gslX680 4-0041: read failed
我最近刚买了一个Core-3399-JD4,配的官方的底板,屏幕是10.1寸的LVDS屏幕,烧写的是AIO-3399JD4_Android7.1.2_LVDS_190429.img镜像,串口一直报gslX680 4-0041: read failed,gsl_ts_read set data address fail!,想请教下是什么原因
请把完整的内核log发一下
DDR Version 1.17 20190115
channel 0
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 400MHz 0,1
channel 0
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
change freq to 800MHz 1,0
Channel 0: LPDDR4,800MHz
Channel 1: LPDDR4,800MHz
256B stride
pmugrf_os_reg[2] = 0x3AA1FAA1, stride = 0xD
Boot1: 2017-06-09, version: 1.09
CPUId = 0x0
ChipType = 0x10, 1839
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
SdmmcInit=0 20
StorageInit ok = 66620
LoadTrustBL
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0x7a1f4
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):2bb878d
NOTICE: BL31: Built : 11:57:30, Jan 4 2019
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1181): pd status 3e
INFO: BL31: Initializing BL32
INFO: SPSR = 0x3c9
U-Boot 2014.10-RK3399-06 (Apr 26 2019 - 10:00:43)
CPU: rk3399
cpu version = 0
CPU’s clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
aclk_periph_h = 133333333HZ, hclk_periph_h = 66666666HZ, pclk_per iph_h = 33333333HZ
aclk_periph_l0 = 100000000HZ, hclk_periph_l0 = 100000000HZ, pclk_ periph_l0 = 50000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
Reserve memory for trust os.
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
remotectl v0.1
pwm freq=0xb8320
pwm_freq_nstime=0x52d
Load FDT from resource image.
power key: bank-0 pin-5
can’t find dts node for fixed
pmic:rk808
can’t find dts node for pwm1
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
#Boot ver: 2019-04-26#1.09
empty serial no.
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
failed to find phy node
no fuel gauge found
Using display timing dts
Detailed mode clock 166000 kHz, flags[a]
H: 0800 2380 2390 2490
V: 1280 1290 1300 1325
bus_format: 100e
rk lcdc - 0 dclk set: dclk = 166000000HZ, pll select = 1, div = 1
force target_mbps=800
final DSI-Link bandwidth: 800 Mbps x 4
failed to wait for phy clk lane stop state
failed to display kernel logo
checkKey
vbus = 1
load fdt from resouce.
vendor read error!
Set oem_unlocked=0Secure Boot state: 0
kernel @ 0x00280000 (0x0125a008)
ramdisk @ 0x04bf0000 (0x001ad8e8)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000004600000, end 00000000046171b0 … OK
Add bank:000000000a200000, 00000000ede00000
[ 0.000000] Linux version 4.4.103 (lizs@tchipserver2) (gcc version 4.9 201501 23 (prerelease) (GCC) ) #22 SMP PREEMPT Sun Apr 28 11:53:35 CST 2019
[ 0.000000] Reserved memory: failed to reserve memory for node ‘stb-devinfo@0 0000000’: base 0x0000000000000000, size 0 MiB
[ 0.000000] cma: Reserved 16 MiB at 0x00000000f7000000
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f6ee8000 s45504 r8192 d323 20 u86016
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag es: 991752
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb= 1 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=r k30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0 x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x0000 8000@0x00008000(resource),0x0000C000@0x00010000(kernel),0x00010000@0x0001C000(bo ot),0x00010000@0x0002C000(recovery),0x00038000@0x0003C000(backup),0x00040000@0x0 0074000(cache),0x00300000@0x000B4000(system),0x00008000@0x003B4000(metadata),0x0 0002000@0x003BC000(baseparamer),-@0x003BE000(userdata) storagemedia=emmc uboot_l ogo=0x02000000@0xf5c00000 loader.timestamp=2019-04-26_10:00:43 hdmi.vic=-1 Secur eBootCheckOk=0
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes )
[ 0.000000] software IO TLB [mem 0xf6ea0000-0xf6ee0000] (0MB) mapped at [ffff ffc0f6ea0000-ffffffc0f6edffff]
[ 0.000000] Memory: 3918760K/4030464K available (11006K kernel code, 1640K rw data, 5256K rodata, 832K init, 1073K bss, 95320K reserved, 16384K cma-reserved)
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 M B)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000 ( 246 G B)
[ 0.000000] .init : 0xffffff8009070000 - 0xffffff8009140000 ( 832 K B)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008b40000 ( 11008 K B)
[ 0.000000] .rodata : 0xffffff8008b40000 - 0xffffff8009070000 ( 5312 K B)
[ 0.000000] .data : 0xffffff8009140000 - 0xffffff80092da008 ( 1641 K B)
[ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 G B maximum)
[ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc3e00000 ( 61 M B actual)
[ 0.000000] fixed : 0xffffffbffe7fd000 - 0xffffffbffec00000 ( 4108 K B)
[ 0.000000] PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000 ( 16 M B)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc0f8000000 ( 3966 M B)
[ 0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpu s/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[ 0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /c pus/cpu@101[5] }
[ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 43980 46511097ns
[ 0.001980] Calibrating delay loop (skipped), value calculated using timer fr equency.. 48.00 BogoMIPS (lpj=80000)
[ 0.002950] pid_max: default: 32768 minimum: 301
[ 0.003470] Security Framework initialized
[ 0.003861] SELinux: Initializing.
[ 0.004279] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.004911] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.006419] Initializing cgroup subsys freezer
[ 0.006850] Initializing cgroup subsys debug
[ 0.008206] sched-energy: Sched-energy-costs installed from DT
[ 0.008759] CPU0: update cpu_capacity 401
[ 0.009220] ASID allocator initialised with 65536 entries
[ 0.026054] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee2 0000 domain created
[ 0.027354] Platform MSI: /interrupt-controller@fee00000/interrupt-controller @fee20000 domain created
[ 0.039450] Detected VIPT I-cache on CPU1
[ 0.039483] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.039524] CPU1: using LPI pending table @0x00000000f1c00000
[ 0.039567] CPU1: update cpu_capacity 401
[ 0.039571] CPU1: Booted secondary processor [410fd034]
[ 0.049442] Detected VIPT I-cache on CPU2
[ 0.049461] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.049493] CPU2: using LPI pending table @0x00000000f1c30000
[ 0.049522] CPU2: update cpu_capacity 401
[ 0.049525] CPU2: Booted secondary processor [410fd034]
[ 0.059481] Detected VIPT I-cache on CPU3
[ 0.059499] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.059532] CPU3: using LPI pending table @0x00000000f1c70000
[ 0.059558] CPU3: update cpu_capacity 401
[ 0.059562] CPU3: Booted secondary processor [410fd034]
[ 0.069529] Detected PIPT I-cache on CPU4
[ 0.069558] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.069597] CPU4: using LPI pending table @0x00000000f1cb0000
[ 0.069638] CPU4: update cpu_capacity 1024
[ 0.069641] CPU4: Booted secondary processor [410fd082]
[ 0.079552] Detected PIPT I-cache on CPU5
[ 0.079570] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.079606] CPU5: using LPI pending table @0x00000000f1cf0000
[ 0.079633] CPU5: update cpu_capacity 1024
[ 0.079636] CPU5: Booted secondary processor [410fd082]
[ 0.079720] Brought up 6 CPUs
[ 0.091887] SMP: Total of 6 processors activated.
[ 0.092332] CPU features: detected feature: GIC system register CPU interface
[ 0.093006] CPU: All CPU(s) started at EL2
[ 0.093431] alternatives: patching kernel code
[ 0.095542] devtmpfs: initialized
[ 0.116853] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 6370867519511994 ns
[ 0.117816] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.123471] pinctrl core: initialized pinctrl subsystem
[ 0.125534] Failed to find legacy iommu devices
[ 0.126380] NET: Registered protocol family 16
[ 0.127165] schedtune: init normalization constants…
[ 0.127671] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[ 0.128308] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 0.128943] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[ 0.129579] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 0.130224] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 0.130860] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[ 0.131495] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[ 0.132130] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[ 0.132764] schedtune: SYSTEM min_pwr: 121 max_pwr: 4434
[ 0.133400] schedtune: using normalization constants mul: 3862781856 sh1: 1 s h2: 12
[ 0.134172] schedtune: verify normalization constants…
[ 0.134691] schedtune: max_pwr/2^0: 4313 => norm_pwr: 1024
[ 0.135233] schedtune: max_pwr/2^1: 2156 => norm_pwr: 511
[ 0.135776] schedtune: max_pwr/2^2: 1078 => norm_pwr: 255
[ 0.136318] schedtune: max_pwr/2^3: 539 => norm_pwr: 127
[ 0.136860] schedtune: max_pwr/2^4: 269 => norm_pwr: 63
[ 0.137402] schedtune: max_pwr/2^5: 134 => norm_pwr: 31
[ 0.137950] schedtune: configured to support 5 boost groups
[ 0.147985] cpuidle: using governor ladder
[ 0.157990] cpuidle: using governor menu
[ 0.158386] Registered FIQ tty driver
[ 0.159060] vdso: 2 pages (1 code @ ffffff8008b46000, 1 data @ ffffff80091440 00)
[ 0.159804] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.161872] DMA: preallocated 2048 KiB pool for atomic allocations
[ 0.183153] console [pstore0] enabled
[ 0.183749] pstore: Registered ramoops as persistent store backend
[ 0.184355] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.187323] fiq debugger fiq mode enabled
[ [ 0.188000] console [ttyFIQ0] enabled
[[ 0.188704] bootconsole [uart0] disabled
[ 0.189607] Registered fiq debugger ttyFIQ0
[ 0.219793] Rockchip hdmi driver version 2.0
[ 0.222401] iommu: Adding device ff650000.vpu_service to group 0
[ 0.222501] iommu: Adding device ff660000.rkvdec to group 1
[ 0.222569] iommu: Adding device ff670000.iep to group 2
[ 0.222664] iommu: Adding device ff8f0000.vop to group 3
[ 0.222741] iommu: Adding device ff900000.vop to group 4
[ 0.222853] iommu: Adding device ff910000.isp to group 5
[ 0.222930] iommu: Adding device ff920000.isp to group 6
[ 0.223649] rk_iommu ff670800.iommu: can’t get aclk
[ 0.223671] rk_iommu ff670800.iommu: can’t get hclk
[ 0.224568] SCSI subsystem initialized
[ 0.229022] usbcore: registered new interface driver usbfs
[ 0.229073] usbcore: registered new interface driver hub
[ 0.229153] usbcore: registered new device driver usb
[ 0.229556] media: Linux media interface: v0.10
[ 0.229597] Linux video capture interface: v2.00
[ 0.229732] pps_core: LinuxPPS API ver. 1 registered
[ 0.229744] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome tti <giometti@linux.it>
[ 0.229769] PTP clock support registered
[ 0.231232] Advanced Linux Sound Architecture Driver Initialized.
[ 0.231708] Bluetooth: Core ver 2.21
[ 0.231743] NET: Registered protocol family 31
[ 0.231754] Bluetooth: HCI device and connection manager initialized
[ 0.231772] Bluetooth: HCI socket layer initialized
[ 0.231787] Bluetooth: L2CAP socket layer initialized
[ 0.231816] Bluetooth: SCO socket layer initialized
[ 0.232850] rockchip-cpuinfo cpuinfo: Serial : eabfd767515b0e72
[ 0.233329] clocksource: Switched to clocksource arch_sys_counter
[ 0.277889] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.278141] NET: Registered protocol family 2
[ 0.278600] TCP established hash table entries: 32768 (order: 6, 262144 bytes )
[ 0.278865] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.279408] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.279505] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.279617] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.279870] NET: Registered protocol family 1
[ 0.280458] Trying to unpack rootfs image as initramfs…
[ 0.369824] Freeing initrd memory: 1716K
[ 0.370403] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counte rs available
[ 0.370498] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counte rs available
[ 0.373083] audit: initializing netlink subsys (disabled)
[ 0.373153] audit: type=2000 audit(0.366:1): initialized
[ 0.378201] VFS: Disk quotas dquot_6.6.0
[ 0.378327] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.379675] fuse init (API version 7.23)
[ 0.380816]
[ 0.380816] TEE Core Framework initialization (ver 1:0.1)
[ 0.380850] TEE armv7 Driver initialization
[ 0.381238] tz_tee_probe: name=“armv7sec”, id=0, pdev_name=“armv7sec.0”
[ 0.381255] TEE core: Alloc the misc device “opteearmtz00” (id=0)
[ 0.381437] TEE Core: Register the misc device “opteearmtz00” (id=0,minor=62)
[ 0.385435] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 47)
[ 0.385470] io scheduler noop registered
[ 0.385638] io scheduler cfq registered (default)
[ 0.386915] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: vbus_drv is not a ssigned
[ 0.387996] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not a ssigned
[ 0.393163] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.393198] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.393217] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 0.913380] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 0.913561] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 0.914392] backlight supply power not found, using dummy regulator
[ 0.915480] iep: failed to find iep power down clock source.
[ 0.916026] IEP Power ON
[ 0.916301] IEP Power OFF
[ 0.916380] IEP Driver loaded succesfully
[ 0.916533] Module initialized.
[ 0.917907] rk-vcodec ff650000.vpu_service: probe device
[ 0.917983] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc0f1f26010
[ 0.918173] rk-vcodec ff650000.vpu_service: allocator is drm
[ 0.918242] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 0.918930] rk-vcodec ff650000.vpu_service: init success
[ 0.919783] rk-vcodec ff660000.rkvdec: probe device
[ 0.919842] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc0f1f26810
[ 0.920054] rk-vcodec ff660000.rkvdec: allocator is drm
[ 0.920120] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 0.920505] rk-vcodec ff660000.rkvdec: init success
[ 0.922526] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-2 41330
[ 0.922547] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chan s-6 Num_Peri-12 Num_Events-12
[ 0.923902] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-2 41330
[ 0.923920] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Cha ns-8 Num_Peri-20 Num_Events-16
[ 0.925583] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 0.927204] console [ttyS0] disabled
[ 0.927579] ff180000.serial: ▒▒yS0 at MMIO 0xff180000 (irq = 37, base_baud = 1500000) is a 16550A
[ 0.928180] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 38, base_baud = 1500000) is a 16550A
[ 0.928650] [drm:drm_core_init] Initialized drm 1.1.0 20060810
[ 0.932579] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_compo nent_ops)
[ 0.932824] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_compo nent_ops)
[ 0.932852] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 0.933112] rockchip-drm display-subsystem: master bind failed: -517
[ 0.934596] ff960000.dsi.0 supply power not found, using dummy regulator
[ 0.934847] panel-simple-dsi ff960000.dsi.0: panel_simple_dsi_parse_dcs_cmds: dcs_cmd=29 len=243, cmd_cnt=27
[ 0.934867] panel-simple-dsi ff960000.dsi.0: panel_simple_dsi_parse_dcs_cmds: dcs_cmd=5 len=8, cmd_cnt=2
[ 0.935287] mali ff9a0000.gpu: Failed to get regulator
[ 0.935302] mali ff9a0000.gpu: Power control initialization failed
[ 0.935610] Unable to detect cache hierarchy from DT for CPU 0
[ 0.949716] brd: module loaded
[ 0.955959] loop: module loaded
[ 0.959956] zram: Added device: zram0
[ 0.960966] SCSI Media Changer driver v0.25
[ 0.962766] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[ 0.962798] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[ 0.963841] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[ 1.134180] wk2xxx_serial_init()
[ 1.134198] wk2xxx_request_port
[ 1.134212] ttysWK0 at I/O 0x1 (irq = 143, base_baud = 460800) is a wk2xxx
[ 1.134459] uart_add_one_port success for line i:= 0 with right 0
[ 1.134471] wk2xxx_request_port
[ 1.134483] ttysWK1 at I/O 0x2 (irq = 143, base_baud = 460800) is a wk2xxx
[ 1.134668] uart_add_one_port success for line i:= 1 with right 0
[ 1.134680] wk2xxx_request_port
[ 1.134692] ttysWK2 at I/O 0x3 (irq = 143, base_baud = 460800) is a wk2xxx
[ 1.134877] uart_add_one_port success for line i:= 2 with right 0
[ 1.134889] wk2xxx_request_port
[ 1.134900] ttysWK3 at I/O 0x4 (irq = 143, base_baud = 460800) is a wk2xxx
[ 1.135080] uart_add_one_port success for line i:= 3 with right 0
[ 1.135092] uart_add_one_port = 0x0
[ 1.135117] register spi return v = :0
[ 1.135170] tun: Universal TUN/TAP device driver, 1.6
[ 1.135180] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.136080] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 1.136171] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.136191] rk_gmac-dwmac fe300000.ethernet: TX delay(0x24).
[ 1.136205] rk_gmac-dwmac fe300000.ethernet: RX delay(0x23).
[ 1.136232] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 1.136399] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.141418] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.141543] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.141554] Ring mode enabled
[ 1.141563] DMA HW capability register supported
[ 1.141573] Normal descriptors
[ 1.141584] RX Checksum Offload Engine supported (type 2)
[ 1.141594] Wake-Up On Lan supported
[ 1.141631] Enable RX Mitigation via HW Watchdog Timer
[ 1.209576] libphy: stmmac: probed
[ 1.209605] eth%d: PHY ID 001cc916 at 0 IRQ POLL (stmmac-0:00) active
[ 1.209621] eth%d: PHY ID 001cc916 at 1 IRQ POLL (stmmac-0:01)
[ 1.211023] PPP generic driver version 2.4.2
[ 1.211331] PPP BSD Compression module registered
[ 1.211346] PPP Deflate Compression module registered
[ 1.211388] PPP MPPE Compression module registered
[ 1.211409] NET: Registered protocol family 24
[ 1.211459] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) ( 6 bit encapsulation enabled).
[ 1.211482] CSLIP: code copyright 1989 Regents of the University of Californi a.
[ 1.211593] usbcore: registered new interface driver mt7601u
[ 1.211615] Rockchip WiFi SYS interface (V1.00) …
[ 1.211697] usbcore: registered new interface driver catc
[ 1.211756] usbcore: registered new interface driver kaweth
[ 1.211773] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet dri ver
[ 1.211823] usbcore: registered new interface driver pegasus
[ 1.211880] usbcore: registered new interface driver rtl8150
[ 1.211935] usbcore: registered new interface driver r8152
[ 1.211951] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.212031] usbcore: registered new interface driver hso
[ 1.212098] usbcore: registered new interface driver asix
[ 1.212154] usbcore: registered new interface driver ax88179_178a
[ 1.212209] usbcore: registered new interface driver cdc_ether
[ 1.212264] usbcore: registered new interface driver cdc_eem
[ 1.212319] usbcore: registered new interface driver dm9601
[ 1.212390] usbcore: registered new interface driver smsc75xx
[ 1.212456] usbcore: registered new interface driver smsc95xx
[ 1.212511] usbcore: registered new interface driver gl620a
[ 1.212566] usbcore: registered new interface driver net1080
[ 1.212621] usbcore: registered new interface driver plusb
[ 1.212680] usbcore: registered new interface driver rndis_host
[ 1.212738] usbcore: registered new interface driver cdc_subset
[ 1.212792] usbcore: registered new interface driver zaurus
[ 1.212849] usbcore: registered new interface driver MOSCHIP usb-ethernet dri ver
[ 1.212930] usbcore: registered new interface driver int51x1
[ 1.212985] usbcore: registered new interface driver kalmia
[ 1.213046] usbcore: registered new interface driver ipheth
[ 1.213105] usbcore: registered new interface driver sierra_net
[ 1.213161] usbcore: registered new interface driver cx82310_eth
[ 1.213232] usbcore: registered new interface driver cdc_ncm
[ 1.213289] usbcore: registered new interface driver qmi_wwan
[ 1.213374] usbcore: registered new interface driver cdc_mbim
[ 1.220389] rockchip-dwc3 usb@fe800000: fail to get drvdata hcd
[ 1.226437] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[ 1.227419] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.227440] ehci-pci: EHCI PCI platform driver
[ 1.227539] ehci-platform: EHCI generic platform driver
[ 1.231332] ehci-platform fe380000.usb: EHCI Host Controller
[ 1.231369] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[ 1.231638] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 1.240043] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 1.240251] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.240267] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 1.240281] usb usb1: Product: EHCI Host Controller
[ 1.240294] usb usb1: Manufacturer: Linux 4.4.103 ehci_hcd
[ 1.240306] usb usb1: SerialNumber: fe380000.usb
[ 1.241001] hub 1-0:1.0: USB hub found
[ 1.241068] hub 1-0:1.0: 1 port detected
[ 1.245191] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.245236] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[ 1.245496] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 1.253365] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.253555] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.253571] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 1.253586] usb usb2: Product: EHCI Host Controller
[ 1.253598] usb usb2: Manufacturer: Linux 4.4.103 ehci_hcd
[ 1.253610] usb usb2: SerialNumber: fe3c0000.usb
[ 1.254230] hub 2-0:1.0: USB hub found
[ 1.254288] hub 2-0:1.0: 1 port detected
[ 1.255123] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.255162] ohci-platform: OHCI generic platform driver
[ 1.255607] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 1.255638] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[ 1.255847] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 1.310857] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.310896] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 1.310913] usb usb3: Product: Generic Platform OHCI controller
[ 1.310927] usb usb3: Manufacturer: Linux 4.4.103 ohci_hcd
[ 1.310939] usb usb3: SerialNumber: fe3a0000.usb
[ 1.311568] hub 3-0:1.0: USB hub found
[ 1.311610] hub 3-0:1.0: 1 port detected
[ 1.312309] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.312341] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[ 1.312530] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 1.367504] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.367531] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 1.367548] usb usb4: Product: Generic Platform OHCI controller
[ 1.367562] usb usb4: Manufacturer: Linux 4.4.103 ohci_hcd
[ 1.367575] usb usb4: SerialNumber: fe3e0000.usb
[ 1.368191] hub 4-0:1.0: USB hub found
[ 1.368242] hub 4-0:1.0: 1 port detected
[ 1.369646] usbcore: registered new interface driver cdc_acm
[ 1.369660] cdc_acm: USB Abstract Control Model driver for USB modems and ISD N adapters
[ 1.369741] usbcore: registered new interface driver usblp
[ 1.369808] usbcore: registered new interface driver cdc_wdm
[ 1.369874] usbcore: registered new interface driver uas
[ 1.370090] usbcore: registered new interface driver usb-storage
[ 1.370151] usbcore: registered new interface driver ums-alauda
[ 1.370208] usbcore: registered new interface driver ums-cypress
[ 1.370268] usbcore: registered new interface driver ums-datafab
[ 1.370328] usbcore: registered new interface driver ums_eneub6250
[ 1.370384] usbcore: registered new interface driver ums-freecom
[ 1.370441] usbcore: registered new interface driver ums-isd200
[ 1.370499] usbcore: registered new interface driver ums-jumpshot
[ 1.370555] usbcore: registered new interface driver ums-karma
[ 1.370611] usbcore: registered new interface driver ums-onetouch
[ 1.370669] usbcore: registered new interface driver ums-sddr09
[ 1.370730] usbcore: registered new interface driver ums-sddr55
[ 1.370792] usbcore: registered new interface driver ums-usbat
[ 1.370903] usbcore: registered new interface driver usbserial
[ 1.370955] usbcore: registered new interface driver usbserial_generic
[ 1.370995] usbserial: USB Serial support registered for generic
[ 1.371056] usbcore: registered new interface driver ch341
[ 1.371094] usbserial: USB Serial support registered for ch341-uart
[ 1.371155] usbcore: registered new interface driver cp210x
[ 1.371197] usbserial: USB Serial support registered for cp210x
[ 1.371286] usbcore: registered new interface driver option
[ 1.371326] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.371602] usbcore: registered new interface driver pl2303
[ 1.371639] usbserial: USB Serial support registered for pl2303
[ 1.371715] usbcore: registered new interface driver trancevibrator
[ 1.371733] usb20_otg: version 3.10a 21-DEC-2012
[ 1.372038] usb20_host: version 3.10a 21-DEC-2012
[ 1.380151] usbcore: registered new interface driver xpad
[ 1.380211] usbcore: registered new interface driver usb_acecad
[ 1.380262] usbcore: registered new interface driver aiptek
[ 1.380321] usbcore: registered new interface driver gtco
[ 1.380372] usbcore: registered new interface driver hanwang
[ 1.380420] usbcore: registered new interface driver kbtab
[ 1.380437] ==gsl_ts_init==
[ 1.380467] ret=0
[ 1.380891] .. rk pwm remotectl v1.1 init
[ 1.381116] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input 0
[ 1.381631] sensor_register_slave:mma8452,id=17
[ 1.381650] sensor_register_slave:lis3dh,id=7
[ 1.381665] sensor_register_slave:mma7660,id=18
[ 1.381681] sensor_register_slave:lsm303d,id=22
[ 1.381697] sensor_register_slave:gs_mc3230,id=23
[ 1.381707] [Gsensor] gsensor_init
[ 1.381722] sensor_register_slave:mpu6880_acc,id=24
[ 1.381738] sensor_register_slave:mpu6500_acc,id=25
[ 1.381754] sensor_register_slave:lsm330_acc,id=26
[ 1.381770] sensor_register_slave:akm8975,id=29
[ 1.381785] sensor_register_slave:akm8963,id=30
[ 1.381800] sensor_register_slave:l3g4200d,id=44
[ 1.381816] sensor_register_slave:l3g20d,id=45
[ 1.381832] sensor_register_slave:ewtsa,id=46
[ 1.381847] sensor_register_slave:lsm330_gyro,id=50
[ 1.381862] sensor_register_slave:cm3217,id=52
[ 1.381877] sensor_register_slave:cm3218,id=53
[ 1.382589] i2c /dev entries driver
[ 1.383685] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 1.383755] fan53555-reg: supplied by vcc5v0_sys
[ 1.385443] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 1.385495] fan53555-reg: supplied by vcc5v0_sys
[ 1.387298] rk808 0-001b: Pmic Chip id: 0x0
[ 1.390312] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.390375] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.390460] DCDC_REG1: supplied by vcc3v3_sys
[ 1.391158] DCDC_REG2: supplied by vcc3v3_sys
[ 1.391652] DCDC_REG3: supplied by vcc3v3_sys
[ 1.391859] DCDC_REG4: supplied by vcc3v3_sys
[ 1.392256] LDO_REG1: supplied by vcc3v3_sys
[ 1.393298] LDO_REG2: supplied by vcc3v3_sys
[ 1.394211] LDO_REG3: supplied by vcc3v3_sys
[ 1.395125] LDO_REG4: supplied by vcc3v3_sys
[ 1.396029] LDO_REG5: supplied by vcc3v3_sys
[ 1.396932] LDO_REG6: supplied by vcc3v3_sys
[ 1.397853] LDO_REG7: supplied by vcc3v3_sys
[ 1.398762] LDO_REG8: supplied by vcc3v3_sys
[ 1.399663] SWITCH_REG1: supplied by vcc3v3_sys
[ 1.399899] SWITCH_REG2: supplied by vcc3v3_sys
[ 1.403248] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 1.403672] rk808 0-001b: Can not read property pmic,hold-gpio
[ 1.403694] rk808 0-001b: Can not read property pmic,stby-gpio
[ 1.403724] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff800994 2000
[ 1.404305] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff800994 4000
[ 1.404794] rk3x-i2c ff120000.i2c: Initialized RK3xxx I2C bus at ffffff800994 6000
[ 1.404878] rockchip-pinctrl pinctrl: pin gpio4-17 already requested by ff940 000.hdmi; cannot claim for ff130000.i2c
[ 1.404897] rockchip-pinctrl pinctrl: pin-145 (ff130000.i2c) status -22
[ 1.404912] rockchip-pinctrl pinctrl: could not request pin 145 (gpio4-17) fr om group i2c3-xfer on device rockchip-pinctrl
[ 1.404928] rk3x-i2c ff130000.i2c: Error applying setting, reverse things bac k
[ 1.405269] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff800994 8000
[ 1.405840] GSLX680 Enter gsl_ts_probe
[ 1.405851] ==kzalloc success=
[ 1.560021] usb 2-1: new high-speed USB device number 2 using ehci-platform
[ 1.684043] usb 2-1: New USB device found, idVendor=1a40, idProduct=0201
[ 1.684069] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.684083] usb 2-1: Product: USB 2.0 Hub [MTT]
[ 1.684821] hub 2-1:1.0: USB hub found
[ 1.684911] hub 2-1:1.0: 7 ports detected
[ 1.966681] usb 2-1.5: new low-speed USB device number 3 using ehci-platform
[ 2.068789] usb 2-1.5: New USB device found, idVendor=17ef, idProduct=6050
[ 2.068814] usb 2-1.5: New USB device strings: Mfr=0, Product=2, SerialNumber =0
[ 2.068829] usb 2-1.5: Product: Lenovo Precision USB Mouse
[ 2.080020] i2c master ret:-6
[ 2.080352] gsl_ts_probe–1359, i2c_master_recv sucess
[ 2.080384] [GSLX680] Enter gslX680_ts_init
[ 2.080737] input: gslX680 as /devices/platform/ff3d0000.i2c/i2c-4/4-0041/inp ut/input1
[ 2.080905] orz chip_type=36
[ 2.134166] chip_type=36, reg=36
[ 3.160566] I read reg 0xf0 is 0
[ 3.167045] I write reg 0xf0 0x12
[ 3.173895] I read reg 0xf0 is 0x12
[ 3.290011] =============gsl_load_fw start==============
[ 3.290042] --------------3680B-----------------------
[ 5.246596] =============gsl_load_fw end==============
[ 5.357646] [GSLX680] End gsl_ts_probe
[ 5.357706] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff800994 a000
[ 5.358957] IR NEC protocol handler initialized
[ 5.358974] IR RC5(x/sz) protocol handler initialized
[ 5.358988] IR RC6 protocol handler initialized
[ 5.359003] IR JVC protocol handler initialized
[ 5.359017] IR Sony protocol handler initialized
[ 5.359031] IR SANYO protocol handler initialized
[ 5.359045] IR Sharp protocol handler initialized
[ 5.359060] IR MCE Keyboard/mouse protocol handler initialized
[ 5.359074] IR XMP protocol handler initialized
[ 5.359425] usbcore: registered new interface driver uvcvideo
[ 5.359436] USB Video Class driver (1.1.1)
[ 5.359455] CamSys driver version: v0.38.0, CamSys head file version: v1.0.0
[ 5.371749] power_supply_register: Expected proper parent device for 'test ac’
[ 5.371934] power_supply_register: Expected proper parent device for 'test battery’
[ 5.372260] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 5.372390] power_supply_register: Expected proper parent device for 'test usb’
[ 5.378377] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, tem perature=2147483647
[ 5.380426] device-mapper: uevent: version 1.0.3
[ 5.380844] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-d evel@redhat.com
[ 5.380996] Bluetooth: HCI UART driver ver 2.3
[ 5.381018] Bluetooth: HCI UART protocol H4 registered
[ 5.381030] Bluetooth: HCI UART protocol LL registered
[ 5.381048] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[ 5.381059] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1. 2
[ 5.381071] rtk_btusb: Register usb char device interface for BT driver
[ 5.381340] usbcore: registered new interface driver rtk_btusb
[ 5.381988] cpu cpu0: leakage=19
[ 5.399578] cpu cpu0: temp=33333, pvtm=144202 (145122 + -920)
[ 5.400067] cpu cpu0: pvtm-sel=1
[ 5.400500] cpu cpu4: leakage=33
[ 5.412828] cpu cpu4: temp=33333, pvtm=149794 (150362 + -568)
[ 5.412993] cpu cpu4: pvtm-sel=1
[ 5.418702] sdhci: Secure Digital Host Controller Interface driver
[ 5.418760] sdhci: Copyright(c) Pierre Ossman
[ 5.418781] Synopsys Designware Multimedia Card Interface Driver
[ 5.420090] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode .
[ 5.420292] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 5.420313] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 5.420381] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 5.420422] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 5.420481] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 5.420536] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 5.421686] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode .
[ 5.421782] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 5.421802] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 5.421850] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 5.421876] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 5.422004] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 5.422918] sdhci-pltfm: SDHCI platform and OF driver helper
[ 5.424960] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 5.424975] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 5.453454] mmc0: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using A DMA
[ 5.457219] hidraw: raw HID events driver (C) Jiri Kosina
[ 5.467428] input: Lenovo Precision USB Mouse as /devices/platform/fe3c0000.u sb/usb2/2-1/2-1.5/2-1.5:1.0/0003:17EF:6050.0001/input/input2
[ 5.495441] mmc0: MAN_BKOPS_EN bit is not set
[ 5.509835] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 5.510729] mmcblk0: mmc0:0001 AJTD4R 14.6 GiB
[ 5.514929] mmcblk0boot0: mmc0:0001 AJTD4R partition 1 4.00 MiB
[ 5.515643] mmcblk0boot1: mmc0:0001 AJTD4R partition 2 4.00 MiB
[ 5.516142] mmcblk0rpmb: mmc0:0001 AJTD4R partition 3 4.00 MiB
[ 5.516811] rkpart: partition size too small (0)
[ 5.516839] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 5.516851] trust: 0x000800000 – 0x000c00000 (4 MB)
[ 5.516863] misc: 0x000c00000 – 0x001000000 (4 MB)
[ 5.516874] resource: 0x001000000 – 0x002000000 (16 MB)
[ 5.516886] kernel: 0x002000000 – 0x003800000 (24 MB)
[ 5.516897] boot: 0x003800000 – 0x005800000 (32 MB)
[ 5.516909] recovery: 0x005800000 – 0x007800000 (32 MB)
[ 5.516921] backup: 0x007800000 – 0x00e800000 (112 MB)
[ 5.516932] cache: 0x00e800000 – 0x016800000 (128 MB)
[ 5.516944] system: 0x016800000 – 0x076800000 (1536 MB)
[ 5.516956] metadata: 0x076800000 – 0x077800000 (16 MB)
[ 5.516967] baseparamer: 0x077800000 – 0x077c00000 (4 MB)
[ 5.516979] userdata: 0x077c00000 – 0x3a3a00000 (12990 MB)
[ 5.517048] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13
[ 5.520328] hid-generic 0003:17EF:6050.0001: input,hidraw0: USB HID v1.11 Mou se [Lenovo Precision USB Mouse] on usb-fe3c0000.usb-1.5/input0
[ 5.520467] usbcore: registered new interface driver usbhid
[ 5.520478] usbhid: USB HID core driver
[ 5.520691] inv_mpu_iio: inv_mpu_init:746
[ 5.521707] ashmem: initialized
[ 5.524332] ff100000.saradc supply vref not found, using dummy regulator
[ 5.526069] rknandbase v1.1 2016-11-08
[ 5.526824] usbcore: registered new interface driver snd-usb-audio
[ 5.528759] rt5640 1-001c: Can not read property hp-con-gpio
[ 5.528825] rt5640 1-001c: Can not read property: linein-mute.
[ 5.544724] rockchip-pinctrl pinctrl: pin gpio3-16 already requested by 1-001 c; cannot claim for ff870000.spdif
[ 5.544797] rockchip-pinctrl pinctrl: pin-112 (ff870000.spdif) status -22
[ 5.544813] rockchip-pinctrl pinctrl: could not request pin 112 (gpio3-16) fr om group spdif-bus-1 on device rockchip-pinctrl
[ 5.544828] rockchip-spdif ff870000.spdif: Error applying setting, reverse th ings back
[ 5.549943] u32 classifier
[ 5.550012] Actions configured
[ 5.550085] Netfilter messages via NETLINK v0.30.
[ 5.550177] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 5.550643] ctnetlink v0.93: registering with nfnetlink.
[ 5.553362] xt_time: kernel timezone is -0000
[ 5.555053] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 5.555292] arp_tables: (C) 2002 David S. Miller
[ 5.556292] Initializing XFRM netlink socket
[ 5.556879] NET: Registered protocol family 10
[ 5.560314] mip6: Mobile IPv6
[ 5.560370] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 5.563439] sit: IPv6 over IPv4 tunneling driver
[ 5.564006] NET: Registered protocol family 17
[ 5.564037] NET: Registered protocol family 15
[ 5.564081] bridge: automatic filtering via arp/ip/ip6tables has been depreca ted. Update your scripts to load br_netfilter if you need this.
[ 5.565905] Bridge firewalling registered
[ 5.565920] Ebtables v2.0 registered
[ 5.569685] Bluetooth: RFCOMM TTY layer initialized
[ 5.569711] Bluetooth: RFCOMM socket layer initialized
[ 5.569786] Bluetooth: RFCOMM ver 1.11
[ 5.569809] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 5.569817] Bluetooth: BNEP filters: protocol multicast
[ 5.569838] Bluetooth: BNEP socket layer initialized
[ 5.569853] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 5.569865] Bluetooth: HIDP socket layer initialized
[ 5.569943] l2tp_core: L2TP core driver, V2.0
[ 5.569965] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 5.570032] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 5.570526] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 5.570624] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[ 5.570634] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 5.570644] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gp io.
[ 5.570742] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wa ke_irq = 3, flags = 0.
[ 5.570751] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 5.570764] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 5.570837] [BT_RFKILL]: Enter rfkill_rk_init
[ 5.571360] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts
gpios = 83.
[ 5.571409] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset
gpio = 9.
[ 5.571443] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_g pio = 90.
[ 5.571477] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_h ost_irq = 4.
[ 5.571847] [BT_RFKILL]: Request irq for bt wakeup host
[ 5.571882] [BT_RFKILL]: BT_WAKE_HOST IRQ fired
[ 5.571904] [BT_RFKILL]: ** disable irq
[ 5.572056] [BT_RFKILL]: bt_default device registered.
[ 5.573449] sensor_register_slave:mpu6880_gyro,id=49
[ 5.575074] Registered cp15_barrier emulation handler
[ 5.575182] Registered setend emulation handler
[ 5.575880] registered taskstats version 1
[ 5.577268] rockchip ion idev is NULL
[ 5.577289] rga2 ff680000.rga: rga ion client create success!
[ 5.577541] rga: Driver loaded successfully ver:3.02
[ 5.579129] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_compo nent_ops)
[ 5.579349] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_compo nent_ops)
[ 5.579434] rockchip-drm display-subsystem: bound ff960000.dsi (ops dw_mipi_d si_ops)
[ 5.579866] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 5.579906] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 5.580168] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 5.585361] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi
rockchip_ops)
[ 5.585404] [drm:drm_vblank_init] Supports vblank timestamp caching Rev 2 (21 .10.2013).
[ 5.585436] [drm:drm_vblank_init] No driver support for vblank timestamp quer y.
[ 5.593983] vendor storage:20160801 ret = 0
[ 5.869061] rockchip-drm display-subsystem: fb0: frame buffer device
[ 5.880154] mali ff9a0000.gpu: leakage=24
[ 5.904661] mali ff9a0000.gpu: temp=33333, pvtm=122037 (122405 + -368)
[ 5.906075] mali ff9a0000.gpu: pvtm-sel=1
[ 5.907750] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 5.908714] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfr eq.c; [Line] : 284; [Func] : kbase_devfreq_init(); success initing power_model_s imple.
[ 5.909379] mali ff9a0000.gpu: Probed as mali0
[ 5.914093] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 5.914137] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus nu mber 5
[ 5.914440] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 5.914506] xhci-hcd xhci-hcd.9.auto: irq 236, io mem 0xfe800000
[ 5.914669] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 5.914683] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 5.914695] usb usb5: Product: xHCI Host Controller
[ 5.914706] usb usb5: Manufacturer: Linux 4.4.103 xhci-hcd
[ 5.914716] usb usb5: SerialNumber: xhci-hcd.9.auto
[ 5.919850] hub 5-0:1.0: USB hub found
[ 5.920268] hub 5-0:1.0: 1 port detected
[ 5.921149] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 5.921203] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus nu mber 6
[ 5.922470] usb usb6: We don’t know the algorithms for LPM for this host, dis abling LPM.
[ 5.923422] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[ 5.923463] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 5.923491] usb usb6: Product: xHCI Host Controller
[ 5.923515] usb usb6: Manufacturer: Linux 4.4.103 xhci-hcd
[ 5.923539] usb usb6: SerialNumber: xhci-hcd.9.auto
[ 5.926907] hub 6-0:1.0: USB hub found
[ 5.926983] hub 6-0:1.0: 1 port detected
[ 5.930378] xhci-hcd xhci-hcd.9.auto: remove, state 1
[ 5.930441] usb usb6: USB disconnect, device number 1
[ 5.960163] xhci-hcd xhci-hcd.9.auto: Host not halted after 16000 microsecond s.
[ 5.960212] xhci-hcd xhci-hcd.9.auto: Host controller not halted, aborting re set.
[ 5.961734] xhci-hcd xhci-hcd.9.auto: USB bus 6 deregistered
[ 5.962287] xhci-hcd xhci-hcd.9.auto: remove, state 1
[ 5.962793] usb usb5: USB disconnect, device number 1
[ 5.963725] xhci-hcd xhci-hcd.9.auto: USB bus 5 deregistered
[ 5.969073] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 5.969152] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus n umber 5
[ 5.969473] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x11 0 quirks 0x02030010
[ 5.969529] xhci-hcd xhci-hcd.10.auto: irq 237, io mem 0xfe900000
[ 5.969705] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 5.969719] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 5.969731] usb usb5: Product: xHCI Host Controller
[ 5.969741] usb usb5: Manufacturer: Linux 4.4.103 xhci-hcd
[ 5.969752] usb usb5: SerialNumber: xhci-hcd.10.auto
[ 5.970928] hub 5-0:1.0: USB hub found
[ 5.971008] hub 5-0:1.0: 1 port detected
[ 5.971973] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 5.972024] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus n umber 6
[ 5.972179] usb usb6: We don’t know the algorithms for LPM for this host, dis abling LPM.
[ 5.972421] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[ 5.972451] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 5.972478] usb usb6: Product: xHCI Host Controller
[ 5.972502] usb usb6: Manufacturer: Linux 4.4.103 xhci-hcd
[ 5.972526] usb usb6: SerialNumber: xhci-hcd.10.auto
[ 5.973606] hub 6-0:1.0: USB hub found
[ 5.973682] hub 6-0:1.0: 1 port detected
[ 5.976762] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode .
[ 5.976940] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 5.976979] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 5.977044] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 5.977096] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 5.977192] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 5.977216] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 5.977907] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 5.990126] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 6.003641] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 6.009349] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode .
[ 6.009661] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 6.009701] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 6.009765] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 6.009875] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 6.010177] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 6.011077] dwmmc_rockchip fe320000.dwmmc: allocated mmc-pwrseq
[ 6.011357] vcc_sd: unsupportable voltage range: 3300000-3000000uV
[ 6.011407] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 6.011442] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 6.023755] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 6.038205] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 6.051585] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 6.053368] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 6.054439] asoc-simple-card rt5640-sound: rt5640-aif1 ↔ ff890000.i2s mappi ng ok
[ 6.055039] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 6.058027] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 6.061680] mmc1: queuing unknown CIS tuple 0x81 (9 bytes)
[ 6.066398] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/ rt5640-sound/sound/card0/input3
[ 6.071130] asoc-simple-card spdif-sound: dit-hifi ↔ ff870000.spdif mapping ok
[ 6.076965] rk-hdmi-dp-sound hdmi-dp-sound: i2s-hifi ↔ ff8a0000.i2s mapping ok
[ 6.080290] otg_wakelock_init: No USB transceiver found
[ 6.081184] i2c i2c-2: sensor_probe: gs_mc3230,ffffffc0f1398400
[ 6.081857] sensors 2-004c: sensor_chip_init:gs_mc3230:devid=0x0,ops=0xffffff 80091ff068
[ 6.116498] mmc_host mmc1: Bus speed (slot 0) = 200000000Hz (slot req 2080000 00Hz, actual 200000000HZ div = 0)
[ 6.357019] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 67
[ 6.359563] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 6.359689] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 7.080374] rk3x-i2c ff120000.i2c: timeout, ipd: 0x00, state: 1
[ 8.080374] rk3x-i2c ff120000.i2c: timeout, ipd: 0x00, state: 1
[ 9.090386] rk3x-i2c ff120000.i2c: timeout, ipd: 0x00, state: 1
[ 9.383500] usb 2-1.6: new high-speed USB device number 4 using ehci-platform
[ 9.491706] usb 2-1.6: New USB device found, idVendor=2c7c, idProduct=0125
[ 9.491850] usb 2-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber =0
[ 9.491878] usb 2-1.6: Product: Android
[ 9.491902] usb 2-1.6: Manufacturer: Android
[ 9.494412] option 2-1.6:1.0: GSM modem (1-port) converter detected
[ 9.495317] usb 2-1.6: GSM modem (1-port) converter now attached to ttyUSB0
[ 9.496375] option 2-1.6:1.1: GSM modem (1-port) converter detected
[ 9.497431] usb 2-1.6: GSM modem (1-port) converter now attached to ttyUSB1
[ 9.498616] option 2-1.6:1.2: GSM modem (1-port) converter detected
[ 9.499572] usb 2-1.6: GSM modem (1-port) converter now attached to ttyUSB2
[ 9.500812] option 2-1.6:1.3: GSM modem (1-port) converter detected
[ 9.501697] usb 2-1.6: GSM modem (1-port) converter now attached to ttyUSB3
[ 9.503977] qmi_wwan 2-1.6:1.4: cdc-wdm0: USB WDM device
[ 9.504075] qmi_wwan 2-1.6:1.4: Quectel EC21&EC25&EC20 R2.0 work on RawIP mod e
[ 9.505906] qmi_wwan 2-1.6:1.4 wwan0: register ‘qmi_wwan’ at usb-fe3c0000.usb -1.6, WWAN/QMI device, ce:fd:fb:5a:f2:36
[ 10.090369] rk3x-i2c ff120000.i2c: timeout, ipd: 0x00, state: 1
[ 11.090387] rk3x-i2c ff120000.i2c: timeout, ipd: 0x00, state: 1
[ 12.100384] rk3x-i2c ff120000.i2c: timeout, ipd: 0x00, state: 1
[ 13.100366] rk3x-i2c ff120000.i2c: timeout, ipd: 0x00, state: 1
[ 14.110377] rk3x-i2c ff120000.i2c: timeout, ipd: 0x00, state: 1
[ 14.110455] [Gsensor] init_3230_ctl_data 445 : error: -110
[ 14.110485] sensors 2-004c: sensor_initial:fail to init sensor
[ 14.110509] sensors 2-004c: sensor_chip_init:fail to init sensor
[ 14.110535] i2c i2c-2: sensor_probe failed -2
[ 14.110535]
[ 14.110591] sensors: probe of 2-004c failed with error -2
[ 14.112242] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 09:03:54 UTC (1358499834)
[ 14.114641] It doesn’t contain Rogue gpu
[ 14.146044] ret 1024
[ 14.147372] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux .c; [Line] : 414; [Func] : mali_module_init(); svn_rev_string_from_arm of this m ali_ko is ‘-Firefly-RK3399_Android7.1.1_170516_internal-2696-g350ca66’, rk_ko_ve r is ‘5’, built at ‘11:47:07’, on ‘Apr 28 2019’.
[ 14.150258] Mali: Mali device driver loaded
[ 14.151245] input: rk29-keypad as /devices/platform/rockchip-key/input/input4
[ 14.153858] ALSA device list:
[ 14.153917] #0: rockchip,rt5640-codec
[ 14.153926] #1: ROCKCHIP,SPDIF
[ 14.153933] #2: rk-hdmi-dp-sound
[ 14.154474] Freeing unused kernel memory: 832K
[ 14.157072] init: init first stage started!
[ 14.158615] init: init second stage started!
[ 14.161521] init: Setting ro.rk.soc=rk3399
[ 14.162042] init: OK,EMMC DRIVERS INIT OK
[ 14.162440] init: property_set(“ro.boot.mode”, “emmc”) failed
[ 14.163038] init: property_set(“ro.hardware”, “rk30board”) failed
[ 14.163674] init: Running restorecon…
[ 14.164208] init: waitpid failed: No child processes
[ 14.165081] init: (Loading properties from /default.prop took 0.00s.)
[ 14.167748] init: /init.rc: 588: invalid keyword ‘echo’
[ 14.168791] init: (Parsing /init.environ.rc took 0.00s.)
[ 14.169846] init: (Parsing /init.usb.rc took 0.00s.)
[ 14.171654] init: (Parsing init.rk30board.bootmode.emmc.rc took 0.00s.)
[ 14.173496] init: (Parsing init.rk30board.usb.rc took 0.00s.)
[ 14.174095] init: (Parsing init.rk30board.environment.rc took 0.00s.)
[ 14.174769] init: could not import file ‘/init.stt_trace.rc’ from ‘/init.debu g.rc’: No such file or directory
[ 14.175852] init: (Parsing /init.logs.rc took 0.00s.)
[ 14.176402] init: (Parsing /init.crashlogd.rc took 0.00s.)
[ 14.176986] init: (Parsing /init.coredump.rc took 0.00s.)
[ 14.177537] init: (Parsing /init.log-watch.rc took 0.00s.)
[ 14.178095] init: (Parsing /init.kernel.rc took 0.00s.)
[ 14.178681] init: (Parsing /init.debug-charging.rc took 0.00s.)
[ 14.179226] init: (Parsing /init.debug.rc took 0.00s.)
[ 14.179710] init: (Parsing init.rockchip.rc took 0.01s.)
[ 14.180760] init: (Parsing init.connectivity.rc took 0.00s.)
[ 14.181383] init: (Parsing init.box.samba.rc took 0.00s.)
[ 14.182003] init: (Parsing init.rk3399.rc took 0.00s.)
[ 14.182144] init: init.box.rc: 25: invalid keyword ‘ioprio’
[ 14.182177] init: (Parsing init.box.rc took 0.00s.)
[ 14.182222] init: could not import file ‘init.car.rc’ from ‘/init.rk30board.r c’: No such file or directory
[ 14.182257] init: could not import file ‘init.optee.rc’ from ‘/init.rk30board .rc’: No such file or directory
[ 14.182278] init: (Parsing /init.rk30board.rc took 0.01s.)
[ 14.183127] init: (Parsing /init.usb.configfs.rc took 0.00s.)
[ 14.183248] init: (Parsing /init.zygote64_32.rc took 0.00s.)
[ 14.183267] init: (Parsing /init.rc took 0.02s.)
[ 14.183698] init: Starting service ‘ueventd’…
[ 14.185074] init: write_file: Unable to open ‘/proc/self/coredump_filter’: No such file or directory
[ 14.185132] init: write_file: Unable to open ‘/proc/sys/kernel/panic_on_stack overflow’: No such file or directory
[ 14.189591] ueventd: ueventd started!
[ 14.191195] ueventd: invalid gid ‘trace’
[ 14.290033] init: Waiting for /dev/.coldboot_done…
[ 14.347990] ueventd: Coldboot took 0.15s.
[ 14.351013] init: Waiting for /dev/.coldboot_done took 0.06s.
[ 14.351166] init: /dev/hw_random not found
[ 14.351858] keychord: using input dev ff420030.pwm for fevent
[ 14.351894] keychord: using input dev rk29-keypad for fevent
[ 14.354823] init: write_file: Unable to open ‘/proc/cpu/alignment’: No such f ile or directory
[ 14.361654] Registered swp emulation handler
[ 14.361867] init: write_file: Unable to open ‘/sys/module/rockchip_pm/paramet ers/policy’: No such file or directory
[ 14.362461] init: /dev/hw_random not found
[ 14.363149] fs_mgr: Warning: unknown flag resize
[ 14.366325] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 14.366387] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name /system,target=/system,type=ext4)=0
[ 14.367134] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-n ame/cache,/cache,ext4)=-1: No such file or directory
[ 14.367658] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe33000 0.sdhci/by-name/cache
[ 14.373984] random: e2fsck: uninitialized urandom read (40 bytes read, 98 bit s of entropy available)
[ 14.410076] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 14.410076]
[ 14.410143] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/cache: recover ing journal
[ 14.410143]
[ 14.410158] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/cache: clean, 23/8192 files, 1608/32768 blocks (check in 4 mounts)
[ 14.410158]
[ 14.413400] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. O pts: noauto_da_alloc,discard
[ 14.413465] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name /cache,target=/cache,type=ext4)=0
[ 14.414514] EXT4-fs (mmcblk0p11): Ignoring removed nomblk_io_submit option
[ 14.416026] EXT4-fs (mmcblk0p11): recovery complete
[ 14.416042] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[ 14.416074] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-n ame/metadata,/metadata,ext4)=0: Success
[ 14.431281] fs_mgr: check_fs(): unmount(/metadata) succeeded
[ 14.431337] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe33000 0.sdhci/by-name/metadata
[ 14.432608] random: e2fsck: uninitialized urandom read (40 bytes read, 100 bi ts of entropy available)
[ 14.440854] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 14.440854]
[ 14.440911] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/metadata: clea n, 11/1024 files, 1102/4096 blocks (check in 4 mounts)
[ 14.440911]
[ 14.443118] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 14.443165] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name /metadata,target=/metadata,type=ext4)=0
[ 14.443215] fs_mgr: Running /system/bin/fsck.f2fs -a /dev/block/platform/fe33 0000.sdhci/by-name/userdata
[ 14.444440] fsck.f2fs: executing /system/bin/fsck.f2fs failed: No such file o r directory
[ 14.444440]
[ 14.444473] fsck.f2fs: fsck.f2fs terminated by exit(255)
[ 14.444473]
[ 14.484565] F2FS-fs (mmcblk0p13): Mounted with checkpoint version = 5a
[ 14.484635] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name /userdata,target=/data,type=f2fs)=0
[ 14.487976] init: (Parsing /system/etc/init/atrace.rc took 0.00s.)
[ 14.488239] init: (Parsing /system/etc/init/audioserver.rc took 0.00s.)
[ 14.488551] init: (Parsing /system/etc/init/bootanim.rc took 0.00s.)
[ 14.488821] init: (Parsing /system/etc/init/bootstat.rc took 0.00s.)
[ 14.489049] init: (Parsing /system/etc/init/cameraserver.rc took 0.00s.)
[ 14.489265] init: (Parsing /system/etc/init/debuggerd.rc took 0.00s.)
[ 14.489490] init: (Parsing /system/etc/init/debuggerd64.rc took 0.00s.)
[ 14.489729] init: (Parsing /system/etc/init/drmserver.rc took 0.00s.)
[ 14.490024] init: (Parsing /system/etc/init/dumpstate.rc took 0.00s.)
[ 14.490335] init: (Parsing /system/etc/init/gatekeeperd.rc took 0.00s.)
[ 14.490574] init: (Parsing /system/etc/init/init-debug.rc took 0.00s.)
[ 14.490791] init: (Parsing /system/etc/init/installd.rc took 0.00s.)
[ 14.491014] init: (Parsing /system/etc/init/keystore.rc took 0.00s.)
[ 14.491238] init: (Parsing /system/etc/init/lmkd.rc took 0.00s.)
[ 14.491562] init: (Parsing /system/etc/init/logcatd.rc took 0.00s.)
[ 14.491784] init: (Parsing /system/etc/init/logd.rc took 0.00s.)
[ 14.492087] init: (Parsing /system/etc/init/mdnsd.rc took 0.00s.)
[ 14.492310] init: (Parsing /system/etc/init/mediacodec.rc took 0.00s.)
[ 14.492533] init: (Parsing /system/etc/init/mediadrmserver.rc took 0.00s.)
[ 14.492765] init: (Parsing /system/etc/init/mediaextractor.rc took 0.00s.)
[ 14.492939] init: (Parsing /system/etc/init/mediaserver.rc took 0.00s.)
[ 14.493110] init: (Parsing /system/etc/init/mtpd.rc took 0.00s.)
[ 14.493269] init: (Parsing /system/etc/init/netd.rc took 0.00s.)
[ 14.493438] init: (Parsing /system/etc/init/perfprofd.rc took 0.00s.)
[ 14.493605] init: (Parsing /system/etc/init/racoon.rc took 0.00s.)
[ 14.494722] init: ignored duplicate definition of service ‘ril-daemon’init: ( Parsing /system/etc/init/rild.rc took 0.00s.)
[ 14.494955] init: (Parsing /system/etc/init/servicemanager.rc took 0.00s.)
[ 14.495136] init: (Parsing /system/etc/init/surfaceflinger.rc took 0.00s.)
[ 14.495321] init: (Parsing /system/etc/init/uncrypt.rc took 0.00s.)
[ 14.495506] init: (Parsing /system/etc/init/vdc.rc took 0.00s.)
[ 14.495692] init: (Parsing /system/etc/init/vold.rc took 0.00s.)
[ 14.496413] init: property_set(“ro.board.platform”, “rk3399”) failed
[ 14.496679] init: property_set(“ro.rk.screenoff_time”, “2147483647”) failed
[ 14.496789] init: property_set(“ro.rk.screenshot_enable”, “true”) failed
[ 14.496864] init: (Loading properties from /system/build.prop took 0.00s.)
[ 14.496897] init: (Loading properties from /vendor/build.prop took 0.00s.)
[ 14.496918] init: (Loading properties from /factory/factory.prop took 0.00s.)
[ 14.496978] fs_mgr: Warning: unknown flag resize
[ 14.497032] init: /recovery not specified in fstab
[ 14.497094] init: Starting service ‘healthd’…
[ 14.497429] init: cannot find ‘/system/bin/displayd’ (No such file or directo ry), disabling ‘displayd’
[ 14.497815] init: Starting service ‘earlylogs’…
[ 14.498115] init: Starting service ‘zygote’…
[ 14.498363] init: Starting service ‘zygote_secondary’…
[ 14.498793] init: Starting service ‘lmkd’…
[ 14.499168] init: Starting service ‘servicemanager’…
[ 14.499637] init: Starting service ‘surfaceflinger’…
[ 14.500237] init: Starting service ‘vold’…
[ 14.501749] random: surfaceflinger: uninitialized urandom read (40 bytes read , 103 bits of entropy available)
[ 14.502762] random: lmkd: uninitialized urandom read (40 bytes read, 103 bits of entropy available)
[ 14.503674] binder: 196:196 transaction failed 29189/-22, size 0-0 line 2951
[ 14.503877] random: servicemanager: uninitialized urandom read (40 bytes read , 103 bits of entropy available)
[ 14.505503] random: app_process32: uninitialized urandom read (40 bytes read, 104 bits of entropy available)
[ 14.508288] init: insmod: open(“/system/lib/modules/ump.ko”) failed: No such file or directory
[ 14.508319] random: app_process64: uninitialized urandom read (40 bytes read, 104 bits of entropy available)
[ 14.508389] init: insmod: open(“/system/lib/modules/mali.ko”) failed: No such file or directoryinit: insmod: open(“/system/lib/modules/mali_kbase.ko”) failed : No such file or directoryinit: insmod: open(“/system/lib/modules/rk30_mirrorin g.ko”) failed: No such file or directory
[ 14.510545] random: vold: uninitialized urandom read (40 bytes read, 104 bits of entropy available)
[ 14.511405] random: elogs.sh: uninitialized urandom read (40 bytes read, 104 bits of entropy available)
[ 14.511853] init: finit_module for “/system/lib/modules/rk29-ipp.ko” failed: Exec format errorinit: insmod: open(“/system/lib/modules/pvrsrvkm.ko”) failed: N o such file or directoryinit: finit_module for “/drmboot.ko” failed: Exec format errorfs_mgr: Warning: unknown flag resize
[ 14.513807] zram0: detected capacity change from 0 to 533413888
[ 14.524466] random: mkswap: uninitialized urandom read (40 bytes read, 105 bi ts of entropy available)
[ 14.536312] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 a cross:520908k SS
[ 14.536539] init: Service ‘earlylogs’ (pid 197) exited with status 0
[ 14.538312] init: Starting service ‘debuggerd’…
[ 14.538840] init: Starting service ‘debuggerd64’…
[ 14.543781] init: Not bootcharting.
[ 14.683730] fs_mgr: Warning: unknown flag resize
[ 14.755821] init: Failed to reload policy
[ 14.755990] init: Starting service ‘exec 1 (/system/bin/tzdatacheck)’…
[ 14.765824] init: Service ‘exec 1 (/system/bin/tzdatacheck)’ (pid 217) exited with status 0
[ 14.780588] F2FS-fs (mmcblk0p13): Unrecognized mount option “seclabel” or mis sing value
[ 14.782748] init: write_file: Unable to open ‘/proc/sys/kernel/core_pattern’: No such file or directory
[ 14.783736] init: (Loading properties from /data/local.prop took 0.00s.)
[ 14.816152] init: Starting service ‘logd’…
[ 14.817227] init: Starting service ‘logd-reinit’…
[ 14.818848] init: write_file: Unable to open ‘/proc/sys/vm/min_free_order_shi ft’: No such file or directory
[ 14.821480] init: write_file: Unable to open ‘/proc/sys/vm/lazy_vfree_tlb_flu sh_all_threshold’: No such file or directory
[ 14.823077] init: Starting service ‘fsud’…
[ 14.823553] init: Starting service ‘vm_daemon’…
[ 14.824826] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro. serialno}’
[ 14.824850] init: write: cannot expand ‘${ro.serialno}’
[ 14.825188] file system registered
[ 14.829500] using random self ethernet address
[ 14.829518] using random host ethernet address
[ 14.829570] init: write_file: Unable to open ‘/config/usb_gadget/g1/functions /rndis.gs4/wceis’: Permission denied
[ 14.837392] init: Starting service ‘console’…
[ 14.838249] init: Starting service ‘adbd’…
[ 14.843317] logd.auditd: start
[ 14.843424] logd.klogd: 14840100132
[ 14.844147] init: Service ‘logd-reinit’ (pid 232) exited with status 145
[ 14.844353] init: Starting service ‘ap_log_srv’…
[ 14.845510] init: cannot find ‘/system/bin/update_verifier’ (No such file or directory), disabling ‘exec 2 (/system/bin/update_verifier)’
[ 14.845615] init: Starting service ‘ril-daemon’…
[ 14.846350] init: cannot find ‘/system/bin/install-recovery.sh’ (No such file or directory), disabling ‘flash_recovery’
[ 14.846427] init: Starting service ‘drmservice’…
[ 14.846885] init: cannot find ‘/system/bin/bplus_helper’ (No such file or dir ectory), disabling ‘bplus_helper’
[ 14.846937] init: Starting service ‘up_eth0’…
[ 14.847867] init: cannot find ‘/system/bin/rk_store_keybox’ (No such file or directory), disabling ‘rk_store_keybox’
[ 14.848078] init: Starting service ‘akmd’…
[ 14.849301] init: Starting service ‘audioserver’…
[ 14.850752] init: Starting service ‘cameraserver’…
[ 14.851269] init: couldn’t write 250 to /dev/cpuset/camera-daemon/tasks: No s uch file or directory
[ 14.851400] init: Starting service ‘drm’…
[ 14.852036] init: Starting service ‘installd’…
[ 14.852768] init: Starting service ‘keystore’…
[ 14.855086] rk_gmac-dwmac fe300000.ethernet: rk_get_eth_addr: mac address: 0e :82:18:e3:1d:1c
[ 14.855108] eth0: device MAC address 0e:82:18:e3:1d:1c
[ 14.855152] phy_rtl8211f_led_fixup in
[ 14.857400] init: Starting service ‘mediacodec’…
[ 14.858042] init: Starting service ‘mediadrm’…
[ 14.858696] init: Starting service ‘mediaextractor’…
[ 14.859334] init: Starting service ‘media’…
[ 14.859983] init: Starting service ‘netd’…
[ 14.860821] init: Starting service ‘crashlogd’…
rk3399_firefly_aiojd4_lvds_box:/ $ [ 14.861507] init: Starting service ‘log-wa tch’…
[ 14.862234] init: Starting service ‘gatekeeperd’…
[ 14.863016] init: Starting service ‘perfprofd’…
[ 14.891790] random: nonblocking pool is initialized
[ 14.919410] init: Service ‘akmd’ (pid 248) exited with status 254
[ 14.940027] ret = ffffffffffffffff
[ 14.940097] init: Starting service ‘apk_logfs’…
[ 14.941508] init: property ‘sys.serialno’ doesn’t exist while expanding ‘${sy s.serialno}’
[ 14.941536] init: setprop: cannot expand ‘${sys.serialno}’
[ 14.945522] init: Service ‘ap_log_srv’ (pid 243) exited with status 0
[ 14.953078] init: Service ‘up_eth0’ (pid 247) exited with status 0
[ 14.958787] init: Service ‘drmservice’ (pid 246) exited with status 0
[ 15.050141] read descriptors
[ 15.050184] read strings
[ 15.293598] init: Untracked pid 319 exited with status 0
[ 15.336252] init: Untracked pid 331 exited with status 0
[ 15.504904] healthd: BatteryCurrentNowPath not found
[ 15.504935] healthd: BatteryCycleCountPath not found
[ 15.929591] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 15.930260] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 15.932202] init: Starting service ‘bootanim’…
[ 15.933364] [GSLX680] Enter gsl_ts_late_resume
[ 15.933366] I’am in gsl_ts_resume() start
[ 15.940879] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910 000.isp; cannot claim for ff920000.isp
[ 15.940881] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 15.940884] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) fro m group cif-clkout on device rockchip-pinctrl
[ 15.940888] RockChip-CamSys ff920000.isp: Error applying setting, reverse thi ngs back
[ 15.940889] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 15.951612] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 15.951816] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 15.980978] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 15.981137] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 15.991706] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910 000.isp; cannot claim for ff920000.isp
[ 15.991710] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 15.991715] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) fro m group cif-clkout on device rockchip-pinctrl
[ 15.991720] RockChip-CamSys ff920000.isp: Error applying setting, reverse thi ngs back
[ 15.991722] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 16.002547] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 16.002708] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 16.035504] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 16.035683] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 16.046134] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910 000.isp; cannot claim for ff920000.isp
[ 16.046137] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 16.046143] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) fro m group cif-clkout on device rockchip-pinctrl
[ 16.046147] RockChip-CamSys ff920000.isp: Error applying setting, reverse thi ngs back
[ 16.046149] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 16.053741] #########check mem read 0xb0 = 0 0 0 0 #########
[ 16.056980] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 16.057149] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 16.806847] init: Untracked pid 325 exited with status 1
[ 16.818770] init: Untracked pid 334 exited with status 1
[ 17.080536] I read reg 0xf0 is 29
[ 17.216727] =============gsl_load_fw start==============
[ 17.216730] --------------3680B-----------------------
[ 17.262511] =============gsl_load_fw end==============
[ 17.370423] gsl_ts_read set data address fail!
[ 17.370427] #########check mem read 0xb0 = 0 0 0 0 #########
[ 17.381621] capability: warning: `main’ uses 32-bit capabilities (legacy supp ort in use)
[ 18.410594] gsl_ts_read set data address fail!
[ 18.410975] gsl_ts_read set data address fail!
[ 18.423924] gsl_ts_read set data address fail!
[ 18.424231] gsl_ts_read set data address fail!
[ 18.440317] gsl_ts_read set data address fail!
[ 18.440691] gsl_ts_read set data address fail!
[ 18.453943] gsl_ts_read set data address fail!
[ 18.454321] gsl_ts_read set data address fail!
[ 18.460740] I write reg 0xf0 0x12
[ 18.467857] gsl_ts_read set data address fail!
[ 18.480587] gsl_ts_read set data address fail!
[ 18.480966] gsl_ts_read set data address fail!
[ 18.493620] gsl_ts_read set data address fail!
[ 18.493863] gsl_ts_read set data address fail!
[ 18.500739] I write reg 0xf0 0x12
[ 18.507847] gsl_ts_read set data address fail!
[ 18.520383] gsl_ts_read set data address fail!
[ 18.520643] gsl_ts_read set data address fail!
[ 18.533605] gsl_ts_read set data address fail!
[ 18.533606] ------gslX680 test_i2c error------
[ 18.533608] gsl_ts_resume () end
[ 18.534052] gsl_ts_read set data address fail!
[ 18.534070] gslX680 4-0041: read failed
[ 18.565907] dwhdmi-rockchip ff940000.hdmi: Rate 181250000 missing; compute N dynamically
[ 18.631692] dwhdmi-rockchip ff940000.hdmi: Rate 181250000 missing; compute N dynamically
[ 18.741871] Freeing drm_logo memory: 488K
[ 19.147768] gsl_ts_read set data address fail!
[ 19.147815] gslX680 4-0041: read failed
[ 19.212317] gsl_ts_read set data address fail!
[ 19.212370] gslX680 4-0041: read failed
[ 19.276649] gsl_ts_read set data address fail!
[ 19.276715] gslX680 4-0041: read failed
[ 19.341854] gsl_ts_read set data address fail!
[ 19.341906] gslX680 4-0041: read failed
[ 19.406590] gsl_ts_read set data address fail!
[ 19.406640] gslX680 4-0041: read failed
[ 19.472977] gsl_ts_read set data address fail!
[ 19.473032] gslX680 4-0041: read failed
[ 19.538072] gsl_ts_read set data address fail!
[ 19.538121] gslX680 4-0041: read failed
[ 19.602924] gsl_ts_read set data address fail!
[ 19.602972] gslX680 4-0041: read failed
[ 19.668454] gsl_ts_read set data address fail!
[ 19.668511] gslX680 4-0041: read failed
[ 19.733951] gsl_ts_read set data address fail!
[ 19.733998] gslX680 4-0041: read failed
[ 19.798488] gsl_ts_read set data address fail!
[ 19.798519] gslX680 4-0041: read failed
[ 19.864405] gsl_ts_read set data address fail!
[ 19.864441] gslX680 4-0041: read failed
[ 19.929496] gsl_ts_read set data address fail!
[ 19.929538] gslX680 4-0041: read failed
[ 19.996954] gsl_ts_read set data address fail!
[ 19.997003] gslX680 4-0041: read failed
[ 20.060455] gsl_ts_read set data address fail!
[ 20.060480] gslX680 4-0041: read failed
[ 20.124335] gsl_ts_read set data address fail!
[ 20.124366] gslX680 4-0041: read failed
[ 20.190206] gsl_ts_read set data address fail!
[ 20.190233] gslX680 4-0041: read failed
[ 20.254910] gsl_ts_read set data address fail!
[ 20.254947] gslX680 4-0041: read failed
[ 20.320023] gsl_ts_read set data address fail!
[ 20.320068] gslX680 4-0041: read failed
[ 20.341618] acc_open
[ 20.341646] acc_release
[ 20.386711] gsl_ts_read set data address fail!
[ 20.386769] gslX680 4-0041: read failed
[ 20.515623] gsl_ts_read set data address fail!
[ 20.515662] gslX680 4-0041: read failed
[ 20.580984] gsl_ts_read set data address fail!
[ 20.581033] gslX680 4-0041: read failed
[ 20.709870] gsl_ts_read set data address fail!
[ 20.709922] gslX680 4-0041: read failed
[ 20.776903] gsl_ts_read set data address fail!
[ 20.776947] gslX680 4-0041: read failed
[ 20.840904] gsl_ts_read set data address fail!
[ 20.840954] gslX680 4-0041: read failed
[ 20.906337] gsl_ts_read set data address fail!
[ 20.906379] gslX680 4-0041: read failed
[ 20.970259] gsl_ts_read set data address fail!
[ 20.970318] gslX680 4-0041: read failed
[ 21.037034] gsl_ts_read set data address fail!
[ 21.037107] gslX680 4-0041: read failed
[ 21.100678] gsl_ts_read set data address fail!
[ 21.100732] gslX680 4-0041: read failed
[ 21.231261] gsl_ts_read set data address fail!
[ 21.231290] gslX680 4-0041: read failed
[ 21.297270] gsl_ts_read set data address fail!
[ 21.297300] gslX680 4-0041: read failed
[ 21.361832] gsl_ts_read set data address fail!
[ 21.361869] gslX680 4-0041: read failed
[ 21.426982] gsl_ts_read set data address fail!
[ 21.427008] gslX680 4-0041: read failed
[ 21.493760] gsl_ts_read set data address fail!
[ 21.493786] gslX680 4-0041: read failed
[ 21.623890] gsl_ts_read set data address fail!
[ 21.623932] gslX680 4-0041: read failed
[ 21.754240] gsl_ts_read set data address fail!
[ 21.754286] gslX680 4-0041: read failed
[ 21.820212] gsl_ts_read set data address fail!
[ 21.820258] gslX680 4-0041: read failed
[ 21.885375] gsl_ts_read set data address fail!
[ 21.885402] gslX680 4-0041: read failed
[ 21.964203] gsl_ts_read set data address fail!
[ 21.964252] gslX680 4-0041: read failed
[ 22.081459] gsl_ts_read set data address fail!
[ 22.081511] gslX680 4-0041: read failed
[ 22.147135] gsl_ts_read set data address fail!
[ 22.147179] gslX680 4-0041: read failed
[ 22.212075] gsl_ts_read set data address fail!
[ 22.212103] gslX680 4-0041: read failed
[ 22.277358] gsl_ts_read set data address fail!
[ 22.277402] gslX680 4-0041: read failed
[ 22.293238] dwhdmi-rockchip ff940000.hdmi: Rate 181250000 missing; compute N dynamically
[ 22.345174] gsl_ts_read set data address fail!
[ 22.345200] gslX680 4-0041: read failed
[ 22.410345] gsl_ts_read set data address fail!
[ 22.410368] gslX680 4-0041: read failed
[ 22.421169] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 22.421436] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 22.431733] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910 000.isp; cannot claim for ff920000.isp
[ 22.431788] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 22.431798] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) fro m group cif-clkout on device rockchip-pinctrl
[ 22.431808] RockChip-CamSys ff920000.isp: Error applying setting, reverse thi ngs back
[ 22.431814] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 22.442838] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 22.443232] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 22.470724] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 22.470990] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 22.481166] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910 000.isp; cannot claim for ff920000.isp
[ 22.481208] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 22.481218] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) fro m group cif-clkout on device rockchip-pinctrl
[ 22.481227] RockChip-CamSys ff920000.isp: Error applying setting, reverse thi ngs back
[ 22.481235] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 22.492126] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 22.492327] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 22.523481] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 22.523730] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 22.534120] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910 000.isp; cannot claim for ff920000.isp
[ 22.534154] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 22.534165] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) fro m group cif-clkout on device rockchip-pinctrl
[ 22.534176] RockChip-CamSys ff920000.isp: Error applying setting, reverse thi ngs back
[ 22.534184] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 22.538985] gsl_ts_read set data address fail!
[ 22.539012] gslX680 4-0041: read failed
[ 22.545267] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 22.545471] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 22.603680] gsl_ts_read set data address fail!
[ 22.603719] gslX680 4-0041: read failed
[ 22.669652] gsl_ts_read set data address fail!
[ 22.669696] gslX680 4-0041: read failed
[ 22.735700] gsl_ts_read set data address fail!
[ 22.735734] gslX680 4-0041: read failed
[ 22.800527] gsl_ts_read set data address fail!
[ 22.800578] gslX680 4-0041: read failed
[ 22.801467] init: cannot find ‘/system/bin/glgps’ (No such file or directory) , disabling ‘gpsd’
[ 22.801596] init: Starting service ‘mode_switch’…
[ 22.804274] init: Starting service ‘exec 3 (/system/bin/bootstat)’…
[ 22.829902] init: Service ‘exec 3 (/system/bin/bootstat)’ (pid 1043) exited w ith status 0
[ 22.830162] init: Starting service ‘exec 4 (/system/bin/bootstat)’…
[ 22.843837] init: Service ‘exec 4 (/system/bin/bootstat)’ (pid 1049) exited w ith status 0
[ 22.844008] init: Starting service ‘exec 5 (/system/bin/bootstat)’…
[ 22.858642] init: Service ‘exec 5 (/system/bin/bootstat)’ (pid 1050) exited w ith status 0
[ 22.858936] init: Starting service ‘exec 6 (/system/bin/bootstat)’…
[ 22.866901] gsl_ts_read set data address fail!
[ 22.866936] gslX680 4-0041: read failed
[ 22.868811] init: Service ‘exec 6 (/system/bin/bootstat)’ (pid 1051) exited w ith status 0
[ 22.933237] gsl_ts_read set data address fail!
[ 22.933294] gslX680 4-0041: read failed
[ 23.000202] gsl_ts_read set data address fail!
[ 23.000231] gslX680 4-0041: read failed
[ 23.046754] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 23.046830] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus nu mber 7
[ 23.063958] gsl_ts_read set data address fail!
[ 23.063987] gslX680 4-0041: read failed
[ 23.084036] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 23.084113] xhci-hcd xhci-hcd.9.auto: irq 236, io mem 0xfe800000
[ 23.086356] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002
[ 23.086393] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 23.086402] usb usb7: Product: xHCI Host Controller
[ 23.086409] usb usb7: Manufacturer: Linux 4.4.103 xhci-hcd
[ 23.086417] usb usb7: SerialNumber: xhci-hcd.9.auto
[ 23.088906] hub 7-0:1.0: USB hub found
[ 23.093204] hub 7-0:1.0: 1 port detected
[ 23.093897] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 23.093939] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus nu mber 8
[ 23.094025] usb usb8: We don’t know the algorithms for LPM for this host, dis abling LPM.
[ 23.094137] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003
[ 23.094148] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 23.094157] usb usb8: Product: xHCI Host Controller
[ 23.094165] usb usb8: Manufacturer: Linux 4.4.103 xhci-hcd
[ 23.094172] usb usb8: SerialNumber: xhci-hcd.9.auto
[ 23.096646] hub 8-0:1.0: USB hub found
[ 23.097351] hub 8-0:1.0: 1 port detected
[ 23.097751] rockchip-dwc3 usb@fe800000: USB HOST connected
[ 23.099593] init: Service ‘mode_switch’ (pid 1040) exited with status 1
[ 23.128962] gsl_ts_read set data address fail!
[ 23.129009] gslX680 4-0041: read failed
[ 23.194754] gsl_ts_read set data address fail!
[ 23.194811] gslX680 4-0041: read failed
[ 23.259245] gsl_ts_read set data address fail!
[ 23.259289] gslX680 4-0041: read failed
[ 23.325026] gsl_ts_read set data address fail!
[ 23.325073] gslX680 4-0041: read failed
[ 23.390124] gsl_ts_read set data address fail!
[ 23.390173] gslX680 4-0041: read failed
[ 23.455786] gsl_ts_read set data address fail!
[ 23.455827] gslX680 4-0041: read failed
[ 23.521702] gsl_ts_read set data address fail!
[ 23.521787] gslX680 4-0041: read failed
[ 23.588484] gsl_ts_read set data address fail!
[ 23.588569] gslX680 4-0041: read failed
[ 23.653619] gsl_ts_read set data address fail!
[ 23.653722] gslX680 4-0041: read failed
[ 23.781138] gsl_ts_read set data address fail!
[ 23.781240] gslX680 4-0041: read failed
[ 23.850438] gsl_ts_read set data address fail!
[ 23.850561] gslX680 4-0041: read failed
[ 23.913991] gsl_ts_read set data address fail!
[ 23.914521] gslX680 4-0041: read failed
[ 23.977705] gsl_ts_read set data address fail!
[ 23.977779] gslX680 4-0041: read failed
[ 24.105463] gsl_ts_read set data address fail!
[ 24.105535] gslX680 4-0041: read failed
[ 24.170655] gsl_ts_read set data address fail!
[ 24.170771] gslX680 4-0041: read failed
[ 24.238123] gsl_ts_read set data address fail!
[ 24.238200] gslX680 4-0041: read failed
[ 24.365782] gsl_ts_read set data address fail!
[ 24.365854] gslX680 4-0041: read failed
[ 24.478097] init: Service ‘bootanim’ is being killed…
[ 24.496106] gsl_ts_read set data address fail!
[ 24.496179] gslX680 4-0041: read failed
[ 24.562515] init: Service ‘bootanim’ (pid 384) killed by signal 9
[ 24.628144] gsl_ts_read set data address fail!
[ 24.628238] gslX680 4-0041: read failed
[ 24.690610] gsl_ts_read set data address fail!
[ 24.691123] gslX680 4-0041: read failed
[ 24.755538] gsl_ts_read set data address fail!
[ 24.755577] gslX680 4-0041: read failed
[ 24.820962] gsl_ts_read set data address fail!
[ 24.821022] gslX680 4-0041: read failed
[ 24.886295] gsl_ts_read set data address fail!
[ 24.886351] gslX680 4-0041: read failed
[ 25.016721] gsl_ts_read set data address fail!
[ 25.016753] gslX680 4-0041: read failed
[ 25.081054] gsl_ts_read set data address fail!
[ 25.081119] gslX680 4-0041: read failed
[ 25.147460] gsl_ts_read set data address fail!
[ 25.147561] gslX680 4-0041: read failed
[ 25.211670] gsl_ts_read set data address fail!
[ 25.211710] gslX680 4-0041: read failed
[ 25.214684] init: Untracked pid 1302 exited with status 0
[ 25.258596] init: Untracked pid 1311 exited with status 0
[ 25.275536] gsl_ts_read set data address fail!
[ 25.275580] gslX680 4-0041: read failed
[ 25.341878] gsl_ts_read set data address fail!
[ 25.341925] gslX680 4-0041: read failed
[ 25.406199] gsl_ts_read set data address fail!
[ 25.406230] gslX680 4-0041: read failed
[ 25.472737] gsl_ts_read set data address fail!
[ 25.472785] gslX680 4-0041: read failed
[ 25.537956] gsl_ts_read set data address fail!
[ 25.537998] gslX680 4-0041: read failed
[ 25.606627] gsl_ts_read set data address fail!
[ 25.606691] gslX680 4-0041: read failed
[ 25.670687] gsl_ts_read set data address fail!
[ 25.670731] gslX680 4-0041: read failed
[ 25.734705] gsl_ts_read set data address fail!
[ 25.734748] gslX680 4-0041: read failed
[ 25.800228] gsl_ts_read set data address fail!
[ 25.800337] gslX680 4-0041: read failed
[ 25.865261] gsl_ts_read set data address fail!
[ 25.865320] gslX680 4-0041: read failed
[ 25.907706] init: Untracked pid 1314 exited with status 0
[ 25.908264] init: Untracked pid 1306 exited with status 0
[ 25.930634] gsl_ts_read set data address fail!
[ 25.930695] gslX680 4-0041: read failed
[ 25.995986] gsl_ts_read set data address fail!
[ 25.996045] gslX680 4-0041: read failed
[ 26.060382] gsl_ts_read set data address fail!
[ 26.060437] gslX680 4-0041: read failed
[ 26.125784] gsl_ts_read set data address fail!
[ 26.125876] gslX680 4-0041: read failed
[ 26.190360] gsl_ts_read set data address fail!
[ 26.190417] gslX680 4-0041: read failed
[ 26.255220] gsl_ts_read set data address fail!
[ 26.255275] gslX680 4-0041: read failed
[ 26.321454] gsl_ts_read set data address fail!
[ 26.321552] gslX680 4-0041: read failed
[ 26.385992] gsl_ts_read set data address fail!
[ 26.386090] gslX680 4-0041: read failed
[ 26.450623] gsl_ts_read set data address fail!
[ 26.450686] gslX680 4-0041: read failed
[ 26.517255] gsl_ts_read set data address fail!
[ 26.517316] gslX680 4-0041: read failed
[ 26.581487] gsl_ts_read set data address fail!
[ 26.581588] gslX680 4-0041: read failed
[ 26.645308] gsl_ts_read set data address fail!
[ 26.645400] gslX680 4-0041: read failed
[ 26.711408] gsl_ts_read set data address fail!
[ 26.711474] gslX680 4-0041: read failed
[ 26.777172] gsl_ts_read set data address fail!
[ 26.777228] gslX680 4-0041: read failed
[ 26.841929] gsl_ts_read set data address fail!
[ 26.841982] gslX680 4-0041: read failed
[ 26.906338] gsl_ts_read set data address fail!
[ 26.906405] gslX680 4-0041: read failed
[ 26.974804] gsl_ts_read set data address fail!
[ 26.974926] gslX680 4-0041: read failed
[ 27.101280] gsl_ts_read set data address fail!
[ 27.101389] gslX680 4-0041: read failed
[ 27.167359] gsl_ts_read set data address fail!
[ 27.167510] gslX680 4-0041: read failed
[ 27.297194] gsl_ts_read set data address fail!
[ 27.297346] gslX680 4-0041: read failed
[ 27.361591] gsl_ts_read set data address fail!
[ 27.361746] gslX680 4-0041: read failed
[ 27.426908] gsl_ts_read set data address fail!
[ 27.427049] gslX680 4-0041: read failed
[ 27.491740] gsl_ts_read set data address fail!
[ 27.491811] gslX680 4-0041: read failed
[ 27.557937] gsl_ts_read set data address fail!
[ 27.558083] gslX680 4-0041: read failed
[ 27.621379] gsl_ts_read set data address fail!
[ 27.621524] gslX680 4-0041: read failed
[ 27.686189] gsl_ts_read set data address fail!
[ 27.686334] gslX680 4-0041: read failed
[ 27.817008] gsl_ts_read set data address fail!
[ 27.817151] gslX680 4-0041: read failed
[ 27.881369] gsl_ts_read set data address fail!
[ 27.881492] gslX680 4-0041: read failed
[ 27.946843] gsl_ts_read set data address fail!
[ 27.946921] gslX680 4-0041: read failed
[ 28.012187] gsl_ts_read set data address fail!
[ 28.012266] gslX680 4-0041: read failed
[ 28.078043] gsl_ts_read set data address fail!
[ 28.078123] gslX680 4-0041: read failed
shichaoxiang 发表于 2019-11-29 11:50
DDR Version 1.17 20190115
channel 0
https://pan.baidu.com/s/1wtUlMjrcT7Kzi3uU1Ps81Q
可以使用这个固件试试,看是否还有一样的问题。
[ 1.363485] usbcore: registered new interface driver usbserial_generic
[ 1.363527] usbserial: USB Serial support registered for generic
[ 1.363590] usbcore: registered new interface driver ch341
[ 1.363629] usbserial: USB Serial support registered for ch341-uart
[ 1.363692] usbcore: registered new interface driver cp210x
[ 1.363734] usbserial: USB Serial support registered for cp210x
[ 1.363824] usbcore: registered new interface driver option
[ 1.363863] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.364135] usbcore: registered new interface driver pl2303
[ 1.364176] usbserial: USB Serial support registered for pl2303
[ 1.364253] usbcore: registered new interface driver trancevibrator
[ 1.364271] usb20_otg: version 3.10a 21-DEC-2012
[ 1.364566] usb20_host: version 3.10a 21-DEC-2012
[ 1.365231] usbcore: registered new interface driver xpad
[ 1.365300] usbcore: registered new interface driver usb_acecad
[ 1.365366] usbcore: registered new interface driver aiptek
[ 1.365437] usbcore: registered new interface driver gtco
[ 1.365504] usbcore: registered new interface driver hanwang
[ 1.365567] usbcore: registered new interface driver kbtab
[ 1.365584] ==gsl_ts_init==
[ 1.365626] ret=0
[ 1.366266] .. rk pwm remotectl v1.1 init
[ 1.366592] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 1.367230] sensor_register_slave:mma8452,id=17
[ 1.367251] sensor_register_slave:lis3dh,id=7
[ 1.367269] sensor_register_slave:mma7660,id=18
[ 1.367286] sensor_register_slave:lsm303d,id=22
[ 1.367304] sensor_register_slave:gs_mc3230,id=23
[ 1.367314] [Gsensor] gsensor_init
[ 1.367331] sensor_register_slave:mpu6880_acc,id=24
[ 1.367348] sensor_register_slave:mpu6500_acc,id=25
[ 1.367366] sensor_register_slave:lsm330_acc,id=26
[ 1.367383] sensor_register_slave:akm8975,id=29
[ 1.367400] sensor_register_slave:akm8963,id=30
[ 1.367417] sensor_register_slave:l3g4200d,id=44
[ 1.367435] sensor_register_slave:l3g20d,id=45
[ 1.367453] sensor_register_slave:ewtsa,id=46
[ 1.367470] sensor_register_slave:lsm330_gyro,id=50
[ 1.367487] sensor_register_slave:cm3217,id=52
[ 1.367503] sensor_register_slave:cm3218,id=53
[ 1.368487] i2c /dev entries driver
[ 1.370137] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 1.370256] fan53555-reg: supplied by vcc5v0_sys
[ 1.372248] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 1.372319] fan53555-reg: supplied by vcc5v0_sys
[ 1.374508] rk808 0-001b: Pmic Chip id: 0x0
[ 1.378356] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.378432] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.378565] DCDC_REG1: supplied by vcc3v3_sys
[ 1.379416] DCDC_REG2: supplied by vcc3v3_sys
[ 1.380025] DCDC_REG3: supplied by vcc3v3_sys
[ 1.380299] DCDC_REG4: supplied by vcc3v3_sys
[ 1.380764] LDO_REG1: supplied by vcc3v3_sys
[ 1.381935] LDO_REG2: supplied by vcc3v3_sys
[ 1.382953] LDO_REG3: supplied by vcc3v3_sys
[ 1.383977] LDO_REG4: supplied by vcc3v3_sys
[ 1.385007] LDO_REG5: supplied by vcc3v3_sys
[ 1.386048] LDO_REG6: supplied by vcc3v3_sys
[ 1.387080] LDO_REG7: supplied by vcc3v3_sys
[ 1.388150] LDO_REG8: supplied by vcc3v3_sys
[ 1.389199] SWITCH_REG1: supplied by vcc3v3_sys
[ 1.389495] SWITCH_REG2: supplied by vcc3v3_sys
[ 1.393307] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 1.393786] rk808 0-001b: Can not read property pmic,hold-gpio
[ 1.393810] rk808 0-001b: Can not read property pmic,stby-gpio
[ 1.393851] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff8009942000
[ 1.394706] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff8009944000
[ 1.395384] rk3x-i2c ff120000.i2c: Initialized RK3xxx I2C bus at ffffff8009946000
[ 1.395508] rockchip-pinctrl pinctrl: pin gpio4-17 already requested by ff940000.hdmi; cannot claim for ff130000.i2c
[ 1.395526] rockchip-pinctrl pinctrl: pin-145 (ff130000.i2c) status -22
[ 1.395542] rockchip-pinctrl pinctrl: could not request pin 145 (gpio4-17) from group i2c3-xfer on device rockchip-pinctrl
[ 1.395556] rk3x-i2c ff130000.i2c: Error applying setting, reverse things back
[ 1.396049] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff8009948000
[ 1.396885] GSLX680 Enter gsl_ts_probe
[ 1.396897] ==kzalloc success=
[ 1.552495] usb 2-1: new high-speed USB device number 2 using ehci-platform
[ 1.676423] usb 2-1: New USB device found, idVendor=1a40, idProduct=0201
[ 1.676447] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.676462] usb 2-1: Product: USB 2.0 Hub [MTT]
[ 1.677041] hub 2-1:1.0: USB hub found
[ 1.677168] hub 2-1:1.0: 7 ports detected
[ 2.072501] i2c master ret:-6
[ 2.072817] gsl_ts_probe–1359, i2c_master_recv sucess
[ 2.072848] [GSLX680] Enter gslX680_ts_init
[ 2.073193] input: gslX680 as /devices/platform/ff3d0000.i2c/i2c-4/4-0041/input/input1
[ 2.073350] orz chip_type=36
[ 2.126641] chip_type=36, reg=36
[ 3.153002] I read reg 0xf0 is 0
[ 3.159499] I write reg 0xf0 0x12
[ 3.166332] I read reg 0xf0 is 0x12
[ 3.282495] =============gsl_load_fw start==============
[ 3.282514] --------------3680B-----------------------
[ 5.239010] =============gsl_load_fw end==============
[ 5.350098] [GSLX680] End gsl_ts_probe
[ 5.350173] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff800994a000
[ 5.351392] IR NEC protocol handler initialized
[ 5.351434] IR RC5(x/sz) protocol handler initialized
[ 5.351451] IR RC6 protocol handler initialized
[ 5.351467] IR JVC protocol handler initialized
[ 5.351482] IR Sony protocol handler initialized
[ 5.351496] IR SANYO protocol handler initialized
[ 5.351511] IR Sharp protocol handler initialized
[ 5.351526] IR MCE Keyboard/mouse protocol handler initialized
[ 5.351541] IR XMP protocol handler initialized
[ 5.351919] usbcore: registered new interface driver uvcvideo
[ 5.351929] USB Video Class driver (1.1.1)
[ 5.351949] CamSys driver version: v0.38.0, CamSys head file version: v1.0.0
[ 5.358076] __power_supply_register: Expected proper parent device for ‘test_ac’
[ 5.358288] __power_supply_register: Expected proper parent device for ‘test_battery’
[ 5.358610] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 5.358740] __power_supply_register: Expected proper parent device for ‘test_usb’
[ 5.362119] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 5.363543] device-mapper: uevent: version 1.0.3
[ 5.363950] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 5.364190] Bluetooth: HCI UART driver ver 2.3
[ 5.364205] Bluetooth: HCI UART protocol H4 registered
[ 5.364218] Bluetooth: HCI UART protocol LL registered
[ 5.364233] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[ 5.364244] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[ 5.364254] rtk_btusb: Register usb char device interface for BT driver
[ 5.364546] usbcore: registered new interface driver rtk_btusb
[ 5.365120] cpu cpu0: leakage=19
[ 5.382883] cpu cpu0: temp=25000, pvtm=143825 (145665 + -1840)
[ 5.383350] cpu cpu0: pvtm-sel=1
[ 5.383785] cpu cpu4: leakage=33
[ 5.396127] cpu cpu4: temp=25000, pvtm=149600 (150736 + -1136)
[ 5.396283] cpu cpu4: pvtm-sel=1
[ 5.401938] sdhci: Secure Digital Host Controller Interface driver
[ 5.401986] sdhci: Copyright(c) Pierre Ossman
[ 5.402005] Synopsys Designware Multimedia Card Interface Driver
[ 5.403314] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 5.403519] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 5.403540] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 5.403601] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 5.403640] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 5.403699] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 5.403761] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 5.404879] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 5.404960] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 5.404980] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 5.405030] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 5.405056] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 5.405169] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 5.406090] sdhci-pltfm: SDHCI platform and OF driver helper
[ 5.408089] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 5.408103] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 5.439271] mmc0: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 5.443203] hidraw: raw HID events driver (C) Jiri Kosina
[ 5.445770] usbcore: registered new interface driver usbhid
[ 5.446322] usbhid: USB HID core driver
[ 5.446818] inv_mpu_iio: inv_mpu_init:746
[ 5.447838] ashmem: initialized
[ 5.449918] ff100000.saradc supply vref not found, using dummy regulator
[ 5.452747] rknandbase v1.1 2016-11-08
[ 5.453880] usbcore: registered new interface driver snd-usb-audio
[ 5.455880] rt5640 1-001c: Can not read property hp-con-gpio
[ 5.456423] rt5640 1-001c: Can not read property: linein-mute.
[ 5.475425] rockchip-pinctrl pinctrl: pin gpio3-16 already requested by 1-001c; cannot claim for ff870000.spdif
[ 5.475521] rockchip-pinctrl pinctrl: pin-112 (ff870000.spdif) status -22
[ 5.475537] rockchip-pinctrl pinctrl: could not request pin 112 (gpio3-16) from group spdif-bus-1 on device rockchip-pinctrl
[ 5.475553] rockchip-spdif ff870000.spdif: Error applying setting, reverse things back
[ 5.477638] u32 classifier
[ 5.477656] Actions configured
[ 5.477730] Netfilter messages via NETLINK v0.30.
[ 5.477807] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 5.478250] ctnetlink v0.93: registering with nfnetlink.
[ 5.479111] xt_time: kernel timezone is -0000
[ 5.480138] mmc0: MAN_BKOPS_EN bit is not set
[ 5.480220] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 5.480480] arp_tables: (C) 2002 David S. Miller
[ 5.481029] Initializing XFRM netlink socket
[ 5.481629] NET: Registered protocol family 10
[ 5.482806] mip6: Mobile IPv6
[ 5.482845] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 5.485492] sit: IPv6 over IPv4 tunneling driver
[ 5.487288] NET: Registered protocol family 17
[ 5.487732] NET: Registered protocol family 15
[ 5.488187] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 5.489172] Bridge firewalling registered
[ 5.489193] Ebtables v2.0 registered
[ 5.489912] Bluetooth: RFCOMM TTY layer initialized
[ 5.489939] Bluetooth: RFCOMM socket layer initialized
[ 5.489982] Bluetooth: RFCOMM ver 1.11
[ 5.490009] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 5.490020] Bluetooth: BNEP filters: protocol multicast
[ 5.490037] Bluetooth: BNEP socket layer initialized
[ 5.490056] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 5.490072] Bluetooth: HIDP socket layer initialized
[ 5.490126] l2tp_core: L2TP core driver, V2.0
[ 5.490153] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 5.490173] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 5.490702] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 5.490799] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[ 5.490811] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 5.490822] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 5.490931] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 5.490942] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 5.490957] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 5.491101] [BT_RFKILL]: Enter rfkill_rk_init
[ 5.491701] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 5.491758] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[ 5.491800] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[ 5.491840] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[ 5.492233] [BT_RFKILL]: Request irq for bt wakeup host
[ 5.492280] [BT_RFKILL]: BT_WAKE_HOST IRQ fired
[ 5.492301] [BT_RFKILL]: ** disable irq
[ 5.492349] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 5.492596] [BT_RFKILL]: bt_default device registered.
[ 5.492992] sensor_register_slave:mpu6880_gyro,id=49
[ 5.494937] Registered cp15_barrier emulation handler
[ 5.495048] Registered setend emulation handler
[ 5.496098] registered taskstats version 1
[ 5.496701] mmcblk0: mmc0:0001 AJTD4R 14.6 GiB
[ 5.497089] mmcblk0boot0: mmc0:0001 AJTD4R partition 1 4.00 MiB
[ 5.497402] mmcblk0boot1: mmc0:0001 AJTD4R partition 2 4.00 MiB
[ 5.497532] rockchip ion idev is NULL
[ 5.497549] rga2 ff680000.rga: rga ion client create success!
[ 5.497762] mmcblk0rpmb: mmc0:0001 AJTD4R partition 3 4.00 MiB
[ 5.497851] rga: Driver loaded successfully ver:3.02
[ 5.498177] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 5.498189] trust: 0x000800000 – 0x000c00000 (4 MB)
[ 5.498200] misc: 0x000c00000 – 0x001000000 (4 MB)
[ 5.498211] resource: 0x001000000 – 0x002000000 (16 MB)
[ 5.498221] kernel: 0x002000000 – 0x003800000 (24 MB)
[ 5.498231] boot: 0x003800000 – 0x005800000 (32 MB)
[ 5.498241] recovery: 0x005800000 – 0x007800000 (32 MB)
[ 5.498252] backup: 0x007800000 – 0x00e800000 (112 MB)
[ 5.498262] cache: 0x00e800000 – 0x016800000 (128 MB)
[ 5.498273] system: 0x016800000 – 0x076800000 (1536 MB)
[ 5.498282] metadata: 0x076800000 – 0x077800000 (16 MB)
[ 5.498292] baseparamer: 0x077800000 – 0x077c00000 (4 MB)
[ 5.498303] userdata: 0x077c00000 – 0x3a3a00000 (12990 MB)
[ 5.498360] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13
[ 5.499647] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 5.499896] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 5.499978] rockchip-drm display-subsystem: bound ff960000.dsi (ops dw_mipi_dsi_ops)
[ 5.500552] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 5.500595] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 5.500683] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 5.502172] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[ 5.502195] [drm:drm_vblank_init] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 5.502206] [drm:drm_vblank_init] No driver support for vblank timestamp query.
[ 5.795295] rockchip-drm display-subsystem: fb0: frame buffer device
[ 5.808230] mali ff9a0000.gpu: leakage=24
[ 5.833037] mali ff9a0000.gpu: temp=25625, pvtm=121745 (122481 + -736)
[ 5.833986] mali ff9a0000.gpu: pvtm-sel=1
[ 5.835736] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 5.837138] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 284; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 5.839500] mali ff9a0000.gpu: Probed as mali0
[ 5.846553] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 5.847125] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 5
[ 5.848306] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 5.849239] xhci-hcd xhci-hcd.9.auto: irq 236, io mem 0xfe800000
[ 5.850022] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 5.850667] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.851342] usb usb5: Product: xHCI Host Controller
[ 5.851813] usb usb5: Manufacturer: Linux 4.4.103 xhci-hcd
[ 5.852334] usb usb5: SerialNumber: xhci-hcd.9.auto
[ 5.853655] hub 5-0:1.0: USB hub found
[ 5.854074] hub 5-0:1.0: 1 port detected
[ 5.854934] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 5.855480] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 6
[ 5.856295] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 5.857201] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[ 5.857843] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.858517] usb usb6: Product: xHCI Host Controller
[ 5.858548] usb usb6: Manufacturer: Linux 4.4.103 xhci-hcd
[ 5.858572] usb usb6: SerialNumber: xhci-hcd.9.auto
[ 5.860723] hub 6-0:1.0: USB hub found
[ 5.861135] hub 6-0:1.0: 1 port detected
[ 5.864152] xhci-hcd xhci-hcd.9.auto: remove, state 1
[ 5.864676] usb usb6: USB disconnect, device number 1
[ 5.894034] xhci-hcd xhci-hcd.9.auto: Host not halted after 16000 microseconds.
[ 5.894080] xhci-hcd xhci-hcd.9.auto: Host controller not halted, aborting reset.
[ 5.895645] xhci-hcd xhci-hcd.9.auto: USB bus 6 deregistered
[ 5.896172] xhci-hcd xhci-hcd.9.auto: remove, state 1
[ 5.896642] usb usb5: USB disconnect, device number 1
[ 5.897518] xhci-hcd xhci-hcd.9.auto: USB bus 5 deregistered
[ 5.902731] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 5.902801] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 5
[ 5.903130] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 5.903183] xhci-hcd xhci-hcd.10.auto: irq 237, io mem 0xfe900000
[ 5.903343] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 5.903357] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.903369] usb usb5: Product: xHCI Host Controller
[ 5.903379] usb usb5: Manufacturer: Linux 4.4.103 xhci-hcd
[ 5.903390] usb usb5: SerialNumber: xhci-hcd.10.auto
[ 5.908093] hub 5-0:1.0: USB hub found
[ 5.908184] hub 5-0:1.0: 1 port detected
[ 5.908474] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 5.908526] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 6
[ 5.908595] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 5.908713] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[ 5.908727] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.908738] usb usb6: Product: xHCI Host Controller
[ 5.908749] usb usb6: Manufacturer: Linux 4.4.103 xhci-hcd
[ 5.908759] usb usb6: SerialNumber: xhci-hcd.10.auto
[ 5.909343] hub 6-0:1.0: USB hub found
[ 5.909436] hub 6-0:1.0: 1 port detected
[ 5.912522] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 5.912710] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 5.912749] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 5.912814] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 5.912863] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 5.912963] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 5.912988] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 5.913679] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 5.926277] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 5.939481] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 5.945157] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 5.945511] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 5.945548] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 5.945613] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 5.945721] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 5.945967] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 5.946939] dwmmc_rockchip fe320000.dwmmc: allocated mmc-pwrseq
[ 5.947275] vcc_sd: unsupportable voltage range: 3300000-3000000uV
[ 5.947328] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 5.947362] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[ 5.959470] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 5.975165] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 5.987210] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 5.988943] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 5.990546] asoc-simple-card rt5640-sound: rt5640-aif1 ↔ ff890000.i2s mapping ok
[ 5.990673] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 5.993648] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 5.997326] mmc1: queuing unknown CIS tuple 0x81 (9 bytes)
[ 6.005020] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/rt5640-sound/sound/card0/input2
[ 6.015760] rk-hdmi-dp-sound hdmi-dp-sound: i2s-hifi ↔ ff8a0000.i2s mapping ok
[ 6.018992] otg_wakelock_init: No USB transceiver found
[ 6.019390] i2c i2c-2: sensor_probe: gs_mc3230,ffffffc0f109f800
[ 6.019475] sensors 2-004c: sensor_chip_init:gs_mc3230:devid=0x0,ops=0xffffff80091ff090
[ 6.026475] vendor storage:20160801 ret = 0
[ 6.054131] mmc_host mmc1: Bus speed (slot 0) = 200000000Hz (slot req 208000000Hz, actual 200000000HZ div = 0)
[ 6.252722] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 65
[ 6.255356] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 6.255456] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 7.019536] rk3x-i2c ff120000.i2c: timeout, ipd: 0x00, state: 1
[ 8.019529] rk3x-i2c ff120000.i2c: timeout, ipd: 0x00, state: 1
[ 9.029530] rk3x-i2c ff120000.i2c: timeout, ipd: 0x00, state: 1
[ 9.272844] usb 2-1.6: new high-speed USB device number 3 using ehci-platform
[ 9.380922] usb 2-1.6: New USB device found, idVendor=2c7c, idProduct=0125
[ 9.381041] usb 2-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.381070] usb 2-1.6: Product: Android
[ 9.381093] usb 2-1.6: Manufacturer: Android
[ 9.383603] option 2-1.6:1.0: GSM modem (1-port) converter detected
[ 9.384508] usb 2-1.6: GSM modem (1-port) converter now attached to ttyUSB0
[ 9.385504] option 2-1.6:1.1: GSM modem (1-port) converter detected
[ 9.386522] usb 2-1.6: GSM modem (1-port) converter now attached to ttyUSB1
[ 9.387659] option 2-1.6:1.2: GSM modem (1-port) converter detected
[ 9.388651] usb 2-1.6: GSM modem (1-port) converter now attached to ttyUSB2
[ 9.389824] option 2-1.6:1.3: GSM modem (1-port) converter detected
[ 9.390697] usb 2-1.6: GSM modem (1-port) converter now attached to ttyUSB3
[ 9.392895] qmi_wwan 2-1.6:1.4: cdc-wdm0: USB WDM device
[ 9.392973] qmi_wwan 2-1.6:1.4: Quectel EC21&EC25&EC20 R2.0 work on RawIP mode
[ 9.394860] qmi_wwan 2-1.6:1.4 wwan0: register ‘qmi_wwan’ at usb-fe3c0000.usb-1.6, WWAN/QMI device, 06:26:2b:ff:c2:40
[ 10.029541] rk3x-i2c ff120000.i2c: timeout, ipd: 0x00, state: 1
[ 11.029528] rk3x-i2c ff120000.i2c: timeout, ipd: 0x00, state: 1
[ 12.039530] rk3x-i2c ff120000.i2c: timeout, ipd: 0x00, state: 1
[ 13.039533] rk3x-i2c ff120000.i2c: timeout, ipd: 0x00, state: 1
[ 14.049538] rk3x-i2c ff120000.i2c: timeout, ipd: 0x00, state: 1
[ 14.049672] [Gsensor] init_3230_ctl_data 445 : error: -110
[ 14.049703] sensors 2-004c: sensor_initial:fail to init sensor
[ 14.049728] sensors 2-004c: sensor_chip_init:fail to init sensor
[ 14.049754] i2c i2c-2: sensor_probe failed -2
[ 14.049754]
[ 14.049816] sensors: probe of 2-004c failed with error -2
[ 14.051741] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:15 UTC (1358499015)
[ 14.054124] It doesn’t contain Rogue gpu
[ 14.089888] ret 1024
[ 14.091161] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 414; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘-Firefly-RK3399_Android7.1.1_170516_internal-2727-gdc7e889’, rk_ko_ver is ‘5’, built at ‘10:47:14’, on ‘Nov 6 2019’.
[ 14.092054] Mali: Mali device driver loaded
[ 14.092922] input: rk29-keypad as /devices/platform/rockchip-key/input/input3
[ 14.094699] ALSA device list:
[ 14.094771] #0: rockchip,rt5640-codec
[ 14.094785] #1: rk-hdmi-dp-sound
[ 14.095491] Freeing unused kernel memory: 832K
[ 14.099370] init: init first stage started!
[ 14.179892] audit: type=1403 audit(1358499015.626:2): policy loaded auid=4294967295 ses=4294967295
[ 14.180887] init: (Initializing SELinux non-enforcing took 0.08s.)
[ 14.186645] init: init second stage started!
[ 14.194717] init: Setting ro.rk.soc=rk3399
[ 14.194899] init: OK,EMMC DRIVERS INIT OK
[ 14.194940] init: property_set(“ro.boot.mode”, “emmc”) failed
[ 14.195022] init: property_set(“ro.hardware”, “rk30board”) failed
[ 14.197630] init: Running restorecon…
[ 14.283966] init: waitpid failed: No child processes
[ 14.284415] init: (Loading properties from /default.prop took 0.00s.)
[ 14.286347] init: /init.rc: 588: invalid keyword ‘echo’
[ 14.286867] init: (Parsing /init.environ.rc took 0.00s.)
[ 14.287286] init: (Parsing /init.usb.rc took 0.00s.)
[ 14.288287] init: (Parsing init.rk30board.bootmode.emmc.rc took 0.00s.)
[ 14.289065] init: (Parsing init.rk30board.usb.rc took 0.00s.)
[ 14.289225] init: (Parsing init.rk30board.environment.rc took 0.00s.)
[ 14.289316] init: could not import file ‘/init.stt_trace.rc’ from ‘/init.debug.rc’: No such file or directory
[ 14.289505] init: (Parsing /init.logs.rc took 0.00s.)
[ 14.289590] init: (Parsing /init.crashlogd.rc took 0.00s.)
[ 14.289670] init: (Parsing /init.coredump.rc took 0.00s.)
[ 14.289723] init: (Parsing /init.log-watch.rc took 0.00s.)
[ 14.289782] init: (Parsing /init.kernel.rc took 0.00s.)
[ 14.289895] init: (Parsing /init.debug-charging.rc took 0.00s.)
[ 14.289914] init: (Parsing /init.debug.rc took 0.00s.)
[ 14.289930] init: (Parsing init.rockchip.rc took 0.00s.)
[ 14.290393] init: (Parsing init.connectivity.rc took 0.00s.)
[ 14.290486] init: (Parsing init.box.samba.rc took 0.00s.)
[ 14.290607] init: (Parsing init.rk3399.rc took 0.00s.)
[ 14.290728] init: init.box.rc: 25: invalid keyword ‘ioprio’
[ 14.290754] init: (Parsing init.box.rc took 0.00s.)
[ 14.290792] init: could not import file ‘init.car.rc’ from ‘/init.rk30board.rc’: No such file or directory
[ 14.290824] init: could not import file ‘init.optee.rc’ from ‘/init.rk30board.rc’: No such file or directory
[ 14.290841] init: (Parsing /init.rk30board.rc took 0.00s.)
[ 14.291597] init: (Parsing /init.usb.configfs.rc took 0.00s.)
[ 14.291701] init: (Parsing /init.zygote64_32.rc took 0.00s.)
[ 14.291719] init: (Parsing /init.rc took 0.01s.)
[ 14.292310] init: Starting service ‘ueventd’…
[ 14.294351] audit: type=1400 audit(1358499015.740:3): avc: denied { getattr } for pid=1 comm=“init” path=“/sys/kernel/debug/tracing/trace_marker” dev=“tracefs” ino=3094 scontext=u:r:init:s0 tcontext=u:object_r:debugfs_trace_marker:s0 tclass=file permissive=1
[ 14.297337] ueventd: ueventd started!
[ 14.298978] ueventd: invalid gid ‘trace’
[ 14.517796] ueventd: Coldboot took 0.21s.
[ 14.545486] init: write_file: Unable to open ‘/proc/self/coredump_filter’: No such file or directory
[ 14.545542] init: write_file: Unable to open ‘/proc/sys/kernel/panic_on_stackoverflow’: No such file or directory
[ 14.623034] init: Waiting for /dev/.coldboot_done…
[ 14.623222] init: Waiting for /dev/.coldboot_done took 0.00s.
[ 14.623301] init: /dev/hw_random not found
[ 14.624003] keychord: using input dev ff420030.pwm for fevent
[ 14.624020] keychord: using input dev rk29-keypad for fevent
[ 14.630084] init: write_file: Unable to open ‘/proc/cpu/alignment’: No such file or directory
[ 14.639780] Registered swp emulation handler
[ 14.640054] init: write_file: Unable to open ‘/sys/module/rockchip_pm/parameters/policy’: No such file or directory
[ 14.640821] init: /dev/hw_random not found
[ 14.641759] fs_mgr: Warning: unknown flag resize
[ 14.644961] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 14.646246] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/system,target=/system,type=ext4)=0
[ 14.647894] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/cache,/cache,ext4)=-1: No such file or directory
[ 14.649498] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/cache
[ 14.656363] random: e2fsck: uninitialized urandom read (40 bytes read, 96 bits of entropy available)
[ 14.693164] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 14.693164]
[ 14.693213] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/cache: recovering journal
[ 14.693213]
[ 14.693226] e2fsck: Superblock last mount time is in the future.
[ 14.693226]
[ 14.693236] e2fsck: (by less than a day, probably due to the hardware clock being incorrectly set) Fix? yes
[ 14.693236]
[ 14.693248] e2fsck:
[ 14.693248]
[ 14.693257] e2fsck: Setting free inodes count to 8166 (was 8168)
[ 14.693257]
[ 14.693267] e2fsck: Setting free blocks count to 31140 (was 31143)
[ 14.693267]
[ 14.693276] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/cache: clean, 26/8192 files, 1628/32768 blocks
[ 14.693276]
[ 14.702030] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 14.702198] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/cache,target=/cache,type=ext4)=0
[ 14.702862] EXT4-fs (mmcblk0p11): Ignoring removed nomblk_io_submit option
[ 14.704368] EXT4-fs (mmcblk0p11): recovery complete
[ 14.704382] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[ 14.704441] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/metadata,/metadata,ext4)=0: Success
[ 14.724718] fs_mgr: check_fs(): unmount(/metadata) succeeded
[ 14.724797] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/metadata
[ 14.726060] random: e2fsck: uninitialized urandom read (40 bytes read, 101 bits of entropy available)
[ 14.734095] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 14.734095]
[ 14.734150] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/metadata: clean, 11/1024 files, 1102/4096 blocks
[ 14.734150]
[ 14.736496] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 14.736580] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/metadata,target=/metadata,type=ext4)=0
[ 14.736655] fs_mgr: Running /system/bin/fsck.f2fs -a /dev/block/platform/fe330000.sdhci/by-name/userdata
[ 14.739816] fsck.f2fs: executing /system/bin/fsck.f2fs failed: No such file or directory
[ 14.739816]
[ 14.739845] fsck.f2fs: fsck.f2fs terminated by exit(255)
[ 14.739845]
[ 14.790690] F2FS-fs (mmcblk0p13): recover_inode: ino = 7a, name = system@framework@boot.oat
[ 14.790801] F2FS-fs (mmcblk0p13): recover_data: ino = 7a (i_size: recover) recovered = 0, err = 0
[ 14.791477] F2FS-fs (mmcblk0p13): recover_data: ino = 7a (i_size: recover) recovered = 47, err = 0
[ 14.791488] F2FS-fs (mmcblk0p13): recover_inode: ino = 7b, name = system@framework@boot.oat
[ 14.791535] F2FS-fs (mmcblk0p13): recover_data: ino = 7b (i_size: recover) recovered = 0, err = 0
[ 14.792128] F2FS-fs (mmcblk0p13): recover_data: ino = 7b (i_size: recover) recovered = 47, err = 0
[ 14.794039] F2FS-fs (mmcblk0p13): checkpoint: version = b
[ 14.794168] F2FS-fs (mmcblk0p13): Mounted with checkpoint version = b
[ 14.794486] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/userdata,target=/data,type=f2fs)=0
[ 14.797568] init: (Parsing /system/etc/init/atrace.rc took 0.00s.)
[ 14.797883] init: (Parsing /system/etc/init/audioserver.rc took 0.00s.)
[ 14.798084] init: (Parsing /system/etc/init/bootanim.rc took 0.00s.)
[ 14.798356] init: (Parsing /system/etc/init/bootstat.rc took 0.00s.)
[ 14.798598] init: (Parsing /system/etc/init/cameraserver.rc took 0.00s.)
[ 14.798798] init: (Parsing /system/etc/init/debuggerd.rc took 0.00s.)
[ 14.798992] init: (Parsing /system/etc/init/debuggerd64.rc took 0.00s.)
[ 14.799231] init: (Parsing /system/etc/init/drmserver.rc took 0.00s.)
[ 14.799532] init: (Parsing /system/etc/init/dumpstate.rc took 0.00s.)
[ 14.799733] init: (Parsing /system/etc/init/gatekeeperd.rc took 0.00s.)
[ 14.799982] init: (Parsing /system/etc/init/init-debug.rc took 0.00s.)
[ 14.800201] init: (Parsing /system/etc/init/installd.rc took 0.00s.)
[ 14.800423] init: (Parsing /system/etc/init/keystore.rc took 0.00s.)
[ 14.800648] init: (Parsing /system/etc/init/lmkd.rc took 0.00s.)
[ 14.801040] init: (Parsing /system/etc/init/logcatd.rc took 0.00s.)
[ 14.801278] init: (Parsing /system/etc/init/logd.rc took 0.00s.)
[ 14.801496] init: (Parsing /system/etc/init/mdnsd.rc took 0.00s.)
[ 14.801713] init: (Parsing /system/etc/init/mediacodec.rc took 0.00s.)
[ 14.801912] init: (Parsing /system/etc/init/mediadrmserver.rc took 0.00s.)
[ 14.802111] init: (Parsing /system/etc/init/mediaextractor.rc took 0.00s.)
[ 14.802331] init: (Parsing /system/etc/init/mediaserver.rc took 0.00s.)
[ 14.802567] init: (Parsing /system/etc/init/mtpd.rc took 0.00s.)
[ 14.802775] init: (Parsing /system/etc/init/netd.rc took 0.00s.)
[ 14.802974] init: (Parsing /system/etc/init/perfprofd.rc took 0.00s.)
[ 14.803177] init: (Parsing /system/etc/init/racoon.rc took 0.00s.)
[ 14.804419] init: ignored duplicate definition of service 'ril-daemon’init: (Parsing /system/etc/init/rild.rc took 0.00s.)
[ 14.804693] init: (Parsing /system/etc/init/servicemanager.rc took 0.00s.)
[ 14.804913] init: (Parsing /system/etc/init/surfaceflinger.rc took 0.00s.)
[ 14.805148] init: (Parsing /system/etc/init/uncrypt.rc took 0.00s.)
[ 14.805413] init: (Parsing /system/etc/init/vdc.rc took 0.00s.)
[ 14.805652] init: (Parsing /system/etc/init/vold.rc took 0.00s.)
[ 14.806692] init: property_set(“ro.board.platform”, “rk3399”) failed
[ 14.807071] init: property_set(“ro.rk.screenoff_time”, “2147483647”) failed
[ 14.807233] init: property_set(“ro.rk.screenshot_enable”, “true”) failed
[ 14.807342] init: (Loading properties from /system/build.prop took 0.00s.)
[ 14.807385] init: (Loading properties from /vendor/build.prop took 0.00s.)
[ 14.807417] init: (Loading properties from /factory/factory.prop took 0.00s.)
[ 14.807512] fs_mgr: Warning: unknown flag resize
[ 14.807595] init: /recovery not specified in fstab
[ 14.807699] init: Starting service ‘healthd’…
[ 14.808100] init: cannot find ‘/system/bin/displayd’ (No such file or directory), disabling ‘displayd’
[ 14.808653] init: Starting service ‘earlylogs’…
[ 14.809859] init: Starting service ‘zygote’…
[ 14.810353] init: Starting service ‘zygote_secondary’…
[ 14.810849] init: Starting service ‘lmkd’…
[ 14.811381] init: Starting service ‘servicemanager’…
[ 14.812134] init: Starting service ‘surfaceflinger’…
[ 14.814216] binder: 196:196 transaction failed 29189/-22, size 0-0 line 2951
[ 14.814947] init: Starting service ‘vold’…
[ 14.815315] random: app_process64: uninitialized urandom read (40 bytes read, 105 bits of entropy available)
[ 14.816372] random: elogs.sh: uninitialized urandom read (40 bytes read, 105 bits of entropy available)
[ 14.816582] random: surfaceflinger: uninitialized urandom read (40 bytes read, 105 bits of entropy available)
[ 14.818504] random: lmkd: uninitialized urandom read (40 bytes read, 105 bits of entropy available)
[ 14.820006] random: servicemanager: uninitialized urandom read (40 bytes read, 105 bits of entropy available)
[ 14.825985] random: app_process32: uninitialized urandom read (40 bytes read, 106 bits of entropy available)
[ 14.827712] init: insmod: open(“/system/lib/modules/ump.ko”) failed: No such file or directoryinit: Service ‘earlylogs’ (pid 197) exited with status 0
[ 14.828016] init: insmod: open(“/system/lib/modules/mali.ko”) failed: No such file or directoryinit: insmod: open(“/system/lib/modules/mali_kbase.ko”) failed: No such file or directoryinit: insmod: open(“/system/lib/modules/rk30_mirroring.ko”) failed: No such file or directory
[ 14.828323] random: vold: uninitialized urandom read (40 bytes read, 106 bits of entropy available)
[ 14.829242] init: finit_module for “/system/lib/modules/rk29-ipp.ko” failed: Exec format errorinit: insmod: open(“/system/lib/modules/pvrsrvkm.ko”) failed: No such file or directoryinit: finit_module for “/drmboot.ko” failed: Exec format errorfs_mgr: Warning: unknown flag resize
[ 14.831563] zram0: detected capacity change from 0 to 533413888
[ 14.835164] random: mkswap: uninitialized urandom read (40 bytes read, 106 bits of entropy available)
[ 14.861060] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
[ 14.862846] init: Starting service ‘debuggerd’…
[ 14.863727] init: Starting service ‘debuggerd64’…
[ 14.872855] init: Not bootcharting.
[ 14.989420] fs_mgr: Warning: unknown flag resize
[ 15.062857] init: Starting service ‘exec 1 (/system/bin/tzdatacheck)’…
[ 15.076706] init: Service ‘exec 1 (/system/bin/tzdatacheck)’ (pid 224) exited with status 0
[ 15.083168] audit: type=1400 audit(1358499016.530:4): avc: denied { setattr } for pid=1 comm=“init” name=“cifsmanager” dev=“mmcblk0p13” ino=86 scontext=u:r:init:s0 tcontext=u:object_r:cifsmanager_exec:s0 tclass=dir permissive=1
[ 15.092536] F2FS-fs (mmcblk0p13): acl options not supported
[ 15.092561] F2FS-fs (mmcblk0p13): Unrecognized mount option “errors=panic” or missing value
[ 15.103052] init: write_file: Unable to open ‘/proc/sys/kernel/core_pattern’: No such file or directory
[ 15.104138] init: (Loading properties from /data/local.prop took 0.00s.)
[ 15.120412] init: Starting service ‘logd’…
[ 15.121150] init: Starting service ‘logd-reinit’…
[ 15.122970] init: write_file: Unable to open ‘/proc/sys/vm/min_free_order_shift’: No such file or directory
[ 15.124524] init: SELinux: Could not stat /sys/devices/system/cpu/cpufreq/interactive: No such file or directory.
[ 15.125462] init: write_file: Unable to open ‘/proc/sys/vm/lazy_vfree_tlb_flush_all_threshold’: No such file or directory
[ 15.127476] audit: type=1400 audit(1358499016.573:5): avc: denied { relabelto } for pid=1 comm=“init” name=“recovery” dev=“tmpfs” ino=2499 scontext=u:r:init:s0 tcontext=u:object_r:recovery_block_device:s0 tclass=lnk_file permissive=1
[ 15.127560] audit: type=1400 audit(1358499016.573:6): avc: denied { relabelto } for pid=1 comm=“init” name=“boot” dev=“tmpfs” ino=2495 scontext=u:r:init:s0 tcontext=u:object_r:boot_block_device:s0 tclass=lnk_file permissive=1
[ 15.128904] audit: type=1400 audit(1358499016.573:7): avc: denied { getattr } for pid=1 comm=“init” path=“/system/xbin/fsu” dev=“mmcblk0p10” ino=2791 scontext=u:r:init:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 15.128949] init: Starting service ‘fsud’…
[ 15.129671] init: Starting service ‘vm_daemon’…
[ 15.131760] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 15.131780] init: write: cannot expand ‘${ro.serialno}’
[ 15.132235] file system registered
[ 15.133965] audit: type=1400 audit(1358499016.580:12): avc: denied { transition } for pid=233 comm=“init” path=“/system/xbin/fsu” dev=“mmcblk0p10” ino=2791 scontext=u:r:init:s0 tcontext=u:r:systemdaemon:s0 tclass=process permissive=1
[ 15.134013] audit: type=1400 audit(1358499016.580:13): avc: denied { entrypoint } for pid=233 comm=“init” path=“/system/xbin/fsu” dev=“mmcblk0p10” ino=2791 scontext=u:r:systemdaemon:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
[ 15.137957] using random self ethernet address
[ 15.137972] using random host ethernet address
[ 15.138022] init: write_file: Unable to open ‘/config/usb_gadget/g1/functions/rndis.gs4/wceis’: Permission denied
[ 15.141053] audit: type=1400 audit(1358499016.586:24): avc: denied { rlimitinh } for pid=233 comm=“fsu” scontext=u:r:init:s0 tcontext=u:r:systemdaemon:s0 tclass=process permissive=1
[ 15.141095] audit: type=1400 audit(1358499016.586:25): avc: denied { siginh } for pid=233 comm=“fsu” scontext=u:r:init:s0 tcontext=u:r:systemdaemon:s0 tclass=process permissive=1
[ 15.147268] init: Starting service ‘console’…
[ 15.148376] init: Starting service ‘adbd’…
[ 15.152965] init: Starting service ‘ap_log_srv’…
[ 15.154800] init: Service ‘logd-reinit’ (pid 232) exited with status 145
[ 15.155457] logd.auditd: start
[ 15.155516] logd.klogd: 15153037998
[ 15.156266] init: cannot find ‘/system/bin/update_verifier’ (No such file or directory), disabling ‘exec 2 (/system/bin/update_verifier)’
[ 15.157484] init: Starting service ‘ril-daemon’…
[ 15.158059] init: cannot find ‘/system/bin/install-recovery.sh’ (No such file or directory), disabling ‘flash_recovery’
[ 15.158418] init: Starting service ‘drmservice’…
[ 15.159017] init: cannot find ‘/system/bin/bplus_helper’ (No such file or directory), disabling ‘bplus_helper’
[ 15.159347] init: Service up_eth0 does not have a SELinux domain defined.
[ 15.159385] init: cannot find ‘/system/bin/rk_store_keybox’ (No such file or directory), disabling ‘rk_store_keybox’
[ 15.159547] init: Starting service ‘akmd’…
[ 15.160731] init: Starting service ‘audioserver’…
[ 15.161987] init: Starting service ‘cameraserver’…
[ 15.163259] init: Starting service ‘drm’…
[ 15.163699] init: couldn’t write 250 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[ 15.164372] init: Starting service ‘installd’…
[ 15.165522] init: Starting service ‘keystore’…
[ 15.166724] init: Starting service ‘mediacodec’…
[ 15.167935] init: Starting service ‘mediadrm’…
[ 15.169103] init: Starting service ‘mediaextractor’…
[ 15.170426] init: Starting service ‘media’…
[ 15.171651] init: Starting service ‘netd’…
[ 15.172757] init: Starting service ‘crashlogd’…
[ 15.173657] init: Starting service ‘log-watch’…
[ 15.174946] init: Starting service ‘gatekeeperd’…
ire 15.176309] init: Starting service 'perrfkpro339’9._f
fly_aiojd4_lvds_box:/ $ [ 15.184740] random: nonblocking pool is initialized
[ 15.186741] ret = ffffffffffffffff
[ 15.188179] init: property ‘sys.serialno’ doesn’t exist while expanding ‘${sys.serialno}’
[ 15.188227] init: setprop: cannot expand ‘${sys.serialno}’
[ 15.198682] init: Service ‘akmd’ (pid 246) exited with status 254
[ 15.200850] init: Service ‘drmservice’ (pid 245) exited with status 0
[ 15.220981] init: avc: denied { set } for property=telephony.lteOnCdmaDevice pid=244 uid=0 gid=1001 scontext=u:r:rild:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=1
[ 15.274160] init: Starting service ‘apk_logfs’…
[ 15.283793] init: Service ‘ap_log_srv’ (pid 239) exited with status 0
[ 15.354453] read descriptors
[ 15.354499] read strings
[ 15.439083] type=1400 audit(1358499016.883:35): avc: denied { execute } for pid=298 comm=“audioserver” name=“sh” dev=“mmcblk0p10” ino=411 scontext=u:r:audioserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[ 15.439668] type=1400 audit(1358499016.883:36): avc: denied { read open } for pid=298 comm=“audioserver” path=“/system/bin/sh” dev=“mmcblk0p10” ino=411 scontext=u:r:audioserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[ 15.440913] type=1400 audit(1358499016.886:37): avc: denied { execute_no_trans } for pid=298 comm=“audioserver” path=“/system/bin/sh” dev=“mmcblk0p10” ino=411 scontext=u:r:audioserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[ 15.441809] type=1400 audit(1358499016.886:38): avc: denied { getattr } for pid=298 comm=“sh” path=“/system/bin/sh” dev=“mmcblk0p10” ino=411 scontext=u:r:audioserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[ 15.459321] type=1400 audit(1358499016.903:39): avc: denied { getattr } for pid=298 comm=“sh” path=“/system/bin/toybox” dev=“mmcblk0p10” ino=445 scontext=u:r:audioserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[ 15.459529] type=1400 audit(1358499016.903:40): avc: denied { execute } for pid=298 comm=“sh” name=“toybox” dev=“mmcblk0p10” ino=445 scontext=u:r:audioserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[ 15.459614] type=1400 audit(1358499016.903:41): avc: denied { read open } for pid=298 comm=“sh” path=“/system/bin/toybox” dev=“mmcblk0p10” ino=445 scontext=u:r:audioserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[ 15.459688] type=1400 audit(1358499016.903:42): avc: denied { execute_no_trans } for pid=298 comm=“sh” path=“/system/bin/toybox” dev=“mmcblk0p10” ino=445 scontext=u:r:audioserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[ 15.547938] type=1400 audit(1358499016.993:49): avc: denied { sys_ptrace } for pid=311 comm=“fsu” capability=19 scontext=u:r:systemdaemon:s0 tcontext=u:r:systemdaemon:s0 tclass=capabil
[ 15.548400] type=1400 audit(1358499016.993:50): avc: denied { read } for pid=311 comm=“fsu” scontext=u:r:systemdaemon:s0 tcontext=u:r:audioserver:s0 tclass=f
[ 15.548484] type=1400 audit(1358499016.993:51): avc: denied { search } for pid=311 comm=“fsu” name=“309” dev=“proc” ino=15630 scontext=u:r:systemdaemon:s0 tcontext=u:r:audioserver:s0 tclass=
[ 15.548566] type=1400 audit(1358499016.993:52): avc: denied { read } for pid=311 comm=“fsu” name=“exe” dev=“proc” ino=15631 scontext=u:r:systemdaemon:s0 tcontext=u:r:audioserver:s0 tclass=lnk_f
[ 15.569391] type=1400 audit(1358499017.006:53): avc: denied { open } for pid=323 comm=“fsu” path=“/proc/309/cmdline” dev=“proc” ino=15640 scontext=u:r:systemdaemon:s0 tcontext=u:r:audioserver:s0 tclass=f
[ 15.569906] type=1400 audit(1358499017.013:54): avc: denied { setuid } for pid=323 comm=“fsu” capability=7 scontext=u:r:systemdaemon:s0 tcontext=u:r:systemdaemon:s0 tclass=capabil
[ 15.589051] init: Untracked pid 311 exited with status 0
[ 15.612652] type=1400 audit(1358499017.020:55): avc: denied { setgid } for pid=323 comm=“fsu” capability=6 scontext=u:r:systemdaemon:s0 tcontext=u:r:systemdaemon:s0 tclass=capabil
[ 15.612875] type=1400 audit(1358499017.020:56): avc: denied { execute } for pid=323 comm=“fsu” name=“sh” dev=“mmcblk0p10” ino=411 scontext=u:r:systemdaemon:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[ 15.612960] type=1400 audit(1358499017.020:57): avc: denied { read open } for pid=323 comm=“fsu” path=“/system/bin/sh” dev=“mmcblk0p10” ino=411 scontext=u:r:systemdaemon:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[ 15.613033] type=1400 audit(1358499017.020:58): avc: denied { execute_no_trans } for pid=323 comm=“fsu” path=“/system/bin/sh” dev=“mmcblk0p10” ino=411 scontext=u:r:systemdaemon:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[ 15.613106] type=1400 audit(1358499017.020:59): avc: denied { getattr } for pid=323 comm=“sh” path=“/system/bin/sh” dev=“mmcblk0p10” ino=411 scontext=u:r:systemdaemon:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[ 15.613176] type=1400 audit(1358499017.020:60): avc: denied { getattr } for pid=323 comm=“sh” path=“/vendor” dev=“rootfs” ino=8782 scontext=u:r:systemdaemon:s0 tcontext=u:object_r:rootfs:s0 tclass=lnk_f
[ 15.613247] type=1400 audit(1358499017.023:61): avc: denied { getattr } for pid=323 comm=“sh” path=“/system/bin/toybox” dev=“mmcblk0p10” ino=445 scontext=u:r:systemdaemon:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[ 15.613316] type=1400 audit(1358499017.023:62): avc: denied { execute } for pid=323 comm=“sh” name=“toybox” dev=“mmcblk0p10” ino=445 scontext=u:r:systemdaemon:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[ 15.613387] type=1400 audit(1358499017.023:63): avc: denied { read open } for pid=323 comm=“sh” path=“/system/bin/toybox” dev=“mmcblk0p10” ino=445 scontext=u:r:systemdaemon:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[ 15.613469] type=1400 audit(1358499017.023:64): avc: denied { execute_no_trans } for pid=323 comm=“sh” path=“/system/bin/toybox” dev=“mmcblk0p10” ino=445 scontext=u:r:systemdaemon:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=f
[ 15.649480] type=1400 audit(1358499017.093:70): avc: denied { execute } for pid=334 comm=“fsu” name=“sh” dev=“mmcblk0p10” ino=411 scontext=u:r:systemdaemon:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[ 15.650054] type=1400 audit(1358499017.093:71): avc: denied { read open } for pid=334 comm=“fsu” path=“/system/bin/sh” dev=“mmcblk0p10” ino=411 scontext=u:r:systemdaemon:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[ 15.650181] type=1400 audit(1358499017.093:72): avc: denied { execute_no_trans } for pid=334 comm=“fsu” path=“/system/bin/sh” dev=“mmcblk0p10” ino=411 scontext=u:r:systemdaemon:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[ 15.650258] type=1400 audit(1358499017.093:73): avc: denied { getattr } for pid=334 comm=“sh” path=“/system/bin/sh” dev=“mmcblk0p10” ino=411 scontext=u:r:systemdaemon:s0 tcontext=u:object_r:shell_exec:s0 tclass=f
[ 15.681834] init: Untracked pid 331 exited with status 0
[ 15.816377] healthd: BatteryCurrentNowPath not found
[ 15.816410] healthd: BatteryCycleCountPath not found
[ 15.891007] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 15.891833] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 15.902720] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 15.902738] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 15.902746] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 15.902757] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 15.902764] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 15.919591] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 15.919838] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 15.951731] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 15.951932] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 15.962004] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 15.962026] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 15.962036] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 15.962046] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 15.962053] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 15.976403] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 15.976589] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 16.010101] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 16.010278] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 16.020477] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[ 16.020495] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[ 16.020504] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[ 16.020514] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[ 16.020521] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[ 16.033872] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[ 16.034128] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[ 16.193165] init: Starting service ‘bootanim’…
[ 16.194111] [GSLX680] Enter gsl_ts_late_resume
[ 16.194114] I’am in gsl_ts_resume() start
[ 16.312904] gsl_ts_read set data address fail!
[ 16.312908] #########check mem read 0xb0 = 0 0 0 0 #########
[ 17.339846] I read reg 0xf0 is 0
[ 17.346307] I write reg 0xf0 0x12
[ 17.353296] I read reg 0xf0 is 0x12
[ 17.469186] =============gsl_load_fw start==============
[ 17.469189] --------------3680B-----------------------
[ 17.514985] =============gsl_load_fw end==============
[ 17.623498] #########check mem read 0xb0 = 0 0 0 0 #########
[ 18.650224] I read reg 0xf0 is 0
[ 18.656492] I write reg 0xf0 0x12
[ 18.663557] I read reg 0xf0 is 0x12
[ 18.779350] =============gsl_load_fw start==============
[ 18.779353] --------------3680B-----------------------
[ 18.827318] =============gsl_load_fw end==============
[ 18.902689] gsl_ts_resume () end
[ 18.912299] gsl_ts_read set data address fail!
[ 18.912330] gslX680 4-0041: read failed
[ 18.936124] dwhdmi-rockchip ff940000.hdmi: Rate 181250000 missing; compute N dynamically
[ 18.981503] gsl_ts_read set data address fail!
[ 18.981546] gslX680 4-0041: read failed
[ 18.994002] dwhdmi-rockchip ff940000.hdmi: Rate 181250000 missing; compute N dynamically
[ 19.052315] gsl_ts_read set data address fail!
[ 19.052382] gslX680 4-0041: read failed
[ 19.097996] Freeing drm_logo memory: 488K
[ 19.131385] gsl_ts_read set data address fail!
[ 19.131435] gslX680 4-0041: read failed
[ 19.215781] gsl_ts_read set data address fail!
[ 19.215843] gslX680 4-0041: read failed
[ 19.284301] gsl_ts_read set data address fail!
[ 19.284342] gslX680 4-0041: read failed
[ 19.359132] gsl_ts_read set data address fail!
[ 19.359219] gslX680 4-0041: read failed
[ 19.431086] gsl_ts_read set data address fail!
[ 19.431124] gslX680 4-0041: read failed
[ 19.502126] gsl_ts_read set data address fail!
[ 19.502170] gslX680 4-0041: read failed
[ 19.572131] gsl_ts_read set data address fail!
[ 19.572398] gslX680 4-0041: read failed
[ 19.648492] gsl_ts_read set data address fail!
[ 19.648536] gslX680 4-0041: read failed
[ 19.722118] gsl_ts_read set data address fail!
[ 19.722157] gslX680 4-0041: read failed
[ 19.792183] gsl_ts_read set data address fail!
[ 19.792227] gslX680 4-0041: read failed
[ 19.865672] gsl_ts_read set data address fail!
[ 19.865714] gslX680 4-0041: read failed
[ 19.942505] gsl_ts_read set data address fail!
[ 19.942549] gslX680 4-0041: read failed
[ 20.015523] gsl_ts_read set data address fail!
[ 20.015567] gslX680 4-0041: read failed
[ 20.085204] gsl_ts_read set data address fail!
[ 20.085246] gslX680 4-0041: read failed
[ 20.155482] gsl_ts_read set data address fail!
[ 20.155524] gslX680 4-0041: read failed
[ 20.225359] gsl_ts_read set data address fail!
[ 20.225404] gslX680 4-0041: read failed
[ 20.301948] gsl_ts_read set data address fail!
[ 20.301991] gslX680 4-0041: read failed
[ 20.372180] gsl_ts_read set data address fail!
[ 20.372224] gslX680 4-0041: read failed
[ 20.442287] gsl_ts_read set data address fail!
[ 20.442329] gslX680 4-0041: read failed
[ 20.518810] gsl_ts_read set data address fail!
[ 20.518852] gslX680 4-0041: read failed
[ 20.588852] gsl_ts_read set data address fail!
[ 20.588893] gslX680 4-0041: read failed
[ 20.658734] gsl_ts_read set data address fail!
[ 20.658776] gslX680 4-0041: read failed
[ 20.729065] gsl_ts_read set data address fail!
[ 20.729109] gslX680 4-0041: read failed
[ 20.802024] gsl_ts_read set data address fail!
[ 20.802065] gslX680 4-0041: read failed
[ 20.872289] gsl_ts_read set data address fail!
[ 20.872332] gslX680 4-0041: read failed
[ 20.945452] gsl_ts_read set data address fail!
[ 20.945489] gslX680 4-0041: read failed
[ 21.019169] gsl_ts_read set data address fail!
[ 21.019215] gslX680 4-0041: read failed
[ 21.092026] gsl_ts_read set data address fail!
[ 21.092067] gslX680 4-0041: read failed
[ 21.161927] gsl_ts_read set data address fail!
[ 21.161969] gslX680 4-0041: read failed
[ 21.232653] gsl_ts_read set data address fail!
[ 21.232681] gslX680 4-0041: read failed
[ 21.305649] gsl_ts_read set data address fail!
[ 21.305695] gslX680 4-0041: read failed
[ 21.384745] gsl_ts_read set data address fail!
[ 21.384790] gslX680 4-0041: read failed
[ 21.455893] gsl_ts_read set data address fail!
[ 21.455941] gslX680 4-0041: read failed
[ 21.528956] gsl_ts_read set data address fail!
[ 21.528997] gslX680 4-0041: read failed
[ 21.602725] gsl_ts_read set data address fail!
[ 21.602769] gslX680 4-0041: read failed
[ 21.675608] gsl_ts_read set data address fail!
[ 21.675655] gslX680 4-0041: read failed
[ 21.752491] gsl_ts_read set data address fail!
[ 21.752536] gslX680 4-0041: read failed
[ 21.828907] gsl_ts_read set data address fail!
[ 21.828949] gslX680 4-0041: read failed
[ 21.899241] gsl_ts_read set data address fail!
[ 21.899283] gslX680 4-0041: read failed
[ 21.973258] gsl_ts_read set data address fail!
[ 21.973300] gslX680 4-0041: read failed
[ 22.045268] gsl_ts_read set data address fail!
[ 22.045309] gslX680 4-0041: read failed
[ 22.116012] gsl_ts_read set data address fail!
[ 22.116054] gslX680 4-0041: read failed
[ 22.189168] gsl_ts_read set data address fail!
[ 22.189210] gslX680 4-0041: read failed
[ 22.262249] gsl_ts_read set data address fail!
[ 22.262289] gslX680 4-0041: read failed
[ 22.332043] gsl_ts_read set data address fail!
[ 22.332085] gslX680 4-0041: read failed
[ 22.402176] gsl_ts_read set data address fail!
[ 22.402218] gslX680 4-0041: read failed
[ 22.472049] gsl_ts_read set data address fail!
[ 22.472090] gslX680 4-0041: read failed
[ 22.542022] gsl_ts_read set data address fail!
[ 22.542067] gslX680 4-0041: read failed
[ 22.612318] gsl_ts_read set data address fail!
[ 22.612361] gslX680 4-0041: read failed
[ 22.685674] gsl_ts_read set data address fail!
[ 22.685716] gslX680 4-0041: read failed
[ 22.758848] gsl_ts_read set data address fail!
[ 22.758889] gslX680 4-0041: read failed
[ 22.828544] gsl_ts_read set data address fail!
[ 22.828587] gslX680 4-0041: read failed
[ 22.898639] gsl_ts_read set data address fail!
[ 22.898679] gslX680 4-0041: read failed
[ 22.968857] gsl_ts_read set data address fail!
[ 22.968893] gslX680 4-0041: read failed
[ 23.039458] gsl_ts_read set data address fail!
[ 23.039498] gslX680 4-0041: read failed
[ 23.113064] gsl_ts_read set data address fail!
[ 23.113111] gslX680 4-0041: read failed
[ 23.185229] gsl_ts_read set data address fail!
[ 23.185266] gslX680 4-0041: read failed
[ 23.255505] gsl_ts_read set data address fail!
[ 23.255544] gslX680 4-0041: read failed
[ 23.325492] gsl_ts_read set data address fail!
[ 23.325529] gslX680 4-0041: read failed
[ 23.395988] gsl_ts_read set data address fail!
[ 23.396028] gslX680 4-0041: read failed
[ 23.468650] gsl_ts_read set data address fail!
[ 23.468691] gslX680 4-0041: read failed
[ 23.539065] gsl_ts_read set data address fail!
[ 23.539110] gslX680 4-0041: read failed
[ 23.612404] gsl_ts_read set data address fail!
[ 23.612444] gslX680 4-0041: read failed
[ 23.685353] gsl_ts_read set data address fail!
[ 23.685392] gslX680 4-0041: read failed
[ 23.755358] gsl_ts_read set data address fail!
[ 23.755395] gslX680 4-0041: read failed
[ 23.825187] gsl_ts_read set data address fail!
[ 23.825226] gslX680 4-0041: read failed
[ 23.895261] gsl_ts_read set data address fail!
[ 23.895299] gslX680 4-0041: read failed
[ 23.966833] gsl_ts_read set data address fail!
[ 23.966873] gslX680 4-0041: read failed
[ 24.038488] gsl_ts_read set data address fail!
[ 24.038527] gslX680 4-0041: read failed
[ 24.108702] gsl_ts_read set data address fail!
[ 24.108740] gslX680 4-0041: read failed
[ 24.178587] gsl_ts_read set data address fail!
[ 24.178626] gslX680 4-0041: read failed
[ 24.248585] gsl_ts_read set data address fail!
[ 24.248622] gslX680 4-0041: read failed
[ 24.318269] gsl_ts_read set data address fail!
[ 24.318307] gslX680 4-0041: read failed
[ 24.389175] gsl_ts_read set data address fail!
[ 24.389213] gslX680 4-0041: read failed
[ 24.457756] gsl_ts_read set data address fail!
[ 24.457792] gslX680 4-0041: read failed
[ 24.528876] gsl_ts_read set data address fail!
[ 24.528918] gslX680 4-0041: read failed
[ 24.598302] gsl_ts_read set data address fail!
[ 24.598341] gslX680 4-0041: read failed
[ 24.668807] gsl_ts_read set data address fail!
[ 24.668847] gslX680 4-0041: read failed
[ 24.738598] gsl_ts_read set data address fail!
[ 24.738635] gslX680 4-0041: read failed
[ 24.809524] gsl_ts_read set data address fail!
[ 24.809562] gslX680 4-0041: read failed
[ 24.882145] gsl_ts_read set data address fail!
[ 24.882194] gslX680 4-0041: read failed
[ 24.952537] gsl_ts_read set data address fail!
[ 24.952583] gslX680 4-0041: read failed
[ 25.025949] gsl_ts_read set data address fail!
[ 25.025990] gslX680 4-0041: read failed
[ 25.098409] gsl_ts_read set data address fail!
[ 25.098447] gslX680 4-0041: read failed
[ 25.168488] gsl_ts_read set data address fail!
[ 25.168526] gslX680 4-0041: read failed
[ 25.239087] gsl_ts_read set data address fail!
[ 25.239126] gslX680 4-0041: read failed
[ 25.312140] gsl_ts_read set data address fail!
[ 25.312176] gslX680 4-0041: read failed
[ 25.383132] gsl_ts_read set data address fail!
[ 25.383178] gslX680 4-0041: read failed
[ 25.456366] gsl_ts_read set data address fail!
[ 25.456408] gslX680 4-0041: read failed
[ 25.524655] gsl_ts_read set data address fail!
[ 25.524694] gslX680 4-0041: read failed
[ 25.595193] gsl_ts_read set data address fail!
[ 25.595231] gslX680 4-0041: read failed
[ 25.665346] gsl_ts_read set data address fail!
[ 25.665384] gslX680 4-0041: read failed
[ 25.735548] gsl_ts_read set data address fail!
[ 25.735586] gslX680 4-0041: read failed
[ 25.806275] gsl_ts_read set data address fail!
[ 25.806314] gslX680 4-0041: read failed
[ 25.880603] gsl_ts_read set data address fail!
[ 25.880647] gslX680 4-0041: read failed
[ 25.952432] gsl_ts_read set data address fail!
[ 25.952525] gslX680 4-0041: read failed
[ 26.025528] gsl_ts_read set data address fail!
[ 26.025570] gslX680 4-0041: read failed
[ 26.095678] gsl_ts_read set data address fail!
[ 26.095720] gslX680 4-0041: read failed
[ 26.168855] gsl_ts_read set data address fail!
[ 26.168898] gslX680 4-0041: read failed
[ 26.240966] gsl_ts_read set data address fail!
[ 26.241011] gslX680 4-0041: read failed
[ 26.308138] gsl_ts_read set data address fail!
[ 26.308206] gslX680 4-0041: read failed
[ 26.379063] gsl_ts_read set data address fail!
[ 26.379113] gslX680 4-0041: read failed
[ 26.452270] gsl_ts_read set data address fail!
[ 26.452311] gslX680 4-0041: read failed
[ 26.525570] gsl_ts_read set data address fail!
[ 26.525612] gslX680 4-0041: read failed
[ 26.595276] gsl_ts_read set data address fail!
[ 26.595319] gslX680 4-0041: read failed
[ 26.665602] gsl_ts_read set data address fail!
[ 26.665646] gslX680 4-0041: read failed
[ 26.738644] gsl_ts_read set data address fail!
[ 26.738689] gslX680 4-0041: read failed
[ 26.809246] gsl_ts_read set data address fail!
[ 26.809292] gslX680 4-0041: read failed
[ 26.882530] gsl_ts_read set data address fail!
[ 26.882575] gslX680 4-0041: read failed
[ 26.955937] gsl_ts_read set data address fail!
[ 26.955984] gslX680 4-0041: read failed
[ 27.029005] gsl_ts_read set data address fail!
[ 27.029057] gslX680 4-0041: read failed
[ 27.102318] gsl_ts_read set data address fail!
[ 27.102363] gslX680 4-0041: read failed
[ 27.175695] gsl_ts_read set data address fail!
[ 27.175755] gslX680 4-0041: read failed
[ 27.255274] gsl_ts_read set data address fail!
[ 27.255321] gslX680 4-0041: read failed
[ 27.325692] gsl_ts_read set data address fail!
[ 27.325741] gslX680 4-0041: read failed
[ 27.398904] gsl_ts_read set data address fail!
[ 27.398951] gslX680 4-0041: read failed
[ 27.469252] gsl_ts_read set data address fail!
[ 27.469294] gslX680 4-0041: read failed
[ 27.542593] gsl_ts_read set data address fail!
[ 27.542640] gslX680 4-0041: read failed
[ 27.616005] gsl_ts_read set data address fail!
[ 27.616052] gslX680 4-0041: read failed
[ 27.688959] gsl_ts_read set data address fail!
[ 27.689005] gslX680 4-0041: read failed
[ 27.762225] gsl_ts_read set data address fail!
[ 27.762276] gslX680 4-0041: read failed
[ 27.833056] gsl_ts_read set data address fail!
[ 27.833107] gslX680 4-0041: read failed
[ 27.905639] gsl_ts_read set data address fail!
[ 27.905690] gslX680 4-0041: read failed
[ 27.979176] gsl_ts_read set data address fail!
[ 27.979220] gslX680 4-0041: read failed
[ 28.052692] gsl_ts_read set data address fail!
[ 28.052738] gslX680 4-0041: read failed
[ 28.125773] gsl_ts_read set data address fail!
[ 28.125851] gslX680 4-0041: read failed
[ 28.198951] gsl_ts_read set data address fail!
[ 28.199001] gslX680 4-0041: read failed
[ 28.272650] gsl_ts_read set data address fail!
[ 28.272698] gslX680 4-0041: read failed
[ 28.345696] gsl_ts_read set data address fail!
[ 28.345747] gslX680 4-0041: read failed
[ 28.418934] gsl_ts_read set data address fail!
[ 28.418982] gslX680 4-0041: read failed
[ 28.492735] gsl_ts_read set data address fail!
[ 28.492783] gslX680 4-0041: read failed
[ 28.566095] gsl_ts_read set data address fail!
[ 28.566142] gslX680 4-0041: read failed
[ 28.639540] gsl_ts_read set data address fail!
[ 28.639580] gslX680 4-0041: read failed
[ 28.713069] gsl_ts_read set data address fail!
[ 28.713114] gslX680 4-0041: read failed
[ 28.786225] gsl_ts_read set data address fail!
[ 28.786269] gslX680 4-0041: read failed
[ 28.854569] gsl_ts_read set data address fail!
[ 28.854612] gslX680 4-0041: read failed
[ 28.921465] gslX680 4-0041: read failed
130|rk3399_firefly_aiojd4_lvds_box:/ $ [ 28.992561] gsl_ts_read set data address fail!
[ 28.992612] gslX680 4-0041: read failed
[ 29.066370] gsl_ts_read set data address fail!
[ 29.066414] gslX680 4-0041: read failed
[ 29.139519] gsl_ts_read set data address fail!
[ 29.139564] gslX680 4-0041: read failed
130|rk3399_firefly_aiojd4_lvds_box:/ $ [ 29.212856] gsl_ts_read set data address fail!
[ 29.212905] gslX680 4-0041: read failed
[ 29.285564] gsl_ts_read set data address fail!
[ 29.285611] gslX680 4-0041: read failed
[ 29.358729] gsl_ts_read set data address fail!
[ 29.358776] gslX680 4-0041: read failed
130|rk3399_firefly_aiojd4_lvds_box:/ $ [ 29.429034] gsl_ts_read set data address fail!
[ 29.429081] gslX680 4-0041: read failed
[ 29.502553] gsl_ts_read set data address fail!
[ 29.502598] gslX680 4-0041: read failed
[ 29.575428] gsl_ts_read set data address fail!
[ 29.575473] gslX680 4-0041: read
130|rk3399_firefly_aiojd4_lvds_box:/ $ failed
[ 29.645921] gsl_ts_read set data address fail!
[ 29.645967] gslX680 4-0041: read failed
[ 29.719276] gsl_ts_read set data address fail!
[ 29.719321] gslX680 4-0041: read failed
130|rk3399_firefly_aiojd4_lvds_box:/ $ [ 29.792565] gsl_ts_read set data address fail!
[ 29.792612] gslX680 4-0041: read failed
[ 29.865865] gsl_ts_read set data address fail!
[ 29.865910] gslX680 4-0041: read failed
[ 29.938931] gsl_ts_read set data address fail!
[ 29.938979] gslX680 4-0041: read failed
130|rk3399_firefly_aiojd4_lvds_box:/ $ [ 30.012457] gsl_ts_read set data address fail!
[ 30.012556] gslX680 4-0041: read failed
[ 30.085736] gsl_ts_read set data address fail!
[ 30.085786] gslX680 4-0041: read failed
[ 30.158860] gsl_ts_read set data address fail!
[ 30.158908] gslX680 4-0041: read failed
130|rk3399_firefly_aiojd4_lvds_box:/ $ [ 30.229046] gsl_ts_read set data address fail!
[ 30.229093] gslX680 4-0041: read failed
[ 30.302360] gsl_ts_read set data address fail!
[ 30.302414] gslX680 4-0041: read failed
[ 30.375731] gsl_ts_read set data address fail!
[ 30.375780] gslX680 4-0041: read failed
[ 30.449100] gsl_ts_read set data address fail!
[ 30.449184] gslX680 4-0041: read failed
130|rk3399_firefly_aiojd4_lvds_box:/ $ [ 30.522258] gsl_ts_read set data address fail!
[ 30.522308] gslX680 4-0041: read failed
[ 30.595621] gsl_ts_read set data address fail!
[ 30.595666] gslX680 4-0041: read failed
130|rk3399_firefly_aiojd4_lvds_box:/ $ [ 30.669183] gsl_ts_read set data address fail!
[ 30.669226] gslX680 4-0041: read failed
[ 30.743118] gsl_ts_read set data address fail!
[ 30.743164] gslX680 4-0041: read failed
[ 30.816317] gsl_ts_read set data address fail!
[ 30.816361] gslX680 4-0041: read failed
130|rk3399_firefly_aiojd4_lvds_box:/ $ [ 30.895847] gsl_ts_read set data address fail!
[ 30.895884] gslX680 4-0041: read failed
[ 30.969487] gsl_ts_read set data address fail!
[ 30.969532] gslX680 4-0041: read failed
[ 31.037716] gsl_ts_read set data address fail!
[ 31.037768] gslX680 4-0041: read failed
[ 31.109105] gsl_ts_read set data address fail!
[ 31.109190] gslX680 4-0041: read failed
130|rk3399_firefly_aiojd4_lvds_box:/ $ [ 31.182164] gsl_ts_read set data address fail!
[ 31.182214] gslX680 4-0041: read failed
[ 31.252176] gsl_ts_read set data address fail!
[ 31.252223] gslX680 4-0041: read failed
[ 31.322350] gsl_ts_read set data address fail!
[ 31.322401] gslX680 4-0041: read failed
130|rk3399_firefly_aiojd4_lvds_box:/ $ [ 31.395665] gsl_ts_read set data address fail!
[ 31.395714] gslX680 4-0041: read failed
[ 31.469059] gsl_ts_read set data address fail!
[ 31.469105] gslX680 4-0041: read failed
[ 31.542435] gsl_ts_read set data address fail!
[ 31.542524] gslX680 4-0041: read failed
130|rk3399_firefly_aiojd4_lvds_box:/ $ [ 31.615649] gsl_ts_read set data address fail!
[ 31.615698] gslX680 4-0041: read failed
[ 31.688943] gsl_ts_read set data address fail!
[ 31.688992] gslX680 4-0041: read failed
[ 31.762265] gsl_ts_read set data address fail!
[ 31.762313] gslX680 4-0041: read failed
130|rk3399_firefly_aiojd4_lvds_box:/ $ [ 31.835694] gsl_ts_read set data address fail!
[ 31.835741] gslX680 4-0041: read failed
[ 31.909184] gsl_ts_read set data address fail!
[ 31.909231] gslX680 4-0041: read failed
[ 31.982313] gsl_ts_read set data address fail!
[ 31.982360] gslX680 4-0041: read failed
130|rk3399_firefly_aiojd4_lvds_box:/ $ [ 32.055843] gsl_ts_read set data address fail!
[ 32.055889] gslX680 4-0041: read failed
[ 32.129121] gsl_ts_read set data address fail!
[ 32.129213] gslX680 4-0041: read failed
[ 32.202407] gsl_ts_read set data address fail!
[ 32.202457] gslX680 4-0041: read failed
[ 32.275705] gsl_ts_read set data address fail!
[ 32.275762] gslX680 4-0041: read failed
[ 32.349673] gsl_ts_read set data address fail!
[ 32.349724] gslX680 4-0041: read failed
[ 32.424193] gsl_ts_read set data address fail!
[ 32.424245] gslX680 4-0041: read failed
[ 32.495514] gsl_ts_read set data address fail!
[ 32.495557] gslX680 4-0041: read failed
[ 32.565869] gsl_ts_read set data address fail!
[ 32.565921] gslX680 4-0041: read failed
[ 32.639084] gsl_ts_read set data address fail!
[ 32.639197] gslX680 4-0041: read failed
[ 32.712440] gsl_ts_read set data address fail!
[ 32.712534] gslX680 4-0041: read failed
[ 32.785707] gsl_ts_read set data address fail!
[ 32.785754] gslX680 4-0041: read failed
[ 32.859023] gsl_ts_read set data address fail!
[ 32.859074] gslX680 4-0041: read failed
[ 32.934247] gsl_ts_read set data address fail!
[ 32.934298] gslX680 4-0041: read failed
[ 33.009014] gsl_ts_read set data address fail!
[ 33.009061] gslX680 4-0041: read failed
[ 33.078062] gsl_ts_read set data address fail!
[ 33.078112] gslX680 4-0041: read failed
[ 33.149201] gsl_ts_read set data address fail!
[ 33.149248] gslX680 4-0041: read failed
[ 33.217679] gsl_ts_read set data address fail!
[ 33.217724] gslX680 4-0041: read failed
[ 33.289086] gsl_ts_read set data address fail!
[ 33.289191] gslX680 4-0041: read failed
[ 33.362951] gsl_ts_read set data address fail!
[ 33.362997] gslX680 4-0041: read failed
[ 33.436305] gsl_ts_read set data address fail!
[ 33.436349] gslX680 4-0041: read failed
[ 33.517347] gsl_ts_read set data address fail!
[ 33.517396] gslX680 4-0041: read failed
[ 33.584140] gsl_ts_read set data address fail!
[ 33.584191] gslX680 4-0041: read failed
[ 33.655935] gsl_ts_read set data address fail!
[ 33.655980] gslX680 4-0041: read failed
[ 33.729352] gsl_ts_read set data address fail!
[ 33.729401] gslX680 4-0041: read failed
[ 33.802444] gsl_ts_read set data address fail!
[ 33.802530] gslX680 4-0041: read failed
[ 33.875432] gsl_ts_read set data address fail!
[ 33.875480] gslX680 4-0041: read failed
[ 33.945649] gsl_ts_read set data address fail!
[ 33.945697] gslX680 4-0041: read failed
[ 34.019428] gsl_ts_read set data address fail!
[ 34.019472] gslX680 4-0041: read failed
[ 34.093963] gsl_ts_read set data address fail!
[ 34.094007] gslX680 4-0041: read failed
[ 34.166523] gsl_ts_read set data address fail!
[ 34.166567] gslX680 4-0041: read failed
[ 34.239205] gsl_ts_read set data address fail!
[ 34.239252] gslX680 4-0041: read failed
[ 34.312505] gsl_ts_read set data address fail!
[ 34.312553] gslX680 4-0041: read failed
[ 34.385667] gsl_ts_read set data address fail!
[ 34.385713] gslX680 4-0041: read failed
[ 34.459197] gsl_ts_read set data address fail!
[ 34.459241] gslX680 4-0041: read failed
[ 34.532364] gsl_ts_read set data address fail!
[ 34.532412] gslX680 4-0041: read failed
[ 34.606397] gsl_ts_read set data address fail!
[ 34.606446] gslX680 4-0041: read failed
[ 34.679024] gsl_ts_read set data address fail!
[ 34.679074] gslX680 4-0041: read failed
[ 34.752758] gsl_ts_read set data address fail!
[ 34.752802] gslX680 4-0041: read failed
[ 34.826083] gsl_ts_read set data address fail!
[ 34.826142] gslX680 4-0041: read failed
[ 34.899287] gsl_ts_read set data address fail!
[ 34.899340] gslX680 4-0041: read failed
[ 34.973170] gsl_ts_read set data address fail!
[ 34.973227] gslX680 4-0041: read failed
[ 35.045644] gsl_ts_read set data address fail!
[ 35.045695] gslX680 4-0041: read failed
[ 35.119101] gsl_ts_read set data address fail!
[ 35.119181] gslX680 4-0041: read failed
[ 35.192260] gsl_ts_read set data address fail!
[ 35.192306] gslX680 4-0041: read failed
[ 35.265306] gsl_ts_read set data address fail!
[ 35.265349] gslX680 4-0041: read failed
[ 35.335719] gsl_ts_read set data address fail!
[ 35.335763] gslX680 4-0041: read failed
[ 35.409297] gsl_ts_read set data address fail!
[ 35.409344] gslX680 4-0041: read failed
[ 35.482747] gsl_ts_read set data address fail!
[ 35.482791] gslX680 4-0041: read failed
[ 35.555698] gsl_ts_read set data address fail!
[ 35.555742] gslX680 4-0041: read failed
[ 35.629177] gsl_ts_read set data address fail!
[ 35.629228] gslX680 4-0041: read failed
[ 35.702878] gsl_ts_read set data address fail!
[ 35.702924] gslX680 4-0041: read failed
[ 35.775469] gsl_ts_read set data address fail!
[ 35.775515] gslX680 4-0041: read failed
[ 35.845629] gsl_ts_read set data address fail!
[ 35.845673] gslX680 4-0041: read failed
[ 35.919468] gsl_ts_read set data address fail!
[ 35.919513] gslX680 4-0041: read failed
[ 35.992713] gsl_ts_read set data address fail!
[ 35.992756] gslX680 4-0041: read failed
[ 36.065701] gsl_ts_read set data address fail!
[ 36.065748] gslX680 4-0041: read failed
[ 36.139234] gsl_ts_read set data address fail!
[ 36.139281] gslX680 4-0041: read failed
[ 36.212729] gsl_ts_read set data address fail!
[ 36.212777] gslX680 4-0041: read failed
[ 36.285267] gsl_ts_read set data address fail!
[ 36.285311] gslX680 4-0041: read failed
[ 36.355861] gsl_ts_read set data address fail!
[ 36.355907] gslX680 4-0041: read failed
[ 36.424303] gsl_ts_read set data address fail!
[ 36.424351] gslX680 4-0041: read failed
[ 36.496219] gsl_ts_read set data address fail!
[ 36.496262] gslX680 4-0041: read failed
[ 36.569477] gsl_ts_read set data address fail!
[ 36.569525] gslX680 4-0041: read failed
[ 36.642763] gsl_ts_read set data address fail!
[ 36.642807] gslX680 4-0041: read failed
[ 36.715708] gsl_ts_read set data address fail!
[ 36.715769] gslX680 4-0041: read failed
[ 36.789015] gsl_ts_read set data address fail!
[ 36.789068] gslX680 4-0041: read failed
[ 36.862000] gsl_ts_read set data address fail!
[ 36.862050] gslX680 4-0041: read failed
[ 36.940825] gsl_ts_read set data address fail!
[ 36.940872] gslX680 4-0041: read failed
[ 37.012438] gsl_ts_read set data address fail!
[ 37.012506] gslX680 4-0041: read failed
[ 37.085840] gsl_ts_read set data address fail!
[ 37.085883] gslX680 4-0041: read failed
[ 37.162562] gsl_ts_read set data address fail!
[ 37.162609] gslX680 4-0041: read failed
[ 37.238903] gsl_ts_read set data address fail!
[ 37.238948] gslX680 4-0041: read failed
[ 37.309439] gsl_ts_read set data address fail!
[ 37.309485] gslX680 4-0041: read failed
[ 37.382429] gsl_ts_read set data address fail!
[ 37.382503] gslX680 4-0041: read failed
[ 37.457470] gsl_ts_read set data address fail!
[ 37.457514] gslX680 4-0041: read failed
[ 37.537753] gsl_ts_read set data address fail!
[ 37.537800] gslX680 4-0041: read failed
[ 37.611741] gsl_ts_read set data address fail!
[ 37.611787] gslX680 4-0041: read failed
[ 37.682800] gsl_ts_read set data address fail!
[ 37.682848] gslX680 4-0041: read failed
[ 37.756069] gsl_ts_read set data address fail!
[ 37.756117] gslX680 4-0041: read failed
[ 37.829090] gsl_ts_read set data address fail!
[ 37.829165] gslX680 4-0041: read failed
[ 37.904569] gsl_ts_read set data address fail!
[ 37.904613] gslX680 4-0041: read failed
[ 37.976128] gsl_ts_read set data address fail!
[ 37.976173] gslX680 4-0041: read failed
[ 38.049120] gsl_ts_read set data address fail!
[ 38.049191] gslX680 4-0041: read failed
[ 38.122328] gsl_ts_read set data address fail!
[ 38.122374] gslX680 4-0041: read failed
[ 38.196007] gsl_ts_read set data address fail!
[ 38.196052] gslX680 4-0041: read failed
[ 38.269124] gsl_ts_read set data address fail!
[ 38.269232] gslX680 4-0041: read failed
[ 38.342372] gsl_ts_read set data address fail!
[ 38.342417] gslX680 4-0041: read failed
[ 38.416123] gsl_ts_read set data address fail!
[ 38.416172] gslX680 4-0041: read failed
[ 38.489281] gsl_ts_read set data address fail!
[ 38.489326] gslX680 4-0041: read failed
[ 38.562903] gsl_ts_read set data address fail!
[ 38.562948] gslX680 4-0041: read failed
[ 38.636113] gsl_ts_read set data address fail!
[ 38.636160] gslX680 4-0041: read failed
[ 38.710394] gsl_ts_read set data address fail!
[ 38.710442] gslX680 4-0041: read failed
[ 38.783102] gsl_ts_read set data address fail!
[ 38.783147] gslX680 4-0041: read failed
[ 38.862151] gsl_ts_read set data address fail!
[ 38.862196] gslX680 4-0041: read failed
[ 38.932384] gsl_ts_read set data address fail!
[ 38.932426] gslX680 4-0041: read failed
[ 39.006123] gsl_ts_read set data address fail!
[ 39.006175] gslX680 4-0041: read failed
[ 39.079601] gsl_ts_read set data address fail!
[ 39.079648] gslX680 4-0041: read failed
[ 39.152706] gsl_ts_read set data address fail!
[ 39.152750] gslX680 4-0041: read failed
[ 39.226328] gsl_ts_read set data address fail!
[ 39.226378] gslX680 4-0041: read failed
[ 39.299219] gsl_ts_read set data address fail!
[ 39.299272] gslX680 4-0041: read failed
[ 39.372295] gsl_ts_read set data address fail!
[ 39.372339] gslX680 4-0041: read failed
[ 39.445482] gsl_ts_read set data address fail!
[ 39.445526] gslX680 4-0041: read failed
[ 39.515722] gsl_ts_read set data address fail!
[ 39.515781] gslX680 4-0041: read failed
[ 39.589555] gsl_ts_read set data address fail!
[ 39.589600] gslX680 4-0041: read failed
[ 39.662862] gsl_ts_read set data address fail!
[ 39.662910] gslX680 4-0041: read failed
[ 39.736437] gsl_ts_read set data address fail!
[ 39.736478] gslX680 4-0041: read failed
[ 39.809424] gsl_ts_read set data address fail!
[ 39.809469] gslX680 4-0041: read failed
[ 39.882877] gsl_ts_read set data address fail!
[ 39.882922] gslX680 4-0041: read failed
[ 39.957601] gsl_ts_read set data address fail!
[ 39.957646] gslX680 4-0041: read failed
[ 40.035186] gsl_ts_read set data address fail!
[ 40.035232] gslX680 4-0041: read failed
[ 40.106124] gsl_ts_read set data address fail!
[ 40.106173] gslX680 4-0041: read failed
[ 40.179261] gsl_ts_read set data address fail!
[ 40.179310] gslX680 4-0041: read failed
[ 40.252996] gsl_ts_read set data address fail!
[ 40.253043] gslX680 4-0041: read failed
[ 40.326188] gsl_ts_read set data address fail!
[ 40.326232] gslX680 4-0041: read failed
[ 40.399760] gsl_ts_read set data address fail!
[ 40.399813] gslX680 4-0041: read failed
[ 40.472787] gsl_ts_read set data address fail!
[ 40.472831] gslX680 4-0041: read failed
[ 40.545790] gsl_ts_read set data address fail!
[ 40.545872] gslX680 4-0041: read failed
[ 40.618723] gsl_ts_read set data address fail!
[ 40.618770] gslX680 4-0041: read failed
[ 40.689334] gsl_ts_read set data address fail!
[ 40.689384] gslX680 4-0041: read failed
[ 40.762247] gsl_ts_read set data address fail!
[ 40.762295] gslX680 4-0041: read failed
[ 40.836105] gsl_ts_read set data address fail!
[ 40.836149] gslX680 4-0041: read failed
[ 40.909333] gsl_ts_read set data address fail!
[ 40.909378] gslX680 4-0041: read failed
[ 40.982221] gsl_ts_read set data address fail!
[ 40.982263] gslX680 4-0041: read failed
[ 41.052399] gsl_ts_read set data address fail!
[ 41.052445] gslX680 4-0041: read failed
[ 41.128786] gsl_ts_read set data address fail!
[ 41.128828] gslX680 4-0041: read failed
[ 41.198637] gsl_ts_read set data address fail!
[ 41.198684] gslX680 4-0041: read failed
[ 41.269002] gsl_ts_read set data address fail!
[ 41.269042] gslX680 4-0041: read failed
[ 41.342172] gsl_ts_read set data address fail!
[ 41.342217] gslX680 4-0041: read failed
[ 41.416256] gsl_ts_read set data address fail!
[ 41.416299] gslX680 4-0041: read failed
[ 41.490448] gsl_ts_read set data address fail!
[ 41.490488] gslX680 4-0041: read failed
[ 41.561882] gsl_ts_read set data address fail!
[ 41.561922] gslX680 4-0041: read failed
[ 41.632010] gsl_ts_read set data address fail!
[ 41.632044] gslX680 4-0041: read failed
[ 41.702195] gsl_ts_read set data address fail!
[ 41.702222] gslX680 4-0041: read failed
[ 41.772019] gsl_ts_read set data address fail!
[ 41.772047] gslX680 4-0041: read failed
[ 41.842110] gsl_ts_read set data address fail!
[ 41.842133] gslX680 4-0041: read failed
[ 41.912393] gsl_ts_read set data address fail!
[ 41.912426] gslX680 4-0041: read failed
[ 41.986055] gsl_ts_read set data address fail!
[ 41.986081] gslX680 4-0041: read failed
[ 42.058643] gsl_ts_read set data address fail!
[ 42.058684] gslX680 4-0041: read failed
[ 42.128518] gsl_ts_read set data address fail!
[ 42.128562] gslX680 4-0041: read failed
[ 42.201669] gsl_ts_read set data address fail!
[ 42.201708] gslX680 4-0041: read failed
[ 42.267941] gsl_ts_read set data address fail!
[ 42.267981] gslX680 4-0041: read failed
[ 42.339835] gsl_ts_read set data address fail!
[ 42.339884] gslX680 4-0041: read failed
[ 42.413444] gsl_ts_read set data address fail!
[ 42.413500] gslX680 4-0041: read failed
[ 42.485330] gsl_ts_read set data address fail!
[ 42.485372] gslX680 4-0041: read failed
[ 42.555345] gsl_ts_read set data address fail!
[ 42.555384] gslX680 4-0041: read failed
[ 42.620914] gslX680 4-0041: read failed
[ 42.693713] gsl_ts_read set data address fail!
[ 42.693756] gslX680 4-0041: read failed
[ 42.766554] gsl_ts_read set data address fail!
[ 42.766601] gslX680 4-0041: read failed
[ 42.839646] gsl_ts_read set data address fail!
[ 42.839691] gslX680 4-0041: read failed
[ 42.913183] gsl_ts_read set data address fail!
[ 42.913239] gslX680 4-0041: read failed
[ 42.985290] gsl_ts_read set data address fail!
[ 42.985333] gslX680 4-0041: read failed
[ 43.055395] gsl_ts_read set data address fail!
[ 43.055435] gslX680 4-0041: read failed
[ 43.125312] gsl_ts_read set data address fail!
[ 43.125352] gslX680 4-0041: read failed
[ 43.195881] gsl_ts_read set data address fail!
[ 43.195927] gslX680 4-0041: read failed
[ 43.272876] gsl_ts_read set data address fail!
[ 43.272912] gslX680 4-0041: read failed
[ 43.345913] gsl_ts_read set data address fail!
[ 43.345957] gslX680 4-0041: read failed
[ 43.418858] gsl_ts_read set data address fail!
[ 43.418900] gslX680 4-0041: read failed
[ 43.489381] gsl_ts_read set data address fail!
[ 43.489424] gslX680 4-0041: read failed
[ 43.562056] gsl_ts_read set data address fail!
[ 43.562100] gslX680 4-0041: read failed
[ 43.632536] gsl_ts_read set data address fail!
[ 43.632577] gslX680 4-0041: read failed
[ 43.706533] gsl_ts_read set data address fail!
[ 43.706577] gslX680 4-0041: read failed
[ 43.774194] gsl_ts_read set data address fail!
[ 43.774221] gslX680 4-0041: read failed
[ 43.845641] gsl_ts_read set data address fail!
[ 43.845669] gslX680 4-0041: read failed
[ 43.919202] gsl_ts_read set data address fail!
[ 43.919229] gslX680 4-0041: read failed
[ 43.992702] gsl_ts_read set data address fail!
[ 43.992738] gslX680 4-0041: read failed
[ 44.065549] gsl_ts_read set data address fail!
[ 44.065608] gslX680 4-0041: read failed
[ 44.135121] gsl_ts_read set data address fail!
[ 44.135156] gslX680 4-0041: read failed
[ 44.209183] gsl_ts_read set data address fail!
[ 44.209218] gslX680 4-0041: read failed
[ 44.288713] gsl_ts_read set data address fail!
[ 44.288748] gslX680 4-0041: read failed
[ 44.363724] gsl_ts_read set data address fail!
[ 44.363778] gslX680 4-0041: read failed
[ 44.434940] gsl_ts_read set data address fail!
[ 44.434975] gslX680 4-0041: read failed
[ 44.504956] gsl_ts_read set data address fail!
[ 44.504992] gslX680 4-0041: read failed
[ 44.578275] gsl_ts_read set data address fail!
[ 44.578310] gslX680 4-0041: read failed
[ 44.648294] gsl_ts_read set data address fail!
[ 44.648333] gslX680 4-0041: read failed
[ 44.718316] gsl_ts_read set data address fail!
[ 44.718350] gslX680 4-0041: read failed
[ 44.789863] gsl_ts_read set data address fail!
[ 44.789900] gslX680 4-0041: read failed
[ 44.861670] gsl_ts_read set data address fail!
[ 44.861706] gslX680 4-0041: read failed
[ 44.931613] gsl_ts_read set data address fail!
[ 44.931655] gslX680 4-0041: read failed
[ 45.001611] gsl_ts_read set data address fail!
[ 45.001649] gslX680 4-0041: read failed
[ 45.074975] gsl_ts_read set data address fail!
[ 45.075014] gslX680 4-0041: read failed
[ 45.145047] gsl_ts_read set data address fail!
[ 45.145091] gslX680 4-0041: read failed
[ 45.218978] gsl_ts_read set data address fail!
[ 45.219021] gslX680 4-0041: read failed
[ 45.292086] gsl_ts_read set data address fail!
[ 45.292128] gslX680 4-0041: read failed
[ 45.363049] gsl_ts_read set data address fail!
[ 45.363090] gslX680 4-0041: read failed
[ 45.436146] gsl_ts_read set data address fail!
[ 45.436193] gslX680 4-0041: read failed
[ 45.509510] gsl_ts_read set data address fail!
[ 45.509535] gslX680 4-0041: read failed
[ 45.584135] gsl_ts_read set data address fail!
[ 45.584160] gslX680 4-0041: read failed
[ 45.659053] gsl_ts_read set data address fail!
[ 45.659078] gslX680 4-0041: read failed
[ 45.731895] gsl_ts_read set data address fail!
[ 45.731945] gslX680 4-0041: read failed
[ 45.802084] gsl_ts_read set data address fail!
[ 45.802126] gslX680 4-0041: read failed
[ 45.875353] gsl_ts_read set data address fail!
[ 45.875387] gslX680 4-0041: read failed
[ 45.949305] gsl_ts_read set data address fail!
[ 45.949347] gslX680 4-0041: read failed
[ 46.022109] gsl_ts_read set data address fail!
[ 46.022164] gslX680 4-0041: read failed
[ 46.095145] gsl_ts_read set data address fail!
[ 46.095183] gslX680 4-0041: read failed
[ 46.168469] gsl_ts_read set data address fail!
[ 46.168522] gslX680 4-0041: read failed
[ 46.238556] gsl_ts_read set data address fail!
[ 46.238605] gslX680 4-0041: read failed
[ 46.308336] gsl_ts_read set data address fail!
[ 46.308391] gslX680 4-0041: read failed
[ 46.380847] gsl_ts_read set data address fail!
[ 46.380908] gslX680 4-0041: read failed
[ 46.455597] gsl_ts_read set data address fail!
[ 46.455661] gslX680 4-0041: read failed
[ 46.501663] capability: warning: `main’ uses 32-bit capabilities (legacy support in use)
[ 46.541660] gsl_ts_read set data address fail!
[ 46.541705] gslX680 4-0041: read failed
[ 46.612959] gsl_ts_read set data address fail!
[ 46.613009] gslX680 4-0041: read failed
[ 46.685820] gsl_ts_read set data address fail!
[ 46.685864] gslX680 4-0041: read failed
[ 46.758686] gsl_ts_read set data address fail!
[ 46.758730] gslX680 4-0041: read failed
[ 46.828417] gsl_ts_read set data address fail!
[ 46.828453] gslX680 4-0041: read failed
[ 46.902275] gsl_ts_read set data address fail!
[ 46.902310] gslX680 4-0041: read failed
[ 46.976146] gsl_ts_read set data address fail!
[ 46.976201] gslX680 4-0041: read failed
[ 47.052289] gsl_ts_read set data address fail!
[ 47.052331] gslX680 4-0041: read failed
[ 47.126118] gsl_ts_read set data address fail!
[ 47.126174] gslX680 4-0041: read failed
[ 47.201844] gsl_ts_read set data address fail!
[ 47.201892] gslX680 4-0041: read failed
[ 47.272751] gsl_ts_read set data address fail!
[ 47.272785] gslX680 4-0041: read failed
[ 47.345413] gsl_ts_read set data address fail!
[ 47.345465] gslX680 4-0041: read failed
[ 47.415192] gsl_ts_read set data address fail!
[ 47.415246] gslX680 4-0041: read failed
[ 47.485579] gsl_ts_read set data address fail!
[ 47.485633] gslX680 4-0041: read failed
[ 47.558892] gsl_ts_read set data address fail!
[ 47.558917] gslX680 4-0041: read failed
[ 47.628758] gsl_ts_read set data address fail!
[ 47.628783] gslX680 4-0041: read failed
[ 47.698673] gsl_ts_read set data address fail!
[ 47.698711] gslX680 4-0041: read failed
[ 47.769803] gsl_ts_read set data address fail!
[ 47.769846] gslX680 4-0041: read failed
[ 47.842063] gsl_ts_read set data address fail!
[ 47.842104] gslX680 4-0041: read failed
[ 47.912027] gsl_ts_read set data address fail!
[ 47.912066] gslX680 4-0041: read failed
[ 47.985515] gsl_ts_read set data address fail!
[ 47.985555] gslX680 4-0041: read failed
[ 48.055339] gsl_ts_read set data address fail!
[ 48.055376] gslX680 4-0041: read failed
[ 48.125341] gsl_ts_read set data address fail!
[ 48.125379] gslX680 4-0041: read failed
[ 48.196183] gsl_ts_read set data address fail!
[ 48.196220] gslX680 4-0041: read failed
[ 48.269577] gsl_ts_read set data address fail!
[ 48.269619] gslX680 4-0041: read failed
[ 48.341993] gsl_ts_read set data address fail!
[ 48.342031] gslX680 4-0041: read failed
[ 48.411940] gsl_ts_read set data address fail!
[ 48.411980] gslX680 4-0041: read failed
[ 48.481980] gsl_ts_read set data address fail!
[ 48.482020] gslX680 4-0041: read failed
[ 48.555260] gsl_ts_read set data address fail!
[ 48.555299] gslX680 4-0041: read failed
[ 48.621252] gsl_ts_read set data address fail!
[ 48.621291] gslX680 4-0041: read failed
[ 48.688348] gsl_ts_read set data address fail!
[ 48.688392] gslX680 4-0041: read failed
[ 48.758629] gsl_ts_read set data address fail!
[ 48.758671] gslX680 4-0041: read failed
[ 48.829000] gsl_ts_read set data address fail!
[ 48.829042] gslX680 4-0041: read failed
[ 48.901985] gsl_ts_read set data address fail!
[ 48.902023] gslX680 4-0041: read failed
[ 48.972039] gsl_ts_read set data address fail!
[ 48.972085] gslX680 4-0041: read failed
[ 49.041950] gsl_ts_read set data address fail!
[ 49.041992] gslX680 4-0041: read failed
[ 49.115939] gsl_ts_read set data address fail!
[ 49.115977] gslX680 4-0041: read failed
[ 49.189377] gsl_ts_read set data address fail!
[ 49.189423] gslX680 4-0041: read failed
[ 49.262060] gsl_ts_read set data address fail!
[ 49.262101] gslX680 4-0041: read failed
[ 49.332059] gsl_ts_read set data address fail!
[ 49.332101] gslX680 4-0041: read failed
[ 49.402099] gsl_ts_read set data address fail!
[ 49.402143] gslX680 4-0041: read failed
[ 49.472438] gsl_ts_read set data address fail!
[ 49.472529] gslX680 4-0041: read failed
[ 49.545470] gsl_ts_read set data address fail!
[ 49.545508] gslX680 4-0041: read failed
[ 49.615499] gsl_ts_read set data address fail!
[ 49.615543] gslX680 4-0041: read failed
[ 49.685562] gsl_ts_read set data address fail!
[ 49.685603] gslX680 4-0041: read failed
[ 49.756533] gsl_ts_read set data address fail!
[ 49.756583] gslX680 4-0041: read failed
[ 49.829263] gsl_ts_read set data address fail!
[ 49.829319] gslX680 4-0041: read failed
[ 49.901888] gsl_ts_read set data address fail!
[ 49.901929] gslX680 4-0041: read failed
[ 49.975569] gsl_ts_read set data address fail!
[ 49.975608] gslX680 4-0041: read failed
[ 50.050996] gsl_ts_read set data address fail!
[ 50.051038] gslX680 4-0041: read failed
[ 50.122821] gsl_ts_read set data address fail!
[ 50.122861] gslX680 4-0041: read failed
[ 50.196387] gsl_ts_read set data address fail!
[ 50.196432] gslX680 4-0041: read failed
[ 50.268333] gsl_ts_read set data address fail!
[ 50.268375] gslX680 4-0041: read failed
[ 50.338632] gsl_ts_read set data address fail!
[ 50.338678] gslX680 4-0041: read failed
[ 50.408707] gsl_ts_read set data address fail!
[ 50.408748] gslX680 4-0041: read failed
[ 50.478552] gsl_ts_read set data address fail!
[ 50.478591] gslX680 4-0041: read failed
[ 50.548943] gsl_ts_read set data address fail!
[ 50.548983] gslX680 4-0041: read failed
[ 50.622998] gsl_ts_read set data address fail!
[ 50.623044] gslX680 4-0041: read failed
[ 50.696576] gsl_ts_read set data address fail!
[ 50.696621] gslX680 4-0041: read failed
[ 50.769234] gsl_ts_read set data address fail!
[ 50.769279] gslX680 4-0041: read failed
[ 50.842154] gsl_ts_read set data address fail!
[ 50.842198] gslX680 4-0041: read failed
[ 50.915406] gsl_ts_read set data address fail!
[ 50.915450] gslX680 4-0041: read failed
[ 50.985407] gsl_ts_read set data address fail!
[ 50.985447] gslX680 4-0041: read failed
130|rk3399_firefly_aiojd4_lvds_box:/ $ [ 51.055683] gsl_ts_read set data address fail!
[ 51.055727] gslX680 4-0041: read failed
[ 51.129356] gsl_ts_read set data address fail!
[ 51.129397] gslX680 4-0041: read failed
[ 51.202699] gsl_ts_read set data address fail!
[ 51.202743] gslX680 4-0041: read failed
[ 51.275768] gsl_ts_read set data address fail!
[ 51.275832] gslX680 4-0041: read failed
[ 51.349779] gsl_ts_read set data address fail!
[ 51.349831] gslX680 4-0041: read failed
[ 51.424540] gsl_ts_read set data address fail!
[ 51.424587] gslX680 4-0041: read failed
[ 51.498723] gsl_ts_read set data address fail!
[ 51.498765] gslX680 4-0041: read failed
[ 51.568386] gsl_ts_read set data address fail!
[ 51.568427] gslX680 4-0041: read failed
[ 51.634799] gsl_ts_read set data address fail!
[ 51.634842] gslX680 4-0041: read failed
[ 51.705903] gsl_ts_read set data address fail!
[ 51.705939] gslX680 4-0041: read failed
[ 51.774417] gsl_ts_read set data address fail!
[ 51.774460] gslX680 4-0041: read failed
130|rk3399_firefly_aiojd4_lvds_box:/ $ [ 51.845915] gsl_ts_read set data address fail!
[ 51.845968] gslX680 4-0041: read failed
[ 51.918638] gsl_ts_read set data address fail!
[ 51.918680] gslX680 4-0041: read failed
[ 51.988625] gsl_ts_read set data address fail!
[ 51.988664] gslX680 4-0041: read failed
130|rk3399_firefly_aiojd4_lvds_box:/ $ [ 52.059346] gsl_ts_read set data address fail!
[ 52.059385] gslX680 4-0041: read failed
[ 52.138045] gsl_ts_read set data address fail!
[ 52.138086] gslX680 4-0041: read failed
[ 52.209373] gsl_ts_read set data address fail!
[ 52.209410] gslX680 4-0041: read failed
130|rk3399_firefly_aiojd4_lvds_box:/ $ [ 52.281876] gsl_ts_read set data address fail!
[ 52.281917] gslX680 4-0041: read failed
[ 52.353152] gsl_ts_read set data address fail!
[ 52.353194] gslX680 4-0041: read failed
130|rk3399_firefly_aiojd4_lvds_box:/ $ [ 52.427597] gsl_ts_read set data address fail!
[ 52.427642] gslX680 4-0041: read failed
[ 52.498619] gsl_ts_read set data address fail!
[ 52.498661] gslX680 4-0041: read failed
[ 52.568651] gsl_ts_read set data address fail!
[ 52.568690] gslX680 4-0041: read failed
130|rk3399_firefly_aiojd4_lvds_box:/ $ [ 52.639802] gsl_ts_read set data address fail!
[ 52.639840] gslX680 4-0041: read failed
[ 52.712408] gsl_ts_read set data address fail!
[ 52.712528] gslX680 4-0041: read failed
[ 52.785836] gsl_ts_read set data address fail!
[ 52.785880] gslX680 4-0041: read failed
130|rk3399_firefly_aiojd4_lvds_box:/ $ [ 52.859271] gsl_ts_read set data address fail!
[ 52.859314] gslX680 4-0041: read failed
[ 52.932427] gsl_ts_read set data address fail!
[ 52.932515] gslX680 4-0041: read failed
[ 53.001028] gsl_ts_read set data address fail!
[ 53.001067] gslX680 4-0041: read failed
[ 53.067628] gsl_ts_read set data address fail!
[ 53.067669] gslX680 4-0041: read failed
[ 53.138627] gsl_ts_read set data address fail!
[ 53.138668] gslX680 4-0041: read failed
[ 53.208885] gsl_ts_read set data address fail!
[ 53.208925] gslX680 4-0041: read failed
[ 53.279776] gsl_ts_read set data address fail!
[ 53.279818] gslX680 4-0041: read failed
[ 53.352941] gsl_ts_read set data address fail!
[ 53.352983] gslX680 4-0041: read failed
[ 53.425369] gsl_ts_read set data address fail!
[ 53.425410] gslX680 4-0041: read failed
[ 53.495302] gsl_ts_read set data address fail!
[ 53.495343] gslX680 4-0041: read failed
[ 53.566203] gsl_ts_read set data address fail!
[ 53.566243] gslX680 4-0041: read failed
[ 53.638673] gsl_ts_read set data address fail!
[ 53.638715] gslX680 4-0041: read failed
[ 53.709247] gsl_ts_read set data address fail!
[ 53.709292] gslX680 4-0041: read failed
[ 53.782881] gsl_ts_read set data address fail!
[ 53.782931] gslX680 4-0041: read failed
[ 53.855217] gsl_ts_read set data address fail!
[ 53.855259] gslX680 4-0041: read failed
[ 53.925299] gsl_ts_read set data address fail!
[ 53.925339] gslX680 4-0041: read failed
[ 53.995561] gsl_ts_read set data address fail!
[ 53.995601] gslX680 4-0041: read failed
[ 54.066846] gsl_ts_read set data address fail!
[ 54.066886] gslX680 4-0041: read failed
[ 54.141978] gsl_ts_read set data address fail!
[ 54.142020] gslX680 4-0041: read failed
[ 54.213327] gsl_ts_read set data address fail!
[ 54.213367] gslX680 4-0041: read failed
[ 54.285454] gsl_ts_read set data address fail!
[ 54.285496] gslX680 4-0041: read failed
[ 54.355435] gsl_ts_read set data address fail!
[ 54.355474] gslX680 4-0041: read failed
[ 54.420938] gsl_ts_read set data address fail!
[ 54.420983] gslX680 4-0041: read failed
[ 54.495400] gsl_ts_read set data address fail!
[ 54.495447] gslX680 4-0041: read failed
[ 54.563979] gsl_ts_read set data address fail!
[ 54.564018] gslX680 4-0041: read failed
[ 54.638869] gsl_ts_read set data address fail!
[ 54.638913] gslX680 4-0041: read failed
[ 54.709820] gsl_ts_read set data address fail!
[ 54.709869] gslX680 4-0041: read failed
[ 54.783164] gsl_ts_read set data address fail!
[ 54.783216] gslX680 4-0041: read failed
[ 54.855483] gsl_ts_read set data address fail!
[ 54.855532] gslX680 4-0041: read failed
[ 54.925372] gsl_ts_read set data address fail!
[ 54.925414] gslX680 4-0041: read failed
[ 54.995235] gsl_ts_read set data address fail!
[ 54.995276] gslX680 4-0041: read failed
[ 55.065272] gsl_ts_read set data address fail!
[ 55.065313] gslX680 4-0041: read failed
[ 55.135982] gsl_ts_read set data address fail!
[ 55.136025] gslX680 4-0041: read failed
[ 55.209358] gsl_ts_read set data address fail!
[ 55.209401] gslX680 4-0041: read failed
[ 55.281629] gsl_ts_read set data address fail!
[ 55.281666] gslX680 4-0041: read failed
[ 55.352271] gsl_ts_read set data address fail!
[ 55.352315] gslX680 4-0041: read failed
[ 55.425321] gsl_ts_read set data address fail!
[ 55.425360] gslX680 4-0041: read failed
[ 55.495298] gsl_ts_read set data address fail!
[ 55.495338] gslX680 4-0041: read failed
[ 55.565384] gsl_ts_read set data address fail!
[ 55.565422] gslX680 4-0041: read failed
[ 55.638893] gsl_ts_read set data address fail!
[ 55.638931] gslX680 4-0041: read failed
[ 55.712750] gsl_ts_read set data address fail!
[ 55.712794] gslX680 4-0041: read failed
[ 55.786451] gsl_ts_read set data address fail!
[ 55.786498] gslX680 4-0041: read failed
[ 55.862404] gsl_ts_read set data address fail!
[ 55.862454] gslX680 4-0041: read failed
[ 55.935473] gsl_ts_read set data address fail!
[ 55.935511] gslX680 4-0041: read failed
[ 56.005485] gsl_ts_read set data address fail!
[ 56.005526] gslX680 4-0041: read failed
[ 56.078806] gsl_ts_read set data address fail!
[ 56.078848] gslX680 4-0041: read failed
[ 56.148816] gsl_ts_read set data address fail!
[ 56.148845] gslX680 4-0041: read failed
[ 56.219797] gsl_ts_read set data address fail!
[ 56.219822] gslX680 4-0041: read failed
[ 56.293240] gsl_ts_read set data address fail!
[ 56.293267] gslX680 4-0041: read failed
[ 56.365526] gsl_ts_read set data address fail!
[ 56.365551] gslX680 4-0041: read failed
[ 56.435702] gsl_ts_read set data address fail!
[ 56.435726] gslX680 4-0041: read failed
[ 56.509249] gsl_ts_read set data address fail!
[ 56.509301] gslX680 4-0041: read failed
[ 56.585586] gsl_ts_read set data address fail!
[ 56.585622] gslX680 4-0041: read failed
[ 56.658677] gsl_ts_read set data address fail!
[ 56.658713] gslX680 4-0041: read failed
[ 56.734588] gsl_ts_read set data address fail!
[ 56.734631] gslX680 4-0041: read failed
[ 56.805957] gsl_ts_read set data address fail!
[ 56.806013] gslX680 4-0041: read failed
换了镜像,还是一样的
看这个信息,似乎是I2C通信的问题,可以使用这个工具检测一下是否可以读出对应的I2C地址
{:4_90:}
i2cdetect.rar (229 KB)
