急!!!android不能启动
按照手册上的说明,编译了kernel和android,但是android不能正常启动。打印信息如下:
DDR Version 1.00 20141007
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-06-gb1ceed8-dirty (Mar 26 2015 - 10:37:10)
CPU: rk3288
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks:1
128 MiB
storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_MODEL:rk3288!
Unknow param: MACHINE_ID:007!
Unknow param: MANUFACTURER:RK3288!
power key: bank-0 pin-5
pmic:act8846
#Boot ver: 2015-03-26#2.19
sn:10061200020000EA
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
Hit any key to stop autoboot: 1  0
failed to load fdt from boot!
Secure Boot state: 0
kernel @ 0x02000000 (0x005fc430)
ramdisk @ 0x05bf0000 (0x00121027)
bootrk: do_bootm_linux…
Loading Device Tree to 05710000, end 0572b1a4 … OK
[ 0.000000] Linux version 3.10.0 (lxl@lxl-virtual-machine) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #2 SMP PREEMPT Mon May 18 16:36:21 CST 2015
[ 0.000000] cma: CMA: reserved 16 MiB at 2e800000
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1ebc000 s14016 r8192 d14656 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 522768
[ 0.000000] Kernel command line: console=ttyS2 earlyprintk androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00200000@0x0039A000(userdata),0x00020000@0x0059A000(radical_update),-@0x005BA000(user) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2015-03-26_10:37:10 androidboot.serialno=10061200020000EA
[ 0.000000] Memory: 2047056k/2047056k available, 50096k reserved, 1318912K highmem
[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0a7ced4 (10708 kB)
[ 0.000000] .init : 0xc0a7d000 - 0xc0ccc6c0 (2366 kB)
[ 0.000000] .data : 0xc0cce000 - 0xc0d6afc8 ( 628 kB)
[ 0.000000] .bss : 0xc0d6afc8 - 0xc0e84e84 (1128 kB)
[ 0.000000] rk_clk_tree_init start! cru base = 0xfed00000
[ 0.000000] rkclk_init_clks: cnt_rate = 32
[ 0.000000] Architected local timer running at 24.00MHz (phys).
[ 0.000000] process version: 0
[ 0.000000] channel:0, lkg:0
[ 0.000000] target-temp:95
[ 0.000000] channel:2, lkg:0
[ 0.000000] channel:1, lkg:0
[ 0.524944] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.524997] pid_max: default: 32768 minimum: 301
[ 0.525336] Security Framework initialized
[ 0.525378] SELinux: Initializing.
[ 0.525610] Mount-cache hash table entries: 512
[ 0.527656] Initializing cgroup subsys debug
[ 0.527700] Initializing cgroup subsys freezer
[ 0.527791] CPU: Testing write buffer coherency: ok
[ 0.528540] /cpus/cpu@0 missing clock-frequency property
[ 0.528583] /cpus/cpu@1 missing clock-frequency property
[ 0.528616] /cpus/cpu@2 missing clock-frequency property
[ 0.528648] /cpus/cpu@3 missing clock-frequency property
[ 0.528773] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.528886] Setting up static identity map for 0xc078fcd8 - 0xc078fd30
[ 0.532616] last_log: 0x2e100000 map to 0xf0004000 and copy to 0xf0086000, size 0x80000 early 0x14de (version 3.0)
[ 0.612824] CPU1: Booted secondary processor
[ 0.612913] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.632539] CPU2: Booted secondary processor
[ 0.632622] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.652327] CPU3: Booted secondary processor
[ 0.652409] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.652785] Brought up 4 CPUs
[ 0.652884] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.652914] CPU: All CPU(s) started in SVC mode.
[ 0.655150] devtmpfs: initialized
[ 0.673328] pinctrl core: initialized pinctrl subsystem
[ 0.674059] regulator-dummy: no parameters
[ 0.675694] NET: Registered protocol family 16
[ 0.681138] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.682129] ion_snapshot: 0x2e230000 map to 0xf0107000 and copy to 0xc0e604d4 (version 0.1)
[ 0.682638] Registered FIQ tty driver
[ 0.683559] fiq-debugger is disabled in device tree
[ 0.685581] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[ 0.685655] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[ 0.685715] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 0.685774] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[ 0.686019] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 0.686234] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 0.686442] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 0.686651] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 0.686857] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 0.687066] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[ 0.687280] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 0.687492] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[ 0.687721] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 0.687940] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 0.687987] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 0.688029] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 0.688069] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 0.689784] rockchip_interrupts_register:bank_num=7
[ 0.696552] of_get_gpio_init_config:gpio[0] = 256, value = 0
[ 0.696625] of_get_gpio_init_config:gpio[1] = 233, value = 0
[ 0.696695] of_get_gpio_init_config:gpio[2] = 136, value = 0
[ 0.696858] rockchip_pinctrl_probe:init ok
[ 0.717047] rk_iommu ff900800.iep_mmu: (iep) Enter
[ 0.717404] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.717448] rk_iommu ff900800.iep_mmu: (iep) Initialized
[ 0.717987] rk_iommu ff950800.vip_mmu: (vip) Enter
[ 0.718298] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.718340] rk_iommu ff950800.vip_mmu: (vip) Initialized
[ 0.718862] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[ 0.719178] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.719220] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[ 0.719774] rk_iommu ff940300.vopl_mmu: (vopl) Enter
[ 0.720091] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.720132] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[ 0.720688] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[ 0.721063] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.721105] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[ 0.721711] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[ 0.722026] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.722069] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[ 0.722638] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[ 0.723004] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.723048] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
[ 0.728632] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.728674] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.729267] DDR DEBUG: version 1.00 20140603
[ 0.729340] DDR DEBUG: Channel a:
[ 0.729370] DDR DEBUG: DDR3 Device
[ 0.729413] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.729443] DDR DEBUG: Channel b:
[ 0.729468] DDR DEBUG: DDR3 Device
[ 0.729508] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.729539] DDR DEBUG: addr=0xd70000
[ 0.729572] DDR DEBUG: stride=9, size=256, halfcap=40000000
[ 0.729603] DDR DEBUG: socAddr[0]=0xd70000, socAddr[1]=0xd70100
[ 0.729635] DDR DEBUG: chAddr[0]=0xd70000, chAddr[1]=0xd70000
[ 0.729670] DDR DEBUG: dtar[0]=0x1ae000, dtar[1]=0x1ae000
[ 0.729821] DDR DEBUG: init success!!! freq=200MHz
[ 0.729847] DDR DEBUG: Channel a:
[ 0.729890] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.729934] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.729977] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.730020] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.730058] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.730090] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.730120] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.730145] DDR DEBUG: Channel b:
[ 0.730186] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.730229] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.730272] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.730315] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.730352] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.730383] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.730412] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.806263] bio: create slab at 0
[ 0.807975] Enter firefly_noatx8_init
[ 0.808450] firefly_noatx8_probe 51
[ 0.809199] SCSI subsystem initialized
[ 0.809681] usbcore: registered new interface driver usbfs
[ 0.809821] usbcore: registered new interface driver hub
[ 0.810104] usbcore: registered new device driver usb
[ 0.813151] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 0.817593] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
[ 0.819026] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
[ 0.820524] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 0.821340] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 0.824074] media: Linux media interface: v0.10
[ 0.824214] Linux video capture interface: v2.00
[ 0.824360] pps_core: LinuxPPS API ver. 1 registered
[ 0.824395] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.824461] PTP clock support registered
[ 0.824888] rockchip_temp_probe,line=362
[ 0.825629] tsadc ff280000.tsadc: initialized
[ 0.826830] rockchip_ion_parse_dt: num_heaps = 1
[ 0.826880] 0: 0 3 vmalloc 0x (null)
[ 0.827675] Rockchip ion module is successfully loaded (v1.0)
[ 0.828186] Advanced Linux Sound Architecture Driver Initialized.
[ 0.829343] Bluetooth: Core ver 2.16
[ 0.829464] NET: Registered protocol family 31
[ 0.829499] Bluetooth: HCI device and connection manager initialized
[ 0.829549] Bluetooth: HCI socket layer initialized
[ 0.829592] Bluetooth: L2CAP socket layer initialized
[ 0.829689] Bluetooth: SCO socket layer initialized
[ 0.830425] cfg80211: Calling CRDA to update world regulatory domain
[ 0.832639] act8846_i2c_probe,line=898
[ 0.834029] act8846_parse_dt,line=746
[ 0.835540] act8846_i2c_probe: act8846_pmic_hold=1
[ 0.835600] act8846_i2c_probe: act8846_pmic_sleep=1
[ 0.835649] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
[ 0.835696] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
[ 0.838177] act_dcdc1: 1200 mV
[ 0.842167] vccio: 3300 mV
[ 0.844788] vdd_logic: 700 ↔ 1500 mV at 1100 mV
[ 0.848529] act_dcdc4: 2000 mV
[ 0.850406] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
[ 0.853279] act_ldo2: 1050 mV
[ 0.856146] act_ldo3: 2800 mV
[ 0.859049] act_ldo4: 3300 mV
[ 0.861954] act_ldo5: 3300 mV
[ 0.864878] act_ldo6: 1100 mV
[ 0.867766] vcc_18: 1800 mV
[ 0.870850] act_ldo8: 1850 mV
[ 0.877394] vdd_arm: 712 ↔ 1500 mV at 1000 mV
[ 0.883811] vdd_gpu: 712 ↔ 1500 mV at 1000 mV
[ 0.884748] rk808_i2c_probe,line=1368
[ 0.886440] The device is not rk808 -11
[ 0.886702] rk808: probe of 0-001b failed with error -11
[ 0.891336] Switching to clocksource arch_sys_counter
[ 0.911886] usb_battery_charger_detect_synop , battery_charger_detect 1, pass DCD, dcd_state = 1
[ 0.958111] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.958166] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.959240] rk-screen rk_screen.8: rockchip screen probe success
[ 0.959999] rk32-lvds rk32-lvds: rk32 lvds driver probe success
[ 0.960783] rk32-edp ff970000.edp: screen is not edp!
[ 0.960848] rk32-edp: probe of ff970000.edp failed with error -22
[ 0.961978] rk3288-lcdc lcdc0: can’t find power_ctr node for lcdc0
[ 0.962736] graphics fb0: rockchip framebuffer registerd:fb0
[ 0.963902] graphics fb1: rockchip framebuffer registerd:fb1
[ 0.964437] graphics fb2: rockchip framebuffer registerd:fb2
[ 0.964964] graphics fb3: rockchip framebuffer registerd:fb3
[ 0.965491] graphics fb4: rockchip framebuffer registerd:fb4
[ 0.967146] rk_iommu ff930300.vopb_mmu: (vopb) Enabled
[ 0.967568] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60
[ 0.967630] rk3288-lcdc lcdc0: wakeup from standby!
[ 1.072734] alloc_buffer:ion_phy_addr=0x10000000
[ 1.116079] fb0:phy:10000000>>vir:f0191000>>len:0x1800000
[ 1.233983] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
[ 1.235125] rockchip_set_mux:warning ignore bank num 15
[ 1.235530] rockchip_set_mux:warning ignore bank num 15
[ 1.236065] rockchip_set_mux:warning ignore bank num 15
[ 1.236470] rockchip_set_mux:warning ignore bank num 15
[ 1.236850] rockchip_set_mux:warning ignore bank num 15
[ 1.237227] rockchip_set_mux:warning ignore bank num 15
[ 1.238132] rockchip_set_mux:warning ignore bank num 15
[ 1.238622] rockchip_set_mux:warning ignore bank num 15
[ 1.239478] rockchip_set_mux:warning ignore bank num 15
[ 1.239964] rockchip_set_mux:warning ignore bank num 15
[ 1.240848] rockchip_set_mux:warning ignore bank num 15
[ 1.241340] rockchip_set_mux:warning ignore bank num 15
[ 1.242162] rockchip_set_mux:warning ignore bank num 15
[ 1.242671] rockchip_set_mux:warning ignore bank num 15
[ 1.247103] NET: Registered protocol family 2
[ 1.248581] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 1.249055] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 1.249539] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.249685] TCP: reno registered
[ 1.249731] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 1.249851] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 1.250496] NET: Registered protocol family 1
[ 1.251049] Unpacking initramfs…
[ 1.473503] Freeing initrd memory: 1156K (c5bf0000 - c5d11000)
[ 1.475509] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 1.476895] probe device ff9a0000.vpu_service
[ 1.477315] vpu_service: power on
[ 1.478459] checking hw id 4831
[ 1.479538] vpu_service set to auto frequency mode
[ 1.479701] vcodec vpu_service: vcodec ion client create success!
[ 1.480767] vpu_service: power off…
[ 1.480853] done
[ 1.480880] init success
[ 1.481033] probe device ff9c0000.hevc_service
[ 1.481619] hevc_service: power on
[ 1.482738] checking hw id 6867
[ 1.483630] vcodec hevc_service: vcodec ion client create success!
[ 1.484496] hevc_service: power off…
[ 1.484583] done
[ 1.484610] init success
[ 1.484958] rknandbase v1.0 2014-03-31
[ 1.485576] rknand_probe clk rate = 148500000
[ 1.485943] rknand_driver:ret = 0
[ 1.487051] audit: initializing netlink socket (disabled)
[ 1.487156] type=2000 audit(0.970:1): initialized
[ 1.489420] bounce pool size: 64 pages
[ 1.505224] fuse init (API version 7.22)
[ 1.506455] msgmni has been set to 1456
[ 1.512732] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.512779] io scheduler noop registered
[ 1.512812] io scheduler deadline registered
[ 1.513146] io scheduler cfq registered (default)
[ 1.515369] rga ff920000.rga: rga ion client create success!
[ 1.515758] rga: Driver loaded succesfully
[ 1.517170] IEP Power ON
[ 1.517278] iep ion client create success!
[ 1.518261] rk_iommu ff900800.iep_mmu: (iep) Enabled
[ 1.518341] IEP Power OFF
[ 1.518383] rk_iommu ff900800.iep_mmu: (iep) Disabled
[ 1.518427] rk_iommu ff900800.iep_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e244000
[ 1.518474] IEP Driver loaded succesfully
[ 1.518790] Module initialized.
[ 1.521180] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.521323] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 1.525635] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.525693] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.526416] pwm-voltage-regulator pwm_regulator.22: unable to request PWM, trying legacy API
[ 1.526465] pwm-voltage-regulator pwm_regulator.22: unable to request legacy PWM
[ 1.526494] pwm_regulator_probe:error
[ 1.526563] platform pwm_regulator.22: Driver pwm-voltage-regulator requests probe deferral
[ 1.527643] rk_serial.c v1.8 2014-03-04
[ 1.528330] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[ 1.528956] serial ff180000.serial: membase f0172000
[ 1.529391] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
[ 1.529444] 2, baud is:115200
[ 3.210179] console [ttyS2] enabled
[ 3.214230] serial ff690000.serial: membase fed60000
[ 3.228928] loop: module loaded
[ 3.233858] SCSI Media Changer driver v0.25
[ 3.239035] tun: Universal TUN/TAP device driver, 1.6
[ 3.244088] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 3.251808] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 3.258578] stmmac_probe_config_dt: Can not read property: pmu_enable_level.
[ 3.265574] stmmac_probe_config_dt: clock input or output? (input).
[ 3.271763] stmmac_probe_config_dt: TX delay(0x30).
[ 3.276617] stmmac_probe_config_dt: RX delay(0x20).
[ 3.281521] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[ 3.286883] stmmc_pltfr_init:
[ 3.290093] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[ 3.295672] stmmc_pltfr_init: ERROR: Request gmac phy reset pin failed.
[ 3.302194] stmmc_pltfr_init: init for RGMII
[ 3.306454] tx delay=0x30
[ 3.306454] rx delay=0x20
[ 3.313083] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 3.318073] Normal descriptors
[ 3.321181] Ring mode enabled
[ 3.324259] DMA HW capability register supported
[ 3.328741] RX Checksum Offload Engine supported (type 2)
[ 3.334372] TX Checksum insertion supported
[ 3.338592] Wake-Up On Lan supported
[ 3.342327] Enable RX Mitigation via HW Watchdog Timer
[ 3.348733] PPP generic driver version 2.4.2
[ 3.353498] PPP BSD Compression module registered
[ 3.358155] PPP Deflate Compression module registered
[ 3.363217] PPP MPPE Compression module registered
[ 3.367958] NET: Registered protocol family 24
[ 3.372446] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 3.381994] CSLIP: code copyright 1989 Regents of the University of California.
[ 3.389206] Rockchip WiFi SYS interface (V1.00) …
[ 3.394366] usbcore: registered new interface driver catc
[ 3.399806] usbcore: registered new interface driver kaweth
[ 3.405360] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 3.412789] usbcore: registered new interface driver pegasus
[ 3.418467] usbcore: registered new interface driver rtl8150
[ 3.424190] usbcore: registered new interface driver r8152
[ 3.429609] hso: drivers/net/usb/hso.c: Option Wireless
[ 3.434989] usbcore: registered new interface driver hso
[ 3.440397] usbcore: registered new interface driver asix
[ 3.445832] usbcore: registered new interface driver ax88179_178a
[ 3.451989] usbcore: registered new interface driver cdc_ether
[ 3.457836] usbcore: registered new interface driver cdc_eem
[ 3.463558] usbcore: registered new interface driver dm9601
[ 3.469149] usbcore: registered new interface driver dm9620
[ 3.474815] usbcore: registered new interface driver smsc75xx
[ 3.480672] usbcore: registered new interface driver smsc95xx
[ 3.486442] usbcore: registered new interface driver gl620a
[ 3.492178] usbcore: registered new interface driver net1080
[ 3.497862] usbcore: registered new interface driver plusb
[ 3.503427] usbcore: registered new interface driver rndis_host
[ 3.509408] usbcore: registered new interface driver cdc_subset
[ 3.515340] usbcore: registered new interface driver zaurus
[ 3.520987] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 3.528434] usbcore: registered new interface driver int51x1
[ 3.534168] usbcore: registered new interface driver kalmia
[ 3.539808] usbcore: registered new interface driver ipheth
[ 3.545418] usbcore: registered new interface driver sierra_net
[ 3.551402] usbcore: registered new interface driver cx82310_eth
[ 3.557457] usbcore: registered new interface driver cdc_ncm
[ 3.563200] usbcore: registered new interface driver qmi_wwan
[ 3.569016] usbcore: registered new interface driver cdc_mbim
[ 3.574695] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 3.584361] ehci_rk_probe f1a00000 f1a00010
[ 3.588572] rockchip_ehci_host ff500000.usb: Rockchip On-Chip EHCI Host Controller
[ 3.596095] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[ 3.605319] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
[ 3.627077] rockchip_ehci_host ff500000.usb: USB 0.0 started, EHCI 1.00
[ 3.633795] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.640557] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.647750] usb usb1: Product: Rockchip On-Chip EHCI Host Controller
[ 3.654032] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 3.659405] usb usb1: SerialNumber: ff500000.usb
[ 3.665300] hub 1-0:1.0: USB hub found
[ 3.669128] hub 1-0:1.0: 1 port detected
[ 3.695941] ehci_rk_probe ok
[ 3.699205] usbcore: registered new interface driver cdc_acm
[ 3.704800] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 3.712891] usbcore: registered new interface driver usblp
[ 3.718459] usbcore: registered new interface driver cdc_wdm
[ 3.724213] usbcore: registered new interface driver usb-storage
[ 3.730282] usbcore: registered new interface driver ums-alauda
[ 3.736291] usbcore: registered new interface driver ums-cypress
[ 3.742315] usbcore: registered new interface driver ums-datafab
[ 3.748383] usbcore: registered new interface driver ums_eneub6250
[ 3.754571] usbcore: registered new interface driver ums-freecom
[ 3.760636] usbcore: registered new interface driver ums-isd200
[ 3.766750] usbcore: registered new interface driver ums-jumpshot
[ 3.772860] usbcore: registered new interface driver ums-karma
[ 3.778765] usbcore: registered new interface driver ums-onetouch
[ 3.784923] usbcore: registered new interface driver ums-sddr09
[ 3.790860] usbcore: registered new interface driver ums-sddr55
[ 3.796855] usbcore: registered new interface driver ums-usbat
[ 3.802867] usbcore: registered new interface driver usbserial
[ 3.808778] usbcore: registered new interface driver usbserial_generic
[ 3.815338] usbserial: USB Serial support registered for generic
[ 3.821367] usbcore: registered new interface driver option
[ 3.826986] usbserial: USB Serial support registered for GSM modem (1-port)
[ 3.834096] usbcore: registered new interface driver trancevibrator
[ 3.840286] usb20_otg: version 3.10a 21-DEC-2012
[ 3.845899] f1a80040
[ 3.848086] Core Release: 3.10a
[ 3.851201] Setting default values for core params
[ 3.856366] Using Buffer DMA mode
[ 3.859655] Periodic Transfer Interrupt Enhancement - disabled
[ 3.865458] Multiprocessor Interrupt Enhancement - disabled
[ 3.870965] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.875303] ^^^^^^^^^^^^^^^^^Device Mode
[ 3.879195] Dedicated Tx FIFOs mode
[ 3.882671] pcd_init otg_dev = ed910000
[ 3.886946] usb20_otg ff580000.usb: DWC OTG Controller
[ 3.892079] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
[ 3.899571] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 3.905453] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.912169] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.919345] usb usb2: Product: DWC OTG Controller
[ 3.924038] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 3.929635] usb usb2: SerialNumber: ff580000.usb
[ 3.935536] hub 2-0:1.0: USB hub found
[ 3.939290] hub 2-0:1.0: 1 port detected
[ 3.944111] usb20_host: version 3.10a 21-DEC-2012
[ 3.952122] f1b00040
[ 3.954308] Core Release: 3.10a
[ 3.957424] Setting default values for core params
[ 3.962576] Using Buffer DMA mode
[ 3.965869] Periodic Transfer Interrupt Enhancement - disabled
[ 3.971670] Multiprocessor Interrupt Enhancement - disabled
[ 3.977175] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.981514] ^^^^^^^^^^^^^^^^^^Host Mode
[ 3.985354] usb20_host ff540000.usb: DWC OTG Controller
[ 3.990566] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
[ 3.998122] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[ 4.004046] Init: Power Port (0)
[ 4.007415] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.014182] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.021351] usb usb3: Product: DWC OTG Controller
[ 4.026010] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 4.031636] usb usb3: SerialNumber: ff540000.usb
[ 4.037476] hub 3-0:1.0: USB hub found
[ 4.041419] hub 3-0:1.0: 1 port detected
[ 4.046906] .. rk pwm remotectl v1.0 init
[ 4.051147] remotectl probe j=0x0
[ 4.054947] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
[ 4.061885] pwm enable val=0x646205
[ 4.066236] usbcore: registered new interface driver xpad
[ 4.071762] usbcore: registered new interface driver usb_acecad
[ 4.077720] usbcore: registered new interface driver aiptek
[ 4.083383] usbcore: registered new interface driver gtco
[ 4.088829] usbcore: registered new interface driver hanwang
[ 4.094574] usbcore: registered new interface driver kbtab
[ 4.100168] usbcore: registered new interface driver wacom
[ 4.106621] sensor_register_slave:mma8452,id=17
[ 4.111161] sensor_register_slave:cm3217,id=44
[ 4.115560] sensor_register_slave:cm3218,id=45
[ 4.119984] tchip_rm_init is here!
[ 4.124838] input: tchip_remote_key as /devices/virtual/input/input1
[ 4.131504] tchiprm_register_device is here!
[ 4.136133] input: tchip_remote_touch as /devices/virtual/input/input2
[ 4.143105] tchip_remote_abs_register_device is here!
[ 4.148483] input: tchip_remote_gsensor as /devices/virtual/input/input3
[ 4.155489] tchip_remote_gsensor_register_device is here!
[ 4.167996] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 4.174592] i2c /dev entries driver
[ 4.180435] IR NEC protocol handler initialized
[ 4.184922] IR RC5(x) protocol handler initialized
[ 4.189703] IR RC6 protocol handler initialized
[ 4.194182] IR JVC protocol handler initialized
[ 4.198694] IR Sony protocol handler initialized
[ 4.203258] IR RC5 (streamzap) protocol handler initialized
[ 4.208788] IR SANYO protocol handler initialized
[ 4.213438] IR MCE Keyboard/mouse protocol handler initialized
[ 4.219447] usbcore: registered new interface driver uvcvideo
[ 4.225122] USB Video Class driver (1.1.1)
[ 4.229219] CamSys driver version: v0.19.0, CamSys head file version: v0.8.0
[ 4.239547] D1:camsys_platform_probe(1061): 1-gpios-cifpower: gpio=236
[ 4.246031] D1:camsys_platform_probe(1064): gpios-cifpower: gpio_request
[ 4.252724] D1:camsys_platform_probe(1066): 1-gpios-cifpower: gpio_request=0
[ 4.259739] D1:camsys_platform_probe(1075): gpios-cifpower: 236 high
[ 4.266189] D1:camsys_mipiphy_probe_cb(163): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 4.277376] D1:camsys_mipiphy_probe_cb(160): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xf19b0000 size: 0x4000)
[ 4.291665] D1:camsys_platform_probe(1208): ff910000.isp memory:
[ 4.297668] D1:camsys_platform_probe(1218): Register memory (phy: 0xff910000 vir: 0xf19e0000 size: 0x10000)
[ 4.307655] D1:camsys_platform_probe(1213): I2c memory (phy: 0x2d9f6000 vir: 0xed9f6000 size: 0x1000)
[ 4.317119] D1:camsys_platform_probe(1233): Probe ff910000.isp device success
[ 4.327276] device-mapper: uevent: version 1.0.3
[ 4.332570] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 4.341814] Bluetooth: HCI UART driver ver 2.2
[ 4.346273] Bluetooth: HCI H4 protocol initialized
[ 4.351011] Bluetooth: HCILL protocol initialized
[ 4.361714] cpufreq version 1.0, suspend freq 1200 MHz
[ 4.367414] cpuidle: using governor ladder
[ 4.371477] cpuidle: using governor menu
[ 4.375492] Synopsys Designware Multimedia Card Interface Driver
[ 4.382118] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[ 4.388996] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
[ 4.396498] 3291..dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
[ 4.402981] mmc0 : Rockchip specific MHSC: Ver 1.13 2014-09-05
[ 4.408910] 1381..dw_mci_set_ios: no card. [mmc0]
[ 4.424063] 1381..dw_mci_set_ios: no card. [mmc0]
[ 4.443766] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 4.443792] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
[ 4.443805] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[ 4.444144] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[ 4.474304] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
[ 4.481305] 3285..dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
[ 4.487656] mmc1 : Rockchip specific MHSC: Ver 1.13 2014-09-05
[ 4.493875] 1381..dw_mci_set_ios: no card. [mmc1]
[ 4.505441] mmc0: BKOPS_EN bit is not set
[ 4.511298] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0]
[ 4.512595] 1381..dw_mci_set_ios: no card. [mmc1]
[ 4.524150] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 4.532426] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
[ 4.532435] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
[ 4.532781] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[ 4.555683] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 4.564163] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
[ 4.571132] 3291..dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
[ 4.577484] mmc2 : Rockchip specific MHSC: Ver 1.13 2014-09-05
[ 4.579206] rk_sdmmc: BOOT
[ 4.579206] execute tuning: candidates_degree = SDMMC_SHIFT_DEGREE_0 SDMMC_SHIFT_DEGREE_90 SDMMC_SHIFT_DEGREE_INVALID SDMMC_SHIFT_DEGREE_INVALID[mmc0]
[ 4.579303] mmc0: new HS200 MMC card at address 0001
[ 4.579597] mmcblk0: mmc0:0001 AWMB3R 14.5 GiB
[ 4.579946] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 4.579954] misc: 0x000800000 – 0x000c00000 (4 MB)
[ 4.579961] resource: 0x000c00000 – 0x001c00000 (16 MB)
[ 4.579967] kernel: 0x001c00000 – 0x002c00000 (16 MB)
[ 4.579973] boot: 0x002c00000 – 0x004c00000 (32 MB)
[ 4.579979] recovery: 0x004c00000 – 0x006c00000 (32 MB)
[ 4.579985] backup: 0x006c00000 – 0x00a000000 (52 MB)
[ 4.579991] cache: 0x00a000000 – 0x012000000 (128 MB)
[ 4.579996] kpanic: 0x012000000 – 0x012400000 (4 MB)
[ 4.580002] system: 0x012400000 – 0x072400000 (1536 MB)
[ 4.580008] metadata: 0x072400000 – 0x073400000 (16 MB)
[ 4.580014] userdata: 0x073400000 – 0x0b3400000 (1024 MB)
[ 4.580020] radical_update: 0x0b3400000 – 0x0b7400000 (64 MB)
[ 4.580025] user: 0x0b7400000 – 0x3a3a00000 (11974 MB)
[ 4.581609] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p141381..dw_mci_set_ios: no card. [mmc1]
[ 4.694647] 1381..dw_mci_set_ios: no card. [mmc2]
[ 4.709383] 1381..dw_mci_set_ios: no card. [mmc2]
[ 4.729076] 1381..dw_mci_set_ios: no card. [mmc2]
[ 4.729238] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
[ 4.729244] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[ 4.729467] leds-gpio leds.30: pins are not configured from the driver
[ 4.729650] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.730762] usbcore: registered new interface driver usbhid
[ 4.730766] usbhid: USB HID core driver
[ 4.731072] ashmem: initialized
[ 4.731162] logger: created 256K log ‘log_main’
[ 4.731244] logger: created 256K log ‘log_events’
[ 4.731318] logger: created 256K log ‘log_radio’
[ 4.731394] logger: created 256K log ‘log_system’
[ 4.732326] input: rk29-keypad as /devices/ff100000.adc/key.33/input/input4
[ 4.732844] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ; cannot claim for 2-0010
[ 4.732853] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
[ 4.732859] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl
[ 4.732864] ES8323 2-0010: Error applying setting, reverse things back
[ 4.830377] es8323 probe i2c recv ok
[ 4.834094] i2c-core: driver [ES8323] using legacy suspend method
[ 4.840113] i2c-core: driver [ES8323] using legacy resume method
[ 4.846312] rockchip-hdmi-spdif rockchip-hdmi-spdif.26: ASoC: CPU DAI (null) not registered
[ 4.854550] rockchip_hdmi_spdif_audio_probe() register card failed:-517
[ 4.861075] platform rockchip-hdmi-spdif.26: Driver rockchip-hdmi-spdif requests probe deferral
[ 4.869828] es8323_probe
[ 4.872397] es8323_probe:register ISR (irq=194)
[ 5.457420] iep dpi mode inactivity
[ 5.517639] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → NULL → Left Line Mux
[ 5.525430] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → NULL → Left Line Mux
[ 5.533324] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → NULL → Left Line Mux
[ 5.541250] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → NULL → Left Line Mux
[ 5.549133] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → NULL → Left Line Mux
[ 5.557499] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → NULL → Left Line Mux
[ 5.565803] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → NULL → Right Line Mux
[ 5.573712] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → NULL → Right Line Mux
[ 5.581736] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → NULL → Right Line Mux
[ 5.589708] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → NULL → Right Line Mux
[ 5.597706] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → NULL → Right Line Mux
[ 5.606181] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → NULL → Right Line Mux
[ 5.614590] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left PGA Mux
[ 5.622465] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left PGA Mux
[ 5.630138] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left PGA Mux
[ 5.637777] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left PGA Mux
[ 5.645411] ES8323 2-0010: ASoC: no dapm match for Differential Mux → LAMP → Left PGA Mux
[ 5.653794] ES8323 2-0010: ASoC: Failed to add route Differential Mux → LAMP → Left PGA Mux
[ 5.662211] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right PGA Mux
[ 5.669933] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right PGA Mux
[ 5.677675] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right PGA Mux
[ 5.685395] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right PGA Mux
[ 5.693114] ES8323 2-0010: ASoC: no dapm match for Differential Mux → RAMP → Right PGA Mux
[ 5.701616] ES8323 2-0010: ASoC: Failed to add route Differential Mux → RAMP → Right PGA Mux
[ 5.710117] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Differential Mux
[ 5.718111] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Differential Mux
[ 5.726100] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Differential Mux
[ 5.734089] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Differential Mux
[ 5.742063] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Differential Mux
[ 5.750029] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Differential Mux
[ 5.758006] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Differential Mux
[ 5.765973] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Differential Mux
[ 5.773984] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left Line Mux
[ 5.781687] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left Line Mux
[ 5.789405] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left Line Mux
[ 5.797128] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left Line Mux
[ 5.804848] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → LAMP → Left Line Mux
[ 5.812997] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → LAMP → Left Line Mux
[ 5.821135] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right Line Mux
[ 5.828932] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right Line Mux
[ 5.836745] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right Line Mux
[ 5.844538] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right Line Mux
[ 5.852343] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → RAMP → Right Line Mux
[ 5.860638] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → RAMP → Right Line Mux
[ 5.869143] ES8323 2-0010: ASoC: mux Right Line Mux has no paths
[ 5.875085] ES8323 2-0010: ASoC: mux Left Line Mux has no paths
[ 5.880940] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths
[ 5.886774] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths
[ 5.892550] ES8323 2-0010: ASoC: mux Differential Mux has no paths
[ 5.901604] Enter::rk29_es8323_init----135
[ 5.909882] rockchip-es8323 rockchip-es8323.28: ES8323 HiFi ↔ rockchip-i2s.0 mapping ok
[ 5.918703] u32 classifier
[ 5.921382] Actions configured
[ 5.924733] Netfilter messages via NETLINK v0.30.
[ 5.929416] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 5.935826] ctnetlink v0.93: registering with nfnetlink.
[ 5.941140] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 5.947985] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 5.954067] xt_time: kernel timezone is -0000
[ 5.958616] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 5.964002] arp_tables: (C) 2002 David S. Miller
[ 5.968594] TCP: cubic registered
[ 5.971882] Initializing XFRM netlink socket
[ 5.976333] NET: Registered protocol family 10
[ 5.981334] mip6: Mobile IPv6
[ 5.984276] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 5.989740] sit: IPv6 over IPv4 tunneling driver
[ 5.994658] NET: Registered protocol family 17
[ 5.999068] NET: Registered protocol family 15
[ 6.003487] Bridge firewalling registered
[ 6.007434] Ebtables v2.0 registered
[ 6.011133] Bluetooth: RFCOMM TTY layer initialized
[ 6.015948] Bluetooth: RFCOMM socket layer initialized
[ 6.021028] dwc_otg_hcd_enable, enable host controller
[ 6.027961] Bluetooth: RFCOMM ver 1.11
[ 6.031650] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 6.036867] Bluetooth: BNEP filters: protocol multicast
[ 6.042017] Bluetooth: BNEP socket layer initialized
[ 6.046895] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 6.052724] Bluetooth: HIDP socket layer initialized
[ 6.057623] l2tp_core: L2TP core driver, V2.0
[ 6.061909] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 6.066615] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 6.071438] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 6.076147] wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[ 6.081716] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 6.088736] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 6.097118] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 6.104399] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
[ 6.113416] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
[ 6.122477] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 6.127640] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
[ 6.129434] Using Buffer DMA mode
[ 6.129438] Periodic Transfer Interrupt Enhancement - disabled
[ 6.129441] Multiprocessor Interrupt Enhancement - disabled
[ 6.129444] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 6.129448] ^^^^^^^^^^^^^^^^^^Host Mode
[ 6.158478] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 6.163156] [BT_RFKILL]: Enter rfkill_rk_init
[ 6.167560] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
[ 6.175606] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155.
[ 6.175615] Init: Power Port (0)
[ 6.186731] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
[ 6.194684] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
[ 6.202555] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
[ 6.210819] [BT_RFKILL]: Request irq for bt wakeup host
[ 6.216043] [BT_RFKILL]: ** disable irq
[ 6.219876] [BT_RFKILL]: ap6335 device registered.
[ 6.382478] Indeed it is in host mode hprt0 = 00021501
[ 6.540031] rk3288-hdmi ff980000.hdmi: warning: no CEA video mode parsed from EDID !!!
[ 6.547994] ******** Show Sink Info ********
[ 6.552341] Max tmds clk is 0
[ 6.555308] Support video mode:
[ 6.558439] 1280x720p@60Hz
[ 6.559540] usb 3-1: new high-speed USB device number 2 using usb20_host
[ 6.559990] Indeed it is in host mode hprt0 = 00001101
[ 6.573020] 1280x720p@50Hz
[ 6.575806] 720x576p@50Hz
[ 6.578470] 720x480p@60Hz
[ 6.581147] Support video color mode:
[ 6.584749] RGB
[ 6.586560] Support video color depth:
[ 6.590268] 24bit
[ 6.592251] Support audio type:
[ 6.595341] ******** Show Sink Info ********
[ 6.599571]
[ 6.599571] rk_fb_switch_screen lcdc_id 0 type 6 enable 1
[ 6.606341] fb0 win id 1 state 1
[ 6.609665] rk3288-lcdc lcdc0: lcdc0: dclk:74250000>>fps:60
[ 6.615250] fb1 win id 0 state 0
[ 6.618437] fb2 win id 2 state 0
[ 6.621612] fb3 win id 3 state 0
[ 6.624784] fb4 win id 4 state 0
[ 6.627958]
[ 6.627958] rk_fb_switch_screen lcdc_id 0 type 6 enable 1 done
[ 6.627958]
[ 6.636615] pixel clk is 74250000 tmds clk is 74250000
[ 6.641687] rk3288-hdmi ff980000.hdmi: [hdmi_dev_config_video] sucess output DVI.
[ 6.658464] rk3288-hdmi ff980000.hdmi: rk3288 hdmi probe sucess.
[ 6.664883] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 6.672449] rk3288_init_suspend
[ 6.675539] rk3288_suspend_init enter
[ 6.679318] rk3288_suspend_init: pm_ctrbits =40017
[ 6.684059] gpio_get_dts_info suspend:8
[ 6.687840] gpio_get_dts_info resume:8
[ 6.691525] rockchip,pmic-suspend_gpios:1007c30 1007c40 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 6.700095] rockchip,pmic-resume_gpios:2007c32 2007c42 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 6.708685] clks_gating_suspend_init:clkgt info ok
[ 6.713504] Registering SWP/SWPB emulation handler
[ 6.718696] ddrfreq: verion 1.2 20140526
[ 6.722720] ddrfreq: normal 456MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 456MHz
[ 6.733410] ddrfreq: auto-freq=0
[ 6.733417] ddrfreq: auto-freq-table[0] 240MHz
[ 6.733421] ddrfreq: auto-freq-table[1] 324MHz
[ 6.733425] ddrfreq: auto-freq-table[2] 456MHz
[ 6.733429] ddrfreq: auto-freq-table[3] 528MHz
[ 6.734010] act_ldo3: operation not allowed
[ 6.758421] vga_edid_probe: turn on ldo3 done.
[ 6.762820] act_ldo4: operation not allowed
[ 6.767173] vga_edid_probe: turn on ldo done.
[ 6.771484] act_ldo2: operation not allowed
[ 6.775852] vga_edid_probe: turn on ldo2 done.
[ 6.780293] act_ldo8: operation not allowed
[ 6.784484] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101
[ 6.791091] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 6.798127] usb 3-1: Product: USB 2.0 Hub [MTT]
[ 6.798132] vga_edid_probe: turn on ldo done.
[ 6.807145] hub 3-1:1.0: USB hub found
[ 6.810896] hub 3-1:1.0: 4 ports detected
[ 6.816534] unable to read EDID block.
[ 6.854776] unable to read EDID block.
[ 6.893009] unable to read EDID block.
[ 6.896719] vga-ddc: read and parse edid failed errno:-5.
[ 6.902024] vga_edid_probe: success. 10
[ 6.906027] firefly_vga_get_enable 180, 0
[ 6.909967] firefly_vga_get_status 186
[ 6.913657] firefly_vga_set_enable 159 enable:0
[ 6.918152] regulator-dummy: disabling
[ 6.922115] rockchip-hdmi-spdif rockchip-hdmi-spdif.26: ASoC: CPU DAI (null) not registered
[ 6.930375] rockchip_hdmi_spdif_audio_probe() register card failed:-517
[ 6.936891] platform rockchip-hdmi-spdif.26: Driver rockchip-hdmi-spdif requests probe deferral
[ 6.945546] pcd_pullup, is_on 0
[ 6.948661] file system registered
[ 6.952536] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 6.959302] android_usb gadget: Number of LUNs=2
[ 6.963854] lun0: LUN: removable file: (no medium)
[ 6.968645] lun1: LUN: removable file: (no medium)
[ 6.973563] android_usb gadget: android_usb ready
[ 6.978253] sensor_init: Probe name sensors
[ 6.982371] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 6.991107] rtc_hym8563 0-0051: setting system clock to 2011-01-01 12:12:48 UTC (1293883968)
[ 7.005103] usbcore: registered new interface driver snd-usb-audio
[ 7.011222] ALSA device list:
[ 7.014301] #0: RK_ES8323
[ 7.017444] 2, baud is:115200
[ 7.019161] rockchip-hdmi-spdif rockchip-hdmi-spdif.26: rk-hdmi-spdif-hifi ↔ rockchip-spdif mapping ok
[ 7.032154] Freeing unused kernel memory: 2364K (c0a7d000 - c0ccc000)
[ 7.046060] SELinux: Permission attach_queue in class tun_socket not defined in policy.
[ 7.054093] SELinux: the above unknown classes and permissions will be denied
[ 7.090775] usb 3-1.1: new low-speed USB device number 3 using usb20_host
[ 7.191148] usb 3-1.1: New USB device found, idVendor=04b3, idProduct=310d
[ 7.197921] usb 3-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 7.208214] input: HID 04b3:310d as /devices/ff540000.usb/usb3/3-1/3-1.1/3-1.1:1.0/input/input5
[ 7.217041] hid-generic 0003:04B3:310D.0001: input,hidraw0: USB HID v1.11 Mouse [HID 04b3:310d] on usb-ff540000.usb-1.1/input0
[ 7.330551] type=1403 audit(1293883968.840:2): policy loaded auid=4294967295 ses=4294967295
[ 7.338886] SELinux: Loaded policy from /sepolicy
[ 8.090440] init: init.rk30board.bootmode.emmc.rc: 8: invalid command ‘/devices/ff0f0000.rksdmmc/mmc_host/mmc’
[ 8.100293] init: init.rk30board.bootmode.emmc.rc: 9: invalid command ‘/devices/ff0c0000.rksdmmc/mmc_host/mmc’
[ 8.110131] init: init.rk30board.bootmode.emmc.rc: 10: invalid command ‘/devices/ff580000.usb’
[ 8.119172] init: init.rk30board.bootmode.emmc.rc: 11: invalid command ‘/devices/ff580000.usb’
[ 8.127659] init: init.rk30board.bootmode.emmc.rc: 12: invalid command ‘/devices/ff500000.usb’
[ 8.136129] init: init.rk30board.bootmode.emmc.rc: 13: invalid command ‘/devices/ff500000.usb’
[ 8.144598] init: init.rk30board.bootmode.emmc.rc: 14: invalid command ‘/devices/ff540000.usb’
[ 8.153059] init: init.rk30board.bootmode.emmc.rc: 15: invalid command ‘/devices/ff540000.usb’
[ 8.161964] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[ 8.220851] init: /dev/hw_random not found
[ 8.224957] keychord: using input dev ff680000.pwm for fevent
[ 8.230603] keychord: using input dev tchip_remote_key for fevent
[ 8.236611] keychord: using input dev rk29-keypad for fevent
[ 8.242289] 2, baud is:115200
[ 8.250150] fs_mgr: parse_link_device : path = NULL
[ 8.255022] fs_mgr: parse_link_device : path = NULL
[ 8.259837] fs_mgr: parse_link_device : path = NULL
[ 8.264667] fs_mgr: parse_link_device : path = NULL
[ 8.269476] fs_mgr: parse_link_device : path = NULL
[ 8.274308] fs_mgr: parse_link_device : path = NULL
[ 8.279119] fs_mgr: parse_link_device : path = NULL
[ 8.283961] fs_mgr: parse_link_device : path = NULL
[ 8.288824] fs_mgr: ---------------resize_fs blk_dev /dev/block/platform/ff0f0000.rksdmmc/by-name/system, type ext4fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
[ 8.307244] resize2fs: resize2fs 1.41.14 (22-Dec-2010)resize2fs: The filesystem is already 393216 blocks long. Nothing to do!resize2fs:
[ 8.324797] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 8.347017] EXT4-fs (mmcblk0p8): recovery complete
[ 8.352266] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 8.363882] EXT4-fs (mmcblk0p11): recovery complete
[ 8.368680] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 8.512482] EXT4-fs (mmcblk0p12): recovery complete
[ 8.517853] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 8.533279] drmboot: module license ‘unspecified’ taints kernel.
[ 8.539210] Disabling lock debugging due to kernel taint
[ 8.545250] %s: ok, 20130810
[ 8.553704] mali pd enabled
[ 8.556460] clk enabled
[ 8.558896] MALI_DVFS_STEP=4,div_dvfs=10
[ 8.562752] mali_dvfs_infotbl[0].clock=198000,min_threshold=0,max_threshold=70
[ 8.569873] mali_dvfs_infotbl[1].clock=297000,min_threshold=70,max_threshold=80
[ 8.577086] mali_dvfs_infotbl[2].clock=417000,min_threshold=80,max_threshold=90
[ 8.584281] mali_dvfs_infotbl[3].clock=480000,min_threshold=94,max_threshold=100
[ 8.591675] turn on mali power
[ 8.594694] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
[ 8.601481] mali ffa30000.gpu: Probed as mali0
[ 8.608301] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ’ should be ‘3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 8.630464] init: /dev/hw_random not found
[ 8.642694] binder: 132:132 transaction failed 29189, size 0-0
[ 8.643088] init: cannot find ‘/system/vendor/bin/pvrsrvctl’, disabling ‘pvrsrvctl’
[ 8.645869] init: cannot find ‘/system/bin/rild3’, disabling ‘ril-daemon3’
[ 8.647602] init: cannot find ‘/system/etc/install-recovery.sh’, disabling ‘flash_recovery’
[ 8.649353] init: cannot find ‘/system/bin/chrome.sh’, disabling ‘chrome’
[ 8.649708] init: cannot find ‘/system/bin/bplus_helper’, disabling ‘bplus_helper’
[ 8.702125] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 8.710047] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
[ 8.720125] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
[ 8.73250] rknand_sys_storage_open
[ 8.733360] 0,baud is:9600
[ 8.735970] 2, baud is:115200
[ 8.741577] RKNAND_GET_DRM_KEY
[ 8.744500] 2, baud is:115200
[ 8.744540] return ret = 0
[ 8.750359] 0,baud is:9600
[ 8.829401] rk3288-lcdc lcdc0: lcdc0: dclk:74250000>>fps:60
[ 8.831575] fs_mgr: parse_link_device : path = NULL
[ 8.831603] fs_mgr: parse_link_device : path = NULL
[ 8.831624] fs_mgr: parse_link_device : path = NULL
[ 8.831644] fs_mgr: parse_link_device : path = NULL
[ 8.831662] fs_mgr: parse_link_device : path = NULL
[ 8.831680] fs_mgr: parse_link_device : path = NULL
[ 8.831711] fs_mgr: parse_link_device : path = NULL
[ 8.831730] fs_mgr: parse_link_device : path = NULL
[ 8.892243] init: property ‘sys.powerctl’ doesn’t exist while expanding ‘${sys.powerctl}’
[ 8.892614] firefly_vga_get_enable 180, 0
[ 8.892665] firefly_vga_get_status 186
[ 8.908081] init: powerctl: cannot expand ‘${sys.powerctl}’
[ 8.913799] init: property ‘sys.sysctl.extra_free_kbytes’ doesn’t exist while expanding ‘${sys.sysctl.extra_free_kbytes}’
[ 8.913907] firefly_vga_set_enable 159 enable:0
[ 8.929063] init: cannot expand ‘${sys.sysctl.extra_free_kbytes}’ while writing to ‘/proc/sys/vm/extra_free_kbytes’
[ 8.940938] android_usb: already disabled
[ 8.945966] 2, baud is:115200
[ 8.947158] read descriptors
[ 8.947168] read strings
[ 8.947196] pcd_pullup, is_on 1
shell@rk3288:/ $ [ 9.395041] rk3288-lcdc lcdc0: blank mode:0
[ 9.672400] init: sys_prop: permission denied uid:1003 name:sys.gmali.version
[ 9.842799] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_hal.ver
[ 9.850613] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_trace
[ 9.858259] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_camboard.ver
[ 9.866433] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_libisp.ver
[ 9.874399] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_isi.ver
[ 9.887932] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.895328] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 9.902688] D1:camsys_open(710): camsys_marvin(ed8fc510) is opened!
[ 9.908933] D1:camsys_extdev_register(226): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
[ 9.918897] D1:camsys_extdev_register(226): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
[ 9.928848] D1:camsys_extdev_register(226): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
[ 9.938819] rockchip_gpio_request:GPIO7-13
[ 9.942853] rockchip_gpio_set:GPIO7-13 level = 1
[ 9.947411] rockchip_gpio_direction_output:set GPIO7-13 level 1
[ 9.953252] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
[ 9.959975] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x207600,result=0x207600
[ 9.970863] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 9.977682] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000400,result=0x400
[ 9.984544] _rockchip_pinconf_set:GPIO7-13,group=isp_flash_trigger, function=isp_pin, type=3
[ 9.992839] rk3288_calc_drv_reg_and_bit:GPIO7-13, drv_reg=0x74, bit=10
[ 9.999290] _rockchip_pinconf_set:GPIO-7 13 data=0xc000000,type=3
[ 10.005296] D1:camsys_extdev_register(248): Extdev(dev_id: 0x2000000) register success
[ 10.018134] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 10.026108] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 10.031091] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 10.036018] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 10.045306] D1:camsys_sysctl_extdev(326): Sysctl 11 success, gpio(11) set 1
[ 10.053214] D1:camsys_sysctl_extdev(330): Sysctl 8 success, gpio(79) set 1
[ 10.061032] D1:camsys_sysctl_extdev(330): Sysctl 7 success, gpio(78) set 1
[ 10.071054] E:camsys_i2c_write(77): i2c write dev(addr:0x20) failed!
[ 10.078584] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
[ 10.084939] D1:camsys_sysctl_extdev(326): Sysctl 7 success, gpio(78) set 0
[ 10.091761] D1:camsys_sysctl_extdev(326): Sysctl 8 success, gpio(79) set 0
[ 10.098574] D1:camsys_sysctl_extdev(330): Sysctl 11 success, gpio(11) set 0
[ 10.106551] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 10.113252] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 10.122101] D1:camsys_extdev_deregister(308): Extdev(dev_id: 0x2000000) is deregister success
[ 10.130509] D1:camsys_irq_disconnect(635): All thread disconnect camsys_marvin irq success!
[ 10.138812] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 10.146286] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 10.153773] D1:camsys_release(734): camsys_marvin(ed8fc510) is closed
[ 10.162841] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 10.170197] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 10.177597] D1:camsys_open(710): camsys_marvin(ed8fc510) is opened!
[ 10.183815] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit
[ 10.190783] D1:camsys_extdev_register(248): Extdev(dev_id: 0x1000000) register success
[ 10.203613] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 10.211591] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 10.216574] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 10.221494] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 10.230786] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 10.239113] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 10.247373] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 10.257816] E:camsys_i2c_write(77): i2c write dev(addr:0x60) failed!
[ 10.264190] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 10.271444] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 10.278657] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 10.287050] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 10.293728] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 10.302579] D1:camsys_extdev_deregister(308): Extdev(dev_id: 0x1000000) is deregister success
[ 10.311051] D1:camsys_irq_disconnect(635): All thread disconnect camsys_marvin irq success!
[ 10.319307] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 10.326766] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 10.334275] D1:camsys_release(734): camsys_marvin(ed8fc510) is closed
[ 10.343141] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 10.350530] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 10.357912] D1:camsys_open(710): camsys_marvin(ed8fc510) is opened!
[ 10.364159] rockchip_gpio_set:GPIO7-13 level = 0
[ 10.368725] rockchip_gpio_direction_output:set GPIO7-13 level 0
[ 10.374552] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
[ 10.381273] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x207600,result=0x207600
[ 10.392155] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 10.398949] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000400,result=0x400
[ 10.405798] _rockchip_pinconf_set:GPIO7-13,group=isp_flash_trigger, function=isp_pin, type=3
[ 10.414121] rk3288_calc_drv_reg_and_bit:GPIO7-13, drv_reg=0x74, bit=10
[ 10.420554] _rockchip_pinconf_set:GPIO-7 13 data=0xc000000,type=3
[ 10.426567] D1:camsys_extdev_register(248): Extdev(dev_id: 0x2000000) register success
[ 10.439413] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 10.447393] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 10.452376] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 10.457337] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 10.466629] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 10.474960] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 10.483213] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 10.493648] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
[ 10.499979] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 10.507249] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 10.514479] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 10.522861] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 10.529556] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 10.538396] D1:camsys_extdev_deregister(308): Extdev(dev_id: 0x2000000) is deregister success
[ 10.546853] D1:camsys_irq_disconnect(635): All thread disconnect camsys_marvin irq success!
[ 10.555114] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 10.562589] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 10.570068] D1:camsys_release(734): camsys_marvin(ed8fc510) is closed
[ 10.805029] warning: `zygote’ uses 32-bit capabilities (legacy support in use)
[ 10.815848] Enter::rk29_hw_params----52
[ 10.820628] Enter:rk29_hw_params, 86, rate=44100
[ 10.825209] Enter:rk29_hw_params, 104, LRCK=64
[ 11.056446] Enter::rk29_hw_params----52
[ 11.061260] Enter:rk29_hw_params, 86, rate=44100
[ 11.065828] Enter:rk29_hw_params, 104, LRCK=64
[ 12.758859] es8323_mic_state_ctrl read: 0
[ 12.762809] mic_state_switch 0
[ 12.765811] hp_det = 0,insert hp
[ 12.769818] hp mic use intern
[ 14.494676] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_hal.ver
[ 14.502706] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_trace
[ 14.510375] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_camboard.ver
[ 14.518600] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_libisp.ver
[ 14.526884] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_isi.ver
[ 14.537733] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 14.545221] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 14.552594] D1:camsys_open(710): camsys_marvin(ed8fc510) is opened!
[ 14.558810] D1:camsys_extdev_register(226): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
[ 14.568761] D1:camsys_extdev_register(226): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
[ 14.578705] D1:camsys_extdev_register(226): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
[ 14.588676] rockchip_gpio_set:GPIO7-13 level = 1
[ 14.593332] rockchip_gpio_direction_output:set GPIO7-13 level 1
[ 14.599180] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
[ 14.605859] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x207600,result=0x207600
[ 14.616759] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 14.623559] D1:camsys_extdev_register(248): Extdev(dev_id: 0x2000000) register success
[ 14.631477] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 14.631485] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 14.631590] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 14.631623] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 14.632705] D1:camsys_sysctl_extdev(326): Sysctl 11 success, gpio(11) set 1
[ 14.633788] D1:camsys_sysctl_extdev(330): Sysctl 8 success, gpio(79) set 1
[ 14.634870] D1:camsys_sysctl_extdev(330): Sysctl 7 success, gpio(78) set 1
[ 14.664669] E:camsys_i2c_write(77): i2c write dev(addr:0x20) failed!
[ 14.685131] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
[ 14.691569] D1:camsys_sysctl_extdev(326): Sysctl 7 success, gpio(78) set 0
[ 14.698441] D1:camsys_sysctl_extdev(326): Sysctl 8 success, gpio(79) set 0
[ 14.705231] D1:camsys_sysctl_extdev(330): Sysctl 11 success, gpio(11) set 0
[ 14.713257] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 14.719922] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 14.728842] D1:camsys_extdev_deregister(308): Extdev(dev_id: 0x2000000) is deregister success
[ 14.737262] D1:camsys_irq_disconnect(635): All thread disconnect camsys_marvin irq success!
[ 14.745477] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 14.752940] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 14.760411] D1:camsys_release(734): camsys_marvin(ed8fc510) is closed
[ 14.767240] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 14.774599] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 14.782046] D1:camsys_open(710): camsys_marvin(ed8fc510) is opened!
[ 14.788360] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit
[ 14.795299] D1:camsys_extdev_register(248): Extdev(dev_id: 0x1000000) register success
[ 14.808176] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 14.816189] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 14.821174] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 14.826102] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 14.835384] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 14.843739] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 14.852053] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 14.862626] E:camsys_i2c_write(77): i2c write dev(addr:0x60) failed!
[ 14.868984] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 14.876207] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 14.883399] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 14.891855] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 14.898490] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 14.907394] D1:camsys_extdev_deregister(308): Extdev(dev_id: 0x1000000) is deregister success
[ 14.915805] D1:camsys_irq_disconnect(635): All thread disconnect camsys_marvin irq success!
[ 14.924032] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 14.931469] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 14.938942] D1:camsys_release(734): camsys_marvin(ed8fc510) is closed
[ 14.945998] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 14.953380] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 14.953387] D1:camsys_open(710): camsys_marvin(ed8fc510) is opened!
[ 14.953454] rockchip_gpio_set:GPIO7-13 level = 0
[ 14.953457] rockchip_gpio_direction_output:set GPIO7-13 level 0
[ 14.953465] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
[ 14.953470] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x207600,result=0x207600
[ 14.953475] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 14.953498] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000400,result=0x400
[ 14.953503] _rockchip_pinconf_set:GPIO7-13,group=isp_flash_trigger, function=isp_pin, type=3
[ 14.953507] rk3288_calc_drv_reg_and_bit:GPIO7-13, drv_reg=0x74, bit=10
[ 14.953511] _rockchip_pinconf_set:GPIO-7 13 data=0xc000000,type=3
[ 14.953516] D1:camsys_extdev_register(248): Extdev(dev_id: 0x2000000) register success
[ 14.958568] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 14.958574] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 14.958676] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 14.958706] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 14.959766] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 14.960827] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 14.961885] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 14.965139] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
[ 14.965186] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 14.965193] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 14.965197] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 14.966285] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 14.966326] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 14.968374] D1:camsys_extdev_deregister(308): Extdev(dev_id: 0x2000000) is deregister success
[ 14.968392] D1:camsys_irq_disconnect(635): All thread disconnect camsys_marvin irq success!
[ 14.968398] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 14.968402] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 14.968406] D1:camsys_release(734): camsys_marvin(ed8fc510) is closed
[ 15.101293] Enter::rk29_hw_params----52
[ 15.102264] Enter:rk29_hw_params, 86, rate=44100
[ 15.102272] Enter:rk29_hw_params, 104, LRCK=64
[ 19.377527] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_hal.ver
[ 19.385351] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_trace
[ 19.393078] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_camboard.ver
[ 19.401315] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_libisp.ver
[ 19.409332] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_isi.ver
[ 19.419600] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 19.427015] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 19.434401] D1:camsys_open(710): camsys_marvin(ed8fc510) is opened!
[ 19.440718] D1:camsys_extdev_register(226): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
[ 19.450746] D1:camsys_extdev_register(226): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
[ 19.460755] D1:camsys_extdev_register(226): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
[ 19.470800] rockchip_gpio_set:GPIO7-13 level = 1
[ 19.475344] rockchip_gpio_direction_output:set GPIO7-13 level 1
[ 19.481250] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
[ 19.487936] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x207600,result=0x207600
[ 19.498876] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 19.505664] D1:camsys_extdev_register(248): Extdev(dev_id: 0x2000000) register success
[ 19.518530] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 19.526562] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 19.531745] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 19.536660] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 19.546040] D1:camsys_sysctl_extdev(326): Sysctl 11 success, gpio(11) set 1
[ 19.554125] D1:camsys_sysctl_extdev(330): Sysctl 8 success, gpio(79) set 1
[ 19.562183] D1:camsys_sysctl_extdev(330): Sysctl 7 success, gpio(78) set 1
[ 19.572230] E:camsys_i2c_write(77): i2c write dev(addr:0x20) failed!
[ 19.579744] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
[ 19.586059] D1:camsys_sysctl_extdev(326): Sysctl 7 success, gpio(78) set 0
[ 19.592875] D1:camsys_sysctl_extdev(326): Sysctl 8 success, gpio(79) set 0
[ 19.599690] D1:camsys_sysctl_extdev(330): Sysctl 11 success, gpio(11) set 0
[ 19.607631] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 19.614289] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 19.623153] D1:camsys_extdev_deregister(308): Extdev(dev_id: 0x2000000) is deregister success
[ 19.631720] D1:camsys_irq_disconnect(635): All thread disconnect camsys_marvin irq success!
[ 19.640028] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 19.647711] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 19.647722] D1:camsys_release(734): camsys_marvin(ed8fc510) is closed
[ 19.648227] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 19.648232] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 19.648236] D1:camsys_open(710): camsys_marvin(ed8fc510) is opened!
[ 19.648273] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit
[ 19.648374] D1:camsys_extdev_register(248): Extdev(dev_id: 0x1000000) register success
[ 19.653420] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 19.653427] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 19.653530] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 19.653559] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 19.654616] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 19.655679] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 19.656752] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 19.660005] E:camsys_i2c_write(77): i2c write dev(addr:0x60) failed!
[ 19.660047] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 19.660052] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 19.660056] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 19.661149] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 19.661179] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 19.661542] vbus detect**
[ 19.663234] D1:camsys_extdev_deregister(308): Extdev(dev_id: 0x1000000) is deregister success
[ 19.663247] D1:camsys_irq_disconnect(635): All thread disconnect camsys_marvin irq success!
[ 19.663254] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 19.663258] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 19.663261] D1:camsys_release(734): camsys_marvin(ed8fc510) is closed
[ 19.663825] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 19.663830] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 19.663834] D1:camsys_open(710): camsys_marvin(ed8fc510) is opened!
[ 19.663889] rockchip_gpio_set:GPIO7-13 level = 0
[ 19.663892] rockchip_gpio_direction_output:set GPIO7-13 level 0
[ 19.663900] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
[ 19.663906] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x207600,result=0x207600
[ 19.663910] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 19.664191] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000400,result=0x400
[ 19.664197] _rockchip_pinconf_set:GPIO7-13,group=isp_flash_trigger, function=isp_pin, type=3
[ 19.664201] rk3288_calc_drv_reg_and_bit:GPIO7-13, drv_reg=0x74, bit=10
[ 19.664205] _rockchip_pinconf_set:GPIO-7 13 data=0xc000000,type=3
[ 19.664210] D1:camsys_extdev_register(248): Extdev(dev_id: 0x2000000) register success
[ 19.669242] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 19.669248] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 19.669351] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 19.669378] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 19.670430] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 19.671479] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 19.672532] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 19.675799] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
[ 19.675842] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 19.675847] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 19.675853] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 19.676944] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 19.676983] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 19.679036] D1:camsys_extdev_deregister(308): Extdev(dev_id: 0x2000000) is deregister success
[ 19.679048] D1:camsys_irq_disconnect(635): All thread disconnect camsys_marvin irq success!
[ 19.679062] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 19.679066] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 19.679070] D1:camsys_release(734): camsys_marvin(ed8fc510) is closed
[ 19.803608] Enter::rk29_hw_params----52
[ 19.837066] Enter:rk29_hw_params, 86, rate=44100
[ 19.837074] Enter:rk29_hw_params, 104, LRCK=64
[ 19.850865] Using Buffer DMA mode
[ 19.850872] Periodic Transfer Interrupt Enhancement - disabled
[ 19.850875] Multiprocessor Interrupt Enhancement - disabled
[ 19.850879] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 19.850882] ^^^^^^^^^^^^^^^^^Device Mode
[ 19.850920] soft connect!!!
[ 19.961056] USB RESET
[ 20.003857] android_work: sent uevent USB_STATE=CONNECTED
[ 20.011198] USB RESET
[ 20.117273] android_usb gadget: high-speed config #1: android
[ 20.123156] android_work: sent uevent USB_STATE=CONFIGURED
[ 24.314297] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_hal.ver
[ 24.322127] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_trace
[ 24.329724] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_camboard.ver
[ 24.337969] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_libisp.ver
[ 24.346049] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_isi.ver
[ 24.356342] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 24.363755] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 24.371136] D1:camsys_open(710): camsys_marvin(ed8fc510) is opened!
[ 24.377348] D1:camsys_extdev_register(226): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
[ 24.387316] D1:camsys_extdev_register(226): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
[ 24.397253] D1:camsys_extdev_register(226): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
[ 24.407283] rockchip_gpio_set:GPIO7-13 level = 1
[ 24.411828] rockchip_gpio_direction_output:set GPIO7-13 level 1
[ 24.411839] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
[ 24.411847] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x207600,result=0x207600
[ 24.411851] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 24.411863] D1:camsys_extdev_register(248): Extdev(dev_id: 0x2000000) register success
[ 24.416911] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 24.416916] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 24.417018] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 24.417045] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 24.418104] D1:camsys_sysctl_extdev(326): Sysctl 11 success, gpio(11) set 1
[ 24.419160] D1:camsys_sysctl_extdev(330): Sysctl 8 success, gpio(79) set 1
[ 24.420213] D1:camsys_sysctl_extdev(330): Sysctl 7 success, gpio(78) set 1
[ 24.423416] E:camsys_i2c_write(77): i2c write dev(addr:0x20) failed!
[ 24.424596] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
[ 24.424637] D1:camsys_sysctl_extdev(326): Sysctl 7 success, gpio(78) set 0
[ 24.424647] D1:camsys_sysctl_extdev(326): Sysctl 8 success, gpio(79) set 0
[ 24.424654] D1:camsys_sysctl_extdev(330): Sysctl 11 success, gpio(11) set 0
[ 24.425718] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 24.425735] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 24.427780] D1:camsys_extdev_deregister(308): Extdev(dev_id: 0x2000000) is deregister success
[ 24.427788] D1:camsys_irq_disconnect(635): All thread disconnect camsys_marvin irq success!
[ 24.427795] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 24.427798] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 24.427802] D1:camsys_release(734): camsys_marvin(ed8fc510) is closed
[ 24.428232] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 24.428236] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 24.428240] D1:camsys_open(710): camsys_marvin(ed8fc510) is opened!
[ 24.428273] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit
[ 24.428361] D1:camsys_extdev_register(248): Extdev(dev_id: 0x1000000) register success
[ 24.433379] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 24.433383] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 24.433486] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 24.433503] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 24.434554] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 24.435604] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 24.436659] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 24.439896] E:camsys_i2c_write(77): i2c write dev(addr:0x60) failed!
[ 24.439930] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 24.439940] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 24.439944] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 24.441021] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 24.441053] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 24.443094] D1:camsys_extdev_deregister(308): Extdev(dev_id: 0x1000000) is deregister success
[ 24.443106] D1:camsys_irq_disconnect(635): All thread disconnect camsys_marvin irq success!
[ 24.443112] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 24.443115] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 24.443119] D1:camsys_release(734): camsys_marvin(ed8fc510) is closed
[ 24.443608] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 24.443613] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 24.443617] D1:camsys_open(710): camsys_marvin(ed8fc510) is opened!
[ 24.443674] rockchip_gpio_set:GPIO7-13 level = 0
[ 24.443678] rockchip_gpio_direction_output:set GPIO7-13 level 0
[ 24.443684] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
[ 24.443691] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x207600,result=0x207600
[ 24.443695] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 24.443712] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000400,result=0x400
[ 24.443718] _rockchip_pinconf_set:GPIO7-13,group=isp_flash_trigger, function=isp_pin, type=3
[ 24.443721] rk3288_calc_drv_reg_and_bit:GPIO7-13, drv_reg=0x74, bit=10
[ 24.443725] _rockchip_pinconf_set:GPIO-7 13 data=0xc000000,type=3
[ 24.443729] D1:camsys_extdev_register(248): Extdev(dev_id: 0x2000000) register success
[ 24.448760] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 24.448767] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 24.448869] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 24.448896] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 24.449951] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 24.451004] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 24.452063] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 24.455286] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
[ 24.455329] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 24.455334] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 24.455338] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 24.456416] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 24.456449] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 24.458497] D1:camsys_extdev_deregister(308): Extdev(dev_id: 0x2000000) is deregister success
[ 24.458509] D1:camsys_irq_disconnect(635): All thread disconnect camsys_marvin irq success!
[ 24.458519] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 24.458522] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 24.458526] D1:camsys_release(734): camsys_marvin(ed8fc510) is closed
[ 24.583627] Enter::rk29_hw_params----52
[ 24.584604] Enter:rk29_hw_params, 86, rate=44100
[ 24.584612] Enter:rk29_hw_params, 104, LRCK=64
[ 24.800996] Enter::rk29_hw_params----52
[ 24.801993] Enter:rk29_hw_params, 86, rate=44100
[ 24.802003] Enter:rk29_hw_params, 104, LRCK=64
[ 29.250471] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_hal.ver
[ 29.258244] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_trace
[ 29.265950] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_camboard.ver
[ 29.274159] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_libisp.ver
[ 29.282242] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_isi.ver
[ 29.292458] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 29.299879] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 29.307236] D1:camsys_open(710): camsys_marvin(ed8fc510) is opened!
[ 29.313597] D1:camsys_extdev_register(226): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
[ 29.323586] D1:camsys_extdev_register(226): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
[ 29.333553] D1:camsys_extdev_register(226): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
[ 29.343554] rockchip_gpio_set:GPIO7-13 level = 1
[ 29.348110] rockchip_gpio_direction_output:set GPIO7-13 level 1
[ 29.354019] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
[ 29.360711] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x207600,result=0x207600
[ 29.371609] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 29.378398] D1:camsys_extdev_register(248): Extdev(dev_id: 0x2000000) register success
[ 29.391267] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 29.399320] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 29.404390] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 29.409499] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 29.418820] D1:camsys_sysctl_extdev(326): Sysctl 11 success, gpio(11) set 1
[ 29.426769] D1:camsys_sysctl_extdev(330): Sysctl 8 success, gpio(79) set 1
[ 29.434724] D1:camsys_sysctl_extdev(330): Sysctl 7 success, gpio(78) set 1
[ 29.444765] E:camsys_i2c_write(77): i2c write dev(addr:0x20) failed!
[ 29.452244] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
[ 29.458547] D1:camsys_sysctl_extdev(326): Sysctl 7 success, gpio(78) set 0
[ 29.465316] D1:camsys_sysctl_extdev(326): Sysctl 8 success, gpio(79) set 0
[ 29.472118] D1:camsys_sysctl_extdev(330): Sysctl 11 success, gpio(11) set 0
[ 29.480104] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 29.486771] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 29.495608] D1:camsys_extdev_deregister(308): Extdev(dev_id: 0x2000000) is deregister success
[ 29.504083] D1:camsys_irq_disconnect(635): All thread disconnect camsys_marvin irq success!
[ 29.512347] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 29.519854] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 29.527321] D1:camsys_release(734): camsys_marvin(ed8fc510) is closed
[ 29.534180] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 29.541609] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 29.549053] D1:camsys_open(710): camsys_marvin(ed8fc510) is opened!
[ 29.555357] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit
[ 29.562579] D1:camsys_extdev_register(248): Extdev(dev_id: 0x1000000) register success
[ 29.575642] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 29.583644] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 29.588667] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 29.593666] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 29.603096] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 29.611549] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 29.620033] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 29.630504] E:camsys_i2c_write(77): i2c write dev(addr:0x60) failed!
[ 29.636820] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 29.644069] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 29.651284] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 29.659687] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 29.666341] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 29.675195] D1:camsys_extdev_deregister(308): Extdev(dev_id: 0x1000000) is deregister success
[ 29.683639] D1:camsys_irq_disconnect(635): All thread disconnect camsys_marvin irq success!
[ 29.691863] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 29.691869] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 29.691873] D1:camsys_release(734): camsys_marvin(ed8fc510) is closed
[ 29.692380] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 29.692385] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 29.692390] D1:camsys_open(710): camsys_marvin(ed8fc510) is opened!
[ 29.692443] rockchip_gpio_set:GPIO7-13 level = 0
[ 29.692447] rockchip_gpio_direction_output:set GPIO7-13 level 0
[ 29.692454] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
[ 29.692461] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x207600,result=0x207600
[ 29.692466] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 29.692489] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000400,result=0x400
[ 29.692494] _rockchip_pinconf_set:GPIO7-13,group=isp_flash_trigger, function=isp_pin, type=3
[ 29.692497] rk3288_calc_drv_reg_and_bit:GPIO7-13, drv_reg=0x74, bit=10
[ 29.692503] _rockchip_pinconf_set:GPIO-7 13 data=0xc000000,type=3
[ 29.692508] D1:camsys_extdev_register(248): Extdev(dev_id: 0x2000000) register success
[ 29.697586] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 29.697592] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 29.697696] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 29.697729] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 29.698791] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 29.699851] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 29.700912] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 29.704209] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
[ 29.704248] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 29.704253] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 29.704258] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 29.705347] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 29.705387] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 29.707444] D1:camsys_extdev_deregister(308): Extdev(dev_id: 0x2000000) is deregister success
[ 29.707457] D1:camsys_irq_disconnect(635): All thread disconnect camsys_marvin irq success!
[ 29.707472] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 29.707476] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 29.707480] D1:camsys_release(734): camsys_marvin(ed8fc510) is closed
[ 29.832307] Enter::rk29_hw_params----52
[ 29.833262] Enter:rk29_hw_params, 86, rate=44100
[ 29.833270] Enter:rk29_hw_params, 104, LRCK=64
[ 30.052552] Enter::rk29_hw_params----52
[ 30.057341] Enter:rk29_hw_params, 86, rate=44100
[ 30.061971] Enter:rk29_hw_params, 104, LRCK=64
[ 34.203869] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_hal.ver
[ 34.211673] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_trace
[ 34.219308] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_camboard.ver
[ 34.227616] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_libisp.ver
[ 34.235683] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_isi.ver
[ 34.246246] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 34.253695] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 34.261116] D1:camsys_open(710): camsys_marvin(ed8fc510) is opened!
[ 34.267366] D1:camsys_extdev_register(226): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
[ 34.277425] D1:camsys_extdev_register(226): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
[ 34.287469] D1:camsys_extdev_register(226): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
[ 34.297674] rockchip_gpio_set:GPIO7-13 level = 1
[ 34.302455] rockchip_gpio_direction_output:set GPIO7-13 level 1
[ 34.302465] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
[ 34.302473] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x207600,result=0x207600
[ 34.302479] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 34.302494] D1:camsys_extdev_register(248): Extdev(dev_id: 0x2000000) register success
[ 34.307559] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 34.307566] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 34.307668] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 34.307698] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 34.308762] D1:camsys_sysctl_extdev(326): Sysctl 11 success, gpio(11) set 1
[ 34.309819] D1:camsys_sysctl_extdev(330): Sysctl 8 success, gpio(79) set 1
[ 34.310874] D1:camsys_sysctl_extdev(330): Sysctl 7 success, gpio(78) set 1
[ 34.314069] E:camsys_i2c_write(77): i2c write dev(addr:0x20) failed!
[ 34.315237] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
[ 34.315275] D1:camsys_sysctl_extdev(326): Sysctl 7 success, gpio(78) set 0
[ 34.315287] D1:camsys_sysctl_extdev(326): Sysctl 8 success, gpio(79) set 0
[ 34.315295] D1:camsys_sysctl_extdev(330): Sysctl 11 success, gpio(11) set 0
[ 34.316360] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 34.316378] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 34.318423] D1:camsys_extdev_deregister(308): Extdev(dev_id: 0x2000000) is deregister success
[ 34.318433] D1:camsys_irq_disconnect(635): All thread disconnect camsys_marvin irq success!
[ 34.318439] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 34.318442] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 34.318446] D1:camsys_release(734): camsys_marvin(ed8fc510) is closed
[ 34.318900] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 34.318905] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 34.318910] D1:camsys_open(710): camsys_marvin(ed8fc510) is opened!
[ 34.318941] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit
[ 34.319033] D1:camsys_extdev_register(248): Extdev(dev_id: 0x1000000) register success
[ 34.324052] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 34.324056] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 34.324159] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 34.324178] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 34.325231] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 34.326281] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 34.327330] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 34.330522] E:camsys_i2c_write(77): i2c write dev(addr:0x60) failed!
[ 34.330552] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 34.330557] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 34.330561] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 34.331622] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 34.331637] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 34.333674] D1:camsys_extdev_deregister(308): Extdev(dev_id: 0x1000000) is deregister success
[ 34.333682] D1:camsys_irq_disconnect(635): All thread disconnect camsys_marvin irq success!
[ 34.333687] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 34.333690] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 34.333694] D1:camsys_release(734): camsys_marvin(ed8fc510) is closed
[ 34.334084] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 34.334089] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on
[ 34.334093] D1:camsys_open(710): camsys_marvin(ed8fc510) is opened!
[ 34.334146] rockchip_gpio_set:GPIO7-13 level = 0
[ 34.334150] rockchip_gpio_direction_output:set GPIO7-13 level 0
[ 34.334156] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0
[ 34.334162] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x207600,result=0x207600
[ 34.334166] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 34.334181] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000400,result=0x400
[ 34.334186] _rockchip_pinconf_set:GPIO7-13,group=isp_flash_trigger, function=isp_pin, type=3
[ 34.334190] rk3288_calc_drv_reg_and_bit:GPIO7-13, drv_reg=0x74, bit=10
[ 34.334194] _rockchip_pinconf_set:GPIO-7 13 data=0xc000000,type=3
[ 34.334198] D1:camsys_extdev_register(248): Extdev(dev_id: 0x2000000) register success
[ 34.339209] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 34.339213] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1
[ 34.339315] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0
[ 34.339335] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 34.340388] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 34.341440] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 34.342496] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 34.345716] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed!
[ 34.345748] E:camsys_sysctl_extdev(333): Sysctl 7 failed, because gpio is NULL!
[ 34.345752] E:camsys_sysctl_extdev(333): Sysctl 8 failed, because gpio is NULL!
[ 34.345756] E:camsys_sysctl_extdev(333): Sysctl 11 failed, because gpio is NULL!
[ 34.346828] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off
[ 34.346852] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off
[ 34.348896] D1:camsys_extdev_deregister(308): Extdev(dev_id: 0x2000000) is deregister success
[ 34.348907] D1:camsys_irq_disconnect(635): All thread disconnect camsys_marvin irq success!
[ 34.348913] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 34.348916] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off
[ 34.348920] D1:camsys_release(734): camsys_marvin(ed8fc510) is closed
[ 34.465108] Enter::rk29_hw_params----52
[ 34.466100] Enter:rk29_hw_params, 86, rate=44100
[ 34.466109] Enter:rk29_hw_params, 104, LRCK=64
[ 34.691700] Enter::rk29_hw_params----52
[ 34.692690] Enter:rk29_hw_params, 86, rate=44100
[ 34.692698] Enter:rk29_hw_params, 104, LRCK=64
楼主有没有把代码更新到最新哦
这个是更新过的。
用什么显示,说一下具体什么现象
log没看出什么问题
用hdmi输出到电脑显示屏幕,启动画面停在“android"几个字,但是没有死机,打印信息的后面几十行在反复重复打印。
那应该提供一下logcat的信息,把log放在附件吧,好分析一些
hx_zhao 发表于 2015-5-20 15:56
用hdmi输出到电脑显示屏幕,启动画面停在“android"几个字,但是没有死机,打印信息的后面几十行在反复重复 …
你解决了吗,我也遇到这样的问题,求指导
lsh 发表于 2018-10-26 15:54
你解决了吗,我也遇到这样的问题,求指导
你们解决了吗?
解决了吗?
同问
