RK3288烧写固件后没法启动,一直显示I2C有问题
RK3288烧录的是官方固件,开机log里,kernel启动之前显示 I2C Send Start Bit Timeout。kernel启动后显示 i2c is not in idle
请问是哪儿有问题啊。
DDR Version 1.00 20160530
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-10 (May 30 2018 - 16:38:11)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 400
SdmmcInit = 2 0
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
No pmic detect.
can’t find dts node for pwm1
set pwm voltage ok,pwm_id =1 vol=1100000,pwm_value=63
#Boot ver: 2018-05-30#2.30
empty serial no.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
pll_src = 0, dclk_hz = 65000000, dclk_div = 6
no fuel gauge found
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x02000000 (0x006a93c8)
ramdisk @ 0x05bf0000 (0x001464d8)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0561c208 … OK
[ 0.000000] Linux version 3.10.0 (sujl@tchipserver2) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #28 SMP PREEMPT Wed Jul 11 10:36:00 CST 2018
[ 0.000000] rockchip_uboot_logo_setup: mem: 0x02000000@0x7dc00000, offset:0x00000000
[ 0.000000] rockchip_uboot_mem_reserve: reserve 0x02000000@0x7dc00000 for uboot logo
[ 0.000000] ion heap(cma): base(0) size(1000000) align(0)
[ 0.000000] cma: CMA: reserved 16 MiB at 7cc00000
[ 0.000000] ion_reserve: cma reserved base 7cc00000 size 16777216
[ 0.000000] cma: CMA: reserved 16 MiB at 1f000000
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1f1e000 s13376 r8192 d15296 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523264
[ 0.000000] Kernel command line: vmalloc=496M console=ttyS2 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 root=/dev/block/mtd/by-name/linuxroot rw rootfstype=ext4 init=/sbin/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00002000@0x0039A000(baseparamer),-@0x003BC000(userdata) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2018-05-30_16:38:11
[ 0.000000] allocated 4194304 bytes of page_cgroup
[ 0.000000] Memory: 1993656k/1993656k available, 103496k reserved, 1523712K highmem
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0bb3b78 (11951 kB)
[ 0.000000] .init : 0xc0bb4000 - 0xc0c0d440 ( 358 kB)
[ 0.000000] .data : 0xc0c0e000 - 0xc0da0680 (1610 kB)
[ 0.000000] .bss : 0xc0da0680 - 0xc0ec3c3c (1166 kB)
[ 0.000000] rk_clk_tree_init start!
[ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div
[ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error
[ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1
[ 0.000000] rkclk_init_clks: cnt_rate = 29
[ 0.000000] rk3288 set GPLL BW 20 for HDMI!
[ 0.000000] process version: 1
[ 0.000000] channel:0, lkg:41
[ 0.000000] target-temp:80
[ 0.000000] channel:2, lkg:0
[ 0.000000] channel:1, lkg:29
[ 0.495872] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.495888] pid_max: default: 32768 minimum: 301
[ 0.496005] Security Framework initialized
[ 0.496022] SELinux: Initializing.
[ 0.496095] Mount-cache hash table entries: 512
[ 0.496735] Initializing cgroup subsys debug
[ 0.496749] Initializing cgroup subsys memory
[ 0.496776] Initializing cgroup subsys freezer
[ 0.496803] CPU: Testing write buffer coherency: ok
[ 0.497119] /cpus/cpu@0 missing clock-frequency property
[ 0.497133] /cpus/cpu@1 missing clock-frequency property
[ 0.497142] /cpus/cpu@2 missing clock-frequency property
[ 0.497152] /cpus/cpu@3 missing clock-frequency property
[ 0.497203] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.497253] Setting up static identity map for 0xc0863668 - 0xc08636c0
[ 0.499712] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x17e0 (version 3.1)
[ 0.574037] CPU1: Booted secondary processor
[ 0.574069] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.593705] CPU2: Booted secondary processor
[ 0.593730] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.613415] CPU3: Booted secondary processor
[ 0.613438] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.613539] Brought up 4 CPUs
[ 0.613567] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.613576] CPU: All CPU(s) started in SVC mode.
[ 0.614314] devtmpfs: initialized
[ 0.618743] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.619843] pinctrl core: initialized pinctrl subsystem
[ 0.620093] regulator-dummy: no parameters
[ 0.634164] NET: Registered protocol family 16
[ 0.635994] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.636309] ion_snapshot: 0x1e9b8000 map to 0xe0907000 and copy to 0xc0e9eecc (version 0.1)
[ 0.636543] Registered FIQ tty driver
[ 0.636937] fiq-debugger is disabled in device tree
[ 0.637666] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[ 0.637687] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[ 0.637705] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 0.637722] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[ 0.637814] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 0.637881] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 0.637942] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 0.638005] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 0.638067] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 0.638136] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[ 0.638200] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 0.638262] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[ 0.638329] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 0.638393] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 0.638406] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 0.638418] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 0.638429] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 0.639050] rockchip_interrupts_register:bank_num=7
[ 0.640944] of_get_gpio_init_config:gpio[0] = 136, value = 0
[ 0.640965] of_get_gpio_init_config:gpio[1] = 13, value = 1
[ 0.641030] rockchip_pinctrl_probe:init ok
[ 0.648139] rk_iommu ff900800.iep_mmu: (iep) Enter
[ 0.648227] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.648240] rk_iommu ff900800.iep_mmu: (iep) Initialized
[ 0.648406] rk_iommu ff950800.vip_mmu: (vip) Enter
[ 0.648476] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.648489] rk_iommu ff950800.vip_mmu: (vip) Initialized
[ 0.648653] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[ 0.648726] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.648739] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[ 0.648901] rk_iommu ff940300.vopl_mmu: (vopl) Enter
[ 0.648971] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.648983] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[ 0.649151] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[ 0.649236] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.649248] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[ 0.649420] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[ 0.649494] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.649506] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[ 0.649677] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[ 0.649759] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.649771] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
[ 0.651450] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.651463] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.652037] rk3368_init_rockchip_pmu_ops: could not find pmu dt node
[ 0.652061] DDR DEBUG: version 1.00 20150126
[ 0.652089] DDR DEBUG: Channel a:
[ 0.652097] DDR DEBUG: DDR3 Device
[ 0.652111] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.652119] DDR DEBUG: Channel b:
[ 0.652126] DDR DEBUG: DDR3 Device
[ 0.652138] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.652147] DDR DEBUG: addr=0xdaa000
[ 0.652157] DDR DEBUG: stride=9, size=256, halfcap=40000000
[ 0.652165] DDR DEBUG: socAddr[0]=0xdaa000, socAddr[1]=0xdaa100
[ 0.652175] DDR DEBUG: chAddr[0]=0xdaa000, chAddr[1]=0xdaa000
[ 0.652186] DDR DEBUG: dtar[0]=0x201b5000, dtar[1]=0x201b5000
[ 0.652239] DDR DEBUG: init success!!! freq=200MHz
[ 0.652246] DDR DEBUG: Channel a:
[ 0.652259] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.652271] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.652284] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.652296] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.652308] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.652317] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.652325] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.652333] DDR DEBUG: Channel b:
[ 0.652344] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.652356] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.652368] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.652381] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.652392] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.652400] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.652409] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.677275] bio: create slab at 0
[ 0.677771] Rockchip hdmi driver version 2.0
[ 0.677771] .
[ 0.678930] SCSI subsystem initialized
[ 0.679089] usbcore: registered new interface driver usbfs
[ 0.679141] usbcore: registered new interface driver hub
[ 0.679228] usbcore: registered new device driver usb
[ 0.681494] host_en_gpio= -2
[ 0.683948] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 0.684586] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
[ 0.685032] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
[ 0.685281] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 0.685885] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 0.686010] media: Linux media interface: v0.10
[ 0.686050] Linux video capture interface: v2.00
[ 0.686106] pps_core: LinuxPPS API ver. 1 registered
[ 0.686116] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.686139] PTP clock support registered
[ 0.686198] i2c-core: driver [bq24296] using legacy suspend method
[ 0.686207] i2c-core: driver [bq24296] using legacy resume method
[ 0.686531] RK29 Watchdog Timer, (c) 2011 Rockchip Electronics
[ 0.687011] ion_drm_heap_create: 0@0
[ 0.687136] Rockchip ion module is successfully loaded (v1.1)
[ 0.687293] Advanced Linux Sound Architecture Driver Initialized.
[ 0.687701] Bluetooth: Core ver 2.16
[ 0.687759] NET: Registered protocol family 31
[ 0.687769] Bluetooth: HCI device and connection manager initialized
[ 0.687785] Bluetooth: HCI socket layer initialized
[ 0.687798] Bluetooth: L2CAP socket layer initialized
[ 0.687823] Bluetooth: SCO socket layer initialized
[ 0.688053] cfg80211: Calling CRDA to update world regulatory domain
[ 0.688761] act8846_i2c_probe,line=898
[ 0.977398] rockchip_i2c ff650000.i2c: Addr[0x005a] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x0
[ 0.979382] rockchip_i2c ff650000.i2c: I2C_CON: start bit is set
[ 1.174277] rockchip_i2c ff650000.i2c: i2c is not in idle(state = 2)
[ 1.174289] act8846 set 0xf4 error!
[ 1.174373] act8846: probe of 0-005a failed with error -5
[ 1.371173] rockchip_i2c ff650000.i2c: Addr[0x0040] wait event timeout, state: 2, is_busy: 1, error: 0, complete_what: 0x2, ipd: 0x20
[ 1.374140] The device is not syr82x ffffff92
[ 1.374156] syr82x: probe of 0-0040 failed with error -110
[ 1.587744] rockchip_i2c ff650000.i2c: Addr[0x0041] wait event timeout, state: 2, is_busy: 1, error: 0, complete_what: 0x2, ipd: 0x20
[ 1.590710] The device is not syr82x ffffff92
[ 1.590726] syr82x: probe of 0-0041 failed with error -110
[ 1.591189] rk808_i2c_probe,line=1355
[ 1.784636] rockchip_i2c ff650000.i2c: i2c is not in idle(state = 2)
[ 1.784649] The device is not rk808 -5
[ 1.784714] rk808: probe of 0-001b failed with error -5
[ 1.784792] i2c-core: driver [rk818] using legacy suspend method
[ 1.784802] i2c-core: driver [rk818] using legacy resume method
[ 1.786582] Switching to clocksource arch_sys_counter
[ 1.810546] rga: Module initialized.
[ 1.811255] rga2 ff920000.rga: rga ion client create success!
[ 1.811424] rga: Driver loaded succesfully
[ 1.811627] fb disp policy is box
[ 1.811670] rk-fb rockchip-fb: rk fb ion client create success!
[ 1.811683] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 1.811979] rk-screen rk_screen.8: rockchip screen probe success
[ 1.812235] rk32-lvds rk32-lvds: rk32 lvds driver probe success
[ 1.812608] rk32-edp ff970000.edp: screen is not edp!
[ 1.812629] rk32-edp: probe of ff970000.edp failed with error -22
[ 1.813138] pwr_ctr_name:lcd_en
[ 1.813138] pwr_type:gpio
[ 1.813138] gpio:227
[ 1.813138] atv_val:1
[ 1.813138] delay:10
[ 1.813138]
[ 1.813375] graphics fb0: rockchip framebuffer registerd:fb0
[ 1.813669] graphics fb1: rockchip framebuffer registerd:fb1
[ 1.813837] graphics fb2: rockchip framebuffer registerd:fb2
[ 1.813995] graphics fb3: rockchip framebuffer registerd:fb3
[ 1.814702] rk3288-lcdc lcdc0: lcdc0: dclk:65000000>>fps:58
[ 1.814717] rk3288-lcdc lcdc0: wakeup from standby!
[ 1.830327] alloc_buffer:ion_phy_addr=0x10000000
[ 1.836710] fb0:phy:10000000>>vir:e0991000>>len:0xc00000
[ 1.851754] rk_iommu ff930300.vopb_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eaa6000
[ 1.851796] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
[ 1.852018] rk3288-lcdc lcdc1: can’t find power_ctr node for lcdc1
[ 1.852031] rk_fb_trsm_ops_get:un supported transmitter:0!
[ 1.852288] graphics fb4: rockchip framebuffer registerd:fb4
[ 1.852611] graphics fb5: rockchip framebuffer registerd:fb5
[ 1.852775] graphics fb6: rockchip framebuffer registerd:fb6
[ 1.852936] graphics fb7: rockchip framebuffer registerd:fb7
[ 1.853763] unknow screen type: 0
[ 1.853844] rk3288-lcdc lcdc1: lcdc1: dclk:65000000>>fps:649
[ 1.853857] rk3288-lcdc lcdc1: wakeup from standby!
[ 1.855774] fb4:phy:10000000>>vir:e0991000>>len:0xc00000
[ 1.855788] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu enabled
[ 1.856673] rockchip_set_mux:warning ignore bank num 15
[ 1.856798] rockchip_set_mux:warning ignore bank num 15
[ 1.856914] rockchip_set_mux:warning ignore bank num 15
[ 1.857037] rockchip_set_mux:warning ignore bank num 15
[ 1.857148] rockchip_set_mux:warning ignore bank num 15
[ 1.857264] rockchip_set_mux:warning ignore bank num 15
[ 1.857380] rockchip_set_mux:warning ignore bank num 15
[ 1.857502] rockchip_set_mux:warning ignore bank num 15
[ 1.857637] rockchip_set_mux:warning ignore bank num 15
[ 1.857761] rockchip_set_mux:warning ignore bank num 15
[ 1.858842] tc358749_hdmiin_probe!
[ 1.918099] tc358749_hdmiin_probe OK!
[ 1.918566] NET: Registered protocol family 2
[ 1.919241] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 1.919331] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 1.919405] TCP: Hash tables configured (established 4096 bind 4096)
[ 1.919462] TCP: reno registered
[ 1.919478] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 1.919502] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 1.919692] NET: Registered protocol family 1
[ 1.920322] Unpacking initramfs…
[ 1.991338] Freeing initrd memory: 1304K (c5bf0000 - c5d36000)
[ 1.992141] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 1.992720] vcodec_service: probe device ff9a0000.vpu_service
[ 1.992951] vcodec_service: No reset resource define
[ 1.993161] vcodec_service: ff9a0000.vpu_service: power on
[ 1.993249] vcodec_service: probe device ff9a0000.vpu_service
[ 1.993317] vcodec_service: checking hw id 4831
[ 1.994297] vcodec_service: ff9a0000.vpu_service: power off…
[ 1.994340] vcodec_service: done
[ 1.994348] vcodec_service: init success
[ 1.994414] vcodec_service: probe device ff9c0000.hevc_service
[ 1.994766] vcodec_service: ff9c0000.hevc_service: power on
[ 1.994827] vcodec_service: probe device ff9c0000.hevc_service
[ 1.994843] vcodec_service: checking hw id 6867
[ 1.995404] vcodec_service: ff9c0000.hevc_service: power off…
[ 1.995444] vcodec_service: done
[ 1.995453] vcodec_service: init success
[ 1.995587] rknandbase v1.0 2014-03-31
[ 1.995723] rknand: probe of ff400000.nandc failed with error -1
[ 1.995846] rknand_driver:ret = 0
[ 1.997823] audit: initializing netlink socket (disabled)
[ 1.997869] type=2000 audit(1.520:1): initialized
[ 1.998701] bounce pool size: 64 pages
[ 2.003488] fuse init (API version 7.22)
[ 2.003875] msgmni has been set to 952
[ 2.005687] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 2.005701] io scheduler noop registered
[ 2.005711] io scheduler deadline registered
[ 2.005802] io scheduler cfq registered (default)
[ 2.007369] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess.
[ 2.008058] IEP Power ON
[ 2.008102] iep ion client create success!
[ 2.008534] rk_iommu ff900800.iep_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eaa1000
[ 2.008543] IEP Power OFF
[ 2.008560] IEP Driver loaded succesfully
[ 2.008655] Module initialized.
[ 2.009508] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 2.009525] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 2.010871] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 2.010888] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 2.011193] pwm-voltage-regulator pwm_regulator.23: unable to request PWM, trying legacy API
[ 2.011207] pwm-voltage-regulator pwm_regulator.23: unable to request legacy PWM
[ 2.011217] pwm_regulator_probe:error
[ 2.011237] platform pwm_regulator.23: Driver pwm-voltage-regulator requests probe deferral
[ 2.011437] rk_serial.c v1.8 2014-03-04
[ 2.011668] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[ 2.011856] serial ff180000.serial: membase e097e000
[ 2.012028] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1
[ 2.012219] serial ff190000.serial: membase e359c000
[ 2.012359] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
[ 2.014038] console [ttyS2] enabled
[ 2.014272] serial ff690000.serial: membase fed60000
[ 2.014450] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90) is a rk29_serial.3
[ 2.014638] serial ff1b0000.serial: membase e359e000
[ 2.017529] loop: module loaded
[ 2.017900] zram: Created 1 device(s) …
[ 2.017992] i2c-core: driver [mpu6050B1] using legacy suspend method
[ 2.018004] i2c-core: driver [mpu6050B1] using legacy resume method
[ 2.018022] mpu_init: Probe name mpu6050B1
[ 2.018182] ak8963_mod_init: Probe name ak8963_mod
[ 2.018902] SCSI Media Changer driver v0.25
[ 2.019198] dws->regs: e35be000
[ 2.020482] rockchip_spi_probe:num_cs=2,bus_num=0,irq=76,freq=45692308 ok
[ 2.020779] tun: Universal TUN/TAP device driver, 1.6
[ 2.020792] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.020923] vmac_init.
[ 2.021516] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 2.021532] stmmac_probe_config_dt: clock input/output? (input).
[ 2.021559] stmmac_probe_config_dt: TX delay(0x23).
[ 2.021570] stmmac_probe_config_dt: RX delay(0x19).
[ 2.021620] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[ 2.021631] stmmc_pltfr_init:
[ 2.021641] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[ 2.021663] gmac_phy_reset: ERROR: Request pin stmmc_pltfr_init failed.
[ 2.021675] stmmc_pltfr_init: init for RGMII
[ 2.021686] tx delay=0x23
[ 2.021686] rx delay=0x19
[ 2.021701] tx delay=0x23
[ 2.021701] rx delay=0x19
[ 2.022156] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 2.022167] Normal descriptors
[ 2.022176] Ring mode enabled
[ 2.022186] DMA HW capability register supported
[ 2.022198] RX Checksum Offload Engine supported (type 2)
[ 2.022209] TX Checksum insertion supported
[ 2.022218] Wake-Up On Lan supported
[ 2.022256] Enable RX Mitigation via HW Watchdog Timer
[ 2.022708] PPP generic driver version 2.4.2
[ 2.022883] PPP BSD Compression module registered
[ 2.022895] PPP Deflate Compression module registered
[ 2.022920] PPP MPPE Compression module registered
[ 2.022933] NET: Registered protocol family 24
[ 2.022976] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 2.022990] CSLIP: code copyright 1989 Regents of the University of California.
[ 2.023003] Rockchip WiFi SYS interface (V1.00) …
[ 2.023038] esp_mem_init enter date May 30 2018 16:39:38
[ 2.023049] esp_mem_init VERSION [V2.5]
[ 2.023110] esp_mem_init complete
[ 2.023197] usbcore: registered new interface driver catc
[ 2.023240] usbcore: registered new interface driver kaweth
[ 2.023254] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 2.023301] usbcore: registered new interface driver pegasus
[ 2.023343] usbcore: registered new interface driver rtl8150
[ 2.023387] usbcore: registered new interface driver r8152
[ 2.023399] hso: drivers/net/usb/hso.c: Option Wireless
[ 2.023466] usbcore: registered new interface driver hso
[ 2.023513] usbcore: registered new interface driver asix
[ 2.023554] usbcore: registered new interface driver ax88179_178a
[ 2.023601] usbcore: registered new interface driver cdc_ether
[ 2.023642] usbcore: registered new interface driver cdc_eem
[ 2.023681] usbcore: registered new interface driver dm9601
[ 2.023719] usbcore: registered new interface driver dm9620
[ 2.023769] usbcore: registered new interface driver smsc75xx
[ 2.023818] usbcore: registered new interface driver smsc95xx
[ 2.023867] usbcore: registered new interface driver gl620a
[ 2.023907] usbcore: registered new interface driver net1080
[ 2.023948] usbcore: registered new interface driver plusb
[ 2.023990] usbcore: registered new interface driver rndis_host
[ 2.024031] usbcore: registered new interface driver cdc_subset
[ 2.024070] usbcore: registered new interface driver zaurus
[ 2.024113] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 2.024178] usbcore: registered new interface driver int51x1
[ 2.024224] usbcore: registered new interface driver kalmia
[ 2.024266] usbcore: registered new interface driver ipheth
[ 2.024311] usbcore: registered new interface driver sierra_net
[ 2.024354] usbcore: registered new interface driver cx82310_eth
[ 2.024403] usbcore: registered new interface driver cdc_ncm
[ 2.024455] usbcore: registered new interface driver qmi_wwan
[ 2.024511] usbcore: registered new interface driver cdc_mbim
[ 2.024525] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 2.027001] EHCI: ehci_rk_probe e3640000 e3640010
[ 2.027020] rockchip_ehci_host ff500000.usb: EHCI Host Controller
[ 2.027056] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[ 2.027378] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
[ 2.042501] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00
[ 2.042584] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.042601] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.042616] usb usb1: Product: EHCI Host Controller
[ 2.042629] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 2.042642] usb usb1: SerialNumber: ff500000.usb
[ 2.043116] hub 1-0:1.0: USB hub found
[ 2.043142] hub 1-0:1.0: 1 port detected
[ 2.043303] EHCI: ehci_rk_probe ok
[ 2.043409] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 2.043716] usbcore: registered new interface driver cdc_acm
[ 2.043729] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.043784] usbcore: registered new interface driver usblp
[ 2.043826] usbcore: registered new interface driver cdc_wdm
[ 2.043887] usbcore: registered new interface driver usb-storage
[ 2.043935] usbcore: registered new interface driver ums-alauda
[ 2.043975] usbcore: registered new interface driver ums-cypress
[ 2.044014] usbcore: registered new interface driver ums-datafab
[ 2.044051] usbcore: registered new interface driver ums_eneub6250
[ 2.044089] usbcore: registered new interface driver ums-freecom
[ 2.044128] usbcore: registered new interface driver ums-isd200
[ 2.044167] usbcore: registered new interface driver ums-jumpshot
[ 2.044204] usbcore: registered new interface driver ums-karma
[ 2.044243] usbcore: registered new interface driver ums-onetouch
[ 2.044282] usbcore: registered new interface driver ums-sddr09
[ 2.044321] usbcore: registered new interface driver ums-sddr55
[ 2.044364] usbcore: registered new interface driver ums-usbat
[ 2.044452] usbcore: registered new interface driver usbserial
[ 2.044499] usbcore: registered new interface driver usbserial_generic
[ 2.044532] usbserial: USB Serial support registered for generic
[ 2.044573] usbcore: registered new interface driver ch341
[ 2.044604] usbserial: USB Serial support registered for ch341-uart
[ 2.044646] usbcore: registered new interface driver cp210x
[ 2.044675] usbserial: USB Serial support registered for cp210x
[ 2.044727] usbcore: registered new interface driver option
[ 2.044758] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.044831] usbcore: registered new interface driver pl2303
[ 2.044861] usbserial: USB Serial support registered for pl2303
[ 2.044908] usbcore: registered new interface driver trancevibrator
[ 2.044920] usb20_otg: version 3.10a 21-DEC-2012
[ 2.045359] e3680040
[ 2.045373] Core Release: 3.10a
[ 2.045384] Setting default values for core params
[ 2.045517] Using Buffer DMA mode
[ 2.045529] Periodic Transfer Interrupt Enhancement - disabled
[ 2.045540] Multiprocessor Interrupt Enhancement - disabled
[ 2.045552] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.045562] ^^^^^^^^^^^^^^^^^Device Mode
[ 2.045576] Dedicated Tx FIFOs mode
[ 2.045595] pcd_init otg_dev = debe3a40
[ 2.045749] usb20_otg ff580000.usb: DWC OTG Controller
[ 2.045784] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
[ 2.045816] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 2.045876] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.045894] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.045909] usb usb2: Product: DWC OTG Controller
[ 2.045922] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 2.045935] usb usb2: SerialNumber: ff580000.usb
[ 2.046338] hub 2-0:1.0: USB hub found
[ 2.046362] hub 2-0:1.0: 1 port detected
[ 2.052482] usb20_host: version 3.10a 21-DEC-2012
[ 2.055021] e3700040
[ 2.055035] Core Release: 3.10a
[ 2.055045] Setting default values for core params
[ 2.055160] Using Buffer DMA mode
[ 2.055172] Periodic Transfer Interrupt Enhancement - disabled
[ 2.055182] Multiprocessor Interrupt Enhancement - disabled
[ 2.055194] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.055204] ^^^^^^^^^^^^^^^^^^Host Mode
[ 2.055229] usb20_host ff540000.usb: DWC OTG Controller
[ 2.055257] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
[ 2.055288] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[ 2.055380] Init: Power Port (0)
[ 2.055434] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.055451] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.055465] usb usb3: Product: DWC OTG Controller
[ 2.055478] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 2.055491] usb usb3: SerialNumber: ff540000.usb
[ 2.055890] hub 3-0:1.0: USB hub found
[ 2.055913] hub 3-0:1.0: 1 port detected
[ 2.056633] usbcore: registered new interface driver xpad
[ 2.056694] usbcore: registered new interface driver usb_acecad
[ 2.056743] usbcore: registered new interface driver aiptek
[ 2.056789] usbcore: registered new interface driver gtco
[ 2.056836] usbcore: registered new interface driver hanwang
[ 2.056882] usbcore: registered new interface driver kbtab
[ 2.056935] usbcore: registered new interface driver wacom
[ 2.056945] ==gsl_ts_init==
[ 2.057038] GSLX680 Enter gsl_ts_probe
[ 2.144973] Using Buffer DMA mode
[ 2.144989] Periodic Transfer Interrupt Enhancement - disabled
[ 2.144999] Multiprocessor Interrupt Enhancement - disabled
[ 2.145011] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.145021] ^^^^^^^^^^^^^^^^^^Host Mode
[ 2.190148] Init: Power Port (0)
[ 2.190163] rk_battery_charger_detect_cb , battery_charger_detect 5
[ 2.593525] gsl_ts_probe–1318, i2c_master_recv fail
[ 2.593547] gslX680: probe of 4-0041 failed with error -11
[ 2.593592] ret=0
[ 2.593881] sensor_register_slave:mma8452,id=17
[ 2.593895] sensor_register_slave:gs_mc3230,id=23
[ 2.593905] gsensor_init
[ 2.593916] sensor_register_slave:mpu6880_acc,id=24
[ 2.593927] sensor_register_slave:mpu6500_acc,id=25
[ 2.593938] sensor_register_slave:cm3217,id=48
[ 2.593949] sensor_register_slave:cm3218,id=49
[ 2.594174] .. rk pwm remotectl v1.1 init
[ 2.594448] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
[ 2.790331] rockchip_i2c ff650000.i2c: i2c is not in idle(state = 2)
[ 2.987126] rockchip_i2c ff650000.i2c: i2c is not in idle(state = 2)
[ 3.183927] rockchip_i2c ff650000.i2c: i2c is not in idle(state = 2)
[ 3.380732] rockchip_i2c ff650000.i2c: i2c is not in idle(state = 2)
[ 3.577527] rockchip_i2c ff650000.i2c: i2c is not in idle(state = 2)
[ 3.951453] rockchip_i2c ff650000.i2c: Addr[0x0051] wait event timeout, state: 2, is_busy: 1, error: 0, complete_what: 0x2, ipd: 0x20
[ 4.020323] EHCI: rk_ehci_hcd_enable, disable host controller
[ 4.148251] rockchip_i2c ff650000.i2c: i2c is not in idle(state = 2)
[ 4.463140] rockchip_i2c ff650000.i2c: Addr[0x0051] wait event timeout, state: 2, is_busy: 1, error: 0, complete_what: 0x2, ipd: 0x20
[ 4.659927] rockchip_i2c ff650000.i2c: i2c is not in idle(state = 2)
[ 4.856727] rockchip_i2c ff650000.i2c: i2c is not in idle(state = 2)
[ 5.112572] rockchip_i2c ff650000.i2c: Addr[0x0051] wait event timeout, state: 2, is_busy: 1, error: 0, complete_what: 0x2, ipd: 0x20
[ 5.115745] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 5.447133] rockchip_i2c ff650000.i2c: Addr[0x0051] wait event timeout, state: 2, is_busy: 1, error: 0, complete_what: 0x2, ipd: 0x20
[ 5.702974] rockchip_i2c ff650000.i2c: Addr[0x0051] wait event timeout, state: 3, is_busy: 1, error: 0, complete_what: 0x2, ipd: 0x20
[ 5.706000] i2c /dev entries driver
[ 5.706705] IR NEC protocol handler initialized
[ 5.706718] IR RC5(x) protocol handler initialized
[ 5.706729] IR RC6 protocol handler initialized
[ 5.706739] IR JVC protocol handler initialized
[ 5.706759] IR Sony protocol handler initialized
[ 5.706770] IR RC5 (streamzap) protocol handler initialized
[ 5.706780] IR SANYO protocol handler initialized
[ 5.706790] IR MCE Keyboard/mouse protocol handler initialized
[ 5.706960] usbcore: registered new interface driver uvcvideo
[ 5.706973] USB Video Class driver (1.1.1)
[ 5.706987] CamSys driver version: v0.32.0, CamSys head file version: v0.11.0
[ 5.708497] D1:camsys_platform_probe(1300): 1-gpios-cifpower: gpio=236
[ 5.708521] D1:camsys_platform_probe(1303): gpios-cifpower: gpio_request
[ 5.708543] D1:camsys_platform_probe(1305): 1-gpios-cifpower: gpio_request=0
[ 5.708565] D1:camsys_platform_probe(1314): gpios-cifpower: 236 high
[ 5.708610] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288
[ 5.708610]
[ 5.708683] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 5.708850] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe35f8000 size: 0x4000)
[ 5.709525] D1:camsys_platform_probe(1446): ff910000.isp memory:
[ 5.709543] D1:camsys_platform_probe(1456): Register memory (phy: 0xff910000 vir: 0xe3620000 size: 0x10000)
[ 5.709560] D1:camsys_platform_probe(1451): I2c memory (phy: 0x1dfa4000 vir: 0xddfa4000 size: 0x1000)
[ 5.709575] D1:camsys_init_ext_fsh_module(20): init external flash module
[ 5.709587] D1:camsys_platform_probe(1471): Probe ff910000.isp device success
[ 5.710014] not find test_power_init dev node
[ 5.710076] i2c-core: driver [bq27320] using legacy suspend method
[ 5.710088] i2c-core: driver [bq27320] using legacy resume method
[ 5.710450] rockchip_temp_probe,line=364
[ 5.762010] tsadc ff280000.tsadc: initialized
[ 5.762408] device-mapper: uevent: version 1.0.3
[ 5.762650] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 5.762981] Bluetooth: HCI UART driver ver 2.2
[ 5.762998] Bluetooth: HCI H4 protocol initialized
[ 5.763010] Bluetooth: HCILL protocol initialized
[ 5.763022] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21
[ 5.763034] rtk_btusb: Register usb char device interface for BT driver
[ 5.763224] usbcore: registered new interface driver rtk_btusb
[ 5.763280] DVFS ERR: clk_enable_dvfs: vd(vd_logic) can’t get regulator(vdd_logic)!
[ 5.763306] DVFS ERR: clk_enable_dvfs: vd(vd_gpu) can’t get regulator(vdd_gpu)!
[ 5.763322] DVFS ERR: clk_enable_dvfs: vd(vd_logic) can’t get regulator(vdd_logic)!
[ 5.763340] DVFS ERR: clk_enable_dvfs: vd(vd_arm) can’t get regulator(vdd_arm)!
[ 5.763353] cpufreq version 1.0, suspend freq 1200 MHz
[ 5.763551] cpuidle: using governor ladder
[ 5.763565] cpuidle: using governor menu
[ 5.763599] Synopsys Designware Multimedia Card Interface Driver
[ 5.763611] MHSC version = Ver 2.00 2015-06-10
[ 5.763898] dw cru_regsbase addr 0x1d8.
[ 5.763910] dw cru_reset_offset val 3.
[ 5.763925] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[ 5.763967] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc
[ 5.764270] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
[ 5.764465] dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
[ 5.764595] 1358..dw_mci_set_ios: no card. [mmc0]
[ 5.781708] 1358..dw_mci_set_ios: no card. [mmc0]
[ 5.801410] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 5.801427] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
[ 5.801438] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[ 5.801736] dw cru_regsbase addr 0x1d8.
[ 5.801749] dw cru_reset_offset val 0.
[ 5.801765] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[ 5.801801] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc
[ 5.802583] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
[ 5.802742] dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
[ 5.802830] mmc1: no vmmc regulator found
[ 5.802959] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
[ 5.803048] 1358..dw_mci_set_ios: no card. [mmc1]
[ 5.821070] 1358..dw_mci_set_ios: no card. [mmc1]
[ 5.833557] mmc0: BKOPS_EN bit is not set
[ 5.835478] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0]
[ 5.837786] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 5.837814] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 5.837842] [mmc0] tuning regsbase addr 0x218.
[ 5.838862] [mmc0] Data transmission error !!! MINTSTS: [0x000000c6]
[ 5.838876] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 5.838920] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 5.838939] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 5.838956] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 5.838970] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 5.839025] mmc0: new HS200 MMC card at address 0001
[ 5.839391] mmcblk0: mmc0:0001 AJTD4R 14.5 GiB
[ 5.839552] mmcblk0rpmb: mmc0:0001 AJTD4R partition 3 4.00 MiB
[ 5.839940] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 5.839958] misc: 0x000800000 – 0x000c00000 (4 MB)
[ 5.839971] resource: 0x000c00000 – 0x001c00000 (16 MB)
[ 5.839984] kernel: 0x001c00000 – 0x002c00000 (16 MB)
[ 5.839997] boot: 0x002c00000 – 0x004c00000 (32 MB)
[ 5.840018] recovery: 0x004c00000 – 0x006c00000 (32 MB)
[ 5.840031] backup: 0x006c00000 – 0x00a000000 (52 MB)
[ 5.840044] cache: 0x00a000000 – 0x012000000 (128 MB)
[ 5.840057] kpanic: 0x012000000 – 0x012400000 (4 MB)
[ 5.840070] system: 0x012400000 – 0x072400000 (1536 MB)
[ 5.840083] metadata: 0x072400000 – 0x073400000 (16 MB)
[ 5.840109] baseparamer: 0x073400000 – 0x073800000 (4 MB)
[ 5.840123] userdata: 0x077800000 – 0x3a3a00000 (12994 MB)
[ 5.840166] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13[ 5.840803] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
[ 5.840824] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
[ 5.841250] dw cru_regsbase addr 0x1d8.
[ 5.841265] dw cru_reset_offset val 1.
[ 5.841280] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[ 5.841328] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc
[ 5.841655] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
[ 5.841825] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
[ 5.842185] 1358..dw_mci_set_ios: no card. [mmc2]
rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc1]
[ 5.860405] 1358..dw_mci_set_ios: no card. [mmc2]
[ 5.880128] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
[ 5.880147] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[ 5.880516] leds-gpio leds.28: pins are not configured from the driver
[ 5.880903] hidraw: raw HID events driver (C) Jiri Kosina
[ 5.883020] usbcore: registered new interface driver usbhid
[ 5.883035] usbhid: USB HID core driver
[ 5.883194] ashmem: initialized
[ 5.883353] logger: created 256K log ‘log_main’
[ 5.883485] logger: created 256K log ‘log_events’
[ 5.883627] logger: created 256K log ‘log_radio’
[ 5.883759] logger: created 256K log ‘log_system’
[ 5.885176] input: rk29-keypad as /devices/ff100000.adc/key.30/input/input1
[ 5.886285] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ff890000.rockchip-i2s; cannot claim for 2-0010
[ 5.886308] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
[ 5.886325] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl
[ 5.886342] ES8323 2-0010: Error applying setting, reverse things back
[ 5.886412] es8323_adc = 0
[ 5.886433] jp es8323_line_det_gpio:79
[ 5.948969] iep dpi mode inactivity
[ 6.076904] rockchip_i2c ff660000.i2c: i2c is not in idle(state = 3)
[ 6.076921] es8323 probe error
[ 6.076943] ES8323: probe of 2-0010 failed with error -5
[ 6.078026] rockchip-spdif ff880000.rockchip-spdif: spdif ready.
[ 6.078779] rockchip-es8323 rockchip-es8323.27: ASoC: CODEC (null) not registered
[ 6.078819] rockchip_es8323_audio_probe() register card failed:-517
[ 6.078842] platform rockchip-es8323.27: Driver rockchip-es8323 requests probe deferral
[ 6.079092] u32 classifier
[ 6.079105] Actions configured
[ 6.079121] Netfilter messages via NETLINK v0.30.
[ 6.079195] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 6.079664] ctnetlink v0.93: registering with nfnetlink.
[ 6.079753] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 6.079768] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 6.080161] xt_time: kernel timezone is -0000
[ 6.080466] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 6.080655] arp_tables: (C) 2002 David S. Miller
[ 6.080707] TCP: cubic registered
[ 6.080718] Initializing XFRM netlink socket
[ 6.081039] NET: Registered protocol family 10
[ 6.081788] mip6: Mobile IPv6
[ 6.081829] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 6.081990] sit: IPv6 over IPv4 tunneling driver
[ 6.082475] NET: Registered protocol family 17
[ 6.082511] NET: Registered protocol family 15
[ 6.082583] Bridge firewalling registered
[ 6.082601] Ebtables v2.0 registered
[ 6.082799] Bluetooth: RFCOMM TTY layer initialized
[ 6.082855] Bluetooth: RFCOMM socket layer initialized
[ 6.082868] Bluetooth: RFCOMM ver 1.11
[ 6.082880] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 6.082892] Bluetooth: BNEP filters: protocol multicast
[ 6.082910] Bluetooth: BNEP socket layer initialiver 1.2
[ 6.082940] Bluetooth: HIDP socket layer initialized
[ 6.082982] l2tp_core: L2TP core driver, V2.0
[ 6.083003] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 6.083014] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 6.083277] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 6.083293] [WLAN_RFKILL]: can’t find rockchip,grf property
[ 6.083306] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[ 6.083319] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 6.083333] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 6.083346] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 6.083379] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
[ 6.083411] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
[ 6.083424] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 6.083457] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
[ 6.083471] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 6.083524] [BT_RFKILL]: Enter rfkill_rk_init
[ 6.083720] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
[ 6.083756] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
[ 6.083779] [BT_RFKILL]: bluetooth_platdata_parseL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
[ 6.083863] [BT_RFKILL]: Request irq for bt wakeup host
[ 6.083985] [BT_RFKILL]: ** disable irq
[ 6.084099] [BT_RFKILL]: ap6335 device registered.
[ 6.085353] rk3288_init_suspend
[ 6.085369] rk3288_suspend_init enter
[ 6.085605] rk3288_suspend_init: pm_ctrbits =200007
[ 6.085653] gpio_get_dts_info suspend:4
[ 6.085665] gpio_get_dts_info resume:4
[ 6.085675] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 6.085723] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 6.085952] clks_gating_suspend_init:clkgt info ok
[ 6.086086] Registering SWP/SWPB emulation handler
[ 6.086105] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 0x02000000@0x7dc00000
[ 6.090424] DVFS ERR: clk_enable_dvfs: vd(vd_logic) can’t get regulator(vdd_logic)!
[ 6.091001] ddrfreq: verion 1.2 20140526
[ 6.091021] ddrfreq: normal 528MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 528MHz
[ 6.091034] ddrfreq: auto-freq=0
[ 6.091044] ddrfreq: auto-freq-table[0] 240MHz
[ 6.091054] ddrfreq: auto-freq-table[1] 324MHz
[ 6.091064] ddrfreq: auto-freq-table[2] 456MHz
[ 6.091074] ddrfreq: auto-freq-table[3] 528MHz
[ 6.091950] regulator-dummy: disabling
[ 6.092800] rockchip-es8323 rockchip-es8323.27: ASoC: CODEC (null) not registered
[ 6.092845] rockchip_es8323_audio_probe() register card failed:-517
[ 6.092871] platform rockchip-es8323.27: Driver rockchip-es8323 requests probe deferral
[ 6.092981] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[ 6.260583] wk2xxx_probe() GENA = 0xFF
[ 6.260595] spi driver error!!!
[ 6.260624] wk2xxxspi: probe of spi0.0 failed with error 1
[ 6.260658] register spi return v = :0
[ 6.260674] =======================================================
[ 6.260686] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 6.260696] =======================================================
[ 6.260708] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init.
[ 6.260814] dhd_module_init: in
[ 6.260827] ======== bcm_wlan_set_plat_data ========
[ 6.260839] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 6.260869] host_oob_irq: 196
[ 6.260879] host_oob_irq_flags=4
[ 6.260888] dhd_wifi_platform_load: Enter
[ 6.260917] Power-up adapter ‘DHD generic adapter’
[ 6.260923] pcd_pullup, is_on 0
[ 6.260945] WARN::dwc_otg_handle_mode_mismatch_intr:69: Mode Mismatch Interrupt: currently in Host mode
[ 6.260945]
[ 6.260987] wifi_platform_set_power = 1
[ 6.260997] file system registered
[ 6.261008] ======== PULL WL_REG_ON HIGH! ========
[ 6.261019] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 6.261031] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
[ 6.261041] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 6.262022] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 6.262038] android_usb gadget: Number of LUNs=2
[ 6.262053] lun0: LUN: removable file: (no medium)
[ 6.262065] lun1: LUN: removable file: (no medium)
[ 6.262334] android_usb gadget: android_usb ready
[ 6.262534] i2c i2c-4: sensor_probe: gs_mc3230,de00a800
[ 6.262588] sensor_chip_init:gs_mc3230:devid=0x0,ops=0xc0d25ca0
[ 6.314822] [Gsensor] init_3230_ctl_data 671 : error: -11
[ 6.315359] sensor_active:line=1500,error
[ 6.315371] sensor_init:line=1548,eshell@firefly:/ $ rror
[ 6.315382] sensor_initial:fail to init sensor
[ 6.315392] sensor_chip_init:fail to init sensor
[ 6.315408] i2c i2c-4: sensor_probe failed -11
[ 6.315408]
[ 6.315433] sensors: probe of 4-004c failed with error -11
[ 6.315472] sensor_init: Probe name sensors
[ 6.315503] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 6.362251] [WLAN_RFKILL]: wifi turn on power. 156
[ 6.568904] wifi_platform_bus_enumerate device present 1
[ 6.568918] ======== Card detection to detect SDIO card! ========
[ 6.568932] mmc2:mmc host rescan start!
[ 6.588583] rockchip_i2c ff650000.i2c: Addr[0x0051] wait event timeout, state: 2, is_busy: 1, error: 0, complete_what: 0x2, ipd: 0x20
[ 6.591563] rtc_hym8563 0-0051: hctosys: invalid date/time
[ 6.604160] rockchip-spdif-card rockchip-spdif-card.26: rk-hdmi-spdif-hifi ↔ ff880000.rockchip-spdif mapping ok
[ 6.605325] rockchip-es8323 rockchip-es8323.27: ASoC: CODEC (null) not registered
[ 6.605387] rockchip_es8323_audio_probe() register card failed:-517
[ 6.605414] platform rockchip-es8323.27: Driver rockchip-es8323 requests probe deferral
[ 6.605452] ret 1024
[ 6.606131] usbcore: registered new interface driver snd-usb-audio
[ 6.606146] ALSA device list:
[ 6.606157] #0: RK-SPDIF-CARD
[ 6.606766] Freeing unused kernel memory: 356K (c0bb4000 - c0c0d000)
[ 6.909605] type=1403 audit(6.510:2): policy loaded auid=4294967295 ses=4294967295
[ 6.958926] init: invalid gid ‘trace’
[ 7.126789] init: /dev/hw_random not found
[ 7.126904] keychord: using input dev ff680000.pwm for fevent
[ 7.126930] keychord: using input dev rk29-keypad for fevent
[ 7.135880] init: /dev/hw_random not found
[ 7.137654] fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
[ 7.139153] resize2fs: resize2fs 1.42.9 (28-Dec-2013)resize2fs: The filesystem is already 393216 blocks long. Nothing to do!resize2fs:
[ 7.142468] EXT4-fs (mmcblk0p10): Ignoring removed nomblk_io_submit option
[ 7.147301] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 7.147470] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/system,/system,ext4)=0
[ 7.148661] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
[ 7.155830] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 7.155912] e2fsck: system: clean, 1908/86208 files, 117433/393216 blocks
[ 7.160234] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 7.160368] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/system,target=/system,type=ext4)=0
[ 7.168121] EXT4-fs (mmcblk0p8): recovery complete
[ 7.168532] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 7.168644] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/cache,target=/cache,type=ext4)=0
[ 7.169165] EXT4-fs (mmcblk0p11): Ignoring removed nomblk_io_submit option
[ 7.173104] EXT4-fs (mmcblk0p11): recovery complete
[ 7.173134] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 7.173237] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,/metadata,ext4)=0
[ 7.174305] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata
[ 7.180182] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 7.180248] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata: clean, 11/1024 files, 1102/4096 blocks
[ 7.184766] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 7.184890] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,target=/metadata,type=ext4)=0
[ 7.184970] fs_mgr: Running /system/bin/fsck.f2fs -f /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
[ 7.186456] fsck.f2fs: executing /system/bin/fsck.f2fs failed: No such file or directory
[ 7.186525] fsck.f2fs: fsck.f2fs terminated by exit(255)
[ 7.186972] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=f2fs)=-1
[ 7.187509] EXT4-fs (mmcblk0p13): Ignoring removed nomblk_io_submit option
[ 7.212597] EXT4-fs (mmcblk0p13): recovery complete
[ 7.213021] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 7.213169] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,/data,ext4)=0
[ 7.214682] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
[ 7.240653] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 7.240724] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata: clean, 466/832320 files, 94365/3326464 blocks
[ 7.245683] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard,errors=panic
[ 7.245807] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=ext4)=0
[ 7.245844] fs_mgr: mount_with_alternatives(): Mounted /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata on /data with fs_type=ext4 instead of f2fs
[ 7.265297] arm_release_ver of this mali_ko is ‘r6p0-02rel0’, rk_ko_ver is ‘13’, built at ‘09:15:10’, on ‘Oct 22 2015’.
[ 7.265458] mali ffa30000.gpu: Continuing without Mali clock control
[ 7.265523] mali pd enabled
[ 7.265547] clk enabled
[ 7.265565] MALI_DVFS_STEP = 4, div_dvfs = 10
[ 7.265582] mali_dvfs_infotbl[0].clock=200000,min_threshold=0,max_threshold=70
[ 7.265599] mali_dvfs_infotbl[1].clock=300000,min_threshold=70,max_threshold=80
[ 7.265616] mali_dvfs_infotbl[2].clock=420000,min_threshold=81,max_threshold=90
[ 7.265633] mali_dvfs_infotbl[3].clock=500000,min_threshold=93,max_threshold=100
[ 7.265817] turn on mali power
[ 7.265843] kbase_platform_rk_init,register_reboot_notifier
[ 7.265920] hrtimer: interrupt took 21000 ns
[ 7.266092] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
[ 7.267447] mali ffa30000.gpu: Probed as mali0
[ 7.268200] rockchip-es8323 rockchip-es8323.27: ASoC: CODEC (null) not registered
[ 7.268262] rockchip_es8323_audio_probe() register card failed:-517
[ 7.268291] platform rockchip-es8323.27: Driver rockchip-es8323 requests probe deferral
[ 7.269129] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 7.270018] rk29_ipp: version magic '3.0.36+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 7.270767] rk29_ipp: version magic '3.0.101+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 7.272282] zram0: detected capacity change from 0 to 533413888
[ 7.327627] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
[ 7.371254] EXT4-fs (mmcblk0p13): Unrecognized mount option “background_gc=on” or missing value
[ 7.383745] drmboot: module license ‘unspecified’ taints kernel.
[ 7.383789] Disabling lock debugging due to kernel taint
[ 7.384229] drm init, 20140910
[ 7.384853] drm init ok
[ 7.387876] bat_cap: oldcap path is /sys/devices/ff100000.adc
[ 7.387970] bat_cap: oldcap_path no exist
[ 7.388262] binder: 154:154 transaction failed 29189, size 0-0
[ 7.389282] init: Warning! Service displayd needs a SELinux domain defined; please fix!
[ 7.398883] type=1400 audit(7.010:3): avc: denied { transition } for pid=160 comm=“init” path=“/system/xbin/vm” dev=“mmcblk0p10” ino=1907 scontext=u:r:init:s0 tcontext=u:r:su:s0 tclass=process permissive=1
[ 7.399276] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 7.399320] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
[ 7.399752] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
[ 7.400666] rtk_btusb: btchr_open: BT usb char device is opening
[ 7.400696] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 7.400739] rtk_btusb: btchr_open: BT usb char device is opening
[ 7.400758] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 7.400799] rtk_btusb: btchr_open: BT usb char device is opening
[ 7.400817] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 7.400842] rtk_btusb: btchr_open: BT usb char device is opening
[ 7.400859] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 7.421739] type=1400 audit(7.030:4): avc: denied { rlimitinh } for pid=160 comm=“vm” scontext=u:r:init:s0 tcontext=u:r:su:s0 tclass=process permissive=1
[ 7.421803] type=1400 audit(7.030:5): avc: denied { siginh } for pid=160 comm=“vm” scontext=u:r:init:s0 tcontext=u:r:su:s0 tclass=process permissive=1
[ 7.443849] logd.auditd: start
[ 7.470025] init: cannot find ‘/system/bin/debuggerd64’, disabling ‘debuggerd64’
[ 7.476977] init: cannot find ‘/system/bin/install-recovery.sh’, disabling ‘flash_recovery’
[ 7.477877] init: cannot find ‘/system/bin/bplus_helper’, disabling ‘bplus_helper’
[ 7.478205] init: Warning! Service drmservice needs a SELinux domain defined; please fix!
[ 7.641791] RKNAND_GET_SN_SECTOR
[ 7.641819] return ret = 0
[ 7.888530] RKNAND_GET_DRM_KEY
[ 7.888556] return ret = 0
[ 8.166658] avc: denied { set } for property=telephony.lteOnCdmaDevice scontext=u:r:rild:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service
[ 8.167560] android_usb: already disabled
[ 8.182831] read descriptors
[ 8.182859] read strings
[ 8.182894] mtp_bind_config
[ 8.182944] pcd_pullup, is_on 1
[ 8.301296] slot->flags = 1
[ 8.301325] CPU: 0 PID: 6 Comm: kworker/u8:0 Tainted: P 3.10.0 #28
[ 8.301355] Workqueue: kmmcd mmc_rescan
[ 8.301396] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 8.301421] [] (show_stack+0x10/0x14) from [] (dw_mci_set_ios+0x9c/0x214)
[ 8.301448] [] (dw_mci_set_ios+0x9c/0x214) from [] (mmc_set_chip_select+0x18/0x1c)
[ 8.301473] [] (mmc_set_chip_select+0x18/0x1c) from [] (mmc_go_idle+0x94/0xc4)
[ 8.301495] [] (mmc_go_idle+0x94/0xc4) from [] (mmc_rescan_try_freq+0x54/0xd0)
[ 8.301520] [] (mmc_rescan_try_freq+0x54/0xd0) from [] (mmc_rescan+0x204/0x298)
[ 8.301547] [] (mmc_rescan+0x204/0x298) from [] (process_one_work+0x29c/0x458)
[ 8.301568] [] (process_one_work+0x29c/0x458) from [] (worker_thread+0x194/0x2d4)
[ 8.301589] [] (worker_thread+0x194/0x2d4) from [] (kthread+0xa0/0xac)
[ 8.301614] [] (kthread+0xa0/0xac) from [] (ret_from_fork+0x14/0x3c)
[ 8.301630] dw_mci_set_ios: wait for unbusy timeout… STATUS = 0x206 [mmc1]
[ 8.373463] healthd: No charger supplies found
[ 8.373491] healthd: No battery devices found
[ 8.536958] failed to power up DHD generic adapter, 0 retry left
[ 8.552870] wifi_platform_set_power = 0
[ 8.552894] ======== PULL WL_REG_ON LOW! ========
[ 8.552906] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 8.655012] [WLAN_RFKILL]: wifi shut off power.
[ 8.655037] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
[ 8.655050] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 8.655066] wifi_platform_bus_enumerate device present 0
[ 8.655077] ======== Card detection to remove SDIO card! ========
[ 8.655090] mmc2:mmc host rescan start!
[ 8.655119] failed to power up DHD generic adapter, max retry reached**
[ 8.655158] unregister wifi platform drivers
[ 8.655168] wifi_platform_bus_enumerate device present 0
[ 8.655181] ======== Card detection to remove SDIO card! ========
[ 8.655193] mmc2:mmc host rescan start!
[ 8.655210] dhd_module_init: Failed to load the driver, try cnt 0
[ 8.655250] dhd_module_init: Failed to load driver max retry reached**
[ 8.655263] dhd_module_init: Exit err=-19
[ 9.944038] [otg id chg] last id -1 current id 1
[ 11.008898] rk3288-lcdc lcdc0: blank mode:0
[ 13.220797] slot->flags = 1
[ 13.220836] CPU: 0 PID: 6 Comm: kworker/u8:0 Tainted: P 3.10.0 #28
[ 13.220946] Workqueue: kmmcd mmc_rescan
[ 13.220987] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 13.221015] [] (show_stack+0x10/0x14) from [] (dw_mci_set_ios+0x9c/0x214)
[ 13.221048] [] (dw_mci_set_ios+0x9c/0x214) from [] (mmc_power_off+0x5c/0x7c)
[ 13.221073] [] (mmc_power_off+0x5c/0x7c) from [] (mmc_rescan_try_freq+0xc8/0xd0)
[ 13.221095] [] (mmc_rescan_try_freq+0xc8/0xd0) from [] (mmc_rescan+0x204/0x298)
[ 13.221119] [] (mmc_rescan+0x204/0x298) from [] (process_one_work+0x29c/0x458)
[ 13.221154] [] (process_one_work+0x29c/0x458) from [] (worker_thread+0x194/0x2d4)
[ 13.221179] [] (worker_thread+0x194/0x2d4) from [] (kthread+0xa0/0xac)
[ 13.221206] [] (kthread+0xa0/0xac) from [] (ret_from_fork+0x14/0x3c)
[ 13.221223] dw_mci_set_ios: wait for unbusy timeout… STATUS = 0x206 [mmc1]
[ 15.680770] rk_sdmmc: ERROR mci_send_cmd: wait for unbusy timeout! [mmc1]
[ 15.729936] mmc_host mmc1: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80202000)
[ 15.877746] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 15.877783] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 15.877800] D1:camsys_open(739): camsys_marvin(ddf98410) is opened!
[ 15.882588] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
[ 15.882616] D1:camsys_extdev_register(243): Get RK30_PIN3_PB0(104) gpio(active: 0) for dev_id 0x2000000 success!
[ 15.882639] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
[ 15.882691] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 15.882736] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
[ 15.888176] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 15.888196] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 15.888308] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 15.888363] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 15.889455] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
[ 15.890536] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(104) set 1
[ 15.891607] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
[ 16.084309] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
[ 16.084350] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
[ 16.281008] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
[ 16.281047] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 16.281211] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
[ 16.281235] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(104) set 0
[ 16.281256] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
[ 16.282378] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 16.282444] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 16.284528] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
[ 16.284556] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 16.284576] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 16.284589] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 16.284604] D1:camsys_release(763): camsys_marvin(ddf98410) is closed
[ 16.285702] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 16.285722] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 16.285738] D1:camsys_open(739): camsys_marvin(ddf98410) is opened!
[ 16.285892] D1:camsys_extdev_register(243): Get RK30_PIN2_PA0(64) gpio(active: 0) for dev_id 0x1000000 success!
[ 16.285918] D1:camsys_extdev_register(243): Get RK30_PIN3_PB0(104) gpio(active: 0) for dev_id 0x1000000 success!
[ 16.285941] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x1000000 success!
[ 16.285973] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 16.286001] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: OV13850) register success
[ 16.291084] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 16.291106] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 16.291219] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 16.291271] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 16.292362] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
[ 16.293446] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(104) set 1
[ 16.294528] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(64) set 1
[ 16.487646] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
[ 16.487687] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
[ 16.684472] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
[ 16.684512] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 16.684665] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(64) set 0
[ 16.684689] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(104) set 0
[ 16.684710] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
[ 16.694324] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 16.694395] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 16.696478] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
[ 16.696506] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 16.696525] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 16.696539] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 16.696553] D1:camsys_release(763): camsys_marvin(ddf98410) is closed
[ 16.702921] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 16.702943] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 16.702958] D1:camsys_open(739): camsys_marvin(ddf98410) is opened!
[ 16.703118] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default
[ 16.703165] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: TC358749XBG) register success
[ 16.708246] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 16.708270] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 16.708381] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 16.708432] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on
[ 16.709514] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
[ 16.710704] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
[ 16.711761] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
[ 16.715333] E:camsys_i2c_write(78): i2c write dev(addr:0x1f) failed!
[ 16.716831] E:camsys_i2c_write(78): i2c write dev(addr:0xf) failed!
[ 16.716961] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
[ 16.716979] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
[ 16.716995] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
[ 16.718096] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 16.718146] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 16.720203] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
[ 16.720230] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 16.720250] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 16.720264] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 16.720278] D1:camsys_release(763): camsys_marvin(ddf98410) is closed
[ 16.734074] type=1400 audit(16.500:6): avc: denied { execute } for pid=463 comm=“mediaserver” name=“sh” dev=“mmcblk0p10” ino=321 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 16.734443] type=1400 audit(16.500:7): avc: denied { read open } for pid=463 comm=“mediaserver” path=“/system/bin/sh” dev=“mmcblk0p10” ino=321 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 16.736848] type=1400 audit(16.500:8): avc: denied { execute_no_trans } for pid=463 comm=“mediaserver” path=“/system/bin/sh” dev=“mmcblk0p10” ino=321 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 16.742808] type=1400 audit(16.500:9): avc: denied { getattr } for pid=463 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=336 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 16.744352] type=1400 audit(16.510:10): avc: denied { execute } for pid=463 comm=“sh” name=“toolbox” dev=“mmcblk0p10” ino=336 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 16.744529] type=1400 audit(16.510:11): avc: denied { read open } for pid=463 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=336 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 16.744705] type=1400 audit(16.510:12): avc: denied { execute_no_trans } for pid=463 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=336 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 18.189951] slot->flags = 1
[ 18.189995] CPU: 1 PID: 6 Comm: kworker/u8:0 Tainted: P 3.10.0 #28
[ 18.190029] Workqueue: kmmcd mmc_rescan
[ 18.190069] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 18.190095] [] (show_stack+0x10/0x14) from [] (dw_mci_set_ios+0x9c/0x214)
[ 18.190121] [] (dw_mci_set_ios+0x9c/0x214) from [] (mmc_power_up.part.16+0x60/0xa0)
[ 18.190146] [] (mmc_power_up.part.16+0x60/0xa0) from [] (mmc_rescan_try_freq+0x14/0xd0)
[ 18.190169] [] (mmc_rescan_try_freq+0x14/0xd0) from [] (mmc_rescan+0x204/0x298)
[ 18.190192] [] (mmc_rescan+0x204/0x298) from [] (process_one_work+0x29c/0x458)
[ 18.190213] [] (process_one_work+0x29c/0x458) from [] (worker_thread+0x194/0x2d4)
[ 18.190237] [] (worker_thread+0x194/0x2d4) from [] (kthread+0xa0/0xac)
[ 18.190263] [] (kthread+0xa0/0xac) from [] (ret_from_fork+0x14/0x3c)
[ 18.190279] dw_mci_set_ios: wait for unbusy timeout… STATUS = 0x206 [mmc1]
[ 20.649929] rk_sdmmc: ERROR mci_send_cmd: wait for unbusy timeout! [mmc1]
[ 20.699147] mmc_host mmc1: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80202000)
[ 23.178819] slot->flags = 3
[ 23.178862] CPU: 1 PID: 6 Comm: kworker/u8:0 Tainted: P 3.10.0 #28
[ 23.178895] Workqueue: kmmcd mmc_rescan
[ 23.178932] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 23.178960] [] (show_stack+0x10/0x14) from [] (dw_mci_set_ios+0x9c/0x214)
[ 23.178985] [] (dw_mci_set_ios+0x9c/0x214) from [] (mmc_power_up.part.16+0x94/0xa0)
[ 23.179010] [] (mmc_power_up.part.16+0x94/0xa0) from [] (mmc_rescan_try_freq+0x14/0xd0)
[ 23.179033] [] (mmc_rescan_try_freq+0x14/0xd0) from [] (mmc_rescan+0x204/0x298)
[ 23.179057] [] (mmc_rescan+0x204/0x298) from [] (process_one_work+0x29c/0x458)
[ 23.179078] [] (process_one_work+0x29c/0x458) from [] (worker_thread+0x194/0x2d4)
[ 23.179104] [] (worker_thread+0x194/0x2d4) from [] (kthread+0xa0/0xac)
[ 23.179127] [] (kthread+0xa0/0xac) from [] (ret_from_fork+0x14/0x3c)
[ 23.179144] dw_mci_set_ios: wait for unbusy timeout… STATUS = 0x206 [mmc1]
[ 23.179169] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 300000Hz, actual 297619HZ div = 84)
[ 25.638811] rk_sdmmc: ERROR mci_send_cmd: wait for unbusy timeout! [mmc1]
[ 25.688015] mmc_host mmc1: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80202000)
[ 25.688038] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 600000Hz for init[mmc1]
[ 28.148020] rk_sdmmc: ERROR mci_send_cmd: wait for unbusy timeout! [mmc1]
[ 28.197241] mmc_host mmc1: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80202000)
[ 30.657282] rk_sdmmc: ERROR mci_send_cmd: wait for unbusy timeout! [mmc1]
[ 30.706426] mmc_host mmc1: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80202000)
[ 33.186106] slot->flags = 3
[ 33.186151] CPU: 1 PID: 6 Comm: kworker/u8:0 Tainted: P 3.10.0 #28
[ 33.195983] Workqueue: kmmcd mmc_rescan
[ 33.196033] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 33.196061] [] (show_stack+0x10/0x14) from [] (dw_mci_set_ios+0x9c/0x214)
[ 33.196088] [] (dw_mci_set_ios+0x9c/0x214) from [] (mmc_set_chip_select+0x18/0x1c)
[ 33.196112] [] (mmc_set_chip_select+0x18/0x1c) from [] (mmc_go_idle+0x34/0xc4)
[ 33.196135] [] (mmc_go_idle+0x34/0xc4) from [] (mmc_rescan_try_freq+0x54/0xd0)
[ 33.196156] [] (mmc_rescan_try_freq+0x54/0xd0) from [] (mmc_rescan+0x204/0x298)
[ 33.196181] [] (mmc_rescan+0x204/0x298) from [] (process_one_work+0x29c/0x458)
[ 33.196206] [] (process_one_work+0x29c/0x458) from [] (worker_thread+0x194/0x2d4)
[ 33.196229] [] (worker_thread+0x194/0x2d4) from [] (kthread+0xa0/0xac)
[ 33.196255] [] (kthread+0xa0/0xac) from [] (ret_from_fork+0x14/0x3c)
[ 33.196272] dw_mci_set_ios: wait for unbusy timeout… STATUS = 0x206 [mmc1]
[ 34.180034] dwmmc_rockchip ff0c0000.rksdmmc: req failed (CMD0): error = -110, timeout = 500ms
[ 34.180070] [mmc1] – Timeout recovery procedure start –
[ 34.193863] rk_sdmmc: ERROR stop recovery failed![mmc1]
[ 34.194895] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 300000Hz, actual 297619HZ div = 84)
[ 34.194928] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 600000Hz for init[mmc1]
[ 34.195005] [mmc1] – Timeout recovery procedure finished –
[ 34.681847] dwmmc_rockchip ff0c0000.rksdmmc: req failed (CMD8): error = -110, timeout = 500ms
[ 34.681886] [mmc1] – Timeout recovery procedure start –
[ 34.681945] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 300000Hz, actual 297619HZ div = 84)
[ 34.681976] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 600000Hz for init[mmc1]
[ 34.682026] [mmc1] – Timeout recovery procedure finished –
[ 38.617831] slot->flags = 1
[ 38.617882] CPU: 2 PID: 6 Comm: kworker/u8:0 Tainted: P 3.10.0 #28
[ 38.617916] Workqueue: kmmcd mmc_rescan
[ 38.617953] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 38.617979] [] (show_stack+0x10/0x14) from [] (dw_mci_set_ios+0x9c/0x214)
[ 38.618003] [] (dw_mci_set_ios+0x9c/0x214) from [] (mmc_power_off+0x5c/0x7c)
[ 38.618028] [] (mmc_power_off+0x5c/0x7c) from [] (mmc_rescan_try_freq+0xc8/0xd0)
[ 38.618049] [] (mmc_rescan_try_freq+0xc8/0xd0) from [] (mmc_rescan+0x204/0x298)
[ 38.618072] [] (mmc_rescan+0x204/0x298) from [] (process_one_work+0x29c/0x458)
[ 38.618094] [] (process_one_work+0x29c/0x458) from [] (worker_thread+0x194/0x2d4)
[ 38.618118] [] (worker_thread+0x194/0x2d4) from [] (kthread+0xa0/0xac)
[ 38.618144] [] (kthread+0xa0/0xac) from [] (ret_from_fork+0x14/0x3c)
[ 38.618160] dw_mci_set_ios: wait for unbusy timeout… STATUS = 0x206 [mmc1]
[ 41.077868] rk_sdmmc: ERROR mci_send_cmd: wait for unbusy timeout! [mmc1]
[ 41.128009] mmc_host mmc1: Timeout
需要完整log,这log只有一小段,如果i2c有问题,可以先检查一下是否哪一路i2c被短路了
好的,上传完整log了。也没有发现i2c被短路。这是在弄RK3288 core板,没加底板。只有CPU,内存,pmu和PHY等基础件
你的机器是否有选择对应的固件?
jpchen 发表于 2019-12-12 17:29
你的机器是否有选择对应的固件?
这是在弄RK3288 core板,没加底板。只有CPU,内存,pmu和PHY等,烧录的官方固件,Android5.1,firefly教程里给的。我查查看。谢谢大佬
用酒精把金手指和接插器重新擦干净后,就不显示I2C错误了。
