U-Boot 2017.09-ge9a3933 (Sep 28 2019 - 13:55:29 +0800)
Model: Firefly-RK3399 Board
PreSerial: 2
DRAM: 2 GiB
Sysmem: init
Relocation Offset is: 7dbeb000
no mmc device at slot 1
do_rkimg_test found IDB in SDcard
dwmmc@fe320000: 1 (SD), sdhci@fe330000: 0
Bootdev(atags): mmc 1
MMC1: Legacy, 50Mhz
PartType: EFI
get part misc fail -1
boot mode: None
Load FDT from boot part
DTB: rk-kernel.dtb
I2c speed: 400000Hz
PMIC: RK808
vdd_center 900000 uV
vdd_cpu_l 900000 uV
vdd_log 900000 uV
In: serial
Out: serial
Err: serial
Model: Firefly-RK3399 Board (Linux Opensource)
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 24000 KHz, init 24000 KHz, kernel 0N/A)
aplll 816000 KHz
apllb 24000 KHz
dpll 800000 KHz
cpll 24000 KHz
gpll 800000 KHz
npll 600000 KHz
vpll 24000 KHz
aclk_perihp 133333 KHz
hclk_perihp 66666 KHz
pclk_perihp 33333 KHz
aclk_perilp0 266666 KHz
hclk_perilp0 88888 KHz
pclk_perilp0 44444 KHz
hclk_perilp1 100000 KHz
pclk_perilp1 50000 KHz
Net: eth0: ethernet@fe300000
Could not find misc partition
Fdt Ramdisk skip relocation
Booting IMAGE kernel at 0x00280000 with fdt at 0x8300000…
## Booting Android Image at 0x0027f800 …
Kernel load addr 0x00280000 size 21407 KiB
## Flattened Device Tree blob at 08300000
Booting using the fdt blob at 0x8300000
XIP Kernel Image … OK
‘reserved-memory’ region@110000: addr=110000 size=f0000
Using Device Tree in place at 0000000008300000, end 000000000831c0c2
Can’t find file:logo_kernel.bmp
Total: 3555.150 ms
[ 0.000000] Linux version 4.4.179-ga179e62-dirty (root@renxus-ThinkPad-X240) ((HEAD: a179e620b38958254c1f74d283a9cf853ae20813) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #3 SMP Sat Sep 28 13:56:41 CST 2019
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07fee2000 s46312 r8192 d31512 u86016
[ 0.000000] Kernel command line: storagemedia=sd androidboot.storagemedia=sd androidboot.mode=normal androidboot.slot_suffix= androidboot.serialno=3373ca8618f03ab2 rw rootwait earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 console=ttyFIQ0 root=PARTUUID=614e0000-0000 rootfstype=ext4 coherent_pool=1m systemd.gpt_auto=0
[ 0.000000] software IO TLB: mapped [mem 0x7fe9a000-0x7feda000] (0MB)
[ 0.000000] Memory: 2003500K/2064384K available (13374K kernel code, 1822K rwdata, 5028K rodata, 1152K init, 1983K bss, 60884K reserved, 0K cma-reserved)
[ 0.000000] .init : 0xffffff8009280000 - 0xffffff80093a0000 ( 1152 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008d90000 ( 13376 KB)
[ 0.000000] .rodata : 0xffffff8008d90000 - 0xffffff8009280000 ( 5056 KB)
[ 0.000000] .data : 0xffffff80093a0000 - 0xffffff8009567808 ( 1823 KB)
[ 0.000000] ITS: allocated 65536 Devices @a280000 (psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x000000000a210000
[ 0.000000] CPU0: using LPI pending table @0x000000000a220000
[ 0.002229] Console: colour dummy device 80x25
[ 0.002670] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.003660] pid_max: default: 32768 minimum: 301
[ 0.004185] Security Framework initialized
[ 0.004650] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.005292] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.006689] Initializing cgroup subsys io
[ 0.007098] Initializing cgroup subsys memory
[ 0.007540] Initializing cgroup subsys devices
[ 0.007972] Initializing cgroup subsys freezer
[ 0.008413] Initializing cgroup subsys perf_event
[ 0.008868] Initializing cgroup subsys net_prio
[ 0.009307] Initializing cgroup subsys pids
[ 0.009741] ftrace: allocating 48228 entries in 189 pages
[ 0.133926] sched-energy: Sched-energy-costs installed from DT
[ 0.134491] CPU0: update cpu_capacity 401
[ 0.134943] ASID allocator initialised with 32768 entries
[ 0.138625] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.140006] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.142260] Detected VIPT I-cache on CPU1
[ 0.142292] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.142322] CPU1: using LPI pending table @0x000000007d0b0000
[ 0.142364] CPU1: update cpu_capacity 401
[ 0.142368] CPU1: Booted secondary processor [410fd034]
[ 0.142921] Detected VIPT I-cache on CPU2
[ 0.142942] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.142969] CPU2: using LPI pending table @0x000000007d0e0000
[ 0.142995] CPU2: update cpu_capacity 401
[ 0.142999] CPU2: Booted secondary processor [410fd034]
[ 0.143529] Detected VIPT I-cache on CPU3
[ 0.143548] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.143575] CPU3: using LPI pending table @0x000000007d130000
[ 0.143601] CPU3: update cpu_capacity 401
[ 0.143604] CPU3: Booted secondary processor [410fd034]
[ 0.144166] Detected PIPT I-cache on CPU4
[ 0.144193] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.144232] CPU4: using LPI pending table @0x000000007d170000
[ 0.144270] CPU4: update cpu_capacity 1024
[ 0.144273] CPU4: Booted secondary processor [410fd082]
[ 0.144831] Detected PIPT I-cache on CPU5
[ 0.144849] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.144885] CPU5: using LPI pending table @0x000000007d1a0000
[ 0.144911] CPU5: update cpu_capacity 1024
[ 0.144914] CPU5: Booted secondary processor [410fd082]
[ 0.145015] Brought up 6 CPUs
[ 0.157382] SMP: Total of 6 processors activated.
[ 0.157833] CPU features: detected feature: GIC system register CPU interface
[ 0.158522] CPU features: detected feature: 32-bit EL0 Support
[ 0.159082] CPU: All CPU(s) started at EL2
[ 0.159514] alternatives: patching kernel code
[ 0.161355] devtmpfs: initialized
[ 0.179794] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.180727] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.181777] xor: measuring software checksum speed
[ 0.192265] 8regs : 2860.000 MB/sec
[ 0.202323] 8regs_prefetch: 2564.000 MB/sec
[ 0.212379] 32regs : 3208.000 MB/sec
[ 0.222435] 32regs_prefetch: 2848.000 MB/sec
[ 0.222875] xor: using function: 32regs (3208.000 MB/sec)
[ 0.223392] pinctrl core: initialized pinctrl subsystem
[ 0.224636] NET: Registered protocol family 16
[ 0.230205] cpuidle: using governor ladder
[ 0.236220] cpuidle: using governor menu
[ 0.236603] Registered FIQ tty driver
[ 0.237369] vdso: 2 pages (1 code @ ffffff8008d96000, 1 data @ ffffff80093a4000)
[ 0.238083] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.239252] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.263043] console [pstore-1] enabled
[ 0.263399] pstore: Registered ramoops as persistent store backend
[ 0.263978] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.267046] console [ttyFIQ0] enabled
[ 0.267732] bootconsole [uart0] disabled
[ 0.268656] Registered fiq debugger ttyFIQ0
[ 0.314011] raid6: int64x1 gen() 496 MB/s
[ 0.331103] raid6: int64x1 xor() 371 MB/s
[ 0.348203] raid6: int64x2 gen() 820 MB/s
[ 0.365301] raid6: int64x2 xor() 603 MB/s
[ 0.382424] raid6: int64x4 gen() 1089 MB/s
[ 0.399499] raid6: int64x4 xor() 673 MB/s
[ 0.416603] raid6: int64x8 gen() 906 MB/s
[ 0.433660] raid6: int64x8 xor() 630 MB/s
[ 0.450797] raid6: neonx1 gen() 1003 MB/s
[ 0.467863] raid6: neonx1 xor() 626 MB/s
[ 0.484963] raid6: neonx2 gen() 1527 MB/s
[ 0.502064] raid6: neonx2 xor() 947 MB/s
[ 0.519164] raid6: neonx4 gen() 2132 MB/s
[ 0.536243] raid6: neonx4 xor() 1173 MB/s
[ 0.553342] raid6: neonx8 gen() 1687 MB/s
[ 0.570432] raid6: neonx8 xor() 1242 MB/s
[ 0.570815] raid6: using algorithm neonx4 gen() 2132 MB/s
[ 0.571294] raid6: … xor() 1173 MB/s, rmw enabled
[ 0.571739] raid6: using intx1 recovery algorithm
[ 0.576984] iommu: Adding device ff650000.vpu_service to group 0
[ 0.577605] iommu: Adding device ff660000.rkvdec to group 1
[ 0.578202] iommu: Adding device ff8f0000.vop to group 2
[ 0.578766] iommu: Adding device ff900000.vop to group 3
[ 0.579321] iommu: Adding device ff910000.rkisp1 to group 4
[ 0.579909] iommu: Adding device ff920000.rkisp1 to group 5
[ 0.580884] rk_iommu ff650800.iommu: can’t get sclk
[ 0.581581] rk_iommu ff660480.iommu: can’t get sclk
[ 0.582227] rk_iommu ff8f3f00.iommu: can’t get sclk
[ 0.582822] rk_iommu ff903f00.iommu: can’t get sclk
[ 0.583431] rk_iommu ff914000.iommu: can’t get sclk
[ 0.584021] rk_iommu ff924000.iommu: can’t get sclk
[ 0.584828] SCSI subsystem initialized
[ 0.585543] usbcore: registered new interface driver usbfs
[ 0.586071] usbcore: registered new interface driver hub
[ 0.586629] usbcore: registered new device driver usb
[ 0.587131] media: Linux media interface: v0.10
[ 0.587574] Linux video capture interface: v2.00
[ 0.588066] pps_core: LinuxPPS API ver. 1 registered
[ 0.588512] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.589341] PTP clock support registered
[ 0.590833] Advanced Linux Sound Architecture Driver Initialized.
[ 0.591858] Bluetooth: Core ver 2.21
[ 0.592198] NET: Registered protocol family 31
[ 0.592608] Bluetooth: HCI device and connection manager initialized
[ 0.593177] Bluetooth: HCI socket layer initialized
[ 0.593622] Bluetooth: L2CAP socket layer initialized
[ 0.594086] Bluetooth: SCO socket layer initialized
[ 0.595152] rockchip-cpuinfo cpuinfo: Serial : 3373ca8618f03ab2
[ 0.596406] clocksource: Switched to clocksource arch_sys_counter
[ 0.647707] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.648627] NET: Registered protocol family 2
[ 0.649455] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.650233] TCP bind hash table entries: 16384 (order: 7, 524288 bytes)
[ 0.651276] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.651935] UDP hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.652566] UDP-Lite hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.653413] NET: Registered protocol family 1
[ 0.654090] RPC: Registered named UNIX socket transport module.
[ 0.654633] RPC: Registered udp transport module.
[ 0.655056] RPC: Registered tcp transport module.
[ 0.655486] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.657293] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.658121] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.662022] Initialise system trusted keyring
[ 0.670315] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.671613] NFS: Registering the id_resolver key type
[ 0.672080] Key type id_resolver registered
[ 0.672470] Key type id_legacy registered
[ 0.672899] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.673685] fuse init (API version 7.23)
[ 0.674378] SGI XFS with security attributes, no debug enabled
[ 0.680349] NET: Registered protocol family 38
[ 0.680791] Key type asymmetric registered
[ 0.681163] Asymmetric key parser ‘x509’ registered
[ 0.681822] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.682633] io scheduler noop registered
[ 0.682993] io scheduler deadline registered
[ 0.683420] io scheduler cfq registered (default)
[ 0.685457] phy phy-ff770000.syscon:usb2-phy@e460.1: Failed to get VBUS supply regulator
[ 0.692654] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.693246] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.693851] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 0.694425] rockchip-pcie f8000000.pcie: missing “memory-region” property
[ 0.695030] PCI host bridge /pcie@f8000000 ranges:
[ 0.695475] MEM 0xfa000000..0xfbdfffff → 0xfa000000
[ 0.695936] IO 0xfbe00000..0xfbefffff → 0xfbe00000
[ 1.238466] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 1.239087] rockchip-pcie f8000000.pcie: deferred probe failed
[ 1.239731] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 1.241575] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 1.242510] rk-vcodec ff650000.vpu_service: probe device
[ 1.243268] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[ 1.244627] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 1.245249] rk-vcodec ff650000.vpu_service: init success
[ 1.246153] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 1.247179] rk-vcodec ff660000.rkvdec: probe device
[ 1.247863] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[ 1.249037] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 1.249650] rk-vcodec ff660000.rkvdec: init success
[ 1.252354] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.253052] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 1.255897] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.256592] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.259061] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 1.261293] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 1.262711] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
[ 1.264184] ff370000.serial: ttyS4 at MMIO 0xff370000 (irq = 38, base_baud = 1500000) is a 16550A
[ 1.266545] [drm] Initialized drm 1.1.0 20060810
[ 1.270811] [drm] Rockchip DRM driver version: v1.0.1
[ 1.273390] mali ff9a0000.gpu: Failed to get regulator
[ 1.273862] mali ff9a0000.gpu: Power control initialization failed
[ 1.274793] Unable to detect cache hierarchy for CPU 0
[ 1.276129] brd: module loaded
[ 1.281657] loop: module loaded
[ 1.282508] zram: Added device: zram0
[ 1.283131] lkdtm: No crash points registered, enable through debugfs
[ 1.285225] register spi return v = :0
[ 1.286899] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 1.287618] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.288243] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 1.288761] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[ 1.289281] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 1.289996] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 1.290625] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.296170] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.296781] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.297227] Ring mode enabled
[ 1.297510] DMA HW capability register supported
[ 1.297909] Normal descriptors
[ 1.298218] RX Checksum Offload Engine supported (type 2)
[ 1.298716] Wake-Up On Lan supported
[ 1.299077] Enable RX Mitigation via HW Watchdog Timer
[ 1.364609] libphy: stmmac: probed
[ 1.364922] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.365506] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 1.367304] usbcore: registered new interface driver rtl8192cu
[ 1.367913] usbcore: registered new interface driver rndis_wlan
[ 1.368741] usbcore: registered new interface driver mt7601u
[ 1.369344] Rockchip WiFi SYS interface (V1.00) …
[ 1.369911] usbcore: registered new interface driver rtl8150
[ 1.370478] usbcore: registered new interface driver r8152
[ 1.371031] usbcore: registered new interface driver asix
[ 1.371575] usbcore: registered new interface driver ax88179_178a
[ 1.372168] usbcore: registered new interface driver cdc_ether
[ 1.372745] usbcore: registered new interface driver rndis_host
[ 1.373357] usbcore: registered new interface driver cdc_ncm
[ 1.373924] usbcore: registered new interface driver qmi_wwan
[ 1.374501] usbcore: registered new interface driver cdc_mbim
[ 1.377024] rockchip-dwc3 usb0: failed to get drvdata dwc3
[ 1.382513] rockchip-dwc3 usb1: fail to get drvdata hcd
[ 1.384710] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.385313] ehci-pci: EHCI PCI platform driver
[ 1.385812] ehci-platform: EHCI generic platform driver
[ 1.390348] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.391123] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 1.391980] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 1.398438] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.399209] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.399835] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.400490] usb usb1: Product: EHCI Host Controller
[ 1.400928] usb usb1: Manufacturer: Linux 4.4.179-ga179e62-dirty ehci_hcd
[ 1.401546] usb usb1: SerialNumber: fe3c0000.usb
[ 1.402592] hub 1-0:1.0: USB hub found
[ 1.402970] hub 1-0:1.0: 1 port detected
[ 1.404123] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.404708] ohci-platform: OHCI generic platform driver
[ 1.405859] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.406717] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[ 1.407537] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 1.462630] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.463241] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.463898] usb usb2: Product: Generic Platform OHCI controller
[ 1.464439] usb usb2: Manufacturer: Linux 4.4.179-ga179e62-dirty ohci_hcd
[ 1.465047] usb usb2: SerialNumber: fe3e0000.usb
[ 1.466062] hub 2-0:1.0: USB hub found
[ 1.466466] hub 2-0:1.0: 1 port detected
[ 1.468164] usbcore: registered new interface driver cdc_acm
[ 1.468682] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.469453] usbcore: registered new interface driver cdc_wdm
[ 1.470006] usbcore: registered new interface driver uas
[ 1.470600] usbcore: registered new interface driver usb-storage
[ 1.471243] usbcore: registered new interface driver usbserial
[ 1.471810] usbcore: registered new interface driver usbserial_generic
[ 1.472438] usbserial: USB Serial support registered for generic
[ 1.473020] usbcore: registered new interface driver ch341
[ 1.473555] usbserial: USB Serial support registered for ch341-uart
[ 1.474160] usbcore: registered new interface driver cp210x
[ 1.474706] usbserial: USB Serial support registered for cp210x
[ 1.475299] usbcore: registered new interface driver ftdi_sio
[ 1.475858] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.476692] usbcore: registered new interface driver keyspan
[ 1.477226] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 1.477965] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 1.478659] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 1.479344] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 1.480061] usbcore: registered new interface driver option
[ 1.480597] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.481418] usbcore: registered new interface driver oti6858
[ 1.481951] usbserial: USB Serial support registered for oti6858
[ 1.482547] usbcore: registered new interface driver pl2303
[ 1.483069] usbserial: USB Serial support registered for pl2303
[ 1.483661] usbcore: registered new interface driver qcserial
[ 1.484210] usbserial: USB Serial support registered for Qualcomm USB modem
[ 1.484907] usbcore: registered new interface driver sierra
[ 1.485442] usbserial: USB Serial support registered for Sierra USB modem
[ 1.487530] usbcore: registered new interface driver usbtouchscreen
[ 1.488526] .. rk pwm remotectl v1.1 init
[ 1.489218] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 1.490474] sensor_register_slave:mma8452,id=17
[ 1.490892] sensor_register_slave:lis3dh,id=7
[ 1.491286] sensor_register_slave:mma7660,id=18
[ 1.491717] sensor_register_slave:lsm303d,id=22
[ 1.492133] sensor_register_slave:gs_mc3230,id=23
[ 1.492565] [Gsensor] gsensor_init
[ 1.492891] sensor_register_slave:mpu6880_acc,id=24
[ 1.493330] sensor_register_slave:mpu6500_acc,id=25
[ 1.493781] sensor_register_slave:lsm330_acc,id=26
[ 1.494220] sensor_register_slave:akm8975,id=30
[ 1.494647] sensor_register_slave:akm8963,id=31
[ 1.495063] sensor_register_slave:l3g4200d,id=45
[ 1.495489] sensor_register_slave:l3g20d,id=46
[ 1.495894] sensor_register_slave:ewtsa,id=47
[ 1.496288] sensor_register_slave:lsm330_gyro,id=51
[ 1.496738] sensor_register_slave:cm3217,id=53
[ 1.497143] sensor_register_slave:cm3218,id=54
[ 1.498146] i2c /dev entries driver
[ 1.500220] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 1.500956] fan53555-reg: supplied by vcc5v0_sys
[ 1.504173] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 1.504875] fan53555-reg: supplied by vcc5v0_sys
[ 1.508120] rk808 0-001b: Pmic Chip id: 0x0
[ 1.512360] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.513007] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.513711] DCDC_REG1: supplied by vcc3v3_sys
[ 1.515084] DCDC_REG2: supplied by vcc3v3_sys
[ 1.516241] DCDC_REG3: supplied by vcc3v3_sys
[ 1.517055] DCDC_REG4: supplied by vcc3v3_sys
[ 1.518078] LDO_REG1: supplied by vcc3v3_sys
[ 1.519795] LDO_REG2: supplied by vcc3v3_sys
[ 1.521322] LDO_REG3: supplied by vcc3v3_sys
[ 1.522879] LDO_REG4: supplied by vcc3v3_sys
[ 1.524444] LDO_REG5: supplied by vcc3v3_sys
[ 1.525960] LDO_REG6: supplied by vcc3v3_sys
[ 1.527544] LDO_REG7: supplied by vcc3v3_sys
[ 1.529089] LDO_REG8: supplied by vcc3v3_sys
[ 1.530670] SWITCH_REG1: supplied by vcc3v3_sys
[ 1.531561] SWITCH_REG2: supplied by vcc3v3_sys
[ 1.535894] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 1.537121] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80099dc000
[ 1.538926] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80099de000
[ 1.541418] fusb302 4-0022: Can’t get property of role, set role to default DRP
[ 1.545535] fusb302 4-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
[ 1.546535] input: Typec_Headphone as /devices/platform/ff3d0000.i2c/i2c-4/4-0022/input/input1
[ 1.547510] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80099f2000
[ 1.549839] IR NEC protocol handler initialized
[ 1.551390] rkisp1 ff910000.rkisp1: rkisp1 driver version: v00.01.04
[ 1.551987] rkisp1 ff910000.rkisp1: Missing rockchip,grf property
[ 1.554921] rkisp1 ff920000.rkisp1: rkisp1 driver version: v00.01.04
[ 1.555519] rkisp1 ff920000.rkisp1: Missing rockchip,grf property
[ 1.558307] usbcore: registered new interface driver uvcvideo
[ 1.558843] USB Video Class driver (1.1.1)
[ 1.561982] Boot mode: coldboot
