qslia@qsliapc:~/Linux_SDK$ sudo apt-get install gcc-4.8-multilib-arm-linux-gnueabihf
Reading package lists… Done
Building dependency tree
E: Unable to locate package gcc-4.8-multilib-arm-linux-gnueabihf
E: Couldn’t find any package by glob ‘gcc-4.8-multilib-arm-linux-gnueabihf’
E: Couldn’t find any package by regex ‘gcc-4.8-multilib-arm-linux-gnueabihf’
编译 Ubuntu 固件(GPT)
qslia@qsliapc:~/Linux_SDK/firefly/linux_sdk$ ./build.sh aio-rk3399pro-jd4.mk
ERR: aio-rk3399pro-jd4.mk not found
Can’t found build config, please check again
ls device/rockchip/rkxxxx
====USAGE: build.sh modules====
uboot -build uboot
kernel -build kernel
extboot -build extlinux boot.img, boot from EFI partition
rootfs -build default rootfs, currently build buildroot as default
buildroot -build buildroot rootfs
yocto -build yocto rootfs, currently build ros as default
ros -build ros rootfs
debian -build debian rootfs
pcba -build pcba
recovery -build recovery
all -build uboot, kernel, rootfs, recovery image
cleanall -clean uboot, kernel, rootfs, recovery
firmware -pack all the image we need to boot up system
updateimg -pack update image
sdbootimg -pack sdboot image
sdupdateimg -pack sdupdate image
save -save images, patches, commands used to debug
default -build all modules
BoardConfig Board -select Board and it’s BoardConfig.mk
qslia@qsliapc:~/Linux_SDK/firefly/linux_sdk$ source envsetup.sh
Top of tree: /home/qslia/Linux_SDK/firefly/linux_sdk
You’re building on Linux
Lunch menu…pick a combo:
- rockchip_px30_32
- rockchip_px30_64
- rockchip_px30_64_open
- rockchip_px30_recovery
- rockchip_px30_robot32
- rockchip_px30_robot64
- rockchip_px30_robot64_no_gpu
- rockchip_px3se
- rockchip_px3se_recovery
- rockchip_rk1808
- rockchip_rk1808-multi
- rockchip_rk1808_recovery
- rockchip_rk3036
- rockchip_rk3036_recovery
- rockchip_rk3128
- rockchip_rk3128_recovery
- rockchip_rk3229
- rockchip_rk3229_recovery
- rockchip_rk3288
- rockchip_rk3288_recovery
- rockchip_rk3308_32_debug
- rockchip_rk3308_32_dueros
- rockchip_rk3308_32_mini_release
- rockchip_rk3308_32_release
- rockchip_rk3308_64_dueros
- rockchip_rk3308_b_32_release
- rockchip_rk3308_b_release
- rockchip_rk3308_gk_32_release
- rockchip_rk3308_mini_release
- rockchip_rk3308_pcba
- rockchip_rk3308_recovery
- rockchip_rk3308_release
- rockchip_rk3308_robot32
- rockchip_rk3308_robot64
- rockchip_rk3326_32
- rockchip_rk3326_64
- rockchip_rk3326_64_open
- rockchip_rk3326_recovery
- rockchip_rk3326_robot32
- rockchip_rk3326_robot64
- rockchip_rk3326_robot64_no_gpu
- rockchip_rk3328
- rockchip_rk3328_recovery
- rockchip_rk3399
- rockchip_rk3399pro
- rockchip_rk3399pro-npu
- rockchip_rk3399pro_recovery
- rockchip_rk3399_recovery
- rockchip_rv1108
Which would you like? [1]: 46
#TARGET_BOARD=rk3399pro-npu
#OUTPUT_DIR=output/rockchip_rk3399pro-npu
#CONFIG=rockchip_rk3399pro-npu_defconfig
make: Entering directory ‘/home/qslia/Linux_SDK/firefly/linux_sdk/buildroot’
mkdir -p /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro-npu/build/buildroot-config/lxdialog
PKG_CONFIG_PATH=“” make CC=“/usr/bin/gcc” HOSTCC=“/usr/bin/gcc”
obj=/home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro-npu/build/buildroot-config -C support/kconfig -f Makefile.br conf
make[1]: Entering directory ‘/home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/support/kconfig’
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -DCURSES_LOC=“<ncurses.h>” -DLOCALE -I/home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro-npu/build/buildroot-config -DCONFIG_="" -MM *.c > /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro-npu/build/buildroot-config/.depend 2>/dev/null || :
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -DCURSES_LOC=“<ncurses.h>” -DLOCALE -I/home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro-npu/build/buildroot-config -DCONFIG_="" -c conf.c -o /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro-npu/build/buildroot-config/conf.o
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -DCURSES_LOC=“<ncurses.h>” -DLOCALE -I/home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro-npu/build/buildroot-config -DCONFIG_="" -I. -c /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro-npu/build/buildroot-config/zconf.tab.c -o /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro-npu/build/buildroot-config/zconf.tab.o
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -DCURSES_LOC=“<ncurses.h>” -DLOCALE -I/home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro-npu/build/buildroot-config -DCONFIG_="" /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro-npu/build/buildroot-config/conf.o /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro-npu/build/buildroot-config/zconf.tab.o -o /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro-npu/build/buildroot-config/conf
rm /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro-npu/build/buildroot-config/zconf.tab.c
make[1]: Leaving directory ‘/home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/support/kconfig’
GEN /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro-npu/Makefile
/home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/build/defconfig_hook.py -m /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/configs/rockchip_rk3399pro-npu_defconfig /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro-npu/.rockchipconfig
BR2_DEFCONFIG=‘’ KCONFIG_AUTOCONFIG=/home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro-npu/build/buildroot-config/auto.conf KCONFIG_AUTOHEADER=/home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro-npu/build/buildroot-config/autoconf.h KCONFIG_TRISTATE=/home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro-npu/build/buildroot-config/tristate.config BR2_CONFIG=/home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro-npu/.config HOST_GCC_VERSION=“7” BUILD_DIR=/home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro-npu/build SKIP_LEGACY= BR2_DEFCONFIG=/home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/configs/rockchip_rk3399pro-npu_defconfig /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro-npu/build/buildroot-config/conf --defconfig=/home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro-npu/.rockchipconfig Config.in
# configuration written to /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro-npu/.config
make: Leaving directory ‘/home/qslia/Linux_SDK/firefly/linux_sdk/buildroot’
./build.sh kernel
Building modules, stage 2.
MODPOST 4 modules
CC drivers/net/wireless/mwifiex/mwifiex.mod.o
CC drivers/net/wireless/mwifiex/mwifiex_sdio.mod.o
CC drivers/net/wireless/rockchip_wlan/rkwifi/bcmdhd/bcmdhd.mod.o
CC drivers/net/wireless/rockchip_wlan/rtl8188eu/8188eu.mod.o
LD [M] drivers/net/wireless/mwifiex/mwifiex_sdio.ko
LD [M] drivers/net/wireless/rockchip_wlan/rtl8188eu/8188eu.ko
LD [M] drivers/net/wireless/rockchip_wlan/rkwifi/bcmdhd/bcmdhd.ko
LD [M] drivers/net/wireless/mwifiex/mwifiex.ko
Pack to resource.img successed!
Image: resource.img (with rk3399pro-evb-v11-linux.dtb logo.bmp ) is ready
Image: boot.img (with Image resource.img) is ready
Image: zboot.img (with Image.lz4 resource.img) is ready
====Build kernel ok!====
./build.sh uboot
load addr is 0x200000!
pack input ./u-boot.bin
pack file size: 860863
crc = 0x8f16156b
uboot version: U-Boot 2017.09-g14ce716885 (Dec 07 2019 - 14:21:02)
pack uboot.img success!
pack uboot okay! Input: ./u-boot.bin
out:rk3399pro_loader_v1.20.115.bin
fix opt:rk3399pro_loader_v1.20.115.bin
merge success(rk3399pro_loader_v1.20.115.bin)
pack loader okay! Input: /home/qslia/Linux_SDK/firefly/linux_sdk/rkbin/RKBOOT/RK3399PROMINIALL.ini
/home/qslia/Linux_SDK/firefly/linux_sdk/u-boot
out:trust.img
merge success(trust.img)
pack trust okay! Input: /home/qslia/Linux_SDK/firefly/linux_sdk/rkbin/RKTRUST/RK3399PROTRUST.ini
Platform RK3399PRO is build OK, with new .config(make rk3399pro_defconfig)
====Build uboot ok!====
./build.sh recovery
编译recovery真的是久。。。
Exportable Squashfs 4.0 filesystem, gzip compressed, data block size 131072
compressed data, compressed metadata, compressed fragments, compressed xattrs
duplicates are removed
Filesystem size 23267.11 Kbytes (22.72 Mbytes)
52.12% of uncompressed filesystem size (44641.12 Kbytes)
Inode table size 6771 bytes (6.61 Kbytes)
26.12% of uncompressed inode table size (25921 bytes)
Directory table size 7072 bytes (6.91 Kbytes)
55.04% of uncompressed directory table size (12848 bytes)
Number of duplicate files found 6
Number of inodes 697
Number of files 244
Number of fragments 29
Number of symbolic links 356
Number of device nodes 1
Number of fifo nodes 0
Number of socket nodes 0
Number of directories 96
Number of ids (unique uids + gids) 2
Number of uids 2
root (0)
www-data (33)
Number of gids 2
root (0)
www-data (33)
/usr/bin/install -m 0644 support/misc/target-dir-warning.txt /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro_recovery/target/THIS_IS_NOT_YOUR_ROOT_FILESYSTEM
Generating root filesystem image rootfs.tar
rm -rf /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro_recovery/build/buildroot-fs
mkdir -p /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro_recovery/build/buildroot-fs
echo ‘#!/bin/sh’ > /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro_recovery/build/buildroot-fs/fakeroot.fs
echo “set -e” >> /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro_recovery/build/buildroot-fs/fakeroot.fs
echo “chown -h -R 0:0 /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro_recovery/target” >> /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro_recovery/build/buildroot-fs/fakeroot.fs
printf ’ - - input -1 * - - - Input device group\n\n’ >> /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro_recovery/build/buildroot-fs/users_table.txt
PATH=“/home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro_recovery/host/bin:/home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro_recovery/host/sbin:/usr/lib/jvm/java-8-openjdk-amd64/bin:/usr/lib/jvm/java-8-openjdk-amd64/jre/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin” /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/support/scripts/mkusers /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro_recovery/build/buildroot-fs/users_table.txt /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro_recovery/target >> /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro_recovery/build/buildroot-fs/fakeroot.fs
cat system/device_table.txt > /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro_recovery/build/buildroot-fs/device_table.txt
printf ’ /bin/busybox f 4755 0 0 - - - - -\n /dev/console c 622 0 0 5 1 - - -\n\n’ >> /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro_recovery/build/buildroot-fs/device_table.txt
echo “/home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro_recovery/host/bin/makedevs -d /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro_recovery/build/buildroot-fs/device_table.txt /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro_recovery/target” >> /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro_recovery/build/buildroot-fs/fakeroot.fs
printf ’ (cd /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro_recovery/target; find -print0 | LC_ALL=C sort -z | tar -cf /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro_recovery/images/rootfs.tar --null --no-recursion -T - --numeric-owner)\n’ >> /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro_recovery/build/buildroot-fs/fakeroot.fs
chmod a+x /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro_recovery/build/buildroot-fs/fakeroot.fs
rm -f /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro_recovery/target/THIS_IS_NOT_YOUR_ROOT_FILESYSTEM
PATH=“/home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro_recovery/host/bin:/home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro_recovery/host/sbin:/usr/lib/jvm/java-8-openjdk-amd64/bin:/usr/lib/jvm/java-8-openjdk-amd64/jre/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin” /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro_recovery/host/bin/fakeroot – /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro_recovery/build/buildroot-fs/fakeroot.fs
rootdir=/home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro_recovery/target
table=‘/home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro_recovery/build/buildroot-fs/device_table.txt’
====Build recovery ok!====
pack recovery image…done.
you take 24:19.04 to build recovery
./build.sh rootfs 尽管官网提供了编译好的img,但还是自己编译感受下
Filesystem size 124218.52 Kbytes (121.31 Mbytes)
38.53% of uncompressed filesystem size (322416.52 Kbytes)
Inode table size 64243 bytes (62.74 Kbytes)
30.20% of uncompressed inode table size (212732 bytes)
Directory table size 63046 bytes (61.57 Kbytes)
49.86% of uncompressed directory table size (126443 bytes)
Number of duplicate files found 42
Number of inodes 5995
Number of files 4688
Number of fragments 467
Number of symbolic links 638
Number of directories 668
Number of ids (unique uids + gids) 3
Number of uids 3
root (0)
qslia (1000)
www-data (33)
Number of gids 3
root (0)
qslia (1000)
www-data (33)
/usr/bin/install -m 0644 support/misc/target-dir-warning.txt /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/target/THIS_IS_NOT_YOUR_ROOT_FILESYSTEM
rm -rf /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/build/buildroot-fs
mkdir -p /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/build/buildroot-fs
echo ‘#!/bin/sh’ > /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/build/buildroot-fs/fakeroot.fs
echo “set -e” >> /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/build/buildroot-fs/fakeroot.fs
echo “chown -h -R 0:0 /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/target” >> /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/build/buildroot-fs/fakeroot.fs
printf ’ dbus -1 dbus -1 * /var/run/dbus - dbus DBus messagebus user\n - - input -1 * - - - Input device group\n sshd -1 sshd -1 * - - - SSH drop priv user\n\n’ >> /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/build/buildroot-fs/users_table.txt
PATH=“/home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/host/bin:/home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/host/sbin:/usr/lib/jvm/java-8-openjdk-amd64/bin:/usr/lib/jvm/java-8-openjdk-amd64/jre/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin” /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/support/scripts/mkusers /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/build/buildroot-fs/users_table.txt /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/target >> /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/build/buildroot-fs/fakeroot.fs
cat system/device_table.txt > /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/build/buildroot-fs/device_table.txt
printf ’ /bin/busybox f 4755 0 0 - - - - -\n /usr/libexec/dbus-daemon-launch-helper f 4755 0 0 - - - - -\n /bin/ping f 4755 0 0 - - - - -\n /bin/traceroute6 f 4755 0 0 - - - - -\n /dev/console c 622 0 0 5 1 - - -\n\n’ >> /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/build/buildroot-fs/device_table.txt
echo “/home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/host/bin/makedevs -d /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/build/buildroot-fs/device_table.txt /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/target” >> /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/build/buildroot-fs/fakeroot.fs
printf ’ (cd /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/target; find -print0 | LC_ALL=C sort -z | tar -cf /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/images/rootfs.tar --null --no-recursion -T - --numeric-owner)\n’ >> /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/build/buildroot-fs/fakeroot.fs
chmod a+x /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/build/buildroot-fs/fakeroot.fs
rm -f /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/target/THIS_IS_NOT_YOUR_ROOT_FILESYSTEM
PATH=“/home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/host/bin:/home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/host/sbin:/usr/lib/jvm/java-8-openjdk-amd64/bin:/usr/lib/jvm/java-8-openjdk-amd64/jre/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin” /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/host/bin/fakeroot – /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/build/buildroot-fs/fakeroot.fs
rootdir=/home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/target
table=‘/home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/build/buildroot-fs/device_table.txt’
pack buildroot image at: /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/images/rootfs.ext4
you take 1:12:45 to build builroot
====Build buildroot ok!====
qslia@qsliapc:~/Linux_SDK/firefly/linux_sdk$ ./mkfirmware.sh
create rootfs.img…done.
create parameter…done.
create recovery.img…done.
create misc.img…done.
create oem.img…SIZE = 8192
genext2fs -b 8192 -N 2048 -d /home/qslia/Linux_SDK/firefly/linux_sdk/device/rockchip/oem/oem_normal /home/qslia/Linux_SDK/firefly/linux_sdk/rockdev/oem.img
e2fsck 1.44.1 (24-Mar-2018)
Filesystem did not have a UUID; generating one.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/home/qslia/Linux_SDK/firefly/linux_sdk/rockdev/oem.img: 16/2048 files (0.0% non-contiguous), 6599/8192 blocks
done.
create userdata.img…SIZE = 3072
genext2fs -b 3072 -N 768 -d /home/qslia/Linux_SDK/firefly/linux_sdk/device/rockchip/userdata/userdata_normal /home/qslia/Linux_SDK/firefly/linux_sdk/rockdev/userdata.img
/home/qslia/Linux_SDK/firefly/linux_sdk/rockdev/userdata.img: 14/768 files (0.0% non-contiguous), 525/3072 blocks
done.
create uboot.img…done.
error: /home/qslia/Linux_SDK/firefly/linux_sdk/u-boot/idbloader.img not found! ------->>>这是啥??
create trust.img…done.
create loader…done.
create boot.img…done.
Image: image in rockdev is ready
qslia@qsliapc:~/Linux_SDK/firefly/linux_sdk$ ls
app buildroot build.sh debian device distro docs envsetup.sh external kernel Makefile mkfirmware.sh prebuilts rkbin rkflash.sh rockdev tools u-boot
qslia@qsliapc:~/Linux_SDK/firefly/linux_sdk$ cd rockdev
qslia@qsliapc:~/Linux_SDK/firefly/linux_sdk/rockdev$ ls
boot.img MiniLoaderAll.bin misc.img oem.img parameter.txt recovery.img rootfs.img trust.img uboot.img userdata.img
qslia@qsliapc:~/Linux_SDK/firefly/linux_sdk$ ./build.sh updateimg
Make update.img
start to make update.img…
Android Firmware Package Tool v1.65
------ PACKAGE ------
Add file: ./package-file
Add file: ./Image/MiniLoaderAll.bin
Add file: ./Image/parameter.txt
Add file: ./Image/trust.img
Add file: ./Image/uboot.img
Add file: ./Image/misc.img
Add file: ./Image/boot.img
Add file: ./Image/recovery.img
Add file: ./Image/rootfs.img
Add file: ./Image/oem.img
Add file: ./Image/userdata.img
Add CRC…
Make firmware OK!
------ OK ------
RKImageMaker ver 1.66
Generating new image, please wait…
Writing head info…
Writing boot file…
Writing firmware…
Generating MD5 data…
MD5 data generated successfully!
New image generated successfully!
Making ./Image/update.img OK.
Make update image ok!
Img_path:/home/qslia/Linux_SDK/firefly/linux_sdk/rockdev/update.img
qslia@qsliapc:~/Linux_SDK/firefly/linux_sdk/rockdev$ ls -hl
total 591M
lrwxrwxrwx 1 qslia qslia 55 12月 7 16:23 boot.img → /home/qslia/Linux_SDK/firefly/linux_sdk/kernel/boot.img
lrwxrwxrwx 1 qslia qslia 77 12月 7 16:23 MiniLoaderAll.bin → /home/qslia/Linux_SDK/firefly/linux_sdk/u-boot/rk3399pro_loader_v1.20.115.bin
lrwxrwxrwx 1 qslia qslia 81 12月 7 16:23 misc.img → /home/qslia/Linux_SDK/firefly/linux_sdk/device/rockchip/rockimg/wipe_all-misc.img
-rw-r–r-- 1 qslia qslia 8.0M 12月 7 16:23 oem.img
lrwxrwxrwx 1 qslia qslia 89 12月 7 16:23 parameter.txt → /home/qslia/Linux_SDK/firefly/linux_sdk/device/rockchip/rk3399pro/parameter-buildroot.txt
lrwxrwxrwx 1 qslia qslia 104 12月 7 16:23 recovery.img → /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro_recovery/images/recovery.img
lrwxrwxrwx 1 qslia qslia 94 12月 7 16:23 rootfs.img → /home/qslia/Linux_SDK/firefly/linux_sdk/buildroot/output/rockchip_rk3399pro/images/rootfs.ext4
lrwxrwxrwx 1 qslia qslia 56 12月 7 16:23 trust.img → /home/qslia/Linux_SDK/firefly/linux_sdk/u-boot/trust.img
lrwxrwxrwx 1 qslia qslia 56 12月 7 16:23 uboot.img → /home/qslia/Linux_SDK/firefly/linux_sdk/u-boot/uboot.img
-rw-r–r-- 1 qslia qslia 580M 12月 7 16:29 update.img
-rw-r–r-- 1 qslia qslia 3.0M 12月 7 16:23 userdata.img
楼主你好,请问gcc-4.8-multilib-arm-linux-gnueabihf安装报错E: Unable to locate package gcc-4.8-multilib-arm-linux-gnueabihf这个问题你是怎么解决的呢?
sudo apt-get install gdc-8-multilib-arm-linux-gnueabihf
用这个可以
楼主求教一下,我编译的时候出现下面的错误指导是什么问题吗?
./../prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc -Wp,-MD,scripts/mod/.devicetable-offsets.s.d -nostdinc -isystem ./../prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc -print-file-name=include[Errno 8] Exec format error -I./arch/arm64/include -Iarch/arm64/include/generated/uapi -Iarch/arm64/include/generated -Iinclude -I./arch/arm64/include/uapi -Iarch/arm64/include/generated/uapi -I./include/uapi -Iinclude/generated/uapi -include ./include/linux/kconfig.h -D__KERNEL__ -mlittle-endian -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -std=gnu89 -mgeneral-regs-only -fno-pic -fno-asynchronous-unwind-tables -Os -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -DKBUILD_STR(s)=#s -DKBUILD_BASENAME=KBUILD_STR(devicetable_offsets) -DKBUILD_MODNAME=KBUILD_STR(devicetable_offsets) -fverbose-asm -S -o scripts/mod/devicetable-offsets.s scripts/mod/devicetable-offsets.c[Errno 8] Exec format error
scripts/Makefile.build:153: recipe for target ‘scripts/mod/devicetable-offsets.s’ failed
make[2]: *** [scripts/mod/devicetable-offsets.s] Error 8
make[2]: *** Waiting for unfinished jobs…
./../prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc -Wp,-MD,kernel/.bounds.s.d -nostdinc -isystem ./../prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc -print-file-name=include[Errno 8] Exec format error -I./arch/arm64/include -Iarch/arm64/include/generated/uapi -Iarch/arm64/include/generated -Iinclude -I./arch/arm64/include/uapi -Iarch/arm64/include/generated/uapi -I./include/uapi -Iinclude/generated/uapi -include ./include/linux/kconfig.h -D__KERNEL__ -mlittle-endian -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -std=gnu89 -mgeneral-regs-only -fno-pic -fno-asynchronous-unwind-tables -Os -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -DKBUILD_STR(s)=#s -DKBUILD_BASENAME=KBUILD_STR(bounds) -DKBUILD_MODNAME=KBUILD_STR(bounds) -fverbose-asm -S -o kernel/bounds.s kernel/bounds.c[Errno 8] Exec format error
./../prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc -Wp,-MD,scripts/mod/.empty.o.d -nostdinc -isystem ./../prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc -print-file-name=include[Errno 8] Exec format error -I./arch/arm64/include -Iarch/arm64/include/generated/uapi -Iarch/arm64/include/generated -Iinclude -I./arch/arm64/include/uapi -Iarch/arm64/include/generated/uapi -I./include/uapi -Iinclude/generated/uapi -include ./include/linux/kconfig.h -D__KERNEL__ -mlittle-endian -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -std=gnu89 -mgeneral-regs-only -fno-pic -fno-asynchronous-unwind-tables -Os -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -DKBUILD_STR(s)=#s -DKBUILD_BASENAME=KBUILD_STR(empty) -DKBUILD_MODNAME=KBUILD_STR(empty) -c -o scripts/mod/empty.o scripts/mod/empty.c[Errno 8] Exec format error
Kbuild:19: recipe for target ‘kernel/bounds.s’ failed
make[1]: *** [kernel/bounds.s] Error 8
Makefile:1079: recipe for target ‘prepare0’ failed
make: *** [prepare0] Error 2
make: *** Waiting for unfinished jobs…
scripts/Makefile.build:277: recipe for target ‘scripts/mod/empty.o’ failed
make[2]: *** [scripts/mod/empty.o] Error 8
scripts/Makefile.build:484: recipe for target ‘scripts/mod’ failed
make[1]: *** [scripts/mod] Error 2
make[1]: *** Waiting for unfinished jobs…
Makefile:579: recipe for target ‘scripts’ failed
make: *** [scripts] Error 2
====Build kernel failed!====
用这个可以
谢谢!
归来归去和楼主,你好!
我也遇到了这个问题,gcc-4.8-multilib-arm-linux-gnueabihf安装报错E: Unable to locate package gcc-4.8-multilib-arm-linux-gnueabihf。
用sudo apt-get install gdc-8-multilib-arm-linux-gnueabihf,没有报错。
但是后面的编译,一开始就有问题。感觉编译工具还是没有装好。
环境包安装列表已经更新了,不再需要安装 gcc-4.8-multilib-arm-linux-gnueabihf
这里使用Ubuntu18.04进行测试(推荐使用Ubuntu16.04及其以上版本):
sudo apt-get update
sudo apt-get install repo git-core gitk git-gui gcc-arm-linux-gnueabihf u-boot-tools device-tree-compiler \
gcc-aarch64-linux-gnu mtools parted libudev-dev libusb-1.0-0-dev python-linaro-image-tools \
linaro-image-tools gcc-arm-linux-gnueabihf libssl-dev liblz4-tool genext2fs lib32stdc++6 \
gcc-aarch64-linux-gnu g+conf autotools-dev libsigsegv2 m4 intltool libdrm-dev curl sed make \
binutils build-essential gcc g++ bash patch gzip bzip2 perl tar cpio python unzip rsync file bc wget \
libncurses5 libqt4-dev libglib2.0-dev libgtk2.0-dev libglade2-dev cvs git mercurial rsync openssh-client \
subversion asciidoc w3m dblatex graphviz python-matplotlib libssl-dev texinfo fakeroot \
libparse-yapp-perl default-jre patchutils swig chrpath diffstat gawk time expect-dev
