rk3399的linux ubuntu移植失败
[ 8.264864] input: rockchip_headset as /devices/platform/rockchip_headset/input/input4
[ 8.274870] vcc_sd: disabling
[ 8.278275] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘’, rk_ko_ver is ‘5’, built at ‘22:35:25’, on ‘Nov 20 2019’.
[ 8.299422] Mali: Mali device driver loaded
[ 8.304121] usb 5-1: New USB device found, idVendor=0424, idProduct=2517
[ 8.310846] usb 5-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 8.311089] rkisp1 ff910000.rkisp1: clear unready subdev num: 1
[ 8.312209] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 8.312212] rockchip-mipi-dphy-rx: No link between dphy and sensor
[ 8.312214] rkisp1: update sensor failed
[ 8.312222] rkisp1 ff920000.rkisp1: clear unready subdev num: 1
[ 8.312874] rkisp1: update sensor failed
[ 8.324357] ALSA device list:
[ 8.324361] #0: rockchip,rt5640-codec
[ 8.341191] callback: 1576118251, 372926
[ 8.362081] hub 5-1:1.0: USB hub found
[ 8.366079] hub 5-1:1.0: 7 ports detected
[ 8.375475] EXT4-fs (mmcblk1p8): mounted filesystem with ordered data mode. Opts: (null)
[ 8.383689] VFS: Mounted root (ext4 filesystem) on device 179:8.
[ 8.392706] devtmpfs: mounted
[ 8.396413] Freeing unused kernel memory: 1088K
[ 8.415298] mmc_host mmc2: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0)
[ 8.432677] request_module: runaway loop modprobe binfmt-464c
[ 8.444195] Starting init: /sbin/init exists but couldn’t execute it (error -8)
[ 8.453929] Starting init: /etc/init exists but couldn’t execute it (error -13)
[ 8.475082] request_module: runaway loop modprobe binfmt-464c
[ 8.487618] Starting init: /bin/sh exists but couldn’t execute it (error -8)
[ 8.494754] Kernel panic - not syncing: No working init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidance.
[ 8.507877] CPU: 2 PID: 1 Comm: swapper/0 Tainted: G W 4.4.189 #93
[ 8.515184] Hardware name: Rockchip RK3399 Excavator Board (Linux Opensource) (DT)
这个大概什么问题?
我也出现一样的问题
您好 你解决了吗
