bootloader 也进不去了,灯也不亮了
DDR Version 1.06 20171020
Channel a: DDR3 400MHz
Channel b: DDR3 400MHz
Memory OK
Memory OK
Boot1 Release Time: Apr 11 2018 10:32:58, version: 2.36
ChipType = 0x8, 227
mmc2:cmd19,256
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=14910MB
FwPartOffset=2000 , 2000
mmc0:cmd8,1024
mmc0:cmd8,1024
mmc0:cmd8,1024
SdmmcInit=0 1
StorageInit ok = 30968
LOADER Check OK! 0x200000, 56387
TOS Check OK! 0x8400000, 91036
Enter Trust OS
INF [0x0] TEE-CORE:init_primary_helper:377: Initializing (1.1.0-374-g4981120 #1 Wed Feb 20 03:32:43 UTC 2019 arm)
INF [0x0] TEE-CORE:init_primary_helper:378: Release version: 1.3
INF [0x0] TEE-CORE:init_primary_helper:379: Next entry point address: 0x200000
U-Boot 2017.09-g0b1f585 (Dec 18 2019 - 21:33:34 -0800)
Model: Firefly-RK3288
DRAM: 2 GiB
Relocation Offset is: 00000000
Sysmem: init
I2c speed: 400000Hz
MMC: dwmmc@ff0c0000: 1, dwmmc@ff0f0000: 0
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
mmc_init: -95, time 2109
switch to partitions #0, OK
Bootdev: mmc 0
failed to read ‘keyup-threshold-microvolt’, ret=-1
PartType: EFI
get part misc fail -1
boot mode: None
CLK: (uboot. arm: enter 1000000 KHz, init 1000000 KHz, kernel 0N/A)
apll 1000000 KHz
dpll 396000 KHz
cpll 384000 KHz
gpll 594000 KHz
npll 24000 KHz
aclk_bus 297000 KHz
Net:
Warning: ethernet@ff290000 (eth0) using random MAC address - 82:e4:58:8e:08:07
eth0: ethernet@ff290000
android_bootloader_boot_flow Could not find misc partition
Load FDT from boot part
DTB: rk-kernel.dtb
FDT load addr 0x10f00000 size 201 KiB
Booting kernel at 0x02008000 with fdt at 0x8300000…
## Booting Android Image at 0x03752970 …
Kernel load addr 0x03753170 size 7952 KiB
## Flattened Device Tree blob at 08300000
Booting using the fdt blob at 0x8300000
XIP Kernel Image … OK
CACHE: Misaligned operation at range [03753170, 03f16f70]
Loading Device Tree to 0ffea000, end 0ffff90b … OK
Adding bank: 0x00000000 - 0x08400000 (size: 0x08400000)
Adding bank: 0x09200000 - 0x80000000 (size: 0x76e00000)
Total: 6031.526 ms
[ 0.000000] Linux version 4.4.167 (wlgy@ubuntu) ((no: 2ad015924ddfa794886055ad3e8b48b1a9260c2d) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #1 SMP Wed Dec 18 06:05:59 PST 2019
[ 0.000000] Machine model: Firefly-RK3288 Board (Linux Opensource)
[ 0.000000] Reserved memory: failed to reserve memory for node ‘drm-logo@00000000’: base 0x00000000, size 0 MiB
[ 0.000000] cma: Reserved 16 MiB at 0x7f000000
[ 0.000000] psci: PSCIv65535.65535 detected in firmware.
[ 0.000000] PERCPU: Embedded 14 pages/cpu @eef7b000 s24728 r8192 d24424 u57344
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 519168
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.mode=emmc androidboot.slot_suffix= androidboot.serialno=c3d9b8674f4b94f6 earlyprintk rw rootwait console=ttyFIQ0 root=PARTUUID=614e0000-0000 rootfstype=ext4
[ 0.000000] Memory: 2027688K/2082816K available (12288K kernel code, 1002K rwdata, 3464K rodata, 1024K init, 649K bss, 38744K reserved, 16384K cma-reserved, 1294336K highmem)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0d00000 (13280 kB)
[ 0.000000] .init : 0xc1200000 - 0xc1300000 (1024 kB)
[ 0.000000] .data : 0xc1300000 - 0xc13fa834 (1003 kB)
[ 0.000000] .bss : 0xc13fc000 - 0xc149e670 ( 650 kB)
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000009] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000029] Switching to timer-based delay loop, resolution 41ns
[ 0.003715] Console: colour dummy device 80x30
[ 0.003759] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.003784] pid_max: default: 32768 minimum: 301
[ 0.003913] Security Framework initialized
[ 0.003931] Yama: becoming mindful.
[ 0.004024] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.004048] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.005225] Initializing cgroup subsys devices
[ 0.005257] Initializing cgroup subsys freezer
[ 0.005308] CPU: Testing write buffer coherency: ok
[ 0.005363] ftrace: allocating 44335 entries in 131 pages
[ 0.137180] CPU0: update cpu_capacity 430
[ 0.137200] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.137292] Setting up static identity map for 0x100000 - 0x100058
[ 0.140676] CPU1: update cpu_capacity 430
[ 0.140686] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.141926] CPU2: update cpu_capacity 430
[ 0.141936] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.143164] CPU3: update cpu_capacity 430
[ 0.143173] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.143330] Brought up 4 CPUs
[ 0.143373] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.143383] CPU: All CPU(s) started in SVC mode.
[ 0.145472] devtmpfs: initialized
[ 0.175881] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.176447] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.176489] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.178049] pinctrl core: initialized pinctrl subsystem
[ 0.179653] NET: Registered protocol family 16
[ 0.182224] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.207014] cpuidle: using governor ladder
[ 0.237066] cpuidle: using governor menu
[ 0.237123] Registered FIQ tty driver
[ 0.289975] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.289993] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.291097] fiq debugger fiq mode enabled
[ 0.759612] console [ttyFIQ0] enabled
[ 0.763675] Registered fiq debugger ttyFIQ0
[ 0.854414] vcc_flash: regulator get failed, ret=-517
[ 0.860261] vcc_sd: regulator get failed, ret=-517
[ 0.865794] vcc28_dvp: regulator get failed, ret=-517
[ 0.871602] dovdd_1v8: regulator get failed, ret=-517
[ 0.877736] iommu: Adding device ff910000.isp to group 0
[ 0.883266] iommu: Adding device ff930000.vop to group 1
[ 0.888740] iommu: Adding device ff940000.vop to group 2
[ 0.894253] iommu: Adding device ff9a0000.vpu-service to group 3
[ 0.900420] iommu: Adding device ff9c0000.hevc-service to group 4
[ 0.907409] rk_iommu ff914000.iommu: can’t get sclk
[ 0.912954] rk_iommu ff930300.iommu: can’t get sclk
[ 0.918310] rk_iommu ff940300.iommu: can’t get sclk
[ 0.923621] rk_iommu ff9a0800.iommu: can’t get sclk
[ 0.929061] rk_iommu ff9c0440.iommu: can’t get sclk
[ 0.934858] SCSI subsystem initialized
[ 0.939091] usbcore: registered new interface driver usbfs
[ 0.944680] usbcore: registered new interface driver hub
[ 0.950196] usbcore: registered new device driver usb
[ 0.955497] media: Linux media interface: v0.10
[ 0.960155] Linux video capture interface: v2.00
[ 0.964842] pps_core: LinuxPPS API ver. 1 registered
[ 0.969805] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.979008] PTP clock support registered
[ 0.985569] Advanced Linux Sound Architecture Driver Initialized.
[ 0.992768] Bluetooth: Core ver 2.21
[ 0.996407] NET: Registered protocol family 31
[ 1.000854] Bluetooth: HCI device and connection manager initialized
[ 1.007262] Bluetooth: HCI socket layer initialized
[ 1.012152] Bluetooth: L2CAP socket layer initialized
[ 1.017285] Bluetooth: SCO socket layer initialized
[ 1.023819] rockchip-cpuinfo cpuinfo: Serial : 754277dfa70f9fa8
[ 1.031341] clocksource: Switched to clocksource arch_sys_counter
[ 1.124519] NET: Registered protocol family 2
[ 1.129820] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 1.137031] TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
[ 1.143854] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.150296] UDP hash table entries: 512 (order: 2, 24576 bytes)
[ 1.156309] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes)
[ 1.163034] NET: Registered protocol family 1
[ 1.167932] RPC: Registered named UNIX socket transport module.
[ 1.173909] RPC: Registered udp transport module.
[ 1.178620] RPC: Registered tcp transport module.
[ 1.183355] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.191617] hw perfevents: enabled with armv7_cortex_a12 PMU driver, 7 counters available
[ 1.203401] Initialise system trusted keyring
[ 1.223497] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.232566] NFS: Registering the id_resolver key type
[ 1.237677] Key type id_resolver registered
[ 1.241918] Key type id_legacy registered
[ 1.245963] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 1.253378] fuse init (API version 7.23)
[ 1.266220] NET: Registered protocol family 38
[ 1.270704] Key type asymmetric registered
[ 1.274921] Asymmetric key parser ‘x509’ registered
[ 1.279930] bounce: pool size: 64 pages
[ 1.284164] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.291683] io scheduler noop registered
[ 1.295627] io scheduler deadline registered
[ 1.299962] io scheduler cfq registered (default)
[ 1.312432] rk-vcodec ff9a0000.vpu-service: no regulator for vcodec
[ 1.319100] rk-vcodec ff9a0000.vpu-service: probe device
[ 1.324942] rk-vcodec ff9a0000.vpu-service: drm allocator with mmu enabled
[ 1.332996] rk-vcodec ff9a0000.vpu-service: could not find power_model node
[ 1.339966] rk-vcodec ff9a0000.vpu-service: init success
[ 1.345849] rk-vcodec ff9c0000.hevc-service: no regulator for vcodec
[ 1.352773] rk-vcodec ff9c0000.hevc-service: probe device
[ 1.358606] rk-vcodec ff9c0000.hevc-service: drm allocator with mmu enabled
[ 1.366458] rk-vcodec ff9c0000.hevc-service: could not find power_model node
[ 1.373570] rk-vcodec ff9c0000.hevc-service: init success
[ 1.382970] dma-pl330 ff250000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.390546] dma-pl330 ff250000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.401269] dma-pl330 ff600000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.408904] dma-pl330 ff600000.dma-controller: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 1.420928] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 1.428400] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 37, base_baud = 1500000) is a 16550A
[ 1.438205] rockchip-pinctrl pinctrl: pin gpio7-22 already requested by fiq-debugger; cannot claim for ff690000.serial
[ 1.448959] rockchip-pinctrl pinctrl: pin-238 (ff690000.serial) status -22
[ 1.455873] rockchip-pinctrl pinctrl: could not request pin 238 (gpio7-22) from group uart2-xfer on device rockchip-pinctrl
[ 1.467109] dw-apb-uart ff690000.serial: Error applying setting, reverse things back
[ 1.475090] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 38, base_baud = 1500000) is a 16550A
[ 1.486514] [drm] Initialized drm 1.1.0 20060810
[ 1.497509] [drm] Rockchip DRM driver version: v1.0.1
[ 1.503119] rockchip-drm display-subsystem: devfreq is not set
[ 1.510614] rockchip-drm display-subsystem: bound ff930000.vop (ops 0xc0d65be8)
[ 1.519194] rockchip-drm display-subsystem: bound ff940000.vop (ops 0xc0d65be8)
[ 1.526947] i2c i2c-6: of_i2c: modalias failure on /hdmi@ff980000/ports
[ 1.533623] dwhdmi-rockchip ff980000.hdmi: registered DesignWare HDMI I2C bus driver
[ 1.541539] dwhdmi-rockchip ff980000.hdmi: Detected HDMI TX controller v2.01a with HDCP (DWC HDMI 2.0 TX PHY)
[ 1.553020] rockchip-drm display-subsystem: bound ff980000.hdmi (ops 0xc0d5d5c8)
[ 1.560424] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.567080] [drm] No driver support for vblank timestamp query.
[ 1.573378] rockchip-drm display-subsystem: failed to parse loader memory
[ 1.580223] rockchip-drm display-subsystem: No connectors reported connected with modes
[ 1.588356] [drm] Cannot find any crtc or sizes - going 1024x768
[ 1.622229] Console: switching to colour frame buffer device 128x48
[ 1.644966] rockchip-drm display-subsystem: fb0: frame buffer device
[ 1.684178] usbcore: registered new interface driver udl
[ 1.694603] mali ffa30000.gpu: Failed to get regulator
[ 1.699756] mali ffa30000.gpu: Power control initialization failed
[ 1.708049] brd: module loaded
[ 1.722030] loop: module loaded
[ 1.726461] zram: Added device: zram0
[ 1.730178] lkdtm: No crash points registered, enable through debugfs
[ 1.738009] rockchip-spi ff110000.spi: no high_speed pinctrl state
[ 1.745991] tun: Universal TUN/TAP device driver, 1.6
[ 1.751055] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.759853] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 1.766561] rk_gmac-dwmac ff290000.ethernet: phy regulator is not available yet, deferred probing
[ 1.777335] PPP generic driver version 2.4.2
[ 1.782150] usbcore: registered new interface driver rndis_wlan
[ 1.788467] usbcore: registered new interface driver rt2800usb
[ 1.794481] Rockchip WiFi SYS interface (V1.00) …
[ 1.799515] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.807111] usbcore: registered new interface driver pegasus
[ 1.812952] usbcore: registered new interface driver rtl8150
[ 1.818708] usbcore: registered new interface driver r8152
[ 1.824359] usbcore: registered new interface driver asix
[ 1.829877] usbcore: registered new interface driver ax88179_178a
[ 1.836113] usbcore: registered new interface driver cdc_ether
[ 1.842091] usbcore: registered new interface driver dm9601
[ 1.847783] usbcore: registered new interface driver smsc75xx
[ 1.853688] usbcore: registered new interface driver smsc95xx
[ 1.859530] usbcore: registered new interface driver net1080
[ 1.865330] usbcore: registered new interface driver rndis_host
[ 1.871404] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.878954] usbcore: registered new interface driver cdc_ncm
[ 1.884760] usbcore: registered new interface driver qmi_wwan
[ 1.890602] usbcore: registered new interface driver cdc_mbim
[ 1.896997] ff540000.usb supply vusb_d not found, using dummy regulator
[ 1.903754] ff540000.usb supply vusb_a not found, using dummy regulator
[ 2.022057] dwc2 ff540000.usb: DWC OTG Controller
[ 2.026806] dwc2 ff540000.usb: new USB bus registered, assigned bus number 1
[ 2.033952] dwc2 ff540000.usb: irq 44, io mem 0xff540000
[ 2.039690] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.046533] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.053790] usb usb1: Product: DWC OTG Controller
[ 2.058504] usb usb1: Manufacturer: Linux 4.4.167 dwc2_hsotg
[ 2.064190] usb usb1: SerialNumber: ff540000.usb
[ 2.069894] hub 1-0:1.0: USB hub found
[ 2.073765] hub 1-0:1.0: 1 port detected
[ 2.078705] ff580000.usb supply vusb_d not found, using dummy regulator
[ 2.085470] ff580000.usb supply vusb_a not found, using dummy regulator
[ 2.211425] dwc2 ff580000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[ 2.219350] dwc2 ff580000.usb: DWC OTG Controller
[ 2.224159] dwc2 ff580000.usb: new USB bus registered, assigned bus number 2
[ 2.231252] dwc2 ff580000.usb: irq 45, io mem 0xff580000
[ 2.236910] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.243752] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.250980] usb usb2: Product: DWC OTG Controller
[ 2.255721] usb usb2: Manufacturer: Linux 4.4.167 dwc2_hsotg
[ 2.261409] usb usb2: SerialNumber: ff580000.usb
[ 2.267033] hub 2-0:1.0: USB hub found
[ 2.270858] hub 2-0:1.0: 1 port detected
[ 2.277607] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 2.284210] ehci-platform: EHCI generic platform driver
[ 2.289873] ehci-platform ff500000.usb: EHCI Host Controller
[ 2.295970] ehci-platform ff500000.usb: new USB bus registered, assigned bus number 3
[ 2.304095] ehci-platform ff500000.usb: irq 42, io mem 0xff500000
[ 2.451410] usb 1-1: new high-speed USB device number 2 using dwc2
[ 2.471411] ehci-platform ff500000.usb: USB 2.0 started, EHCI 1.00
[ 2.477948] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.484798] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.492058] usb usb3: Product: EHCI Host Controller
[ 2.496941] usb usb3: Manufacturer: Linux 4.4.167 ehci_hcd
[ 2.502460] usb usb3: SerialNumber: ff500000.usb
[ 2.508098] hub 3-0:1.0: USB hub found
[ 2.511969] hub 3-0:1.0: 1 port detected
[ 2.517050] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 2.523374] ohci-platform: OHCI generic platform driver
[ 2.528996] ohci-platform ff520000.usb: Generic Platform OHCI controller
[ 2.536277] ohci-platform ff520000.usb: new USB bus registered, assigned bus number 4
[ 2.544382] ohci-platform ff520000.usb: irq 43, io mem 0xff520000
[ 2.605744] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.612611] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.619840] usb usb4: Product: Generic Platform OHCI controller
[ 2.625806] usb usb4: Manufacturer: Linux 4.4.167 ohci_hcd
[ 2.631301] usb usb4: SerialNumber: ff520000.usb
[ 2.637235] hub 4-0:1.0: USB hub found
[ 2.641061] hub 4-0:1.0: 1 port detected
[ 2.646216] usbcore: registered new interface driver cdc_acm
[ 2.651951] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.660178] usbcore: registered new interface driver cdc_wdm
[ 2.666106] usbcore: registered new interface driver usb-storage
[ 2.672403] usbcore: registered new interface driver usbserial
[ 2.678327] usbcore: registered new interface driver usbserial_generic
[ 2.684973] usbserial: USB Serial support registered for generic
[ 2.691095] usbcore: registered new interface driver ch341
[ 2.696861] usbserial: USB Serial support registered for ch341-uart
[ 2.703555] usbcore: registered new interface driver cp210x
[ 2.709179] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101
[ 2.715943] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.716063] usbserial: USB Serial support registered for cp210x
[ 2.716223] usbcore: registered new interface driver ftdi_sio
[ 2.716282] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.716561] usbcore: registered new interface driver keyspan
[ 2.716619] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 2.716671] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 2.716723] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 2.716775] usbserial: USB Serial support registered for Keyspan 4 port adapter
