nfs系统启动内核失败
[ 14.290021] systemd[1]: Mounted Debug File System.
[ OK ] Mounted Debug File System.
[ 14.329204] systemd[1]: Started Remount Root and Kernel File Systems.
[ OK ] Started Remount Root and Kernel File Systems.
[ 14.406062] systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
[ 14.416344] systemd[1]: Failed to start Load Kernel Modules.
[FAILED] Failed to start Load Kernel Modules.
See ‘systemctl status systemd-modules-load.service’ for details.
[ 14.427602] systemd[1]: systemd-modules-load.service: Unit entered failed state.
[ 14.440527] systemd[1]: systemd-modules-load.service: Failed with result ‘exit-code’.
[ 14.449079] systemd[1]: Started Set console keymap.
[ OK ] Started Set console keymap.
[ 14.468068] systemd[1]: Started Create Static Device Nodes in /dev.
[ OK ] Started Create Static Device Nodes in /dev.
[ 14.475679] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
Starting udev Kernel Device Manager…
Mounting FUSE Control File System…
Mounting Configuration File System…
Starting Apply Kernel Variables…
Starting Load/Save Random Seed…
[ OK ] Reached target Local File Systems (Pre).
[ OK ] Reached target Local File Systems.
Starting Set console font and keymap…
Starting LSB: AppArmor initialization…
Starting Tell Plymouth To Write Out Runtime Data…
Starting Commit a transient machine-id on disk…
Starting udev Coldplug all Devices…
Starting Flush Journal to Persistent Storage…
http://wiki.t-firefly.com/zh_CN/Firefly-RK3399/ubuntu_support.html#wang-luo-qi-dong
可以参考下这个~
可以参考下这 …
这个链接怎么是空的呢?
