大神们看看这个开机LOG,到底是不是MMC的问题, [mmc0] Data transmission error
DDR Version 1.00 20160530
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-10 (Nov 20 2017 - 17:19:35)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 400
SdmmcInit = 2 0
storage init OK!
GetParam
Load FDT from boot image.
power key: bank-0 pin-5
pmic:act8846
can’t find dts node for pwm1
#Boot ver: 2017-11-20#2.30
empty serial no.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
no fuel gauge found
Secure Boot state: 0
kernel @ 0x02000000 (0x006a57c0)
ramdisk @ 0x05bf0000 (0x00146444)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0561bf33 … OK
[ 0.000000] Linux version 3.10.0 (firefly@tchip-server) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #159 SMP PREEMPT Tue Mar 6 18:26:58 CST 2018
[ 0.000000] rockchip_uboot_logo_setup: mem: 0x02000000@0x7dc00000, offset:0x00000000
[ 0.000000] rockchip_uboot_mem_reserve: reserve 0x02000000@0x7dc00000 for uboot logo
[ 0.000000] ion heap(cma): base(0) size(1000000) align(0)
[ 0.000000] cma: CMA: reserved 16 MiB at 7cc00000
[ 0.000000] ion_reserve: cma reserved base 7cc00000 size 16777216
[ 0.000000] cma: CMA: reserved 16 MiB at 1f000000
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1f18000 s13376 r8192 d15296 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523264
[ 0.000000] Kernel command line: vmalloc=496M console=ttyS2 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 root=/dev/block/mtd/by-name/linuxroot rw rootfstype=ext4 init=/sbin/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00002000@0x0039A000(baseparamer),-@0x003BC000(userdata) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2017-11-20_17:19:35
[ 0.000000] allocated 4194304 bytes of page_cgroup
[ 0.000000] Memory: 1993680k/1993680k available, 103472k reserved, 1523712K highmem
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0bac9a0 (11923 kB)
[ 0.000000] .init : 0xc0bad000 - 0xc0c06440 ( 358 kB)
[ 0.000000] .data : 0xc0c08000 - 0xc0d9a1c0 (1609 kB)
[ 0.000000] .bss : 0xc0d9a1c0 - 0xc0ebd73c (1166 kB)
[ 0.000000] rk_clk_tree_init start!
[ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div
[ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error
[ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1
[ 0.000000] rkclk_init_clks: cnt_rate = 29
[ 0.000000] rk3288 set GPLL BW 20 for HDMI!
[ 0.000000] process version: 1
[ 0.000000] channel:0, lkg:26
[ 0.000000] target-temp:80
[ 0.000000] channel:2, lkg:0
[ 0.000000] channel:1, lkg:22
[ 0.493988] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.494004] pid_max: default: 32768 minimum: 301
[ 0.494119] Security Framework initialized
[ 0.494135] SELinux: Initializing.
[ 0.494208] Mount-cache hash table entries: 512
[ 0.494847] Initializing cgroup subsys debug
[ 0.494862] Initializing cgroup subsys memory
[ 0.494888] Initializing cgroup subsys freezer
[ 0.494917] CPU: Testing write buffer coherency: ok
[ 0.495218] /cpus/cpu@0 missing clock-frequency property
[ 0.495231] /cpus/cpu@1 missing clock-frequency property
[ 0.495241] /cpus/cpu@2 missing clock-frequency property
[ 0.495250] /cpus/cpu@3 missing clock-frequency property
[ 0.495298] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.495348] Setting up static identity map for 0xc085e818 - 0xc085e870
[ 0.498432] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x17e3 (version 3.1)
[ 0.572138] CPU1: Booted secondary processor
[ 0.572172] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.591813] CPU2: Booted secondary processor
[ 0.591837] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.611523] CPU3: Booted secondary processor
[ 0.611546] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.611646] Brought up 4 CPUs
[ 0.611675] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.611684] CPU: All CPU(s) started in SVC mode.
[ 0.612419] devtmpfs: initialized
[ 0.616809] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.617897] pinctrl core: initialized pinctrl subsystem
[ 0.618147] regulator-dummy: no parameters
[ 0.632247] NET: Registered protocol family 16
[ 0.634070] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.634384] ion_snapshot: 0x1e9b8000 map to 0xe0907000 and copy to 0xc0e989cc (version 0.1)
[ 0.634623] Registered FIQ tty driver
[ 0.635032] fiq-debugger is disabled in device tree
[ 0.635744] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[ 0.635765] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[ 0.635782] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 0.635799] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[ 0.635897] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 0.635965] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 0.636027] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 0.636088] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 0.636149] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 0.636210] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[ 0.636271] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 0.636334] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[ 0.636401] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 0.636465] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 0.636478] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 0.636490] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 0.636501] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 0.637129] rockchip_interrupts_register:bank_num=7
[ 0.639025] of_get_gpio_init_config:gpio[0] = 136, value = 0
[ 0.639046] of_get_gpio_init_config:gpio[1] = 13, value = 1
[ 0.639112] rockchip_pinctrl_probe:init ok
[ 0.646125] rk_iommu ff900800.iep_mmu: (iep) Enter
[ 0.646223] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.646236] rk_iommu ff900800.iep_mmu: (iep) Initialized
[ 0.646403] rk_iommu ff950800.vip_mmu: (vip) Enter
[ 0.646475] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.646487] rk_iommu ff950800.vip_mmu: (vip) Initialized
[ 0.646646] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[ 0.646724] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.646737] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[ 0.646905] rk_iommu ff940300.vopl_mmu: (vopl) Enter
[ 0.646980] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.646992] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[ 0.647162] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[ 0.647245] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.647257] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[ 0.647426] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[ 0.647499] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.647511] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[ 0.647681] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[ 0.647767] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.647779] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
[ 0.649395] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.649407] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.649984] rk3368_init_rockchip_pmu_ops: could not find pmu dt node
[ 0.650007] DDR DEBUG: version 1.00 20150126
[ 0.650034] DDR DEBUG: Channel a:
[ 0.650042] DDR DEBUG: DDR3 Device
[ 0.650056] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.650065] DDR DEBUG: Channel b:
[ 0.650072] DDR DEBUG: DDR3 Device
[ 0.650084] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.650094] DDR DEBUG: addr=0xda4000
[ 0.650103] DDR DEBUG: stride=9, size=256, halfcap=40000000
[ 0.650112] DDR DEBUG: socAddr[0]=0xda4000, socAddr[1]=0xda4100
[ 0.650121] DDR DEBUG: chAddr[0]=0xda4000, chAddr[1]=0xda4000
[ 0.650133] DDR DEBUG: dtar[0]=0x401b4000, dtar[1]=0x401b4000
[ 0.650187] DDR DEBUG: init success!!! freq=200MHz
[ 0.650195] DDR DEBUG: Channel a:
[ 0.650208] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.650220] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.650233] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.650245] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.650256] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.650266] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.650275] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.650282] DDR DEBUG: Channel b:
[ 0.650293] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.650306] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.650318] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.650330] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.650341] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.650350] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.650358] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.675054] bio: create slab at 0
[ 0.675542] Rockchip hdmi driver version 2.0
[ 0.675542] .
[ 0.676694] SCSI subsystem initialized
[ 0.676855] usbcore: registered new interface driver usbfs
[ 0.676901] usbcore: registered new interface driver hub
[ 0.676989] usbcore: registered new device driver usb
[ 0.681666] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 0.682310] rockchip_i2c ff140000.i2c: i2c-1: Rockchip Ikchip I2C adapter
[ 0.683011] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 0.683446] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 0.683566] media: Linux media interface: v0.10
[ 0.683605] Linux video capture interface: v2.00
[ 0.683659] pps_core: LinuxPPS API ver. 1 registered
[ 0.683669] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.683689] PTP clock support registered
[ 0.683752] i2c-core: driver [bq24296] using legacy suspend method
[ 0.683762] i2c-core: driver [bq24296] using legacy resume method
[ 0.684078] RK29 Watchdog Timer, (c) 2011 Rockchip Electronics
[ 0.684550] ion_drm_heap_create: 0@0
[ 0.684678] Rockchip ion module is successfully loaded (v1.1)
[ 0.684842] Advanced Linux Sound Architecture Driver Initialized.
[ 0.685244] Bluetooth: Core ver 2.16
[ 0.685298] NET: Registered protocol family 31
[ 0.685308] Bluetooth: HCI device and connection manager initialized
[ 0.685323] Bluetooth: HCI socket layer initialized
[ 0.685335] Bluetooth: L2CAP socket layer initialized
[ 0.685365] Bluetooth: SCO socket layer initialized
[ 0.685600] cfg80211: Calling CRDA to update world regulatory domain
[ 0.686287] act8846_i2c_probe,line=898
[ 0.68726act8846_pmic_hold=1
[ 0.687749] act8846_i2c_probe: act8846_pmic_sleep=1
[ 0.687764] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
[ 0.687780] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
[ 0.689853] act_dcdc1: 1200 mV
[ 0.692813] vccio: 3300 mV
[ 0.694676] vdd_logic: 700 ↔ 1500 mV at 1100 mV
[ 0.697633] act_dcdc4: 2000 mV
[ 0.698881] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
[ 0.701182] act_ldo2: 1050 mV
[ 0.703482] act_ldo3: 3300 mV
[ 0.705778] act_ldo4: 3300 mV
[ 0.708069] act_ldo5: 3300 mV
[ 0.710393] act_ldo6: 1100 mV
[ 0.712688] vcc_18: 1800 mV
[ 0.714990] act_ldo8: 1850 mV
[ 0.719723] vdd_arm: 712 ↔ 1500 mV at 1000 mV
[ 0.724420] vdd_gpu: 712 ↔ 1500 mV at 1000 mV
[ 0.725162] rk808_i2c_probe,line=1355
[ 0.726495] The device is not rk808 -11
[ 0.726579] rk808: probe of 0-001b failed with error -11
[ 0.726653] i2c-core: driver [rk818] using legacy suspend method
[ 0.726663] i2c-core: driver [rk818] using legacy resume method
[ 0.728469] Switching to clocksource arch_sys_counter
[ 0.752656] rga: Module initialized.
[ 0.753384] rga2 ff920000.rga: rga ion client create success!
[ 0.753543] rga: Driver loaded succesfully
[ 0.753739] fb disp policy is box
[ 0.753781] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.753793] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.754127] rk-screen rk_screen.8: rockchip screen probe success
[ 0.754389] rk32-lvds rk32-lvds: rk32 lvds driver probe success
[ 0.754744] rk32-edp ff970000.edp: screen is not edp!
[ 0.754764] rk32-edp: probe of ff970000.edp failed with error -22
[ 0.755239] rk3288-lcdc lcdc0: can’t find power_ctr node for lcdc0
[ 0.755451] graphics fb0: rockchip framebuffer registerd:fb0
[ 0.755749] graphics fb1: rockchip framebuffer registerd:fb1
[ 0.755917] graphics fb2: rockchip framebuffer registerd:fb2
[ 0.756084] graphics fb3: rockchip framebuffer registerd:fb3
[ 0.756829] rk3288-lcdc lcdc0: lcdc0: dclk:297000000>>fps:120
[ 0.756843] rk3288-lcdc lcdc0: wakeup from standby!
[ 0.787707] alloc_buffer:ion_phy_addr=0x10000000
[ 0.800527] fb0:phy:10000000>>vir:e0991000>>len:0x1800000
[ 0.814165] rk_iommu ff930300.vopb_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eaa6000
[ 0.814212] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
[ 0.814430] rk3288-lcdc lcdc1: can’t find power_ctr node for lcdc1
[ 0.814442] rk_fb_trsm_ops_get:un supported transmitter:0!
[ 0.814707] graphics fb4: rockchip framebuffer registerd:fb4
[ 0.815047] graphics fb5: rockchip framebuffer registerd:fb5
[ 0.815220] graphics fb6: rockchip framebuffer registerd:fb6
[ 0.815384] graphics fb7: rockchip framebuffer registerd:fb7
[ 0.816208] unknow screen type: 0
[ 0.816225] vop ver:3007236,unsupport output color:1
[ 0.816288] rk3288-lcdc lcdc1: lcdc1: dclk:148500000>>fps:868
[ 0.816301] rk3288-lcdc lcdc1: wakeup from standby!
[ 0.820120] fb4:phy:10000000>>vir:e0991000>>len:0x1800000
[ 0.820136] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu enabled
[ 0.821000] rockchip_set_mux:warning ignore bank num 15
[ 0.821143] rockchip_set_mux:warning ignore bank num 15
[ 0.821262] rockchip_set_mux:warning ignore bank num 15
[ 0.821401] rockchip_set_mux:warning ignore bank num 15
[ 0.821523] rockchip_set_mux:warning ignore bank num 15
[ 0.821638] rockchip_set_mux:warning ignore bank num 15
[ 0.822213] rockchip_set_mux:warning ignore bank num 15
[ 0.822394] rockchip_set_mux:warning ignore bank num 15
[ 0.822953] rockchip_set_mux:warning ignore bank num 15
[ 0.823100] rockchip_set_mux:warning ignore bank num 15
[ 0.823635] rockchip_set_mux:warning ignore bank num 15
[ 0.823787] rockchip_set_mux:warning ignore bank num 15
[ 0.824323] rockchip_set_mux:warning ignore bank num 15
[ 0.824475] rockchip_set_mux:warning ignore bank num 15
[ 0.825579] tc358749_hdmiin_probe!
[ 0.884854] tc358749_hdmiin_probe OK!
[ 0.885323] NET: Registered protocol family 2
[ 0.886025] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.886101] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.886173] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.886231] TCP: reno registered
[ 0.886245] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.886269] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.886464] NET: Registered protocol family 1
[ 0.887101] Unpacking initramfs…
[ 0.958143] Freeing initrd memory: 1304K (c5bf0000 - c5d36000)
[ 0.958981] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 0.959584] vcodec_service: probe device ff9a0000.vpu_service
[ 0.959792] vcodec_service: No reset resource define
[ 0.959962] vcodec_service: ff9a0000.vpu_service: power on
[ 0.960049] vcodec_service: probe device ff9a0000.vpu_service
[ 0.960064] vcodec_service: checking hw id 4831
[ 0.961071] vcodec_service: ff9a0000.vpu_service: power off…
[ 0.961114] vcodec_service: done
[ 0.961123] vcodec_service: init success
[ 0.961187] vcodec_service: probe device ff9c0000.hevc_service
[ 0.961525] vcodec_service: ff9c0000.hevc_service: power on
[ 0.961589] vcodec_service: probe device ff9c0000.hevc_service
[ 0.961603] vcodec_service: checking hw id 6867
[ 0.962194] vcodec_service: ff9c0000.hevc_service: power off…
[ 0.962237] vcodec_service: done
[ 0.962245] vcodec_service: init success
[ 0.962378] rknandbase v1.0 2014-03-31
[ 0.962508] rknand: probe of ff400000.nandc failed with error -1
[ 0.962618] rknand_driver:ret = 0
[ 0.964473] audit: initializing netlink socket (disabled)
[ 0.964518] type=2000 audit(0.460:1): initialized
[ 0.965414] bounce pool size: 64 pages
[ 0.970092] fuse init (API version 7.22)
[ 0.970476] msgmni has been set to 952
[ 0.972374] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.972392] io scheduler noop registered
[ 0.972401] io scheduler deadline registered
[ 0.972497] io scheduler cfq registered (default)
[ 0.973689] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess.
[ 0.974371] IEP Power ON
[ 0.974412] iep ion client create success!
[ 0.974888] rk_iommu ff900800.iep_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eaa1000
[ 0.974900] IEP Power OFF
[ 0.974919] IEP Driver loaded succesfully
[ 0.975019] Module initialized.
[ 0.975864] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 0.975882] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 0.977239] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 0.977256] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.977538] pwm-voltage-regulator pwm_regulator.22: unable to request PWM, trying legacy API
[ 0.977553] pwm-voltage-regulator pwm_regulator.22: unable to request legacy PWM
[ 0.977562] pwm_regulator_probe:error
[ 0.977582] platform pwm_regulator.22: Driver pwm-voltage-regulator requests probe deferral
[ 0.977778] rk_serial.c v1.8 2014-03-04
[ 0.978013] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[ 0.978198] serial ff180000.serial: membase e097e000
[ 0.978367] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1
[ 0.978546] serial ff190000.serial: membase e419c000
[ 0.978688] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
[ 0.980353] console [ttyS2] enabled
[ 0.980528] serial ff690000.serial: membase fed60000
[ 0.980693] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90) is a rk29_serial.3
[ 0.980862] serial ff1b0000.serial: membase e419e000
[ 0.983673] loop: module loaded
[ 0.984035] zram: Created 1 device(s) …
[ 0.984122] i2c-core: driver [mpu6050B1] using legacy suspend method
[ 0.984135] i2c-core: driver [mpu6050B1] using legacy resume method
[ 0.984152] mpu_init: Probe name mpu6050B1
[ 0.984305] ak8963_mod_init: Probe name ak8963_mod
[ 0.985035] SCSI Media Changer driver v0.25
[ 0.985324] dws->regs: e41be000
[ 0.986522] rockchip_spi_probe:num_cs=2,bus_num=0,irq=76,freq=45692308 ok
[ 0.986857] tun: Universal TUN/TAP device driver, 1.6
[ 0.986871] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.986994] vmac_init.
[ 0.987570] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 0.987587] stmmac_probe_config_dt: clock input/output? (input).
[ 0.987600] stmmac_probe_config_dt: TX delay(0x23).
[ 0.987612] stmmac_probe_config_dt: RX delay(0x19).
[ 0.987662] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[ 0.987673] stmmc_pltfr_init:
[ 0.987682] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[ 0.987705] gmac_phy_reset: ERROR: Request pin stmmc_pltfr_init failed.
[ 0.987717] stmmc_pltfr_init: init for RGMII
[ 0.987728] tx delay=0x23
[ 0.987728] rx delay=0x19
[ 0.987744] tx delay=0x23
[ 0.987744] rx delay=0x19
[ 0.988206] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.988218] Normal descriptors
[ 0.988226] Ring mode enabled
[ 0.988238] DMA HW capability register supported
[ 0.988251] RX Checksum Offload Engine supported (type 2)
[ 0.988261] TX Checksum insertion supported
[ 0.988270] Wake-Up On Lan supported
[ 0.988304] Enable RX Mitigation via HW Watchdog Timer
[ 0.988732] PPP generic driver version 2.4.2
[ 0.988888] PPP BSD Compression module registered
[ 0.988901] PPP Deflate Compression module registered
[ 0.988925] PPP MPPE Compression module registered
[ 0.988938] NET: Registered protocol family 24
[ 0.988974] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 0.988988] CSLIP: code copyright 1989 Regents of the University of California.
[ 0.989000] Rockchip WiFi SYS interface (V1.00) …
[ 0.989034] esp_mem_init enter date Oct 9 2017 16:20:34
[ 0.989045] esp_mem_init VERSION [V2.5]
[ 0.989091] esp_mem_init complete
[ 0.989175] usbcore: registered new interface driver catc
[ 0.989215] usbcore: registered new interface driver kaweth
[ 0.989229] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 0.989274] usbcore: registered new interface driver pegasus
[ 0.989314] usbcore: registered new interface driver rtl8150
[ 0.989353] usbcore: registered new interface driver r8152
[ 0.989365] hso: drivers/net/usb/hso.c: Option Wireless
[ 0.989435] usbcore: registered new interface driver hso
[ 0.989479] usbcore: registered new interface driver asix
[ 0.989519] usbcore: registered new interface driver ax88179_178a
[ 0.989558] usbcore: registered new interface driver cdc_ether
[ 0.989596] usbcore: registered new interface driver cdc_eem
[ 0.989633] usbcore: registered new interface driver dm9601
[ 0.989677] usbcore: registered new interface driver dm9620
[ 0.989725] usbcore: registered new interface driver smsc75xx
[ 0.989772] usbcore: registered new interface driver smsc95xx
[ 0.989811] usbcore: registered new interface driver gl620a
[ 0.989850] usbcore: registered new interface driver net1080
[ 0.989889] usbcore: registered new interface driver plusb
[ 0.989932] usbcore: registered new interface driver rndis_host
[ 0.989972] usbcore: registered new interface driver cdc_subset
[ 0.990009] usbcore: registered new interface driver zaurus
[ 0.990050] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 0.990114] usbcore: registered new interface driver int51x1
[ 0.990155] usbcore: registered new interface driver kalmia
[ 0.990194] usbcore: registered new interface driver ipheth
[ 0.990245] usbcore: registered new interface driver sierra_net
[ 0.990288] usbcore: registered new interface driver cx82310_eth
[ 0.990336] usbcore: registered new interface driver cdc_ncm
[ 0.990375] usbcore: registered new interface driver qmi_wwan
[ 0.990415] usbcore: registered new interface driver cdc_mbim
[ 0.990428] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.992879] EHCI: ehci_rk_probe e4240000 e4240010
[ 0.992898] rockchip_ehci_host ff500000.usb: EHCI Host Controller
[ 0.992932] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[ 0.993247] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
[ 1.004080] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00
[ 1.004163] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.004181] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.004196] usb usb1: Product: EHCI Host Controller
[ 1.004209] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 1.004223] usb usb1: SerialNumber: ff500000.usb
[ 1.004656] hub 1-0:1.0: USB hub found
[ 1.004681] hub 1-0:1.0: 1 port detected
[ 1.004848] EHCI: ehci_rk_probe ok
[ 1.004954] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.005245] usbcore: registered new interface driver cdc_acm
[ 1.005259] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.005321] usbcore: registered new interface driver usblp
[ 1.005366] usbcore: registered new interface driver cdc_wdm
[ 1.005430] usbcore: registered new interface driver usb-storage
[ 1.005469] usbcore: registered new interface driver ums-alauda
[ 1.005508] usbcore: registered new interface driver ums-cypress
[ 1.005547] usbcore: registered new interface driver ums-datafab
[ 1.005585] usbcore: registered new interface driver ums_eneub6250
[ 1.005624] usbcore: registered new interface driver ums-freecom
[ 1.005670] usbcore: registered new interface driver ums-isd200
[ 1.005710] usbcore: registered new interface driver ums-jumpshot
[ 1.005749] usbcore: registered new interface driver ums-karma
[ 1.005789] usbcore: registered new interface driver ums-onetouch
[ 1.005832] usbcore: registered new interface driver ums-sddr09
[ 1.005872] usbcore: registered new interface driver ums-sddr55
[ 1.005911] usbcore: registered new interface driver ums-usbat
[ 1.006001] usbcore: registered new interface driver usbserial
[ 1.006050] usbcore: registered new interface driver usbserial_generic
[ 1.006084] usbserial: USB Serial support registered for generic
[ 1.006125] usbcore: registered new interface driver ch341
[ 1.006157] usbserial: USB Serial support registered for ch341-uart
[ 1.006199] usbcore: registered new interface driver cp210x
[ 1.006229] usbserial: USB Serial support registered for cp210x
[ 1.006274] usbcore: registered new interface driver option
[ 1.006305] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.006375] usbcore: registered new interface driver pl2303
[ 1.006406] usbserial: USB Serial support registered for pl2303
[ 1.006459] usbcore: registered new interface driver trancevibrator
[ 1.006471] usb20_otg: version 3.10a 21-DEC-2012
[ 1.006899] e4280040
[ 1.006913] Core Release: 3.10a
[ 1.006925] Setting default values for core params
[ 1.007070] Using Buffer DMA mode
[ 1.007082] Periodic Transfer Interrupt Enhancement - disabled
[ 1.007092] Multiprocessor Interrupt Enhancement - disabled
[ 1.007104] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.007114] ^^^^^^^^^^^^^^^^^Device Mode
[ 1.007129] Dedicated Tx FIFOs mode
[ 1.007148] pcd_init otg_dev = ddfa4380
[ 1.007309] usb20_otg ff580000.usb: DWC OTG Controller
[ 1.007338] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
[ 1.007370] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 1.007427] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.007443] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.007457] usb usb2: Product: DWC OTG Controller
[ 1.007470] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 1.007483] usb usb2: SerialNumber: ff580000.usb
[ 1.007931] hub 2-0:1.0: USB hub found
[ 1.007954] hub 2-0:1.0: 1 port detected
[ 1.011152] usb20_host: version 3.10a 21-DEC-2012
[ 1.013668] e4300040
[ 1.013681] Core Release: 3.10a
[ 1.013697] Setting default values for core params
[ 1.013807] Using Buffer DMA mode
[ 1.013819] Periodic Transfer Interrupt Enhancement - disabled
[ 1.013830] Multiprocessor Interrupt Enhancement - disabled
[ 1.013841] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.013851] ^^^^^^^^^^^^^^^^^^Host Mode
[ 1.013909] usb20_host ff540000.usb: DWC OTG Controller
[ 1.013938] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
[ 1.013979] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[ 1.014072] Init: Power Port (0)
[ 1.014129] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.014146] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.014160] usb usb3: Product: DWC OTG Controller
[ 1.014173] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 1.014186] usb usb3: SerialNumber: ff540000.usb
[ 1.014604] hub 3-0:1.0: USB hub found
[ 1.014625] hub 3-0:1.0: 1 port detected
[ 1.015371] usbcore: registered new interface driver xpad
[ 1.015432] usbcore: registered new interface driver usb_acecad
[ 1.015481] usbcore: registered new interface driver aiptek
[ 1.015528] usbcore: registered new interface driver gtco
[ 1.015577] usbcore: registered new interface driver hanwang
[ 1.015624] usbcore: registered new interface driver kbtab
[ 1.015679] usbcore: registered new interface driver wacom
[ 1.015690] ==gsl_ts_init==
[ 1.015762] ret=0
[ 1.016038] sensor_register_slave:mma8452,id=17
[ 1.016052] sensor_register_slave:gs_mc3230,id=23
[ 1.016062] gsensor_init
[ 1.016072] sensor_register_slave:mpu6880_acc,id=24
[ 1.016083] sensor_register_slave:mpu6500_acc,id=25
[ 1.016095] sensor_register_slave:cm3217,id=48
[ 1.016106] sensor_register_slave:cm3218,id=49
[ 1.016327] .. rk pwm remotectl v1.1 init
[ 1.016564] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
[ 1.019030] rtc_hym8563 0-0051: clock/calendar information is no longer guaranteed
[ 1.022008] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 1.022610] i2c /dev entries driver
[ 1.023287] IR NEC protocol handler initialized
[ 1.023301] IR RC5(x) protocol handler initialized
[ 1.023312] IR RC6 protocol handler initialized
[ 1.023322] IR JVC protocol handler initialized
[ 1.023331] IR Sony protocol handler initialized
[ 1.023341] IR RC5 (streamzap) protocol handler initialized
[ 1.023352] IR SANYO protocol handler initialized
[ 1.023362] IR MCE Keyboard/mouse protocol handler initialized
[ 1.023513] usbcore: registered new interface driver uvcvideo
[ 1.023525] USB Video Class driver (1.1.1)
[ 1.023538] CamSys driver version: v0.32.0, CamSys head file version: v0.11.0
[ 1.025028] D1:camsys_platform_probe(1300): 1-gpios-cifpower: gpio=236
[ 1.025052] D1:camsys_platform_probe(1303): gpios-cifpower: gpio_request
[ 1.025074] D1:camsys_platform_probe(1305): 1-gpios-cifpower: gpio_request=0
[ 1.025097] D1:camsys_platform_probe(1314): gpios-cifpower: 236 high
[ 1.025123] D1:camsys_platform_probe(1328): gpios-dvppower: 11
[ 1.025153] D1:camsys_platform_probe(1334): gpios-dvppower: 11 high
[ 1.025191] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288
[ 1.025191]
[ 1.025265] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 1.025416] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe41f8000 size: 0x4000)
[ 1.026058] D1:camsys_platform_probe(1446): ff910000.isp memory:
[ 1.026075] D1:camsys_platform_probe(1456): Register memory (phy: 0xff910000 vir: 0xe4220000 size: 0x10000)
[ 1.026091] D1:camsys_platform_probe(1451): I2c memory (phy: 0x1dfac000 vir: 0xddfac000 size: 0x1000)
[ 1.026106] D1:camsys_init_ext_fsh_module(20): init external flash module
[ 1.026118] D1:camsys_platform_probe(1471): Probe ff910000.isp device success
[ 1.026519] not find test_power_init dev node
[ 1.026578] i2c-core: driver [bq27320] using legacy suspend method
[ 1.026591] i2c-core: driver [bq27320] using legacy resume method
[ 1.026934] rockchip_temp_probe,line=364
[ 1.082784] tsadc ff280000.tsadc: initialized
[ 1.083170] device-mapper: uevent: version 1.0.3
[ 1.083416] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 1.083681] Bluetooth: HCI UART driver ver 2.2
[ 1.083697] Bluetooth: HCI H4 protocol initialized
[ 1.083708] Bluetooth: HCILL protocol initialized
[ 1.083719] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21
[ 1.083731] rtk_btusb: Register usb char device interface for BT driver
[ 1.083925] usbcore: registered new interface driver rtk_btusb
[ 1.084556] DVFS WARNING: clk_enable_dvfs: clk(aclk_vio1) freq table all value are smaller than default(594000), use default, just enable dvfs
[ 1.088594] cpufreq version 1.0, suspend freq 1200 MHz
[ 1.088792] cpuidle: using governor ladder
[ 1.088805] cpuidle: using governor menu
[ 1.088841] Synopsys Designware Multimedia Card Interface Driver
[ 1.088853] MHSC version = Ver 2.00 2015-06-10
[ 1.089162] dw cru_regsbase addr 0x1d8.
[ 1.089175] dw cru_reset_offset val 3.
[ 1.089189] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[ 1.089232] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc
[ 1.106567] Using Buffer DMA mode
[ 1.106582] Periodic Transfer Interrupt Enhancement - disabled
[ 1.106593] Multiprocessor Interrupt Enhancement - disabled
[ 1.106605] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.106616] ^^^^^^^^^^^^^^^^^^Host Mode
[ 1.106741] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
[ 1.106917] dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
[ 1.107046] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.122162] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.141849] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 1.141862] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
[ 1.141874] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[ 1.142107] dw cru_regsbase addr 0x1d8.
[ 1.142116] dw cru_reset_offset val 0.
[ 1.142126] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[ 1.142160] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc
[ 1.142956] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
[ 1.143057] dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
[ 1.143480] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
[ 1.143546] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.151795] Init: Power Port (0)
[ 1.151805] rk_battery_charger_detect_cb , battery_charger_detect 5
[ 1.161510] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.173962] mmc0: BKOPS_EN bit is not set
[ 1.175833] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0]
[ 1.178110] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 1.178134] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 1.178158] [mmc0] tuning regsbase addr 0x218.
[ 1.178883] [mmc0] Data transmission error !!! MINTSTS: [0x00002004]
[ 1.178893] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 1.178915] dwmmc_rockchip ff0f0000.rksdmmc: data FIFO error (status=00002004)
[ 1.178933] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-5
[ 1.178957] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 1.178965] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 1.178993] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 1.179006] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-259 (24 len)
[ 1.179017] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-259 (24 len)
[ 1.179027] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 1.179068] mmc0: new HS200 MMC card at address 0001
[ 1.179346] mmcblk0: mmc0:0001 AJTD4R 14.5 GiB
[ 1.179455] mmcblk0rpmb: mmc0:0001 AJTD4R partition 3 4.00 MiB
[ 1.179793] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 1.179804] misc: 0x000800000 – 0x000c00000 (4 MB)
[ 1.179813] resource: 0x000c00000 – 0x001c00000 (16 MB)
[ 1.179822] kernel: 0x001c00000 – 0x002c00000 (16 MB)
[ 1.179830] boot: 0x002c00000 – 0x004c00000 (32 MB)
[ 1.179840] recovery: 0x004c00000 – 0x006c00000 (32 MB)
[ 1.179848] backup: 0x006c00000 – 0x00a000000 (52 MB)
[ 1.179857] cache: 0x00a000000 – 0x012000000 (128 MB)
[ 1.179865] kpanic: 0x012000000 – 0x012400000 (4 MB)
[ 1.179873] system: 0x012400000 – 0x072400000 (1536 MB)
[ 1.179882] metadata: 0x072400000 – 0x073400000 (16 MB)
[ 1.179891] baseparamer: 0x073400000 – 0x073800000 (4 MB)
[ 1.179899] userdata: 0x077800000 – 0x3a3a00000 (12994 MB)
[ 1.179922] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13[ 1.181263] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
[ 1.181276] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
[ 1.181593] dw cru_regsbase addr 0x1d8.
[ 1.181602] dw cru_reset_offset val 1.
[ 1.181612] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[ 1.181649] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc
[ 1.182456] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
[ 1.182584] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
[ 1.182848] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.200869] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.220557] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.220568] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
[ 1.220581] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[ 1.220883] leds-gpio leds.27: pins are not configured from the driver
[ 1.221158] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.222587] usbcore: registered new interface driver usbhid
[ 1.222597] usbhid: USB HID core driver
[ 1.222704] ashmem: initialized
[ 1.222818] logger: created 256K log ‘log_main’
[ 1.222915] logger: created 256K log ‘log_events’
[ 1.223009] logger: created 256K log ‘log_radio’
[ 1.223108] logger: created 256K log ‘log_system’
[ 1.224224] input: rk29-keypad as /devices/ff100000.adc/key.29/input/input1
[ 1.225088] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ff890000.rockchip-i2s; cannot claim for 2-0010
[ 1.225104] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
[ 1.225116] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl
[ 1.225128] ES8323 2-0010: Error applying setting, reverse things back
[ 1.225184] jp es8323_line_det_gpio:79
[ 1.225438] es8323 probe i2c recv ok
[ 1.226372] rockchip-spdif ff880000.rockchip-spdif: spdif ready.
[ 1.226947] es8323_probe
[ 1.227053] es8323_probe:register ISR (irq=194)
[ 1.712539] line_detect_do_switch Exit line in mode
[ 1.860495] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → NULL → Left Line Mux
[ 1.860507] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → NULL → Left Line Mux
[ 1.860518] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → NULL → Left Line Mux
[ 1.860526] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → NULL → Left Line Mux
[ 1.860535] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → NULL → Left Line Mux
[ 1.860544] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → NULL → Left Line Mux
[ 1.860553] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → NULL → Right Line Mux
[ 1.860562] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → NULL → Right Line Mux
[ 1.860571] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → NULL → Right Line Mux
[ 1.860580] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → NULL → Right Line Mux
[ 1.860589] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → NULL → Right Line Mux
[ 1.860596] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → NULL → Right Line Mux
[ 1.860606] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left PGA Mux
[ 1.860615] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left PGA Mux
[ 1.860624] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left PGA Mux
[ 1.860632] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left PGA Mux
[ 1.860641] ES8323 2-0010: ASoC: no dapm match for Differential Mux → LAMP → Left PGA Mux
[ 1.860648] ES8323 2-0010: ASoC: Failed to add route Differential Mux → LAMP → Left PGA Mux
[ 1.860658] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right PGA Mux
[ 1.860665] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right PGA Mux
[ 1.860674] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right PGA Mux
[ 1.860683] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right PGA Mux
[ 1.860692] ES8323 2-0010: ASoC: no dapm match for Differential Mux → RAMP → Right PGA Mux
[ 1.860700] ES8323 2-0010: ASoC: Failed to add route Differential Mux → RAMP → Right PGA Mux
[ 1.860710] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Differential Mux
[ 1.860718] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Differential Mux
[ 1.860728] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Differential Mux
[ 1.860736] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Differential Mux
[ 1.860744] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Differential Mux
[ 1.860752] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Differential Mux
[ 1.860761] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Differential Mux
[ 1.860768] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Differential Mux
[ 1.860788] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left Line Mux
[ 1.860796] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left Line Mux
[ 1.860804] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left Line Mux
[ 1.860812] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left Line Mux
[ 1.860821] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → LAMP → Left Line Mux
[ 1.860829] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → LAMP → Left Line Mux
[ 1.860838] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right Line Mux
[ 1.860846] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right Line Mux
[ 1.860854] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right Line Mux
[ 1.860862] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right Line Mux
[ 1.860870] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → RAMP → Right Line Mux
[ 1.860878] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → RAMP → Right Line Mux
[ 1.861021] ES8323 2-0010: ASoC: mux Right Line Mux has no paths
[ 1.861032] ES8323 2-0010: ASoC: mux Left Line Mux has no paths
[ 1.861042] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths
[ 1.861052] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths
[ 1.861084] ES8323 2-0010: ASoC: mux Differential Mux has no paths
[ 1.867430] rockchip-es8323 rockchip-es8323.26: ES8323 HiFi ↔ ff890000.rockchip-i2s mapping ok
[ 1.867825] input: RK_ES8323 Headphone Jack as /devices/rockchip-es8323.26/sound/card0/input2
[ 1.868240] u32 classifier
[ 1.868247] Actions configured
[ 1.868258] Netfilter messages via NETLINK v0.30.
[ 1.868311] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.868598] ctnetlink v0.93: registering with nfnetlink.
[ 1.868658] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 1.868666] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 1.868887] xt_time: kernel timezone is -0000
[ 1.869058] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.869176] arp_tables: (C) 2002 David S. Miller
[ 1.869213] TCP: cubic registered
[ 1.869220] Initializing XFRM netlink socket
[ 1.869400] NET: Registered protocol family 10
[ 1.869846] mip6: Mobile IPv6
[ 1.869869] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.870037] sit: IPv6 over IPv4 tunneling driver
[ 1.870316] NET: Registered protocol family 17
[ 1.870340] NET: Registered protocol family 15
[ 1.870393] Bridge firewalling registered
[ 1.870404] Ebtables v2.0 registered
[ 1.870564] Bluetooth: RFCOMM TTY layer initialized
[ 1.870589] Bluetooth: RFCOMM socket layer initialized
[ 1.870596] Bluetooth: RFCOMM ver 1.11
[ 1.870602] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.870608] Bluetooth: BNEP filters: protocol multicast
[ 1.870617] Bluetooth: BNEP socket layer initialized
[ 1.870624] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.870633] Bluetooth: HIDP socket layer initialized
[ 1.870658] l2tp_core: L2TP core driver, V2.0
[ 1.870669] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.870676] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.870876] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.870886] [WLAN_RFKILL]: can’t find rockchip,grf property
[ 1.870893] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[ 1.870901] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.870907] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 1.870916] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.870936] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
[ 1.870955] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
[ 1.870962] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.870988] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
[ 1.870995] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.871029] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.871160] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
[ 1.871181] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
[ 1.871193] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
[ 1.871206] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
[ 1.871246] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.871336] [BT_RFKILL]: ** disable irq
[ 1.871410] [BT_RFKILL]: ap6335 device registered.
[ 1.872088] rk3288_init_suspend
[ 1.872099] rk3288_suspend_init enter
[ 1.872310] rk3288_suspend_init: pm_ctrbits =200007
[ 1.872342] gpio_get_dts_info suspend:4
[ 1.872348] gpio_get_dts_info resume:4
[ 1.872354] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 1.872379] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 1.872506] clks_gating_suspend_init:clkgt info ok
[ 1.872584] Registering SWP/SWPB emulation handler
[ 1.872595] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 0x02000000@0x7dc00000
[ 1.875103] ddrfreq: verion 1.2 20140526
[ 1.875117] ddrfreq: normal 528MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 528MHz
[ 1.875124] ddrfreq: auto-freq=0
[ 1.875129] ddrfreq: auto-freq-table[0] 240MHz
[ 1.875135] ddrfreq: auto-freq-table[1] 324MHz
[ 1.875140] ddrfreq: auto-freq-table[2] 456MHz
[ 1.875146] ddrfreq: auto-freq-table[3] 528MHz
[ 1.880637] regulator-dummy: disabling
[ 1.880904] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max[ 2.048385] wk2xxx_serial_init()
[ 2.048393] wk2xxx_request_port
[ 2.048400] ttysWK0 at I/O 0x1 (irq = 197) is a wk2xxx
[ 2.048496] uart_add_one_port success for line i:= 0 with right 0
[ 2.048503] wk2xxx_request_port
[ 2.048509] ttysWK1 at I/O 0x2 (irq = 197) is a wk2xxx
[ 2.048593] uart_add_one_port success for line i:= 1 with right 0
[ 2.048599] wk2xxx_request_port
[ 2.048605] ttysWK2 at I/O 0x3 (irq = 197) is a wk2xxx
[ 2.048682] uart_add_one_port success for line i:= 2 with right 0
[ 2.048689] wk2xxx_request_port
[ 2.048695] ttysWK3 at I/O 0x4 (irq = 197) is a wk2xxx
[ 2.048771] uart_add_one_port success for line i:= 3 with right 0
[ 2.048777] uart_add_one_port = 0x0
[ 2.048798] register spi return v = :0
[ 2.048805] =======================================================
[ 2.048811] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 2.048816] =======================================================
[ 2.048821] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init.
[ 2.048875] dhd_module_init: in
[ 2.048882] ======== bcm_wlan_set_plat_data ========
[ 2.048887] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 2.048903] host_oob_irq: 198 [ 2.048908] host_oob_irq_flags=4
[ 2.048912] dhd_wifi_platform_load: Enter
[ 2.048925] Power-up adapter ‘DHD generic adapter’
[ 2.048928] pcd_pullup, is_on 0
[ 2.048938] WARN::dwc_otg_handle_mode_mismatch_intr:69: Mode Mismatch Interrupt: currently in Host mode
[ 2.048938]
[ 2.048955] wifi_platform_set_power = 1
[ 2.048961] ======== PULL WL_REG_ON HIGH! ========
[ 2.048966] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 2.048972] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
[ 2.048977] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 2.048987] file system registered
[ 2.049507] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 2.049515] android_usb gadget: Number of LUNs=2
[ 2.049523] lun0: LUN: removable file: (no medium)
[ 2.049528] lun1: LUN: removable file: (no medium)
[ 2.049668] android_usb gadget: android_usb ready
[ 2.049765] i2c i2c-4: sensor_probe: gs_mma8452,de016200
[ 2.049796] sensor_chip_init:gs_mma8452:devid=0x0,ops=0xc0d1f79c
[ 2.051500] input: gsensor as /devices/ff160000.i2c/i2c-4/4-001d/input/input3
[ 2.051735] sensor_misc_device_register:miscdevice: mma8452_daemon
[ 2.051744] sensor_probe:initialized ok,sensor name:mma8452,type:2,id=17
[ 2.051744]
[ 2.051774] sensor_init: Probe name sensors
[ 2.051788] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 2.052313] rtc_hym8563 0-0051: setting system clock to 2011-01-01 12:00:01 UTC (1293883201)
[ 2.058399] rockchip-spdif-card rockchip-spdif-card.25: rk-hdmi-spdif-hifi ↔ ff880000.rockchip-spdif mapping ok
[ 2.059194] ret 1024
[ 2.059555] usbcore: registered new interface driver snd-usb-audio
[ 2.059563] ALSA device list:
[ 2.059568] #0: RK_ES8323
[ 2.059573] #1: RK-SPDIF-CARD
[ 2.059993] Freeing unused kernel memory: 356K (c0bad000 - c0c06000)
[ 2.155344] [WLAN_RFKILL]: wifi turn on power. 156
[ 2.276633] type=1403 audit(1293883201.720:2): policy loaded auid=4294967295 ses=4294967295
[ 2.303663] init: invalid gid ‘trace’
[ 2.361983] wifi_platform_bus_enumerate device present 1
[ 2.361999] ======== Card detection to detect SDIO card! ========
[ 2.362010] mmc2:mmc host rescan start!
[ 2.412144] init: /dev/hw_random not found
[ 2.412196] keychord: using input dev ff680000.pwm for fevent
[ 2.412210] keychord: using input dev rk29-keypad for fevent
[ 2.416521] init: /dev/hw_random not found
[ 2.417337] fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
[ 2.418052] resize2fs: resize2fs 1.42.9 (28-Dec-2013)resize2fs: The filesystem is already 393216 blocks long. Nothing to do!resize2fs:
[ 2.420494] EXT4-fs (mmcblk0p10): Ignoring removed nomblk_io_submit option
[ 2.424205] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 2.424290] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/system,/system,ext4)=0
[ 2.425023] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
[ 2.429871] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.429914] e2fsck: system: clean, 1889/85248 files, 116244/393216 blocks
[ 2.433349] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 2.433415] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/system,target=/system,type=ext4)=0
[ 2.440151] EXT4-fs (mmcblk0p8): recovery complete
[ 2.440588] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.440640] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/cache,target=/cache,type=ext4)=0
[ 2.441003] EXT4-fs (mmcblk0p11): Ignoring removed nomblk_io_submit option
[ 2.444466] EXT4-fs (mmcblk0p11): recovery complete
[ 2.444486] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 2.444542] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,/metadata,ext4)=0
[ 2.445234] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata
[ 2.449450] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.449487] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata: clean, 11/1024 files, 1102/4096 blocks
[ 2.453385] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.453459] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,target=/metadata,type=ext4)=0
[ 2.453505] fs_mgr: Running /system/bin/fsck.f2fs -f /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
[ 2.454365] fsck.f2fs: executing /system/bin/fsck.f2fs failed: No such file or directory
[ 2.454403] fsck.f2fs: fsck.f2fs terminated by exit(255)
[ 2.454653] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=f2fs)=-1
[ 2.454927] EXT4-fs (mmcblk0p13): Ignoring removed nomblk_io_submit option
[ 2.520984] EXT4-fs (mmcblk0p13): recovery complete
[ 2.521353] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 2.521431] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,/data,ext4)=0
[ 2.523002] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
[ 2.538046] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.538082] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata: clean, 515/832320 files, 115616/3326464 blocks
[ 2.542104] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard,errors=panic
[ 2.542172] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=ext4)=0
[ 2.542193] fs_mgr: mount_with_alternatives(): Mounted /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata on /data with fs_type=ext4 instead of f2fs
[ 2.556252] arm_release_ver of this mali_ko is ‘r6p0-02rel0’, rk_ko_ver is ‘13’, built at ‘09:15:10’, on ‘Oct 22 2015’.
[ 2.556330] mali ffa30000.gpu: Continuing without Mali clock control
[ 2.556371] mali pd enabled
[ 2.556384] clk enabled
[ 2.556396] MALI_DVFS_STEP = 4, div_dvfs = 10
[ 2.556407] mali_dvfs_infotbl[0].clock=198000,min_threshold=0,max_threshold=70
[ 2.556417] mali_dvfs_infotbl[1].clock=297000,min_threshold=70,max_threshold=80
[ 2.556426] mali_dvfs_infotbl[2].clock=417000,min_threshold=80,max_threshold=90
[ 2.556437] mali_dvfs_infotbl[3].clock=480000,min_threshold=94,max_threshold=100
[ 2.556529] turn on mali power
[ 2.556542] kbase_platform_rk_init,register_reboot_notifier
[ 2.556584] hrtimer: interrupt took 11375 ns
[ 2.556680] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
[ 2.557443] mali ffa30000.gpu: Probed as mali0
[ 2.558437] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 2.559063] rk29_ipp: version magic '3.0.36+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 2.559654] rk29_ipp: version magic '3.0.101+ SMP preempt mod_unload ARMv7 ’ should be ‘3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 2.560393] zram0: detected capacity change from 0 to 533413888
[ 2.578461] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2]
[ 2.606496] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
[ 2.613285] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.614832] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.616363] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.619121] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.622463] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
[ 2.639375] EXT4-fs (mmcblk0p13): Unrecognized mount option “background_gc=on” or missing value
[ 2.646828] drmboot: module license ‘unspecified’ taints kernel.
[ 2.646850] Disabling lock debugging due to kernel taint
[ 2.647068] drm init, 20140910
[ 2.647560] drm init ok
[ 2.675049] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 2.675075] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
[ 2.675137] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=4bits.[mmc2]
[ 2.676755] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 2.676781] mmc2: new high speed SDIO card at address 0001
[ 2.692910] bcmsdh_register: register client driver
[ 2.692987] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2.693065] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 2.693076] bus num (host idx)=2, slot num (rca)=1
[ 2.693085] found adapter info ‘DHD generic adapter’
[ 2.693338] F1 signature read @0x18000000=0x15264345
[ 2.695108] F1 signature OK, socitype:0x1 chip:0x4345 rev:0x6 pkg:0x2
[ 2.695448] DHD: dongle ram size is set to 819200(orig 819200) at 0x198000
[ 2.695495] wifi_platform_get_mac_addr
[ 2.695506] ======== bcm_wlan_get_mac_address ========
[ 2.695514] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
[ 2.695525] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
[ 2.695533] [WLAN_RFKILL]: This mac address is not valid, ignored…
[ 2.695545] dhd_conf_set_chiprev: chip=0x4345, chiprev=6
[ 2.695589] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmware/config.txt
[ 2.695864] wl_create_event_handler(): thread:wl_event_handler:9a started
[ 2.695869] tsk Enter, tsk = 0xdd40149c
[ 2.695993] dhd_attach(): thread:dhd_watchdog_thread:9b started
[ 2.696041] dhd_attach(): thread:dhd_dpc:9c started
[ 2.696053] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
[ 2.696103] dhd_attach(): thread:dhd_rxf:9d started
[ 2.696117] dhd_deferred_work_init: work queue initialized
[ 2.696224] dhdsdio_probe_init: set use_rxchain 1 from config.txt
[ 2.701292] Dongle Host Driver, version 1.201.59.5 (r506368)
[ 2.701292] Compiled in drivers/net/wireless/bcmdhd on Oct 9 2017 at 16:20:44
[ 2.701607] Register interface [wlan0] MAC: cc:4b:73:77:2d:14
[ 2.701607]
[ 2.701627] dhd_prot_ioctl : bus is down. we have nothing to do
[ 2.701667] bcmsdh_oob_intr_unregister: Enter
[ 2.701678] bcmsdh_oob_intr_unregister: irq is not registered
[ 2.701690] dhd_txglom_enable: enable 0
[ 2.701698] dhd_bus_devreset: WLAN OFF DONE
[ 2.701731] wifi_platform_set_power = 0
[ 2.701741] ======== PULL WL_REG_ON LOW! ========
[ 2.701750] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 2.804767] [WLAN_RFKILL]: wifi shut off power.
[ 2.804780] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
[ 2.804788] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 2.804837] dhd_module_init: Exit err=0
[ 2.885967] bat_cap: oldcap path is /sys/devices/ff100000.adc
[ 2.886018] bat_cap: oldcap_path no exist
[ 2.886169] binder: 162:162 transaction failed 29189, size 0-0
[ 2.886728] init: Warning! Service displayd needs a SELinux domain defined; please fix!
[ 2.890342] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 2.890372] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
[ 2.890599] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
[ 2.891099] rtk_btusb: btchr_open: BT usb char device is opening
[ 2.891114] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 2.891132] rtk_btusb: btchr_open: BT usb char device is opening
[ 2.891143] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 2.891166] rtk_btusb: btchr_open: BT usb char device is opening
[ 2.891176] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 2.891192] rtk_btusb: btchr_open: BT usb char device is opening
[ 2.891202] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 2.900358] init: cannot find ‘/system/bin/debuggerd64’, disabling ‘debuggerd64’
[ 2.901890] init: cannot find ‘/system/bin/install-recovery.sh’, disabling ‘flash_recovery’
[ 2.902323] init: cannot find ‘/system/bin/bplus_helper’, disabling ‘bplus_helper’
[ 2.902518] init: Warning! Service drmservice needs a SELinux domain defined; please fix!
[ 2.981913] EHCI: rk_ehci_hcd_enable, disable host controller
[ 2.991741] dwc_otg_hcd_enable, enable host controller
[ 3.095106] Using Buffer DMA mode
[ 3.095117] Periodic Transfer Interrupt Enhancement - disabled
[ 3.095122] Multiprocessor Interrupt Enhancement - disabled
[ 3.095128] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.095134] ^^^^^^^^^^^^^^^^^^Host Mode
[ 3.139429] Init: Power Port (0)
[ 3.233431] logd.auditd: start
[ 3.273573] RKNAND_GET_SN_SECTOR
[ 3.273586] return ret = 0
[ 3.296289] init: Warning! Service daemonsu needs a SELinux domain defined; please fix!
[ 3.298588] RKNAND_GET_DRM_KEY
[ 3.298597] return ret = 0
[ 3.405074] Indeed it is in host mode hprt0 = 00021501
[ 3.582184] usb 3-1: new high-speed USB device number 2 using usb20_host
[ 3.582263] Indeed it is in host mode hprt0 = 00001101
[ 3.779186] usb 3-1: New USB device found, idVendor=1a40, idProduct=0201
[ 3.779199] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.779207] usb 3-1: Product: USB 2.0 Hub [MTT]
[ 3.779630] hub 3-1:1.0: USB hub found
[ 3.779693] hub 3-1:1.0: 7 ports detected
[ 3.793525] avc: denied { set } for property=telephony.lteOnCdmaDevice scontext=u:r:rild:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service
[ 3.800011] android_usb: already disabled
[ 3.803122] read descriptors
[ 3.803136] read strings
[ 3.803150] mtp_bind_config
[ 3.803172] pcd_pullup, is_on 1
[ 3.870736] healthd: No charger supplies found
[ 3.870751] healthd: No battery devices found
[ 3.883685] rk3288-lcdc lcdc0: blank mode:0
[ 4.217662] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 4.217676] [mmc0] Data transmission error, need to try retuning 1.
[ 4.217717] [mmc0] tuning regsbase addr 0x218.
[ 4.218467] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 4.218475] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 4.218504] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 4.218543] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 4.218553] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-259 (24 len)
[ 4.218561] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-259 (24 len)
[ 4.218569] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 4.218592] need_retune:1,brq->retune_retry_done:0.
[ 4.218598] mmcblk0: retrying because a re-tune was needed
[ 4.289805] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 4.289817] [mmc0] Data transmission error, need to try retuning 1.
[ 4.289826] [mmc0] Data transmission error !!! MINTSTS: [0x00008088]
[ 4.289833] [mmc0] Data transmission error, need to try retuning 1.
[ 4.289860] [mmc0] tuning regsbase addr 0x218.
[ 4.290578] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 4.290585] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 4.290642] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 4.290680] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 4.290690] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-259 (24 len)
[ 4.290698] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-259 (24 len)
[ 4.290705] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 4.290728] need_retune:1,brq->retune_retry_done:0.
[ 4.290734] mmcblk0: retrying because a re-tune was needed
[ 4.371668] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 4.371679] [mmc0] Data transmission error, need to try retuning 1.
[ 4.371704] [mmc0] tuning regsbase addr 0x218.
[ 4.372469] [mmc0] Data transmission error !!! MINTSTS: [0x00000084]
[ 4.372475] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 4.372503] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 4.372538] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 4.372548] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-259 (24 len)
[ 4.372555] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-259 (24 len)
[ 4.372562] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 4.372581] need_retune:1,brq->retune_retry_done:0.
[ 4.372587] mmcblk0: retrying because a re-tune was needed
[ 4.453784] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 4.453794] [mmc0] Data transmission error, need to try retuning 1.
[ 4.453829] [mmc0] tuning regsbase addr 0x218.
[ 4.454552] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 4.454559] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 4.454586] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 4.454622] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 4.454631] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-259 (24 len)
[ 4.454639] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-259 (24 len)
[ 4.454646] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 4.454666] need_retune:1,brq->retune_retry_done:0.
[ 4.454672] mmcblk0: retrying because a re-tune was needed
[ 4.535827] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 4.535837] [mmc0] Data transmission error, need to try retuning 1.
[ 4.535864] [mmc0] tuning regsbase addr 0x218.
[ 4.536584] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 4.536590] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 4.625182] dwmmc_rockchip ff0f0000.rksdmmc: req failed (CMD21): error = -110, timeout = 100ms
[ 4.625196] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-110, data.error:-84
[ 4.625241] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 4.625250] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-259 (24 len)
[ 4.625258] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-259 (24 len)
[ 4.625267] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 4.625289] need_retune:1,brq->retune_retry_done:0.
[ 4.625295] mmcblk0: retrying because a re-tune was needed
[ 4.700005] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 4.700015] [mmc0] Data transmission error, need to try retuning 1.
[ 4.700044] [mmc0] tuning regsbase addr 0x218.
[ 4.700767] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 4.700775] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 4.700804] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 4.700842] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 4.700851] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-259 (24 len)
[ 4.700859] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-259 (24 len)
[ 4.700866] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 4.700890] need_retune:1,brq->retune_retry_done:0.
[ 4.700897] mmcblk0: retrying because a re-tune was needed
[ 4.782139] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 4.782150] [mmc0] Data transmission error, need to try retuning 1.
[ 4.782184] [mmc0] tuning regsbase addr 0x218.
[ 4.783105] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 4.783114] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 4.783142] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 4.783181] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 4.783190] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-259 (24 len)
[ 4.783198] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-259 (24 len)
[ 4.783206] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 4.783228] need_retune:1,brq->retune_retry_done:0.
[ 4.783233] mmcblk0: retrying because a re-tune was needed
[ 4.946268] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 4.946281] [mmc0] Data transmission error, need to try retuning 1.
[ 4.946294] [mmc0] Data transmission error !!! MINTSTS: [0x00008088]
[ 4.946300] [mmc0] Data transmission error, need to try retuning 1.
[ 4.946359] [mmc0] tuning regsbase addr 0x218.
[ 4.947084] [mmc0] Data transmission error !!! MINTSTS: [0x0000008c]
[ 4.947092] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 4.947121] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 4.947160] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 4.947170] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-259 (24 len)
[ 4.947178] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-259 (24 len)
[ 4.947184] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 4.947207] need_retune:1,brq->retune_retry_done:0.
[ 4.947213] mmcblk0: retrying because a re-tune was needed
[ 5.028343] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 5.028355] [mmc0] Data transmission error, need to try retuning 1.
[ 5.028393] [mmc0] tuning regsbase addr 0x218.
[ 5.030392] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 5.030402] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 5.030429] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 5.030467] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 5.030476] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-259 (24 len)
[ 5.030484] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-259 (24 len)
[ 5.030491] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 5.030512] need_retune:1,brq->retune_retry_done:0.
[ 5.030518] mmcblk0: retrying because a re-tune was needed
[ 5.110393] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 5.110403] [mmc0] Data transmission error, need to try retuning 1.
[ 5.110440] [mmc0] tuning regsbase addr 0x218.
[ 5.111596] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 5.111609] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 5.111617] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 5.111624] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 5.111647] need_retune:1,brq->retune_retry_done:0.
[ 5.111654] mmcblk0: retrying because a re-tune was needed
[ 5.192479] [mmc0] Data transmission error !!! MINTSTS: [0x00008080]
[ 5.192489] [mmc0] Data transmission error, need to try retuning 1.
[ 5.192520] [mmc0] tuning regsbase addr 0x218.
[ 5.193373] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 5.193381] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 5.193410] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 5.193448] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 5.193457] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-259 (24 len)
[ 5.193465] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-259 (24 len)
[ 5.193472] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 5.193493] need_retune:1,brq->retune_retry_done:0.
[ 5.193499] mmcblk0: retrying because a re-tune was needed
[ 5.274505] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 5.274515] [mmc0] Data transmission error, need to try retuning 1.
[ 5.274543] [mmc0] tuning regsbase addr 0x218.
[ 5.275313] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 5.275324] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 5.275332] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 5.275339] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 5.275359] need_retune:1,brq->retune_retry_done:0.
[ 5.275365] mmcblk0: retrying because a re-tune was needed
[ 5.356659] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 5.356670] [mmc0] Data transmission error, need to try retuning 1.
[ 5.356704] [mmc0] tuning regsbase addr 0x218.
[ 5.357575] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 5.357583] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 5.357614] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 5.357652] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 5.357661] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-259 (24 len)
[ 5.357669] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-259 (24 len)
[ 5.357677] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 5.357697] need_retune:1,brq->retune_retry_done:0.
[ 5.357703] mmcblk0: retrying because a re-tune was needed
[ 5.438778] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 5.438789] [mmc0] Data transmission error, need to try retuning 1.
[ 5.438826] [mmc0] tuning regsbase addr 0x218.
[ 5.439580] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 5.439589] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 5.439618] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 5.439658] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 5.439669] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-259 (24 len)
[ 5.439679] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-259 (24 len)
[ 5.439686] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 5.439709] need_retune:1,brq->retune_retry_done:0.
[ 5.439715] mmcblk0: retrying because a re-tune was needed
[ 5.463752] warning: `system_server’ uses 32-bit capabilities (legacy support in use)
[ 5.520780] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 5.520790] [mmc0] Data transmission error, need to try retuning 1.
[ 5.520821] [mmc0] tuning regsbase addr 0x218.
[ 5.521564] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 5.521572] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 5.521600] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 5.521637] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 5.521647] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-259 (24 len)
[ 5.521655] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-259 (24 len)
[ 5.521662] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 5.521682] need_retune:1,brq->retune_retry_done:0.
[ 5.521688] mmcblk0: retrying because a re-tune was needed
[ 5.602871] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 5.602882] [mmc0] Data transmission error, need to try retuning 1.
[ 5.602911] [mmc0] tuning regsbase addr 0x218.
[ 5.603630] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 5.603639] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 5.603670] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 5.603706] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 5.603716] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-259 (24 len)
[ 5.603723] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-259 (24 len)
[ 5.603731] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 5.603753] need_retune:1,brq->retune_retry_done:0.
[ 5.603759] mmcblk0: retrying because a re-tune was needed
[ 5.684991] [mmc0] Data transmission error !!! MINTSTS: [0x00002000]
[ 5.685005] [mmc0] Data transmission error, need to try retuning 1.
[ 5.685026] dwmmc_rockchip ff0f0000.rksdmmc: data FIFO error (status=00002000)
[ 5.685274] [mmc0] tuning regsbase addr 0x218.
[ 5.685998] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 5.686004] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 5.686031] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 5.686067] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 5.686077] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-259 (24 len)
[ 5.686085] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-259 (24 len)
[ 5.686092] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 5.686112] need_retune:1,brq->retune_retry_done:0.
[ 5.686117] mmcblk0: retrying because a re-tune was needed
[ 5.767046] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 5.767056] [mmc0] Data transmission error, need to try retuning 1.
[ 5.767093] [mmc0] tuning regsbase addr 0x218.
[ 5.767825] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 5.767833] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 5.767864] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 5.767903] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 5.767912] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-259 (24 len)
[ 5.767920] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-259 (24 len)
[ 5.767927] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 5.767948] need_retune:1,brq->retune_retry_done:0.
[ 5.767954] mmcblk0: retrying because a re-tune was needed
[ 5.931246] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 5.931257] [mmc0] Data transmission error, need to try retuning 1.
[ 5.931371] [mmc0] tuning regsbase addr 0x218.
[ 5.932180] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 5.932187] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 5.932215] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 5.932251] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 5.932261] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-259 (24 len)
[ 5.932268] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-259 (24 len)
[ 5.932275] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 5.932296] need_retune:1,brq->retune_retry_done:0.
[ 5.932302] mmcblk0: retrying because a re-tune was needed
[ 6.095381] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 6.095391] [mmc0] Data transmission error, need to try retuning 1.
[ 6.095428] [mmc0] tuning regsbase addr 0x218.
[ 6.096149] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 6.096156] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 6.096185] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 6.096222] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 6.096231] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-259 (24 len)
[ 6.096239] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-259 (24 len)
[ 6.096247] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 6.096268] mmcblk0: error -110 sending stop command, original cmd response 0x900, card status 0x400900
[ 6.096276] need_retune:1,brq->retune_retry_done:0.
[ 6.096281] mmcblk0: retrying because a re-tune was needed
[ 6.402456] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 6.402468] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 6.402476] D1:camsys_open(739): camsys_marvin(debd7910) is opened!
[ 6.402557] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
[ 6.402571] D1:camsys_extdev_register(243): Get RK30_PIN3_PB0(104) gpio(active: 0) for dev_id 0x2000000 success!
[ 6.402585] E:camsys_extdev_register(239): Request RK30_PIN0_PB3(11) failed
[ 6.402592] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
[ 6.402610] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 6.402630] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
[ 6.407671] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 6.407683] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 6.407787] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 6.407810] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 6.408876] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
[ 6.409936] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(104) set 1
[ 6.410995] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
[ 6.414223] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
[ 6.415411] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 6.415483] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
[ 6.415495] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(104) set 0
[ 6.415506] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
[ 6.416587] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 6.416615] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 6.418665] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
[ 6.418676] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 6.418686] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 6.418692] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 6.418700] D1:camsys_release(763): camsys_marvin(debd7910) is closed
[ 6.419240] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 6.419249] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 6.419256] D1:camsys_open(739): camsys_marvin(debd7910) is opened!
[ 6.419340] D1:camsys_extdev_register(243): Get RK30_PIN2_PA0(64) gpio(active: 0) for dev_id 0x1000000 success!
[ 6.419353] D1:camsys_extdev_register(243): Get RK30_PIN3_PB0(104) gpio(active: 0) for dev_id 0x1000000 success!
[ 6.419364] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x1000000 success!
[ 6.419381] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 6.419394] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: OV13850) register success
[ 6.423688] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 6.423699] [mmc0] Data transmission error, need to try retuning 1.
[ 6.423709] [mmc0] Data transmission error !!! MINTSTS: [0x00008088]
[ 6.423714] [mmc0] Data transmission error, need to try retuning 1.
[ 6.423742] [mmc0] tuning regsbase addr 0x218.
[ 6.424440] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 6.424449] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 6.424462] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 6.424468] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 6.424496] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 6.424531] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 6.424540] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-259 (24 len)
[ 6.424548] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-259 (24 len)
[ 6.424555] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 6.424558] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 6.424576] need_retune:1,brq->retune_retry_done:0.
[ 6.424582] mmcblk0: retrying because a re-tune was needed
[ 6.424588] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 6.425647] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
[ 6.426707] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(104) set 1
[ 6.427775] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(64) set 1
[ 6.431007] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
[ 6.432213] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 6.432289] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(64) set 0
[ 6.432302] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(104) set 0
[ 6.432313] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
[ 6.433403] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 6.433430] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 6.435486] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
[ 6.435502] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 6.435512] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 6.435529] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 6.435537] D1:camsys_release(763): camsys_marvin(debd7910) is closed
[ 6.437056] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 6.437066] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 6.437073] D1:camsys_open(739): camsys_marvin(debd7910) is opened!
[ 6.437143] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default
[ 6.437165] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: TC358749XBG) register success
[ 6.442195] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 6.442205] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 6.442309] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 6.442331] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on
[ 6.443385] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
[ 6.444437] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
[ 6.445488] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
[ 6.448973] E:camsys_i2c_write(78): i2c write dev(addr:0x1f) failed!
[ 6.450432] E:camsys_i2c_write(78): i2c write dev(addr:0xf) failed!
[ 6.450498] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
[ 6.450506] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
[ 6.450514] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
[ 6.451599] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 6.451623] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 6.453674] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
[ 6.453689] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 6.453699] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 6.453705] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 6.453713] D1:camsys_release(763): camsys_marvin(debd7910) is closed
[ 6.455480] type=1400 audit(1293883205.960:3): avc: denied { execute } for pid=507 comm=“mediaserver” name=“sh” dev=“mmcblk0p10” ino=321 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 6.455696] type=1400 audit(1293883205.960:4): avc: denied { read open } for pid=507 comm=“mediaserver” path=“/system/bin/sh” dev=“mmcblk0p10” ino=321 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 6.455814] type=1400 audit(1293883205.970:5): avc: denied { execute_no_trans } for pid=507 comm=“mediaserver” path=“/system/bin/sh” dev=“mmcblk0p10” ino=321 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 6.457701] type=1400 audit(1293883205.970:6): avc: denied { getattr } for pid=507 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=336 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 6.457795] type=1400 audit(1293883205.970:7): avc: denied { execute } for pid=507 comm=“sh” name=“toolbox” dev=“mmcblk0p10” ino=336 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 6.457866] type=1400 audit(1293883205.970:8): avc: denied { read open } for pid=507 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=336 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 6.457952] type=1400 audit(1293883205.970:9): avc: denied { execute_no_trans } for pid=507 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=336 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 6.505774] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 6.505785] [mmc0] Data transmission error, need to try retuning 1.
[ 6.505815] [mmc0] tuning regsbase addr 0x218.
[ 6.506533] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 6.506540] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 6.506568] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 6.506606] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 6.506615] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-259 (24 len)
[ 6.506622] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-259 (24 len)
[ 6.506630] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 6.506649] need_retune:1,brq->retune_retry_done:0.
[ 6.506655] mmcblk0: retrying because a re-tune was needed
[ 6.587858] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 6.587868] [mmc0] Data transmission error, need to try retuning 1.
[ 6.587894] [mmc0] tuning regsbase addr 0x218.
[ 6.588611] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 6.588618] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 6.588645] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 6.588681] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 6.588690] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-259 (24 len)
[ 6.588698] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-259 (24 len)
[ 6.588705] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 6.588727] need_retune:1,brq->retune_retry_done:0.
[ 6.588733] mmcblk0: retrying because a re-tune was needed
[ 6.752048] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 6.752058] [mmc0] Data transmission error, need to try retuning 1.
[ 6.752092] [mmc0] tuning regsbase addr 0x218.
[ 6.752850] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 6.752860] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 6.752868] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 6.752875] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 6.752895] need_retune:1,brq->retune_retry_done:0.
[ 6.752901] mmcblk0: retrying because a re-tune was needed
[ 6.834082] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 6.834092] [mmc0] Data transmission error, need to try retuning 1.
[ 6.834122] [mmc0] tuning regsbase addr 0x218.
[ 6.834835] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 6.834842] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 6.834871] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 6.834907] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 6.834917] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-259 (24 len)
[ 6.834924] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-259 (24 len)
[ 6.834931] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 6.834948] need_retune:1,brq->retune_retry_done:0.
[ 6.834954] mmcblk0: retrying because a re-tune was needed
[ 6.916183] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 6.916193] [mmc0] Data transmission error, need to try retuning 1.
[ 6.916202] [mmc0] Data transmission error !!! MINTSTS: [0x00008088]
[ 6.916208] [mmc0] Data transmission error, need to try retuning 1.
[ 6.916234] [mmc0] tuning regsbase addr 0x218.
[ 6.916958] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 6.916965] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 6.916993] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 6.917030] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 6.917039] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-259 (24 len)
[ 6.917046] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-259 (24 len)
[ 6.917054] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 6.917074] need_retune:1,brq->retune_retry_done:0.
[ 6.917080] mmcblk0: retrying because a re-tune was needed
[ 6.998287] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 6.998299] [mmc0] Data transmission error, need to try retuning 1.
[ 6.998325] [mmc0] tuning regsbase addr 0x218.
[ 6.999028] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 6.999034] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 6.999061] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 6.999098] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 6.999107] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-259 (24 len)
[ 6.999115] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-259 (24 len)
[ 6.999122] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 6.999141] need_retune:1,brq->retune_retry_done:0.
[ 6.999149] mmcblk0: retrying because a re-tune was needed
[ 7.080329] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 7.080341] [mmc0] Data transmission error, need to try retuning 1.
[ 7.080348] [mmc0] Data transmission error !!! MINTSTS: [0x00008088]
[ 7.080354] [mmc0] Data transmission error, need to try retuning 1.
[ 7.080384] [mmc0] tuning regsbase addr 0x218.
[ 7.081103] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 7.081110] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 7.081138] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 7.081177] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 7.081188] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-259 (24 len)
[ 7.081195] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-259 (24 len)
[ 7.081202] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 7.081222] need_retune:1,brq->retune_retry_done:0.
[ 7.081228] mmcblk0: retrying because a re-tune was needed
[ 7.1shell@firefly:/ $ 62418] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 7.162428] [mmc0] Data transmission error, need to try retuning 1.
[ 7.162459] [mmc0] tuning regsbase addr 0x218.
[ 7.163183] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 7.163189] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 7.163217] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 7.163255] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 7.163264] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-259 (24 len)
[ 7.163272] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-259 (24 len)
[ 7.163278] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 7.163300] need_retune:1,brq->retune_retry_done:0.
[ 7.163305] mmcblk0: retrying because a re-tune was needed
[ 7.244610] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 7.244621] [mmc0] Data transmission error, need to try retuning 1.
[ 7.244654] [mmc0] tuning regsbase addr 0x218.
[ 7.245393] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 7.245403] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 7.245436] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 7.245479] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 7.245489] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-259 (24 len)
[ 7.245498] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-259 (24 len)
[ 7.245505] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 7.245529] need_retune:1,brq->retune_retry_done:0.
[ 7.245536] mmcblk0: retrying because a re-tune was needed
[ 7.326576] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 7.326587] [mmc0] Data transmission error, need to try retuning 1.
[ 7.326616] [mmc0] tuning regsbase addr 0x218.
[ 7.327331] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 7.327338] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 7.327369] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 7.327405] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 7.327415] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-259 (24 len)
[ 7.327422] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-259 (24 len)
[ 7.327430] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 7.327448] need_retune:1,brq->retune_retry_done:0.
[ 7.327455] mmcblk0: retrying because a re-tune was needed
[ 7.490747] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 7.490757] [mmc0] Data transmission error, need to try retuning 1.
[ 7.490766] [mmc0] Data transmission error !!! MINTSTS: [0x00008088]
[ 7.490771] [mmc0] Data transmission error, need to try retuning 1.
[ 7.490798] [mmc0] tuning regsbase addr 0x218.
[ 7.491556] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 7.491566] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 7.491574] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 7.491581] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 7.491603] need_retune:1,brq->retune_retry_done:0.
[ 7.491609] mmcblk0: retrying because a re-tune was needed
[ 7.572813] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 7.572823] [mmc0] Data transmission error, need to try retuning 1.
[ 7.572849] [mmc0] tuning regsbase addr 0x218.
[ 7.573566] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 7.573572] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 7.573599] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 7.573636] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 7.573645] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-259 (24 len)
[ 7.573653] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-259 (24 len)
[ 7.573661] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 7.573680] need_retune:1,brq->retune_retry_done:0.
[ 7.573687] mmcblk0: retrying because a re-tune was needed
[ 7.654904] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 7.654914] [mmc0] Data transmission error, need to try retuning 1.
[ 7.654945] [mmc0] tuning regsbase addr 0x218.
[ 7.655709] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 7.655719] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 7.655727] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 7.655734] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 7.655755] need_retune:1,brq->retune_retry_done:0.
[ 7.655761] mmcblk0: retrying because a re-tune was needed
[ 7.737007] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 7.737018] [mmc0] Data transmission error, need to try retuning 1.
[ 7.737055] [mmc0] tuning regsbase addr 0x218.
[ 7.737763] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 7.737770] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 7.737798] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 7.737835] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 7.737845] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-259 (24 len)
[ 7.737853] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-259 (24 len)
[ 7.737860] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 7.737879] need_retune:1,brq->retune_retry_done:0.
[ 7.737884] mmcblk0: retrying because a re-tune was needed
[ 7.901186] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 7.901198] [mmc0] Data transmission error, need to try retuning 1.
[ 7.901234] [mmc0] tuning regsbase addr 0x218.
[ 7.902023] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 7.902035] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 7.902042] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 7.902053] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 7.902075] need_retune:1,brq->retune_retry_done:0.
[ 7.902082] mmcblk0: retrying because a re-tune was needed
[ 8.065406] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 8.065421] [mmc0] Data transmission error, need to try retuning 1.
[ 8.065433] [mmc0] Data transmission error !!! MINTSTS: [0x00008088]
[ 8.065440] [mmc0] Data transmission error, need to try retuning 1.
[ 8.065476] [mmc0] tuning regsbase addr 0x218.
[ 8.066324] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 8.066333] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 8.066364] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 8.066403] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 8.066413] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-259 (24 len)
[ 8.066420] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-259 (24 len)
[ 8.066428] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 8.066449] need_retune:1,brq->retune_retry_done:0.
[ 8.066455] mmcblk0: retrying because a re-tune was needed
[ 8.348669] healthd: battery none chg=
[ 8.519532] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
[ 8.519546] lowmemorykiller: oom_adj 0 => oom_score_adj 0
[ 8.519552] lowmemorykiller: oom_adj 1 => oom_score_adj 58
[ 8.519558] lowmemorykiller: oom_adj 2 => oom_score_adj 117
[ 8.519563] lowmemorykiller: oom_adj 3 => oom_score_adj 176
[ 8.519568] lowmemorykiller: oom_adj 9 => oom_score_adj 529
[ 8.519574] lowmemorykiller: oom_adj 15 => oom_score_adj 1000
[ 8.874936] acc_open
[ 8.874952] acc_release
[ 8.885913] [otg id chg] last id -1 current id 1
[ 8.982894] phy_power_on: enable = 1
[ 9.022293] Read the Ethernet MAC address from IDB:00:00:00:00:00:00
[ 9.022324] eth0: device MAC address ae:22:22:8a:5e:53
[ 9.025911] libphy: stmmac: probed
[ 9.025920] eth0: No PHY found
[ 9.122540] es8323_mic_state_ctrl read: 0
[ 9.122550] mic_state_switch 0
[ 9.122557] hp_det = 0,insert hp
[ 9.122561] hp mic use intern
[ 9.491911] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 9.491925] [mmc0] Data transmission error, need to try retuning 1.
[ 9.491962] [mmc0] tuning regsbase addr 0x218.
[ 9.492659] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 9.492667] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 9.492694] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 9.492733] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 9.492743] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-259 (24 len)
[ 9.492752] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-259 (24 len)
[ 9.492760] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 9.492780] need_retune:1,brq->retune_retry_done:0.
[ 9.492786] mmcblk0: retrying because a re-tune was needed
[ 10.122135] pm policy 0 → 1
[ 11.316483] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 11.316508] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 11.316517] D1:camsys_open(739): camsys_marvin(debd7910) is opened!
[ 11.325365] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
[ 11.325382] D1:camsys_extdev_register(243): Get RK30_PIN3_PB0(104) gpio(active: 0) for dev_id 0x2000000 success!
[ 11.325394] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
[ 11.325686] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 11.325708] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
[ 11.330898] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 11.330911] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 11.331017] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 11.331045] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 11.332198] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
[ 11.333269] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(104) set 1
[ 11.334336] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
[ 11.337580] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
[ 11.338796] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 11.338879] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
[ 11.338893] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(104) set 0
[ 11.338904] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
[ 11.339999] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 11.340032] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 11.342095] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
[ 11.342111] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 11.342122] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 11.342129] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 11.342136] D1:camsys_release(763): camsys_marvin(debd7910) is closed
[ 11.342785] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 11.342795] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 11.342802] D1:camsys_open(739): camsys_marvin(debd7910) is opened!
[ 11.342885] D1:camsys_extdev_register(243): Get RK30_PIN2_PA0(64) gpio(active: 0) for dev_id 0x1000000 success!
[ 11.342898] D1:camsys_extdev_register(243): Get RK30_PIN3_PB0(104) gpio(active: 0) for dev_id 0x1000000 success!
[ 11.342909] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x1000000 success!
[ 11.342927] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 11.342941] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: OV13850) register success
[ 11.348120] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 11.348134] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 11.348239] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 11.348269] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 11.349300] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
[ 11.350366] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(104) set 1
[ 11.351428] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(64) set 1
[ 11.354658] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
[ 11.355942] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 11.356028] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(64) set 0
[ 11.356042] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(104) set 0
[ 11.356053] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
[ 11.357231] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 11.357263] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 11.359323] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
[ 11.359337] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 11.359348] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 11.359355] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 11.359362] D1:camsys_release(763): camsys_marvin(debd7910) is closed
[ 11.359943] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 11.359952] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 11.359959] D1:camsys_open(739): camsys_marvin(debd7910) is opened!
[ 11.360027] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default
[ 11.360050] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: TC358749XBG) register success
[ 11.365089] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 11.365104] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 11.365209] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 11.365238] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on
[ 11.366302] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
[ 11.367368] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
[ 11.368447] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
[ 11.374314] E:camsys_i2c_write(78): i2c write dev(addr:0x1f) failed!
[ 11.375928] E:camsys_i2c_write(78): i2c write dev(addr:0xf) failed!
[ 11.376017] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
[ 11.376026] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
[ 11.376043] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
[ 11.377138] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 11.377173] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 11.379232] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
[ 11.379249] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 11.379262] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 11.379269] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 11.379278] D1:camsys_release(763): camsys_marvin(debd7910) is closed
[ 11.387255] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 11.387269] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 11.387277] D1:camsys_open(739): camsys_marvin(debd7910) is opened!
[ 11.387344] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
[ 11.387357] D1:camsys_extdev_register(243): Get RK30_PIN3_PB0(104) gpio(active: 0) for dev_id 0x2000000 success!
[ 11.387369] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
[ 11.387386] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 11.387408] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
[ 11.392472] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 11.392485] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 11.392828] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 11.392858] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 11.393935] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
[ 11.396557] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(104) set 1
[ 11.398213] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
[ 11.401611] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
[ 11.403014] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 11.403105] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
[ 11.403118] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(104) set 0
[ 11.403129] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
[ 11.404191] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 11.404230] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 11.407907] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
[ 11.407925] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 11.407937] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 11.407944] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 11.407951] D1:camsys_release(763): camsys_marvin(debd7910) is closed
[ 11.408589] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 11.408600] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 11.408607] D1:camsys_open(739): camsys_marvin(debd7910) is opened!
[ 11.408679] D1:camsys_extdev_register(243): Get RK30_PIN2_PA0(64) gpio(active: 0) for dev_id 0x1000000 success!
[ 11.408692] D1:camsys_extdev_register(243): Get RK30_PIN3_PB0(104) gpio(active: 0) for dev_id 0x1000000 success!
[ 11.408703] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x1000000 success!
[ 11.408721] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 11.408735] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: OV13850) register success
[ 11.413784] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 11.413796] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 11.413901] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 11.413928] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 11.415183] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
[ 11.416844] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(104) set 1
[ 11.417920] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(64) set 1
[ 11.421247] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
[ 11.422453] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 11.422542] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(64) set 0
[ 11.422556] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(104) set 0
[ 11.422568] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
[ 11.423659] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 11.423692] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 11.425750] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
[ 11.425768] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 11.425779] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 11.425786] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 11.425793] D1:camsys_release(763): camsys_marvin(debd7910) is closed
[ 11.426380] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 11.426391] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 11.426399] D1:camsys_open(739): camsys_marvin(debd7910) is opened!
[ 11.426467] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default
[ 11.426491] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: TC358749XBG) register success
[ 11.431651] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 11.431664] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 11.431773] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 11.432057] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on
[ 11.433127] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
[ 11.434191] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
[ 11.435253] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
[ 11.438762] E:camsys_i2c_write(78): i2c write dev(addr:0x1f) failed!
[ 11.440383] E:camsys_i2c_write(78): i2c write dev(addr:0xf) failed!
[ 11.440482] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
[ 11.440491] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
[ 11.440500] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
[ 11.441593] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 11.441625] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 11.443677] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
[ 11.443694] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 11.443704] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 11.443711] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 11.443718] D1:camsys_release(763): camsys_marvin(debd7910) is closed
[ 11.751214] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 11.751227] [mmc0] Data transmission error, need to try retuning 1.
[ 11.751275] [mmc0] tuning regsbase addr 0x218.
[ 11.751988] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 11.751996] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 11.752026] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 11.752046] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 11.752053] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 11.752080] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 11.752118] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 11.752128] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-248 (23 len)
[ 11.752136] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-248 (23 len)
[ 11.752144] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 124
[ 11.752168] need_retune:1,brq->retune_retry_done:0.
[ 11.752174] mmcblk0: retrying because a re-tune was needed
[ 11.790304] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 11.790318] [mmc0] Data transmission error, need to try retuning 1.
[ 11.790356] [mmc0] tuning regsbase addr 0x218.
[ 11.791064] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 11.791074] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 11.791082] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 11.791089] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 11.791109] need_retune:1,brq->retune_retry_done:0.
[ 11.791114] mmcblk0: retrying because a re-tune was needed
[ 13.031376] type=1400 audit(1293883212.650:10): avc: denied { entrypoint } for pid=1066 comm=“init” path=“/system/bin/usb_mode_switch.sh” dev=“mmcblk0p10” ino=347 scontext=u:r:install_recovery:s0 tcontext=u:object_r:system_file:s0 tclass=file permissive=1
[ 16.382881] type=1400 audit(1293883216.050:11): avc: denied { write } for pid=1132 comm=“chip.devicetest” name=“force_usb_mode” dev=“sysfs” ino=12676 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[ 16.385283] force_usb_mode_store 1->1
遇到了一样的打印,不知道这算不算是emmc加载出错?
