SDK: linux-sdk.7z
来源: https://pan.baidu.com/s/1NXcFa3F … 670-539758088014873
MD5: e20d13ef2568efa4a653a4b5c983d49f
全自动编译,执行./build.sh编译成功
使用AndroidTool_Release_v2.63烧录rockdev/update.img (size: 523551192)成功
但系统无法正常启动,当输出如下信息以后不再有任何反应
[ 1.236883] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.237565] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 1.239811] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.240480] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
请教一下如何解决这个问题?开发板型号:firefly-rk3399
完整串口日志如下
DDR Version 1.14 20180803
Channel 0: DDR3, 800MHz
Channel 1: DDR3, 800MHz
256B stride
CPUId = 0x0
ChipType = 0x10, 214
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 67768
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
GPT part: 2, name: misc, start:0x8000, size:0x2000
GPT part: 3, name: boot, start:0xa000, size:0x10000
GPT part: 4, name: recovery, start:0x1a000, size:0x10000
GPT part: 5, name: backup, start:0x2a000, size:0x10000
GPT part: 6, name: oem, start:0x3a000, size:0x20000
GPT part: 7, name: rootfs, start:0x5a000, size:0x100000
GPT part: 8, name: userdata, start:0x15a000, size:0x1bc4fdf
find partition:uboot OK. first_lba:0x4000.
find partition:trust OK. first_lba:0x6000.
LoadTrust Addr:0x6000
No find bl30.bin
Load uboot, ReadLba = 4000
Load OK, addr=0x200000, size=0xc5cf8
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):56eea3d
NOTICE: BL31: Built : 15:27:37, Aug 8 2018
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1151): pd status 3e
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-170-gc4654a6 #16 Wed May 30 08:54:30 UTC 2018 aarch64)
INFO: SPSR = 0x3c9
U-Boot 2017.09-g73d3fd4b32-dirty (Dec 02 2019 - 21:16:23 +0800)
Model: Rockchip RK3399 Evaluation Board
DRAM: 2 GiB
Relocation Offset is: 7dc08000
PMIC: RK808
pwm-regulator(vdd-center): init 950000 uV
vdd_center 950000 uV
regulator(vdd-center) init 950000 uV
MMC: dwmmc@fe320000: 1, sdhci@fe330000: 0
Can’t get mcu-pix-total
Warn: can’t find phy driver
In: serial
Out: serial
Err: serial
mmc_init: -95, time 9
switch to partitions #0, OK
enter Recovery mode!
Rockchip UBOOT DRM driver version: v1.0.0
Using display timing dts
Detailed mode clock 200000 kHz, flags[a]
H: 1536 1548 1564 1612
V: 2048 2056 2060 2068
bus_format: 100e
AUX CH command reply failed!
Rx Max Link Rate is abnormal :ff !
LT link start failed!
eDP link training failed (-110)
eDP link training failed (-121)
unable to do link train
Net: eth0: ethernet@fe300000
Error: Bad gzipped data
FDT load addr 0x10f00000 size 225 KiB
Booting kernel at 0x207f800 with fdt at 3947e00…
## Booting Android Image at 0x0207f800 …
Kernel load addr 0x02080000 size 18985 KiB
RAM disk load addr 0x11000000 size 6387 KiB
## Flattened Device Tree blob at 03947e00
Booting using the fdt blob at 0x3947e00
XIP Kernel Image … OK
Loading Ramdisk to 07bc3000, end 081ffbf8 … OK
Loading Device Tree to 0000000007ba7000, end 0000000007bc263f … OK
Adding bank: start=0x00200000, size=0x08200000
Adding bank: start=0x0a200000, size=0x75e00000
Can’t find file:logo_kernel.bmp
[ 0.000000] Linux version 4.4.154 (xiaofan@kubuntu) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #1 SMP Mon Dec 2 18:50:01 CST 2019
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07fee7000 s45800 r8192 d32024 u86016
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.mode=emmc androidboot.slot_suffix= androidboot.serialno=501e5b82714e4d20 rw rootwait earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 console=ttyFIQ0 root=PARTUUID=614e0000-0000 rootfstype=ext4
[ 0.000000] software IO TLB [mem 0x7fe9f000-0x7fedf000] (0MB) mapped at [ffffffc07fe9f000-ffffffc07fedefff]
[ 0.000000] Memory: 2000208K/2064384K available (11646K kernel code, 1704K rwdata, 4452K rodata, 1152K init, 760K bss, 64176K reserved, 0K cma-reserved)
[ 0.000000] .init : 0xffffff8009040000 - 0xffffff8009160000 ( 1152 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008be0000 ( 11648 KB)
[ 0.000000] .rodata : 0xffffff8008be0000 - 0xffffff8009040000 ( 4480 KB)
[ 0.000000] .data : 0xffffff8009160000 - 0xffffff800930a008 ( 1705 KB)
[ 0.000000] ITS: allocated 65536 Devices @a300000 (psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x000000000a290000
[ 0.000000] CPU0: using LPI pending table @0x000000000a2a0000
[ 0.002154] Console: colour dummy device 80x25
[ 0.002597] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.003587] pid_max: default: 32768 minimum: 301
[ 0.004171] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.004824] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.006209] Initializing cgroup subsys devices
[ 0.006645] Initializing cgroup subsys freezer
[ 0.007102] ftrace: allocating 42156 entries in 165 pages
[ 0.112447] sched-energy: Sched-energy-costs installed from DT
[ 0.113013] CPU0: update cpu_capacity 401
[ 0.113452] ASID allocator initialised with 32768 entries
[ 0.117157] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.118488] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.120714] Detected VIPT I-cache on CPU1
[ 0.120747] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.120777] CPU1: using LPI pending table @0x0000000000320000
[ 0.120818] CPU1: update cpu_capacity 401
[ 0.120823] CPU1: Booted secondary processor [410fd034]
[ 0.121364] Detected VIPT I-cache on CPU2
[ 0.121385] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.121412] CPU2: using LPI pending table @0x0000000000340000
[ 0.121438] CPU2: update cpu_capacity 401
[ 0.121442] CPU2: Booted secondary processor [410fd034]
[ 0.121960] Detected VIPT I-cache on CPU3
[ 0.121981] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.122008] CPU3: using LPI pending table @0x0000000000390000
[ 0.122034] CPU3: update cpu_capacity 401
[ 0.122038] CPU3: Booted secondary processor [410fd034]
[ 0.122586] Detected PIPT I-cache on CPU4
[ 0.122612] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.122650] CPU4: using LPI pending table @0x00000000003d0000
[ 0.122688] CPU4: update cpu_capacity 1024
[ 0.122691] CPU4: Booted secondary processor [410fd082]
[ 0.123240] Detected PIPT I-cache on CPU5
[ 0.123259] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.123297] CPU5: using LPI pending table @0x000000007d000000
[ 0.123323] CPU5: update cpu_capacity 1024
[ 0.123327] CPU5: Booted secondary processor [410fd082]
[ 0.123412] Brought up 6 CPUs
[ 0.135790] SMP: Total of 6 processors activated.
[ 0.136242] CPU features: detected feature: GIC system register CPU interface
[ 0.136935] CPU: All CPU(s) started at EL2
[ 0.137367] alternatives: patching kernel code
[ 0.139161] devtmpfs: initialized
[ 0.156581] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.157525] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.158561] pinctrl core: initialized pinctrl subsystem
[ 0.159796] NET: Registered protocol family 16
[ 0.165275] cpuidle: using governor ladder
[ 0.169284] cpuidle: using governor menu
[ 0.169697] Registered FIQ tty driver
[ 0.170349] vdso: 2 pages (1 code @ ffffff8008be6000, 1 data @ ffffff8009164000)
[ 0.171071] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.171864] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.196755] console [ttyFIQ0] enabled
[ 0.197429] bootconsole [uart0] disabled
[ 0.198364] Registered fiq debugger ttyFIQ0
[ 0.228436] iommu: Adding device ff650000.vpu_service to group 0
[ 0.229029] iommu: Adding device ff660000.rkvdec to group 1
[ 0.229620] iommu: Adding device ff8f0000.vop to group 2
[ 0.230159] iommu: Adding device ff900000.vop to group 3
[ 0.230758] iommu: Adding device ff910000.cif_isp to group 4
[ 0.231333] iommu: Adding device ff920000.cif_isp to group 5
[ 0.233453] SCSI subsystem initialized
[ 0.233976] usbcore: registered new interface driver usbfs
[ 0.234505] usbcore: registered new interface driver hub
[ 0.235056] usbcore: registered new device driver usb
[ 0.235567] media: Linux media interface: v0.10
[ 0.236008] Linux video capture interface: v2.00
[ 0.236458] pps_core: LinuxPPS API ver. 1 registered
[ 0.236902] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.237726] PTP clock support registered
[ 0.239142] Advanced Linux Sound Architecture Driver Initialized.
[ 0.240147] Bluetooth: Core ver 2.21
[ 0.240484] NET: Registered protocol family 31
[ 0.240892] Bluetooth: HCI device and connection manager initialized
[ 0.241458] Bluetooth: HCI socket layer initialized
[ 0.241901] Bluetooth: L2CAP socket layer initialized
[ 0.242362] Bluetooth: SCO socket layer initialized
[ 0.243402] rockchip-cpuinfo cpuinfo: Serial : 501e5b82714e4d20
[ 0.244519] clocksource: Switched to clocksource arch_sys_counter
[ 0.292896] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.293824] NET: Registered protocol family 2
[ 0.294661] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.295431] TCP bind hash table entries: 16384 (order: 7, 524288 bytes)
[ 0.296472] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.297135] UDP hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.297756] UDP-Lite hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.298613] NET: Registered protocol family 1
[ 0.299295] RPC: Registered named UNIX socket transport module.
[ 0.299843] RPC: Registered udp transport module.
[ 0.300263] RPC: Registered tcp transport module.
[ 0.300694] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.301946] Trying to unpack rootfs image as initramfs…
[ 0.647314] Freeing initrd memory: 6384K
[ 0.648148] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.648966] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.652850] Initialise system trusted keyring
[ 0.661043] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.662347] NFS: Registering the id_resolver key type
[ 0.662827] Key type id_resolver registered
[ 0.663202] Key type id_legacy registered
[ 0.663657] fuse init (API version 7.23)
[ 0.664386] SGI XFS with security attributes, no debug enabled
[ 0.669673] NET: Registered protocol family 38
[ 0.670087] Key type asymmetric registered
[ 0.670456] Asymmetric key parser ‘x509’ registered
[ 0.671058] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.671728] io scheduler noop registered
[ 0.672085] io scheduler deadline registered
[ 0.672589] io scheduler cfq registered (default)
[ 0.674624] phy phy-ff770000.syscon:usb2-phy@e460.1: Failed to get VBUS supply regulator
[ 0.680190] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.680787] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.681368] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 1.223577] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 1.224300] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 1.225854] backlight supply power not found, using dummy regulator
[ 1.227167] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[ 1.228122] rk-vcodec ff650000.vpu_service: probe device
[ 1.228921] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[ 1.230261] rk-vcodec ff650000.vpu_service: could not find power_model node
[ 1.230898] rk-vcodec ff650000.vpu_service: init success
[ 1.231776] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[ 1.232789] rk-vcodec ff660000.rkvdec: probe device
[ 1.233438] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[ 1.234412] rk-vcodec ff660000.rkvdec: could not find power_model node
[ 1.235001] rk-vcodec ff660000.rkvdec: init success
