24:17][ 0.674430] SCSI subsystem initialized
[10:24:17][ 0.674585] usbcore: registered new interface driver usbfs
[10:24:17][ 0.674629] usbcore: registered new interface driver hub
[10:24:17][ 0.674715] usbcore: registered new device driver usb
[10:24:17][ 0.676976] host_en_gpio= -2
[10:24:17][ 0.679395] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[10:24:17][ 0.680045] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
[10:24:17][ 0.680485] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
[10:24:17][ 0.680732] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[10:24:17][ 0.681172] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[10:24:17][ 0.681287] media: Linux media interface: v0.10
[10:24:17][ 0.681327] Linux video capture interface: v2.00
[10:24:17][ 0.681382] pps_core: LinuxPPS API ver. 1 registered
[10:24:17][ 0.681391] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.>
[10:24:17][ 0.681412] PTP clock support registered
[10:24:17][ 0.681475] i2c-core: driver [bq24296] using legacy suspend method
[10:24:17][ 0.681484] i2c-core: driver [bq24296] using legacy resume method
[10:24:17][ 0.681791] RK29 Watchdog Timer, (c) 2011 Rockchip Electronics
[10:24:17][ 0.682259] ion_drm_heap_create: 0@0
[10:24:17][ 0.682393] Rockchip ion module is successfully loaded (v1.1)
[10:24:17][ 0.682549] Advanced Linux Sound Architecture Driver Initialized.
[10:24:17][ 0.682962] Bluetooth: Core ver 2.16
[10:24:17][ 0.683000] NET: Registered protocol family 31
[10:24:17][ 0.683009] Bluetooth: HCI device and connection manager initialized
[10:24:17][ 0.683025] Bluetooth: HCI socket layer initialized
[10:24:17][ 0.683038] Bluetooth: L2CAP socket layer initialized
[10:24:17][ 0.683065] Bluetooth: SCO socket layer initialized
[10:24:17][ 0.683303] cfg80211: Calling CRDA to update world regulatory domain
[10:24:17][ 0.683984] act8846_i2c_probe,line=898
[10:24:17][ 0.684986] act8846_parse_dt,line=746
[10:24:17][ 0.685448] act8846_i2c_probe: act8846_pmic_hold=1
[10:24:17][ 0.685469] act8846_i2c_probe: act8846_pmic_sleep=1
[10:24:17][ 0.685486] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
[10:24:17][ 0.685500] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
[10:24:17][ 0.687585] act_dcdc1: 1200 mV
[10:24:17][ 0.690560] vccio: 3300 mV
[10:24:17][ 0.692422] vdd_logic: 700 ↔ 1500 mV at 1100 mV
[10:24:17][ 0.695395] act_dcdc4: 2000 mV
[10:24:17][ 0.696653] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
[10:24:17][ 0.698964] act_ldo2: 1050 mV
[10:24:17][ 0.701258] act_ldo3: 3300 mV
[10:24:17][ 0.703554] act_ldo4: 3300 mV
[10:24:17][ 0.705858] act_ldo5: 3300 mV
[10:24:17][ 0.708186] act_ldo6: 1100 mV
[10:24:17][ 0.710504] vcc_18: 1800 mV
[10:24:17][ 0.712802] act_ldo8: 1850 mV
[10:24:17][ 0.717551] vdd_arm: 712 ↔ 1500 mV at 1000 mV
[10:24:17][ 0.722267] vdd_gpu: 712 ↔ 1500 mV at 1000 mV
[10:24:17][ 0.723018] rk808_i2c_probe,line=1355
[10:24:17][ 0.724347] The device is not rk808 -11
[10:24:17][ 0.724430] rk808: probe of 0-001b failed with error -11
[10:24:17][ 0.724505] i2c-core: driver [rk818] using legacy suspend method
[10:24:17][ 0.724514] i2c-core: driver [rk818] using legacy resume method
[10:24:17][ 0.726287] Switching to clocksource arch_sys_counter
[10:24:17][ 0.750254] rga: Module initialized.
[10:24:17][ 0.750986] rga2 ff920000.rga: rga ion client create success!
[10:24:17][ 0.751160] rga: Driver loaded succesfully
[10:24:17][ 0.751358] fb disp policy is box
[10:24:17][ 0.751399] rk-fb rockchip-fb: rk fb ion client create success!
[10:24:17][ 0.751411] rk-fb rockchip-fb: rockchip framebuffer driver probe
[10:24:17][ 0.751750] rk-screen rk_screen.8: rockchip screen probe success
[10:24:17][ 0.751997] rk32-lvds rk32-lvds: rk32 lvds driver probe success
[10:24:17][ 0.752351] rk32-edp ff970000.edp: screen is not edp!
[10:24:17][ 0.752373] rk32-edp: probe of ff970000.edp failed with error -22
[10:24:17][ 0.752847] rk3288-lcdc lcdc0: can’t find power_ctr node for lcdc0
[10:24:17][ 0.753071] graphics fb0: rockchip framebuffer registerd:fb0
[10:24:17][ 0.753376] graphics fb1: rockchip framebuffer registerd:fb1
[10:24:17][ 0.753550] graphics fb2: rockchip framebuffer registerd:fb2
[10:24:17][ 0.753711] graphics fb3: rockchip framebuffer registerd:fb3
[10:24:17][ 0.754425] rk3288-lcdc lcdc0: lcdc0: dclk:297000000>>fps:120
[10:24:17][ 0.754441] rk3288-lcdc lcdc0: wakeup from standby!
[10:24:17][ 0.778271] rk_battery_charger_detect_cb , battery_charger_detect 1
[10:24:17][ 0.785477] alloc_buffer:ion_phy_addr=0x10000000
[10:24:17][ 0.798376] fb0:phy:10000000>>vir:e0991000>>len:0x1800000
[10:24:17][ 0.812281] rk_iommu ff930300.vopb_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgt0
[10:24:17][ 0.812357] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
[10:24:17][ 0.813288] rockchip_set_mux:warning ignore bank num 15
[10:24:17][ 0.813427] rockchip_set_mux:warning ignore bank num 15
[10:24:17][ 0.813556] rockchip_set_mux:warning ignore bank num 15
[10:24:17][ 0.813676] rockchip_set_mux:warning ignore bank num 15
[10:24:17][ 0.813795] rockchip_set_mux:warning ignore bank num 15
[10:24:17][ 0.813915] rockchip_set_mux:warning ignore bank num 15
[10:24:17][ 0.814501] rockchip_set_mux:warning ignore bank num 15
[10:24:17][ 0.814662] rockchip_set_mux:warning ignore bank num 15
[10:24:17][ 0.815211] rockchip_set_mux:warning ignore bank num 15
[10:24:17][ 0.815361] rockchip_set_mux:warning ignore bank num 15
[10:24:17][ 0.815896] rockchip_set_mux:warning ignore bank num 15
[10:24:17][ 0.816042] rockchip_set_mux:warning ignore bank num 15
[10:24:17][ 0.816579] rockchip_set_mux:warning ignore bank num 15
[10:24:17][ 0.816730] rockchip_set_mux:warning ignore bank num 15
[10:24:17][ 0.817839] tc358749_hdmiin_probe!
[10:24:17][ 0.877121] tc358749_hdmiin_probe OK!
[10:24:17][ 0.877620] NET: Registered protocol family 2
[10:24:17][ 0.878300] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[10:24:17][ 0.878376] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[10:24:17][ 0.878447] TCP: Hash tables configured (established 4096 bind 4096)
[10:24:17][ 0.878502] TCP: reno registered
[10:24:17][ 0.878517] UDP hash table entries: 256 (order: 1, 8192 bytes)
[10:24:17][ 0.878540] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[10:24:17][ 0.878724] NET: Registered protocol family 1
[10:24:17][ 0.879320] Unpacking initramfs…
[10:24:17][ 1.011836] Freeing initrd memory: 2740K (c5bf0000 - c5e9d000)
[10:24:17][ 1.012646] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[10:24:17][ 1.013190] vcodec_service: probe device ff9a0000.vpu_service
[10:24:17][ 1.013387] vcodec_service: No reset resource define
[10:24:17][ 1.013564] vcodec_service: ff9a0000.vpu_service: power on
[10:24:17][ 1.013653] vcodec_service: probe device ff9a0000.vpu_service
[10:24:17][ 1.013668] vcodec_service: checking hw id 4831
[10:24:17][ 1.014705] vcodec_service: ff9a0000.vpu_service: power off…
[10:24:17][ 1.014748] vcodec_service: done
[10:24:17][ 1.014756] vcodec_service: init success
[10:24:17][ 1.014820] vcodec_service: probe device ff9c0000.hevc_service
[10:24:17][ 1.015160] vcodec_service: ff9c0000.hevc_service: power on
[10:24:17][ 1.015220] vcodec_service: probe device ff9c0000.hevc_service
[10:24:17][ 1.015234] vcodec_service: checking hw id 6867
[10:24:17][ 1.015800] vcodec_service: ff9c0000.hevc_service: power off…
[10:24:17][ 1.015840] vcodec_service: done
[10:24:17][ 1.015848] vcodec_service: init success
[10:24:17][ 1.015976] rknandbase v1.0 2014-03-31
[10:24:17][ 1.016114] rknand: probe of ff400000.nandc failed with error -1
[10:24:17][ 1.016220] rknand_driver:ret = 0
[10:24:17][ 1.018072] audit: initializing netlink socket (disabled)
[10:24:17][ 1.018117] type=2000 audit(0.520:1): initialized
[10:24:17][ 1.018953] bounce pool size: 64 pages
[10:24:17][ 1.023622] fuse init (API version 7.22)
[10:24:17][ 1.023984] msgmni has been set to 952
[10:24:18][ 1.025746] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[10:24:18][ 1.025760] io scheduler noop registered
[10:24:18][ 1.025770] io scheduler deadline registered
[10:24:18][ 1.025855] io scheduler cfq registered (default)
[10:24:18][ 1.027049] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess.
[10:24:18][ 1.027728] IEP Power ON
[10:24:18][ 1.027769] iep ion client create success!
[10:24:18][ 1.028213] rk_iommu ff900800.iep_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgta0
[10:24:18][ 1.028224] IEP Power OFF
[10:24:18][ 1.028242] IEP Driver loaded succesfully
[10:24:18][ 1.028337] Module initialized.
[10:24:18][ 1.029177] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[10:24:18][ 1.029195] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[10:24:18][ 1.030557] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[10:24:18][ 1.030574] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-6
[10:24:18][ 1.030853] pwm-voltage-regulator pwm_regulator.22: unable to request PWM, trying legacy API
[10:24:18][ 1.030868] pwm-voltage-regulator pwm_regulator.22: unable to request legacy PWM
[10:24:18][ 1.030877] pwm_regulator_probe:error
[10:24:18][ 1.030897] platform pwm_regulator.22: Driver pwm-voltage-regulator requests probe deferral
[10:24:18][ 1.031087] rk_serial.c v1.8 2014-03-04
[10:24:18][ 1.031321] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[10:24:18][ 1.031426] --11
[10:24:18][ 1.031593] serial ff180000.serial: membase e097e000
[10:24:18][ 1.031778] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1
[10:24:18][ 1.031957] serial ff190000.serial: membase e41ae000
[10:24:18][ 1.032109] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
[10:24:18][ 1.033769] console [ttyS2] enabled
[10:24:18][ 1.033935] serial ff690000.serial: membase fed60000
[10:24:18][ 1.034104] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90) is a rk29_serial.3
[10:24:18][ 1.034271] serial ff1b0000.serial: membase e41b6000
[10:24:18][ 1.036994] loop: module loaded
[10:24:18][ 1.037370] zram: Created 1 device(s) …
[10:24:18][ 1.037451] i2c-core: driver [mpu6050B1] using legacy suspend method
[10:24:18][ 1.037464] i2c-core: driver [mpu6050B1] using legacy resume method
[10:24:18][ 1.037481] mpu_init: Probe name mpu6050B1
[10:24:18][ 1.037640] ak8963_mod_init: Probe name ak8963_mod
[10:24:18][ 1.038340] SCSI Media Changer driver v0.25
[10:24:18][ 1.038606] dws->regs: e41b8000
[10:24:18][ 1.039915] rockchip_spi_probe:num_cs=2,bus_num=0,irq=76,freq=45692308 ok
[10:24:18][ 1.040194] tun: Universal TUN/TAP device driver, 1.6
[10:24:18][ 1.040207] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[10:24:18][ 1.040331] vmac_init.
[10:24:18][ 1.040893] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[10:24:18][ 1.040909] stmmac_probe_config_dt: clock input/output? (input).
[10:24:18][ 1.040922] stmmac_probe_config_dt: TX delay(0x23).
[10:24:18][ 1.040933] stmmac_probe_config_dt: RX delay(0x19).
[10:24:18][ 1.040982] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[10:24:18][ 1.040994] stmmc_pltfr_init:
[10:24:18][ 1.041003] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[10:24:18][ 1.041025] gmac_phy_reset: ERROR: Request pin stmmc_pltfr_init failed.
[10:24:18][ 1.041037] stmmc_pltfr_init: init for RGMII
[10:24:18][ 1.041048] tx delay=0x23
[10:24:18][ 1.041048] rx delay=0x19
[10:24:18][ 1.041064] tx delay=0x23
[10:24:18][ 1.041064] rx delay=0x19
[10:24:18][ 1.041576] stmmac - user ID: 0x10, Synopsys ID: 0x35
[10:24:18][ 1.041589] Normal descriptors
[10:24:18][ 1.041597] Ring mode enabled
[10:24:18][ 1.041608] DMA HW capability register supported
[10:24:18][ 1.041620] RX Checksum Offload Engine supported (type 2)
[10:24:18][ 1.041631] TX Checksum insertion supported
[10:24:18][ 1.041640] Wake-Up On Lan supported
[10:24:18][ 1.041680] Enable RX Mitigation via HW Watchdog Timer
[10:24:18][ 1.042162] PPP generic driver version 2.4.2
[10:24:18][ 1.042322] PPP BSD Compression module registered
[10:24:18][ 1.042336] PPP Deflate Compression module registered
[10:24:18][ 1.042360] PPP MPPE Compression module registered
[10:24:18][ 1.042374] NET: Registered protocol family 24
[10:24:18][ 1.042410] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation .
[10:24:18][ 1.042423] CSLIP: code copyright 1989 Regents of the University of California.
[10:24:18][ 1.042437] Rockchip WiFi SYS interface (V1.00) …
[10:24:18][ 1.042472] esp_mem_init enter date Apr 18 2018 10:10:02
[10:24:18][ 1.042483] esp_mem_init VERSION [V2.5]
[10:24:18][ 1.042529] esp_mem_init complete
[10:24:18][ 1.042616] usbcore: registered new interface driver catc
[10:24:18][ 1.042658] usbcore: registered new interface driver kaweth
[10:24:18][ 1.042672] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[10:24:18][ 1.042713] usbcore: registered new interface driver pegasus
[10:24:18][ 1.042755] usbcore: registered new interface driver rtl8150
[10:24:18][ 1.042803] usbcore: registered new interface driver r8152
[10:24:18][ 1.042815] hso: drivers/net/usb/hso.c: Option Wireless
[10:24:18][ 1.042885] usbcore: registered new interface driver hso
[10:24:18][ 1.042933] usbcore: registered new interface driver asix
[10:24:18][ 1.042974] usbcore: registered new interface driver ax88179_178a
[10:24:18][ 1.043023] usbcore: registered new interface driver cdc_ether
[10:24:18][ 1.043063] usbcore: registered new interface driver cdc_eem
[10:24:18][ 1.043106] usbcore: registered new interface driver dm9601
[10:24:18][ 1.043146] usbcore: registered new interface driver dm9620
[10:24:18][ 1.043192] usbcore: registered new interface driver smsc75xx
[10:24:18][ 1.043238] usbcore: registered new interface driver smsc95xx
[10:24:18][ 1.043277] usbcore: registered new interface driver gl620a
[10:24:18][ 1.043315] usbcore: registered new interface driver net1080
[10:24:18][ 1.043358] usbcore: registered new interface driver plusb
[10:24:18][ 1.043399] usbcore: registered new interface driver rndis_host
[10:24:18][ 1.043437] usbcore: registered new interface driver cdc_subset
[10:24:18][ 1.043474] usbcore: registered new interface driver zaurus
[10:24:18][ 1.043514] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[10:24:18][ 1.043580] usbcore: registered new interface driver int51x1
[10:24:18][ 1.043619] usbcore: registered new interface driver kalmia
[10:24:18][ 1.043657] usbcore: registered new interface driver ipheth
[10:24:18][ 1.043705] usbcore: registered new interface driver sierra_net
[10:24:18][ 1.043746] usbcore: registered new interface driver cx82310_eth
[10:24:18][ 1.043793] usbcore: registered new interface driver cdc_ncm
[10:24:18][ 1.043833] usbcore: registered new interface driver qmi_wwan
[10:24:18][ 1.043873] usbcore: registered new interface driver cdc_mbim
[10:24:18][ 1.043886] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[10:24:18][ 1.046347] EHCI: ehci_rk_probe e4240000 e4240010
[10:24:18][ 1.046365] rockchip_ehci_host ff500000.usb: EHCI Host Controller
[10:24:18][ 1.046395] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[10:24:18][ 1.046765] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
[10:24:18][ 1.060918] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00
[10:24:18][ 1.061004] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[10:24:18][ 1.061022] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[10:24:18][ 1.061037] usb usb1: Product: EHCI Host Controller
[10:24:18][ 1.061051] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[10:24:18][ 1.061064] usb usb1: SerialNumber: ff500000.usb
[10:24:18][ 1.061519] hub 1-0:1.0: USB hub found
[10:24:18][ 1.061551] hub 1-0:1.0: 1 port detected
[10:24:18][ 1.061715] EHCI: ehci_rk_probe ok
[10:24:18][ 1.061824] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[10:24:18][ 1.062092] ohci-rockchip ff520000.usb: RK OHCI Host Controller
[10:24:18][ 1.062121] ohci-rockchip ff520000.usb: new USB bus registered, assigned bus number 2
[10:24:18][ 1.062172] ohci-rockchip ff520000.usb: irq 73, io mem 0xff520000
[10:24:18][ 1.079519] hdmi->edidread:1[ 1.123942] usb usb2: New USB device found, idVendor=1d6b, idProdu1
[10:24:18][ 1.123961] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[10:24:18][ 1.123976] usb usb2: Product: RK OHCI Host Controller
[10:24:18][ 1.123989] usb usb2: Manufacturer: Linux 3.10.0 ohci_hcd
[10:24:18][ 1.124003] usb usb2: SerialNumber: ff520000.usb
[10:24:18][ 1.124394] hub 2-0:1.0: USB hub found
[10:24:18][ 1.124418] hub 2-0:1.0: 1 port detected
[10:24:18][ 1.124721] usbcore: registered new interface driver cdc_acm
[10:24:18][ 1.124735] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[10:24:18][ 1.124792] usbcore: registered new interface driver usblp
[10:24:18][ 1.124843] usbcore: registered new interface driver cdc_wdm
[10:24:18][ 1.124914] usbcore: registered new interface driver usb-storage
[10:24:18][ 1.124957] usbcore: registered new interface driver ums-alauda
[10:24:18][ 1.124998] usbcore: registered new interface driver ums-cypress
[10:24:18][ 1.125038] usbcore: registered new interface driver ums-datafab
[10:24:18][ 1.125077] usbcore: registered new interface driver ums_eneub6250
[10:24:18][ 1.125118] usbcore: registered new interface driver ums-freecom
[10:24:18][ 1.125157] usbcore: registered new interface driver ums-isd200
[10:24:18][ 1.125203] usbcore: registered new interface driver ums-jumpshot
[10:24:18][ 1.125243] usbcore: registered new interface driver ums-karma
[10:24:18][ 1.125283] usbcore: registered new interface driver ums-onetouch
[10:24:18][ 1.125325] usbcore: registered new interface driver ums-sddr09
[10:24:18][ 1.125365] usbcore: registered new interface driver ums-sddr55
[10:24:18][ 1.125407] usbcore: registered new interface driver ums-usbat
[10:24:18][ 1.125495] usbcore: registered new interface driver usbserial
[10:24:18][ 1.125538] usbcore: registered new interface driver usbserial_generic
[10:24:18][ 1.125581] usbserial: USB Serial support registered for generic
[10:24:18][ 1.125628] usbcore: registered new interface driver ch341
[10:24:18][ 1.125661] usbserial: USB Serial support registered for ch341-uart
[10:24:18][ 1.125704] usbcore: registered new interface driver cp210x
[10:24:18][ 1.125736] usbserial: USB Serial support registered for cp210x
[10:24:18][ 1.125787] usbcore: registered new interface driver option
[10:24:18][ 1.125819] usbserial: USB Serial support registered for GSM modem (1-port)
[10:24:18][ 1.125911] usbcore: registered new interface driver pl2303
[10:24:18][ 1.125943] usbserial: USB Serial support registered for pl2303
[10:24:18][ 1.125992] usbcore: registered new interface driver trancevibrator
[10:24:18][ 1.126005] usb20_otg: version 3.10a 21-DEC-2012
[10:24:18][ 1.126427] e4300040
[10:24:18][ 1.126443] Core Release: 3.10a
[10:24:18][ 1.126455] Setting default values for core params
[10:24:18][ 1.126586] Using Buffer DMA mode
[10:24:18][ 1.126598] Periodic Transfer Interrupt Enhancement - disabled
[10:24:18][ 1.126609] Multiprocessor Interrupt Enhancement - disabled
[10:24:18][ 1.126621] OTG VER PARAM: 0, OTG VER FLAG: 0
[10:24:18][ 1.126632] ^^^^^^^^^^^^^^^^^Device Mode
[10:24:18][ 1.126646] Dedicated Tx FIFOs mode
[10:24:18][ 1.126666] pcd_init otg_dev = ddf31180
[10:24:18][ 1.126830] usb20_otg ff580000.usb: DWC OTG Controller
[10:24:18][ 1.126860] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 3
[10:24:18][ 1.126893] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[10:24:18][ 1.126954] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[10:24:18][ 1.126971] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[10:24:18][ 1.126985] usb usb3: Product: DWC OTG Controller
[10:24:18][ 1.126999] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[10:24:18][ 1.127012] usb usb3: SerialNumber: ff580000.usb
[10:24:18][ 1.127446] hub 3-0:1.0: USB hub found
[10:24:18][ 1.127470] hub 3-0:1.0: 1 port detected
[10:24:18][ 1.129955] usb20_host: version 3.10a 21-DEC-2012
[10:24:18][ 1.132478] e4380040
[10:24:18][ 1.132492] Core Release: 3.10a
[10:24:18][ 1.132508] Setting default values for core params
[10:24:18][ 1.132619] Using Buffer DMA mode
[10:24:18][ 1.132632] Periodic Transfer Interrupt Enhancement - disabled
[10:24:18][ 1.132642] Multiprocessor Interrupt Enhancement - disabled
[10:24:19][ 1.132654] OTG VER PARAM: 0, OTG VER FLAG: 0
[10:24:19][ 1.132664] ^^^^^^^^^^^^^^^^^^Host Mode
[10:24:19][ 1.132692] usb20_host ff540000.usb: DWC OTG Controller
[10:24:19][ 1.132735] usb20_host ff540000.usb: new USB bus registered, assigned bus number 4
[10:24:19][ 1.132768] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[10:24:19][ 1.132861] Init: Power Port (0)
[10:24:19][ 1.132917] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[10:24:19][ 1.132935] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[10:24:19][ 1.132949] usb usb4: Product: DWC OTG Controller
[10:24:19][ 1.132962] usb usb4: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[10:24:19][ 1.132976] usb usb4: SerialNumber: ff540000.usb
[10:24:19][ 1.133405] hub 4-0:1.0: USB hub found
[10:24:19][ 1.133429] hub 4-0:1.0: 1 port detected
[10:24:19][ 1.134149] usbcore: registered new interface driver xpad
[10:24:19][ 1.134210] usbcore: registered new interface driver usb_acecad
[10:24:19][ 1.134260] usbcore: registered new interface driver aiptek
[10:24:19][ 1.134317] usbcore: registered new interface driver gtco
[10:24:19][ 1.134366] usbcore: registered new interface driver hanwang
[10:24:19][ 1.134413] usbcore: registered new interface driver kbtab
[10:24:19][ 1.134471] usbcore: registered new interface driver wacom
[10:24:19][ 1.134483] ==gsl_ts_init==
[10:24:19][ 1.134554] ret=0
[10:24:19][ 1.134825] sensor_register_slave:mma8452,id=17
[10:24:19][ 1.134839] sensor_register_slave:gs_mc3230,id=23
[10:24:19][ 1.134850] gsensor_init
[10:24:19][ 1.134860] sensor_register_slave:mpu6880_acc,id=24
[10:24:19][ 1.134873] sensor_register_slave:mpu6500_acc,id=25
[10:24:19][ 1.134884] sensor_register_slave:cm3217,id=48
[10:24:19][ 1.134895] sensor_register_slave:cm3218,id=49
[10:24:19][ 1.135110] .. rk pwm remotectl v1.1 init
[10:24:19][ 1.135369] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
[10:24:19][ 1.137845] rtc_hym8563 0-0051: clock/calendar information is no longer guaranteed
[10:24:19][ 1.140868] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[10:24:19][ 1.141477] i2c /dev entries driver
[10:24:19][ 1.142133] IR NEC protocol handler initialized
[10:24:19][ 1.142148] IR RC5(x) protocol handler initialized
[10:24:19][ 1.142159] IR RC6 protocol handler initialized
[10:24:19][ 1.142169] IR JVC protocol handler initialized
[10:24:19][ 1.142179] IR Sony protocol handler initialized
[10:24:19][ 1.142190] IR RC5 (streamzap) protocol handler initialized
[10:24:19][ 1.142201] IR SANYO protocol handler initialized
[10:24:19][ 1.142212] IR MCE Keyboard/mouse protocol handler initialized
[10:24:19][ 1.142369] usbcore: registered new interface driver uvcvideo
[10:24:19][ 1.142382] USB Video Class driver (1.1.1)
[10:24:19][ 1.142394] CamSys driver version: v0.32.0, CamSys head file version: v0.11.0
[10:24:19][ 1.143863] D1:camsys_platform_probe(1300): 1-gpios-cifpower: gpio=236
[10:24:19][ 1.143887] D1:camsys_platform_probe(1303): gpios-cifpower: gpio_request
[10:24:19][ 1.143909] D1:camsys_platform_probe(1305): 1-gpios-cifpower: gpio_request=0
[10:24:19][ 1.143931] D1:camsys_platform_probe(1314): gpios-cifpower: 236 high
[10:24:19][ 1.143971] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288
[10:24:19][ 1.144047] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 r)
[10:24:19][ 1.144200] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff96)
[10:24:19][ 1.144856] D1:camsys_platform_probe(1446): ff910000.isp memory:
[10:24:19][ 1.144875] D1:camsys_platform_probe(1456): Register memory (phy: 0xff910000 vir: 0xe4220000 )
[10:24:19][ 1.144892] D1:camsys_platform_probe(1451): I2c memory (phy: 0x1def9000 vir: 0xddef9000 size:)
[10:24:19][ 1.144907] D1:camsys_init_ext_fsh_module(20): init external flash module
[10:24:19][ 1.144920] D1:camsys_platform_probe(1471): Probe ff910000.isp device success
[10:24:19][ 1.145315] not find test_power_init dev node
[10:24:19][ 1.145370] i2c-core: driver [bq27320] using legacy suspend method
[10:24:19][ 1.145383] i2c-core: driver [bq27320] using legacy resume method
[10:24:19][ 1.145716] rockchip_temp_probe,line=364
[10:24:19]
[10:24:19][ 1.175802] hdmi output corlor mode is 3
[10:24:19][ 1.175821] hdmi connect to lcdc0
[10:24:19][ 1.175834] switch:en=1,lcdc_id=0,screen type=6,cur type=1
[10:24:19][ 1.175907] rk3288-lcdc lcdc0: lcdc0: dclk:74250000>>fps:60
[10:24:19][ 1.175963] pixel clk is 74250000 tmds clk is 74250000
[10:24:19][ 1.176019] rockchip-hdmiv2 ff980000.hdmi: [hdmi_dev_config_video] sucess output HDMI.
[10:24:19][ 1.198681] tsadc ff280000.tsadc: initialized
[10:24:19][ 1.199071] device-mapper: uevent: version 1.0.3
[10:24:19][ 1.199324] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[10:24:19][ 1.199602] Bluetooth: HCI UART driver ver 2.2
[10:24:19][ 1.199618] Bluetooth: HCI H4 protocol initialized
[10:24:19][ 1.199630] Bluetooth: HCILL protocol initialized
[10:24:19][ 1.199641] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21
[10:24:19][ 1.199653] rtk_btusb: Register usb char device interface for BT driver
[10:24:19][ 1.199837] usbcore: registered new interface driver rtk_btusb
[10:24:19][ 1.200468] DVFS WARNING: clk_enable_dvfs: clk(aclk_vio1) freq table all value are smaller thas
[10:24:19][ 1.204488] cpufreq version 1.0, suspend freq 1200 MHz
[10:24:19][ 1.204683] cpuidle: using governor ladder
[10:24:19][ 1.204697] cpuidle: using governor menu
[10:24:19][ 1.204732] Synopsys Designware Multimedia Card Interface Driver
[10:24:19][ 1.204744] MHSC version = Ver 2.00 2015-06-10
[10:24:19][ 1.205039] dw cru_regsbase addr 0x1d8.
[10:24:19][ 1.205052] dw cru_reset_offset val 3.
[10:24:19][ 1.205067] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[10:24:19][ 1.205111] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc
[10:24:19][ 1.226085] Using Buffer DMA mode
[10:24:19][ 1.226102] Periodic Transfer Interrupt Enhancement - disabled
[10:24:19][ 1.226112] Multiprocessor Interrupt Enhancement - disabled
[10:24:19][ 1.226125] OTG VER PARAM: 0, OTG VER FLAG: 0
[10:24:19][ 1.226135] ^^^^^^^^^^^^^^^^^^Host Mode
[10:24:19][ 1.226295] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
[10:24:19][ 1.226454] dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
[10:24:19][ 1.226584] 1358..dw_mci_set_ios: no card. [mmc0]
[10:24:19][ 1.238049] 1358..dw_mci_set_ios: no card. [mmc0]
[10:24:19][ 1.257740] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[10:24:19][ 1.257774] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width,o
[10:24:19][ 1.257787] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[10:24:19][ 1.258024] dw cru_regsbase addr 0x1d8.
[10:24:19][ 1.258034] dw cru_reset_offset val 0.
[10:24:19][ 1.258043] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[10:24:19][ 1.258076] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc
[10:24:19][ 1.258857] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
[10:24:19][ 1.258977] dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
[10:24:19][ 1.259402] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
[10:24:19][ 1.259465] 1358..dw_mci_set_ios: no card. [mmc1]
[10:24:19][ 1.267608] Init: Power Port (0)
[10:24:19][ 1.267618] rk_battery_charger_detect_cb , battery_charger_detect 5
[10:24:19][ 1.277402] 1358..dw_mci_set_ios: no card. [mmc1]
[10:24:19][ 1.289862] mmc0: BKOPS_EN bit is not set
[10:24:19][ 1.291730] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0]
[10:24:19][ 1.294008] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 1000000)
[10:24:19][ 1.294032] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[10:24:19][ 1.294052] [mmc0] tuning regsbase addr 0x218.
[10:24:19][ 1.294742] [mmc0] Data transmission error !!! MINTSTS: [0x00002000]
[10:24:19][ 1.294752] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[10:24:19][ 1.294772] dwmmc_rockchip ff0f0000.rksdmmc: data FIFO error (status=00002000)
[10:24:19][ 1.294797] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-5
[10:24:19][ 1.294821] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[10:24:19][ 1.294830] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[10:24:19][ 1.294859] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[10:24:19][ 1.294903] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-248 (23 len)
[10:24:19][ 1.294915] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 282-282 (1 len)
[10:24:19][ 1.294925] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-248 (23 len)
[10:24:19][ 1.294935] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 124
[10:24:19][ 1.294979] mmc0: new HS200 MMC card at address 0001
[10:24:19][ 1.295263] mmcblk0: mmc0:0001 AJTD4R 14.5 GiB
[10:24:19][ 1.295377] mmcblk0rpmb: mmc0:0001 AJTD4R partition 3 4.00 MiB
[10:24:19][ 1.295704] parameter: 0x000000000 – 0x000400000 (4 MB)
[10:24:19][ 1.295716] uboot: 0x000400000 – 0x000800000 (4 MB)
[10:24:19][ 1.295726] misc: 0x000800000 – 0x000c00000 (4 MB)
[10:24:19][ 1.295734] resource: 0x000c00000 – 0x001c00000 (16 MB)
[10:24:19][ 1.295743] kernel: 0x001c00000 – 0x002c00000 (16 MB)
[10:24:19][ 1.295751] boot: 0x002c00000 – 0x004c00000 (32 MB)
[10:24:19][ 1.295760] recovery: 0x004c00000 – 0x006c00000 (32 MB)
[10:24:19][ 1.295769] backup: 0x006c00000 – 0x00a000000 (52 MB)
[10:24:19][ 1.295777] cache: 0x00a000000 – 0x012000000 (128 MB)
[10:24:19][ 1.295785] kpanic: 0x012000000 – 0x012400000 (4 MB)
[10:24:19][ 1.295794] system: 0x012400000 – 0x072400000 (1536 MB)
[10:24:19][ 1.295802] metadata: 0x072400000 – 0x073400000 (16 MB)
[10:24:19][ 1.295811] baseparamer: 0x073400000 – 0x073800000 (4 MB)
[10:24:19][ 1.295819] userdata: 0x077800000 – 0x3a3a00000 (12994 MB)
[10:24:19][ 1.295850] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14[ 1.297144] dwmmc_rockchipo
[10:24:19][ 1.297159] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
[10:24:19]1358..dw_mci_set_ios: no card. [mmc1]
[10:24:19][ 1.297476] dw cru_regsbase addr 0x1d8.
[10:24:19][ 1.297484] dw cru_reset_offset val 1.
[10:24:19][ 1.297494] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[10:24:19][ 1.297531] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc
[10:24:19][ 1.298480] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
[10:24:19][ 1.298601] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
[10:24:19][ 1.298858] 1358..dw_mci_set_ios: no card. [mmc2]
[10:24:19][ 1.316763] 1358..dw_mci_set_ios: no card. [mmc2]
[10:24:19][ 1.336450] 1358..dw_mci_set_ios: no card. [mmc2]
[10:24:19][ 1.336482] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width,o
[10:24:19][ 1.336496] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[10:24:19][ 1.336778] leds-gpio leds.27: pins are not configured from the driver
[10:24:19][ 1.337079] hidraw: raw HID events driver (C) Jiri Kosina
[10:24:19][ 1.338477] usbcore: registered new interface driver usbhid
[10:24:19][ 1.338487] usbhid: USB HID core driver
[10:24:19][ 1.338613] ashmem: initialized
[10:24:19][ 1.338725] logger: created 256K log ‘log_main’
[10:24:19][ 1.338822] logger: created 256K log ‘log_events’
[10:24:19][ 1.338917] logger: created 256K log ‘log_radio’
[10:24:19][ 1.339006] logger: created 256K log ‘log_system’
[10:24:19][ 1.340105] input: rk29-keypad as /devices/ff100000.adc/key.29/input/input1
[10:24:19][ 1.340917] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ff890000.rockchip0
[10:24:19][ 1.340934] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
[10:24:19][ 1.340946] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctl
[10:24:19][ 1.340956] ES8323 2-0010: Error applying setting, reverse things back
[10:24:19][ 1.341008] es8323_adc = 0
[10:24:19][ 1.341022] jp es8323_line_det_gpio:79
[10:24:19][ 1.341282] es8323 probe i2c recv ok
[10:24:20][ 1.342224] rockchip-spdif ff880000.rockchip-spdif: spdif ready.
[10:24:20][ 1.342776] es8323_probe
[10:24:20][ 1.342877] es8323_probe:register ISR (irq=194)
[10:24:20][ 1.395483] hdmi remove from lcdc0
[10:24:20][ 1.395493] switch:en=0,lcdc_id=0,screen type=6,cur type=6
[10:24:20][ 1.690669] --11
[10:24:20][ 1.738452] hdmi->edidread:1[ 1.828427] line_detect_do_switch Exit line in mode
[10:24:20]
[10:24:20][ 1.834028] hdmi output corlor mode is 3
[10:24:20][ 1.834036] hdmi connect to lcdc0
[10:24:20][ 1.834042] switch:en=1,lcdc_id=0,screen type=6,cur type=6
[10:24:20][ 1.834064] rk3288-lcdc lcdc0: lcdc0: dclk:74250000>>fps:60
[10:24:20][ 1.834097] pixel clk is 74250000 tmds clk is 74250000
[10:24:20][ 1.834145] rockchip-hdmiv2 ff980000.hdmi: [hdmi_dev_config_video] sucess output HDMI.
[10:24:20][ 1.976395] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → NULL → Left Line Mux
[10:24:20][ 1.976406] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → NULL → Left Line Mux
[10:24:20][ 1.976416] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → NULL → Left Line Mux
[10:24:20][ 1.976425] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → NULL → Left Line Mux
[10:24:20][ 1.976434] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → NULL → Left Line Mux
[10:24:20][ 1.976442] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → NULL → Left Line Mux
[10:24:20][ 1.976452] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → NULL → Right Line Mux
[10:24:20][ 1.976459] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → NULL → Right Line Mux
[10:24:20][ 1.976468] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → NULL → Right Line Mux
[10:24:20][ 1.976476] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → NULL → Right Line Mux
[10:24:20][ 1.976485] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → NULL → Right Line Mux
[10:24:20][ 1.976493] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → NULL → Right Line Mux
[10:24:20][ 1.976503] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left PGA Mux
[10:24:20][ 1.976510] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left PGA Mux
[10:24:20][ 1.976518] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left PGA Mux
[10:24:20][ 1.976526] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left PGA Mux
[10:24:20][ 1.976535] ES8323 2-0010: ASoC: no dapm match for Differential Mux → LAMP → Left PGA Mux
[10:24:20][ 1.976542] ES8323 2-0010: ASoC: Failed to add route Differential Mux → LAMP → Left PGA Mux
[10:24:20][ 1.976551] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right PGA Mux
[10:24:20][ 1.976559] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right PGA Mux
[10:24:20][ 1.976568] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right PGA Mux
[10:24:20][ 1.976575] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right PGA Mux
[10:24:20][ 1.976584] ES8323 2-0010: ASoC: no dapm match for Differential Mux → RAMP → Right PGA Mux
[10:24:20][ 1.976592] ES8323 2-0010: ASoC: Failed to add route Differential Mux → RAMP → Right PGA Mux
[10:24:20][ 1.976602] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Differential Mux
[10:24:20][ 1.976609] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Differential Mux
[10:24:20][ 1.976618] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Differential Mux
[10:24:20][ 1.976625] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Differential Mux
[10:24:20][ 1.976634] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Differential Mux
[10:24:20][ 1.976641] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Differential Mux
[10:24:20][ 1.976650] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Differential Mux
[10:24:20][ 1.976658] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Differential Mux
[10:24:20][ 1.976678] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left Line Mux
[10:24:20][ 1.976686] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left Line Mux
[10:24:20][ 1.976695] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left Line Mux
[10:24:20][ 1.976702] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left Line Mux
[10:24:20][ 1.976711] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → LAMP → Left Line Mux
[10:24:20][ 1.976719] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → LAMP → Left Line Mux
[10:24:20][ 1.976728] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right Line Mux
[10:24:20][ 1.976735] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right Line Mux
[10:24:20][ 1.976744] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right Line Mux
[10:24:20][ 1.976751] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right Line Mux
[10:24:20][ 1.976760] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → RAMP → Right Line Mux
[10:24:20][ 1.976768] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → RAMP → Right Line Mux
[10:24:20][ 1.976914] ES8323 2-0010: ASoC: mux Right Line Mux has no paths
[10:24:20][ 1.976925] ES8323 2-0010: ASoC: mux Left Line Mux has no paths
[10:24:20][ 1.976934] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths
[10:24:20][ 1.976945] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths
[10:24:20][ 1.976964] ES8323 2-0010: ASoC: mux Differential Mux has no paths
[10:24:20][ 1.983267] rockchip-es8323 rockchip-es8323.26: ES8323 HiFi ↔ ff890000.rockchip-i2s mapping ok
[10:24:20][ 1.983673] input: RK_ES8323 Headphone Jack as /devices/rockchip-es8323.26/sound/card0/input2
[10:24:20][ 1.984087] u32 classifier
[10:24:20][ 1.984094] Actions configured
[10:24:20][ 1.984105] Netfilter messages via NETLINK v0.30.
[10:24:20][ 1.984160] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[10:24:20][ 1.984439] ctnetlink v0.93: registering with nfnetlink.
[10:24:20][ 1.984503] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[10:24:20][ 1.984510] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[10:24:20][ 1.984739] xt_time: kernel timezone is -0000
[10:24:20][ 1.984905] ip_tables: (C) 2000-2006 Netfilter Core Team
[10:24:20][ 1.985018] arp_tables: (C) 2002 David S. Miller
[10:24:20][ 1.985050] TCP: cubic registered
[10:24:20][ 1.985055] Initializing XFRM netlink socket
[10:24:20][ 1.985252] NET: Registered protocol family 10
[10:24:20][ 1.985712] mip6: Mobile IPv6
[10:24:20][ 1.985739] ip6_tables: (C) 2000-2006 Netfilter Core Team
[10:24:20][ 1.985840] sit: IPv6 over IPv4 tunneling driver
[10:24:20][ 1.986166] NET: Registered protocol family 17
[10:24:20][ 1.986191] NET: Registered protocol family 15
[10:24:20][ 1.986237] Bridge firewalling registered
[10:24:20][ 1.986248] Ebtables v2.0 registered
[10:24:20][ 1.986402] Bluetooth: RFCOMM TTY layer initialized
[10:24:20][ 1.986425] Bluetooth: RFCOMM socket layer initialized
[10:24:20][ 1.986432] Bluetooth: RFCOMM ver 1.11
[10:24:20][ 1.986438] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[10:24:20][ 1.986444] Bluetooth: BNEP filters: protocol multicast
[10:24:20][ 1.986453] Bluetooth: BNEP socket layer initialized
[10:24:20][ 1.986460] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[10:24:20][ 1.986470] Bluetooth: HIDP socket layer initialized
[10:24:20][ 1.986493] l2tp_core: L2TP core driver, V2.0
[10:24:20][ 1.986506] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[10:24:20][ 1.986512] [WLAN_RFKILL]: Enter rfkill_wlan_init
[10:24:20][ 1.986714] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[10:24:20][ 1.986724] [WLAN_RFKILL]: can’t find rockchip,grf property
[10:24:20][ 1.986732] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[10:24:20][ 1.986740] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[10:24:20][ 1.986748] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[10:24:20][ 1.986756] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[10:24:20][ 1.986776] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags =.
[10:24:20][ 1.986793] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags .
[10:24:20][ 1.986801] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[10:24:20][ 1.986827] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
[10:24:20][ 1.986835] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[10:24:20][ 1.986868] [BT_RFKILL]: Enter rfkill_rk_init
[10:24:20][ 1.986984] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
[10:24:20][ 1.987004] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
[10:24:20][ 1.987018] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
[10:24:20][ 1.987031] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
[10:24:20][ 1.987077] [BT_RFKILL]: Request irq for bt wakeup host
[10:24:20][ 1.987172] [BT_RFKILL]: ** disable irq
[10:24:20][ 1.987239] [BT_RFKILL]: ap6335 device registered.
[10:24:20][ 1.987942] rk3288_init_suspend
[10:24:20][ 1.987954] rk3288_suspend_init enter
[10:24:20][ 1.988152] rk3288_suspend_init: pm_ctrbits =200007
[10:24:20][ 1.988183] gpio_get_dts_info suspend:4
[10:24:20][ 1.988189] gpio_get_dts_info resume:4
[10:24:20][ 1.988195] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[10:24:20][ 1.988220] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[10:24:20][ 1.988347] clks_gating_suspend_init:clkgt info ok
[10:24:20][ 1.988429] Registering SWP/SWPB emulation handler
[10:24:20][ 1.988439] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 0x02000000@0x7dc00000
[10:24:20][ 1.991027] ddrfreq: verion 1.2 20140526
[10:24:20][ 1.991041] ddrfreq: normal 528MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspez
[10:24:20][ 1.991048] ddrfreq: auto-freq=0
[10:24:20][ 1.991053] ddrfreq: auto-freq-table[0] 240MHz
[10:24:20][ 1.991059] ddrfreq: auto-freq-table[1] 324MHz
[10:24:20][ 1.991064] ddrfreq: auto-freq-table[2] 456MHz
[10:24:20][ 1.991070] ddrfreq: auto-freq-table[3] 528MHz
[10:24:20][ 2.004369] regulator-dummy: disabling
[10:24:20][ 2.004632] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[10:24:20][ 2.172109] wk2xxx_serial_init()
[10:24:20][ 2.172116] wk2xxx_request_port
[10:24:20][ 2.172123] ttysWK0 at I/O 0x1 (irq = 197) is a wk2xxx
[10:24:20][ 2.172225] uart_add_one_port success for line i:= 0 with right 0
[10:24:20][ 2.172231] wk2xxx_request_port
[10:24:20][ 2.172238] ttysWK1 at I/O 0x2 (irq = 197) is a wk2xxx
[10:24:20][ 2.172327] uart_add_one_port success for line i:= 1 with right 0
[10:24:20][ 2.172334] wk2xxx_request_port
[10:24:20][ 2.172340] ttysWK2 at I/O 0x3 (irq = 197) is a wk2xxx
[10:24:20][ 2.172418] uart_add_one_port success for line i:= 2 with right 0
[10:24:20][ 2.172425] wk2xxx_request_port
[10:24:20][ 2.172431] ttysWK3 at I/O 0x4 (irq = 197) is a wk2xxx
[10:24:20][ 2.172507] uart_add_one_port success for line i:= 3 with right 0
[10:24:20][ 2.172513] uart_add_one_port = 0x0
[10:24:20][ 2.172533] register spi return v = :0
[10:24:20][ 2.172540] =======================================================
[10:24:20][ 2.172545] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[10:24:20][ 2.172550] =======================================================
[10:24:20][ 2.172556] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init.
[10:24:20][ 2.172607] dhd_module_init: in
[10:24:20][ 2.172614] ======== dhd_wlan_init_plat_data ========
[10:24:20][ 2.172620] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[10:24:20][ 2.172625] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[10:24:20][ 2.172631] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[10:24:20][ 2.172647] dhd_wlan_init_gpio: host_oob_irq: 198
[10:24:20][ 2.172652] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[10:24:20][ 2.172655] pcd_pullup, is_on 0
[10:24:20][ 2.172664] dhd_wifi_platform_load: Enter
[10:24:20][ 2.172671] WARN::dwc_otg_handle_mode_mismatch_intr:69: Mode Mismatch Interrupt: currently in Hose
[10:24:20][ 2.172675] Power-up adapter ‘DHD generic adapter’
[10:24:20][ 2.172694] wifi_platform_set_power = 1
[10:24:20][ 2.172700] ======== PULL WL_REG_ON(-1) HIGH! ========
[10:24:20][ 2.172706] [WLAN_RFKILL]: rockchip_wifi_power: 1
[10:24:20][ 2.172712] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
[10:24:20][ 2.172718] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabl.
[10:24:20][ 2.172720] file system registered
[10:24:21][ 2.173244] android_usb gadget: Mass Storage Function, version: 2009/09/11
[10:24:21][ 2.173252] android_usb gadget: Number of LUNs=2
[10:24:21][ 2.173259] lun0: LUN: removable file: (no medium)
[10:24:21][ 2.173265] lun1: LUN: removable file: (no medium)
[10:24:21][ 2.173406] android_usb gadget: android_usb ready
[10:24:21][ 2.173501] i2c i2c-4: sensor_probe: gs_mma8452,debd1600
[10:24:21][ 2.173531] sensor_chip_init:gs_mma8452:devid=0x0,ops=0xc0d2dcac
[10:24:21][ 2.175264] input: gsensor as /devices/ff160000.i2c/i2c-4/4-001d/input/input3
[10:24:21][ 2.175500] sensor_misc_device_register:miscdevice: mma8452_daemon
[10:24:21][ 2.175509] sensor_probe:initialized ok,sensor name:mma8452,type:2,id=17
[10:24:21][ 2.175539] sensor_init: Probe name sensors
[10:24:21][ 2.175552] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[10:24:21][ 2.176073] rtc_hym8563 0-0051: setting system clock to 2011-01-01 12:00:01 UTC (1293883201)
[10:24:21][ 2.182156] rockchip-spdif-card rockchip-spdif-card.25: rk-hdmi-spdif-hifi ↔ ff880000.rockchipk
[10:24:21]u 2.182981]
补充下平台信息: AIO-3288J开发板,2G-16G的规格
你解决了吗?可以加个好友吗?
