Andoid系统的selinux安全级别从permissive改为enforcing,系统无法启动
[16:28:53.652]
[16:28:53.792]
[16:29:01.147] DDR Version 1.23 20190709
[16:29:01.147] In
[16:29:01.147] channel 0
[16:29:01.196] CS = 0
[16:29:01.196] MR0=0x98
[16:29:01.196] MR4=0x3
[16:29:01.196] MR5=0xFF
[16:29:01.196] MR8=0x8
[16:29:01.196] MR12=0x72
[16:29:01.196] MR14=0x72
[16:29:01.196] MR18=0x0
[16:29:01.196] MR19=0x0
[16:29:01.196] MR24=0x8
[16:29:01.196] MR25=0xFF
[16:29:01.196] channel 1
[16:29:01.196] channel 0 training pass!
[16:29:01.196] channel 1 training pass!
[16:29:01.196] change freq to 416MHz 0,1
[16:29:01.196] Channel 0: LPDDR4,416MHz
[16:29:01.196] Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
[16:29:01.196] Channel 1: LPDDR4,416MHz
[16:29:01.196] 256B stride
[16:29:01.196] MR4=0x81
[16:29:01.196] channel 0, cs 0, advanced training done
[16:29:01.486]
[16:29:01.785] channel 1, cs 0, advanced training done
[16:29:01.785] change freq to 856MHz 1,0
[16:29:01.785] ch 0 ddrconfig = 0x101, ddrsize = 0x20
[16:29:01.785] ch 1 ddrconfig = 0x101, ddrsize = 0x20
[16:29:01.785] pmugrf_os_reg[2] = 0x3281F281, stride = 0x9
[16:29:01.785] OUT
[16:29:01.785] Boot1: 2018-08-06, version: 1.15
[16:29:01.823] CPUId = 0x0
[16:29:01.823] ChipType = 0x10, 224
[16:29:01.823] SdmmcInit=2 0
[16:29:01.876] BootCapSize=100000
[16:29:01.876] UserCapSize=14910MB
[16:29:01.876] FwPartOffset=2000 , 100000
[16:29:01.876] mmc0:cmd8,20
[16:29:01.885] mmc0:cmd5,20
[16:29:01.885] mmc0:cmd55,20
[16:29:01.885] mmc0:cmd1,20
[16:29:01.885] mmc0:cmd8,20
[16:29:01.894] mmc0:cmd5,20
[16:29:01.894] mmc0:cmd55,20
[16:29:01.894] mmc0:cmd1,20
[16:29:01.894] SdmmcInit=0 1
[16:29:01.894] StorageInit ok = 67788
[16:29:01.894] SecureMode = 0
[16:29:01.894] SecureInit read PBA: 0x4
[16:29:01.894] SecureInit read PBA: 0x404
[16:29:01.894] SecureInit read PBA: 0x804
[16:29:01.894] SecureInit read PBA: 0xc04
[16:29:01.894] SecureInit read PBA: 0x1004
[16:29:01.894] SecureInit read PBA: 0x1404
[16:29:01.894] SecureInit read PBA: 0x1804
[16:29:01.894] SecureInit read PBA: 0x1c04
[16:29:01.894] SecureInit ret = 0, SecureMode = 0
[16:29:01.894] GPT 0x3190d20 signature is wrong
[16:29:01.894] LoadTrust Addr:0x4000
[16:29:01.894] No find bl30.bin
[16:29:01.894] Load uboot, ReadLba = 2000
[16:29:01.912] Load OK, addr=0x200000, size=0x84304
[16:29:01.912] RunBL31 0x10000
[16:29:01.926] NOTICE: BL31: v1.3(debug):22b599a
[16:29:01.926] NOTICE: BL31: Built : 11:03:32, Jul 10 2019
[16:29:01.926] NOTICE: BL31: Rockchip release version: v1.1
[16:29:01.941] INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
[16:29:01.941] INFO: Using opteed sec cpu_context!
[16:29:01.941] INFO: boot cpu mask: 0
[16:29:01.941] INFO: plat_rockchip_pmu_init(1181): pd status 3e
[16:29:01.941] INFO: BL31: Initializing runtime services
[16:29:01.941] INFO: BL31: Initializing BL32
[16:29:01.941] INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-195-g8f090d20 #6 Fri Dec 7 06:11:20 UTC 2018 aarch64)
[16:29:01.965]
[16:29:01.965] INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.2
[16:29:01.965]
[16:29:01.965] INF [0x0] TEE-CORE:init_teecore:83: teecore inits done
[16:29:01.968] INFO: BL31: Preparing for EL3 exit to normal world
[16:29:01.968] INFO: Entry point address = 0x200000
[16:29:01.968] INFO: SPSR = 0x3c9
[16:29:01.974]
[16:29:01.974]
[16:29:01.974] U-Boot 2014.10-RK3399-06 (Jan 20 2020 - 21:26:24)
[16:29:01.974]
[16:29:01.974] CPU: rk3399
[16:29:01.974] cpu version = 0
[16:29:01.974] CPU’s clock information:
[16:29:01.974] aplll = 816000000HZ
[16:29:01.974] apllb = 24000000HZ
[16:29:01.974] gpll = 800000000HZ
[16:29:01.974] aclk_periph_h = 133333333HZ, hclk_periph_h = 66666666HZ, pclk_periph_h = 33333333HZ
[16:29:01.974] aclk_periph_l0 = 266666666HZ, hclk_periph_l0 = 88888888HZ, pclk_periph_l0 = 44444444HZ
[16:29:01.974] hclk_periph_l1 = 100000000HZ, pclk_periph_l1 = 50000000HZ
[16:29:01.974] cpll = 800000000HZ
[16:29:01.974] dpll = 856000000HZ
[16:29:01.974] vpll = 24000000HZ
[16:29:01.974] npll = 24000000HZ
[16:29:01.974] ppll = 676000000HZ
[16:29:01.974] Board: Rockchip platform Board
[16:29:01.974] Uboot as second level loader
[16:29:01.974] DRAM: Found dram banks: 1
[16:29:01.974] Adding bank:0000000000200000(000000007fe00000)
[16:29:01.974] Reserve memory for trust os.
[16:29:01.974] dram reserve bank: base = 0x08400000, size = 0x01e00000
[16:29:01.974] 128 MiB
[16:29:01.974] SdmmcInit = 0 20
[16:29:02.055] storage init OK!
[16:29:02.116] Using default environment
[16:29:02.116]
[16:29:02.116] GetParam
[16:29:02.116] Load FDT from boot image.
[16:29:02.116] power key: bank-0 pin-5
[16:29:02.116] can’t find dts node for fixed
[16:29:02.121] usb bc: can find node by path: /dwc-control-usb/usb_bc
[16:29:02.144] pmic:rk808
[16:29:02.144] can’t find dts node for pwm1
[16:29:02.156] set pwm voltage ok,pwm_id =2 vol=1000000,pwm_value=60
[16:29:02.156] CPU’s clock information:
[16:29:02.156] aplll = 816000000HZ
[16:29:02.156] apllb = 24000000HZ
[16:29:02.156] gpll = 800000000HZ
[16:29:02.156] aclk_periph_h = 133333333HZ, hclk_periph_h = 66666666HZ, pclk_periph_h = 33333333HZ
[16:29:02.156] aclk_periph_l0 = 266666666HZ, hclk_periph_l0 = 88888888HZ, pclk_periph_l0 = 44444444HZ
[16:29:02.156] hclk_periph_l1 = 100000000HZ, pclk_periph_l1 = 50000000HZ
[16:29:02.156] cpll = 800000000HZ
[16:29:02.156] dpll = 856000000HZ
[16:29:02.156] vpll = 24000000HZ
[16:29:02.156] npll = 24000000HZ
[16:29:02.156] ppll = 676000000HZ
[16:29:02.156] Can’t find dts node for fuel guage cw201x
[16:29:02.156] can’t find dts node for ec-battery
[16:29:02.156] Can’t find dts node for charger bq25700
[16:29:02.163] invalide header tag
[16:29:02.163] ca head not found
[16:29:02.163] SecureBootEn = 0, SecureBootLock = 0
[16:29:02.163]
[16:29:02.163] #Boot ver: 0000-00-00#0.00
[16:29:02.163] empty serial no.
[16:29:02.163] normal boot.
[16:29:02.163] checkKey
[16:29:02.163] vbus = 1
[16:29:02.163] rockusb key pressed.
[16:29:02.163]
[16:40:14.790] ERROR: [FW_HandleUnknownCmd]: FW_HandleUnknownCmd: unknown cmd 0xaa
[16:40:14.790]
[16:40:16.146] DDR Version 1.23 20190709
[16:40:16.146] In
[16:40:16.146] soft reset
[16:40:16.149] SRX
[16:40:16.149] channel 0
[16:40:16.166] CS = 0
[16:40:16.166] MR0=0x98
[16:40:16.166] MR4=0x1
[16:40:16.166] MR5=0xFF
[16:40:16.166] MR8=0x8
[16:40:16.166] MR12=0x72
[16:40:16.166] MR14=0x72
[16:40:16.166] MR18=0x0
[16:40:16.166] MR19=0x0
[16:40:16.166] MR24=0x8
[16:40:16.166] MR25=0xFF
[16:40:16.166] channel 1
[16:40:16.166] channel 0 training pass!
[16:40:16.166] channel 1 training pass!
[16:40:16.166] change freq to 416MHz 0,1
[16:40:16.166] Channel 0: LPDDR4,416MHz
[16:40:16.166] Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
[16:40:16.166] Channel 1: LPDDR4,416MHz
[16:40:16.166] 256B stride
[16:40:16.171] MR24=0x8
[16:40:16.171] MR25=0xFF
[16:40:16.171] channel 1
[16:40:16.171] CS = 0
[16:40:16.171] MR0=0x98
[16:40:16.171] MR4=0x1
[16:40:16.171] MR5=0xFF
[16:40:16.171] MR8=0x8
[16:40:16.171] MR12=0x72
[16:40:16.171] MR14=0x72
[16:40:16.171] MR18=0x0
[16:40:16.171] MR19=0x0
[16:40:16.171] channel 0 training pass!
[16:40:16.171] channel 1 training pass!
[16:40:16.171] channel 0, cs 0, advanced training done
[16:40:16.511]
[16:40:16.855] channel 1, cs 0, advanced training done
[16:40:16.855] change freq to 856MHz 1,0
[16:40:16.855] ch 0 ddrconfig = 0x101, ddrsize = 0x20
[16:40:16.855] ch 1 ddrconfig = 0x101, ddrsize = 0x20
[16:40:16.855] pmugrf_os_reg[2] = 0x3281F281, stride = 0x9
[16:40:16.855] OUT
[16:40:16.855] Boot1: 2018-08-06, version: 1.15
[16:40:16.898] CPUId = 0x0
[16:40:16.898] ChipType = 0x10, 285
[16:40:16.898] SdmmcInit=2 0
[16:40:16.956] BootCapSize=100000
[16:40:16.956] UserCapSize=14910MB
[16:40:16.956] FwPartOffset=2000 , 100000
[16:40:16.956] mmc0:cmd8,20
[16:40:16.956] mmc0:cmd5,20
[16:40:16.956] mmc0:cmd55,20
[16:40:16.966] mmc0:cmd1,20
[16:40:16.966] mmc0:cmd8,20
[16:40:16.966] mmc0:cmd5,20
[16:40:16.966] mmc0:cmd55,20
[16:40:16.966] SdmmcInit=0 1
[16:40:16.966] StorageInit ok = 68691
[16:40:16.966] GPT 0x3190e40 signature is wrong
[16:40:16.970] powerOn 82626
[16:40:16.980]
[16:41:01.633] DDR Version 1.23 20190709
[16:41:01.633] In
[16:41:01.633] soft reset
[16:41:01.633] SRX
[16:41:01.633] channel 0
[16:41:01.646] CS = 0
[16:41:01.646] MR0=0x98
[16:41:01.646] MR4=0x1
[16:41:01.646] MR5=0xFF
[16:41:01.646] MR8=0x8
[16:41:01.646] MR12=0x72
[16:41:01.646] MR14=0x72
[16:41:01.646] MR18=0x0
[16:41:01.646] MR19=0x0
[16:41:01.646] MR24=0x8
[16:41:01.646] MR25=0xFF
[16:41:01.646] channel 1
[16:41:01.656] CS = 0
[16:41:01.656] MR0=0x98
[16:41:01.656] MR4=0x3
[16:41:01.656] MR5=0xFF
[16:41:01.656] MR8=0x8
[16:41:01.656] MR12=0x72
[16:41:01.656] MR14=0x72
[16:41:01.656] MR18=0x0
[16:41:01.656] MR19=0x0
[16:41:01.656] MR24=0x8
[16:41:01.656] MR25=0xFF
[16:41:01.656] channel 0 training pass!
[16:41:01.656] channel 1 training pass!
[16:41:01.656] change freq to 416MHz 0,1
[16:41:01.656] Channel 0: LPDDR4,416MHz
[16:41:01.656] Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
[16:41:01.656] Channel 1: LPDDR4,416MHz
[16:41:01.656] 256B stride
[16:41:01.656] MR4=0x1
[16:41:01.656] channel 0, cs 0, advanced training done
[16:41:01.999]
[16:41:02.346] channel 1, cs 0, advanced training done
[16:41:02.346] change freq to 856MHz 1,0
[16:41:02.346] ch 0 ddrconfig = 0x101, ddrsize = 0x20
[16:41:02.346] ch 1 ddrconfig = 0x101, ddrsize = 0x20
[16:41:02.346] pmugrf_os_reg[2] = 0x3281F281, stride = 0x9
[16:41:02.346] OUT
[16:41:02.346] Boot1: 2018-08-06, version: 1.15
[16:41:02.389] CPUId = 0x0
[16:41:02.389] ChipType = 0x10, 286
[16:41:02.389] SdmmcInit=2 0
[16:41:02.444] BootCapSize=100000
[16:41:02.444] UserCapSize=14910MB
[16:41:02.444] FwPartOffset=2000 , 100000
[16:41:02.444] mmc0:cmd8,20
[16:41:02.456] mmc0:cmd5,20
[16:41:02.456] mmc0:cmd55,20
[16:41:02.456] mmc0:cmd1,20
[16:41:02.456] mmc0:cmd8,20
[16:41:02.456] SdmmcInit=0 1
[16:41:02.456] StorageInit ok = 68753
[16:41:02.456] SecureMode = 0
[16:41:02.456] SecureInit read PBA: 0x4
[16:41:02.462] SecureInit read PBA: 0x404
[16:41:02.462] SecureInit read PBA: 0x804
[16:41:02.462] SecureInit read PBA: 0xc04
[16:41:02.462] SecureInit read PBA: 0x1004
[16:41:02.462] SecureInit read PBA: 0x1404
[16:41:02.462] SecureInit read PBA: 0x1804
[16:41:02.462] SecureInit read PBA: 0x1c04
[16:41:02.462] SecureInit ret = 0, SecureMode = 0
[16:41:02.462] GPT 0x3190d20 signature is wrong
[16:41:02.462] LoadTrust Addr:0x4000
[16:41:02.462] No find bl30.bin
[16:41:02.462] Load uboot, ReadLba = 2000
[16:41:02.476] Load OK, addr=0x200000, size=0x84304
[16:41:02.486] RunBL31 0x10000
[16:41:02.486] NOTICE: BL31: v1.3(debug):22b599a
[16:41:02.498] NOTICE: BL31: Built : 11:03:32, Jul 10 2019
[16:41:02.498] NOTICE: BL31: Rockchip release version: v1.1
[16:41:02.516] INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
[16:41:02.516] INFO: Using opteed sec cpu_context!
[16:41:02.516] INFO: boot cpu mask: 0
[16:41:02.516] INFO: plat_rockchip_pmu_init(1181): pd status 3e
[16:41:02.516] INFO: BL31: Initializing runtime services
[16:41:02.516] INFO: BL31: Initializing BL32
[16:41:02.518] INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-195-g8f090d20 #6 Fri Dec 7 06:11:20 UTC 2018 aarch64)
[16:41:02.536]
[16:41:02.536] INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.2
[16:41:02.536]
[16:41:02.536] INF [0x0] TEE-CORE:init_teecore:83: teecore inits done
[16:41:02.566] INFO: BL31: Preparing for EL3 exit to normal world
[16:41:02.566] INFO: Entry point address = 0x200000
[16:41:02.566] INFO: SPSR = 0x3c9
[16:41:02.566]
[16:41:02.566]
[16:41:02.566] U-Boot 2014.10-RK3399-06 (Feb 07 2020 - 16:21:01)
[16:41:02.566]
[16:41:02.566] CPU: rk3399
[16:41:02.566] cpu version = 0
[16:41:02.566] CPU’s clock information:
[16:41:02.566] aplll = 816000000HZ
[16:41:02.566] apllb = 24000000HZ
[16:41:02.566] gpll = 800000000HZ
[16:41:02.566] aclk_periph_h = 133333333HZ, hclk_periph_h = 66666666HZ, pclk_periph_h = 33333333HZ
[16:41:02.566] aclk_periph_l0 = 266666666HZ, hclk_periph_l0 = 88888888HZ, pclk_periph_l0 = 44444444HZ
[16:41:02.566] hclk_periph_l1 = 100000000HZ, pclk_periph_l1 = 50000000HZ
[16:41:02.566] cpll = 800000000HZ
[16:41:02.566] dpll = 856000000HZ
[16:41:02.566] vpll = 24000000HZ
[16:41:02.566] npll = 24000000HZ
[16:41:02.566] ppll = 676000000HZ
[16:41:02.566] Board: Rockchip platform Board
[16:41:02.566] Uboot as second level loader
[16:41:02.566] DRAM: Found dram banks: 1
[16:41:02.566] Adding bank:0000000000200000(000000007fe00000)
[16:41:02.566] Reserve memory for trust os.
[16:41:02.566] dram reserve bank: base = 0x08400000, size = 0x01e00000
[16:41:02.569] 128 MiB
[16:41:02.569] SdmmcInit = 0 20
[16:41:02.651] storage init OK!
[16:41:02.706] Using default environment
[16:41:02.706]
[16:41:02.706] GetParam
[16:41:02.706] Load FDT from boot image.
[16:41:02.706] power key: bank-0 pin-5
[16:41:02.716] can’t find dts node for fixed
[16:41:02.716] usb bc: can find node by path: /dwc-control-usb/usb_bc
[16:41:02.753] pmic:rk808
[16:41:02.756] can’t find dts node for pwm1
[16:41:02.756] set pwm voltage ok,pwm_id =2 vol=1000000,pwm_value=60
[16:41:02.756] CPU’s clock information:
[16:41:02.756] aplll = 816000000HZ
[16:41:02.756] apllb = 24000000HZ
[16:41:02.756] gpll = 800000000HZ
[16:41:02.756] aclk_periph_h = 133333333HZ, hclk_periph_h = 66666666HZ, pclk_periph_h = 33333333HZ
[16:41:02.756] aclk_periph_l0 = 266666666HZ, hclk_periph_l0 = 88888888HZ, pclk_periph_l0 = 44444444HZ
[16:41:02.756] hclk_periph_l1 = 100000000HZ, pclk_periph_l1 = 50000000HZ
[16:41:02.756] cpll = 800000000HZ
[16:41:02.756] dpll = 856000000HZ
[16:41:02.756] vpll = 24000000HZ
[16:41:02.756] npll = 24000000HZ
[16:41:02.756] ppll = 676000000HZ
[16:41:02.756] Can’t find dts node for fuel guage cw201x
[16:41:02.756] can’t find dts node for ec-battery
[16:41:02.756] Can’t find dts node for charger bq25700
[16:41:02.756] invalide header tag
[16:41:02.756] ca head not found
[16:41:02.756] SecureBootEn = 0, SecureBootLock = 0
[16:41:02.756]
[16:41:02.756] #Boot ver: 2020-02-07#1.15
[16:41:02.756] empty serial no.
[16:41:02.756] reboot normal.
[16:41:02.756] checkKey
[16:41:02.763] vbus = 1
[16:41:02.763] no fuel gauge found
[16:41:02.763] Rockchip UBOOT DRM driver version: develop-v1.0.0
[16:41:02.763] failed to find panel driver
[16:41:02.773] read logo on state from dts [1]
[16:41:02.773] no fuel gauge found
[16:41:02.773]
[16:41:03.043] Monitor has basic audio support
[16:41:03.043] drm_rk_selete_output; fail get baseparameter
[16:41:03.043] rk lcdc - 0 dclk set: dclk = 148500000HZ, pll select = 0, div = 1
[16:41:03.043] rockchip_panel_prepare: failed to find panel prepare funcs
[16:41:03.043] CEA mode used vic=16
[16:41:03.043] dw_hdmi_setup HDMI mode
[16:41:03.065] rockchip_panel_enable: failed to find panel prepare funcs
[16:41:03.065] ERROR: [get_entry_ram]: Cannot find logo_kernel.bmp!
[16:41:03.065] failed to display kernel logo
[16:41:03.065] got recovery cmd from misc.
[16:41:03.065]
[16:41:03.756] hwversion: disabled!
[16:41:03.756] Secure Boot state: 0
[16:41:03.756] kernel @ 0x00280000 (0x01309808)
[16:41:03.756] ramdisk @ 0x04bf0000 (0x0074e5f4)
[16:41:03.756] bootrk: do_bootm_linux…
[16:41:03.756] Loading Device Tree to 0000000004600000, end 0000000004616a1e … OK
[16:41:03.759] Add bank:0000000000200000, 0000000008200000
[16:41:03.759] Add bank:000000000a200000, 0000000075e00000
[16:41:03.759] WARNING: could not set reg FDT_ERR_BADOFFSET.
[16:41:03.783]
[16:41:03.783] Starting kernel …
[16:41:03.783]
[16:41:03.783] [ 0.000000] Booting Linux on physical CPU 0x0
[16:41:03.795] [ 0.000000] Initializing cgroup subsys cpuset
[16:41:03.795] [ 0.000000] Initializing cgroup subsys cpuacct
[16:41:03.795] [ 0.000000] Initializing cgroup subsys schedtune
[16:41:03.795] [ 0.000000] Linux version 4.4.126 (yangjie@vizumsrv) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #6 SMP PREEMPT Tue Dec 31 15:01:06 CST 2019
[16:41:03.795] [ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[16:41:03.795] [ 0.000000] earlycon: Early serial console at MMIO32 0xff1a0000 (options ‘’)
[16:41:03.795] [ 0.000000] bootconsole [uart0] enabled
[16:41:03.795] [ 0.000000] Reserved memory: failed to reserve memory for node ‘stb-devinfo@00000000’: base 0x0000000000000000, size 0 MiB
[16:41:03.800] [ 0.000000] cma: Reserved 16 MiB at 0x000000007f000000
[16:41:03.800] [ 0.000000] psci: probing for conduit method from DT.
[16:41:03.896] [ 0.000000] psci: PSCIv1.0 detected in firmware.
[16:41:03.896] [ 0.000000] psci: Using standard PSCI v0.2 function IDs
[16:41:03.896] [ 0.000000] psci: Trusted OS migration not required
[16:41:03.896] [ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07eefa000 s45528 r8192 d32296 u86016
[16:41:03.896] [ 0.000000] Detected VIPT I-cache on CPU0
[16:41:03.896] [ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[16:41:03.896] [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 507912
[16:41:03.896] [ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 coherent_pool=1m console=ttyFIQ0 androidboot.baseband=N/A androidboot.selinux=enforcing androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x0000C000@0x00010000(kernel),0x00010000@0x0001C000(boot),0x00020000@0x0002C000(recovery),0x00038000@0x0004C000(backup),0x00040000@0x00084000(cache),0x00300000@0x000C4000(system),0x00100000@0x003C4000(oem),0x00008000@0x004C4000(metadata),0x00000040@0x004CC000(verity_mode),0x00002000@0x004CC040(reserved),0x00000400@0x004CE040(frp),-@0x004CE440(userdata) storagemedia=emmc androidboot.oem_unlocked=0 uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2020-02-07_16:21:01 SecureBootCheckOk=0
[16:41:03.906] [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[16:41:03.906] [ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[16:41:03.914] [ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[16:41:03.914] [ 0.000000] software IO TLB [mem 0x7eeb2000-0x7eef2000] (0MB) mapped at [ffffffc07eeb2000-ffffffc07eef1fff]
[16:41:03.914] [ 0.000000] Memory: 1981820K/2064384K available (11262K kernel code, 1702K rwdata, 5632K rodata, 832K init, 1134K bss, 66180K reserved, 16384K cma-reserved)
[16:41:03.986] [ 0.000000] Virtual kernel memory layout:
[16:41:03.986] [ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[16:41:03.986] [ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000 ( 246 GB)
[16:41:03.986] [ 0.000000] .init : 0xffffff8009110000 - 0xffffff80091e0000 ( 832 KB)
[16:41:03.986] [ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008b80000 ( 11264 KB)
[16:41:03.986] [ 0.000000] .rodata : 0xffffff8008b80000 - 0xffffff8009110000 ( 5696 KB)
[16:41:03.986] [ 0.000000] .data : 0xffffff80091e0000 - 0xffffff8009389808 ( 1703 KB)
[16:41:03.996] [ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
[16:41:03.996] [ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc2000000 ( 31 MB actual)
[16:41:03.996] [ 0.000000] fixed : 0xffffffbffe7fb000 - 0xffffffbffec00000 ( 4116 KB)
[16:41:03.996] [ 0.000000] PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000 ( 16 MB)
[16:41:03.996] [ 0.000000] memory : 0xffffffc000200000 - 0xffffffc080000000 ( 2046 MB)
[16:41:03.996] [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[16:41:03.996] [ 0.000000] Preemptible hierarchical RCU implementation.
[16:41:03.996] [ 0.000000] Build-time adjustment of leaf fanout to 64.
[16:41:03.996] [ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
[16:41:03.996] [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[16:41:03.996] [ 0.000000] NR_IRQS:64 nr_irqs:64 0
[16:41:04.006] [ 0.000000] GIC: Using split EOI/Deactivate mode
[16:41:04.006] [ 0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000
[16:41:04.006] [ 0.000000] ITS: allocated 65536 Devices @a200000 (psz 64K, shr 0)
[16:41:04.006] [ 0.000000] ITS: using cache flushing for cmd queue
[16:41:04.006] [ 0.000000] GIC: using LPI property table @0x000000000a280000
[16:41:04.006] [ 0.000000] ITS: Allocated 1792 chunks for LPIs
[16:41:04.006] [ 0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000
[16:41:04.006] [ 0.000000] CPU0: using LPI pending table @0x000000000a290000
[16:41:04.006] [ 0.000000] GIC: using cache flushing for LPI property table
[16:41:04.006] [ 0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[16:41:04.006] [ 0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[16:41:04.008] [ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work
[16:41:04.025] [ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work
[16:41:04.025] [ 0.000000] rockchip_cpuclk_pre_rate_change: limiting alt-divider 33 to 31
[16:41:04.035] [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[16:41:04.086] [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[16:41:04.086] [ 0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[16:41:04.086] [ 0.001942] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[16:41:04.086] [ 0.002928] pid_max: default: 32768 minimum: 301
[16:41:04.086] [ 0.003432] Security Framework initialized
[16:41:04.086] [ 0.003831] SELinux: Initializing.
[16:41:04.086] [ 0.004276] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[16:41:04.086] [ 0.004920] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[16:41:04.086] [ 0.006388] Initializing cgroup subsys memory
[16:41:04.086] [ 0.006829] Initializing cgroup subsys freezer
[16:41:04.091] [ 0.008166] sched-energy: Sched-energy-costs installed from DT
[16:41:04.091] [ 0.008729] CPU0: update cpu_capacity 401
[16:41:04.091] [ 0.009196] ASID allocator initialised with 32768 entries
[16:41:04.091] [ 0.026030] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[16:41:04.109] [ 0.027337] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[16:41:04.109] [ 0.039429] Detected VIPT I-cache on CPU1
[16:41:04.166] [ 0.039461] CPU1: found redistributor 1 region 0:0x00000000fef20000
[16:41:04.166] [ 0.039496] CPU1: using LPI pending table @0x000000000a3f0000
[16:41:04.166] [ 0.039539] CPU1: update cpu_capacity 401
[16:41:04.166] [ 0.039543] CPU1: Booted secondary processor [410fd034]
[16:41:04.166] [ 0.049407] Detected VIPT I-cache on CPU2
[16:41:04.166] [ 0.049426] CPU2: found redistributor 2 region 0:0x00000000fef40000
[16:41:04.166] [ 0.049459] CPU2: using LPI pending table @0x000000007c020000
[16:41:04.166] [ 0.049486] CPU2: update cpu_capacity 401
[16:41:04.166] [ 0.049490] CPU2: Booted secondary processor [410fd034]
[16:41:04.166] [ 0.059439] Detected VIPT I-cache on CPU3
[16:41:04.166] [ 0.059457] CPU3: found redistributor 3 region 0:0x00000000fef60000
[16:41:04.166] [ 0.059490] CPU3: using LPI pending table @0x000000007c060000
[16:41:04.166] [ 0.059515] CPU3: update cpu_capacity 401
[16:41:04.166] [ 0.059518] CPU3: Booted secondary processor [410fd034]
[16:41:04.175] [ 0.069487] Detected PIPT I-cache on CPU4
[16:41:04.175] [ 0.069514] CPU4: found redistributor 100 region 0:0x00000000fef80000
[16:41:04.175] [ 0.069552] CPU4: using LPI pending table @0x000000007c0b0000
[16:41:04.175] [ 0.069591] CPU4: update cpu_capacity 1024
[16:41:04.175] [ 0.069594] CPU4: Booted secondary processor [410fd082]
[16:41:04.175] [ 0.079509] Detected PIPT I-cache on CPU5
[16:41:04.175] [ 0.079527] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[16:41:04.175] [ 0.079562] CPU5: using LPI pending table @0x000000007c0e0000
[16:41:04.175] [ 0.079588] CPU5: update cpu_capacity 1024
[16:41:04.175] [ 0.079591] CPU5: Booted secondary processor [410fd082]
[16:41:04.175] [ 0.079676] Brought up 6 CPUs
[16:41:04.175] [ 0.092074] SMP: Total of 6 processors activated.
[16:41:04.175] [ 0.092528] CPU features: detected feature: GIC system register CPU interface
[16:41:04.175] [ 0.093216] CPU: All CPU(s) started at EL2
[16:41:04.175] [ 0.093649] alternatives: patching kernel code
[16:41:04.175] [ 0.096027] devtmpfs: initialized
[16:41:04.178] [ 0.116698] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[16:41:04.206] [ 0.117618] futex hash table entries: 2048 (order: 5, 131072 bytes)
[16:41:04.206] [ 0.118925] pinctrl core: initialized pinctrl subsystem
[16:41:04.206] [ 0.121403] Failed to find legacy iommu devices
[16:41:04.206] [ 0.122192] NET: Registered protocol family 16
[16:41:04.206] [ 0.123042] schedtune: init normalization constants…
[16:41:04.206] [ 0.123525] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[16:41:04.206] [ 0.124132] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[16:41:04.206] [ 0.124735] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[16:41:04.206] [ 0.125344] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[16:41:04.206] [ 0.125951] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[16:41:04.206] [ 0.126566] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[16:41:04.214] [ 0.127174] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[16:41:04.214] [ 0.127783] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[16:41:04.214] [ 0.128387] schedtune: SYSTEM min_pwr: 121 max_pwr: 4434
[16:41:04.214] [ 0.128992] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[16:41:04.214] [ 0.129697] schedtune: verify normalization constants…
[16:41:04.214] [ 0.130198] schedtune: max_pwr/2^0: 4313 => norm_pwr: 1024
[16:41:04.214] [ 0.130716] schedtune: max_pwr/2^1: 2156 => norm_pwr: 511
[16:41:04.214] [ 0.131233] schedtune: max_pwr/2^2: 1078 => norm_pwr: 255
[16:41:04.214] [ 0.131752] schedtune: max_pwr/2^3: 539 => norm_pwr: 127
[16:41:04.214] [ 0.132268] schedtune: max_pwr/2^4: 269 => norm_pwr: 63
[16:41:04.214] [ 0.132785] schedtune: max_pwr/2^5: 134 => norm_pwr: 31
[16:41:04.214] [ 0.133301] schedtune: configured to support 5 boost groups
[16:41:04.214] [ 0.143856] cpuidle: using governor ladder
[16:41:04.225] [ 0.153858] cpuidle: using governor menu
[16:41:04.235] [ 0.154233] Registered FIQ tty driver
[16:41:04.235] [ 0.154964] vdso: 2 pages (1 code @ ffffff8008b86000, 1 data @ ffffff80091e4000)
[16:41:04.235] [ 0.155672] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[16:41:04.239] [ 0.157367] DMA: preallocated 1024 KiB pool for atomic allocations
[16:41:04.239]
[16:41:04.266] [ 0.178137] console [pstore-1] enabled
[16:41:04.266] [ 0.178727] pstore: Registered ramoops as persistent store backend
[16:41:04.266] [ 0.179309] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[16:41:04.266] [ 0.182236] fiq debugger fiq mode enabled
[16:41:04.266] [ [ 0.182870] console [ttyFIQ0] enabled
[16:41:04.266] 0.182870] console [ttyFIQ0] enabled
[16:41:04.266] [ 0.183550] bootconsole [uart0] disabled
[16:41:04.266] [ 0.184123] Registered fiq debugger ttyFIQ0
[16:41:04.268] [ 0.218265] iommu: Adding device ff650000.vpu_service to group 0
[16:41:04.305] [ 0.218340] iommu: Adding device ff660000.rkvdec to group 1
[16:41:04.305] [ 0.218409] iommu: Adding device ff670000.iep to group 2
[16:41:04.305] [ 0.218498] iommu: Adding device ff8f0000.vop to group 3
[16:41:04.305] [ 0.218568] iommu: Adding device ff900000.vop to group 4
[16:41:04.316] [ 0.218676] iommu: Adding device ff910000.isp to group 5
[16:41:04.316] [ 0.218748] iommu: Adding device ff920000.isp to group 6
[16:41:04.316] [ 0.219415] rk_iommu ff670800.iommu: can’t get aclk
[16:41:04.316] [ 0.219430] rk_iommu ff670800.iommu: can’t get hclk
[16:41:04.316] [ 0.220311] SCSI subsystem initialized
[16:41:04.316] [ 0.220656] usbcore: registered new interface driver usbfs
[16:41:04.316] [ 0.220716] usbcore: registered new interface driver hub
[16:41:04.316] [ 0.220793] usbcore: registered new device driver usb
[16:41:04.316] [ 0.221170] media: Linux media interface: v0.10
[16:41:04.316] [ 0.221208] Linux video capture interface: v2.00
[16:41:04.316] [ 0.221372] pps_core: LinuxPPS API ver. 1 registered
[16:41:04.316] [ 0.221384] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[16:41:04.316] [ 0.221404] PTP clock support registered
[16:41:04.316] [ 0.222958] Advanced Linux Sound Architecture Driver Initialized.
[16:41:04.316] [ 0.223483] Bluetooth: Core ver 2.21
[16:41:04.316] [ 0.223513] NET: Registered protocol family 31
[16:41:04.316] [ 0.223521] Bluetooth: HCI device and connection manager initialized
[16:41:04.316] [ 0.223535] Bluetooth: HCI socket layer initialized
[16:41:04.316] [ 0.223546] Bluetooth: L2CAP socket layer initialized
[16:41:04.316] [ 0.223578] Bluetooth: SCO socket layer initialized
[16:41:04.319] [ 0.224318] rockchip-cpuinfo cpuinfo: Serial : 4007a25c55642b9a
[16:41:04.319] [ 0.224854] clocksource: Switched to clocksource arch_sys_counter
[16:41:04.319] [ 0.268875] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[16:41:04.355] [ 0.269124] NET: Registered protocol family 2
[16:41:04.355] [ 0.269598] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[16:41:04.355] [ 0.269740] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[16:41:04.355] [ 0.270013] TCP: Hash tables configured (established 16384 bind 16384)
[16:41:04.355] [ 0.270093] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[16:41:04.355] [ 0.270154] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[16:41:04.355] [ 0.270325] NET: Registered protocol family 1
[16:41:04.355] [ 0.271204] Trying to unpack rootfs image as initramfs…
[16:41:04.355] [ 0.597839] Freeing initrd memory: 7480K
[16:41:04.686] [ 0.598467] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[16:41:04.686] [ 0.598557] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[16:41:04.686] [ 0.601356] audit: initializing netlink subsys (disabled)
[16:41:04.686] [ 0.601430] audit: type=2000 audit(0.596:1): initialized
[16:41:04.686] [ 0.606702] VFS: Disk quotas dquot_6.6.0
[16:41:04.686] [ 0.606835] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[16:41:04.696] [ 0.607841] Registering sdcardfs 0.1
[16:41:04.696] [ 0.608425] fuse init (API version 7.23)
[16:41:04.696] [ 0.609521]
[16:41:04.696] [ 0.609521] TEE Core Framework initialization (ver 1:0.1)
[16:41:04.696] [ 0.609549] TEE armv7 Driver initialization
[16:41:04.696] [ 0.609926] tz_tee_probe: name=“armv7sec”, id=0, pdev_name=“armv7sec.0”
[16:41:04.696] [ 0.609942] TEE core: Alloc the misc device “opteearmtz00” (id=0)
[16:41:04.696] [ 0.610114] TEE Core: Register the misc device “opteearmtz00” (id=0,minor=62)
[16:41:04.696] [ 0.614029] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[16:41:04.696] [ 0.614052] io scheduler noop registered
[16:41:04.696] [ 0.614213] io scheduler cfq registered (default)
[16:41:04.696] [ 0.615456] phy phy-ff770000.syscon:usb2-phy@e450.0: Failed to get VBUS supply regulator
[16:41:04.696] [ 0.616356] phy phy-ff770000.syscon:usb2-phy@e460.2: Failed to get VBUS supply regulator
[16:41:04.696] [ 0.616382] rockchip_usb2phy_otg_port_init() Can not read property vbus-5v-gpio
[16:41:04.706] [ 0.619358] ace test_init function.
[16:41:04.706] [ 0.619507] ace test_init end.ret=0
[16:41:04.706] [ 0.619785] radar end.ret=0
[16:41:04.706] [ 0.621389] iep: failed to find iep power down clock source.
[16:41:04.706] [ 0.621836] IEP Power ON
[16:41:04.706] [ 0.622007] IEP Power OFF
[16:41:04.706] [ 0.622081] IEP Driver loaded succesfully
[16:41:04.706] [ 0.622200] Module initialized.
[16:41:04.706] [ 0.622459] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[16:41:04.706] [ 0.622668] rk-vcodec ff650000.vpu_service: probe device
[16:41:04.706] [ 0.622835] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[16:41:04.706] [ 0.623352] rk-vcodec ff650000.vpu_service: could not find power_model node
[16:41:04.706] [ 0.623368] rk-vcodec ff650000.vpu_service: init success
[16:41:04.706] [ 0.623555] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[16:41:04.706] [ 0.623943] rk-vcodec ff660000.rkvdec: probe device
[16:41:04.706] [ 0.624104] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[16:41:04.716] [ 0.624491] rk-vcodec ff660000.rkvdec: could not find power_model node
[16:41:04.716] [ 0.624505] rk-vcodec ff660000.rkvdec: init success
[16:41:04.716] [ 0.626134] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[16:41:04.716] [ 0.626151] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[16:41:04.716] [ 0.627519] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[16:41:04.716] [ 0.627537] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[16:41:04.716] [ 0.629347] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[16:41:04.716] [ 0.629905] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
[16:41:04.716] [ 0.630359] [drm] Initialized drm 1.1.0 20060810
[16:41:04.716] [ 0.633668] [drm] Rockchip DRM driver version: v1.0.0
[16:41:04.716] [ 0.633989] rockchip-drm display-subsystem: dmc is disabled
[16:41:04.716] [ 0.634279] rockchip-vop ff900000.vop: missing rockchip,grf property
[16:41:04.716] [ 0.634537] rockchip-vop ff900000.vop: unable to request PWM
[16:41:04.716] [ 0.634567] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[16:41:04.716] [ 0.634607] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[16:41:04.716] [ 0.634787] rockchip-vop ff8f0000.vop: unable to request PWM
[16:41:04.722] [ 0.634803] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[16:41:04.722] [ 0.635072] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[16:41:04.722] [ 0.635092] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[16:41:04.722] [ 0.635195] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[16:41:04.722] [ 0.635913] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[16:41:04.722] [ 0.635929] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[16:41:04.722] [ 0.635937] [drm] No driver support for vblank timestamp query.
[16:41:04.722]
[16:41:05.429] [ 1.346572] rockchip-drm display-subsystem: fb0: frame buffer device
[16:41:05.429] [ 1.361999] mali ff9a0000.gpu: Failed to get regulator
[16:41:05.446] [ 1.362040] mali ff9a0000.gpu: Power control initialization failed
[16:41:05.446] [ 1.362366] Unable to detect cache hierarchy for CPU 0
[16:41:05.446] [ 1.371136] brd: module loaded
[16:41:05.457] [ 1.376038] loop: module loaded
[16:41:05.457] [ 1.376596] zram: Added device: zram0
[16:41:05.462] [ 1.377518] SCSI Media Changer driver v0.25
[16:41:05.462] [ 1.378423] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[16:41:05.462] [ 1.378443] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[16:41:05.462] [ 1.378453] rockchip-spi ff1d0000.spi: no high_speed pinctrl state
[16:41:05.462] [ 1.379245] 11wk2xxx_probe: setup mode 0, 8 bits/w, 10000000 Hz max
[16:41:05.462] [ 1.549560] wk2xxx_serial_init()
[16:41:05.637] [ 1.549572] wk2xxx_request_port
[16:41:05.637] [ 1.549585] ttysWK0 at I/O 0x1 (irq = 222, base_baud = 460800) is a wk2xxx
[16:41:05.637] [ 1.549792] uart_add_one_port success for line i:= 0 with right 0
[16:41:05.637] [ 1.549804] wk2xxx_request_port
[16:41:05.637] [ 1.549815] ttysWK1 at I/O 0x2 (irq = 222, base_baud = 460800) is a wk2xxx
[16:41:05.637] [ 1.549994] uart_add_one_port success for line i:= 1 with right 0
[16:41:05.637] [ 1.550005] wk2xxx_request_port
[16:41:05.637] [ 1.550015] ttysWK2 at I/O 0x3 (irq = 222, base_baud = 460800) is a wk2xxx
[16:41:05.637] [ 1.550200] uart_add_one_port success for line i:= 2 with right 0
[16:41:05.637] [ 1.550211] wk2xxx_request_port
[16:41:05.637] [ 1.550221] ttysWK3 at I/O 0x4 (irq = 222, base_baud = 460800) is a wk2xxx
[16:41:05.637] [ 1.550398] uart_add_one_port success for line i:= 3 with right 0
[16:41:05.637] [ 1.550410] uart_add_one_port = 0x0
[16:41:05.637] [ 1.550434] register spi return v = :0
[16:41:05.637] [ 1.550480] register firefly_spi_init spi return v = :0
[16:41:05.637] [ 1.550542] tun: Universal TUN/TAP device driver, 1.6
[16:41:05.648] [ 1.550552] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[16:41:05.648] [ 1.551545] force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[16:41:05.648] [ 1.551660] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[16:41:05.648] [ 1.551678] rk_gmac-dwmac fe300000.ethernet: TX delay(0x2f).
[16:41:05.648] [ 1.551689] rk_gmac-dwmac fe300000.ethernet: RX delay(0x26).
[16:41:05.648] [ 1.551714] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[16:41:05.648] [ 1.551882] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[16:41:05.648] [ 1.551891] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[16:41:05.648] [ 1.556905] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[16:41:05.648] [ 1.557031] stmmac - user ID: 0x10, Synopsys ID: 0x35
[16:41:05.648] [ 1.557038] Ring mode enabled
[16:41:05.648] [ 1.557057] DMA HW capability register supported
[16:41:05.648] [ 1.557063] Normal descriptors
[16:41:05.648] [ 1.557073] RX Checksum Offload Engine supported (type 2)
[16:41:05.648] [ 1.557079] Wake-Up On Lan supported
[16:41:05.648] [ 1.557118] Enable RX Mitigation via HW Watchdog Timer
[16:41:05.648] [ 1.624438] libphy: stmmac: probed
[16:41:05.706] [ 1.624501] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[16:41:05.706] [ 1.624515] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[16:41:05.706] [ 1.626160] PPP generic driver version 2.4.2
[16:41:05.706] [ 1.626399] PPP BSD Compression module registered
[16:41:05.706] [ 1.626425] PPP Deflate Compression module registered
[16:41:05.706] [ 1.626473] PPP MPPE Compression module registered
[16:41:05.716] [ 1.626500] NET: Registered protocol family 24
[16:41:05.716] [ 1.626564] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[16:41:05.716] [ 1.626573] CSLIP: code copyright 1989 Regents of the University of California.
[16:41:05.716] [ 1.626592] Rockchip WiFi SYS interface (V1.00) …
[16:41:05.716] [ 1.626729] usbcore: registered new interface driver catc
[16:41:05.716] [ 1.626794] usbcore: registered new interface driver kaweth
[16:41:05.716] [ 1.626813] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[16:41:05.716] [ 1.626866] usbcore: registered new interface driver pegasus
[16:41:05.716] [ 1.626930] usbcore: registered new interface driver rtl8150
[16:41:05.716] [ 1.626995] usbcore: registered new interface driver r8152
[16:41:05.716] [ 1.627013] hso: drivers/net/usb/hso.c: Option Wireless
[16:41:05.716] [ 1.627085] usbcore: registered new interface driver hso
[16:41:05.716] [ 1.627153] usbcore: registered new interface driver asix
[16:41:05.716] [ 1.627218] usbcore: registered new interface driver ax88179_178a
[16:41:05.716] [ 1.627280] usbcore: registered new interface driver cdc_ether
[16:41:05.716] [ 1.627339] usbcore: registered new interface driver cdc_eem
[16:41:05.716] [ 1.627403] usbcore: registered new interface driver dm9601
[16:41:05.716] [ 1.627468] usbcore: registered new interface driver smsc75xx
[16:41:05.716] [ 1.627532] usbcore: registered new interface driver smsc95xx
[16:41:05.716] [ 1.627593] usbcore: registered new interface driver gl620a
[16:41:05.725] [ 1.627653] usbcore: registered new interface driver net1080
[16:41:05.725] [ 1.627705] usbcore: registered new interface driver plusb
[16:41:05.725] [ 1.627780] usbcore: registered new interface driver rndis_host
[16:41:05.725] [ 1.627841] usbcore: registered new interface driver cdc_subset
[16:41:05.725] [ 1.627897] usbcore: registered new interface driver zaurus
[16:41:05.725] [ 1.627953] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[16:41:05.725] [ 1.628033] usbcore: registered new interface driver int51x1
[16:41:05.725] [ 1.628093] usbcore: registered new interface driver kalmia
[16:41:05.725] [ 1.628150] usbcore: registered new interface driver ipheth
[16:41:05.725] [ 1.628231] usbcore: registered new interface driver sierra_net
[16:41:05.725] [ 1.628298] usbcore: registered new interface driver cx82310_eth
[16:41:05.725] [ 1.628364] usbcore: registered new interface driver cdc_ncm
[16:41:05.725] [ 1.628419] usbcore: registered new interface driver qmi_wwan
[16:41:05.725] [ 1.628475] usbcore: registered new interface driver cdc_mbim
[16:41:05.725] [ 1.655120] phy phy-ff7c0000.phy.6: phy poweron failed → -110
[16:41:05.746] [ 1.655257] dwc3 fe800000.dwc3: failed to initialize core
[16:41:05.746] [ 1.655340] dwc3: probe of fe800000.dwc3 failed with error -110
[16:41:05.746] [ 1.655507] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[16:41:05.746] [ 1.661657] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[16:41:05.746] [ 1.663504] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[16:41:05.746] [ 1.663523] ehci-pci: EHCI PCI platform driver
[16:41:05.746] [ 1.663588] ehci-platform: EHCI generic platform driver
[16:41:05.746] [ 1.667248] ehci-platform fe380000.usb: EHCI Host Controller
[16:41:05.756] [ 1.667493] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[16:41:05.756] [ 1.667752] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[16:41:05.756] [ 1.674898] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[16:41:05.756] [ 1.675152] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[16:41:05.756] [ 1.675200] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[16:41:05.756] [ 1.675244] usb usb1: Product: EHCI Host Controller
[16:41:05.756] [ 1.675257] usb usb1: Manufacturer: Linux 4.4.126 ehci_hcd
[16:41:05.763] [ 1.675269] usb usb1: SerialNumber: fe380000.usb
[16:41:05.763] [ 1.675864] hub 1-0:1.0: USB hub found
[16:41:05.763] [ 1.675944] hub 1-0:1.0: 1 port detected
[16:41:05.763] [ 1.680077] ehci-platform fe3c0000.usb: EHCI Host Controller
[16:41:05.763] [ 1.680355] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[16:41:05.763] [ 1.680585] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[16:41:05.763] [ 1.688221] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[16:41:05.776] [ 1.688444] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[16:41:05.776] [ 1.688491] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[16:41:05.776] [ 1.688504] usb usb2: Product: EHCI Host Controller
[16:41:05.776] [ 1.688516] usb usb2: Manufacturer: Linux 4.4.126 ehci_hcd
[16:41:05.776] [ 1.688562] usb usb2: SerialNumber: fe3c0000.usb
[16:41:05.776] [ 1.689118] hub 2-0:1.0: USB hub found
[16:41:05.776] [ 1.689196] hub 2-0:1.0: 1 port detected
[16:41:05.776] [ 1.690023] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[16:41:05.776] [ 1.690060] ohci-platform: OHCI generic platform driver
[16:41:05.776] [ 1.690510] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[16:41:05.776] [ 1.690715] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[16:41:05.776] [ 1.690949] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[16:41:05.776] [ 1.745727] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[16:41:05.827] [ 1.745775] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[16:41:05.827] [ 1.745790] usb usb3: Product: Generic Platform OHCI controller
[16:41:05.833] [ 1.745803] usb usb3: Manufacturer: Linux 4.4.126 ohci_hcd
[16:41:05.833] [ 1.745816] usb usb3: SerialNumber: fe3a0000.usb
[16:41:05.833] [ 1.746433] hub 3-0:1.0: USB hub found
[16:41:05.833] [ 1.746505] hub 3-0:1.0: 1 port detected
[16:41:05.833] [ 1.747178] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[16:41:05.833] [ 1.747410] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[16:41:05.833] [ 1.747617] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[16:41:05.833] [ 1.802387] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[16:41:05.888] [ 1.802436] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[16:41:05.888] [ 1.802452] usb usb4: Product: Generic Platform OHCI controller
[16:41:05.888] [ 1.802466] usb usb4: Manufacturer: Linux 4.4.126 ohci_hcd
[16:41:05.888] [ 1.802479] usb usb4: SerialNumber: fe3e0000.usb
[16:41:05.888] [ 1.803078] hub 4-0:1.0: USB hub found
[16:41:05.888] [ 1.803148] hub 4-0:1.0: 1 port detected
[16:41:05.888] [ 1.804546] usbcore: registered new interface driver cdc_acm
[16:41:05.888] [ 1.804596] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[16:41:05.897] [ 1.804681] usbcore: registered new interface driver usblp
[16:41:05.897] [ 1.804742] usbcore: registered new interface driver cdc_wdm
[16:41:05.897] [ 1.804809] usbcore: registered new interface driver uas
[16:41:05.897] [ 1.805027] usbcore: registered new interface driver usb-storage
[16:41:05.897] [ 1.805115] usbcore: registered new interface driver ums-alauda
[16:41:05.897] [ 1.805175] usbcore: registered new interface driver ums-cypress
[16:41:05.897] [ 1.805235] usbcore: registered new interface driver ums-datafab
[16:41:05.897] [ 1.805321] usbcore: registered new interface driver ums_eneub6250
[16:41:05.897] [ 1.805374] usbcore: registered new interface driver ums-freecom
[16:41:05.897] [ 1.805432] usbcore: registered new interface driver ums-isd200
[16:41:05.897] [ 1.805525] usbcore: registered new interface driver ums-jumpshot
[16:41:05.897] [ 1.805578] usbcore: registered new interface driver ums-karma
[16:41:05.897] [ 1.805632] usbcore: registered new interface driver ums-onetouch
[16:41:05.897] [ 1.805695] usbcore: registered new interface driver ums-sddr09
[16:41:05.897] [ 1.805786] usbcore: registered new interface driver ums-sddr55
[16:41:05.897] [ 1.805841] usbcore: registered new interface driver ums-usbat
[16:41:05.897] [ 1.805952] usbcore: registered new interface driver usbserial
[16:41:05.897] [ 1.806035] usbcore: registered new interface driver usbserial_generic
[16:41:05.897] [ 1.806075] usbserial: USB Serial support registered for generic
[16:41:05.897] [ 1.806135] usbcore: registered new interface driver option
[16:41:05.897] [ 1.806208] usbserial: USB Serial support registered for GSM modem (1-port)
[16:41:05.906] [ 1.806469] usbcore: registered new interface driver trancevibrator
[16:41:05.906] [ 1.806516] usb20_otg: version 3.10a 21-DEC-2012
[16:41:05.906] [ 1.806811] usb20_host: version 3.10a 21-DEC-2012
[16:41:05.906] [ 1.807643] usbcore: registered new interface driver xpad
[16:41:05.906] [ 1.807718] usbcore: registered new interface driver usb_acecad
[16:41:05.906] [ 1.807784] usbcore: registered new interface driver aiptek
[16:41:05.906] [ 1.807852] usbcore: registered new interface driver gtco
[16:41:05.906] [ 1.807913] usbcore: registered new interface driver hanwang
[16:41:05.906] [ 1.807980] usbcore: registered new interface driver kbtab
[16:41:05.906] [ 1.808727] .. rk pwm remotectl v1.1 init
[16:41:05.906] [ 1.809063] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[16:41:05.906] [ 1.809693] sensor_register_slave:mma8452,id=17
[16:41:05.906] [ 1.809755] sensor_register_slave:lis3dh,id=7
[16:41:05.906] [ 1.809772] sensor_register_slave:mma7660,id=18
[16:41:05.906] [ 1.809788] sensor_register_slave:lsm303d,id=22
[16:41:05.906] [ 1.809803] sensor_register_slave:gs_mc3230,id=23
[16:41:05.906] [ 1.809811] [Gsensor] gsensor_init
[16:41:05.906] [ 1.809827] sensor_register_slave:mpu6880_acc,id=24
[16:41:05.906] [ 1.809843] sensor_register_slave:mpu6500_acc,id=25
[16:41:05.906] [ 1.809858] sensor_register_slave:lsm330_acc,id=26
[16:41:05.906] [ 1.809873] sensor_register_slave:bma2xx_acc,id=27
[16:41:05.906] [ 1.809889] sensor_register_slave:akm8975,id=30
[16:41:05.906] [ 1.809905] sensor_register_slave:akm8963,id=31
[16:41:05.916] [ 1.809922] sensor_register_slave:l3g4200d,id=45
[16:41:05.916] [ 1.809970] sensor_register_slave:l3g20d,id=46
[16:41:05.916] [ 1.809986] sensor_register_slave:ewtsa,id=47
[16:41:05.916] [ 1.810003] sensor_register_slave:lsm330_gyro,id=51
[16:41:05.916] [ 1.810018] sensor_register_slave:cm3217,id=53
[16:41:05.916] [ 1.810034] sensor_register_slave:cm3218,id=54
[16:41:05.916] [ 1.810049] sensor_register_slave:ls_stk3410,id=62
[16:41:05.916] [ 1.810065] sensor_register_slave:ps_stk3410,id=67
[16:41:05.916] [ 1.811162] i2c /dev entries driver
[16:41:05.916] [ 1.813052] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[16:41:05.916] [ 1.813188] fan53555-reg: supplied by vcc5v0_sys
[16:41:05.916] [ 1.815873] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[16:41:05.916] [ 1.815986] fan53555-reg: supplied by vcc5v0_sys
[16:41:05.916] [ 1.818290] rockchip-pinctrl pinctrl: pin gpio1-18 already requested by 0-0040; cannot claim for 0-001b
[16:41:05.916] [ 1.818309] rockchip-pinctrl pinctrl: pin-50 (0-001b) status -22
[16:41:05.916] [ 1.818365] rockchip-pinctrl pinctrl: could not request pin 50 (gpio1-18) from group pmic-dvs2 on device rockchip-pinctrl
[16:41:05.916] [ 1.818378] rk808 0-001b: Error applying setting, reverse things back
[16:41:05.916] [ 1.818836] rk808 0-001b: Pmic Chip id: 0x0
[16:41:05.916] [ 1.822501] rk808-regulator rk808-regulator: there is no dvs0 gpio
[16:41:05.916] [ 1.822615] rk808-regulator rk808-regulator: there is no dvs1 gpio
[16:41:05.916] [ 1.822760] DCDC_REG1: supplied by vcc3v3_sys
[16:41:05.927] [ 1.823718] DCDC_REG2: supplied by vcc3v3_sys
[16:41:05.927] [ 1.824434] DCDC_REG3: supplied by vcc3v3_sys
[16:41:05.927] [ 1.824773] DCDC_REG4: supplied by vcc3v3_sys
[16:41:05.927] [ 1.825385] LDO_REG1: supplied by vcc3v3_sys
[16:41:05.927] [ 1.826652] LDO_REG2: supplied by vcc3v3_sys
[16:41:05.927] [ 1.827744] LDO_REG3: supplied by vcc3v3_sys
[16:41:05.927] [ 1.828854] LDO_REG4: supplied by vcc3v3_sys
[16:41:05.927] [ 1.830001] LDO_REG5: supplied by vcc3v3_sys
[16:41:05.927] [ 1.831101] LDO_REG6: supplied by vcc3v3_sys
[16:41:05.927] [ 1.832205] LDO_REG7: supplied by vcc3v3_sys
[16:41:05.927] [ 1.833355] LDO_REG8: supplied by vcc3v3_sys
[16:41:05.927] [ 1.834457] SWITCH_REG1: supplied by vcc3v3_sys
[16:41:05.927] [ 1.834871] SWITCH_REG2: supplied by vcc3v3_sys
[16:41:05.927] [ 1.835488] firefly_hwversion_in_range 焘
以上是enforcing下串口的log permissive模式下系统正常启动,请各路大神帮忙分析
补充log 信息
[16:42:03.956] [ 1.623880] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[16:42:03.956] [ 1.624508] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80098de000
[16:42:03.956] [ 1.625410] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80098e0000
[16:42:03.956] [ 1.626132] rk3x-i2c ff120000.i2c: Initialized RK3xxx I2C bus at ffffff80098e2000
[16:42:03.956] [ 1.626841] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80098e4000
[16:42:03.956] [ 1.628271] IR NEC protocol handler initialized
[16:42:03.956] [ 1.628319] IR RC5(x/sz) protocol handler initialized
[16:42:03.956] [ 1.628333] IR RC6 protocol handler initialized
[16:42:03.956] [ 1.628346] IR JVC protocol handler initialized
[16:42:03.956] [ 1.628358] IR Sony protocol handler initialized
[16:42:03.956] [ 1.628371] IR SANYO protocol handler initialized
[16:42:03.956] [ 1.628384] IR Sharp protocol handler initialized
[16:42:03.970] [ 1.628397] IR MCE Keyboard/mouse protocol handler initialized
[16:42:03.970] [ 1.628410] IR XMP protocol handler initialized
[16:42:03.970] [ 1.628736] usbcore: registered new interface driver uvcvideo
[16:42:03.970] [ 1.628748] USB Video Class driver (1.1.1)
[16:42:03.970] [ 1.628803] CamSys driver version: v0.41.0, CamSys head file version: v1.0.0
[16:42:03.970] [ 1.634688] __power_supply_register: Expected proper parent device for ‘test_ac’
[16:42:03.970] [ 1.634916] __power_supply_register: Expected proper parent device for ‘test_battery’
[16:42:03.970] [ 1.635282] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[16:42:03.976] [ 1.635447] __power_supply_register: Expected proper parent device for ‘test_usb’
[16:42:03.976] [ 1.638891] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[16:42:03.976] [ 1.640020] device-mapper: uevent: version 1.0.3
[16:42:03.976] [ 1.640487] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[16:42:03.976] [ 1.640729] Bluetooth: HCI UART driver ver 2.3
[16:42:03.976] [ 1.640751] Bluetooth: HCI UART protocol H4 registered
[16:42:03.976] [ 1.640761] Bluetooth: HCI UART protocol LL registered
[16:42:03.976] [ 1.640777] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[16:42:03.976] [ 1.640786] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[16:42:03.976] [ 1.640795] rtk_btusb: Register usb char device interface for BT driver
[16:42:03.976] [ 1.641069] usbcore: registered new interface driver rtk_btusb
[16:42:03.976] [ 1.641566] cpu cpu0: bin=1
[16:42:03.976] [ 1.641629] cpu cpu0: leakage=20
[16:42:03.976] [ 1.653639] cpu cpu0: temp=35000, pvtm=149117 (149807 + -690)
[16:42:03.976] [ 1.653928] cpu cpu0: pvtm-volt-sel=2
[16:42:03.976] [ 1.654007] cpu cpu0: bin-scale=34
[16:42:03.976] [ 1.654291] cpu cpu4: bin=1
[16:42:03.976] [ 1.654367] cpu cpu4: leakage=35
[16:42:03.984] [ 1.667396] cpu cpu4: temp=35000, pvtm=152579 (153005 + -426)
[16:42:03.996] [ 1.668597] cpu cpu4: pvtm-volt-sel=1
[16:42:03.996] [ 1.668667] cpu cpu4: bin-scale=17
[16:42:03.996] [ 1.669713] cpu cpu0: avs=0, target-scale=34
[16:42:03.996] [ 1.669810] cpu cpu0: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[16:42:03.996] [ 1.670947] cpu cpu4: avs=0, target-scale=17
[16:42:03.996] [ 1.671043] cpu cpu4: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[16:42:03.996] [ 1.672471] sdhci: Secure Digital Host Controller Interface driver
[16:42:03.996] [ 1.672504] sdhci: Copyright(c) Pierre Ossman
[16:42:03.996] [ 1.672517] Synopsys Designware Multimedia Card Interface Driver
[16:42:03.996] [ 1.673363] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[16:42:03.996] [ 1.673509] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[16:42:03.996] [ 1.673529] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[16:42:03.996] [ 1.673582] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[16:42:03.996] [ 1.673631] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[16:42:04.004] [ 1.673674] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[16:42:04.004] [ 1.673684] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[16:42:04.004] [ 1.674456] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[16:42:04.004] [ 1.674533] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[16:42:04.004] [ 1.674550] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[16:42:04.004] [ 1.674608] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[16:42:04.004] [ 1.674627] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[16:42:04.004] [ 1.675403] sdhci-pltfm: SDHCI platform and OF driver helper
[16:42:04.004] [ 1.677093] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[16:42:04.004] [ 1.677104] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[16:42:04.004] [ 1.704965] mmc0: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[16:42:04.033] [ 1.707174] hidraw: raw HID events driver (C) Jiri Kosina
[16:42:04.033] [ 1.709892] usbcore: registered new interface driver usbhid
[16:42:04.033] [ 1.709907] usbhid: USB HID core driver
[16:42:04.033] [ 1.710038] inv_mpu_iio: inv_mpu_init:746
[16:42:04.033] [ 1.710635] ashmem: initialized
[16:42:04.033] [ 1.715739] rknandbase v1.1 2016-11-08
[16:42:04.042] [ 1.717109] usbcore: registered new interface driver snd-usb-audio
[16:42:04.042] [ 1.719572] rt5640 1-001c: rt5640 have no io-channels defined
[16:42:04.042] [ 1.719614] rt5640 1-001c: rt5640 have no aux_det_adc_value defined
[16:42:04.042] [ 1.731054] rk-hdmi-dp-sound hdmi-dp-sound: i2s-hifi ↔ ff8a0000.i2s mapping ok
[16:42:04.057] [ 1.732994] u32 classifier
[16:42:04.057] [ 1.733033] Actions configured
[16:42:04.057] [ 1.733091] Netfilter messages via NETLINK v0.30.
[16:42:04.057] [ 1.733166] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[16:42:04.057] [ 1.733577] ctnetlink v0.93: registering with nfnetlink.
[16:42:04.057] [ 1.734292] xt_time: kernel timezone is -0000
[16:42:04.057] [ 1.735141] ip_tables: (C) 2000-2006 Netfilter Core Team
[16:42:04.057] [ 1.735391] arp_tables: (C) 2002 David S. Miller
[16:42:04.066] [ 1.735947] Initializing XFRM netlink socket
[16:42:04.066] [ 1.736431] NET: Registered protocol family 10
[16:42:04.066] [ 1.737670] mip6: Mobile IPv6
[16:42:04.066] [ 1.737785] ip6_tables: (C) 2000-2006 Netfilter Core Team
[16:42:04.066] [ 1.740504] sit: IPv6 over IPv4 tunneling driver
[16:42:04.066] [ 1.741262] NET: Registered protocol family 17
[16:42:04.066] [ 1.741351] NET: Registered protocol family 15
[16:42:04.066] [ 1.741576] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[16:42:04.066] [ 1.743766] Bridge firewalling registered
[16:42:04.066] [ 1.743832] Ebtables v2.0 registered
[16:42:04.066] [ 1.744359] Bluetooth: RFCOMM TTY layer initialized
[16:42:04.066] [ 1.744397] Bluetooth: RFCOMM socket layer initialized
[16:42:04.066] [ 1.744438] Bluetooth: RFCOMM ver 1.11
[16:42:04.066] [ 1.744464] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[16:42:04.066] [ 1.744473] Bluetooth: BNEP filters: protocol multicast
[16:42:04.066] [ 1.744488] Bluetooth: BNEP socket layer initialized
[16:42:04.076] [ 1.744536] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[16:42:04.076] [ 1.744551] Bluetooth: HIDP socket layer initialized
[16:42:04.076] [ 1.745797] mmc0: MAN_BKOPS_EN bit is not set
[16:42:04.076] [ 1.744634] l2tp_core: L2TP core driver, V2.0
[16:42:04.076] [ 1.744660] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[16:42:04.076] [ 1.744679] [WLAN_RFKILL]: Enter rfkill_wlan_init
[16:42:04.076] [ 1.745293] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[16:42:04.076] [ 1.745410] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6255
[16:42:04.076] [ 1.745420] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[16:42:04.076] [ 1.745430] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[16:42:04.076] [ 1.745539] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[16:42:04.076] [ 1.745568] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[16:42:04.076] [ 1.745581] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[16:42:04.076] [ 1.745662] [BT_RFKILL]: Enter rfkill_rk_init
[16:42:04.076] [ 1.746298] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[16:42:04.076] [ 1.746378] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[16:42:04.076] [ 1.746418] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[16:42:04.076] [ 1.746457] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[16:42:04.076] [ 1.746737] [BT_RFKILL]: Request irq for bt wakeup host
[16:42:04.086] [ 1.746829] [BT_RFKILL]: ** disable irq
[16:42:04.086] [ 1.747012] [BT_RFKILL]: bt_default device registered.
[16:42:04.086] [ 1.747246] sensor_register_slave:mpu6500_gyro,id=49
[16:42:04.086] [ 1.747272] sensor_register_slave:mpu6880_gyro,id=50
[16:42:04.086] [ 1.749227] Registered cp15_barrier emulation handler
[16:42:04.086] [ 1.749338] Registered setend emulation handler
[16:42:04.086] [ 1.750484] registered taskstats version 1
[16:42:04.086] [ 1.751545] rockchip ion idev is NULL
[16:42:04.086] [ 1.751573] rga2 ff680000.rga: rga ion client create success!
[16:42:04.086] [ 1.751886] rga: Driver loaded successfully ver:3.02
[16:42:04.086] [ 1.757363] mali ff9a0000.gpu: leakage=25
[16:42:04.086] [ 1.757918] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[16:42:04.086] [ 1.758592] mmcblk0: mmc0:0001 AJTD4R 14.6 GiB
[16:42:04.086] [ 1.758946] mmcblk0boot0: mmc0:0001 AJTD4R partition 1 4.00 MiB
[16:42:04.086] [ 1.759325] mmcblk0boot1: mmc0:0001 AJTD4R partition 2 4.00 MiB
[16:42:04.086] [ 1.759603] mmcblk0rpmb: mmc0:0001 AJTD4R partition 3 4.00 MiB
[16:42:04.096] [ 1.770069] mali ff9a0000.gpu: temp=35625, pvtm=124622 (124898 + -276)
[16:42:04.086] [ 1.759953] uboot: 0x000400000 – 0x000800000 (4 MB)
[16:42:04.086] [ 1.759965] trust: 0x000800000 – 0x000c00000 (4 MB)
[16:42:04.086] [ 1.759975] misc: 0x000c00000 – 0x001000000 (4 MB)
[16:42:04.086] [ 1.759985] resource: 0x001000000 – 0x002000000 (16 MB)
[16:42:04.086] [ 1.760003] kernel: 0x002000000 – 0x003800000 (24 MB)
[16:42:04.086] [ 1.760012] boot: 0x003800000 – 0x005800000 (32 MB)
[16:42:04.096] [ 1.760020] recovery: 0x005800000 – 0x009800000 (64 MB)
[16:42:04.096] [ 1.760029] backup: 0x009800000 – 0x010800000 (112 MB)
[16:42:04.096] [ 1.760038] cache: 0x010800000 – 0x018800000 (128 MB)
[16:42:04.096] [ 1.760046] system: 0x018800000 – 0x078800000 (1536 MB)
[16:42:04.096] [ 1.760055] oem: 0x078800000 – 0x098800000 (512 MB)
[16:42:04.096] [ 1.760063] metadata: 0x098800000 – 0x099800000 (16 MB)
[16:42:04.096] [ 1.760072] verity_mode: 0x099800000 – 0x099808000 (0 MB)
[16:42:04.096] [ 1.760081] reserved: 0x099808000 – 0x099c08000 (4 MB)
[16:42:04.096] [ 1.760089] frp: 0x099c08000 – 0x099c88000 (0 MB)
[16:42:04.096] [ 1.760097] userdata: 0x099c88000 – 0x3a3a00000 (12445 MB)
[16:42:04.096] [ 1.760151] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16
[16:42:04.096] [ 1.771028] mali ff9a0000.gpu: pvtm-volt-sel=1
[16:42:04.096] [ 1.771559] usb 1-1: new high-speed USB device number 2 using ehci-platform
[16:42:04.096] [ 1.772612] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[16:42:04.096] [ 1.773237] mali ff9a0000.gpu: Protected mode not available
[16:42:04.096] [ 1.774037] mali ff9a0000.gpu: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[16:42:04.096] [ 1.774107] mali ff9a0000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model
[16:42:04.106] [ 1.774276] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 414; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[16:42:04.106] [ 1.774972] mali ff9a0000.gpu: Probed as mali0
[16:42:04.106] [ 1.780550] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[16:42:04.106] [ 1.780932] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 5
[16:42:04.106] [ 1.781595] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[16:42:04.106] [ 1.781689] xhci-hcd xhci-hcd.10.auto: irq 234, io mem 0xfe800000
[16:42:04.106] [ 1.781896] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[16:42:04.106] [ 1.781945] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[16:42:04.106] [ 1.781958] usb usb5: Product: xHCI Host Controller
[16:42:04.106] [ 1.781971] usb usb5: Manufacturer: Linux 4.4.126 xhci-hcd
[16:42:04.106] [ 1.781984] usb usb5: SerialNumber: xhci-hcd.10.auto
[16:42:04.106] [ 1.782901] hub 5-0:1.0: USB hub found
[16:42:04.106] [ 1.783041] hub 5-0:1.0: 1 port detected
[16:42:04.106] [ 1.783839] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[16:42:04.116] [ 1.784268] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 6
[16:42:04.116] [ 1.784393] usb usb6: We don’t know the algorithms for LPM for this host, disabling LPM.
[16:42:04.116] [ 1.784737] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[16:42:04.116] [ 1.784807] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[16:42:04.116] [ 1.785031] usb usb6: Product: xHCI Host Controller
[16:42:04.116] [ 1.785253] usb usb6: Manufacturer: Linux 4.4.126 xhci-hcd
[16:42:04.116] [ 1.785477] usb usb6: SerialNumber: xhci-hcd.10.auto
[16:42:04.116] [ 1.786623] hub 6-0:1.0: USB hub found
[16:42:04.116] [ 1.786861] hub 6-0:1.0: 1 port detected
[16:42:04.116] [ 1.793827] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[16:42:04.116] [ 1.794259] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 7
[16:42:04.116] [ 1.794997] xhci-hcd xhci-hcd.11.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010
[16:42:04.116] [ 1.795301] xhci-hcd xhci-hcd.11.auto: irq 235, io mem 0xfe900000
[16:42:04.126] [ 1.795725] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002
[16:42:04.126] [ 1.795946] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[16:42:04.126] [ 1.796170] usb usb7: Product: xHCI Host Controller
[16:42:04.126] [ 1.796398] usb usb7: Manufacturer: Linux 4.4.126 xhci-hcd
[16:42:04.126] [ 1.796624] usb usb7: SerialNumber: xhci-hcd.11.auto
[16:42:04.126] [ 1.797850] hub 7-0:1.0: USB hub found
[16:42:04.126] [ 1.797966] hub 7-0:1.0: 1 port detected
[16:42:04.126] [ 1.798806] xhci-hcd xhci-hcd.11.auto: xHCI Host Controller
[16:42:04.126] [ 1.799228] xhci-hcd xhci-hcd.11.auto: new USB bus registered, assigned bus number 8
[16:42:04.126] [ 1.799523] usb usb8: We don’t know the algorithms for LPM for this host, disabling LPM.
[16:42:04.126] [ 1.799802] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003
[16:42:04.126] [ 1.799872] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[16:42:04.126] [ 1.800096] usb usb8: Product: xHCI Host Controller
[16:42:04.126] [ 1.800322] usb usb8: Manufacturer: Linux 4.4.126 xhci-hcd
[16:42:04.126] [ 1.800548] usb usb8: SerialNumber: xhci-hcd.11.auto
[16:42:04.126] [ 1.801771] hub 8-0:1.0: USB hub found
[16:42:04.126] [ 1.801892] hub 8-0:1.0: 1 port detected
[16:42:04.126] [ 1.805318] xhci-hcd xhci-hcd.11.auto: remove, state 1
[16:42:04.126] [ 1.805392] usb usb8: USB disconnect, device number 1
[16:42:04.132] [ 1.806920] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[16:42:04.147] [ 1.807050] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[16:42:04.156] [ 1.807081] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[16:42:04.156] [ 1.807132] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[16:42:04.156] [ 1.807169] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[16:42:04.156] [ 1.807244] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[16:42:04.156] [ 1.807262] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[16:42:04.156] [ 1.807783] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[16:42:04.156] [ 1.825001] xhci-hcd xhci-hcd.11.auto: Host not halted after 16000 microseconds.
[16:42:04.156] [ 1.825018] xhci-hcd xhci-hcd.11.auto: Host controller not halted, aborting reset.
[16:42:04.156] [ 1.825491] xhci-hcd xhci-hcd.11.auto: USB bus 8 deregistered
[16:42:04.156] [ 1.818499] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[16:42:04.156] [ 1.826109] xhci-hcd xhci-hcd.11.auto: remove, state 1
[16:42:04.156] [ 1.826252] usb usb7: USB disconnect, device number 1
[16:42:04.156] [ 1.827114] xhci-hcd xhci-hcd.11.auto: USB bus 7 deregistered
[16:42:04.156] [ 1.831875] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[16:42:04.156] [ 1.833646] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[16:42:04.156] [ 1.834543] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[16:42:04.156] [ 1.834775] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[16:42:04.156] [ 1.835029] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[16:42:04.162] [ 1.835248] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[16:42:04.162] [ 1.836486] dwmmc_rockchip fe320000.dwmmc: allocated mmc-pwrseq
[16:42:04.162] [ 1.837013] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[16:42:04.162] [ 1.837203] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[16:42:04.162] [ 1.837439] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[16:42:04.162] [ 1.837655] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3000000 done
[16:42:04.162] [ 1.848282] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[16:42:04.172] [ 1.862675] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[16:42:04.185] [ 1.871887] asoc-simple-card rt5640-sound: rt5640-aif1 ↔ ff890000.i2s mapping ok
[16:42:04.194] [ 1.877638] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[16:42:04.206] [ 1.879229] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/rt5640-sound/sound/card1/input1
[16:42:04.206] [ 1.879490] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[16:42:04.206] [ 1.881106] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[16:42:04.206] [ 1.882158] i2c i2c-2: sensor_probe: gs_mc3230,ffffffc07b741000
[16:42:04.206] [ 1.882316] sensors 2-004c: sensor_chip_init:gs_mc3230:devid=0x0,ops=0xffffff80092a9580
[16:42:04.206] [ 1.884223] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[16:42:04.206] [ 1.887786] mmc1: queuing unknown CIS tuple 0x81 (9 bytes)
[16:42:04.216] [ 1.895661] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101
[16:42:04.221] [ 1.895740] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[16:42:04.221] [ 1.895776] usb 1-1: Product: USB 2.0 Hub [MTT]
[16:42:04.221] [ 1.896876] hub 1-1:1.0: USB hub found
[16:42:04.221] [ 1.897155] hub 1-1:1.0: 4 ports detected
[16:42:04.221] [ 1.943212] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[16:42:04.266]
[16:42:04.501] [ 2.178531] usb 1-1.2: new low-speed USB device number 3 using ehci-platform
[16:42:04.501] [ 2.253700] vendor storage:20160801 ret = 0
[16:42:04.576] [ 2.280933] usb 1-1.2: New USB device found, idVendor=413c, idProduct=301a
[16:42:04.605] [ 2.281080] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[16:42:04.605] [ 2.281106] usb 1-1.2: Product: Dell MS116 USB Optical Mouse
[16:42:04.605] [ 2.281130] usb 1-1.2: Manufacturer: PixArt
[16:42:04.605] [ 2.286550] input: PixArt Dell MS116 USB Optical Mouse as /devices/platform/fe380000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:413C:301A.0001/input/input2
[16:42:04.611] [ 2.287770] hid-generic 0003:413C:301A.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt Dell MS116 USB Optical Mouse] on usb-fe380000.usb-1.2/input0
[16:42:04.611] [ 2.300900] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 5
[16:42:04.626] [ 2.304655] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[16:42:04.626] [ 2.304794] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[16:42:04.631]
[16:42:08.061] [ 5.738554] rk3x-i2c ff120000.i2c: timeout, ipd: 0x81, state: 3
[16:42:08.061]
[16:42:09.972] [ 7.648490] rk3x-i2c ff120000.i2c: timeout, ipd: 0x81, state: 3
[16:42:09.972]
[16:42:11.823] [ 9.499895] [Gsensor] init_3230_ctl_data 445 : error: -6
[16:42:11.823] [ 9.499982] sensors 2-004c: sensor_initial:fail to init sensor
[16:42:11.823] [ 9.500004] sensors 2-004c: sensor_chip_init:fail to init sensor
[16:42:11.835] [ 9.500026] i2c i2c-2: sensor_probe failed -2
[16:42:11.835] [ 9.500074] sensors: probe of 2-004c failed with error -2
[16:42:11.835] [ 9.501678] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 09:03:11 UTC (1358499791)
[16:42:11.835] [ 9.504231] It doesn’t contain Rogue gpu
[16:42:11.835] [ 9.537895] vdd3v3_pcie: disabling
[16:42:11.866] [ 9.542208] ret 1024
[16:42:11.866] [ 9.543254] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘-3568ce9’, rk_ko_ver is ‘5’, built at ‘15:00:57’, on ‘Dec 31 2019’.
[16:42:11.866] [ 9.544043] Mali: Mali device driver loaded
[16:42:11.866] [ 9.545051] input: rk29-keypad as /devices/platform/rockchip-key/input/input3
[16:42:11.873] [ 9.547549] ALSA device list:
[16:42:11.873] [ 9.547623] #0: rk-hdmi-dp-sound
[16:42:11.873] [ 9.547818] #1: rockchip,rt5640-codec
[16:42:11.873] [ 9.548775] Freeing unused kernel memory: 832K
[16:42:11.873] [ 9.551918] init: init first stage started!
[16:42:11.873] [ 9.622625] audit: type=1403 audit(1358499791.620:2): policy loaded auid=4294967295 ses=4294967295
[16:42:11.946] [ 9.623360] audit: type=1404 audit(1358499791.620:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
[16:42:11.946] [ 9.635404] init: (Initializing SELinux enforcing took 0.08s.)
[16:42:11.966] [ 9.638898] init: init second stage started!
[16:42:11.966] [ 9.643175] init: Setting ro.rk.soc=rk3399
[16:42:11.966] [ 9.643355] init: OK,EMMC DRIVERS INIT OK
[16:42:11.966] [ 9.643482] init: property_set(“ro.boot.mode”, “emmc”) failed
[16:42:11.966] [ 9.643761] init: property_set(“ro.hardware”, “rk30board”) failed
[16:42:11.971] [ 9.647011] init: Running restorecon…
[16:42:11.971] [ 9.741321] init: waitpid failed: No child processes
[16:42:12.066] [ 9.741764] init: (Loading properties from /default.prop took 0.00s.)
[16:42:12.066] [ 9.744118] init: (Parsing /init.environ.rc took 0.00s.)
[16:42:12.066] [ 9.744589] init: (Parsing /init.usb.rc took 0.00s.)
[16:42:12.066] [ 9.745843] init: (Parsing init.rk30board.bootmode.emmc.rc took 0.00s.)
[16:42:12.076] [ 9.746657] init: (Parsing init.rk30board.usb.rc took 0.00s.)
[16:42:12.076] [ 9.746730] init: (Parsing init.rk30board.environment.rc took 0.00s.)
[16:42:12.076] [ 9.746832] init: could not import file ‘/init.stt_trace.rc’ from ‘/init.debug.rc’: No such file or directory
[16:42:12.076] [ 9.746870] init: could not import file ‘/init.logs.rc’ from ‘/init.debug.rc’: No such file or directory
[16:42:12.076] [ 9.746900] init: could not import file ‘/init.crashlogd.rc’ from ‘/init.debug.rc’: No such file or directory
[16:42:12.076] [ 9.746930] init: could not import file ‘/init.coredump.rc’ from ‘/init.debug.rc’: No such file or directory
[16:42:12.076] [ 9.746959] init: could not import file ‘/init.log-watch.rc’ from ‘/init.debug.rc’: No such file or directory
[16:42:12.076] [ 9.746989] init: could not import file ‘/init.kernel.rc’ from ‘/init.debug.rc’: No such file or directory
[16:42:12.076] [ 9.747021] init: could not import file ‘/init.debug-charging.rc’ from ‘/init.debug.rc’: No such file or directory
[16:42:12.076] [ 9.747045] init: (Parsing /init.debug.rc took 0.00s.)
[16:42:12.076] [ 9.747061] init: (Parsing init.rockchip.rc took 0.00s.)
[16:42:12.076] [ 9.747477] init: (Parsing init.connectivity.rc took 0.00s.)
[16:42:12.076] [ 9.747518] init: could not import file ‘init.box.samba.rc’ from ‘/init.rk30board.rc’: No such file or directory
[16:42:12.076] [ 9.747705] init: (Parsing init.rk3399.rc took 0.00s.)
[16:42:12.076] [ 9.747809] init: init.tablet.rc: 23: invalid keyword ‘ioprio’
[16:42:12.086] [ 9.747852] init: (Parsing init.tablet.rc took 0.00s.)
[16:42:12.086] [ 9.747887] init: could not import file ‘init.car.rc’ from ‘/init.rk30board.rc’: No such file or directory
[16:42:12.086] [ 9.747918] init: could not import file ‘init.optee.rc’ from ‘/init.rk30board.rc’: No such file or directory
[16:42:12.086] [ 9.747940] init: (Parsing /init.rk30board.rc took 0.00s.)
[16:42:12.086] [ 9.749588] init: (Parsing /init.usb.configfs.rc took 0.00s.)
[16:42:12.086] [ 9.749944] init: (Parsing /init.zygote64_32.rc took 0.00s.)
[16:42:12.086] [ 9.750037] init: (Parsing /init.rc took 0.01s.)
[16:42:12.086] [ 9.751185] init: Starting service ‘ueventd’…
[16:42:12.086] [ 9.765660] ueventd: ueventd started!
[16:42:12.094] [ 9.767475] ueventd: invalid gid ‘trace’
[16:42:12.094]
[16:42:12.412] [ 10.089919] ueventd: Coldboot took 0.31s.
[16:42:12.412] [ 10.115983] init: Waiting for /dev/.coldboot_done…
[16:42:12.446] [ 10.116063] init: Waiting for /dev/.coldboot_done took 0.00s.
[16:42:12.446] [ 10.116097] init: /dev/hw_random not found
[16:42:12.446] [ 10.116624] keychord: using input dev ff420030.pwm for fevent
[16:42:12.446] [ 10.116640] keychord: using input dev rk29-keypad for fevent
[16:42:12.446] [ 10.125826] init: write_file: Unable to open ‘/proc/cpu/alignment’: No such file or directory
[16:42:12.468] [ 10.137729] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: (null)
[16:42:12.473] [ 10.137869] Registered swp emulation handler
[16:42:12.473] [ 10.138066] init: write_file: Unable to open ‘/sys/module/rockchip_pm/parameters/policy’: No such file or directory
[16:42:12.473] [ 10.138820] init: /dev/hw_random not found
[16:42:12.473] [ 10.138924] init: Starting service ‘exec 1 (/sbin/slideshow)’…
[16:42:12.473]
[16:42:13.753] [ 11.430962] Freeing drm_logo memory: 732K
[16:42:13.753]
[16:42:18.874] [ 16.552519] rockchip-vop ff900000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11
[16:42:18.874] [ 16.699710] init: Service ‘exec 1 (/sbin/slideshow)’ (pid 189) exited with status 0
[16:42:19.022] [ 16.918685] fs_mgr: Enabling dm-verity for system (mode 0)
[16:42:19.246] [ 16.918890] fs_mgr: loading verity table: ‘1 /dev/block/platform/fe330000.sdhci/by-name/system /dev/block/platform/fe330000.sdhci/by-name/system 4096 4096 387072 387072 sha256 579352f779222e5fc5467f08d5eba4f80d39f6f32b7592d6921c621433670415 aee087a5be3b982978c923f566a94613496b417f2af592639bc80d141e34dfe7 9 use_fec_from_device /dev/block/platform/fe330000.sdhci/by-name/system fec_start 390129 fec_blocks 390129 fec_roots 2 ignore_zero_blocks’fs_mgr: check_fs(): mount(/dev/block/dm-0,/system,ext4)=-1: Permission denied
[16:42:19.246] [ 16.924143] fs_mgr: Not running /system/bin/e2fsck on /dev/block/dm-0 (executable not in system image)
[16:42:19.266] [ 16.931366] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[16:42:19.266] [ 16.931464] fs_mgr: __mount(source=/dev/block/dm-0,target=/system,type=ext4)=0
[16:42:19.266] [ 16.932848] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/cache,/cache,ext4)=-1: No such file or directory
[16:42:19.266] [ 16.935171] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/cache
[16:42:19.266] [ 16.942949] random: e2fsck: uninitialized urandom read (40 bytes read, 127 bits of entropy available)
[16:42:19.266] [ 16.964669] random: nonblocking pool is initialized
[16:42:19.290] [ 16.981573] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[16:42:19.307] [ 16.981573]
[16:42:19.307] [ 16.981626] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/cache: clean, 21/8192 files, 1587/32768 blocks
[16:42:19.307] [ 16.986329] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[16:42:19.316] [ 16.986600] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/cache,target=/cache,type=ext4)=0
[16:42:19.316] [ 16.988790] EXT4-fs (mmcblk0p12): Ignoring removed nomblk_io_submit option
[16:42:19.316] [ 16.992797] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[16:42:19.316] [ 16.992912] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/metadata,/metadata,ext4)=0: Success
[16:42:19.316] [ 17.017778] fs_mgr: check_fs(): unmount(/metadata) succeeded
[16:42:19.343] [ 17.017968] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/metadata
[16:42:19.343] [ 17.042828] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[16:42:19.366] [ 17.042828]
[16:42:19.366] [ 17.043017] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/metadata: clean, 11/1024 files, 1102/4096 blocks (check in 5 mounts)
[16:42:19.366] [ 17.049585] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[16:42:19.375] [ 17.049794] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/metadata,target=/metadata,type=ext4)=0
[16:42:19.375] [ 17.054376] EXT4-fs (mmcblk0p16): Ignoring removed nomblk_io_submit option
[16:42:19.382] [ 17.057866] EXT4-fs (mmcblk0p16): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[16:42:19.382] [ 17.058131] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/userdata,/data,ext4)=0: Success
[16:42:19.382] [ 17.076207] fs_mgr: check_fs(): unmount(/data) succeeded
[16:42:19.399] [ 17.076407] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/userdata
[16:42:19.399] [ 17.114244] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[16:42:19.436] [ 17.114244]
[16:42:19.436] [ 17.114498] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/userdata: clean, 11/796544 files, 90601/3186040 blocks
[16:42:19.444] [ 17.120487] EXT4-fs (mmcblk0p16): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard,errors=panic
[16:42:19.444] [ 17.120686] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/userdata,target=/data,type=ext4)=0
[16:42:19.444] [ 17.127947] init: (Parsing /system/etc/init/atrace.rc took 0.00s.)
[16:42:19.467] [ 17.128593] init: (Parsing /system/etc/init/audioserver.rc took 0.00s.)
[16:42:19.467] [ 17.129073] init: (Parsing /system/etc/init/bootanim.rc took 0.00s.)
[16:42:19.467] [ 17.129574] init: (Parsing /system/etc/init/bootstat.rc took 0.00s.)
[16:42:19.467] [ 17.130002] init: (Parsing /system/etc/init/cameraserver.rc took 0.00s.)
[16:42:19.467] [ 17.130472] init: (Parsing /system/etc/init/debuggerd.rc took 0.00s.)
[16:42:19.467] [ 17.130934] init: (Parsing /system/etc/init/debuggerd64.rc took 0.00s.)
[16:42:19.467] [ 17.131429] init: (Parsing /system/etc/init/drmserver.rc took 0.00s.)
[16:42:19.467] [ 17.132020] init: (Parsing /system/etc/init/dumpstate.rc took 0.00s.)
[16:42:19.467] [ 17.132424] init: (Parsing /system/etc/init/gatekeeperd.rc took 0.00s.)
[16:42:19.467] [ 17.132821] init: (Parsing /system/etc/init/installd.rc took 0.00s.)
[16:42:19.467] [ 17.133196] init: (Parsing /system/etc/init/keystore.rc took 0.00s.)
[16:42:19.467] [ 17.133559] init: (Parsing /system/etc/init/lmkd.rc took 0.00s.)
[16:42:19.467] [ 17.133944] init: (Parsing /system/etc/init/logd.rc took 0.00s.)
[16:42:19.467] [ 17.134306] init: (Parsing /system/etc/init/mdnsd.rc took 0.00s.)
[16:42:19.467] [ 17.134666] init: (Parsing /system/etc/init/mediacodec.rc took 0.00s.)
[16:42:19.467] [ 17.135032] init: (Parsing /system/etc/init/mediadrmserver.rc took 0.00s.)
[16:42:19.467] [ 17.135501] init: (Parsing /system/etc/init/mediaextractor.rc took 0.00s.)
[16:42:19.467] [ 17.135993] init: (Parsing /system/etc/init/mediaserver.rc took 0.00s.)
[16:42:19.467] [ 17.136462] init: (Parsing /system/etc/init/mtpd.rc took 0.00s.)
[16:42:19.467] [ 17.136903] init: (Parsing /system/etc/init/netd.rc took 0.00s.)
[16:42:19.467] [ 17.137365] init: (Parsing /system/etc/init/racoon.rc took 0.00s.)
[16:42:19.467] [ 17.137751] init: ignored duplicate definition of service ‘ril-daemon’init: (Parsing /system/etc/init/rild.rc took 0.00s.)
[16:42:19.467] [ 17.138245] init: (Parsing /system/etc/init/servicemanager.rc took 0.00s.)
[16:42:19.467] [ 17.138636] init: (Parsing /system/etc/init/surfaceflinger.rc took 0.00s.)
[16:42:19.467] [ 17.139085] init: (Parsing /system/etc/init/uncrypt.rc took 0.00s.)
[16:42:19.467] [ 17.139485] init: (Parsing /system/etc/init/vdc.rc took 0.00s.)
[16:42:19.467] [ 17.139866] init: (Parsing /system/etc/init/vold.rc took 0.00s.)
[16:42:19.467] [ 17.142183] init: Starting service ‘logd’…
[16:42:19.467] [ 17.154931] init: insmod: open(“/system/lib/modules/ump.ko”) failed: No such file or directoryinit: insmod: open(“/system/lib/modules/mali.ko”) failed: No such file or directory
[16:42:19.531] [ 17.207948] logd.auditd: start
[16:42:19.531] [ 17.208021] logd.klogd: 17206519037
[16:42:19.531] [ 17.319538] midgard_kbase: disagrees about version of symbol module_layout
[16:42:19.646] [ 17.322086] init: finit_module for “/system/lib/modules/mali_kbase.ko” failed: Exec format errorinit: insmod: open(“/system/lib/modules/rk30_mirroring.ko”) failed: No such file or directoryinit: finit_module for “/system/lib/modules/rk29-ipp.ko” failed: Exec format errorinit: insmod: open(“/system/lib/modules/pvrsrvkm.ko”) failed: No such file or directoryinit: finit_module for “/drmboot.ko” failed: Exec format error
[16:42:19.646] [ 17.325438] zram0: detected capacity change from 0 to 533413888
[16:42:19.663] [ 17.361980] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
[16:42:19.685] [ 17.364818] init: property_set(“ro.board.platform”, “rk3399”) failed
[16:42:19.695] [ 17.366060] init: property_set(“ro.rk.screenoff_time”, “60000”) failed
[16:42:19.695] [ 17.366680] init: property_set(“ro.rk.screenshot_enable”, “true”) failed
[16:42:19.695] [ 17.366824] init: property_set(“ro.adb.secure”, “1”) failed
[16:42:19.695] [ 17.366967] init: property_set(“ro.sf.lcd_density”, “160”) failed
[16:42:19.695] [ 17.367241] init: (Loading properties from /system/build.prop took 0.00s.)
[16:42:19.695] [ 17.367507] init: (Loading properties from /vendor/build.prop took 0.00s.)
[16:42:19.695] [ 17.367691] init: (Loading properties from /factory/factory.prop took 0.00s.)
[16:42:19.695] [ 17.368374] init: /recovery not specified in fstab
[16:42:19.695] [ 17.370015] init: Starting service ‘debuggerd’…
[16:42:19.695] [ 17.371723] init: Starting service ‘debuggerd64’…
[16:42:19.695] [ 17.373645] init: Starting service ‘vold’…
[16:42:19.695] [ 17.380444] init: Not bootcharting.
[16:42:19.703]
[16:42:19.983] [ 17.659207] init: Starting service ‘exec 2 (/system/bin/tzdatacheck)’…
[16:42:19.983] [ 17.683460] init: Service ‘exec 2 (/system/bin/tzdatacheck)’ (pid 234) exited with status 0
[16:42:20.004] [ 17.718061] EXT4-fs (mmcblk0p16): Unrecognized mount option “background_gc=on” or missing value
[16:42:20.041] [ 17.732538] init: Starting service ‘logd-reinit’…
[16:42:20.056] [ 17.734787] init: write_file: Unable to open ‘/proc/sys/vm/min_free_order_shift’: No such file or directory
[16:42:20.065] [ 17.737088] init: Starting service ‘healthd’…
[16:42:20.065] [ 17.737776] init: cannot find ‘/system/bin/displayd’ (No such file or directory), disabling ‘displayd’
[16:42:20.065] [ 17.738340] init: Starting service ‘lmkd’…
[16:42:20.065] [ 17.746580] binder: 236:236 transaction failed 29189/-22, size 0-0 line 2948
[16:42:20.065] [ 17.739228] init: Starting service ‘servicemanager’…
[16:42:20.065] [ 17.740441] init: Starting service ‘surfaceflinger’…
[16:42:20.065] [ 17.741819] init: SELinux: Could not stat /sys/devices/system/cpu/cpufreq/interactive: No such file or directory.
[16:42:20.072] [ 17.746674] init: write_file: Unable to open ‘/proc/sys/vm/lazy_vfree_tlb_flush_all_threshold’: No such file or directory
[16:42:20.072] [ 17.763041] init: Starting service ‘fsud’…
[16:42:20.086] [ 17.763937] init: Starting service ‘vm_daemon’…
[16:42:20.086] [ 17.766061] init: cannot execve(’/system/xbin/vm’): Permission denied
[16:42:20.096] [ 17.767004] init: Service ‘vm_daemon’ (pid 241) exited with status 127
[16:42:20.096] [ 17.767745] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[16:42:20.096] [ 17.767795] init: write: cannot expand ‘${ro.serialno}’
[16:42:20.096] [ 17.772141] file system registered
[16:42:20.096] [ 17.776952] using random self ethernet address
[16:42:20.101] [ 17.776991] using random host ethernet address
[16:42:20.101] [ 17.777200] init: write_file: Unable to open ‘/config/usb_gadget/g1/functions/rndis.gs4/wceis’: Permission denied
[16:42:20.101] [ 17.801548] logd.daemon: reinit
[16:42:20.127] [ 17.803757] init: Service ‘logd-reinit’ (pid 235) exited with status 0
[16:42:20.127] [ 17.805129] init: Starting service ‘adbd’…
[16:42:20.127] [ 17.805996] init: cannot find ‘/system/bin/update_verifier’ (No such file or directory), disabling ‘exec 3 (/system/bin/update_verifier)’
[16:42:20.136] [ 17.806611] init: Starting service ‘ril-daemon’…
[16:42:20.136] [ 17.807220] init: cannot find ‘/system/bin/install-recovery.sh’ (No such file or directory), disabling ‘flash_recovery’
[16:42:20.136] [ 17.807654] init: Starting service ‘drmservice’…
[16:42:20.136] [ 17.808362] init: cannot find ‘/system/bin/bplus_helper’ (No such file or directory), disabling ‘bplus_helper’
[16:42:20.136] [ 17.808422] init: cannot find ‘/system/bin/busybox’ (No such file or directory), disabling ‘up_eth0’
[16:42:20.136] [ 17.808449] init: cannot find ‘/system/bin/rk_store_keybox’ (No such file or directory), disabling ‘rk_store_keybox’
[16:42:20.136] [ 17.808701] init: Starting service ‘akmd’…
[16:42:20.136] [ 17.809802] init: Starting service ‘zygote’…
[16:42:20.136] [ 17.810821] init: Starting service ‘zygote_secondary’…
[16:42:20.136] [ 17.812187] init: Starting service ‘audioserver’…
[16:42:20.136] [ 17.813243] init: Starting service ‘cameraserver’…
[16:42:20.136] [ 17.814497] init: Starting service ‘drm’…
[16:42:20.136] [ 17.814039] init: couldn’t write 250 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[16:42:20.136] [ 17.815701] init: Starting service ‘installd’…
[16:42:20.145] [ 17.817526] init: Starting service ‘keystore’…
[16:42:20.145] [ 17.818979] init: Starting service ‘mediacodec’…
[16:42:20.145] [ 17.820550] init: Starting service ‘mediadrm’…
[16:42:20.145] [ 17.822241] init: Starting service ‘mediaextractor’…
[16:42:20.145] [ 17.823519] init: Starting service ‘media’…
[16:42:20.145] [ 17.824710] init: Starting service ‘netd’…
[16:42:20.151] [ 17.826604] init: Starting service ‘gatekeeperd’…
[16:42:20.151] [ 17.843694] init: Service ‘akmd’ (pid 246) exited with status 254
[16:42:20.166] [ 18.155546] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.10 (r)
[16:42:20.485] [ 18.155626] ======== dhd_wlan_init_plat_data ========
[16:42:20.485] [ 18.155838] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[16:42:20.485] [ 18.156060] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=71, oob_irq_flags=0x414
[16:42:20.485] [ 18.156275] dhd_wlan_init_gpio: WL_REG_ON=-1
[16:42:20.485] [ 18.156494] dhd_wifi_platform_load: Enter
[16:42:20.485] [ 18.156730] Power-up adapter ‘DHD generic adapter’
[16:42:20.485] [ 18.158128] wifi_platform_set_power = 1
[16:42:20.485] [ 18.158334] ======== PULL WL_REG_ON(-1) HIGH! ========
[16:42:20.485] [ 18.158606] [WLAN_RFKILL]: rockchip_wifi_power: 1
[16:42:20.485] [ 18.158823] [WLAN_RFKILL]: wifi turn on power. -1
[16:42:20.485]
[16:42:20.607] [ 18.285907] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[16:42:20.607] [ 18.285998] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[16:42:20.616] [ 18.296169] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[16:42:20.623] [ 18.296191] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[16:42:20.623] [ 18.296199] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[16:42:20.623] [ 18.296205] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[16:42:20.623] [ 18.296210] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[16:42:20.623] [ 18.306979] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[16:42:20.632] [ 18.307067] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[16:42:20.632] [ 18.331911] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[16:42:20.655] [ 18.331994] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[16:42:20.655] [ 18.343978] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[16:42:20.666] [ 18.343995] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[16:42:20.666] [ 18.344002] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[16:42:20.671] [ 18.344008] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[16:42:20.671] [ 18.344013] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[16:42:20.671] [ 18.358277] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[16:42:20.682] [ 18.358391] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[16:42:20.682] [ 18.408818] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[16:42:20.731] [ 18.408984] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[16:42:20.731] [ 18.420087] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[16:42:20.755] [ 18.420202] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[16:42:20.755] [ 18.420406] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[16:42:20.755] [ 18.420420] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[16:42:20.755] [ 18.420428] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[16:42:20.755] [ 18.431261] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[16:42:20.755] [ 18.431346] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[16:42:20.755] [ 18.453899] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[16:42:20.776] [ 18.453987] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[16:42:20.781] [ 18.466367] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[16:42:20.795] [ 18.466384] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[16:42:20.795] [ 18.466391] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[16:42:20.795] [ 18.466398] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[16:42:20.795] [ 18.466403] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[16:42:20.795] [ 18.479523] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[16:42:20.803] [ 18.479644] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[16:42:20.795] [ 18.471616] wifi_platform_bus_enumerate device present 1
[16:42:20.795] [ 18.471648] ======== Card detection to detect SDIO card! ========
[16:42:20.795] [ 18.471656] mmc1:mmc host rescan start!
[16:42:20.803] [ 18.487817] bcmsdh_register: register client driver
[16:42:20.816] [ 18.488035] bcmsdh_sdmmc_probe: Enter num=1
[16:42:20.816] [ 18.489245] bcmsdh_sdmmc_probe: Enter num=2
[16:42:20.816] [ 18.489277] bus num (host idx)=1, slot num (rca)=1
[16:42:20.816] [ 18.489286] found adapter info ‘DHD generic adapter’
[16:42:20.816] [ 18.489367] sdioh_attach: set sd_f2_blocksize 256
[16:42:20.816] [ 18.489407] sdioh_attach: sd clock rate = 0
[16:42:20.816] [ 18.489603] dhdsdio_probe : no mutex held. set lock
[16:42:20.816] [ 18.489698] F1 signature read @0x18000000=0x15264345
[16:42:20.861] [ 18.547412] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[16:42:20.874] [ 18.547509] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[16:42:20.816] [ 18.494612] F1 signature OK, socitype:0x1 chip:0x4345 rev:0x6 pkg:0x2
[16:42:20.816] [ 18.495250] DHD: dongle ram size is set to 819200(orig 819200) at 0x198000
[16:42:20.816] [ 18.495350] dhd_conf_set_chiprev: chip=0x4345, chiprev=6
[16:42:20.826] [ 18.495651] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[16:42:20.826] [ 18.501015] CFG80211-ERROR) wl_init_prof : wl_init_prof: No profile
[16:42:20.826] [ 18.501284] wl_escan_attach: Enter
[16:42:20.826] [ 18.501332] wl_escan_init: Enter
[16:42:20.826] [ 18.501468] wl_create_event_handler(): thread:wl_escan_handler:148 started
[16:42:20.826] [ 18.501472] tsk Enter, tsk = 0xffffffc070ad01a0
[16:42:20.826] [ 18.501708] dhd_attach(): thread:dhd_watchdog_thread:149 started
[16:42:20.826] [ 18.502198] dhd_attach(): thread:dhd_dpc:14a started
[16:42:20.826] [ 18.502326] dhd_attach(): thread:dhd_rxf:14b started
[16:42:20.826] [ 18.502346] dhd_deferred_work_init: work queue initialized
[16:42:20.826] [ 18.502355] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 → mode 2
[16:42:20.826] [ 18.502398] dhd_bus_set_default_min_res_mask: Unhandled chip id
[16:42:20.836] [ 18.502935] sdioh_cis_read: func_cis_ptr[0]=0x10ac
[16:42:20.853] [ 18.536566] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[16:42:20.861] [ 18.536591] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[16:42:20.861] [ 18.536602] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[16:42:20.861] [ 18.536612] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[16:42:20.861] [ 18.536618] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[16:42:20.836] [ 18.510444] Dongle Host Driver, version 1.579.77.41.10 (r)
[16:42:20.836] [ 18.512033] wl_ext_iapsta_attach_netdev: ifidx=0, bssidx=0
[16:42:20.836] [ 18.512073] Register interface [wlan0] MAC: cc:4b:73:8a:41:3a
[16:42:20.836] [ 18.512165] dhd_tcpack_suppress_set: TCP ACK Suppress mode 2 → mode 0
[16:42:20.836] [ 18.512182] dhd_wl_ioctl: returning as busstate=0
[16:42:20.836] [ 18.512191] dhd_dbg_detach_pkt_monitor, 2204
[16:42:20.836] [ 18.512199] dhd_bus_devreset: == Power OFF ==
[16:42:20.836] [ 18.512428] bcmsdh_oob_intr_unregister: Enter
[16:42:20.842] [ 18.512442] bcmsdh_oob_intr_unregister: irq is not registered
[16:42:20.842] [ 18.512456] dhd_txglom_enable: enable 0
[16:42:20.842] [ 18.512463] dhd_conf_set_txglom_params: txglom_mode=copy
[16:42:20.842] [ 18.512470] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0
[16:42:20.842] [ 18.512476] dhd_conf_set_txglom_params: txinrx_thres=128, dhd_txminmax=-1
[16:42:20.842] [ 18.512482] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=-1
[16:42:20.842] [ 18.512488] dhd_bus_devreset: WLAN OFF DONE
[16:42:20.842] [ 18.512530] wifi_platform_set_power = 0
[16:42:20.842] [ 18.512538] ======== PULL WL_REG_ON(-1) LOW! ========
[16:42:20.842] [ 18.512546] [WLAN_RFKILL]: rockchip_wifi_power: 0
[16:42:20.842] [ 18.512567] [WLAN_RFKILL]: wifi shut off power.
[16:42:20.842] [ 18.512574] dhdsdio_probe : the lock is released.
[16:42:20.842] [ 18.512829] dhd_module_init: Exit err=0
[16:42:20.842] [ 18.525689] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[16:42:20.853] [ 18.525854] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[16:42:20.874] [ 18.557348] dhd_open: Enter ffffffc078085000
[16:42:20.883] [ 18.557389] dhd_open : no mutex held. set lock
[16:42:20.883] [ 18.557403]
[16:42:20.883] [ 18.557403] Dongle Host Driver, version 1.579.77.41.10 (r)
[16:42:20.883] [ 18.557413] wl_ext_iapsta_attach_netdev: ifidx=0, bssidx=0
[16:42:20.883] [ 18.557421] wl_android_wifi_on in 1
[16:42:20.883] [ 18.557428] wl_android_wifi_on in 2: g_wifi_on=0
[16:42:20.883] [ 18.557436] wifi_platform_set_power = 1
[16:42:20.883] [ 18.557456] ======== PULL WL_REG_ON(-1) HIGH! ========
[16:42:20.883] [ 18.557464] [WLAN_RFKILL]: rockchip_wifi_power: 1
[16:42:20.883] [ 18.557472] [WLAN_RFKILL]: wifi turn on power. -1
[16:42:20.883] [ 18.571315] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[16:42:20.894] [ 18.571429] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[16:42:20.894] [ 18.584602] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[16:42:20.906] [ 18.584622] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[16:42:20.906] [ 18.584633] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[16:42:20.911] [ 18.584642] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[16:42:20.911] [ 18.584649] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[16:42:20.911] [ 18.597480] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[16:42:20.923] [ 18.597586] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[16:42:20.923] [ 18.749464] healthd: BatteryCurrentNowPath not found
[16:42:21.072] [ 18.749512] healthd: BatteryCycleCountPath not found
[16:42:21.072]
[16:42:21.180] [ 18.858277] sdio_reset_comm():
[16:42:21.180] [ 18.871641] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[16:42:21.195] [ 18.889138] mmc_host mmc1: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[16:42:21.212] [ 18.935383] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[16:42:21.265] [ 18.938509] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[16:42:21.265] [ 18.941714] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[16:42:21.265] [ 18.947610] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[16:42:21.276] [ 18.954441] mmc1: queuing unknown CIS tuple 0x81 (9 bytes)
[16:42:21.276] [ 19.057584] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[16:42:21.380] [ 19.194548] init: Starting service ‘bootanim’…
[16:42:21.522]
[16:42:21.750] [ 19.412634] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 6
[16:42:21.750] [ 19.412733] sdioh_start: set sd_f2_blocksize 256
[16:42:21.750] [ 19.413113]
[16:42:21.750] [ 19.413113] dhd_bus_devreset: == WLAN ON ==
[16:42:21.750] [ 19.413213] F1 signature read @0x18000000=0x15264345
[16:42:21.754] [ 19.416727] F1 signature OK, socitype:0x1 chip:0x4345 rev:0x6 pkg:0x2
[16:42:21.754] [ 19.417272] DHD: dongle ram size is set to 819200(orig 819200) at 0x198000
[16:42:21.754] [ 19.417338] dhd_bus_set_default_min_res_mask: Unhandled chip id
[16:42:21.754] [ 19.441118] dhd_conf_read_config: Ignore config file /system/etc/firmware/config.txt
[16:42:21.766] [ 19.441185] Final fw_path=/system/etc/firmware/fw_bcm43455c0_ag.bin
[16:42:21.766] [ 19.441192] Final nv_path=/system/etc/firmware/nvram_ap6255.txt
[16:42:21.766] [ 19.441198] Final clm_path=/system/etc/firmware/clm.blob
[16:42:21.766] [ 19.441203] Final conf_path=/system/etc/firmware/config.txt
[16:42:21.766] [ 19.442040] dhd_os_open_image: /system/etc/firmware/fw_bcm43455c0_ag.bin (618288 bytes) open success
[16:42:21.766] [ 19.578351] dhd_os_open_image: /system/etc/firmware/nvram_ap6255.txt (1644 bytes) open success
[16:42:21.901] [ 19.587395] NVRAM version: AP6255_NVRAM_V1.0_29052015
[16:42:21.912] [ 19.588029] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[16:42:21.912] [ 19.670918] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[16:42:21.996] [ 19.671183] bcmsdh_oob_intr_register: HW_OOB irq=71 flags=0x4
[16:42:21.996] [ 19.671694] dhd_get_memdump_info: File [/data/misc/wifi/.memdump.info] doesn’t exist
[16:42:21.996] [ 19.671726] dhd_get_memdump_info: MEMDUMP ENABLED = 2
[16:42:21.996] [ 19.672426] Disable tdls_auto_op failed. -1
[16:42:21.996] [ 19.672452] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 → mode 1
[16:42:21.996] [ 19.672858] dhd_apply_default_clm: Ignore clm file /system/etc/firmware/clm.blob
[16:42:21.996] [ 19.674765] Firmware up: op_mode=0x0005, MAC=cc:4b:73:8a:41:3a
[16:42:22.001] [ 19.677780] dhd_preinit_ioctls Set scancache failed -23
[16:42:22.001] [ 19.685720] Driver: 1.579.77.41.10 (r)
[16:42:22.013] [ 19.685720] Firmware: wl0: Dec 28 2017 16:06:01 version 7.45.96.13 (4050a91@shgit) (r) FWID 01-477dd05 es7.c5.n4.a3
[16:42:22.013] [ 19.685720] CLM: 7.14.8
[16:42:22.013] [ 19.685968] dhd_txglom_enable: enable 1
[16:42:22.013] [ 19.685982] dhd_conf_set_txglom_params: txglom_mode=copy
[16:42:22.013] [ 19.685990] dhd_conf_set_txglom_params: txglomsize=36, deferred_tx_len=0
[16:42:22.013] [ 19.685997] dhd_conf_set_txglom_params: txinrx_thres=128, dhd_txminmax=-1
[16:42:22.013] [ 19.686004] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=-1
[16:42:22.013] [ 19.686017] dhd_conf_get_disable_proptx: fw_proptx=1, disable_proptx=-1
[16:42:22.013] [ 19.686700] dhd_wlfc_hostreorder_init(): successful bdcv2 tlv signaling, 64
[16:42:22.013] [ 19.688108] dhd_pno_init: Support Android Location Service
[16:42:22.013] [ 19.708572] CFG80211-ERROR) wl_cfg80211_event : Event handler is not created
[16:42:22.036] [ 19.709019] dhd_rtt_init : FTM is supported
[16:42:22.036] [ 19.709358] dhd_preinit_ioctls: SensorHub diabled 0
[16:42:22.036] [ 19.709877] dhd_preinit_ioctls failed to set ShubHub disable
[16:42:22.036] [ 19.711102] dhd_wl_ioctl_get_intiovar: get int iovar wnm_bsstrans_resp failed, ERR -23
[16:42:22.036] [ 19.711120] failed to get wnm_bsstrans_resp
[16:42:22.036] [ 19.711642] failed to set WNM capabilities
[16:42:22.036] [ 19.711917] CFG80211-ERROR) wl_cfg80211_event : Event handler is not created
[16:42:22.036] [ 19.711904] dhd_conf_set_country: set country CN, revision 38
[16:42:22.036] [ 19.714470] Country code: CN (CN/38)
[16:42:22.036] [ 19.716425] CONFIG-ERROR) dhd_conf_set_intiovar: txbf setting failed -23
[16:42:22.041] [ 19.716863] wl_android_wifi_on: Success
[16:42:22.041] [ 19.740584] dhd_open : the lock is released.
[16:42:22.066] [ 19.740622] dhd_open: Exit ret=0
[16:42:22.066] [ 19.745391] dhd_stop: Enter ffffffc078085000
[16:42:22.076] [ 19.747527] CFGP2P-ERROR) wl_cfgp2p_disable_discovery : do nothing, not initialized
[16:42:22.076] [ 19.747573] CFGP2P-ERROR) wl_cfgp2p_deinit_priv : In
[16:42:22.076] [ 19.749490] dhd_tcpack_suppress_set: TCP ACK Suppress mode 1 → mode 0
[16:42:22.076] [ 19.749524] wl_android_wifi_off in 1
[16:42:22.076] [ 19.749531] wl_android_wifi_off in 2: g_wifi_on=1, on_failure=1
[16:42:22.076] [ 19.749732] dhd_dbg_detach_pkt_monitor, 2204
[16:42:22.076] [ 19.749749] dhd_bus_devreset: == Power OFF ==
[16:42:22.076] [ 19.749924] bcmsdh_oob_intr_unregister: Enter
[16:42:22.076] [ 19.749960] dhd_txglom_enable: enable 0
[16:42:22.076] [ 19.749968] dhd_conf_set_txglom_params: txglom_mode=copy
[16:42:22.076] [ 19.749975] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0
[16:42:22.076] [ 19.749981] dhd_conf_set_txglom_params: txinrx_thres=128, dhd_txminmax=-1
[16:42:22.076] [ 19.749987] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=-1
[16:42:22.076] [ 19.750003] dhd_bus_devreset: WLAN OFF DONE
[16:42:22.076] [ 19.750050] wifi_platform_set_power = 0
[16:42:22.076] [ 19.750058] ======== PULL WL_REG_ON(-1) LOW! ========
[16:42:22.076] [ 19.750066] [WLAN_RFKILL]: rockchip_wifi_power: 0
[16:42:22.076] [ 19.750084] [WLAN_RFKILL]: wifi shut off power.
[16:42:22.076] [ 19.750090] wl_android_wifi_off out
[16:42:22.081] [ 19.750097] wl_ext_iapsta_dettach_netdev: ifidx=0
[16:42:22.081] [ 19.750127] dhd_stop: Exit
[16:42:22.081]
[16:42:22.280] [ 19.957509] init: Service ‘drmservice’ (pid 245) exited with status 0
[16:42:22.280] [ 20.023654] read descriptors
[16:42:22.346] [ 20.023705] read strings
[16:42:53.830] [ 51.506588] capability: warning: `main’ uses 32-bit capabilities (legacy support in use)
[16:42:22.346]
[18:23:01.746] [ 114.991521] binder_alloc: 567: binder_alloc_buf, no vma
[18:23:01.746] [ 114.991612] binder: 240:302 transaction failed 29189/-3, size 68-0 line 3071
[18:23:01.756] [ 115.201073] init: Service ‘zygote’ (pid 248) killed by signal 9
[18:23:01.957] [ 115.201140] init: Service ‘zygote’ (pid 248) killing any children in process group
[18:23:01.957] [ 115.201327] init: write_file: Unable to open ‘/sys/android_power/request_state’: No such file or directory
[18:23:01.957] [ 115.201462] init: write_file: Unable to write to ‘/sys/power/state’: Invalid argument
[18:23:01.966] [ 115.201595] init: Service ‘audioserver’ is being killed…
[18:23:01.966] [ 115.201847] init: Service ‘cameraserver’ is being killed…
[18:23:01.966] [ 115.201992] init: Service ‘media’ is being killed…
[18:23:01.966] [ 115.202120] init: Service ‘netd’ is being killed…
[18:23:01.966] [ 115.204022] init: Starting service ‘zygote’…
[18:23:01.966] [ 115.206625] init: Service ‘cameraserver’ (pid 251) killed by signal 9
[18:23:01.966] [ 115.206690] init: Service ‘cameraserver’ (pid 251) killing any children in process group
[18:23:01.966] [ 115.207371] init: Starting service ‘cameraserver’…
[18:23:01.966] [ 115.211130] init: couldn’t write 898 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[18:23:01.966] [ 115.211466] init: Service ‘audioserver’ (pid 250) killed by signal 9
[18:23:01.966] [ 115.211610] init: Service ‘audioserver’ (pid 250) killing any children in process group
[18:23:01.966] [ 115.212473] init: Service ‘netd’ (pid 259) killed by signal 9
[18:23:01.966] [ 115.212552] init: Service ‘netd’ (pid 259) killing any children in process group
[18:23:01.975] [ 115.213352] init: Service ‘media’ (pid 258) killed by signal 9
[18:23:01.975] [ 115.213424] init: Service ‘media’ (pid 258) killing any children in process group
[18:23:01.975] [ 115.214381] init: Starting service ‘audioserver’…
[18:23:01.975] [ 115.215738] init: Starting service ‘media’…
[18:23:01.975] [ 115.216640] init: Starting service ‘netd’…
[18:23:01.975] [ 115.460413] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[18:23:02.217] [ 115.460506] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[18:23:02.217] [ 115.470333] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[18:23:02.237] [ 115.470345] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[18:23:02.237] [ 115.470353] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[18:23:02.237] [ 115.470358] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[18:23:02.237] [ 115.470363] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[18:23:02.237] [ 115.481056] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[18:23:02.237] [ 115.481146] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[18:23:02.248]
[18:23:02.260] [ 115.504345] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[18:23:02.260] [ 115.504432] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[18:23:02.260] [ 115.516332] rockchip-pinctrl pinctrl: pin gpio2-11 already requested by ff910000.isp; cannot claim for ff920000.isp
[18:23:02.285] [ 115.516345] rockchip-pinctrl pinctrl: pin-75 (ff920000.isp) status -22
[18:23:02.285] [ 115.516352] rockchip-pinctrl pinctrl: could not request pin 75 (gpio2-11) from group cif-clkout on device rockchip-pinctrl
[18:23:02.285] [ 115.516358] RockChip-CamSys ff920000.isp: Error applying setting, reverse things back
[18:23:02.285] [ 115.516363] E:camsys_mrv_iomux_cb(126): pinctrl_select_state failed!
[18:23:02.285] [ 115.529072] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
[18:23:02.285] [ 115.529157] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[18:23:02.285] [ 115.609883] E:camsys_i2c_write(84): i2c write dev(addr:0x20) failed!,err = -6
[18:23:02.366] [ 115.609988] E:camsys_i2c_write(84): i2c write dev(addr:0x6c) failed!,err = -6
该问题已解决,根据串口log 无法定位问题,可根据kernel . logcat日志进行进一步增加权限。
大佬你好 请问这个问题具体是如何解决的,我现在机器也是起不来,log信息和你的差不多,都是zygote核心进程莫名被kill,能否指导一下,谢谢!
我也遇到同样的问题,log和你的一样,这是怎么解决的?望不吝赐教,谢谢!
666
