当前硬件是Core-3399-JD4核心板以及配套底板,使用官网下载的固件能正常启动。此时使用SDK编译得到的内核则无法正常启动。官网下载的SDK已更新,且无修改,编译方式为http://wiki.t-firefly.com/zh_CN/Core-3399-JD4/Linux_development.html#bian-yi-sdk。仅编译内核。将内核写入0x00280000后,启动失败。
报错打印一:此处仅报错,未停止运行
[ 4.028549] systemd[1]: Detected architecture arm64.
[ 4.036898] EXT4-fs error (device mmcblk1p5): ext4_iget:4434: inode #42191: comm systemd: bad extended attribute block 3942645823
[ 4.038814] Aborting journal on device mmcblk1p5-8.
报错打印二:在Started D-Bus System Message Bus.成功后,系统停止。
[ OK ] Started Apply Kernel Variables.
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Mounted FUSE Control File System.
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Set the console keyboard layout.
[ OK ] Reached target Local File Systems (Pre).
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories…
Starting Set console font and keymap…
Starting Tell Plymouth To Write Out Runtime Data…
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Reached target Local Encrypted Volumes.
[ OK ] Created slice system-systemd\x2dbacklight.slice.
Starting Load/Save Screen Backlight鈥ghtness of backlight:backlight…
[FAILED] Failed to start Load/Save Screen Ba鈥rightness of backlight:backlight.
See ‘systemctl status systemd-backlight鈥klight:backlight.service’ for details.
[ OK ] Started Tell Plymouth To Write Out Runtime Data.
[FAILED] Failed to start Create Volatile Files and Directories.
See ‘systemctl status systemd-tmpfiles-setup.service’ for details.
[FAILED] Failed to start Network Name Resolution.
See ‘systemctl status systemd-resolved.service’ for details.
[ OK ] Reached target Host and Network Name Lookups.
[FAILED] Failed to start Network Time Synchronization.
See ‘systemctl status systemd-timesyncd.service’ for details.
[ OK ] Reached target System Time Synchronized.
Starting Update UTMP about System Boot/Shutdown…
[ OK ] Started Set console font and keymap.
[ OK ] Stopped Network Time Synchronization.
[ OK ] Stopped Network Name Resolution.
[ OK ] Found device /dev/ttyFIQ0.
[ OK ] Reached target Sound Card.
[FAILED] Failed to start Update UTMP about System Boot/Shutdown.
See ‘systemctl status systemd-update-utmp.service’ for details.
[DEPEND] Dependency failed for Update UTMP about System Runlevel Changes.
[ OK ] Reached target System Initialization.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
Starting Socket activation for snappy daemon.
Starting Docker Socket for the API.
[ OK ] Reached target Paths.
[ OK ] Listening on Socket activation for snappy daemon.
[ OK ] Listening on Docker Socket for the API.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting Dispatcher daemon for systemd-networkd…
Starting LSB: automatic crash report generation…
[ OK ] Started D-Bus System Message Bus.
