rk3328-cc 如何更改根分区大小
机型:ROC-RK3328-CC 存储:emmc -8g
根分区: /
需求:/ 这个根分区使用完剩下的磁盘容量
以下是分别是 parameter.txt 和磁盘 、分区情况
我该如何更改然后需要怎么操作 。才能使我的根分区使用完emmc剩下的容量。
FIRMWARE_VER: 8.1
MACHINE_MODEL: RK3399
MACHINE_ID: 007
MANUFACTURER: RK3399
MAGIC: 0x5041524B
ATAG: 0x00200800
MACHINE: 3399
CHECK_MASK: 0x80
PWR_HLD: 0,0,A,0,1
TYPE: GPT
CMDLINE: mtdparts=rk29xxnand:0x00002000@0x00004000(uboot),0x00002000@0x00006000(trust),0x00010000@0x0000a000(boot),0x00010000@0x0002a000(backup),-@0x0005a000(rootfs:grow)
uuid:rootfs=614e0000-0000-4b53-8000-1d28000054a9
root@localhost:~# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 969M 684M 219M 76% /
devtmpfs 980M 0 980M 0% /dev
tmpfs 981M 0 981M 0% /dev/shm
tmpfs 981M 17M 965M 2% /run
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 981M 0 981M 0% /sys/fs/cgroup
tmpfs 197M 0 197M 0% /run/user/0
root@localhost:~# fdisk -l
Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk /dev/mmcblk1: 7.3 GiB, 7818182656 bytes, 15269888 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 32090000-0000-4D75-8000-4728000022D2
Device Start End Sectors Size Type
/dev/mmcblk1p1 16384 24575 8192 4M unknown
/dev/mmcblk1p2 24576 32767 8192 4M unknown
/dev/mmcblk1p3 40960 172031 131072 64M unknown
/dev/mmcblk1p4 172032 237567 65536 32M unknown
/dev/mmcblk1p5 368640 15269854 14901215 7.1G unknown
Disk /dev/mmcblk1boot1: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/mmcblk1boot0: 4 MiB, 4194304 bytes, 8192 sectors
http://wiki.t-firefly.com/zh_CN/Firefly-RK3399/linux_build_ubuntu_rootfs.html#gen-wen-jian-xi-tong-jia-zai-hou-da-xiao-bu-zheng-chang-wei-zhan-man-zheng-ge-fen-qu
试试看。
