RK3399PRO-JD4固件无法烧写
1.上周五收到了两块rk3399pro-jd4的新主板,一块可以烧写,一块却烧写不了,刷机步骤,方法一:长按recover,然后按一下reset,过段时间松开recover,但是没有进入刷机模式。方法二:想用adb命令进入刷机模式,但是将usb公对公插入ubuntu电脑,设备都识别到,插入windows电脑也没识别到设备,usb线换过3跟,排除了usb线的问题。
2.之前问贵司买过几块rk3399pro-jd4板子,其中一块刷了ubuntu固件之前操作都没问题,不知什么原因该板子上周有时候出现开机无法进入系统,有时候进入系统过个4-5分钟鼠标卡主,整个系统都卡住了,固件重新烧写,也是一样的现象,用贵司的hdmi触摸屏也出现一样的现象,想抓debug log 用usb转ttl,波特率1500000,一堆乱码,无法获取log,询问淘宝客服,让我发帖询问。
1、烧写固件时请注意:先用数据线连接开发板的 USB3.0(OTG)接口和电脑,然后再按照你的方法一进入loader模式。如果还是没有进入loader模式,可以按照wiki进入maskrom模式烧录固件: http://wiki.t-firefly.com/zh_CN/Core-3399pro-JD4/maskrom_mode.html
2、串口波特率等相关设置都正确,然而还是出现乱码的话,试试看把 TX/RX 交换看看。详情请参考wiki:http://wiki.t-firefly.com/zh_CN/Core-3399pro-JD4/debug.html
1.第一个问题解决了。
2.第二个问题换了个usb转ttl设备,log能出来,下面是debug抓取的完整log,一直卡在firefly开机log界面
Welcome to minicom 2.7.1
OPTIONS: I18n
Compiled on Aug 13 2017, 15:25:34.
Port /dev/ttyUSB0, 12:51:26
Press CTRL-A Z for help on special keys
DDR Version 1.20 20190314
Channel 0: LPDDR3, 800MHz
CS = 0
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x3
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=32 Size=1024MB
Channel 1: LPDDR3, 800MHz
CS = 0
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x2
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
256B stride
pmugrf_os_reg[2] = 0x3280D280, stride = 0x9
CPUId = 0x0
ChipType = 0x10, 216
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 67820
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
GPT part: 2, name: boot, start:0xa000, size:0x10000
GPT part: 3, name: backup, start:0x4a000, size:0x10000
GPT part: 4, name: rootfs, start:0x7a000, size:0x1ca4fdf
find partition:uboot OK. first_lba:0x4000.
find partition:trust OK. first_lba:0x6000.
LoadTrust Addr:0x6000
No find bl30.bin
Load uboot, ReadLba = 4000
Load OK, addr=0x200000, size=0xd22b8
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):cd61876
NOTICE: BL31: Built : 16:25:54, Jan 23 2019
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1181): pd status 3e
INFO: BL31: Initializing BL32
INFO: SPSR = 0x3c9
U-Boot 2017.09-g14ce716 (Jul 24 2019 - 09:14:26 +0800)
Model: Rockchip RK3399 Evaluation Board
PreSerial: 2
DRAM: 2 GiB
Sysmem: init
Relocation Offset is: 7dbf4000
mmc_init: -95, time 9
switch to partitions #0, OK
Bootdev: mmc 0
PartType: EFI
get part misc fail -1
boot mode: None
Load FDT from boot part
DTB: rk-kernel.dtb
I2c speed: 400000Hz
PMIC: RK8090 (on=0x00, off=0x00)
vdd_center 900000 uV
vdd_cpu_l 900000 uV
Model: RK3399pro-firefly-aiojd4 board
xfer: num: 2, addr: 0x50
Monitor has basic audio support
mode:1920x1080
CEA mode used vic=16
final pixclk = 148500000 tmdsclk = 148500000
PHY powered down in 0 iterations
PHY PLL locked 1 iterations
sink has audio support
hdmi_set_clk_regenerator: fs=48000Hz ftdms=148.500MHz N=6144 cts=148500
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 24000 KHz, init 24000 KHz, kernel 0N/A)
aplll 816000 KHz
apllb 24000 KHz
dpll 800000 KHz
cpll 24000 KHz
gpll 800000 KHz
npll 600000 KHz
vpll 148000 KHz
aclk_perihp 133333 KHz
hclk_perihp 66666 KHz
pclk_perihp 33333 KHz
aclk_perilp0 266666 KHz
hclk_perilp0 88888 KHz
pclk_perilp0 44444 KHz
hclk_perilp1 100000 KHz
pclk_perilp1 50000 KHz
Net: eth0: ethernet@fe300000
Could not find misc partition
Fdt Ramdisk skip relocation
FDT load addr 0x10f00000 size 228 KiB
Booting kernel at 0x00280000 with fdt at 0x8300000…
## Booting Android Image at 0x0027f800 …
Kernel load addr 0x00280000 size 18925 KiB
## Flattened Device Tree blob at 08300000
Booting using the fdt blob at 0x8300000
XIP Kernel Image … OK
‘reserved-memory’ region@110000: addr=110000 size=f0000
Using Device Tree in place at 0000000008300000, end 000000000831c3f5
Can’t find file:logo_kernel.bmp
Total: 970.178 ms
[ 0.000000] Linux version 4.4.167 (daijh@tchip14) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #66 SMP Wed Jul 24 10:37:48 CST 2019
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07fee2000 s45800 r8192 d32024 u86016
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.mode=normal androidboot.slot_suffix= androidboot.serialno=bed506dd64d61532 rw rootwait earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 con0
[ 0.000000] software IO TLB [mem 0x7fe99000-0x7fed9000] (0MB) mapped at [ffffffc07fe99000-ffffffc07fed8fff]
[ 0.000000] Memory: 2005388K/2064384K available (11646K kernel code, 1644K rwdata, 4524K rodata, 1088K init, 2005K bss, 58996K reserved, 0K cma-reserved)
[ 0.000000] .init : 0xffffff8009050000 - 0xffffff8009160000 ( 1088 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008be0000 ( 11648 KB)
[ 0.000000] .rodata : 0xffffff8008be0000 - 0xffffff8009050000 ( 4544 KB)
[ 0.000000] .data : 0xffffff8009160000 - 0xffffff80092fb008 ( 1645 KB)
[ 0.000000] ITS: allocated 65536 Devices @a280000 (psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x000000000a210000
[ 0.000000] CPU0: using LPI pending table @0x000000000a220000
[ 0.002271] Console: colour dummy device 80x25
[ 0.002712] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[ 0.003702] pid_max: default: 32768 minimum: 301
[ 0.004279] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.004932] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.006333] Initializing cgroup subsys devices
[ 0.006768] Initializing cgroup subsys freezer
[ 0.007229] ftrace: allocating 42355 entries in 166 pages
[ 0.119709] sched-energy: Sched-energy-costs installed from DT
[ 0.120276] CPU0: update cpu_capacity 401
[ 0.120718] ASID allocator initialised with 32768 entries
[ 0.124302] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.125704] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.127983] Detected VIPT I-cache on CPU1
[ 0.128016] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.128046] CPU1: using LPI pending table @0x000000007d0a0000
[ 0.128089] CPU1: update cpu_capacity 401
[ 0.128093] CPU1: Booted secondary processor [410fd034]
[ 0.128645] Detected VIPT I-cache on CPU2
[ 0.128666] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.128692] CPU2: using LPI pending table @0x000000007d0d0000
[ 0.128719] CPU2: update cpu_capacity 401
[ 0.128722] CPU2: Booted secondary processor [410fd034]
[ 0.129245] Detected VIPT I-cache on CPU3
[ 0.129266] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.129292] CPU3: using LPI pending table @0x000000007d120000
[ 0.129317] CPU3: update cpu_capacity 401
[ 0.129320] CPU3: Booted secondary processor [410fd034]
[ 0.129872] Detected PIPT I-cache on CPU4
[ 0.129898] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.129937] CPU4: using LPI pending table @0x000000007d150000
[ 0.129975] CPU4: update cpu_capacity 1024
[ 0.129978] CPU4: Booted secondary processor [410fd082]
[ 0.130526] Detected PIPT I-cache on CPU5
[ 0.130544] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.130580] CPU5: using LPI pending table @0x000000007d180000
[ 0.130606] CPU5: update cpu_capacity 1024
[ 0.130610] CPU5: Booted secondary processor [410fd082]
[ 0.130710] Brought up 6 CPUs
[ 0.143075] SMP: Total of 6 processors activated.
[ 0.143526] CPU features: detected feature: GIC system register CPU interface
[ 0.144216] CPU features: detected feature: 32-bit EL0 Support
[ 0.144777] CPU: All CPU(s) started at EL2
[ 0.145208] alternatives: patching kernel code
[ 0.147032] devtmpfs: initialized
[ 0.165087] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.166029] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.167071] pinctrl core: initialized pinctrl subsystem
[ 0.168311] NET: Registered protocol family 16
[ 0.174079] cpuidle: using governor ladder
[ 0.178088] cpuidle: using governor menu
[ 0.178469] Registered FIQ tty driver
[ 0.179148] vdso: 2 pages (1 code @ ffffff8008be6000, 1 data @ ffffff8009164000)
[ 0.179857] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.180657] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.204346] console [pstore-1] enabled
[ 0.204700] pstore: Registered ramoops as persistent store backend
[ 0.205288] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.208471] console [ttyFIQ0] enabled
[ 0.209145] bootconsole [uart0] disabled
[ 0.210053] Registered fiq debugger ttyFIQ0
[ 0.241317] iommu: Adding device ff8f0000.vop to group 0
[ 0.241883] iommu: Adding device ff900000.vop to group 1
[ 0.242452] iommu: Adding device ff910000.rkisp1 to group 2
[ 0.243032] iommu: Adding device ff920000.rkisp1 to group 3
[ 0.244011] rk_iommu ff650800.iommu: can’t get sclk
[ 0.244707] rk_iommu ff660480.iommu: can’t get sclk
[ 0.245356] rk_iommu ff8f3f00.iommu: can’t get sclk
[ 0.245963] rk_iommu ff903f00.iommu: can’t get sclk
[ 0.246557] rk_iommu ff914000.iommu: can’t get sclk
[ 0.247170] rk_iommu ff924000.iommu: can’t get sclk
[ 0.247945] SCSI subsystem initialized
[ 0.248466] usbcore: registered new interface driver usbfs
[ 0.248997] usbcore: registered new interface driver hub
[ 0.249553] usbcore: registered new device driver usb
[ 0.250060] media: Linux media interface: v0.10
[ 0.250500] Linux video capture interface: v2.00
[ 0.250992] pps_core: LinuxPPS API ver. 1 registered
[ 0.251438] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.252265] PTP clock support registered
[ 0.253772] Advanced Linux Sound Architecture Driver Initialized.
[ 0.254795] Bluetooth: Core ver 2.21
[ 0.255134] NET: Registered protocol family 31
[ 0.255545] Bluetooth: HCI device and connection manager initialized
[ 0.256112] Bluetooth: HCI socket layer initialized
[ 0.256557] Bluetooth: L2CAP socket layer initialized
[ 0.257022] Bluetooth: SCO socket layer initialized
[ 0.258091] rockchip-cpuinfo cpuinfo: Serial : bed506dd64d61532
[ 0.259258] clocksource: Switched to clocksource arch_sys_counter
[ 0.307684] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.308617] NET: Registered protocol family 2
[ 0.309466] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.310239] TCP bind hash table entries: 16384 (order: 7, 524288 bytes)
[ 0.311310] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.311966] UDP hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.312590] UDP-Lite hash table entries: 1024 (order: 4, 98304 bytes)
[ 0.313455] NET: Registered protocol family 1
[ 0.314136] RPC: Registered named UNIX socket transport module.
[ 0.314682] RPC: Registered udp transport module.
[ 0.315105] RPC: Registered tcp transport module.
[ 0.315535] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.317276] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.318083] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.321946] Initialise system trusted keyring
[ 0.330207] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.331518] NFS: Registering the id_resolver key type
[ 0.331982] Key type id_resolver registered
[ 0.332383] Key type id_legacy registered
[ 0.332820] fuse init (API version 7.23)
[ 0.333545] SGI XFS with security attributes, no debug enabled
[ 0.338891] NET: Registered protocol family 38
[ 0.339324] Key type asymmetric registered
[ 0.339695] Asymmetric key parser ‘x509’ registered
[ 0.340293] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.340955] io scheduler noop registered
[ 0.341323] io scheduler deadline registered
[ 0.341821] io scheduler cfq registered (default)
[ 0.343274] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: failed to create phy
[ 0.344278] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: failed to create phy
[ 0.346457] rockchip-mipi-dphy-rx ff770000.syscon:mipi-dphy-rx0: invalid resource
[ 0.352022] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.352629] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.353217] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 0.353791] rockchip-pcie f8000000.pcie: missing “memory-region” property
[ 0.354404] PCI host bridge /pcie@f8000000 ranges:
[ 0.354841] MEM 0xfa000000..0xfbdfffff → 0xfa000000
[ 0.355312] IO 0xfbe00000..0xfbefffff → 0xfbe00000
[ 0.897326] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 0.897948] rockchip-pcie f8000000.pcie: deferred probe failed
[ 0.898594] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 0.902269] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.902951] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.905958] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.906654] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.909750] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 0.910954] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 35, base_baud = 1500000) is a 16550A
[ 0.912851] [drm] Initialized drm 1.1.0 20060810
[ 0.916992] [drm] Rockchip DRM driver version: v1.0.1
[ 0.917781] rockchip-drm display-subsystem: defer getting devfreq
[ 0.918638] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 0.919490] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffffff8008c83140)
[ 0.920227] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 0.920982] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffffff8008c83140)
[ 0.921939] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 0.922547] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 0.923336] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 0.924996] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffffff8008c77f48)
[ 0.925730] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.926323] [drm] No driver support for vblank timestamp query.
[ 1.390406] rockchip-drm display-subsystem: fb0: frame buffer device
[ 1.400873] mali ff9a0000.gpu: Failed to get regulator
[ 1.401353] mali ff9a0000.gpu: Power control initialization failed
[ 1.402516] Unable to detect cache hierarchy for CPU 0
[ 1.403788] brd: module loaded
[ 1.410847] loop: module loaded
[ 1.411803] zram: Added device: zram0
[ 1.412676] lkdtm: No crash points registered, enable through debugfs
[ 1.414547] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[ 1.415135] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[ 1.415737] rockchip-spi ff1d0000.spi: no high_speed pinctrl state
[ 1.417446] rockchip-spi ff1e0000.spi: Failed to request TX DMA channel
[ 1.418035] rockchip-spi ff1e0000.spi: Failed to request RX DMA channel
[ 1.418636] rockchip-spi ff1e0000.spi: no high_speed pinctrl state
[ 1.420506] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[ 1.421084] wk2xxx_probe() Can not read property power-gpio
[ 1.591965] wk2xxx_serial_init()
[ 1.592286] wk2xxx_request_port
[ 1.592575] ttysWK0 at I/O 0x1 (irq = 136, base_baud = 460800) is a wk2xxx
[ 1.593416] uart_add_one_port success for line i:= 0 with right 0
[ 1.593955] wk2xxx_request_port
[ 1.594242] ttysWK1 at I/O 0x2 (irq = 136, base_baud = 460800) is a wk2xxx
[ 1.595057] uart_add_one_port success for line i:= 1 with right 0
[ 1.595609] wk2xxx_request_port
[ 1.595896] ttysWK2 at I/O 0x3 (irq = 136, base_baud = 460800) is a wk2xxx
[ 1.596699] uart_add_one_port success for line i:= 2 with right 0
[ 1.597237] wk2xxx_request_port
[ 1.597537] ttysWK3 at I/O 0x4 (irq = 136, base_baud = 460800) is a wk2xxx
[ 1.598339] uart_add_one_port success for line i:= 3 with right 0
[ 1.598876] uart_add_one_port = 0x0
[ 1.599219] register spi return v = :0
[ 1.600553] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.601178] rk_gmac-dwmac fe300000.ethernet: TX delay(0x26).
[ 1.601697] rk_gmac-dwmac fe300000.ethernet: RX delay(0x23).
[ 1.602218] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[ 1.602953] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[ 1.603583] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.609129] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.609753] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.610198] Ring mode enabled
[ 1.610482] DMA HW capability register supported
[ 1.610881] Normal descriptors
[ 1.611190] RX Checksum Offload Engine supported (type 2)
[ 1.611688] TX Checksum insertion supported
[ 1.612065] Wake-Up On Lan supported
[ 1.612432] Enable RX Mitigation via HW Watchdog Timer
[ 1.677563] libphy: stmmac: probed
[ 1.677875] eth%d: PHY ID 001cc916 at 0 IRQ POLL (stmmac-0:00) active
[ 1.678467] eth%d: PHY ID 001cc916 at 1 IRQ POLL (stmmac-0:01)
[ 1.680327] usbcore: registered new interface driver rndis_wlan
[ 1.681133] Rockchip WiFi SYS interface (V1.00) …
[ 1.681705] usbcore: registered new interface driver rtl8150
[ 1.682276] usbcore: registered new interface driver r8152
[ 1.682828] usbcore: registered new interface driver asix
[ 1.683377] usbcore: registered new interface driver ax88179_178a
[ 1.683959] usbcore: registered new interface driver cdc_ether
[ 1.684536] usbcore: registered new interface driver rndis_host
[ 1.685147] usbcore: registered new interface driver cdc_ncm
[ 1.685714] usbcore: registered new interface driver qmi_wwan
[ 1.686290] usbcore: registered new interface driver cdc_mbim
[ 1.688935] rockchip-dwc3 usb0: failed to get drvdata dwc3
[ 1.690833] rockchip-dwc3 usb1: failed to get drvdata dwc3
[ 1.692884] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.693506] ehci-pci: EHCI PCI platform driver
[ 1.693976] ehci-platform: EHCI generic platform driver
[ 1.695430] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.695997] ohci-platform: OHCI generic platform driver
[ 1.697868] usbcore: registered new interface driver cdc_acm
[ 1.698388] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.699152] usbcore: registered new interface driver cdc_wdm
[ 1.699719] usbcore: registered new interface driver uas
[ 1.700281] usbcore: registered new interface driver usb-storage
[ 1.700915] usbcore: registered new interface driver usbserial
[ 1.701485] usbcore: registered new interface driver usbserial_generic
[ 1.702099] usbserial: USB Serial support registered for generic
[ 1.702694] usbcore: registered new interface driver cp210x
[ 1.703225] usbserial: USB Serial support registered for cp210x
[ 1.703808] usbcore: registered new interface driver ftdi_sio
[ 1.704367] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.705061] usbcore: registered new interface driver keyspan
[ 1.705609] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 1.706353] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 1.707033] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 1.707727] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 1.708434] usbcore: registered new interface driver option
[ 1.708955] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.709628] usbcore: registered new interface driver oti6858
[ 1.710164] usbserial: USB Serial support registered for oti6858
[ 1.710808] usbcore: registered new interface driver pl2303
[ 1.711347] usbserial: USB Serial support registered for pl2303
[ 1.711907] usbcore: registered new interface driver qcserial
[ 1.712456] usbserial: USB Serial support registered for Qualcomm USB modem
[ 1.713106] usbcore: registered new interface driver sierra
[ 1.713631] usbserial: USB Serial support registered for Sierra USB modem
[ 1.715461] usbcore: registered new interface driver usbtouchscreen
[ 1.716287] .. rk pwm remotectl v1.1 init
[ 1.716890] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 1.718484] i2c /dev entries driver
[ 1.720133] rk808 0-0020: Pmic Chip id: 0x8090
[ 1.720872] rk808 0-0020: source: on=0x10, off=0x00
[ 1.722137] rk808 0-0020: support dcdc3 fb mode:-22, 2085538816
[ 1.722938] rk808 0-0020: support pmic reset mode:0,0
[ 1.723626] rk808 0-0020: no pinctrl handle
[ 1.725563] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.726171] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.726831] DCDC_REG1: supplied by vcc5v0_sys
[ 1.728720] DCDC_REG2: supplied by vcc5v0_sys
[ 1.730686] DCDC_REG3: supplied by vcc5v0_sys
[ 1.732375] DCDC_REG4: supplied by vcc5v0_sys
[ 1.734071] DCDC_REG5: supplied by vcc5v0_sys
[ 1.735593] LDO_REG1: supplied by vcc_buck5
[ 1.737756] LDO_REG2: supplied by vcc_buck5
[ 1.739907] LDO_REG3: supplied by vcc_buck5
[ 1.742081] LDO_REG4: supplied by vcc_buck5
[ 1.744240] LDO_REG5: supplied by vcc_buck5
[ 1.746420] LDO_REG6: supplied by vcc_buck5
[ 1.748600] LDO_REG7: supplied by vcc3v3_sys
[ 1.750764] LDO_REG8: supplied by vcc3v3_sys
[ 1.753070] LDO_REG9: supplied by vcc3v3_sys
[ 1.755313] SWITCH_REG1: supplied by vcc5v0_sys
[ 1.756553] SWITCH_REG2: supplied by vcc3v3_sys
[ 1.758147] rk817-battery rk817-battery: Failed to find matching dt id
[ 1.758903] rk817-charger rk817-charger: Failed to find matching dt id
[ 1.761630] input: rk8xx_pwrkey as /devices/platform/ff3c0000.i2c/i2c-0/0-0020/input/input1
[ 1.766048] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 1.768585] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected!
[ 1.769288] fan53555-reg: supplied by vcc5v0_sys
[ 1.771977] fan53555-regulator 0-0010: FAN53555 Option[0] Rev[15] Detected!
[ 1.772661] fan53555-reg: supplied by vcc5v0_sys
[ 1.774753] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80096c6000
[ 1.776167] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80096c8000
[ 1.777390] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80096ca000
[ 1.779082] IR NEC protocol handler initialized
[ 1.780318] rkisp1 ff910000.rkisp1: rkisp1 driver version: v00.01.01
[ 1.780901] rkisp1 ff910000.rkisp1: Missing rockchip,grf property
[ 1.783011] rkisp1 ff920000.rkisp1: rkisp1 driver version: v00.01.01
[ 1.783612] rkisp1 ff920000.rkisp1: Missing rockchip,grf property
[ 1.785500] usbcore: registered new interface driver uvcvideo
[ 1.786015] USB Video Class driver (1.1.1)
[ 1.789745] Boot mode: coldboot
[ 1.791100] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 1.792047] rockchip-thermal ff260000.tsadc: tsadc is probed successfully!
[ 1.793266] dw_wdt ff848000.watchdog: Should better to setup a ‘resets’ property in dt, that must been named with reset
[ 1.794460] Bluetooth: Virtual HCI driver ver 1.5
[ 1.794995] Bluetooth: HCI UART driver ver 2.3
[ 1.795411] Bluetooth: HCI UART protocol H4 registered
[ 1.795869] Bluetooth: HCI UART protocol LL registered
[ 1.796335] Bluetooth: HCI UART protocol ATH3K registered
[ 1.796871] usbcore: registered new interface driver bfusb
[ 1.797420] usbcore: registered new interface driver btusb
[ 1.798422] cpu cpu0: leakage=0
[ 1.811459] cpu cpu0: temp=40555, pvtm=142573 (142688 + -115)
[ 1.812941] cpu cpu0: pvtm-volt-sel=0
[ 1.813650] cpu cpu4: leakage=0
[ 1.826549] cpu cpu4: temp=41111, pvtm=156517 (156517 + 0)
[ 1.827901] cpu cpu4: pvtm-volt-sel=2
[ 1.829697] cpu cpu0: avs=0
[ 1.830027] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 1.831985] cpu cpu0: failed to find power_model node
[ 1.833452] cpu cpu4: avs=0
[ 1.833785] cpu cpu4: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 1.835662] cpu cpu4: failed to find power_model node
[ 1.836986] sdhci: Secure Digital Host Controller Interface driver
[ 1.837559] sdhci: Copyright(c) Pierre Ossman
[ 1.837972] Synopsys Designware Multimedia Card Interface Driver
[ 1.839421] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.840092] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.840712] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.841278] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.842156] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.842966] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.843526] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.844975] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.845666] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 1.846283] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 1.846832] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 1.847707] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 1.848760] dwmmc_rockchip fe320000.dwmmc: Failed getting OCR mask: -22
[ 1.849637] dwmmc_rockchip fe320000.dwmmc: could not set regulator OCR (-22)
[ 1.850272] dwmmc_rockchip fe320000.dwmmc: failed to enable vmmc regulator
[ 1.852159] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.853076] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.864393] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.875433] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 1.876330] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.878638] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 1.879177] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 1.906366] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 1.908807] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.909802] usbcore: registered new interface driver usbhid
[ 1.910332] usbhid: USB HID core driver
[ 1.911674] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[ 1.915728] usbcore: registered new interface driver snd-usb-audio
[ 1.921418] Initializing XFRM netlink socket
[ 1.922460] NET: Registered protocol family 10
[ 1.924376] NET: Registered protocol family 17
[ 1.924806] NET: Registered protocol family 15
[ 1.925473] Bluetooth: RFCOMM socket layer initialized
[ 1.925946] Bluetooth: RFCOMM ver 1.11
[ 1.926328] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.926860] Bluetooth: HIDP socket layer initialized
[ 1.927377] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.928094] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.928571] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6255
[ 1.929180] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.929819] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.930553] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 1.931382] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 1.932025] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.932507] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.932998] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.933780] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 1.934630] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 92.
[ 1.935375] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[ 1.936105] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 5.
[ 1.939221] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.939821] [BT_RFKILL]: ** disable irq
[ 1.940371] [BT_RFKILL]: bt_default device registered.
[ 1.940968] Key type dns_resolver registered
[ 1.945489] ov13850 1-0036: write SCCB_ID failed
[ 1.945925] rockchip-pinctrl pinctrl: pin gpio1-9 already requested by ff1d0000.spi; cannot claim for 1-0036
[ 1.946818] rockchip-pinctrl pinctrl: pin-41 (1-0036) status -22
[ 1.947373] rockchip-pinctrl pinctrl: could not request pin 41 (gpio1-9) from group cam0-default-pins on device rockchip-pinctrl
[ 1.948414] ov13850 1-0036: Error applying setting, reverse things back
[ 1.949232] ov13850: probe of 1-0036 failed with error -5
[ 1.951035] mmc1: MAN_BKOPS_EN bit is not set
[ 1.953153] ov13850 1-0046: write SCCB_ID failed
[ 1.953620] rockchip-pinctrl pinctrl: pin gpio1-9 already requested by ff1d0000.spi; cannot claim for 1-0046
[ 1.954510] rockchip-pinctrl pinctrl: pin-41 (1-0046) status -22
[ 1.955052] rockchip-pinctrl pinctrl: could not request pin 41 (gpio1-9) from group cam0-default-pins on device rockchip-pinctrl
[ 1.956110] ov13850 1-0046: Error applying setting, reverse things back
[ 1.956943] ov13850: probe of 1-0046 failed with error -5
[ 1.958388] Registered cp15_barrier emulation handler
[ 1.958938] Registered setend emulation handler
[ 1.960737] Loading compiled-in X.509 certificates
[ 1.962585] rga: Driver loaded successfully ver:3.02
[ 1.963502] rga2: Module initialized.
[ 1.964470] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[ 1.965856] mmcblk1: mmc1:0001 AJTD4R 14.6 GiB
[ 1.965958] phy phy-ff770000.syscon:usb2-phy@e450.7: Failed to get VBUS supply regulator
[ 1.967597] mmcblk1boot0: mmc1:0001 AJTD4R partition 1 4.00 MiB
[ 1.967829] phy phy-ff770000.syscon:usb2-phy@e460.9: Failed to get VBUS supply regulator
[ 1.968564] mali ff9a0000.gpu: leakage=0
[ 1.969698] mmcblk1boot1: mmc1:0001 AJTD4R partition 2 4.00 MiB
[ 1.970679] mmcblk1rpmb: mmc1:0001 AJTD4R partition 3 4.00 MiB
[ 1.974406] mmcblk1: p1 p2 p3 p4 p5
[ 1.993104] mali ff9a0000.gpu: temp=40555, pvtm=158227 (158273 + -46)
[ 1.994631] mali ff9a0000.gpu: pvtm-volt-sel=3
[ 1.995889] mali ff9a0000.gpu: avs=0
[ 1.997158] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 1.998882] mali ff9a0000.gpu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 1.999766] I : [File] : drivers/gpu/arm/midgard_for_linux/backend/gpu/mali_kbase_devfreq.c; [Line] : 307; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 2.002155] mali ff9a0000.gpu: Probed as mali0
[ 2.008407] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller
[ 2.009182] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 1
[ 2.010115] xhci-hcd xhci-hcd.7.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 2.010983] xhci-hcd xhci-hcd.7.auto: irq 226, io mem 0xfe800000
[ 2.011907] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.012547] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.013193] usb usb1: Product: xHCI Host Controller
[ 2.013661] usb usb1: Manufacturer: Linux 4.4.167 xhci-hcd
[ 2.014160] usb usb1: SerialNumber: xhci-hcd.7.auto
[ 2.015537] hub 1-0:1.0: USB hub found
[ 2.015927] hub 1-0:1.0: 1 port detected
[ 2.016844] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller
[ 2.017661] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 2
[ 2.018495] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 2.019421] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.020032] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.020699] usb usb2: Product: xHCI Host Controller
[ 2.021149] usb usb2: Manufacturer: Linux 4.4.167 xhci-hcd
[ 2.021665] usb usb2: SerialNumber: xhci-hcd.7.auto
[ 2.022952] hub 2-0:1.0: USB hub found
[ 2.023421] hub 2-0:1.0: 1 port detected
[ 2.030991] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller
[ 2.031817] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 3
[ 2.032742] xhci-hcd xhci-hcd.8.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[ 2.033610] xhci-hcd xhci-hcd.8.auto: irq 227, io mem 0xfe900000
[ 2.034548] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.035160] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.035830] usb usb3: Product: xHCI Host Controller
[ 2.036297] usb usb3: Manufacturer: Linux 4.4.167 xhci-hcd
[ 2.036796] usb usb3: SerialNumber: xhci-hcd.8.auto
[ 2.038113] hub 3-0:1.0: USB hub found
[ 2.038583] hub 3-0:1.0: 1 port detected
[ 2.039500] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller
[ 2.040238] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 4
[ 2.041069] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 2.041991] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.042629] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.043291] usb usb4: Product: xHCI Host Controller
[ 2.043741] usb usb4: Manufacturer: Linux 4.4.167 xhci-hcd
[ 2.044238] usb usb4: SerialNumber: xhci-hcd.8.auto
[ 2.045589] hub 4-0:1.0: USB hub found
[ 2.045976] hub 4-0:1.0: 1 port detected
[ 2.050104] ehci-platform fe380000.usb: EHCI Host Controller
[ 2.050941] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5
[ 2.051852] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 2.058465] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 2.059356] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.059973] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.060657] usb usb5: Product: EHCI Host Controller
[ 2.061110] usb usb5: Manufacturer: Linux 4.4.167 ehci_hcd
[ 2.061627] usb usb5: SerialNumber: fe380000.usb
[ 2.062925] hub 5-0:1.0: USB hub found
[ 2.063392] hub 5-0:1.0: 1 port detected
[ 2.067218] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 2.068058] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 6
[ 2.068963] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 2.075492] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 2.076454] usb usb6: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.077070] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.077755] usb usb6: Product: EHCI Host Controller
[ 2.078206] usb usb6: Manufacturer: Linux 4.4.167 ehci_hcd
[ 2.078737] usb usb6: SerialNumber: fe3c0000.usb
[ 2.080106] hub 6-0:1.0: USB hub found
[ 2.080576] hub 6-0:1.0: 1 port detected
[ 2.082448] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 2.083361] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 7
[ 2.084237] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 2.140371] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.141007] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.141687] usb usb7: Product: Generic Platform OHCI controller
[ 2.142233] usb usb7: Manufacturer: Linux 4.4.167 ohci_hcd
[ 2.142756] usb usb7: SerialNumber: fe3a0000.usb
[ 2.145057] hub 7-0:1.0: USB hub found
[ 2.145549] hub 7-0:1.0: 1 port detected
[ 2.148004] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 2.149671] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 8
[ 2.150730] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 2.207105] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.207769] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.208448] usb usb8: Product: Generic Platform OHCI controller
[ 2.208993] usb usb8: Manufacturer: Linux 4.4.167 ohci_hcd
[ 2.209516] usb usb8: SerialNumber: fe3e0000.usb
[ 2.211872] hub 8-0:1.0: USB hub found
[ 2.212328] hub 8-0:1.0: 1 port detected
[ 2.214481] input: adc-keys as /devices/platform/adc-keys/input/input2
[ 2.218590] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.219344] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 2.219971] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 2.220563] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.221496] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 2.222489] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 2.223050] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 2.224239] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 2.235656] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.247555] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 2.250412] rockchip-dmc dmc: Failed to get leakage
[ 2.251763] rockchip-dmc dmc: Failed to get pvtm
[ 2.253166] rockchip-dmc dmc: avs=0
[ 2.253948] rockchip-dmc dmc: could not find power_model node
[ 2.261827] asoc-simple-card hdmi-sound: i2s-hifi ↔ ff8a0000.i2s mapping ok
[ 2.273618] asoc-simple-card rk809-sound: rk817-hifi ↔ ff890000.i2s mapping ok
[ 2.274382] asoc-simple-card rk809-sound: ASoC: no source widget found for MICBIAS1
[ 2.275084] asoc-simple-card rk809-sound: ASoC: Failed to add route MICBIAS1 → direct → Mic Jack
[ 2.275915] asoc-simple-card rk809-sound: ASoC: no sink widget found for IN1P
[ 2.276592] asoc-simple-card rk809-sound: ASoC: Failed to add route Mic Jack → direct → IN1P
[ 2.277397] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOL
[ 2.278061] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOL → direct → Headphone Jack
[ 2.278900] asoc-simple-card rk809-sound: ASoC: no source widget found for HPOR
[ 2.279584] asoc-simple-card rk809-sound: ASoC: Failed to add route HPOR → direct → Headphone Jack
[ 2.285654]
[ 2.285817] =======================================================
[ 2.285854] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.10 (r)
[ 2.285878] ======== dhd_wlan_init_plat_data ========
[ 2.285886] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 2.285903] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=67, oob_irq_flags=0x414
[ 2.285908] dhd_wlan_init_gpio: WL_REG_ON=-1
[ 2.285912] dhd_wifi_platform_load: Enter
[ 2.285950] Power-up adapter ‘DHD generic adapter’
[ 2.286038] wifi_platform_set_power = 1
[ 2.286044] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 2.286051] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 2.286057] [WLAN_RFKILL]: wifi turn on power. -1
[ 2.291648] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 2.292209] =======================================================
[ 2.292792] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver v5.2.2.3_24783.20171030) init.
[ 2.293611] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 2.294012] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.294552] [WLAN_RFKILL]: wifi turn on power. -1
[ 2.294984] RTW: module init start
[ 2.295329] RTW: rtl8188eu v5.2.2.3_24783.20171030
[ 2.295714] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.296274] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 2.297098] usbcore: registered new interface driver rtl8188eu
[ 2.297402] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.298140] RTW: module init ret=0
[ 2.299626] ==gsl_ts_init==
[ 2.300028] ret=0
[ 2.300520] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.302704] rk808-rtc rk808-rtc: setting system clock to 2017-08-05 09:05:05 UTC (1501923905)
[ 2.305746] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
[ 2.340747] vcc_mipi: disabling
[ 2.341063] dvdd_1v2: disabling
[ 2.342031] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘’, rk_ko_ver is ‘5’, built at '1.
[ 2.344735] Mali: Mali device driver loaded
[ 2.346138] ALSA device list:
[ 2.346436] #0: rockchip,hdmi
[ 2.346720] #1: rockchip,rk809-codec
[ 2.359011] mmc_host mmc2: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0)
[ 2.382419] usb 6-1: new high-speed USB device number 2 using ehci-platform
[ 2.488682] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 144
[ 2.493485] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 2.494079] mmc2: new ultra high speed SDR104 SDIO card at address 0001
[ 2.498988] usb 6-1: New USB device found, idVendor=1a40, idProduct=0201
[ 2.499635] usb 6-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.500310] usb 6-1: Product: USB 2.0 Hub [MTT]
[ 2.502206] hub 6-1:1.0: USB hub found
[ 2.502727] hub 6-1:1.0: 7 ports detected
[ 2.586421] wifi_platform_bus_enumerate device present 1
[ 2.586929] ======== Card detection to detect SDIO card! ========
[ 2.587512] mmc2:mmc host rescan start!
[ 2.601014] vendor storage:20160801 ret = 0
[ 2.603399] bcmsdh_register: register client driver
[ 2.604310] bcmsdh_sdmmc_probe: Enter num=1
[ 2.605020] bcmsdh_sdmmc_probe: Enter num=2
[ 2.605437] bus num (host idx)=2, slot num (rca)=1
[ 2.605875] found adapter info ‘DHD generic adapter’
[ 2.606608] sdioh_attach: set sd_f2_blocksize 256
[ 2.607235] sdioh_attach: sd clock rate = 0
[ 2.608914] dhdsdio_probe : no mutex held. set lock
[ 2.609865] F1 signature read @0x18000000=0x17224356
[ 2.618221] EXT4-fs (mmcblk1p5): 1 orphan inode deleted
[ 2.618736] EXT4-fs (mmcblk1p5): recovery complete
[ 2.627158] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x2 pkg:0x2
[ 2.630460] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 2.631373] dhd_conf_set_chiprev: chip=0x4354, chiprev=2
[ 2.632007] EXT4-fs (mmcblk1p5): mounted filesystem with ordered data mode. Opts: (null)
[ 2.632354] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 2.633296] CFG80211-ERROR) wl_init_prof : wl_init_prof: No profile
[ 2.633491] wl_escan_attach: Enter
[ 2.633536] wl_escan_init: Enter
[ 2.633902] wl_create_event_handler(): thread:wl_escan_handler:9d started
[ 2.634107] tsk Enter, tsk = 0xffffffc07b9f01b0
[ 2.634486] dhd_attach(): thread:dhd_watchdog_thread:9e started
[ 2.634969] dhd_attach(): thread:dhd_dpc:9f started
[ 2.635410] dhd_attach(): thread:dhd_rxf:a0 started
[ 2.635422] dhd_deferred_work_init: work queue initialized
[ 2.635428] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 → mode 2
[ 2.635458] dhd_bus_set_default_min_res_mask: Unhandled chip id
[ 2.639371] sdioh_cis_read: func_cis_ptr[0]=0x10ac
[ 2.648384] VFS: Mounted root (ext4 filesystem) on device 179:5.
[ 2.650833] devtmpfs: mounted
[ 2.652343] Freeing unused kernel memory: 1088K
[ 2.656575] Dongle Host Driver, version 1.579.77.41.10 (r)
[ 2.657897] wl_ext_iapsta_attach_netdev: ifidx=0, bssidx=0
[ 2.658408] Register interface [wlan0] MAC: 6c:21:a2:9e:c8:68
[ 2.658408]
[ 2.659228] dhd_tcpack_suppress_set: TCP ACK Suppress mode 2 → mode 0
[ 2.659856] dhd_wl_ioctl: returning as busstate=0
[ 2.660303] dhd_dbg_detach_pkt_monitor, 2204
[ 2.660692] dhd_bus_devreset: == Power OFF ==
[ 2.661335] bcmsdh_oob_intr_unregister: Enter
[ 2.661745] bcmsdh_oob_intr_unregister: irq is not registered
[ 2.662279] dhd_txglom_enable: enable 0
[ 2.662622] dhd_conf_set_txglom_params: txglom_mode=copy
[ 2.663098] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0
[ 2.663700] dhd_conf_set_txglom_params: txinrx_thres=128, dhd_txminmax=-1
[ 2.664313] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=300
[ 2.664917] dhd_bus_devreset: WLAN OFF DONE
[ 2.665737] wifi_platform_set_power = 0
[ 2.666097] ======== PULL WL_REG_ON(-1) LOW! ========
[ 2.666641] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 2.667109] [WLAN_RFKILL]: wifi shut off power.
[ 2.667562] dhdsdio_probe : the lock is released.
[ 2.668593] dhd_module_init: Exit err=0
[ 2.872181] systemd[1]: System time before build time, advancing clock.
[ 2.880959] systemd[1]: Failed to insert module ‘autofs4’: No such file or directory
[ 2.884912] cgroup: cgroup2: unknown option “nsdelegate”
[ 2.899046] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -ID)
[ 2.902057] systemd[1]: Detected architecture arm64.
Welcome to Ubuntu 18.04.1 LTS!
[ 2.908491] systemd[1]: Set hostname to .
[ 3.083443] systemd[1]: File /lib/systemd/system/systemd-udevd.service:34 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 3.084971] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 3.094671] systemd[1]: Configuration file /lib/systemd/system/npu-S11.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 3.289011] random: systemd: uninitialized urandom read (16 bytes read, 126 bits of entropy available)
[ 3.291154] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ 3.292367] random: systemd: uninitialized urandom read (16 bytes read, 126 bits of entropy available)
[ 3.293574] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 3.294467] random: systemd: uninitialized urandom read (16 bytes read, 126 bits of entropy available)
[ 3.295789] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 3.296509] random: systemd: uninitialized urandom read (16 bytes read, 126 bits of entropy available)
[ 3.298011] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 3.298785] random: systemd: uninitialized urandom read (16 bytes read, 126 bits of entropy available)
[ 3.300577] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 3.301481] random: systemd: uninitialized urandom read (16 bytes read, 126 bits of entropy available)
[ 3.303080] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 3.303849] random: systemd: uninitialized urandom read (16 bytes read, 126 bits of entropy available)
[ 3.304893] systemd[1]: Reached target User and Group Name Lookups.
[ OK ] Reached target User and Group Name Lookups.
[ 3.305647] random: systemd: uninitialized urandom read (16 bytes read, 126 bits of entropy available)
[ 3.306898] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 3.307497] random: systemd: uninitialized urandom read (16 bytes read, 126 bits of entropy available)
[ 3.308734] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 3.309402] random: systemd: uninitialized urandom read (16 bytes read, 126 bits of entropy available)
[ 3.310812] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 3.322388] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 3.323634] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 3.324404] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 3.325666] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 3.333531] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 3.341523] systemd[1]: Starting Load Kernel Modules…
[ 3.347233] systemd[1]: Starting udev Coldplug all Devices…
[ 3.354873] systemd[1]: Starting Set the console keyboard layout…
[ 3.364776] systemd[1]: Mounting Kernel Debug File System…
[ 3.378919] random: nonblocking pool is initialized
[ 3.378999] systemd[1]: Starting Create Static Device Nodes in /dev…
[ 3.392374] systemd[1]: Starting Journal Service…
[ 3.397465] systemd[1]: Started Remount Root and Kernel File Systems.
[ OK ] Started Remount Root and Kernel File Systems.
[ 3.416527] systemd[1]: Started Load Kernel Modules.
[ OK ] Started Load Kernel Modules.
[ 3.417918] systemd[1]: Mounted Kernel Debug File System.
[ OK ] Mounted Kernel Debug File System.
[ 3.422715] systemd[1]: Mounting Kernel Configuration File System…
[ 3.430454] systemd[1]: Mounting FUSE Control File System…
[ 3.443965] systemd[1]: Starting Apply Kernel Variables…
[ 3.461083] systemd[1]: Starting Load/Save Random Seed…
[ 3.470174] systemd[1]: Started Create Static Device Nodes in /dev.
[ OK ] Started Create Static Device Nodes in /dev.
[ 3.472540] systemd[1]: Mounted Kernel Configuration File System.
[ OK ] Mounted Kernel Configuration File System.
[ 3.474706] systemd[1]: Mounted FUSE Control File System.
[ OK ] Mounted FUSE Control File System.
[ 3.482032] systemd[1]: Starting udev Kernel Device Manager…
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Journal Service.
Starting Flush Journal to Persistent Storage…
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Set the console keyboard layout.
[ OK ] Reached target Local File Systems (Pre).
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories…
Starting Tell Plymouth To Write Out Runtime Data…
Starting Set console font and keymap…
[ OK ] Started Tell Plymouth To Write Out Runtime Data.
[ OK ] Started Set console font and keymap.
[ OK ] Started Create Volatile Files and Directories.
Starting Network Time Synchronization…
Starting Update UTMP about System Boot/Shutdown…
Starting Network Name Resolution…
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Reached target Local Encrypted Volumes.
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Network Name Resolution.
[ OK ] Reached target Host and Network Name Lookups.
[ OK ] Found device /dev/ttyFIQ0.
[ OK ] Reached target Sound Card.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Synchronized.
[ OK ] Reached target System Initialization.
[ OK ] Reached target Paths.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Started Discard unused blocks once a week.
Starting Socket activation for snappy daemon.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Started Message of the Day.
[ OK ] Started Daily apt download activities.
[ OK ] Started Daily apt upgrade and clean activities.
[ OK ] Reached target Timers.
[ OK ] Listening on Socket activation for snappy daemon.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting LSB: automatic crash report generation…
Starting Restore /etc/resolv.conf i��…fore the ppp link was shut down…
Starting Dispatcher daemon for systemd-networkd…
[ OK ] Started D-Bus System Message Bus.
[ OK ] Started Regular background program processing daemon.
Starting Avahi mDNS/DNS-SD Stack…
Starting Adbd for linux…
Starting Login Service…
Starting Accounts Service…
[ OK ] Started Set the CPU Frequency Scaling governor.
Starting Modem Manager…
Starting Disk Manager…
Starting System Logging Service…
Starting Network Manager…
Starting start S11-npu service…
Starting Save/Restore Sound Card State…
Starting WPA supplicant…
Starting Snappy daemon…
[ OK ] Started Restore /etc/resolv.conf if��…before the ppp link was shut down.
[ OK ] Started System Logging Service.
[ OK ] Started Save/Restore Sound Card State.
[ OK ] Started Adbd for linux.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started Login Service.
Starting Authorization Manager…
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Starting Load/Save RF Kill Switch Status…
[ OK ] Started WPA supplicant.
[ OK ] Started LSB: automatic crash report generation.
[ OK ] Started Load/Save RF Kill Switch Status.
Starting bluetooth-toggle…
[ OK ] Started Authorization Manager.
[ OK ] Started Accounts Service.
[ OK ] Started bluetooth-toggle.
Starting Bluetooth service…
[ OK ] Started Modem Manager.
Starting Hostname Service…
[ OK ] Started Bluetooth service.
[ OK ] Reached target Bluetooth.
[ OK ] Started Snappy daemon.
Starting Wait until snapd is fully seeded…
[ OK ] Started Hostname Service.
[ OK ] Started Wait until snapd is fully seeded.
[ OK ] Started Disk Manager.
Starting Network Manager Script Dispatcher Service…
[ OK ] Started Network Manager Script Dispatcher Service.
[ 5.755540] usb 3-1: device descriptor read/64, error -71
[ OK ] Started Dispatcher daemon for systemd-networkd.
[ OK ] Started Network Manager.
[ OK ] Reached target Network.
Starting Permit User Sessions…
Starting /etc/rc.local Compatibility…
Starting OpenBSD Secure Shell server…
[ OK ] Started /etc/rc.local Compatibility.
[ OK ] Started Permit User Sessions.
Starting Light Display Manager…
Starting Hold until boot process finishes up…
[ OK ] Started Hold until boot process finishes up.
[ OK ] Started Serial Getty on ttyFIQ0.
Starting Set console scheme…
[ OK ] Started Set console scheme.
[ OK ] Created slice system-getty.slice.
[ OK ] Started Getty on tty1.
[ OK ] Reached target Login Prompts.
[ OK ] Started OpenBSD Secure Shell server.
[ OK ] Reached target Multi-User System.
[ OK ] Started Light Display Manager.
[ OK ] Reached target Graphical Interface.
Starting Update UTMP about System Runlevel Changes…
[ OK ] Started Update UTMP about System Runlevel Changes.
[ 8.346960] mali ff9a0000.gpu: Unhandled Page fault in AS0 at VA 0x0000007F245EC000
[ 8.346960] Reason: Memory is not mapped on the GPU
[ 8.346960] raw fault status: 0x8002C1
[ 8.346960] decoded fault status: SLAVE FAULT
[ 8.346960] exception type 0xC1: TRANSLATION_FAULT
[ 8.346960] access type 0x2: READ
[ 8.346960] source id 0x80
[ 8.346960] pid: 509
这样的情况是hdmi屏幕卡住了,但是在串口里还可以操作是吗?
hdmi屏幕没卡住的时候,串口可以操作,卡住的时候,串口里也卡住,按回车也没反应,没接hdmi也是一样的现象
我是经常遇到过无线鼠标卡住几秒钟的情况,我一直以为是usb的无线鼠标的问题,没注意是不是内核卡主还是哪里卡住了,一般不接串口
请问接下来怎么操作,这是什么原因导致的,买了几块板,就这块有问题,不知是软件还是硬件问题
1.如果只有一块有问题可能是硬件问题,烧个android验证一下会不会也是异常
2.如果没有打印任何错误log就挂掉很可能是硬件问题,你可以试一下串口卡住的时候输入"fiq" fiq是优先级最高的终端模式,防止机器卡死时候可以抓取log。
3.如果上诉方法都验证过有问题,就没有办法了,寄回去硬件检查一下吧
