CORE-3399PRO-JD4核心板和底板,按照wiki教程(http://wiki.t-firefly.com/zh_CN/Core-3399pro-JD4/Linux_development.html),中的内容编译时无法进行./build.sh aio-rk3399pro-jd4.mk 这个脚本文件是不认识这个mk文件的,然后我就手动的链接了device/rockchip/rk3399pro/aio-rk3399pro-jd4.mk到device/rockchip/.BoardConfig.mk上去。默认配置编译buildroot固件;没有提供ubuntu的镜像;./build.sh后发现了update.img镜像,烧写后启动失败,串口打印信息详见附件。。。请问如何破??
[ 2.589939] Kernel Offset: disabled
[ 2.590257] Memory Limit: none
[ 2.590553] rockchip-thermal ff260000.tsadc: channal 0: temperature(30 C)
[ 2.591156] THERMAL REGS:
[ 2.606182] —[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,5)
