串口出错android_bootloader_boot_flow Could not find misc partition
发了这2条命令,想用SD卡启动,
shell@firefly:/ $ su
shell@firefly:/ # mkdosfs /dev/block/mmcblk0
断电后,插上SD卡,出口出现这个情况,请问怎么解决,谢谢!
DDR Version 1.06 20171020
Channel a: DDR3 400MHz
Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB
Channel b: DDR3 400MHz
Memory OK
Memory OK
Boot1 Release Time: Apr 11 2018 10:32:58, version: 2.36
ChipType = 0x8, 227
mmc2:cmd19,256
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=29820MB
FwPartOffset=2000 , 2000
mmc0:cmd5,32
SdmmcInit=0 0
BootCapSize=0
UserCapSize=3837MB
FwPartOffset=2000 , 0
StorageInit ok = 35951
LOADER Check OK! 0x0, 93597
TOS Check OK! 0x8400000, 168025
Enter Trust OS
INF [0x0] TEE-CORE:init_primary_helper:377: Initializing (1.1.0-316-g7b4ec90 #59 Wed May 30 08:26:33 UTC 2018 arm)
INF [0x0] TEE-CORE:init_primary_helper:378: Release version: 1.3
INF [0x0] TEE-CORE:init_primary_helper:379: Next entry point address: 0x0
U-Boot 2017.09-gd80ac02 (Feb 25 2019 - 16:26:01 +0800)
Model: Firefly-RK3288
DRAM: 4 GiB
Relocation Offset is: fbe63000
MMC: dwmmc@ff0c0000: 1, dwmmc@ff0f0000: 0
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
switch to partitions #0, OK
mmc1 is current device
do_rkimg_test fail to read data from IDB
get part misc fail -1
Net:
Warning: ethernet@ff290000 (eth0) using random MAC address - 1a:7c:87:8b:94:4a
eth0: ethernet@ff290000
Unknown command ‘usb’ - try ‘help’
出现这个问题,怎么解决啊?求大神指导!
{:4_96:}没人帮忙回答呢
我真难啊
您好,请问您的usb转ttl芯片是firefly官网买的么?我是买了这个芯片,但是在win10上装了驱动或者不装驱动插上芯片后什么反应都没有?请问您是怎么接通串口调试的?
紫翼之狮 发表于 2019-12-18 22:54
您好,请问您的usb转ttl芯片是firefly官网买的么?我是买了这个芯片,但是在win10上装了驱动或者不装驱动插 …
5块钱一条线随便买的,不是官网买的
