新品入手,進入terminal 最後一直出現以下訊息
<234020391 ms> monitor_work_routine m_ping_interval:1
<234021393 ms> Ping sendto failed:Network is unreachable.
<234022393 ms> Ping sendto failed:Network is unreachable.
<234023394 ms> Ping sendto failed:Network is unreachable.
<234024397 ms> Ping sendto failed:Network is unreachable.
<234025398 ms> monitor_work_routine m_ping_interval:1
想變更網路設定,但檔案無法編輯 出現Read-only file system
應該如何解決?
WIFI或者以太网连接网络,参考维基教程: http://wiki.t-firefly.com/ROC-RK3308-CC/network_config.html
網路安裝完成後變成以下訊息是正常嗎?
<6113736 ms> monitor_work_routine m_ping_interval:300
<6132456 ms> =============================1.updateJsonFile:status:1 content:1 time:92
<6192459 ms> =============================1.updateJsonFile:status:1 content:1 time:93
<6252462 ms> =============================1.updateJsonFile:status:1 content:1 time:94
<6312465 ms> =============================1.updateJsonFile:status:1 content:1 time:95
<6372467 ms> =============================1.updateJsonFile:status:1 content:1 time:96
- ifconfig 查看下有没有分配到ip地址?
- ping 通不通?
- ping 通不通?
1.有分配到IP
2.也可以ping到 ping 216.58.200.228 (www.google.com)
ping 216.58.200.228
PING 216.58.200.228 (216.58.200.228): 56 data bytes
64 bytes from 216.58.200.228: seq=0 ttl=51 time=6.819 ms
64 bytes from 216.58.200.228: seq=1 ttl=51 time=6.134 ms
64 bytes from 216.58.200.228: seq=2 ttl=51 time=8.441 ms
