Core-3288J核心板开机后特别不稳定,画面闪动,会自动重启。
log里显示说mmc有问题,感觉无从下手。
Version 1.00 20160530
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-10 (May 30 2018 - 16:38:11)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 400
SdmmcInit = 2 0
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
pmic:act8846
can’t find dts node for pwm1
#Boot ver: 2018-05-30#2.30
empty serial no.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
pll_src = 0, dclk_hz = 65000000, dclk_div = 6
no fuel gauge found
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x02000000 (0x006a93c8)
ramdisk @ 0x05bf0000 (0x001464d8)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0561c208 … OK
[ 0.000000] Linux version 3.10.0 (sujl@tchipserver2) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #28 SMP PREEMPT Wed Jul 11 10:36:00 CST 2018
[ 0.000000] rockchip_uboot_logo_setup: mem: 0x02000000@0x7dc00000, offset:0x00000000
[ 0.000000] rockchip_uboot_mem_reserve: reserve 0x02000000@0x7dc00000 for uboot logo
[ 0.000000] ion heap(cma): base(0) size(1000000) align(0)
[ 0.000000] cma: CMA: reserved 16 MiB at 7cc00000
[ 0.000000] ion_reserve: cma reserved base 7cc00000 size 16777216
[ 0.000000] cma: CMA: reserved 16 MiB at 1f000000
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1f1e000 s13376 r8192 d15296 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523264
[ 0.000000] Kernel command line: vmalloc=496M console=ttyS2 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 root=/dev/block/mtd/by-name/linuxroot rw rootfstype=ext4 init=/sbin/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00002000@0x0039A000(baseparamer),-@0x003BC000(userdata) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2018-05-30_16:38:11
[ 0.000000] allocated 4194304 bytes of page_cgroup
[ 0.000000] Memory: 1993656k/1993656k available, 103496k reserved, 1523712K highmem
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0bb3b78 (11951 kB)
[ 0.000000] .init : 0xc0bb4000 - 0xc0c0d440 ( 358 kB)
[ 0.000000] .data : 0xc0c0e000 - 0xc0da0680 (1610 kB)
[ 0.000000] .bss : 0xc0da0680 - 0xc0ec3c3c (1166 kB)
[ 0.000000] rk_clk_tree_init start!
[ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div
[ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error
[ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1
[ 0.000000] rkclk_init_clks: cnt_rate = 29
[ 0.000000] rk3288 set GPLL BW 20 for HDMI!
[ 0.000000] process version: 1
[ 0.000000] channel:0, lkg:41
[ 0.000000] target-temp:80
[ 0.000000] channel:2, lkg:0
[ 0.000000] channel:1, lkg:29
[ 0.494193] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.494209] pid_max: default: 32768 minimum: 301
[ 0.494325] Security Framework initialized
[ 0.494341] SELinux: Initializing.
[ 0.494413] Mount-cache hash table entries: 512
[ 0.495056] Initializing cgroup subsys debug
[ 0.495072] Initializing cgroup subsys memory
[ 0.495098] Initializing cgroup subsys freezer
[ 0.495126] CPU: Testing write buffer coherency: ok
[ 0.495449] /cpus/cpu@0 missing clock-frequency property
[ 0.495463] /cpus/cpu@1 missing clock-frequency property
[ 0.495472] /cpus/cpu@2 missing clock-frequency property
[ 0.495482] /cpus/cpu@3 missing clock-frequency property
[ 0.495538] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.495590] Setting up static identity map for 0xc0863668 - 0xc08636c0
[ 0.497930] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x17e0 (version 3.1)
[ 0.572347] CPU1: Booted secondary processor
[ 0.572379] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.592022] CPU2: Booted secondary processor
[ 0.592045] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.611727] CPU3: Booted secondary processor
[ 0.611750] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.611850] Brought up 4 CPUs
[ 0.611879] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.611888] CPU: All CPU(s) started in SVC mode.
[ 0.612621] devtmpfs: initialized
[ 0.617085] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.618189] pinctrl core: initialized pinctrl subsystem
[ 0.618442] regulator-dummy: no parameters
[ 0.632448] NET: Registered protocol family 16
[ 0.634289] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.634659] ion_snapshot: 0x1ea98000 map to 0xe0907000 and copy to 0xc0e9eecc (version 0.1)
[ 0.634898] Registered FIQ tty driver
[ 0.635300] fiq-debugger is disabled in device tree
[ 0.636024] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[ 0.636045] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[ 0.636062] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 0.636079] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[ 0.636169] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 0.636232] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 0.636293] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 0.636355] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 0.636415] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 0.636478] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[ 0.636539] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 0.636600] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[ 0.636668] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 0.636732] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 0.636745] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 0.636757] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 0.636768] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 0.637384] rockchip_interrupts_register:bank_num=7
[ 0.639308] of_get_gpio_init_config:gpio[0] = 136, value = 0
[ 0.639329] of_get_gpio_init_config:gpio[1] = 13, value = 1
[ 0.639383] rockchip_pinctrl_probe:init ok
[ 0.646437] rk_iommu ff900800.iep_mmu: (iep) Enter
[ 0.646524] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.646537] rk_iommu ff900800.iep_mmu: (iep) Initialized
[ 0.646705] rk_iommu ff950800.vip_mmu: (vip) Enter
[ 0.646782] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.646795] rk_iommu ff950800.vip_mmu: (vip) Initialized
[ 0.646956] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[ 0.647025] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.647037] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[ 0.647196] rk_iommu ff940300.vopl_mmu: (vopl) Enter
[ 0.647274] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.647287] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[ 0.647455] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[ 0.647528] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.647541] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[ 0.647703] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[ 0.647784] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.647797] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[ 0.647968] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[ 0.648053] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.648065] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
[ 0.649737] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.649750] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.650333] rk3368_init_rockchip_pmu_ops: could not find pmu dt node
[ 0.650356] DDR DEBUG: version 1.00 20150126
[ 0.650385] DDR DEBUG: Channel a:
[ 0.650393] DDR DEBUG: DDR3 Device
[ 0.650406] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.650414] DDR DEBUG: Channel b:
[ 0.650422] DDR DEBUG: DDR3 Device
[ 0.650434] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.650443] DDR DEBUG: addr=0xdaa000
[ 0.650453] DDR DEBUG: stride=9, size=256, halfcap=40000000
[ 0.650461] DDR DEBUG: socAddr[0]=0xdaa000, socAddr[1]=0xdaa100
[ 0.650470] DDR DEBUG: chAddr[0]=0xdaa000, chAddr[1]=0xdaa000
[ 0.650481] DDR DEBUG: dtar[0]=0x201b5000, dtar[1]=0x201b5000
[ 0.650535] DDR DEBUG: init success!!! freq=200MHz
[ 0.650543] DDR DEBUG: Channel a:
[ 0.650556] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.650569] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.650581] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.650594] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.650606] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.650615] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.650624] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.650631] DDR DEBUG: Channel b:
[ 0.650643] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.650656] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.650668] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.650681] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.650693] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.650702] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19 0.675749] bio: create slab at 0
[ 0.676287] Rockchip hdmi driver version 2.0
[ 0.676287] .
[ 0.677456] SCSI subsystem initialized
[ 0.677613] usbcore: registered new interface driver usbfs
[ 0.677658] usbcore: registered new interface driver hub
[ 0.677748] usbcore: registered new device driver usb
[ 0.680019] host_en_gpio= -2
[ 0.682434] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 0.683078] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
[ 0.683516] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
[ 0.683760] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 0.684386] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 0.684504] media: Linux media interface: v0.10
[ 0.684543] Linux video capture interface: v2.00
[ 0.684606] pps_core: LinuxPPS API ver. 1 registered
[ 0.684616] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.684635] PTP clock support registered
[ 0.684691] i2c-core: driver [bq24296] using legacy suspend method
[ 0.684700] i2c-core: driver [bq24296] using legacy resume method
[ 0.685023] RK29 Watchdog Timer, (c) 2011 Rockchip Electronics
[ 0.685505] ion_drm_heap_create: 0@0
[ 0.685640] Rockchip ion module is successfully loaver Initialized.
[ 0.686219] Bluetooth: Core ver 2.16
[ 0.686257] NET: Registered protocol family 31
[ 0.686266] Bluetooth: HCI device and connection manager initialized
[ 0.686283] Bluetooth: HCI socket layer initialized
[ 0.686296] Bluetooth: L2CAP socket layer initialized
[ 0.686322] Bluetooth: SCO socket layer initialized
[ 0.686555] cfg80211: Calling CRDA to update world regulatory domain
[ 0.687243] act8846_i2c_probe,line=898
[ 0.688260] act8846_parse_dt,line=746
[ 0.688705] act8846_i2c_probe: act8846_pmic_hold=1
[ 0.688726] act8846_i2c_probe: act8846_pmic_sleep=1
[ 0.688742] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
[ 0.688757] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
[ 0.690852] act_dcdc1: 1200 mV
[ 0.693828] vccio: 3300 mV
[ 0.695685] vdd_logic: 700 ↔ 1500 mV at 1100 mV
[ 0.698665] act_dcdc4: 2000 mV
[ 0.699900] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
[ 0.702200] act_ldo2: 1050 mV
[ 0.704505] act_ldo3: 3300 mV
[ 0.706805] act_ldo4: 3300 mV
[ 0.709109] act_ldo5: 3300 mV
[ 0.711505] act_ldo6: 1100 mV
[ 0.713811] vcc_18: 1800 mV
[ 0.716123] act_ldo8: 1850 mV
[ 0.720880] vdd_arm: 712 ↔ 1500 mV at 1000 mV
[ 0.725579] vdd_gpu: 712 ↔ 1500 mV at 1000 mV
[ 0.726337] rk808_i2c_probe,line=1355
[ 0.727664] The device is not rk808 -11
[ 0.727749] rk808: probe of 0-001b failed with error -11
[ 0.727825] i2c-core: driver [rk818] using legacy suspend method
[ 0.727835] i2c-core: driver [rk818] using legacy resume method
[ 0.729786] Switching to clocksource arch_sys_counter
[ 0.753568] rga: Module initialized.
[ 0.754297] rga2 ff920000.rga: rga ion client create success!
[ 0.754456] rga: Driver loaded succesfully
[ 0.754651] fb disp policy is box
[ 0.754693] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.754705] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.754998] rk-screen rk_screen.8: rockchip screen probe success
[ 0.755265] rk32-lvds rk32-lvds: rk32 lvds driver probe success
[ 0.755623] rk32-edp ff970000.edp: screen is not edp!
[ 0.755643] rk32-edp: probe of ff970000.edp failed with error -22
[ 0.756152] pwr_ctr_name:lcd_en
[ 0.756152] pwr_type:gpio
[ 0.756152] gpio:227
[ 0.756152] atv_val:1
[ 0.756152] delay:10
[ 0.756152]
[ 0.756386] graphics fb0: rockchip framebuffer registerd:fb0
[ 0.756684] graphics fb1: rockchip framebuffer registerd:fb1
[ 0.756857] graphics fb2: rockchip framebuffer registerd:fb2
[ 0.757021] graphics fb3: rockchip framebuffer registerd:fb3
[ 0.757727] rk3288-lcdc lcdc0: lcdc0: dclk:65000000>>fps:58
[ 0.757742] rk3288-lcdc lcdc0: wakeup from standby!
[ 0.773283] alloc_buffer:ion_phy_addr=0x10000000
[ 0.779639] fb0:phy:10000000>>vir:e0991000>>len:0xc00000
[ 0.792188] rk_iommu ff930300.vopb_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eab4000
[ 0.792243] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
[ 0.792463] rk3288-lcdc lcdc1: can’t find power_ctr node for lcdc1
[ 0.792477] rk_fb_trsm_ops_get:un supported transmitter:0!
[ 0.792740] graphics fb4: rockchip framebuffer registerd:fb4
[ 0.793076] graphics fb5: rockchip framebuffer registerd:fb5
[ 0.793249] graphics fb6: rockchip framebuffer registerd:fb6
[ 0.793414] graphics fb7: rockchip framebuffer registerd:fb7
[ 0.794232] unknow screen type: 0
[ 0.794316] rk3288-lcdc lcdc1: lcdc1: dclk:65000000>>fps:649
[ 0.794329] rk3288-lcdc lcdc1: wakeup from standby!
[ 0.796208] fb4:phy:10000000>>vir:e0991000>>len:0xc00000
[ 0.796222] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu enabled
[ 0.797114] rockchip_set_mux:warning ignore bank num 15
[ 0.797251] rockchip_set_mux:warning ignore bank num 15
[ 0.797376] rockchip_set_mux:warning ignore bank num 15
[ 0.797497] rockchip_set_mux:warning ignore bank num 15
[ 0.797615] rockchip_set_mux:warning ignore bank num 15
[ 0.797733] rockchip_set_mux:warning ignore bank num 15
[ 0.798306] rockchip_set_mux:warning ignore bank num 15
[ 0.798476] rockchip_set_mux:warning ignore bank num 15
[ 0.799027] rockchip_set_mux:warning ignore bank num 15
[ 0.799172] rockchip_set_mux:warning ignore bank num 15
[ 0.799708] rockchip_set_mux:warning ignore bank num 15
[ 0.799858] rockchip_set_mux:warning ignore bank num 15
[ 0.800408] rockchip_set_mux:warning ignore bank num 15
[ 0.800563] rockchip_set_mux:warning ignore bank num 15
[ 0.801678] tc358749_hdmiin_probe!
[ 0.860944] tc358749_hdmiin_probe OK!
[ 0.861414] NET: Registered protocol family 2
[ 0.862088] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.862164] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.862237] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.862291] TCP: reno registered
[ 0.862307] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.862330] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.862519] NET: Registered protocol family 1
[ 0.863149] Unpacking initramfs…
[ 0.934225] Freeing initrd memory: 1304K (c5bf0000 - c5d36000)
[ 0.935074] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 0.935634] vcodec_service: probe device ff9a0000.vpu_service
[ 0.935837] vcodec_service: No reset resource define
[ 0.936011] vcodec_service: ff9a0000.vpu_service: power on
[ 0.936094] vcodec_service: probe device ff9a0000.vpu_service
[ 0.936110] vcodec_service: checking hw id 4831
[ 0.937197] vcodec_service: ff9a0000.vpu_service: power off…
[ 0.937242] vcodec_service: done
[ 0.937251] vcodec_service: init success
[ 0.937318] vcodec_service: probe device ff9c0000.hevc_service
[ 0.937657] vcodec_service: ff9c0000.hevc_service: power on
[ 0.937724] vcodec_service: probe device ff9c0000.hevc_service
[ 0.937738] vcodec_service: checking hw id 6867
[ 0.938311] vcodec_service: ff9c0000.hevc_service: power off…
[ 0.938353] vcodec_service: done
[ 0.938361] vcodec_service: init success
[ 0.938496] rknandbase v1.0 2014-03-31
[ 0.938628] rknand: probe of ff400000.nandc failed with error -1
[ 0.938737] rknand_driver:ret = 0
[ 0.940696] audit: initializing netlink socket (disabled)
[ 0.940747] type=2000 audit(0.450:1): initialized
[ 0.941589] bounce pool size: 64 pages
[ 0.946149] fuse init (API version 7.22)
[ 0.946567] msgmni has been set to 952
[ 0.948357] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.948373] io scheduler noop registered
[ 0.948382] io scheduler deadline registered
[ 0.948479] io scheduler cfq registered (default)
[ 0.950090] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess.
[ 0.950797] IEP Power ON
[ 0.950849] iep ion client create success!
[ 0.951293] rk_iommu ff900800.iep_mmu: rockchip_iommu_attach_dshell@firefly:/ $ evice: Attached new IOMMU with pgtable 0x1eaae000
[ 0.951303] IEP Power OFF
[ 0.951320] IEP Driver loaded succesfully
[ 0.951425] Module initialized.
[ 0.952272] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 0.952290] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 0.953629] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 0.953646] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.953938] pwm-voltage-regulator pwm_regulator.23: unable to request PWM, trying legacy API
[ 0.953953] pwm-voltage-regulator pwm_regulator.23: unable to request legacy PWM
[ 0.953962] pwm_regulator_probe:error
[ 0.953982] platform pwm_regulator.23: Driver pwm-voltage-regulator requests probe deferral
[ 0.954189] rk_serial.c v1.8 2014-03-04
[ 0.954416] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[ 0.954600] serial ff180000.serial: membase e097e000
[ 0.954762] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1
[ 0.954927] serial ff190000.serial: membase e359c000
[ 0.955069] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
[ 0.956780] console [ttyS2] enabled
[ 0.956957] serial ff690000.serial: membase fed60000
[ 0.957142] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90) is a rk29_serial.3
[ 0.957310] serial ff1b0000.serial: membase e359e000
[ 0.960114] loop: module loaded
[ 0.960484] zram: Created 1 device(s) …
[ 0.960571] i2c-core: driver [mpu6050B1] using legacy suspend method
[ 0.960584] i2c-core: driver [mpu6050B1] using legacy resume method
[ 0.960602] mpu_init: Probe name mpu6050B1
[ 0.960756] ak8963_mod_init: Probe name ak8963_mod
[ 0.961474] SCSI Media Changer driver v0.25
[ 0.961780] dws->regs: e35be000
[ 0.962976] rockchip_spi_probe:num_cs=2,bus_num=0,irq=76,freq=45692308 ok
[ 0.963282] tun: Universal TUN/TAP device driver, 1.6
[ 0.963297] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.963434] vmac_init.
[ 0.964033] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 0.964049] stmmac_probe_config_dt: clock input/output? (input).
[ 0.964062] stmmac_probe_config_dt: TX delay(0x23).
[ 0.964073] stmmac_probe_config_dt: RX delay(0x19).
[ 0.964123] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[ 0.964134] stmmc_pltfr_init:
[ 0.964144] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[ 0.964166] gmac_phy_reset: ERROR: Request pin stmmc_pltfr_init failed.
[ 0.964177] stmmc_pltfr_init: init for RGMII
[ 0.964188] tx delay=0x23
[ 0.964188] rx delay=0x19
[ 0.964204] tx delay=0x23
[ 0.964204] rx delay=0x19
[ 0.964655] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.964666] Normal descriptors
[ 0.964675] Ring mode enabled
[ 0.964686] DMA HW capability register supported
[ 0.964698] RX Checksum Offload Engine supported (type 2)
[ 0.964708] TX Checksum insertion supported
[ 0.964717] Wake-Up On Lan supported
[ 0.964753] Enable RX Mitigation via HW Watchdog Timer
[ 0.965203] PPP generic driver version 2.4.2
[ 0.965364] PPP BSD Compression module registered
[ 0.965377] PPP Deflate Compression module registered
[ 0.965401] PPP MPPE Compression module registered
[ 0.965414] NET: Registered protocol family 24
[ 0.965452] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 0.965465] CSLIP: code copyright 1989 Regents of the University of California.
[ 0.965478] Rockchip WiFi SYS interface (V1.00) …
[ 0.965511] esp_mem_init enter date May 30 2018 16:39:38
[ 0.965522] esp_mem_init VERSION [V2.5]
[ 0.965570] esp_mem_init complete
[ 0.965655] usbcore: registered new interface driver catc
[ 0.965696] usbcore: registered new interface driver kaweth
[ 0.965709] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 0.965749] usbcore: registered new interface driver pegasus
[ 0.965787] usbcore: registered new interface driver rtl8150
[ 0.965826] usbcore: registered new interface driver r8152
[ 0.965837] hso: drivers/net/usb/hso.c: Option Wireless
[ 0.965909] usbcore: registered new interface driver hso
[ 0.965954] usbcore: registered new interface driver asix
[ 0.966020] usbcore: registered new interface driver ax88179_178a
[ 0.966064] usbcore: registered new interface driver cdc_ether
[ 0.966103] usbcore: registered new interface driver cdc_eem
[ 0.966140] usbcore: registered new interface driver dm9601
[ 0.966182] usbcore: registered new interface driver dm9620
[ 0.966230] usbcore: registered new interface driver smsc75xx
[ 0.966277] usbcore: registered new interface driver smsc95xx
[ 0.966318] usbcore: registered new interface driver gl620a
[ 0.966357] usbcore: registered new interface driver net1080
[ 0.966395] usbcore: registered new interface driver plusb
[ 0.966439] usbcore: registered new interface driver rndis_host
[ 0.966490] usbcore: registered new interface driver cdc_subset
[ 0.966531] usbcore: registered new interface driver zaurus
[ 0.966588] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 0.966654] usbcore: registered new interface driver int51x1
[ 0.966695] usbcore: registered new interface driver kalmia
[ 0.966739] usbcore: registered new interface driver ipheth
[ 0.966787] usbcore: registered new interface driver sierra_net
[ 0.966829] usbcore: registered new interface driver cx82310_eth
[ 0.966878] usbcore: registered new interface driver cdc_ncm
[ 0.966918] usbcore: registered new interface driver qmi_wwan
[ 0.966957] usbcore: registered new interface driver cdc_mbim
[ 0.966970] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.969440] EHCI: ehci_rk_probe e3640000 e3640010
[ 0.969459] rockchip_ehci_host ff500000.usb: EHCI Host Controller
[ 0.969491] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[ 0.969868] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
[ 0.985694] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00
[ 0.985775] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.985792] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.985807] usb usb1: Product: EHCI Host Controller
[ 0.985820] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 0.985833] usb usb1: SerialNumber: ff500000.usb
[ 0.986312] hub 1-0:1.0: USB hub found
[ 0.986345] hub 1-0:1.0: 1 port detected
[ 0.986513] EHCI: ehci_rk_probe ok
[ 0.986625] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.986935] usbcore: registered new interface driver cdc_acm
[ 0.986949] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.987010] usbcore: registered new interface driver usblp
[ 0.987054] usbcore: registered new interface driver cdc_wdm
[ 0.987122] usbcore: registered new interface driver usb-storage
[ 0.987165] usbcore: registered new interface driver ums-alauda
[ 0.987204] usbcore: registered new interface driver ums-cypress
[ 0.987244] usbcore: registered new interface driver ums-datafab
[ 0.987282] usbcore: registered new interface driver ums_eneub6250
[ 0.987320] usbcore: registered new interface driver ums-freecom
[ 0.987360] usbcore: registered new interface driver ums-isd200
[ 0.987407] usbcore: registered new interface driver ums-jumpshot
[ 0.987448] usbcore: registered new interface driver ums-karma
[ 0.987488] usbcore: registered new interface driver ums-onetouch
[ 0.987528] usbcore: registered new interface driver ums-sddr09
[ 0.987569] usbcore: registered new interface driver ums-sddr55
[ 0.987608] usbcore: registered new interface driver ums-usbat
[ 0.987703] usbcore: registered new interface driver usbserial
[ 0.987745] usbcore: registered new interface driver usbserial_generic
[ 0.987784] usbserial: USB Serial support registered for generic
[ 0.987828] usbcore: registered new interface driver ch341
[ 0.987860] usbserial: USB Serial support registered for ch341-uart
[ 0.987902] usbcore: registered new interface driver cp210x
[ 0.987934] usbserial: USB Serial support registered for cp210x
[ 0.987980] usbcore: registered new interface driver option
[ 0.988011] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.988080] usbcore: registered new interface driver pl2303
[ 0.988112] usbserial: USB Serial support registered for pl2303
[ 0.988166] usbcore: registered new interface driver trancevibrator
[ 0.988178] usb20_otg: version 3.10a 21-DEC-2012
[ 0.988632] e3680040
[ 0.988646] Core Release: 3.10a
[ 0.988657] Setting default values for core params
[ 0.988788] Using Buffer DMA mode
[ 0.988801] Periodic Transfer Interrupt Enhancement - disabled
[ 0.988812] Multiprocessor Interrupt Enhancement - disabled
[ 0.988824] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.988835] ^^^^^^^^^^^^^^^^^Device Mode
[ 0.988848] Dedicated Tx FIFOs mode
[ 0.988867] pcd_init otg_dev = ddf3e200
[ 0.989021] usb20_otg ff580000.usb: DWC OTG Controller
[ 0.989049] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
[ 0.989080] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 0.989138] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.989155] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.989170] usb usb2: Product: DWC OTG Controller
[ 0.989183] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 0.989196] usb usb2: SerialNumber: ff580000.usb
[ 0.989613] hub 2-0:1.0: USB hub found
[ 0.989638] hub 2-0:1.0: 1 port detected
[ 0.995685] usb20_host: version 3.10a 21-DEC-2012
[ 0.998204] e3700040
[ 0.998216] Core Release: 3.10a
[ 0.998227] Setting default values for core params
[ 0.998358] Using Buffer DMA mode
[ 0.998370] Periodic Transfer Interrupt Enhancement - disabled
[ 0.998380] Multiprocessor Interrupt Enhancement - disabled
[ 0.998403] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.998414] ^^^^^^^^^^^^^^^^^^Host Mode
[ 0.998444] usb20_host ff540000.usb: DWC OTG Controller
[ 0.998471] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
[ 0.998502] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[ 0.998595] Init: Power Port (0)
[ 0.998651] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.998667] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.998682] usb usb3: Product: DWC OTG Controller
[ 0.998694] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 0.998708] usb usb3: SerialNumber: ff540000.usb
[ 0.999115] hub 3-0:1.0: USB hub found
[ 0.999137] hub 3-0:1.0: 1 port detected
[ 0.999865] usbcore: registered new interface driver xpad
[ 0.999939] usbcore: registered new interface driver usb_acecad
[ 0.999999] usbcore: registered new interface driver aiptek
[ 1.000054] usbcore: registered new interface driver gtco
[ 1.000103] usbcore: registered new interface driver hanwang
[ 1.000149] usbcore: registered new interface driver kbtab
[ 1.000199] usbcore: registered new interface driver wacom
[ 1.000209] ==gsl_ts_init==
[ 1.000301] GSLX680 Enter gsl_ts_probe
[ 1.088255] Using Buffer DMA mode
[ 1.088270] Periodic Transfer Interrupt Enhancement - disabled
[ 1.088280] Multiprocessor Interrupt Enhancement - disabled
[ 1.088291] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.088302] ^^^^^^^^^^^^^^^^^^Host Mode
[ 1.133349] Init: Power Port (0)
[ 1.133363] rk_battery_charger_detect_cb , battery_charger_detect 5
[ 1.536726] gsl_ts_probe–1318, i2c_master_recv fail
[ 1.536747] gslX680: probe of 4-0041 failed with error -11
[ 1.536790] ret=0
[ 1.537074] sensor_register_slave:mma8452,id=17
[ 1.537088] sensor_register_slave:gs_mc3230,id=23
[ 1.537099] gsensor_init
[ 1.537109] sensor_register_slave:mpu6880_acc,id=24
[ 1.537120] sensor_register_slave:mpu6500_acc,id=25
[ 1.537132] sensor_register_slave:cm3217,id=48
[ 1.537143] sensor_register_slave:cm3218,id=49
[ 1.537374] .. rk pwm remotectl v1.1 init
[ 1.537625] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
[ 1.540994] rtc_hym8563 0-0051: clock/calendar information is no longer guaranteed
[ 1.551664] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 1.553325] i2c /dev entries driver
[ 1.554010] IR NEC protocol handler initialized
[ 1.554024] IR RC5(x) protocol handler initialized
[ 1.554035] IR RC6 protocol handler initialized
[ 1.554045] IR JVC protocol handler initialized
[ 1.554055] IR Sony protocol handler initialized
[ 1.554064] IR RC5 (streamzap) protocol handler initialized
[ 1.554075] IR SANYO protocol handler initialized
[ 1.554084] IR MCE Keyboard/mouse protocol handler initialized
[ 1.554244] usbcore: registered new interface driver uvcvideo
[ 1.554256] USB Video Class driver (1.1.1)
[ 1.554269] CamSys driver version: v0.32.0, CamSys head file version: v0.11.0
[ 1.555766] D1:camsys_platform_probe(1300): 1-gpios-cifpower: gpio=236
[ 1.555791] D1:camsys_platform_probe(1303): gpios-cifpower: gpio_request
[ 1.555812] D1:camsys_platform_probe(1305): 1-gpios-cifpower: gpio_request=0
[ 1.555833] D1:camsys_platform_probe(1314): gpios-cifpower: 236 high
[ 1.555872] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288
[ 1.555872]
[ 1.555954] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 1.556126] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe35f8000 size: 0x4000)
[ 1.556808] D1:camsys_platform_probe(1446): ff910000.isp memory:
[ 1.556826] D1:camsys_platform_probe(1456): Register memory (phy: 0xff910000 vir: 0xe3620000 size: 0x10000)
[ 1.556843] D1:camsys_platform_probe(1451): I2c memory (phy: 0x1dfcb000 vir: 0xddfcb000 size: 0x1000)
[ 1.556859] D1:camsys_init_ext_fsh_module(20): init external flash module
[ 1.556872] D1:camsys_platform_probe(1471): Probe ff910000.isp device success
[ 1.557268] not find test_power_init dev node
[ 1.557325] i2c-core: driver [bq27320] using legacy suspend method
[ 1.557338] i2c-core: driver [bq27320] using legacy resume method
[ 1.557698] rockchip_temp_probe,line=364
[ 1.615461] tsadc ff280000.tsadc: initialized
[ 1.615831] device-mapper: uevent: version 1.0.3
[ 1.616082] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 1.616373] Bluetooth: HCI UART driver ver 2.2
[ 1.616389] Bluetooth: HCI H4 protocol initialized
[ 1.616401] Bluetooth: HCILL protocol initialized
[ 1.616413] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21
[ 1.616425] rtk_btusb: Register usb char device interface for BT driver
[ 1.616612] usbcore: registered new interface driver rtk_btusb
[ 1.620021] cpufreq version 1.0, suspend freq 1200 MHz
[ 1.620217] cpuidle: using governor ladder
[ 1.620230] cpuidle: using governor menu
[ 1.620268] Synopsys Designware Multimedia Card Interface Driver
[ 1.620279] MHSC version = Ver 2.00 2015-06-10
[ 1.620597] dw cru_regsbase addr 0x1d8.
[ 1.620610] dw cru_reset_offset val 3.
[ 1.620625] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[ 1.620669] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc
[ 1.620971] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
[ 1.621134] dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
[ 1.621275] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.635140] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.654843] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 1.654865] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
[ 1.654882] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[ 1.655209] dw cru_regsbase addr 0x1d8.
[ 1.655222] dw cru_reset_offset val 0.
[ 1.655237] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[ 1.655272] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc
[ 1.656041] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
[ 1.656205] dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
[ 1.656705] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
[ 1.656771] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.674493] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.686963] mmc0: BKOPS_EN bit is not set
[ 1.688832] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0]
[ 1.691110] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 1.691134] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 1.691154] [mmc0] tuning regsbase addr 0x218.
[ 1.691902] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 1.691913] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 1.691943] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 1.691955] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 1.691966] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 1.691977] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 1.692018] mmc0: new HS200 MMC card at address 0001
[ 1.692293] mmcblk0: mmc0:0001 AJTD4R 14.5 GiB
[ 1.692416] mmcblk0rpmb: mmc0:0001 AJTD4R partition 3 4.00 MiB
[ 1.692738] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 1.692752] misc: 0x000800000 – 0x000c00000 (4 MB)
[ 1.692761] resource: 0x000c00000 – 0x001c00000 (16 MB)
[ 1.692770] kernel: 0x001c00000 – 0x002c00000 (16 MB)
[ 1.692778] boot: 0x002c00000 – 0x004c00000 (32 MB)
[ 1.692787] recovery: 0x004c00000 – 0x006c00000 (32 MB)
[ 1.692795] backup: 0x006c00000 – 0x00a000000 (52 MB)
[ 1.692804] cache: 0x00a000000 – 0x012000000 (128 MB)
[ 1.692812] kpanic: 0x012000000 – 0x012400000 (4 MB)
[ 1.692820] system: 0x012400000 – 0x072400000 (1536 MB)
[ 1.692829] metadata: 0x072400000 – 0x073400000 (16 MB)
[ 1.692837] baseparamer: 0x073400000 – 0x073800000 (4 MB)
[ 1.692846] userdata: 0x077800000 – 0x3a3a00000 (12994 MB)
[ 1.692870] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13[ 1.694209] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
[ 1.694224] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc1]
[ 1.694543] dw cru_regsbase addr 0x1d8.
[ 1.694551] dw cru_reset_offset val 1.
[ 1.694561] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[ 1.694598] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc
[ 1.694836] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
[ 1.694966] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
[ 1.695232] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.713844] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.733575] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
[ 1.733588] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[ 1.733876] leds-gpio leds.28: pins are not configured from the driver
[ 1.734139] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.735575] usbcore: registered new interface driver usbhid
[ 1.735586] usbhid: USB HID core driver
[ 1.735698] ashmem: initialized
[ 1.735821] logger: created 256K log ‘log_main’
[ 1.735912] logger: created 256K log ‘log_events’
[ 1.736007] logger: created 256K log ‘log_radio’
[ 1.736104] logger: created 256K log ‘log_system’
[ 1.737220] input: rk29-keypad as /devices/ff100000.adc/key.30/input/input1
[ 1.738087] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ff890000.rockchip-i2s; cannot claim for 2-0010
[ 1.738104] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
[ 1.738116] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl
[ 1.738128] ES8323 2-0010: Error applying setting, reverse things back
[ 1.738176] es8323_adc = 0
[ 1.738192] jp es8323_line_det_gpio:79
[ 1.738860] es8323 probe error
[ 1.738877] ES8323: probe of 2-0010 failed with error -11
[ 1.739613] rockchip-spdif ff880000.rockchip-spdif: spdif ready.
[ 1.740134] rockchip-es8323 rockchip-es8323.27: ASoC: CODEC (null) not registered
[ 1.740165] rockchip_es8323_audio_probe() register card failed:-517
[ 1.740182] platform rockchip-es8323.27: Driver rockchip-es8323 requests probe deferral
[ 1.740351] u32 classifier
[ 1.740360] Actions configured
[ 1.740373] Netfilter messages via NETLINK v0.30.
[ 1.740432] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.740780] ctnetlink v0.93: registering with nfnetlink.
[ 1.740855] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 1.740863] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 1.741159] xt_time: kernel timezone is -0000
[ 1.741371] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.741506] arp_tables: (C) 2002 David S. Miller
[ 1.741551] TCP: cubic registered
[ 1.741558] Initializing XFRM netlink socket
[ 1.741790] NET: Registered protocol family 10
[ 1.742334] mip6: Mobile IPv6
[ 1.742364] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.742489] sit: IPv6 over IPv4 tunneling driver
[ 1.742844] NET: Registered protocol family 17
[ 1.742875] NET: Registered protocol family 15
[ 1.742930] Bridge firewalling registered
[ 1.742943] Ebtables v2.0 registered
[ 1.743108] Bluetooth: RFCOMM TTY layer initialized
[ 1.743137] Bluetooth: RFCOMM socket layer initialized
[ 1.743146] Bluetooth: RFCOMM ver 1.11
[ 1.743154] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.743162] Bluetooth: BNEP filters: protocol multicast
[ 1.743174] Bluetooth: BNEP socket layer initialized
[ 1.743183] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.743196] Bluetooth: HIDP socket layer initialized
[ 1.743226] l2tp_core: L2TP core driver, V2.0
[ 1.743242] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.743251] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.743486] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.743499] [WLAN_RFKILL]: can’t find rockchip,grf property
[ 1.743509] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[ 1.743518] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.743528] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 1.743537] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.743561] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
[ 1.743583] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
[ 1.743593] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.743621] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
[ 1.743631] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.743681] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.743828] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
[ 1.743853] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
[ 1.743870] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
[ 1.743886] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
[ 1.743940] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.744042] [BT_RFKILL]: ** disable irq
[ 1.744119] [BT_RFKILL]: ap6335 device registered.
[ 1.744977] rk3288_init_suspend
[ 1.744991] rk3288_suspend_init enter
[ 1.745197] rk3288_suspend_init: pm_ctrbits =200007
[ 1.745235] gpio_get_dts_info suspend:4
[ 1.745244] gpio_get_dts_info resume:4
[ 1.745251] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 1.745284] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 1.745441] clks_gating_suspend_init:clkgt info ok
[ 1.745532] Registering SWP/SWPB emulation handler
[ 1.745546] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 0x02000000@0x7dc00000
[ 1.748823] ddrfreq: verion 1.2 20140526
[ 1.748840] ddrfreq: normal 528MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 528MHz
[ 1.748849] ddrfreq: auto-freq=0
[ 1.748856] ddrfreq: auto-freq-table[0] 240MHz
[ 1.748863] ddrfreq: auto-freq-table[1] 324MHz
[ 1.748870] ddrfreq: auto-freq-table[2] 456MHz
[ 1.748877] ddrfreq: auto-freq-table[3] 528MHz
[ 1.752863] regulator-dummy: disabling
[ 1.753396] rockchip-es8323 rockchip-es8323.27: ASoC: CODEC (null) not registered
[ 1.753423] rockchip_es8323_audio_probe() register card failed:-517
[ 1.753439] platform rockchip-es8323.27: Driver rockchip-es8323 requests probe deferral
[ 1.753514] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[ 1.920973] wk2xxx_probe() GENA = 0xFF
[ 1.920978] spi driver error!!!
[ 1.920992] wk2xxxspi: probe of spi0.0 failed with error 1
[ 1.921008] register spi return v = :0
[ 1.921016] =======================================================
[ 1.921021] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 1.921026] =======================================================
[ 1.921032] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init.
[ 1.921085] dhd_module_init: in
[ 1.921092] ======== bcm_wlan_set_plat_data ========
[ 1.921098] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 1.921113] host_oob_irq: 196
[ 1.921117] host_oob_irq_flags=4
[ 1.921122] dhd_wifi_platform_load: Enter
[ 1.921135] Power-up adapter ‘DHD generic adapter’
[ 1.921140] pcd_pullup, is_on 0
[ 1.921152] WARN::dwc_otg_handle_mode_mismatch_intr:69: Mode Mismatch Interrupt: currently in Host mode
[ 1.921152]
[ 1.921160] wifi_platform_set_power = 1
[ 1.921163] ======== PULL WL_REG_ON HIGH! ========
[ 1.921167] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.921171] file system registered
[ 1.921174] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
[ 1.921178] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 1.921639] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 1.921647] android_usb gadget: Number of LUNs=2
[ 1.921654] lun0: LUN: removable file: (no medium)
[ 1.921660] lun1: LUN: removable file: (no medium)
[ 1.921795] android_usb gadget: android_usb ready
[ 1.921893] i2c i2c-4: sensor_probe: gs_mc3230,debd1800
[ 1.921919] sensor_chip_init:gs_mc3230:devid=0x0,ops=0xc0d25ca0
[ 1.981235] [Gsensor] init_3230_ctl_data 671 : error: -11
[ 1.981722] sensor_active:line=1500,error
[ 1.981728] sensor_init:line=1548,error
[ 1.981733] sensor_initial:fail to init sensor
[ 1.981738] sensor_chip_init:fail to init sensor
[ 1.981745] i2c i2c-4: sensor_probe failed -11
[ 1.981745]
[ 1.981758] sensors: probe of 4-004c failed with error -11
[ 1.981777] sensor_init: Probe name sensors
[ 1.981793] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 1.983256] rtc_hym8563 0-0051: hctosys: invalid date/time
[ 1.989245] rockchip-spdif-card rockchip-spdif-card.26: rk-hdmi-spdif-hifi ↔ ff880000.rockchip-spdif mapping ok
[ 1.989824] rockchip-es8323 rockchip-es8323.27: ASoC: CODEC (null) not registered
[ 1.989845] rockchip_es8323_audio_probe() register card failed:-517
[ 1.989857] platform rockchip-es8323.27: Driver rockchip-es8323 requests probe deferral
[ 1.990060] ret 1024
[ 1.990420] usbcore: registered new interface driver snd-usb-audio
[ 1.990428] ALSA device list:
[ 1.990433] #0: RK-SPDIF-CARD
[ 1.990834] Freeing unused kernel memory: 356K (c0bb4000 - c0c0d000)
[ 2.028719] [WLAN_RFKILL]: wifi turn on power. 156
[ 2.235365] wifi_platform_bus_enumerate device present 1
[ 2.235377] ======== Card detection to detect SDIO card! ========
[ 2.235387] mmc2:mmc host rescan start!
[ 2.248140] type=1403 audit(1.780:2): policy loaded auid=4294967295 ses=4294967295
[ 2.272134] init: invalid gid ‘trace’
[ 2.360870] init: /dev/hw_random not found
[ 2.360924] keychord: using input dev ff680000.pwm for fevent
[ 2.360936] keychord: using input dev rk29-keypad for fevent
[ 2.365304] init: /dev/hw_random not found
[ 2.366161] fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
[ 2.366893] resize2fs: resize2fs 1.42.9 (28-Dec-2013)resize2fs: The filesystem is already 393216 blocks long. Nothing to do!resize2fs:
[ 2.369204] EXT4-fs (mmcblk0p10): Ignoring removed nomblk_io_submit option
[ 2.373163] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 2.373245] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/system,/system,ext4)=0
[ 2.374013] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
[ 2.378637] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.378677] e2fsck: system: clean, 1908/86208 files, 117433/393216 blocks
[ 2.382021] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 2.382082] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/system,target=/system,type=ext4)=0
[ 2.388742] EXT4-fs (mmcblk0p8): recovery complete
[ 2.389099] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.389159] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/cache,target=/cache,type=ext4)=0
[ 2.389484] EXT4-fs (mmcblk0p11): Ignoring removed nomblk_io_submit option
[ 2.392905] EXT4-fs (mmcblk0p11): recovery complete
[ 2.392920] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 2.392971] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,/metadata,ext4)=0
[ 2.393704] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata
[ 2.397617] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.397651] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata: clean, 11/1024 files, 1102/4096 blocks
[ 2.401314] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.401375] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,target=/metadata,type=ext4)=0
[ 2.401414] fs_mgr: Running /system/bin/fsck.f2fs -f /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
[ 2.402194] fsck.f2fs: executing /system/bin/fsck.f2fs failed: No such file or directory
[ 2.402230] fsck.f2fs: fsck.f2fs terminated by exit(255)
[ 2.402444] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=f2fs)=-1
[ 2.402761] EXT4-fs (mmcblk0p13): Ignoring removed nomblk_io_submit option
[ 2.496405] EXT4-fs (mmcblk0p13): recovery complete
[ 2.496768] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 2.496845] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,/data,ext4)=0
[ 2.498821] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
[ 2.512113] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.512148] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata: clean, 517/832320 files, 115635/3326464 blocks
[ 2.515995] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard,errors=panic
[ 2.516053] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=ext4)=0
[ 2.516072] fs_mgr: mount_with_alternatives(): Mounted /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata on /data with fs_type=ext4 instead of f2fs
[ 2.529446] arm_release_ver of this mali_ko is ‘r6p0-02rel0’, rk_ko_ver is ‘13’, built at ‘09:15:10’, on ‘Oct 22 2015’.
[ 2.529519] mali ffa30000.gpu: Continuing without Mali clock control
[ 2.529562] mali pd enabled
[ 2.529573] clk enabled
[ 2.529584] MALI_DVFS_STEP = 4, div_dvfs = 10
[ 2.529593] mali_dvfs_infotbl[0].clock=198000,min_threshold=0,max_threshold=70
[ 2.529601] mali_dvfs_infotbl[1].clock=297000,min_threshold=70,max_threshold=80
[ 2.529611] mali_dvfs_infotbl[2].clock=417000,min_threshold=80,max_threshold=90
[ 2.529620] mali_dvfs_infotbl[3].clock=480000,min_threshold=94,max_threshold=100
[ 2.529704] turn on mali power
[ 2.529717] kbase_platform_rk_init,register_reboot_notifier
[ 2.529756] hrtimer: interrupt took 10500 ns
[ 2.529842] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
[ 2.530504] mali ffa30000.gpu: Probed as mali0
[ 2.530883] rockchip-es8323 rockchip-es8323.27: ASoC: CODEC (null) not registered
[ 2.530911] rockchip_es8323_audio_probe() register card failed:-517
[ 2.530925] platform rockchip-es8323.27: Driver rockchip-es8323 requests probe deferral
[ 2.531518] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 2.532156] rk29_ipp: version magic '3.0.36+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 2.532715] rk29_ipp: version magic '3.0.101+ SMP preempt mod_unload ARMv7 ’ should be ‘3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 2.533509] zram0: detected capacity change from 0 to 533413888
[ 2.578380] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
[ 2.610795] EXT4-fs (mmcblk0p13): Unrecognized mount option “background_gc=on” or missing value
[ 2.617910] drmboot: module license ‘unspecified’ taints kernel.
[ 2.617929] Disabling lock debugging due to kernel taint
[ 2.618131] drm init, 20140910
[ 2.618561] drm init ok
[ 2.620052] bat_cap: oldcap path is /sys/devices/ff100000.adc
[ 2.620096] bat_cap: oldcap_path no exist
[ 2.620276] binder: 154:154 transaction failed 29189, size 0-0
[ 2.620763] init: Warning! Service displayd needs a SELinux domain defined; please fix!
[ 2.625067] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 2.625103] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
[ 2.625114] type=1400 audit(2.160:3): avc: denied { transition } for pid=160 comm=“init” path=“/system/xbin/vm” dev=“mmcblk0p10” ino=1907 scontext=u:r:init:s0 tcontext=u:r:su:s0 tclass=process permissive=1
[ 2.625313] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
[ 2.625730] rtk_btusb: btchr_open: BT usb char device is opening
[ 2.625744] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 2.625764] rtk_btusb: btchr_open: BT usb char device is opening
[ 2.625773] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 2.625795] rtk_btusb: btchr_open: BT usb char device is opening
[ 2.625805] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 2.625834] rtk_btusb: btchr_open: BT usb char device is opening
[ 2.625844] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 2.651342] init: cannot find ‘/system/bin/debuggerd64’, disabling ‘debuggerd64’
[ 2.655839] init: cannot find ‘/system/bin/install-recovery.sh’, disabling ‘flash_recovery’
[ 2.656227] init: cannot find ‘/system/bin/bplus_helper’, disabling ‘bplus_helper’
[ 2.656420] init: Warning! Service drmservice needs a SELinux domain defined; please fix!
[ 2.658295] android_usb: already disabled
[ 2.664058] logd.auditd: start
[ 2.665611] read descriptors
[ 2.665623] read strings
[ 2.665645] mtp_bind_config
[ 2.665671] pcd_pullup, is_on 1
[ 2.789156] RKNAND_GET_SN_SECTOR
[ 2.789169] return ret = 0
[ 2.819537] RKNAND_GET_DRM_KEY
[ 2.819548] return ret = 0
[ 2.963528] EHCI: rk_ehci_hcd_enable, disable host controller
[ 3.011130] type=1400 audit(2.550:4): avc: denied { rlimitinh } for pid=160 comm=“vm” scontext=u:r:init:s0 tcontext=u:r:su:s0 tclass=process permissive=1
[ 3.011224] type=1400 audit(2.550:5): avc: denied { siginh } for pid=160 comm=“vm” scontext=u:r:init:s0 tcontext=u:r:su:s0 tclass=process permissive=1
[ 3.358298] avc: denied { set } for property=telephony.lteOnCdmaDevice scontext=u:r:rild:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service
[ 3.604838] healthd: No charger supplies found
[ 3.604852] healthd: No battery devices found
[ 4.154156] slot->flags = 1
[ 4.154171] CPU: 0 PID: 6 Comm: kworker/u8:0 Tainted: P 3.10.0 #28
[ 4.154186] Workqueue: kmmcd mmc_rescan
[ 4.154204] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 4.154217] [] (show_stack+0x10/0x14) from [] (dw_mci_set_ios+0x9c/0x214)
[ 4.154229] [] (dw_mci_set_ios+0x9c/0x214) from [] (mmc_set_chip_select+0x18/0x1c)
[ 4.154241] [] (mmc_set_chip_select+0x18/0x1c) from [] (mmc_go_idle+0x94/0xc4)
[ 4.154251] [] (mmc_go_idle+0x94/0xc4) from [] (mmc_rescan_try_freq+0x54/0xd0)
[ 4.154262] [] (mmc_rescan_try_freq+0x54/0xd0) from [] (mmc_rescan+0x204/0x298)
[ 4.154273] [] (mmc_rescan+0x204/0x298) from [] (process_one_work+0x29c/0x458)
[ 4.154283] [] (process_one_work+0x29c/0x458) from [] (worker_thread+0x194/0x2d4)
[ 4.154293] [] (worker_thread+0x194/0x2d4) from [] (kthread+0xa0/0xac)
[ 4.154305] [] (kthread+0xa0/0xac) from [] (ret_from_fork+0x14/0x3c)
[ 4.154312] dw_mci_set_ios: wait for unbusy timeout… STATUS = 0x206 [mmc1]
[ 4.203359] failed to power up DHD generic adapter, 0 retry left
[ 4.219186] wifi_platform_set_power = 0
[ 4.219192] ======== PULL WL_REG_ON LOW! ========
[ 4.219199] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 4.321445] [WLAN_RFKILL]: wifi shut off power.
[ 4.321454] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
[ 4.321460] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 4.321466] wifi_platform_bus_enumerate device present 0
[ 4.321472] ======== Card detection to remove SDIO card! ========
[ 4.321478] mmc2:mmc host rescan start!
[ 4.321489] failed to power up DHD generic adapter, max retry reached**
[ 4.321508] unregister wifi platform drivers
[ 4.321514] wifi_platform_bus_enumerate device present 0
[ 4.321518] ======== Card detection to remove SDIO card! ========
[ 4.321524] mmc2:mmc host rescan start!
[ 4.321531] dhd_module_init: Failed to load the driver, try cnt 0
[ 4.321549] dhd_module_init: Failed to load driver max retry reached**
[ 4.321555] dhd_module_init: Exit err=-19
[ 4.673551] rk3288-lcdc lcdc0: blank mode:0
[ 4.989302] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 4.989313] [mmc0] Data transmission error, need to try retuning 1.
[ 4.989322] [mmc0] Data transmission error !!! MINTSTS: [0x00008088]
[ 4.989328] [mmc0] Data transmission error, need to try retuning 1.
[ 4.989355] [mmc0] tuning regsbase addr 0x218.
[ 4.990117] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 4.990128] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 4.990137] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 4.990143] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 4.990164] need_retune:1,brq->retune_retry_done:0.
[ 4.990170] mmcblk0: retrying because a re-tune was needed
[ 5.068426] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 5.068437] [mmc0] Data transmission error, need to try retuning 1.
[ 5.068470] [mmc0] tuning regsbase addr 0x218.
[ 5.069233] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 5.069243] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 5.069251] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 5.069258] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 5.069288] need_retune:1,brq->retune_retry_done:0.
[ 5.069375] mmcblk0: retrying because a re-tune was needed
[ 5.631078] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 5.631091] [mmc0] Data transmission error, need to try retuning 1.
[ 5.631160] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 5.631165] [mmc0] Data transmission error, need to try retuning 1.
[ 6.122315] [mmc0] tuning regsbase addr 0x218.
[ 6.615017] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 6.615030] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 6.615038] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 6.615049] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 6.615073] mmcblk0: error -110 sending stop command, original cmd response 0x900, card status 0x400900
[ 6.615081] need_retune:1,brq->retune_retry_done:0.
[ 6.615086] mmcblk0: retrying because a re-tune was needed
[ 6.615356] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 6.615365] [mmc0] Data transmission error, need to try retuning 1.
[ 6.615393] [mmc0] tuning regsbase addr 0x218.
[ 6.616160] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 6.616170] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 6.616192] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 6.616200] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 6.616220] need_retune:1,brq->retune_retry_done:1.
[ 6.616236] mmcblk0: error -84 transferring data, sector 4032600, nr 256, cmd response 0x900, card status 0xb00
[ 6.616281] mmcblk0: retrying using single block read
[ 6.620975] [mmc0] Data transmission error !!! MINTSTS: [0x00008080]
[ 6.620984] [mmc0] Data transmission error, need to try retuning 1.
[ 6.621006] [mmc0] tuning regsbase addr 0x218.
[ 6.621044] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-110, data.error:-115
[ 6.621740] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 6.621749] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 12-270 (24 len)
[ 6.621757] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 12-270 (24 len)
[ 6.621764] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 147
[ 6.621784] need_retune:1,brq->retune_retry_done:1.
[ 6.621791] mmcblk0: error -84 transferring data, sector 4032647, nr 209, cmd response 0x900, card status 0x0
[ 6.621802] end_request: I/O error, dev mmcblk0, sector 4032647
[ 6.698381] [mmc0] Data transmission error !!! MINTSTS: [0x00008088]
[ 6.698393] [mmc0] Data transmission error, need to try retuning 1.
[ 6.698427] [mmc0] tuning regsbase addr 0x218.
[ 6.699179] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 6.699189] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 6.699197] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 6.699205] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 6.699228] need_retune:1,brq->retune_retry_done:0.
[ 6.699234] mmcblk0: retrying because a re-tune was needed
[ 6.780459] [mmc0] Data transmission error !!! MINTSTS: [0x00008088]
[ 6.780469] [mmc0] Data transmission error, need to try retuning 1.
[ 6.780505] [mmc0] tuning regsbase addr 0x218.
[ 6.781245] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 6.781256] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 6.781264] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 6.781271] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 6.781292] need_retune:1,brq->retune_retry_done:0.
[ 6.781298] mmcblk0: retrying because a re-tune was needed
[ 6.862541] [mmc0] Data transmission error !!! MINTSTS: [0x00008088]
[ 6.862552] [mmc0] Data transmission error, need to try retuning 1.
[ 6.862579] [mmc0] tuning regsbase addr 0x218.
[ 6.863297] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 6.863307] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 6.863316] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 6.863323] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 6.863341] need_retune:1,brq->retune_retry_done:0.
[ 6.863347] mmcblk0: retrying because a re-tune was needed
[ 6.944876] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 6.944887] [mmc0] Data transmission error, need to try retuning 1.
[ 6.944917] [mmc0] tuning regsbase addr 0x218.
[ 6.945645] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 6.945655] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 6.945663] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 6.945670] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 6.945689] need_retune:1,brq->retune_retry_done:0.
[ 6.945694] mmcblk0: retrying because a re-tune was needed
[ 7.026688] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 7.026701] [mmc0] Data transmission error, need to try retuning 1.
[ 7.026819] [mmc0] tuning regsbase addr 0x218.
[ 7.027712] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 7.027723] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 7.027731] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 7.027738] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 7.027756] need_retune:1,brq->retune_retry_done:0.
[ 7.027762] mmcblk0: retrying because a re-tune was needed
[ 7.132687] warning: `system_server’ uses 32-bit capabilities (legacy support in use)
[ 7.190860] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 7.190872] [mmc0] Data transmission error, need to try retuning 1.
[ 7.191059] [mmc0] tuning regsbase addr 0x218.
[ 7.191866] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 7.191876] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 7.191884] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 7.191892] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 7.191911] need_retune:1,brq->retune_retry_done:0.
[ 7.191917] mmcblk0: retrying because a re-tune was needed
[ 7.272999] [mmc0] Data transmission error !!! MINTSTS: [0x00008088]
[ 7.273008] [mmc0] Data transmission error, need to try retuning 1.
[ 7.273037] [mmc0] tuning regsbase addr 0x218.
[ 7.273794] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 7.273805] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 7.273813] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 7.273821] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 7.273843] need_retune:1,brq->retune_retry_done:0.
[ 7.273849] mmcblk0: retrying because a re-tune was needed
[ 7.354984] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 7.354994] [mmc0] Data transmission error, need to try retuning 1.
[ 7.355002] [mmc0] Data transmission error !!! MINTSTS: [0x00008088]
[ 7.355008] [mmc0] Data transmission error, need to try retuning 1.
[ 7.355036] [mmc0] tuning regsbase addr 0x218.
[ 7.355767] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 7.355777] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 7.355785] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 7.355792] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 7.355823] need_retune:1,brq->retune_retry_done:0.
[ 7.355829] mmcblk0: retrying because a re-tune was needed
[ 7.437053] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 7.437063] [mmc0] Data transmission error, need to try retuning 1.
[ 7.437088] [mmc0] tuning regsbase addr 0x218.
[ 7.437808] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 7.437818] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 7.437826] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 7.437833] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 7.437852] need_retune:1,brq->retune_retry_done:0.
[ 7.437858] mmcblk0: retrying because a re-tune was needed
[ 7.519194] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 7.519204] [mmc0] Data transmission error, need to try retuning 1.
[ 7.519212] [mmc0] Data transmission error !!! MINTSTS: [0x00008088]
[ 7.519218] [mmc0] Data transmission error, need to try retuning 1.
[ 7.519248] [mmc0] tuning regsbase addr 0x218.
[ 7.519997] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 7.520007] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 7.520015] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 7.520023] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 7.520044] need_retune:1,brq->retune_retry_done:0.
[ 7.520050] mmcblk0: retrying because a re-tune was needed
[ 7.683302] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 7.683317] [mmc0] Data transmission error, need to try retuning 1.
[ 7.683347] [mmc0] tuning regsbase addr 0x218.
[ 7.684093] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 7.684104] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 7.684112] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 7.684119] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 7.684142] need_retune:1,brq->retune_retry_done:0.
[ 7.684148] mmcblk0: retrying because a re-tune was needed
[ 8.011640] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 8.011655] [mmc0] Data transmission error, need to try retuning 1.
[ 8.011683] [mmc0] tuning regsbase addr 0x218.
[ 8.012411] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 8.012421] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 8.012429] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 8.012437] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 8.012455] need_retune:1,brq->retune_retry_done:0.
[ 8.012461] mmcblk0: retrying because a re-tune was needed
[ 8.093741] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 8.093756] [mmc0] Data transmission error, need to try retuning 1.
[ 8.093787] [mmc0] tuning regsbase addr 0x218.
[ 8.094511] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 8.094521] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 8.094529] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 8.094537] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 8.094555] need_retune:1,brq->retune_retry_done:0.
[ 8.094561] mmcblk0: retrying because a re-tune was needed
[ 8.175788] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 8.175803] [mmc0] Data transmission error, need to try retuning 1.
[ 8.175836] [mmc0] tuning regsbase addr 0x218.
[ 8.176566] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 8.176576] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 8.176584] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 8.176591] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 8.176616] need_retune:1,brq->retune_retry_done:0.
[ 8.176622] mmcblk0: retrying because a re-tune was needed
[ 8.257871] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 8.257890] [mmc0] Data transmission error, need to try retuning 1.
[ 8.258053] [mmc0] tuning regsbase addr 0x218.
[ 8.258776] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 8.258787] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 8.258795] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 8.258802] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 8.258824] need_retune:1,brq->retune_retry_done:0.
[ 8.258829] mmcblk0: retrying because a re-tune was needed
[ 8.339989] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 8.340005] [mmc0] Data transmission error, need to try retuning 1.
[ 8.340041] [mmc0] tuning regsbase addr 0x218.
[ 8.340744] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 8.340754] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 8.340762] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 8.340769] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 8.340786] need_retune:1,brq->retune_retry_done:0.
[ 8.340792] mmcblk0: retrying because a re-tune was needed
[ 8.422066] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 8.422083] [mmc0] Data transmission error, need to try retuning 1.
[ 8.422112] [mmc0] tuning regsbase addr 0x218.
[ 8.423170] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 8.423182] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 8.423190] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 8.423198] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 8.423216] need_retune:1,brq->retune_retry_done:0.
[ 8.423222] mmcblk0: retrying because a re-tune was needed
[ 8.481186] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 8.481205] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 8.481213] D1:camsys_open(739): camsys_marvin(ddf30b10) is opened!
[ 8.481296] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
[ 8.481308] D1:camsys_extdev_register(243): Get RK30_PIN3_PB0(104) gpio(active: 0) for dev_id 0x2000000 success!
[ 8.481320] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
[ 8.481336] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 8.481356] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
[ 8.486395] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 8.486405] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 8.486509] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 8.486535] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 8.487597] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
[ 8.488659] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(104) set 1
[ 8.489715] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
[ 8.504094] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 8.504105] [mmc0] Data transmission error, need to try retuning 1.
[ 8.504136] [mmc0] tuning regsbase addr 0x218.
[ 8.504871] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 8.504881] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 8.504889] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 8.504896] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 8.504914] need_retune:1,brq->retune_retry_done:0.
[ 8.504919] mmcblk0: retrying because a re-tune was needed
[ 8.586215] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 8.586225] [mmc0] Data transmission error, need to try retuning 1.
[ 8.586233] [mmc0] Data transmission error !!! MINTSTS: [0x00008088]
[ 8.586239] [mmc0] Data transmission error, need to try retuning 1.
[ 8.586267] [mmc0] tuning regsbase addr 0x218.
[ 8.586971] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 8.586981] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 8.586989] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 8.586996] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 8.587017] need_retune:1,brq->retune_retry_done:0.
[ 8.587023] mmcblk0: retrying because a re-tune was needed
[ 8.668270] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 8.668280] [mmc0] Data transmission error, need to try retuning 1.
[ 8.668311] [mmc0] tuning regsbase addr 0x218.
[ 8.669020] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 8.669027] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 8.669047] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 8.669056] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 8.669065] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 8.669072] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 8.669101] need_retune:1,brq->retune_retry_done:0.
[ 8.669107] mmcblk0: retrying because a re-tune was needed
[ 8.680576] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
[ 8.680591] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
[ 8.832481] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 8.832498] [mmc0] Data transmission error, need to try retuning 1.
[ 8.832533] [mmc0] tuning regsbase addr 0x218.
[ 8.833233] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 8.833243] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 8.833251] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 8.833259] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 8.833277] need_retune:1,brq->retune_retry_done:0.
[ 8.833283] mmcblk0: retrying because a re-tune was needed
[ 8.867538] [otg id chg] last id -1 current id 1
[ 8.877383] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
[ 8.877397] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 8.877479] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
[ 8.877493] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(104) set 0
[ 8.877504] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
[ 8.878587] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 8.878617] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 8.880668] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
[ 8.880683] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 8.880694] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 8.880701] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 8.880709] D1:camsys_release(763): camsys_marvin(ddf30b10) is closed
[ 8.881284] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 8.881293] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 8.881301] D1:camsys_open(739): camsys_marvin(ddf30b10) is opened!
[ 8.881377] D1:camsys_extdev_register(243): Get RK30_PIN2_PA0(64) gpio(active: 0) for dev_id 0x1000000 success!
[ 8.881389] D1:camsys_extdev_register(243): Get RK30_PIN3_PB0(104) gpio(active: 0) for dev_id 0x1000000 success!
[ 8.881399] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x1000000 success!
[ 8.881415] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 8.881428] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: OV13850) register success
[ 8.886467] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 8.886478] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 8.886583] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 8.886607] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 8.887677] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
[ 8.888737] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(104) set 1
[ 8.889798] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(64) set 1
[ 8.996620] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 8.996632] [mmc0] Data transmission error, need to try retuning 1.
[ 8.996642] [mmc0] Data transmission error !!! MINTSTS: [0x00008088]
[ 8.996647] [mmc0] Data transmission error, need to try retuning 1.
[ 8.996675] [mmc0] tuning regsbase addr 0x218.
[ 8.997382] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 8.997391] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 8.997399] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 8.997406] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 8.997425] need_retune:1,brq->retune_retry_done:0.
[ 8.997431] mmcblk0: retrying because a re-tune was needed
[ 9.074180] slot->flags = 1
[ 9.074194] CPU: 0 PID: 6 Comm: kworker/u8:0 Tainted: P 3.10.0 #28
[ 9.074209] Workqueue: kmmcd mmc_rescan
[ 9.074227] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 9.074239] [] (show_stack+0x10/0x14) from [] (dw_mci_set_ios+0x9c/0x214)
[ 9.074250] [] (dw_mci_set_ios+0x9c/0x214) from [] (mmc_power_off+0x5c/0x7c)
[ 9.074261] [] (mmc_power_off+0x5c/0x7c) from [] (mmc_rescan_try_freq+0xc8/0xd0)
[ 9.074272] [] (mmc_rescan_try_freq+0xc8/0xd0) from [] (mmc_rescan+0x204/0x298)
[ 9.074283] [] (mmc_rescan+0x204/0x298) from [] (process_one_work+0x29c/0x458)
[ 9.074293] [] (process_one_work+0x29c/0x458) from [] (worker_thread+0x194/0x2d4)
[ 9.074303] [] (worker_thread+0x194/0x2d4) from [] (kthread+0xa0/0xac)
[ 9.074315] [] (kthread+0xa0/0xac) from [] (ret_from_fork+0x14/0x3c)
[ 9.074322] dw_mci_set_ios: wait for unbusy timeout… STATUS = 0x206 [mmc1]
[ 9.078676] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 9.078686] [mmc0] Data transmission error, need to try retuning 1.
[ 9.078720] [mmc0] tuning regsbase addr 0x218.
[ 9.079680] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 9.079693] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 9.079701] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 9.079708] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 9.079728] need_retune:1,brq->retune_retry_done:0.
[ 9.079734] mmcblk0: retrying because a re-tune was needed
[ 9.084037] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
[ 9.084055] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
[ 9.160797] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 9.160808] [mmc0] Data transmission error, need to try retuning 1.
[ 9.160839] [mmc0] tuning regsbase addr 0x218.
[ 9.161552] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 9.161562] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 9.161571] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 9.161578] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 9.161597] need_retune:1,brq->retune_retry_done:0.
[ 9.161602] mmcblk0: retrying because a re-tune was needed
[ 9.242981] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 9.242993] [mmc0] Data transmission error, need to try retuning 1.
[ 9.243032] [mmc0] tuning regsbase addr 0x218.
[ 9.243767] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 9.243778] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 9.243787] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 9.243794] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 9.243817] need_retune:1,brq->retune_retry_done:0.
[ 9.243823] mmcblk0: retrying because a re-tune was needed
[ 9.280906] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
[ 9.280922] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 9.281010] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(64) set 0
[ 9.281024] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(104) set 0
[ 9.281035] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
[ 9.282128] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 9.282159] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 9.284215] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
[ 9.284229] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 9.284239] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 9.284246] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 9.284253] D1:camsys_release(763): camsys_marvin(ddf30b10) is closed
[ 9.288158] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 9.288169] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 9.288177] D1:camsys_open(739): camsys_marvin(ddf30b10) is opened!
[ 9.288257] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default
[ 9.288281] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: TC358749XBG) register success
[ 9.293326] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 9.293337] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 9.293442] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 9.293469] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on
[ 9.294538] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
[ 9.295597] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
[ 9.296657] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
[ 9.300159] E:camsys_i2c_write(78): i2c write dev(addr:0x1f) failed!
[ 9.301624] E:camsys_i2c_write(78): i2c write dev(addr:0xf) failed!
[ 9.301709] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
[ 9.301719] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
[ 9.301726] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
[ 9.302813] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 9.302843] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 9.304894] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
[ 9.304910] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 9.304920] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 9.304927] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 9.304934] D1:camsys_release(763): camsys_marvin(ddf30b10) is closed
[ 9.306476] type=1400 audit(8.950:6): avc: denied { execute } for pid=500 comm=“mediaserver” name=“sh” dev=“mmcblk0p10” ino=321 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 9.306644] type=1400 audit(8.950:7): avc: denied { read open } for pid=500 comm=“mediaserver” path=“/system/bin/sh” dev=“mmcblk0p10” ino=321 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 9.306751] type=1400 audit(8.950:8): avc: denied { execute_no_trans } for pid=500 comm=“mediaserver” path=“/system/bin/sh” dev=“mmcblk0p10” ino=321 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 9.308571] type=1400 audit(8.950:9): avc: denied { getattr } for pid=500 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=336 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 9.308670] type=1400 audit(8.950:10): avc: denied { execute } for pid=500 comm=“sh” name=“toolbox” dev=“mmcblk0p10” ino=336 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 9.308735] type=1400 audit(8.950:11): avc: denied { read open } for pid=500 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=336 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 9.308801] type=1400 audit(8.950:12): avc: denied { execute_no_trans } for pid=500 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=336 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 9.407155] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 9.407167] [mmc0] Data transmission error, need to try retuning 1.
[ 9.407201] [mmc0] tuning regsbase addr 0x218.
[ 9.407944] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 9.407955] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 9.407963] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 9.407970] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 9.407992] need_retune:1,brq->retune_retry_done:0.
[ 9.407998] mmcblk0: retrying because a re-tune was needed
[ 9.489150] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 9.489163] [mmc0] Data transmission error, need to try retuning 1.
[ 9.489238] [mmc0] tuning regsbase addr 0x218.
[ 9.490023] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 9.490034] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 9.490042] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 9.490049] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 9.490069] need_retune:1,brq->retune_retry_done:0.
[ 9.490075] mmcblk0: retrying because a re-tune was needed
[ 9.735381] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 9.735393] [mmc0] Data transmission error, need to try retuning 1.
[ 9.735426] [mmc0] tuning regsbase addr 0x218.
[ 9.743704] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 9.743718] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 9.743726] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 9.743733] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 9.743755] need_retune:1,brq->retune_retry_done:0.
[ 9.743761] mmcblk0: retrying because a re-tune was needed
[ 9.904688] healthd: battery none chg=
[ 10.082665] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
[ 10.082685] lowmemorykiller: oom_adj 0 => oom_score_adj 0
[ 10.082691] lowmemorykiller: oom_adj 1 => oom_score_adj 58
[ 10.082696] lowmemorykiller: oom_adj 2 => oom_score_adj 117
[ 10.082702] lowmemorykiller: oom_adj 3 => oom_score_adj 176
[ 10.082707] lowmemorykiller: oom_adj 9 => oom_score_adj 529
[ 10.082712] lowmemorykiller: oom_adj 15 => oom_score_adj 1000
[ 10.429707] acc_open
[ 10.429734] acc_release
[ 10.564279] phy_power_on: enable = 1
[ 10.603679] Read the Ethernet MAC address from IDB:00:00:00:00:00:00
[ 10.603710] eth0: device MAC address 02:b6:b6:24:2f:ed
[ 10.607494] libphy: stmmac: probed
[ 10.607502] eth0: No PHY found
[ 11.019765] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 11.019784] [mmc0] Data transmission error, need to try retuning 1.
[ 11.019820] [mmc0] tuning regsbase addr 0x218.
[ 11.020536] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 11.020548] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-270 (25 len)
[ 11.020556] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-270 (25 len)
[ 11.020564] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 135
[ 11.020696] need_retune:1,brq->retune_retry_done:0.
[ 11.020703] mmcblk0: retrying because a re-tune was needed
[ 11.534634] rk_sdmmc: ERROR mci_send_cmd: wait for unbusy timeout! [mmc1]
[ 11.583549] mmc_host mmc1: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80202000)
[ 11.734623] pm policy 0 → 1
[ 12.763115] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 12.763132] [mmc0] Data transmission error, need to try retuning 1.
[ 12.763215] [mmc0] tuning regsbase addr 0x218.
[ 12.763771] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 12.763781] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 12.763824] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 12.764141] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 12.764162] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-169 (16 len)
[ 12.764170] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 192-270 (8 len)
[ 12.764178] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-169 (16 len)
[ 12.764185] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 90
[ 12.764207] need_retune:1,brq->retune_retry_done:0.
[ 12.764214] mmcblk0: retrying because a re-tune was needed
[ 13.044454] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 13.044474] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 13.044482] D1:camsys_open(739): camsys_marvin(ddf30b10) is opened!
[ 13.044555] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
[ 13.044568] D1:camsys_extdev_register(243): Get RK30_PIN3_PB0(104) gpio(active: 0) for dev_id 0x2000000 success!
[ 13.044579] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
[ 13.044596] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 13.044616] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
[ 13.049655] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 13.049663] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 13.049768] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 13.049793] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 13.050854] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
[ 13.051911] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(104) set 1
[ 13.052966] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
[ 13.246335] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
[ 13.246354] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
[ 13.443135] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
[ 13.443156] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 13.443231] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
[ 13.443244] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(104) set 0
[ 13.443255] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
[ 13.444332] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 13.444359] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 13.446404] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
[ 13.446415] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 13.446425] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 13.446432] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 13.446439] D1:camsys_release(763): camsys_marvin(ddf30b10) is closed
[ 13.447021] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 13.447030] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 13.447037] D1:camsys_open(739): camsys_marvin(ddf30b10) is opened!
[ 13.447106] D1:camsys_extdev_register(243): Get RK30_PIN2_PA0(64) gpio(active: 0) for dev_id 0x1000000 success!
[ 13.447119] D1:camsys_extdev_register(243): Get RK30_PIN3_PB0(104) gpio(active: 0) for dev_id 0x1000000 success!
[ 13.447130] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x1000000 success!
[ 13.447146] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 13.447160] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: OV13850) register success
[ 13.452181] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 13.452190] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 13.452295] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 13.452313] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 13.453378] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
[ 13.454461] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(104) set 1
[ 13.455539] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(64) set 1
[ 13.649775] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
[ 13.649798] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
[ 13.846579] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
[ 13.846606] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 13.846685] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(64) set 0
[ 13.846698] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(104) set 0
[ 13.846709] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
[ 13.847781] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 13.847808] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 13.849852] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
[ 13.849864] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 13.849874] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 13.849881] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 13.849888] D1:camsys_release(763): camsys_marvin(ddf30b10) is closed
[ 13.850433] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 13.850443] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 13.850450] D1:camsys_open(739): camsys_marvin(ddf30b10) is opened!
[ 13.850515] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default
[ 13.850536] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: TC358749XBG) register success
[ 13.855552] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 13.855560] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 13.855665] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 13.855684] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on
[ 13.856750] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
[ 13.857801] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
[ 13.858852] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
[ 13.862435] E:camsys_i2c_write(78): i2c write dev(addr:0x1f) failed!
[ 13.863885] E:camsys_i2c_write(78): i2c write dev(addr:0xf) failed!
[ 13.863937] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
[ 13.863946] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
[ 13.863953] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
[ 13.865017] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 13.865036] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 13.867074] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
[ 13.867085] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 13.867094] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 13.867100] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 13.867107] D1:camsys_release(763): camsys_marvin(ddf30b10) is closed
[ 13.871840] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 13.871851] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 13.871858] D1:camsys_open(739): camsys_marvin(ddf30b10) is opened!
[ 13.871927] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
[ 13.871940] D1:camsys_extdev_register(243): Get RK30_PIN3_PB0(104) gpio(active: 0) for dev_id 0x2000000 success!
[ 13.871951] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
[ 13.871966] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 13.871984] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
[ 13.877003] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 13.877012] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 13.877117] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 13.877140] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 13.878200] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
[ 13.879261] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(104) set 1
[ 13.880315] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
[ 14.043349] slot->flags = 1
[ 14.043362] CPU: 2 PID: 6 Comm: kworker/u8:0 Tainted: P 3.10.0 #28
[ 14.043377] Workqueue: kmmcd mmc_rescan
[ 14.043395] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 14.043408] [] (show_stack+0x10/0x14) from [] (dw_mci_set_ios+0x9c/0x214)
[ 14.043420] [] (dw_mci_set_ios+0x9c/0x214) from [] (mmc_power_up.part.16+0x60/0xa0)
[ 14.043432] [] (mmc_power_up.part.16+0x60/0xa0) from [] (mmc_rescan_try_freq+0x14/0xd0)
[ 14.043444] [] (mmc_rescan_try_freq+0x14/0xd0) from [] (mmc_rescan+0x204/0x298)
[ 14.043455] [] (mmc_rescan+0x204/0x298) from [] (process_one_work+0x29c/0x458)
[ 14.043465] [] (process_one_work+0x29c/0x458) from [] (worker_thread+0x194/0x2d4)
[ 14.043475] [] (worker_thread+0x194/0x2d4) from [] (kthread+0xa0/0xac)
[ 14.043487] [] (kthread+0xa0/0xac) from [] (ret_from_fork+0x14/0x3c)
[ 14.043495] dw_mci_set_ios: wait for unbusy timeout… STATUS = 0x206 [mmc1]
[ 14.072902] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
[ 14.072912] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
[ 14.269696] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
[ 14.269709] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 14.269782] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
[ 14.269795] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(104) set 0
[ 14.269806] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
[ 14.270888] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 14.270915] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 14.272962] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
[ 14.272974] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 14.272983] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 14.272990] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 14.272997] D1:camsys_release(763): camsys_marvin(ddf30b10) is closed
[ 14.273585] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 14.273595] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 14.273603] D1:camsys_open(739): camsys_marvin(ddf30b10) is opened!
[ 14.273677] D1:camsys_extdev_register(243): Get RK30_PIN2_PA0(64) gpio(active: 0) for dev_id 0x1000000 success!
[ 14.273689] D1:camsys_extdev_register(243): Get RK30_PIN3_PB0(104) gpio(active: 0) for dev_id 0x1000000 success!
[ 14.273701] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x1000000 success!
[ 14.273717] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 14.273731] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: OV13850) register success
[ 14.278756] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 14.278764] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 14.278869] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 14.278887] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 14.279949] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
[ 14.281006] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(104) set 1
[ 14.282060] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(64) set 1
[ 14.476338] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
[ 14.476350] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
[ 14.673129] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3)
[ 14.673149] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 14.673221] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(64) set 0
[ 14.673234] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(104) set 0
[ 14.673246] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
[ 14.674325] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 14.674352] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 14.676400] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
[ 14.676413] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 14.676422] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 14.676429] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 14.676436] D1:camsys_release(763): camsys_marvin(ddf30b10) is closed
[ 14.676974] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 14.676983] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 14.676991] D1:camsys_open(739): camsys_marvin(ddf30b10) is opened!
[ 14.677056] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default
[ 14.677076] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: TC358749XBG) register success
[ 14.682102] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 14.682110] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 14.682214] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 14.682233] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on
[ 14.683287] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
[ 14.684340] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
[ 14.685392] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
[ 14.688868] E:camsys_i2c_write(78): i2c write dev(addr:0x1f) failed!
[ 14.690318] E:camsys_i2c_write(78): i2c write dev(addr:0xf) failed!
[ 14.690372] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
[ 14.690380] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
[ 14.690388] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
[ 14.691453] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 14.691472] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 14.693510] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x1000000) is deregister success
[ 14.693522] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 14.693530] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 14.693537] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 14.693545] D1:camsys_release(763): camsys_marvin(ddf30b10) is closed
[ 16.172638] type=1400 audit(15.930:13): avc: denied { entrypoint } for pid=1063 comm=“init” path=“/system/bin/usb_mode_switch.sh” dev=“mmcblk0p10” ino=347 scontext=u:r:install_recovery:s0 tcontext=u:object_r:system_file:s0 tclass=file permissive=1
[ 16.503360] rk_sdmmc: ERROR mci_send_cmd: wait for unbusy timeout! [mmc1]
[ 16.552568] mmc_host mmc1: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80202000)
[ 18.774966] type=1400 audit(18.570:14): avc: denied { write } for pid=1129 comm=“chip.devicetest” name=“force_usb_mode” dev=“sysfs” ino=12715 scontext=u:r:system_app:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[ 18.775535] force_usb_mode_store 1->1
[ 19.032229] slot->flags = 3
[ 19.032247] CPU: 2 PID: 6 Comm: kworker/u8:0 Tainted: P 3.10.0 #28
[ 19.032262] Workqueue: kmmcd mmc_rescan
[ 19.032280] [] (unwind_backtrace+0x0/0xe0) from [] (show_stack+0x10/0x14)
[ 19.032293] [] (show_stack+0x10/0x14) from [] (dw_mci_set_ios+0x9c/0x214)
[ 19.032305] [] (dw_mci_set_ios+0x9c/0x214) from [] (mmc_power_up.part.16+0x94/0xa0)
[ 19.032316] [] (mmc_power_up.part.16+0x94/0xa0) from [] (mmc_rescan_try_freq+0x14/0xd0)
[ 19.032327] [] (mmc_rescan_try_freq+0x14/0xd0) from [] (mmc_rescan+0x204/0x298)
[ 19.032338] [] (mmc_rescan+0x204/0x298) from [] (process_one_work+0x29c/0x458)
[ 19.032347] [] (process_one_work+0x29c/0x458) from [] (worker_thread+0x194/0x2d4)
[ 19.032358] [] (worker_thread+0x194/0x2d4) from [] (kthread+0xa0/0xac)
[ 19.032370] [] (kthread+0xa0/0xac) from [] (ret_from_fork+0x14/0x3c)
[ 19.032378] dw_mci_set_ios: wait for unbusy timeout… STATUS = 0x206 [mmc1]
[ 19.032390] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 300000Hz, actual 297619HZ div = 84)
[ 21.492232] rk_sdmmc: ERROR mci_send_cmd: wait for unbusy timeout! [mmc1]
[ 21.541436] mmc_host mmc1: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80202000)
[ 21.541451] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 600000Hz for init[mmc1]
[ 24.001431] rk_sdmmc: ERROR mci_send_cmd: wait for unbusy timeout! [mmc1]
[ 24.050632] mmc_host mmc1: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80202000)
[ 26.510630] rk_sdmmc: ERROR mci_send_cmd: wait for unbusy timeout! [mmc1]
[ 26.559831] mmc_host mmc1: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80202000)
