自己做的板子移植4.4内核,卡在这里,已经一周了,解决不了,帮忙看看
bootrk: do_bootm_linux…
Loading Device Tree to 05716000, end 05729b01 … OK
[ 0.000000] Linux version 4.4.154 (lisa@ubuntu-12044-amd64) (gcc version 4.8.3 20140401 (prerelease) (crosstool-NG linaro-1.13.1-4.8-2014.04 - Linaro GCC 4.8-2014.04) ) #3 SMP Fri Nov 29 14:09:38 CST 2019
[ 0.000000] Machine model: Firefly-RK3288 Board (Linux Opensource)
[ 0.000000] earlycon: Early serial console at MMIO32 0xff690000 (options ‘’)
[ 0.000000] cma: Reserved 16 MiB at 0x7f000000
[ 0.000000] PERCPU: Embedded 14 pages/cpu @df780000 s24768 r8192 d24384 u57344
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523248
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff690000 vmalloc=496M console=ttyS2,115200n8 earlyprintk root=/dev/mmcblk0p6 rw rootfstype=ext4 init=/sbin/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00001000@0x00006000(resource),0x00007000@0x00007000(kernel),0x00010000@0x0000E000(boot),-@0x0001e000(system) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2015-06-20_15:49:25
[ 0.000000] Memory: 2040804K/2097152K available (12288K kernel code, 995K rwdata, 3404K rodata, 1024K init, 641K bss, 39964K reserved, 16384K cma-reserved, 1548288K highmem)
[ 0.000000] vmalloc : 0xe1000000 - 0xff800000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0800000 ( 520 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0d00000 (13280 kB)
[ 0.000000] .init : 0xc1200000 - 0xc1300000 (1024 kB)
[ 0.000000] .data : 0xc1300000 - 0xc13f8cf4 ( 996 kB)
[ 0.000000] .bss : 0xc13fa000 - 0xc149a73c ( 642 kB)
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] rockchip_clk_register_branches: unknown clock type 9
[ 0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000000] Switching to timer-based delay loop, resolution 41ns
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000000] pid_max: default: 32768 minimum: 301
[ 0.000000] Security Framework initialized
[ 0.000000] Yama: becoming mindful.
[ 0.000000] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Initializing cgroup subsys devices
[ 0.000000] Initializing cgroup subsys freezer
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] ftrace: allocating 44097 entries in 130 pages
[ 0.000000] CPU0: update cpu_capacity 430
[ 0.000000] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.000000] Setting up static identity map for 0x100000 - 0x100058
[ 0.000000] Brought up 1 CPUs
[ 0.000000] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] devtmpfs: initialized
[ 0.000000] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.000000] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.000000] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.000000] pinctrl core: initialized pinctrl subsystem
[ 0.000000] NET: Registered protocol family 16
[ 0.000000] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.000000] cpuidle: using governor ladder
[ 0.000000] cpuidle: using governor menu
[ 0.000000] Registered FIQ tty driver
[ 0.000000] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.000000] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.000000] Bad mode in prefetch abort handler detected
[ 0.000000] Internal error: Oops - bad mode: 0 [#1] SMP ARM
[ 0.000000] Modules linked in:aaaaaaaaaa-------------------------aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
[ 0.000000]
[ 0.000000] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.4.154 #3
[ 0.000000] Hardware name: Generic DT based system
[ 0.000000] task: df0c8000 task.stack: df0c2000
[ 0.000000] PC is at 0x62a12648
[ 0.000000] LR is at __invoke_sip_fn_smc+0x4c/0x60
[ 0.000000] pc : [<62a12648>] lr : [] psr: 200001d6
[ 0.000000] sp : df0c3cb8 ip : df0c3d10 fp : df0c3d4c
[ 0.000000] r10: 00000000 r9 : 000001ee r8 : 00000000
[ 0.000000] r7 : 00000000 r6 : 00000000 r5 : 00000000 r4 : 00000000
[ 0.000000] r3 : 00000000 r2 : 00080207 r1 : 00000001 r0 : 82000003
[ 0.000000] Flags: nzCv IRQs off FIQs off Mode MON_32 ISA ARM Segment kernel
[ 0.000000] Control: 10c5387d Table: 0000406a DAC: df0c3d58
[ 0.000000]
[ 0.000000] LR: 0xc096475c:
[ 0.000000] 475c e24cb004 e52de004 e8bd4000 e3a01000 e1a04000 eb009270 e3500000 0a000002
[ 0.000000] 477c e1a01004 ebffff9e e89da818 e3e00012 e89da818 e1a0c00d e92dd830 e24cb004
[ 0.000000] 479c e24dd028 e52de004 e8bd4000 e1a04000 e24b5024 e3a00000 e58d5010 e58d0000
[ 0.000000] 47bc e58d0004 e58d0008 e58d000c e1a00001 e1a01002 e1a02003 e59b3004 ebdebe30
[ 0.000000] 47dc e895000f e884000f e1a00004 e24bd014 e89da830 e1a0c00d e92dd810 e24cb004
[ 0.000000] 47fc e24dd00c e52de004 e8bd4000 e1a0e001 e1a0c002 e1a04000 e58d3000 e59f1014
[ 0.000000] 481c e1a0200e e1a0300c ebffffd9 e1a00004 e24bd010 e89da810 8200000c e1a0c00d
[ 0.000000] 483c e92ddff0 e24cb004 e24dd0b4 e52de004 e8bd4000 e59f0184 e50b2098 e5902000
[ 0.000000]
[ 0.000000] SP: 0xdf0c3c38:
[ 0.000000] 3c38 c01a4ac0 c01f1680 c0f9f880 c145100c c13148fc 00000000 c0ef05ed c13fa2c4
[ 0.000000] 3c58 df0c3cb8 df0c8000 df0c3ca4 df0c3c70 c010c050 c0108194 00000000 0000000b
[ 0.000000] 3c78 c01f16ac df0c3cb8 62a12648 200001d6 ffffffff 00000000 000001ee 00000000
[ 0.000000] 3c98 df0c3cb4 df0c3ca8 c010c468 c010bf28 00000000 df0c3cb8 c09647dc c010c428
[ 0.000000] 3cb8 82000003 00000001 00080207 00000000 00000000 00000000 00000000 00000000
[ 0.000000] 3cd8 00000000 000001ee 00000000 df0c3d4c df0c3d10 df0c3cb8 c09647dc 62a12648
[ 0.000000] 3cf8 200001d6 ffffffff df0c3d58 df0c3d28 00000000 c1466734 00000000 00000000
[ 0.000000] 3d18 00000000 00000000 df0c3d28 c0987de8 00000000 00000000 df0c3d84 00000001
[ 0.000000]
[ 0.000000] IP: 0xdf0c3c90:
[ 0.000000] 3c90 000001ee 00000000 df0c3cb4 df0c3ca8 c010c468 c010bf28 00000000 df0c3cb8
[ 0.000000] 3cb0 c09647dc c010c428 82000003 00000001 00080207 00000000 00000000 00000000
[ 0.000000] 3cd0 00000000 00000000 00000000 000001ee 00000000 df0c3d4c df0c3d10 df0c3cb8
[ 0.000000] 3cf0 c09647dc 62a12648 200001d6 ffffffff df0c3d58 df0c3d28 00000000 c1466734
[ 0.000000] 3d10 00000000 00000000 00000000 00000000 df0c3d28 c0987de8 00000000 00000000
[ 0.000000] 3d30 df0c3d84 00000001 df7e30c4 df2c5200 df0c3d74 df0c3d50 c0964ae0 c096479c
[ 0.000000] 3d50 00000000 00000001 00000000 df7e30c4 df2c5200 00000000 df0c3dbc df0c3d78
[ 0.000000] 3d70 c122baa0 c0964ab8 00000000 df0c3d88 c02a10f8 00080207 00000000 00000000
[ 0.000000]
[ 0.000000] FP: 0xdf0c3ccc:
[ 0.000000] 3ccc 00000000 00000000 00000000 00000000 000001ee 00000000 df0c3d4c df0c3d10
[ 0.000000] 3cec df0c3cb8 c09647dc 62a12648 200001d6 ffffffff df0c3d58 df0c3d28 00000000
[ 0.000000] 3d0c c1466734 00000000 00000000 00000000 00000000 df0c3d28 c0987de8 00000000
[ 0.000000] 3d2c 00000000 df0c3d84 00000001 df7e30c4 df2c5200 df0c3d74 df0c3d50 c0964ae0
[ 0.000000] 3d4c c096479c 00000000 00000001 00000000 df7e30c4 df2c5200 00000000 df0c3dbc
[ 0.000000] 3d6c df0c3d78 c122baa0 c0964ab8 00000000 df0c3d88 c02a10f8 00080207 00000000
[ 0.000000] 3d8c 00000000 00000000 00000000 00000000 00000000 df2c5210 c122b87c c135d248
[ 0.000000] 3dac c1466734 df0c3ddc df0c3dc0 c0575b40 c122b888 c0575ae0 df2c5210 00000000
[ 0.000000] Process swapper/0 (pid: 1, stack limit = 0xdf0c2258)
[ 0.000000] Stack: (0xdf0c3cb8 to 0xdf0c4000)
[ 0.000000] 3ca0: 82000003 00000001
[ 0.000000] 3cc0: 00080207 00000000 00000000 00000000 00000000 00000000 00000000 000001ee
[ 0.000000] 3ce0: 00000000 df0c3d4c df0c3d10 df0c3cb8 c09647dc 62a12648 200001d6 ffffffff
[ 0.000000] 3d00: df0c3d58 df0c3d28 00000000 c1466734 00000000 00000000 00000000 00000000
[ 0.000000] 3d20: df0c3d28 c0987de8 00000000 00000000 df0c3d84 00000001 df7e30c4 df2c5200
[ 0.000000] 3d40: df0c3d74 df0c3d50 c0964ae0 c096479c 00000000 00000001 00000000 df7e30c4
[ 0.000000] 3d60: df2c5200 00000000 df0c3dbc df0c3d78 c122baa0 c0964ab8 00000000 df0c3d88
[ 0.000000] 3d80: c02a10f8 00080207 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.000000] 3da0: df2c5210 c122b87c c135d248 c1466734 df0c3ddc df0c3dc0 c0575b40 c122b888
[ 0.000000] 3dc0: c0575ae0 df2c5210 00000000 c135d248 df0c3e04 df0c3de0 c0573c7c c0575aec
[ 0.000000] 3de0: 00000000 df2c5210 df2c5244 c135d248 00000000 c122b854 df0c3e24 df0c3e08
[ 0.000000] 3e00: c0573e7c c0573b70 c0573e04 00000000 c135d248 c0573e04 df0c3e4c df0c3e28
[ 0.000000] 3e20: c05720f0 c0573e10 df003274 df2d1040 c0c88d04 c135d248 df2f2e80 c1368328
[ 0.000000] 3e40: df0c3e5c df0c3e50 c0573798 c0572078 df0c3e84 df0c3e60 c0573324 c057377c
[ 0.000000] 3e60: c0f271c6 df0c3e70 c135d248 c130cee0 c130cee0 c13fa000 df0c3e9c df0c3e88
[ 0.000000] 3e80: c05749f4 c0573254 c135d234 c130cee0 df0c3eac df0c3ea0 c0575a80 c0574954
[ 0.000000] 3ea0: df0c3ecc df0c3eb0 c0575fac c0575a4c 00000000 df2fc480 c130cee0 c130cee0
[ 0.000000] 3ec0: df0c3edc df0c3ed0 c122b870 c0575f5c df0c3f5c df0c3ee0 c0101af4 c122b860
[ 0.000000] 3ee0: 00000001 c0c88d24 00000000 c0139be0 df0c3f00 df0c3f00 c1200618 c0423694
[ 0.000000] 3f00: df7badfb df7bae0c df0c3f5c df0c3f18 c0139e2c c1200608 c1052aa4 00000004
[ 0.000000] 3f20: 00000004 000001ee c105040c 00000000 00000000 00000004 c1266034 c12b2268
[ 0.000000] 3f40: c13fa000 c13fa000 000001ee 00000000 df0c3f94 df0c3f60 c1200f54 c01019ec
[ 0.000000] 3f60: 00000004 00000004 00000000 c12005fc 00000000 c0c84610 00000000 00000000
[ 0.000000] 3f80: 00000000 00000000 df0c3fac df0c3f98 c0c84628 c1200d9c df0c2000 00000000
[ 0.000000] 3fa0: 00000000 df0c3fb0 c01075d0 c0c8461c 00000000 00000000 00000000 00000000
[ 0.000000] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.000000] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[ 0.000000] [] (__invoke_sip_fn_smc) from [] (sip_smc_set_suspend_mode+0x34/0x44)
[ 0.000000] [] (sip_smc_set_suspend_mode) from [] (pm_config_init+0x224/0x2c4)
[ 0.000000] [] (pm_config_init) from [] (platform_drv_probe+0x60/0xac)
[ 0.000000] [] (platform_drv_probe) from [] (driver_probe_device+0x118/0x2a0)
[ 0.000000] [] (driver_probe_device) from [] (__driver_attach+0x78/0x9c)
[ 0.000000] [] (__driver_attach) from [] (bus_for_each_dev+0x84/0x98)
[ 0.000000] [] (bus_for_each_dev) from [] (driver_attach+0x28/0x30)
[ 0.000000] [] (driver_attach) from [] (bus_add_driver+0xdc/0x1f8)
[ 0.000000] [] (bus_add_driver) from [] (driver_register+0xac/0xf0)
[ 0.000000] [] (driver_register) from [] (__platform_driver_register+0x40/0x54)
[ 0.000000] [] (__platform_driver_register) from [] (__platform_driver_probe+0x5c/0xe0)
[ 0.000000] [] (__platform_driver_probe) from [] (rockchip_pm_drv_register+0x1c/0x28)
[ 0.000000] [] (rockchip_pm_drv_register) from [] (do_one_initcall+0x114/0x1c8)
[ 0.000000] [] (do_one_initcall) from [] (kernel_init_freeable+0x1c4/0x298)
[ 0.000000] [] (kernel_init_freeable) from [] (kernel_init+0x18/0x11c)
[ 0.000000] [] (kernel_init) from [] (ret_from_fork+0x14/0x24)
[ 0.000000] Code: bad PC value
[ 0.000000] —[ end trace 0411c6498e877664 ]—
[ 0.000000] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 0.000000]
