ubuntu18.04编译Android8.1
E: Unable to locate package libesd0-dev
1 sudo vim /etc/apt/sources.list //在行尾添加如下两行的内容
2 deb http://us.archive.ubuntu.com/ubuntu/ xenial main universe
3 deb-src http://us.archive.ubuntu.com/ubuntu/ xenial main universe
sudo apt-get update && sudo apt-get install libesd0-dev
参考https://blog.csdn.net/weixin_34248258/article/details/86028896
E: Unable to locate package libwxgtk2.8-dev
E: Couldn’t find any package by glob ‘libwxgtk2.8-dev’
E: Couldn’t find any package by regex ‘libwxgtk2.8-dev’
E: Package ‘lib32readline-gplv2-dev’ has no installation candidate
Would you like to replace the existing file:
Path: AIO-RK3399ProJD4/firenow-oreo-rk3399pro/libcore/luni/src/test/resources/org/apache/harmony/tests/java/lang/test#.properties
Size: 44 bytes (1 KiB)
Modified: 2019-04-30 09:29:34
with the file from archive:
Path: firenow-oreo-rk3399pro/libcore/luni/src/test/resources/org/apache/harmony/tests/java/lang/test?.properties
? (Y)es / (N)o / (A)lways / (S)kip all / A(u)to rename all / (Q)uit? u
Everything is Ok
Folders: 103872
Files: 729557
Compressed: 22868407317
qslia@qsliapc:~/Android8.1/Android8.1/AIO-RK3399ProJD4/firenow-oreo-rk3399pro$ git reset --hard
Checking out files: 100% (729535/729535), done.
HEAD is now at c22a3286e3 Init the AIO-RK3399Pro-JD4 Android8.1 SDK
qslia@qsliapc:~/Android8.1/Android8.1/AIO-RK3399ProJD4/firenow-oreo-rk3399pro$ .bundle/update
[Info]Update Bundle repo…
git@gitlab.com: Permission denied (publickey).
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
[Info]Update to FETCH_HEAD:
Receiving objects: 100% (52/52), 954.15 KiB | 119.27 MiB/s, done.
Resolving deltas: 100% (36/36), completed with 35 local objects.
From .bundle/0.bundle
  • branch HEAD → FETCH_HEAD
    [Info]Fetch .bundle/0.bundle successfully!!
    Receiving objects: 100% (2692/2692), 314.99 MiB | 93.79 MiB/s, done.
    Resolving deltas: 100% (1838/1838), completed with 1240 local objects.
    From .bundle/1.bundle
    [Info]Fetch .bundle/1.bundle successfully!!
    qslia@qsliapc:~/Android8.1/Android8.1/AIO-RK3399ProJD4/firenow-oreo-rk3399pro$ git rebase FETCH_HEAD
    First, rewinding head to replay your work on top of it…
    Fast-forwarded firefly to FETCH_HEAD.
编译kernel
qslia@qsliapc:~/Android8.1/Android8.1/AIO-RK3399ProJD4/firenow-oreo-rk3399pro$ cd kernel/
qslia@qsliapc:~/Android8.1/Android8.1/AIO-RK3399ProJD4/firenow-oreo-rk3399pro/kernel$ make ARCH=arm64 firefly_defconfig
make -j8 ARCH=arm64 rk3399pro-firefly-aiojd4.img
sudo apt-get update
sudo apt-get install liblz4-tool
Pack to resource.img successed!
Image: resource.img (with rk3399pro-firefly-aiojd4.dtb logo.bmp ) is ready
Image: boot.img (with Image resource.img) is ready
Image: zboot.img (with Image.lz4 resource.img) is ready
qslia@qsliapc:~/Android8.1/Android8.1/AIO-RK3399ProJD4/firenow-oreo-rk3399pro/u-boot$ ./make.sh rk3399pro
load addr is 0x200000!
pack input ./u-boot.bin
pack file size: 967367(944 KB)
crc = 0x7167f967
uboot version: U-Boot 2017.09 (Dec 08 2019 - 14:52:51)
pack uboot.img success!
pack uboot okay! Input: ./u-boot.bin
out:rk3399pro_loader_v1.20.115.bin
fix opt:rk3399pro_loader_v1.20.115.bin
merge success(rk3399pro_loader_v1.20.115.bin)
pack loader okay! Input: /home/qslia/Android8.1/Android8.1/AIO-RK3399ProJD4/firenow-oreo-rk3399pro/rkbin/RKBOOT/RK3399PROMINIALL.ini
/home/qslia/Android8.1/Android8.1/AIO-RK3399ProJD4/firenow-oreo-rk3399pro/u-boot
out:trust.img
merge success(trust.img)
pack trust okay! Input: /home/qslia/Android8.1/Android8.1/AIO-RK3399ProJD4/firenow-oreo-rk3399pro/rkbin/RKTRUST/RK3399PROTRUST.ini
Platform RK3399PRO is build OK, with new .config(make rk3399pro_defconfig)
source build/envsetup.sh
including device/rockchip/rk3399pro/vendorsetup.sh
including sdk/bash_completion/adb.bash
qslia@qsliapc:~/Android8.1/Android8.1/AIO-RK3399ProJD4/firenow-oreo-rk3399pro$ lunch
You’re building on Linux
Lunch menu… pick a combo:
1. aosp_arm-eng
2. aosp_arm64-eng
3. aosp_mips-eng
4. aosp_mips64-eng
5. aosp_x86-eng
6. aosp_x86_64-eng
7. rk3399pro_firefly_aiojd4-userdebug
8. rk3399pro_firefly_aiojd4-user
9. rk3399pro_firefly_aioc-userdebug
10. rk3399pro_firefly_aioc-user
11. rk3399pro-userdebug
12. rk3399pro-user
Which would you like? [aosp_arm-eng] 7
PLATFORM_VERSION_CODENAME=REL
PLATFORM_VERSION=8.1.0
TARGET_PRODUCT=rk3399pro_firefly_aiojd4
TARGET_BUILD_VARIANT=userdebug
TARGET_BUILD_TYPE=release
TARGET_PLATFORM_VERSION=OPM1
TARGET_BUILD_APPS=
TARGET_ARCH=arm64
TARGET_ARCH_VARIANT=armv8-a
TARGET_CPU_VARIANT=cortex-a53
TARGET_2ND_ARCH=arm
TARGET_2ND_ARCH_VARIANT=armv7-a-neon
TARGET_2ND_CPU_VARIANT=cortex-a15
HOST_ARCH=x86_64
HOST_2ND_ARCH=x86
HOST_OS=linux
HOST_OS_EXTRA=Linux-5.0.0-37-generic-x86_64-with-Ubuntu-18.04-bionic
HOST_CROSS_OS=windows
HOST_CROSS_ARCH=x86
HOST_CROSS_2ND_ARCH=x86_64
HOST_BUILD_TYPE=release
BUILD_ID=OPM8.190405.001
OUT_DIR=out
AUX_OS_VARIANT_LIST=
qslia@qsliapc:~/Android8.1/Android8.1/AIO-RK3399ProJD4/firenow-oreo-rk3399pro$ make -j8
TARGET_ARCH=arm64
TARGET_2ND_ARCH=arm
HOST_ARCH=x86_64
HOST_2ND_ARCH=x86
HOST_OS=linux
HOST_CROSS_ARCH=x86
OUT_DIR=out
[44/44] bootstrap out/soong/.minibootstrap/build.ninja.in
[4/4] out/soong/.bootstrap/bin/minibp out/soong/.bootstrap/build.ninja
[851/852] glob test/vts/utils/native/libprofiling/Android.bp
[54/54] out/soong/.bootstrap/bin/soong_build out/soong/build.ninja
out/build-rk3399pro_firefly_aiojd4.ninja is missing, regenerating…
[4/1059] including ./bootable/recovery/Android.mk …
./bootable/recovery/Android.mk:101: warning: *** Redirect log to UART
[485/1059] including ./hardware/rockchip/camera/Android.mk …
BOARD_DEFAULT_CAMERA_HAL_VERSION=1.0
[491/1059] including ./hardware/rockchip/librga/Android.mk …
Generated version.h
[495/1059] including ./hardware/rockchip/omx_il/Android.mk …
cp: cannot create regular file ‘.git/hooks/pre-commit’: No such file or directory
tools/hooks .git/hooks
[497/1059] including ./hardware/rockchip/sensor/Android.mk …
YD>>PLATFORM_VERSION=8.1.0
YD>>ANDRIOD VERSION=8.1
YD>>VERSION_L=, VERSION_KK=
YD>>LOCAL_MODULE=sensors.rk30board
YD>>LOCAL_MODULE=sensors.rk30board, LOCAL_SRC_FILES=sensors_mpl.cpp SamsungSensorBase.cpp LightSensor.cpp ProximitySensor.cpp, LOCAL_SHARED_LIBRARIES=libinvensense_hal libcutils libutils libdl liblog libmllite
[1059/1059] including ./vendor/rockchip/common/vpu/Android.mk …
PRODUCT_COPY_FILES device/rockchip/common/init.rk30board.usb.rc:root/init.rk30board.usb.rc ignored.
PRODUCT_COPY_FILES vendor/rockchip/common/npu/bin/npu_transfer_proxy:vendor/bin/npu_transfer_proxy ignored.
PRODUCT_COPY_FILES vendor/rockchip/common/npu/npu_transfer_proxy.rc:vendor/etc/init/npu_transfer_proxy.rc ignored.
PRODUCT_COPY_FILES vendor/rockchip/common/phone/etc/apns-full-conf.xml:system/etc/apns-conf.xml ignored.
No private recovery resources for TARGET_DEVICE rk3399pro_firefly_aiojd4
build/core/aapt2.mk:32: warning: overriding commands for target out/target/product/rk3399pro_firefly_aiojd4/obj/APPS/Bluetooth_intermediates/flat-res/device/rockchip/common/overlay/packages/apps/Bluetooth/res/values_config.arsc.flat' build/core/aapt2.mk:32: warning: ignoring old commands for target out/target/product/rk3399pro_firefly_aiojd4/obj/APPS/Bluetooth_intermediates/flat-res/device/rockchip/common/overlay/packages/apps/Bluetooth/res/values_config.arsc.flat’
build/core/Makefile:34: warning: overriding commands for target out/target/product/rk3399pro_firefly_aiojd4/system/bin/chat' build/core/base_rules.mk:390: warning: ignoring old commands for target out/target/product/rk3399pro_firefly_aiojd4/system/bin/chat’
build/core/Makefile:34: warning: overriding commands for target out/target/product/rk3399pro_firefly_aiojd4/vendor/bin/hw/rild' build/core/base_rules.mk:390: warning: ignoring old commands for target out/target/product/rk3399pro_firefly_aiojd4/vendor/bin/hw/rild’
build/core/Makefile:34: warning: overriding commands for target out/target/product/rk3399pro_firefly_aiojd4/vendor/lib/libjpeghwenc.so' build/core/base_rules.mk:390: warning: ignoring old commands for target out/target/product/rk3399pro_firefly_aiojd4/vendor/lib/libjpeghwenc.so’
build/core/Makefile:34: warning: overriding commands for target out/target/product/rk3399pro_firefly_aiojd4/vendor/lib/libjpeghwdec.so' build/core/base_rules.mk:390: warning: ignoring old commands for target out/target/product/rk3399pro_firefly_aiojd4/vendor/lib/libjpeghwdec.so’
build/core/Makefile:34: warning: overriding commands for target out/target/product/rk3399pro_firefly_aiojd4/vendor/lib64/libjpeghwenc.so' build/core/base_rules.mk:390: warning: ignoring old commands for target out/target/product/rk3399pro_firefly_aiojd4/vendor/lib64/libjpeghwenc.so’
[ 99% 1573/1574] glob vendor///Android.bp
[ 2% 2464/83051] target C: e2fsdroid_static <= external/e2fsprogs/contrib/android/block_range.c
In file included from external/e2fsprogs/contrib/android/block_range.c:3:
In file included from external/e2fsprogs/contrib/android/block_range.h:5:
In file included from external/e2fsprogs/lib/ext2fs/ext2fs.h:71:
external/e2fsprogs/lib/ext2fs/ext2_types.h:30:9: warning: ‘__bitwise’ macro redefined [-Wmacro-redefined]
#define __bitwise
bionic/libc/kernel/uapi/linux/types.h:25:9: note: previous definition is here
#define __bitwise bitwise
1 warning generated.
[ 2% 2465/83051] target C: e2fsdroid_static <= external/e2fsprogs/contrib/android/e2fsdroid.c
In file included from external/e2fsprogs/contrib/android/e2fsdroid.c:6:
#define __bitwise
[ 2% 2466/83051] target C: e2fsdroid_static <= external/e2fsprogs/contrib/android/block_list.c
In file included from external/e2fsprogs/contrib/android/block_list.c:1:
In file included from external/e2fsprogs/contrib/android/block_list.h:4:
In file included from external/e2fsprogs/contrib/android/fsmap.h:11:
#define __bitwise
[ 2% 2467/83051] target C: e2fsdroid_static <= external/e2fsprogs/contrib/android/fsmap.c
In file included from external/e2fsprogs/contrib/android/fsmap.c:1:
#define __bitwise
[ 2% 2470/83051] target C: e2fsdroid_static <= external/e2fsprogs/contrib/android/base_fs.c
In file included from external/e2fsprogs/contrib/android/base_fs.c:1:
In file included from external/e2fsprogs/contrib/android/base_fs.h:4:
#define __bitwise
[ 2% 2472/83051] target C: e2fsdroid_static <= external/e2fsprogs/contrib/android/perms.c
In file included from external/e2fsprogs/contrib/android/perms.c:4:
In file included from external/e2fsprogs/contrib/android/perms.h:5:
#define __bitwise
external/e2fsprogs/contrib/android/perms.c:291:31: warning: unused parameter ‘seopts’ [-Wunused-parameter]
struct selinux_opt *seopts,
external/e2fsprogs/contrib/android/perms.c:292:24: warning: unused parameter ‘nopt’ [-Wunused-parameter]
unsigned int nopt,
3 warnings generated.
[ 2% 2476/83051] target C: e2fsdroid_static <= external/e2fsprogs/contrib/android/basefs_allocator.c
In file included from external/e2fsprogs/contrib/android/basefs_allocator.c:3:
In file included from external/e2fsprogs/contrib/android/basefs_allocator.h:5:
#define __bitwise
[ 3% 2594/83051] target C: libmtdutils <= bootable/recovery/mtdutils/rk29.c
bootable/recovery/mtdutils/rk29.c:66:51: warning: unused parameter ‘len’ [-Wunused-parameter]
int rk_make_ext4fs(const char *filename,long long len, const char *mountpoint)
[ 3% 3119/83051] Ensuring Jack server is installed and started
Writing client settings in /home/qslia/.jack-settings
Installing jack server in “/home/qslia/.jack-server”
Warning:
The JKS keystore uses a proprietary format. It is recommended to migrate to PKCS12 which is an industry standard format using “keytool -importkeystore -srckeystore /home/qslia/.jack-server/server.jks -destkeystore /home/qslia/.jack-server/server.jks -deststoretype pkcs12”.
Warning:
The JKS keystore uses a proprietary format. It is recommended to migrate to PKCS12 which is an industry standard format using “keytool -importkeystore -srckeystore /home/qslia/.jack-server/client.jks -destkeystore /home/qslia/.jack-server/client.jks -deststoretype pkcs12”.
Launching Jack server java -XX:MaxJavaStackTraceDepth=-1 -Djava.io.tmpdir=/tmp -Dfile.encoding=UTF-8 -XX:+TieredCompilation -cp /home/qslia/.jack-server/launcher.jar com.android.jack.launcher.ServerLauncher
[ 5% 4153/83051] target thumb C: libsvoxpico_32 <= external/svox/pico/lib/picodbg.c
external/svox/pico/lib/picodbg.c:427:33: warning: all paths through this function will call itself [-Winfinite-recursion]
static void picodbg_dummy(void) {
[ 5% 4154/83051] target thumb C: libsvoxpico_32 <= external/svox/pico/lib/picoextapi.c
external/svox/pico/lib/picoextapi.c:116:10: warning: explicitly assigning value of variable of type 'const pico_Char ’ (aka 'const unsigned char ') to itself [-Wself-assign]
name = name; /PP 13.10.08 : fix warning “var not used in this function”/
external/svox/pico/lib/picoextapi.c:130:10: warning: explicitly assigning value of variable of type 'const pico_Char ’ (aka 'const unsigned char ') to itself [-Wself-assign]
2 warnings generated.
[ 5% 4155/83051] target thumb C: libsvoxpico_32 <= external/svox/pico/lib/picoctrl.c
external/svox/pico/lib/picoctrl.c:271:8: warning: explicitly assigning value of variable of type ‘picoos_MemoryManager’ (aka 'struct memory_manager ') to itself [-Wself-assign]
mm = mm; /
external/svox/pico/lib/picoctrl.c:297:21: warning: unused parameter ‘levelAwareCbOut’ [-Wunused-parameter]
picoos_bool levelAwareCbOut,
[ 5% 4156/83051] target thumb C: libsvoxpico_32 <= external/svox/pico/lib/picodata.c
external/svox/pico/lib/picodata.c:577:75: warning: unused parameter ‘this’ [-Wunused-parameter]
static pico_status_t puSimpleInitialize (register picodata_ProcessingUnit this, picoos_int32 resetMode) {
external/svox/pico/lib/picodata.c:577:94: warning: unused parameter ‘resetMode’ [-Wunused-parameter]
external/svox/pico/lib/picodata.c:581:74: warning: unused parameter ‘this’ [-Wunused-parameter]
static pico_status_t puSimpleTerminate (register picodata_ProcessingUnit this) {
external/svox/pico/lib/picodata.c:590:10: warning: explicitly assigning value of variable of type ‘picoos_int16’ (aka ‘short’) to itself [-Wself-assign]
mode = mode; /PP 13.10.08 : fix warning “var not used in this function”/
4 warnings generated.
[ 5% 4157/83051] target thumb C: libsvoxpico_32 <= external/svox/pico/lib/picokdbg.c
external/svox/pico/lib/picokdbg.c:161:34: warning: all paths through this function will call itself [-Winfinite-recursion]
static void picokdbg_dummy(void) {
[ 5% 4158/83051] target thumb C: libsvoxpico_32 <= external/svox/pico/lib/picocep.c
external/svox/pico/lib/picocep.c:374:68: warning: unused parameter ‘this’ [-Wunused-parameter]
static pico_status_t cepTerminate(register picodata_ProcessingUnit this)
external/svox/pico/lib/picocep.c:392:8: warning: explicitly assigning value of variable of type ‘picoos_MemoryManager’ (aka 'struct memory_manager ') to itself [-Wself-assign]
mm = mm; /
avoid warning “var not used in this function”
external/svox/pico/lib/picocep.c:1495:10: warning: explicitly assigning value of variable of type ‘picoos_int16’ (aka ‘short’) to itself [-Wself-assign]
mode = mode; /
[ 5% 4160/83051] target thumb C: libsvoxpico_32 <= external/svox/pico/lib/picoacph.c
external/svox/pico/lib/picoacph.c:279:69: warning: unused parameter ‘this’ [-Wunused-parameter]
static pico_status_t acphTerminate(register picodata_ProcessingUnit this)
external/svox/pico/lib/picoacph.c:286:8: warning: explicitly assigning value of variable of type ‘picoos_MemoryManager’ (aka ‘struct memory_manager ') to itself [-Wself-assign]
mm = mm; /
avoid warning “var not used in this function”/
external/svox/pico/lib/picoacph.c:328:69: warning: unused parameter ‘this’ [-Wunused-parameter]
static picoos_uint8 acphGetNrSylls(register picodata_ProcessingUnit this,
external/svox/pico/lib/picoacph.c:361:39: warning: equality comparison with extraneous parentheses [-Wparentheses-equality]
if ((acph->headx[i].head.type == PICODATA_ITEM_WORDPHON)) {
external/svox/pico/lib/picoacph.c:361:39: note: remove extraneous parentheses around the comparison to silence this warning
external/svox/pico/lib/picoacph.c:361:39: note: use ‘=’ to turn this equality comparison into an assignment
external/svox/pico/lib/picoacph.c:352:79: warning: unused parameter ‘this’ [-Wunused-parameter]
static picoos_uint8 acphPhrItemSeqGetPosLeft(register picodata_ProcessingUnit this,
external/svox/pico/lib/picoacph.c:626:39: warning: equality comparison with extraneous parentheses [-Wparentheses-equality]
external/svox/pico/lib/picoacph.c:626:39: note: remove extraneous parentheses around the comparison to silence this warning
external/svox/pico/lib/picoacph.c:626:39: note: use ‘=’ to turn this equality comparison into an assignment
external/svox/pico/lib/picoacph.c:617:79: warning: unused parameter ‘this’ [-Wunused-parameter]
static picoos_uint8 acphAccItemSeqGetPosLeft(register picodata_ProcessingUnit this,
external/svox/pico/lib/picoacph.c:637:73: warning: unused parameter ‘this’ [-Wunused-parameter]
static picoos_uint8 acphAccNrSyllParts(register picodata_ProcessingUnit this,
external/svox/pico/lib/picoacph.c:767:78: warning: unused parameter ‘this’ [-Wunused-parameter]
static picoos_uint8 acphIsWordWithoutStress(register picodata_ProcessingUnit this,
external/svox/pico/lib/picoacph.c:1062:10: warning: explicitly assigning value of variable of type ‘picoos_int16’ (aka ‘short’) to itself [-Wself-assign]
mode = mode; /
10 warnings generated.
[ 5% 4162/83051] target thumb C++: libttspico_32 <= external/svox/pico/tts/com_svox_picottsengine.cpp
external/svox/pico/tts/com_svox_picottsengine.cpp:756:61: warning: unused parameter ‘length’ [-Wunused-parameter]
extern char * createPhonemeString( const char * xsampa, int length )
external/svox/pico/tts/com_svox_picottsengine.cpp:1072:28: warning: comparison of integers of different signs: ‘size_t’ (aka ‘unsigned int’) and ‘int’ [-Wsign-compare]
if (strlen(config) >= max_filename_length) {
external/svox/pico/tts/com_svox_picottsengine.cpp:1119:48: warning: unused parameter ‘lang’ [-Wunused-parameter]
tts_result TtsEngine::loadLanguage(const char lang, const char country, const char variant)
external/svox/pico/tts/com_svox_picottsengine.cpp:1119:66: warning: unused parameter ‘country’ [-Wunused-parameter]
external/svox/pico/tts/com_svox_picottsengine.cpp:1119:87: warning: unused parameter ‘variant’ [-Wunused-parameter]
external/svox/pico/tts/com_svox_picottsengine.cpp:1133:90: warning: unused parameter ‘variant’ [-Wunused-parameter]
tts_result TtsEngine::setLanguage( const char * lang, const char * country, const char * variant )
external/svox/pico/tts/com_svox_picottsengine.cpp:1212:25: warning: unused parameter ‘variant’ [-Wunused-parameter]
const char variant) {
external/svox/pico/tts/com_svox_picottsengine.cpp:1316:92: warning: unused parameter ‘size’ [-Wunused-parameter]
tts_result TtsEngine::setProperty( const char * property, const char * value, const size_t size )
8 warnings generated.
[ 5% 4168/83051] target thumb C: libsvoxpico_32 <= external/svox/pico/lib/picokdt.c
external/svox/pico/lib/picokdt.c:398:65: warning: unused parameter ‘this’ [-Wunused-parameter]
static pico_status_t kdtDtCheck(register picoknow_KnowledgeBase this,
[ 5% 4170/83051] target thumb C: libsvoxpico_32 <= external/svox/pico/lib/picokpr.c
external/svox/pico/lib/picokpr.c:286:12: warning: explicitly assigning value of variable of type ‘picoos_int32’ (aka ‘int’) to itself [-Wself-assign]
len__9 = len__9; /PP 13.10.08 : fix warning “var not used in this function”/
external/svox/pico/lib/picokpr.c:296:13: warning: explicitly assigning value of variable of type ‘picoos_int32’ (aka ‘int’) to itself [-Wself-assign]
len__10 = len__10; /PP 13.10.08 : fix warning “var not used in this function”/
external/svox/pico/lib/picokpr.c:306:13: warning: explicitly assigning value of variable of type ‘picoos_int32’ (aka ‘int’) to itself [-Wself-assign]
len__11 = len__11; /PP 13.10.08 : fix warning “var not used in this function”/
external/svox/pico/lib/picokpr.c:317:13: warning: explicitly assigning value of variable of type ‘picoos_int32’ (aka ‘int’) to itself [-Wself-assign]
len__12 = len__12; /
[ 5% 4171/83051] target thumb C: libsvoxpico_32 <= external/svox/pico/lib/picopal.c
external/svox/pico/lib/picopal.c:416:10: warning: explicitly assigning value of variable of type ‘picopal_objsize_t’ (aka ‘unsigned int’) to itself [-Wself-assign]
size = size; /
external/svox/pico/lib/picopal.c:452:10: warning: explicitly assigning value of variable of type 'void ’ to itself [-Wself-assign]
addr = addr; /
external/svox/pico/lib/picopal.c:453:9: warning: explicitly assigning value of variable of type ‘picopal_objsize_t’ (aka ‘unsigned int’) to itself [-Wself-assign]
len = len; /
external/svox/pico/lib/picopal.c:454:10: warning: explicitly assigning value of variable of type ‘picopal_int16’ (aka ‘short’) to itself [-Wself-assign]
prot = prot; /
[ 5% 4173/83051] target thumb C: libsvoxpico_32 <= external/svox/pico/lib/picoos.c
external/svox/pico/lib/picoos.c:533:18: warning: equality comparison with extraneous parentheses [-Wparentheses-equality]
if ((c->size == (picoos_ptrdiff_t) cellSize)) {
external/svox/pico/lib/picoos.c:533:18: note: remove extraneous parentheses around the comparison to silence this warning
external/svox/pico/lib/picoos.c:533:18: note: use ‘=’ to turn this equality comparison into an assignment
external/svox/pico/lib/picoos.c:1108:18: warning: equality comparison with extraneous parentheses [-Wparentheses-equality]
if ((pos == f->lPos)) {
external/svox/pico/lib/picoos.c:1108:18: note: remove extraneous parentheses around the comparison to silence this warning
external/svox/pico/lib/picoos.c:1108:18: note: use ‘=’ to turn this equality comparison into an assignment
external/svox/pico/lib/picoos.c:1624:34: warning: equality comparison with extraneous parentheses [-Wparentheses-equality]
if ((sdFile->enc == PICOOS_ENC_LIN)) {
external/svox/pico/lib/picoos.c:1624:34: note: remove extraneous parentheses around the comparison to silence this warning
external/svox/pico/lib/picoos.c:1624:34: note: use ‘=’ to turn this equality comparison into an assignment
external/svox/pico/lib/picoos.c:2283:33: warning: equality comparison with extraneous parentheses [-Wparentheses-equality]
if ((string[(ind)] == sepCh)) {
external/svox/pico/lib/picoos.c:2283:33: note: remove extraneous parentheses around the comparison to silence this warning
external/svox/pico/lib/picoos.c:2283:33: note: use ‘=’ to turn this equality comparison into an assignment
[ 5% 4174/83051] target thumb C: libsvoxpico_32 <= external/svox/pico/lib/picorsrc.c
external/svox/pico/lib/picorsrc.c:464:34: warning: unused parameter ‘this’ [-Wunused-parameter]
picorsrc_ResourceManager this,
external/svox/pico/lib/picorsrc.c:484:13: warning: explicitly assigning value of variable of type ‘picoos_uint32’ (aka ‘unsigned int’) to itself [-Wself-assign]
datalen = datalen;
[ 5% 4175/83051] target thumb C: libsvoxpico_32 <= external/svox/pico/lib/picosig.c
external/svox/pico/lib/picosig.c:391:12: warning: explicitly assigning value of variable of type ‘picoos_uint16’ (aka ‘unsigned short’) to itself [-Wself-assign]
numinb = numinb; /
external/svox/pico/lib/picosig.c:762:10: warning: explicitly assigning value of variable of type ‘picoos_int16’ (aka ‘short’) to itself [-Wself-assign]
mode = mode; /
avoid warning “var not used in this function” /
[ 5% 4176/83051] target thumb C: libsvoxpico_32 <= external/svox/pico/lib/picosa.c
external/svox/pico/lib/picosa.c:427:67: warning: unused parameter ‘this’ [-Wunused-parameter]
static pico_status_t saTerminate(register picodata_ProcessingUnit this) {
external/svox/pico/lib/picosa.c:489:79: warning: unused parameter ‘this’ [-Wunused-parameter]
static picoos_uint8 saPosDItemSeqGetPosRight(register picodata_ProcessingUnit this,
external/svox/pico/lib/picosa.c:791:67: warning: unused parameter ‘this’ [-Wunused-parameter]
static picoos_uint8 saGetNrVowel(register picodata_ProcessingUnit this,
external/svox/pico/lib/picosa.c:1078:73: warning: unused parameter ‘this’ [-Wunused-parameter]
static pico_status_t saExtractPhonemes(register picodata_ProcessingUnit this,
external/svox/pico/lib/picosa.c:1204:10: warning: explicitly assigning value of variable of type ‘picoos_int16’ (aka ‘short’) to itself [-Wself-assign]
mode = mode; /
5 warnings generated.
[ 5% 4179/83051] target thumb C: libsvoxpico_32 <= external/svox/pico/lib/picopam.c
external/svox/pico/lib/picopam.c:746:12: warning: explicitly assigning value of variable of type ‘picoos_MemoryManager’ (aka 'struct memory_manager ') to itself [-Wself-assign]
mm = mm; /
external/svox/pico/lib/picopam.c:2336:10: warning: explicitly assigning value of variable of type ‘picoos_int16’ (aka ‘short’) to itself [-Wself-assign]
mode = mode; /* avoid warning “var not used in this function”/
external/svox/pico/lib/picopam.c:2601:33: warning: explicitly assigning value of variable of type ‘pico_status_t’ (aka ‘int’) to itself [-Wself-assign]
sResult = sResult;
external/svox/pico/lib/picopam.c:2893:15: warning: explicitly assigning value of variable of type ‘picoos_uint8’ (aka ‘unsigned char’) to itself [-Wself-assign]
iteminfo1 = iteminfo1; /
external/svox/pico/lib/picopam.c:3536:37: warning: equality comparison with extraneous parentheses [-Wparentheses-equality]
if ((event_type == PICOPAM_EVENT_P_BOUND)) {
external/svox/pico/lib/picopam.c:3536:37: note: remove extraneous parentheses around the comparison to silence this warning
external/svox/pico/lib/picopam.c:3536:37: note: use ‘=’ to turn this equality comparison into an assignment
[ 5% 4181/83051] target thumb C: libsvoxpico_32 <= external/svox/pico/lib/picospho.c
external/svox/pico/lib/picospho.c:289:89: warning: unused parameter ‘resetMode’ [-Wunused-parameter]
static pico_status_t sphoInitialize(register picodata_ProcessingUnit this, picoos_int32 resetMode)
external/svox/pico/lib/picospho.c:336:69: warning: unused parameter ‘this’ [-Wunused-parameter]
static pico_status_t sphoTerminate(register picodata_ProcessingUnit this)
external/svox/pico/lib/picospho.c:496:10: warning: explicitly assigning value of variable of type 'spho_subobj_t ’ (aka 'struct spho_subobj ') to itself [-Wself-assign]
spho = spho; /
external/svox/pico/lib/picospho.c:955:10: warning: explicitly assigning value of variable of type ‘picoos_int16’ (aka ‘short’) to itself [-Wself-assign]
mode = mode; /
[ 5% 4186/83051] target thumb C: libsvoxpico_32 <= external/svox/pico/lib/picowa.c
external/svox/pico/lib/picowa.c:146:67: warning: unused parameter ‘this’ [-Wunused-parameter]
static pico_status_t waTerminate(register picodata_ProcessingUnit this) {
external/svox/pico/lib/picowa.c:155:8: warning: explicitly assigning value of variable of type ‘picoos_MemoryManager’ (aka 'struct memory_manager ') to itself [-Wself-assign]
mm = mm; /
external/svox/pico/lib/picowa.c:387:10: warning: explicitly assigning value of variable of type ‘picoos_int16’ (aka ‘short’) to itself [-Wself-assign]
[ 5% 4189/83051] target thumb C: libsvoxpico_32 <= external/svox/pico/lib/picopr.c
external/svox/pico/lib/picopr.c:436:11: warning: explicitly assigning value of variable of type ‘pr_MemTypes’ to itself [-Wself-assign]
mType = mType; /
external/svox/pico/lib/picopr.c:448:11: warning: explicitly assigning value of variable of type ‘pr_MemTypes’ to itself [-Wself-assign]
mType = mType; /
external/svox/pico/lib/picopr.c:621:69: warning: unused parameter ‘this’ [-Wunused-parameter]
static picoos_int32 tok_tokenDigitStrToInt (picodata_ProcessingUnit this, pr_subobj_t * pr, picoos_uchar stokenStr[])
external/svox/pico/lib/picopr.c:1004:49: warning: unused parameter ‘this’ [-Wunused-parameter]
static void pr_initItem(picodata_ProcessingUnit this, pr_ioItem * item)
external/svox/pico/lib/picopr.c:1047:57: warning: unused parameter ‘this’ [-Wunused-parameter]
static void pr_copyItemContent (picodata_ProcessingUnit this, pr_ioItem * inItem, pr_ioItem * outItem)
external/svox/pico/lib/picopr.c:1087:52: warning: unused parameter ‘this’ [-Wunused-parameter]
static void pr_appendItem (picodata_ProcessingUnit this, pr_ioItemPtr * firstItem, pr_ioItemPtr * lastItem, pr_ioItemPtr item)
external/svox/pico/lib/picopr.c:1758:52: warning: equality comparison with extraneous parentheses [-Wparentheses-equality]
if ((ltype == PICODATA_ITEMINFO1_TOKTYPE_LETTERV)/
|| (ltype == PICODATA_ITEMINFO1_TOKTYPE_DIGIT)/) {
external/svox/pico/lib/picopr.c:1758:52: note: remove extraneous parentheses around the comparison to silence this warning
external/svox/pico/lib/picopr.c:1758:52: note: use ‘=’ to turn this equality comparison into an assignment
external/svox/pico/lib/picopr.c:2088:69: warning: equality comparison with extraneous parentheses [-Wparentheses-equality]
if ((pr->ritems[with__0->ritemid+1]->head.info1 == PICODATA_ITEMINFO1_TOKTYPE_SPACE)) {
external/svox/pico/lib/picopr.c:2088:69: note: remove extraneous parentheses around the comparison to silence this warning
external/svox/pico/lib/picopr.c:2088:69: note: use ‘=’ to turn this equality comparison into an assignment
external/svox/pico/lib/picopr.c:2262:61: warning: unused parameter ‘this’ [-Wunused-parameter]
static picoos_bool pr_getNextToken (picodata_ProcessingUnit this, pr_subobj_t * pr)
external/svox/pico/lib/picopr.c:2287:60: warning: unused parameter ‘this’ [-Wunused-parameter]
static picoos_bool pr_getAltToken (picodata_ProcessingUnit this, pr_subobj_t * pr)
external/svox/pico/lib/picopr.c:2326:63: warning: unused parameter ‘this’ [-Wunused-parameter]
static picoos_bool pr_findProduction (picodata_ProcessingUnit this, pr_subobj_t * pr,
external/svox/pico/lib/picopr.c:2404:65: warning: unused parameter ‘this’ [-Wunused-parameter]
static picoos_bool pr_getProdContToken (picodata_ProcessingUnit this, pr_subobj_t * pr)
external/svox/pico/lib/picopr.c:2429:65: warning: unused parameter ‘this’ [-Wunused-parameter]
static picoos_bool pr_getTopLevelToken (picodata_ProcessingUnit this, pr_subobj_t * pr, picoos_bool firstprod)
external/svox/pico/lib/picopr.c:2457:57: warning: unused parameter ‘this’ [-Wunused-parameter]
static picoos_bool pr_getToken (picodata_ProcessingUnit this, pr_subobj_t * pr)
external/svox/pico/lib/picopr.c:2480:66: warning: unused parameter ‘this’ [-Wunused-parameter]
static picoos_bool pr_getNextMultiToken (picodata_ProcessingUnit this, pr_subobj_t * pr)
external/svox/pico/lib/picopr.c:2516:8: warning: explicitly assigning value of variable of type 'pr_subobj_t ’ (aka 'struct pr_subobj ') to itself [-Wself-assign]
pr = pr; /
external/svox/pico/lib/picopr.c:2517:11: warning: explicitly assigning value of variable of type ‘picokpr_TokSetNP’ (aka ‘unsigned int’) to itself [-Wself-assign]
npset = npset; /
external/svox/pico/lib/picopr.c:2518:11: warning: explicitly assigning value of variable of type ‘picokpr_TokSetWP’ (aka ‘unsigned int’) to itself [-Wself-assign]
wpset = wpset; /
external/svox/pico/lib/picopr.c:2503:66: warning: unused parameter ‘this’ [-Wunused-parameter]
static pr_MatchState pr_matchMultiToken (picodata_ProcessingUnit this, pr_subobj_t * pr,
external/svox/pico/lib/picopr.c:2523:67: warning: unused parameter ‘this’ [-Wunused-parameter]
static pr_MatchState pr_matchTokensSpace (picodata_ProcessingUnit this, pr_subobj_t * pr, picoos_int32 cmpres,
external/svox/pico/lib/picopr.c:2570:67: warning: unused parameter ‘this’ [-Wunused-parameter]
static pr_MatchState pr_matchTokensDigit (picodata_ProcessingUnit this, pr_subobj_t * pr, picoos_int32 cmpres,
external/svox/pico/lib/picopr.c:2619:65: warning: unused parameter ‘this’ [-Wunused-parameter]
static pr_MatchState pr_matchTokensSeq (picodata_ProcessingUnit this, pr_subobj_t * pr, picoos_int32 cmpres,
external/svox/pico/lib/picopr.c:2662:66: warning: unused parameter ‘this’ [-Wunused-parameter]
static pr_MatchState pr_matchTokensChar (picodata_ProcessingUnit this, pr_subobj_t * pr, picoos_int32 cmpres,
external/svox/pico/lib/picopr.c:2682:68: warning: unused parameter ‘this’ [-Wunused-parameter]
static pr_MatchState pr_matchTokensLetter (picodata_ProcessingUnit this, pr_subobj_t * pr, picoos_int32 cmpres,
external/svox/pico/lib/picopr.c:2767:11: warning: explicitly assigning value of variable of type ‘picokpr_TokSetNP’ (aka ‘unsigned int’) to itself [-Wself-assign]
npset = npset; /
external/svox/pico/lib/picopr.c:2768:11: warning: explicitly assigning value of variable of type ‘picokpr_TokSetWP’ (aka ‘unsigned int’) to itself [-Wself-assign]
wpset = wpset; /
external/svox/pico/lib/picopr.c:2764:67: warning: unused parameter ‘this’ [-Wunused-parameter]
static pr_MatchState pr_matchTokensBegin (picodata_ProcessingUnit this, pr_subobj_t * pr,
external/svox/pico/lib/picopr.c:2781:11: warning: explicitly assigning value of variable of type ‘picokpr_TokSetNP’ (aka ‘unsigned int’) to itself [-Wself-assign]
npset = npset; /
external/svox/pico/lib/picopr.c:2782:11: warning: explicitly assigning value of variable of type ‘picokpr_TokSetWP’ (aka ‘unsigned int’) to itself [-Wself-assign]
wpset = wpset; /
external/svox/pico/lib/picopr.c:2778:65: warning: unused parameter ‘this’ [-Wunused-parameter]
static pr_MatchState pr_matchTokensEnd (picodata_ProcessingUnit this, pr_subobj_t * pr,
external/svox/pico/lib/picopr.c:2904:32: warning: equality comparison with extraneous parentheses [-Wparentheses-equality]
if ((pr->ractpath.rlen == 0)) {
external/svox/pico/lib/picopr.c:2904:32: note: remove extraneous parentheses around the comparison to silence this warning
external/svox/pico/lib/picopr.c:2904:32: note: use ‘=’ to turn this equality comparison into an assignment
external/svox/pico/lib/picopr.c:3038:53: warning: unused parameter ‘this’ [-Wunused-parameter]
static void pr_prepareItem (picodata_ProcessingUnit this, pr_subobj_t * pr, pr_ioItemPtr item)
external/svox/pico/lib/picopr.c:3258:60: warning: unused parameter ‘this’ [-Wunused-parameter]
pico_status_t prTerminate(register picodata_ProcessingUnit this)
external/svox/pico/lib/picopr.c:3272:12: warning: explicitly assigning value of variable of type ‘picoos_MemoryManager’ (aka 'struct memory_manager ') to itself [-Wself-assign]
mm = mm; /
external/svox/pico/lib/picopr.c:3354:10: warning: explicitly assigning value of variable of type ‘picoos_int16’ (aka ‘short’) to itself [-Wself-assign]
35 warnings generated.
[ 5% 4197/83051] target thumb C: libsvoxpico_32 <= external/svox/pico/lib/picotok.c
external/svox/pico/lib/picotok.c:444:26: warning: equality comparison with extraneous parentheses [-Wparentheses-equality]
if ((tok->utfpos == tok->utflen)) {
external/svox/pico/lib/picotok.c:444:26: note: remove extraneous parentheses around the comparison to silence this warning
external/svox/pico/lib/picotok.c:444:26: note: use ‘=’ to turn this equality comparison into an assignment
external/svox/pico/lib/picotok.c:482:50: warning: unused parameter ‘this’ [-Wunused-parameter]
static void tok_putItem (picodata_ProcessingUnit this, tok_subobj_t * tok,
external/svox/pico/lib/picotok.c:577:51: warning: unused parameter ‘this’ [-Wunused-parameter]
static void tok_putItem2 (picodata_ProcessingUnit this, tok_subobj_t * tok,
external/svox/pico/lib/picotok.c:1342:49: warning: equality comparison with extraneous parentheses [-Wparentheses-equality]
} else if ((tok->utf[tok->utfpos-1] == EOL)) {
external/svox/pico/lib/picotok.c:1342:49: note: remove extraneous parentheses around the comparison to silence this warning
external/svox/pico/lib/picotok.c:1342:49: note: use ‘=’ to turn this equality comparison into an assignment
external/svox/pico/lib/picotok.c:1402:83: warning: unused parameter ‘resetMode’ [-Wunused-parameter]
static pico_status_t tokReset(register picodata_ProcessingUnit this, picoos_int32 resetMode)
external/svox/pico/lib/picotok.c:1481:68: warning: unused parameter ‘this’ [-Wunused-parameter]
static pico_status_t tokTerminate(register picodata_ProcessingUnit this)
external/svox/pico/lib/picotok.c:1495:8: warning: explicitly assigning value of variable of type ‘picoos_MemoryManager’ (aka 'struct memory_manager ') to itself [-Wself-assign]
mm = mm; /
external/svox/pico/lib/picotok.c:1542:10: warning: explicitly assigning value of variable of type ‘picoos_int16’ (aka ‘short’) to itself [-Wself-assign]
mode = mode; /* avoid warning “var not used in this function”*/
[ 5% 4219/83051] target C: abc <= external/abc/abc.c
In file included from external/abc/abc.c:17:
external/abc/config.h:71:9: warning: ‘LOG_TAG’ macro redefined [-Wmacro-redefined]
#define LOG_TAG “abc”
system/core/liblog/include/log/log.h:51:9: note: previous definition is here
#define LOG_TAG NULL
external/abc/abc.c:32:31: warning: unused parameter ‘arg’ [-Wunused-parameter]
static void *abc_upload(void *arg)
external/abc/abc.c:156:32: warning: unused parameter ‘arg’ [-Wunused-parameter]
static void *abc_android(void *arg)
external/abc/abc.c:178:32: warning: unused parameter ‘arg’ [-Wunused-parameter]
static void *abc_process(void *arg)
external/abc/abc.c:200:31: warning: unused parameter ‘arg’ [-Wunused-parameter]
static void *abc_kernel(void *arg)
external/abc/abc.c:255:39: warning: unused parameter ‘arg’ [-Wunused-parameter]
static void *abc_monitor_uevent(void *arg)
external/abc/abc.c:262:42: warning: unused parameter ‘arg’ [-Wunused-parameter]
static void *abc_copy_log_to_flash(void *arg)
external/abc/abc.c:271:14: warning: unused parameter ‘argc’ [-Wunused-parameter]
int main(int argc, char *argv)
external/abc/abc.c:271:26: warning: unused parameter ‘argv’ [-Wunused-parameter]
int main(int argc, char argv[])
9 warnings generated.
[ 5% 4222/83051] target C: abc <= external/abc/mail.c
In file included from external/abc/mail.c:17:
[ 5% 4227/83051] target C: abc <= external/abc/misc.c
In file included from external/abc/misc.c:16:
external/abc/misc.c:363:25: warning: more ‘%’ conversions than data arguments [-Wformat]
printf(“error: %s not found,return\n,path”);
external/abc/misc.c:19:16: note: expanded from macro ‘printf’
#define printf ALOGD
system/core/liblog/include/log/log_main.h:201:52: note: expanded from macro ‘ALOGD’
#define ALOGD(…) ((void)ALOG(LOG_DEBUG, LOG_TAG, VA_ARGS))
system/core/liblog/include/log/log_main.h:306:67: note: expanded from macro ‘ALOG’
#define ALOG(priority, tag, …) LOG_PRI(ANDROID_##priority, tag, VA_ARGS)
system/core/liblog/include/log/log_main.h:70:69: note: expanded from macro ‘LOG_PRI’
#define LOG_PRI(priority, tag, …) android_printLog(priority, tag, VA_ARGS)
system/core/liblog/include/log/log_main.h:61:34: note: expanded from macro ‘android_printLog’
__android_log_print(prio, tag, VA_ARGS)
external/abc/misc.c:368:16: warning: passing 'const char ’ to parameter of type 'char ’ discards qualifiers [-Wincompatible-pointer-types-discards-qualifiers]
strcat(path,“/rk_logs/”);//for 3399 7.1 the sdcard mountpoint is similar to “/storage/8527-18E3/rk_logs” , 8527-18E3 is the uuid
bionic/libc/include/string.h:199:46: note: passing argument to parameter ‘dst’ here
char
strcat(char
_Nonnull __restrict const dst __pass_object_size, const char
_Nonnull __restrict src)
[ 5% 4228/83051] target C: abc <= external/abc/hotplug.c
In file included from external/abc/hotplug.c:11:
[ 5% 4372/83051] target C++: libapplypatch <= bootable/recovery/applypatch/../rktools.cpp
bootable/recovery/applypatch/../rktools.cpp:155:27: warning: unused parameter ‘arg’ [-Wunused-parameter]
void *thrd_led_func(void *arg) {
bootable/recovery/applypatch/../rktools.cpp:323:80: warning: unused parameter ‘c’ [-Wunused-parameter]
void SplitString(const std::string& s, std::string& result, const std::string& c){
[ 5% 4404/83051] Lex: applypatch <= bootable/recovery/edify/lexer.ll
FAILED: out/target/product/rk3399pro_firefly_aiojd4/obj/STATIC_LIBRARIES/libedify_intermediates/lexer.cpp
/bin/bash -c “prebuilts/misc/linux-x86/flex/flex-2.5.39 -oout/target/product/rk3399pro_firefly_aiojd4/obj/STATIC_LIBRARIES/libedify_intermediates/lexer.cpp bootable/recovery/edify/lexer.ll”
flex-2.5.39: loadlocale.c:130: _nl_intern_locale_data: Assertion `cnt < (sizeof (_nl_value_type_LC_TIME) / sizeof (_nl_value_type_LC_TIME[0]))’ failed.
Aborted (core dumped)
[ 5% 4411/83051] target arm C++: libaudioprocessing_32 <= frameworks/av/media/libaudioprocessing/AudioMixer.cpp
ninja: build stopped: subcommand failed.
15:04:06 ninja failed with: exit status 1
#### failed to build some targets (04:53 (mm:ss)) ####
一般都是环境的问题,建议使用14.04或16.04,或是参考如下链接
http://dev.t-firefly.com/thread-100560-1-1.html
帮我看下编译的ubuntu哪里出问题了
http://dev.t-firefly.com/thread-100601-1-1.html
m4 libxml2-utils
m4 libxml2-utils
