U-Boot 2017.09 (Jun 12 2019 - 11:15:10 +0800)
Model: Rockchip RK3399 Evaluation Board
DRAM: 3.8 GiB
Relocation Offset is: f5be0000
mmc_init: -95, time 9
switch to partitions #0, OK
Bootdev: mmc 0
PartType: EFI
get part misc fail -1
boot mode: None
init_resource_list: failed to get resource part, ret=-1
DTB: rk-kernel.dtb
Can’t find file:rk-kernel.dtb
init_kernel_dtb dtb in resource read fail
Can’t find UCLASS_IO_DOMAIN driver -19
rockchip_set_serialno: could not find efuse device
download key pressed… rockchip_chg_get_type: get u2phy node failed: -19
CLK:
aplll 816000 KHz
apllb 24000 KHz
dpll 800000 KHz
cpll 24000 KHz
gpll 800000 KHz
npll 600000 KHz
vpll 24000 KHz
aclk_perihp 133333 KHz
hclk_perihp 66666 KHz
pclk_perihp 33333 KHz
aclk_perilp0 266666 KHz
hclk_perilp0 88888 KHz
pclk_perilp0 44444 KHz
hclk_perilp1 100000 KHz
pclk_perilp1 50000 KHz
Net: No ethernet found.
android_bootloader_boot_flow Could not find misc partition
** Invalid Android Image header **
load_android_image: boot part load fail, ret=-1
=Booting Rockchip format image=
boot_rockchip_image kernel or boot part info error
Failed to mount ext2 filesystem…
** Unrecognized filesystem type **
starting USB…
USB0: Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
USB1: Register 2000140 NbrPorts 2
USB XHCI 1.10
scanning bus 0 for devices… 1 USB Device(s) found
scanning bus 1 for devices… 1 USB Device(s) found
scanning usb for storage devices… 0 Storage Device(s) found
Device 0: unknown device
No ethernet found.
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-rockchip
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
No ethernet found.
