/home/xust/linux/repo/linux-sdk/buildroot/output/rockchip_rk3399_recovery/Makefile:16: recipe for target ‘_all’ failed
make: *** [_all] Error 2
====Build recovery failed!====
you take 2:54.21 to build recovery
fakeroot: preload library `libfakeroot.so’ not found, aborting.
fs/cpio/cpio.mk:43: recipe for target ‘/home/xust/linux/repo/linux-sdk/buildroot/output/rockchip_rk3399/images/rootfs.cpio’ failed
make[1]: *** [/home/xust/linux/repo/linux-sdk/buildroot/output/rockchip_rk3399/images/rootfs.cpio] Error 1
/home/xust/linux/repo/linux-sdk/buildroot/output/rockchip_rk3399/Makefile:16: recipe for target ‘_all’ failed
you take 0:17.35 to build builroot
====Build buildroot failed!====
请问有按照官方wiki进行操作吗?代码是否更新?recovery是可以正常编译的。不过这个revocery是可以忽略的,一般我们不用到它。
fs/cpio/cpio.mk:43: recipe for targ …
您好,请文您的源码是按照官方wiki指导下载的么?我使用windows10没有下载下来。
是的,百度网盘下载
解决了吗
