[ 6.694585] rk3288-hdmi ff980000.hdmi: Removed.
[ 6.714311] hdmi connect to lcdc1
[ 6.727331] rk3288-lcdc lcdc1: lcdc1: dclk:74250000>>fps:60
[ 6.741799] rk3288-lcdc lcdc1: wakeup from standby!
[ 6.749777] rk3288-lcdc lcdc1: lcdc1: dclk:74250000>>fps:60
[ 7.097158] hdmi remove from lcdc1
[ 7.115045] rk3288-lcdc lcdc1: no layer is used,go to standby!
[ 7.161363] rk3288-hdmi ff980000.hdmi: Removed.
[ 7.826051] rk3288-hdmi ff980000.hdmi: Removed.
[ 7.845860] hdmi connect to lcdc1
[ 7.852288] rk3288-lcdc lcdc1: lcdc1: dclk:74250000>>fps:60
[ 7.860955] rk3288-lcdc lcdc1: wakeup from standby!
[ 7.868954] rk3288-lcdc lcdc1: lcdc1: dclk:74250000>>fps:60
[ 11.023395] vbus detect**
Gave up waiting for root device. Common problems:
Boot args (cat /proc/cmdline)
Check rootdelay= (did the system wait long enough?)
Check root= (did the system wait for the right device?)
Missing modules (cat /proc/modules; ls /dev)
ALERT! /dev/block/mtd/by-name/linuxroot does not exist. Dropping to a shell!
FATAL: Could not load /lib/modules/3.10.0/modules.dep: No such file or directory
/bin/sh: can’t access tty; job control turned off
(initramfs) [ 11.771377] es8323_create file error
[ 12.027022] rk_battery_charger_detect_cb , battery_charger_detect 2
@talent881 请教下,内核模块是需要拷到根文件系统中即可:rsync -av ./modules_install/ /path/to/your/rfs/ ,针对Ubuntu 具体是拷贝到哪里呢?我开机时候一直打印modprobe: FATAL: Could not load /lib/modules/3.10.0/modules.dep: No such file or directory
