jpchen 发表于 2019-11-28 10:57
请先烧录官方固件验证是否会有重启的问题。
同时接上串口把内核log,也抓一下看看
官方的没问题,下面是内核log
[ 0.000000] Linux version 3.10.0 (liteng@cnc-server) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #3 SMP PREEMPT Sat Nov 23 16:45:24 CST 2019
[ 0.000000] ion heap(cma): base(0) size(1000000) align(0)
[ 0.000000] cma: CMA: reserved 16 MiB at 7f000000
[ 0.000000] ion_reserve: cma reserved base 7f000000 size 16777216
[ 0.000000] cma: CMA: reserved 16 MiB at 1f000000
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1f22000 s13376 r8192 d15296 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523264
[ 0.000000] Kernel command line: vmalloc=496M console=ttyFIQ0 androidboot.selinux=0 androidboot.hardware=rk30board androidboot.console=ttyFIQ0 root=/dev/block/mtd/by-name/linuxroot rw rootfstype=ext4 init=/sbin/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00002000@0x0039A000(baseparamer),-@0x003BC000(userdata) storagemedia=emmc loader.timestamp=2019-11-01_15:15:28
[ 0.000000] allocated 4194304 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Memory: 2026408k/2026408k available, 70744k reserved, 1556480K highmem
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0bb7aa0 (11967 kB)
[ 0.000000] .init : 0xc0bb8000 - 0xc0c11440 ( 358 kB)
[ 0.000000] .data : 0xc0c12000 - 0xc0da4980 (1611 kB)
[ 0.000000] .bss : 0xc0da4980 - 0xc0ec5cbc (1157 kB)
[ 0.000000] rk_clk_tree_init start!
[ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div
[ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error
[ 0.000000] rkclk_init_clks: cnt_rate = 29
[ 0.000000] rk3288 set GPLL BW 20 for HDMI!
[ 0.000000] process version: 0
[ 0.000000] channel:0, lkg:14
[ 0.000000] target-temp:80
[ 0.000000] channel:2, lkg:0
[ 0.000000] channel:1, lkg:9
[ 0.505846] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.505861] pid_max: default: 32768 minimum: 301
[ 0.505976] Security Framework initialized
[ 0.505992] SELinux: Initializing.
[ 0.506065] Mount-cache hash table entries: 512
[ 0.506702] Initializing cgroup subsys debug
[ 0.506716] Initializing cgroup subsys memory
[ 0.506743] Initializing cgroup subsys freezer
[ 0.506772] CPU: Testing write buffer coherency: ok
[ 0.507078] /cpus/cpu@0 missing clock-frequency property
[ 0.507092] /cpus/cpu@1 missing clock-frequency property
[ 0.507102] /cpus/cpu@2 missing clock-frequency property
[ 0.507112] /cpus/cpu@3 missing clock-frequency property
[ 0.507161] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.507213] Setting up static identity map for 0xc085f948 - 0xc085f9a0
[ 0.510364] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x1701 (version 3.1)
[ 0.583973] CPU1: Booted secondary processor
[ 0.584007] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.603647] CPU2: Booted secondary processor
[ 0.603670] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.623351] CPU3: Booted secondary processor
[ 0.623375] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.623474] Brought up 4 CPUs
[ 0.623504] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.623513] CPU: All CPU(s) started in SVC mode.
[ 0.624246] devtmpfs: initialized
[ 0.628590] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.629691] pinctrl core: initialized pinctrl subsystem
[ 0.629941] regulator-dummy: no parameters
[ 0.644060] NET: Registered protocol family 16
[ 0.645875] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.646192] ion_snapshot: 0x1ea90000 map to 0xe0907000 and copy to 0xc0ea0f4c (version 0.1)
[ 0.646418] Registered FIQ tty driver
[ 0.647681] console [ttyFIQ0] enabled
[ 0.647913] Registered fiq debugger ttyFIQ0
[ 0.648578] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[ 0.648603] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[ 0.648622] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 0.648642] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[ 0.648738] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 0.648807] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 0.648873] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 0.648939] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 0.649005] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 0.649071] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[ 0.649144] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 0.649213] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[ 0.649286] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 0.649355] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 0.649371] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 0.649385] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 0.649399] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 0.650022] rockchip_interrupts_register:bank_num=7
[ 0.651976] of_get_gpio_init_config:gpio[0] = 256, value = 0
[ 0.652000] of_get_gpio_init_config:gpio[1] = 6, value = 0
[ 0.652023] of_get_gpio_init_config:gpio[2] = 233, value = 1
[ 0.652046] of_get_gpio_init_config:gpio[3] = 234, value = 1
[ 0.652070] of_get_gpio_init_config:gpio[4] = 236, value = 1
[ 0.652093] of_get_gpio_init_config:gpio[5] = 238, value = 1
[ 0.652118] of_get_gpio_init_config:gpio[6] = 9, value = 0
[ 0.652143] of_get_gpio_init_config:gpio[7] = 235, value = 1
[ 0.652259] rockchip_pinctrl_probe:init ok
[ 0.659408] rk_iommu ff900800.iep_mmu: (iep) Enter
[ 0.659497] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.659513] rk_iommu ff900800.iep_mmu: (iep) Initialized
[ 0.659680] rk_iommu ff950800.vip_mmu: (vip) Enter
[ 0.659755] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.659771] rk_iommu ff950800.vip_mmu: (vip) Initialized
[ 0.659943] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[ 0.660011] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.660027] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[ 0.660191] rk_iommu ff940300.vopl_mmu: (vopl) Enter
[ 0.660265] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.660281] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[ 0.660461] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[ 0.660537] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.660553] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[ 0.660717] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[ 0.660794] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.660810] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[ 0.660989] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[ 0.661071] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.661087] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
[ 0.662805] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.662822] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.663426] rk3368_init_rockchip_pmu_ops: could not find pmu dt node
[ 0.663451] DDR DEBUG: version 1.00 20150126
[ 0.663480] DDR DEBUG: Channel a:
[ 0.663490] DDR DEBUG: DDR3 Device
[ 0.663505] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.663517] DDR DEBUG: Channel b:
[ 0.663525] DDR DEBUG: DDR3 Device
[ 0.663539] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.663551] DDR DEBUG: addr=0xdae000
[ 0.663562] DDR DEBUG: stride=9, size=256, halfcap=40000000
[ 0.663573] DDR DEBUG: socAddr[0]=0xdae000, socAddr[1]=0xdae100
[ 0.663584] DDR DEBUG: chAddr[0]=0xdae000, chAddr[1]=0xdae000
[ 0.663597] DDR DEBUG: dtar[0]=0x601b5000, dtar[1]=0x601b5000
[ 0.663656] DDR DEBUG: init success!!! freq=200MHz
[ 0.663666] DDR DEBUG: Channel a:
[ 0.663680] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.663696] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.663712] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.663728] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.663743] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.663754] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.663765] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.663775] DDR DEBUG: Channel b:
[ 0.663787] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.663803] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.663818] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.663834] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.663848] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.663860] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.663871] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.688079] bio: create slab at 0
[ 0.688620] Rockchip hdmi driver version 2.0
[ 0.689807] SCSI subsystem initialized
[ 0.689968] usbcore: registered new interface driver usbfs
[ 0.690018] usbcore: registered new interface driver hub
[ 0.690113] usbcore: registered new device driver usb
[ 0.692392] host_en_gpio= -2
[ 0.694899] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 0.695945] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
[ 0.696412] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
[ 0.696675] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 0.697488] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 0.697758] rockchip_i2c ff170000.i2c: i2c-5: Rockchip I2C adapter
[ 0.697881] media: Linux media interface: v0.10
[ 0.697930] Linux video capture interface: v2.00
[ 0.697990] pps_core: LinuxPPS API ver. 1 registered
[ 0.698002] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email]giometti@linux.it[/email]>
[ 0.698026] PTP clock support registered
[ 0.698091] i2c-core: driver [bq24296] using legacy suspend method
[ 0.698104] i2c-core: driver [bq24296] using legacy resume method
[ 0.698440] RK29 Watchdog Timer, (c) 2011 Rockchip Electronics
[ 0.699140] ion_drm_heap_create: 0@0
[ 0.699274] Rockchip ion module is successfully loaded (v1.1)
[ 0.699433] Advanced Linux Sound Architecture Driver Initialized.
[ 0.699817] Bluetooth: Core ver 2.16
[ 0.699857] NET: Registered protocol family 31
[ 0.699869] Bluetooth: HCI device and connection manager initialized
[ 0.699887] Bluetooth: HCI socket layer initialized
[ 0.699903] Bluetooth: L2CAP socket layer initialized
[ 0.699932] Bluetooth: SCO socket layer initialized
[ 0.700184] cfg80211: Calling CRDA to update world regulatory domain
[ 0.700841] act8846_i2c_probe,line=898
[ 0.702340] act8846 set 0xf4 error!
[ 0.702430] act8846: probe of 0-005a failed with error -11
[ 0.703206] The device is not syr82x fffffff5
[ 0.703225] syr82x: probe of 0-0040 failed with error -11
[ 0.703930] The device is not syr82x fffffff5
[ 0.703948] syr82x: probe of 0-0041 failed with error -11
[ 0.704416] rk808_i2c_probe,line=1355
[ 0.704924] rk808_pre_init,line=1224
[ 0.715048] rk808_i2c_probe: rk808_pmic_sleep=0
[ 0.721363] vdd_arm: 712 <--> 1500 mV at 1100 mV
[ 0.728128] vdd_gpu: 712 <--> 1500 mV at 1100 mV
[ 0.734736] rk_dcdc3: 1200 mV
[ 0.741492] vccio: 1800 <--> 3300 mV at 3300 mV
[ 0.747943] rk_ldo1: 3300 mV
[ 0.754371] rk_ldo2: 3300 mV
[ 0.760804] rk_ldo3: 1000 mV
[ 0.767236] rk_ldo4: 1800 mV
[ 0.773677] rk_ldo5: 3300 mV
[ 0.780135] rk_ldo6: 1800 mV
[ 0.786590] rk_ldo7: 1800 mV
[ 0.793030] rk_ldo8: 3300 mV
[ 0.793138] rk_battery_charger_detect_cb , battery_charger_detect 1
[ 0.796326] rk_ldo9: at 3300 mV
[ 0.799612] rk_ldo10: at 3300 mV
[ 0.802349] rk808_irq_init: rk808_pmic_irq=1
[ 0.802713] i2c-core: driver [rk818] using legacy suspend method
[ 0.802729] i2c-core: driver [rk818] using legacy resume method
[ 0.803115] rk808_rtc_probe,line=540
[ 0.820069] rk808-rtc rk808-rtc: rtc core: registered rk808 as rtc0
[ 0.823569] rk808_rtc_probe:ok
[ 0.825077] Switching to clocksource arch_sys_counter
[ 0.848831] rga: Module initialized.
[ 0.849559] rga2 ff920000.rga: rga ion client create success!
[ 0.849731] rga: Driver loaded succesfully
[ 0.849958] fb disp policy is sdk
[ 0.850003] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.850018] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.850289] prmry screen timing parse success
[ 0.850359] pwr_ctr_name:lcd_en
[ 0.850359] pwr_type:gpio
[ 0.850359] gpio:257
[ 0.850359] atv_val:1
[ 0.850359] delay:120
[ 0.850359]
[ 0.850397] pwr_ctr_name:bl_en
[ 0.850397] pwr_type:gpio
[ 0.850397] gpio:265
[ 0.850397] atv_val:1
[ 0.850397] delay:120
[ 0.850397]
[ 0.850432] prmry screen power ctrl parse success
[ 0.850499] extend screen timing parse success
[ 0.850548] pwr_ctr_name:lcd_en
[ 0.850548] pwr_type:gpio
[ 0.850548] gpio:264
[ 0.850548] atv_val:1
[ 0.850548] delay:120
[ 0.850548]
[ 0.850586] pwr_ctr_name:bl_en
[ 0.850586] pwr_type:gpio
[ 0.850586] gpio:3
[ 0.850586] atv_val:1
[ 0.850586] delay:120
[ 0.850586]
[ 0.850621] extend screen power ctrl parse success
[ 0.850635] rk-screen rk_screen.9: rockchip screen probe success
[ 0.850798] Use LVDS as extend screen
[ 0.850888] rk32-lvds rk32-lvds: rk32 lvds driver probe success
[ 0.851190] Use EDP as prmry screen
[ 0.851328] rk32-edp rk32-edp: failed to get reset
[ 0.851343] rk32-edp rk32-edp: failed to get reset
[ 0.851493] rk32-edp rk32-edp: rk32 edp driver probe success
[ 0.852208] graphics fb0: rockchip framebuffer registerd:fb0
[ 0.852531] graphics fb1: rockchip framebuffer registerd:fb1
[ 0.852708] graphics fb2: rockchip framebuffer registerd:fb2
[ 0.852888] graphics fb3: rockchip framebuffer registerd:fb3
[ 1.090568] rk3288-lcdc lcdc0: lcdc0: dclk:72000000>>fps:60
[ 1.090784] rk32-edp rk32-edp: edp pll locked
[ 1.091430] rk32-edp rk32-edp: ==========rk32_edp_read_byte_from_dpcd 0=
[ 1.091445] rk32-edp rk32-edp: =========rk32_edp_get_max_rx_bandwidth 0=
[ 1.092062] rk32-edp rk32-edp: =========rk32_edp_get_max_rx_lane_count 0=
[ 1.092077] rk32-edp rk32-edp: max link rate:2.70Gps max number of lanes:1
[ 1.096044] rk32-edp rk32-edp: link training success.
[ 1.148332] rk3288-lcdc lcdc0: wakeup from standby!
[ 1.169284] alloc_buffer:ion_phy_addr=0x10000000
[ 1.175081] fb0:phy:10000000>>vir:e0991000>>len:0xb00000
[ 1.175112] rk_iommu ff930300.vopb_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1ead4000
[ 1.175130] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
[ 1.175602] graphics fb4: rockchip framebuffer registerd:fb4
[ 1.175961] graphics fb5: rockchip framebuffer registerd:fb5
[ 1.176151] graphics fb6: rockchip framebuffer registerd:fb6
[ 1.176317] graphics fb7: rockchip framebuffer registerd:fb7
[ 1.176330] rk3288_lcdc_mmu_en,clk_on = 0
[ 1.176347] ion_phys: ion_phys is not implemented by this heap.
[ 1.176361] graphics fb4: ion map to get phy addr failed
[ 1.176385] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu enabled
[ 1.177330] rockchip_set_mux:warning ignore bank num 15
[ 1.177469] rockchip_set_mux:warning ignore bank num 15
[ 1.177587] rockchip_set_mux:warning ignore bank num 15
[ 1.177716] rockchip_set_mux:warning ignore bank num 15
[ 1.177831] rockchip_set_mux:warning ignore bank num 15
[ 1.177953] rockchip_set_mux:warning ignore bank num 15
[ 1.178914] rockchip_set_mux:warning ignore bank num 15
[ 1.179100] rockchip_set_mux:warning ignore bank num 15
[ 1.180038] rockchip_set_mux:warning ignore bank num 15
[ 1.180210] rockchip_set_mux:warning ignore bank num 15
[ 1.181138] rockchip_set_mux:warning ignore bank num 15
[ 1.181297] rockchip_set_mux:warning ignore bank num 15
[ 1.182260] rockchip_set_mux:warning ignore bank num 15
[ 1.182418] rockchip_set_mux:warning ignore bank num 15
[ 1.183973] NET: Registered protocol family 2
[ 1.184666] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 1.184750] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 1.184826] TCP: Hash tables configured (established 4096 bind 4096)
[ 1.184883] TCP: reno registered
[ 1.184899] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 1.184925] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 1.185117] NET: Registered protocol family 1
[ 1.185776] Unpacking initramfs...
[ 1.256575] Freeing initrd memory: 1304K (c5bf0000 - c5d36000)
[ 1.257353] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 1.257937] vcodec_service: probe device ff9a0000.vpu_service
[ 1.258193] vcodec_service: No reset resource define
[ 1.258369] vcodec_service: ff9a0000.vpu_service: power on
[ 1.258460] vcodec_service: probe device ff9a0000.vpu_service
[ 1.258479] vcodec_service: checking hw id 4831
[ 1.259494] vcodec_service: ff9a0000.vpu_service: power off...
[ 1.259542] vcodec_service: done
[ 1.259553] vcodec_service: init success
[ 1.259622] vcodec_service: probe device ff9c0000.hevc_service
[ 1.259963] vcodec_service: ff9c0000.hevc_service: power on
[ 1.260027] vcodec_service: probe device ff9c0000.hevc_service
[ 1.260043] vcodec_service: checking hw id 6867
[ 1.260626] vcodec_service: ff9c0000.hevc_service: power off...
[ 1.260670] vcodec_service: done
[ 1.260680] vcodec_service: init success
[ 1.260816] rknandbase v1.0 2014-03-31
[ 1.260955] rknand: probe of ff400000.nandc failed with error -1
[ 1.261067] rknand_driver:ret = 0
[ 1.263063] audit: initializing netlink socket (disabled)
[ 1.263110] type=2000 audit(0.760:1): initialized
[ 1.263919] bounce pool size: 64 pages
[ 1.268648] fuse init (API version 7.22)
[ 1.269038] msgmni has been set to 952
[ 1.270847] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.270869] io scheduler noop registered
[ 1.270880] io scheduler deadline registered
[ 1.270982] io scheduler cfq registered (default)
[ 1.271762] pwm-backlight backlight.24: unable to request PWM, trying legacy API
[ 1.272645] IEP Driver loaded succesfully
[ 1.272733] Module initialized.
[ 1.273530] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.273552] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 1.274877] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.274897] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.275209] pwm-voltage-regulator pwm_regulator.23: unable to request PWM, trying legacy API
[ 1.275227] pwm-voltage-regulator pwm_regulator.23: unable to request legacy PWM
[ 1.275240] pwm_regulator_probe:error
[ 1.275262] platform pwm_regulator.23: Driver pwm-voltage-regulator requests probe deferral
[ 1.275466] rk_serial.c v1.8 2014-03-04
[ 1.275706] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[ 1.275899] serial ff180000.serial: membase e1492000
[ 1.276065] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1
[ 1.276238] serial ff190000.serial: membase e14b2000
[ 1.276399] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90) is a rk29_serial.3
[ 1.276571] serial ff1b0000.serial: membase e14c4000
[ 1.279469] loop: module loaded
[ 1.279829] zram: Created 1 device(s) ...
[ 1.280010] i2c i2c-1: mpu_probe: 0
[ 1.280159] 6mldl_cfg:Reset MPU6050 B1
[ 1.281154] drivers/misc/inv_mpu/mlsl-kernel.c|inv_i2c_write|48 returning -11
[ 1.281171] drivers/misc/inv_mpu/mldl_cfg.c|mpu60xx_pwr_mgmt|574 returning -11
[ 1.281185] drivers/misc/inv_mpu/mldl_cfg.c|inv_mpu_open|1472 returning -11
[ 1.281201] i2c i2c-1: Unable to open mpu6050B1 -11
[ 1.281216] i2c i2c-1: mpu_probe failed -19
[ 1.281266] i2c-core: driver [mpu6050B1] using legacy suspend method
[ 1.281279] i2c-core: driver [mpu6050B1] using legacy resume method
[ 1.281299] mpu_init: Probe name mpu6050B1
[ 1.281471] ak8963_mod_init: Probe name ak8963_mod
[ 1.282217] SCSI Media Changer driver v0.25
[ 1.282464] dws->regs: e14c6000
[ 1.283645] rockchip_spi_probe:num_cs=2,bus_num=0,irq=76,freq=45692308 ok
[ 1.283946] tun: Universal TUN/TAP device driver, 1.6
[ 1.283960] tun: (C) 1999-2004 Max Krasnyansky <[email]maxk@qualcomm.com[/email]>
[ 1.284083] vmac_init.
[ 1.284659] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 1.284675] stmmac_probe_config_dt: clock input/output? (input).
[ 1.284688] stmmac_probe_config_dt: TX delay(0x1d).
[ 1.284700] stmmac_probe_config_dt: RX delay(0x16).
[ 1.284749] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[ 1.284760] stmmc_pltfr_init:
[ 1.284769] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[ 1.284787] stmmc_pltfr_init: init for RGMII
[ 1.284798] tx delay=0x1d
[ 1.284798] rx delay=0x16
[ 1.284814] tx delay=0x1d
[ 1.284814] rx delay=0x16
[ 1.285275] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.285287] Normal descriptors
[ 1.285295] Ring mode enabled
[ 1.285306] DMA HW capability register supported
[ 1.285318] RX Checksum Offload Engine supported (type 2)
[ 1.285329] TX Checksum insertion supported
[ 1.285338] Wake-Up On Lan supported
[ 1.285374] Enable RX Mitigation via HW Watchdog Timer
[ 1.285810] PPP generic driver version 2.4.2
[ 1.285968] PPP BSD Compression module registered
[ 1.285982] PPP Deflate Compression module registered
[ 1.286006] PPP MPPE Compression module registered
[ 1.286019] NET: Registered protocol family 24
[ 1.286056] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.286070] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.286084] Rockchip WiFi SYS interface (V1.00) ...
[ 1.286117] esp_mem_init enter date Nov 21 2019 08:48:15
[ 1.286128] esp_mem_init VERSION [V2.5]
[ 1.286173] esp_mem_init complete
[ 1.286258] usbcore: registered new interface driver catc
[ 1.286299] usbcore: registered new interface driver kaweth
[ 1.286313] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.286360] usbcore: registered new interface driver pegasus
[ 1.286402] usbcore: registered new interface driver rtl8150
[ 1.286442] usbcore: registered new interface driver r8152
[ 1.286454] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.286523] usbcore: registered new interface driver hso
[ 1.286569] usbcore: registered new interface driver asix
[ 1.286608] usbcore: registered new interface driver ax88179_178a
[ 1.286653] usbcore: registered new interface driver cdc_ether
[ 1.286693] usbcore: registered new interface driver cdc_eem
[ 1.286732] usbcore: registered new interface driver dm9601
[ 1.286769] usbcore: registered new interface driver dm9620
[ 1.286817] usbcore: registered new interface driver smsc75xx
[ 1.286863] usbcore: registered new interface driver smsc95xx
[ 1.286908] usbcore: registered new interface driver gl620a
[ 1.286949] usbcore: registered new interface driver net1080
[ 1.286988] usbcore: registered new interface driver plusb
[ 1.287028] usbcore: registered new interface driver rndis_host
[ 1.287068] usbcore: registered new interface driver cdc_subset
[ 1.287106] usbcore: registered new interface driver zaurus
[ 1.287147] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.287212] usbcore: registered new interface driver int51x1
[ 1.287259] usbcore: registered new interface driver kalmia
[ 1.287300] usbcore: registered new interface driver ipheth
[ 1.287346] usbcore: registered new interface driver sierra_net
[ 1.287387] usbcore: registered new interface driver cx82310_eth
[ 1.287435] usbcore: registered new interface driver cdc_ncm
[ 1.287476] usbcore: registered new interface driver qmi_wwan
[ 1.287521] usbcore: registered new interface driver cdc_mbim
[ 1.287534] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.290009] EHCI: ehci_rk_probe e1500000 e1500010
[ 1.290028] rockchip_ehci_host ff500000.usb: EHCI Host Controller
[ 1.290059] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[ 1.290369] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
[ 1.307327] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00
[ 1.307429] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.307448] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.307462] usb usb1: Product: EHCI Host Controller
[ 1.307475] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 1.307488] usb usb1: SerialNumber: ff500000.usb
[ 1.307962] hub 1-0:1.0: USB hub found
[ 1.307987] hub 1-0:1.0: 1 port detected
[ 1.308162] EHCI: ehci_rk_probe ok
[ 1.308270] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.308536] ohci-rockchip ff520000.usb: RK OHCI Host Controller
[ 1.308564] ohci-rockchip ff520000.usb: new USB bus registered, assigned bus number 2
[ 1.308608] ohci-rockchip ff520000.usb: irq 73, io mem 0xff520000
[ 1.370350] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.370369] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.370385] usb usb2: Product: RK OHCI Host Controller
[ 1.370399] usb usb2: Manufacturer: Linux 3.10.0 ohci_hcd
[ 1.370412] usb usb2: SerialNumber: ff520000.usb
[ 1.370827] hub 2-0:1.0: USB hub found
[ 1.370852] hub 2-0:1.0: 1 port detected
[ 1.371180] usbcore: registered new interface driver cdc_acm
[ 1.371193] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.371252] usbcore: registered new interface driver usblp
[ 1.371297] usbcore: registered new interface driver cdc_wdm
[ 1.371374] usbcore: registered new interface driver usb-storage
[ 1.371435] usbcore: registered new interface driver ums-alauda
[ 1.371485] usbcore: registered new interface driver ums-cypress
[ 1.371527] usbcore: registered new interface driver ums-datafab
[ 1.371567] usbcore: registered new interface driver ums_eneub6250
[ 1.371608] usbcore: registered new interface driver ums-freecom
[ 1.371648] usbcore: registered new interface driver ums-isd200
[ 1.371689] usbcore: registered new interface driver ums-jumpshot
[ 1.371730] usbcore: registered new interface driver ums-karma
[ 1.371771] usbcore: registered new interface driver ums-onetouch
[ 1.371812] usbcore: registered new interface driver ums-sddr09
[ 1.371854] usbcore: registered new interface driver ums-sddr55
[ 1.371895] usbcore: registered new interface driver ums-usbat
[ 1.371994] usbcore: registered new interface driver usbserial
[ 1.372037] usbcore: registered new interface driver usbserial_generic
[ 1.372071] usbserial: USB Serial support registered for generic
[ 1.372114] usbcore: registered new interface driver ch341
[ 1.372146] usbserial: USB Serial support registered for ch341-uart
[ 1.372190] usbcore: registered new interface driver cp210x
[ 1.372221] usbserial: USB Serial support registered for cp210x
[ 1.372273] usbcore: registered new interface driver option
[ 1.372311] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.372409] usbcore: registered new interface driver pl2303
[ 1.372441] usbserial: USB Serial support registered for pl2303
[ 1.372512] usbcore: registered new interface driver trancevibrator
[ 1.372525] usb20_otg: version 3.10a 21-DEC-2012
[ 1.372953] e1580040
[ 1.372966] Core Release: 3.10a
[ 1.372977] Setting default values for core params
[ 1.373113] Using Buffer DMA mode
[ 1.373125] Periodic Transfer Interrupt Enhancement - disabled
[ 1.373136] Multiprocessor Interrupt Enhancement - disabled
[ 1.373148] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.373159] ^^^^^^^^^^^^^^^^^Device Mode
[ 1.373172] Dedicated Tx FIFOs mode
[ 1.373192] pcd_init otg_dev = ddf9c900
[ 1.373347] usb20_otg ff580000.usb: DWC OTG Controller
[ 1.373377] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 3
[ 1.373406] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 1.373466] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.373482] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.373497] usb usb3: Product: DWC OTG Controller
[ 1.373511] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 1.373524] usb usb3: SerialNumber: ff580000.usb
[ 1.373911] hub 3-0:1.0: USB hub found
[ 1.373935] hub 3-0:1.0: 1 port detected
[ 1.374237] usb20_host: version 3.10a 21-DEC-2012
[ 1.376788] e1600040
[ 1.376801] Core Release: 3.10a
[ 1.376812] Setting default values for core params
[ 1.376926] Using Buffer DMA mode
[ 1.376938] Periodic Transfer Interrupt Enhancement - disabled
[ 1.376949] Multiprocessor Interrupt Enhancement - disabled
[ 1.376960] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.376971] ^^^^^^^^^^^^^^^^^^Host Mode
[ 1.376997] usb20_host ff540000.usb: DWC OTG Controller
[ 1.377024] usb20_host ff540000.usb: new USB bus registered, assigned bus number 4
[ 1.377056] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[ 1.377150] Init: Power Port (0)
[ 1.377212] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.377228] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.377243] usb usb4: Product: DWC OTG Controller
[ 1.377256] usb usb4: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 1.377268] usb usb4: SerialNumber: ff540000.usb
[ 1.377651] hub 4-0:1.0: USB hub found
[ 1.377674] hub 4-0:1.0: 1 port detected
[ 1.378366] usbcore: registered new interface driver xpad
[ 1.378430] usbcore: registered new interface driver usb_acecad
[ 1.378479] usbcore: registered new interface driver aiptek
[ 1.378526] usbcore: registered new interface driver gtco
[ 1.378572] usbcore: registered new interface driver hanwang
[ 1.378618] usbcore: registered new interface driver kbtab
[ 1.378674] usbcore: registered new interface driver wacom
[ 1.378807] ==gsl_ts_init==
[ 1.378874] GSLX680 Enter gsl_ts_probe
[ 1.622201] usb 1-1: new high-speed USB device number 2 using rockchip_ehci_host
[ 1.770360] usb 1-1: New USB device found, idVendor=1a40, idProduct=0801
[ 1.770379] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.770394] usb 1-1: Product: USB 2.0 Hub
[ 1.770843] hub 1-1:1.0: USB hub found
[ 1.770973] hub 1-1:1.0: 4 ports detected
[ 1.917382] gsl_ts_probe--1318, i2c_master_recv fail
[ 1.917405] gslX680: probe of 1-0040 failed with error -11
[ 1.917459] GSLX680 Enter gsl_ts_probe
[ 2.045389] usb 1-1.2: new high-speed USB device number 3 using rockchip_ehci_host
[ 2.156456] usb 1-1.2: New USB device found, idVendor=05e3, idProduct=0610
[ 2.156475] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.156490] usb 1-1.2: Product: USB2.0 Hub
[ 2.156503] usb 1-1.2: Manufacturer: GenesysLogic
[ 2.157303] hub 1-1.2:1.0: USB hub found
[ 2.157808] hub 1-1.2:1.0: 4 ports detected
[ 2.458587] gsl_ts_probe--1318, i2c_master_recv fail
[ 2.458610] gslX680: probe of 1-0041 failed with error -11
[ 2.458662] ret=0
[ 2.458950] sensor_register_slave:mma8452,id=17
[ 2.458965] sensor_register_slave:gs_mc3230,id=23
[ 2.458975] gsensor_init
[ 2.458986] sensor_register_slave:mpu6880_acc,id=24
[ 2.458998] sensor_register_slave:mpu6500_acc,id=25
[ 2.459010] sensor_register_slave:cm3217,id=48
[ 2.459020] sensor_register_slave:cm3218,id=49
[ 2.459265] .. rk pwm remotectl v1.1 init
[ 2.459528] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
[ 2.464510] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc1
[ 2.465117] i2c /dev entries driver
[ 2.465945] IR NEC protocol handler initialized
[ 2.465958] IR RC5(x) protocol handler initialized
[ 2.465968] IR RC6 protocol handler initialized
[ 2.465978] IR JVC protocol handler initialized
[ 2.465988] IR Sony protocol handler initialized
[ 2.465998] IR RC5 (streamzap) protocol handler initialized
[ 2.466009] IR SANYO protocol handler initialized
[ 2.466019] IR MCE Keyboard/mouse protocol handler initialized
[ 2.466192] usbcore: registered new interface driver uvcvideo
[ 2.466205] USB Video Class driver (1.1.1)
[ 2.466218] CamSys driver version: v0.32.0, CamSys head file version: v0.11.0
[ 2.467732] D1:camsys_platform_probe(1300): 1-gpios-cifpower: gpio=236
[ 2.467757] D1:camsys_platform_probe(1303): gpios-cifpower: gpio_request
[ 2.467781] D1:camsys_platform_probe(1305): 1-gpios-cifpower: gpio_request=-16
[ 2.467794] E:camsys_platform_probe(1308): Request cifpower(236) failed
[ 2.467834] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288
[ 2.467834]
[ 2.467910] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 2.468076] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe14d8000 size: 0x4000)
[ 2.468786] D1:camsys_platform_probe(1446): ff910000.isp memory:
[ 2.468805] D1:camsys_platform_probe(1456): Register memory (phy: 0xff910000 vir: 0xe15e0000 size: 0x10000)
[ 2.468821] D1:camsys_platform_probe(1451): I2c memory (phy: 0x1dfc4000 vir: 0xddfc4000 size: 0x1000)
[ 2.468836] D1:camsys_init_ext_fsh_module(20): init external flash module
[ 2.468848] D1:camsys_platform_probe(1471): Probe ff910000.isp device success
[ 2.468895] usb 1-1.2.3: new high-speed USB device number 6 using rockchip_ehci_host
[ 2.469313] not find test_power_init dev node
[ 2.469384] i2c-core: driver [bq27320] using legacy suspend method
[ 2.469396] i2c-core: driver [bq27320] using legacy resume method
[ 2.469759] rockchip_temp_probe,line=364
[ 2.527464] tsadc ff280000.tsadc: initialized
[ 2.527874] device-mapper: uevent: version 1.0.3
[ 2.528123] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: [email]dm-devel@redhat.com[/email]
[ 2.528411] Bluetooth: HCI UART driver ver 2.2
[ 2.528427] Bluetooth: HCI H4 protocol initialized
[ 2.528439] Bluetooth: HCILL protocol initialized
[ 2.528450] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21
[ 2.528463] rtk_btusb: Register usb char device interface for BT driver
[ 2.528650] usbcore: registered new interface driver rtk_btusb
[ 2.528713] DVFS ERR: clk_enable_dvfs: vd(vd_logic) can't get regulator(vdd_logic)!
[ 2.532620] DVFS ERR: clk_enable_dvfs: vd(vd_logic) can't get regulator(vdd_logic)!
[ 2.536479] cpufreq version 1.0, suspend freq 1200 MHz
[ 2.536675] cpuidle: using governor ladder
[ 2.536689] cpuidle: using governor menu
[ 2.536725] Synopsys Designware Multimedia Card Interface Driver
[ 2.536736] MHSC version = Ver 2.00 2015-06-10
[ 2.537059] dw cru_regsbase addr 0x1d8.
[ 2.537072] dw cru_reset_offset val 3.
[ 2.537087] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[ 2.537133] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc
[ 2.537457] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
[ 2.537622] dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
[ 2.537746] 1358..dw_mci_set_ios: no card. [mmc0]
[ 2.556980] 1358..dw_mci_set_ios: no card. [mmc0]
[ 2.576723] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 2.576752] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
[ 2.576771] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[ 2.577164] dw cru_regsbase addr 0x1d8.
[ 2.577177] dw cru_reset_offset val 0.
[ 2.577192] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[ 2.577253] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc
[ 2.577877] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
[ 2.578371] dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
[ 2.578472] usb 1-1.2.3: New USB device found, idVendor=12d1, idProduct=107e
[ 2.578477] mmc1: no vmmc regulator found
[ 2.578493] usb 1-1.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.578504] usb 1-1.2.3: Product: EML-AL00
[ 2.578513] usb 1-1.2.3: Manufacturer: HUAWEI
[ 2.578522] usb 1-1.2.3: SerialNumber: CLB7N18322006718
[ 2.578577] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
[ 2.578668] 1358..dw_mci_set_ios: no card. [mmc1]
[ 2.580664] usb-storage 1-1.2.3:1.1: USB Mass Storage device detected
[ 2.581037] transfer actual length=31, result=0
[ 2.581088] scsi0 : usb-storage 1-1.2.3:1.1
[ 2.596341] 1358..dw_mci_set_ios: no card. [mmc1]
[ 2.608802] mmc0: BKOPS_EN bit is not set
[ 2.610672] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0]
[ 2.612962] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 2.612984] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 2.613009] [mmc0] tuning regsbase addr 0x218.
[ 2.613652] [mmc0] Data transmission error !!!! MINTSTS: [0x00002000]
[ 2.613662] [mmc0] host was already tuning, Don't need to retry tune again ignore 0.
[ 2.613683] dwmmc_rockchip ff0f0000.rksdmmc: data FIFO error (status=00002000)
[ 2.613710] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-5
[ 2.613733] [mmc0] Data transmission error !!!! MINTSTS: [0x00000088]
[ 2.613742] [mmc0] host was already tuning, Don't need to retry tune again ignore 0.
[ 2.613770] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 2.613793] [mmc0] Data transmissioheer@fr ef!!:/MINTSTS: [0x00000080]
[ 2.613802] [mmc0] host was already tuning, Don't need to retry tune again ignore 0.
[ 2.613831] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 2.613855] [mmc0] Data transmission error !!!! MINTSTS: [0x00000080]
[ 2.613863] [mmc0] host was already tuning, Don't need to retry tune again ignore 0.
[ 2.613891] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 2.613913] [mmc0] Data transmission error !!!! MINTSTS: [0x00002046]
[ 2.613922] [mmc0] host was already tuning, Don't need to retry tune again ignore 0.
[ 2.613950] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 2.613963] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-225 (21 len)
[ 2.613974] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-225 (21 len)
[ 2.613983] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 113
[ 2.614027] mmc0: new HS200 MMC card at address 0001
[ 2.614301] mmcblk0: mmc0:0001 8GTF4R 7.28 GiB
[ 2.614615] uboot: 0x000400000 -- 0x000800000 (4 MB)
[ 2.614626] misc: 0x000800000 -- 0x000c00000 (4 MB)
[ 2.614635] resource: 0x000c00000 -- 0x001c00000 (16 MB)
[ 2.614644] kernel: 0x001c00000 -- 0x002c00000 (16 MB)
[ 2.614652] boot: 0x002c00000 -- 0x004c00000 (32 MB)
[ 2.614661] recovery: 0x004c00000 -- 0x006c00000 (32 MB)
[ 2.614670] backup: 0x006c00000 -- 0x00a000000 (52 MB)
[ 2.614678] cache: 0x00a000000 -- 0x012000000 (128 MB)
[ 2.614686] kpanic: 0x012000000 -- 0x012400000 (4 MB)
[ 2.614695] system: 0x012400000 -- 0x072400000 (1536 MB)
[ 2.614703] metadata: 0x072400000 -- 0x073400000 (16 MB)
[ 2.614711] baseparamer: 0x073400000 -- 0x073800000 (4 MB)
[ 2.614720] userdata: 0x077800000 -- 0x1d1c00000 (5540 MB)
[ 2.614749] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p131358..dw_mci_set_ios: no card. [mmc1]
[ 2.616081] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
[ 2.616093] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
[ 2.616442] dw cru_regsbase addr 0x1d8.
[ 2.616452] dw cru_reset_offset val 1.
[ 2.616462] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[ 2.616505] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc
[ 2.616757] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
[ 2.616887] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
[ 2.617136] 1358..dw_mci_set_ios: no card. [mmc2]
[ 2.635709] 1358..dw_mci_set_ios: no card. [mmc2]
[ 2.655405] 1358..dw_mci_set_ios: no card. [mmc2]
[ 2.655444] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
[ 2.655457] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[ 2.655765] leds-gpio leds.29: pins are not configured from the driver
[ 2.656001] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.657493] usbcore: registered new interface driver usbhid
[ 2.657504] usbhid: USB HID core driver
[ 2.657609] ashmem: initialized
[ 2.657727] logger: created 256K log 'log_main'
[ 2.657822] logger: created 256K log 'log_events'
[ 2.657913] logger: created 256K log 'log_radio'
[ 2.658006] logger: created 256K log 'log_system'
[ 2.659133] input: rk29-keypad as /devices/ff100000.adc/key.31/input/input1
[ 2.659998] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ff890000.rockchip-i2s; cannot claim for 2-0010
[ 2.660017] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
[ 2.660029] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl
[ 2.660040] ES8323 2-0010: Error applying setting, reverse things back
[ 2.660087] es8323_adc = 0
[ 2.660099] jp es8323_line_det_gpio:-1
[ 2.660353] es8323 probe i2c recv ok
[ 2.661256] rockchip-spdif ff880000.rockchip-spdif: spdif ready.
[ 2.661863] es8323_probe
[ 3.088670] usb 1-1.2.4: new low-speed USB device number 7 using rockchip_ehci_host
[ 3.201581] usb 1-1.2.4: New USB device found, idVendor=1bcf, idProduct=0007
[ 3.201595] usb 1-1.2.4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 3.201606] usb 1-1.2.4: Product: USB Optical Mouse
[ 3.208645] input: USB Optical Mouse as /devices/ff500000.usb/usb1/1-1/1-1.2/1-1.2.4/1-1.2.4:1.0/input/input2
[ 3.208968] hid-generic 0003:1BCF:0007.0001: input,hiddev0,hidraw0: USB HID v1.10 Mouse [USB Optical Mouse] on usb-ff500000.usb-1.2.4/input0
[ 3.295444] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> NULL --> Left Line Mux
[ 3.295460] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> NULL -> Left Line Mux
[ 3.295475] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> NULL --> Left Line Mux
[ 3.295485] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> NULL -> Left Line Mux
[ 3.295498] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux --> NULL --> Left Line Mux
[ 3.295508] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux -> NULL -> Left Line Mux
[ 3.295521] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> NULL --> Right Line Mux
[ 3.295531] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> NULL -> Right Line Mux
[ 3.295542] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> NULL --> Right Line Mux
[ 3.295552] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> NULL -> Right Line Mux
[ 3.295564] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux --> NULL --> Right Line Mux
[ 3.295574] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux -> NULL -> Right Line Mux
[ 3.295586] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> LAMP --> Left PGA Mux
[ 3.295596] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> LAMP -> Left PGA Mux
[ 3.295607] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> LAMP --> Left PGA Mux
[ 3.295617] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> LAMP -> Left PGA Mux
[ 3.295628] ES8323 2-0010: ASoC: no dapm match for Differential Mux --> LAMP --> Left PGA Mux
[ 3.295638] ES8323 2-0010: ASoC: Failed to add route Differential Mux -> LAMP -> Left PGA Mux
[ 3.295662] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> RAMP --> Right PGA Mux
[ 3.295673] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> RAMP -> Right PGA Mux
[ 3.295685] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> RAMP --> Right PGA Mux
[ 3.295695] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> RAMP -> Right PGA Mux
[ 3.295707] ES8323 2-0010: ASoC: no dapm match for Differential Mux --> RAMP --> Right PGA Mux
[ 3.295717] ES8323 2-0010: ASoC: Failed to add route Differential Mux -> RAMP -> Right PGA Mux
[ 3.295729] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> LAMP --> Differential Mux
[ 3.295739] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> LAMP -> Differential Mux
[ 3.295751] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> RAMP --> Differential Mux
[ 3.295762] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> RAMP -> Differential Mux
[ 3.295773] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> LAMP --> Differential Mux
[ 3.295783] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> LAMP -> Differential Mux
[ 3.295795] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> RAMP --> Differential Mux
[ 3.295805] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> RAMP -> Differential Mux
[ 3.295866] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> LAMP --> Left Line Mux
[ 3.295877] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> LAMP -> Left Line Mux
[ 3.295889] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> LAMP --> Left Line Mux
[ 3.295900] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> LAMP -> Left Line Mux
[ 3.295912] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux --> LAMP --> Left Line Mux
[ 3.295923] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux -> LAMP -> Left Line Mux
[ 3.295935] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> RAMP --> Right Line Mux
[ 3.295945] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> RAMP -> Right Line Mux
[ 3.295957] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> RAMP --> Right Line Mux
[ 3.295966] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> RAMP -> Right Line Mux
[ 3.295978] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux --> RAMP --> Right Line Mux
[ 3.295988] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux -> RAMP -> Right Line Mux
[ 3.296165] ES8323 2-0010: ASoC: mux Right Line Mux has no paths
[ 3.296180] ES8323 2-0010: ASoC: mux Left Line Mux has no paths
[ 3.296194] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths
[ 3.296207] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths
[ 3.296236] ES8323 2-0010: ASoC: mux Differential Mux has no paths
[ 3.303623] rockchip-es8323 rockchip-es8323.27: ES8323 HiFi <-> ff890000.rockchip-i2s mapping ok
[ 3.304113] input: RK_ES8323 Headphone Jack as /devices/rockchip-es8323.27/sound/card0/input3
[ 3.304640] u32 classifier
[ 3.304650] Actions configured
[ 3.304663] Netfilter messages via NETLINK v0.30.
[ 3.304719] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 3.305108] ctnetlink v0.93: registering with nfnetlink.
[ 3.305177] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 3.305186] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 3.305453] xt_time: kernel timezone is -0000
[ 3.305656] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.305800] arp_tables: (C) 2002 David S. Miller
[ 3.305839] TCP: cubic registered
[ 3.305846] Initializing XFRM netlink socket
[ 3.306082] NET: Registered protocol family 10
[ 3.306616] mip6: Mobile IPv6
[ 3.306645] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.306775] sit: IPv6 over IPv4 tunneling driver
[ 3.307104] NET: Registered protocol family 17
[ 3.307129] NET: Registered protocol family 15
[ 3.307195] Bridge firewalling registered
[ 3.307208] Ebtables v2.0 registered
[ 3.307371] Bluetooth: RFCOMM TTY layer initialized
[ 3.307403] Bluetooth: RFCOMM socket layer initialized
[ 3.307412] Bluetooth: RFCOMM ver 1.11
[ 3.307420] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.307427] Bluetooth: BNEP filters: protocol multicast
[ 3.307440] Bluetooth: BNEP socket layer initialized
[ 3.307448] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.307460] Bluetooth: HIDP socket layer initialized
[ 3.307487] l2tp_core: L2TP core driver, V2.0
[ 3.307503] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 3.307511] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 3.307742] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 3.307754] [WLAN_RFKILL]: can't find rockchip,grf property
[ 3.307764] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6212
[ 3.307773] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 3.307783] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 3.307793] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 3.307818] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
[ 3.307841] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
[ 3.307854] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 3.307882] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
[ 3.307892] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 3.307935] [BT_RFKILL]: Enter rfkill_rk_init
[ 3.308095] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
[ 3.308114] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155.
[ 3.308130] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
[ 3.308146] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
[ 3.308161] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
[ 3.308214] [BT_RFKILL]: Request irq for bt wakeup host
[ 3.308318] [BT_RFKILL]: ** disable irq
[ 3.308395] [BT_RFKILL]: ap6212 device registered.
[ 3.309255] rk3288_init_suspend
[ 3.309270] rk3288_suspend_init enter
[ 3.309490] rk3288_suspend_init: pm_ctrbits =200005
[ 3.309525] gpio_get_dts_info suspend:4
[ 3.309533] gpio_get_dts_info resume:4
[ 3.309540] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 3.309573] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 3.309737] clks_gating_suspend_init:clkgt info ok
[ 3.309835] Registering SWP/SWPB emulation handler
[ 3.315534] DVFS ERR: clk_enable_dvfs: vd(vd_logic) can't get regulator(vdd_logic)!
[ 3.316048] ddrfreq: verion 1.2 20140526
[ 3.316062] ddrfreq: normal 528MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 528MHz
[ 3.316071] ddrfreq: auto-freq=0
[ 3.316078] ddrfreq: auto-freq-table[0] 240MHz
[ 3.316085] ddrfreq: auto-freq-table[1] 324MHz
[ 3.316091] ddrfreq: auto-freq-table[2] 456MHz
[ 3.316098] ddrfreq: auto-freq-table[3] 528MHz
[ 3.319044] regulator-dummy: disabling
[ 3.319398] =======================================================
[ 3.319410] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 3.319418] =======================================================
[ 3.319426] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init.
[ 3.319498] dhd_module_init: in
[ 3.319509] ======== dhd_wlan_init_plat_data ========
[ 3.319518] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[ 3.319525] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[ 3.319534] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 3.319562] dhd_wlan_init_gpio: host_oob_irq: 200
[ 3.319569] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[ 3.319576] dhd_wifi_platform_load: Enter
[ 3.319585] pcd_pullup, is_on 0
[ 3.319598] Power-up adapter 'DHD generic adapter'
[ 3.319627] wifi_platform_set_power = 1
[ 3.319635] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 3.319639] file system registered
[ 3.319650] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 3.319660] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
[ 3.319667] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 3.320367] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 3.320379] android_usb gadget: Number of LUNs=2
[ 3.320389] lun0: LUN: removable file: (no medium)
[ 3.320397] lun1: LUN: removable file: (no medium)
[ 3.320589] android_usb gadget: android_usb ready
[ 3.320726] sensor_init: Probe name sensors
[ 3.320750] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 3.324890] rk808-rtc rk808-rtc: setting system clock to 2013-01-21 08:50:07 UTC (1358758207)
[ 3.332234] rockchip-spdif-card rockchip-spdif-card.25: ASoC: CODEC (null) not registered
[ 3.332282] rockchip_spdif_card_probe() register card failed:-517
[ 3.332303] platform rockchip-spdif-card.25: Driver rockchip-spdif-card requests probe deferral
[ 3.332912] usbcore: registered new interface driver snd-usb-audio
[ 3.332923] ALSA device list:
[ 3.332931] #0: RK_ES8323
[ 3.333322] Freeing unused kernel memory: 356K (c0bb8000 - c0c11000)
[ 3.354087] dwc_otg_hcd_enable, enable host controller
[ 3.422915] [WLAN_RFKILL]: wifi turn on power. 156
[ 3.436686] type=1403 audit(1358758207.600:2): policy loaded auid=4294967295 ses=4294967295
[ 3.440124] init: SELinux: Unknown value of ro.boot.selinux. Got: "0". Assuming enforcing.
[ 3.440231] type=1404 audit(1358758207.600:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
[ 3.457602] Using Buffer DMA mode
[ 3.457613] Periodic Transfer Interrupt Enhancement - disabled
[ 3.457618] Multiprocessor Interrupt Enhancement - disabled
[ 3.457625] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.457631] ^^^^^^^^^^^^^^^^^^Host Mode
[ 3.501732] Init: Power Port (0)
[ 3.573808] init: invalid gid 'trace'
[ 3.611626] type=1400 audit(1358758207.780:4): avc: denied { write } for pid=133 comm="ueventd" name="/" dev="rootfs" ino=1 scontext=u:r:ueventd:s0 tcontext=u:object_r:rootfs:s0 tclass=dir permissive=0
[ 3.629590] wifi_platform_bus_enumerate device present 1
[ 3.629604] ======== Card detection to detect SDIO card! ========
[ 3.629612] mmc2:mmc host rescan start!
[ 3.649452] usb 1-1.2.3: reset high-speed USB device number 6 using rockchip_ehci_host
[ 3.672361] init: /dev/hw_random not found
[ 3.672436] keychord: using input dev ff680000.pwm for fevent
[ 3.672448] keychord: using input dev rk29-keypad for fevent
[ 3.677627] init: /dev/hw_random not found
[ 3.678718] fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
[ 3.679930] resize2fs: resize2fs 1.42.9 (28-Dec-2013)resize2fs: The filesystem is already 393216 blocks long. Nothing to do!resize2fs:
[ 3.682582] EXT4-fs (mmcblk0p10): Ignoring removed nomblk_io_submit option
[ 3.686834] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 3.686960] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/system,/system,ext4)=0
[ 3.687852] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
[ 3.693310] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 3.693368] e2fsck: system: clean, 1928/86592 files, 118001/393216 blocks
[ 3.696917] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 3.697003] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/system,target=/system,type=ext4)=0
[ 3.703791] EXT4-fs (mmcblk0p8): recovery complete
[ 3.704180] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 3.704245] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/cache,target=/cache,type=ext4)=0
[ 3.704592] EXT4-fs (mmcblk0p11): Ignoring removed nomblk_io_submit option
[ 3.707943] EXT4-fs (mmcblk0p11): recovery complete
[ 3.707953] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 3.708009] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,/metadata,ext4)=0
[ 3.708771] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata
[ 3.713388] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 3.713429] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata: clean, 11/1024 files, 1102/4096 blocks
[ 3.717255] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 3.717331] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,target=/metadata,type=ext4)=0
[ 3.717379] fs_mgr: Running /system/bin/fsck.f2fs -f /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
[ 3.718413] fsck.f2fs: executing /system/bin/fsck.f2fs failed: No such file or directory
[ 3.718456] fsck.f2fs: fsck.f2fs terminated by exit(255)
[ 3.718747] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=f2fs)=-1
[ 3.719096] EXT4-fs (mmcblk0p13): Ignoring removed nomblk_io_submit option
[ 3.779119] scsi 0:0:0:0: CD-ROM Linux File-CD Gadget 0409 PQ: 0 ANSI: 2
[ 3.779850] scsi 0:0:0:0: Attached scsi generic sg0 type 5
[ 3.846048] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2]
[ 3.865523] EXT4-fs (mmcblk0p13): recovery complete
[ 3.865987] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 3.866096] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,/data,ext4)=0
[ 3.868982] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
[ 3.876908] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 3.876950] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata: clean, 791/354816 files, 145826/1418240 blocks
[ 3.881018] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard,errors=panic
[ 3.881093] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=ext4)=0
[ 3.881110] fs_mgr: mount_with_alternatives(): Mounted /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata on /data with fs_type=ext4 instead of f2fs
[ 3.881555] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 3.883109] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.884679] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.887413] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 3.890719] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
[ 3.898287] arm_release_ver of this mali_ko is 'r6p0-02rel0', rk_ko_ver is '13', built at '09:15:10', on 'Oct 22 2015'.
[ 3.898415] mali ffa30000.gpu: Continuing without Mali clock control
[ 3.898460] mali pd enabled
[ 3.898471] clk enabled
[ 3.898484] MALI_DVFS_STEP = 4, div_dvfs = 10
[ 3.898491] mali_dvfs_infotbl[0].clock=198000,min_threshold=0,max_threshold=70
[ 3.898498] mali_dvfs_infotbl[1].clock=297000,min_threshold=70,max_threshold=80
[ 3.898506] mali_dvfs_infotbl[2].clock=417000,min_threshold=80,max_threshold=90
[ 3.898512] mali_dvfs_infotbl[3].clock=480000,min_threshold=94,max_threshold=100
[ 3.898640] turn on mali power
[ 3.898653] kbase_platform_rk_init,register_reboot_notifier
[ 3.898701] hrtimer: interrupt took 13708 ns
[ 3.898845] mali ffa30000.gpu: GPU identified as 0x0750 r1p0 status 0
[ 3.899672] mali ffa30000.gpu: Probed as mali0
[ 3.900339] rockchip-spdif-card rockchip-spdif-card.25: ASoC: CODEC (null) not registered
[ 3.900373] rockchip_spdif_card_probe() register card failed:-517
[ 3.900390] platform rockchip-spdif-card.25: Driver rockchip-spdif-card requests probe deferral
[ 3.900988] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ' should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 '
[ 3.901639] rk29_ipp: version magic '3.0.36+ SMP preempt mod_unload ARMv7 ' should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 '
[ 3.902245] rk29_ipp: version magic '3.0.101+ SMP preempt mod_unload ARMv7 ' should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 '
[ 3.903409] zram0: detected capacity change from 0 to 533413888
[ 3.905149] Indeed it is in host mode hprt0 = 00021501
[ 3.950138] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
[ 3.975468] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 3.975496] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
[ 3.975573] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=4bits.[mmc2]
[ 3.976836] mmc2: new high speed SDIO card at address 0001
[ 3.977686] rockchip-spdif-card rockchip-spdif-card.25: ASoC: CODEC (null) not registered
[ 3.977718] rockchip_spdif_card_probe() register card failed:-517
[ 3.977733] platform rockchip-spdif-card.25: Driver rockchip-spdif-card requests probe deferral
[ 3.991455] EXT4-fs (mmcblk0p13): Unrecognized mount option "background_gc=on" or missing value
[ 3.993143] bcmsdh_register: register client driver
[ 3.993258] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 3.993315] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 3.993323] bus num (host idx)=2, slot num (rca)=1
[ 3.993329] found adapter info 'DHD generic adapter'
[ 3.993363] sdioh_attach: set sd_f2_blocksize 128
[ 3.993590] F1 signature read @0x18000000=0x1541a9a6
[ 3.993657] rockchip-spdif-card rockchip-spdif-card.25: ASoC: CODEC (null) not registered
[ 3.993684] rockchip_spdif_card_probe() register card failed:-517
[ 3.993698] platform rockchip-spdif-card.25: Driver rockchip-spdif-card requests probe deferral
[ 3.995177] F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x1 pkg:0x4
[ 3.995731] DHD: dongle ram size is set to 524288(orig 524288) at 0x0
[ 3.995817] wifi_platform_get_mac_addr
[ 3.995824] ======== dhd_wlan_get_mac_addr ========
[ 3.995831] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
[ 3.995841] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
[ 3.995847] [WLAN_RFKILL]: This mac address is not valid, ignored...
[ 3.995859] dhd_conf_set_chiprev: chip=0xa9a6, chiprev=1
[ 3.995911] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmware/config.txt
[ 3.996357] wl_create_event_handler(): thread:wl_event_handler:a0 started
[ 3.996363] tsk Enter, tsk = 0xdd48149c
[ 3.996471] wl_escan_attach: Enter
[ 3.996511] wl_escan_init: Enter
[ 3.996564] wl_create_event_handler(): thread:wl_escan_handler:a1 started
[ 3.996568] tsk Enter, tsk = 0xdd530164
[ 3.996620] dhd_attach(): thread:dhd_watchdog_thread:a2 started
[ 3.996665] dhd_attach(): thread:dhd_dpc:a3 started
[ 3.996710] dhd_attach(): thread:dhd_rxf:a4 started
[ 3.996723] dhd_deferred_work_init: work queue initialized
[ 4.001711] drmboot: module license 'unspecified' taints kernel.
[ 4.001727] Disabling lock debugging due to kernel taint
[ 4.002010] drm init, 20140910
[ 4.002227] Dongle Host Driver, version 1.201.59.11 (r506368)
[ 4.002227] Compiled in drivers/net/wireless/bcmdhd on Nov 21 2019 at 08:48:21
[ 4.002678] Register interface [wlan0] MAC: 10:d0:7a:f4:5d:30
[ 4.002678]
[ 4.002695] dhd_prot_ioctl : bus is down. we have nothing to do
[ 4.002739] bcmsdh_oob_intr_unregister: Enter
[ 4.002746] bcmsdh_oob_intr_unregister: irq is not registered
[ 4.002758] dhd_txglom_enable: enable 0
[ 4.002764] dhd_conf_set_txglom_params: swtxglom=0, txglom_ext=0
[ 4.002770] dhd_conf_set_txglom_params: txglom_bucket_size=0
[ 4.002776] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0, bus_txglom=-1
[ 4.002783] dhd_conf_set_txglom_params: tx_in_rx=1, tx_max_offset=0, txctl_tmo_fix=1
[ 4.002790] sdioh_set_mode: set txglom_mode to multi-desc
[ 4.002796] dhd_bus_devreset: WLAN OFF DONE
[ 4.002830] drm init ok
[ 4.002836] wifi_platform_set_power = 0
[ 4.002841] ======== PULL WL_REG_ON(-1) LOW! ========
[ 4.002846] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 4.005062] bat_cap: oldcap path is /sys/devices/ff100000.adc
[ 4.005123] bat_cap: oldcap_path no exist
[ 4.005341] binder: 166:166 transaction failed 29189, size 0-0
[ 4.005772] init: Warning! Service displayd needs a SELinux domain defined; please fix!
[ 4.011398] init: property 'ro.serialno' doesn't exist while expanding '${ro.serialno}'
[ 4.011423] init: cannot expand '${ro.serialno}' while writing to '/sys/class/android_usb/android0/iSerial'
[ 4.011627] type=1400 audit(1358758208.180:5): avc: denied { transition } for pid=172 comm="init" path="/system/xbin/vm" dev="mmcblk0p10" ino=1927 scontext=u:r:init:s0 tcontext=u:r:su:s0 tclass=process permissive=0
[ 4.011672] init: using deprecated syntax for specifying property 'ro.product.usbfactory', use ${name} instead
[ 4.011679] init: cannot execve('/system/xbin/vm'): Permission denied
[ 4.012487] rtk_btusb: btchr_open: BT usb char device is opening
[ 4.012498] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 4.012513] rtk_btusb: btchr_open: BT usb char device is opening
[ 4.012520] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 4.012540] rtk_btusb: btchr_open: BT usb char device is opening
[ 4.012545] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 4.012558] rtk_btusb: btchr_open: BT usb char device is opening
[ 4.012564] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 4.019602] init: cannot find '/system/bin/debuggerd64', disabling 'debuggerd64'
[ 4.021494] init: cannot find '/system/bin/install-recovery.sh', disabling 'flash_recovery'
[ 4.022048] init: cannot find '/system/bin/bplus_helper', disabling 'bplus_helper'
[ 4.022305] init: Warning! Service drmservice needs a SELinux domain defined; please fix!
[ 4.022621] init: cannot find '/system/bin/akmd', disabling 'akmd'
[ 4.024708] android_usb: already disabled
[ 4.027316] read descriptors
[ 4.027337] read strings
[ 4.027357] mtp_bind_config
[ 4.027389] pcd_pullup, is_on 1
[ 4.082266] usb 4-1: new high-speed USB device number 2 using usb20_host
[ 4.082812] Indeed it is in host mode hprt0 = 00001101
[ 4.101888] [WLAN_RFKILL]: wifi shut off power.
[ 4.101908] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
[ 4.101915] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 4.101992] dhd_module_init: Exit err=0
[ 4.102594] rockchip-spdif-card rockchip-spdif-card.25: ASoC: CODEC (null) not registered
[ 4.102625] rockchip_spdif_card_probe() register card failed:-517
[ 4.102642] platform rockchip-spdif-card.25: Driver rockchip-spdif-card requests probe deferral
[ 4.239733] yemk:mpu6050_load_cablic
[ 4.239754] mpu6050_load_cablic: open file /dev/mtd/mtd6
[ 4.262522] RKNAND_GET_SN_SECTOR
[ 4.262542] return ret = 0
[ 4.266442] RKNAND_GET_DRM_KEY
[ 4.266455] return ret = 0
[ 4.333828] usb 4-1: New USB device found, idVendor=0bda, idProduct=5822
[ 4.333847] usb 4-1: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 4.333857] usb 4-1: Product: YTLF
[ 4.333863] usb 4-1: Manufacturer: MTD
[ 4.333869] usb 4-1: SerialNumber: 20180604
[ 4.338422] uvcvideo: Found UVC 1.00 device YTLF (0bda:5822)
[ 4.343094] input: YTLF as /devices/ff540000.usb/usb4/4-1/4-1:1.0/input/input4
[ 4.343766] rockchip-spdif-card rockchip-spdif-card.25: ASoC: CODEC (null) not registered
[ 4.343799] rockchip_spdif_card_probe() register card failed:-517
[ 4.343815] platform rockchip-spdif-card.25: Driver rockchip-spdif-card requests probe deferral
[ 4.527055] logd.auditd: start
[ 4.771147] type=1400 audit(1358758208.870:6): avc: denied { read write } for pid=260 comm="io" name="mem" dev="tmpfs" ino=3302 scontext=u:r:rild:s0 tcontext=u:object_r:kmem_device:s0 tclass=chr_file permissive=0
[ 4.990779] healthd: No charger supplies found
[ 4.990805] healthd: No battery devices found
[ 5.088321] rk3288-lcdc lcdc0: blank mode:0
[ 5.333648] rk3288-lcdc lcdc1: lcdc1: dclk:144000000>>fps:59
[ 5.333973] rk3288-lcdc lcdc1: wakeup from standby!
[ 5.366720] rk_iommu ff940300.vopl_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1ead6000
[ 6.699843] warning: `system_server' uses 32-bit capabilities (legacy support in use)
[ 7.794916] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 7.794947] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 7.794956] D1:camsys_open(739): camsys_marvin(ddfa5510) is opened!
[ 7.795084] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
[ 7.795099] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
[ 7.795112] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
[ 7.795135] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 7.795170] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
[ 7.800239] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 7.800252] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 7.800360] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 7.800402] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 7.801474] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
[ 7.802564] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
[ 7.803634] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
[ 7.807056] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
[ 7.808512] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 7.808672] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
[ 7.808807] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
[ 7.808825] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
[ 7.809961] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 7.810014] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 7.812114] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
[ 7.812139] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 7.812153] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 7.812160] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 7.812169] D1:camsys_release(763): camsys_marvin(ddfa5510) is closed
[ 7.818005] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 7.818021] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 7.818031] D1:camsys_open(739): camsys_marvin(ddfa5510) is opened!
[ 7.818161] D1:camsys_extdev_register(243): Get RK30_PIN3_PB4(108) gpio(active: 1) for dev_id 0x4000000 success!
[ 7.818177] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x4000000 success!
[ 7.818192] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x4000000 success!
[ 7.818202] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit
[ 7.818313] D1:camsys_extdev_register(268): Extdev(dev_id: 0x4000000 dev_name: OV5640) register success
[ 7.823395] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 7.823409] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 7.823514] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 7.823565] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 7.824643] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
[ 7.825714] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
[ 7.826792] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(108) set 0
[ 7.830357] E:camsys_i2c_write(78): i2c write dev(addr:0x78) failed!
[ 7.830520] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(108) set 1
[ 7.830538] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
[ 7.830552] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
[ 7.831661] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 7.831739] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 7.833810] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x4000000) is deregister success
[ 7.833829] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 7.833842] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 7.833849] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 7.833858] D1:camsys_release(763): camsys_marvin(ddfa5510) is closed
[ 7.838839] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 7.838858] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 7.838867] D1:camsys_open(739): camsys_marvin(ddfa5510) is opened!
[ 7.838995] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default
[ 7.839040] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: TC358749XBG) register success
[ 7.844122] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 7.844137] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 7.844243] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 7.844290] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on
[ 7.845364] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
[ 7.846440] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
[ 7.847516] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
[ 7.851085] E:camsys_i2c_write(78): i2c write dev(addr:0x1f) failed!
[ 7.852626] E:camsys_i2c_write(78): i2c write dev(addr:0xf) failed!
[ 7.852731] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
[ 7.852743] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
[ 7.852751] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
[ 7.853879] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 7.853939] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 7.856011] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
[ 7.856032] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 7.856048] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 7.856056] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 7.856065] D1:camsys_release(763): camsys_marvin(ddfa5510) is closed
[ 8.033101] type=1400 audit(1358758212.270:7): avc: denied { execute } for pid=512 comm="mediaserver" name="sh" dev="mmcblk0p10" ino=328 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=0
[ 9.248227] [otg id chg] last id -1 current id 1
[ 9.248272] PortPower off
[ 9.248282] rk_battery_charger_detect_cb , battery_charger_detect 6
[ 9.348832] Using Buffer DMA mode
[ 9.348860] Periodic Transfer Interrupt Enhancement - disabled
[ 9.348867] Multiprocessor Interrupt Enhancement - disabled
[ 9.348875] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 9.348884] ^^^^^^^^^^^^^^^^^Device Mode
[ 9.838667] ***************vbus detect*****************
[ 9.840877] rk_battery_charger_detect_cb , battery_charger_detect 1
[ 9.912643] healthd: battery none chg=
[ 10.023880] Using Buffer DMA mode
[ 10.023912] Periodic Transfer Interrupt Enhancement - disabled
[ 10.023921] Multiprocessor Interrupt Enhancement - disabled
[ 10.023930] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 10.023936] ^^^^^^^^^^^^^^^^^Device Mode
[ 10.023984] *******************soft connect!!!*******************
[ 10.123419] USB RESET
[ 10.125882] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
[ 10.125901] lowmemorykiller: oom_adj 0 => oom_score_adj 0
[ 10.125907] lowmemorykiller: oom_adj 1 => oom_score_adj 58
[ 10.125914] lowmemorykiller: oom_adj 2 => oom_score_adj 117
[ 10.125920] lowmemorykiller: oom_adj 3 => oom_score_adj 176
[ 10.125925] lowmemorykiller: oom_adj 9 => oom_score_adj 529
[ 10.125931] lowmemorykiller: oom_adj 15 => oom_score_adj 1000
[ 10.210405] android_work: sent uevent USB_STATE=CONNECTED
[ 10.258770] android_usb gadget: high-speed config #1: android
[ 10.258990] android_work: sent uevent USB_STATE=CONFIGURED
[ 10.547902] es8323_mic_state_ctrl read: 0
[ 10.547934] mic_state_switch 0
[ 10.547945] hp_det = 0,insert hp
[ 10.547951] hp mic use intern
[ 10.614592] acc_open
[ 10.614636] acc_release
[ 10.762308] phy_power_on: enable = 1
[ 10.801745] Read the Ethernet MAC address from IDB:00:00:00:00:00:00
[ 10.801804] eth0: device MAC address 06:40:29:2b:9b:d5
[ 10.805521] libphy: stmmac: probed
[ 10.805534] eth0: No PHY found
[ 11.413396] Current WiFi chip is AP6212.
[ 11.413539] Current WiFi chip is AP6212.
[ 11.419228] Current WiFi chip is AP6212.
[ 11.495976] dhd_open: Enter c5b70000
[ 11.496023]
[ 11.496023] Dongle Host Driver, version 1.201.59.11 (r506368)
[ 11.496023] Compiled in drivers/net/wireless/bcmdhd on Nov 21 2019 at 08:48:21
[ 11.496042] wl_android_wifi_on in 1
[ 11.496049] wl_android_wifi_on in 2: g_wifi_on=0
[ 11.496058] wifi_platform_set_power = 1
[ 11.496066] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 11.496074] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 11.496083] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
[ 11.496090] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 11.600011] [WLAN_RFKILL]: wifi turn on power. 156
[ 11.806628] sdio_reset_comm():
[ 11.809683] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 200000Hz, actual 200000HZ div = 125)
[ 11.809705] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 400000Hz for init[mmc2]
[ 11.810081] mtp_open
[ 11.831827] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 11.834979] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 11.838137] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 11.843877] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 11.851634] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
[ 11.987011] pm policy 0 -> 1
[ 12.045658] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 12.045711] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
[ 12.045861] sdioh_start: set sd_f2_blocksize 128
[ 12.046119]
[ 12.046119]
[ 12.046119] dhd_bus_devreset: == WLAN ON ==
[ 12.046228] F1 signature read @0x18000000=0x1541a9a6
[ 12.048022] F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x1 pkg:0x4
[ 12.048710] DHD: dongle ram size is set to 524288(orig 524288) at 0x0
[ 12.053540] dhd_conf_read_config: Ignore config file /system/etc/firmware/config.txt
[ 12.053571] dhd_conf_set_fw_name_by_chip: firmware_path=/system/etc/firmware/fw_bcm43438a1.bin
[ 12.053582] dhd_conf_set_bus_params: set use_rxchain 0
[ 12.053589] dhd_conf_set_bus_params: set txinrx_thres -1
[ 12.053595] dhd_conf_set_bus_params: set txglomsize 36
[ 12.053601] Final fw_path=/system/etc/firmware/fw_bcm43438a1.bin
[ 12.053608] Final nv_path=/system/etc/firmware/nvram_ap6212a.txt
[ 12.053614] Final conf_path=/system/etc/firmware/config.txt
[ 12.152756] NVRAM version: AP6212A_NVRAM_V1.0.1_20160606
[ 12.156323] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 12.217433] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 12.229896] bcmsdh_oob_intr_register: Enter
[ 12.229917] bcmsdh_oob_intr_register: HW_OOB enabled
[ 12.229924] bcmsdh_oob_intr_register OOB irq=200 flags=0x4
[ 12.230040] bcmsdh_oob_intr_register: enable_irq_wake
[ 12.231020] dhd_conf_set_intiovar: set WLC_SET_BAND 142 0
[ 12.231230] dhd_preinit_ioctls: Set tcpack_sup_mode 0
[ 12.231261] wifi_platform_get_mac_addr
[ 12.231269] ======== dhd_wlan_get_mac_addr ========
[ 12.231277] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
[ 12.231286] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
[ 12.231295] [WLAN_RFKILL]: This mac address is not valid, ignored...
[ 12.234318] Firmware up: op_mode=0x0005, MAC=10:d0:7a:f4:5d:30
[ 12.234338] dhd_conf_set_country: set country CN, revision 0
[ 12.261795] Country code: CN (CN/0)
[ 12.262396] dhd_conf_set_intiovar: set roam_off 1
[ 12.273835] Firmware version = wl0: Nov 25 2016 15:06:56 version 7.46.57.5.apsta.r4.o12 (Station/Softap) FWID 01-64fb9fe8 es6.c5.n4.a3
[ 12.273872] Driver: 1.201.59.11 (r506368)
[ 12.273872] Firmware: wl0: Nov 25 2016 15:06:56 version 7.46.57.5.apsta.r4.o12 (Station/Softap) FWID 01-64fb9fe8 es6.c5.n4.a3
[ 12.274130] dhd_txglom_enable: enable 1
[ 12.274144] dhd_conf_set_txglom_params: swtxglom=0, txglom_ext=0
[ 12.274151] dhd_conf_set_txglom_params: txglom_bucket_size=0
[ 12.274159] dhd_conf_set_txglom_params: txglomsize=36, deferred_tx_len=36, bus_txglom=-1
[ 12.274168] dhd_conf_set_txglom_params: tx_in_rx=1, tx_max_offset=0, txctl_tmo_fix=1
[ 12.274175] sdioh_set_mode: set txglom_mode to multi-desc
[ 12.274188] dhd_conf_get_disable_proptx: fw_proptx=1, disable_proptx=-1
[ 12.276363] dhd_wlfc_hostreorder_init(): successful bdcv2 tlv signaling, 64
[ 12.276569] dhd_conf_set_intiovar: set ampdu_hostreorder 1
[ 12.277584] wl_android_wifi_on: Success
[ 12.315488] dhd_open: Exit ret=0
[ 12.469388] P2P interface registered
[ 12.501062] WLC_E_IF: NO_IF set, event Ignored
[ 12.504259] P2P interface started
[ 12.575181] Current WiFi chip is AP6212.
[ 12.580679] dhd_pktfilter_offload_set: failed to add pktfilter 102 0 0 0 0xFFFFFF 0x01005E, retcode = -2
[ 12.619436] dhd_set_suspend: Remove extra suspend setting
[ 13.703880] Connectting with dc:fe:18:18:f5:85 channel (13) ssid "TP-LINK_F585", len (12)
[ 13.703880]
[ 13.740135] wl_iw_event: Link UP with BSSID=DC:FE:00:00:F5:85
[ 13.740335] wl_bss_connect_done succeeded with dc:fe:18:18:f5:85
[ 13.785403] wl_bss_connect_done succeeded with dc:fe:18:18:f5:85
[ 13.968864] dhd_set_suspend: Remove extra suspend setting
[ 13.985380] dhd_pno_get_for_batch: Batching SCAN mode is not enabled
[ 13.985964] dhd_pno_stop_for_batch : PNO BATCH MODE is not enabled
[ 13.985981] NULL POINTER (_dhd_pno_clear_all_batch_results) : head->next is NULL
[ 13.985989] NULL POINTER (_dhd_pno_clear_all_batch_results) : head->next is NULL
[ 14.346747] type=1400 audit(1358758218.690:8): avc: denied { write } for pid=517 comm="Binder_1" name="/" dev="mmcblk0p13" ino=2 scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=dir permissive=0
[ 14.347953] type=1400 audit(1358758218.690:9): avc: denied { write } for pid=1095 comm="Binder_1" name="/" dev="mmcblk0p13" ino=2 scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=dir permissive=0
[ 17.241095] init: cannot execve('/system/bin/usb_mode_switch.sh'): Permission denied
[ 17.241107] type=1400 audit(1574647134.753:10): avc: denied { entrypoint } for pid=1297 comm="init" path="/system/bin/usb_mode_switch.sh" dev="mmcblk0p10" ino=354 scontext=u:r:install_recovery:s0 tcontext=u:object_r:system_file:s0 tclass=file permissive=0
[ 20.344126] type=1400 audit(1574647137.903:11): avc: denied { write } for pid=1345 comm="chip.devicetest" name="force_usb_mode" dev="sysfs" ino=13044 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=0
