RK3399 PWM3 的使用
在Firefly 中RK3399系列,我们选择AIO-3399C(AI) 机器,有一路PWM3是用做红外遥控的功能,但是如果用成普通的PWM功能改如何修改呢?其实比较简单,把dts里面配置PWM3红外的相关信息删除,然后在rk3399-firefly-demo.dtsi 里面设置pwm_id 为3,state设置
--- a/kernel/arch/arm64/boot/dts/rockchip/rk3399-firefly-demo.dtsi
+++ b/kernel/arch/arm64/boot/dts/rockchip/rk3399-firefly-demo.dtsi
@@ -57,9 +57,9 @@
        pwm_demo: pwm_demo {
-                       status = "disabled";
+                       status = "okay";
                        compatible = "firefly,rk3399-pwm";
-                       pwm_id = <1>;
+                       pwm_id = <3>;
                        min_period = <0>;
                        max_period = <10000>;
                        duty_ns = <5000>;
--- a/kernel/arch/arm64/boot/dts/rockchip/rk3399-firefly-port.dtsi
+++ b/kernel/arch/arm64/boot/dts/rockchip/rk3399-firefly-port.dtsi
@@ -306,32 +306,10 @@
 &pwm3 {
        status = "okay";
-       interrupts = <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH 0>;
-       compatible = "rockchip,remotectl-pwm";
-       remote_pwm_id = <3>;
-       handle_cpu_id = <0>;
-       remote_support_psci = <1>;
-    ir_key1{
-        rockchip,usercode = <0xff00>;
-        rockchip,key_table =
-            <0xeb   KEY_POWER>,
-            <0xec   KEY_MENU>,
-            <0xfe   KEY_BACK>,
-            <0xb7   KEY_HOME>,
-            <0xa3   KEY_WWW>,
-            <0xf4   KEY_VOLUMEUP>,
-            <0xa7   KEY_VOLUMEDOWN>,
-            <0xf8   KEY_REPLY>,
-            <0xfc   KEY_UP>,
-            <0xfd   KEY_DOWN>,
-            <0xf1   KEY_LEFT>,
-            <0xe5   KEY_RIGHT>;
同时,我们可以cat节点看到对应pwm的信息
rk3399_firefly_aioc_ai_lvds_box:/ # cat sys/kernel/debug/pwm
platform/ff420030.pwm, 1 PWM device
 pwm-0   (firefly-pwm         ): requested enabled period: 10003 ns duty: 4991 ns polarity: inverse
platform/ff420020.pwm, 1 PWM device
 pwm-0   (vdd-log             ): requested enabled period: 24997 ns duty: 16485 ns polarity: inverse
platform/ff420010.pwm, 1 PWM device
 pwm-0   ((null)              ): period: 0 ns duty: 0 ns polarity: inverse
platform/ff420000.pwm, 1 PWM device
 pwm-0   (backlight           ): requested enabled period: 24997 ns duty: 13524 ns polarity: inverse
结果如图所示
按照操作开机一直出现循环重启,错误提示: firefly-pwm pwm-demo: unable to request legacy PWM,错误代码: -517
kiswih 发表于 2019-12-2 15:32
按照操作开机一直出现循环重启,错误提示: firefly-pwm pwm-demo: unable to request legacy PWM,错误代 …
更新附件,然后修改dts就可以解决此问题
pwm-firefly.zip (1.75 KB)
    	    status = "okay";
          pwms = <&pwm3 0 10000 1>;   //pwm1:PWM number   0 10000:PWM period in nanoseconds  1:polarity
          duty_ns = <5000>;           //pwm duty cycle activation time, unit ns
学习下。。。
{:4_89:} thanks
{:4_92:}
{:4_103:}{:4_103:}
学习了
{:4_107:}
学习 学习
学习下
学习下
学习下
学习下
学习了
学习下。。。
学习下
